ø22mm
HW1Z Illuminated Buzzer
Optimal illuminated buzzer for
elevators and production sites
■ Combination buzzer and pilot light
■ Alerts workers of danger with sound and light
■ Waterproof construction
Complies with the new EU elevator safety standard
EN81-1/2, the safety rules for the construction and installation of lifts (electric and hydraulic) were revised to EN81-20/50
in July 2014 (effective in September 2017). As GB and JIS standards will follow suit, the requirements in the new rules
must be taken into consideration when designing elevators.
EN81-20 (5.12.1.8.3 g)
An audible signal at the car and a flashing light under the car shall be activated during movement.
The sound level of the audible warning shall be minimum 55 dB(A) below the car at 1 m distance.
Can be used in semi-outdoor applications
With waterproof and dustproof construction, HW1Z
can be used in semi-outdoor
applications such as elevators
exposed to rain and dust.
Meets waterproof requirements for
fireman’s elevator
HW1Z’s IPX3 waterproof
characteristics can be
used in emergency
situations exposed to
water.
Buzzer/lamp in one can be installed easy and quick
Easy wiring and tight installation places
Wiring is accomplished with push-in terminals.
No tightening of screw is required.
Short, 19.7 mm depth behind panel.
Can be installed in tight places.
19.7 mm
Lamp and buzzer functions are integrated.
Flashing light
Panel front: IP65 waterproof
Buzzer sound
Installing an optional terminal rubber boot upgrades the
terminal’s waterproof characteristics to IP54 without
the need to use a rear enclosure.
—Other Applications—
Automatic Storage
01
Flashing lights and buzzer sounds alert workers
of fast-moving parts in automatic storages.
Production Lines
02
Installed in areas where robots operate, HW1Z
alerts workers when they enter potentially
hazardous locations.
AGV
03
Control Station
04
HW1Z can be used to alert workers of AGV
movement. Also suitable for applications where
multiple buzzers are required, such as in a
control station.
ø22mm HW1Z Illuminated Buzzer
Model
Shape
HW1Z
Part No.
Illumination Color
HW1Z-P1F2PQ4R
Red
HW1Z-P1F2PQ4Y
Yellow
Accessories
Shape
Terminal Rubber Boot
Material
Part No.
Package Quantity
Nitryl Rubber
HW9Z-CZ1
1
Notes
Applicable cable: ø4.5 to 8.5 mm
Cut the end of rubber boot to fit the cable size
(see dimensions).
Weight: 10 g (approx.)
Specifications
Rated Insulation Voltage
Rated Voltage
Voltage Range
Rated Current (effective value)
Inrush Current
Sound Pressure
(of HW1Z itself)
(at 25ºC)
Sound Frequency
(at 25ºC)
Sound Type
Intermittent Cycle
(at 25ºC)
Illumination Type
Illumination Flash Cycle
(at 25ºC)
Buzzer
Operating
Temperature
Operating Humidity
Storage
Temperature
Insulation
Resistance
Dielectric Strength
30V
12 to 24V DC
10.8 to 26.4V DC
18mA (24V DC), 8mA (12V DC)
100mA maximum
90dB min. at 0.1m (24VDC)
70dB min. at 1m (24V DC, equivalent value)
84dB min. at 0.1m (12V DC)
64dB min. at 1m (12VDC, equivalent value)
–20 to +50ºC (no freezing)
20% to 85% RH (no condensation)
–30 to +80ºC (no freezing)
100MΩ minimum (at 500V DC megger)
Between live and earthed metal parts: 1000V AC, 1 minute
Operation extremes: 5 to 55Hz, amplitude 0.5mm
Vibration Resistance
Damage limits: 5 to 55Hz, amplitude 0.5mm
Operation extremes: 100 m/s2
Shock Resistance
Damage limits: 1,000 m/s2
Panel front: IP65 (IEC 60529)
Degree of Protection Terminal: IP40 (IEC 60529)
IP54 (with terminal rubber boot) (IEC 60529)
Terminal Style
Push-in Terminals
Solid wire/ferrule (without sleeve): 0.2 to 1.5 mm2
Applicable Wire
Ferrule (with sleeve): 0.2 to 0.75 mm2
Weight (approx.)
17g
2,200 to 2,450Hz
Intermittent sound
105 cycles/minute approx. (1.75Hz approx.)
Flashing
Applicable Standards
UL508
File No.E68961
EN60947-5-1
EMC Directive
Dimensions
Cut here when cable size is ø5.5 to 6.5 (*1)
Cut here when cable size is ø6.5 to 7.5 (*1)
Cut here when cable size is ø7.5 to 8.5 (*1)
3
Panel Thickness 0.8 to 6 mm
45°
0.5
17.6
Bellows (*2)
17 to 22
x. (*
ma
19.7
ø3
ø3
Rubber Gasket
Locking Ring
All dimensinos in mm.
With terminal rubber boot
3)
54 to 59
58 to 63
62 to 67
66 to 71
Terminal Arrangement (botom view)
Mounting Hole Layout
+0
0 .4
2.
3
ø2
ax.
8m
R0.
24.1 +0.4
X2 X1
X1 and X2
have no polarity.
*1: ø4.5-5.5 cable needs no cutting.
*2: The bellows must be 17 to 22mm long after installing
the terminal rubber boot.
*3: Maintain a cable angle of 45° max. to the HW1Z axis.
Panel cut-out
+0.2
3.2 0 hole is for anti-rotation.
Not required when nameplate/anti-rotation is not used.
Safety Precautions
• Turn off the power to the HW1Z before installation, removal, wiring, maintenance, and inspection. Failure to turn power off may cause electrical shocks or
fire hazard.
• For wiring, use wires of a proper gauge to meet the voltage and current
requirements.
• Prevent metal fragments and pieces of wire from dropping inside when installing or wiring the HW1Z. Otherwise fire, failure, or malfunction may be caused.
Operating Instructions
Panel Mounting
4. Install the terminal rubber boot as shown below.
• Insert the HW1Z into the panel cut-out from the front, and tighten the locking
ring from the back.
Panel
Note for panel mounting
• Use the optional locking ring wrench (MW9Z-T1) to
tighten the locking ring to a recommended tightening torque of 1.5 to 2.0 N·m.
• Do not use pliers and do not tighten excessively,
otherwise the HW1Z may be damaged.
Locking Ring
5. Cover part B with part A.
Wiring
Part B
• When using solid wire, strip the wire insulation 8 mm from the end. When
using stranded wire, clamp a ferrule and insert into the terminal, and make
sure that the wire does not loosen.
Recommended Ferrules
Installed
(terminal rubber boot: cross section view)
Part A
6. Make sure that the bellows is 17 to 22 mm long.
Phoenix Contact
Without sleeve
For 0.5mm2: A0,5-8
For 0.75mm2: A0,75-8
For 1.0mm2: A1-8
With sleeve
For 0.25mm2: AI0,25-8YE
For 0.5mm2: AI0,5-8WH
For 0.75mm2: AI0,75-8GY
Wire removal
Wire Removal Part
(white)
Push in the white wire removal part above the wire ports using a
small flat screw driver, and pull out the wire.
Note for wiring
Bellows
Note for terminal rubber boot
• After installing the terminal rubber boot, make sure that the bellows is 17
to 22 mm long. Waterproof characteristics cannot be achieved with longer
bellows.
• Maintain a cable angle of 45° maximum to the axis of the HW1Z, otherwise
the terminal rubber boot may come off.
Make sure that the terminal is not constantly pulled by the wire. Wiring must be
performed in environments of –5 to +50°C.
Installing the terminal rubber boot
1. Cut the end of terminal rubber boot to fit the cable size.
2. Insert the cable into the terminal rubber boot in the direction of arrow shown
below.
Cut here when cable size is ø5.5 to 6.5 mm
Cut here when cable size is ø6.5 to 7.5 mm
Cut here when cable size is ø7.5 to 8.5 mm
45°
Bent excessively
Operating Conditions
Do not use the HW1Z in the following locations.
• Exposed to direct sunlight
• Subject to corrosive or flammable gases
Cable insertion
3. Strip the sheath of the cable 30 mm from the end.
Solid wire: strip each wire 8 mm from the end
Stranded wire: clamp the ferrule
Insert the cable into the terminal.
www.idec.com
Head Office
6-64, Nishi-Miyahara-2-Chome, Yodogawa-ku, Osaka 532-0004, Japan
USA
Germany
Singapore
Thailand
Australia
Taiwan
IDEC Corporation
IDEC Elekrotechnik GmbH
IDEC Izumi Asia Pte. Ltd.
IDEC Asia (Thailand) Co., Ltd
IDEC Australia Pty. Ltd.
IDEC Taiwan Corporation
Tel: +1-408-747-0550
Tel: +49-40-25 30 54 - 0
Tel: +65-6746-1155
Tel: +66-2-392-9765
Tel: +61-3-8523-5900
Tel: +886-2-2698-3929
opencontact@idec.com
service@eu.idec.com
info@sg.idec.com
sales@th.idec.com
sales@au.idec.com
service@tw.idec.com
Specifications and other descriptions in this brochure are subject to change without notice.
2017 IDEC Corporation, All Rights Reserved.
EP1616-1 DECEMBER 2017
Hong Kong
China/Shanghai
China/Shenzhen
China/Beijing
Japan
IDEC Izumi (H.K.) Co., Ltd.
IDEC (Shanghai) Corporation
IDEC (Shenzhen) Corporation
IDEC (Beijing) Corporation
IDEC Corporation
Tel: +852-2803-8989
Tel: +86-21-6135-1515
Tel: +86-755-8356-2977
Tel: +86-10-6581-6131
Tel: +81-6-6398-2527
info@hk.idec.com
idec@cn.idec.com
idec@cn.idec.com
idec@cn.idec.com
marketing@idec.co.jp
很抱歉,暂时无法提供与“HW1Z-P1F2PQ4R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+294.965081+38.33147
- 3+260.650113+33.87215
- 4+256.354544+33.31393
- 5+253.785465+32.98007
- 9+249.209039+32.38535
- 10+248.6390410+32.31128
- 20+246.0617020+31.97635
- 国内价格 香港价格
- 1+576.872401+74.96604
