FB1W-XW1E-BV413MRH-Y0
    IDEC(日本和泉)
    IDEC - FB1W-XW1E-BV413MRH-Y0 - Emergency Stop Switch, 3PST-NC, SPST-NO, Pushlock Turn Reset/Push-Pul...
FB1W-XW1E-BV413MRH-Y0 数据手册
Control Boxes FB Series Control Stations IP65 lightweight control stations. IDEC HW and XW series switches and pilot lights installed. APEM Switches & Pilot Lights Control Boxes Emergency Stop Switches Enabling Switches • ø22 mm switches/pilot lights can be installed. • Blank front enclosures, without mounting holes, are also avail­able. • Blank front enclosures can also be used as junction boxes to mount terminal blocks. • Yellow cover enclosures for emergency stop switches are also available. • Front panel mounting, rear panel mounting, hook mounting, and frame mounting options are available. Safety Products Explosion Proof Terminal Blocks Relays & Sockets • Contact cover box (Part no.: FB1WBR) is not UL or c-UL listed. • Enclosures without mounting hole is not UL or c-UL listed. (Enclosures less than 1,639 cm3 is not approved by UL50, 2:8.) • See website for details on approvals and standards. Circuit Protectors Power Supplies LED Illumination Controllers Operator Interfaces Sensors Enclosures Size  76mm 140mm AUTO-ID 200mm FB Package Quantity: 1 No. of Mounting Holes Mounting Hole Description 0 1 1 0 2 3 0 3 4 5 Without mounting hole ø22mm ø22mm Without mounting hole ø22mm, mounting centers 50mm ø22mm, mounting centers 30mm Without mounting hole ø22mm, mounting centers 50mm ø22mm, mounting centers 36mm ø22mm, mounting centers 30mm Cover Color (*1) Light beige Yellow Light beige Light beige Light beige Light beige Light beige Light beige Light beige Light beige Part No. FB1T-000Z FB1W-111Y FB1W-111Z FB2T-000Z FB2W-211Z FB2W-312Z FB3T-000Z FB3W-311Z FB3W-413Z FB3W-512Z *1) Light beige (Munsell 5Y7/1 or equivalent), Yellow (Munsell 2.5Y8/10 or equivalent), Enclosure base color: Black (Munsell N1.5 or equivalent) Contact Cover Box Size 76mm Material Box cover / box base: polycarbonate (*5) Box cover mounting screw: stainless Applicable Switches/ Pilot Lights IDEC’s HW/TW/XW series and accessories (*3) (*4) Weight (approx.)   76 mm: 125g (FB1W-111Y) 140 mm: 184g (FB2W-211Z) 200 mm: 243g (FB3W-311Z) *2) The above specifications are for enclosures. For switches/pilot lights, refer to the specifications of each unit. *3) Choose switches/pilot lights and accessories which match the mounting hole centers, effective depth behind the cover, and the thickness of the cover where switches/pilot lights are installed (3 mm). Note that enclosures with 30 mm or 36 mm mounting hole centers may limit the knob orien­tation of selector switches, because the contact blocks can be mounted in one direction only on these mounting centers. *4) An XW series emergency stop switch of screw terminal model can be installed on an enclosure with one mounting hole or mounting holes of 50 mm mounting centers, by connecting one clamping terminal to one terminal pole. *5) Flame-resistant (UL94V-0). C-007 Light beige Part No. FB1WR-111Z Accessories Description Part No. Ordering No. Package Quantity Mounting Bracket FB9Z-PK1 FB9Z-PK1 DIN Rail Adapter FB9Z-PK3 FB9Z-PK3PN02 2 Mounting Hole Plug LW9Z-BP1 LW9Z-BP1 1 1 • Connectors and nuts are supplied by users. ø21.3 Knockout 76 Cover Mounting Screws (Stainless Steel) Switches 76, 140, or 200 Electric Shock Protection Class II (when class II switches/pilot lights are installed) Cover Color • For operating instructions, see C-019. Specifications (*2) IEC/EN60529 UL508 Applicable Standards UL50 CSA C22.2 No. 14 CSA C22.2 No. 94 Ambient temperature: –25 to +60°C (no freezing) Standard Relative humidity: 45 to 85%RH (no condensation) Operating Storage temperature: –40 to +80°C (no freezing) Conditions Degree of pollution: 3 IP65 (when IP65 switches/pilot lights are installed) Degree of NEMA Type 4X Indoor Use Only Protection (when Type 4X switches/pilot lights are installed) Package Quantity: 1 No. of Mounting Holes Mounting Hole Description 1 ø22 mm hole in the base Nameplate Marking Plate (Optional) 59.5 ø21.3 Knockout For Formore moreinformation, information,visit visithttp://asia.idec.com http://eu.idec.com FB Series Control Stations All dimensions in mm. 76 mm (FB1) ø66 (Marking Plate Area) Cover Mounting Screws 2-Front Mounting Holes Cover 4-M4 Tapping Screw Holes for Rear Mounting (Depth: 10mm) 140/200 mm (FB2/FB3) 4-M4 Tapping Holes for Rear Mounting (Depth: 10 mm) 2-Front Mounting Holes Cover 2-ø14 Knockout ø14 Knockout 21 Cover Mounting Screws Control Boxes Dimensions 4R2 APEM 21 41 .2 L A B C Switches & Pilot Lights 2- ø4 Base c 76 59.5 Control Boxes .6 15.5 Emergency Stop Switches Enabling Switches 62 Contact Cover (FB1WR-111Z) 2-ø21.3 Knockout Base ø22.3 Safety Products 31 62 59.5 Explosion Proof 18 76 2-ø21.3 Knockout Base 18 * Dimensions are the same as standard. FB2 FB3 L 140 200 A  84 144 B 104 164 C 106 166 Terminal Blocks Relays & Sockets Circuit Protectors Power Supplies FB Series Control Stations FB Series Control Stations With ø22 mm XW Series EMO Switches With ø22 mm XW Series EMO Switches + SEMI Switch Guard (HW9Z-KG3) 21 18 18 59.5 21 21 41 41 18 (6) (6) 150 130 (37.5) 46 50.5 5.5 Internal Projection (Height: 1.8mm, diameter: ø1.8mm) M3 Tapping Holes for Rear Mounting (Depth: 7mm) (118.5) 92 70 (56) (6) 10 3 2 Switch Mounting Area Thickness 45 (60) 64 45 (60) 64 Choose an enclosure in consideration of switch’s depth behind the panel and the mounting centers of the adjacent switches. 18 62 (6) 45 27 55 21 21 21 21 41 41 15.5 (5.5) 35 59.5 59.5 Box Base 45 (60) 64 21 41 15.5 15.5 62 62 35 35 21 ø14 Knockout .6 Box Cover 2-ø21.3 Knockout Internal Dimensions 2-Front Mounting Holes ø4 Box BoxBase Base 2-ø21.3 Knockout 2- Box BoxCover Cover 2-ø21.3 2-ø21.3Knockout Knockout 18 18 76 76 35 35 21 41 59.5 35 59.5 32.2 59.5 59.5 18 18 59.5 18 90 90 76 76 ø14 ø14Knockout Knockout 4-M4 tapping holes fo rear mounting (Depth: 10mm) 62 Box Cover Box Base 4..66 -øø4 22- 90 76 2-Front 2-FrontMounting MountingHoles Holes .6 4-M4 4-M4tapping tappingholes holesfoforear rearmounting mounting (Depth: (Depth:10mm) 10mm) 15.5 BoxBase Base Box .6 EMO Switch Guard (HW9Z-KG4) FB ø4 ø4 2-ø21.3 Knockout Box Base Cover Mounting Screws 15.5 15.5 62 62 2- 2- 2-ø21.3Knockout Knockout 2-ø21.3 Box Cover EMO EMOSwitch Switch With ø22 mm XW Series EMO Switches + Cover Cover Mounting Screws MountingGuard Screws(HW9Z-KG4) Guard Guard(HW9Z-KG4) (HW9Z-KG4) SEMI Switch ø14 Knockout BoxCover Cover Box 15.5 62 Box BoxBase Base FB Series Control Stations AUTO-ID 2-Front Mounting Holes Guard (HW9Z-KG3) Box BoxCover Cover 2-ø21.3 2-ø21.3Knockout Knockout 59.5 EMO Switch .6 ø44.6 22--ø .6 ø44.6 22--ø 15.5 15.5 62 62 Sensors ø14Knockout Knockout ø14 4-M4 tapping holes fo rear mounting (Depth: 10mm) 76 21 21 41 41 21 21 ø14 Knockout Guard Guard(HW9Z-KG3) (HW9Z-KG3) Cover Mounting Screws Operator Interfaces 2-FrontMounting MountingHoles Holes 2-Front 21 41 Cover Cover MountingScrews Screws Mounting ø14 ø14Knockout Knockout 4-M4 tapping holes fo rear mounting (Depth: 10mm) 2-Front Mounting Holes EMO Switch EMOSwitch Switch EMO (6) (6) EMO EMOSwitch Switch 21 Cover Mounting Screws 32.2 32.2 76 76 76 Cover Cover Mounting MountingScrews Screws 2-Front 2-FrontMounting MountingHoles Holes Controllers 4-M4 4-M4tapping tappingholes holesfoforear rearmounting mounting (Depth:10mm) 10mm) (Depth: 21 21 4-M4 4-M4tapping tappingholes holesfoforear rearmounting mounting (Depth: (Depth:10mm) 10mm) LED Illumination Download Downloadcatalogs catalogsand andCAD CADfrom fromhttp://asia.idec.com/downloads http://eu.idec.com/downloads C-008 FB Series Control Stations APEM Applicable Accessories Series Safety Products Explosion Proof Terminal Blocks HW Series Circuit Protectors Power Supplies LED Illumination Controllers Operator Interfaces Sensors AUTO-ID Model 200mm 140/200mm 50 mm mounting centers 36/50 mm mounting centers 30 mm mounting centers XW Series Emergency Stop Switches 3.2 3.2 3 3 2. 2. ø2 ø2 13 13 13 13 Applicable DIN Rail Description Nameplate: HWAM, HWAQ, HWAS, HWAV- Marking plate for nameplate: HWNP- Anti-rotation ring: HW9Z-RL EMO switch guard: HW9Z-KG3, HW9Z-KG4 Switch guard: HW9Z-K1, HW9Z-K11 Pushbutton clear boot: OC-31, OC-32 Padlock cover: HW9Z-KL1 Nameplate: HWAV- EMO switch guard: HW9Z-KG3, HW9Z-KG4 Anti-rotation ring: HW9Z-RL Nameplate: NWA-, NWAQ-, NWAS-0, NWAL-0, NWAQL-0, NWAV- FB TW Series Anti-rotation ring: OGL-31 Metal protector: OLW-C Pushbutton clear boot: OC-31, OC-32 Button cover: OCW-10✽, OCW-11✽ Padlock cover: HW9Z-KL1, HS9Z-PC22 Description DIN Rail End Clip Material Part No. Ordering No. Aluminum BAA1000 BAA1000PN10 Steel BAP1000 BAP1000PN10 Steel BNL6 BNL6PN10 Note: Use DIN rail adapters FB9Z-PK3 when installing a DIN in the control box. See H-071 for DIN rail products. Applicable Terminal Block / Transformer Series / Part No. Terminal Block BN-W / BNH-W / BN1U BN10W, BN15MW, BN15LW, BN30W BNH10W, BNH15MW, BNH15LW, BNH30W BN1U-16W, BN1U-20W, BN1U-40W BA BA111T, BA211T, BA311T Separate Mounting Transformer TWR5∗∗ Note: Install the terminal blocks and separate mounting transformers on a DIN rail using two DIN rail adapters (FB9Z-PK3). Choose the types and quantity of terminal blocks, transformers, end clips, and enclo­sures carefully taking the specifications into consideration. The sepa­rate mounting transformer can be installed on a DIN rail adapter directly. Note: Confirm the specifications of boxes, switches/pilot lights, and accessories before choosing accessories, referring to separate catalogs. C-009 3.2 3.2 3.23.2 Note: For contact cover boxes, see C-019. Control Boxes Relays & Sockets 140mm 3 3 2. 2. ø2 ø2 Switches & Pilot Lights Emergency Stop Switches Enabling Switches 76mm 13 13 30 30 30 30 36 36 36 50 50 50 30 30 Model Mounting Hole Dimensions 200mm 2 mounting holes 3 mounting holes 3 mounting holes 4 mounting holes 5 mounting holes Shape 76mm 140mm Shape Control Boxes Switch/Pilot Light Mounting Hole Centers For Formore moreinformation, information,visit visithttp://asia.idec.com http://eu.idec.com FB Series Control Stations Control Boxes Control Stations Symbols of Switches Legend / Guard Symbols ES Item Emergency Stop Switches E-STOP Nameplate PB PL Nameplate Part No. Legend / Guard Pushbuttons Pilot Lights Nameplate Selector Switches SS Key Selector Switches Guard HWAM Guard / Marking Plate Part No. − HWAV-0 − EMERGENCY-STOP HWAV-27 − APEM ON HWAM HWNP-1 OFF HWAM HWNP-2 Switches & Pilot Lights START HWAM HWNP-3 Control Boxes STOP HWAM HWNP-4 OFF-ON HWAM HWNP-31 HAND-AUTO HWAM HWNP-35 Emergency Stop Switches Enabling Switches HAND-OFF-AUTO HWAM HWNP-53 Safety Products HW9Z-KG4 − HW9Z-KG4 HW9Z-KG3 − HW9Z-KG3 Explosion Proof Terminal Blocks Relays & Sockets 1 Hole (Box Size: 76mm) Symbols Specification Legend Switch Part No. XW Series Emergency Stop Switches (Non-illuminated, pushlock pull or turn reset) XW Series Emergency Stop Switches (Push-ON LED, LED/24V,pushlock pull or turn reset) Part No. (Ordering Part No.) Circuit Protectors With nameplate "EMERGENCY STOP" Color (∗) Part No. (Ordering Part No.) Color (∗) Power Supplies LED Illumination 1NC FB1W-XW1E-BV401MRH-Y0 FB1W-XW1E-BV401MRH-Y1 2NC FB1W-XW1E-BV402MRH-Y0 FB1W-XW1E-BV402MRH-Y1 Operator Interfaces 3NC FB1W-XW1E-BV403MRH-Y0 FB1W-XW1E-BV403MRH-Y1 Sensors 4NC FB1W-XW1E-BV404MRH-Y0 XW1E-BV4 ES XW Series Emergency Stop Switches (Illuminated, LED/24V, pushlock pull or turn reset) Contact Configuration RH 1NO1NC FB1W-XW1E-BV411MRH-Y0 FB1W-XW1E-BV411MRH-Y1 1NO2NC FB1W-XW1E-BV412MRH-Y0 FB1W-XW1E-BV412MRH-Y1 1NO3NC FB1W-XW1E-BV413MRH-Y0 FB1W-XW1E-BV413MRH-Y1 2NO2NC FB1W-XW1E-BV422MRH-Y0 FB1W-XW1E-BV422MRH-Y1 1NC FB1W-XW1E-LV401Q4MR-Y0 FB1W-XW1E-LV401Q4MR-Y1 2NC FB1W-XW1E-LV402Q4MR-Y0 FB1W-XW1E-LV402Q4MR-Y1 3NC FB1W-XW1E-LV403Q4MR-Y00 FB1W-XW1E-LV403Q4MR-Y1 4NC FB1W-XW1E-LV404Q4MR-Y0 R 1NO1NC FB1W-XW1E-LV411Q4MR-Y0 FB1W-XW1E-LV411Q4MR-Y1 1NO2NC FB1W-XW1E-LV412Q4MR-Y0 FB1W-XW1E-LV412Q4MR-Y1 1NO3NC FB1W-XW1E-LV413Q4MR-Y0 FB1W-XW1E-LV413Q4MR-Y1 2NO2NC FB1W-XW1E-LV422Q4MR-Y0 FB1W-XW1E-LV422Q4MR-Y1 3NC FB1W-XW1E-TV403Q4MR-Y0 FB1W-XW1E-TV403Q4MR-Y1 R 1NO2NC FB1W-XW1E-TV412Q4MR-Y0 FB FB1W-XW1E-LV404Q4MR-Y1 R XW1E-TV4 AUTO-ID FB1W-XW1E-BV404MRH-Y1 RH XW1E-LV4 Controllers R FB1W-XW1E-TV412Q4MR-Y1 Color code (∗): Red (R), Bright Red (RH) Download Downloadcatalogs catalogsand andCAD CADfrom fromhttp://asia.idec.com/downloads http://eu.idec.com/downloads C-010 FB Series Control Stations Control Boxes Control Stations 1 Hole (Box Size: 76mm) Symbol Legend Specification Switch Part No. HW Series Emergency Stop Switches (Pushlock turn reset) APEM Switches & Pilot Lights HW1B-V4 Control Boxes Emergency Stop Switches Enabling Switches ES Safety Products HW Series Emergency Stop Switches (Pushlock pull reset) HW1B-Y2 Explosion Proof Terminal Blocks HW Series Emergency Stop Switches (Pushlock key reset) Relays & Sockets Circuit Protectors Power Supplies HW1B-X4 With nameplate "EMERGENCY"stop Contact Configuration Part No. (Ordering Part No.) 1NC FB1W-HW1B-V401R-Y0 2NC FB1W-HW1B-V402R-Y0 1NO1NC FB1W-HW1B-V411R-Y0 FB1W-HW1B-V411R-Y1 1NC FB1W-HW1B-Y201R-Y0 FB1W-HW1B-Y201R-Y1 2NC FB1W-HW1B-Y202R-Y0 1NO1NC FB1W-HW1B-Y211R-Y0 FB1W-HW1B-Y211R-Y1 1NC FB1W-HW1B-X401R-Y0 FB1W-HW1B-X401R-Y1 2NC FB1W-HW1B-X402R-Y0 1NO1NC FB1W-HW1B-X411R-Y0 Color (∗) Part No. (Ordering Part No.) Color (∗) FB1W-HW1B-V401R-Y1 FB1W-HW1B-V402R-Y1 R FB1W-HW1B-Y202R-Y1 R FB1W-HW1B-X402R-Y1 R R R R FB1W-HW1B-X411R-Y1 Color code (∗): Red (R) LED Illumination Controllers Operator Interfaces Control Stations with SEMI Emergency off (EMO) Switches Symbol Guard Specification Sensors Switch Part No. AUTO-ID Contact Configuration Part No. (Ordering Part No.) SEMI Switchguard Color (∗) Part No. (Ordering Part No.) 1NC FB1W-HW1B-V401R-EMO-Y0 2NC FB1W-HW1B-V402R-EMO-Y0 1NO1NC FB1W-HW1B-V411R-EMO-Y0 FB1W-HW1B-V411R-EMO-Y 1NC FB1W-XW1E-BV401MRH-EMO-Y0 FB1W-XW1E-BV401MRH-EMO-Y ES 2NC FB1W-XW1E-BV402MRH-EMO-Y0 FB1W-XW1E-BV402MRH-EMO-Y (For SEMI) 3NC FB1W-XW1E-BV403MRH-EMO-Y0 FB1W-XW1E-BV403MRH-EMO-Y 4NC FB1W-XW1E-BV404MRH-EMO-Y0 HW Series SEMI EMO Pushbutton (Pushlock turn reset) HW1B-V4 FB XW Series SEMI EMO Pushbuttons (Non-illuminated, pushlock pull or turn reset) XW1E-BV4 FB1W-HW1B-V401R-EMO-Y R FB1W-HW1B-V402R-EMO-Y RH 1NO1NC FB1W-XW1E-BV411MRH-EMO-Y0 FB1W-XW1E-BV411MRH-EMO-Y 1NO2NC FB1W-XW1E-BV412MRH-EMO-Y0 FB1W-XW1E-BV412MRH-EMO-Y 1NO3NC FB1W-XW1E-BV413MRH-EMO-Y0 FB1W-XW1E-BV413MRH-EMO-Y 2NO2NC FB1W-XW1E-BV422MRH-EMO-Y0 FB1W-XW1E-BV422MRH-EMO-Y Control Stations C-011 With HW1B-V4 & HW9Z-KG3 With HW1B-V4 & HW9Z-KG4 With XW1E-BV4 R FB1W-XW1E-BV404MRH-EMO-Y RH Color code (∗): Red (R), Bright Red (RH) *1) Specify a code for SEMI switchguard in place of  in the part no. (2: HW9Z-KG3, 3: HW9Z-KG4) Control stations with HW9Z-KG3, HW9Z-KG4 are SEMI S2 compliant. For details, see D-052. With HW1B-V4 Color (∗) With XW1E-BV4 & HW9Z-KG3 For Formore moreinformation, information,visit visithttp://asia.idec.com http://eu.idec.com With XW1E-BV4 & HW9Z-KG4 FB Series Control Stations Control Boxes Control Stations 1 Hole (Box Size: 76mm) Symbol Legend Specification Switch Part No. Pushbutton (Momentary,flush) Contact Configuration Part No. (Ordering Part No.) 1NO FB1W-HW1B-M110∗-Z0 1NO1NC FB1W-HW1B-M111∗-Z0 1NC FB1W-HW1B-M201∗-Z0 1NO1NC FB1W-HW1B-M211∗-Z0 1NO FB1W-HW1B-M410∗-Z0 HW1B-M1 PB Pushbutton (Momentary, extended) HW1B-M2 Pushbutton (Momentary, ø40) HW1B-M4 Color (∗) G W R B Part No. (Ordering Part No.) FB1W-HW1B-M110∗-Z1 FB1W-HW1B-M111∗-Z1 FB1W-HW1B-M201∗-Z1 FB1W-HW1B-M211∗-Z1 APEM G W FB1W-HW1B-M411G-Z0 Switches & Pilot Lights Control Boxes R B FB1W-HW1B-M410G-Z1 G 1NO1NC Color (∗) G FB1W-HW1B-M411G-Z1 Emergency Stop Switches Enabling Switches Safety Products Explosion Proof Color code (∗): Black (B), Green (G), Red (R), White (W) Terminal Blocks Relays & Sockets Symbol Legend Specification Switch Part No. Pushbutton (Momentary,flush) With nameplate "ON" Contact Configuration Part No. (Ordering Part No.) 1NO FB1W-HW1B-M110∗-Z2 1NO1NC FB1W-HW1B-M111∗-Z2 1NO FB1W-HW1B-M410G-Z2 HW1B-M1 PB Pushbutton (Momentary, ø40) HW1B-M4 Color (∗) G W Part No. (Ordering Part No.) FB1W-HW1B-M110∗-Z3 FB1W-HW1B-M111∗-Z3 FB1W-HW1B-M411G-Z2 Legend With nameplate "OFF" Color (∗) Power Supplies LED Illumination G W Controllers Operator Interfaces FB1W-HW1B-M410G-Z3 G 1NO1NC Circuit Protectors With nameplate "START" G FB1W-HW1B-M411G-Z3 Sensors AUTO-ID Color code (∗): Green (G), White (W) Symbol Specification Contact Switch Part No. Configuration PB Pushbutton (Momentary, extended) Part No. (Ordering Part No.) 1NC FB1W-HW1B-M201∗-Z2 1NO1NC FB1W-HW1B-M211∗-Z2 HW1B-M2 With nameplate "STOP" Color (∗) R B Part No. (Ordering Part No.) FB1W-HW1B-M201∗-Z3 FB1W-HW1B-M211∗-Z3 FB Color (∗) R B Color code (∗): Black (B), Red (R) Symbol PB Dual Pushbutton (Momentary, flush−extended) Dual Pushbutton (Interlock, flush-extended) Symbol Legend Specification Switch Part No. Part No. (Ordering Part No.) Color (∗) 1NC FB1W-HW7D-B121001WB1-Z0 WB (Top: White / Bottom: Black) 1NC FB1W-HW7D-B221001WB1-Z0 WB (Top: White / Bottom: Black) Bottom Buttton HW7D-B12 1NO HW7D-B22 1NO Legend Specification Pilot Light Contact Configuration Top Button Illuminated Voltage Part No. (Ordering Part No.) Color (∗) Part No. (Ordering Part No.) Color (∗) HW1P-2Q LED / 24V FB1W-HW1P-2Q4∗-Z0 Color 1 FB1W-HW1P-2Q4∗-Z0 PW S HW1P-5Q LED / 24V FB1W-HW1P-5Q4∗-Z0 Color 1 FB1W-HW1P-5Q4∗-Z0 PW S Switch Part No. PL With "I&ON/O&OFF" on Switch (Round extended) (Dome) (Color 1) R ,G, A, Y Color code (∗): Red (R), Green (G), Amber (A), Yellow (Y), Pure White (PW), Blue (S) Download Downloadcatalogs catalogsand andCAD CADfrom fromhttp://asia.idec.com/downloads http://eu.idec.com/downloads C-012 FB Series Control Stations Control Boxes Control Stations 1 Hole (Box Size: 76mm) Symbol Legend Specification Switch Part No. Selector Switches (2-position maintained, knob, black) APEM Switches & Pilot Lights SS Safety Products Selector Switches (2-position maintained, knob, key selector) (*1) Contact Configuration Part No. (Ordering Part No.) 1NO FB1W-HW1S-2T10-Z0 FB1W-HW1S-2T10-Z1 1NO1NC FB1W-HW1S-2T11-Z0 FB1W-HW1S-2T11-Z1 1NO FB1W-HW1K-2A10-Z0 FB1W-HW1K-2A10-Z1 1NO1NC FB1W-HW1K-2A11-Z0 FB1W-HW1K-2A11-Z1 Legend With nameplate "ON-OFF" With nameplate "HAND-AUTO" HW1S-2T Control Boxes Emergency Stop Switches Enabling Switches HW1K-2A *1) Keys removable in both left and right. Explosion Proof Terminal Blocks Symbol Specification Switch Part No. Relays & Sockets Selector Switches (2-position maintained, knob, black) Circuit Protectors Power Supplies SS Selector Switches (2-position maintained, knob, key selector) (*1) Operator Interfaces Sensors AUTO-ID Part No. (Ordering Part No.) 1NO FB1W-HW1S-2T10-Z2 FB1W-HW1S-2T10-Z3 1NO1NC FB1W-HW1S-2T11-Z2 FB1W-HW1S-2T11-Z3 1NO FB1W-HW1K-2A10-Z2 FB1W-HW1K-2A10-Z3 1NO1NC FB1W-HW1K-2A11-Z2 FB1W-HW1K-2A11-Z3 Legend HW1S-2T LED Illumination Controllers Contact Configuration HW1K-2A *1) Keys removable in both left and right. Symbol SS Specification Selector Switches (3-position maintained, knob, black) FB Symbol SS Switch Part No. Contact Configuration HW1S-3T 2NO FB1W-HW1S-3T20-Z0 Legend With nameplate "HAND-OFF-AUTO" Switch Part No. Contact Configuration Part No. (Ordering Part No.) HW1S-3T 2NO FB1W-HW1S-3T20-Z2 Specification Selector Switches (3-position maintained, knob, black) Part No. (Ordering Part No.) FB1W-HW1S-3T20-Z1 2 Holes (Box Size: 140mm, Mounting Centers: 50mm) Symbol Specification Switch Part No.   PB PB Symbol Pushbutton (Momentary, flush, green) Pushbutton (Momentary, flush, red) HW1B-M1 HW1B-M1 Specification Switch Part No.   C-013 PB PB Pushbutton (Momentary, flush, white) Pushbutton (Momentary, flush, black) HW1B-M1 HW1B-M1 Legend With nameplate "ON" With nameplate "START" Legend With nameplate "OFF" With nameplate "STOP" Contact Configuration Part No. (Ordering Part No.) 1NO 1NO FB2W-211Z-A02001 − − − 1NO 1NC FB2W-211Z-A02002 FB2W-211Z-A02003 FB2W-211Z-A02004 FB2W-211Z-A02005 1NO1NC 1NO1NC FB2W-211Z-A02006 FB2W-211Z-A02007 FB2W-211Z-A02008 FB2W-211Z-A02009 Legend With nameplate "ON" With nameplate "START" Legend With nameplate "OFF" With nameplate "STOP" Contact Configuration Part No. (Ordering Part No.) 1NO 1NO FB2W-211Z-A02010 − − − 1NO 1NC FB2W-211Z-A02011 FB2W-211Z-A02012 FB2W-211Z-A02013 FB2W-211Z-A02014 1NO1NC 1NO1NC FB2W-211Z-A02015 FB2W-211Z-A02016 FB2W-211Z-A02017 FB2W-211Z-A02018 For Formore moreinformation, information,visit visithttp://asia.idec.com http://eu.idec.com FB Series Control Stations Control Boxes Control Stations 2 Holes (Box Size: 140mm, Mounting Centers: 50mm) Symbol  PB  PB Legend Legend Specification Pushbutton (Momentary, flush, green) Pushbutton (Momentary, extended, red) Contact Configuration HW1B-M1 HW1B-M2 With nameplate "ON" With nameplate "OFF" With nameplate "START" With nameplate "STOP" Part No. (Ordering Part No.) 1NO 1NC FB2W-211Z-A02019 FB2W-211Z-A02020 FB2W-211Z-A02021 FB2W-211Z-A02022 1NO1NC 1NO1NC FB2W-211Z-A02023 FB2W-211Z-A02024 FB2W-211Z-A02025 FB2W-211Z-A02026 APEM Switches & Pilot Lights Control Boxes Symbol   PB PB Symbol Legend Legend Specification Pushbutton (Momentary, flush, white) Pushbutton (Momentary, extended, red) Contact Configuration HW1B-M1 HW1B-M2 Specification Switch Part No.  PB  PB Pushbutton (Momentary, flush, white) Pushbutton (Momentary, ø40, black) HW1B-M1 HW1B-M4 With nameplate "ON" With nameplate "OFF" With nameplate "START" With nameplate "STOP" Emergency Stop Switches Enabling Switches Safety Products Part No. (Ordering Part No.) 1NO 1NC FB2W-211Z-A02027 FB2W-211Z-A02028 FB2W-211Z-A02029 FB2W-211Z-A02030 1NO1NC 1NO1NC FB2W-211Z-A02031 FB2W-211Z-A02032 FB2W-211Z-A02033 FB2W-211Z-A02034 Legend Legend Explosion Proof Terminal Blocks Relays & Sockets Contact Configuration With nameplate "ON" With nameplate "OFF" With nameplate "START" With nameplate "STOP" Part No. (Ordering Part No.) Circuit Protectors Power Supplies LED Illumination 1NO 1NC FB2W-211Z-A02035 FB2W-211Z-A02036 FB2W-211Z-A02037 FB2W-211Z-A02038 Controllers 1NO1NC 1NO1NC FB2W-211Z-A02039 FB2W-211Z-A02040 FB2W-211Z-A02041 FB2W-211Z-A02042 Operator Interfaces Sensors Symbol  PL  PL Symbol  PL  PB Symbol  PL  SS Symbol  PL  SS Legend Legend Specification Pilot Light (Round extended, red) Pilot Light (Round extended, green) Switch Part No. HW1P-2Q HW1P-2Q Specification Pilot Light Switch Part No. (Round extended, red) Pilot Light HW1P-2Q (Momentary, extended,black) HW1B-M2 Specification Pilot Light (Round extended, red) Selector Switch (2-position maintained, knob, black) AUTO-ID Illuminated Part No. (Ordering Part No.) Voltage LED / 24V LED / 24V FB2W-211Z-A02043 Legend Legend Illuminated Voltage Contact Configuration LED / 24V 1NO1NC FB2W-211Z-A02045 Legend Legend Illuminated Voltage Contact Configuration HW1P-2Q HW1S-2T LED / 24V 1NO1NC FB2W-211Z-A02048 Legend Legend Switch Part No. Illuminated Voltage Contact Configuration HW1P-2Q HW1K-2A LED / 24V 1NO1NC FB With nameplate "STOP" Part No. (Ordering Part No.) Switch Part No. Specification Pilot Light (Round extended, red) Selector Switch (*1) (2-position maintained, key selector) FB2W-211Z-A02046 FB2W-211Z-A02047 With nameplate "HAND-AUTO" Part No. (Ordering Part No.) FB2W-211Z-A02049 FB2W-211Z-A02050 With nameplate "HAND-AUTO" Part No. (Ordering Part No.) FB2W-211Z-A02051 FB2W-211Z-A02052 FB2W-211Z-A02053 *1) Keys removable in both left and right. Download Downloadcatalogs catalogsand andCAD CADfrom fromhttp://asia.idec.com/downloads http://eu.idec.com/downloads C-014 FB Series Control Stations Control Boxes Control Stations 3 Holes (Box Size: 140mm, Mounting Centers: 30mm) Legend Legend Legend Symbol Specification   PB PB PB APEM Switches & Pilot Lights  Pushbutton (Momentary, flush, green) Pushbutton (Momentary, flush, red) Pushbutton (Momentary, flush, green) Control Boxes Emergency Stop Switches Enabling Switches  Explosion Proof Terminal Blocks  Contact Configuration HW1B-M1 HW1B-M1 HW1B-M1 1NO 1NC 1NO FB2W-312Z-A03001 FB2W-312Z-A03002 Legend Legend Legend  PB PB PB Pushbutton (Momentary, flush, white) Pushbutton (Momentary, flush, red) Pushbutton (Momentary, flush, black) Switch Part No. Symbol Specification Safety Products Part No. (Ordering Part No.) Switch Part No. Contact Configuration HW1B-M1 HW1B-M1 HW1B-M1 1NO 1NC 1NO FB2W-312Z-A03003 FB2W-312Z-A03004 Legend Legend Legend Part No. (Ordering Part No.) Relays & Sockets Circuit Protectors Symbol Specification Power Supplies  LED Illumination PL PB PB Controllers Operator Interfaces Sensors AUTO-ID  Pilot Light (Round extended, red) Pushbutton (Momentary, flush, red) Pushbutton (Momentary, extended, black)  PB  PB  PB Symbol  PB  PB  PB Symbol C-015 Switch Part No. Illuminated Voltage Contact Configuration HW1P-2Q HW1B-M1 HW1B-M2 LED / 24V 1NO 1NC  PB  PB  ES Legend Legend Legend Specification Pushbutton (Momentary, flush, green) Pushbutton (Momentary, flush, red) Pushbutton (Momentary, flush, green) Switch Part No. HW1B-M1 HW1B-M1 HW1B-M1 Specification Pushbutton (Momentary, flush, white) Pushbutton (Momentary, flush, red) Pushbutton (Momentary, flush, black) Switch Part No. HW1B-M1 HW1B-M1 HW1B-M1 FB2W-312Z-A03005 FB2W-312Z-A03006 FB2W-312Z-A03007 Part No. (Ordering Part No.) 1NO 1NC 1NO FB3W-311Z-A03009 FB3W-311Z-A03010 1NO1NC 1NO1NC 1NO1NC FB3W-311Z-A03011 FB3W-311Z-A03012 Legend Legend Legend Contact Configuration Part No. (Ordering Part No.) 1NO 1NC 1NO FB3W-311Z-A03013 FB3W-311Z-A03014 1NO1NC 1NO1NC 1NO1NC FB3W-311Z-A03015 FB3W-311Z-A03016 With nameplate "ON" With nameplate "OFF" Legend Legend Legend Specification Pushbutton (Momentary, flush, white) Pushbutton (Momentary, flush, black) Emergency Stop Switch (Pushlock turn reset) Contact Configuration Switch Part No. Contact Configuration HW1B-M1 HW1B-M2 HW1B-V4 1NO 1NC 2NC With nameplate "START" With nameplate "STOP" Part No. (Ordering Part No.) 3 Holes (Box Size: 200mm, Mounting Centers: 50mm) Symbol FB  With nameplate "ON" With nameplate "OFF" (with yellow blank nameplate) With nameplate "START" With nameplate "STOP" With nameplate"EMERGENCY-STOP" With nameplate"EMERGENCY-STOP" Part No. (Ordering Part No.) FB3W-311Z-A03017 FB3W-311Z-A03018 FB3W-311Z-A03019 For Formore moreinformation, information,visit visithttp://asia.idec.com http://eu.idec.com FB2W-312Z-A03008 FB Series Control Stations Control Boxes Control Stations 3 Holes (Box Size: 140mm, Mounting Centers: 30mm) Symbol  PB  PB  ES Symbol  PB  PB  ES Legend Legend Legend Specification Switch Part No. Pushbutton (Momentary, flush, white) Pushbutton (Momentary, extended, black) HW1B-M1  Emergency Stop Switch HW1B-M2 (Pushlock pull or turn reset) XW1E-BV4 Specification Pushbutton (Momentary, flush, white) Pushbutton (Momentary, extended, black)  Emergency Stop Switch (Illuminated type) (Pushlock pull or turn reset) Switch Part No. HW1B-M1 HW1B-M2 XW1E-LV4 1NO1NC 1NO1NC 1NO2NC With nameplate "START" With nameplate "STOP" (with yellow blank nameplate) With nameplate"EMERGENCY-STOP" With nameplate"EMERGENCY-STOP" Contact Configuration 1NO1NC 1NO1NC 2NC With nameplate "ON" With nameplate "OFF" Part No. (Ordering Part No.) FB3W-311Z-A03020 FB3W-311Z-A03021 APEM Control Boxes FB3W-311Z-A03026 FB3W-311Z-A03027 FB3W-311Z-A03028 With nameplate "ON" With nameplate "OFF" With nameplate "START" With nameplate "STOP" Legend Legend Legend (with yellow blank nameplate) With nameplate"EMERGENCY-STOP" With nameplate"EMERGENCY-STOP" Illuminated Voltage Contact Configuration Part No. (Ordering Part No.) 2NC/LED/24V 1NO1NC 1NO1NC Switches & Pilot Lights FB3W-311Z-A03022 FB3W-311Z-A03023 1NO2NC/LED/24V 1NO1NC FB3W-311Z-A03029 1NO1NC FB3W-311Z-A03024 Emergency Stop Switches Enabling Switches Safety Products Explosion Proof Terminal Blocks Relays & Sockets FB3W-311Z-A03025 Circuit Protectors FB3W-311Z-A03030 FB3W-311Z-A03031 Power Supplies LED Illumination Symbol  PL  PB  PB Symbol  PB  PB  SS Legend Legend Legend Specification Switch Part No. Pilot Light (Round extended, red) Pushbutton (Momentary, flush, white) HW1P-2Q Pushbutton HW1B-M1 (Momentary, extended, black) HW1B-M2 Specification Pushbutton (Momentary, flush, white) Pushbutton (Momentary, flush, black) Selector Switch (2-position, knob, black) Switch Part No. HW1B-M1 HW1B-M2 HW1S-2T Illuminated Voltage Contact Configuration With nameplate "ON" With nameplate "OFF" With nameplate "START" With nameplate "STOP" Controllers Operator Interfaces Sensors Part No. (Ordering Part No.) AUTO-ID LED / 24V 1NO 1NC FB3W-311Z-A03032 FB3W-311Z-A03033 FB3W-311Z-A03034 FB3W-311Z-A03035 LED / 24V 1NO1NC 1NO1NC FB3W-311Z-A03036 FB3W-311Z-A03037 FB3W-311Z-A03038 FB3W-311Z-A03039 Legend Legend Legend Contact Configuration FB With nameplate "ON" With nameplate "START" With nameplate "OFF" With nameplate "STOP" With nameplate "HAND-AUTO" With nameplate "HAND-AUTO" Part No. (Ordering Part No.) 1NO 1NC 1NO FB3W-311Z-A03041 FB3W-311Z-A03042 FB3W-311Z-A03044 FB3W-311Z-A03043 1NO1NC 1NO1NC 1NO1NC FB3W-311Z-A03045 FB3W-311Z-A03046 FB3W-311Z-A03048 FB3W-311Z-A03047 Download Downloadcatalogs catalogsand andCAD CADfrom fromhttp://asia.idec.com/downloads http://eu.idec.com/downloads C-016 FB Series Control Stations Control Boxes Control Stations 4 Holes (Box Size: 200mm, Mounting Centers: 36mm) Legend Legend Legend Legend Symbol Specification  APEM Switches & Pilot Lights Control Boxes Emergency Stop Switches Enabling Switches Safety Products Explosion Proof    PL PL PB PB Switch Part No. Pilot Light (Round extended, red) Pilot Light (Round extended, green) Pushbutton (Momentary, flush, white) Pushbutton (Momentary, extended, black) Symbol Specification     PL PB PB SS Switch Part No. Terminal Blocks Relays & Sockets Circuit Protectors HW1P-2Q HW1P-2Q HW1B-M1 HW1B-M2 Pilot Light (Round extended, red) Pushbutton (Momentary, flush, white) Pushbutton (Momentary, extended, black) Selector Switch (2-position maintained, knob, black) HW1P-2Q HW1B-M1 HW1B-M2 HW1S-2T Illuminated Voltage Contact Configuration With nameplate "ON" With nameplate "OFF" Part No. (Ordering Part No.) LED / 24V LED / 24V 1NO1NC 1NO1NC FB3W-413Z-A04001 Legend Legend Legend Legend Illuminated Voltage Contact Configuration LED / 24V 1NO1NC 1NO1NC 1NO1NC FB3W-413Z-A04002 FB3W-413Z-A04003 With nameplate "ON" With nameplate "OFF" With nameplate "HAND-AUTO" Part No. (Ordering Part No.) FB3W-413Z-A04004 FB3W-413Z-A04005 FB3W-413Z-A04006 Power Supplies LED Illumination 5 Holes (Box Size: 200mm, Mounting Centers: 30mm) Operator Interfaces Sensors      PL PL PB PB SS Switch Part No. AUTO-ID FB Legend Legend Legend Legend Legend Symbol Specification Controllers Pilot Light (Round extended, red) Pilot Light (Round extended, green) Pushbutton (Momentary, flush, white) Pushbutton (Momentary, extended, black) Selector Switch (2-position maintained, knob, black) HW1P-2Q HW1P-2Q HW1B-M1 HW1B-M2 HW1S-2T Symbol Specification      SS PB PB PB PB Switch Part No. Selector Switch (2-position maintained, knob, black) Pushbutton (Momentary, flush, green) Pushbutton (Momentary, flush, green) Pushbutton (Momentary, flush, green) Pushbutton (Momentary, flush, green) HW1S-2T HW1B-M1 HW1B-M1 HW1B-M1 HW1B-M1 Illuminated Voltage Contact Configuration With nameplate "ON" With nameplate "OFF" With nameplate "HAND-AUTO" Part No. (Ordering Part No.) LED / 24V LED / 24V 1NO1NC 1NO1NC 1NO1NC FB3W-512Z-A05001 Legend Legend Legend Legend Legend Contact Configuration Part No. (Ordering Part No.) 1NO 1NO 1NO 1NO 2NO FB3W-512Z-A05004 FB3W-512Z-A05002 FB3W-512Z-A05003 Safety Precautions • Turn off power before installation, removal, maintenance, and inspection. Failure to turn power off may cause electrical shocks or fire hazard. C-017 • To avoid burning your hand, use the lamp holder tool when replacing the lamps. For Formore moreinformation, information,visit visithttp://asia.idec.com http://eu.idec.com FB Series Control Stations Control Boxes Instructions Installation Panel Mounting 1. Installing the FB series from the front • Using two M4 screws, install the base onto the panel. Recommended tightening torque: 1.4 to 2.0 N·m • Determine the screw length in consideration of the base and panel thickness. • Mounting screws are not supplied with the FB series. Use M4 mounting screws. Mounting Screws (M4) Installing the Cover and Base • Attach the cover to the base so that the TOP mark on the cover and base are in the same direction. • Use cover mounting screws to attach the cover to the base. (Recommended tightening torque: 1.3±0.1 N·m) • Make sure that the cover and the base are attached in the correct direction. Otherwise, the FB series may be damaged. Inside the box TOP TOP Marking Emergency Stop Switches Enabling Switches M3 tapping screw hole (Cover) Safety Products (Base) Installation using tapping screw hole inside the enclosure Box Base Panel 2. Installing the FB series from the rear • Insert four M4 tapped screws into holes for tapping screws on the back of the base (depth: 8 to 10 mm, tapping screw hole diameter: ø3.7 mm), and fasten the screws to a tightening torque of 1.3±0.1 N·m (Nitto Seiko M4-P-TITE). • Mounting screws are not supplied with the FB series. Use M4 tapping screws (recommended screws: Nitto Seiko M4-P-TITE). • The value of the recommended tightening torque has been confirmed with a M4 tapping screw (Nitto Seiko M4-P-TITE). When using other screws, check that the tapping screw hole is not damaged and the screw can be securely tightened. 3. Installation using mounting bracket FB9Z-PK1 • Refer to installation instructions on C-020. Explosion Proof • When using M3 tapping hole screws inside the enclosure, make sue to install the devices in consideration of the insulation distance and temperature rise. Damages caused by using devices other than those specified by IDEC are excluded from any warranty. Ensures installed with devices using tapping screw holes will not be UL or c-UL listed. • M3 tapping screw hole (depth: 6 to 7mm, tapping screw hole diameter ø2.7m) • Recommended tightening torque: 0.9 ±0.1 N·m, M3-P-TITE (Nitto Seiko) Applicable Crimping Terminal Relays & Sockets Circuit Protectors Power Supplies Controllers HW/TW Series Operator Interfaces Non-insulated Terminal Sensors Crimping terminal from A ø4.3 min. AUTO-ID ø3.6 min. 8 max. 7 max. 4 max. 4 max. 6 min. Applicable Crimping Terminal 6 min. FB IP20 terminalInsulating Tube ø3.6∼4.3 Installing the Cable Gland • Break a desired knockout to mount a cable gland using a hammer and a screwdriver, and install the cable gland. • When breaking the knockout to make a cable gland hole, be careful not to damage the internal contact block. • Note that cracks or burrs on the cable gland hole will degrade the waterproof characteristics. Terminal Blocks LED Illumination Installing and Removing the Switch/Pilot Light • Refer to installation instructions for each unit. Switches & Pilot Lights Control Boxes TOP 5.0 mm (Box Thickness) APEM Wire 7 max. 20.2max 6 min. 4 max. Crrimping terminal from B ø3.6 min. ø4.3 min. 6.6 max. ø3.6 min. 8 max. 6 min. 4 max. 4 max. 7 max. 4 max. 6 min. Dimensions for intallling insulated tube Applicable Crimping Terminal 6 min. Insulating Tube Wire 20.2max • See HW series catalog pages for applicable crimping terminals. Wiring Directions A A B B B B A A Download Downloadcatalogs catalogsand andCAD CADfrom fromhttp://asia.idec.com/downloads http://eu.idec.com/downloads C-018 FB Series Control Stations Control Boxes Instructions Notes XW Series (Screw Terminal) Non-insulated Terminal Applicable Crimping Terminal Insulating Tube Wire ø3.2min 6.0max 3.0max (*1) 4.7min 14.9max APEM Switches & Pilot Lights Control Boxes Emergency Stop Switches Enabling Switches 4.7 to 5.9 • Use cable glands with waterproof characteristics (IP65, TYPE 4X) which can be mounted on a panel thickness of 3 mm or more. Power Supplies LED Illumination ∗ Cable gland and Locking nuts are not attached. 10 mm max. 3 mm 30 mm max. All dimensions in mm. Flexible conduits: VF-03 (Made by Nippon Flex Co., Ltd.) Gland Port Size Operator Interfaces M20 G1/2 Sensors PG13.5 Plastic Cable Gland Metal Cable Gland RLC-103 (Nippon Flex) RBC-103PG13.5 (Nippon Flex) Plastic Cable Gland Metal Cable Gland M20 5311 1220 [Skintop-ST-M] Applicable gasket: GPM20 (LAPP, Germany) ALS-EC20 (Nippon Flex) G1/2 5380 6030 [Skintop-ST-PF] Applicable gasket: GP 050 (LAPP, Germany) ALS16- (Nippon Flex) PG13.5 5301 5030 [Skintop-ST] Applicable gasket: GP13.5 (LAPP, Germany) ABS-PG13.5 (Nippon Flex) 3) Locking ring for cable gland (plastic, optional) Gland Port Size Locking Nut Part No. (made of plastic) M20 HW9Z-NM20 (IDEC) G1/2 HW9Z-G (IDEC) PG13.5 HW9Z-PG135 (IDEC) • The degree of protection of the cable gland examples described above is not NEMA TYPE 4X. • When using the FB series in North America, be sure to use UL approved plastic cable glands. • Tighten cable glands to a torque of 3.0±0.3 N·m. ∗ Insufficient tightening of the cable gland may degrade the waterproof char­ acteristics. ∗ Electric shock protection Class II is maintained only when a plastic cable gland is used. • Determine the cable gland for a multi-core cable according to the outside diameter of the cable sheath. • When wiring from the back of FB series, use the ø14 knockout on the back of the enclosure. A cable gland cannot be installed to the ø14 knockout. C-019 Wiring • Avoid foreign objects such as dust, liquid, and oil from entering the switch while connecting a conduit or wiring. • Do not twist or pull the cable of flexible conduit with excessive force. Otherwise, the wire, FB series, and switches/pilot lights may be damaged. • Because the FB series is not provided with a PG terminal, bonding circuits cannot be interconnected. Installation of switches/pilot lights on 30 mm centers • When mounting HW/TW series con­trol units on 30mm mounting centers (close mounting), make sure to use a barrier (optional: HWVU1) to secure the insulation properties of the terminal. The barriers (HW-VU1) can be easily pressed into the side of the contact block. Operation • Avoid any contact with oil or coolants. Otherwise, the FB series may be damaged. • Use the FB series for INDOOR applications only. RLC-103EC20 (Nippon Flex) When using multi-core cables (Example) Gland Port Size FB Locking ring for Cable Gland Box Base M20, G1/2, PG13.5 1) When using flexible conduits (Example) Controllers AUTO-ID 4.7 to 5.9 *1) When a spade terminal is used, the dimension is 4.7 to 5.9 mm. ∗ Be sure to install an insulating tube on the crimping terminal. ∗ When using crimping terminals for the XW series, use only one crimping terminal for each terminal. ∗ Make sure that the wiring does not contact the control stations. Applicable Cable Gland Circuit Protectors 6.0max 3.0max 14.9max Explosion Proof Relays & Sockets ø3.2min 18.3max Safety Products Terminal Blocks Applicable Wire Size • Determine the wire size in consideration of the applicable wire for switches/pilot lights and the applicable diameter of cables. Insulated Terminal Contact Cover Box Specifications, applicable units, and wiring • Same as the standard control stations. Installing XW series to the FB1WR-111Z contact cover • Remove the contact block and the locking ring from the opera­tor and check that the rubber gasket is in place. Insert the operator from panel front into the panel hole. Attach the rubber gasket and the base to the operator unit (place the rubber gas­ket between the panel and the base) and tighten the locking ring using locking ring wrench MW9Z-T1. Recommended tightening torque: 2.0 N·m • Attach the contact block to the operator. After wiring, attach the cover to the base using four cover mounting screws. Rec­ommended tightening torque: 1.3±0.1 N·m • Use a nameplate if necessary. • Determine the panel thickness by excluding the thickness of the base (2.0 mm) and accessories (if used) from the maxi­mum panel thickness for the switch/pilot light. Panel Rubber Gasket Cover Contact Block Base Operator Nameplate Locking Ring Rubber Gasket (supplied) Notes • Do not expose the cable to excessive force, otherwise failure or damage may be caused. When mounting strength is needed, insert M4 tapping screws from the front of the panel (screw tightening depth: 8 to 10 mm tapping screw hole: ø3.7 mm) • Determine the mounting hole centers referring to the dimen­sions of the control stations. For Formore moreinformation, information,visit visithttp://asia.idec.com http://eu.idec.com FB Series Control Stations Control Boxes Instructions Mounting Bracket 1) Hook Mounting Mounting Hole B Hook Mounting • Attach the FB9Z-PK1 mounting bracket on the FB series with the supplied screws (two M4 tapping screws). Recommended tightening torque: 1.3±0.1 N·m • Do not tighten the FB9Z-PK1 onto the FB series with exces­sive force. The tapping screw hole may be damaged and may not securely hold the FB series. A FB Series FB9Z-PK1 APEM Switches & Pilot Lights L Depth 10mm Control Boxes Two M4 Tapping Screws (supplied) Two M4 Tapping Screw Holes (Depth: 10mm) 76 Frame Mounting • The FB9Z-PK1 can be used as frame mounting brackets by attaching two FB9Z-PK1 as shown below. 59.5 28 10 Safety Products FB1 FB Series FB2 FB3 76 19 12.5 140 18.5 12 200 18.5 12 (76mm) L A B Emergency Stop Switches Enabling Switches (140mm) (200mm) FB Series Four M4 Tapping Screw Holes Terminal Blocks Relays & Sockets Circuit Protectors 2) Frame Mounting FB9Z-PK1 Explosion Proof Power Supplies LED Illumination Controllers Two M4 Tapping Screws (supplied) L C D Operator Interfaces Sensors AUTO-ID • Attach the FB9Z-PK1 on the FB series with the supplied screws (two M4 tapping screws). Recommended tightening torque: 1.3±0.1 N·m. • Do not tighten the FB9Z-PK1 onto the FB series with exces­sive force. The tapping screw hole may be damaged and may not securely hold the control station. • Using two M6 screws, fasten the FB9Z-PK1 securely on the frame. Recommended tightening torque: 5.0±0.3 N·m M6 Screw 59.5 10 FB1 FB Series FB2 FB3 76 93 114 140 156 177 200 216 237 (76mm) 28 (*1) 36 76 L C D (140mm) FB (200mm) FB Series M6 Screw Nut FB9Z-PK1 Frame • M6 mounting screws and nuts are not supplied with the FB9Z-PK1. • The value of the recommended tightening torque for M6 screws has been confirmed with a hexagon socket head screw. When other screws are used and tightened to a smaller torque, make sure that the screws do not become loose after mounting. Dimensions R3 72 36 54 .3 6.6 10.5 All dimensions in mm. 30 2 6.5 10 13 R2 .5 R4 Download Downloadcatalogs catalogsand andCAD CADfrom fromhttp://asia.idec.com/downloads http://eu.idec.com/downloads C-020 FB Series Control Stations Control Boxes Instructions DIN Rail Adapter APEM Switches & Pilot Lights Control Boxes Emergency Stop Switches Enabling Switches Safety Products Explosion Proof Terminal Blocks Relays & Sockets Mounting 3) Mounting Switches/Pilot Lights on DIN Rail • Refer to each instruction sheet. 1) Installing the FB9Z-PK3 DIN Rail Adapter • To attach the FB9Z-PK3 on the FB series, position the positioning hole of the FB9Z-PK3 with the positioning boss in the enclosure using four M3 tapping screws (supplied) as shown in the figure below. Recommended tightening torque: 0.9±0.1 N·m • Do not tighten the FB9Z-PK3 onto the FB series with excessive force. The tapping screw hole may be damaged and may not securely hold the control station. 4) Installing the Separate Mounting Transformer • After attaching the FB9Z-PK3 on the FB series, attach the sepa­rate mounting transformer on the FB9Z-PK3, using plain washers and spring washers on two M3 screws as shown in the figure below. Recommended tightening torque: 0.5 to 0.8 N·m • Separate mounting transformer mounting screw (M3) Screw Length: (Spring washer thickness) + (Plain washer thick­ness) + 7 to 10 mm 2) Installing the DIN Rail • To attach a DIN rail, use plain washers and spring washers on two M5 screws and tighten firmly. Recommended tightening torque: 2.0 ±0.1 N·m • DIN rail mounting screw (M5) Screw length: (spring washer thickness + plain washer thickness + DIN rail thickness) + 3 to 5 mm Circuit Protectors FB Series FB9Z-PK3 Positioning Boss FB Series Power Supplies Separate Mounting Transformer FB9Z-PK3 Positioning Hole LED Illumination Two Plain Washers Two M3 Screws Four M3 Tapping Screws (supplied) Controllers Two Spring Washers Operator Interfaces Two M5 Screws (including spring washer and plaing washer) Sensors AUTO-ID DIN Rail • M3 screws, spring washers, and plain washers are not supplied. • Do not tighten the screw with excessive force. The screw hole and the separate mounting transformer may be damaged. FB Series FB M5 Screw Length Spring Washer Thickness + Plain Washer Thickness M3 Screw Length Spring Washer Thickness + Plain Washer Thickness • M5 screws, spring washers, and plain washers are not supplied. • The length of DIN rail must be within the effective internal dimen­ sions. • Do not tighten the M5 screw onto the FB9Z-PK3 with excessive force. The screw hole may be damaged and may not securely hold the FB9Z-PK3. M3 Screw Separate Mounting Transformer FB9Z-PK3 FB Series Plain Washer Spring Washer M5 Screw DIN Rail FB9Z-PK3 Dimensions All dimensions in mm. Spring Washer 40 2 66 C-021 For Formore moreinformation, information,visit visithttp://asia.idec.com http://eu.idec.com 29 22 Plain Washer 12.5 DIN Rail Thickness 2-M3 2-M5 FB Series Control Stations Control Boxes Instructions Inside Dimensions of FB Series FB9Z-PK3 Installation Positions APEM Switches & Pilot Lights A ✽ ✽ B Control Boxes Emergency Stop Switches Enabling Switches Safety Products 45 64 FB Series Enclosure FB3 FB2 5 46 (140mm) (200mm) A 50 112.5 B — 37.5 ✽ See internal dimensions on C-008. Note: Only one DIN rail adapter can be used for FB1 (76mm). Explosion Proof Terminal Blocks Relays & Sockets Circuit Protectors Power Supplies LED Illumination 5) Other Precautions • Rated current of terminal blocks depends on operating conditions such as wire type, number of bundle wires, and ambient tempera­ture. Check the specifications of terminal blocks carefully, and use terminal blocks within the specification values. Otherwise electric shock or fire hazard may be caused. • FB series is rated as Class II protection against electric shock (no reliance on installation protective measures, according to IEC 61140). When using a blank front enclosure as a junction box and grounding is necessary, provide appropriate grounding, for exam­ple installing a grounding terminal block inside the enclosure. • For wiring, refer to the instructions of the FB series and switches/pilot lights used. Download Downloadcatalogs catalogsand andCAD CADfrom fromhttp://asia.idec.com/downloads http://eu.idec.com/downloads Controllers Operator Interfaces Sensors AUTO-ID FB C-022
FB1W-XW1E-BV413MRH-Y0 价格&库存
很抱歉,暂时无法提供与“FB1W-XW1E-BV413MRH-Y0”相匹配的价格&库存,您可以联系我们找货
