HW1Z-P1F2PQ4Y
HW1Z-P1F2PQ4Y
    IDEC(日本和泉)
    IDEC - HW1Z-P1F2PQ4Y - Buzzer, Yellow, 70 dB, Flashing, Intermittent, 24 VDC, Quick Connect
HW1Z-P1F2PQ4Y 数据手册
HW SERIES ILLUMINATED BUZZER HW1Z-P1F2PQ4Y ILLUMINATED BUZZER Ø22MM, YELLOW 12-24VDC IP65 HW SERIES > ILLUMINATED BUZZER WITH PILOT LIGHTS FEATURES - Combination buzzer and pilot light - Easy wiring and tight installation places - Lamp and buzzer functions are integrated - Panel front IP65 - Installing an optional terminal rubber boot upgrades the terminal’s to IP54 - Complies with the new EU elevator safety standard APPLICATIONS - Semi-outdoor applications - Waterproof requirements for fireman’s elevator - Automatic Storage - Production lines - Automatic guided vehicle systems (AGV) - Control Station SPECIFICATIONS Part No. (Illuminated Buzzer) HW1Z-P1F2PQ4Y Part No. (Optional Terminal Rubber Boot) HW9Z-CZ1 Illumination Color Yellow Rated Insulation Voltage 30V Rated Voltage 12 to 24V DC Voltage Range 10.8 to 26.4V DC Rated Current (effective value) 18mA (24V DC), 8mA (12V DC) Inrush Current Max.100mA Buzzer Sound Pressure (of HW1Z itself) (at 25˚C) 12VDC 84dB min. at 0.1m 64dB min. at 1m Sound Pressure (of HW1Z itself) (at 25˚C) 24VDC 90db min. at 0.1m 70dB min. at 1m Sound Frequency (at 25˚C) 2,200 to 2,450Hz Sound Type Intermittent sound Intermittent Cycle (at 25˚C) 105 cycles/minute approx. (1.75Hz approx.) Illumination Illumination Type Flashing Flash Cycle (at 25˚C) 105 cycles/minute approx. (1.75Hz approx.) Operating Temperature –20 to +50˚C (no freezing) Operating Humidity 20% to 85% RH (no condensation) Storage Temperature –30 to +80˚C (no freezing) Insulation Resistance 100MΩ minimum (at 500V DC megger) Dielectric Strength Between live and earthed metal parts 1000V AC, 1 minute Vibration Resistance Operation extremes: 5 to 55Hz, amplitude 0.5mm Damage limits: 5 to 55Hz, amplitude 0.5mm Shock Resistance Operation extremes: 100 m/s² Damage limits: 1,000 m/s² 1 HW SERIES ILLUMINATED BUZZER HW1Z-P1F2PQ4Y SPECIFICATIONS Degree of Protection Panel front: IP65 (IEC 60529) Terminal: IP40 (IEC 60529) IP54 (with terminal rubber boot) (IEC 60529) Terminal Style Push-in Terminals Applicable Wire Solid wire/ferrule (without sleeve): 0.2 to 1.5 mm² Ferrule (with sleeve): 0.2 to 0.75 mm² Weight (approx.) 17g Standards UL508, EN60947-5-1 DIMENSIONS HW1Z-P1F2PQ4Y Illuminated Buzzer HW9Z-CZ1 Illuminated Buzzer with Terminal Rubber Boot 2
HW1Z-P1F2PQ4Y 价格&库存
很抱歉,暂时无法提供与“HW1Z-P1F2PQ4Y”相匹配的价格&库存,您可以联系我们找货
HW1Z-P1F2PQ4Y
    • 1+294.965081+38.33147
    • 3+260.650113+33.87215
    • 4+256.354544+33.31393
    • 5+253.785465+32.98007
    • 9+249.209039+32.38535
    • 10+248.6390410+32.31128
    • 20+246.0617020+31.97635
    库存:25
