AL6M-M14-G
AL6M-M14-G
    IDEC(日本和泉)
    按动开关
AL6M-M14-G 数据手册
Switches & Pilot Devices 16mm A6 A6 Series — Miniature Switches and Pilot Devices: 16mm Switches & Pilot Lights Key features: • • • • • • • 16mm (5/8”) mounting hole LED illumination Compact design saves space Momentary, Maintained, Selectors, and E-Stops Gold-clad Silver contacts for reliable low level switching Snap action contacts IP40 (dustproof) or IP65 (oiltight) versions Degree of Protection IP40: Dustproof IP65 Watertight/Oiltight Contact Configuration SPDT, DPDT Maximum Voltage 250V AC/DC Thermal Current 3A Minimum Applicable Load 5V AC/DC, 1mA Contact Material Gold-clad silver Terminal Style .110” Solder/ Quick Connect Operating Temperature -25º to +55ºC (no freezing) Operating Humidity 45 to 85% RH Contact Resistance 50mΩ maximum (initial value) Insulation Resistance 100MΩ minimum (500V DC megger) Vibration Resistance 10 to 55Hz, amplitude 1.5mm p-p Shock Resistance Damage limits: 500m/sec2 (approx. 50G) Operating extremes: 200m/sec2 (approx. 20G) Electrical Life 100,000 operations minimum (at full rated load) Mechanical Life Maintained: 100,000 operations minimum Momentary: 1,000,000 operations minimum Selector/Keylock: 250,000 operations minimum Dielectric Strength Switch Unit: 2,000V AC, 1 min. between live/dead part and terminals of different poles; 1,000V AC, 1 minute between terminals of the same pole; 1,500V AC, 1 minute between contact and lamp terminals. Illumination Unit: 2,000V AC, 1 min. between live part/ground Soldering Temperature 20W/5 seconds or 260ºC/3 seconds Operating Voltage DC Rated Voltage/Current 24V 120V 240V — 1.0A 0.5A Inductive — 0.7A 0.5A Resistive 1.0A 0.2A — Inductive 0.7A 0.1A — Terminal Blocks AC (50/60Hz) Resistive Timers Contact Ratings CSA Certified File No. LR21451 Relays & Sockets LED Lamp Ratings R Display Lights Specifications UL Recognized File No.E55996 5V DC ±5% 6V AC/DC (±10%) 12V AC/DC (±10%) 24V AC/DC (±10%) 8mA AC: A, R, W, Y: 8mA G, S: 7mA DC: A, R, W, Y: 6mA G, S: 5mA AC: 9mA DC: 8mA AC: 9mA DC: 8mA Circuit Breakers 1. AC Inductive Load, PF = 0.6 – 0.7; DC Inductive Load, L/R = 7ms. 2. LED lamp contains a built-in current limiting resistor and a protection diode. 3. LED’s don’t “burn out.” Luminance is reduced to 50% of initial intensity after being lit for 50,000 hours continuously. USA: 800-262-IDEC Canada: 888-317-IDEC 457 Switches & Pilot Devices 16mm A6 jButton Color Code Part Number Style Contact Momentary Dustproof (IP40) Maintained (Latching) Oiltight (IP65) Dustproof (IP40) Oiltight (IP65) Round 18mm Standard Button SPDT DPDT AB6M-M1-j AB6M-M2-j AB6M-M1P-j AB6M-M2P-j AB6M-A1-j AB6M-A2-j AB6M-A1P-j AB6M-A2P-j Color Code Black B Green G Red R Blue S White W Yellow Y Square 18mm SPDT DPDT AB6Q-M1-j AB6Q-M2-j AB6Q-M1P-j AB6Q-M2P-j AB6Q-A1-j AB6Q-A2-j AB6Q-A1P-j AB6Q-A2P-j SPDT DPDT AB6H-M1-j AB6H-M2-j AB6H-M1P-j AB6H-M2P-j AB6H-A1-j AB6H-A2-j AB6H-A1P-j AB6H-A2P-j Rectangular 18mm x 24mm Relays & Sockets Display Lights Switches & Pilot Lights AB6 Non-Illuminated Pushbuttons (Assembled) Non-Illuminated Pushbuttons Round 23.5mm Oversize Button SPDT DPDT – AB6M-M1P-Mj AB6M-M2P-Mj AB6M-A1P-Mj AB6M-A2P-Mj – Square 23.5mm SPDT DPDT – AB6Q-M1P-Qj AB6Q-M2P-Qj – AB6Q-A1P-Qj AB6Q-A2P-Qj SPDT DPDT – AB6Q-M1P-Hj AB6Q-M2P-Hj – AB6Q-A1P-Hj AB6Q-A2P-Hj 1. In place of j, specify Button Color Code from the table at right. 2. To order as sub-assembled, see page 459. 3. For accessories, see page 466. 4. For dimensions, see page 468. Timers Rectangular 17.5 X 23.5mm AB6-V Pushlock Turn Reset Terminal Blocks Shape Operation Contact Part Number Dustproof (IP40) Remarks Oiltight (IP65) 23.5mm Round Mushroom Pushlock Turn Reset SPDT DPDT AB6M-V1-R AB6M-V2-R AB6M-V1P-R AB6M-V2P-R Buzzer Buzzer Ratings Circuit Breakers Style Shape Voltage Part Number 12V DC UZ6-11 24V DC UZ6-12 Round (18mm) 458 1. Button available in red only. 2. Replacement button: order AB6M-V-R Frequency 2 khz ± 500 HZ Amplitude 80db @ 0.1m (at rated voltage) Operating Voltage 6V AC/DC or 12 - 24V AC/DC ± 10% Adjustable Cycle 55 to 600 cycles per minute Current Draw DC: 7mA, AC: 20mA Life 1000 hrs. minimum Insulation Voltage 60V AC/DC Operating Temperature -20 to 55 C (no freezing), 45 to 85% rh www.idec.com Switches & Pilot Devices 16mm A6 AB6 Non-Illuminated Pushbuttons (Sub-Assembled) + Button = Switches & Pilot Lights Operator Completed Unit Operators Style Contact Round Square Rectangular Momentary AB6M-M100 AB6Q-M100 AB6H-M100 Maintained AB6M-A100 AB6Q-A100 AB6H-A100 Momentary AB6M-M200 AB6Q-M200 AB6H-M200 Maintained AB6M-A200 AB6Q-A200 AB6H-A200 Display Lights Non-Illuminated Pushbuttons Part Number Operator SPDT DPDT Oversize rectangular button uses square operator. jButton Color Code Part Number Description Relays & Sockets Buttons Button Dustproof (IP40) Oiltight (IP65) AB6M-BK1-j AB6M-BK2-j Round Square AB6Q-BK2-j AB6H-BK1-j AB6H-BK2-j Code Black B Green G Red R Blue S White W Yellow Y Timers AB6Q-BK1-j Color Rectangular Round Oversize AB6M-BK2-Mj – AB6Q-BK2-Qj – AB6Q-BK2-Hj Terminal Blocks – Square Oversize Rectangular Oversize Circuit Breakers 1. In place of j, specify Button Color Code from table. 2. Buttons which are rated IP65 include a waterproof rubber gasket. 3. For accessories, see page 466. USA: 800-262-IDEC Canada: 888-317-IDEC 459 Switches & Pilot Devices 16mm A6 Switches & Pilot Lights AL6 Illuminated Pushbuttons (Assembled) LED Illuminated Pushbuttons Part Numbers Description Style Momentary Contact Maintained (Latching) Dustproof (IP40) Oiltight (IP65) Dustproof (IP40) Oiltight (IP65) SPDT DPDT AL6M-M1l-k AL6M-M2l-k AL6M-M1lP-k AL6M-M2lP-k AL6M-A1l-k AL6M-A2l-k AL6M-A1lP-k AL6M-A2lP-k SPDT DPDT AL6Q-M1l-k AL6Q-M2l-k AL6Q-M1lP-k AL6Q-M2lP-k AL6Q-A1l-k AL6Q-A2l-k AL6Q-A1lP-k AL6Q-A2lP-k SPDT DPDT AL6H-M1l-k AL6H-M2l-k AL6H-M1lP-k AL6H-M2lP-k AL6H-A1l-k AL6H-A2l-k AL6H-A1lP-k AL6H-A2lP-k Round (18mm lens) Display Lights Square (18mm lens) Standard Lens Relays & Sockets Rectangular (18mm x 24mm lens) Round (24mm lens) SPDT DPDT – AL6M-M1lP-Mk AL6M-M2lP-Mk – AL6M-A1lP-Mk AL6M-A2lP-Mk SPDT DPDT – AL6Q-M1lP-Qk AL6Q-M2lP-Qk – AL6Q-A1lP-Qk AL6Q-A2lP-Qk SPDT DPDT – AL6Q-M1lP-Hk AL6Q-M2lP-Hk – AL6Q-A1lP-Hk AL6Q-A2lP-Hk Oversize Lens Rectangular (18mm x 24mm lens) Terminal Blocks Timers Square (24mm lens) 1. In place of k, specify Lens/LED Color Code from table below. 2. In place of l, specify Voltage Code from table below. 3. Lamps also available in 5V DC, 6V AC/DC or 12 V AC/DC, change “4” using voltage/lamp codes (ie AL6M-M13-k uses 12V AC/DC LED). 4. LED lamp is included in unit and contains a current-limiting resistor and a protection diode. (External resistor not required.) 5. To order as sub-assembled, see page 461. 6. For accessories, see page 466. 7. For dimensions, see page 468. 8. Light independent of switch position. Circuit Breakers kLens/LED Color Code lVoltage Code Voltage Code Color Code Amber A 5V DC 1 Green G 6V AC/DC 2 Red R 12V AC/DC 3 Blue S 24V AC/DC 4 Warm White W Cool White JW Yellow 460 Y www.idec.com Switches & Pilot Devices 16mm A6 AL6 Illuminated Pushbuttons (Sub-Assembled) + LED Lamp + Lens = Switches & Pilot Lights Operator Completed Unit Operators Style Contact Round Square Rectangular Momentary AL6M-M100 AL6Q-M100 AL6H-M100 Maintained AL6M-A100 AL6Q-A100 AL6H-A100 Momentary AL6M-M200 AL6Q-M200 AL6H-M200 Maintained AL6M-A200 AL6Q-A200 AL6H-A200 Display Lights AL6 Illuminated Pushbuttons Part Number Operator SPDT DPDT Oversize rectangular button uses square operator. Unit Relays & Sockets Lenses Part Number Degree of Protection Dustproof (IP40) Size Standard Oiltight (IP65) Standard Oversize AL6M-LK1-k AL6M-LK2-k AL6M-LK2-M k AL6Q-LK1-k AL6Q-LK2-k AL6Q-LK2-Q k AL6H-LK1-k AL6H-LK2-k AL6Q-LK2-H k Round Timers Square Rectangular Terminal Blocks 1. In place of k, specify Lens Color Code from table below. 2. Lenses which are rated IP65 include a waterproof rubber gasket. 3. For accessories, see page 466. kLens/LED Color Code LED Lamps Color Code Amber A 5V DC LATD-5 k Green G 6V AC/DC LATD-6 k Red R 12V AC/DC LATD-1 k Blue S 24V AC/DC LATD-2 k Warm White W Cool White JW Rated Voltage Part Number Circuit Breakers Yellow Appearance 1. In place of k, specify LED Color Code from table at left. Y USA: 800-262-IDEC Canada: 888-317-IDEC 461 Switches & Pilot Devices 16mm A6 Switches & Pilot Lights AL6 Pilot Lights (Assembled) LED Pilot Lights Description Part Number Dustproof (IP40) Oiltight (IP65) Round (18mm Lens) AL6M-Pl-k AL6M-PlP-k AL6Q-Pl-k AL6Q-PlP-k AL6H-Pl-k AL6H-PlP-k Display Lights Square (18mm Lens) Relays & Sockets Rectangular (18mm x 24mm Lens) 1. In place of k, specify Lens Color Code from table below. 2. In place of l, specify Voltage Code from table below. 3. LEDs also available in 5V DC, 6V AC/DC or 12 V AC/DC, change “4” using voltage codes (ie AL6M-P3-k uses 12V AC/DC LED). 4. LED is included and contains built-in current limiting resistor and reverse polarity protection diode. (no external resistor required) 5. To order sub-assembled, see page 463. 6. For accessories, see page 466. 7. For dimensions, see page 468. 8. For one piece pilot lights and/or dome lens pilot lights, see AP series miniature pilot lights. Timers kLens/LED Color Code lVoltage Code Voltage Code Color Code Amber A 5V DC 1 Green G 6V AC/DC 2 Red R 12V AC/DC 3 Blue S 24V AC/DC 4 Warm White W Cool White JW Y Circuit Breakers Terminal Blocks Yellow 462 www.idec.com Switches & Pilot Devices 16mm A6 AL6 Pilot Lights (Sub-Assembled) + LED Lamp + Lens = Switches & Pilot Lights Operator Completed Unit Operators Part Number Style Round Square Rectangular AL6M-P00 AL6Q-P00 Display Lights AL6 Pilot Lights AL6H-P00 Lenses Part Number Degree of Protection Oiltight IP65 AL6M-LK3-k AL6Q-LK1-k AL6Q-LK3-k AL6H-LK1-k AL6H-LK3-k Relays & Sockets Dustproof IP40 AL6M-LK1-k Round Square Timers Rectangular kLens/LED Color Code LED Lamps Code Rated Voltage Part Number A 5V DC LATD-5 k Green G 6V AC/DC LATD-6 k Red R 12V AC/DC LATD-1 k Blue S 24V AC/DC LATD-2 k Warm White W Cool White JW Appearance Circuit Breakers Color Amber Yellow Terminal Blocks 1. In place of k, specify Lens Color Code from table below. 2. Lenses which are rated IP65 include a waterproof rubber gasket. 3. For accessories, see page 466. 1. In place of k, specify LED Color Code from table at left. Y USA: 800-262-IDEC Canada: 888-317-IDEC 463 Switches & Pilot Devices 16mm A6 Square Keylock Timers Rectangular Selector 3-Position 45º 2-Position 90º Display Lights Square Selector 3-Position 45º Round Selector Function 2-Position 90º Style Round Keylock Relays & Sockets Contact Operations AS6 Selector Switches and Keylock Switches (2 & 3 Position) 2-Position 90º Switches & Pilot Lights AS6 Selector and Keylock Switches R AS6M-2Y2P AS6M-2KT2Pj Spring Return Right L R AS6M-21Y2P AS6M-21KT2PB Maintained L R AS6M-3Y2P AS6M-3KT2Pj Terminal Blocks 3-Position 45º C Spring Return Right gCenter L Spring Return Left gCenter L 2-Way ReturngCenter C R AS6M-31Y2P AS6M-31KT2Pj R AS6M-32Y2P AS6M-32KT2Pj L R AS6M-33Y2P AS6M-33KT2PD L R AS6Q-2Y2P AS6Q-2KT2Pj 464 (for all selectors) Contents Operator Position & Contact Operation Left Right Contact Contact NO NC NO NC Left C 2-pos. (DPDT) C Left Right Contact Contact NO NC NO NC Right C Maintained C C L C Maintained L Spring Return RightgCenter L Spring Return Left gCenter L 2-Way ReturngCenter Maintained Spring Return Right Spring Return Right gCenter R AS6Q-21Y2P AS6Q-3Y2P AS6Q-3KT2Pj R AS6Q-31Y2P AS6Q-31KT2Pj R AS6Q-32Y2P AS6Q-32KT2Pj L R AS6Q-33Y2P AS6Q-33KT2PD L R AS6H-2Y2P AS6H-2KT2Pj L R AS6H-21Y2P AS6H-21KT2PB C C R C Spring Return LeftgCenter L 2-Way ReturngCenter L C Left Right Contact Contact NO NC NO NC Right C jKey Retention Codes C L C C C L Center AS6Q-21KT2PB R C Left Right Contact Contact NO NC NO NC 3-pos. (DPDT) Spring Return to Right C Left Right Contact Contact NO NC NO NC Left C R C AS6H-3Y2P AS6H-31Y2P AS6H-3KT2Pj R AS6H-32Y2P AS6H-32KT2Pj R AS6H-33Y2P AS6H-33KT2PD C Code All models are IP65 and DPDT. In place of j, specify Key Retention Code. See table on right. Available as assembled units only. For accessories, see page 466. For dimensions, see page 468. www.idec.com Description A Key not retained in any position (removable in all positions) B Key retained in right position only C Key retained in left position only D Key retained in left and right (3 position only) E Key retained in center only (3 position only) G Key retained right and center (3 position only) H Key retained left and center (3 position only) AS6H-31KT2Pj Circuit Breakers 1. 2. 3. 4. 5. Key L Maintained Maintained Rectangular Keylock Knob Key cannot be removed in a spring return position. Switches & Pilot Devices 16mm A6 Switches & Pilot Lights Switch Engraving Order Form – A6 Series Copy this order form and use it to specify Letter Height, Maximum Number of Lines and Text to be engraved. To insure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: Telephone: Name: Fax: Address: Email: PO: Part Number to be Engraved: Display Lights Please check one of the boxes below to indicate your choice of engraving options: Rectangular Switch Round Switch Square Switch Letter Height Max. Characters Per Line # of Lines Letter Height Max. Characters Per Line 1 5/32 6 1 5/32 5 # of Lines Letter Height Max. Characters Per Line 5/32 3 1/8 3 1 5/32 6 2 3 5/32 5 1/8 6 2 5/32 Custom* 1/8 6 3 1/8 Custom* 4 3/32 Custom* 2 1/8 6 1/8 6 4 N/A 3 4 N/A Relays & Sockets # of Lines *Engraving is possible, but character size will be smaller than standard sizes. Timers 1. Engraving is done on the button itself for non-Illuminated pushbuttons and on marking plate for illuminated pushbuttons and pilot lights. 2. Please enter text exactly how you want it engraved, take care to emphasize capital or small letters. Sample Letter Sizes Enter text to be engraved: 1/8 Letters: Line 1: 5/32 Letters: Terminal Blocks Line 2: Line 3: Line 4: Circuit Breakers For IDEC Internal Use Only: Work Order #: USA: 800-262-IDEC Canada: 888-317-IDEC 465 Switches & Pilot Devices 16mm A6 Display Lights Switches & Pilot Lights Accessories Appearance Description Locking Ring Wrench Made of metal. Used for tightening plastic locking ring during installation. Tightening torque should not exceed 3kgf-cm Part Number Ø 5/8” (16mm) units MT-001 Ø 31/64” (12mm) AP2M units MT-002 Ø 13/32” (10mm) AP1M units MT-003 Lens Removal Tool Made of metal. Used for removing lens or button from the housing All pushbuttons and pilot lights MT-101 Lamp Holder Tool Made of rubber. Used for removing and replacing LED lamps in illuminated units All illuminated pushbuttons and pilot lights OR-77 Prevents inadvertent switch operation. IP40 dust-tight. 90 degrees opening maintained Round/Square AL-K6 Rectangular AL-KH6 Prevents inadvertent switch operation. IP65 oiltight 180 degrees opening, spring return Round/Square AL-K6SP Rectangular AL-KH6SP Made of translucent nylon. Fits over and shields the terminals All 5/8” (16mm) units AL-V6 All round units AL-D6 All square units AL-DQ6 All rectangular units AL-DH6 Switch Guard Terminal Cover Relays & Sockets Used With Dust Cover Fits over the lens or button to provide extra protection from dust (not applicable for oversize lenses or buttons). Plug-on terminal adaptor with solder terminals Adaptor Socket Mounting Hole Plug Plug-on terminal adaptor with PCB terminals AL-C6 All 5/8” (16mm) units Fills unused panel cutouts. Made of nitrile rubber. Push-in installation from front of panel. IP65 (oiltight). Rubber AL-B6 Fills unused panel cutouts. Made of aluminum. Screw-on locking ring from inside of panel. IP65 (oiltight). Aluminum AL-BM6 Timers Round Mounting Hole Plug Terminal Blocks Plastic (Applicable for flush mount switches only) LA9Z-BS7 5V DC LATD-5 k 6V AC/DC LATD-6 k 12V AC/DC LATD-1 k 24V AC/DC LATD-2 k Rectangular Mounting Hole Plug LED with built in current limiting resistor (with all illuminated assemblies). LA9Z-BS8 Replacement Locking Ring Fastens operators to panel (included with all operators). All switches & pilot lights HA9Z-LN Anti-Rotation Ring Prevents rotation of switches in panel (included with all operators). All switches & pilot lights AL6-LP Round standard AL6M-W Square standard AL6Q-W Replacement Engraving Inserts Circuit Breakers LA9Z-BS6 Square Mounting Hole Plug Replacement LED Lamps AL-C6V Replacement Keys Engraving plates to allow legends underneath translucent lenses (included with all lenses). Pair of keys (#132). All key switches use same standard key. 1. In place of k specify color code. A=Amber, G=Green, Y=Yellow, R=Red, S=Blue, W=Warm White, JW=Cool White. 2. LEDs include built-in current limiting resistor and reverse polarity protection diode. 466 www.idec.com Rectangular standard AL6H-W Round oversize AL6M-MW Square/rectangular oversize AL6Q-QW All key selectors AS6-SK Switches & Pilot Devices Appearance 16mm A6 Used With Part Number ø24mm round, metal (aluminum color), panel cut-out ø20.2mm Pushbuttons, pilot lights, illuminated pushbutton, selector switches, key selector switches and illuminated selector switches. LA9Z-SM61 ø24mm round, plastic (black), square panel cut-out ø20.2mm Switches & Pilot Lights Description LA9Z-S61B A6 Switch Flush Bezel + 24mm square, plastic (black), panel cut-out 20.2 x 20.2mm LA9Z-S71B Switch Guard w/ Flush Bezel (spring return) Display Lights Flush Bezel 24 x 30mm rectangular, plastic (black), rectangular panel cut-out ø20.2 x 26.2mm LA9Z-S81B = Rectangular, plastic (black) LA9Z-KS8 Flush Switch Relays & Sockets Schematics — A Series: 5/8” (16mm) Terminal Arrangement (Top View) Non-illuminated Pushbuttons and Selector Switches Illuminated Pushbuttons (TOP) (TOP) (TOP) (TOP) (TOP) NC1 NC1 NC2 NC1 NC1 NC2 NO1 NO1 NO2 NO1 NO1 NO2 C1 Lamp Terminal (–) SPDT Contact (Single-pole/Double Throw) Lamp Terminal (+) C1 C2 Lamp Terminal (–) DPDT Contact (Double-pole/Double Throw) C1 C1 SPDT Contact (Single-pole/Double Throw) C2 Lamp Terminal (+) Lamp Terminal (–) Timers Lamp Terminal (+) Pilot Lights DPDT Contact (Double-pole/Double Throw) Terminal Blocks IDEC’s Superbright LED Internal Circuits LATD-1,-2,-6 (GS) LATD-5 (ARWY) LED Chip Protective Diode Zener Diode LATD-1,-2,-6 (ARWY) LATD-5 (GS) Circuit Breakers USA: 800-262-IDEC Canada: 888-317-IDEC 467 Switches & Pilot Devices 16mm A6 Pushbuttons, Ø 5/8” (16mm) Rubber Gasket Terminal Width 2.8×0.5t Anti-rotation Ring 2.5 3 Locking Ring Panel Thickness 0.5 to 6 Round Square (TOP) ø18 (TOP) 18 5 Rectangular (TOP) 5 Switches & Pilot Lights Dimensions (mm) 1 0.6 9 22 24 Oversize Lens Rubber Gasket Anti-rotation Ring Teminal Width 2.8×0.5t Locking Ring 2.5 3 Panel Thickness 0.5 to 6 Rectangular (TOP) 6 1 8 0.6 9 22 Round (TOP) c 23.5 ø23.5 Square (TOP) 17.5 6 Relays & Sockets 5.7 18 9 5 5 Display Lights 8 23.5 0.6 9 15.5 0.6 15.5 12.5 Selector Switches, Ø 5/8” (16mm) Terminal Width 2.8×0.5t 2.5 3 Rubber Gasket Anti-rotation Ring Panel Thickness 0.5 to 6 Rectangular (TOP) Locking Ring Square (TOP) Round (TOP) 8 5 18 5 ø1 8 Timers 1 8 22 15.5 c18 24 Key Selector Switches, Ø 5/8” (16mm) 2.5 Right Contact 3 Rubber Gasket Terminal Width 2.8×0.5t 2.5 5 3 Anti-rotation Ring Panel Thickness 0.5 to 6 Locking Ring Rectangular (TOP) Square (TOP) Round (TOP) NC 18 5 Terminal Blocks TOP Left Contact NO C Circuit Breakers 1 8 468 22 26 24 www.idec.com 18 ø18 Switches & Pilot Devices 16mm A6 Switch Guard, Ø 5/8” (16mm) 26.5 minimum (45.5 minimum for 180° opening type) 13 23.5 Panel Thickness 0.5 to 5 32 R2 33 24 10.5 26.5 minimum (45.5 minimum for 180° opening type) 13 10.5 23.5 18 Rubber Gasket 28 14 28 (180° opening type) R2 24 Panel Thickness 0.5 to 5 Waterproof Gasket for Switch Guard 45.5 min. 2 14 19 min. Rubber Gasket 0.4 28 Relays & Sockets 45.5 min. 23.5 10.5 13 33 18 Display Lights 25 minimum 34 23.5 10.5 13 2 Rubber Gasket 14 (90°/110° opening type) 19 minimum Switches & Pilot Lights Panel Thickness 0.5 to 5 34 25 min. Flush Bezel Flush Bezel with Switch Panel Thickness 0.5 to 5 14.8 8 8 ø2 4 18 24 Selector Switches Illuminated & Non-illuminated 2 20 21.4 2 Key 2 17 26 27.4 8.5 Terminal Blocks 2 18.1 2 24 30 23 Lever 24 18 8.5 Rectangular 29 2 20 21.4 8.5 1 8 Timers Square ø1 ø2 4 ø1 0.9 0.8 9.8 Plastic Metal ø 20 22.6 Round Flush Bezel Gasket ø21.4 Mounting Bracket 9.3 2 Flush Bezel Mounting Hole Layout Square + – 0 0.2 .1 Round 26.2 +0.2 – 0.1 24 min.∗ 24 min.∗ 24 min.∗ +0.2 20.2 -0.1 Circuit Breakers ø2 0. 2 20.2 Rectangular +0.2 – 0.1 24 min.∗ 24 min.∗ USA: 800-262-IDEC 30 min.∗ Canada: 888-317-IDEC 469 Switches & Pilot Devices 16mm A6 Terminal Sockets Switches & Pilot Lights 3 3 (TOP) 5 5 5 5 NC1 NC2 NO1 NO2 16.2 7.5 6 16.2 6 Solder Terminal Type (AL-C6) 3.8 6 6 Lamp Terminal (+) PC Board Mounting Hole Layout (Bottom View) PC Board Terminal Type (AL-C6V) Dust Covers C1 C2 Lamp Terminal (–) Terminal Arrangement (Bottom View) Panel Cut-Outs For Units w/Dust Cover AL-D6, Round AL-DQ6, Square ø24 AL-DH6, Rectangular Round/Square 30 c 24 ø16.2 Rectangular +0.2 0 ø16.2 +0.2 0 13 0.3 0.3 Waterproof Gasket for Dust Cover Waterproof Gasket for Dust Cover Marking Plates Style Round—AL6M-W Square—AL6Q-W Pushbuttons with Oversize Lens Rectangular—AL6H-W Style Round—AL6M-MW a1 øOD øa Engraving Area Square/Rectangular—AL6Q-QW øOD ❏ OD ❏a Dimensions ca Marking Area Marking Area a2 0.8 øa 0.8 0.8 Timers Dimensions Marking Area Engraving Area OD1 øOD OD2 Ø 5/8” (16mm) Terminal Blocks 24 min. 7.5 7.5 13 13 7.5 Waterproof Gasket for Dust Cover Pushbuttons with Standard Size Lens Circuit Breakers 30 min. 24 min. 0.3 Relays & Sockets 24 min. 24 Display Lights +0.3 0 Holes 2.4 2.5 8-1.6 2.5 Terminal 1.5×0.3t 33.5 TOP 33.5 Outside (OD) (13.8mm) (13.8mm) (OD1 x OD2) 13.8 x 19.8mm Marking Area (a) (12mm) (12mm) (a1xa2) 12 x 18mm Outside (OD) Ø 0.491” (12.6mm) 0.491” (12.6mm) Marking Area (a) Ø 0.429” (11mm) 0.429” (11mm) Engraving must be made on the engraving area within 0.02” (0.5mm) deep. Replacing & and Marking Plate Removal Remove the lens holder assembly (lens, marking plate and holder) from the operator by holding the color lens recesses with the lens removal tool (Part No.MT-101) and pulling out. Remove marking plate by pushing the color lens from the rear to disengage the latches. Marking plate must be engraved on the side as shown in the figure on the right. Ø 5/8” (16mm) Installation For illuminated pushbuttons: 1. Insert marking plate inside lens in correct direction 2. Press color lens on to lens holder to engage latches. 3. Insert lens holder into housing in correct direction. Do not loosen spring on illuminated pushbutton units (except on pilot light units). The marking plate must be engraved on the front side as shown above. Fitting Grooves Grooves Engraving Surface Color Lens 470 Marking Plate Lens Holder www.idec.com
AL6M-M14-G 价格&库存
很抱歉,暂时无法提供与“AL6M-M14-G”相匹配的价格&库存,您可以联系我们找货
