Standard Interlock Safety Switches
HS6B
HS6B Subminiature Interlock Switches
Overview
Key features:
• Only 78 x 30 x 15mm
• Two actuator entrances provide flexibility for installation options
• Integrated molded cable reduces wiring time
• IP67 (IEC60529)
• Direct Opening Action
• Actuators comply with ISO14119 and EN1088
Double
Insulation
Actuator Keys (order separately)
Part Number
1NC-1NO
1m
HS6B-11B01
3m
HS6B-11B03
5m
HS6B-11B05
1m
HS6B-02B01
3m
HS6B-02B03
5m
HS6B-02B05
1m
HS6B-12B01
3m
HS6B-12B03
5m
HS6B-12B05
1m
HS6B-03B01
3m
HS6B-03B03
5m
HS6B-03B05
2NC
11
31
12
34
Zb
12
32
2NC-1NO
11
21
33
3NC
Zb
12
22
34
Zb
11
12
21
22
31
32
Appearance
Part Number
Shape
HS9Z-A61
Straight
HS9Z-A62
Right-angle
HS9Z-A65
Adjustable actuator
90° angle
HS9Z-A66
Adjustable actuator
180° angle
Safety Control Relays
Cable
Length
Enabling Switches
Contact Configuration
11
33
Interlock Switches
Part Numbers
Zb
XW Series E-Stops
Direct Opening
Action
GS-ET-15
BG standard in Germany
Actuators are not included and must be ordered separately.
Standard stock items in bold.
Contact Configuration & Operation Chart
Type
HS6B-11
HS6B-12
11
33
2NC
11
31
2NC-1NO
11
21
33
3NC
11
21
31
Zb
Zb
Zb
Zb
34
11-12
33-34
12
32
11-12
31-32
12
22
34
11-12
21-22
33-34
12
22
32
11-12
21-22
31-32
Actuator inserted completely
800-262-IDEC (4332) • USA & Canada
: Contact ON (closed)
: Contact OFF (open)
AS-Interface Safety at Work
HS6B-03
1NC-1NO
Contact Operation Chart
0.8 (Actuator Mounting Reference Position)
5.5 5.8
28.2 (Travel: mm)
Light Curtains
HS6B-02
Actuator removed completely
271
HS6B
Enabling Switches
Interlock Switches
XW Series E-Stops
Overview
Specifications
Conforming to Standards
EN1088, IEC60947-5-1, EN60947-5-1, GS-ET-15, IEC60664-1, IEC60204-1, EN60204-1, UL508,
CSA C22.2 No. 14
Operating Temperature
–25 to +70˚C (no freezing)
Storage Temperature
–40 to +80˚C (no freezing)
Relative Humidity
45 to 85% RH (no condensation)
Storage Humidity
95% maximum (no condensation)
Altitude
2,000m maximum
Pollution Degree
3
Rated Insulation Voltage (Ui)
300V
Impulse Withstand Voltage (Uimp)
Insulation Resistance
4kv
Between live & dead metal parts: 100MΩ maximum
Between positive & negative live parts: 100MΩ minimum
Electric Shock Protection Class
Class II
Degree of Protection
IP67 (IEC60529)
Vibration
Resistance
Operating Extremes
Damage Limits
Contact Resistance
Shock
Resistance
5 to 55 Hz, half amplitude 0.5 mm
30Hz, half amplitude 1.5mm
300mΩ maximum
Operating Extremes
300m/s2 (30G)
Damage Limits
1000m/s2 (100G)
Direct Opening Travel
8mm minimum
Direct Opening Force
60N minimum
Thermal Current (lth)
2.5A
Operating Frequency
1200 operations/hour
Mechanical Life
1,000,000 operations (GS-ET-15)
Recommended Actuation Speed
0.05 to 1.0m/s
Wire Tensile Strength
50N minimum
Electrical Life
100,000 operations (at full rated load)
Conditional Short-Circuit Current
50A 250V (IEC60947-5-1, IEC60269-1, -2)
Weight
120g
Contact Ratings
Operating Voltage (Ue)
AC
Rated Operating Current (Ie)
Resistive load (AC-12)
Inductive load (AC-15)
Resistive load (DC-12)
DC
125V
250V
2.5A
1.5A
1.5A
0.75A
2.5A
1.1A
0.55A
(2A)
(0.4)A
(0.2A)
2.3A
0.55A
0.27A
(1A)
(0.22A)
(0.1A)
Light Curtains
Inductive load (DC-13)
30V
272
www.IDEC.com
HS6B
Installation Notes
• Safety switch body installation (M4 screw): 1.0~1.5N-m
• Do not tighten or loosen the fastened cable conduit of the safety switch
• Actuator installation (M4 screw): 1.0~1.5N-m
• Minimum bend radius of installed cable: 40mm
Gland
um
nim ius
Mi ad
R
mm
40
(100)
Handling Cables
Overview
Recommended Screw Torque
Wiring Designations
NC
21-22
brown-brown/white
NO
33-34
orange-orange/white
NC
11-12
blue-blue/white
NC
21-22
brown-brown/white
NC
31-32
orange-orange/white
NC
11-12
blue-blue/white
NO
33-34
orange-orange/white
NC
11-12
blue-blue/white
NC
31-32
orange-orange/white
2
• Interlock Switch
Dimensions (mm)
10.4
•HS6B
Interlock Switch
2.
R
2
2.
R
(9)
78
4
(ø7.6)
(ø7.6)
10.4
4 4
27.6
27.6
(ø7.6)
4
5.5
4
10.4
(9)
78
35
(9)
• Using the HS9Z-A61 Straight Actuator
• Using the HS9Z-A62 Right-angle Actuator
• Using the HS9Z-A65/A66
Angle Adjustable Actuator
±1
Using
Angle
Actuator
(12.6
(25)
Angle
Adjustable Actuator
•Straight
Using(HS9Z-A61)
the
HS9Z-A61
Straight
Actuator
•Right-angle
Using actuator
the HS9Z-A62
Right-angle
Actuator
• UsingAdjustable
the HS9Z-A65/A66
(21.4)
actuator
Using
Right-angle
(HS9Z-A62)
•Using
Using straight
the HS9Z-A61
Actuator
Using
the
HS9Z-A62
Actuator
Using
the
HS9Z-A65/A66
(12.6±1)
±1 Actuator
(25)
Angle
Adjustable
30.8
22.6
28.8
A65/A66)
(5)
(25)
28.8
22.6±1
15.1±1
0.8
48.8
0.8
48.8
0.8
(25)
28.8
0.8
0.8
0.8 0.8
(25)
48.8
48.8
0.8
(25)(25)
(41.4)
0.8
22.6
(25)±1
22.6±1
0.8
±1 ±1
15.115.1
Actuator Stop
(Note 2) (supplied)
Actuator Stop
(Note 2) (supplied)
Actuator Stop
Actuator Stop
(Note 2) (supplied)
(Note 2) (supplied)
0.8
(41.4)
0.8
0.8 0.8
(14)
22.6±1
28.8
15.1±1
±1
22.6
(21.4)
(41.4)
(41.4)
0.8
40.1±1
22.6±1
0.8
(5)
22.6±1
(14)
(5)
(21.4)
(21.4)
40.1±1
0.8
±1 ±1(14)(14)
40.150.8
40.1
(14)
(5)
50.8
0.8
0.8
50.850.8 (14)(14)
0.8 0.8 (5)
(5)
(30.1±1)
Actuator Stop
(Note 2)
(supplied
Actuator
Stop
(Note 2)
(supplied)
30.8
Actuator Stop
(Note 2) (supplied)
Actuator Stop
(Note 2) (supplied)
Actuator Stop
Actuator Stop
(Note 2) (supplied)
(Note 2) (supplied)
Light Curtains
Actuator Stop
(Note 2)
Actuator
(suppliedStop
(Note 2)
(supplied)
0.8
(30.1±1)
(5) (5)
±1) ±1)
(30.1(30.1
30.8
0.8
0.8
(14)
(12.6±1)
±1)
30.8
(12.6
(HS9Z-
10.410.4
20 to 22
20 to 22
2-M4 Screws
(ø4.3 or M4 tapped)
2-M4 Screws
2-M4 Screws
(ø4.3 or M4 tapped)
2-M4 Screws
The interlock
can be
(ø4.3 or switch
M4 tapped)
(ø4.3 or M4 tapped)
The interlock switchmounted
can be in two directions.
mounted in two directions.The interlock switch can be
35
(9)
4
1
35
15
35
20 to 22
20 to 22
(58)
(58)
1
30
5.5
1
30
5.5
1 20 20 1
10.1
10.1
30 30
10.110.1
15
(58)
(58)
78
Slot
15 Plug (Note 1)
5.5
Slot Plug (Note 1) (supplied)
78
5.5
(supplied)
Slot Plug (Note 1)
Slot Plug (Note 1) Note 1:(supplied)
Plug the unused
5.5 actuator
(supplied)
entry slot
using the slot plug
Note 1: Plug the unused
actuator
supplied
with
the
interlock
switch.
entry slot using the slot plug
Note 1: Plug the unused actuator
Note
1: Plug
actuator
27.6
supplied
withthe
theunused
interlock
switch.
entry
slot using the slot
plug
supplied with the interlock
27.6 switch.
supplied with the interlock switch.
15
• Mounting Hole Layout
• Mounting Hole
Layout
Installation
Enabling Switches
5.5 5.5
1
10.4
10.4
R R 1
2. 2.
2 2
• Interlock Switch
• Interlock 10.4
Switch
(ø7.6)
HS6B-02B01
(2NC)
blue-blue/white
Interlock Switches
HS6B-11B01
(1NC-1NO)
Color
11-12
4
HS6B-03B01
(3NC)
Terminal #
NC
4
HS6B-12B01
(2NC-1NO)
Contact
XW Series E-Stops
Part Number
273
2-ø9
28.2
7.5
5.5
25
34
20°
8.4
3.5
1.2
Horizontal Adjustment
The base is made of glass-reinforced PA66 (66 nylon).
Angle adjustment screws are stainless steel. When using adhesive
on screws, take material compatibility into consideration.
Vertical Adjustment
20°
• Actuator Mounting Hole Layout
Straight/Right-angle
Actuator
20°
3.5
1.2
13.1 14
34
4.3
3.5
10.4
1.2
metal key inserted in opposite directions.
(M3 Hexagon Socket Head Screw)
2-ø
8.4
20°
16.8
20° 5.5
25
25
34
34
Enabling Switches
R2 2.5 Angle Adjustment
(M3 Hexagon
4 H .1
Socket Head Screw)
ole
s)
(M
Orienting Insert
Orienting Insert
R2
4 H .1
ole
s)
(M
34
13.1 14
3.5
34
The orientation of actuator adjustment (horizontal/vertical) can be
Vertical Adjustment
When
(5) of actuator
The mounted
orientation
adjustment
can be
changed
using the orienting
insertHorizontal
(white plastic)
installed Vertical
on the Adjustment
14
Adjustment
changed using the orienting insert (white
plastic)
installed on the
back of
the actuator.
Rubber
back of the actuator.
2-ø
Bushing
4.3
PA66 (66Mounting
nylon).
• Actuator
Hole Layout
14
PA66
(66 nylon).screws are stainless steel. When using adhesive
Angle
adjustment
14Straight/Right-angle
steel. When
adhesive
on screws,
take using
material
compatibility Straight/Right-angle
into consideration.
Actuator
1.2on screws, take material compatibility into consideration.
Actuator
2-M4 Screws
Note 2: After mounting the actuator, remove the actuator
2-M4 Screws
(ø4.3 or M4 tapped)
Note 2: After mounting the actuator, removestop
the actuator
from the interlock switch.
(ø4.3 or M4 tapped)
stop from the interlock switch.
Actuator Stop (supplied)
(Note 2)
25
25
2-M4 Screws
(ø4.3 or M4 tapped)
2-M4 Screws
(ø4.3 or M4 tapped)
Light Curtains
13.1 14
2-ø9
ed)
15
(M3 Hexagon
Socket Head Screw)
20°
14
15
20°
When mounted (33.8)
n
nted (5.6)
0.8
16.8
5.5
3.5
1.2
Angle Adjustment
2-M4 Screws
Vertical Adjustment
Angle Adjustment
Hexagon
Headremove
Screw) the actuator
Note 2: After(M3
mounting
theSocket
actuator,
(ø4.3 or M4 tapped)
Adjustment
(M3 Hexagon Socket Head Screw)stop from Vertical
the interlock
switch.
Angle
Adjustment
Vertical Adjustment
Angle Adjustment
(M3 Hexagon Socket
HeadAdjustable
Screw)
Angle
Actuator
Vertical Adjustment
13
28.2
Actuator Stop
2-ø9
13(supplied)
28.2
(Note
2)
Stop (supplied)
(Note 2)
7.5
2
Actuator
Stop
(supplied)
(Note
2)
Rubber Bushing
7.5
2
(Note 2)
Orienting Insert
2-M4 Screws
Orienting Insert
(ø4.3 or M4 tapped)
Right-angle Actuator (HS9Z-A62)
-A62)
274
20°
Actuator
2-M4 Scre
(ø4.3 or M4 ta
2-M4 Screws
(ø4.3 or M4 tapp
Orienting Insert
The orientation of Horizontal
actuator adjustment
Adjustment
Angle
Adjustment
changed using the orienting insert (white plastic) installed
on the
back of the actuator.Angle Adjustment
20°
Interlock Switches
Rubber
Bushing
14
20°
When
mounted (5)
14
2-ø9
3
4.
When mounted (5)
Vert
The H
HS9Z-A65 and HS9Z-A66 have the
(M3 Hexagon
0.8 The HS9Z-A65
les inserted in opposite directions.
andHead
HS9Z-A66
the okey
Socket
Screw)havemetal
Orienting Insert
0.8
8.4
ø
2-
(15.8)
Orienting Insert
0.8
14 15
5.5
20°
(Note 2)
When
mounted (33.8)
• Angle Adjustmentable Actuator
• Angle Adjustmentable Actuator (HS9Z-A65)
Straight Actuaor
(HS9Z-A61)
When
• Angle
Adjustmentable
Actuator (HS9Z-A65)
Adjustable
Adjustable
Actuator (HS9Z-A66)
(HS9Z-A66)
mounted
(5.6)
0.8 Actuator (HS9Z-A65)
R2
(M
.1
(HS9Z-A66)
43.2
20.9
15
4
25
34
34
Angle Adjustment
Note
2: AfterSocket
mounting
(M3
Hexagon
Headthe
Screw)
2
(Note 2)
Orienting Insert
• Right-angle Actuator (HS9Z-A62)
PA66
(66 nylon).
2-M4
Screws
When using adhesive
(ø4.3 orsteel.
M4 tapped)
Vertical
Adjustment
20°
13
13.1 14
3.5
3.5
10.4
1.2
Rubber
Bushing
Orienting Inse
R2
(M
4 H .1
2-M4 Screws
(M3 Hexagon
ole
s)
Socket
Head
Screw)
(ø4.3 or M4 tapped)
Actuator can be
changed using the orienting insert (white plastic) installed on
25 the
14
20°
When
mounted (5)
When mounted (5)
2-ø
4.3
Angle Adjustment
1.2
Vertical Adjustment
(Note 2)
Rubber Bushing
14
Screw)
Angle
Adjustable
(Note 2)
2-ø9
15
Angle Adjustment
16.8
0.8
(HS9Z-A62)
Actuator Installation
TheRight-angle
base is made ofactuator
glass-reinforced
PA66 (66 nylon).
(HS9Z-A66)
Horizontal Angle
Adjustment
When mounted
(33.8)
adjustment
screws are
stainless steel. WhenThe
using
adhesive
HS9Z-A65
and
HS9Z-A66
have the
When
0.8
screws,
Orienting on
Insert
directions.
mountedtake
(5.6) material
0.8
Actuator
3.5
3.5
1.2
14
3
4.
15
8.4
ø
2-
Overview
(15.8)
14
Actuator Stop (supp
(No
2
Vertical Adjustment
Actuator
• Actuator
Actuator
(HS9Z-A65)
• Right-angle
Actuator
(HS9Z-A62)
8.4
1.2
4.3
34
43.2
13.1 14
2-ø9
20.9
7.5
Rubber Bushing
The orientation
Orienting Insert Horizontal Adjustment
changed using the orienting insert (white plastic) installed on the
14
Rubber
2-ø
• Straight
Straight Actuaor
(HS9Z-A61)
Bushing
actuator
(HS9Z-A61)
XW Series E-Stops
Angle Adjustment
28.2
20°
When mounted (5)
13
(Note 2)
2-ø9
Vertical Adjustment
16.8
8.
HS6B
R2
(M
4 H .1
ole Adjustment
Vertical
s)
(M3 Hexagon
Socket Head Screw)
15
www.IDEC.com
14
25
HS6B
Minimum Radius of Hinged Door
Note: Because deviation or dislocation of hinged door may occur in actual applications, make sure
of the correct operation before installation.
HS9Z-A62 Actuator
M
1
im 60 m
um m
Ra
di
us
M
in
1
im 60 m
um m
Ra
di
us
50 mm
um Radius
Minim
50 mm
dius Door Hinge
Minimum Ra
Door Hinge
Label
Label
HS9Z-A65
HS9Z-A65
HS9Z-A66
HS9Z-A66
in
Door Hinge
Door Hinge
2
im 30 m
um m
Ra
di
us
Door Hinge
Label
Label
HS9Z-A65
HS9Z-A65
HS9Z-A66
HS9Z-A66
Door Hinge
50 mm
Door Hinge
Minim50
ummm
Radius
Minimum Radiu
s
• When
the doorSwing
hinge is on extension line of Vertical
the actuator
mounting surface:
Horizontal
Swing
Horizontal Swing
m
ius
d
m
70 mmRa ius
u
im
0 m ad
Min7 um R
im
Min
HS9Z-A65
HS9Z-A65
HS9Z-A66
HS9Z-A66
70
Min
m
im
70 m
Min um
imu Rm
am
m R dius
adi
us
in
50 mm
m Radius
Minimu
50 mm
Door Hinge
Minimum Radius
Door Hinge
Door Hinge
Door Hinge
Label
Label
Door Hinge
Door Hinge
VerticalmSwing
ius
m ad
70 ummR ius
im m ad
Min70 um R
im
Min
Door Hinge
Door Hinge
HS9Z-A65
HS9Z-A65
HS9Z-A66
HS9Z-A66
Label
Label
7
Min
im 0 m
Door Hinge
Min um70R m
m
imu
a
m R dmius Door Hinge
adi
us
Actuator Angle Adjustment for the HS9Z-A65/HS9Z-A66
Door Hinge
• Using the angle adjustment screw, the actuator angle can be adjusted (see
figures on page 370).
• Adjustable angle: 0 to 20°
• The larger the adjusted angle of the actuator, the smaller the applicable
radius of the door opening.
• After installing the actuator, open the door. Then adjust the actuator so that
its edge can enter properly into the actuator entry slot of the interlock switch.
• After adjusting the actuator angle, apply Loctite to the adjustment screw so
that the screw will not become loose.
Enabling Switches
M
in
Vertical Swing
Vertical Swing
Interlock Switches
2
im 30 m
um m
Ra
di
us
Horizontal Swing
Horizontal Swing
Door Hinge
50 mm
Door Hinge
Minim50
ummm
Radius
Minimum Radiu
s
• When the door hinge is on the extension line of the actuator mounting
surface:
M
• When the door hinge is on the extension line of the interlock switch surface:
XW Series E-Stops
When using the HS9Z-A65/HS9Z-A66 Angle Adjustable
(vertical) Actuator
Overview
• When using the interlock switch for a hinged door, refer to the minimum
radius of doors shown below. For doors with small minimum radius, use angle
adjustable actuators (HS9Z-A65 or HS9Z-A66).
Light Curtains
275
很抱歉,暂时无法提供与“HS6B-12B05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1091.338071+141.36645
