FB3W-512Z
FB3W-512Z
    IDEC(日本和泉)
FB3W-512Z 数据手册
Enclosures for HW, TW & XW 22mm Switches & Pilot Devices Features • • • • • • Three compact sizes (mm): 76 x 76, 140 x 76 and 200 x 76 Available in 1, 2, 3, 4 or 5 mounting hole configurations Easy installation: panel, wall or frame mountable Polycarbonate enclosure cover and base, stainless steel screws UL Listed, RoHS Compliant IP65 and Nema Type 4X rated (when installed with IP65 or Nema Type 4X unit) • Class II electric shock protection (when installed with applicable unit) • Ideal for high temperatures (-25 to 60ºC) & corrosive environments Specifications Accessories Operating Conditions Ambient temperature –25 to +60°C (no freezing) Description Relative humidity 45 to 85%RH (no condensation) Plug Adaptor 13.5mm HW9Z-PG135 Storage temperature –40 to +80°C (no freezing) Mounting Bracket FB9Z-PK1 Degree of pollution 3 Degree of Protection IP65 (when IP65 switches & pilot devices are installed) NEMA Type 4X Indoor Use Only (when Type 4X switches & pilot devices are installed) Electric Shock Protection Class II (when class II switches & pilot devices are installed) Material Cover and base Polycarbonate Cover mounting screws Stainless steel Applicable Switches & Pilot Devices HW, TW and XW series switches, pilot devices & accessories (see note below) Weight (approx.) 76mm type: 125g (FB1W-111Z) 140mm type: 184g (FB2W-211Z) 200mm type: 243g (FB3W-311Z) Note: Choose switches, pilot devices and accessories that match the mounting hole centers, effective depth behind the cover, and the thickness of the cover where switches and pilot devices are installed (3 mm). Enclosures with 30 or 36mm mounting hole centers may limit the knob orientation of selector switches because the contact blocks can be mounted in one direction only on these mounting centers. Enclosure Part Numbers Size (mm) 76 x 76 x 59.5 140 x 76 x 59.5 200 x 76 x 59.5 Switches & pilot devices are sold separately. Description Part Number Note: Connectors and nuts are not supplied with accessories. Switch & Pilot Device Accessories Series HW Series XW Series E-Stops Distance Between Hole Centers (mm) Enclosure 1 hole, Yellow FB1W-111Y – Enclosure 1 hole, Beige FB1W-111Z – Enclosure 2 hole, Beige FB2W-211Z 50 Enclosure 3 hole, Beige FB2W-312Z 30 Enclosure 3 hole, Beige FB3W-311Z 50 Enclosure 4 hole, Beige FB3W-413Z 36 Enclosure 5 hole, Beige FB3W-512Z 30 Part Number TW Series Description Part Number Nameplate HWAM, HWAQ, HWAS, HWAV Marking plate for nameplate HWNP Anti-rotation ring HW9Z-RL EMO switch guard HW9Z-KG1, HW9Z-KG2 HW9Z-KG3, HW9Z-KG4 Switch cover HW9Z-K1, HW9Z-K11 Pushbutton clear boot OC-31, OC-32 Padlock cover HW9Z-KL1 Nameplate HWAV EMO switch guard HW9Z-KG1, HW9Z-KG2 HW9Z-KG3, HW9Z-KG4 Anti-rotation ring HW9Z-RL Nameplate NWA, NWAQ, NWAS-0, NWAL-0, NWAQL-0, NWAV Anti-rotation ring OGL-31 Metal button guard OLW-C Pushbutton clear boot OC-31, OC-32 Button cover OCW-11 Padlock cover HW9Z-KL1 Specifications con’t on back External Dimensions Cover Mounting Screws Cover Mounting Screws Cover Mounting Screws 2-ø21.3 Knockout Cover Mounting Screws 30 50 18 36 30 59.5 Cover Mounting Screws 30 36 50 30 30 30 36 50 140 140 .3 ø22 200 200 200 Cover Mounting Screws 76 76 76 FB1W-111Y FB1W-111Z 76 FB2W-312Z FB2W-211Z Internal Dimensions D FB3W-311Z FB3W-413Z FB3W-512Z 76mm (FB1) Model FB1 FB2 FB3 D 45 92 150 140 and 200mm (FB2/FB3) 4-M4 Tapped Holes for Rear Mounting (Depth: 10 mm) 2-Front Mounting Holes 2-Front Mounting Holes ø14 Knockout 2-ø14 Knockout 21 Switch & Pilot Device Mounting Area Thickness Measurements (mm) 4-M4 Tapped Screw Holes for Rear Mounting (Depth: 10mm) 2 Model FB2 FB3 A 84 144 B 104 164 C 106 166 .2 R2 21 41 3 76 4- 55 76 External Back Dimensions Measurements (mm) 45 76 2- 15.5 A B C ø4 .6 62 Mounting FB9Z-PK1 Frame Mounting Adapter R3 .3 72 36 31 62 6.6 10.5 Four M4 Tapped Screw Holes 54 FB9Z-PK1 All dimensions are in mm. 30 2 6.5 10 13 Two M4 Tapped Screws (supplied) R2 .5 R4 Mounting Hole Dimensions FB2/FB3 50mm Mounting Centers 36/50mm Mounting Centers 30mm Mounting Centers 3.2 3.2 3.2 FB1 FB3 13 Model FB2 Shape .3 2 ø2 2. 13 ø2 3 13 IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.idec.com ©2007 IDEC Corporation. All Rights Reserved. Catalog No. FB9Y-DS100-0 1/07 10K
FB3W-512Z 价格&库存
很抱歉,暂时无法提供与“FB3W-512Z”相匹配的价格&库存,您可以联系我们找货
FB3W-512Z
    • 1+335.05920
    • 200+133.69320
    • 500+129.22200
    FB3W-512Z
      • 1+470.134631+61.11598
      FB3W-512Z
      • 1+319.06956
      • 5+306.32302
      • 10+293.54524
      库存:11
