CW4S-2L
CW4S-2L
    IDEC(日本和泉)
    IDEC - CW4S-2L - Switch Actuator, Idec 22mm CW Series Selector Switches, CW
CW4S-2L 数据手册
Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices ø22 Flush Mount CW Switches & Pilot Devices Flush bezel projects only 2.5mm from front of panel and only 39.9mm behind the panel! Key features: Mark File No. or Organization UL508 CSA C22.2 No.14 Relays & Sockets Applicable Standards Signaling Lights • ø22.3mm mounting hole compliant with IEC 60947-5-1 • 3.5-mm operator travel for pushbuttons ensures comfortable and reliable operation • Black and metallic bezels available • Illuminated pushbuttons, pushbuttons, pilot lights, selector switches and key selector switches are available • Direct opening NC contact • Seven different keys can be chosen for key selector switches • 10A contact rating; up to three contact blocks for non-illuminated and two contact blocks for illuminated models can be connected • Contact blocks can be removed by locking lever • IP20 finger-safe screw terminals • UL Type 4X rating UL/c-UL File No. E68961 TÜV SÜD EN60947-5-1 EC Low Voltage Directive Specifications Contact Ratings Operating Humidity 45 to 85% RH (no condensation) Storage Temperature –40 to +80°C Contact Resistance 50 mΩ maximum (initial value) Insulation Resistance 100 MΩ minimum (500V DC megger) Overvoltage Category II (IEC 60664-1) Impulse Withstand Voltage 2.5 kV (IEC60664-1/60947-5-1) Rated Insulation Voltage (Ui) 300V Rated Thermal Current (Ith) 10A Rated Operating Voltage (Ue) 24V 120V 240V Resistive Load (AC-12) 10A 10A 6A Inductive Load (AC-15) 10A 6A 3A Resistive Load (DC-12) 8A 2.2A 1.1A Inductive Load (DC-13) 4A 1.1A 0.55A Resistive Load (AC-12) 5A 5A 3A Inductive Load (AC-15) 5A 3A 1.5A Resistive Load (DC-12) 4A 1.1A 0.55A Inductive Load (DC-13) 2A 0.55A 0.27A Electrical Life 50,000 operations AC 50/60 Hz 3 (IEC60947-5-1) Vibration Resistance Operating extremes: 5 to 55Hz, amplitude 0.5 mm Shock Resistance Operating extremes: 100 m/s2 Damage limits: 1000 m/s2 Mechanical Life (minimum operations) Pushbutton, illuminated pushbutton: 2,000,000 Selector switch: 250,000 Key selector switch: 250,000 Electrical Life (minimum operations) 50,000 (see Contact Ratings) 100,000 (see Contact Ratings) (switching frequency 1800 operations/h) Degree of Protection (IEC60529) Panel front: IP65 Terminals: IP20 Short-circuit Protection 250V/10A fuse, (Type aM IEC60269-1, IEC602069-2) Electrical Shock Protection Class II (IEC61140) Terminal Style Screw terminal (M3.5 slotted Phillips screw) Bezel Material Polyamide Applicable Wire Size Up to 2 wires of 2 mm (solid wire ø1.6) maximum (AWG14 to 16) (Ring terminal cannot be used) 2-position (3NC) 3-position (2NC) Operator Angle for Direct Opening Action 90° 45° Recommended Tightening Torque Terminal: Locking ring: Minimum Operator Torque for Direct Opening Action 0.2 N·m 0.3 N·m Maximum Operator Angle 90° 45° Type 4X Rated Operating Current (Ie) Electrical Life 100,000 operations AC 50/60 Hz DC Contact Material Silver 1. Minimum applicable load (reference value): 3V AC/DC, 5 mA (Applicable range is subject to the operating conditions and load.) 2. The operational current represents the classification by making and breaking currents (IEC 60947-5-1). 3. UL, c-UL rating: A300 1.0 to 1.3 N·m 1.2 N·m 800-262-IDEC (4332) • USA & Canada Circuit Breakers Direct Opening of Key Selector Switch 2 Terminal Blocks Pollution Degree Contactors DC Timers Operating Temperature Non-illuminated: –25 to +60°C (no freezing) LED illuminated: –25 to +55°C (no freezing) 531 Switches & Pilot Devices Switches & Pilot Devices ø22mm - CW Series Weights Illuminated Pushbutton 46g (CW1L-M1E02QH, 2 contact blocks) Pushbutton 45g (CW1B-M1E03, 3 contact blocks) Pilot Light 27g (CW1P-1EQH) Selector Switch 48g (CW1S-2E03, 3 contact blocks) Key Selector Switch 61g (CW1K-2E03, 3 contact blocks) Signaling Lights LED Module Rated Insulation Voltage (Ui) 250V Rated Operating Voltage (Ue) 6V AC/DC 12V AC/DC Operating Voltage Range 6V AC/DC±10% 12V AC/DC±10% 24V AC/DC 100/120V AC 230/240V AC 24V AC/DC±10% 100/120V AC±10% 230/240V AC±10% A (amber), G (green), PW (white), R (red), S (blue) Illumination Color Code k LED Module Part Number CW-EAQ2k CW-EAQ3k CW-EAQ4k CW-EAQHk CW-EAQM4k Current Draw 15 mA 15 mA 16.5 mA 18 mA 18 mA Relays & Sockets Life (reference value) Approx. 30,000 hours X1 X1 R Internal Circuit LED Chip R X2 Rectifying Diode Zener Diode Resistor Timers 1. Specify an illumination color code in place of k in the part number. 2. Use the white (PW) LED module for yellow illumination. Mounting Hole Layout IEC 60947-5-1 compliant 3.2 +0.2 0 R0.8 max. ø22 Contactors 50 24.1+0.4 0 .3 +0.4 0 30 Circuit Breakers Terminal Blocks Note: Determine mounting centers to ensure proper spacing. 532 R www.IDEC.com R X2 C R LED Chip Rectifying Diode Zener Diode Resistor Capacitor Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Illuminated Pushbuttons (Assembled) Style Operating Voltage 6V AC/DC Round Flush CW0L-01 (black bezel) 24V AC/DC (metallic bezel) Round Extended CW0L-02 6V AC/DC 24V AC/DC CW4L-1E01Q2k 1NO-1NC CW1L-1E11Q2k CW4L-1E11Q2k 2NO CW1L-1E20Q2k CW4L-1E20Q2k 2NC CW1L-1E02Q2k CW4L-1E02Q2k 1NO CW1L-1E10Q3k CW4L-1E10Q3k 1NC CW1L-1E01Q3k CW4L-1E01Q3k 1NO-1NC CW1L-1E11Q3k CW4L-1E11Q3k 2NO CW1L-1E20Q3k CW4L-1E20Q3k 2NC CW1L-1E02Q3k CW4L-1E02Q3k 1NO CW1L-1E10Q4k CW4L-1E10Q4k 1NC CW1L-1E01Q4k CW4L-1E01Q4k 1NO-1NC CW1L-1E11Q4k CW4L-1E11Q4k 2NO CW1L-1E20Q4k CW4L-1E20Q4k 2NC CW1L-1E02Q4k CW4L-1E02Q4k 1NO CW1L-1E10QHk CW4L-1E10QHk 1NC CW1L-1E01QHk CW4L-1E01QHk 1NO-1NC CW1L-1E11QHk CW4L-1E11QHk 2NO CW1L-1E20QHk CW4L-1E20QHk 2NC CW1L-1E02QHk CW4L-1E02QHk 1NO CW1L-1E10QM4k CW4L-1E10QM4k 1NC CW1L-1E01QM4k CW4L-1E01QM4k 1NO-1NC CW1L-1E11QM4k CW4L-1E11QM4k 2NO CW1L-1E20QM4k CW4L-1E20QM4k 2NC CW1L-1E02QM4k CW4L-1E02QM4k 1NO CW1L-2E10Q2k CW4L-2E10Q2k 1NC CW1L-2E01Q2k CW4L-2E01Q2k 1NO-1NC CW1L-2E11Q2k CW4L-2E11Q2k 2NO CW1L-2E20Q2k CW4L-2E20Q2k 2NC CW1L-2E02Q2k CW4L-2E02Q2k 1NO CW1L-2E10Q3k CW4L-2E10Q3k 1NC CW1L-2E01Q3k CW4L-2E01Q3k 1NO-1NC CW1L-2E11Q3k CW4L-2E11Q3k 2NO CW1L-2E20Q3k CW4L-2E20Q3k 2NC CW1L-2E02Q3k CW4L-2E02Q3k 1NO CW1L-2E10Q4k CW4L-2E10Q4k 1NC CW1L-2E01Q4k CW4L-2E01Q4k 1NO-1NC CW1L-2E11Q4k CW4L-2E11Q4k 2NO CW1L-2E20Q4k CW4L-2E20Q4k 2NC CW1L-2E02Q4k CW4L-2E02Q4k 1NO CW1L-2E10QHk CW4L-2E10QHk 1NC CW1L-2E01QHk CW4L-2E01QHk CW1L-2E11QHk CW4L-2E11QHk 2NO CW1L-2E20QHk CW4L-2E20QHk 2NC CW1L-2E02QHk CW4L-2E02QHk 1NO CW1L-2E10QM4k CW4L-2E10QM4k 1NC CW1L-2E01QM4k CW4L-2E01QM4k CW1L-2E11QM4k CW4L-2E11QM4k 2NO CW1L-2E20QM4k CW4L-2E20QM4k 2NC CW1L-2E02QM4k CW4L-2E02QM4k 100/120V AC 1NO-1NC (metallic bezel) 230/240V AC 1NO-1NC 800-262-IDEC (4332) • USA & Canada A: G: PW: R: S: Y: amber green white red blue yellow A: G: PW: R: S: Y: amber green white red blue yellow 1. Specify an illumination color code in place of k in the Part Number. 2. Specify function code in place of  in the Part Number. M: momentary, A: maintained 3. See page 543 for dimensions. 4. See next page for replacement LED modules. 5. A dummy block is installed when one contact block is used. Circuit Breakers CW4L-1E10Q2k CW1L-1E01Q2k Terminal Blocks (black bezel) CW1L-1E10Q2k 1NC Contactors 12V AC/DC 1NO Illumination Color Code k Timers 230/240V AC Metallic Bezel Relays & Sockets 100/120V AC Black Bezel Signaling Lights 12V AC/DC Contact Configuration 533 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø22mm - CW Series Illuminated Pushbuttons (Sub-assembled) Contact Blocks + LED Module + Contact Blocks Style Contacts Mounting Adapter + Operator + 1NO 1NC Black Bezel Style Relays & Sockets YW-E10R Dummy Block Round Extended Part Number Timers Contactors 1. In place of j, specify the Lens/LED Color Code from table. 2. In place of k, specify the Voltage Code from table. 3. Use PW LED for yellow lens. Contact Block Mounting Adaptor Round Extended Lens Style Part Number Round Flush Round Extended CW9Z-L11j CW9Z-L12j 1. In place of j, specify the Lens/LED Color Code from table. Part Number Circuit Breakers Terminal Blocks CW-CN CW1L-M20 CW4L-M20 CW1L-A10 CW4L-A10 CW1L-A20 Completed Unit j Lens/LED Color Code Color Code Amber A Green G Red R Blue S White PW Yellow Y CW4L-A20 k Voltage Code CW-EAQ kj 534 CW1L-M10 CW4L-M10 Maintained CW-DB LED Module Style Metallic Bezel Momentary YW-E01 Round Flush Style = Operators Round Flush Finger-safe screw terminal Lens www.IDEC.com Voltage Code 6V AC/DC 2 12V AC/DC 3 24V AC/DC 4 100/120V AC H 230/240V AC M4 Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Non-Illuminated Pushbuttons (Assembled) Style Round Flush CW0B-01 Round Extended CW0B-02 Metallic Bezel 1NO CW1B-1E10j CW4B-1E10j 1NC CW1B-1E01j CW4B-1E01j 1NO-1NC CW1B-1E11j CW4B-1E11j 2NO CW1B-1E20j CW4B-1E20j 2NC CW1B-1E02j CW4B-1E02j 2NO-1NC* CW1B-M1E21j CW4B-M1E21j 1NO-2NC* CW1B-M1E12j CW4B-M1E12j 3NO* CW1B-M1E30j CW4B-M1E30j 3NC* CW1B-M1E03j CW4B-M1E03j 1NO CW1B-2E10j CW4B-2E10j 1NC CW1B-2E01j CW4B-2E01j 1NO-1NC CW1B-2E11j CW4B-2E11j 2NO CW1B-2E20j CW4B-2E20j 2NC CW1B-2E02j CW4B-2E02j 2NO-1NC* CW1B-M2E21j CW4B-M2E21j 1NO-2NC* CW1B-M2E12j CW4B-M2E12j 3NO* CW1B-M2E30j CW4B-M2E30j 3NC* CW1B-M2E03j CW4B-M2E03j Button Color Code j B: G: R: S: W: Y: black green red blue white yellow 1. Specify a button color code in place of j in the part number. 2. Specify function code in place of  in the Part Number. M: momentary, A: maintained 3. See page 543 for dimensions. 4. Two or one dummy block is installed when one or two contact blocks are used, respectively. *These contact configurations are not available in maintained action Relays & Sockets (metallic bezel) Black Bezel Signaling Lights (black bezel) Contact Configuration Non-Illuminated Pushbuttons (Sub-assembled) Style Contacts LED Module + Lens = Operators* 1NO 1NC j Button Color Code Style Black Bezel Round Flush Finger-safe screw terminal Completed Unit CW1B-M1j Metallic Bezel CW4B-M1j Momentary YW-E10R YW-E01 Round Extended CW1B-M2j CW4B-M2j CW1B-A1j CW4B-A1j Round Extended CW1B-A2j CW4B-A2j Maintained Dummy Block CW-DB Code Black B Green G Red R Blue S White W Yellow Y Terminal Blocks Round Flush Color Contactors Contact Blocks + Timers Contact Blocks 1. Specify a button color code in place of j. 2. *Operator button is not removable from operator. Contact Block Mounting Adaptor Style Part Number Circuit Breakers CW-CN 800-262-IDEC (4332) • USA & Canada 535 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - CW Series Pilot Lights (Assembled) Style Operating Voltage Black Bezel Metallic Bezel Round Flush Lens CW0P-1 6V AC/DC CW1P-1EQ2k CW4P-1EQ2k 12V AC/DC CW1P-1EQ3k CW4P-1EQ3k 24V AC/DC CW1P-1EQ4k CW4P-1EQ4k 100/120V AC CW1P-1EQHk CW4P-1EQHk (black bezel) 230/240V AC CW1P-1EQM4k CW4P-1EQM4k Round Dome Lens CW0P-2 6V AC/DC CW1P-2EQ2k CW4P-2EQ2k 12V AC/DC CW1P-2EQ3k CW4P-2EQ3k 24V AC/DC CW1P-2EQ4k CW4P-2EQ4k 100/120V AC CW1P-2EQHk CW4P-2EQHk 230/240V AC CW1P-2EQM4k CW4P-2EQM4k (metallic bezel) Illumination Color Code k A: G: R: S: PW: Y: amber green red blue white yellow 1. Specify an illumination color code in place of k in the Part Number 2. See page 543 for dimensions. 3. See page 545 for replacement LED modules. 4. Two dummy blocks are installed. Pilot Lights (Sub-assembled) + LED Module + Mounting Adapter + Operator + Lens = Completed Unit Timers Contact Blocks* * 2 dummy blocks are required for each completed pilot light. Contactors Contact Block Style Contact Block Mounting Adaptor Contacts Dummy Block Part Number Style Part Number Lens Style Part Number CW-DB CW-CN LED Module Style Part Number Terminal Blocks Black Bezel CW1P-00 Metallic Bezel CW4P-00 Circuit Breakers 1. In place of j, specify the Lens/LED Color Code from table. 2. In place of k, specify the Voltage Code from table. 3. Use PW LED for yellow lens. Style 536 CW9Z-L11j Round Dome CW9Z-L15j 1. In place of j, specify the Lens/LED Color Code from table. Operators CW-EAQ kj Round Flush www.IDEC.com j Lens/LED Color Code k Voltage Code Voltage Code Color Code 6V AC/DC 2 Amber A 12V AC/DC 3 Green G 24V AC/DC 4 Red R 100/120V AC H Blue S 230/240V AC M4 White PW Yellow Y Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Selector Switches (Assembled) CW0S (Knob Operator) Shape (black bezel) 1NO (10) 1NO-1NC (11) Dummy CW0S-2E11 CW0S-21E11 Dummy CW0S-2E20 CW0S-21E20 Dummy CW0S-2E02 CW0S-21E02 CW0S-2E21 CW0S-21E21 CW0S-2E12 CW0S-21E12 CW0S-2E30 CW0S-21E30 CW0S-2E03 CW0S-21E03 1 — Dummy 2 — 3 NC 1 NO 2 — NC — 2NC (02) 1 NC 2 — 3 NC 1 NO 2 NO 3 NC 1 NO 2 NC 3 NC 1 NO 2 NO 3 NO 1 NC 2 NC 3 NC L R Contactors CW0S-21E01 Dummy NO 3NC (03) CW0S-2E01 Dummy — 3 3NO (30) Dummy — 3 2 1NO-2NC (12) CW0S-21E10 NO 2 2NO (20) 2NO-1NC (21) CW0S-2E10 1 NO R Spring return from right Type 1 L R Maintained Mounting Position 3 L Timers 90° 2-position Operator Position Relays & Sockets 1NC (01) Contact Block Signaling Lights No. of Positions Contact Configuration (metallic bezel) Terminal Blocks 1. Specify a bezel color code in place of 0 in the part number: 1 (black bezel), 4 (metallic bezel). 2. Lever operator is also available. For dimensions, see page 544. 3. To order a lever operator selector switch, insert L before E in the knob operator part number. Example: Knob Operator part number CW1S-2E10 becomes CW1S-2LE10 for Lever Operator. Lever Operator Contact Block Mounting Position 1 2 3 Left Center Right CW1S-0L (black bezel) CW4S-0L (metallic bezel) 800-262-IDEC (4332) • USA & Canada 1 NO 2 NC 3 NC C R Operator Position Circuit Breakers L 537 Switches & Pilot Devices No. of Positions Contact Configuration 1NO-1NC (11) 1NO-1NC (11N1) Signaling Lights Switches & Pilot Devices ø22mm - CW Series 1NO-1NC (11N2) 1NO-1NC (11N3) Relays & Sockets 1NO-1NC (11N4) 2NO (20) Timers 2NO (20N1) 45° 3-position 2NC (02) 2NC (02N1) 2NO-1NC (21) Contactors 2NO-1NC (21N1) 1NO-2NC (12) Terminal Blocks 1NO-2NC (12N1) 3NO (30) 3NC (03) Operator Position Contact Block Mounting Position Type 1 NO 2 3 1 2 — NC NC — 3 NO 1 NO 2 NC 3 1 — — 2 NC 3 NO 1 — 2 NO 3 NC 1 NO 2 — 3 NO 1 — 2 NO 3 NO 1 2 3 1 NC — NC — 2 NC 3 NC 1 NO 2 NO 3 NC 1 NO 2 NC 3 NO 1 NO 2 NC 3 1 NC NC 2 NO 3 NC 1 NO 2 NO 3 NO 1 NC 2 NC 3 NC L L C R L Circuit Breakers R L C R L C R Maintained Spring return from right Spring return from left Spring return two-way Dummy CW0S-3E11 CW0S-31E11 CW0S-32E11 CW0S-33E11 Dummy CW0S-3E11N1 CW0S-31E11N1 CW0S-32E11N1 CW0S-33E11N1 CW0S-3E11N2 CW0S-31E11N2 CW0S-32E11N2 CW0S-33E11N2 CW0S-3E11N3 CW0S-31E11N3 CW0S-32E11N3 CW0S-33E11N3 CW0S-3E11N4 CW0S-31E11N4 CW0S-32E11N4 CW0S-33E11N4 CW0S-3E20 CW0S-31E20 CW0S-32E20 CW0S-33E20 CW0S-3E20N1 CW0S-31E20N1 CW0S-32E20N1 CW0S-33E20N1 CW0S-3E02 CW0S-31E02 CW0S-32E02 CW0S-33E02 CW0S-3E02N1 CW0S-31E02N1 CW0S-32E02N1 CW0S-33E02N1 CW0S-3E21 CW0S-31E21 CW0S-32E21 CW0S-33E21 CW0S-3E21N1 CW0S-31E21N1 CW0S-32E21N1 CW0S-33E21N1 CW0S-3E12 CW0S-31E12 CW0S-32E12 CW0S-33E12 CW0S-3E12N1 CW0S-31E12N1 CW0S-32E12N1 CW0S-33E12N1 CW0S-3E30 CW0S-31E30 CW0S-32E30 CW0S-33E30 CW0S-3E03 CW0S-31E03 CW0S-32E03 CW0S-33E03 C R Dummy Dummy Dummy Dummy Dummy Dummy Dummy 1. Specify a bezel color code in place of 0 in the Part Number, 1 (black bezel), 4 (metallic bezel) 2. For the contact block mounting position, see page 540. 3. Lever operator is also available. For dimensions, see page 544. 4. To order a lever operator selector switch, insert L before E in the knob operator part number. Example: Knob Operator part number CW1S-3E11 becomes CW1S-3LE11 for Lever Operator. 538 C www.IDEC.com Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Selector Switches (Sub-assembled) Contact Block + Mounting Adaptor + Operator = Completed Unit Signaling Lights Contact Blocks Style Contacts 1NO 1NC Finger-safe screw terminal YW-E10R YW-E01 Relays & Sockets Dummy Block CW-DB Contact Block Mounting Adaptor Style Part Number Timers CW-CN Operators Style Position Handle 2 position Lever Knob (knob operator shown) Lever Metallic Bezel Maintained CW1S-2 CW4S-2 Spring return from right CW1S-21 CW4S-21 Maintained CW1S-2L CW4S-2L Spring return from right CW1S-21L CW4S-21L Maintained CW1S-3 CW4S-3 Spring return from right CW1S-31 CW4S-31 Spring return from left CW1S-32 CW4S-32 Spring return two-way CW1S-33 CW4S-33 Maintained CW1S-3L CW4S-3L Spring return from right CW1S-31L CW4S-31L Spring return from left CW1S-32L CW4S-32L Spring return two-way CW1S-33L CW4S-33L Terminal Blocks 3 position Black Bezel Contactors Knob Description Lever or knob is supplied with operator. Circuit Breakers 800-262-IDEC (4332) • USA & Canada 539 Switches & Pilot Devices Switches & Pilot Devices ø22mm - CW Series Key Selector Switches (Assembled) CW0K Shape (black bezel) Signaling Lights Contact Block No. of Positions Contact Configuration Type 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 NO — — — — NC NO — NC NO — NO NC — NC NO NO NC NO NC NC NO NO NO NC NC NC Relays & Sockets 1NC (01) 1NO-1NC (11) 2NO (20) 2NC (02) Timers 2NO-1NC (21) 1NO-2NC (12) 3NO (30) Contactors Operator Position L Mounting Position 1NO (10) 90° 2-position (metallic bezel) 3NC (03) R L R Maintained Spring return from right Dummy Dummy Dummy Dummy CW0K-2AE10 CW0K-21BE10 CW0K-2AE01 CW0K-21BE01 Dummy CW0K-2AE11 CW0K-21BE11 Dummy CW0K-2AE20 CW0K-21BE20 Dummy CW0K-2AE02 CW0K-21BE02 CW0K-2AE21 CW0K-21BE21 CW0K-2AE12 CW0K-21BE12 CW0K-2AE30 CW0K-21BE30 CW0K-2AE03 CW0K-21BE03 L R Terminal Blocks 1. Specify a bezel color code in place of 0 in the Part Number: 1 (black bezel), 4 (metallic bezel). 2. On the spring-returned models, the key can be released only from the maintained position. On the maintained models, the key can be released from any position. Key retained positions are also available. See below. 3. Two keys are supplied. 4. Key cylinder material: Metal 5. Besides the standard key (key number 0H), six other keys are also available. See below. 6. For the contact block mounting position, see page 541. 7. For dimensions, see page 544. 8. When ordering an optional key or optional key retained positions, specify designation codes as shown below: Example: CW1K-2AE10-1H (blank): 1H to 2H: 3H to 6H: Standard key (0H, reversible) Reversible key Non-reversible key Circuit Breakers Key removal position code 2-position A: Removable in all positions B: Removable in left only C: Removable in right only Note: Key number is indicated on the key cylinder. Standard keys do not have a key number indication. 3-position A: Removable in all positions B: Removable in left and center C: Removable in right and center D: Removable in center only E: Removable in right and left G: Removable in left only H: Removable in right only Note: Key is retained in all spring-returned positions. 540 www.IDEC.com Switches & Pilot Devices Contact Configuration 1NO-1NC (11) 1NO-1NC (11N1) 1NO-1NC (11N3) 2NO (20) 2NO (20N1) 45° 3-position 2NC (02) 2NO-1NC (21) 1NO-2NC (12) 1NO-2NC (12N1) 3NC (03) L C R L C R Maintained Spring return from right Spring return from left Spring return two-way Dummy CW0K-3AE11 CW0K-31BE11 CW0K-32CE11 CW0K-33DE11 Dummy CW0K-3AE11N1 CW0K-31BE11N1 CW0K-32CE11N1 CW0K-33DE11N1 CW0K-3AE11N2 CW0K-31BE11N2 CW0K-32CE11N2 CW0K-33DE11N2 CW0K-3AE11N3 CW0K-31BE11N3 CW0K-32CE11N3 CW0K-33DE11N3 CW0K-3AE11N4 CW0K-31BE11N4 CW0K-32CE11N4 CW0K-33DE11N4 CW0K-3AE20 CW0K-31BE20 CW0K-32CE20 CW0K-33DE20 CW0K-3AE20N1 CW0K-31BE20N1 CW0K-32CE20N1 CW0K-33DE20N1 CW0K-3AE02 CW0K-31BE02 CW0K-32CE02 CW0K-33DE02 CW0K-3AE02N1 CW0K-31BE02N1 CW0K-32CE02N1 CW0K-33DE02N1 C R 1 NO 2 3 1 2 NC — — NC 3 1 2 3 1 2 3 1 2 NO — NO NC NO — NO — NO 3 1 2 3 1 2 3 1 NO NC — NC — NC NC NO 2 3 1 NO NC NO CW0K-3AE21 CW0K-31BE21 CW0K-32CE21 CW0K-33DE21 2 NC CW0K-3AE21N1 CW0K-31BE21N1 CW0K-32CE21N1 CW0K-33DE21N1 3 NO 1 NO 2 3 1 2 3 1 NC NC NC NO NC NO CW0K-3AE12 CW0K-31BE12 CW0K-32CE12 CW0K-33DE12 CW0K-3AE12N1 CW0K-31BE12N1 CW0K-32CE12N1 CW0K-33DE12N1 2 NO CW0K-3AE30 CW0K-31BE30 CW0K-32CE30 CW0K-33DE30 3 1 2 3 NO NC NC NC CW0K-3AE03 CW0K-31BE03 CW0K-32CE03 CW0K-33DE03 Dummy Dummy Dummy Dummy Dummy Dummy Dummy Contact Block Mounting Position 1 2 3 800-262-IDEC (4332) • USA & Canada Left Center Right L 1 NO 2 NC 3 NC C R Circuit Breakers 1. Specify a bezel color code in place of 0 in the Part Number: 1 (black bezel), 4 (metallic bezel) 2. On the spring-returned types, the key can be released only from the maintained position. On the maintained types, the key can be released from every position. Key retained positions are also available. See page 540. 3. Two keys are supplied. 4. Key cylinder material: Metal 5. Besides the standard key (key number 0H), six other keys are also available. See page 540. 6. For the contact block mounting position, see right. 7. For dimensions, see page 544. Terminal Blocks 3NO (30) R Contactors 2NO-1NC (21N1) NO — NC NC — NO C Timers 2NC (02N1) 1 2 3 1 2 3 L L R Relays & Sockets 1NO-1NC (11N4) Type C Signaling Lights 1NO-1NC (11N2) Mounting Position L Switches & Pilot Devices No. of Positions Operator Position Contact Block ø22mm - CW Series Operator Position 541 Switches & Pilot Devices Key Selector Switches (Sub-assembled) Contact Block + Mounting Adaptor + Contact Block Style Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - CW Series Operator = Completed Unit Contact Block Mounting Adaptor Contacts 1NO 1NC Finger-safe screw terminal YW-E10R YW-E01 Dummy Block Style Part Number CW-CN CW-DB Operator Position Timers Style Contactors 2 position Terminal Blocks 3 position Description Black Bezel Metallic Bezel Maintained, key removable all positions CW1K-2A CW4K-2A Maintained, key removed left only CW1K-2B CW4K-2B Maintained, key removed right only CW1K-2C CW4K-2C Spring return from right CW1K-21B CW4K-21B Maintained, key removable all positions CW1K-3A CW1K-3A Maintained, key removed left and center only CW1K-3B CW4K-3B Maintained, key removed right and center only CW1K-3C CW4K-3C Maintained, key removed center only CW1K-3D CW4K-3D Maintained, key removed left and right only CW1K-3E CW4K-3E Maintained, key removed left only CW1K-3G CW4K-3G Maintained, key removed right only CW1K-3H CW4K-3H Spring return from right, key removed left and center only CW1K-31B CW4K-31B Spring return from right, key removed center only CW1K-31D CW4K-31D Spring return from right, key removed left only CW1K-31G CW4K-31G Spring return from left, key removed right and center only CW1K-32C CW4K-32C Spring return from left, key removed center only CW1K-32D CW4K-32D Spring return from left, key removed right only CW1K-32H CW4K-32H Spring return two-way, key removed center only CW1K-33D CW4K-33D Circuit Breakers 2 keys supplied with operator. 542 www.IDEC.com Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Illuminated Pushbuttons Round Extended M3.5 Terminal Screw Contact Block 10 10 Locking Ring LOC 28.5 Gasket K 41.4 ø19.5 Lens Diameter ø28 10 10 ø19.5 Lens Diameter ø28 K 0.5 M3.5 Terminal Screw LED Module Signaling Lights 41.4 LOC Gasket 1 1 Locking Ring 2 2 0.5 M3.5 Terminal Screw LED Module Panel Thickness 0.8 to 3.2 3 3 10 Panel Thickness 0.8 to 3.2 10 M3.5 Terminal Screw Contact Block 28.5 Round Flush 2.5 2.5 Momentary: 39.9 Maintained: 44.6 30 5.2 Momentary: 39.9 Maintained: 44.6 30 Relays & Sockets Pushbuttons Round Flush Round Extended Panel Thickness 0.8 to 3.2 10 10 10 0.5 0.5 ø19.5 K 28.5 28.5 41.4 LOC Gasket ø28 Locking Ring K ø28 ø19.5 Button Diameter 41.4 LOC Gasket Timers Locking Ring Button Diameter 10 1 1 2 2 10 Panel Thickness 0.8 to 3.2 M3.5 Terminal Screw Contact Block 3 3 10 M3.5 Terminal Screw Contact Block 2.5 2.5 30 Momentary: 39.9 Maintained: 44.6 5.2 30 Contactors Momentary: 39.9 Maintained: 44.6 Pilot Lights Round Flush Round Dome Panel Thickness 0.8 to 3.2 10 10 28.5 K ø28 ø19.5 41.4 LOC Gasket (Lens Diameter) Locking Ring 28.5 ø28 ø19.5 0.5 Circuit Breakers (Lens Diameter) 10 10 10 41.4 K Terminal Blocks LOC Gasket 1 1 M3.5 Terminal Screw LED Module 0.5 Locking Ring 2 2 M3.5 Terminal Screw LED Module 3 3 10 Panel Thickness 0.8 to 3.2 2.5 39.9 2.5 30 800-262-IDEC (4332) • USA & Canada 39.9 4.1 30 543 Switches & Pilot Devices Selector Switches Knob Operator Lever Operator Panel Thickness 0.8 to 3.2 10 10 10 1 1 10 Panel Thickness 0.8 to 3.2 2 10 M3.5 Terminal Screw Contact Block 3 2 10 M3.5 Terminal Screw Contact Block 3 Switches & Pilot Devices ø22mm - CW Series 0.5 Operator Angle 45° Gasket LOC K 45 Locking Ring ° Gasket 13.1 30 Keys 1 45° LOC ° Key No. Stamping Key No. Stamping ø28 41.4 Key No. Key No. 0 H0 H K Logo Stamping Logo Stamping 45 28.5 Gasket 22 22 1414 10 2 Operator Angle 0.5 4.84.8 10 3 8.8 8.8 Locking Ring Non-reversible Key 8.8 8.8 10.4 Terminal Blocks Key No. Stamping Key No. Stamping 31.5 Circuit Breakers Key No.: 3H to 6H (non-reversible key) Logo Stamping Logo Stamping 3 H3 H 1.5 6.36.3 30 31.5 Key No.: 0H to 2H (reversible key) 544 22 22 1414 Contactors 2.5 39.9 K 30 Reversible Key Panel Thickness 0.8 to 3.2 10 17.1 39.9 Key Selector Switches M3.5 Terminal Screw Contact Block LOC 2.5 2.5 39.9 45° ø28 41.4 ø28 41.4 28.5 Locking Ring 28.5 Signaling Lights Operator Angle Timers Relays & Sockets 0.5 www.IDEC.com Key No. Key No. 45 ° Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Accessories Item Appearance Part Number Remarks Locking Ring Wrench Brass MW9Z-T1 • Used to tighten the locking ring when installing the CW series control unit in a panel cut-out • Weight: Approx 150g Mounting Hole Plug Polyamide (black) LW9Z-BP1 • Used to plug an unnecessary ø22.3mm hole in the panel • Degree of protection: IP65 • Panel thickness: 0.8 to 6.0mm 110 8 ø2 Signaling Lights Material LED Modules Shape Current Draw Part Number Illumination Color Code k 6V AC/DC±10% 15 mA CW-EAQ2k Specify an illumination color code in place of k in the Part Number A: amber G: green PW: white R: red S: blue 12V AC/DC±10% 15 mA CW-EAQ3k 24V AC/DC±10% 16.5 mA CW-EAQ4k 100/120V AC±10% 18 mA CW-EAQHk 230/240V AC±10% 18 mA CW-EAQM4k Use a white (PW) LED module for yellow (Y) illumination. Replacement Parts Remarks 1 Round Flush Polyalylate CW9Z-L11k 2 Round Extended Polyalylate CW9Z-L12k 3 Round Dome Polyalylate CW9Z-L15k Color code k: A (amber), C (clear), G (green), R (red), S (blue), Y (yellow) Use a clear (C) lens for white (PW) illumination. 1: For illuminated pushbutton, pilot light 2: For illuminated pushbutton 3: For pilot light 1NO YW-E10R Housing color: Blue/Black Terminal No.: 3-4 1NC YW-E01 Housing color: Reddish purple Terminal No.: 1-2 Dummy Block Polyamide (black) CW-DB Locking Ring Polyamide (black) CW9Z-LN Gasket Nitrile rubber CW9Z-WM Waterproof gasket between CW control unit bezel and the mounting panel. LA9Z-SK-0 Specify a key No. in place of 0. 0H: Standard key (reversible) 1H to 2H: Reversible key 3H to 6H: Non-reversible key For dimensions, see page 544. CW9Z-D11 Use for flush buttons and pilot lights. CW9Z-D12 Use for extended buttons and dome pilot. Lens 1 2 3 Contact Blocks Spare Key Zinc (nickel-plated) Reversible Nameplate Round Flush Round Extended Plastic Circuit Breakers Rubber Boot (clear) Terminal Blocks Non-reversible Contactors Part Number Timers Material Item Relays & Sockets Operating Voltage Range CWAM-OB 800-262-IDEC (4332) • USA & Canada 545 Switches & Pilot Devices Nameplates - CW Series Nameplate Standard Legend Codes CWAM–Black Plastic Legend Nameplate (blank engraving CWAM-OB plate included) Nameplate (engraved) CWAM-j Additional Insert HWNP-O (blank) Relays & Sockets Pushbuttons Additional Insert HWNP-j (engraved) HWNP Dimensions 27 AUTO CLOSE DOWN EMERG.STOP FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON Pushbuttons/Selector Switches Code Legend Code 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 OPEN OUT RAISE RESET REVERSE RUN SLOW START STOP TEST UP I (Int’l On) O (Int’l Off) EMO 116 117 118 119 120 121 122 123 125 126 127 150 151 152 Legend AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWER-RAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISE-LOWER Code 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 Legend Selector Switches Code REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN OI (Int’l OFF ON) 216 217 218 219 220 221 222 223 250 12 Signaling Lights Switches & Pilot Devices ø22mm - CW Series Legend AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFF-WINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO 1. To order engraved nameplates, add legend code to nameplate part number. 2. Character height based on the number of characters and size of nameplate. Standard character size is 3/16”. 3. Nameplates with standard legends are the same list price as blank nameplates. 1. In place of j, insert either the standard legend code from table below or custom engraving delimited by “ “. 2. Standard engravings are available at no charge. Contactors Timers Nameplates Order Form — CW Series Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To ensure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: IDEC Rep/Distributor Contact: Name: PO number (if known): Telephone: IDEC Rep/Distributor Phone: Fax & Email: IDEC Rep/Distributor Fax & Email: CWAM Nameplate Terminal Blocks Engraving Location Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 9 characters. 11 characters maximum (for 7/64” size letters) 1/8” Letter Size 9 characters maximum (for 7/8” size letters) Sample Letter Sizes 7/64” Letters: A B C D Qty 1 2 3 4 5 6 7 8 9 10 11 Circuit Breakers Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 546 www.IDEC.com 1/8” Letters: A BCD Code 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 Switches & Pilot Devices ø22mm - CW Series Turn off the power to CW series switches before installation, removal, wiring and maintenance. Failure to turn power off may cause electrical shocks or fire hazard. When wiring, use wires of a proper size to meet the voltage and current requirements. Tighten the M3.5 terminal screws to a tightening torque of 1.0 to 1.3 N·m. Failure to tighten the terminal screws may cause overheating and fire. Operating Instructions Removing and Installing the Contact Unit Illuminated Pushbuttons and Pilot Lights When using the CW series switches in a safetyrelated circuit of a control system, observe safety rules and regulations of each country concerning particular applications of the actual machines and facilities. Perform risk assessment before operation to ensure safety. 1. To remove the contact block from the operator, push the yellow locking lever and turn it to the left. Removing the Lens To remove the lens from an illuminated pushbutton or pilot light, insert a flat screwdriver under the flange of the lens at 90° from the TOP marking and twist the screwdriver. Locking Lever Do not insert the screwdriver too far and do not apply excessive force to the lens, otherwise the bezel surface may be damaged. Operating Conditions Main parts of the CW series switches are made of plastic. Do not scratch the surface with a sharp object or apply excessive electric shock or load, otherwise the switches may be damaged. In particular, keep the button, lens and bezel from such damage, otherwise appearance and function may be impaired. Installation in Panel Cut-out Remove the locking ring from the operator. With the anti-rotation projection on the operator aligned with the recess in the mounting hole, insert the operator into the mounting hole. Tighten the locking ring from the rear of the panel. Anti-rotation projection Recess in mounting hole TOP Marking TOP Marking Screwdriver Insertion Angle Panel Approx. 30° Panel Surface TOP marking on illuminated pushbuttons, pushbuttons and pilot lights Panel Mounting First remove the contact block and then the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block to the operator. Installing the Lens Turn the groove in the lens to the TOP marking on the operator housing. With the groove aligned with the ridge, press the lens in. TOP Marking Ridge TOP marking on selector and key selector switches 1. Mounting hole dimensions are in compliance with IEC60947-5-1. Groove in the Lens Note for Panel Mounting When installing the operator in a panel cut-out, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring to a recommended tightening torque of 1.2 N·m. Do not use pliers and do not tighten excessively, otherwise the operator may be damaged. Marking Marking film can be applied for inscriptions or identification. Terminal Blocks 2. If the anti-rotation projection is removed from the bezel, CW series switches can be mounted in ø22.3mm mounting holes. To remove the antirotation projection, remove the gasket and use cutting pliers to break the projection. Contactors Mounting Hole Locking Ring Timers Do not apply detergents, cutting oils, or chemicals which may impair the function and appearance of the CW series switches. Screwdriver Insertion Direction 2. To install, align the TOP marking on the operator with the TOP marking on the contact block mounting adaptor, and turn the locking lever to the right. Relays & Sockets In corrosive gas or high-temperature, high-humidity environments, contact failure due to corrosion or color change or breakage of the housing may occur. Signaling Lights Notes for Operation Switches & Pilot Devices Safety Precautions Applicable Marking Film Size Illuminated Pushbutton (Round Flush) Pilot Light (Round Flush, Round Extended) Illuminated Pushbutton (Round Extended) 13.8 9 5. Circuit Breakers 9 5. ø1 12.6 ø1 Thickness: 0.2 mm maximum Film material: Polyester (recommended) Note: Film is not supplied and must be provided by the user. 800-262-IDEC (4332) • USA & Canada 547 Switches & Pilot Devices Operating Instructions, con’t Contact Blocks and LED Modules Applicable Crimping Terminals Pushbutton caps cannot be removed. Do not tamper with the cap using a screwdriver or pliers, otherwise it may be damaged. To remove the contact block from the operator, insert a flat screwdriver under the latch and push the screwdriver down as shown below. Before removing the LED module, first remove all contact blocks, and then remove the LED module in the same manner. Spade terminal When using crimping terminals, be sure to use insulating tubes or insulated crimping terminals. Turn the selector operator or key to the detent positions. Key Selector Switches 8.1 max. Insulation Tube Crimping Terminal Wire To prevent malfunction and damage, take the following precautions. • Besides the standard key (0H), six other keys are available. Use only a key with a number that matches the number on the switches’ key cylinder. (The standard key does not have a key number.) • Keys are available in two shapes. -0H (standard), 1H, 2H: reversible keys -3H, 4H, 5H, 6H: non-reversible keys Make sure of correct insertion direction. Applicable Wires Stranded wire: 2.0 mm2 maximum (14AWG) Solid wire: ø1.6 mm maximum Insulation 8.0 max. 8.0 max. One or two wires can be connected to the terminal. Timers Ferrule When connecting two ferrules to one terminal, use ferrules without insulation. 1.7 max. • Do not remove the key while turning. 0.5 min. Wiring 1.7 max. • Completely insert the key before turning. Relays & Sockets 11.5 max. 3.6 min. Selector Switches 6.9 max. Pushbuttons ø1.6 max. Signaling Lights Switches & Pilot Devices ø22mm - CW Series 8.0 max. When using spade terminals or ferrules, ensure that they are inserted completely. Ring terminals cannot be used. Screw Tightening Torque Circuit Breakers Terminal Blocks Contactors Tighten the M3.5 terminal screws to a recommended torque of 1.0 to 1.3 N·m. 548 www.IDEC.com
CW4S-2L 价格&库存
很抱歉,暂时无法提供与“CW4S-2L”相匹配的价格&库存,您可以联系我们找货
CW4S-2L
    • 1+149.07408
    • 5+143.11737
    • 10+137.16065
    库存:12
