HW9Z-SK-231
HW9Z-SK-231
    IDEC(日本和泉)
    IDEC - HW9Z-SK-231 - Switch Key, Idec HW Series Control Units, HW
HW9Z-SK-231 数据手册
ø22mm HW Series Control Units (0901211) ø22 HW Series Control Units (Selection Guide) Function Category Emergency Stop Switch (Unibody Type) ø40mm Mushroom ø40mm Mushroom (Illuminated) HW1E-BV4 9 Emergency Stop Switch (Separate Type) Pushlock Turn Reset ø29mm Mushroom ø40mm Mushroom ø60mm Mushroom HW1E-LV4 9 HW1B-V3 11 HW1B-V4 11 HW1B-V5 11 Pushlock Key Reset ø40mm Mushroom Emergency Stop Switch Push Pull ø40mm Mushroom Pushlock Turn Reset ø40mm EMO Type HW1B-X4 HW1B-Y2 HW1B-V**R-EMO Page 12 12 14 Shape Type Page Function Category Pushbutton Flush Extended Momentary/Maintained Shape Function Category ø29mm Mushroom ø40 Mushroom Momentary/Maintained Pushbutton ø60 Mushroom Momentary HW1B-M1 HW1B-A1 16 HW1B-M2 HW1B-A2 16 Square Flush Square Extended Momentary/Maintained Shape Type Page Function Category HW1B-M3 HW1B-A3 16 HW1B-M4 HW1B-A4 16 Round Flush w/Square Bezel Pushbutton Round Extended w/Square Bezel Momentary/Maintained ø29mm Mushroom w/Square Bezel HW3B-M1 HW3B-A1 18 HW3B-M2 HW3B-A2 18 HW3B-M3 HW3B-A3 18 HW1B-M5 16 HW2B-M1 HW2B-A1 17 HW2B-M2 HW2B-A2 17 Shape Type Page Function Category Flush (Marking) Pilot Light (LED/Incandescent) Square Flush (Marking) Extended (Dome) Jumbo Dome Shape Type Page 2 HW1P-1 19 HW1P-2 19 HW2P-1 19 HW1P-5 19 (091211) HW Series Control Units (Selection Guide) ø22 Illuminated Pushbutton (LED/Incandescent) Function Category Flush Extended Extended w/Full Shroud Square Flush Flush w/Square Bezel HW1L-M1 HW1L-A1 21 HW1L-M2 HW1L-A2 22 HW1L-MF2 HW1L-AF2 23 HW2L-M1 HW2L-A1 24 HW3L-M1 HW3L-A1 25 Shape Type Page Function Category Illuminated Pushbutton (LED/Incandescent) ø29mm Mushroom ø29mm Mushroom w/ Square Bezel ø40mm Mushroom HW1L-M3 HW1L-A3 26 HW3L-M3 HW3L-A3 27 HW1L-M4 HW1L-A4 28 Dual Pushbutton w/o Pilot Light Flush (top) Flush (top) Flush (bottom) Extended (bottom) Shape Type Page Function Category Dual Pushbutton w/Pilot Light (LED/Incandescent) Flush (top) Flush (top) Flush (bottom) Extended (bottom) HW7D-B11 HW7D-B21 30 Selector Switch HW7D-B12 HW7D-B22 30 Selector Key Illuminated Selector Switch (LED/Incandescent) HW1S HW1K HW1F 35 36 37 Shape Type Page Function Category HW7D-L11 HW7D-L21 31 HW7D-L12 HW7D-L22 31 Mono-Lever Switch Standard Interlocking Pushbutton Selector Shape Type Page Function Category HW1R 44 HW1M 45 Control Station w/Pushbutton w/Selector Switch HW1X-BM 57 HW1X-S 57 HW1M-L 45 Emergency Stop Control Station w/Pushlock Turn w/Pushlock Key Reset Switch Reset Switch Shape Type Page (0901211) HW1X-BV 57 HW1X-BX 57 3 ø22 HW Series Control Units Complete with finger-safe contact blocks Ensure safety and save wiring time • Locking lever removable contact blocks • Spring-up screw and finger-safe (IP20) contact blocks are available. • Self-cleaning rolling action contacts have a raked contact surface. • Degree of protection: IP65 (except dual pushbutton: IP40) • Dual pushbutton switches available with two pushbuttons and a pilot light integrated into one space-saving control unit. • A wide range of operating voltages for worldwide application • UL, CSA rated, and EN compliant. Application for dual pushbuttons: Ideal for use as power switches and start/stop switches (available with I/ON and O/OFF markings on the buttons and a pilot light in the center). Interlock type prevents two pushbuttons from being pressed at the same time, providing the best solution for up/down switches. Applicable Standard Marking Dual Pushbuttons File No. or Organization UL/c-UL File No. E68961 UL508 CSA166730 (LR92374) (jumbo dome pilot light: LR21451) TÜV Rheinland R50054316 (jumbo dome pilot light: R50051481) CSA C22.2 No.14 EN60947-5-1 Specifications and Ratings Contact Ratings Pushbuttons Illuminated Pushbuttons Dual Pushbuttons Selector Switches Illuminated Selector Switches Pushbutton Selectors Contact Block Rated Insulation Voltage Rated Thermal Current Type HW-G / HW-F 600V 10A Contact Ratings by Utilization Category IEC 60947-5-1 AC-15 (A600) DC-13 (P600) Characteristics • Contact Ratings by Utilization Category Operational Current AC 50/60 Hz DC Operational Voltage AC-12 Control of resistive loads and solid state loads AC-15 Control of electromagnetic loads (> 72 VA) DC-12 Control of resistive loads and solid state loads DC-13 Control of electromagnets 24V 10A 10A 8A 4A 48V — — 4A 2A 50V 10A 7A — — 110V 10A 5A 2.2A 1.1A 220V 6A 3A 1.1A 0.6A 440V 2A 1A — — Note: The operational current represents the classification by making and breaking currents (IEC 60947-5-1). • Minimum applicable load: 3V AC/DC, 5 mA (applicable range may vary with operating conditions and load types) For the control units listed below, the rated current (load switching current) is reduced to a half of the rated operational current of the contact block. The rated insulation voltage (600V) and the rated thermal current (10A) remain unchanged. • 3-position selector switches which contain J or S following 3 in the Type No. and which have cam code J or S. Example: HW1S-3JT21N1 • All 4-position and 5-position selector switches • All mono-lever switches • All pushbutton selectors (circuit symbols E, F, N) 4 (091211) HW Series Control Units ø22 Contact Blocks • HW-G (Spring-up Screw Terminal) • Insertion from two directions • Ring or fork connectors can also be used. • HW-F (IP20 Finger-Safe Screw Terminal) • Finger-safe (IP20) terminal • Snap-fit latch • Housing in different colors for NO and NC contact. • Double-break rolling action silver contacts with raked surface • Snap-fit latch • Double-break rolling action silver contacts with raked surface • Push rod Color-coded for different contacts • Spring-up screw terminal is ready for wiring. Screw is held captive. • Push rod Color-coded for different contacts • Housing in different colors for NO and NC contact. Note: HW-G and HW-F contact blocks have different dimensions. For dimensions, see page 49. • Contact Block Types HW-G10 HW-F10 Type No. Contact NO Housing Blue Push Rod Green • Up to 2 layers (4 blocks) can be attached. HW-G01 HW-F01 NC Purple red Red HW-G10R HW-F10R NO (early make) Blue Black LED Illuminated Unit Specifications Unit Pilot Light Illuminated Pushbutton Illuminated Selector Switch Operating Voltage 6V AC/DC 12V AC/DC Full Voltage 24V AC/DC A: amber 100/110V AC G: green 115/120V AC PW: pure white 200/220V AC R: red 230/240V AC S: blue Transformer 380V AC W: white 400/440V AC Y: yellow 480V AC (50/60 Hz) DC-DC Converter 110V DC Color Code ➁ Input Type Lamp Base BA9S/13 • Use a pure white LED for yellow illumination. • Yellow cannot be used with dual pushbuttons. Incandescent Illuminated Unit Specifications Unit Color Code ➁ Input Type Full Voltage Pilot Light Illuminated Pushbutton Illuminated Selector Switch A: G: R: S: W: amber green red blue white Transformer Operating Voltage 6V AC/DC 12V AC/DC 24V AC/DC 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC (50/60 Hz) Lamp Base HW-G01R HW-F01R NC (late break) Purple red White LED Lamp Type No. Voltage 6V AC/DC±10% LSTD-6➁ 12V AC/DC±10% LSTD-1➁ 24V AC/DC±10% LSTD-2➁ LSTD-6➁ 6V AC/DC±10% LSTD-6➁ 6V AC/DC±10% LED Lamp Type No. Voltage LS-6 1W (6.3V) LS-8 1W (18V) LS-3 1W (30V) BA9S/13 LS-6 1W (6.3V) • For LED and incandescent unit specifications of jumbo dome pilot lights, see page 6. (0901211) 5 ø22 HW Series Control Units LED Lamp Ratings (LSTD Type) (Except Jumbo Dome Pilot Lights) Type No. Lamp Base Rated Voltage LSTD-6➁ BA9S/13 6V AC/DC Voltage Range 6V AC/DC ±10% LSTD-1➁ LSTD-2➁ 12V AC/DC 12V AC/DC ±10% 11 mA 24V AC/DC 24V AC/DC ±10% 11 mA 8 mA A, R, W: 7 mA DC 10 mA 10 mA G, PW, S: 5.5 mA A (amber), G (green), PW (pure white), Color Code R (red), S (blue), W (white) Lamp Base Color Same as illumination color Voltage Marking Die stamped on the base Approx. 50,000 hours Life (until the brightness reduces to 50% the initial (reference value) value when lit at complete direct current of the rated voltage under 25ºC environment.) Current Draw AC LED Lamp Ratings (LSTDB Type) X1 Symbols (For Jumbo Dome Pilot Lights Only) Type No. Rated Voltage Voltage Range Current Draw Color Code Life (reference value) X1 LED Chip Recitification Diode Internal Circuit X2 X1 LED Chip Internal Circuit LSTDB-2➁ 24V AC/DC 24V AC/DC ±10% 15 mA A (amber), G (green), PW (pure white), R (red), S (blue), W (white) Approx. 20,000 hours (until the brightness reduces to 50% the initial value when lit at complete direct current of the rated voltage under 25ºC environment.) A, R, W Zener Diode G, PW, S Resistor Recitification Diode Zener Diode X2 X2 Resistor • Use a pure white LED for yellow illumination. Incandescent Lamp Ratings (LS Type) (Except Jumbo Dome Pilot Lights) Type No. Lamp Base Rated Voltage Wattage Voltage Marking Life (reference value) LS-6 BA9S/13 6V AC/DC LS-2 LS-3 12V AC/DC 18V AC/DC 24V AC/DC 1W (6.3V) 1W (18V) 1W (24V) 1W (30V) Die stamped on the base Approx. 1,000 hours minimum (mean value when used on the rated voltage) Specifications Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance Dielectric Strength (Note) Vibration Resistance Shock Resistance Mechanical Life (minimum operations) Electrical Life (minimum operations) Weight LS-8 Incandescent Lamp Ratings (LSB Type) (For Jumbo Dome Pilot Lights Only) Type No. Rated Voltage Wattage Lamp Rating LSB-2 24V AC/DC 3.6W 28V, 0.17A Approx. 1,000 hours Life (reference value) (Mean value at the rated voltage.) • Use incandescent lamp types for displaying the muting status (temporary automatic suspension of a safety function, required by IEC61496-1) of equipment such as light curtains. –25 to +60ºC (no freezing) Illuminated units: –25 to +50ºC Jumbo dome pilot lights: –25 to +55ºC –40 to +80ºC 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts: 2,500V AC, 1 minute (Full voltage type illuminated units: 2,000V AC, 1 minute) Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Damage limits: 1,000 m/s2 Operating extremes: 100 m/s2 Pushbuttons, Illuminated pushbuttons Key selector switches: Momentary: 5,000,000 Illuminated selector switches: Maintained: 500,000 Pushbutton selectors: Dual pushbuttons: 500,000 Mono-lever switches: Selector switches: 500,000 Illuminated selector switches: Pushbuttons, Illuminated pushbuttons: 500,000 *1 Pushbutton selectors: Dual pushbuttons: 500,000 *1 Mono-lever switches: Selector switches: 500,000 *2 Key selector switches: 500,000 *2 500,000 500,000 250,000 250,000 500,000 *2 250,000 *2 250,000 *3 *1 Switching frequency 1,800 operations/h, duty ratio 40% *2 Switching frequency 1,200 operations/h, duty ratio 40% *3 Switching frequency 900 operations/h, duty ratio 40% 66g (HW1B-M122 ), 20g (HW1P-1Q4), 84g (HW1L-M122Q4), 66g (HW1S-2T22), 94g (HW1K-2A22), 84g (HW1F-222Q4), 71g (HW1R-2A22), 82g (HW1M-2222-22N9), 72g (HW7D-B111111), 90g (HW7D-L111111Q4) Note: Dielectric strength for dual pushbuttons are as follows: Without pilot light: 2,500V AC, 1 minute (between live and dead metal parts) With pilot light: Full voltage type: 1,000V AC, 1 minute (between live and dead metal parts) Transformer and DC-DC converter types: 2,000V AC, 1 minute (between live and dead metal parts) 6 (091211) HW Series Control Units ø22 Degree of Protection Unit All units except dual pushbutton switches Dual pushbutton switches NEMA ICS 6-110 Type 1, 2, 3, 3R, (3S), 4, 5, 12,13 IEC 60529 IP65 (Note 1) IP40 (Note 2) Note 1: When using a nameplate with the control unit, IP65 protection degree is achieved only when nameplates shown on page 46 are used. Note 2: IP65 protection degree when HW9Z-D7D button cover is used. Mounting Hole Layout .3 +0.4 50 (45 min.) A 0 24.1 +0.4 0 ø22 The minimum mounting centers are applicable to switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers in consideration of convenience for wiring. • Minimum Mounting Centers Unit A B ø40mm mushroom button 50 mm 40 mm Pilot light 30 mm 30 mm Pushbutton selector 50 mm 50 mm Mono-lever switch 72 mm 72 mm Jumbo dome pilot 85 mm 85 mm Dual pushbutton switches 55 mm 30 mm R0.8 max. *3.2 +0.2 0 B 30 * The 3.2 mm recess is for preventing rotation and is not necessary when the nameplate or anti-rotation ring is not used. Ordering Information Note: When using the safety lever lock, determine the vertical spacing (A) in consideration of convenience for installing and removing the safety lever lock. Recommended vertical spacing: 100 mm The Type No. development charts shown below can be used to specify control units other than those listed on the following pages. Goldplated silver contacts are also available. Emergency Stop Switches (Separate Type) For emergency stop purposes, these switches must contain at least one NC contact block. HW1B-V4 F 11 R -MAU Optional contact MAU: Gold-plated silver contact Button/lens color code Contact arrangement code 01: 1NC 11: 1NO-1NC 02: 2NC 21: 2NO-1NC 12: 1NO-2NC 03: 3NC 31: 3NO-1NC 22: 2NO-2NC 13: 1NO-3NC 04: 4NC Terminals F: Finger-safe (IP20) blank: Spring-up screw Note: Push-pull type HW1B-Y2 can have a maximum of two contact blocks. Pushbuttons HW1B-M1 F 11 R -MAU Optional contact MAU: Gold-plated silver contact Button/lens color code Contact arrangement code 10: 1NO 01: 1NC 11: 1NO-1NC 20: 2NO 02: 2NC 21: 2NO-1NC 12: 1NO-2NC 30: 3NO 03: 3NC 31: 3NO-1NC 22: 2NO-2NC 13: 1NO-3NC 40: 4NO 04: 4NC Terminals F: Finger-safe (IP20) blank: Spring-up screw (0901211) Illuminated Pushbuttons HW1L-M1 F 11 H 2 R -MAU Optional contact MAU: Gold-plated silver contact Lens color code Lamp code 0: Without lamp 2: LED (6V: LSTD) 3: LED (12V: LSTD) 4: LED (24V: LSTD) 5: Incandescent (6V: LS-6) 6: Incandescent (12V: LS-8) 7: Incandescent (24V: LS-3) Operating voltage code Q: Full voltage H: Transformer (100/110V AC) H2: Transformer (115/120V AC) M: Transformer (200/220V AC) M4: Transformer (230/240V AC) S: Transformer (380V AC) T: Transformer (400/440V AC) T8: Transformer (480V AC) D: DC-DC converter (110V DC) Contact arrangement code 10: 1NO 01: 1NC 11: 1NO-1NC 20: 2NO 02: 2NC 21: 2NO-1NC 12: 1NO-2NC 30: 3NO 03: 3NC 31: 3NO-1NC 22: 2NO-2NC 13: 1NO-3NC 40: 4NO 04: 4NC Terminals F: Finger-safe (IP20) blank: Spring-up screw Note: Full voltage type is not supplied with a lamp. Transformer and DC-DC converter types contain an LED lamp (LSTD-6➁) or incandescent lamp (LS-6). Transformer and DC-DC converter types can have two or four contact blocks only. 7 ø22 HW Series Control Units Dual Pushbutton Switches w/o Pilot Light HW7D-B 1 1 F 10 02 GR 1 -MAU Optional contact MAU: Gold-plated silver contact Button legends Blank: Without legend 1: I/ON + O/OFF Button color code GR: Green (top) Red (bottom) WB: White (top) Black (bottom) Contact arrangement code (bottom button) 10: 1NO 01: 1NC 11: 1NO-1NC 20: 2NO 02: 2NC Contact arrangement code (top button) 10: 1NO 01: 1NC 11: 1NO-1NC 20: 2NO 02: 2NC Terminals F: Finger-safe (IP20) blank: Spring-up screw Button style 1: Flush + Flush 2: Flush + Extended Operating type 1: Momentary 2: Interlock Dual Pushbutton Switches with Pilot Light HW7D-L 1 1 F 11 20 H 2 R -GR 1 -MAU Operating type 1: Momentary 2: Interlock Button style 1: Flush+Flush 2: Flush+Extended Terminals F: Finger-safe (IP20) blank: Spring-up screw Contact arrangement code (top button) 10: 1NO 01: 1NC 11: 1NO-1NC 20: 2NO 02: 2NC Contact arrangement code (bottom button) 10: 1NO 01: 1NC 11: 1NO-1NC 20: 2NO 02: 2NC Operating voltage code Q: Full voltage H: Transformer (100/110V AC) H2: Transformer (115/120V AC) M: Transformer (200/220V AC) M4: Transformer (230/240V AC) S: Transformer (380V AC) T: Transformer (400/440V AC) T8: Transformer (480V AC) D: DC-DC converter (110V DC) Optional contact MAU: Gold-plated silver contact Button legends Blank: Without legend 1: I/ON + O/OFF Button color code GR: Green (top) Red (bottom) WB: White (top) Black (bottom) Lamp color code A: Amber (LED only) G: Green (LED only) PW: Pure white (LED only) R: Red (LED only) S: Blue (LED only) W: White (LED/incandescent) Lamp code 0: Without lamp 2: LED (6V: LSTD-6) 3: LED (12V: LSTD-1) 4: LED (24V: LSTD-2) 5: Incandescent (6V: LS-6) 6: Incandescent (12V: LS-8) 7: Incandescent (24V: LS-3) Note: Full voltage type is not supplied with a lamp. Transformer and DC-DC converter types contain an LED lamp (LSTD-6➁) or incandescent lamp (LS-6). Transformer and DC-DC converter types can have two or four contact blocks only. Selector Switches HW1S-3 S T F 22N9 -MAU Cam code J / S / (none) Knob operator Optional contact MAU: Gold-plated silver contact Contact code Terminals F: Finger-safe (IP20) blank: Spring-up screw Illuminated Selector Switches HW1F-2 F 11 H 2 R -MAU Terminals F: Finger-safe (IP20) blank: Spring-up screw Key Selector Switches HW1K-2 A F 11 - 1H -MAU Optional contact MAU: Gold-plated silver contact Key removal position Different key number code 1H / 2H / 3H 2-position Terminals A: Removable in all positions F: Finger-safe (IP20) B: Removable in left only blank: Spring-up screw C: Removable in right only 3-position A: Removable in all positions B: Removable in left and center C: Removable in right and center D: Removable in center only E: Removable in right and left G: Removable in left only H: Removable in right only Note: Key is not removable from spring-return positions. 8 Optional contact MAU: Gold-plated silver contact Lens color code Lamp code 0: Without lamp 2: LED (6V: LSTD) 3: LED (12V: LSTD) 4: LED (24V: LSTD) 5: Incandescent (6V: LS-6) 6: Incandescent (12V: LS-8) 7: Incandescent (24V: LS-3) Operating voltage code Q: Full voltage H: Transformer (100/110V AC) H2: Transformer (115/120V AC) M: Transformer (200/220V AC) M4: Transformer (230/240V AC) S: Transformer (380V AC) T: Transformer (400/440V AC) T8: Transformer (480V AC) Note: Full voltage type is not supplied with a lamp. Transformer type contains an LED lamp (LSTD-6➁) or incandescent lamp (LS-6). Pushbutton Selectors HW1R-2 D F 22N1 B -MAU Circuit category Terminals F: Finger-safe (IP20) blank: Spring-up screw Optional contact MAU: Gold-plated silver contact Button color code Contact code (091211) HW Series Emergency Stop Switches ø22 Emergency Stop Switches (Unibody Type) Specifications Contact Ratings Rated Insulation Voltage (Ui) 250V Rated Thermal Current (Ith) 10A Rated Operational Voltage (Ue) 24V 110V 220V AC Resistive Load (AC-12) 6A 3A 3A 50/60 Rated Inductive Load (AC-15) 6A 3A 3A Hz Operational Resistive Load (DC-12) 6A 2A 1A Current DC Inductive Load (DC-13) 1.5A 0.3A 0.15A • Minimum applicable load (reference value): 3V AC/DC, 5 mA (Applicable range may vary with operating conditions and load types.) • The operational current represents the classification by making and breaking currents (IEC 60947-5-1). LED Lamp Ratings Unit Rated Operating Voltage 6V AC/DC 12V AC/DC 24V AC/DC LED Lamp Type No. Rated Voltage Rated Current LSTD-6R 6V AC/DC ±10% 7 mA LSTD-1R 12V AC/DC ±10% 10 mA LSTD-2R 24V AC/DC ±10% 10 mA Incandescent Lamp Ratings LED Lamp Unit Rated Operating Voltage Type No. Wattage 6V AC/DC LS-6 1W (6.3V) 12V AC/DC LS-8 1W (18V) 24V AC/DC LS-3 1W (30V) Specifications Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance Dielectric Strength Vibration Resistance Shock Resistance Operating Frequency Life Degree of Protection Terminal Style Weight –25 to +60ºC (no freezing) Illuminated units: –25 to +55ºC –40 to +80ºC 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts: Contacts: 2,500V AC, 1 minute Illuminated parts: 1,000V AC, 1 minute Damage limits: 60 m/s2 Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Damage limits: 1,000 m/s2 Operating extremes: 100 m/s2 900 operations/h Mechanical: 250,000 operations minimum Electrical: 100,000 operations minimum (at 900 operations/h, duty ratio 40%) IP65 M3.5 screw 49g (HW1E-BV402R) 56g (HW1E-LV402Q4R) Applicable Standards and Approvals Safety Standards UL508 CSA C22.2 No. 14 EN60947-5-5 GB14048.5 Marking File No. or Organization UL Listing File No. E55996 DEMKO approved Self declaration (EC Low Voltage Directive) CCC No.2004010305132908 Pushlock Turn Reset Switches (Unibody Type) Shape ø40mm Mushroom Pushlock Turn Reset HW1E-BV4 Contact 1NO-1NC Type No. Button Color HW1E-BV4F11R Red only 2NC HW1E-BV4F02R • When pressed, the button is held depressed. The button is released by turning clockwise. • Finger-safe (IP20) terminal. Illuminated Pushlock Turn Reset Switches (Unibody Type) Shape ø40mm Mushroom Pushlock Turn Reset HW1E-LV4 Contact 1NO-1NC Type No. Button Color HW1E-LV4F11Q0R Red only 2NC HW1E-LV4F02Q0R • When pressed, the button is held depressed. The button is released by turning clockwise. • The illuminated pushlock turn reset switch does not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. • Finger-safe (IP20) terminal. (0901211) 9 ø22 HW Series Emergency Stop Switches Dimensions • HW1E-BV4 Panel Thickness 0.8 to 6 Gasket TOP 0.5 Locking Ring ø4 0 M3.5 Terminal Screw 11.5 48 32 • HW1E-LV4 Panel Thickness 0.8 to 6 Gasket TOP M3.5 Terminal Screw Lamp Terminal 0.5 Locking Ring M3.5 Terminal Screw ø4 0 63 Mounting Hole R0.8 max. .3 3.2 +0 .4 0 +0.2 0 24.1 +0.4 0 ø22 Determine the minimum mounting hole centers in consideration of convenience for wiring. 23.5 14 32 All dimensions in mm. Terminal Arrangement (Bottom View) • HW1E-BV4 TOP • HW1E-LV4 TOP X1 .2 (NC) .1 (NC) .3 (NO) LAMP .2 (NC) .3 (NO) .1 (NC) .4 (NO) .4 (NO) (1NO-1NC) X2 (1NO-1NC) 10 (091211) HW Series Emergency Stop Switches ø22 Emergency Stop Switches (Separate Type) Specifications Contact Ratings Rated Insulation Voltage Contact Rated Thermal Current Block Contact Ratings by Utilization Category IEC 60947-5-1 600V 10A AC-15 (A600) DC-13 (P600) Characteristics • Contact Ratings by Utilization Category Operational Current Operational Voltage AC-12 Control of resistive loads and AC solid state loads 50/60 AC-15 Control of Hz electromagnetic loads (> 72 VA) DC-12 Control of resistive loads and solid state loads DC DC-13 Control of electromagnets 24V 48V 50V 110V 220V 440V 10A — 10A 10A 6A 2A 10A — 7A 1A 8A 4A — 2.2A 1.1A — 4A 2A — 1.1A 0.6A — 5A 3A Applicable Standards and Approvals Safety Standards Marking File No. or Organization UL508 UL Listing File No. E68961 CSA C22.2 No. 14 File No. LR92374 EN60947-5-5 GB14048.5 Specifications Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance Dielectric Strength Vibration Resistance Shock Resistance Operating Frequency Life Degree of Protection Terminal Style Weight DEMKO approved –25 to +60ºC (no freezing) –40 to +80ºC 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts Between terminals of different poles Between terminals of the same pole 2,500V AC, 1 minute Damage limits: 60 m/s2 Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Damage limits: 1,000 m/s2 Operating extremes: 100 m/s2 900 operations/h Mechanical: 500,000 operations minimum (push-pull: 250,000 operations) Electrical: 500,000 operations minimum (push-pull: 250,000 operations) (at 900 operations/h, duty ratio 40%) IP65 M3.5 screw 76g (HW1B-V322) 99g (HW1B-X422R) 54g (HW1B-Y202) 79g (HW1B-V422R-EMO) Self declaration (EC Low Voltage Directive) CCC No.2005103050145656 Pushlock Turn Reset Switches (Separate Type) Shape ø29mm Mushroom Pushlock Turn Reset HW1B-V3 ø40mm Mushroom Pushlock Turn Reset HW1B-V4 ø60mm Mushroom Pushlock Turn Reset HW1B-V5 Contact Type No. 1NC HW1B-V3➅01➀ 1NO-1NC HW1B-V3➅11➀ 2NC HW1B-V3➅02➀ 2NO-2NC HW1B-V3➅22➀ 1NC HW1B-V4➅01➀ 1NO-1NC HW1B-V4➅11➀ 2NC HW1B-V4➅02➀ 2NO-2NC HW1B-V4➅22➀ 1NC HW1B-V5➅01➀ 1NO-1NC HW1B-V5➅11➀ 2NC HW1B-V5➅02➀ 2NO-2NC HW1B-V5➅22➀ Button Color Specify a button color code in place of ➀ in the Type No. R: red Y: yellow • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw • Yellow buttons cannot be used as emergency stop switches in compliance with EN standards. • When pressed, the button is held depressed. The button is released by turning clockwise. • Pushlock turn reset switches with one or three contact blocks contain a dummy block. • Safety lever lock HW9Z-LS is supplied with the switch. • Other contact arrangements and gold-plated silver contacts are also available. See page 7. (0901211) 11 ø22 HW Series Emergency Stop Switches Pushlock Key Reset Switches (Separate Type) Shape ø40mm Mushroom Pushlock Key Reset HW1B-X4 Contact Type No. 1NC HW1B-X4➅01R 1NO-1NC HW1B-X4➅11R 2NC HW1B-X4➅02R 2NO-2NC HW1B-X4➅22R Button Color Red only • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw • When pressed, the button is held depressed. The button is released by turning the key clockwise. • Pushlock key reset switches with one or three contact blocks contain a dummy block. • Two identical keys and safety lever lock HW9Z-LS are supplied with the switch. • Other contact arrangements and gold-plated silver contacts are also available. See page 7. Push-Pull Switches (Separate Type) Shape ø40mm Mushroom Push-Pull (2-position) HW1B-Y2 Contact Type No. 1NC HW1B-Y2➅01➀ 1NO-1NC HW1B-Y2➅11➀ 2NC HW1B-Y2➅02➀ Button Color Specify a button color code in place of ➀ in the Type No. R: red Y: yellow • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw • The button is maintained at either pulled or depressed position. • Push-pull switches are available with one or two contact blocks. • Push-pull switches with one contact block contain a dummy block. • Safety lever lock HW9Z-LS is supplied with the switch. Accessory Nameplate Shape EM ER GENCY Name 0 ø6 ø2 STOP 12 2 1.5 0.9 Nameplate for Emergency Stop Switch (See page 13 for panel cutout.) Type No. Legend HWAV-0-Y (blank) HWAV-27-Y EMERGENCY STOP Package Quantity Remarks 1 Background: Yellow Legend: Black Applicable panel thickness: 0.8 to 4.5 mm Material: Polyamide Not applicable for ø60 mm mushroom buttons. Legend "EMERGENCY STOP" is indicated outside a ø44mm circle. (091211) HW Series Emergency Stop Switches ø22 Dimensions • ø29mm Pushlock Turn Reset HW1B-V3 Gasket Locking Ring Safety Lever Lock Panel Thickness 0.8 to 6 LO Terminal Screw M3.5 ø29 41.4 26.5 25 CK 1 contact block 49.4 (1 or 2 blocks) 2 contact blocks 4 contact blocks 69.4 (4 blocks) 29.4 13 32 The above figure illustrates the spring-up screw type. The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. • ø40mm Pushlock Turn Reset HW1B-V4 All dimensions in mm. • ø60mm Pushlock Turn Reset HW1B-V5 Safety Lever Lock Safety Lever Lock LO 13 ø60 ø40 41.4 26.5 25 CK 29.4 32 15 • ø40mm Pushlock Key Reset HW1B-X4 34.5 • ø40mm Push-Pull HW1B-Y2 Safety Lever Lock Safety Lever Lock LO 32 CK 49.4 41.4 25 29.4 ø40 41.4 ø40 13 LO 26.5 26.5 25 CK 13 32 29.4 All dimensions in mm. Panel Cut-Out The minimum mounting centers shown below are applicable to emergency stop switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers in consideration of convenience for wiring. • Minimum Mounting Centers for Emergency Stop Switches R0.8 max. .3 3.2 +0 . 0 4 +0.2 0 24.1 +0.4 0 ø22 Unit Vertical Spacing Horizontal Spacing HW1B-V3 HW1B-V4 50 mm 50 mm HW1B-X4 HW1B-Y2 HW1B-V5 60 mm 60 mm Note: When using the safety lever lock, determine the vertical spacing in consideration of convenience for installing and removing the safety lever lock. Recommended vertical spacing: 100 mm For emergency stop control stations, see page 57. (0901211) 13 ø22 HW Series Emergency Stop Switches EMO Pushbuttons EMO is an abbreviation of Emergency Off. Used for emergency stop according to SEMI standards. Shape ø40mm Mushroom Pushlock Turn Reset HW1E-BV4 Contact Type No. Button Color 1NC HW1B-V4➅01R-EMO 1NO-1NC HW1B-V4➅11R-EMO 2NC HW1B-V4➅02R-EMO 2NO-2NC HW1B-V4➅22R-EMO Red only (Legend: White) • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw Dimensions LOC K Lock Lever 0 ø4 20 41.4 25 26.5 Locking Ring 1 contact block 2 contact blocks 4 contact blocks 49.4 (1 or 2 blocks) 69.4 (4 blocks) 29.4 13 32 All dimensions in mm. The above figure illustrates the spring-up screw type. The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. SEMI Standard Compliant Switch Guards (For ø22mm mounting hole) HW9Z-KG4 14 HW1B-V3 HW1B-V4 HW1B-X4 HW1B-Y2 HW1E-BV4 HW1E-LV4 XW1E-BV4 XW1E-LV4 XW1E-TV4 ø80 32 ø66.8 ø90 ø76.1 52 2 ø74 35 25 ø2 42 35 25 ø2 2 ø90 EMO Switch Guard SEMI S2 compliant (Note 3) SEMATECH compliant (Note 2) 2 HW9Z-KG3 HW1B-V3 HW1B-V4 HW1B-X4 HW1B-Y2 XW1E-BV4 XW1E-LV4 XW1E-TV4 EMO Switch Guard SEMI S2 compliant (Note 3) 36.5 2. HW9Z-KG2 HW1B-V3 HW1B-V4 HW1B-X4 HW1B-Y2 HW1E-BV4 HW1E-LV4 XW1E-BV4 XW1E-LV4 XW1E-TV4 38 22 64 47 ø2 EMO Switch Guard SEMI S2 compliant (Note 1) SEMATECH compliant (Note 2) 2 HW9Z-KG1 Dimensions ø2 EMO Switch Guard SEMI S2 compliant (Note 1) Applicable Emergency Stop Switches HW1B-V3 HW1B-V4 HW1B-X4 HW1B-Y2 HW1E-BV4 HW1E-LV4 XW1E-BV4 XW1E-LV4 XW1E-TV4 67 Type No. ø66 Description & Appearance ø75 • SEMI S2-0200 12.5.1 Compliant 50 (091211) HW Series Emergency Stop Switches ø22 36.2 34.4 27 ø90 HW9Z-KG5 Dimensions 2 ø2 EMO Switch Guard SEMI S2 compliant (Note 3) SEMATECH compliant (Note 2) Applicable Emergency Stop Switches HW1B-V3 HW1B-V4 HW1B-X4 HW1B-Y2 HW1E-BV4 HW1E-LV4 XW1E-BV4 XW1E-LV4 XW1E-TV4 XW1E-BV5 40 33 Type No. 76 Description & Appearance 75 Note 1: SEMI S2-0703, 12.5.1 compliant. Note 2: SEMATECH Application Guide for SEMI S2-93, 12.4. compliant. Note 3: The combination of IDEC's emergency stop switches and EMO switch guards are approved by TÜV Rheinland for compliance with SEMI S2 standard. • Degree of protection IP65 applies to the combination of an emergency stop switch and an EMO switch guard. • HW9Z-KG1, HW9Z-KG2, and HW9Z-KG3 can be used with ø29mm or ø40mm mushroom buttons. ø60mm jumbo mushroom buttons cannot be installed. Panel Cut-out ∗3.2 +0.2 0 um xim ma 24.1 0 +0.4 R 0.8 .4 +00 .3 2 ø2 Projection +0.2 0 The ∗3.2 recess is for preventing rotation and not necessary when anti-rotation is not used. When anti-rotation is not required or when the panel cut-out does not have anti-rotation recess, remove the projection using pliers. Installation TOP Marking TOP Marking Operator Button Panel Thickness: 1.2 to 4 Locking Ring To tighten the locking ring, use locking ring wrench MW9Z-T1. Tighten the locking ring to a torque of 2.0 N·m. EMO Sticker • Type No.: HW9Z-EMO-NPP • Color: Yellow (red legend) • Package Quantity: 10 20 50 E MO Note: EMO switch guards have been designed for applications in semiconductor manufacturing equipment only. Do not use the EMO switchguards with emergency stop switches which are installed on machine tools or food processing machines. (Machinery Directive of the European Commission and IEC 60204-1 require that emergency stop switches be installed in a readily accessible area, and the usage of switch guards is not permitted.) (0901211) 15 ø22 HW Series Pushbuttons Flush / Extended / Mushroom Types Maintained ø40mm Mushroom HW1B-M4 HW1B-A4 Momentary Maintained ø60mm Mushroom HW1B-M5 Momentary 13 69.4 (4 blocks) 29.4 M3.5 Terminal Screw Locking Ring Specify a button color code in place of ➀ in the Type No. B: black G: green R: red S: blue W: white Y: yellow Specify a 1NC HW1B-M➄➅01➀ button color code in place 1NO-1NC HW1B-M➄➅11➀ of ➀ in the Type No. 2NO HW1B-M➄➅20➀ B: black 2NC HW1B-M➄➅02➀ G: green R: red 2NO-2NC HW1B-M➄➅22➀ 41.4 25 49.4 (1 or 2 blocks) LO Panel Thickness 0.8 to 6 CK 41.4 25 HW1B-M➄➅10➀ ø29 1NO 3.6 ø2 13 49.4 (1 or 2 blocks) 69.4 (4 blocks) 29.4 19 M3.5 Terminal Screw Locking Ring LO Panel Thickness 0.8 to 6 CK 41.4 Momentary CK 13 49.4 (1 or 2 blocks) 69.4 (4 blocks) M3.5 Terminal Screw Locking Ring 29.4 23.2 LO Panel Thickness 0.8 to 6 CK 41.4 ø29mm Mushroom HW1B-M3 HW1B-A3 LO Panel Thickness 0.8 to 6 Locking Ring 25 Maintained M3.5 Terminal Screw 25 Momentary HW1B-M1➅10➀ HW1B-M1➅01➀ HW1B-M1➅11➀ HW1B-M1➅20➀ HW1B-M1➅02➀ HW1B-M1➅22➀ HW1B-A1➅10➀ HW1B-A1➅01➀ HW1B-A1➅11➀ HW1B-A1➅20➀ HW1B-A1➅02➀ HW1B-A1➅22➀ HW1B-M2➅10➀ HW1B-M2➅01➀ HW1B-M2➅11➀ HW1B-M2➅20➀ HW1B-M2➅02➀ HW1B-M2➅22➀ HW1B-A2➅10➀ HW1B-A2➅01➀ HW1B-A2➅11➀ HW1B-A2➅20➀ HW1B-A2➅02➀ HW1B-A2➅22➀ HW1B-M3➅10➀ HW1B-M3➅01➀ HW1B-M3➅11➀ HW1B-M3➅20➀ HW1B-M3➅02➀ HW1B-M3➅22➀ HW1B-A3➅10➀ HW1B-A3➅01➀ HW1B-A3➅11➀ HW1B-A3➅20➀ HW1B-A3➅02➀ HW1B-A3➅22➀ HW1B-M4➅10➀ HW1B-M4➅01➀ HW1B-M4➅11➀ HW1B-M4➅20➀ HW1B-M4➅02➀ HW1B-M4➅22➀ HW1B-A4➅10➀ HW1B-A4➅01➀ HW1B-A4➅11➀ HW1B-A4➅20➀ HW1B-A4➅02➀ HW1B-A4➅22➀ ø29 Extended HW1B-M2 HW1B-A2 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC Dimensions (Spring-up screw type) ➀ Button Color Code ø23.6 Maintained Type No. ø29 Momentary Contact ø40 Flush HW1B-M1 HW1B-A1 Operation Type 13 49.4 (1 or 2 blocks) 69.4 (4 blocks) M3.5 Terminal Screw Locking Ring 29.4 23.2 Panel Thickness 0.8 to 6 ø60 Shape 15 49.4 (1 or 2 blocks) 69.4 (4 blocks) 30 • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw • Pushbuttons with one or three contact blocks contain a dummy block. • Other contact arrangements and gold-plated silver contacts are also available. See page 7. • The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. 16 (091211) HW Series Pushbuttons ø22 Square Flush / Square Extended Types Shape Square Flush HW2B-M1 HW2B-A1 Operation Type Contact Type No. Dimensions (Spring-up screw type) ➀ Button Color Code LO CK 29.6 41.4 29.6 41.4 25 1NO HW2B-M1➅10➀ 1NC HW2B-M1➅01➀ M3.5 Terminal Screw 1NO-1NC HW2B-M1➅11➀ Momentary Locking Ring Panel Thickness 0.8 to 6 2NO HW2B-M1➅20➀ 2NC HW2B-M1➅02➀ 2NO-2NC HW2B-M1➅22➀ 1NO HW2B-A1➅10➀ 1NC HW2B-A1➅01➀ Specify a 1NO-1NC HW2B-A1➅11➀ button color 49.4 (1 or 2 blocks) 13 Maintained code in place 69.4 (4 blocks) 2NO HW2B-A1➅20➀ of ➀ in the 2NC HW2B-A1➅02➀ Type No. 2NO-2NC HW2B-A1➅22➀ Square Extended 1NO HW2B-M2➅10➀ B: black HW2B-M2 M3.5 1NC HW2B-M2➅01➀ G: green Terminal Screw R: red HW2B-A2 1NO-1NC HW2B-M2➅11➀ Locking Ring Panel Thickness 0.8 to 6 S: blue Momentary 2NO HW2B-M2➅20➀ W: white 2NC HW2B-M2➅02➀ Y: yellow 2NO-2NC HW2B-M2➅22➀ 1NO HW2B-A2➅10➀ 1NC HW2B-A2➅01➀ 1NO-1NC HW2B-A2➅11➀ 13 Maintained 2NO HW2B-A2➅20➀ 49.4 (1 or 2 blocks) 19 69.4 (4 blocks) 2NC HW2B-A2➅02➀ 2NO-2NC HW2B-A2➅22➀ • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw • Pushbuttons with one or three contact blocks contain a dummy block. • Other contact arrangements and gold-plated silver contacts are also available. See page 7. • The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. 24.8 29.4 LO 24.8 25 CK Contact Block (Bottom View) Spring-up screw type 1 contact block (0901211) 2 contact blocks 4 contact blocks 29.4 Terminal Wiring Arrows indicate access directions for wiring. * * * * *Spring-up screw type only. 17 ø22 HW Series Pushbuttons Round Button with Square Bezel Type Shape Round Flush with Square Bezel HW3B-M1 HW3B-A1 Operation Type Contact Type No. Dimensions (Spring-up screw type) ➀ Button Color Code LO CK 41.4 29.6 25 1NO HW3B-M1➅10➀ 1NC HW3B-M1➅01➀ M3.5 1NO-1NC HW3B-M1➅11➀ Terminal Screw Momentary Locking Ring Panel Thickness 0.8 to 6 2NO HW3B-M1➅20➀ 2NC HW3B-M1➅02➀ 2NO-2NC HW3B-M1➅22➀ 1NO HW3B-A1➅10➀ 1NC HW3B-A1➅01➀ 3.6 ø2 1NO-1NC HW3B-A1➅11➀ 49.4 (1 or 2 blocks) 13 Maintained 2NO HW3B-A1➅20➀ 69.4 (4 blocks) 2NC HW3B-A1➅02➀ 2NO-2NC HW3B-A1➅22➀ Round Extended 1NO HW3B-M2➅10➀ with Square Bezel 1NC HW3B-M2➅01➀ Specify a M3.5 Terminal Screw HW3B-M2 1NO-1NC HW3B-M2➅11➀ button color Locking Ring Panel Thickness 0.8 to 6 Momentary HW3B-A2 code in place 2NO HW3B-M2➅20➀ of ➀ in the 2NC HW3B-M2➅02➀ Type No. 2NO-2NC HW3B-M2➅22➀ 1NO HW3B-A2➅10➀ B: black 1NC HW3B-A2➅01➀ G: green R: red 13 1NO-1NC HW3B-A2➅11➀ S: blue Maintained 19 49.4 (1 or 2 blocks) 2NO HW3B-A2➅20➀ W: white 69.4 (4 blocks) 2NC HW3B-A2➅02➀ Y: yellow 2NO-2NC HW3B-A2➅22➀ ø29mm Mushroom 1NO HW3B-M3➅10➀ with Square Bezel 1NC HW3B-M3➅01➀ M3.5 Terminal Screw HW3B-M3 1NO-1NC HW3B-M3➅11➀ Locking Ring Panel Thickness 0.8 to 6 Momentary HW3B-A3 2NO HW3B-M3➅20➀ 2NC HW3B-M3➅02➀ 2NO-2NC HW3B-M3➅22➀ 1NO HW3B-A3➅10➀ 1NC HW3B-A3➅01➀ 13 1NO-1NC HW3B-A3➅11➀ Maintained 49.4 (1 or 2 blocks) 23.2 2NO HW3B-A3➅20➀ 69.4 (4 blocks) 2NC HW3B-A3➅02➀ 2NO-2NC HW3B-A3➅22➀ • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw • Pushbuttons with one or three contact blocks contain a dummy block. • Other contact arrangements and gold-plated silver contacts are also available. See page 7. • The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. 29.4 LO 29.6 41.4 29.6 41.4 ø23.6 25 CK 29.4 LO ø29 25 CK Contact Block (Bottom View) Spring-up screw type 1 contact block 18 2 contact blocks 4 contact blocks 29.4 Terminal Wiring Arrows indicate access directions for wiring. * * * * *Spring-up screw type only. (091211) HW Series Pilot Lights ø22 Round Flush / Dome / Square Flush / Jumbo Dome Types Shape Round Flush HW1P-1 Lamp Without Lamp LED (Photo: Full Voltage Type) Dome HW1P-2 Square Flush HW2P-1 Full Voltage HW1P-1➅Q0➁ Transformer HW1P-1➅➂2➁ DC-DC Converter* HW1P-1D2➁ Transformer HW1P-1➅➂5➁ Without Lamp Full Voltage HW1P-2➅Q0➁ Transformer HW1P-2➅➂2➁ DC-DC Converter* HW1P-2D2➁ Incandescent Transformer HW1P-2➅➂5➁ Without Lamp Full Voltage HW2P-1➅Q0➁ Transformer HW2P-1➂2➁ DC-DC Converter* HW2P-1D2➁ LED (Photo: Transformer Type) Type No. Incandescent LED (Photo: Full Voltage Type) Input Type Incandescent Transformer HW2P-1➅➂5➁ ➁ Lens/LED Color Code ➂ Operating Voltage Code A: amber G: green PW: pure white R: red S: blue W: white Y: yellow A: G: R: S: W: amber green red blue white A: amber G: green PW: pure white R: red S: blue W: white Y: yellow A: G: R: S: W: amber green red blue white Specify an operating voltage code in place of ➂ in the Type No. H: 100/110V AC H2: 115/120V AC M: 200/220V AC M4: 230/240V AC S: 380V AC T: 400/440V AC T8: 480V AC A: amber G: green PW: pure white R: red S: blue W: white Y: yellow A: G: R: S: W: amber green red blue white A: G: R: S: W: Y: amber green red blue white yellow Jumbo Dome Pilot Light HW1P-5 LED HW1P-5Q4➁ Full Voltage Incandescent HW1P-5Q7➁ Operating voltage: 24V AC/DC • Specify a lens/LED color code in place of ➁ in the Type No. Use a pure white LED lamp for yellow illumination. • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw • Only spring-up screw terminals are available on DC-DC converter types. • Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. • LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). • Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). • *DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC) • Jumbo dome pilot lights contain an exclusive LED and incandescent lamps. See page 51. (0901211) 19 ø22 HW Series Pilot Lights Dimensions • Pilot Light (except jumbo dome pilot light) [Full Voltage Type] Panel Thickness 0.8 to 6 M3.5 Terminal Screw Flush Gasket Locking Ring Dome Round/Dome 9 ø2 Square Flush X2 X1 0.5 43.3∗ [Transformer Type] Flush Dome Round/Dome 9 ø2 Square Flush X1 X2 24 M3.5 Terminal Screw 29.6 17.5 7 60.8∗ 29.6 [DC-DC Converter Type] 17.5 7 Flush Dome Round/Dome 9 ø2 Square Flush X1 X2 24 M3.5 Terminal Screw 29.6 29.6 76.2 29.6 17.5 7 The above figures illustrate the spring-up screw types. All dimensions in mm. *The depths of finger-safe (IP20) types are as follows: [Full Voltage Type] 44.7 mm [Transformer Type] 72.1 mm • Jumbo Dome Pilot Light Panel Thickness 1 to 5 6 ø6 M3.5 Terminal Screw Locking Ring Rubber Gasket 0.5 34.4 50.5 Mounting Hole Layout • Pilot Light (except jumbo dome pilot light) Close mounting on 30mm centers Degree of protection: IP65 +0.4 30 22. R0.8 max. ø22.3 +0.4 0 3.2 +0.2 0 85 30 min. 24.1 +0.4 0 ø • Jumbo Dome Pilot Light 30 min. 85 When mounting transformer or DC-DC converter type units on 30mm centers vertically and horizontally, keep the ambient temperature below 40ºC. 20 (091211) HW Series Illuminated Pushbuttons ø22 Round Flush Illuminated Pushbutton Shape Round Flush HW1L-M1 HW1L-A1 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter* Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter* Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC Type No. HW1L-M1➅10Q0➁ HW1L-M1➅01Q0➁ HW1L-M1➅11Q0➁ HW1L-M1➅20Q0➁ HW1L-M1➅02Q0➁ HW1L-M1➅22Q0➁ HW1L-M1➅11➂2➁ HW1L-M1➅20➂2➁ HW1L-M1➅02➂2➁ HW1L-M1➅22➂2➁ HW1L-M111D2➁ HW1L-M120D2➁ HW1L-M102D2➁ HW1L-M122D2➁ HW1L-M1➅11➂5➁ HW1L-M1➅20➂5➁ HW1L-M1➅02➂5➁ HW1L-M1➅22➂5➁ HW1L-A1➅10Q0➁ HW1L-A1➅01Q0➁ HW1L-A1➅11Q0➁ HW1L-A1➅20Q0➁ HW1L-A1➅02Q0➁ HW1L-A1➅22Q0➁ HW1L-A1➅11➂2➁ HW1L-A1➅20➂2➁ HW1L-A1➅02➂2➁ HW1L-A1➅22➂2➁ HW1L-A111D2➁ HW1L-A120D2➁ HW1L-A102D2➁ HW1L-A122D2➁ HW1L-A1➅11➂5➁ HW1L-A1➅20➂5➁ HW1L-A1➅02➂5➁ HW1L-A1➅22➂5➁ • Designation Code Specify designation codes ➁, ➂, and ➅ in the Type No. LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: PW: R: S: W: Y: amber green pure white red blue white yellow Use a pure white LED lamp for yellow illumination. Incandescent Illuminated Type ➂ Operating Voltage Code ➅ Terminal Style Code ➁ Lens Color Code Specify a lens color code in Specify an operating voltage code Specify a terminal style code in place of ➁ in the Type No. in place of ➂ in the Type No. place of ➅ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC F: Finger-safe (IP20) blank: Spring-up screw Only spring-up screw terminals are available on DC-DC converter types. Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). * DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). (0901211) 21 ø22 HW Series Illuminated Pushbuttons Round Extended Illuminated Pushbutton Shape Round Extended HW1L-M2 HW1L-A2 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter* Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter* Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC Type No. HW1L-M2➅10Q0➁ HW1L-M2➅01Q0➁ HW1L-M2➅11Q0➁ HW1L-M2➅20Q0➁ HW1L-M2➅02Q0➁ HW1L-M2➅22Q0➁ HW1L-M2➅11➂2➁ HW1L-M2➅20➂2➁ HW1L-M2➅02➂2➁ HW1L-M2➅22➂2➁ HW1L-M211D2➁ HW1L-M220D2➁ HW1L-M202D2➁ HW1L-M222D2➁ HW1L-M2➅11➂5➁ HW1L-M2➅20➂5➁ HW1L-M2➅02➂5➁ HW1L-M2➅22➂5➁ HW1L-A2➅10Q0➁ HW1L-A2➅01Q0➁ HW1L-A2➅11Q0➁ HW1L-A2➅20Q0➁ HW1L-A2➅02Q0➁ HW1L-A2➅22Q0➁ HW1L-A2➅11➂2➁ HW1L-A2➅20➂2➁ HW1L-A2➅02➂2➁ HW1L-A222➂2➁ HW1L-A211D2➁ HW1L-A220D2➁ HW1L-A202D2➁ HW1L-A222D2➁ HW1L-A2➅11➂5➁ HW1L-A2➅20➂5➁ HW1L-A2➅02➂5➁ HW1L-A2➅22➂5➁ • Designation Code Specify designation codes ➁, ➂, and ➅ in the Type No. LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: PW: R: S: W: Y: amber green pure white red blue white yellow Use a pure white LED lamp for yellow illumination. Incandescent Illuminated Type ➂ Operating Voltage Code ➅ Terminal Style Code ➁ Lens Color Code Specify a lens color code in Specify an operating voltage code Specify a terminal style code in place of ➁ in the Type No. place of ➅ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC F: Finger-safe (IP20) blank: Spring-up screw Only spring-up screw terminals are available on DC-DC converter types. Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). * DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 22 (091211) HW Series Illuminated Pushbuttons ø22 Round Extended with Full Shroud Illuminated Pushbutton Shape Round Extended with Full Shroud HW1L-MF2 HW1L-AF2 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter* Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter* Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC Type No. HW1L-MF2➅10Q0➁ HW1L-MF2➅01Q0➁ HW1L-MF2➅11Q0➁ HW1L-MF2➅20Q0➁ HW1L-MF2➅02Q0➁ HW1L-MF2➅22Q0➁ HW1L-MF2➅11➂2➁ HW1L-MF2➅20➂2➁ HW1L-MF2➅02➂2➁ HW1L-MF2➅22➂2➁ HW1L-MF211D2➁ HW1L-MF220D2➁ HW1L-MF202D2➁ HW1L-MF222D2➁ HW1L-MF2➅11➂5➁ HW1L-MF2➅20➂5➁ HW1L-MF2➅02➂5➁ HW1L-MF2➅22➂5➁ HW1L-AF2➅10Q0➁ HW1L-AF2➅01Q0➁ HW1L-AF2➅11Q0➁ HW1L-AF2➅20Q0➁ HW1L-AF2➅02Q0➁ HW1L-AF2➅22Q0➁ HW1L-AF2➅11➂2➁ HW1L-AF2➅20➂2➁ HW1L-AF2➅02➂2➁ HW1L-AF2➅22➂2➁ HW1L-AF211D2➁ HW1L-AF220D2➁ HW1L-AF202D2➁ HW1L-AF222D2➁ HW1L-AF2➅11➂5➁ HW1L-AF2➅20➂5➁ HW1L-AF2➅02➂5➁ HW1L-AF2➅22➂5➁ • Designation Code Specify designation codes ➁, ➂, and ➅ in the Type No. LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: PW: R: S: W: Y: amber green pure white red blue white yellow Use a pure white LED lamp for yellow illumination. Incandescent Illuminated Type ➂ Operating Voltage Code ➅ Terminal Style Code ➁ Lens Color Code Specify an operating voltage code Specify a terminal style code in Specify a lens color code in place of ➅ in the Type No. in place of ➂ in the Type No. place of ➁ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC F: Finger-safe (IP20) blank: Spring-up screw Only spring-up screw terminals are available on DC-DC converter types. Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). * DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). (0901211) 23 ø22 HW Series Illuminated Pushbuttons Square Flush Illuminated Pushbutton Shape Square Flush HW2L-M1 HW2L-A1 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter* Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter* Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC Type No. HW2L-M1➅10Q0➁ HW2L-M1➅01Q0➁ HW2L-M1➅11Q0➁ HW2L-M1➅20Q0➁ HW2L-M1➅02Q0➁ HW2L-M1➅22Q0➁ HW2L-M1➅11➂2➁ HW2L-M1➅20➂2➁ HW2L-M1➅02➂2➁ HW2L-M1➅22➂2➁ HW2L-M111D2➁ HW2L-M120D2➁ HW2L-M102D2➁ HW2L-M122D2➁ HW2L-M1➅11➂5➁ HW2L-M1➅20➂5➁ HW2L-M1➅02➂5➁ HW2L-M1➅22➂5➁ HW2L-A1➅10Q0➁ HW2L-A1➅01Q0➁ HW2L-A1➅11Q0➁ HW2L-A1➅20Q0➁ HW2L-A1➅02Q0➁ HW2L-A1➅22Q0➁ HW2L-A1➅11➂2➁ HW2L-A1➅20➂2➁ HW2L-A1➅02➂2➁ HW2L-A1➅22➂2➁ HW2L-A111D2➁ HW2L-A120D2➁ HW2L-A102D2➁ HW2L-A122D2➁ HW2L-A1➅11➂5➁ HW2L-A1➅20➂5➁ HW2L-A1➅02➂5➁ HW2L-A1➅22➂5➁ • Designation Code Specify designation codes ➁, ➂, and ➅ in the Type No. LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: PW: R: S: W: Y: amber green pure white red blue white yellow Use a pure white LED lamp for yellow illumination. Incandescent Illuminated Type ➂ Operating Voltage Code ➅ Terminal Style Code ➁ Lens Color Code Specify a lens color code in Specify an operating voltage code Specify a terminal style code in place of ➁ in the Type No. in place of ➂ in the Type No. place of ➅ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC F: Finger-safe (IP20) blank: Spring-up screw Only spring-up screw terminals are available on DC-DC converter types. Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). * DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 24 (091211) HW Series Illuminated Pushbuttons ø22 Round Flush with Square Bezel Illuminated Pushbutton Shape Round Flush with Square Bezel HW3L-M1 HW3L-A1 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter* Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter* Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC Type No. HW3L-M1➅10Q0➁ HW3L-M1➅01Q0➁ HW3L-M1➅11Q0➁ HW3L-M1➅20Q0➁ HW3L-M1➅02Q0➁ HW3L-M1➅22Q0➁ HW3L-M1➅11➂2➁ HW3L-M1➅20➂2➁ HW3L-M1➅02➂2➁ HW3L-M1➅22➂2➁ HW3L-M111D2➁ HW3L-M120D2➁ HW3L-M102D2➁ HW3L-M122D2➁ HW3L-M1➅11➂5➁ HW3L-M1➅20➂5➁ HW3L-M1➅02➂5➁ HW3L-M1➅22➂5➁ HW3L-A1➅10Q0➁ HW3L-A1➅01Q0➁ HW3L-A1➅11Q0➁ HW3L-A1➅20Q0➁ HW3L-A1➅02Q0➁ HW3L-A1➅22Q0➁ HW3L-A1➅11➂2➁ HW3L-A1➅20➂2➁ HW3L-A1➅02➂2➁ HW3L-A1➅22➂2➁ HW3L-A111D2➁ HW3L-A120D2➁ HW3L-A102D2➁ HW3L-A122D2➁ HW3L-A1➅11➂5➁ HW3L-A1➅20➂5➁ HW3L-A1➅02➂5➁ HW3L-A1➅22➂5➁ • Designation Code Specify designation codes ➁, ➂, and ➅ in the Type No. LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: PW: R: S: W: Y: amber green pure white red blue white yellow Use a pure white LED lamp for yellow illumination. Incandescent Illuminated Type ➂ Operating Voltage Code ➅ Terminal Style Code ➁ Lens Color Code Specify a lens color code in Specify an operating voltage code Specify a terminal style code in place of ➁ in the Type No. in place of ➂ in the Type No. place of ➅ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC F: Finger-safe (IP20) blank: Spring-up screw Only spring-up screw terminals are available on DC-DC converter types. Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). * DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). (0901211) 25 ø22 HW Series Illuminated Pushbuttons Mushroom (ø29mm) Illuminated Pushbutton Shape ø29mm Mushroom HW1L-M3 HW1L-A3 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter* Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter* Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC Type No. HW1L-M3➅10Q0➁ HW1L-M3➅01Q0➁ HW1L-M3➅11Q0➁ HW1L-M3➅20Q0➁ HW1L-M3➅02Q0➁ HW1L-M3➅22Q0➁ HW1L-M3➅11➂2➁ HW1L-M3➅20➂2➁ HW1L-M3➅02➂2➁ HW1L-M3➅22➂2➁ HW1L-M311D2➁ HW1L-M320D2➁ HW1L-M302D2➁ HW1L-M322D2➁ HW1L-M3➅11➂5➁ HW1L-M3➅20➂5➁ HW1L-M3➅02➂5➁ HW1L-M3➅22➂5➁ HW1L-A3➅10Q0➁ HW1L-A3➅01Q0➁ HW1L-A3➅11Q0➁ HW1L-A3➅20Q0➁ HW1L-A3➅02Q0➁ HW1L-A3➅22Q0➁ HW1L-A3➅11➂2➁ HW1L-A3➅20➂2➁ HW1L-A3➅02➂2➁ HW1L-A3➅22➂2➁ HW1L-A311D2➁ HW1L-A320D2➁ HW1L-A302D2➁ HW1L-A322D2➁ HW1L-A3➅11➂5➁ HW1L-A3➅20➂5➁ HW1L-A3➅02➂5➁ HW1L-A3➅22➂5➁ • Designation Code Specify designation codes ➁, ➂, and ➅ in the Type No. LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: PW: R: S: W: Y: amber green pure white red blue white yellow Use a pure white LED lamp for yellow illumination. Incandescent Illuminated Type ➂ Operating Voltage Code ➅ Terminal Style Code ➁ Lens Color Code Specify a lens color code in Specify an operating voltage code Specify a terminal style code in place of ➁ in the Type No. in place of ➂ in the Type No. place of ➅ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC F: Finger-safe (IP20) blank: Spring-up screw Only spring-up screw terminals are available on DC-DC converter types. Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). * DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 26 (091211) HW Series Illuminated Pushbuttons ø22 Mushroom (ø29mm) with Square Bezel Illuminated Pushbutton Shape ø29mm Mushroom with Square Bezel HW3L-M3 HW3L-A3 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter* Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter* Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC Type No. HW3L-M3➅10Q0➁ HW3L-M3➅01Q0➁ HW3L-M3➅11Q0➁ HW3L-M3➅20Q0➁ HW3L-M3➅02Q0➁ HW3L-M3➅22Q0➁ HW3L-M3➅11➂2➁ HW3L-M3➅20➂2➁ HW3L-M3➅02➂2➁ HW3L-M3➅22➂2➁ HW3L-M311D2➁ HW3L-M320D2➁ HW3L-M302D2➁ HW3L-M322D2➁ HW3L-M3➅11➂5➁ HW3L-M3➅20➂5➁ HW3L-M3➅02➂5➁ HW3L-M3➅22➂5➁ HW3L-A3➅10Q0➁ HW3L-A3➅01Q0➁ HW3L-A3➅11Q0➁ HW3L-A3➅20Q0➁ HW3L-A3➅02Q0➁ HW3L-A3➅22Q0➁ HW3L-A3➅11➂2➁ HW3L-A3➅20➂2➁ HW3L-A3➅02➂2➁ HW3L-A3➅22➂2➁ HW3L-A311D2➁ HW3L-A320D2➁ HW3L-A302D2➁ HW3L-A322D2➁ HW3L-A3➅11➂5➁ HW3L-A3➅20➂5➁ HW3L-A3➅02➂5➁ HW3L-A3➅22➂5➁ • Designation Code Specify designation codes ➁, ➂, and ➅ in the Type No. LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: PW: R: S: W: Y: amber green pure white red blue white yellow Use a pure white LED lamp for yellow illumination. Incandescent Illuminated Type ➂ Operating Voltage Code ➅ Terminal Style Code ➁ Lens Color Code Specify a lens color code in Specify an operating voltage code Specify a terminal style code in place of ➁ in the Type No. in place of ➂ in the Type No. place of ➅ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC F: Finger-safe (IP20) blank: Spring-up screw Only spring-up screw terminals are available on DC-DC converter types. Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). * DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). (0901211) 27 ø22 HW Series Illuminated Pushbuttons Mushroom (ø40mm) Illuminated Pushbutton Shape ø40mm Mushroom HW1L-M4 HW1L-A4 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter* Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter* Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC Type No. HW1L-M4➅10Q0➁ HW1L-M4➅01Q0➁ HW1L-M4➅11Q0➁ HW1L-M4➅20Q0➁ HW1L-M4➅02Q0➁ HW1L-M4➅22Q0➁ HW1L-M4➅11➂2➁ HW1L-M4➅20➂2➁ HW1L-M4➅02➂2➁ HW1L-M4➅22➂2➁ HW1L-M411D2➁ HW1L-M420D2➁ HW1L-M402D2➁ HW1L-M422D2➁ HW1L-M4➅11➂5➁ HW1L-M4➅20➂5➁ HW1L-M4➅02➂5➁ HW1L-M4➅22➂5➁ HW1L-A4➅10Q0➁ HW1L-A4➅01Q0➁ HW1L-A4➅11Q0➁ HW1L-A4➅20Q0➁ HW1L-A4➅02Q0➁ HW1L-A4➅22Q0➁ HW1L-A4➅11➂2➁ HW1L-A4➅20➂2➁ HW1L-A4➅02➂2➁ HW1L-A4➅22➂2➁ HW1L-A411D2➁ HW1L-A420D2➁ HW1L-A402D2➁ HW1L-A422D2➁ HW1L-A4➅11➂5➁ HW1L-A4➅20➂5➁ HW1L-A4➅02➂5➁ HW1L-A4➅22➂5➁ • Designation Code Specify designation codes ➁, ➂, and ➅ in the Type No. LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: PW: R: S: W: Y: amber green pure white red blue white yellow Use a pure white LED lamp for yellow illumination. Incandescent Illuminated Type ➂ Operating Voltage Code ➅ Terminal Style Code ➁ Lens Color Code Specify a lens color code in Specify an operating voltage code Specify a terminal style code in place of ➁ in the Type No. in place of ➂ in the Type No. place of ➅ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC F: Finger-safe (IP20) blank: Spring-up screw Only spring-up screw terminals are available on DC-DC converter types. Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). * DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 28 (091211) HW Series Illuminated Pushbuttons ø22 • Operator Panel Thickness 0.8 to 6 LO LO 3.6 X1 25 29.4 X2 LO CK 49.4 (1 block) 25 Full Voltage Adapter 3.6 ø2 13 29.4 18.5 Panel Thickness 0.8 to 6 Extended 41.4 ø23.5 2 contact blocks M3.5 Terminal Screw Contact Block Locking Ring 3.6 24.8 29.4 29.4 1 contact block CK ø2 ø2 13 LO CK CK Panel Thickness 0.8 to 6 Round with Square Bezel Square 29.6 41.4 M3.5 Terminal Screw Contact Block Locking Ring Round 25 1 contact block 41.4 Full Voltage Adapter 25 • Full Voltage Type 29.6 41.4 Dimensions LO 69.4 (2 blocks) 2 contact blocks Full Voltage Adapter .6 3 ø2 18.5 3 contact blocks Extended with Full Shroud 41.4 ø29.5 25 CK 29.4 LO Panel Thickness 0.8 to 6 Mushroom (ø29) 41.4 Locking Ring ø29 M3.5 Terminal Screw Contact Block 25 CK X1 13 23.2 29.4 LO X2 CK 69.4 (3 blocks) 25 Full Voltage Adapter M3.5 Terminal Screw Contact Block ø40 4 contact blocks 41.4 3 contact blocks 13 Locking Ring Panel Thickness 0.8 to 6 Mushroom (ø40) 29.4 23.2 All dimensions in mm. Terminal Wiring Arrows indicate access directions for wiring. Spring-up screw type 89.4 (4 blocks) 4 contact blocks • Transformer Type (240V AC maximum) Safety Lever Lock * * * * Locking Ring X1 3 4 X1 X2 M3.5 Terminal Screws Contact Block Full Voltage Adapter 79.5 (2 blocks)* 99.5 (4 blocks)* * Safety Lever Lock X1 *Spring-up screw type only (0901211) Locking Ring The above figures illustrate the spring-up screw types. X2 M3.5 Terminal Screw * Transformer • Transformer Type (380V AC minimum) • DC-DC Converter Type X1: Positive terminal X2: Negative terminal X2 89.5 (2 blocks) 109.5 (4 blocks) The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. *The depths of finger-safe (IP20) types are as follows: Transformer Type (240V AC maximum): 89.5 (2 blocks) 109.5 (4 blocks) 29 ø22 HW Series Dual Pushbuttons Dual Pushbuttons • Without Pilot Light Operation Type Button Style Flush (top) Flush (bottom) Contact Arrangement Top Bottom Button Button 1NO 1NC HW7D-B11➅1001➃➄ 1NO 1NO HW7D-B11➅1010➃➄ 1NO-1NC Momentary Flush (top) Extended (bottom) 2NC HW7D-B11➅2002➃➄ 2NO 2NO HW7D-B11➅2020➃➄ 1NO 1NC HW7D-B12➅1001➃➄ 1NO 1NO HW7D-B12➅1010➃➄ Interlock Flush (top) Extended (bottom) 2NC HW7D-B12➅2002➃➄ 2NO 2NO HW7D-B12➅2020➃➄ 1NO 1NC HW7D-B21➅1001➃➄ 1NO 1NO HW7D-B21➅1010➃➄ GR: Green (top) Red (bottom) Blank: Without legend 1: WB: White (top) Black (bottom) I/ON (top) O/OFF (bottom) 1NO-1NC HW7D-B21➅1111➃➄ 2NO 2NC HW7D-B21➅2002➃➄ 2NO 2NO HW7D-B21➅2020➃➄ 1NO 1NC HW7D-B22➅1001➃➄ 1NO 1NO HW7D-B22➅1010➃➄ 1NO-1NC ➄ Legend Code 1NO-1NC HW7D-B12➅1111➃➄ 2NO 1NO-1NC ➃ Button Color Code 1NO-1NC HW7D-B11➅1111➃➄ 2NO 1NO-1NC Flush (top) Flush (bottom) Type No. 1NO-1NC HW7D-B22➅1111➃➄ 2NO 2NC HW7D-B22➅2002➃➄ 2NO 2NO HW7D-B22➅2020➃➄ • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw Momentary: Two independent momentary switches are contained in one unit. The contact operates when the button is pressed. When the button is released, the contact goes back to the original position. Interlock: Momentary operation. When one of the buttons are pressed, the other button cannot be operated. Do not operate top and bottom buttons at the same time. Operating the buttons at the same time may lead to malfunctions. Other contact arrangements and gold-plated silver contacts are also available. See page 8. 30 (091211) HW Series Dual Pushbuttons ø22 Dual Pushbuttons • With Pilot Light Operation Type Lamp Input Type Without Lamp Full Voltage Transformer Momentary LED DC-DC Converter Incandescent Transformer Without Lamp Full Voltage Transformer Interlock LED DC-DC Converter Incandescent Transformer • Designation Codes Specify designation codes ➀ to ➅ in the Type No. ➀ Button Style Code 1: Flush (top) Flush (bottom) 2: Flush (top) Extended (bottom) ➁ Operating Voltage Code H: 100/110V AC H2: 115/120V AC M: 200/220V AC M4: 230/240V AC S: 380V AC T: 400/440V AC T8: 480V AC Contact Arrangement Top Button Bottom Button 1NO 1NC 1NO 1NO 1NO-1NC 1NO-1NC 2NO 2NC 2NO 2NO 1NO 1NC 1NO 1NO 1NO-1NC 1NO-1NC 2NO 2NC 2NO 2NO 1NO 1NC 1NO 1NO 1NO-1NC 1NO-1NC 2NO 2NC 2NO 2NO 1NO 1NC 1NO 1NO 1NO-1NC 1NO-1NC 2NO 2NC 2NO 2NO 1NO 1NC 1NO 1NO 1NO-1NC 1NO-1NC 2NO 2NC 2NO 2NO 1NO 1NC 1NO 1NO 1NO-1NC 1NO-1NC 2NO 2NC 2NO 2NO 1NO 1NC 1NO 1NO 1NO-1NC 1NO-1NC 2NO 2NC 2NO 2NO 1NO 1NC 1NO 1NO 1NO-1NC 1NO-1NC 2NO 2NC 2NO 2NO ➂ Lamp Color Code A: amber G: green R: red S: blue W: white The lens is white only. ➃ Button Color Code GR: Green (top) Red (bottom) WB: White (top) Black (bottom) Type No. HW7D-L1➀➅1001Q0W➃➄ HW7D-L1➀➅1010Q0W➃➄ HW7D-L1➀➅1111Q0W➃➄ HW7D-L1➀➅2002Q0W➃➄ HW7D-L1➀➅2020Q0W➃➄ HW7D-L1➀➅1001➁2➂➃➄ HW7D-L1➀➅1010➁2➂➃➄ HW7D-L1➀➅1111➁2➂➃➄ HW7D-L1➀➅2002➁2➂➃➄ HW7D-L1➀➅2020➁2➂➃➄ HW7D-L1➀1001D2➂➃➄ HW7D-L1➀1010D2➂➃➄ HW7D-L1➀1111D2➂➃➄ HW7D-L1➀2002D2➂➃➄ HW7D-L1➀2020D2➂➂➄ HW7D-L1➀➅1001➁5W➃➄ HW7D-L1➀➅1010➁5W➃➄ HW7D-L1➀➅1111➁5W➃➄ HW7D-L1➀➅2002➁5W➃➄ HW7D-L1➀➅2020➁5W➃➄ HW7D-L2➀➅1001Q0W➃➄ HW7D-L2➀➅1010Q0W➃➄ HW7D-L2➀➅1111Q0W➃➄ HW7D-L2➀➅2002Q0W➃➄ HW7D-L2➀➅2020Q0W➃➄ HW7D-L2➀➅1001➁2➂➃➄ HW7D-L2➀➅1010➁2➂➃➄ HW7D-L2➀➅1111➁2➂➃➄ HW7D-L2➀➅2002➁2➂➃➄ HW7D-L2➀➅2020➁2➂➃➄ HW7D-L2➀1001D2➂➃➄ HW7D-L2➀1010D2➂➃➄ HW7D-L2➀1111D2➂➃➄ HW7D-L2➀2002D2➂➃➄ HW7D-L2➀2020D2➂➃➄ HW7D-L2➀➅1001➁5W➃➄ HW7D-L2➀➅1010➁5W➃➄ HW7D-L2➀➅1111➁5W➃➄ HW7D-L2➀➅2002➁5W➃➄ HW7D-L2➀➅2020➁5W➃➄ ➄ Legend Code Blank: Without legend ➅ Terminal Style Code F: Finger-safe (IP20) blank: Spring-up screw Only spring-up 1: I/ON (top) screw terminals are O/OFF (bottom) available on DC-DC converter types. Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➂, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). (0901211) 31 ø22 HW Series Dual Pushbuttons Dimensions HW Without Pilot Light 49.4 (2 contacts) 69.4 (3 or 4 contacts) Panel Thickness 0.8 to 6 Safety Lever Lock Locking Ring Without Button Markings With Button Markings (I/ON and O/OFF) Rubber Gasket 0.5 54.8 54.8 41.4 ON OFF 29.8 14.5 20 29.8 With Pilot Light • Full Voltage Full Voltage Adapter HW (Bottom Button) (Top Button) 69.4 (2 contacts), 89.4 (4 contacts) (Note) Note: The depth of 3-contact type depends on the combination of contact blocks at top and bottom pushbuttons Top Button 1 contact block 2 contact blocks Bottom Button 2 contact blocks 1 contact block Depth 89.4 mm 69.4 mm • Transformer (240V AC maximum) Transformer HW 79.5 (2 contacts)∗, 99.5 (4 contacts)∗ • Transformer (380V AC minimum) • DC-DC Converter Transformer, DC-DC Converter HW 89.5 (2 contacts), 109.5 (4 contacts) All dimensions in mm. The above figures illustrate the spring-up screw types. The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. *The depths of finger-safe (IP20) types are as follows: Transformer Type (240V AC maximum): 89.5 (2 blocks) 109.5 (4 blocks) 32 (091211) HW Series Dual Pushbuttons ø22 Contact Arrangement Chart Top Button Contact Arrangement Bottom Button Contact Code 1NO 1NO 1010 1NO 1NC 1NC 1001 1NO 1NC 0110 1NC 1NO 0101 2NO 1NO 1020 1NO-1NC 1NO 1011 2NC 1NC 1002 2NO 1NC 0120 1NO-1NC 1NC 0111 2NC 2NO 0102 1NO 2NO 2010 1NC 1NO-1NC 2001 1NO 1NO-1NC 1110 1NC 1101 Contact Block Mounting Position Type 1 NO 2 NO NO 1 NC 2 NC 1 2 NO NC 1 NC 2 NO 1 2 NO 3 Dummy NO 4 NO 1 NO 2 3 Dummy 4 NC NO 1 NC 2 Dummy 3 4 NC NC 1 NO 2 Dummy 3 NO 4 1 NC 2 NO 3 Dummy NC 4 NC 1 NC 2 3 Dummy NC 4 1 NO NO 2 3 NO Dummy 4 1 NO NC 2 NO 3 Dummy 4 1 NO NO 2 3 NC Dummy 4 1 NO NC 2 NC 3 Dummy 4 Top Button Normal Push ● Bottom Button Normal Push ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● • Transformer and DC-DC converter types can have two or four contact blocks only. • Contact blocks 1 and 3 are actuated by the top button. Contact blocks 2 and 4 are actuated by the bottom button. • Contact Block Mounting Position and Contact Arrangement Chart 4 3 1 Without Pilot Light With Pilot Light (transformer type) (0901211) 4 2 3 2 1 With Pilot Light (full voltage type) Full Voltage Adapter Contact Block 1 2 3 4 NO NO NC NC Top Button Normal Push ● Bottom Button Normal Push ● ● ● • Type No. Development HW7D - B 12 11 11 GR Contact code (1NO-1NC) of bottom button Contact code (1NO-1NC) of top button 33 ø22 HW Series Dual Pushbuttons Contact Arrangement Chart Top Button Contact Arrangement Bottom Button Contact Code 2NC 1NO 0210 2NC 2NO 2NO 2NO 1NO-1NC 1NO-1NC 1NO-1NC 2NC 2NC 2NC 34 1NC 2NO 1NO-1NC 2NC 2NO 1NO-1NC 2NC 2NO 1NO-1NC 2NC 0201 2020 2011 2002 1120 1111 1102 0220 0211 0202 Contact Block Mounting Position Type NC 1 2 NO 3 NC 4 Dummy NC 1 NC 2 NC 3 4 Dummy NO 1 NO 2 NO 3 4 NO 1 NO NO 2 NO 3 NC 4 1 NO 2 NC 3 NO NC 4 NO 1 NO 2 3 NC NO 4 1 NO NO 2 3 NC NC 4 1 NO NC 2 3 NC NC 4 1 NC NO 2 3 NC NO 4 1 NC NO 2 NC 3 NC 4 NC 1 2 NC 3 NC 4 NC Top Button Normal Push ● Bottom Button Normal Push ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● (091211) HW Series Selector Switches ø22 90º 2-position / 60º 2-position No. of Positions Selector Switches Contact Arrangement Chart Contact Code 10 (1NO) 11 (1NO-1NC) 20 (2NO) 22 (2NO-2NC) Contact Code 20 (2NO) 02 (2NC) 45º 3-position 22N1 (2NO-2NC) 22N9 H (2NO-2NC) 40 (4NO) 40N2 H (4NO) 04 (4NC) 21N1 H (2NO-1NC) Contact Code 30º 5-position / 45º 4-position HW1S Shape 13N6 H (1NO-3NC) 22N3 H (2NO-2NC) 12 H (1NO-2NC) 22N3 H (2NO-2NC) Contact Block Mounting Position 1 2 1 2 1 2 1 2 3 4 Type 1 2 1 2 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 NO NO NC NO NO NO NC NO NC Dummy 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 Type NC NC NC NO NO NC NC NO NO NC NC ● HW1S-2T➅11 HW1S-21T➅11 ● ● ● HW1S-2T➅20 HW1S-21T➅20 HW1S-2T➅22 HW1S-21T➅22 Operator Position C L R ● C R Spring Return from Right C L — — — Spring Return from Left Spring Return Two-way R L C L R C R HW1S-3T➅20 HW1S-31T➅20 HW1S-32T➅20 HW1S-33T➅20 HW1S-3T➅02 HW1S-31T➅02 HW1S-32T➅02 HW1S-33T➅02 HW1S-3T➅22N1 HW1S-31T➅22N1 HW1S-32T➅22N1 HW1S-33T➅22N1 ● ● ● ● — HW1S-3ST➅22N9 — — ● ● ● HW1S-3T➅40 ● HW1S-31T➅40 HW1S-32T➅40 HW1S-33T➅40 ● ● — HW1S-3ST➅40N2 ● — — ● HW1S-3T➅04 HW1S-31T➅04 HW1S-32T➅04 HW1S-33T➅04 ● ● Operator Position 1 2 3 — HW1S-3JT➅21N1 ● 4 5 ● ● Maintained 1 2 3 4 — Maintained 1 2 3 HW1S-4T➅13N6 — HW1S-4T➅22N3 — 4 5 — • Contact Block Mounting Position and Contact Arrangement Chart 4 2 ● ● ● ● 3 ● 1 Left ● ● HW1S-4T➅12 ● Dummy NO NC NC NO Maintained — R HW1S-21T➅10 ● ● L HW1S-2T➅10 ● NO NO NC NC NO NO NC NC NC NC NO NO NO NO NO NO NO NO NO NO NC NC NC NC NO NO NC R Dimensions on page 39. Spring Return from Right (60º) ● ● L Maintained (90º) L R ● Type Contact Block Mounting Position L Dummy Contact Block Mounting Position Operator Position — ● ● — ● ● HW1S-5T➅22N3 1 2 3 4 NO NO NC NC Center L ● C Right R Operator Position ● • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw • On the contact arrangement marked with H in the table above, the rated current (load switching current) is reduced to a half of the rated current of the contact block. The rated insulation voltage and the rated thermal current remain unchanged. • Selector switches with one or three contact blocks contain a dummy block. Knob operator: White indicator on black body • Other contact arrangements are also available. See pages 40 through 43. (0901211) 35 ø22 HW Series Selector Switches 90º 2-position / 60º 2-position No. of Positions Key Selector Switches Contact Arrangement Chart Contact Code 10 (1NO) 11 (1NO-1NC) 20 (2NO) 22 (2NO-2NC) Contact Code 20 (2NO) 02 (2NC) 22N1 (2NO-2NC) 45º 3-position HW1K Shape 22N9 H (2NO-2NC) 40 (4NO) 40N2 H (4NO) 04 (4NC) 21N1 H (2NO-1NC) Contact Block Mounting Position 1 2 1 2 1 2 1 2 3 4 Operator Position Type L NO L R NO NC NO NO NO NC NO NC Mounting Position ● HW1K-2A➅11 HW1K-21B➅11 ● ● ● HW1K-2A➅20 HW1K-21B➅20 HW1K-2A➅22 HW1K-21B➅22 ● ● 1 2 1 2 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 L NO NO NC NC NO NO NC NC NC NC NO NO NO NO NO NO NO NO NO NO NC NC NC NC NO NO NC ● C C L R ● Spring Return from Right Maintained Operator Position L R — — — — Spring Return from Left Spring Return Two-way R HW1K-21B➅10 ● Type L HW1K-2A➅10 ● Contact Block R ● Dummy Dimensions on page 39. Spring Return from Right (60º) Maintained (90º) C R L C R L C R HW1K-3A➅20 HW1K-31B➅20 HW1K-32C➅20 HW1K-33D➅20 HW1K-3A➅02 HW1K-31B➅02 HW1K-32C➅02 HW1K-33D➅02 HW1K-3A➅22N1 HW1K-31B➅22N1 HW1K-32C➅22N1 HW1K-33D➅22N1 ● ● ● ● — HW1K-3SA➅22N9 — — ● ● ● HW1K-3A➅40 ● HW1K-31B➅40 HW1K-32C➅40 HW1K-33D➅40 ● ● — HW1K-3SA➅40N2 ● — — ● HW1K-3A➅04 HW1K-31B➅04 HW1K-32C➅04 HW1K-33D➅04 ● ● — HW1K-3JA➅21N1 ● — — Dummy • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw • On the spring-returned types, the key can be released only from the maintained position. On the maintained types, the key can be released from every position. Key retained positions are also available. See page 8. • Each key selector switch is supplied with two identical keys. Three different keys are also available. See page 8. • On the contact arrangement marked with H in the table above, the rated current (load switching current) is reduced to a half of the rated current of the contact block. The rated insulation voltage and the rated thermal current remain unchanged. • Key selector switches with one or three contact blocks contain a dummy block. • Cylinder cover: black, Cylinder: metal • Other contact arrangements are also available. See pages 40 through 43. • Contact Block Mounting Position and Contact Arrangement Chart 4 3 36 1 2 Left 1 2 3 4 NO NO NC NC Center L ● C Right R Operator Position ● (091211) HW Series Selector Switches ø22 Illuminated Selector Switches 90º 2-position / 60º 2-position HW1F Shape Contact Arrangement Chart Contact Block Contact Code Mounting Position Type 1 NO 2 NC 11 (1NO-1NC) 20 (2NO) L ● Input Type Without Lamp Full Voltage HW1F-2➅11Q0➁ Transformer HW1F-2➅11➂2➁ HW1F-211D2➁ HW1F-2111D2➁ Incandescent Transformer HW1F-2➅11➂5➁ HW1F-21➅11➂5➁ Full Voltage HW1F-2➅20Q0➁ HW1F-21➅20Q0➁ HW1F-2➅20➂2➁ HW1F-21➅20➂2➁ LED ● ● Without Lamp 2 NO ● LED 3 ● NC ● NO 4 Transformer DC-DC Converter LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: R: S: W: Y: amber green red blue white yellow R L R HW1F-21➅11Q0➁ HW1F-21➅11➂2➁ HW1F-220D2➁ HW1F-2120D2➁ Incandescent Transformer HW1F-2➅20➂5➁ HW1F-21➅20➂5➁ ● Without Lamp Full Voltage HW1F-2➅22Q0➁ HW1F-21➅22Q0➁ ● LED HW1F-2➅22➂2➁ HW1F-21➅22➂2➁ HW1F-2➅22➂5➁ HW1F-21➅22➂5➁ Transformer DC-DC Converter Incandescent • Designation Codes L DC-DC Converter NO NO NC Dimensions on page 39. Spring Return from Right Maintained (90º) (60º) Lamp R 1 1 2 22 (2NO-2NC) Operator Position HW1F-222D2➁ Transformer HW1F-2122D2➁ Incandescent Illuminated Type ➂ Operating Voltage Code ➅ Terminal Style Code ➁ Lens Color Code Specify a lens color code in Specify an operating voltage code Specify a terminal style code in place of ➁ in the Type No. in place of ➂ in the Type No. place of ➅ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC F: Finger-safe (IP20) blank: Spring-up screw Only spring-up screw terminals are available on DC-DC converter types. Use a pure white LED lamp for yellow illumination. • Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. • LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). • Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). • Contact Block Mounting Position and Contact Arrangement Chart 4 3 2 1 Full Voltage Type (0901211) Transformer Full Voltage Adapter 4 3 1 Transformer Type Right Left 2 1 2 3 4 NO NO NC NC L ● R Operator Position ● For more contact arrangement chart, see pages 41 and 42. 37 ø22 HW Series Selector Switches 45º 3-position Contact Block Contact Code Operator Position Mounting Position Type L 1 NO ● 20 (2NO) 2 02 (2NC) NO 1 NC 2 NC 1 2 3 4 22N1 (2NO-2NC) NO NO NC NC 1 2 3 4 40 (4NO) NO NO NO NO 1 2 3 4 04 (4NC) C ● ● ● ● ● LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁in the Type No. A: G: R: S: W: Y: ● NC NC NC NC • Designation Codes Input Type R ● Spring Return from Right Maintained L Without Lamp Full Voltage Transformer LED DC-DC Converter Incandescent Transformer Without Lamp Full Voltage Transformer LED DC-DC Converter Incandescent Transformer Without Lamp Full Voltage Transformer LED DC-DC Converter Incandescent Transformer Without Lamp Full Voltage Transformer LED DC-DC Converter Incandescent Transformer Without Lamp Full Voltage Transformer LED DC-DC Converter Incandescent Transformer C R L C Spring Return from Left R L C R Spring Return Two-way L C R HW1F-3➅20Q0➁ HW1F-31➅20Q0➁ HW1F-32➅20Q0➁ HW1F-33➅20Q0➁ HW1F-3➅20➂2➁ HW1F-320D2➁ HW1F-31➅20➂2➁ HW1F-3120D2➁ HW1F-32➅20➂2➁ HW1F-3220D2➁ HW1F-33➅20➂2➁ HW1F-3320D2➁ HW1F-3➅20➂5➁ HW1F-31➅20➂5➁ HW1F-32➅20➂5➁ HW1F-33➅20➂5➁ HW1F-3➅02Q0➁ HW1F-31➅02Q0➁ HW1F-32➅02Q0➁ HW1F-33➅02Q0➁ HW1F-3➅02➂2➁ HW1F-302D2➁ HW1F-31➅02➂2➁ HW1F-3102D2➁ HW1F-32➅02➂2➁ HW1F-3202D2➁ HW1F-33➅02➂2➁ HW1F-3302D2➁ HW1F-3➅02➂5➁ HW1F-31➅02➂5➁ HW1F-32➅02➂5➁ HW1F-33➅02➂5➁ HW1F-3➅22N1Q0➁ HW1F-31➅22N1Q0➁ HW1F-32➅22N1Q0➁ HW1F-33➅22N1Q0➁ HW1F-3➅22N1➂2➁ HW1F-31➅22N1➂2➁ HW1F-32➅22N1➂2➁ HW1F-33➅22N1➂2➁ HW1F-322N1D2➁ HW1F-3122N1D2➁ HW1F-3222N1D2➁ HW1F-3322N1D2➁ HW1F-3➅22N1➂5➁ HW1F-31➅22N1➂5➁ HW1F-32➅22N1➂5➁ HW1F-33➅22N1➂5➁ HW1F-3➅40Q0➁ HW1F-31➅40Q0➁ HW1F-32➅40Q0➁ HW1F-33➅40Q0➁ HW1F-3➅40➂2➁ HW1F-340D2➁ HW1F-31➅40➂2➁ HW1F-3140D2➁ HW1F-32➅40➂2➁ HW1F-3240D2➁ HW1F-33➅40➂2➁ HW1F-3340D2➁ HW1F-3➅40➂5➁ HW1F-31➅40➂5➁ HW1F-32➅40➂5➁ HW1F-33➅40➂5➁ HW1F-3➅04Q0➁ HW1F-31➅04Q0➁ HW1F-32➅04Q0➁ HW1F-33➅04Q0➁ HW1F-3➅04➂2➁ HW1F-304D2➁ HW1F-31➅04➂2➁ HW1F-3104D2➁ HW1F-32➅04➂2➁ HW1F-3204D2➁ HW1F-33➅04➂2➁ HW1F-3304D2➁ HW1F-3➅04➂5➁ HW1F-31➅04➂5➁ HW1F-32➅04➂5➁ HW1F-33➅04➂5➁ Incandescent Illuminated Type ➂ Operating Voltage Code ➅ Terminal Style Code ➁ Lens Color Code Specify a lens color code in Specify an operating voltage code Specify a contact block code in place of ➁ in the Type No. in place of ➂ in the Type No. place of ➅ in the Type No. A: G: R: S: W: amber green red blue white yellow amber green red blue white H: H2: M: M4: S: T: T8: Use a pure white LED lamp for yellow illumination. 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC F: Finger-safe (IP20) blank: Spring-up screw Only spring-up screw terminals are available on DC-DC converter types. • Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 51. • LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). • Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). • Contact Block Mounting Position and Contact Arrangement Chart 4 3 2 1 Full Voltage Type 38 Left Transformer Full Voltage Adapter 4 3 2 1 1 2 3 4 NO NO NC NC Center L ● C Right R Operator Position ● For more contact arrangement chart, see pages 41 and 42. Transformer Type (091211) HW Series Selector Switches ø22 Dimensions: Selector Switches Panel Thickness 0.8 to 6 • Knob Operator Gasket M3.5 Terminal Screw LO Locking Ring CK 9 1 contact block 49.4 (1 or 2 blocks) 2 contact blocks 4 contact blocks 69.4 (3 or 4 blocks) 7 • Key Operator 41.4 ø28.8 25 ø2 29.4 21 LO CK 4 9. 17 41.4 25 ø2 13 29.4 30.5 The above figures illustrates the spring-up screw types. All dimensions in mm. The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. Dimensions: Illuminated Selector Switches M3.5 Terminal Screw LO CK 9 ø2 41.4 25 • Full Voltage Type 69.4 (2 blocks) 89.4 (4 blocks) 7 29.4 21 • Transformer Type (240V AC maximum) LO CK 9 3 4 41.4 25 ø2 X1 X2 79.5 (2 blocks)∗ 99.5 (4 blocks)∗ M.3.5 Terminal Screw 7 21 29.4 The above figures illustrate the spring-up screw types. The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. *The depth of finger-safe (IP20) types are as follows: Transformer Type: 89.5 (2 blocks) 109.5 (4 blocks) For dimensions of transformer types (380V AC minimum) and DC-DC converter types, see page 29. All dimensions in mm. Terminal Wiring Arrows indicate access directions for wiring. Spring-up screw type * * * * Contact Block Full Voltage Adapter (0901211) * X1 X2 Transformer * *Spring-up screw type only. 39 ø22 HW Series Selector Switch Contact Arrangement Charts 90º 2-position (Maintained) / 60º 2-position (Spring Return) 40 (4NO) 7S H (1NO-1NC) 8S H (2NO-2NC) 22N7 H (2NO-2NC) Cam Code 31N1 (3NO-1NC) Illuminated 22N4 (2NO-2NC) Remarks Key 22N1 (2NO-2NC) NO Dummy NC Dummy NO NC NC NO NO NO NC NC NO NC NO NC NC NO NC NO NO NO NC NC NC NO NO NC NC NO NO NO NO NO NO NO NO NC NO NC NO NC NC NO NC NO R Knob 22N2 (2NO-2NC) 1 2 1 2 1 2 1 2 1 2 1 2 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 1 2 3 4 1 2 3 4 L L R Illuminated 22 (2NO-2NC) Type Operator Availability L Key 10 (1NO) 01 (1NC) 11 (1NO-1NC) 11N1 (2NO-2NC) 20 (2NO) 02 (2NC) Mounting Position Operator Position Knob Contact Code Contact Block × × × × ­× × — Standard × × × × ­— × — × × × × ­× × — × × × × ­— × — × × × × ­× × — × × × × ­— × — × × × × ­— × – × × × × ­— × ­— × × × × ­— × ­— ● ● × × × × ­— × ­— ● ● ● ● ● ● ● × × × × ­— × ­— × × × × ­— × ­— × × × × ­— × ­— × × × × ­— × ­— × × × × ­— × ­— R ● ● ● ● ● ● ● ● ● ● Standard Standard ● ● ● Standard ● ● ● ● ● ● ● ● ● ● ● ● • On the contact arrangement marked with H in the table above, the rated current (load switching current) is reduced to a half of the rated current of the contact block. The rated insulation voltage and the rated thermal current remain unchanged. Remarks: When ordering the contact arrangement indicated with “Standard” in the table above, specify the Type No. shown in the standard Type No. on preceding pages. For other contact arrangements, see page 43 to specify the Type No. and contact code. 40 (091211) HW Series Selector Switch Contact Arrangement Charts ø22 45º 3-position Cam Code R Illuminated C Key L Knob R Illuminated C Key L Knob R R Illuminated C C Key L L Knob Type R Illuminated Mounting Position L C Key Contact Code Operator Availability Knob Contact Block Operator Position Remarks NO 1 ● × × × × × × × × × × ­× × — NC 2 1 NC × × × × × × × × × × ­× × — 2 NO ● 1 ● ● NO × × × — — — — — — — ­— — J 2 NC NC 1 ● × × × — — — — — — — ­— — J 2 NO ● 1 NO ● × × × × × × × × × × × × — Standard NO 2 ● 1 ● ● NO × × × — — — — — — — ­— — J NO 2 ● 1 NC ● × × × — — — — — — — ­— — J 2 NO NC 3 × × × × × × × × × × ­× × ­— Standard NC 4 1 NO ● NO 2 ● 22N1 × × × × × × × × × × ­× × ­— Standard (2NO-2NC) NC 3 4 NC 1 NC NO 2 ● 22N2 × × × × × × × × × × ­× × ­— (2NO-2NC) 3 NC NO 4 ● 1 ● ● NO 2 NC 8S H × × × — — — — — — — ­— — ­J (2NO-2NC) 3 ● ● NO 4 NC 1 ● ● NO 2 NC 22N8 H × × × — — — — — — — ­— — ­J (2NO-2NC) NC 3 ● 4 NO ● 1 NC ● 2 NO ● 22N2 H × × × — — — — — — — ­— — ­J (2NO-2NC) NC 3 ● NO 4 ● 1 NO ● NC 2 31 × × × × × × × × × × ­× × ­— (3NO-1NC) 3 NO ● NO 4 ● NC 1 NO 2 ● 31N1 × × × × × × × × × × ­× × ­— (3NO-1NC) 3 NO ● 4 NO ● NO 1 ● NC 2 13 × × × × × × × × × × ­× × ­— (1NO-3NC) NC 3 4 NC NC 1 ● 2 NO ● 13N3 H × × × — — — — — — — ­— — ­J (1NO-3NC) 3 NC ● 4 NC Remarks: When ordering the contact arrangement indicated with “Standard” in the table above, specify the Type No. shown in the standard Type No. on preceding pages. For other contact arrangements, see page 43 to specify the Type No. and contact code. 11 (1NO-1NC) 11N1 (1NO-1NC) 7S H (1NO-1NC) 11N1 H (1NO-1NC) 20 (2NO) 1S H (2NO) 2S H (2NC) 02 (2NC) (0901211) 41 ø22 HW Series Selector Switch Contact Arrangement Charts 45º 3-position Cam Code R Illuminated C Key L Knob R Illuminated C Key L Knob R Illuminated R C Key C L Knob L R Illuminated Type L C Key Mounting Position Operator Availability Knob Contact Code Contact Block Operator Position Remarks NO 1 ● NO 2 ● × × × × × × × × × × ­× × ­— Standard 3 NO ● 4 NO ● NO 1 ● ● NO 2 ● 40N1 H × × × — — — — — — — ­— — ­J (4NO) 3 NO ● ● 4 NO ● NC 1 NC 2 04 × × × × × × × × × × ­× × ­— Standard (4NC) 3 NC 4 NC NC 1 ● NC 2 04N2 H × × × — — — — — — — ­— — ­J (4NC) NC 3 ● 4 NC 1 NO ● 2 NC ● 22 H × × × — — — — — — — ­— — ­J (2NO-2NC) NO 3 ● NC 4 ● 1 NO ● 2 NO ● 21N1 H × × × — — — — — — — ­— — S Standard (2NO-1NC) 3 NC ● Dummy 4 NO 1 ● 2 NO 40N2 H × × × — — — — — — — ­— — S Standard (4NO)) 3 NO ● 4 NO ● 1 NC ● NC 2 ● 22N9 H × × × — — — — — — — ­— — ­J Standard (2NO-2NC) NO 3 4 NO ● 1 NO ● 2 NC 31N4 H × × × — — — — — — — ­— — ­J (3NO-1NC) NO 3 ● ● NO 4 ● 1 NO ● NC 2 13N1 H × × × — — — — — — — ­— — ­J (1NO-3NC) 3 NC ● NC 4 NC 1 NO 2 ● 22N5 H × × × — — — — — — — ­— — ­J (2NO-2NC) 3 NC ● 4 NO ● NO 1 ● NO 2 ● 31N2 H × × × — — — — — — — ­— — ­J (3NO-1NC) NC 3 ● 4 NO ● NC 1 NC 2 13N2 H × × × — — — — — — — ­— — ­J (1NO-3NC) 3 NC ● 4 NO ● Remarks: When ordering the contact arrangement indicated with “Standard” in the table above, specify the Type No. shown in the standard Type No. on preceding pages. For other contact arrangements, see page 43 to specify the Type No. and contact code. 40 (4NO) 42 (091211) HW Series Selector Switch Contact Arrangement Charts ø22 45º 4-position Operator Availability Operator Position Cam Code Contact Block Remarks ● × ­— Standard ● × — ● × ­— ● × — ● × — 1 2 3 4 Mounting Position Type 1 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 NO NC NC Dummy NC NC NC NC NC NC NC NO NO NC NC NC NO NC NC NO ● 12 H (1NO-2NC) 04N3 H (4NC) 13N6 H (1NO-3NC) 13N5 H (1NO-3NC) 22N3 H (2NO-2NC) 2 3 4 Knob ● ● ● ● ● ● ● ● Operator Availability Operator Position Contact Block 1 Mounting Position Type 1 1 2 3 4 NO NC NC NO ● 22N3 H (2NO-2NC) Standard ● 30º 5-position Contact Code Standard 2 3 4 5 2 3 4 Knob ● × ● 5 Cam Code Contact Code Remarks ­— Standard ● • Contact Block Mounting Position and Contact Arrangement Chart 4 3 4 2 3 1 Non-illuminated Selector Illuminated Selector (Transformer Type) Contact code (1NO-1NC) 2-position (0901211) 1 2 3 4 1 • When cam code is not required “T” for knob operator Left Full Voltage Adapter NO NO NC NC Center L ● C Right R Operator Position ● Illuminated Selector (Full Voltage Type) Type No. Development HW1S - 2 T F 11 2 • When cam code is required HW1K - 3 J A F 22N2 Contact code (2NO-2NC) Key removal option code Cam code (J, S, or none) 3-position 43 ø22 HW Series Pushbuttons Selectors Pushbutton Selectors Circuit Category Shape Contact Code Contact Block Mounting Position Type ➀ Button Color Code Type No. Normal Depressed Normal Depressed NO 1 ● ● HW1R-2A➅11➀ NC 2 ● 1 NO ● ● HW1R-2A➅20➀ 2 NO ● A NO 1 ● ● NC 2 ● 22 HW1R-2A➅22➀ (2NO-2NC) NO 3 ● ● 4 NC ● 1 NO ● 20 HW1R-2D➅20➀ (2NO) NO 2 ● Specify a NO 1 ● D button color NO 2 ● 22N1 HW1R-2D➅22N1➀ code in place (2NO-2NC) NC 3 ● of ➀ in the 4 NC ● Type No. 1 NO ● B: black NO 2 ● 22N1 H E HW1R-2E➅22N1➀ G: green (2NO-2NC) NC 3 R: red 4 NC S: blue 1 NO ● W: white NO 2 ● 22N1 H Y: yellow F HW1R-2F➅22N1➀ (2NO-2NC) NC 3 ● NC 4 ● 1 NC ● NO 2 ● ● 22N2 H N HW1R-2N➅22N2➀ (2NO-2NC) 3 NC ● NO 4 ● ● NO 1 ● ● NO 2 ● ● 22N1 H Blocked HW1R-2T➅22N1➀ T (2NO-2NC) 3 NC ● 4 NC ● • On the contact arrangement marked with H in the table above, the rated current (load switching current) is reduced to a half of the rated current of the contact block. The rated insulation voltage and the rated thermal current remain unchanged. • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw • When operating the pushbutton selector, do not turn the operator ring or the lock lever while the button is depressed. Otherwise the pushbutton selector may be damaged. • Other contact arrangements are also available upon request. HW1R 11 (1NO-1NC) 20 (2NO) Dimensions M3.5 Terminal Screw • Contact Block Mounting Position and Contact Arrangement Chart Panel Thickness 0.8 to 6 Gasket 4 LO Locking Ring 2 ø28 41.4 ø29.4 25 CK 49.4 (2 blocks) 69.4 (4 blocks) 23.5 1 29.4 All dimensions in mm. The above figure illustrates the spring-up screw type. The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. 44 3 Contact Block 1 2 3 4 NO NO NC NC Normal Left Depressed Right Normal Depressed Ring Position Button ● ● ● ● (091211) HW Series Mono-Lever Switches ø22 Mono-Lever Switches Shape Type No. HW1M-1010-➅20 HW1M-2020-➅20 HW1M-0101-➅20 2-position HW1M-0202-➅20 HW1M-0101-➅40 HW1M-0202-➅40 HW1M-1111-➅22N9 4-position HW1M-2222-➅22N9 HW1M-L HW1M-L1010-➅20 Interlocking Lever HW1M-L2020-➅20 HW1M-L0101-➅20 2-position HW1M-L0202-➅20 HW1M-L0101-➅40 HW1M-L0202-➅40 HW1M-L1111-➅22N9 4-position HW1M-L2222-➅22N9 • On all mono-lever switches, the rated current (load switching current) is reduced to a half of the rated current of the contact block. The rated insulation voltage and the rated thermal current remain unchanged. • Specify a terminal style code in place of ➅ in the Type No. F: Finger-safe (IP20), blank: Spring-up screw HW1M Standard Lever Positions • Contact Arrangement Chart • 2-position (Right/Left) Lever Operator Position Contact Block Contact Code Mounting Type Position 1 2 1 2 3 4 20 40 • 2-position (Up/Down) Contact Block Contact Code Mounting Left Center Right NO NO NO NO NO NO Position ● 1 2 1 2 3 4 20 ● ● ● 40 ● ● Lever Operator Position Type Down Center NO NO NO NO NO NO Up • 4-position Contact Block Lever Operator Position Contact Mounting Code Type Down Left Center Up Right Position ● ● 1 2 3 4 22N9 ● ● NC NC NO NO ● ● ● ● ● ● Ordering Information Up R Dn L 1 1 1 1 HW1M-L Type Lever Operation Mode Order of Entry Up → Right → Down → Left 1: Maintained 2: Spring returned 0: Blocked HW1M: Standard HW1M-L: Interlocking 22N9 F Terminal Style Code F: Finger-safe (IP20) blank: Spring-up screw Contact Code Select a required contact operation at each lever operator position from the contact arrangement charts above and specify the Contact Code. Dimensions Locking Ring 41.4 25 2 49.4 (2 blocks)* 8 24º 36 max. 24º 1 72 36 max. 3 29.4 69.4 (4 blocks)* Up Contact Block Mounting Position LO CK • Contact Block Mounting Position and Lever Operator Position 4 .2 Panel Thickness 0.8 to 6 Right Left Lever Operator Position Down ø3 4 M3.5 Terminal Screw 45.5 The above figure illustrates the spring-up screw type. All dimensions in mm. The depth of each finger-safe (IP20) contact block is 0.9 mm longer than that of a spring-up screw contact block. (0901211) 45 ø22 HW Series Accessories and Replacement Parts Accessories Nameplates Plastic (black) 1.5 mm thick HWAM 1 HWAMPN10 10 Plastic (black) 1.5 mm thick 2.7 R14.9 2 ø2 1.5 27 HWAQ 10 2.7 R14.9 ø22 1.9 45 HWAS Blank Plastic (black) 1.5 mm thick HWAS-0 1 HWAS-0PN10 10 HWAV-0-Y 1 HWAV-0-Y 2 EM Aluminum (black) 1.0 mm thick HWNP HWAV-27-Y Ordering Type No. Type No. HWNP-∗ 0 ø6 ø2 HWAV-27-Y • Making Plate ER GENCY 1 1 HWNP-∗PN10 10 1.6 0.9 • Legend “Emergency Stop” is indicated outside a ø44mm circle. Package Quantity HWNP∗ 2 STOP Dimensions (mm) White legend on black background. 27 12 EMERGENCY STOP Material 0.9 ø2 Plastic (yellow) 1.5 mm thick Description 1.6 1 HWAS-0 Blank HWAV 1 Marking Plate 29 1 HWAQPN10 Marking Plate 29 27 30 Order marking plate separately. Dimensions (mm) HWAM HWAQ HWAQ Package Quantity 14.5 14.9 Ordering Type No. Type No. 14.5 14.9 Order marking plate separately. HWAM Material 12.1 Legend 30 Description 12.1 •HWAM, HWAQ, HWAS, and HWAV • Specify a legend code in place of ∗ in the Ordering Type No. Code 0 1 2 3 4 31 33 53 46 Legend (blank) ON OFF START STOP OFF-ON HAND-AUTO HAND-OFF-AUTO • Installing the marking plate on a nameplate Marking Plate • Legends Nameplate � � • To remove the marking plate, insert the flat screwdriver beween the marking plate and nameplate. Flat Screwdriver Marking Plate When requring no anti-rotation, remove the projection using pliers. Nameplate Note: When using an nameplate, the mounting panel thickness is decreased by 1.5 mm. (091211) HW Series Accessories and Replacement Parts ø22 Accessories Material Type No. Locking Ring Wrench Ordering Type No. Metal (weight: MW9Z-T1 MW9Z-T1 approx. 150g Package Quantity Dimensions (mm) • Used to tighten the locking ring when installing the HW switch onto a panel. • Tighten the locking ring to a torque of 2.0 N·m. 8 110 1 ø2 • Used to install and remove the LED/ incandescent lamps. Lamp Holder Tool OR-55 OR-55 1 ø11.6 Rubber ø14 Shape Contact Block Removal Tool 59 Metal/ Rubber TW-KC1 TW-KC1 23 • Used to remove the contact block and transformer, and also to install/remove the pilot light and illuminated pushbutton lens. 1 130 39 ø19 Anti-rotation Ring • Used to prevent the operator from turning. Generally used when using no nameplates on selector switches and pushbutton selectors. Plastic HW9Z-RL HW9Z-RLPN10 10 Rubber Mounting Hole Plug 9 ø2 ø22 TOP • Used to plug the unused ø22.2mm mounting holes. ø29 OB-31PN05 5 3.5 OB-31 3.5 LW9Z-BM LW9Z-BM 1 Gasket Locking Ring Plastic Mounting Hole Plug Plastic (nylon) LW9ZBP1 LW9Z-BP1 1 Barrier Plastic HW-VG1 HW-VG1PN10 10 12 Diecast Metal (locking ring: plastic) • Used to plug the unused ø22.2mm mounting holes. • Tighten the locking ring to a torque of 1.2 N·m. IP66 ø25.8 • Mounting panel thickness: 0.8 to 6 mm 3 Metallic Mounting Hole Plug ø25 • Used to plug the unused ø22.2mm mounting holes. • Tighten the locking ring to a torque of 2.0 N·m. IP65 • Mounting panel thickness: 0.8 to 6 mm • Used to prevent contact between adjacent lead wires when units are mounted closely. Barriers should always be used in close mounting. 45 Rubber (black) (0901211) 1.5 20 1.5 47 ø22 HW Series Accessories and Replacement Parts Accessories Shape Material Type No. Switch Guard Spring Return HW9Z-K1 Ordering Type No. HW9Z-K1 Package Quantity 1 Dimensions (mm) • Used to prevent inadvertent operation for flush pushbuttons and illuminated pushbuttons. • IP65 • Maintained type stops at 90º and 180º. 31 min. 49.4 Spring Return Plastic HW9Z-K11 HW9Z-K11 1 51.2 .7 R33 68 min. Maintained Panel Thickness: 0.8 to 5 0.4 48.3 17.4 For flush pushbuttons OC-31 OC-31 1 OC-32 OC-32 1 Rubber (EPDM) For extended pushbuttons • Used to cover and protect pushbuttons where units are subject to watersplash. Not suitable for outdoor use or where the units are subject to oil splash. ø32.6 Button Clear Boot 18 (OC-31) 22 (OC-32) • Used to protect pushbuttons, illuminated pushbuttons, selector switches, and key selector switches. Padlock Cover Panel Thickness 0.8 to 3.2 82.5 1 70 24 2 2. Rubber Boot for Dual Pushbutton Switches ø2 0 ) ø5 4.4 4 :ø I( D Key Hole ø8 29.5 30 Waterproof Rubber Gasket 0.5t • Degree of proctection: IP65 22.5 33 HW9Z-D7D HW9Z-D7D 1 58 Clear Silicon Rubber Ring Adapter Rubber HW9Z-A25 HW9Z-A25PN05 5 Ring Adapter Gasket: Nylon HW9Z-A30 Washer: Metal (brass) 48 93 30 5 6. HW9Z-KL1 R6 Polyarylate (gasket: nitryl HW9Z-KL1 rubber) HW9Z-A30PN02 2 • Used to install the HW/TW units into ø25 mm mounting holes. • IP65 • Cannot be used with anti-rotation ring and nameplate. • Mounting panel thickness: 1.2 to 6.0 mm • Used to install the HW units into ø30 mm mounting holes (except for HW1E, HW1B-M5/V5, and HW7D). • IP65 • Cannot be used with anti-rotation ring, nameplate, full-shroud illuminated pushbuttons, pushbutton selectors, and mono-lever switches. • Mounting panel thickness: 1.6 to 4.0 mm (091211) HW Series Accessories and Replacement Parts ø22 Maintenance Parts Contact Block Spring-up screw Specification NO contact Type No. HW-G10 Ordering Type No. HW-G10 Package Quantity 1 Remarks 14.7 Shape Push Rod Contact Block Finger-safe (IP20) HW-G01 1 EM (early make) contact HW-G10R HW-G10R 1 LB (late break) contact HW-G01R HW-G01R 1 1NO contact HW-F10 HW-F10 1 11.5 HW-G01 20.9 1NC contact Fixed Terminal Plate (Brass) 41.4 M3.5 Terminal Screw HW-F01 HW-F01 1 EM (early make) contact HW-F10R HW-F10R 1 21.8 1NC contact 11.5 Push Rod 40.4 Dummy Block Full Voltage Adapter (Photo: Spring-up screw) Transformer LB (late break) contact HW-F01R HW-F01R 1 Nylon TW-DB TW-DBPN10 10 Spring-up screw HW-GA1 HW-GA1PN02 2 Finger-safe (IP20) HW-DA1FB HW-DA1FB 1 Spring-up screw Finger-safe (IP20) Spring-up screw Finger-safe (IP20) Spring-up screw Finger-safe (IP20) Spring-up screw Finger-safe (IP20) Spring-up screw Finger-safe (IP20) Spring-up screw Finger-safe (IP20) Spring-up screw Finger-safe (IP20) HW-T16 TW-F16B HW-T126 TW-F126B HW-T26 TW-F26B HW-T246 TW-F246B — TW-F386B HW-L46 TW-F46B HW-L486 TW-F486B HW-T16 TW-F16B HW-T126 TW-F126B HW-T26 TW-F26B HW-T246 TW-F246B — TW-F386B HW-L46 TW-F46B HW-L486 TW-F486B 1 1 1 1 1 1 1 1 — 1 1 1 1 1 Spring-up screw HW-L16D HW-L16D 1 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC (Photo: Spring-up screw) 480V AC DC-DC Converter 110V DC Dome Lens for Pilot Light Button (0901211) AS resin HW1A-P2➁ Round flush with HW1A-B1➀ round or square bezel Round extended with HW1A-B2➀ round or square bezel Polyacetal HW2A-B1➀ Square flush Square extended HW2A-B2➀ ø29mm mushroom HW1A-B3➀ ø40mm mushroom HW1A-B4➀ HW1A-P2➁PN05 5 HW1A-B1➀PN05 5 HW1A-B2➀PN05 5 HW2A-B1➀PN05 HW2A-B2➀PN05 HW1A-B3➀PN02 HW1A-B4➀PN02 5 5 2 2 • For illuminated pushbuttons and illuminated selector switches. • Specify a color code in place of ➁. A (amber), G (green), R (red), S (blue), W (white), Y (yellow) • Specify a button color code in place of ➀. B (black) G (green) R (red) S (blue) W (white) Y (yellow) 49 ø22 HW Series Accessories and Replacement Parts Maintenance Parts Shape Lens (for pilot lights and illuminated pushbuttons) Type No. Ordering Type No. Package Quantity HW9Z-L11➁ HW9Z-L11➁PN05 5 HW9Z-L21➁ HW9Z-L21➁PN05 5 HW9Z-L12➁ HW9Z-L12➁PN05 5 ALW31L-➁ ALW31L-➁PN02 2 ALW31LD-➁ ALW31LD-➁PN02 2 ALW41L-➁ ALW41L-➁ 1 ALW41LD-➁ ALW41LD-➁ 1 AS resin HW1A-P2➁ HW1A-P2➁PN05 5 Polycarbonate HW1A-P5➁ HW1A-P5➁ 1 Specify a lens color code in place of ➁. A: amber, G: green, R: red, S: blue, W: white, Y: yellow HW9Z-P11 HW9Z-P12 HW9Z-P21 ALW3B HW9Z-P11PN05 HW9Z-P12PN05 HW9Z-P21PN05 ALW3BPN05 5 5 5 5 • White HW9Z-FDY➁ HW9Z-FDY➁ 1 A (amber), G (green), R (red), S (blue), W (white), Y (yellow) Metal HW9Z-SK-231 HW9Z-SK-231PN02 2 Plastic HW9Z-LN HW9Z-LNPN05 5 HW9Z-CPM HW9Z-CPM 1 HW9Z-BLM HW9Z-BLM 1 Specification Round flush Square flush Polyarylate Round extended Lens (for illuminated pushbuttons) ø29mm mushroom ø40mm mushroom AS, Marking type Dome Lens for Pilot Light Jumbo Dome Lens Marking Plate Round flush Round extended Acrylic Square flush ø29/40mm mushroom Operator Knob for Illuminated Selector Switch Polyarylate Color Code A (amber), C (clear), G (green), R (red), S (blue),Y (yellow) Use a clear lens for pure white and white illumination. C (clear), G (green), R (red), S (blue) A (amber), Y (yellow) C (clear), G (green), R (red), S (blue) A (amber), Y (yellow) Specify a color code in place of ➁. A (amber), G (green), R (red), S (blue), W (white), and Y (yellow) Replacement key Key selector switch Locking Ring • Black Cap for Mono-Lever Switch Boot for Mono-Lever Switch Standard Rubber Diffusing Lens Polycarbonate HW9Z-PP5C HW9Z-PP5C 1 Diffusing lens is used for LED type jumbo dome pilot lights only. Plastic HW9Z-LS HW9Z-LSPN10 10 • Yellow Rubber HW9Z-WM HW9Z-WMP10 10 Safety Lever Lock Gasket Note: Specify a button color code or lens color code in place of ➀ or ➁ in the Ordering Type No. 50 (091211) HW Series Accessories and Replacement Parts ø22 Maintenance Parts LED Lamps (LSTD) [except for HW Jumbo Dome pilot lights] Operating Voltage 6V AC/DC ±5% AC Current Draw DC Ordering Type No. Type No. 8 mA 7 mA (A, R, W,) 5.5 mA (G, PW, S) LSTD-6➁ 11 mA 10 mA LSTD-1➁ 11 mA 10 mA LSTD-2➁ 12V AC/DC ±10% 24V AC/DC ±10% Illumination Color Code LSTD-6➁ LSTD-6➁PN10 LSTD-1➁ LSTD-1➁PN10 LSTD-2➁ LSTD-2➁PN10 Package Quantity Specify a color code in place of ➁ in the Ordering Type No. A: amber G: green PW: pure white R: red S: blue W: white Use a pure white (PW) LED lamp with yellow (Y) lens. Base 1 10 1 BA9S/13 10 1 10 LED Lamps (LSTDB) [used for HW Jumbo Dome pilot lights only] 24V AC/DC ±10% Current Draw AC DC 15 mA Type No. (Ordering Type No.) Illumination Color Code Package Quantity Specify a color code in place of ➁ in the Ordering Type No. A: amber G: green PW: pure white R: red S: blue W: white Use a pure white (PW) LED lamp with yellow (Y) lens. 15 mA LSTDB-2➁ 1 Dimensions Base BA9S/13 Illumination Color Light blue: LSTDB 20.4 ø10.6 Operating Voltage Incandescent Lamps (LS) [except for HW Jumbo Dome pilot lights] Type No. (Ordering Type No.) Lamp Ratings 6V AC/DC 1W (6.3V) LS-6 1W (18V) LS-8 Package Quantity 12V AC/DC Dimensions Base BA9S/13 1 18V AC/DC 1W (24V) LS-2 1W (30V) LS-3 ø11±1 Rated Operating Voltage 22.5 ±1.5 24V AC/DC Incandescent Lamps (LSB) [used for HW Jumbo Dome pilot lights only] Lamp Ratings Type No Ordering Type No. Package Quantity Dimensions Base BA9S/13 28V, 0.17A LSB-2 LSB-2PN02 2 ø10 ±1 Rated Operating Voltage 24V AC/DC 27 ±2 (0901211) 51 ø22 HW Series Accessories and Replacement Parts Separate Mounting Type Transformer Secondary Voltage Primary Voltage 100/110V AC TWR516 TWR5126 TWR526 TWR5386 400/440V AC TWR546 480V AC TWR5486 Dimensions M3.5 Terminal Screw Secondary Side 600V 100 MΩ minimum (500V DC megger) –30 to +60ºC (no freezing) 35 to 85% RH (no condensation) Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Damage limits: 1,000 m/s2 2,500V AC, 1 minute M3.5 2 mm2 maximum, 2 wires maximum 22 30 100/110V AC, 115/120V AC, 200/220V AC, 230/240V AC, 380V AC, 400/440V AC, 480V AC (50/60Hz) 2.4 VA Primary Side 40 48 2–ø3.3 Mounting Hole 52 Terminal Cover 40 41 45.5 Current Draw Rated Insulation Voltage Insulation Resistance Operating Temperature Operating Humidity Vibration Resistance Shock Resistance Dielectric Strength Terminal Screw Applicable Wire 380V AC 3 Operating Voltage LSTD-6 LED lamp (6V AC/DC) or LS-6 incandescent lamp (6V AC/DC, 1W) TWR5246 2 5.5V AC, 1W 230/240V AC JAPAN 200/220V AC PRI. 115/120V AC Specifications Applicable Load 1 For 6V Type No. (Ordering Type No.) SEC. 4 Shape BAA1000 Accessories Type No. BAA1000 BAP1000 • End Clip Type No. BNL6 Ordering Type No. BAA1000PN10 BAP1000PN10 Ordering Type No. BNL6PN10 Length 1000 mm 1000 mm Applicable DIN Rail BAA1000 BAP1000 Weight (approx.) 200g 320g Weight (approx.) 15g Material Material Aluminum Steel Package Quantity 10 10 Package Quantity Steel (Zinc-plated) Dimensions 17 • DIN Rail 10 45 9 • Use plastic end clip BC9Z-E/NS35N when using 400/440V AC primary voltage transformers. 52 (091211) HW Series Instructions ø22 Safety Precautions • Turn off the power to the HW series control units before installation, removal, wiring, maintenance, and inspection of the HW series control units. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid a burn on your hand, use the lamp holder tool when replacing lamps. • For wiring, use wires of a proper size to meet the voltage and current requirements. Tighten the M3.5 terminal screws to a tightening torque of 1.0 to 1.3 N.m. Failure to tighten terminal screws may cause overheat and fire. Instructions • Removing and Installing the Contact Block 1. To remove the operator from the contact block, turn the locking lever in the direction of the arrow shown below. Then the operator can be pulled out. 2. To reinstall, place the TOP markings on the operator and the contact block mounting adapter in the same direction, and insert the operator into the contact block mounting adapter. Then turn the locking lever in the opposite direction. Lock Lever Install Remove the contact block from the operator (for transformer type pilot lights, remove the transformer from the illumination unit). Remove the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block to the operator. 3. When the spacing is narrower than the recommended value, with the lever unlocked, mount the safety lever lock and insert the contact unit to the operator. Then, lock the lever and strongly push in the safety lever lock to install. 4. To remove the safety lever lock, insert a flat screwdriver into the safety lever lock and push upwards. Safety Lever Lock Safety Lever Lock Screwdriver Remove Operator LO CK 26.5 Panel Mounting Contact Block Mounting Adapter Installing • Removing and Installing the Transformer Unit on Pilot Lights 1. Insert a flat screwdriver (5mm wide at the maximum) into the latch hole on the transformer unit as shown in the photo below, and disengage the latch. Then pull out the illumination unit. 2. To reinstall, place the TOP marking on the illumination unit and the latch in the same direction, and push the illumination unit into the transformer unit. Panel Removing When removing safety lever, make sure that the screwdriver does not touch the contact block. Ring Adapter • HW9Z-A25 The bezel protudes 0.5 mm to the front if the gasket is not removed. Remove the rubber gasket Dimensions Panel cut-out 5. ø2 +0 5 1.8 .5 0 ø2 ø2 5.1 8 Safety Lever Lock Panel ø2 • Notes for Panel Mounting 1. When mounting the operator onto a panel, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring. Tightening torque must not exceed 2.0 N.m. Do not use pliers. Excessive tightening will damage the locking ring. 2. For the contact blocks and transformers housing LED and incandescent lamps, make sure not to press the lamps too hard, otherwise the lamp socket may be impaired. • Notes for Illuminated Pushbuttons The full shroud cannot be removed from the extended full shroud type. 1.1 0.5 IDEC strongly recommends using the safety lever lock (HW9Z-LS, yellow) to prevent heavy vibration or maintenance personnel from unlocking contacts. 1. HW series can be mounted vertically with a minimum spacing of 50 mm (70 mm for mono-lever switches) but spacing should be determined to ensure easy operation. 2. Mount the control unit onto the panel, lock the lever, and strongly push in the safety lever lock to install. (0901211) 53 ø22 HW Series Instructions Instructions • HW9Z-A30 Panel Washer Operator (example) Ring Adapter • Installing [For Round Lens Type] TOP Lens Marking Plate Lens Holder Locking Ring Dimensions 5 4 ø3 ø22 ø3 ø2 2 .5 1. Place the marking plate on the lens holder with the anti-rotation projection engaged and press the lens onto the lens holder to engage the latches. 2. Place the marking plate in the correct orientation. [For Square Lens Type] ø30 Washer Adapter 1.4 8.6 0.6 Lens Marking Plate Lens Holder Panel-Cut ø3 0.5 +0 .5 0 1. Place the marking plate on the lens holder and press the lens onto the lens holder to engage the latches. 2. Place the marking plate in the correct orientation. Marking For HW series illuminated pushbuttons and pilot lights, legends and symbols can be engraved on the built-in marking plates, or printed film can be inserted under the lens for labeling purposes. Films are not supplied with illuminated pushbuttons, and may be provided by the user. • Marking Plates and Marking Film Size 2. Remove the marking plate by pushing the lens from the rear to disengage the latches between the lens and the lens holder, using the screwdriver as shown below. [Removing the Lens] Round Lens Type Square Lens Type Engraving Area Engraving Area ø19.6 1 1 19.9 • Engraving must be made on the engraving area within 0.5mm deep. • The marking plate is made of white acrylic resin. 22.7 ø21.5 • Removing 1. Remove the lens unit (color lens, marking plate, and lens holder) by inserting a screwdriver into the recess of the lens through the bezel. [Removing the Lens Unit] Applicable Marking Film Replacement of Lens and Marking Plate Built-in Marking Plate Lens Style 19.4 • Mylar for printing labels is not supplied and must be provided and printed by the user. • Two 0.1mm-thick films or one 0.2mm-thick film can be installed in the lens. • Recommended marking film: Mylar • Insertion Order of Marking Plate and Film [Round Lens Type] Note: The translucent filter in the lens holder cannot be removed because this filter is sealed to make the unit waterproof and oiltight. 54 Lens Film Marking Plate Note: Films are not supplied. Lens Holder Housing (091211) HW Series Instructions ø22 Instructions Nameplate [Square Lens Type] When anti-rotation is not required, remove the projection from the nameplate using pliers. Projection Lens Film Marking Plate Lens Holder Housing Note: Films are not supplied. Replacement of Lens for Dual Pushbuttons • Removing Remove the lens by inserting a screwdriver into the recess of the lens through the bezel. Nameplate Close Mounting When mounting the units closely in a horizontal row on 30 mm centers, use optional barriers to prevent interconnection between adjoining terminals. The barriers can be attached simply by pressing them onto the sides of contact blocks. 30 • Installing Install the lens in the recess between the buttons by pressing against the bezel. 30 Replacement of Lamps Lamps can be replaced by using the lamp holder tool (OR-55) from the front of the panel, or by removing the contact block from the operator unit. • Removing the Lamps from the Front of the Panel [How to Remove] 1. To remove, slip the lamp holder tool onto the lamp head lightly. Then push slightly, and turn the lamp holder tool counterclockwise. Barrier When mounting transformer type illuminated units closely in a hori­ zontal row on 30 mm centers, insert solid wires or stranded wires into inside of the terminal screw on the transformer (see figure below) to prevent short circuit between adjoining terminals. X1 X2 Inside [How to Install] 1. To install, insert the lamp head into the lamp holder tool, and hold the lamp as shown in the figure below. Lamp Lamp Holder Tool 2. Place the pins on the lamp base to the grooves in the lamp socket. Insert the lamp and turn it clockwise. Grooves in the Operator Unit (0901211) X1 Inside X2 *Spring-up screw type When using transformer type pilot lights closely mounted in horizontal and vertical rows on 30 mm centers, keep the ambient temperature below 40ºC. Tightening Torque for Terminal Screws Tighten the M3.5 terminal screws to a torque of 1.0 to 1.3 N·m. Installation of LED Illuminated Units 1. When using full voltage type LED illuminated units, provide protection against electrical noise, if necessary. 2. Notes for Pure White LED Lamps • Do not use the pure white LED outdoors, otherwise it will lead to the degradation of brightness and color. Do not remove or apply shock to the cap on the pure white LED lamp, otherwise it may break or damage the cap. • Use a white lens. The illumination color will be dull if a different color lens is used. 55 ø22 HW Series Instructions Instructions Applicable Wiring The applicable wire size is 2mm2 maximum. (Solid wire ø1.6 mm max.) One or two wires can be connected. • Applicable Crimping Terminal (for spring-up screw terminal) Crimping terminal for A Crimping terminal for B ø3.6 min. ø3.6 min. 6.6 max. 8 max. 4 max. 6 min. 4 max. 6 min. Unibody Pushlock Turn Reset • Removing the lens Remove the lens by inserting a screwdriver into the left or right recess of the lens. Be careful that the lens does not drop off. • Removing the LED/incandescent lamp Use a lens removal tool to remove the lamp. See page 54 for more information. • Notes for Wiring Ensure that the crimping terminal of each wiring is properly insulated. Selector Switch Be sure to turn the knob or key securely to each operator position. A A Key Selector Switch B B B B B A A A A X1 X2 A A B *Spring-up screw type Be sure to use an insulation tube or cover on the crimping part of the crimping terminal to prevent electrical shocks. ø1.6 max. • Solid Wire • Notes for using a different key When a different number key is inserted into the key hole, it will not normally operate. However, if the key is forced to turn or is not inserted properly, it may be turned. Notes on Dual Pushbutton Switches The pushbuttons cannot be removed or replaced. Do not attempt to remove using a flat screwdriver or pincers, otherwise the pushbuttons may be damaged. Anti-rotation Ring and Panel Cut-out Align the TOP marking on the operator and the s mark on the antirotation ring with the recess in the mounting panel. Panel Thickness 1.2 to 4.5 mm Projection When using the HW7D pushbuttons in places where the pushbuttons are subject to water splash or an excessive amount of dust, make sure to use the HW9Z-D7D rubber boot (IP65) which is ordered separately. • Notes for Installing the Rubber Boot Remove the gasket from the operator, and install the rubber boot on the operator. Pull out the seals of the rubber boot and place them around the operator sleeve as shown. Make sure that the seals are not twisted or tucked inside and that the gasket does not remain, otherwise the normal waterproof and dustproof characteristics are not ensured. � Remove the gasket. Gasket Anti-rotation (0.5t) Ring +0.2 0 .8 R0 � Rubber boot is installed. Install Remove x. ma .4 0 +0 .3 22 Gasket Seals ø 24.1 +0.4 0 � Install the rubber boot on the pushbuttons. Seals Locking Ring Mounting Panel • Panel Cut-out (Complies with IEC60947-5-1) 3.2 Pushbuttons Installing the Rubber Boot for Dual Pushbuttons 8max. HW Operator Do not attempt to remove the pushbuttons! 56 (091211) HW Series Control Stations ø22 Control Stations Control Station (Gray Cover) Shape Contact Type No. Button Color Mounted Unit (Operator) 1NO HW1X-BM110➀ Specify a button color code in place of ➀ in the Type No. B: black G: green R: red S: blue W: white Y: yellow HW1B-M1 With Pushbutton HW1X-BM 1NO-1NC Shape No. of Positions With Selector Switch HW1X-S 90º 2-position Maintained 45º 3-position Maintained HW1X-BM111➀ Contact Block Contact Code Mounting Position Type Operator L 10 (1NO) 1 NO 2 Dummy 11 (1NO-1NC) 1 NO 2 NC ● 20 (2NO) 1 NO ● 2 NO Type No. C R — ● HW1X-S2T10 — ● HW1X-S2T11 — ● Mounted Unit (Operator) HW1S-2T HW1X-S3T20 Emergency Stop Control Station (Yellow Cover) Shape Contact Type No. 1NC HW1X-BV401R 1NO-1NC HW1X-BV411R 2NC HW1X-BV402R 1NC HW1X-BX401R 1NO-1NC HW1X-BX411R 2NC HW1X-BX402R With Pushlock Turn Reset Switch HW1X-BV With Pushlock Key Reset Switch HW1X-BX Accessories Name Nameplate Type No. NSA-0 Cover Gasket Connector Locking Nut HW1S-3T Button Color Mounted Unit (Operator) Red only HW1B-V4R Red only HW1B-X4R Ordering Type No. Package Quantity Remarks NSA-0 1 NSA-0PN10 10 Black surface, made of aluminum 1.2 mm thick HW9Z-W HW9Z-WPN05 5 Made of rubber HW9Z-G HW9Z-GPN05 5 Made of white plastic, G1/2 thread HW9Z-PG HW9Z-PGPN05 5 Made of black plastic, PG16 thread Ordering Information • Unless otherwise specified, every control station is supplied with two connector locking nuts (G1/2 thread). • When using PG16 connectors, specify as described below. HW1X-BM110➀ - PG (0901211) Supplied with two PG16 connector locking nuts 57 ø22 HW Series Control Stations Specifications Operating Temperature Storage Temperature Operating Humidity Rated Insulation Voltage Contact Resistance Insulation Resistance Electric Shock Protection Class Dielectric Strength Vibration Resistance Shock Resistance Mechanical Life (minimum operations) Electrical Life (minimum operations) Conduit Port Applicable Connector Applicable Wire Mounting Screw Degree of Protection Weight (approx.) Contact Ratings –25 to +60ºC (no freezing) –40 to +80ºC (no freezing) 45 to 80% RH (no condensation) Contact Block 600V 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Rated Insulation Voltage Rated Thermal Current Contact Ratings by Utilization Category IEC 60947-5-1 Between live and dead parts: 2,500V AC, 1 minute Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Damage limits: 30 Hz, amplitude 1.5 mm Operating extremes: 100 m/s2 Damage limits: 1,000 m/s2 Pushbuttons, momentary: 5,000,000 Selector switches: 500,000 Pushlock turn reset switches: 500,000 Pushlock key reset switches: 500,000 Pushbuttons, momentary: 500,000 *1 Selector switches: 500,000 *2 Pushlock turn reset switches: 500,000 *3 Pushlock key reset switches: 500,000 *3 (Switching frequency) *1 1,800 operations/h, duty ratio 40% *2 1,200 operations/h, duty ratio 40% *3 900 operations/h, duty ratio 40% ø23 mm knockout on top and bottom G1/2 or PG16 (plastic fitting) Solid wire: ø1.6 mm maximum Stranded wire: 2.0 mm2 maximum Two M4 screws Tightening torque 1.4 to 2.0 N·m IP65 (IEC 60529) 157g (HW1X-BM111) AC-15 (A600) DC-13 (P600) Applicable Standards and Approvals Safety Standards Class II (IEC 61140) 600V 10A Mark File No. or Organization UL508 CSA C22.2 No. 14 UL Listing File No. E68961 EN60947-5-1 TÜV SÜD Attachments Name Nameplate *1 Cover Gasket *2 Connector Locking Nut Type No. NSA-0 HW9Z-W HW9Z-G Quantity 1 1 2 For details, see the instruction sheet attached to the control station. *1: The nameplate is supplied with the pushbutton and selector switch control stations, not with the emergency stop control station. *2: The cover gasket is supplied with the emergency stop control station, not with the pushbutton and selector switch control stations. Characteristics • Contact Ratings by Utilization Category Operational Voltage AC 50/60 Hz Operational Current DC AC-12 AC-15 DC-12 DC-13 Control of resistive loads and solid state loads Control of electromagnetic loads (> 72 VA) Control of resistive loads and solid state loads Control of electromagnets 24V 10A 10A 8A 4A 48V — — 4A 2A 50V 10A 7A — — 110V 10A 5A 2.2A 1.1A 220V 6A 3A 1.1A 0.6A 440V 2A 1A — — Note: The operational current represents the classification by making and breaking currents (IEC 60947-5-1). Minimum applicable load: 3V AC/DC, 5 mA (Applicable range may vary with operating conditions and load types.) Dimensions 70 A 58 Control Unit (Operator) Pushbutton Selector Switch Pushlock Turn Reset 58 58 Pushlock Key Reset Dimension A (mm) 13.0 21.0 32.0 32.0 (Key inserted: 49.4) HW1B-V4R Box Cover Mouting Screws 58 Box Cover Box Base (091211) HW Series Control Stations ø22 Mounting Hole Layout • Applicable Connector and Installation 1. To install a connector, break open the conduit port on the top and bottom of the control station. Before opening the conduit port, remove the attached two connector locking nuts from the control station base. Place the tip of a screwdriver on the conduit port and strike the screwdriver end. Make sure that the conduit port is free from burs and cracks, which may hamper waterproof characteristics. 42.4 58 Screwdriver 2-ø4.6 Applicable Terminal ø3.6 min. 4 max. 5.5 min. Nameplate Type No. Thread Size G1/2 PG16 Locking Nut Color White Black Locking Nut Type No. HW9Z-G HW9Z-PG NSA-0 30 max. 7.9 max. Tightening torque: 1.0 to 1.3 N·m A maximum of two pieces can be connected to one terminal. 2. Use G1/2 or PG16 connectors which can mount on a panel of 4.0 mm thick minimum. To install the connector to the control station, use the attached connector locking nut and tighten the locking nut sufficiently. If the locking nut is tightened insufficiently, the waterproof characteristics are not ensured. ø2 5. 5 Color: Black, without legend Thickness: 1.2 mm (Remove the anti-rotation projection) 36 34 Material Aluminum The nameplate is supplied with the pushbutton and selector switch control stations. When not using the nameplate, use the cover gasket (HW9Z-W). HW series nameplates (HWA*) cannot be used. Operating Instructions • Panel Mounting To mount the control station on a panel, use two M4 screws, plane washers and spring washers to preventing loosening. Tighten the screws to a torque of 1.4 to 2.0 N·m. Determine the screw length in consideration of the panel thickness. 3 M4 Screw Hexagonal Nut Plain Washer Locking Nut for Installing Connector (supplied with control station) 4 3. Only when using a plastic connector, Insulation Class II (IEC 61140) is satisfied. 4. Install the enclosure cover flat on the enclosure base. When the enclosure cover is installed diagonally, the enclosure cover cannot be secured correctly, resulting in an operation error. • Applicable Cables Applicable CVV Cable Outside Diameter ø14.5 mm maximum 1.25 mm2 ø14.5 mm maximum 2.0 mm2 • Applicable Conduits Metal Conduit Outside Diameter ø10 mm ø8.3 mm Conduit Inside Diameter minimum 1.25 mm2 2 to 3 IV Wire Quantity 2 to 3 2.0 mm2 Wire containment density: 32% to 48% Select a cable appropriate for the connector. Core Wires 8 maximum 8 maximum ø12 mm ø10.6 mm minimum 4 to 6 3 to 4 Spring Washer Control Box Panel (0901211) 59 Specifications and other descriptions in this catalog are subject to change without notice. 7-31, Nishi-Miyahara 1-Chome, Yodogawa-ku, Osaka 532-8550, Japan Tel: +81-6-6398-2571, Fax: +81-6-6392-9731 E-mail: marketing@idec.co.jp IDEC CORPORATION (USA) 1175 Elko Drive, Sunnyvale, CA 94089-2209, USA Tel: +1-408-747-0550 / (800) 262-IDEC (4332) Fax: +1-408-744-9055 / (800) 635-6246 E-mail: opencontact@idec.com IDEC CANADA LIMITED 3155 Pepper Mill Court, Unit 4, Mississauga, Ontario, L5L 4X7, Canada Tel: +1-905-890-8561, Toll Free: (888) 317-4332 Fax: +1-905-890-8562 E-mail: sales@ca.idec.com IDEC AUSTRALIA PTY. LTD. 2/3 Macro Court, Rowville, Victoria 3178, Australia Tel: +61-3-9763-3244, Toll Free: 1800-68-4332 Fax: +61-3-9763-3255 E-mail: sales@au.idec.com IDEC ELECTRONICS LIMITED www.idec.com (0901211) Unit 2, Beechwood, Chineham Business Park, Basingstoke, Hampshire RG24 8WA, UK Tel: +44-1256-321000, Fax: +44-1256-327755 E-mail: sales@uk.idec.com IDEC ELEKTROTECHNIK GmbH Wendenstrasse 331, 20537 Hamburg, Germany Tel: +49-40-25 30 54 - 0, Fax: +49-40-25 30 54 - 24 E-mail: service@idec.de IDEC (SHANGHAI) CORPORATION Room 608-609, 6F, Gangtai Plaza, No. 700, Yan'an East Road, Shanghai 200001, PRC Tel: +86-21-5353-1000, Fax: +86-21-5353-1263 E-mail: idec@cn.idec.com IDEC (BEIJING) CORPORATION Room 211B, Tower B, The Grand Pacific Building, 8A Guanghua Road, Chaoyang District, Beijing 100026, PRC Tel: +86-10-6581-6131, Fax: +86-10-6581-5119 IDEC (SHENZHEN) CORPORATION Unit AB-3B2, Tian Xiang Building, Tian’an Cyber Park, Fu Tian District, Shenzhen, Guang Dong 518040, PRC Tel: +86-755-8356-2977, Fax: +86-755-8356-2944 IDEC IZUMI (H.K.) CO., LTD. Units 11-15, Level 27, Tower 1, Millennium City 1, 388 Kwun Tong Road, Kwun Tong, Kowloon, Hong Kong Tel: +852-2803-8989, Fax: +852-2565-0171 E-mail: info@hk.idec.com IDEC TAIWAN CORPORATION 8F-1, No. 79, Hsin Tai Wu Road, Sec. 1, Hsi-Chih, Taipei County, Taiwan Tel: +886-2-2698-3929, Fax: +886-2-2698-3931 E-mail: service@tw.idec.com IDEC IZUMI ASIA PTE. LTD. No. 31, Tannery Lane #05-01, HB Centre 2, Singapore 347788 Tel: +65-6746-1155, Fax: +65-6844-5995 E-mail: info@sg.idec.com Cat. No. EP1274-0 NOVEMBER 2009 2T PRINTED IN JAPAN
HW9Z-SK-231 价格&库存
很抱歉,暂时无法提供与“HW9Z-SK-231”相匹配的价格&库存,您可以联系我们找货
HW9Z-SK-231
  • 1+86.25855
  • 5+80.69387
  • 10+76.81401
  • 20+74.06133
  • 50+72.59007
库存:72
