CW1K-31DE11N3
CW1K-31DE11N3
    IDEC(日本和泉)
CW1K-31DE11N3 数据手册
IDEC ø22mm Flush Mount CW Series Switches & Pilot Devices Safety, Style and Flexibility Safety Third-generation Safety Construction Two-action removal of contact blocks IDEC’s original two-action push-turn locking lever provides a higher level of safety by preventing unexpected release of the locking lever. In addition, the position of the locking lever can be used to verify if the contact block was installed securely by checing from the back of the panel. kTurn Guard j Push Locking lever integrated with guard Prevents locking lever from unexpected release or damage by trapped wires. IP20 Finger-safe Terminals Finger-safe, IP20 terminals prevent electrical shock. Illuminated Pushbuttons - Page 6 Bezel Black or metallic 2 • Round flush and extended • Illumination colors: amber, blue, green, white, red, yellow Non-illuminated Pushbuttons - Page 8 • Round flush and extended • Button colors: black, blue, green, red, yellow, white Pilot Lights - Page 9 • Round flush and extended • Illumination colors: amber, blue, green, white, red, yellow The IDEC commitment to assuring safety in all operating environments has resulted in stylish, compact and space-saving switches and pilot devices. The innovative two-step locking lever integrated with a guard provides a higher level of safety, and the low projection from the panel surface reduces the possibility of unexpected activation or operator damage. The CW series adds a sleek and stylish image to the panel with black or metallic bezels. The shortest depth behind the panel in its class contributes to reducing machine size. Design & Style 2.5mm Bezel Thickness Sleek and stylish switches with a 2.5mm-thick bezel The CW series give a sleek, stylish image to your machine or control panel. Because of the slim profile, the surface is safer as there is less chance of unexpected operation or accident by hitting the switch. The design also means that the switch is cleaner as it has less dust build-up. Single Contact Block Short depth behind the panel Space-saving design 39.9mm Depth behind the panel Short depth behind the panel allows for smaller machines and panels. Up to 3 contact blocks (non-illuminated models) or 2 contact blocks (illuminated models) can be installed. Use with IDEC FB series or other control boxes. • 300V AC, 10A contact rating • No transformer needed—the same depth behind the panel—for any illumination voltage. • Up to 6 total contacts per switch are possible Shortest in its class 2.5mm Bezel Thickness Actual size Dual Contact Block Depth behind the panel comparison The depth behind the panel of the CW series is shorter than conventional switches, reducing the amount of space needed in the control panel.  59.9mm Depth behind the panel 800.262.4332 www.IDEC.com/switches Selector Switches - Page 10 • Knob Operator 2- and 3-position Selector Switches - Page 10 • Lever Operator 2- and 3-position • Lever operator with an easy grip Key Selector Switches - Page 13 • 7 different wave-keys available • Hard to duplicate, wave-key ensures a high level of safety 3 ø22mm Flush Mount CW Switches & Pilot Devices Flush bezel projects only 2.5mm from front of panel and as little as 39.9mm behind the panel! • ø22.3mm mounting hole compliant with IEC 60947-5-1 • 3.5mm operator travel for pushbuttons ensures comfortable and reliable operation • Up to 6 contacts per switch are possible with use of dual contact blocks • Black and metallic bezels available • Illuminated pushbuttons, pushbuttons, pilot lights, selector switches and key selector switches are available • Direct opening NC contact • Seven different keys can be chosen for key selector switches • 10A contact rating; up to three contact blocks for non-illuminated and two contact blocks for illuminated models can be connected • Contact blocks can be removed by using the locking lever • IP20 finger-safe screw terminals • UL Type 4X rating  Applicable Standards Mark UL508 CSA C22.2 No.14 File No. or Organization UL/c-UL File No. E68961 Specifications TÜV SÜD EN60947-5-1 Contact Ratings Rated Insulation Voltage (Ui) 300V Rated Thermal Current (Ith) 10A Rated Operating Voltage (Ue) Rated Operating Current (Ie) AC Electrical 50/60 Hz Life 50,000 operations DC Electrical Life 100,000 operations AC 50/60 Hz DC Resistive Load (AC-12) Inductive Load (AC-15) Resistive Load (DC-12) Inductive Load (DC-13) Resistive Load (AC-12) Inductive Load (AC-15) Resistive Load (DC-12) Inductive Load (DC-13) 24V 120V 240V 10A 10A 6A 10A 6A 3A 8A 2.2A 1.1A 4A 1.1A 0.55A 5A 5A 3A 5A 3A 1.5A 4A 1.1A 0.55A 2A 0.55A 0.27A Contact Material Silver 1. Minimum applicable load (reference value): 3V AC/DC, 5 mA (Applicable range is subject to the operating conditions and load.) 2. The operational current represents the classification by making and breaking currents (IEC 60947-5-1). 3. UL, c-UL rating: A300 Weights Illuminated Pushbutton Pushbutton Pilot Light Selector Switch Key Selector Switch 4 46g (CW1L-M1E02QH, 2 contacts) 62g (CW1L-M1E22QH, 4 contacts) 45g (CW1B-M1E03, 3 contacts) 52g (CW1B-M1E22, 4 contacts) 27g (CW1P-1EQH) 48g (CW1S-2E03, 3 contacts) 55g (CW1S-2E22, 4 contacts) 61g (CW1K-2AE03, 3 contacts) 68g (CW1K-2AE22, 4 contacts) Operating Humidity Non-illuminated: –25 to +60°C (no freezing) LED illuminated: –25 to +55°C (no freezing) 45 to 85% RH (no condensation) Storage Temperature –40 to +80°C Contact Resistance Insulation Resistance Overvoltage Category Impulse Withstand Voltage Pollution Degree Vibration Resistance 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) II (IEC 60664-1) Operating Temperature EC Low Voltage Directive Shock Resistance Mechanical Life (minimum operations) Electrical Life (minimum operations) Degree of Protection (IEC60529) Short-circuit Protection Electrical Shock Protection Terminal Style Bezel Material Applicable Wire Size Recommended Tightening Torque 2.5 kV (IEC60664-1/60947-5-1) 3 (IEC60947-5-1) Operating extremes: 5 to 55Hz, amplitude 0.5 mm Operating extremes: 100 m/s2 Damage limits: 1000 m/s2 Pushbutton, illuminated pushbutton: 2,000,000 Selector switch: 250,000 Key selector switch: 250,000 50,000 (see Contact Ratings) 100,000 (see Contact Ratings) (switching frequency 1800 operations/h) Panel front: IP65, IP66, IP67 (see chart on page 5) Terminals: IP20 Type 4X 250V/10A fuse, (Type aM IEC60269-1, IEC602069-2) Class II (IEC61140) Screw terminal (M3.5 slotted Phillips screw) Polyamide Up to 2 wires of 2 mm2 (solid wire ø1.6) maximum (AWG14 to 16) (Ring terminal cannot be used) Terminal: 1.0 to 1.3 N·m Locking ring: 1.2 N·m Direct Opening of Key Selector Switch Operator Angle for Direct Opening Action Minimum Operator Torque for Direct Opening Action Maximum Operator Angle 2-position (3NC) 3-position (2NC) 90° 45° 0.2 N·m 0.3 N·m 90° 45° LED Module Rated Insulation Voltage (Ui) 250V Rated Operating Voltage (Ue) 6V AC/DC 12V AC/DC 24V AC/DC Operating Voltage Range Illumination Color Code k LED Module Part Number Current Draw Life (reference value) 6V AC/DC±10% 12V AC/DC±10% CW-EAQ2k 15 mA CW-EAQ3k 15 mA R X1 100/120V AC X1 LED Chip Internal Circuit 230/240V AC 24V AC/DC±10% 100/120V AC±10% A (amber), G (green), PW (white), R (red), S (blue) CW-EAQ4k CW-EAQHk 16.5 mA 18 mA Approx. 30,000 hours Rectifying Diode R Zener Diode Resistor X2 X2 230/240V AC +/-10% CW-EAQM4k 18 mA R LED Chip Rectifying Diode Zener Diode Resistor Capacitor R R C 1. Specify an illumination color code in place of k in the part number. 2. Use the white (PW) LED module for yellow illumination. Contact Blocks Contact Block Single Contact Block Double Contact Block Contact 1NO 1NC 2NO 2NC 1NO-1NC Part No. YW-E10R YW-E01 YW-EW2R0 YW-EW02 YW-EW1R1 Housing Color Blue/Black Reddish Purple Blue/Black Reddish Purple Reddish Purple/Blue Push Rod Color Black Red Black Red Shape Terminal No. 3-4 1st tier: 13-14 2nd tier: 23-24 1-2 Weight (approx.) Gray 1st tier: 11-12 2nd tier: 21-22 11g 1st tier: (NO) 13-14 2nd tier: (NC) 21-22 19g Mounting Hole Layout Rating IP65 IP66 IP67 UL Type 4X Illuminated Pushbutton Yes Yes * Yes * Yes * Pilot Light Yes Yes No Yes Pushbutton Yes Yes * Yes * Yes * Selector Switch Yes Yes Yes Yes Key Selector Switch Yes Yes No Yes IEC 60947-5-1 compliant 3.2 +0.2 0 R0.8 max. ø22 .3 +0.4 0 24.1+0.4 0 Degree of Protection 50 *When used with rubber boot (CW9Z-D11, -D12) 30  Note: Determine mounting centers to ensure proper spacing. 800.262.4332 www.IDEC.com/switches 5 Illuminated Pushbuttons Illuminated Pushbuttons (Assembled) Shape Round Flush CW0L-01 (black bezel) Operating Voltage Contact Configuration Black Bezel Metallic Bezel 6V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-1E10Q2k CW1L-1E01Q2k CW1L-1E11Q2k CW1L-1E20Q2k CW1L-1E02Q2k CW1L-1E22Q2k CW4L-1E10Q2k CW4L-1E01Q2k CW4L-1E11Q2k CW4L-1E20Q2k CW4L-1E02Q2k CW4L-1E22Q2k 12V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-1E10Q3k CW1L-1E01Q3k CW1L-1E11Q3k CW1L-1E20Q3k CW1L-1E02Q3k CW1L-1E22Q3k CW4L-1E10Q3k CW4L-1E01Q3k CW4L-1E11Q3k CW4L-1E20Q3k CW4L-1E02Q3k CW4L-1E22Q3k 24V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-1E10Q4k CW1L-1E01Q4k CW1L-1E11Q4k CW1L-1E20Q4k CW1L-1E02Q4k CW1L-1E22Q4k CW4L-1E10Q4k CW4L-1E01Q4k CW4L-1E11Q4k CW4L-1E20Q4k CW4L-1E02Q4k CW4L-1E22Q4k 100/120V AC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-1E10QHk CW1L-1E01QHk CW1L-1E11QHk CW1L-1E20QHk CW1L-1E02QHk CW1L-1E22QHk CW4L-1E10QHk CW4L-1E01QHk CW4L-1E11QHk CW4L-1E20QHk CW4L-1E02QHk CW4L-1E22QHk 230/240V AC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-1E10QM4k CW1L-1E01QM4k CW1L-1E11QM4k CW1L-1E20QM4k CW1L-1E02QM4k CW1L-1E22QM4k CW4L-1E10QM4k CW4L-1E01QM4k CW4L-1E11QM4k CW4L-1E20QM4k CW4L-1E02QM4k CW4L-1E22QM4k 6V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-2E10Q2k CW1L-2E01Q2k CW1L-2E11Q2k CW1L-2E20Q2k CW1L-2E02Q2k CW1L-2E22Q2k CW4L-2E10Q2k CW4L-2E01Q2k CW4L-2E11Q2k CW4L-2E20Q2k CW4L-2E02Q2k CW4L-2E22Q2k 12V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-2E10Q3k CW1L-2E01Q3k CW1L-2E11Q3k CW1L-2E20Q3k CW1L-2E02Q3k CW1L-2E22Q3k CW4L-2E10Q3k CW4L-2E01Q3k CW4L-2E11Q3k CW4L-2E20Q3k CW4L-2E02Q3k CW4L-2E22Q3k 24V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-2E10Q4k CW1L-2E01Q4k CW1L-2E11Q4k CW1L-2E20Q4k CW1L-2E02Q4k CW1L-2E22Q4k CW4L-2E10Q4k CW4L-2E01Q4k CW4L-2E11Q4k CW4L-2E20Q4k CW4L-2E02Q4k CW4L-2E22Q4k 100/120V AC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-2E10QHk CW1L-2E01QHk CW1L-2E11QHk CW1L-2E20QHk CW1L-2E02QHk CW1L-2E22QHk CW4L-2E10QHk CW4L-2E01QHk CW4L-2E11QHk CW4L-2E20QHk CW4L-2E02QHk CW4L-2E22QHk 230/240V AC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-2E10QM4k CW1L-2E01QM4k CW1L-2E11QM4k CW1L-2E20QM4k CW1L-2E02QM4k CW1L-2E22QM4k CW4L-2E10QM4k CW4L-2E01QM4k CW4L-2E11QM4k CW4L-2E20QM4k CW4L-2E02QM4k CW4L-2E22QM4k (metallic bezel) Round Extended CW0L-02 (black bezel) (metallic bezel) 1. 2. 3. 4. 5. 6. 6 Specify an illumination color code in place of k in the Part Number Specify function code in place of  in the Part Number. M: momentary, A: maintained See page page 16 for dimensions. See next page for replacement LED modules. A dummy block is installed when one contact block is used. Additional contact configurations available, contact IDEC for more details. Illumination Color Code k A: amber G: green PW: white R: red S: blue Y: yellow A: amber G: green PW: white R: red S: blue Y: yellow Illuminated Pushbuttons Illuminated Pushbuttons (Sub-assembled) Contact Block LED Module Mounting Adaptor + + Operator + Contact Block Style Lens Completed Unit + = Operator Contact Contact Contacts Block Configuration Part Number 1NO YW-E10R 1NC YW-E01 2NO YW-EW2R0 2NC YW-EW02 1N0-1NC YW-EW1R1 Style Single Finger-safe Screw terminal Double Dummy block Black Bezel Metallic Bezel Momentary Round flush CW1B-M10 CW4B-M10 Round extended CW1B-M20 CW4B-M20 Round flush CW1B-A10 CW4B-A10 Round extended CW1B-A20 CW4B-A20 Maintained CW-DB Lens Style Part number LED Module Style Part Number CW-EAQ kj 1. In place of j, specify the Lens/LED Color Code from table. 2. In place of k, specify the Voltage Code from table. CW9Z-L11j Round extended CW9Z-L12j 1. In place of j, specify the Lens/LED Color Code from table. j Lens/LED Color Code Contact Block Mounting Adaptor Style Round flush Color Part Number CW-CN Code k Voltage Code Voltage Code Amber A 6V AC/DC 2 Green G 12V AC/DC 3 Red R 24V AC/DC 4 Blue S 100/120V AC H White* PW or C 230/240V AC M4 Yellow Y *Use PW for LED module, use C for lens.  800.262.4332 www.IDEC.com/switches 7 Non-illuminated Pushbuttons Non-illuminated Pushbuttons (Assembled) Shape Round Flush CW0B-01 (black bezel) Round Extended CW0B-02 (metallic bezel) Contact Configuration Black Bezel Metallic Bezel 1NO 1NC 1NO-1NC 2NO 2NC 2NO-1NC* 1NO-2NC* 3NO* 3NC* 2NO-2NC CW1B-1E10j CW1B-1E01j CW1B-1E11j CW1B-1E20j CW1B-1E02j CW1B-M1E21j CW1B-M1E12j CW1B-M1E30j CW1B-M1E03j CW1B-1E22j CW4B-1E10j CW4B-1E01j CW4B-1E11j CW4B-1E20j CW4B-1E02j CW4B-M1E21j CW4B-M1E12j CW4B-M1E30j CW4B-M1E03j CW4B-1E22j 1NO 1NC 1NO-1NC 2NO 2NC 2NO-1NC* 1NO-2NC* 3NO* 3NC* 2NO-2NC CW1B-2E10j CW1B-2E01j CW1B-2E11j CW1B-2E20j CW1B-2E02j CW1B-M2E21j CW1B-M2E12j CW1B-M2E30j CW1B-M2E03j CW1B-2E22j CW4B-2E10j CW4B-2E01j CW4B-2E11j CW4B-2E20j CW4B-2E02j CW4B-M2E21j CW4B-M2E12j CW4B-M2E30j CW4B-M2E03j CW4B-2E22j Button Color Code j B: black G: green R: red S: blue W: white Y: yellow 1. Specify a button color code in place of j in the part number. 2. Specify function code in place of  in the Part Number. M: momentary, A: maintained 3. See page page 17 for dimensions. 4. Two or one dummy block is installed when one or two contact blocks are used, respectively. 5. *These contact configurations are not available in maintained action. 6. Additional contact configurations available; contact IDEC for more details. Non-illuminated Pushbuttons (Sub-assembled) + Style Part Number YW-E10R Single Finger-safe Screw terminal Double Dummy block 8 1NC YW-E01 2NO YW-EW2R0 2NC YW-EW02 1N0-1NC YW-EW1R1 CW-DB CW-CN j Button Color Code Color Code Black B Green G Red R Blue S White W Yellow Y Operator* Black Bezel Style Metallic Bezel Round flush Part Number Momentary 1NO www.IDEC.com/switches CW1B-M1j CW4B-M1j Round extended Contact Block Mounting Adaptor Contact Contact Contacts Block Configuration  800.262.4332 = Contact Block Style Completed Unit CW1B-M2j CW4B-M2j Round flush + Operator* Maintained Mounting Adaptor CW1B-A1j CW4B-A1j Round extended Contact Block CW1B-A2j CW4B-A2j 1. Specify a button color code in place of j. 2. *Operator button is not removable from operator. Pilot Lights Pilot Lights (Assembled) Shape Operating Voltage Black Bezel Metallic Bezel 6V AC/DC CW1P-1EQ2k CW4P-1EQ2k 12V AC/DC CW1P-1EQ3k CW4P-1EQ3k 24V AC/DC CW1P-1EQ4k CW4P-1EQ4k 100/120V AC CW1P-1EQHk CW4P-1EQHk 230/240V AC CW1P-1EQM4k CW4P-1EQM4k 6V AC/DC CW1P-2EQ2k CW4P-2EQ2k 12V AC/DC CW1P-2EQ3k CW4P-2EQ3k 24V AC/DC CW1P-2EQ4k CW4P-2EQ4k 100/120V AC CW1P-2EQHk CW4P-2EQHk 230/240V AC CW1P-2EQM4k CW4P-2EQM4k Round Flush Lens CW0P-1 (black bezel) Round Dome Lens CW0P-2 (metallic bezel) Illumination Color Code k A: amber G: green R: red S: blue PW: white Y: yellow 1. Specify an illumination color code in place of k in the Part Number 2. See page page 17 for dimensions. 3. See page page 21 for replacement LED modules. 4. Two dummy blocks are installed. Pilot Lights (Sub-assembled) Contact Block* LED Module + Mounting Adaptor + Operator + Lens Completed Unit + = *2 dummy blocks are required for each completed pilot light. Contact Block Style Dummy block Contact Block Mounting Adaptor Part Number Style CW-DB Lens Part Number Style CW-CN Part Number Round flush CW9Z-L11j Round dome CW9Z-L15j 1. In place of j, specify the Lens/LED Color Code from table. Operator LED Module Style Part Number Style Black Bezel Metallic Bezel CW-EAQ kj CW1P-00 1. In place of j, specify the Lens/LED Color Code from table. 2. In place of k, specify the Voltage Code from table. CW4P-00 j Lens/LED Color Code Color k Voltage Code Voltage Code Code 6V AC/DC 2 Amber A 12V AC/DC 3 Green G 24V AC/DC 4 Red R 100/120V AC H S 230/240V AC M4 Blue White* PW or C Yellow Y * Use PW for LED module, use C for lens. 9 Selector Switches Selector Switches (Assembled) CW0S (Knob Operator) Shape (metallic bezel) (black bezel) No. of Positions Contact Configuration (Code) 1NO (10) 1NC (01) 1NO-1NC (11) 2NO (20) 2NC (02) 2NO-1NC (21) 90° 2-position 1NO-2NC (12) 3NO (30) 3NC (03) Contact Block Mounting Position 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2NO-2NC (22) 2 3 1 4NO (40) 2 3 Contact NO — — — — NC NO — NC NO — NO NC — NC NO NO NC NO NC NC NO NO NO NC NC NC NO/ NO NC NC — NO/ NO NC NC NO 2NO NO — NO 2NO NO Operator Position L R L L R R Maintained Spring return from right Dummy Dummy Dummy Dummy CW0S-2E10 CW0S-21E10 CW0S-2E01 CW0S-21E01 Dummy CW0S-2E11 CW0S-21E11 Dummy CW0S-2E20 CW0S-21E20 Dummy CW0S-2E02 CW0S-21E02 CW0S-2E21 CW0S-21E21 CW0S-2E12 CW0S-21E12 CW0S-2E30 CW0S-21E30 CW0S-2E03 CW0S-21E03 Dummy CW0S-2E22 CW0S-21E22 Dummy CW0S-21E40 CW0S-21E40  800.262.4332 1. Specify a bezel color code in place of 0 in the part number: 1 (black bezel), 4 (metallic bezel). 2. Lever operator is also available. For dimensions, see page page 18. 3. To order a lever operator selector switch, insert L before E in the knob operator part number. Example: Knob Operator part number CW1S-2E10 becomes CW1S-2LE10 for Lever Operator. Lever Operator www.IDEC.com/switches Contact Block Mounting Position 1 2 3 Left L 1 2 3 CW1S-0L (black bezel) 10 CW4S-0L (metallic bezel) NO NC NC Center C Right R Operator Position Selector Switches No. of Positions Contact Configuration (Code) 1NO-1NC (11) 1NO-1NC (11N1) 1NO-1NC (11N2) 1NO-1NC (11N3) 1NO-1NC (11N4) 2NO (20) 2NO (20N1) 2NC (02) 2NC (02N1) 45° 3-position 2NO-1NC (21) 2NO-1NC (21N1) 1NO-2NC (12) 1NO-2NC (12N1) 3NO (30) 3NC (03) Mounting Position 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2NO-2NC (22) 2 3 1 4NO (40) 2 3 1 2NO-2NC (22N2) Operator Position Contact Block 2 3 Type NO — NC NC — NO NO NC — — NC NO — NO NC NO — NO — NO NO NC — NC — NC NC NO NO NC NO NC NO NO NC NC NC NO NC NO NO NO NC NC NC NO/ NO NC NC — NO/ NO NC NC NO 2NO NO — NO 2NO NO NC 2NC NC — NC 2NO NC L L C R L C R L C R L C R Maintained Spring return from right Spring return from left Spring return two-way Dummy CW0S-3E11 CW0S-31E11 CW0S-32E11 CW0S-33E11 Dummy CW0S-3E11N1 CW0S-31E11N1 CW0S-32E11N1 CW0S-33E11N1 CW0S-3E11N2 CW0S-31E11N2 CW0S-32E11N2 CW0S-33E11N2 CW0S-3E11N3 CW0S-31E11N3 CW0S-32E11N3 CW0S-33E11N3 CW0S-3E11N4 CW0S-31E11N4 CW0S-32E11N4 CW0S-33E11N4 CW0S-3E20 CW0S-31E20 CW0S-32E20 CW0S-33E20 CW0S-3E20N1 CW0S-31E20N1 CW0S-32E20N1 CW0S-33E20N1 CW0S-3E02 CW0S-31E02 CW0S-32E02 CW0S-33E02 CW0S-3E02N1 CW0S-31E02N1 CW0S-32E02N1 CW0S-33E02N1 CW0S-3E21 CW0S-31E21 CW0S-32E21 CW0S-33E21 CW0S-3E21N1 CW0S-31E21N1 CW0S-32E21N1 CW0S-33E21N1 CW0S-3E12 CW0S-31E12 CW0S-32E12 CW0S-33E12 CW0S-3E12N1 CW0S-31E12N1 CW0S-32E12N1 CW0S-33E12N1 CW0S-3E30 CW0S-31E30 CW0S-32E30 CW0S-33E30 CW0S-3E03 CW0S-31E03 CW0S-32E03 CW0S-33E03 Dummy CW0S-3E22 CW0S-31E22 CW0S-32E22 CW0S-33E22 Dummy CW0S-3E40 CW0S-31E40 CW0S-32E40 CW0S-33E40 Dummy CW0S-3E22N2 CW0S-31E22N2 CW0S-32E22N2 CW0S-33E22N2 C R Dummy Dummy Dummy Dummy Dummy Dummy Dummy 1. Specify a bezel color code in place of 0 in the Part Number, 1 (black bezel), 4 (metallic bezel) 2. For the contact block mounting position, see page 10. 3. Lever operator is also available. For dimensions, see page page 18. 4. To order a lever operator selector switch, insert L before E in the knob operator part number. Example: Knob Operator part number CW1S-3E11 becomes CW1S-3LE11 for Lever Operator. 11 Selector Switches Selector Switches (Sub-assembled) Contact Block Mounting Adaptor + Operator + Completed Unit = Contact Block Style Contacts Contact Contact Block Configuration Part Number 1NO YW-E10R 1NC YW-E01 2NO YW-EW2R0 2NC YW-EW02 800.262.4332 1N0-1NC YW-EW1R1 www.IDEC.com/switches Single Finger-safe Screw terminal Double Dummy block  CW-DB Contact Block Mounting Adaptor Style Part Number CW-CN Operator Style Position Handle Knob 2 position Lever Knob 3 position (knob operator shown) Lever Lever or knob is supplied with operator 12 Black Bezel Metallic Bezel Maintained Description CW1S-2 CW4S-2 Spring return from right CW1S-21 CW4S-21 Maintained CW1S-2L CW4S-2L Spring return from right CW1S-21L CW4S-21L Maintained CW1S-3 CW4S-3 Spring return from right CW1S-31 CW4S-31 Spring return from left CW1S-32 CW4S-32 Spring return two-way CW1S-33 CW4S-33 Maintained CW1S-3L CW4S-3L Spring return from right CW1S-31L CW4S-31L Spring return from left CW1S-32L CW4S-32L Spring return two-way CW1S-33L CW4S-33L Key Selector Switches Key Selector Switches (Assembled) CW0K Shape (metallic bezel) (black bezel) No. of Positions Contact Configuration 1NO (10) 1NC (01) 1NO-1NC (11) 2NO (20) 2NC (02) 2NO-1NC (21) 90° 2-position 1NO-2NC (12) 3NO (30) 3NC (03) Contact Block Mounting Position 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2NO-2NC (22) 2 3 1 4NO (40) 2 3 Type Operator Position 1. Specify a bezel color code in place of 0 in the Part Number: 1 (black bezel), 4 (metallic bezel). 2. On the spring-returned models, the key can be released only from the maintained position. On the maintained models, the key can be released from any position. Key retained positions are also available. See below. 3. Two keys are supplied. 4. Key cylinder material: Metal Example: CW1K-2AE10-1H Key removal position code 2-position A: Removable in all positions B: Removable in left only C: Removable in right only R L R Maintained Spring return from right Dummy Dummy Dummy Dummy CW0K-2AE10 CW0K-21BE10 CW0K-2AE01 CW0K-21BE01 Dummy CW0K-2AE11 CW0K-21BE11 Dummy CW0K-2AE20 CW0K-21BE20 Dummy CW0K-2AE02 CW0K-21BE02 CW0K-2AE21 CW0K-21BE21 CW0K-2AE12 CW0K-21BE12 CW0K-2AE30 CW0K-21BE30 CW0K-2AE03 CW0K-21BE03 Dummy CW0K-2AE22 CW0K-21BE22 Dummy CW0K-2AE40 CW0K-21BE40 L NO — — — — NC NO — NC NO — NO NC — NC NO NO NC NO NC NC NO NO NO NC NC NC NO NO/NC NC — NO NO/NC NC NO 2NO NO — NO 2NO NO L R 5. Besides the standard key (key number 0H), six other keys are also available. See below. 6. For the contact block mounting position, see page 14. 7. For dimensions, see page page 19. 8. When ordering an optional key or optional key retained positions, specify designation codes as shown below: 3-position A: Removable in all positions B: Removable in left and center C: Removable in right and center D: Removable in center only E: Removable in right and left G: Removable in left only H: Removable in right only blank): Standard key (0H, reversible) 1H to 2H: Reversible key 3H to 6H: Non-reversible keyy Note: Key number is indicated on the key cylinder. Standard keys do not have a key number indication. 13 Key Selector Switches No. of Positions Contact Block Contact Configuration Mounting Type Position 1NO-1NC (11) 1NO-1NC (11N1) 1NO-1NC (11N2) 1NO-1NC (11N3) 1NO-1NC (11N4) 2NO (20) 2NO (20N1) 45° 3-position 2NC (02) 2NC (02N1) 2NO-1NC (21) 2NO-1NC (21N1) 1NO-2NC (12) 1NO-2NC (12N1) 3NO (30) 3NC (03) 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2NO-2NC (22) 2 3 1 4NO (40) 2 3 1 2NO-2NC (22N2) 2 3 14 NO — NC NC — NO NO NC — — NC NO — NO NC NO — NO — NO NO NC — NC — NC NC NO NO NC NO NC NO NO NC NC NC NO NC NO NO NO NC NC NC NO/ NO NC NC — NO/ NO NC NC NO 2NO NO — NO 2NO NO NC 2NC NC — NC 2NC NC Operator Position L L C R L C R L C R L C R Maintained Spring return from right Spring return from left Spring return two-way Dummy CW0K-3AE11 CW0K-31BE11 CW0K-32CE11 CW0K-33DE11 Dummy CW0K-3AE11N1 CW0K-31BE11N1 CW0K-32CE11N1 CW0K-33DE11N1 CW0K-3AE11N2 CW0K-31BE11N2 CW0K-32CE11N2 CW0K-33DE11N2 CW0K-3AE11N3 CW0K-31BE11N3 CW0K-32CE11N3 CW0K-33DE11N3 CW0K-3AE11N4 CW0K-31BE11N4 CW0K-32CE11N4 CW0K-33DE11N4 CW0K-3AE20 CW0K-31BE20 CW0K-32CE20 CW0K-3AE20N1 CW0K-31BE20N1 CW0K-32CE20N1 CW0K-3AE02 CW0K-31BE02 CW0K-32CE02 C R Dummy Dummy Dummy Dummy Mounting Position 1 2 3 CW0K-33DE20 Dummy Left Dummy Operator Position 1 NO 2 NC 3 NC Dummy CW0K-3AE02N1 CW0K-31BE02N1 CW0K-32CE02N1 CW0K-3AE21 CW0K-31BE21 CW0K-32CE21 CW0K-3AE21N1 CW0K-31BE21N1 CW0K-32CE21N1 CW0K-3AE12 CW0K-31BE12 CW0K-32CE12 CW0K-3AE12N1 CW0K-31BE12N1 CW0K-3AE30 CW0K-31BE30 CW0K-32CE30 CW0K-33DE30 CW0K-3AE03 CW0K-31BE03 CW0K-32CE03 CW0K-33DE03 Dummy CW0K-3AE22 CW0K-31BE22 CW0K-32CE22 CW0K-33DE22 Dummy CW0K-3AE40 CW0K-31BE40 CW0K-32CE40 CW0K-33DE40 Dummy CW0K-3AE22N2 CW0K-31BE22N2 CW0K-32CE12N1 CW0K-33DE12N1 CW0K-32CE22N2 CW0K-33DE22N2 Center L C Right R 1. Specify a bezel color code in place of 0 in the Type No.: 1 (black bezel), 4 (metallic bezel) 2. On the spring-returned types, the key can be released only from the maintained position. On the maintained types, the key can be released from every position. Key retained positions are also available. See page 13. 3. Two keys are supplied. 4. Key cylinder material: Metal 5. Besides the standard key (key number 0H), six other keys are also available. See page 13. 6. For the contact block mounting position, see above 7. For dimensions, see page 19. Key Selector Switches Key Selector Switches (Sub-assembled) Contact Block Mounting Adaptor + Operator + Completed Unit = Contact Block Style Contacts Contact Block Mounting Adaptor Contact Contact Block Configuration Part Number 1NO YW-E10R 1NC YW-E01 2NO YW-EW2R0 2NC YW-EW02 1N0-1NC YW-EW1R1 Style Part Number Single Finger-safe Screw terminal Double Dummy block CW-CN CW-DB Operator Style Position Description Black Bezel Metallic Bezel Maintained, key removable all positions CW1K-2A CW4K-2A Maintained, key removed left only CW1K-2B CW4K-2B Maintained, key removed right only CW1K-2C CW4K-2C Spring return from right CW1K-21B CW4K-21B Maintained, key removable all positions CW1K-3A CW1K-3A Maintained, key removed left and center only CW1K-3B CW4K-3B 2 position 3 position 2 keys supplied with operator. Maintained, key removed right and center only CW1K-3C CW4K-3C Maintained, key removed center only CW1K-3D CW4K-3D Maintained, key removed left and right only CW1K-3E CW4K-3E Maintained, key removed left only CW1K-3G CW4K-3G Maintained, key removed right only CW1K-3H CW4K-3H Spring return from right, key removed left and center only CW1K-31B CW4K-31B Spring return from right, key removed center only CW1K-31D CW4K-31D Spring return from right, key removed left only CW1K-31G CW4K-31G Spring return from left, key removed right and center only CW1K-32C CW4K-32C Spring return from left, key removed center only CW1K-32D CW4K-32D Spring return from left, key removed right only CW1K-32H CW4K-32H Spring return two-way, key removed center only CW1K-33D CW4K-33D  800.262.4332 www.IDEC.com/switches 15 Dimensions (mm) Illuminated Pushbuttons 1 to 2 Contacts Round Flush Round Extended M3.5 Terminal Screw Contact Block 10 LO 28.5 CK ø28 41.4 ø19.5 28.5 CK (Lens Diameter) LO ø28 ø19.5 (Lens Diameter) 10 10 10 41.4 1 M3.5 0.5 Terminal Screw LED Module Locking Ring Gasket 0.5 Locking Ring Gasket 2 M3.5 Terminal Screw LED Module Panel Thickness 0.8 to 3.2 3 10 Panel Thickness 0.8 to 3.2 10 M3.5 Terminal Screw Contact Block 2.5 Momentary: 39.9 Maintained: 44.6 2.5 Momentary: 39.9 Maintained: 44.6 30 30 5.2 4 Contacts Round Flush Round Extended M3.5 Terminal Screw Contact Block M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 2nd-tier 1st-tier contact block (NC) contact block (NO) LO Locking Ring Gasket ø19.5 CK 28.5 28.5 CK ø28 LO ø28 (Lens Diameter) 41.4 ø19.5 Locking Ring Gasket 0.5 (Lens Diameter) 0.5 41.4 2nd-tier 1st-tier contact block (NC) contact block (NO) 2.5 Momentary: 59.9 Maintained: 64.6 2.5 Momentary: 59.9 Maintained: 64.6 30  800.262.4332 www.IDEC.com/switches 16 5.2 30 Dimensions (mm) Pushbuttons 1 to 2 Contacts Round Flush Round Extended M3.5 Terminal Screw Contact Block M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 LO Momentary ø19.5 41.4 Maintained LO Locking Ring Gasket LO CK CK 28.5 28.5 CK 28.5 28.5 CK ø28 ø19.5 (Button Diameter) 41.4 0.5 Maintained LO ø28 Momentary (Button Diameter) 0.5 Locking Ring Gasket 2.5 2.5 Momentary: 39.9 Maintained: 44.6 30 Momentary: 39.9 Maintained: 44.6 30 5.2 30 30 4 Contacts Round Flush Round Extended M3.5 Terminal Screw Contact Block M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 ø19.5 41.4 30 30 Momentary: 59.9 Maintained: 64.6 Maintained LO LO CK CK 28.5 28.5 CK 28.5 28.5 2.5 Momentary Locking Ring Gasket LO CK ø28 ø19.5 (Button Diameter) 41.4 Momentary: 59.9 Maintained: 64.6 Maintained LO 0.5 ø28 Momentary Locking Ring Gasket 2nd-tier 1st-tier contact block (NC) contact block (NO) (Button Diameter) 0.5 2nd-tier 1st-tier contact block (NC) contact block (NO) 2.5 5.2 30 30 Pilot Lights Round Flush Round Dome Panel Thickness 0.8 to 3.2 LOC Locking Ring Gasket 41.4 ø19.5 28.5 ø28 ø19.5 (Lens Diameter) K K 28.5 LOC Locking Ring Gasket 0.5 ø28 M3.5 Terminal Screw LED Module 0.5 41.4 M3.5 Terminal Screw LED Module (Lens Diameter) 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 2.5 39.9 2.5 30 39.9 4.1 30 17 Dimensions (mm) Selector Switches 1 to 3 Contacts Knob Operator Lever Operator M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 M3.5 Terminal Screw Contact Block 0.5 0.5 Operator Angle Operator Angle 45º LOC 45 º LOC K 45 º ø28 41.4 ø28 41.4 2.5 39.9 45º Locking Ring Gasket 28.5 K 28.5 Locking Ring Gasket 2.5 13.1 39.9 30 30 4 Contacts Knob Operator Lever Operator M3.5 Terminal Screw Contact Block M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 2nd-tier 1st-tier contact block (NC) contact block (NO) 0.5 2nd-tier 1st-tier contact block (NC) contact block (NO) 0.5 Operator Angle Operator Angle LOC K 45 º 18 K ø28 41.4 28.5 ø28 41.4 59.9 LOC 2.5 2.5 13.1 45º Locking Ring Gasket 28.5 45º Locking Ring Gasket 30 59.9 17.1 30 45 º Dimensions (mm) Key Selector Switches Keys 1 to 3 Contacts Reversible Key M3.5 Terminal Screw Contact Block 8.8 8.8 22 22 10 10 14 14 10 Panel Thickness 0.8 to 3.2 Logo Stamping Logo Stamping Key No. Key No. Operator Angle 0.5 LOC K 45 0 H 0 H 45º º Key No. Stamping Key No. Stamping ø28 41.4 28.5 Locking Ring Gasket Non-reversible Key 8.8 8.8 22 22 2.5 6.3 6.3 31.5 14 14 10.4 39.9 30 Logo Stamping Logo Stamping Key No. Key No. Key No: 0H to 2H (reversible key) 3 H 3 H Key No. Stamping Key No. Stamping 31.5 Key No: 3H to 6H (non-reversible key) 4 Contacts M3.5 Terminal Screw Contact Block 10 10 10 Panel Thickness 0.8 to 3.2 2nd-tier 1st-tier contact block (NC) contact block (NO) 0.5 Operator Angle 45º LOC K 45 º ø28 41.4 28.5 Locking Ring Gasket 2.5 10.4 59.9 31.5 30  800.262.4332 www.IDEC.com/switches 19 Acccessories/Parts Accessories Shape Material Part Number Package Quantity Locking Ring Wrench Brass MW9Z-T1 1 Polyamide (black) LW9Z-BP1 1 Remarks • Used to tighten the locking ring when installing the CW series control unit in a panel cut-out. 110 8 ø2 • Weight: Approx 150g Mounting Hole Plug • Used to plug an unnecessary ø22.3mm hole in the panel. • Degree of protection: IP65 • Panel thickness: 0.8 to 6.0 mm Replacement Parts Material Part Number Remarks 1 Round Flush Polyalylate CW9Z-L11k 2 Round Extended Polyalylate CW9Z-L12k 3 Round Dome Polyalylate CW9Z-L15k Color code k: A (amber), C (clear), G (green), R (red), S (blue), Y (yellow) Use a clear (C) lens for white (PW) illumination. 1: For illuminated pushbutton, pilot light 2: For illuminated pushbutton 3: For pilot light 1NO YW-E10R 1NC YW-E01 2NO YW-EW2R0 2NC YW-EW02 1NO, 1NC YW-EW1R1 Shape Lens 1 2 3 Single Contact Block Push rod Housing Double Contact Block Push rod Rubber Boot (clear) Housing Round Flush Push rod color: Black Housing color: Blue/black Terminal No.: 3-4 Push rod color: Red Housing color: Reddish purple Terminal No.: 1-2 Push rod color: black Housing color: blue and black Terminal No. 1st tier: 13-14, 2nd tier: 23-24 Push rod color: red Housing color: reddish purple Terminal No. 1st tier: 11-12, 2nd tier: 21-22 Push rod color: gray Housing color: reddish purple/blue Terminal No. 1st tier: 13-14, 2nd tier: 21-22 CW9Z-D11 CW9Z-D12 Round Extended Dummy Block Locking Ring Polyamide (black) CW-DB Polyamide (black) CW9Z-LN Nitrile rubber CW9Z-WM Plastic CWAM-OB Gasket Waterproof gasket between CW control unit bezel and the mounting panel. Nameplate Spare Key Non-reversible Zinc (nickel-plated) Reversible 20 LA9Z-SK-0 Specify a key No. in place of 0. 0H: Standard key (reversible) 1H to 2H: Reversible key 3H to 6H: Non-reversible key For dimensions, see page 17. Nameplates LED Modules Shape Operating Voltage Range Current Draw Part Number 6V AC/DC±10% 15 mA CW-EAQ2k 12V AC/DC±10% 15 mA CW-EAQ3k 24V AC/DC±10% 16.5 mA 100/120V AC±10% 18 mA 230/240V AC±10% 18 mA Illumination Color Code k Specify an illumination color code in place of k in the Part Number A: amber CW-EAQ4k G: green PW: white CW-EAQHk R: red CW-EAQM4k S: blue Use a white (PW) LED module for yellow (Y) illumination. Nameplate Standard Legend Codes Pushbuttons CWAM–Black Plastic Nameplate (blank insert CWAM-OB included) Nameplate CWAM-j (engraved) Additional Insert HWNP HWNP-O (blank) Dimensions 27 1. In place of j, insert either the standard legend code from table below or custom engraving delimited by “ “. 2. Standard engravings are available at no charge. Selector Switches Legend Code Legend Code Legend Code Legend Code Legend Code AUTO CLOSE DOWN EMERG.STOP FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 OPEN OUT RAISE RESET REVERSE RUN SLOW START STOP TEST UP I (Int’l On) O (Int’l Off) EMO 116 117 118 119 120 121 122 123 125 126 127 150 151 152 AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWER-RAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISE-LOWER 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN OI (Int’l OFF ON) 216 217 218 219 220 221 222 223 250 AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFF-WINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 12 Additional Insert HWNP-j (engraved) Pushbuttons/Selector Switches 1. To order engraved nameplates, add legend code to nameplate part number. 2. Character height based on the number of characters and size of nameplate. Standard character size is 3/16”. 3. Nameplates with standard legends are the same list price as blank nameplates. Nameplates Order Form — CW Series Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To ensure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: IDEC Rep/Distributor Contact: Name: PO number (if known): Telephone: IDEC Rep/Distributor Phone: Fax & Email: IDEC Rep/Distributor Fax & Email: CWAM Nameplate Engraving Location Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 9 characters. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 11 characters maximum (for 7/64” size letters) 1/8” Letter Size 9 characters maximum (for 7/8” size letters) Sample Letter Sizes 7/64” Letters: A B C D 1/8” Letters: A B C D Qty 1 2 3 4 5 6 7 8 9 10 11 21 Precautions & Instructions Safety Precautions Turn off the power to CW series switches before installation, removal, wiring and maintenance. Failure to turn power off may cause electrical shocks or fire hazard. When wiring, use wires of a proper size to meet the voltage and current requirements. Tighten the M3.5 terminal screws to a tightening torque of 1.0 to 1.3 N·m. Failure to tighten the terminal screws may cause overheating and fire. Operating Instructions Notes for Operation When using the CW series switches in a safety-related circuit of a control system, observe safety rules and regulations of each country concerning particular applications of the actual machines and facilities. Perform risk assessment before operation to ensure safety. Operating Conditions In corrosive gas or high-temperature, highhumidity environments, contact failure due to corrosion or color change or breakage of the housing may occur. Main parts of the CW series switches are made of plastic. Do not scratch the surface with a sharp object or apply excessive electric shock or load, otherwise the switches may be damaged. In particular, keep the button, lens and bezel from such damage, otherwise appearance and function may be impaired. Do not apply detergents, cutting oils, or chemicals which may impair the function and appearance of the CW series switches. Panel Mounting First remove the contact block and then the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block to the operator. Mounting Hole 1. Mounting hole dimensions are in compliance with IEC60947-5-1. 2. If the anti-rotation projection is removed from the bezel, CW series switches can be mounted in ø22.3mm mounting holes. To remove the anti-rotation projection, remove the gasket and use cutting pliers to break the projection. Removing and Installing the Contact Unit 1. To remove the contact block from the operator, push the yellow locking lever and turn it to the left. Locking Lever Illuminated Pushbuttons and Pilot Lights Removing the Lens To remove the lens from an illuminated pushbutton or pilot light, insert a flat screwdriver under the flange of the lens at 90° from the TOP marking and twist the screwdriver. Do not insert the screwdriver too far and do not apply excessive force to the lens, otherwise the bezel surface may be damaged. Screwdriver Insertion Direction 2. To install, align the TOP marking on the operator with the TOP marking on the contact block mounting adaptor, and turn the locking lever to the right. Installation in Panel Cut-out Remove the locking ring from the operator. With the anti-rotation projection on the operator aligned with the recess in the mounting hole, insert the operator into the mounting hole. Tighten the locking ring from the rear of the panel. Anti-rotation projection Recess in mounting hole TOP Marking TOP Marking Screwdriver Insertion Angle Approx. 30° Panel Panel Surface TOP marking on illuminated pushbuttons, pushbuttons and pilot lights Locking Ring Installing the Lens Turn the groove in the lens to the TOP marking on the operator housing. With the groove aligned with the ridge, press the lens in. TOP Marking Ridge TOP marking on selector and key selector switches Note for Panel Mounting When installing the operator in a panel cutout, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring to a recommended tightening torque of 1.2 N·m. Do not use pliers and do not tighten excessively, otherwise the operator may be damaged. Groove in the Lens Marking Marking film can be applied for inscriptions or identification. Applicable Marking Film Size Illuminated Pushbutton (Round Flush) Pilot Light (Round Flush, Round Extended) Illuminated Pushbutton (Round Extended) 13.8 9 5. ø1 12.6 9 5. ø1 Thickness: 0.2 mm maximum Film material: Polyester (recommended) Note: Film is not supplied and must be provided by the user. 22 Precautions & Instructions Operating Instructions con’t Pushbutton caps cannot be removed. Do not tamper with the cap using a screwdriver or pliers, otherwise it may be damaged. To remove the contact block from the operator, insert a flat screwdriver under the latch and push the screwdriver down as shown below. Before removing the LED module, first remove all contact blocks, and then remove the LED module in the same manner. Selector Switches Turn the selector operator or key to the detent positions. Key Selector Switches Applicable Crimping Terminals Spade terminal When using crimping terminals, be sure to use insulating tubes or insulated crimping terminals. 3.6 min. Contact Blocks and LED Modules 6.9 max. Pushbuttons 11.5 max. 8.1 max. Insulation Tube Crimping Terminal Wire To prevent malfunction and damage, take the following precautions. 0.5 min. Insulation 8.0 max. 8.0 max. One or two wires can be connected to the terminal. 1.7 max. Applicable Wires Stranded wire: 2.0 mm2 maximum (14AWG) Solid wire: ø1.6 mm maximum Ferrule When connecting two ferrules to one terminal, use ferrules without insulation. 1.7 max. Wiring ø1.6 max. • Completely insert the key before turning. • Do not remove the key while turning. • Besides the standard key (0H), six other keys are available. Use only a key with a number that matches the number on the switches’ key cylinder. (The standard key does not have a key number.) • Keys are available in two shapes. -0H (standard), 1H, 2H: reversible keys -3H, 4H, 5H, 6H: non-reversible keys Make sure of correct insertion direction. 8.0 max. When using spade terminals or ferrules, ensure that they are inserted completely. Ring terminals cannot be used. Screw Tightening Torque Tighten the M3.5 terminal screws to a recommended torque of 1.0 to 1.3 N·m.  800.262.4332 www.IDEC.com/switches 23 16mm LB Series Miniature Switches With a choice of metallic or black plastic bezels, and flush or standard mounting, our newest miniature flush mount switches add style and safety to any application. All LB switches are UL recognized, TUV approved, CSA certified and CE marked, as well as provide an IP65 degree of protection. Available in illuminated pushbuttons, pushbuttons, pilot lights, selector switches and key selector switches, these switches are perfect for use with instrumentation, communication equipment, computer peripheral, telecom, medical equipment, food and beverage processing equipment, semi-conductor equipment, non-industrial applications (train cab, parking machines, audio/visual equipment), panels and more! Think Automation and beyond...  800.262.4332 www.IDEC.com/switches www.IDEC.com USA Japan Germany China/Beijing China/Shenzhen IDEC Corporation Tel: (408) 747-0550 opencontact@IDEC.com IDEC Corporation Tel: +81-6-6398-2571 marketing@IDEC.co.jp IDEC Elektrotechnik GmbH Tel: +49-40-253054-0 service@IDEC.de IDEC (Beijing) Corporation Tel: +86-10-6581-6131 IDEC (Shenzhen) Corporation Tel: +86-755-8356-2977 China/Shanghai Singapore Canada United Kingdom Hong Kong IDEC Canada Ltd. Tel: (905) 890-8561 sales@ca.IDEC.com IDEC Electronics Ltd. Tel: +44-1256-321000 sales@uk.IDEC.com IDEC (H.K.) Co., Ltd. Tel: +852-2803-8989 info@hk.IDEC.com IDEC (Shanghai) Corporation Tel: +86-21-6135-1515 idec@cn.IDEC.com IDEC Asia Pte. Ltd. Tel: +65-6746-1155 info@sg.IDEC.com Australia IDEC Australia Pty. Ltd. Tel: +61-3-8523-5900 sales@au.IDEC.com ©2013 IDEC Corporation. All Rights Reserved. Catalog No. CW9Y-B100-1 09/11 (PDF updated 08/13) 7.5K Specifications and other descriptions in this catalog are subject to change without notice. Taiwan IDEC Taiwan Corporation Tel: +886-2-2698-3929 service@tw.IDEC.com
CW1K-31DE11N3 价格&库存
很抱歉,暂时无法提供与“CW1K-31DE11N3”相匹配的价格&库存,您可以联系我们找货
