Standard Interlock Safety Switches
HS5D
Key features:
• Detects detachment of head for enhanced safety
• Compact dimensions with up to three contacts
• The head orientation can be rotated, allowing 8 different actuator entries
• NC contacts with direct opening action (IEC/EN60947-5-1)
• M3 terminal screws for easy wiring
• Gold-plated contacts suitable for small loads
XW Series E-Stops
Overview
HS5D Miniature Interlock Switches
Part Numbers
Actuator Keys (order separately)
Interlock Switches
Contact Configuration
1NC-1NO
Main Circuit
Monitor Circuit
11
23
2NC
Main Circuit
Monitor Circuit
11
Enabling Switches
11
21
33
3NC
Main Circuit
Main Circuit
Monitor Circuit
12
24
Zb
21
2NC-1NO
Main Circuit
Main Circuit
Monitor Circuit
Zb
11
21
31
12
22
Zb
Zb
12
22
34
12
22
32
Gland Port
Size
Plastic Head
Type
Metal Head
Type
G1/2
HS5D-11RN
HS5D-11ZRN
PG13.5
HS5D-11RNP
HS5D-11ZRNP
M20
HS5D-11RNM
HS5D-11ZRNM
G1/2
HS5D-02RN
HS5D-02ZRN
PG13.5
HS5D-02RNP
HS5D-02ZRNP
M20
HS5D-02RNM
HS5D-02ZRNM
G1/2
HS5D-12RN
HS5D-12ZRN
PG13.5
HS5D-12RNP
HS5D-12ZRNP
M20
HS5D-12RNM
HS5D-12ZRNM
G1/2
HS5D-03RN
HS5D-03ZRN
PG13.5
HS5D-03RNP
HS5D-03ZRNP
M20
HS5D-03RNM
HS5D-03ZRNM
Item
Part Number
Description
HS9Z-A51
Straight
HS9Z-A51A
Straight w/rubber bushings
HS9Z-A52
Right-angle
HS9Z-A52A
Right-angle w/rubber bushings
HS9Z-A55
Angle Adjustable (vertical/horizontal)
HS9Z-A5P
Plug Actuator
HS9Z-SH5
Sliding Actuator
HS9Z-PH5
Padlock Hasp
Parts Description
Right-angle Actuator
(SUS304)
M3 Terminal Screw
Angle
Adjustable
Actuator
(for hinged doors)
Straight Actuator
w/rubber bushing
Actuators are not included and must be ordered separately.
Straight Actuator
(SUS304)
Gland Port
(Use conduits or cable glands
which can maintain
IP67 protection.)
w/rubber bushing
AS-Interface Safety at Work
Light Curtains
Safety Control Relays
Standard stock items in bold.
276
www.IDEC.com
Contact Configuration & Operation Chart
Contact
Configuration
Contact
Configuration
Terminal Arrangement
Contact
Operation
Chart
(reference)
Contact
Operation
Chart
(reference)
0 (Actuator Mounting Reference Position)
Approx. Reference
Approx. Position)
4.6 Approx.
6.7
Approx.
4.6
6.7
HS5D-11*
HS5D-11*
HS5D-12*
HS5D-12*
HS5D-03*
HS5D-03*
11
11
12
12
23
23
24
24
11
11
12
12
21
21
22
22
11
11
21
21
33
33
11
11
21
21
12
12
22
22
34
34
12
12
22
22
11-12
11-12
23-24
23-24
11-12
11-12
Approx. 26.4
(Travel:
Approx. mm)
26.4
(Travel: mm)
: Contact ON
(closed)
: Contact ON
(closed)OFF
: Contact
(open) OFF
: Contact
(open)
Main Circuit: 11-12
Main Circuit: 21-22
Monitor Circuit: 31-32 / Monitor Circuit: 33-34
XW Series E-Stops
HS5D-02*
HS5D-02*
Main Circuit
Main Circuit
Monitor Circuit
Monitor Circuit
Main Circuit
Main Circuit
Main Circuit
Main Circuit
Main Circuit
Main Circuit
Main Circuit
Main Circuit
Monitor Circuit
Monitor Circuit
Main Circuit
Main Circuit
Main Circuit
Main Circuit
Monitor Circuit
Monitor Circuit
Overview
Type Type
HS5D
21-22
21-22
11-12
11-12
21-22
21-22
33-34
33-34
11 -12
11 -12
21-22
21-22
31-32
31-32
Interlock Switches
Actuator removed
completely
Actuator removed
completely
Actuator inserted
completely
Actuator inserted
completely
The operation characteristics shown in the chart above are for the HS9Z-A51. For other actuator types, add 1.3 mm.
The operation characteristics show the contact status when the actuator enters the entry slot of an interlock switch
Specifications
ISO14119, EN1088, IEC60947-5-1, EN60947-5-1 (TÜV approval), GS-ET-15 (TÜV approval), UL508, CSA C22.2
No. 14, GB14048.5 (CCC approval), IEC60204-1/EN60204-1 (applicable standards for use)
Operating Temperature
–30 to +70°C (no freezing)
Relative Humidity
45 to 85% (no condensation)
Storage Temperature
–40 to +80°C (no freezing)
Pollution Degree
3
Impulse Withstand
Voltage
4 kV
50 mΩ maximum (initial value)
Insulation Resistance
(500V DC megger)
Between live and dead metal parts: 100 MΩ minimum
Between terminals of different poles: 100 MΩ minimum
Electric Shock
Protection Class
Class II (IEC61140)
IP67 (IEC60529)
Shock Resistance
Damage limits: 1000 m/s2
Vibration Resistance
Operating extremes: 10 to 55 Hz, amplitude 0.5 mm
Damage limits: 30 Hz, amplitude 1.5 mm
Actuator Operating
Speed
0.05 to 1.0 m/s
Direct Opening Travel
10 mm minimum
Direct Opening Force
50N minimum
Operating Frequency
900 operations per hour
1,000,000 operations minimum (GS-ET-15)
Electrical Durability
100,000 operations minimum
(AC-12 250V, 6A)
(24V AC/DC,100 mA)
(operation frequency: 900 operations per hour)
Performance of
Terminals 11-12 of
Removed Head Unit
Mechanical damage limits: 10 operations min.
Insulation resistance:
100 MΩ (initial value)
Dielectric strength:
1000V, 1 minute (initial value)
Conditional
Short-circuit Current
100A (250V) (note)
Weight (approx.)
Plastic head:
Metal head:
Mechanical Durability
Light Curtains
Degree of Protection
Contact Resistance
Enabling Switches
Applicable Standards
80g
110g
800-262-IDEC (4332) • USA & Canada
277
HS5D
Overview
Contact Ratings
Operating Voltage (Ue)
AC
Rated Operating Current (Ie)
30V
125V
250V
2.5A
1.5A
Inductive load (AC-15)
1.5A
0.75A
Resistive load (DC-12)
2.5A
1.1A
0.55A
(1A)
(0.22A)
(0.1A)
Resistive load (AC-12)
DC
Recommended Screw Torque
• Safety switch body installation (M4 screw): 1.0~1.5N-m
• Actuator installation (M4 screw): 1.0~1.5N-m
Gland
um
nim ius
Mi ad
R
mm
40
(100)
XW Series E-Stops
Installation Notes
1
Gland Port
91
HS5D-ZRN (Metal Head)
With HS9Z-A51 Straight Actuator
RP: Reference mounting position.
Plastic (red) Plastic (gray)
Actuator
Actuator
Actuator Stop
Actuator Stop
11
2020
3030
36.2
36.2
91
91
6 ±1
6 ±1
1515
2424
3030
20 to 22
20 to 22
2-M4 Screws
2-M4 Screws
Gland Port
Gland Port
11
2020
2828
11
2020
3030
36
36
5.2
5.2
11
91
91
1515
2424
3030
Slot Plug (supplied)
Slot Plug
(supplied)
(Note)
(Note)
36.2
36.2
6 ±1
6 ±1
Actuator
Actuator
Actuator
Stop
Actuator Stop
Gland Port
Gland Port
Metal Head Cover
Metal Head Cover
RP
RP 26.4
26.4
6.2
6.2
R2R2
.2.2
R2R2
.2.2
Metal Head Cover
Metal Head Cover
RP
26.4 RP 42.2
26.4
42.2
5.2
6.2
5.2
6.2
2828
2020
Enabling Switches
15
24
30
36.2
1
Interlock Switches
R2
.2
Dimensions and Mounting Hole Layouts
With HS9Z-A52 Right-angle Actuator
2020
3030
36.2
36.2
91
91
1515
2424
3030
7.6 ±1
7.6 ±1
11
2020
3030
20 to 22
20 to 22
2-M4 Screws
2-M4 Screws
Actuator
Actuator
Actuator
Cover
Actuator Cover
Actuator Stop
Actuator Stop
Gland Port
Gland Port
11
R2R2
.2.2
Metal Head Cover Plastic (red) Plastic (gray)
11
11
91
91
1515
2424
3030
Slot Plug
(supplied)
(Note)
(Note)
36.2
36.2
±1±1
7.6
7.6
Actuator Cover
ActuatorActuator
Cover
Actuator
Actuator Stop
Actuator Stop
Gland Port
Gland Port
RP
35.3 RP 27.7
35.3
27.7
2020
3030
R2R2
.2.2
2020
3030
Light Curtains
Metal Head Cover
Metal Head Cover
RP
27.7 RP 41.5
27.7
41.5
All dimensions in mm.
Gland Port
Gland Port
11
11
www.IDEC.com
Plastic (gray)
Plastic (gray)
Plastic Head (red)
Plastic Head (red)
RP
RP 26.4
26.4
6.2
6.2
R2R2
.2.2
Gland Port
Gland Port
36
36
5.2
5.2
8
Plastic (gray)
Plastic (gray)
R2R2
.2.2
Plastic Head (red)
Plastic Head (red)
RP
26.4 RP 42.2
26.4
42.2
6.2
5.2
6.2
5.2
1515
2424
3030
1515
2424
3030
2-M4 Screws
7.6
7.6±1
(Note)
(Note)
HS5D
6±1
6±1
20 to 22
20 to 22
2-M4 Screws
2-M4 Screws
1515
2424
3030
(Note)
(Note)
11
2020
3030
Actuator
Actuator
Actuator Stop
Actuator Stop
36.2
36.2
91
91
6 ±1
6 ±1
11
91
91
1515
2424
3030
36.2
36.2
Gland Port
Gland Port
XW Series E-Stops
Actuator
Actuator
Actuator Stop
Actuator Stop
2020
2828
11
2020
3030
36
36
5.2
5.2
11
2828
2020
Gland Port
Gland Port
Plastic (gray)
Plastic (gray)
Plastic Head (red)
Plastic Head (red)
RP
RP 26.4
26.4
6.2
6.2
R2R2
.2.2
Plastic (gray)
Plastic (gray)
R2R2
.2.2
Plastic Head (red)
Plastic Head (red)
RP
26.4 RP 42.2
26.4
42.2
6.2
5.2
6.2
5.2
Overview
HS5D-RN (Plastic Head)
20 to 22
20 to 22
2-M4 Screws
2-M4 Screws
2020
3030
7.6 ±1
7.6 ±1
91
91
11
36.2
36.2
1515
2424
3030
Actuator
Actuator
Actuator Cover
Actuator Cover
Actuator Stop
Actuator Stop
Gland Port
Gland Port
11
R2R2
.2.2
2020
3030
2020
3030
7.6
7.6±1±1
Plastic (gray)
Plastic (gray)
Note: Plug the unused actuator insertion slot using the slot plug supplied with the safety interlock switch.
Enabling Switches
(Note)
(Note)
91
91
11
36.2
36.2
Actuator Cover
Actuator Cover
Actuator
Actuator
Actuator Stop
Actuator Stop
Plastic Head (red)
Plastic Head (red)
RP
35.3 RP 27.7
35.3
27.7
11
Gland Port
Gland Port
1515
2424
3030
3030
2020
R2R2
.2.2
Plastic (gray)
Plastic (gray)
Interlock Switches
Plastic Head (red)
Plastic Head (red)
RP
27.7 RP 41.5
27.7
41.5
Light Curtains
279
(5)
Actuator Cover
20º
23
26
38
2-M4 Screw
1
29
Vertical Swing
Orienting
Insert
Rubber Bushing
12∗
(20)
15
12
(M4 R2.1
Hole
s)
3.6
As shown in the figure below, the mounting reference position of the actuator when
inserted in the interlock switch is where the actuator stop placed on the actuator lightly
touches the interlock switch.
Actuator Stop
(Note)
Note: After mounting the actuator, remove the actuator stop from the actuator.
Door Stop
0.8
Angle Adjustment
(M3 Hexagon Socket Head Screw)
2
Actuator Stop
HS9Z-A51 Actuator
Door Stop
Interlock Switch
Interlock Switch
Actuator
Stop
Actuator Stop
Actuator
Cover
HS9Z-A52 Actuator
HS9Z-A55 Actuator
20º
Actuator Stop (Note)
*Mounting centers can be widened to 20 mm by moving the rubber cushions.
Interlock Switch
Actuator Mounting Hole Layout
(Straight, Right-angle)
2-M4 Screw
38
Note: The actuator stop is supplied with the actuator and used when adjusting the actuator position.
Remove the actuator stop after the actuator position is determined.
Actuator Orientation (Angle Adjustable)
The angle of actuator swing can be changed using the orienting insert (white plastic) installed on the back of the actuator. Do not lose the orienting insert, otherwise the actuator will
not operate properly.
Light Curtains
B
(Straight w/rubber bushing)
(Right-angle w/rubber bushing)
Actuator Stop
(Note)
7
18.5
15
0.8
The mounting center distance is set to 12 mm at factory. When 20-mm distance is required, adjust the
distance by moving the rubber bushings.
A B : The actuator has flexibility to the directions indicated by the arrows. When 20-mm distance
is selected, the actuator swings vertically.
Angle Adjustment
3
Orienting
Insert
(5)
A
Washer (supplied
with the actuator)
Rubber Bushing
15.8
8.5
2
10
2-ø9
Angle Adjustable (HS9Z-A55)
Horizontal Swing
30
Actuator Stop
(Note)
Washer (supplied with the actuator)
2-ø10
(39.7)
0.8
(11.2)
.3
43.8
0.8
2ø4
1.6
2
2
15.3
2
2-
7.3
4.3
2-ø
15
ø4
.4
49
Enabling Switches
0.8
7.2
2-ø10
R
4Actuator
Stop (Note)
2-M4 Screw
2-M4 Screw
Interlock Switches
30
28
4.5
6.4
7.2
2-ø9
6.4
33
(HS9Z-A52A)
2
2
2.
2
(HS9Z-A51A)
0.8
2
2.
10
XW Series E-Stops
R
4-
32.4
(6) 32.4
0.8 (6)
5.2
0.8
6.2
28
Right-angle (HS9Z-A52)
15
26
15
26
6.2
28
Overview
Actuator Dimensions
Straight (HS9Z-A51)
30
(20)
12∗
HS5D
280
www.IDEC.com
HS5D
Minimum Radius of Hinged Door
When using the HS9Z-A55 Angle Adjustable Actuator
• When the door hinge is on the extension line of the interlock switch surface:
Horizontal Swing
Note: Because deviation or dislocation of hinged door may occur in actual applications, make sure of
the correct operation before installation.
HS9Z-A52 Actuator
M
im
u
50 m R
m ad
m iu
Vertical Swing
Door Hinge
M
in
s
im
u
50 m R
m ad
m iu
Door Hinge
m
imu
Min dius
Ra mm
190
um
nim
Mi dius
Ra 0 mm
17
XW Series E-Stops
in
Door Hinge
Overview
• When using the interlock switch for a hinged door, refer to the minimum
radius of doors shown below. For the doors with small minimum radius, use
angle adjustable actuators (HS9Z-A55).
s
• When the door hinge is on extension line of the actuator mounting surface:
Door Hinge
Horizontal Swing
Vertical Swing
M
M
in
in
Door Hinge
s
Door Hinge
im
u
50 m R
m ad
m iu
s
Door Hinge
Actuator Angle Adjustment for the HS9Z-A55
s
diu
Ra
m
imu mm
Min 260
s
diu
Ra
um m
nim 30 m
2
Mi
Door Hinge
im
u
70 m R
m ad
m iu
Interlock Switches
• When the door hinge is on the extension line of the actuator mounting
surface:
Enabling Switches
• Using the angle adjustment screw, the actuator angle can be adjusted (see
figures “Actuator Dimensions” on page 13). Adjustable angle: 0 to 20°
• The larger the adjusted angle of the actuator, the smaller the applicable
radius of the door opening. After installing the actuator, open the door. Then
adjust the actuator so that its edge can be inserted properly into the actuator
entry slot of the interlock switch.
• After adjusting the actuator angle, apply Loctite to the adjustment screw so
that the screw will not loosen.
Instructions
Head Removal Detection Function
• The head of the HS5D can be rotated by removing the four screws from the
corners of the HS5D head and reinstalling the head in the desired orientation. When reinstalling the head, make sure that no foreign object enters the
interlock switch. Tighten the screws tightly, because loose tightening may
cause malfunction.
Only the NC contact of the main circuit (11-12) turns OFF (open) when the head
is removed, such as when rotating the head. Because NC contacts of other than
the main circuit (11-12) turn ON (closed), be sure to connect the main circuit
(11-12) to the safety circuit.
• Recommended screw tightening torque: 0.9 to 1.1 N·m
Factory Setting
Alternative Head Orientations
Recommended Tightening Torque
Rotating the Head
• Interlock Switch Mounting Screw:
281
Light Curtains
1.8 ± 2.2 N·m
(two M4 screws)
• Housing Lid Screw: 0.2 to 0.4 N·m (M3 screw)
• Terminal Screw:
0.6 to 0.8 N·m (M3 screw)
• Connector:
2.7 to 3.3 N·m
• Actuators
HS9Z-A51:
1.8 ± 2.2 N·m (two M4 screws)
HS9Z-A52:
0.8 ± 1.2 N·m (two M4 Phillips screws)
HS9Z-A51A/A52A: 1.0 to 1.5 N·m (two M4 screws)
HS9Z-A55:
• The above recommended tightening torques of the mounting screws are the values
confirmed with hex socket head bolts. When other screws are used and tightened to a
smaller torque, make sure that the screws do not come loose after mounting.
• Mounting bolts must be provided by the user.
• To avoid unauthorized or unintended removal of the interlock switch and the actuator, it
is recommended that the interlock switch and the actuator be installed in an unremovable manner, for example using special screws or welding the screws.
Applicable Crimping Terminal
Applicable Wire Size
When using crimping terminals, be sure to install insulation tubes on the crimping terminals to prevent electric shocks. When using stranded wires, make sure
that loose wires do not cause short circuit. Also do not solder the terminal to
prevent loose wires.
0.5 to 1.5 mm2 (16 ~ 20 AWG)
Applicable Cable Glands
Use a cable gland with a degree of protection IP67.
17.4max.
A
ø3.2
G1/2, PG13.5, M20
6.4 max.
XW Series E-Stops
4.2 to 5.8
9 max.
Applicable wire size (with insulation tube): 0.2 to 0.5 mm2 (20 ~ 24 AWG)
Note: Do not remove screw A during wiring. Removing the screw may cause malfunction or damage.
Light Curtains
Enabling Switches
Interlock Switches
282
www.IDEC.com
30 max.
Overview
HS5D
很抱歉,暂时无法提供与“HS5D-12RN”相匹配的价格&库存,您可以联系我们找货
