Enclosures for HW, TW & XW 22mm
Switches & Pilot Devices
Features
Three compact sizes (mm): 76 x 76, 140 x 76 and 200 x 76
Available in 1, 2, 3, 4 or 5 mounting hole configurations
Easy installation: panel, wall or frame mountable
Polycarbonate enclosure cover and base, stainless steel screws
UL Listed, RoHS Compliant
IP65 and Nema Type 4X rated (when installed with IP65 or Nema
Type 4X unit)
• Class II electric shock protection (when installed with
applicable unit)
• Ideal for high temperatures (-25 to 60ºC) & corrosive environments
Specifications
Accessories
Operating Conditions
Ambient temperature
–25 to +60°C (no freezing)
Description
Relative humidity
45 to 85%RH
(no condensation)
Plug Adaptor 13.5mm
HW9Z-PG135
Storage temperature
–40 to +80°C (no freezing)
Mounting Bracket
FB9Z-PK1
Degree of pollution
3
Degree of Protection
IP65 (when IP65 switches & pilot devices are installed)
NEMA Type 4X Indoor Use Only (when Type 4X
Electric Shock Protection
Class II (when class II switches & pilot devices
are installed)
Material
Cover and base
Polycarbonate
Cover mounting screws
Stainless steel
Applicable Switches &
Pilot Devices
HW, TW and XW series switches, pilot devices &
accessories (see note below)
Weight (approx.)
76mm type: 125g (FB1W-111Z)
140mm type: 184g (FB2W-211Z)
200mm type: 243g (FB3W-311Z)
Note: Choose switches, pilot devices and accessories that match the mounting hole centers,
effective depth behind the cover, and the thickness of the cover where switches and pilot
devices are installed (3 mm). Enclosures with 30 or 36mm mounting hole centers may limit the
knob orientation of selector switches because the contact blocks can be mounted in one direction only on these mounting centers.
Enclosure Part Numbers
Size (mm)
76 x 76 x 59.5
140 x 76 x 59.5
200 x 76 x 59.5
Switches & pilot
devices are
sold separately.
Description
Part Number
Note: Connectors and nuts are not supplied with accessories.
Switch & Pilot Device Accessories
Series
HW
Series
XW
Series
E-Stops
Distance Between
Hole Centers (mm)
Enclosure 1 hole, Yellow FB1W-111Y
Enclosure 1 hole, Beige
FB1W-111Z
Enclosure 2 hole, Beige
FB2W-211Z
50
Enclosure 3 hole, Beige
FB2W-312Z
30
FB3W-311Z
50
Enclosure 4 hole, Beige
FB3W-413Z
36
Enclosure 5 hole, Beige
FB3W-512Z
30
Part Number
TW
Series
Description
Part Number
Nameplate
HWAM, HWAQ, HWAS,
HWAV
Marking plate for
nameplate
HWNP
Anti-rotation ring
HW9Z-RL
EMO switch guard
HW9Z-KG1, HW9Z-KG2
HW9Z-KG3, HW9Z-KG4
Switch cover
HW9Z-K1, HW9Z-K11
Pushbutton clear
boot
OC-31, OC-32
Padlock cover
HW9Z-KL1
Nameplate
HWAV
EMO switch guard
HW9Z-KG1, HW9Z-KG2
HW9Z-KG3, HW9Z-KG4
Anti-rotation ring
HW9Z-RL
Nameplate
NWA, NWAQ,
NWAS-0, NWAL-0,
NWAQL-0, NWAV
Anti-rotation ring
OGL-31
Metal button guard
OLW-C
Pushbutton clear
boot
OC-31, OC-32
Button cover
OCW-11
Padlock cover
HW9Z-KL1
Specifications con’t on back
External Dimensions
Cover Mounting Screws
2-ø21.3
Knockout
30
50
18
36
30
59.5
30
36
50
30
30
30
36
50
140
140
.3
ø22
200
200
200
Cover
Mounting Screws
76
76
76
FB1W-111Y
FB1W-111Z
76
FB2W-312Z
FB2W-211Z
Internal Dimensions
D
FB3W-311Z
FB3W-413Z
FB3W-512Z
76mm (FB1)
Model
FB1
FB2
FB3
D
45
92
150
140 and 200mm (FB2/FB3)
4-M4 Tapped Holes for Rear Mounting
(Depth: 10 mm)
2-Front Mounting Holes
ø14 Knockout
2-ø14 Knockout
21
Mounting Area
Thickness
Measurements (mm)
4-M4 Tapped Screw Holes for
Rear Mounting (Depth: 10mm)
2
Model FB2 FB3
A
84 144
B
104 164
C
106 166
.2
R2
21
41
3
76
4-
55
76
External Back Dimensions
Measurements (mm)
45
76
2-
15.5
A
B
C
ø4
.6
62
Mounting
FB9Z-PK1 Frame Mounting Adapter
R3
.3
72
36
31
62
6.6
10.5
Four M4 Tapped Screw Holes
54
FB9Z-PK1
All dimensions are in mm.
30
2 6.5
10 13
Two M4 Tapped
Screws (supplied)
R2
.5
R4
Mounting Hole Dimensions
FB2/FB3
50mm Mounting
Centers
36/50mm Mounting
Centers
30mm Mounting
Centers
3.2
3.2
3.2
FB1
FB3
13
Model
FB2
Shape
.3
2
ø2
2.
13
ø2
3
13
IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.idec.com
©2007 IDEC Corporation. All Rights Reserved. Catalog No. FB9Y-DS100-0 1/07 10K
很抱歉,暂时无法提供与“FB2W-211Z.”相匹配的价格&库存,您可以联系我们找货
