HW1B-M1F11-G
HW1B-M1F11-G
    IDEC(日本和泉)
    按动开关
HW1B-M1F11-G 数据手册
Emergency Stop Pushbuttons (Sub-Assembled) Part Numbers: Emergency Stop Operators Part Numbers: Contact Blocks Ø 29mm Head Pushlock Turn Reset 1NO HW1B-V3R* Ø 40mm Head Pushlock Turn Reset red HW4B-V3R* HW1B-V4R HW4B-V4R yellow HW1B-V4Y HW4B-V4Y 1NC Standard Fingersafe (IP20) Spring-Up Terminal Contacts Ø 40mm Head EMO Pushlock Turn Reset HW1B-V4R-EMO-2* HW4B-V4R-EMO-2* HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-G10-MAU (gold contacts) HW-G01-MAU (gold contacts) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Exposed Screw Terminal Contacts Ø 40mm Head Push-Pull red HW1B-Y2R yellow HW1B-Y2Y HW4B-Y2R HW4B-Y2Y Dummy Block Ø 40mm Head Pushlock Key Reset HW1B-X4R* HW4B-X4R* Ø 60mm Head Pushlock Turn Reset HW1B-V5R* 1. *Available in red only. 2. All Emergency Stop Buttons are non-removable from the operator. Part Number: Contact Block Mounting Adaptor (safety lever lock included) HW-CB2C – TW-DB 1. All assembled part numbers in catalog include standard (HW-F...) contacts. (except unibody) 2. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 3. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 4. All contacts (including exposed screw) are UL, CSA, and IEC compliant and carry the CE mark. Part Numbers: Anti-Rotation Ring HW9Z-RL Use with notched panel cutout to prevent unit rotation. 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from unlocking contacts. Emergency Stop Stations Part Numbers: Emergency Stop Stations Ø 40mm Pushlock Turn Reset Ø 29mm Pushlock Turn Reset Ø 40mm Push-Pull Reset Ø 40mm Pushlock Key Reset 1NO-1NC HW1X-BV411-R* HW4X-BV411-R* 2NC HW1X-BV402-R* HW4X-BV402-R* 1NO-1NC HW1X-BV311-R* HW4X-BV311-R* 2NC HW1X-BV302-R* HW4X-BV302-R* 1NO-1NC HW1X-BY411-R* HW4X-BY411-R* 2NC HW1X-BY402-R* HW4X-BY402-R* 1NO-1NC HW1X-BX411-R* HW4X-BX411-R* 2NC HW1X-BX402-R* HW4X-BX402-R* 1. * Available in Red only. 2. Maximum of two contact blocks. 3. Available as completed unit only. 4. Box is supplied with yellow top and black bottom only. Part Numbers: Nameplates for Emergency Stop Stations Black Red NSA-0 NSA-0R NSA-*R NSA-*R 1. In place of * please insert the word, letters, or numbers you would like engraved. For standard engravings, see page A3-96. 2. For specifications on engravings, please consult factory. Part Numbers: Base Mount Contact Blocks 1NO HW-S10 1NC HW-S01 Part Numbers: Plug Adaptors G1/2 HW9Z-G PG16 HW9Z-PG Panel Mount Dimensions Oiltight Switches & Pilot Devices ø22mm - HW Series Pilot Lights (Assembled) Part Numbers: Pilot Lights Style Round Flush Full Voltage Plastic Bezel Metal Bezel HW1P-1FQ➃-➁-➂ HW4P-1FQ➃-➁-➂ HW4P-1FH2➃-➁ HW4P-1FM4➃-➁ HW4P-1FT8➃-➁ 120V AC 240V AC 480V AC HW1P-1FH2➃-➁ HW1P-1FM4➃-➁ HW1P-1FT8➃-➁ (Full Voltage type shown) DC-DC Converter* 110V DC HW1P-1D2➃-➁ Dome Full Voltage – HW1P-2FQ➃-➁-➂ HW4P-2FQ➃-➁-➂ HW4P-2FH2➃-➁ HW4P-2FM4➃-➁ HW4P-2FT8➃-➁ Transformer 120V AC 240V AC 480V AC HW1P-2FH2➃-➁ HW1P-2FM4➃-➁ HW1P-2FT8➃-➁ (Full Voltage type shown) DC-DC Converter* 110V DC HW1P-2D2➃-➁ – Square Flush Full Voltage HW2P-1FQ➃-➁-➂ – (Transformer type shown) Transformer 120V AC 240V AC 480V AC HW2P-1FH2➃-➁ HW2P-1FM4➃-➁ HW2P-1FT8➃-➁ – DC-DC Converter* 110V DC HW2P-1D2➃-➁ – LED HW1P-5Q4-➁ Incandescent HW1P-5Q7-➁ Jumbo Dome Full Voltage** 24V AC/DC A3 Switches & Pilot Devices Transformer – 1. In place of ➁, specify the Lens/LED Color Code. 2. In place of ➂specify the Full Voltage Code from table below. 3. In place of ➃ specify Lamp Type Code. 4. *DC-DC convertor voltage input from 90-140V DC, comes with spring up terminals only. 5. **Available with spring up terminals and 24V only. 6. For nameplates and accessories, see page A3-96. 7 For dimensions, see page A3-100. ➁ Lens/LED Color Code Color Code ➂ Full Voltage Code ➃ Lamp Type Code Lamp Code Amber A 6V AC/DC 6 Incandescent Blank Green G 12V AC/DC 12 LED D Red R 24V AC/DC 24 Voltage Code Blue S 120V AC (LED only) 120 White W 240VAC (LED only) 240 Yellow Y www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-61 Oiltight Switches & Pilot Devices ø22mm - HW Series Pilot Lights (Partial-Assemblies) Full Voltage Models Operator/Lens Switches & Pilot Devices A3 Part Numbers: Operator/Lens Plastic Bezel Style + Lamp Metal Bezel = Part Numbers: Lamps Voltage Type Round Flush LED HW1P-1FQ0-➁ HW4P-1FQ0-➁ Dome HW1P-2FQ0-➁ HW4P-2FQ0-➁ Incandescent Square Flush HW2P-1FQ0-➁ Complete Pilot Light Part Number 6V AC/DC LSTD-6➁ 12V AC/DC LSTD-1➁ 24V AC/DC LSTD-2➁ 120V AC LSTD-H2➁ 240V AC LSTD-M4➁ 6.3V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 30V AC/DC IS-30 1. In place of ➁, specify the LED Color Code from table on previous page. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. – 1. In place of ➁, specify the Lens Color Code from table on previous page. 2. Operator/Lens assembly for use with standard transformers only6, not spring up terminal type. Transformer Models Transformer/Lamp Part Numbers: Operator/Lens Style Plastic Bezel + Operator/Lens Metal Bezel Round Flush HW1P-1F0-➁ HW4P-1F0-➁ Dome HW1P-2F0-➁ HW4P-2F0-➁ Square Flush HW2P-1F0-➁ – = Complete Part Numbers: Transformer/Lamp Item Voltage Part Number 120V AC with LED HW-FH2-➁ 240V AC with LED HW-FM4-➁ 480V AC with LED HW-FT8-➁ 120V AC with Incandescent HW-FH2 240V AC with Incandescent HW-FM4 480V AC with Incandescent HW-FT8 1. In place of ➁, specify the LED Color Code from table on previous page. 2. All transformers have a 6V AC secondary voltage. 3. LED/Lamp supplied with transformer partial assembly. In place of ➁, specify the Lens Color Code from table on previous page. A3-62 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Operator Truth Tables Use the following tables to build custom selector switches. 2 Position Selector Switches Switches & Pilot Devices A3 Contact HW-F10 (NO) HW1S-2T HW1K-2* HW1F-2 HW-F01 (NC) HW-F10R NO-(EM) HW-F01R NC-(LB) Mounting Position 1. Mounting position indicates which side of operator each contact should be mounted (as viewed from the front of the panel). 2. * for key removable code (see page A3-73). Operator Position Left Right L O X R O X L X O R X O L 0 X R O X L X O R X O 3 Position Selector Switches Contact HW-F10 (NO) HW1S-3T HW1K-3* HW1F-3 HW-F01 (NC) HW-F10R NO-(EM) HW-F01R NC-(LB) Contact HW-F10 (NO) HW1S-3ST HW1K-3S* HW-F01 (NC) HW-F10R NO-(EM) HW-F01R NC-(LB) Contact HW-F10 (NO) HW1S-3JT HW1K-3J* HW-F01 (NC) HW-F10R NO-(EM) HW-F01R NC-(LB) A3-80 Mounting Position Operator Position Left Center Right L X O O R O O X L O X X R X X O L X O O R O O X L O X X R X X O Operator Position Mounting Position Left L X O O R O O X L O O X R X O O L X X O R O X X L O X X R X X O Center Right Operator Position Mounting Position Left L X O R O O X L O X O R O X O L X O X R X O X L O X X R X X O www.idec.com Center Right O 1. HW1S-3T is identified by white plungers on the operator. 2. Mounting position indicates which side of operator each contact should be mounted (as viewed from the front of the panel). 3. * for key removable code (see page A3-73). 1. HW1S-3ST is identified by red plungers on the operator. 2. Mounting position indicates which side of operator each contact should be mounted (as viewed from the front of the panel). 3. * for key removable code (see page A3-73). 1. HW1S-3JT is identified by black plungers on the operator. 2. Mounting position indicates which side of operator each contact should be mounted (as viewed from the front of the panel). 3. * for key removable code (see page A3-73). USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Operator Truth Tables con’t 4 Position Selector Switches Contact HW-F01 (NC) HW1S-4T HW-F10R NO-(EM) HW-F01R NC-(LB) 1 2 3 4 L X O O O R O O O X L O O X O R O X O O L X X O X R X O X X L O X X X R X X X O A3 Switches & Pilot Devices HW-F10 (NO) Operator Position Mounting Position 5 Position Selector Switches Contact HW-F10 (NO) HW-F01 (NC) HW1S-5T HW-F10R NO-(EM) HW-F01R NC-(LB) www.idec.com Operator Position Mounting Position 1 2 3 4 5 L X O O O O R O O O O X L O O O X O R O X O O O L X X X O X R X O X X X L O X X X X R X X X X O Mounting position indicates which side of operator each contact should be mounted (as viewed from the front of the panel). USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-81 Oiltight Switches & Pilot Devices ø22mm - HW Series Custom Selector Switch Building Examples Example 1: 3 Position, Maintained Selector Switch with 3 Contacts Knob Position Left Switches & Pilot Devices A3 Determine which operator is capable of producing all the desired contact actions. Operator Center Right HW1S-3T HW1S-3ST HW1S-3JT Contact 1 O O X Possible with HW-F10 mounted on right Possible with HW-F10 mounted on right Possible with HW-F10 mounted on right Contact 2 0 X O Not possible Not possible Possible with HW-F01 mounted on left or right Contact 3 X O O Possible with HW-F10 mounted on left Possible with HW-F10 mounted on left Possible with HW-F10 mounted on left The only operator in this example that will produce all the desired contact actions is HW1S-3JT. Assemble as follows: Right TW-DB (dummy block) Left HW-F10 HW-F01 HW-F10 HW1S-3JT Example 2: 3 Position, Maintained Selector Switch with 2 Contacts Determine which operator is capable of producing all the desired contact actions. Knob Position Left Operator Center Right HW1S-3T HW1S-3ST HW1S-3JT Contact 1 O O X Possible with HW-F10 mounted on right Possible with HW-F10 mounted on right Possible with HW-F10 mounted on right Contact 2 0 X X Possible with HW-F01 mounted on left Possible with HW-F10R mounted on right or HW-F01R mounted on left Not possible This arrangement is possible with either the HW1S-3T or HW1S-3ST operator. It is preferred to use the HW1S-3T as this requires only the standard contacts (HWF10 and HW-F01 and not the early make (HW-F10R) or late break (HW-F01R) contacts. Assemble as follows: Right Left HW-F10 HW-F01 HW1S-3T A3-82 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Custom Selector Switch Building Examples con’t Example 3: 4 Position Selector Switch with 4 Contacts Determine where the contact will be mounted. Knob Position A3 Operator 2 3 4 HW1S-4T Contact 1 O X O O HW-F01 mounted on right Contact 2 0 O X O HW-F01 mounted on left Contact 3 O O O X HW-F10 mounted on right Contact 4 O X X X HW-F01R mounted on left Switches & Pilot Devices 1 Assemble as follows: Right HW-F01 Left HW-F10 HW-F01 HW-F01R HW1S-4T Example 4: 5 Position Selector Switch with 4 Contacts Determine where the contact will be mounted. Knob Position 1 Operator 2 3 4 5 HW1S-5T Contact 1 O X O O O HW-F01 mounted on right Contact 2 O O O X O HW-F01 mounted on left Contact 3 O O O O X HW-F10 mounted on right Contact 4 X O X X X HW-F10R mounted on right Assembled as follows: Right HW-F01 Left HW-F10 HW-F10R TW-DB (dummy block) TW-DB (dummy block) HW-F01 HW1S-5T www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-83 ø22mm - HW Series Oiltight Switches & Pilot Devices Dual Pushbutton Switches Switches & Pilot Devices A3 Two pushbuttons and a pilot light are integrated into one spacesaving ø22 mm control unit. • Momentary and interlock types are available for pushbuttons. Interlock type prevents both buttons from being pressed at the same time. • Pilot lights are available in full voltage and transformer types illuminated with LED or incandescent lamps. • IP40 protection, IP65 when using silicon cover. • UL Listed, CSA approved, and EN compliant Applications: • Ideal for use as power switches and start/stop switches (available with I/ON and O/OFF markings on the buttons and a pilot light in the center). • Interlock type prevents two pushbuttons from being pressed at the same time. Dual Pushbutton Switches (Assembled) Part Numbers: Operation Type Button Style Contact Arrangement Top Bottom Button Button 1NO Flush (top) Flush (bottom) Momentary Flush (top) Extended (bottom) Flush (top) Flush (bottom) Interlock* Flush (top) Extended (bottom) 1NC Part Number ➃ Button Color Code ➄ Legend Code HW7D-B11F1001-➃➄ 1NO 1NO HW7D-B11F1010-➃➄ 1NO-1NC 1NO-1NC HW7D-B11F1111-➃➄ 2NO 2NC HW7D-B11F2002-➃➄ 2NO 2NO HW7D-B11F2020-➃➄ 1NO 1NC HW7D-B12F1001-➃➄ 1NO 1NO HW7D-B12F1010-➃➄ 1NO-1NC 1NO-1NC HW7D-B12F1111-➃➄ 2NO 2NC HW7D-B12F2002-➃➄ 2NO 2NO HW7D-B12F2020-➃➄ 1NO 1NC HW7D-B21F1001-➃➄ 1NO 1NO HW7D-B21F1010-➃➄ 1NO-1NC 1NO-1NC HW7D-B21F1111-➃➄ 2NO 2NC HW7D-B21F2002-➃➄ 2NO 2NO HW7D-B21F2020-➃➄ 1NO 1NC HW7D-B22F1001-➃➄ 1NO 1NO HW7D-B22F1010-➃➄ 1NO-1NC 1NO-1NC HW7D-B22F1111-➃➄ 2NO 2NC HW7D-B22F2002-➃➄ 2NO 2NO HW7D-B22F2020-➃➄ GR: Green (top) Red (bottom) WB: White (top) Black (bottom) Blank:Without legend 1:I/ON (top) O/OFF (bottom) 1. *Interlock type prevents both top and bottom buttons from being pressed simultaneously. 2. Clear silicon rubber cover part number HW9Z-D7D. A3-84 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Part Numbers, con’t Part Numbers: With Center Pilot Light Operation Type Button Style Pilot Light Type Full Voltage Momentary Transformer Full Voltage Flush (Top) Extended (Bottom) Transformer Flush (top) Flush (bottom) Full Voltage Flush (Top) Flush (Bottom) Flush (top) Extended (bottom) Interlock* Transformer Full Voltage Flush (Top) Extended (Bottom) Transformer Bottom Button Part Number 1NO 1NC HW7D-L11F1001➁➂-➃➄ 1NO 1NO HW7D-L11F1010➁➂-➃➄ 1NO-1NC 1NO-1NC HW7D-L11F1111➁➂-➃➄ 2NO 2NC HW7D-L11F2002➁➂-➃➄ 2NO 2NO HW7D-L11F2020➁➂-➃➄ 1NO 1NC HW7D-L11F1001➁➂-➃➄ 1NO 1NO HW7D-L11F1010➁➂➃➄ 1NO-1NC 1NO-1NC HW7D-L11F1111➁➂-➃➄ 2NO 2NC HW7D-L11F2002➁➂-➃➄ 2NO 2NO HW7D-L11F2020➁➂-➃➄ 1NO 1NC HW7D-L12F1001➁➂-➃➄ 1NO 1NO HW7D-L12F1010➁➂-➃➄ 1NO-1NC 1NO-1NC HW7D-L12F1111➁➂-➃➄ 2NO 2NC HW7D-L12F2002➁➂-➃➄ 2NO 2NO HW7D-L12F2020➁➂-➃➄ 1NO 1NC HW7D-L12F1001➁➂-➃➄ 1NO 1NO HW7D-L12F1010➁➂-➃➄ 1NO-1NC 1NO-1NC HW7D-L12F1111➁➂-➃➄ 2NO 2NC HW7D-L12F2002➁➂-➃➄ 2NO 2NO HW7D-L12F2020➁➂-➃➄ 1NO 1NC HW7D-L21F1001➁➂-➃➄ 1NO 1NO HW7D-L21F1010➁➂-➃➄ 1NO-1NC 1NO-1NC HW7D-L21F1111➁➂-➃➄ 2NO 2NC HW7D-L21F2002➁➂-➃➄ 2NO 2NO HW7D-L21F2020➁➂-➃➄ 1NO 1NC HW7D-L21F1001➁➂-➃➄ 1NO 1NO HW7D-L21F1010➁➂-➃➄ 1NO-1NC 1NO-1NC HW7D-L21F1111➁➂-➃➄ 2NO 2NC HW7D-L21F2002➁➂-➃➄ 2NO 2NO HW7D-L21F2020➁➂-➃➄ 1NO 1NC HW7D-L22F1001➁➂-➃➄ 1NO 1NO HW7D-L22F1010➁➂-➃➄ 1NO-1NC 1NO-1NC HW7D-L22F1111➁➂-➃➄ 2NO 2NC HW7D-L22F2002➁➂-➃➄ 2NO 2NO HW7D-L22F2020➁➂-➃➄ 1NO 1NC HW7D-L22F1001➁➂-➃➄ 1NO 1NO HW7D-L22F1010➁➂-➃➄ 1NO-1NC 1NO-1NC HW7D-L22F1111➁➂-➃➄ 2NO 2NC HW7D-L22F2002➁➂-➃➄ 2NO 2NO HW7D-L22F2020➁➂-➃➄ 1. *Interlock type prevents both top and bottom buttons from being pressed simultaneously. 2. Clear silicon rubber cover part number HW9Z-D7D. www.idec.com ➁Pilot Light Illumination Type and Voltage Code Full Voltage Voltage Code 6V AC/DC, LED Q2 12V AC/DC, LED Q3 24V AC/DC, LED Q4 120V AC, LED Q8 6V AC/DC, Incandescent Q5* 12V AC/DC, Incandescent Q6* 24V AC/DC, Incandescent Q7* Step-Down Transformer (6V Secondary Lamp Voltage) Voltage Code 120V AC, LED H22 240V AC, LED M42 480V AC, LED T82 120V AC, Incandescent H25* 240V AC, Incandescent M45* 480V AC, Incandescent T85* * Only available for White Lens Pilot Lamp. ➂Pilot Lamp Color Code Color Code Amber A* Green G* Red R* Blue S* White W Yellow Y* * Only available for LED Type illumination. ➃Pushbutton Color Code Color Code Top Green Bottom Red Top White Bottom Black GR WB ➄Engraving Codes Engraving Code No Engraving I/ON Top O/OFF Bottom USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Blank 1 A3-85 A3 Switches & Pilot Devices Flush (Top) Flush (Bottom) Top Button Oiltight Switches & Pilot Devices ø22mm - HW Series Contact Arrangement Chart Contact Arrangement Top Button Switches & Pilot Devices A3 Bottom Button Contact Code Contact Block Mounting Type Position Top Button Normal Push Bottom Button Normal 1 NO X 2 NO 1 NO X 1NO 1NC 1001 2 NC X 1 NC X 1NC 1NO 0110 2 NO 1 NC X 1NC 1NC 0101 2 NC X 1 NO X 2 NO 1NO 2NO 1020 3 Dummy 4 NO 1 NO X 2 NO 1NO 1NO-1NC 1011 3 Dummy 4 NC X 1 NO X 2 NC X 1NO 2NC 1002 3 Dummy 4 NC X 1 NC X 2 NO 1NC 2NO 0120 3 Dummy 4 NO 1 NC X 2 NO 1NC 1NO-1NC 0111 3 Dummy 4 NC X 1 NC X 2 NC X 1NC 2NC 0102 3 Dummy 4 NC X 1 NO X 2 NO 2NO 1NO 2010 3 NO X 4 Dummy 1 NO X 2 NC X 2NO 1NC 2001 3 NO X 4 Dummy 1 NO X 2 NO 1NO-1NC 1NO 1110 3 NC X 4 Dummy 1 NO X 2 NO X 1NO-1NC 1NC 1101 3 NC X 4 Dummy 1 NC X 2 NO 2NC 1NO 0210 3 NC X 4 Dummy 1. Transformers can have two or four contact blocks only. 2. Contact blocks 1 and 3 are actuated by the top button. Contact blocks 2 and 4 are actuated by the bottom button. 1NO A3-86 1NO 1010 www.idec.com Push X X X X X X X X X X X USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Contact Arrangement Chart con’t Contact Arrangement Top Button Bottom Button 1NC 2NO 2NO 2NO 1NO-1NC 2NO 2NC 1NO-1NC 2NO 1NO-1NC 1NO-1NC 1NO-1NC 2NC 2NC 2NO 2NC 1NO-1NC 2NC 2NC Contact Code 0201 2020 2011 2002 1120 1111 1102 0220 0211 0202 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 NC NC NC Dummy NO NO NO NO NO NO NO NC NO NC NO NC NO NO NC NO NO NO NC NC NO NC NC NC NC NO NC NO NC NO NC NC NC NC NC NC Top Button Normal Push Bottom Button Normal Push A3 X X Switches & Pilot Devices 2NC Contact Block Mounting Type Position X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X Contact Block Mounting Position Example 4 3 2 1 With Pilot Light (transformer type) www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-87 Oiltight Switches & Pilot Devices ø22mm - HW Series Dual Pushbutton Switches (Sub-Assembled) Contact Blocks + Mounting Adaptor + Operator + Lens = Complete Part Part Number Flush (top) Flush (bottom) HW7D-011➃-➄ Flush (top) Extended (bottom) HW7D-012➃-➄ Flush (top) Flush (bottom) HW7D-021➃-➄ Flush (top) Extended (bottom) HW7D-022➃-➄ Interlock Flush Extended Flush Flush Momentary Part Numbers: Operators Style Type Button Style ➃Pushbutton Color Code Color Top Bottom Top Bottom ➄Engraving Codes Code Green Red White Black GR WB Engraving Code No Engraving I/ON Top O/OFF Bottom Blank 1 Part Numbers: Contact Block Mounting Adaptor (safety lever lock included) Appearance Part Number Non-Illuminated HW-CB2C Illuminated (with Pilot Light) HW-CBL Part Numbers: Lamps/Lens Type Voltage Lamps LED Incandescent Non-Illuminated 6V AC/DC 12V AC/DC 24V AC/DC 120V AC 240V AC 6.3V AC/DC 12V AC/DC 24V AC/DC 30V AC/DC 1.Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from unlocking contacts. Illuminated A3-88 Part Numbers: Contact Blocks Description LSTD-6➁ LSTD-1➁ LSTD-2➁ LSTD-H2➁ LSTD-M4➁ IS-6 IS-12 IS-24 IS-30 HW9Z-B7B HW9Z-L7W 1. In place of ➁, specify the LED Color Code from table on right. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. www.idec.com Part Number 1NO 1NC Standard HW-F10 HW-F01 Fingersafe (IP20) HW-F10R (early make) HW-F01R (late break) Spring-Up HW-G10 HW-G01 Terminal HW-G10R (early make) HW-G01R (late break) Contacts HW-G10-MAU (gold contacts) HW-G01-MAU (gold contacts) Exposed Screw HW-C10 HW-C01 Terminal Contacts HW-C10R (early make) HW-C01R (late break) Dummy Block TW-DB 1. All assembled part numbers in catalog include standard (HW-F...) contacts. (excep unibody) 2. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 3. Units with exposed screw terminals (HW-C...) must be ordered as sub-component 4. All contacts (including exposed screw) are UL, CSA, and IEC compliant and carry the CE mark. Part Numbers: Lamp Circuit Components Style Description Terminals Part Number For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. Fingersafe Exposed For use with odd number of contacts. Spring Up Lead Holder Dummy Block with Full Voltage Adaptor Full Voltage Adaptor For use with even number of contacts. 120VAC 240VAC 480VAC 120V 240V 480V 120V 240V 480V 110VDC Transformer Unit Part Number Lens Switches & Pilot Devices A3 (6V secondary voltage) DC-DC Converter HW-LH3 HW-DA1FB HW-DA1B HW-GA1 Fingersafe TW-DA1FB Exposed TW-DA1B Fingersafe Spring Up Exposed TW-F126B TW-F246B TW-F486B HW-T126 HW-T246 HW-L486 TW-T126B TW-T246B TW-T486B HW-L16D HW-GA1 “Dummy Block with full voltage adaptor” does not require the use of HW-LH3. Part Numbers: Anti-Rotation Ring Appearance Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. LED Color Code Color Code Color Code Amber A Blue S Green G White W Red R Yellow Y USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Mono Lever Switches (Assembled) Part Numbers: Mono Lever Switches No. of Description Part Number Positions A3 HW1M-F1010-20 HW1M-F2020-20 HW1M-F0202-20 HW1M Standard Lever HW1M-F0101-40 Part Number Guide ➁ ➀ HW1M- L F 0 up Type 0 1 right down left Lever Action Description Standard ➀ Type ➁ Lever Action – 1 Interlocking mechanism prevents inadvertent activation 1 Spring 2 Blocked 0 HW1M-F2222-22N9 Circuit Number (blank) Maintained HW1M-F1111-22N9 4 HW1M-LF1010-20 Remarks L HW1M-F0202-40 ➂ 20 Code Interlocking Switches & Pilot Devices HW1M-F0101-20 2 HW1M-LF2020-20 HW1M-LF0101-20 2 HW1M-LF0202-20 HW1M-L Interlocking Lever HW1M-LF0101-40 HW1M-LF0202-40 Fill in desired action for each position: Up/Right/Down/Left HW1M-LF1111-22N9 4 HW1M-LF2222-22N9 20 ➂ Circuit Number See Circuit Diagrams below 40 22N9 Circuit Diagrams 2 Position Left/Right Contact Circuit Mounting Number No. 20 40 2 Position Up/Down Contact Circuit Mounting Number No. Position 1 HW-F10 Left Center Right X 0 0 2 HW-F10 0 0 X 1 HW-F10 X 0 0 2 HW-F10 0 0 X 3 HW-F10 X 0 0 4 HW-F10 0 0 X 20 40 3 Position Circuit Number 30 Position Down Center 1 HW-F10 X 2 HW-F10 1 HW-F10 2 HW-F10 3 HW-F10 4 HW-F10 0 Up 0 0 0 0 X X 0 0 0 0 X X 0 0 0 X 4 Position Contact Mounting No. Position Down Left Center Up Right 1 HW-F01 0 O 0 0 X 2 HW-F01 X 0 0 O 0 3 HW-F10 0 X 0 0 O Circuit Number 22N9 Contact Mounting No. Position Down Left Center Up Right 1 HW-F01 0 O 0 0 X 2 HW-F01 X 0 0 O 0 3 HW-F10 0 X 0 0 O 4 HW-F10 O 0 0 X 0 Other circuit arrangements available, contact IDEC for details. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-89 Oiltight Switches & Pilot Devices ø22mm - HW Series Mono Lever Switches (Sub- Assembled) Contact Blocks + Mounting Adaptor + Anti-Rotation Ring + Operator = Complete Part Switches & Pilot Devices A3 Part Numbers: Operators Appearance # of Positions Standard 2 4 Interlocking 2 4 Description Part Number Maintained Up/Down Spring return Up/Down Maintained Left/Right Spring return Left/Right Maintained, 4 position Spring return, 4 position Maintained Up/Down Spring return Up/Down Maintained Left/Right Spring return Left/Right Maintained, 4 position HW1M-1010 HW1M-2020 HW1M-0101 HW1M-0202 HW1M-1111 HW1M-2222 HW1M-L1010 HW1M-L2020 HW1M-L0101 HW1M-L0202 HW1M-L1111 Spring return, 4 position HW1M-L2222 Part Numbers: Contact Block Mounting Adaptor (safety lever lock included) Appearance Part Number Part Numbers: Contact Blocks Description Part Number 1NO 1NC Standard Fingersafe (IP20) HW-CB2C 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from unlocking contacts. Part Numbers: Anti-Rotation Ring Appearance Part Number Part Numbers: Replacement Parts Item Part Number Black Cap HW9Z-CPM Boot HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Spring-Up Terminal Contacts Exposed Screw Terminal Contacts HW9Z-RL 1. Use with notched panel cutout to prevent unit rotation. 2. Not required when using HW series nameplates See page A3-96. HW-F10 Dummy Block TW-DB 1. All assembled part numbers in catalog include standard (HW-F...) contacts. 2. Assembled units with spring-up terminals (HWG...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 3. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. HW9Z-BLM (fits standard type operator only) A3-90 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Pushbutton Selectors (Assembled) Part Numbers: 2–Position Pushbutton Selectors Operator Position Part Number Normal Depressed 1 HW-F10 2 HW-F10 0 0 X 0 0 0 0 X HW1R-2DF20-① 1 HW-F10 0 0 X X X 0 0 X 0 0 X X 0 X X 0 HW1R-2DF22N1-① 0 0 0 X X 0 0 X 0 0 X 0 0 X X 0 HW1R-2EF22N1-① 0 0 0 X 0 X 0 0 0 0 X 0 X 0 0 0 HW1R-2FF22N1-① 2NO-2NC 23 HW-F10 HW-F01 4 HW-F01 1 HW-F10 2NO-2NC 23 HW-F10 HW-F01 4 HW-F01 1 HW-F10 2NO-2NC 23 HW-F10 HW-F01 4 HW-F01 A3 Right Depressed Left Switches & Pilot Devices 2NO Mounting Normal Contacts 1. Available only with momentary pushbutton and maintained selector. 2. In place of ➀, specify the button color code from table below 3. Other contact arrangements available. Contact IDEC for details. 4. All assembled parts use flush buttons. 5. Normal position refers to the button flush with the selector ring. 6. Depressed position refers to the button being pushed in. ① Button Color Code Color www.idec.com Code Black B Green G Red R Blue S White W Yellow Y Grey N USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-91 Oiltight Switches & Pilot Devices ø22mm - HW Series Pushbutton Selectors (Partial-Assemblies) Contact Assembly + Operator/Button = Complete Part Switches & Pilot Devices A3 Part Numbers: Operators Appearance Description Part Number Cam D HW1R-2D-① Cam E HW1R-2E-① Cam F HW1R-2F-① In place of ① specify Button Color Code. Part Numbers: Contact Assemblies Contacts Style Standard Fingersafe Contacts Spring Up Terminal Contacts Part Number 1NO 1NC 1NO/1NC 2NO 2NC 2NO/2NC HW-CBF10 HW-CBF01 HW-CBF11 HW-CBF20 HW-CBF02 HW-CBF22 1NO 1NC 1NO/1NC 2NO 2NC 2NO/2NC HW-CB10 HW-CB01 HW-CB11 HW-CB20 HW-CB02 HW-CB22 ① Button Color Code Color Code Black B Green G Red R Blue S White W Yellow Y Grey N A3-92 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Pushbutton Selectors (Sub-Assembled) Contact Blocks + Contact Mounting Adaptor + Anti-Rotation Ring + Operator + Button = Complete Part A3 Cam D Part Numbers: Buttons Description Part Numbers: Contact Blocks Description Part Number 1NO HW1R-2D Cam E HW1R-2E Cam F HW1R-2F Cam N HW1R-2N Part Number 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Spring-Up Terminal Contacts Round Flush HW1A-B1-① In place of ① specify Button Color Code. Switches & Pilot Devices Part Numbers: Operators Appearance Description Part Number Exposed Screw Terminal Contacts Part Numbers: Anti-Rotation Ring Appearance Part Number Dummy Block HW9Z-RL TW-DB 1. Use with notched panel cutout to prevent unit rotation. 2. Not required when using HW series nameplates See page A3-96. 1. All assembled part numbers in catalog include standard (HW-F...) contacts. 2. Assembled units with spring-up terminals (HWG...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 3. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. Part Numbers: Contact Block Mounting Adaptor (safety lever lock included) Appearance Part Number HW-CB2C 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from unlocking contacts. www.idec.com ① Button Color Code Color Code Black B Green G Red R Blue S White W Yellow Y Grey N USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-93 Oiltight Switches & Pilot Devices ø22mm - HW Series Operator Truth Tables HW Pushbutton Selector Switches - Cam D Operator Position Switches & Pilot Devices A3 Contact Mounting Position Left Button Free Right Button Free Button Pressed Left O Button Pressed X O O Right O O O X HW-F10 (NO) Left X O X X Right X X X O HW-F01 (NC) Left O X O O Right O O O X Left X O X X Right X X X O HW-F10R (NO-EM) HW-F01R (NC-LB) HW Pushbutton Selector Switches - Cam E Operator Position Contact Mounting Position Left Button Free Right Button Free Button Pressed Left O Button Pressed X O O Right O O O X Left O O X X Right X X O O Left X X O O Right O O X X Left X O X X Right X X X O HW-F10 (NO) HW-F01 (NC) HW-F10R (NO-EM) HW-F01R (NC-LB) HW Pushbutton Selector Switches - Cam F Operator Position Contact Mounting Position Left Button Free Right Button Pressed Button Free Button Pressed Left O O O X Right O X O O Left O O X O Right X O O O X HW-F10 (NO) HW-F01 (NC) Left X X O Right O X X X Left X X X O Right X O X X HW-F10R (NO-EM) HW-F01R (NC-LB) HW Pushbutton Selector Switches - Cam N Operator Position Contact Mounting Position Left Left Button Free O Right Button Pressed Button Free Button Pressed X O X HW-F10 (NO) Right O X O X Left O O X O Right X O O O Left X X O X Right O X X X Left X O X O Right X O X O HW-F01 (NC) HW-F10R (NO-EM) HW-F01R (NC-LB) A3-94 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Contactor Reset Button Part Numbers: Reset Buttons (Assembled) Appearance (Blank) Plastic Bezel Metal Bezel HW1B-M1RS-①T HW4B-M1RS-①T HW4B-M1RS-①T-ENG-R 1. In place of ① specify Button Color Code. 2. 5.1” (130mm) overall length. 3. 16mm flat base for easy alignment Color Code Black B Green G Grey N Red R Blue S White W Yellow Y Sub-Assemblies Rod Part Numbers: Button Appearance + Operator Part Number + Button = Part Numbers: Rod Appearance Complete Part Part Number HW9Z-RS-TK2141 HW1A-B1-① In place of ① specify Button Color Code from table. ① Button Color Code Color Part Numbers: Operator Appearance Plastic HW1B-MO www.idec.com Metal HW4B-MO Code Black B Green G Grey N Red R Blue S White W Yellow Y USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-95 A3 Switches & Pilot Devices HW1B-M1RS-①T-ENG-R Engraved “R” ① Button Color Code Oiltight Switches & Pilot Devices ø22mm - HW Series Nameplates — HW Series HWAQ–Black Plastic A3 29mm ON HWAV–Yellow Plastic ERGENCY EM 45mm Ø 60mm 30mm 30mm Switches & Pilot Devices 29mm OFF HWAS–Black Plastic STOP 45mm Part Numbers: Nameplates HWAM–Black Plastic STOP 14.5mm Part Number Part Number Part Number Part Number Nameplate (blank engraving plate included) HWAM-OB HWAQ-OB HWAS-OB HWAV-O Nameplate (engraved) HWAM-➀ HWAQ-➀ HWAS-➀ HWAV-27* HWAV5-27† Additional Insert (blank) HWNP-O HWNP-O HWNP Dimensions 12mm Additional Insert (engraved) HWNP-➀ HWNP-➀ 27mm 1. In place of ➀, insert either the standard legend code from table below or custom engraving delimited by “ “. 2. Standard engravings are available at no charge. 3. * HWAV-27 comes engraved “Emergency Stop” as shown in drawing. 4. † HWAV5-27 for 80mm diameter jumbo mushroom comes engraved “Emergency Stop” as shown in drawing. Standard Legend Codes Pushbuttons Legend AUTO CLOSE DOWN EMERG.STOP FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON Code 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 Legend OPEN OUT RAISE RESET REVERSE RUN SLOW START STOP TEST UP I (Int’l On) O (Int’l Off) EMO Pushbuttons/Selector Switches Code 116 117 118 119 120 121 122 123 125 126 127 150 151 152 Legend Code AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWER-RAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISE-LOWER 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 Legend REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN OI (Int’l OFF ON) Selector Switches Code Legend Code 216 217 218 219 220 221 222 223 250 AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFF-WINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 1. To order engraved nameplates, add legend code to nameplate part number. 2. Character height based on the number of characters and size of nameplate. Standard character size is 3/16". 3. Nameplates with standard legends are the same list price as blank nameplates. 4. Nameplates have built-in anti-rotation feature for use with notched panel cut-outs. Additional anti-rotation ring (HW9Z-RL) is not necessary. A3-96 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Nameplates Order Form — HW Series Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To insure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: IDEC Rep/Distributor Contact: Name: PO number (if known): Telephone: IDEC Rep/Distributor Phone: Fax & Email IDEC Rep/Distributor Fax & Email A3 Engraving Location Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 9 characters. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 11 characters max (for 7/64” size letters) 1/8” Letter Size 9 characters max (for 1/8” size letters) Sample Letter Sizes 7/64” Letters: A B C D 1/8” Letters: A B C D Qty 1 2 3 4 5 6 7 8 9 10 11 HWAQ Nameplate Engraving Location Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 9 characters. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 11 characters max (for 7/64” size letters) 1/8” Letter Size 9 characters max (for 1/8” size letters) Sample Letter Sizes 7/64” Letters: A B C D 1/8” Letters: Qty 1 2 3 4 5 6 7 ABCD 8 9 10 11 HWAS Nameplate Engraving Location A Step 1. Choose Letter Size - 1/8” or 3/32”. Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 14 characters. 3/32” Letter Size 1/8” Letter Size 20 characters maximum (for 3/32” size letters) 14 characters maximum (for 1/8” size letters) Engraving Location B 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Step 2. Specify Quantity. Enter the number of nameplates desired in box on the right. www.idec.com Qty Step 3. Specify Location. Enter the location of engraving (A or B), in box on the right. Sample Letter Sizes 3/32” Letters: A B C D 1/8” Letters: A B C D Location USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-97 Switches & Pilot Devices HWAM Nameplate Oiltight Switches & Pilot Devices ø22mm - HW Series Accessories — HW Series Appearance Description/Usage Part Number Locking Ring Wrench Metallic tool used to tighten the plastic locking ring when installing the HW series unit in a panel MW9Z-T1 Lamp/LED Removal Tool Rubber tool makes lamp/LED removal easier. OR-55 Anti-Rotation Ring Prevents rotation of switches in panel. (included with all assembled switches) Switches & Pilot Devices A3 Rubber Mounting Hole Plug Metallic Mounting Hole Plug for notched panel cutout (standard) HW9Z-RL for round panel cutout LW9Z-L Black rubber plug fills unused mounting holes in panel. OB-31 For plugging unused mounting holes in the panel. Tighten the attached locking ring to a torque of 12 kfg-cm maximum LW9Z-BM Degree of protection: IP66 Barrier To prevent contact between adjacent lead wires when control units are tightly mounted HW-VL1 Used to cover and protect pushbuttons Flush Pushbuttons Operating temperature: –50 to +60°C Extended Pushbuttons OC-32 Plastic hinged cover to protect pushbuttons or selector switches. (Not intended for E-Stops) HW9Z-KL1 OC-31 Pushbutton Clear Boot Padlock Cover Degree of protection: IP65 Tab Terminal Adapter Tab #250 (6.35 x 0.8mm): Single tab TW-FA1 Adaptor (22mm to 30mm) Used to mount round HW series control unit (except Jumbo Mushroom, unibody, and square units) into a 30mm panel cut-out. (includes both pieces) HW9Z-A30 Replacement Safety Lever Lock Used to prevent contact mounting lever from moving due to heavy vibration or panel maintenance. (included with all Contact Block Mounting Adaptors) HWLS-TK1971 Reset Rod for Contactors Overload 5” rod used with HW1B-M0. See Contactors Section D for more information. HW9Z-RS-TK2141 Replacement Operator Washer Provided with operator. Insert between bezel and locking ring. HWM-WASHER Replacement Locking Ring Plastic locking nut comes with all HW operators & assemblies. Standard (plastic) HW9Z-LN Optional (metal) HW9Z-LNM Switch Cover (Square) Used only with round or square flush pushbuttons. HW9Z-K1 (spring return) HW9Z-K11 (maintained cover) Replacement Keys Pair of Keys (#231) HW9Z-SKP A3-98 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices Appearance Replacement Lens ø22mm - HW Series Description/Usage HW Illuminated Unibody Replacement Lens Replacement Jumbo Dome Lens Part Number HWLV-LENSR A3 HW1A-P5① ① = (A, G, R, S, W, Y) Replacement Jumbo Diffusing Lens HW9Z-PP5C Replacement LED Lamps for HW Jumbo Dome Replacement LED Lamp LSTDB-2① Rubber Cover for Dual Pushbuttons Clear Silicon rubber cover HW9Z-D7D Barrier for Dual Pushbuttons Plastic barrier. Used when mounting the HW7 units on 30mm horizontal centers, to prevent possible interconnections between adjoining terminals. HW-VG1 www.idec.com Switches & Pilot Devices Polycarbonate Replacement Lens ① = (A, G, R, S, W, Y) USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-99 Oiltight Switches & Pilot Devices ø22mm - HW Series Dimensions — HW Series Non-Illuminated Pushbuttons Panel Thickness 0.8mm to 6.mm * 29mm * Round: 23.6mm * Square: 24.8mm * D1 D1 0.5mm 50.2mm 32mm D2 70.2mm 40mm 29mm 13mm Square Round D1 D1 32mm D3 m ck 40mm 29.6mm 40.4mm 25mm 29 m Lo D1 = 13mm D2 = 19mm D3 = 23.2mm D1 D3 30mm Monolever 0.21" (8mm) 24 deg. 0.90" (23mm) 1.18" (30mm) 2.83" (72mm) Pilot Lights Panel Thickness 0.8mm to 6.0mm m Gasket M3.5 Terminal Screws 29 m Locking Ring 29.6mm 5mm 44.7mm 7mm M3.5 Terminal Screws 24mm Switches & Pilot Devices A3 Gasket Locking Ring M3.5 Terminal Screws 72.1mm 29.6mm 7mm 17.5mm A3-100 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Dimensions con’t Jumbo Mushroom Pushbutton HW1B-M5 HW1B-V5 Ø2.36in.(Ø60.0mm) 2.36" (60mm) A3 Illuminated Pushbuttons Panel Thickness: 0.8mm to 6.0mm Gasket Locking Ring Extended with Full Shroud 1 block 3 blocks 2 blocks 4 blocks 29.5mm D1 0.5mm 50.2mm 70.2mm 65.8mm 85.8mm 29mm 23.5mm Mushroom Mushroom 29mm 23.2mm 18.5mm D1 W/ Transformer 40mm 23.4mm Extended D1 89.5mm 109.5mm 2 blocks 4 blocks D1 Mushroom 40mm 23.2mm 18.5mm Square 24V AC/DC Round M3.5 Terminal Screws W/ Dummy Block & W/ Full Voltage Adaptor Full Voltage Adaptor 29.6mm ck 40mm 25mm Lo 30mm W/ Transformer M3.5 Terminal Screws D1 = 0.51" 13mm www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-101 Switches & Pilot Devices 1.33" (34mm) 1.15in.(29.2mm) Oiltight Switches & Pilot Devices ø22mm - HW Series Dimensions con’t Unibody Illuminated A3 Panel Thickness 0.8mm to 6.0mm Panel Thickness 0.8mm to 6.0mm Gasket Gasket Locking Ring Locking Ring M3.5 Terminal Screws 40mm M3.5 Terminal Screws 40mm 46mm 60mm 11.5mm 11.5mm 48mm 32mm 63mm 14mm 14mm 32mm Selector Switches Panel thickness: 0.8mm to 6.0mm Gasket M3.5 Terminal Screws 25mm Loc k 37mm 28.8mm 29 m m Locking Ring 0.5mm 1-2 blocks 48.5mm 29.4mm 3-4 blocks 68.5mm Illuminated Selector Switches Pushlock Key Reset Panel Thickness 0.8mm~6mm Panel thickness: 0.8mm to 6.0mm m 40 Rubber Washer 0.5mm 25mm 40.4mm 28.8mm 2 blocks 89.5mm 4 blocks 109.5mm m Lock Lock Nut Locking Ring ø Gasket 21mm 48.5mm 21mm 50.3mm 13mm 30mm 32mm 49.4mm Key Switches M3.5 Terminal Screws 17mm 25mm 29 Loc k m m Panel thickness: 0.8mm to .0mm Gasket Locking Ring 17mm Switches & Pilot Devices Non-Illuminated 0.5mm D1 = 13mm 1-2 blocks 48.5mm 3-4 blocks A3-102 www.idec.com 68.5mm D1 29.4mm 30.5mm USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Dimensions con’t Dual Pushbutton Switches HW Without Pilot Light A3 Switches & Pilot Devices 49.4 (2 contacts) 69.4 (3 or 4 contacts) Panel Thickness 0.8 to 6 Safety Lever Lock Locking Ring Without Button Markings With Button Markings (I/ON and O/OFF) 54.8 54.8 41.4 ON OFF Rubber Gasket 0.5 29.8 14.5 20 29.8 With Pilot Light • Full Voltage Ful Voltage Adapter • The depth of 3-contact type depends on the combination of contact blocks at top and bottom pushbuttons. HW (Bottom Button) (Top Button) 69.4 (2 contacts), 89.4 (4 contacts) (Note) •Transformer (240V maximum) Top Button Bottom Button Depth 1 contact block 2 contact blocks 89.4 mm 2 contact blocks 1 contact block 69.4 mm • Transformer (480V) Transformer Transformer, DC-DC Converter HW HW 79.5 (2 contacts), 99.5 (4 contacts) 89.5 (2 contacts), 109.5 (4 contacts) Mounting Hole Layout R0.8 max. .3 +0.4 55 ∗∗ 0 +0.2 0 24.1 +0.4 0 ∗3.2 ø22 30 • The 3.2 mm recess is for preventing rotation and is not necessary when a nameplate or anti-rotation ring is not used. • When using the safety lever lock, determine the vertical spacing in consideration of convenience for installing and removing the safety lever lock. • Recommended vertical spacing: 100 mm • The minimum mounting centers are applicable to switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers in consideration of convenience for wiring. All dimensions in mm. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-103 Oiltight Switches & Pilot Devices ø22mm - HW Series Dimensions con’t Jumbo Dome Pilot Lights Dimensions 6 ø6 Base BA9S/13 Illumination Color Light blue: LSTDB R0.8 max. ø22.3 3.2 +0.2 0 +0.4 0 24.1 +0.4 0 ø10.6 M3.5 Terminal Screw 85 20.4 Incandescent Lamp LSB Locking Ring Rubber Gasket 0.5 34.4 Base BA9S/13 ø10 ±1 50.5 85 27 ±2 Accessory Dimensions OB-31 Rubber Mounting Hole Plug 3mm LW9Z-BM Metallic Mounting Hole Plug TOP HW9Z-D7D Dual Pushbutton Rubber Cover 3.5mm ø 25mm 59mm 1.5mm HW-VG1 Dual Pushbutton Barrier MW9Z-T1 Locking Ring Wrench 22.5 33 ø 14mm ø 11.6mm m 9m ø2 m m 22 ø 3.5mm Gasket Lock Nut OR-55 Lamp/LED Removal Tool HW9Z-RL Anti-Rotation Ring ø 29mm 12mm ø 25.8mm 8 ø2 58 45 110 1.5 20 HW-VL1 Barrier HW9Z-KL1 Padlock Cover 82.5mm Mounting Hole Layout 45mm 22 .3 m m Panel Thickness 0.8mm - 3.2mm R m 20mm 50mm 45mm minimum {Note 2} .5m 93mm 66 30mm 70mm Switches & Pilot Devices A3 Mounting Hole Layout LED Lamp LSTDB All dimensions in mm. Panel Thickness 1 to 5 1.5mm 24mm ø m m .2 22 ø m m 50 Pad Lock Hole ø 8mm Waterproof Gasket Thickness 0.5mm 29.5mm HWLS-TK1971 Safety Lever Lock 30mm A3-104 www.idec.com Ø 3.5mmm Push to Set Note 1: Mushroom Button 40mm Type: 40mm or more Note 2: Pilot Light: 30mm minimum 0.49" (12.5mm) 0.31" (8mm) 30mm {Note 1} 0.50" (12.8mm) The values represent the minimum mounting centers when one stack of contact blocks is used. When two stacks or an illuminated unit is used, refer to the dimensions and considerwiring accessibility to determine minimum mounting centers. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Accessory Dimensions con’t HW9Z-KG2-TK2120 HW9Z-KG1-TK2120 64.0 48.0 32.0 ø76.1 Switches & Pilot Devices 80.0 A3 36.5 2 2. ø2 38.0 22.0 ø90 2.0 .0 Gasket ø2 TOP Marking TOP Mark TOP Marking TOP Mark Locking Ring Locking Ring Operator Operator Panel Thickness: 1.2 to 4.0 mm Panel Thickness: 1.2 to 4.0 mm Specification Charts — HW Series Rated Operational Power DC Voltage Inductive Millions of operating cycles AC Voltages Voltage V Current A 24 4 48 2 110 1.1 DC Voltages AC Voltages 5 0 0 V AC 1 2 0 V AC 1 . 0 4 8 0 V AC 4 0 0 V AC 3 8 0 V AC 2 4 0 V AC 0.5 0.2 0.1 1 6 0 0 V AC 2 3 4 5 6 10 Voltage V Current A 6 0 0 V AC Millions of operating cycles DC Voltages Resistive 1.0 24 8 www.idec.com 110 2.2 1 2 0 V AC 5 0 0 V AC 4 8 0 V AC 4 0 0 V AC 3 8 0 V AC 2 4 0 V AC 0.5 0.2 0.1 1 2 3 4 5 6 10 Current in A Current in A Conforming to IEC 947-5-1 Appendix C. Utilization categories AC-15 and DC-13. Operation rate: 1,800 op. hour Load factor: 0.4 ± 0.05 48 4 Conforming to IEC 947-5-1 Appendix C. Utilization categories AC-15 and DC-13. Operation rate: 1,800 op. hour Load factor: 0.9 ± 0.05 USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-105 ø22mm - HW Series Oiltight Switches & Pilot Devices HW Safety Precautions Switches & Pilot Devices A3 HW Series Safety Precautions • Turn off power to HW series control units before starting installation, removal, wiring, maintenance, and inspection of the products. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid the possibility of burning yourself, use the lamp holder tool when replacing lamps. For wiring, use wires of a proper size to meet voltage and current requirements. Tighten the M3.5 terminal screws to a tightening torque of 1.0 to 1.3 N·m. Failure to tighten terminal screws may cause overheating and fire. HW General Instructions Panel Mounting Remove the contact block assembly from the operator (for transformer type pilot lights, remove the transformer from the illumination unit). Remove the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block assembly to the operator. Removing and Installing the Contact Block Assembly 1. To remove the operator from the contact block, turn the locking lever in the direction of the arrow shown below. The operator can now be removed. 2. To reinstall, place the TOP markings on the operator and the contact block mounting adapter in the same direction, and insert the operator into the contact block mounting adapter. Then turn the locking lever in the opposite direction. Safety Lever Lock IDEC strongly recommends using the safety lever lock (HW9Z-LS, yellow) to prevent heavy vibration or maintenance personnel from unlocking the contact assembly. 1. HW series can be mounted vertically with a minimum spacing of 55 mm but spacing should be determined to ensure easy operation (recommended minimum spacing: 100 mm). 2. Mount the control unit onto the panel, lock the lever, and push in the safety lever lock to install. 3. When the spacing is narrower than the recommended value, with the lever unlocked, mount the safety lever lock and insert the contact unit to the operator. Then, lock the lever and strongly push in the safety lever lock to install. 4. To remove the safety lever lock, insert a flat screwdriver into the safety lever and push upwards. Removing and Installing the Safety Lever Lock Safety Lever Lock ➀ Push Safety Lever Lock Remove Screwdriver Lock Lever ➁ Install Operator Contact Block Notes for Panel Mounting 1. When mounting the operator onto a panel, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring. Tightening torque must not exceed 2.0 N·m. Do not use pliers. Excessive tightening will damage the locking ring. 2. For the contact blocks and transformers housing LED and incandescent lamps, make sure not to press the lamps too hard, otherwise the lamp socket may be damaged. Removing ➂ Lock Panel Installing Dual Pushbutton Instructions Replacement of Lens Removing • Remove the lens by inserting a screwdriver into the recess of the lens through the bezel. Installing • Install the lens in the recess between the buttons by pressing against the bezel. A3-106 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - HW Series Dual Pushbuttons Instructions con’t Tightening Torque for Terminal Screws Tighten the M3.5 terminal screws to a torque of 1.0 to 1.3 N·m . Installation of LED Illuminated Units When using full voltage type LED illuminated units, provide protection against electrical noise, if necessary. Applicable Wiring The applicable wire size is 2 mm2 maximum. (solid wire ø1.6 mm maximum) One or two wires can be connected. Applicable Crimping Terminal ø3.6 min. 7.9 max. Installation 1. To install, insert the lamp head into the lamp holder tool, and hold the lamp as shown in the figure below. 4 max. Lamp 5.5 min. Lamp Holder Tool ø1.6 max. Be sure to use an insulation tube or cover on the crimping part of the crimping terminal to prevent electrical shocks. Solid Wire 2. Place the pins on the lamp base to the grooves in the lamp socket. Insert the lamp and turn it clockwise. Lamp Base 8 max. Note: When connecting wires to contact blocks or transformers in the direction shown below, keep the insulation stripping length 6.6 mm at the maximum. About Pushbutton Switches The pushbuttons cannot be removed or replaced! Do not attempt to remove using a flat screwdriver or pincers, otherwise the pushbuttons may be damaged. Do not attempt to remove the pushbuttons! Pushbuttons X1 Narrow Mounting When mounting the units closely in a horizontal row on 30mm centers, use optional barriers to prevent interconnection between adjoining terminals. The barriers can be attached simply by pressing them onto the sides of contact blocks. 30 30 Installing the Rubber Cover When using the HW7D pushbuttons in places where the pushbuttons are subjected to water splash or an excessive amount of dust, make sure to use the HW9Z-D7D rubber boot (IP65) which is ordered separately. Notes for Installing the Rubber Cover Remove the gasket from the operator, and install the rubber boot on the operator. Pull out the seals of the rubber boot and place them around the operator sleeve as shown. Make sure that the seals are not twisted or tucked inside and that the gasket does not remain, otherwise the normal waterproof and dustproof characteristics are not ensured. ➀ Remove the gasket. Barrier X2 ➁ Install the rubber boot on the pushbuttons. ➂ Rubber boot is installed. Seals When mounting transformer type illuminated units closely in a horizontal row on 30-mm centers, insert solid wires or stranded wires into inside of the terminal screw on the transformer (see figure on the right) to prevent short circuit between adjoining terminals. www.idec.com Install Remove X1 X2 X1 X2 Gasket Seals Inside Inside USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-107 A3 Switches & Pilot Devices Replacement of Lamps Lamps can be replaced by using the lamp holder tool (OR-55) from the front of the panel, or by removing the contact block assembly from the operator unit. Removing the Lamps from the Front of the Panel Removal 1. To remove, slip the lamp holder tool onto the lamp head lightly. Then push slightly, and turn the lamp holder tool counterclockwise.
HW1B-M1F11-G 价格&库存
很抱歉,暂时无法提供与“HW1B-M1F11-G”相匹配的价格&库存,您可以联系我们找货
HW1B-M1F11-G
  • 1+223.539581+28.92081
  • 10+184.6404210+23.88817
  • 25+171.3040525+22.16275
  • 50+162.2046750+20.98551
  • 100+153.98110100+19.92157
  • 250+144.43935250+18.68709
  • 500+138.18341500+17.87772
库存:17
