Oiltight Switches and Pilot Devices
HW Series: 22mm
HW Series — 22mm IEC Style Global Pushbuttons
A
Switches & Pilot Devices
HW: The Best Engineered Switch in the World
Key features include:
• Locking lever removable contact blocks
• Finger-safe IP20 contacts as standard, other terminal
styles available
• Tamperproof construction
• All E-stops meet EN418 and are compliant with SEMI
S2 standards
• Worldwide approvals
• Easy to assemble
• Available assembled or as sub-components
• Choice of black plastic or metallic front bezels
• Incandescent or LED illumination
• Transformer or full voltage
• Slow make double break self cleaning contacts
File No. E68961
www.idec.com
File No. LR92374
IDEC’s HW switches are “The best engineered switch in the world” for a
reason. Carrying the CE mark, UL, CSA, and TUV approvals, these
switches are designed for use in almost any part of the world.
Complete with finger-safe contact blocks offering IP20 protection, these
7/8" (22mm) switches include illuminated and non-illuminated
pushbuttons, pilot lights, selector switches, and emergency stop
switches.
All switches also incorporate mechanically keyed safety locking levers,
ensuring correct installation and maintaining safety in high-vibration
applications.
Registration No. R9551089 (E-stops)
Registration No. J9551458 (all other switches)
Registration No. J9650511 (Pilot Lights)
USA: (800) 262-IDEC or (408) 747-0550, Canada (888) 317-IDEC
A-75
HW Series: 22mm
Conforming to Standards
Approvals
File No. E68961
File No. LR92374
CSA: pushbuttons and selector switches: A600
pilot lights and illuminated pushbuttons, direct supply
pilot lights and illuminated pushbuttons with integral transformer
(100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V)
UL: pushbuttons and selector switches: A600
TÜV: pushbuttons and selector switches: A600=P600 (NO, NC)/Q600 (NO-EM, NC-LB)
Operating Temperature
Operation: –25 to +50°C (without freezing)
Storage: –40 to +70°C (without freezing)
Vibration Resistance
10 to 55Hz, 98m/sec2 (10G) conforming to IEC6068-2-6
980m/sec2 (100G) conforming to IEC6068-2-7
Class 0 conforming to IEC60536
IP65 (from front of the panel)
IP20 (Type HW-F contact block)
NEMA 1, 2, 3, 3R, 3S, 4, 4X, 5, 12, 13 (from front of panel)
Momentary pushbuttons: 5,000,000 (900 operations per hour)
Mechanical Life
All other switches: 500,000
Pollution Degree
3 for switches not using a transformer
(conforming to IEC60947-1)
2 for switches using a transformer
AC-15: A600 or Ue = 250V, le = 3A (NO, NC, NO-EM, NC-LB)
Rated Operational Characteristics
DC-13: P600 or Ue = 125V, le = 1.1A (NO, NC)
DC-13: Q600 or Ue = 125V, le = 0.9A (NO-EM, NC-LB)
Rated Insulation Voltage
600V
Rated Switching Over-Voltage
Less than 4kV, conforming to IEC60947-1
4kV for contact circuit
Rated Impulse Withstanding Voltage
2.5kV for lamp circuit
Rated Thermal Current
10 Amp
Minimum Switching Capacity
5 mA at 3V AC/DC
Contact Operation
Slow break NC or NO, self-cleaning
5.5mm to 10mm travel to latch
45N minimum force to latch
Positive Action Operation
10mm maximum travel
(Emergency Stops with NC contacts)
1,800 operations per hour maximum for a Pushlock Turn Reset
900 operations per hour maximum for a Push-Pull
Flush and extended pushbuttons—with 1NO or 1NC contact: 6.2±2N (momentary), 7.0±2N (mainOperating Force
tained)
Additional contacts—1NO or 1NC: +3.2N (momentary), + 3.3N (maintained)
Terminal Referencing
Conforming to CENELEC EN50005
Recommended Terminal Torque
0.8 N m (7.1 in lb.)
External Short-Circuit Protection
10A 250V fuse conforming to IEC60269-1
Applicable Wire Size
Minimum 1 x 22 AWG, max. 2 x 14 AWG or 1 x 12 AWG
Contact Resistance
Initial contact resistance of 50mΩ or less
4mm (NO and NC)
Contact Gap
2mm (NO-EM and NC-LB)
Horsepower Rating
Reference Value: 1/4 HP @ 120V (1ø non-reversing), 1HP @ 240V (3ø non-reversing)
Electrical Reliability
MTBF < 1 fault for 10 million operation cycles (3V DC, 5mA)
Incandescent: 1 W
Lamp Ratings
LEDs: 6V/17mA max, 12V & 24V/11mA max, 120 & 240V/10mA max
40 A (40 ms)
Maximum Inrush Current
Silver (gold plated contacts available - contact IDEC)
Contact Material
Break Values
Make Values
AC
DC
AC
DC
Inductive
Resistive
Inductive
Resistive
Inductive
Resistive
Inductive
Resistive
120V:
20A
24V:10A
24V:10A
24V: 5A
24V: 10A
120V: 60A
120V: 11A
120V: 100A
240V: 11A
120V: 5A
120V: 10A
48V:2A
48V:5A
240V: 30A
240V:
6A
240V: 60A
480V: 4A
Rated Operating Current
240V: 3A
240V: 6A
110V:1.1A
110V:2.2A
480V: 15A
12V: 40A
480V: 20A
12V: 40A
480V: 1A
480V: 2A
220V:0.6A
220V:1.1A
600V: 12 A
24V: 40A
24V: 40A
Specifications
Shock Resistance
Electric Shock Protection
Degree of Protection
(conforming to IEC60529)
(conforming to NEMA ICS6-110)
Contact Ratings
A
EN60947-1, EN60947-5-1, VDE0660-200, UL508, CSA C22-2 No.14
1. For dimensions, see page A-116.
2. For life expectancy derating curves, see page A-120.
A-76
www.idec.com
HW Series: 22mm
Nameplates — HW Series
HWAQ–Black Plastic
Ø 60mm
30mm
30mm
ERGENCY
EM
45mm
STOP
STOP
14.5mm
Part Number
ON
HWAV–Yellow Plastic
A
29mm
29mm
OFF
HWAS–Black Plastic
45mm
Part Numbers: Nameplates
HWAM–Black Plastic
Part Number
Part Number
Part Number
Nameplate
(blank engraving
plate included)
HWAM-OB
HWAQ-OB
HWAS-OB
HWAV-OY
Nameplate
(engraved)
HWAM-➀
HWAQ-➀
HWAS-➀
HWAV-27*
HWAV-527†
Additional Insert
(blank)
HWNP-O
HWNP-O
HWNP Dimensions
12mm
Additional Insert
(engraved)
HWNP-➀
HWNP-➀
27mm
1. In place of ➀, insert either the standard legend code from table below or custom engraving delimited by “ “.
2. Standard engravings are available at no charge.
3. * HWAV-27 comes engraved “Emergency Stop” as shown in drawing.
4. † HWAV-527 for 80mm diameter jumbo mushroom comes engraved “Emergency Stop” as shown in drawing.
Standard Legend Codes
Pushbuttons
Legend
AUTO
CLOSE
DOWN
EMERG.STOP
FAST
FORWARD
HAND
HIGH
IN
INCH
JOG
LOW
LOWER
OFF
ON
Code
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
Legend
OPEN
OUT
RAISE
RESET
REVERSE
RUN
SLOW
START
STOP
TEST
UP
I (Int’l On)
O (Int’l Off)
EMO
Pushbuttons/Selector Switches
Code
116
117
118
119
120
121
122
123
125
126
127
150
151
152
Legend
AUTO-MAN
CLOSE-OPEN
DOWN-UP
FAST-SLOW
FOR-REV
HAND-AUTO
HIGH-LOW
JOG-RUN
LEFT-RIGHT
LOWER-RAISE
MAN-AUTO
OFF-ON
ON-OFF
OPEN-CLOSE
RAISE-LOWER
Code
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
Legend
REV-FOR
RUN-JOG
RUN-SAFE
SAFE-RUN
SLOW-FAST
START-STOP
STOP-START
UP-DOWN
OI (Int’l OFF ON)
Selector Switches
Code
Legend
Code
216
217
218
219
220
221
222
223
250
AUTO-MAN-OFF
AUTO-OFF-MAN
CLOSE-OFF-OPEN
DOWN-OFF-SLOW
FAST-OFF-SLOW
FOR-OFF-REV
LEFT-OFF-RIGHT
LOWER-OFF-RAISE
OFF-MAN-AUTO
OFF-SLOW-FAST
OFF-1-2
OPEN-OFF-CLOSE
SLOW-OFF-FAST
SUMMER-OFF-WINTER
UP-OFF-DOWN
1-OFF-2
HAND-OFF-AUTO
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
1. To order engraved nameplates, add legend code to nameplate part number.
2. Character height based on the number of characters and size of nameplate. Standard character size is 3/16".
3. Nameplates with standard legends are the same list price as blank nameplates.
4. Nameplates have built-in anti-rotation feature for use with notched panel cut-outs. Additional anti-rotation ring (HW9Z-RL) is not necessary.
www.idec.com
A-113
