HW9Z-CZ1
HW9Z-CZ1
    IDEC(日本和泉)
    IDEC - HW9Z-CZ1 - Rubber Boot, 22 mm Illuminated Buzzer, Nitrile Rubber, HW9Z Series
HW9Z-CZ1 数据手册
ø22mm HW1Z Illuminated Buzzer Optimal illuminated buzzer for elevators and production sites ■ Combination buzzer and pilot light ■ Alerts workers of danger with sound and light ■ Waterproof construction HW1Z Illuminated Buzzer Complies with the new EU elevator safety standard EN81-1/2, the safety rules for the construction and installation of lifts (electric and hydraulic) were revised to EN81-20/50 in July 2014 (effective in September 2017). As GB and JIS standards will follow suit, the requirements in the new rules must be taken into consideration when designing elevators. EN81-20 (5.12.1.8.3 g) An audible signal at the car and a flashing light under the car shall be activated during movement. The sound level of the audible warning shall be minimum 55 dB(A) below the car at 1 m distance. Can be used in semi-outdoor applications With waterproof and dustproof construction, HW1Z can be used in semi-outdoor applications such as elevators exposed to rain and dust. Meets waterproof requirements for fireman’s elevator HW1Z’s IPX3 waterproof characteristics can be used in emergency situations exposed to water. HW1Z Illuminated Buzzer Buzzer/lamp in one can be installed easy and quick Easy wiring and tight installation places Wiring is accomplished with push-in terminals. No tightening of screw is required. Short, 19.7 mm depth behind panel. Can be installed in tight places. 19.7 mm Lamp and buzzer functions are integrated. Flashing light Waterproof construction Panel front: IP65 waterproof Buzzer sound Installing an optional terminal rubber boot upgrades the terminal’s waterproof characteristics to IP54 without the need to use a rear enclosure. HW1Z Illuminated Buzzer —Other Applications— Automatic Storage 01 Flashing lights and buzzer sounds alert workers of fast-moving parts in automatic storages. Production Lines 02 Installed in areas where robots operate, HW1Z alerts workers when they enter potentially hazardous locations. AGV 03 Control Station 04 HW1Z can be used to alert workers of AGV movement. Also suitable for applications where multiple buzzers are required, such as in a control station. ø22mm HW1Z Illuminated Buzzer Model Shape HW1Z Part No. Illumination Color HW1Z-P1F2PQ4R Red HW1Z-P1F2PQ4Y Yellow Accessories Shape Terminal Rubber Boot Material Part No. Package Quantity Nitryl Rubber HW9Z-CZ1 1 Notes Applicable cable: ø4.5 to 8.5 mm Cut the end of rubber boot to fit the cable size (see dimensions). Weight: 10 g (approx.) Specifications Rated Insulation Voltage Rated Voltage Voltage Range Rated Current (effective value) Inrush Current Sound Pressure (of HW1Z itself) (at 25ºC) Sound Frequency (at 25ºC) Sound Type Intermittent Cycle (at 25ºC) Illumination Type Illumination Flash Cycle (at 25ºC) Buzzer Operating Temperature Operating Humidity Storage Temperature Insulation Resistance Dielectric Strength 30V 12 to 24V DC 10.8 to 26.4V DC 18mA (24V DC), 8mA (12V DC) 100mA maximum 90dB min. at 0.1m (24VDC) 70dB min. at 1m (24V DC, equivalent value) 84dB min. at 0.1m (12V DC) 64dB min. at 1m (12VDC, equivalent value) –20 to +50ºC (no freezing) 20% to 85% RH (no condensation) –30 to +80ºC (no freezing) 100MΩ minimum (at 500V DC megger) Between live and earthed metal parts: 1000V AC, 1 minute Operation extremes: 5 to 55Hz, amplitude 0.5mm Vibration Resistance Damage limits: 5 to 55Hz, amplitude 0.5mm Operation extremes: 100 m/s2 Shock Resistance Damage limits: 1,000 m/s2 Panel front: IP65 (IEC 60529) Degree of Protection Terminal: IP40 (IEC 60529) IP54 (with terminal rubber boot) (IEC 60529) Terminal Style Push-in Terminals Solid wire/ferrule (without sleeve): 0.2 to 1.5 mm2 Applicable Wire Ferrule (with sleeve): 0.2 to 0.75 mm2 Weight (approx.) 17g 2,200 to 2,450Hz Intermittent sound 105 cycles/minute approx. (1.75Hz approx.) Flashing 105 cycles/minute approx. (1.75Hz approx.) Applicable Standards UL508 File No.E68961 EN60947-5-1 EMC Directive Dimensions Cut here when cable size is ø5.5 to 6.5 (*1) Cut here when cable size is ø6.5 to 7.5 (*1) Cut here when cable size is ø7.5 to 8.5 (*1) 3 Panel Thickness 0.8 to 6 mm 45° 0.5 17.6 Bellows (*2) 17 to 22 x. (* ma 19.7 ø3 ø3 0 3. Rubber Gasket Locking Ring All dimensinos in mm. With terminal rubber boot 3) 54 to 59 58 to 63 62 to 67 66 to 71 Terminal Arrangement (botom view) Mounting Hole Layout +0 0 .4 2. 3 ø2 ax. 8m R0. 24.1 +0.4 0 ∗ 3.2 +0.2 0 X2 X1 X1 and X2 have no polarity. *1: ø4.5-5.5 cable needs no cutting. *2: The bellows must be 17 to 22mm long after installing the terminal rubber boot. *3: Maintain a cable angle of 45° max. to the HW1Z axis. Panel cut-out ∗ +0.2 3.2 0 hole is for anti-rotation. Not required when nameplate/anti-rotation is not used. ø22mm HW1Z Illuminated Buzzer Safety Precautions • Turn off the power to the HW1Z before installation, removal, wiring, maintenance, and inspection. Failure to turn power off may cause electrical shocks or fire hazard. • For wiring, use wires of a proper gauge to meet the voltage and current requirements. • Prevent metal fragments and pieces of wire from dropping inside when installing or wiring the HW1Z. Otherwise fire, failure, or malfunction may be caused. Operating Instructions Panel Mounting 4. Install the terminal rubber boot as shown below. • Insert the HW1Z into the panel cut-out from the front, and tighten the locking ring from the back. Panel Note for panel mounting • Use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring to a recommended tightening torque of 1.5 to 2.0 N·m. • Do not use pliers and do not tighten excessively, otherwise the HW1Z may be damaged. Locking Ring 5. Cover part B with part A. Wiring Part B • When using solid wire, strip the wire insulation 8 mm from the end. When using stranded wire, clamp a ferrule and insert into the terminal, and make sure that the wire does not loosen. Recommended Ferrules Installed (terminal rubber boot: cross section view) Part A 6. Make sure that the bellows is 17 to 22 mm long. Phoenix Contact Without sleeve For 0.5mm2: A0,5-8 For 0.75mm2: A0,75-8 For 1.0mm2: A1-8 With sleeve For 0.25mm2: AI0,25-8YE For 0.5mm2: AI0,5-8WH For 0.75mm2: AI0,75-8GY Wire removal Wire Removal Part (white) Push in the white wire removal part above the wire ports using a small flat screw driver, and pull out the wire. Note for wiring Bellows Note for terminal rubber boot • After installing the terminal rubber boot, make sure that the bellows is 17 to 22 mm long. Waterproof characteristics cannot be achieved with longer bellows. • Maintain a cable angle of 45° maximum to the axis of the HW1Z, otherwise the terminal rubber boot may come off. Make sure that the terminal is not constantly pulled by the wire. Wiring must be performed in environments of –5 to +50°C.     Installing the terminal rubber boot 1. Cut the end of terminal rubber boot to fit the cable size. 2. Insert the cable into the terminal rubber boot in the direction of arrow shown below. Cut here when cable size is ø5.5 to 6.5 mm Cut here when cable size is ø6.5 to 7.5 mm Cut here when cable size is ø7.5 to 8.5 mm 45° Bent excessively Operating Conditions Do not use the HW1Z in the following locations. • Exposed to direct sunlight • Subject to corrosive or flammable gases Cable insertion 3. Strip the sheath of the cable 30 mm from the end. Solid wire: strip each wire 8 mm from the end Stranded wire: clamp the ferrule Insert the cable into the terminal. www.idec.com Head Office 6-64, Nishi-Miyahara-2-Chome, Yodogawa-ku, Osaka 532-0004, Japan USA Germany Singapore Thailand Australia Taiwan IDEC Corporation IDEC Elekrotechnik GmbH IDEC Izumi Asia Pte. Ltd. IDEC Asia (Thailand) Co., Ltd IDEC Australia Pty. Ltd. IDEC Taiwan Corporation Tel: +1-408-747-0550 Tel: +49-40-25 30 54 - 0 Tel: +65-6746-1155 Tel: +66-2-392-9765 Tel: +61-3-8523-5900 Tel: +886-2-2698-3929 opencontact@idec.com service@eu.idec.com info@sg.idec.com sales@th.idec.com sales@au.idec.com service@tw.idec.com Specifications and other descriptions in this brochure are subject to change without notice. 2017 IDEC Corporation, All Rights Reserved. EP1616-1 DECEMBER 2017 Hong Kong China/Shanghai China/Shenzhen China/Beijing Japan IDEC Izumi (H.K.) Co., Ltd. IDEC (Shanghai) Corporation IDEC (Shenzhen) Corporation IDEC (Beijing) Corporation IDEC Corporation Tel: +852-2803-8989 Tel: +86-21-6135-1515 Tel: +86-755-8356-2977 Tel: +86-10-6581-6131 Tel: +81-6-6398-2527 info@hk.idec.com idec@cn.idec.com idec@cn.idec.com idec@cn.idec.com marketing@idec.co.jp
HW9Z-CZ1 价格&库存
很抱歉,暂时无法提供与“HW9Z-CZ1”相匹配的价格&库存,您可以联系我们找货
