HW4B-M1F10-G
HW4B-M1F10-G
    IDEC(日本和泉)
HW4B-M1F10-G 数据手册
Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices HW Series — 22mm IEC Style Global Pushbuttons Key features: Signaling Lights • Locking lever removable contact blocks • Finger-safe IP20 contacts as standard, other terminal styles available • Tamperproof construction • All E-stops meet EN418 and are compliant with SEMI S2 standards • Worldwide approvals • Easy to assemble • Choice of black plastic or metallic front bezels • Incandescent or LED illumination • Transformer or full voltage • Slow make double break self cleaning contacts HW: The Best Engineered Switch in the World Complete with finger-safe contact blocks offering IP20 protection, these 7/8” (22mm) switches include illuminated and non-illuminated pushbuttons, pilot lights, selector switches, and emergency stop switches. All switches also incorporate mechanically keyed safety locking levers, ensuring correct installation and maintaining safety in high-vibration applications. Registration No. R9551089 (E-stops) Registration No. R50054316 (Dual Pushbuttons) Registration No. J9650511 (Pilot Lights) Registration No. J9551458 (all other switches) File No. E68961 Certificate No. 2005010305145656 File No. LR92374 Electrical Mechanical 600V Rated Switching Over-Voltage Less than 4kV, conforming to IEC60947-1 Rated Impulse Withstanding Voltage 4kV for contact circuit, 2.5kV for lamp circuit Rated Thermal Current 10 Amp Minimum Switching Capacity 5 mA at 3V AC/DC Electrical Reliability MTBF < 1 fault for 10 million operation cycles (3V DC, 5mA) Lamp Ratings Incandescent: 1 W LEDs: 6V/17mA max, 12V & 24V/11mA max, 120 & 240V/10mA max Contact Operation Slow break NC or NO, self-cleaning Positive Action Operation (Emergency Stops with NC contacts) 5.5mm to 10mm travel to latch, 45N minimum force to latch 10mm maximum travel, 1,800 operations per hour maximum for a Pushlock Turn Reset 900 operations per hour maximum for a Push-Pull Operating Force Flush and extended pushbuttons—with 1NO or 1NC contact: 6.2±2N (momentary), 7.0±2N (maintained) Additional contacts—1NO or 1NC: +3.2N (momentary), + 3.3N (maintained) Recommended Terminal Torque 0.8 N m (7.1 in lb.) Applicable Wire Size Minimum 1 x 22 AWG, max. 2 x 14 AWG or 1 x 12 AWG Contact Resistance Initial contact resistance of 50mΩ or less Contact Gap 4mm (NO and NC), 2mm (NO-EM and NC-LB) Horsepower Rating Reference Value: 1/4 HP @ 120V (1ø non-reversing), 1HP @ 240V (3ø non-reversing) Contact Material Silver (gold plated contacts available - contact IDEC) Operating Temperature Operation: –25 to +50°C (without freezing), Storage: –40 to +70°C (without freezing) Vibration Resistance 10 to 55Hz, 98m/sec2 (10G) conforming to IEC6068-2-6 Shock Resistance 980m/sec2 (100G) conforming to IEC6068-2-7 Mechanical Life Momentary pushbuttons: 5,000,000 (900 operations per hour), All other switches: 500,000 800-262-IDEC (4332) • USA & Canada Circuit Breakers 40 A (40 ms) Rated Insulation Voltage Terminal Blocks Maximum Inrush Current Contactors Rated Operational Characteristics AC-15: A600 or Ue = 250V, le = 3A (NO, NC, NO-EM, NC-LB) DC-13: P600 or Ue = 125V, le = 1.1A (NO, NC) DC-13: Q600 or Ue = 125V, le = 0.9A (NO-EM, NC-LB) Timers Specifications 1705151132 Relays & Sockets IDEC’s HW switches are “The best engineered switch in the world” for a reason. Carrying the CE mark, UL, CSA, CCC (Chinese), and TUV approvals, these switches are designed for use in almost any part of the world. 609 Switches & Pilot Devices Timers Conforming to Standards EN60947-1, EN60947-5-1, VDE0660-200, UL508, CSA C22-2 No.14 Approvals Contact Ratings Standards & Approvals File No. E68961 Characteristics Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series File No. LR92374 Registration No. R9551089 (E-stops) Registration No. R50054316 (Dual Pushbuttons) Registration No. J9650511 (Pilot Lights) Registration No. J9551458 (all other switches) Certificate No. 2005010305145656 CSA: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) UL: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) TÜV: pushbuttons and selector switches: A600=P600 (NO, NC)/Q600 (NO-EM, NC-LB) pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) Electric Shock Protection Class 0 conforming to IEC60536 Degree of Protection (conforming to IEC60529 and UL50) UL Type 1, 4X, 12, 13 1 IP65 (from front of the panel) IP20 (Type HW-F contact block) Pollution Degree (conforming to IEC60947-1) 3 for switches not using a transformer, 2 for switches using a transformer External Short-Circuit Protection 10A 250V fuse conforming to IEC60269-1 Terminal Referencing Conforming to CENELEC EN50005 Pushbuttons Illuminated Pushbuttons Selector Switches Illuminated Selector Switches Pushbutton Selectors Contact Block Type HW-C/HW-F /HW-G Rated Insulation Voltage 600V Rated Continuous Current 10A Contact Ratings by Utilization Category IEC 60947-5-1 AC-15 (A600) DC-13 (P600) Operational Voltage Operational Current AC 50/60 Hz DC 24V 48V 50V 110V 220V 440V AC-12 Control of resistive loads & solid state loads 10A — 10A 10A 6A 2A AC-15 Control of electromagnetic loads (> 72VA) 10A — 7A 5A 3A 1A DC-12 Control of resistive loads & solid state loads 8A 5A — 2.2A 1.1A — DC-13 Control of electromagnets 5A 2A — 1.1A 0.6A — For dimensions, see page 660. Note 1. Except for HW[]F and HW2B LED Lamp Ratings (LSTD Type) Model LSTD-6k LSTD-1k LSTD-2k LSTD-H2k LSTD-M4k Rated Voltage 6V AC/DC 12V AC/DC 24V AC/DC 120V AC 240V AC Voltage Range 6V AC/DC ±10% 12V AC/DC ±10% 24V AC/DC ±10% 120V AC ±5% 240V AC ±5% Contactors Lamp Base Current Draw BA9S/13 AC A, R, W: G, S: 17mA 8mA 11mA 11mA 10mA 10mA DC A, R, W: G, S: 14mA 5.5mA 10mA 10mA – – Color Code A (amber), G (green), R (red), S (blue), W (white) Lamp Base Color Same as illumination color Terminal Blocks Voltage Marking Life (reference value) Die stamped on the base Approx. 50,000 hours (The luminance reduces to 50% the initial intensity when used on complete DC.) A, R, W Circuit Breakers Internal Circuit A, R, W In place of k, specify the Lens/LED Color Code. G, S LED Chip LED Chip LED Chip Protection Diode Protection Protection DiodeDiode Zener Diode Zener Diode Zener Diode 610 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Non-Illuminated Round Pushbuttons (Assembled) Signaling Lights Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-M1-j HW4B-M1-j HW1B-M2-j HW4B-M2-j 1NO HW1B-M1F10-j HW4B-M1F10-j HW1B-M2F10-j HW4B-M2F10-j 1NC HW1B-M1F01-j HW4B-M1F01-j HW1B-M2F01-j HW4B-M2F01-j 1NO-1NC HW1B-M1F11-j HW4B-M1F11-j HW1B-M2F11-j HW4B-M2F11-j 2NO HW1B-M1F20-j HW4B-M1F20-j HW1B-M2F20-j HW4B-M2F20-j 2NC HW1B-M1F02-j HW4B-M1F02-j HW1B-M2F02-j HW4B-M2F02-j 2NO-2NC HW1B-M1F22-j HW4B-M1F22-j HW1B-M2F22-j HW4B-M2F22-j Operator Only HW1B-A1-j HW4B-A1-j HW1B-A2-j HW4B-A2-j 1NO HW1B-A1F10-j HW4B-A1F10-j HW1B-A2F10-j HW4B-A2F10-j 1NC HW1B-A1F01-j HW4B-A1F01-j HW1B-A2F01-j HW4B-A2F01-j 1NO-1NC HW1B-A1F11-j HW4B-A1F11-j HW1B-A2F11-j HW4B-A2F11-j 2NO HW1B-A1F20-j HW4B-A1F20-j HW1B-A2F20-j HW4B-A2F20-j 2NC HW1B-A1F02-j HW4B-A1F02-j HW1B-A2F02-j HW4B-A2F02-j 2NO-2NC HW1B-A1F22-j HW4B-A1F22-j HW1B-A2F22-j HW4B-A2F22-j j Button Color Code Code Black B Green G Red R Blue S White W Yellow Y In place of j, specify the Button Color Code from table below. For nameplates and accessories, see page 655 and 658. For dimensions, see page 660. For contact assembly part numbers, see page 659. All assembled part numbers in catalog include standard, fingersafe (HW-F...) contacts. 6. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 7. Operator only models include operator plus button. 8. Additional contact configurations available (up to 6 total contacts). 1. 2. 3. 4. 5. Terminal Blocks Color Contactors Maintained Round Extended Contacts Timers Momentary Relays & Sockets Round Flush Function Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 611 Switches & Pilot Devices Part Number Structure H 1 Function M 1 F 10 – R Contact Arrangement Operator M: Momentary Action A: Maintained Action Terminals 1: Flush 2: Extended F: Fingersafe Contacts C: Exposed Screw Terminals blank: Spring-up Terminals Mounting Adaptor + Safety Lever Lock Contacts Timers Spring-Up Terminal Contactors Exposed Screw Terminal 10: 1NO 01: 1NC 11: 1NO-NC 1NO 1NC HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Style 20: 2NO 02: 2NC 22: 2NO-2NC B: Black G: Green R: Red S: Blue W: White Y: Yellow Operator = Completed Unit Part Number Style Part Number HW9Z-RL HW1A-B1-j Use with notched panel cutout to prevent unit rotation. Round Extended Operators HW1A-B2-j Plastic Bezel Style Round Flush/ Extended Metal Bezel 1. In place of j, specify the Button Color Code from table. HW1B-M0 HW4B-MO j Button Color Code Part Number HW1B-A0 Safety Lever Lock Style 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Button Buttons TW-DB HW-CB2C + Round Flush Contact Block Mounting Adaptor 612 + Anti-Rotation Ring Dummy Block Style Anti-Rotation Ring Momentary Contact Blocks + Maintained + Standard Fingersafe (IP20) Terminal Blocks - Non-Illuminated Round Pushbuttons (Replacement Parts) Style Circuit Breakers B Button Colors 1: Plastic Bezel 4: Metal Bezel Contact Blocks Relays & Sockets W Bezel Signaling Lights Switches & Pilot Devices ø22mm - HW Series Part Number HW4B-AO Color Code Black B Green G Red R Blue S White W Yellow Y HW9Z-LS www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Non-Illuminated Mushroom Head Pushbuttons (Assembled) Signaling Lights Momentary ø40mm Mushroom Head Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-M3-j HW4B-M3-j HW1B-M4-j HW4B-M4-j 1NO HW1B-M3F10-j HW4B-M3F10-j HW1B-M4F10-j HW4B-M4F10-j 1NC HW1B-M3F01-j HW4B-M3F01-j HW1B-M4F01-j HW4B-M4F01-j 1NO-1NC HW1B-M3F11-j HW4B-M3F11-j HW1B-M4F11-j HW4B-M4F11-j 2NO HW1B-M3F20-j HW4B-M3F20-j HW1B-M4F20-j HW4B-M4F20-j 2NC HW1B-M3F02-j HW4B-M3F02-j HW1B-M4F02-j HW4B-M4F02-j 2NO-2NC HW1B-M3F22-j HW4B-M3F22-j HW1B-M4F22-j HW4B-M4F22-j Operator Only HW1B-A3-j HW4B-A3-j HW1B-A4-j HW4B-A4-j 1NO HW1B-A3F10-j HW4B-A3F10-j HW1B-A4F10-j HW4B-A4F10-j 1NC HW1B-A3F01-j HW4B-A3F01-j HW1B-A4F01-j HW4B-A4F01-j 1NO-1NC HW1B-A3F11-j HW4B-A3F11-j HW1B-A4F11-j HW4B-A4F11-j 2NO HW1B-A3F20-j HW4B-A3F20-j HW1B-A4F20-j HW4B-A4F20-j 2NC HW1B-A3F02-j HW4B-A3F02-j HW1B-A4F02-j HW4B-A4F02-j 2NO-2NC HW1B-A3F22-j HW4B-A3F22-j HW1B-A4F22-j HW4B-A4F22-j j Button Color Code Momentary B Contacts Plastic Bezel Green G Operator Only HW1B-M5-j* Red R 1NO HW1B-M5F10-j* Blue S 1NC HW1B-M5F01-j* White W 1NO-1NC HW1B-M5F11-j* 2NO HW1B-M5F20-j* Yellow Y 2NC HW1B-M5F02-j* 2NO-2NC HW1B-M5F22-j* 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1705151132 Code Black In place of j, specify the Button Color Code from table. *60mm mushroom available only in red, green, black, and yellow. For nameplates and accessories, see page 655 and 658. For dimensions, see page 660. For contact assembly part numbers, see page 659. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 7. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 8. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 9. Operator only models include operator plus button. 10. Additional contact configurations available (up to 6 total contacts). 1. 2. 3. 4. 5. 6. Terminal Blocks Function Color ø60mm Mushroom Head Contactors Contacts Timers Maintained Relays & Sockets ø29mm Mushroom Head Function 613 Switches & Pilot Devices Part Number Structure H 1 B - M 3 F 10 – R Button Colors 1: Plastic Bezel 4: Metal Bezel Function (Not available for 60mm mushroom) 3: ø29mm Mushroom 4: ø40mm Mushroom 5: ø60mm Mushroom Terminals F: Fingersafe Contacts C: Exposed Screw Terminals blank: Spring-up Terminals 10: 1NO 01: 1NC 11: 1NO-NC Mounting Adaptor + Safety Lever Lock Contact Blocks Contacts Timers Spring-Up Terminal Contactors Exposed Screw Terminal + Anti-Rotation Ring + Operator + Button Safety Lever Lock 1NO 1NC HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Dummy Block TW-DB Style Style HW9Z-LS ø29mm Mushroom Cap Part Number HW1A-B3-j Anti-Rotation Ring Appearance Part Number ø40mm Mushroom Cap HW9Z-RL HW1A-B4-j Operators Style Plastic Bezel ø29mm Mushroom ø40mm Mushroom HW1B-M0L Ø60mm Jumbo Mushroom Maintained HW-CB2C HW1B-A0L Momentary Part Number 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Completed Unit Buttons Metal Bezel HW4B-MOL Contact Block Mounting Adaptor Style = Part Number Momentary + Standard Fingersafe (IP20) Terminal Blocks 20: 2NO 02: 2NC 22: 2NO-2NC Non-Illuminated Mushroom Head Pushbuttons (Replacement Parts) Style Circuit Breakers B: Black G: Green R: Red S: Blue W: White Y: Yellow Contact Arrangement Operator M: Momentary Action A: Maintained Action (Not available for 60mm jumbo mushroom pushbutton.) Contact Blocks Relays & Sockets W Bezel Signaling Lights Switches & Pilot Devices ø22mm - HW Series HW1B-M5-j* HW4B-AOL 1. In place of j, specify the Button Color Code from table. j Button Color Code Color Code Color Code Black B Blue S Green G White W R Yellow Y Red HW1B-M5 available only in black, red, green and yellow. – 1. *60mm mushroom operator includes non-removable button (available in red, black, green and yellow only). 2. For nameplates and accessories, see page 655 and 658. 3. For dimensions, see page 660. 614 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Non-Illuminated Square Pushbuttons (Assembled) Signaling Lights Plastic Bezel Operator Only HW2B-M1-j HW2B-M2-j 1NO HW2B-M1F10-j HW2B-M2F10-j 1NC HW2B-M1F01-j HW2B-M2F01-j Momentary 1NO-1NC HW2B-M1F11-j HW2B-M2F11-j 2NO HW2B-M1F20-j HW2B-M2F20-j 2NC HW2B-M1F02-j HW2B-M2F02-j 2NO-2NC HW2B-M1F22-j HW2B-M2F22-j Operator Only HW2B-A1-j HW2B-A2-j 1NO HW2B-A1F10-j HW2B-A2F10-j Maintained 1NC HW2B-A1F01-j HW2B-A2F01-j 1NO-1NC HW2B-A1F11-j HW2B-A2F11-j 2NO HW2B-A1F20-j HW2B-A2F20-j 2NC HW2B-A1F02-j HW2B-A2F02-j 2NO-2NC HW2B-A1F22-j HW2B-A2F22-j j Button Color Code Code Black B Green G Red R Blue S White W Yellow Y In place of j, specify the Button Color Code from table. For nameplates and accessories, see page 655 and 658. For dimensions, see page 660. For contact assembly part numbers, see page 659. Square pushbuttons available in plastic bezel only. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW2B-M1F11-R becomes HW1B-M111-R). 8. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 9. Operator only model includes operator and button. 10. Additional contact configurations available (up to 6 total contacts). 1. 2. 3. 4. 5. 6. 7. Terminal Blocks Color Contactors Square Extended Plastic Bezel Timers Square Flush Contacts Relays & Sockets Function Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 615 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Part Number Structure H W 2 B - M 1 F 10 – R Button Colors Function Contact Arrangement Operator 1: Flush 2: Extended Signaling Lights M: Momentary Action A: Maintained Action 10: 1NO 01: 1NC 11: 1NO-NC Terminals F: Fingersafe Contacts C: Exposed Screw Terminals blank: Spring-up Terminals 20: 2NO 02: 2NC 22: 2NO-2NC B: Black G: Green R: Red S: Blue W: White Y: Yellow Non-Illuminated Square Pushbuttons (Replacement Parts) Mounting Adaptor + + Safety Lever Lock + Anti-Rotation Ring + Operator + Button = Completed Unit Relays & Sockets Contact Blocks Contact Blocks Timers Style Safety Lever Lock Contacts 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 Spring-Up Terminal HW-G10R (early make) HW-G01R (late break) Style Buttons Part Number Style Part Number Square Flush HW9Z-LS HW2A-B1-j Anti-Rotation Ring Appearance Part Number Square Extended HW2A-B2-j HW9Z-RL HW-C01 HW-C10R (early make) HW-C01R (late break) Circuit Breakers Terminal Blocks Dummy Block TW-DB Contact Block Mounting Adaptor Style Part Number HW-CB2C 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. 616 Use with notched panel cutout to prevent unit rotation. Operators Plastic Bezel Style Square Flush Extended Momentary HW-C10 HW2B-M0 Maintained Contactors Exposed Screw Terminal HW2B-A0 1. In place of j, specify the Button Color Code from table. j Button Color Code Color Code Color Code Black B Blue S Green G White W Red R Yellow Y 2. For nameplates and accessories, see pages 655 and 658. 3. For dimensions, see page 660. www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Non-Illuminated E-Stop Pushbuttons (Assembled) Signaling Lights Ø40mm Head Pushlock Turn Reset Contacts Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-V3j† HW4B-V3j† HW1B-V4j† HW4B-V4j† 1NO HW1B-V3F10-j† HW4B-V3F10-j† HW1B-V4F10-j† HW4B-V4F10-j† 1NC HW1B-V3F01-j† HW4B-V3F01-j† HW1B-V4F01-j† HW4B-V4F01-j† 1NO-1NC HW1B-V3F11-j† HW4B-V3F11-j† HW1B-V4F11-j† HW4B-V4F11-j† 2NO HW1B-V3F20-j† HW4B-V3F20-j† HW1B-V4F20-j† HW4B-V4F20-j† 2NC HW1B-V3F02-j† HW4B-V3F02-j† HW1B-V4F02-j† HW4B-V4F02-j† Relays & Sockets Ø29mm Head Pushlock Turn Reset Timers Ø40mm Head EMO Pushlock Turn Reset Ø40mm Head Pushlock Key Reset Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-V4R-EMO-2* HW4B-V4R-EMO-2* HW1B-X4R* HW4B-X4R* 1NO HW1B-V4F10-R-EMO-2* HW4B-V4F10-R-EMO-2* HW1B-X4F10-R* HW4B-X4F10-R* 1NC HW1B-V4F01-R-EMO-2* HW4B-V4F01-R-EMO-2* HW1B-X4F01-R* HW4B-X4F01-R* 1NO-1NC HW1B-V4F11-R-EMO-2* HW4B-V4F11-R-EMO-2* HW1B-X4F11-R* HW4B-X4F11-R* 2NO HW1B-V4F20-R-EMO-2* HW4B-V4F20-R-EMO-2* HW1B-X4F20-R* HW4B-X4F20-R* 2NC HW1B-V4F02-R-EMO-2* HW4B-V4F02-R-EMO-2* HW1B-X4F02-R* HW4B-X4F02-R* Operator Only HW1B-V5R* 1NO HW1B-V5F10-R* 1NC HW1B-V5F01-R* 1NO-1NC HW1B-V5F11-R* 2NO HW1B-V5F20-R* 2NC HW1B-V5F02-R* 1705151132 1. * Available in Red only. 2. † Available in red or yellow. Insert color code in place of j (R: Red, Y: Yellow). 2. For accessories, see page 658. 3. For dimensions, see page 660. 5. For nameplates and shrouds, see page 659. 4. For contact assembly part numbers, see page 659. 7. All HW series E-stops comply with EN60947-5-5, the IEC “E-Stop Addendum to the Low Voltage Directive,” this includes “tamper proof” operation whereby a change of contact state is not possible by “teasing” or “floating” the operator. 8. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 9. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 10. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 11. Operator only models include operator and button. 12. Additional contact configurations available (up to 6 total contacts). 800-262-IDEC (4332) • USA & Canada Circuit Breakers Plastic Bezel Terminal Blocks ø60mm Head Pushlock Turn Reset Contacts Contactors Contacts 617 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Part Number Structure H B – V 3 F 10 – R – EMO-2 Engraved Button* EMO-2: EMO switch 1: Plastic Bezel 4: Metal Bezel Function (not available for 60mm V: Pushlock Turn Reset X: Pushlock Key Reset Signaling Lights *Option available for red EMO E-Stop only Operator 3: ø29mm Head 4: ø40mm Head 5: ø60mm Head Button Colors Contact Arrangement Terminals F: Fingersafe C: Exposed Screw blank: Springup 10: 1NO 01: 1NC 11: 1NO-NC R: Red Y: Yellow 20: 2NO 02: 2NC 22: 2NO-2NC Note: some switches only available in red. Non-Illuminated E-Stop Pushbuttons (Replacement Parts) Contact Blocks Relays & Sockets 1 Bezel jumbo mushroom) + Mounting Adaptor + Contact Blocks Style Contact Blocks 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Spring-Up Terminal Safety Lever Lock + Anti-Rotation Ring + Safety Lever Lock Contacts Exposed Screw Terminal Contactors Timers W Dummy Block Style Operator = Completed Unit Anti-Rotation Ring Part Number Appearance Part Number HW9Z-LS HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Style Plastic ø29mm Head Pushlock Turn Reset ø40mm Head Pushlock Turn Reset TW-DB Metal red HW1B-V3R HW4B-V3R yellow HW1B-V3Y HW4B-V3Y red HW1B-V4R HW4B-V4R yellow HW1B-V4Y HW4B-V4Y ø40mm Head EMO Pushlock Turn Reset* Circuit Breakers Terminal Blocks Contact Block Mounting Adaptor Style Part Number HW1B-V4R-EMO-2 HW4B-V4R-EMO-2 HW1B-X4R HW4B-X4R HW1B-V5R – ø40mm Head Pushlock Key Reset* HW-CB2C 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. ø60mm Head Pushlock Turn Reset* 1. *Available in red only. 2. All E-Stop buttons are not removable from the operator. 618 www.IDEC.com Note: Determine mounting centers to ensure proper spacing. 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Push Pull & Unibody E-Stop Pushbuttons (Assembled) Signaling Lights Contacts Plastic Bezel Metal Bezel Contacts Plastic Bezel HW1E-BV4F11-R HW1B-Y2R HW4B-Y2R Operator Only (Yellow) HW1B-Y2Y HW4B-Y2Y 2NC HW1E-BV4F02-R 1NO HW1B-Y2F10-j† HW4B-Y2F10-j† 1NC HW1B-Y2F01-j† HW4B-Y2F01-j† 1NO-2NC HW1E-BV412R-TK2093-1 1NO-1NC HW1B-Y2F11-j† HW4B-Y2F11-j† 2NC HW1B-Y2F02-j† HW4B-Y2F02-j† 2NO HW1B-Y2F20-j† HW4B-Y2F20-j† Timers Operator Only (Red) 1NO-1NC l Full Voltage Code Unibody Illuminated E-Stops* Contacts LED Incandescent HW1E-LV4F11QD-R-l HW1E-LV4F11Q-R-l 2NC HW1E-LV4F02QD-R-l HW1E-LV4F02Q-R-l 2NC (with push-on illumination) HW1E-TV4F02QD-R-l HW1E-TV4F11Q-R-l 1NO-1NC (with push-on illumination ) HW1E-TV4F11QD-R-l HW1E-TV4F02Q-R-l Terminal Numbering (Unibody only) Voltage Code 6VAC/DC 6V Models Terminal Number 12VAC/DC 12V 1NO-1NC NO = 13/14, NC = 11/12 24VAC/DC 24V 2NC NC = 11/12, NC = 21/22 120V AC* 120V Lamp + = X2, Lamp - = X1 240V AC* 240V HW1E-L HW1E-T Contactors 1NO-1NC Relays & Sockets ø40mm Unibody Pushlock Turn Reset* ø40mm Head Push–Pull *LED only. 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1705151132 Terminal Blocks 1. * Available in Red only. 2. † Available in red or yellow. Insert color code in place of j (R: Red, Y: Yellow). 3. In place of l, specify Full Voltage Code. 4. With single unit construction, the positive action contacts are integrated in the body of the switch. This provides an extra degree of safety and reliability for critical emergency stop functions. 5. In the illuminated version, the light is independent of the switch action (except push-on LED model). 6. For accessories, see page 658. 7. For dimensions, see page 660. 8. For nameplates and shrouds, see page 658. 9. For contact assembly part numbers, see page 658. 10. All HW Series E-Stop operators include non-removable color caps. 11. All HW series E-Stops comply with EN60947-5-5, the IEC “E-Stop Addendum to the Low Voltage Directive,” this includes “tamper proof” operation whereby a change of contact state is not possible by “teasing” or “floating” the operator. 12. All HW series E-Stop switches comply with SEMI S2 standards. 13. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 14. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 15. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 16. Additional contact configurations available (up to 6 total contacts). 619 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Part Number Structure H W 1 E – LV4 F 11 – Q D R – 24V Bezel 1: Plastic Bezel 4: Metal Bezel* (*not available for HW1E unibody) Full Voltage Code Button Colors (Illuminated E-Stop) Function Lamp Code B: Push Pull E: Pushlock Turn Reset D: LED blank: Incandescent Illumination Signaling Lights BV4: Non-illuminated (unibody style) LV4: Illuminated TV4: Illuminated Push On Y2: Non-illuminated Push Pull E-Stop Contacts 11: 02: 10: 20: 1NO-1NC 2NC 1NO 2NO R: Red Y: Yellow* 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120VC AC* 240V: 240V AC* (*only available in 40mm Push Pull E-Stop) Illumination Circuit *LED only blank: 40mm Push Pull & Non-illuminated Unibody E-Stop Q: Illuminated Unibody E-Stop Illuminated & Non-Illuminated E-Stop Pushbuttons (Replacement Parts) + Safety Lever Lock Contact Blocks Timers Style 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 Contactors Exposed Screw Terminal + Operator Style Part Number HW-C01R (late break) Completed Unit Anti-Rotation Ring Appearance Part Number HW9Z-RL HW-CB2C 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock HW-C10R (early make) = Style Use with notched panel cutout to prevent unit rotation. Operators Style Part Number ø40mm Head Push-Pull Plastic HW1B-Y2R Part Number Metal HW4B-Y2R HW9Z-LS Plastic HW1B-Y2Y TW-DB Metal 1. There are no replacement parts for the HW1E unibody E-Stop. 2. For illuminated unibody E-Stop, see page 659 for replacement lens. HW4B-Y2Y All E- Stop Buttons are not removable from the operator. Circuit Breakers Terminal Blocks Dummy Block Anti-Rotation Ring Contact Block Mounting Adaptor Contacts Spring-Up Terminal + red Mounting Adaptor yellow + Relays & Sockets Contact Blocks 620 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices E-Stop Stations Signaling Lights Relays & Sockets 29mm Pushlock Turn Reset 40mm Pushlock Turn Reset Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel 1NO-1NC FB1W-HW1B-V311R FB1W-HW4B-V311R FB1W-HW1B-V411R FB1W-HW4B-V411R 2NC FB1W-HW1B-V302R FB1W-HW4B-V302R FB1W-HW1B-V402R FB1W-HW4B-V402R Contacts Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel 1NO-1NC FB1W-HW1B-Y211R FB1W-HW4B-Y211R FB1W-HW1B-X411R FB1W-HW4B-X411R 2NC FB1W-HW1B-Y202R FB1W-HW4B-Y202R FB1W-HW1B-X402R FB1W-HW4B-X402R Timers Contacts 40mm Push-Pull Reset 40mm Pushlock Key Reset Contactors Terminal Blocks 40mm EMO Pushlock Turn Reset Contacts Plastic Bezel Metal Bezel 1NO-1NC FB1W-HW1B-V411R-EMO-2 FB1W-HW4B-V411R-EMO-2 2NC FB1W-HW1B-V402R-EMO-2 FB1W-HW4B-V402R-EMO-2 1. Maximum of two contact blocks. 2. Box is supplied with yellow top and black bottom only. Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 621 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Jumbo Dome Pilot Lights (Assembled) Operator Only HW1P-5Q0 Full Voltage 24V AC/DC HW1P-5Q4-k Operator Only HW1P-5Q7* Full Voltage 24V AC/DC HW1P-5Q7-k Actual Size LED Jumbo Dome Signaling Lights Plastic Bezel Relays & Sockets Incandescent 1. In place of k, specify the Lens/LED Color Code. 2. *Incandescent operator comes with bulb. 3. Available with spring-up terminals in 24V only. 4. For nameplates and accessories, see page 655 and 658. 5. For dimensions, see page 660. Contactors Timers k Lens/LED Color Code Color Code Amber A Green G Red R Blue S White PW Yellow Y Jumbo Dome Replacement Parts Item Appearance Description Part Number Lens HW1A-P5k Polycarbonate Lens Terminal Blocks LED Diffusing Lens* HW9Z-PP5C LED Lamps LED Lamp Jumbo Dome LSTDB-2k 1. In place of k, specify the Lens/LED Color Code. 2. *Diffusing lens for LED models only. 3. Use white LED for yellow lens. Circuit Breakers Lamp Ratings Part Number LED LSTDB-2 Incandescent LSB-2 622 Operating Voltage 24V AC/DC ±10% Rated Current Power Consumption 15mA 0.36W 150mA 3.6W *Use PW for LED module, use C for lens. www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Pilot Lights (Assembled) Signaling Lights Dome Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1P-1FQ0-k HW4P-1FQ0-k HW1P-2FQ0-k HW4P-2FQ0-k Full Voltage HW1P-1FQm-k-l HW4P-1FQm-k-l HW1P-2FQm-k-l HW4P-2FQm-k-l 120V AC HW1P-1FH2m-k HW4P-1FH2m-k HW1P-2FH2m-k HW4P-2FH2m-k 240V AC HW1P-1FM4m-k HW4P-1FM4m-k HW1P-2FM4m-k HW4P-2FM4m-k 480V AC HW1P-1FT8m-k HW4P-1FT8m-k HW1P-2FT8m-k HW4P-2FT8m-k 110V DC HW1P-1D2D-k – HW1P-2D2D-k – Transformer DC-DC Converter* Relays & Sockets Round Flush Plastic Bezel Timers Square Flush Plastic Bezel HW2P-1FQ0-k Full Voltage HW2P-1FQm-k-l Transformer DC-DC Converter* 120V AC HW2P-1FH2m-k 240V AC HW2P-1FM4m-k 480V AC HW2P-1FT8m-k 110V DC HW2P-1D2D-k k Lens/LED Color Code Contactors Operator Only l Full Voltage Code m Lamp Type Code Code Voltage Code Lamp Code Amber A 6VAC/DC 6V Incandescent Blank Green G 12VAC/DC 12V LED D Red R 24VAC/DC 24V Blue S 120V AC (LED only) 120V White W 240V AC (LED only) 240V Yellow Y 2. In place of lspecify the Full Voltage Code from table below. Terminal Blocks Color 1. In place of k, specify the Lens/LED Color Code from table below. 3. In place of m specify Lamp Type Code from table below. 4. *DC-DC convertor voltage input from 90-140V DC, comes with spring-up terminals only. 5. DC-DC converter models with LED lamps only. 6. For nameplates and accessories, see page 655 and 658. 7. For dimensions, see page 660. 8. Pilot lights do not come with anti-rotation ring. 9. Operator models come with operator and lens. 10. Yellow pilot light comes with white LED. Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 623 Switches & Pilot Devices Part Number Structure H Relays & Sockets 1 P – 1: Round Plastic 2: Square Plastic 4: Round Metal F Q D – R – 12V Operator 1: Flush 2: Dome Illumination Circuit Lens/LED Colors Q: Full Voltage H2: 120V AC Transformer M4: 240V AC Transformer T8: 480V AC Transformer D2: DC-DC Converter + A: Amber G: Green R: Red S: Blue W: White Y: Yellow Lamp Type Code D: LED Blank: Incandescent *LED only Lamp + Operator + Lens = Completed Unit (not applicable for full voltage units) Transformer Units LED/Incandescent (6V secondary voltage) Operators Voltage Part Number 120V AC HW-FH20 HW-MH20* 240V AC HW-FM40 HW-MM40* 480V AC HW-FT80 HW-RT80* 110V DC** Style Type Plastic Bezel Metal Bezel Round Flush Standard HW1P-1FQ0 HW4P-1FQ0 Spring-up Terminals HW1P-1Q0 HW4P-1Q0 Standard HW1P-10 HW4P-10 Spring-up Terminals HW1P-100 – Standard HW1P-2FQ0 HW4P-2FQ0 Spring-up Terminals HW1P-2Q0 HW4P-2Q0 Standard HW1P-20 HW4P-20 Spring-up Terminals HW1P-200 – Standard HW2P-1FQ0 – Spring-up Terminals HW2P-1Q0 Standard HW2P-10 – Spring-up Terminals HW2P-100 – Dome Full Voltage Transformer Square Flush Lamps Style Voltage LED Terminal Blocks Incandescent Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. Full Voltage Transformer HW-RD0* 1. *With spring-up terminals - to use spring-up terminal type, must use transformer type operator designed for spring-up transformer. 2. ** DC-DC converter voltage input from 90-140V DC. Full Voltage Transformer 1. Transformer type requires separate transformer & lamp. Must select correct transformer bases on standard or spring up terminal type. Use 6V lamps or LEDs. 2. Full voltage type only requires lamp. Lenses Style l Lens Color Code Part Number Round/ Flush Dome HW1A-P1-l HW1A-P2-l k LED Color Code Circuit Breakers (full voltage units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120V AC* 240V: 240V AC* Pilot Lights (Replacement Parts) Style Contactors 2 Lamp Voltage Transformer* Timers W Bezel Signaling Lights Switches & Pilot Devices ø22mm - HW Series Code Color Code Amber A Blue S Green G White W R Code Amber A Green G Red R Blue S White W Yellow Y For yellow lens use white LED. Color Red Color Square/ Flush HW2A-P1-l In place of l, specify the Lens Color Code. For yellow lens use white LED. 624 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Illuminated Round Pushbuttons (Assembled) Signaling Lights Illuminated Full Voltage Pushbuttons Extended w/ Full Shroud Metal Bezel Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only 1NO 1NC 1NO-1NC 2NO HW1L-M1-k HW1L-M1F10Qm-k-l HW1L-M1F01Qm-k-l HW1L-M1F11Qm-k-l HW1L-M1F20Qm-k-l HW4L-M1-k HW4L-M1F10Qm-k-l HW4L-M1F01Qm-k-l HW4L-M1F11Qm-k-l HW4L-M1F20Qm-k-l HW1L-M2-k HW1L-M2F10Qm-k-l HW1L-M2F01Qm-k-l HW1L-M2F11Qm-k-l HW1L-M2F20Qm-k-l HW4L-M2-k HW4L-M2F10Qm-k-l HW4L-M2F01Qm-k-l HW4L-M2F11Qm-k-l HW4L-M2F20Qm-k-l HW1L-MF2-k HW1L-MF2F10Qm-k-l HW1L-MF2F01Qm-k-l HW1L-MF2F11Qm-k-l HW1L-MF2F20Qm-k-l HW4L-MF2-k HW4L-MF2F10Qm-k-l HW4L-MF2F01Qm-k-l HW4L-MF2F11Qm-k-l HW4L-MF2F20Qm-k-l Operator Only 1NO 1NC 1NO-1NC 2NO HW1L-A1-k HW1L-A1F10Qm-k-l HW1L-A1F01Qm-k-l HW1L-A1F11Qm-k-l HW1L-A1F20Qm-k-l HW4L-A1-k HW4L-A1F10Qm-k-l HW4L-A1F01Qm-k-l HW4L-A1F11Qm-k-l HW4L-A1F20Qm-k-l HW1L-A2-k HW1L-A2F10Qm-k-l HW1L-A2F01Qm-k-l HW1L-A2F11Qm-k-l HW1L-A2F20Qm-k-l HW4L-A2-k HW4L-A2F10Qm-k-l HW4L-A2F01Qm-k-l HW4L-A2F11Qm-k-l HW4L-A2F20Qm-k-l HW1L-AF2-k HW1L-AF2F10Qm-k-l HW1L-AF2F01Qm-k-l HW1L-AF2F11Qm-k-l HW1L-AF2F20Qm-k-l HW4L-AF2-k HW4L-AF2F10Qm-k-l HW4L-AF2F01Qm-k-l HW4L-AF2F11Qm-k-l HW4L-AF2F20Qm-k-l Timers Plastic Bezel Momentary Extended Maintained Flush Relays & Sockets Contacts Illuminated Transformer Pushbuttons Plastic Bezel Metal Bezel Momentary Extended w/ Full Shroud Metal Bezel Operator Only 1NO-1NC 2NO HW1L-M1-k HW1L-M1F11lm-k HW1L-M1F20lm-k HW4L-M1-k HW4L-M1F11lm-k HW4L-M1F20lm-k HW1L-M2-k HW1L-M2F11lm-k HW1L-M2F20lm-k HW4L-M2-k HW4L-M2F11lm-k HW4L-M2F20lm-k HW1L-MF2-k HW4L-MF2-k HW1L-MF2F11lm-k HW4L-MF2F11lm-k HW1L-MF2F20lm-k HW4L-MF2F20lm-k Operator Only 1NO-1NC 2NO HW1L-A1-k HW1L-A1F11lm-k HW1L-A1F20lm-k HW4L-A1-k HW4L-A1F11lm-k HW4L-A1F20lm-k HW1L-A2-k HW1L-A2F11lm-k HW1L-A2F20lm-k HW4L-A2-k HW4L-A2F11lm-k HW4L-A2F20lm-k HW1L-AF2-k HW1L-AF2F11lm-k HW1L-AF2F20lm-k 2. In place of lspecify Voltage Code from table. Color Code Amber A Green G Red R Blue S White W Yellow Y Yellow LED not available. Use white LED for yellow lens. l Voltage Code HW4L-AF2-k HW4L-AF2F11lm-k HW4L-AF2F20lm-k m Lamp Code Full Voltage Models Transformer Models Voltage Code Voltage Code 6V AC/DC 6V 120V AC H2 12V AC/DC 12V 240V AC M4 24V AC/DC 24V 480V AC T8 120V AC (LED only) 120V 240V AC (LED only) 240V 800-262-IDEC (4332) • USA & Canada Metal Bezel Lamp Code Incandescent Blank LED D Circuit Breakers 3. In place of m specify Lamp Code from table. 4. Light independent of switch position. 5. For replacement part numbers, see page 626. 6. For nameplates and accessories, see page 655. and 658. 7. For dimensions, see page 660. 8. For contact assembly part numbers, see page 659. 9. Full voltage and transformer models use the same operator. 10. Additional contact configurations available (up to 6 total contacts). 11. Yellow pushbutton comes with white LED. k Lens/LED Color Code Plastic Bezel Terminal Blocks 1. In place of k, specify Lens/LED Color Code from table. 1705151132 Extended Plastic Bezel Maintained Flush Contactors Contacts 625 Switches & Pilot Devices Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series H Bezel 1: Plastic 4: Metal Contactors 1 L Lens Color Operator M: Momentary A: Maintained 1F: Flush 2F: Extended F2F: Extended w/ shroud A: Amber S: Blue G: Green W: White R: Red Y: Yellow Contact Arrangement 10: 01: 11: 20: 1NO 1NC 1NO-1NC 2NO Illumination Circuit Q: Full Voltage H2: Transformer 120V AC M4: Transformer 240V AC T8: Transformer 480V AC Lamp Code D: LED Blank: Incandescent (full voltage units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120VC AC* 240V: 240V AC* *LED only Illuminated Round Pushbuttons (Replacement Parts) Transformer* + Contact Blocks + Lead Holder + Mounting Adaptor + Safety Lever Lock + Lamp + Anti-Rotation Ring + Operator + Lens Completed Unit = *Transformer not needed with full voltage models. Lamp Circuit Components Contact Blocks Style Description Lead Holder For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. Dummy Block with Full Voltage Adaptor Transformer Unit (6V secondary voltage) Part Number HW-DA1FB Exposed HW-DA1B Spring Up HW-GA1 Fingersafe TW-DA1FB Exposed TW-DA1B 120VAC 240VAC 480VAC Fingersafe TW-F126B TW-F246B TW-F486B 120V 240V 480V Spring Up HW-T126 HW-T246 HW-L486 Exposed TW-T126B TW-T246B TW-T486B For use with odd number of contacts. For use with even number of contacts. 110VDC Plastic Bezel Metal Bezel Momentary HW1L-M0 HW4L-M0 Maintained HW1L-A0 HW4L-A0 Momentary HW1L-MF0 HW4L-MF0 Maintained HW1L-AF0 HW4L-AF0 Style Extended with Full Shroud 626 Contacts 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F10R (early make) HW-F01 HW-F01R (late break) Spring-Up Terminal HW-G10 HW-G10R (early make) HW-G01 HW-G01R (late break) Exposed Screw Terminal HW-C10 HW-C10R (early make) HW-C01 HW-C01R (late break) 1. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 2. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 3. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. Contact Block Mounting Adaptor Style Part Number Anti-Rotation Ring Part Number Appearance HW-CBL 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Style HW9Z-RL Use with notched panel cutout to prevent unit rotation. Lamps Style Part Number HW-L16D HW-GA1 “Dummy Block with full voltage adaptor” does not require the use of HW-LH3. Round Flush/ Extended Style HW-LH3 Fingersafe 120V 240V 480V DC-DC Converter Terminals Operators Circuit Breakers Part Number Structure – M 1F 10 Q D – G – 12V Lamp Voltage Function Full Voltage Adaptor Terminal Blocks W HW9Z-LS LED Lenses Style Round Flush Part Number HW1A-L1-k Round Extended HW1A-L2-k In place of k, specify the Lens Color Code from previous page. www.IDEC.com Incandescent Voltage Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Yellow LED not available, use white LED when using yellow lens. 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Illuminated Mushroom & Square Pushbuttons (Assembled) Signaling Lights Full Voltage Transformer Metal Bezel Plastic Bezel HW1L-M4-k HW4L-M4-k HW2L-M1-k 1NO HW1L-M4F10Qm-k-l HW4L-M4F10Qm-k-l HW2L-M1F10Qm-k-l 1NC HW1L-M4F01Qm-k-l HW4L-M4F01Qm-k-l HW2L-M1F01Qm-k-l 1NO-1NC HW1L-M4F11Qm-k-l HW4L-M4F11Qm-k-l HW2L-M1F11Qm-k-l 2NO HW1L-M4F20Qm-k-l HW4L-M4F20Qm-k-l HW2L-M1F20Qm-k-l Operator Only HW1L-A4-k HW4L-A4-k HW2L-A1-k 1NO HW1L-A4F10Qm-k-l HW4L-A4F10Qm-k-l HW2L-A1F10Qm-k-l 1NC HW1L-A4F01Qm-k-l HW4L-A4F01Qm-k-l HW2L-A1F01Qm-k-l 1NO-1NC HW1L-A4F11Qm-k-l HW4L-A4F11Qm-k-l HW2L-A1F11Qm-k-l 2NO HW1L-A4F20Qm-k-l HW4L-A4F20Qm-k-l HW2L-A1F20Qm-k-l 1NO-1NC HW1L-M4F11lm-k HW4L-M4F11lm-k Momentary HW2L-M1F11lm-k 2NO HW1L-M4F20lm-k HW4L-M4F20lm-k HW2L-M1F20lm-k Maintained 1NO-1NC HW1L-A4F11lm-k HW4L-A4F11lm-k HW2L-A1F11lm-k 2NO HW1L-A4F20lm-k HW4L-A4F20lm-k HW2L-A1F20lm-k 1. † Full voltage and transformer units use the same operator. 3. In place of lspecify the Voltage Code from table. 1705151132 Code Amber A Green G Red R Blue S White W Yellow Y* 1. *40mm mushroom lenses not available in yellow. 2. Yellow LED not available. Use white LED for yellow lens. 800-262-IDEC (4332) • USA & Canada m Lamp Code Full Voltage Models Transformer Models Voltage Code Voltage Code 6V AC/DC 6V 120V AC H2 12V AC/DC 12V 240V AC M4 24V AC/DC 24V 480V AC T8 120V AC (LED only) 120V 240V AC (LED only) 240V Lamp Code Incandescent Blank LED D Circuit Breakers 4. In place of m specify Lamp Type Code from table. 5. Light independent of switch position 6. For nameplates and accessories, see page 655. and 658. 7. For dimensions, see page 660. 8. For contact assembly part numbers, see page 659. 9. Additional contact configurations available (up to 6 total contacts). 10. Yellow pushbutton comes with white LED. Color l Voltage Code Terminal Blocks 2. In place of k, specify the Lens/LED Color Code from table. k Lens/LED Color Code Contactors Plastic Bezel Operator Only† Timers Contacts † Maintained Square Flush Relays & Sockets Momentary 40mm Mushroom Head 627 Switches & Pilot Devices Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series H Contactors Terminal Blocks 1 Part Number Structure – M 1 F 10 Q D – G – 12V L Lamp Voltage Bezel 1: Round Plastic 2: Square Plastic 4: Round Metal Function M: Momentary A: Maintained Lens Color Operator 1: Square Flush 4: Mushroom A: Amber S: Blue G: Green W: White R: Red Y: Yellow Contact Arrangement 10: 01: 11: 20: 1NO 1NC 1NO-1NC 2NO Illumination Circuit Q: Full Voltage H2: Transformer 120V AC M4: Transformer 240V AC T8: Transformer 480V AC Lamp Code (full voltage units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120VC AC* 240V: 240V AC* *LED only D: LED Blank: Incandescent Illuminated Mushroom & Square Pushbuttons (Replacement Parts) Transformer* + Contact Blocks + Lead Holder + Adaptor† + Safety Lever Lock + Lamp Anti-Rotation Ring + + Operator + Lens Completed Unit = *Transformer not needed with full voltage models. Lamp Circuit Components Contact Blocks Style Description Lead Holder For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. Dummy Block with Full Voltage Adaptor Full Voltage Adaptor Transformer Unit (6V secondary voltage) For use with odd number of contacts. For use with even number of contacts. 120VAC 240VAC 480VAC 120V 240V 480V 120V 240V 480V DC-DC Converter Terminals Part Number HW-DA1FB Exposed HW-DA1B Spring Up HW-GA1 Fingersafe TW-DA1FB Exposed TW-DA1B Fingersafe TW-F126B TW-F246B TW-F486B Spring Up HW-T126 HW-T246 HW-L486 Exposed TW-T126B TW-T246B TW-T486B 110VDC 628 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F10R (early make) HW-F01 HW-F01R (late break) Spring-Up Terminal HW-G10 HW-G10R (early make) HW-G01 HW-G01R (late break) Exposed Screw Terminal HW-C10 HW-C10R (early make) HW-C01 HW-C01R (late break) Contact Block Mounting Adaptor Part Number Anti-Rotation Ring Appearance 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Style Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Lamps Style LED HW9Z-LS Lenses Plastic Bezel Metal Bezel Momentary HW1L-M0L HW4L-M0L Maintained HW1L-A0L HW4L-A0L Momentary HW2L-M0 Maintained HW2L-A0 – Part Number HW-CBL HW-L16D Operators Square Contacts 1. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 2. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 3. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. Style HW-GA1 “Dummy Block with full voltage adaptor” does not require the use of HW-LH3. ø40mm Mushroom Style HW-LH3 Fingersafe Style Circuit Breakers W Style Part Number Incandescent ø40mm Mushroom Lens ALW4BLU-k* Square Flush HW2A-L1-k 1. In place of k, specify the Lens Color Code. 2. *Mushroom lens not available in yellow. www.IDEC.com Voltage Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Yellow LED not available, use white LED when using yellow lens. 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Selector Switches 2-Position (Assembled) Signaling Lights Mounting Operator Position L Handle R Operator Only Maintained L Spring Return from Right L R R Knob Lever HWnS-2T HWnS-2L HWnS-21T HWnS-21L 1 O X Knob Lever HWnS-2TF10 HWnS-2LF10 HWnS-21TF10 HWnS-21LF10 1NO1NC 1 2 O X X O Knob Lever HWnS-2TF11 HWnS-2LF11 HWnS-21TF11 HWnS-21LF11 2NO 1 2 O O X X Knob Lever HWnS-2TF20 HWnS-2LF20 HWnS-21TF20 HWnS-21LF20 2NO2NC 1 2 3 4 X O X O O X O X Knob Lever HWnS-2TF22 HWnS-2LF22 HWnS-21TF22 HWnS-21LF22 Timers 1NO n Bezel Type Type Code Plastic 1 Metal 4 Contactors Terminal Blocks 1. In place of n enter 1 for plastic bezel or 4 for metal bezel. 2. For nameplates, see page 655. 3. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 4. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1BM1F11-R becomes HW1B-M111-R). 5. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 6. Standard color for knob and lever is black. 7. Optional colors available for lever type. Must order in components. See next page for part numbers. 8. Additional contact configurations available (up to 6 total contacts). 9. For Truth Tables see page 668. Relays & Sockets Contact 2-Position Selector Switches Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 629 Switches & Pilot Devices Part Number Structure H W 1 S - 1 T F 10 Contact Arrangement 1: Plastic 4: Metal # of Positions 2: 2-Position 10: 1NO 11: 1NO-1NC 20: 2NO Handle Operator T: Knob L: Lever blank: Maintained 1: Spring Return from Right Selector Switches 2-Position (Replacement Parts) Contact Blocks + Mounting Adaptor + Safety Lever Lock Contact Blocks Style 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 Spring-Up Terminal Contactors + Style HW-C10R (early make) Terminal Blocks Completed Unit Use with notched panel cutout to prevent unit rotation. Operators Style Description TW-DB HW-CB2C Spring Return from Right Handle Plastic Bezel Metal Bezel Knob HW1S-2T HW4S-2T Lever HW1S-2 HW4S-2 Knob HW1S-21T HW4S-21T Lever HW1S-21 HW4S-21 1. Knob operator comes with black handle. 2. To order lever type, lever and inserts must be ordered separately, along with lever operator. See part numbers below. Levers & Inserts Style Part Number 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Lever Safety Lever Lock 630 = HW9Z-RL HW-C01R (late break) Part Number Lever Color Insert Part Number HW9Z-LS Operator Part Number Contact Block Mounting Adaptor Style + Maintained Dummy Block Style Anti-Rotation Ring Anti-Rotation Ring Contacts Exposed Screw Terminal Circuit Breakers 2 Bezel Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series ASWHHL-j TW-HC1-j Standard lever color is black. Standard insert color is white. www.IDEC.com j Handle/Insert Color Code Color Code Black* B Blue S Green G Red R Yellow Y White W † 1. * Lever color inserts not available in black. 2. †Lever not available in white. 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Selector Switches 3-Position (Assembled) Signaling Lights Mounting Contact 3–Position Selector Switches Operator Position L C Handle R L C L R L R C Spring Return Two-Way L R C Knob Lever HWnS-3T* HWnS-3L HWnS-31T HWnS-31L HWnS-32T HWnS-32L HWnS-33T HWnS-33L R 1 2 0 0 X 0 X X Knob Lever HWnS-3TF11 HWnS-3LF11 HWnS-31TF11 HWnS-31LF11 HWnS-32TF11 HWnS-32LF11 HWnS-33TF11 HWnS-33LF11 2NO 1 2 X 0 0 0 0 X Knob Lever HWnS-3TF20 HWnS-3LF20 HWnS-31TF20 HWnS-31LF20 HWnS-32TF20 HWnS-32LF20 HWnS-33TF20 HWnS-33LF20 2NC 1 2 0 X X X X 0 Knob Lever HWnS-3TF02 HWnS-3LF02 HWnS-31TF02 HWnS-31LF02 HWnS-32TF02 HWnS-32LF02 HWnS-33TF02 HWnS-33LF02 2NO1NC 1 2 3 X 0 0 0 0 X 0 X 0 Knob HWnS-3JTF21N1 – – – 2NO2NC 1 2 3 4 X 0 0 X 0 0 X X 0 X X 0 Knob HWnS-3TF22 HWnS-31TF22 HWnS-32TF22 HWnS-33TF22 2NO2NC 1 2 3 4 0 X X 0 0 0 X 0 X 0 0 X Knob HWnS-3STF22N9 – – – 4NO 1 2 3 4 X 0 X 0 0 0 0 0 0 X 0 X Knob 4NO 1 2 3 4 X 0 X 0 0 X 0 0 0 X 0 X Knob HWnS-3STF40N2 – – – 4NC 1 2 3 4 0 X 0 X X X X X X 0 X 0 Knob HWnS-3TF04 HWnS-31TF04 HWnS-32TF04 HWnS-33TF04 Timers 1NO1NC HWnS-3TF40 HWnS-31TF40 HWnS-32TF40 HWnS-33TF40 Type Code Plastic 1 Metal 4 Contactors n Bezel Type Terminal Blocks 7. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 8. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 9 . Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 10. Standard color for knob and lever is black. 11. Optional colors available for lever type. Must order in components. See next page for part numbers. 12. Additional contact configurations available (up to 6 total contacts). 13. For Truth Tables see page 668. 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. In place of n enter 1 for plastic bezel or 4 for metal bezel. 2. Knob operator includes black knob/lever operator includes black lever. 3. * Three position operator is available with three different cams. HWnS-3T: Maintained (standard cam) HWnS-3ST: Maintained (S cam) HWnS-3JT: Maintained (J cam) 4. Operator cams are color coded (white=standard cam, red=S cam, black =J cam). 5. For nameplates, see page 655. 6. For contact assembly part numbers, see page 659 1705151132 C Spring Return from Left Relays & Sockets Operator Only Spring Return from Right Maintained 631 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Part Number Structure H S - 3 1 T F 20 Contact Arrangement 1: Plastic 4: Metal # of Positions 3: 3-Position 11: 1NO-1NC 20: 2NO 21: 2NO-1NC 22: 2NO-2NC 40: 4NO 04: 4NC Handle Operator T: Knob L: Lever blank: Maintained 1: Spring Return from Right 2: Spring Return from Left 3: Spring Return Two Way Signaling Lights Relays & Sockets 1 Bezel Selector Switches 3-Position (Replacement Parts) Contact Blocks + Mounting Adaptor + Safety Lever Lock Contact Blocks Timers Style + Anti-Rotation Ring 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Spring-Up Terminal Dummy Block Style Style Terminal Blocks HW-CB2C Use with notched panel cutout to prevent unit rotation. Handle Plastic Bezel Metal Bezel Maintained (standard cam) Knob HW1S-3T HW4S-3T Lever HW1S-3 HW4S-3 Maintained (S cam) Knob HW1S-3ST HW4S-3ST Maintained (J cam) Knob HW1S-3JT HW4S-3JT Spring Return from Right (standard cam) Knob HW1S-31T HW4S-31T Lever HW1S-31 HW4S-31 Spring Return from Left (standard cam) Knob HW1S-32T HW4S-32T Lever HW1S-32 HW4S-32 2-Way Spring Return (standard cam) Knob HW1S-33T HW4S-33T Lever HW1S-33 HW4S-33 1. Knob operator comes with black handle. 2. Three position knob operator is available with three different cams. 3. Operator cams are color coded (white=standard cam, red=S cam, black =J cam). 4. To order lever type, lever and inserts must be ordered separately, along with lever operator. See part numbers below. Levers & Inserts Style j Handle/Insert Color Code Part Number Part Number HW9Z-LS Circuit Breakers Completed Unit Description Safety Lever Lock 632 = Operators TW-DB 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. HW9Z-RL Part Number Style Operator Part Number Contact Block Mounting Adaptor Style + Anti-Rotation Ring Contacts Exposed Screw Terminal Contactors W Lever ASWHHL-j Lever Color Insert TW-HC1-j Black* B Color Blue S Yellow Code Y Green G White W Red R † 1. * Lever color inserts not available in black. 2. †Lever not available in white. Standard lever color is black. Standard insert color is white. www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Selector Switches 4- & 5-Position (Assembled) Signaling Lights 2 3 4 Maintained 1 2 3 4 Operator Only Mounting 1 Handle Contact Mounting 5-Position Selector Switch Operator Position Knob Lever HWnS-4T HWnS-4L Operator Only 2NO2NC 1 2 3 4 X 0 0 0 0 X 0 0 O 0 X 0 O 0 0 0 Knob Lever HWnS-4TF12 HWnS-4LF12 1NO3NC 1 2 3 4 O O O O X X O O X O X O X O O X Knob Lever HWnS-4TF13N6 HWnS-4LF13N6 2NO2NC 1 2 3 4 X O O O O X O O O O X O O O O X Knob Lever HWnS-4TF22N3 HWnS-4LF22N3 X O O O 2 O X O O 3 O O O O 4 O O X O 5 O O O X Maintained 1 2 3 4 5 Knob Lever HWnS-5T HWnS-5L Knob Lever HWnS-5TF22N3 HWnS-5LF22N3 n Bezel Type Type Code Plastic 1 Metal 4 Contactors Terminal Blocks 1. In place of n enter 1 for plastic bezel or 4 for metal bezel. 2. Knob operator includes black knob/lever operator includes black lever. 3. For nameplates, see page 655. 4. For contact assembly part numbers, see page 659. 5. Five position circuit cannot be made to make five independent contact closures. 6. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 7. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 8. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 9. Standard color for knob and lever is black. 10. Optional colors available for lever type. Must order in components. See next page for part numbers. 11. Additional contact configurations available (up to 6 total contacts). 12. For Truth Tables see page 668. 1 2 3 4 1 Handle Timers 1NO2NC Operator Position Relays & Sockets Contact 4-Position Selector Switches Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 633 Switches & Pilot Devices Part Number Structure H 1 S 1: Plastic 4: Metal 4 T F 13N6 (based on desired truth table) 12: 1NO-2NC 13N6: 1NO-3NC 22N3: 2NO-2NC # of Positions 4: 4-Position 5: 5-Position Handle T: Knob L: Lever Selector Switches 4- & 5-Position (Replacement Parts) Contact Blocks + Mounting Adaptor + Safety Lever Lock Contact Blocks Style + Anti-Rotation Ring + 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Spring-Up Terminal Dummy Block Style Use with notched panel cutout to prevent unit rotation. Operators Style Position 4 TW-DB Terminal Blocks HW-CB2C 5 Description Handle Plastic Bezel Metal Bezel Knob HW1S-4T HW4S-4T Lever HW1S-4 HW4S-4 Knob HW1S-5T HW4S-5T Lever HW1S-5 HW4S-5 Maintained Maintained 1. Knob operator comes with black handle. 2. To order lever type, lever and inserts must be ordered separately, along with lever operator. See part numbers below. Levers & Inserts Style Part Number Lever 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Lever Color Insert Safety Lever Lock Part Number 634 Completed Unit HW9Z-RL Part Number HW9Z-LS = Part Number Contact Block Mounting Adaptor Style Operator Anti-Rotation Ring Contacts Style Circuit Breakers - Contact Arrangement Exposed Screw Terminal Contactors W Bezel Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series ASWHHL-j TW-HC1-j Standard lever color is black. Standard insert color is white. www.IDEC.com j Handle/Insert Color Code Color Code Black* B Blue S Green G Red R Yellow Y White W † 1. * Lever color inserts not available in black. 2. †Lever not available in white. 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Key Switches 2-Position (Assembled) Signaling Lights Mounting Contact 2-Position Key Switches Operator Position L R L R Spring Return from Right L HWnK-2A HWnK-21B R 1NO 1 O X HWnK-2AF10 HWnK-21BF10 1NO1NC 1 2 0 X X 0 HWnK-2AF11 HWnK-21BF11 2NO 1 2 O O X X HWnK-2AF20 HWnK-21BF20 2NO2NC 1 2 3 4 0 X 0 X X 0 X 0 HWnK-2AF22 HWnK-21BF22 Timers n Bezel Type Type Code Plastic 1 Metal 4 Contactors 1. In place of n enter 1 for plastic bezel or 4 for metal bezel. 2. Key is removable in all maintained positions. Other key removable options available. 3. Two keys are supplied with all switches. 4. All standard operators are keyed alike. 5. Other key removable options available. See table below 6. For nameplates, see page 655. 7. For contact assembly part numbers, see page 659. 8. Key is retained in “Spring Return” position. 9. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 10. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 11. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 12. Additional contact configurations available (up to 6 total contacts). 13. For Truth Tables see page 659. Relays & Sockets Operator Only Maintained Key Removable Option Codes Description A Key not retained in any position (removable in all positions) B Key retained in right position only C Key retained in left position only Terminal Blocks Code Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 635 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Part Number Structure H W 1 K - 2 1 B Contact Arrangement 1: Plastic 4: Metal 10: 1NO 20: 2NO 11: 1NO-1NC 22: 2NO-2NC # of Positions 2: 2-Position Operator Key Retained Position Signaling Lights Relays & Sockets A: Key not retained in any position (removable in all positions) B: Key retained in right position only C: Key retained in left position only Key Switches 2-Position (Replacement Parts) Contact Assembly + Mounting Adaptor + Safety Lever Lock Contact Blocks 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Spring-Up Terminal Contactors Exposed Screw Terminal Dummy Block Style Anti-Rotation Ring + Operator = Completed Unit TW-DB Part Number HW-CB2C Part Number HW9Z-LS Anti-Rotation Ring Style Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Style Contact Block Mounting Adaptor Style + Safety Lever Lock Contacts Timers Style Terminal Blocks 10 Bezel blank: Maintained 1: Spring Return from Right Circuit Breakers F Description Plastic Bezel Metal Bezel Maintained HW1K-2A HW4K-2A Maintained, key removed left only HW1K-2B HW4K-2B Spring Return from Right HW1K-21B HW4K-21B Maintained, key removed right only HW1K-2C HW4K-2C 1. Operator includes two keys. 2. All standard operators are keyed alike. 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. 636 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Key Switches 3-Position (Assembled) Signaling Lights Mounting Contact 3-Position Key Switches Operator Position L C R Spring Return from Right Maintained L C L R C R Spring Return from Left L C Spring Return Two Way L R C R n Bezel Type Operator Only HWnK-31B HWnK-32C HWnK-33D Type Code HWnK-31BF11 HWnK-32CF11 HWnK-33DF11 Plastic 1 Metal 4 1NO1NC 1 2 0 0 X 0 X X HWnK-3AF11 2NO 1 2 X 0 0 0 0 X HWnK-3AF20 HWnK-31BF20 HWnK-32CF20 HWnK-33DF20 2NC 1 2 0 X X X X 0 HWnK-3AF02 HWnK-31BF02 HWnK-32CF02 HWnK-33DF02 2NO1NC 1 2 3 X 0 0 0 0 X 0 X 0 HWnK-3JAF21N1 2NO2NC 1 2 3 4 X 0 0 X 0 0 X X 0 X X 0 HWnK-3AF22 2NO2NC 1 2 3 4 0 X X 0 0 0 X 0 X 0 0 X HWnK-3SAF22N9 4NO 1 2 3 4 X 0 X 0 0 0 0 0 0 X 0 X HWnK-3AF40 4NO 1 2 3 4 X 0 X 0 0 X 0 0 0 X 0 X HWnK-3SAF40N2 4NC 1 2 3 4 0 X 0 X X X X X X 0 X 0 HWnK-3AF04 – HWnK-31BF40 – HWnK-31BF04 HWnK-32CF22 – HWnK-33DF22 – HWnK-32CF40 – HWnK-33DF40 – HWnK-32CF04 HWnK-33DF04 Key Removable Option Codes Code Description A Key not retained in any position (removable in all positions) B Key retained in right position only C Key retained in left position only D Key retained in left and right (3 position only) E Key retained in center only (3 position only) G Key retained right and center (3 position only) H Key retained left and center (3 position only) Circuit Breakers 800-262-IDEC (4332) • USA & Canada – Terminal Blocks 8. For contact assembly part numbers, see page 659. 9. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 10. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1BM111-R). 11. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 12. Additional contact configurations available (up to 6 total contacts). 13. For Truth Tables see page 668. Contactors 1705151132 HWnK-31BF22 – Timers 1. In place of n enter 1 for plastic bezel or 4 for metal bezel. 2. Key is removable in all maintained positions. Other key removable options available. 3. Two keys are supplied with all switches. 4. All standard operators are keyed alike. 5. Other key removable options available. See table to the right. 6. * Operator is available with three different cams. HWnK-3A: Maintained (standard cam) HWnK-3SA: Maintained (Cam S) HWnK-3JA: Maintained (Cam J) 7. For nameplates, see page 655. – Relays & Sockets HWnK-3A* 637 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Part Number Structure H 1: Plastic 4: Metal - 3 1 B F 11 11: 1NO-1NC 40: 4NO 20: 2NO 04: 4NC 22: 2NO-2NC # of Positions 3: 3-Position Operator blank: Maintained 1: Spring Return from Right 2: Spring Return from Left 3: Spring Return Two Way Signaling Lights Relays & Sockets K Contact Arrangement Key Removable Option Code (see chart on previous page) Key Switches 3-Position (Replacement Parts) + Mounting Adaptor + Safety Lever Lock Contact Blocks 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Spring-Up Terminal Contactors Exposed Screw Terminal Dummy Block + Style + Operator = Completed Unit Part Number HW9Z-LS Anti-Rotation Ring Style Part Number HW9Z-RL Style TW-DB Part Number HW-CB2C Use with notched panel cutout to prevent unit rotation. Operators Contact Block Mounting Adaptor Style Anti-Rotation Ring Safety Lever Lock Contacts Timers Style Terminal Blocks 1 Bezel Contact Assembly Circuit Breakers W 1. 2. 3. 4. Description Plastic Bezel Metal Bezel Maintained (standard cam) HW1K-3A HW4K-3A Maintained (S cam) HW1K-3SA HW4K-3SA Maintained (J cam) HW1K-3JA HW4K-3JA Spring Return from Right (standard cam) HW1K-31B HW4K-31B Spring Return from Left (standard cam) HW1K-32C HW4K-32C 2-Way Spring Return (standard cam) HW1K-33D HW4K-33D Operator includes two keys. All standard operators are keyed alike. Other key removable options available. See table on previous page. Key not removable from spring-returned position 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. 638 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Illuminated Selector Switches 2-Position (Assembled) Signaling Lights 2-Position Illuminated Selector Switches Contact L Part Number Type R L Operator Only Full Voltage 1 2 O X X O 2NO 1 2 X O O X 2NO2NC 1 2 3 4 O X O X X O X O 120V 240V 480V Transformer Full Voltage 120V 240V 480V Transformer Full Voltage 120V 240V 480V Transformer L R R HWnF-2k HWnF-21k HWnF-2F11Qm-k-l HWnF-21F11Qm-k-l HWnF-2F11H2m-k HWnF-2F11M4m-k HWnF-2F11T8m-k HWnF-21F11H2m-k HWnF-21F11M4m-k HWnF-21F11T8m-k HWnF-2F20Qm-k-l HWnF-21F20Qm-k-l HWnF-2F20H2m-k HWnF-2F20M4m-k HWnF-2F20T8m-k HWnF-21F20H2m-k HWnF-21F20M4m-k HWnF-21F20T8m-k HWnF-2F22Qm-k-l HWnF-21F22Qm-k-l HWnF-2F22H2m-k HWnF-2F22M4m-k HWnF-2F22T8m-k HWnF-21F22H2m-k HWnF-21F22M4m-k HWnF-21F22T8m-k Timers 1NO1NC Spring Return from Right Maintained Relays & Sockets Mounting Style Operator Position Code Full Voltage Models Amber A Voltage Green G 6VAC/DC Red R 12VAC/DC 12V Blue S 24VAC/DC 24V White W 120V AC (LED only) 120V Yellow Y 240V AC (LED only) 240V m Lamp Code n Bezel Code Lamp Code Type Code Code Incandescent Blank Plastic 1 6V LED D Metal 4 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1705151132 l Full Voltage Code Color Terminal Blocks k Lens/LED Color Code Contactors 1. In place of k specify Lens/LED color code. 2. In place of l specify Full Voltage code. 3. In place of m specify Lamp code. 4. In place of n enter 1 for plastic bezel or 4 for metal bezel. 5. For nameplates, see page 655. 6. For contact assembly part numbers, see page 659. 7. Light is independent of switch position. 8. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 9. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 10. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 11. Yellow selector switch comes with white LED. 12. Additional contact configurations available (up to 6 total contacts). 13. For Truth Tables see page 668. 639 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series H 1: Plastic 4: Metal Part Number Structure – 21 F 20 Q D – G – 24V Lamp Voltage (Full voltage units only) 6V: 6V AC/DC A: Amber S: Blue G: Green W: White 12V: 12V AC/DC R: Red Y: Yellow 24V: 24V AC/DC 120V: 120V AC* Lamp Code 240V: 240V AC* D: LED *LED only Blank: Incandescent Contact Arrangement 2: Maintained 21: Spring Return from Right 11: 1NO-1NC 20: 2NO 22: 2NO-2NC Illumination Circuit Q: Full Voltage H2: Transformer 120V AC M4: Transformer 240V AC T8: Tranformer 480V AC Illuminated Selector Switches 2-Position (Replacement Parts) Transformer* + Contact Blocks + Lead Holder + Mounting Adaptor + Safety Lever Lock + Lamp + Anti-Rotation Ring + Operator + Lens = Completed Unit *Transformer not needed with full voltage models. Contact Blocks Lamp Circuit Components Style Description Lead Holder For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. Timers Transformer Unit (6V secondary voltage) For use with odd number of contacts. For use with even number of contacts. 120VAC 240VAC 480VAC 120V 240V 480V 120V 240V 480V DC-DC Converter Terminals Part Number Fingersafe HW-DA1FB Exposed HW-DA1B Spring Up HW-GA1 Fingersafe TW-DA1B Fingersafe TW-F126B TW-F246B TW-F486B Spring Up HW-T126 HW-T246 HW-L486 Exposed TW-T126B TW-T246B TW-T486B Style Style Description Plastic Bezel Metal Bezel Maintained HW1F-2 HW4F-2 Spring return from right HW1F-21 HW4F-21 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F10R (early make) HW-F01 HW-F01R (late break) Spring-Up Terminal HW-G10 HW-G10R (early make) HW-G01 HW-G01R (late break) Exposed Screw Terminal HW-C10 HW-C10R (early make) HW-C01 HW-C01R (late break) Part Number HW-CBL 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Style Part Number Code Color Code Amber A Blue S Green G White W Red R Yellow Y Anti-Rotation Ring Style Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Lamps HW9Z-LS LED Illuminated Knob Appearance Part Number HW9Z-FDY-k In place of k, specify the Color Code. Illuminated knobs must be ordered separately. 640 Color Style HW-L16D 1. HW-GA1 “Dummy Block with full voltage adaptor” does not require the use of HW-LH3. 2. DC-DC convertor features spring-up terminals. 3. DC-DC convertor applicable voltage range 90-140V DC. Contacts Contact Block Mounting Adaptor k Lens/LED Color Code TW-DA1FB Exposed 110VDC Style HW-LH3 Operators Circuit Breakers F Lens Color Position Full Voltage Adaptor Contactors 1 Bezel Dummy Block with Full Voltage Adaptor Terminal Blocks W www.IDEC.com Incandescent Voltage Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Use white LED for yellow lens. Yellow LED not available. 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Illuminated Selector Switches 3-Position (Assembled) Signaling Lights 3-Position Illuminated Selector Switches Mounting Part Number Operator Position L C Type Maintained R L Operator Only Full Voltage X O X X 2NO 1 2 X 0 0 0 O X 2NC 1 2 O X X X X O 1 2 3 4 X O O X O O X X O X X O Full Voltage 2NO2NC X O X O O O O O O X O X Full Voltage 4NO 1 2 3 4 O X O X X X X X X O X O Full Voltage 4NC 1 2 3 4 Transformer 120V 240V 480V Full Voltage Transformer 120V 240V 480V Full Voltage Transformer Transformer Transformer Transformer 1705151132 120V 240V 480V 120V 240V 480V 120V 240V 480V R L C L R C R HWnF-3k HWnF-31k HWnF-32k HWnF-33k HWnF-3F11Qm-k-l HWnF-31F11Qm-k-l HWnF-32F11Qm-k-l HWnF-33F11Qm-k-l HWnF-3F11H2m-k HWnF-3F11M4m-k HWnF-3F11T8m-k HWnF-31F11H2m-k HWnF-31F11M4m-k HWnF-31F11T8m-k HWnF-32F11H2m-k HWnF-32F11M4m-k HWnF-32F11T8m-k HWnF-33F11H2m-k HWnF-33F11M4m-k HWnF-33F11T8m-k HWnF-3F20Qm-k-l HWnF-31F20Qm-k-l HWnF-32F20Qm-k-l HWnF-33F20Qm-k-l HWnF-3F20H2m-k HWnF-3F20M4m-k HWnF-3F20T8m-k HWnF-31F20H2m-k HWnF-31F20M4m-k HWnF-31F20T8m-k HWnF-32F20H2m-k HWnF-32F20M4m-k HWnF-32F20T8m-k HWnF-33F20H2m-k HWnF-33F20M4m-k HWnF-33F20T8m-k HWnF-3F02Qm-k-l HWnF-31F02Qm-k-l HWnF-32F02Qm-k-l HWnF-33F02Qm-k-l HWnF-3F02H2m-k HWnF-3F02M4m-k HWnF-3F02T8m-k HWnF-31F02H2m-k HWnF-31F02M4m-k HWnF-31F02T8m-k HWnF-32F02H2m-k HWnF-32F02M4m-k HWnF-32F02T8m-k HWnF-33F02H2m-k HWnF-33F02M4m-k HWnF-33F02T8m-k HWnF-3F22Qm-k-l HWnF-31F22Qm-k-l HWnF-32F22Qm-k-l HWnF-33F22Qm-k-l HWnF-3F22H2m-k HWnF-3F22M4m-k HWnF-3F22T8m-k HWnF-31F22H2m-k HWnF-31F22M4m-k HWnF-31F22T8m-k HWnF-32F22H2m-k HWnF-32F22M4m-k HWnF-32F22T8m-k HWnF-33F22H2m-k HWnF-33F22M4m-k HWnF-33F22T8m-k HWnF-3F40Qm-k-l HWnF-31F40Qm-k-l HWnF-32F40Qm-k-l HWnF-33F40Qm-k-l HWnF-3F40H2m-k HWnF-3F40M4m-k HWnF-3F40T8m-k HWnF-31F40H2m-k HWnF-31F40M4m-k HWnF-31F40T8m-k HWnF-32F40H2m-k HWnF-32F40M4m-k HWnF-32F40T8m-k HWnF-33F40H2m-k HWnF-33F40M4m-k HWnF-33F40T8m-k HWnF-3F04Qm-k-l HWnF-31F04Qm-k-l HWnF-32F04Qm-k-l HWnF-33F04Qm-k-l HWnF-3F04H2m-k HWnF-3F04M4m-k HWnF-3F04T8m-k HWnF-31F04H2m-k HWnF-31F04M4m-k HWnF-31F04T8m-k HWnF-32F04H2m-k HWnF-32F04M4m-k HWnF-32F04T8m-k HWnF-33F04H2m-k HWnF-33F04M4m-k HWnF-33F04T8m-k 9. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1BM111-R). 10. Units with exposed screw terminals (HW-C...) must be ordered as subcomponents. 11. Yellow selector switch comes with white LED. 12. Additional contact configurations available (up to 6 total contacts). 13. For Truth Tables see page 668. k Lens/LED Color l Full Voltage Code Color Code Lamp Code Amber A Voltage Code Incandescent Blank Green G 6VAC/DC 6V LED D Red R 12VAC/DC 12V Blue S 24VAC/DC 24V White W 120V AC (LED only) 120V Yellow Y 240V AC (LED only) 240V 800-262-IDEC (4332) • USA & Canada Full Voltage Models m Lamp Code n Bezel Code Type Code Plastic 1 Metal 4 Circuit Breakers 1. In place of k specify Lens/LED color code. 2. In place of l specify Full Voltage code. 3. In place of m specify Lamp code. 4. In place of n enter 1 for plastic bezel or 4 for metal bezel. 5. For nameplates, see page 655. 6. For contact assembly part numbers, see page 659. 7. Light is independent of switch position. 8. All assembled part numbers in catalog include standard fingersafe (HW-F...) contacts. 120V 240V 480V C Terminal Blocks O O L Spring Return TwoWay Contactors 1 2 R Spring Return from Left Timers 1NO1NC C Spring Return from Right Relays & Sockets Contact Style 641 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series H 1: Plastic Position 4: Metal 3: Maintained 31: Spring Return from Right 32: Spring Return from Left 33: Spring Return 2-Way Transformer* + Part Number Structure – 31 F 20 Q D – G – 24V Full Voltage Code 6V: 6V AC/DC 12V: 12V AC/DC A: Amber S: Blue G: Green W: White 24V: 24V AC/DC R: Red Y: Yellow 120V: 120V AC* 240V: 240V AC* Lens Color Contact Arrangement 11: 1NO-1NC 22: 2NO-2NC Illumination Circuit 20: 2NO 40: 4NO Q: Full Voltage 02: 2NC 04: 4NC H2: Transformer 120V AC M4: Transformer 240V AC T8: Tranformer 480V AC Lamp Code *LED only D: LED Blank: Incandescent + Lead Holder + Mounting Adaptor + Safety Lever Lock + Lamp + Anti-Rotation Ring + Operator + Lens = Completed Unit *Transformer not needed with full voltage models. Lamp Circuit Components Style Description Timers Transformer Unit (6V secondary voltage) DC-DC Converter Contact Blocks For use with odd number of contacts. Part Number Contacts 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F10R (early make) HW-F01 HW-F01R (late break) HW-LH3 Spring-Up Terminal HW-G10 HW-G10R (early make) HW-G01 HW-G01R (late break) Fingersafe HW-DA1FB Exposed HW-DA1B Exposed Screw Terminal HW-C10 HW-C10R (early make) HW-C01 HW-C01R (late break) Spring Up HW-GA1 Terminals For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. Full Voltage Adaptor Fingersafe TW-DA1FB Exposed TW-DA1B Fingersafe TW-F126B TW-F246B TW-F486B 120V 240V 480V Spring Up HW-T126 HW-T246 HW-L486 120V 240V 480V Exposed TW-T126B TW-T246B TW-T486B For use with even number of contacts. 120VAC 240VAC 480VAC 110VDC 1. HW-GA1 “Dummy Block with full voltage adaptor” does not require the use of HW-LH3. 2. DC-DC convertor features spring-up terminals. 3. DC-DC convertor applicable voltage range 90-140V DC. Style Style Contact Block Mounting Adaptor k Lens/LED Color Code Style Part Number HW-CBL 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Style Part Number Description Plastic Bezel Maintained HW1F-3 HW4F-3 Spring return from right HW1F-31 HW4F-31 Spring return from left HW1F-32 HW4F-32 2-Way spring return HW1F-33 HW4F-33 Color Code A Blue S Green G White W Red R Yellow Y Anti-Rotation Ring Style Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Lamps Style LED Illuminated Knob Part Number HW9Z-FDY-k In place of k, specify the Color Code. Incandescent Voltage Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Use white LED for yellow lens. Yellow LED not available. Illuminated knobs must be ordered separately. 642 Code Amber HW9Z-LS Appearance Metal Bezel Color Safety Lever Lock HW-L16D Operators Circuit Breakers F Illuminated Selector Switches 3-Position (Replacement Parts) Contact Blocks Dummy Block with Full Voltage Adaptor Contactors 1 Bezel Lead Holder Terminal Blocks W www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Mono Lever Switches 2-Position (Assembled) Signaling Lights 2-Position Mono Lever Switches Style HW1M-F1010-20 Maintained up and down HW1M-F2020-20 Spring return up and down HW1M-F1010-40 Maintained up and down HW1M-F2020-40 Spring return up and down HW1M-F0101-20 Maintained right and left HW1M-F0202-20 Spring return right and left HW1M-F0101-40 Maintained right and left HW1M-F0202-40 Spring return right and left HW1M-LF1010-20 Maintained up and down HW1M-LF2020-20 Spring return up and down HW1M-LF1010-40 Maintained up and down HW1M-LF2020-40 Spring return up and down HW1M-LF0101-20 Maintained right and left HW1M-LF0202-20 Spring return right and left HW1M-LF0101-40 Maintained right and left HW1M-LF0202-40 Spring return right and left Circuit Diagrams 2 Position Left/Right Circuit Number 20 40 Contact Mounting No. Position Left Center Right X 0 0 HW-F10 0 0 X HW-F10 X 0 0 HW-F10 0 0 X HW-F10 X 0 0 HW-F10 0 0 X 1 HW-F10 2 1 2 3 4 2 Position Up/Down Circuit Number 20 40 No. Position Down Center Up X 0 0 HW-F10 0 0 X HW-F10 X 0 0 HW-F10 0 0 X HW-F10 X 0 0 HW-F10 0 0 X 1 HW-F10 2 1 2 3 4 Contactors 1. All assembled part numbers in catalog include standard (HW-F...) contacts. 2. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 3. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 4. Additional contact configurations available (up to 6 total contacts). Contact Mounting Timers HW1M-L Interlocking Lever Description Relays & Sockets HW1M Standard Lever Part Number Terminal Blocks Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 643 Switches & Pilot Devices Part Number Structure H W 1 M - L F 0 1 blank: Standard L: Interlocking 1 20 Circuit Number 20 or 40 (see contact arrangement on previous page) Lever Action 1: Maintained 2: Spring 0: Blocked Mono Lever Switches 2-Position (Sub-assembled) Part Numbers Contact Assembly + Mounting Adaptor + Contact Blocks Style 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) Spring-Up Terminal Contactors Safety Lever Lock Anti-Rotation Ring + HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Dummy Block Style = Completed Unit HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Style Description Part Number Standard Maintained Up/Down HW1M-1010 Spring return Up/Down HW1M-2020 Maintained Left/Right HW1M-0101 Spring return Left/Right HW1M-0202 Maintained Up/Down HW1M-L1010 Spring return Up/Down HW1M-L2020 Maintained Left/Right HW1M-L0101 Spring return Left/Right HW1M-L0202 Interlocking TW-DB Part Number Replacement Parts Item Terminal Blocks Operator Part Number Contact Block Mounting Adaptor Style + Anti-Rotation Ring Contacts Exposed Screw Terminal Circuit Breakers 0 up right down left Type Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series HW-CB2C Part Number Black Cap HW9Z-CPM 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Style Boot HW9Z-BLM (fits standard operator only) Part Number HW9Z-LS 644 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Mono Lever Switches 3- & 4-Position (Assembled) Signaling Lights 3-Position 4-Position Style Description HW1M Standard Lever HW1M-F0121-12N3 Maintained right and left, spring return down Style HW1M-F0222-12N3 Spring return right, down, left HW1M-L Interlocking Lever HW1M-LF0121-12N3 Maintained right and left, spring return down HW1M-LF0222-12N3 Spring return right, down, left HW1M Standard Lever Circuit Diagram Circuit Number No. Position Down Left Center Up Right 1 HW-F01 0 0 0 O X 2 HW-F01 X 0 0 O 0 3 HW-F10 0 X 0 0 0 HW1M-L Interlocking Lever Maintained all positions HW1M-F1212-22N9 Maintained up and down, spring left and right HW1M-2121-22N9 Spring up and down, maintained left and right HW1M-2222-22N9 Spring return all positions HW1M-LF1111-22N9 Maintained all positions HW1M-LF1212-22N9 Maintained up and down, spring left and right HW1M-LF2121-22N9 Spring up and down, maintained left and right HW1M-LF2222-22N9 Spring return all positions Circuit Diagram Circuit Number Contact Mounting No. Position Down Left Center Up Right 1 HW-F01 0 O 0 0 X 2 HW-F01 X 0 0 0 0 3 HW-F10 0 X 0 0 0 4 HW-F10 0 0 0 X 0 Contactors 22N9 1. 2. 3. 4. Description HW1M-F1111-22N9 Timers 12N3 Contact Mounting Part Number Relays & Sockets Part Number All assembled part numbers in catalog include standard (HW-F...) contacts. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). Units with exposed screw terminals (HW-C...) must be ordered as sub-components. Additional contact configurations available (up to 6 total contacts). Terminal Blocks Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 645 Switches & Pilot Devices Part Number Structure H W 1 M - L F 0 1 blank: Standard L: Interlocking 1 12N3 Circuit Number 3 Position: 12N3 4 Position: 22N9 Lever Action 1: Maintained 2: Spring 0: Blocked Mono Lever Switches 3 & 4-Position (Sub-assembled) Part Numbers Contact Assembly + Mounting Adaptor + Contact Blocks Style Anti-Rotation Ring + 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) Style HW-C01 Standard HW-C10 HW-C10R (early make) Dummy Block Style Completed Unit Use with notched panel cutout to prevent unit rotation. Operators HW-C01R (late break) TW-DB Part Number Terminal Blocks = HW9Z-RL Contact Block Mounting Adaptor HW-CB2C 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Part Number Description Part Number Combination, 3 position HW1M-0121 Spring return, 3 position HW1M-0222 Maintained, 4 position HW1M-1111 Combination, 4 position HW1M-1212 Combination, 4 position HW1M-2121 Spring return, 4 position HW1M-2222 Combination, 3 position HW1M-L0121 Spring return, 3 position HW1M-L0222 Maintained, 4 position HW1M-L1111 Combination, 4 position HW1M-L1212 Combination, 4 position HW1M-L2121 Spring return, 4 position HW1M-L2222 Replacement Parts Item Style Operator Part Number Interlocking Style + Anti-Rotation Ring 1NO Spring-Up Terminal Contactors Safety Lever Lock Contacts Exposed Screw Terminal Circuit Breakers 2 up right down left Type Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Part Number Black Cap HW9Z-CPM Boot HW9Z-BLM (fits standard operator only) HW9Z-LS 646 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Pushbutton Selectors (Assembled) Signaling Lights 2-Position Pushbutton Selectors Operator Position Left Cam Contacts Mounting Normal j Button Color Code Right Push Normal Push 1NO-1NC A HW1R-2A-j 1 2 HW-F10 HW-F01 0 X X 0 0 0 X 0 2NO 1 2 HW-F10 HW-F10 0 0 X X 0 X X X HW1R-2AF20-j 2NO-2NC 1 2 3 4 HW-F10 HW-F01 HW-F10 HW-F01 0 X 0 X X 0 X 0 0 0 0 0 X 0 X 0 HW1R-2AF22-j 2NO 1 2 HW-F10 HW-F10 0 0 X 0 0 0 0 X HW1R-2DF20-j 2NO-2NC 1 2 3 4 HW-F10 HW-F10 HW-F01 HW-F01 0 0 X X X 0 0 X 0 0 X X 0 X X 0 HW1R-2DF22N1-j 1 2 3 4 HW-F10 HW-F10 HW-F01 HW-F01 0 0 0 X X 0 0 X 0 0 X 0 0 X X 0 1 2 3 4 HW-F10 HW-F10 HW-F01 HW-F01 0 0 0 X 0 X 0 0 0 0 X 0 X 0 0 0 1 2 3 4 HW-F01 HW-F10 HW-F01 HW-F10 0 0 0 0 0 X 0 X X 0 X 0 0 X 0 X Operator Only 2NO-2NC Y Red R Gray N Blue S HW1R-2EF22N1-j HW1R-2FF22N1-j HW1R-2NF22N2-j HW1R-2T-j 1 2 3 4 HW-F10 HW-F10 HW-F01 HW-F01 0 0 X X X X 0 0 X X 0 0 Blocked HW1R-2TF22N1-j Circuit Breakers 1. All assembled part numbers in catalog include standard (HW-F...) contacts. 2. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 1705151132 W Yellow HW1R-2N-j Operator Only T White G Terminal Blocks 2NO-2NC B Green HW1R-2F-j Operator Only N Black Contactors 2NO-2NC Code HW1R-2E-j Operator Only F Color HW1R-2D-j Operator Only 2NO-2NC Code Timers D E HW1R-2AF11-j Color Relays & Sockets Operator Only Part Number 3. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 4. Operator only models come with operator and button. 5. Additional contact configurations available (up to 6 total contacts). 800-262-IDEC (4332) • USA & Canada 647 Switches & Pilot Devices Part Number Structure H R - 2 D F 22N1 – R B: Black G: Green R: Red S: Blue W: White Y: Yellow N: Gray Contact Arrangement Code 11: 1NO-1NC 20: 2NO (For additional contact codes see previous page) Pushbutton Selectors (Sub-assembled) Contact Blocks + Mounting Adaptor + Safety Lever Lock Contact Blocks Style 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) Spring-Up Terminal Contactors + Anti-Rotation Ring + Operator Safety Lever Lock Contacts Style Dummy Block TW-DB (safety lever lock included) Style Part Number + Button = Completed Unit Buttons Style Part Number Part Number Round Flush HW9Z-LS HW1A-B1-j Anti-Rotation Ring Style HW9Z-RL Style Part Number Use with notched panel cutout to prevent unit rotation. Operators Contact Block Mounting Adaptor Terminal Blocks 1 Button Colors A: Cam A D: Cam D E: Cam E F: Cam F N: Cam N T: Cam T Exposed Screw Terminal Circuit Breakers W Operator Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Description Part Number Cam A HW1R-2A Cam D HW1R-2D Cam E HW1R-2E Cam F HW1R-2F Cam N HW1R-2N Cam T HW1R-2T In place of j, specify the Button Color Code from table below. j Button Color Code Color Code Color Code Black B White W Green G Yellow Y Red R Gray N Blue S HW-CB2C 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. 648 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Dual Pushbutton Switches Key features: Signaling Lights • Two pushbuttons and a pilot light are integrated into one spacesaving ø22 mm control unit. • Momentary and interlock types are available for pushbuttons. Interlock type prevents both buttons from being pressed at the same time. • Pilot lights are available in full voltage and transformer with LED or incandescent lamps. • IP40 protection, IP65 when using silicon cover. • UL Listed, CSA approved, and EN compliant Applications: Relays & Sockets • Ideal for use as power switches and start/stop switches (available with I/ON and O/OFF markings on the buttons and a pilot light in the center). • Interlock type prevents two pushbuttons from being pressed at the same time. Dual Pushbutton Switches (Assembled) Part Numbers Without Center Pilot Light Operation Type Button Style Momentary Flush (top) Flush (bottom) Flush (top) Extended (bottom) 1NC HW7D-B11F1001-mn 1NO 1NO HW7D-B11F1010-mn 1NO-1NC 1NO-1NC HW7D-B11F1111-mn 2NO 2NC HW7D-B11F2002-mn 2NO 2NO HW7D-B11F2020-mn 1NO 1NC HW7D-B12F1001-mn 1NO 1NO HW7D-B12F1010-mn 1NO-1NC 1NO-1NC HW7D-B12F1111-mn 2NO 2NC HW7D-B12F2002-mn 2NO 2NO HW7D-B12F2020-mn 1NO 1NC HW7D-B21F1001-mn 1NO 1NO HW7D-B21F1010-mn 1NO-1NC 1NO-1NC HW7D-B21F1111-mn 2NO 2NC HW7D-B21F2002-mn 2NO 2NO HW7D-B21F2020-mn 1NO 1NC HW7D-B22F1001-mn 1NO 1NO HW7D-B22F1010-mn 1NO-1NC 1NO-1NC HW7D-B22F1111-mn 2NO 2NC HW7D-B22F2002-mn 2NO 2NO HW7D-B22F2020-mn nLegend Code GR: Green (top) Red (bottom) WB: White (top) Black (bottom) Blank: Without legend 1: I/ON (top) O/OFF (bottom) Terminal Blocks Interlock* 1NO mButton Color Code Contactors Flush (top) Extended (bottom) Part Number Bottom Button Timers Flush (top) Flush (bottom) Contact Arrangement Top Button 1705151132 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. *Interlock type prevents both top and bottom buttons from being pressed simultaneously. 2. Clear silicon rubber cover part number HW9Z-D7D. 3. Additional contact configurations available (up to 6 total contacts). 649 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series With Center Pilot Light Operation Type Button Style Flush (Top) Flush (Bottom) Flush (top) Flush (bottom) Signaling Lights Momentary Flush (Top) Extended (Bottom) Relays & Sockets Flush (top) Extended (bottom) Flush (Top) Flush (Bottom) Interlock* Timers Flush (Top) Extended (Bottom) Contactors Full Voltage Terminal Blocks Bottom Button Part Number 1NO 1NC HW7D-L11F1001kl-mn 1NO 1NO HW7D-L11F1010kl-mn 1NO-1NC 1NO-1NC HW7D-L11F1111kl-mn 2NO 2NC HW7D-L11F2002kl-mn 2NO 2NO HW7D-L11F2020kl-mn 1NO 1NC HW7D-L12F1001kl-mn 1NO 1NO HW7D-L12F1010kl-mn 1NO-1NC 1NO-1NC HW7D-L12F1111kl-mn 2NO 2NC HW7D-L12F2002kl-mn 2NO 2NO HW7D-L12F2020kl-mn 1NO 1NC HW7D-L21F1001kl-mn 1NO 1NO HW7D-L21F1010kl-mn 1NO-1NC 1NO-1NC HW7D-L21F1111kl-mn 2NO 2NC HW7D-L21F2002kl-mn 2NO 2NO HW7D-L21F2020kl-mn 1NO 1NC HW7D-L22F1001kl-mn 1NO 1NO HW7D-L22F1010kl-mn 1NO-1NC 1NO-1NC HW7D-L22F1111kl-mn 2NO 2NC HW7D-L22F2002kl-mn 2NO 2NO HW7D-L22F2020kl-mn 1. *Interlock type prevents both top and bottom buttons from being pressed simultaneously. 2. Clear silicon rubber cover part number HW9Z-D7D. 3. All assembled part numbers in catalog include standard (HW-F...) contacts. 4. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 5. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. kPilot Light Illumination & Voltage Code Circuit Breakers Top Button l Pilot Lamp Color Code mPushbutton Color Code Color Code Color Amber A* Top Green Code Voltage Code Green G* Bottom Red 6V AC/DC, LED Q2 Red R* Top White 12V AC/DC, LED Q3 Blue S* Bottom Black 24V AC/DC, LED Q4 White 120V AC, LED Q8 6V AC/DC, Incandescent Q5* 12V AC/DC, Incandescent Q6* 24V AC/DC, Incandescent Q7* GR WB nEngraving Codes Engraving Code No Engraving Blank I/ON Top O/OFF Bottom 1 W *Only available in LED illumination. Step-Down Transformer (6V Secondary Lamp Voltage) Voltage Code 120V AC, LED H22 240V AC, LED M42 480V AC, LED T82 120V AC, Incandescent H25* 240V AC, Incandescent M45* 480V AC, Incandescent T85* *Only available for White Lens Pilot Lamp. 650 www.IDEC.com 1705151132 Switches & Pilot Devices Pilot Light 7 D Part Number Structure – L 21 F 20 20 H22 R – GR 1 Engraving Code B: Without Center Pilot Light L: With Center Pilot Light Contact Arrangement Top Button Button Arrangement 11: 12: 21: 22: W 01: 1NC 10: 1NO Voltage Code A: Amber* blank: without center pilot light G: Green* Full Voltage* Transformer* Q2: 6V LED H22: 120V AC LED R: Red* S: Blue* *For additional voltage codes, please see previous page W: White 02: 2NC 20: 2NO Momentary (Flush/Flush) Momentary (Flush/Extended) Bottom Button 01: 1NC 02: 2NC Interlock (Flush/Flush) 10: 1NO 20: 2NO Interlock (Flush/Extended) blank: No Engraving 1: Top: I/ON Bottom: O/OFF Pilot Lamp Color Y: Yellow* blank: without center pilot light Pushbutton Color *Only available in LED illumination. Signaling Lights GR: Top: Green Bottom: Red WB: Top: White Bottom: Black Dual Pushbutton Switches (Sub-assembled) Part Numbers Mounting Adaptor Style Part Number Description Lead Holder HW-LH3 For use with odd number of contacts. HW-DA1FB For use with even number of contacts. Transformer Unit (6V secondary voltage) 120VAC 240VAC 480VAC Style 1NO 1NC = Completed Unit Style Contacts Flush (top) HW-G10 Spring-Up HW-G10R Terminal (early make) HW-G01 HW-G01R (late break) Dummy Block Exposed Screw Terminal HW-C01 HW-C01R (late break) TW-DB Part Number Non-illuminated HW-CB2C Illuminated (with Pilot Light) HW-CBL Style Flush (top) Flush (bottom) Flush (top) Extended (bottom) Top Green Bottom Red GR Instead of * insert: B: Non-illuminated L: Illuminated Anti-Rotation Ring Appearance nEngraving Codes Color Code Top White Bottom Black WB 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 Code Color Code Amber A* Blue S* White W G* Red R* 800-262-IDEC (4332) • USA & Canada LSTD-M4k Color Green 1 240V AC kLED Color Code Blank Bottom LSTD-H2k 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. No Engraving Top LSTD-2k 120V AC HW9Z-L7W Code O/OFF 24V AC/DC Illuminated Engraving I/ON LSTD-1k HW9Z-B7B Part Number Use with notched panel cutout to prevent unit rotation. LSTD-6k 12V AC/DC Nonilluminated HW9Z-RL HW7D-*22m-n Part Number 6V AC/DC Circuit Breakers Code HW9Z-LS HW7D-*21m-n mPushbutton Color Code Color Part Number Voltage Terminal Blocks Extended (bottom) Style HW-C10 HW-C10R (early make) Lamps/Lens 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. HW7D-*11m-n HW7D-*12m-n 1NC Contactors Flush (bottom) 1NO Standard HW-F10 HW-F01 Fingersafe HW-F10R HW-F01R (IP20) (early make) (late break) Contact Block Mounting Adaptor TW-F126B TW-F246B TW-F486B Part Number Flush (top) Momentary Lens Safety Lever Lock Button Interlock Contacts TW-DA1FB Operators + Contact Blocks Exposed and spring up terminals also available. 1705151132 Operator Style Full Voltage Adaptor Style + Timers Dummy Block with Full Voltage Adaptor For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. Safety Lever Lock Relays & Sockets Lamp Circuit Components with Fingersafe Terminals + LED + Incandescent Contact Blocks Switches & Pilot Devices H ø22mm - HW Series Only for LED illumination. 651 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Contact Arrangement Chart Contact Arrangement Top Button Bottom Button Contact Code 1NO 1NO 1010 1NO 1NC 1001 1NC 1NO 0110 1NC 1NC 1NO 2NO 1NO 1NO-1NC 1NO 2NC 2NO 1020 1011 1002 0120 Timers 1NC 0101 Contactors 1NC 1NO-1NC 1NC 2NC Terminal Blocks 2NO 1NO 2NO 1NC Circuit Breakers 1NO-1NC 1NO-1NC 1NO 1NC 0111 0102 2010 2001 1110 1101 Contact Block Mounting Position Example Contact Block Top Button Mounting Position Type 1 NO 2 NO 1 NO 2 NC 1 NC 2 NO 1 NC 2 NC 1 NO 2 NO 3 Dummy 4 NO 1 NO 2 NO 3 Dummy 4 NC 1 NO 2 NC 3 Dummy 4 NC 1 NC 2 NO 3 Dummy 4 NO 1 NC 2 NO 3 Dummy 4 NC 1 NC 2 NC 3 Dummy 4 NC 1 NO 2 NO 3 NO 4 Dummy 1 NO 2 NC 3 NO 4 Dummy 1 NO 2 NO 3 NC 4 Dummy 1 NO 2 NC 3 NC 4 Dummy Normal Push Bottom Button Normal Mounting Position 4 Mounting Position 2 Push X X X Mounting Position 3 Mounting Position 1 X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X 1. Transformers can have two or four contact blocks only. 2. Contact blocks 1 and 3 are actuated by the top button. Contact blocks 2 and 4 are actuated by the bottom button. 652 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Contact Arrangement Top Button 2NC 2NO 2NO 1NO-1NC 2NC 2NC 2NO 1NO-1NC 2NC 2NO 1NO-1NC 2NC 2002 1120 1111 1102 0220 0211 0202 NC X 2 NO 3 NC 4 Dummy 1 NC 2 NC 3 NC 4 Dummy 1 NO 2 NO 3 NO 4 NO 1 NO 2 NO 3 NO 4 NC 1 NO 2 NC 3 NO 4 NC 1 NO 2 NO 3 NC 4 NO 1 NO 2 NO 3 NC 4 NC 1 NO 2 NC 3 NC 4 NC 1 NC 2 NO 3 NC 4 NO 1 NC 2 NO 3 NC 4 NC 1 NC 2 NC 3 NC 4 NC Normal Mounting Position 4 Mounting Position 2 Push X X Mounting Position 3 Mounting Position 1 X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1705151132 2NC 2011 1 Push Terminal Blocks 2NC 1NO-1NC 2020 Normal Contactors 1NO-1NC 2NO 0201 Type Bottom Button Timers 1NO-1NC 1NC 0210 Mounting Position Top Button Relays & Sockets 2NO 1NO Contact Code Contact Block Signaling Lights 2NC Bottom Button Switches & Pilot Devices Contact Block Mounting Position Example Contact Arrangement Chart (con’t) 653 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Contactor Reset Button Reset Buttons (Assembled) j Button Color Code Plastic Bezel Metal Bezel (Blank) HW1B-M1RS-jT HW4B-M1RS-jT Color Code Color Code Engraved “R” HW1B-M1RS-jT-ENG-R HW4B-M1RS-jT-ENG-R Black B White W Green G Yellow Y Red R Gray N Blue S 1. In place of j specify Button Color Code. 2. 130mm (5.1”) overall length. 3. 16mm flat base for easy alignment Contactor Reset Button (Sub-assembled) + Operator + Button = Completed Unit Timers Rod Rod Button Part Number Contactors Style Style Part Number HW9Z-RS-TK2141 HW1A-B1-j Operator Style Plastic Metal In place of j, specify the Button Color Code from table. Terminal Blocks j Button Color Code HW4B-MO Code Color Code Black B White W Green G Yellow Y Red R Gray N Blue S Circuit Breakers HW1B-MO Color 654 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Nameplates - HW Series Engraving Plate Engraving Plate 1.6 0.9 12.1 30 R14.9 ø22 22mm ø22 1.9 1 Nameplate (blank engraving plate included) HWAM-OB HWAQ-OB HWAS-OB HWAV-O HWAV5-0† Nameplate (engraved) HWAM-j HWAQ-j HWAS-j HWAV-27* HWAV5-27† Additional Insert (blank) HWNP-O HWNP-O HWNP Dimensions Additional Insert (engraved) HWNP-j HWNP-j 12 1 45 2.7 HWAV–Yellow Plastic Signaling Lights 1.5 HWAS–Black Plastic 27 14.5 14.9 2 ø2 14.5 14.9 R14.9 29 2.7 12.1 30 29 27 HWAQ–Black Plastic ø60mm HWAM–Black Plastic 27 Relays & Sockets 1. In place of j, insert either the standard legend code from table below or custom engraving delimited by “ “. 2. Standard engravings are available at no charge. 3. * HWAV-27 comes engraved “Emergency Stop” as shown in drawing. 4. † HWAV5-27 and HWAV5-0 for 60mm diameter E-Stops (80mm diameter nameplate). Standard Legend Codes Pushbuttons Pushbuttons/Selector Switches Selector Switches Legend Code Legend Code Legend Code Legend Code AUTO CLOSE DOWN EMERG.STOP FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 OPEN OUT RAISE RESET REVERSE RUN SLOW START STOP TEST UP I (Int’l On) O (Int’l Off) EMO 116 117 118 119 120 121 122 123 125 126 127 150 151 152 AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWER-RAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISE-LOWER 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN OI (Int’l OFF ON) 216 217 218 219 220 221 222 223 250 AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFF-WINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 Contactors Code Timers Legend Terminal Blocks 1. To order engraved nameplates, add legend code to nameplate part number. 2. Character height based on the number of characters and size of nameplate. Standard character size is 3/16”. 3. Nameplates with standard legends are the same list price as blank nameplates. 4. Nameplates have built-in anti-rotation feature for use with notched panel cut-outs. Additional anti-rotation ring (HW9Z-RL) is not necessary. Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 655 Switches & Pilot Devices Nameplates Order Form — HW Series Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To ensure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: IDEC Rep/Distributor Contact: Name: PO number (if known): Telephone: IDEC Rep/Distributor Phone: Fax & Email: IDEC Rep/Distributor Fax & Email: HWAM Nameplate Engraving Location Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 9 characters. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 11 characters maximum (for 7/64” size letters) 1/8” Letter Size 9 characters maximum (for 7/8” size letters) Sample Letter Sizes Qty 1 2 3 4 5 6 7 8 9 10 11 7/64” Letters: ABCD 1/8” Letters: A BCD Engraving Location Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 9 characters. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. Contactors Timers HWAQ Nameplate 7/64” Letter Size 11 characters maximum (for 7/64” size letters) 1/8” Letter Size 9 characters maximum (for 1/8” size letters) Sample Letter Sizes Qty 1 2 3 4 5 6 7 8 9 10 11 7/64” Letters: ABCD 1/8” Letters: A BCD HWAS Nameplate Terminal Blocks Engraving Location A Circuit Breakers Engraving Location B Step 1. Choose Letter Size - 3/32” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 14 characters. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. Qty Step 3. Specify Location. Enter the location of engraving Location (A or B or Both), in box on the right. 3/32” Letter Size 20 characters maximum (for 3/32” size letters) 1/8” Letter Size 14 characters maximum (for 1/8” size letters) A 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 B 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Sample Letter Sizes 3/32” Letters: A B C D 1/8” Letters: A 656 www.IDEC.com BCD 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Switch Engraving Order Form – HW Series Copy this order form and use it to specify Letter Height, Maximum Number of Lines and Text to be engraved. To ensure engraving accuracy, fax it to your IDEC representative or Distributor. Telephone: Name: Fax: Address: Email: PO: Signaling Lights Your Company: Part Number to be Engraved: Please check one of the boxes below to indicate your choice of engraving options: ø29mm, ø40mm Mushroom Head Engraving Letter Height Max. Characters Per Line 5/32 5 1 # of Lines Area 2† Letter Height Max. Characters Per Line 5/32 5 1 6 5/32 5 2 1/8 5 5/32 5 2 1/8 6 3 1/8 6 4 3/32 5 1/8 6 3 1/8 5 4 3/32 5 Engraving Area 1 1 Engraving Area 2 1 Letter Height Max. Characters Per Line 5/32 5 1/8 5 5/32 7 1/8 7 Timers 1/8 # of Lines Relays & Sockets # of Lines Engraving Area 1 Round Switch Square Switch Contactors 1. Above mentioned specifications hold true for standard size pushbuttons (round and square). 2. †Engraving Area 2 can be engraved for 40mm mushroom Head non-Illuminated push button only. 3. Engraving is done on the button itself for non-Illuminated push buttons and on marking plate for illuminated push buttons and pilot lights. 4. Please enter text exactly how you want it engraved, take care to emphasize capital or small letters. Enter text to be engraved: Sample Letter Sizes 1/8 Letters: Line 1: 5/32 Letters: Line 2: Terminal Blocks Line 3: Line 4: For IDEC Internal Use Only: 1705151132 Circuit Breakers Work Order #: 800-262-IDEC (4332) • USA & Canada 657 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Accessories Locking Ring Wrench Metallic tool used to tighten the plastic locking ring when installing the HW series in a panel MW9Z-T1 Lamp/LED Removal Tool Rubber tool makes lamp/LED removal easier. OR-55 Anti-Rotation Ring Prevents rotation of switches in panel. (included with all assembled switches except pilot lights) Timers Contactors Terminal Blocks HW9Z-RL for round panel cutout LW9Z-L Rubber Mounting Hole Plug Black rubber plug fills unused 7/8” mounting holes in panel. OB-31 Metallic Mounting Hole Plug For plugging unused 7/8” mounting holes in the panel. Tighten the attached locking ring to a torque of 12 kfg-cm maximum Degree of protection: IP66 LW9Z-BM Barrier To prevent contact between adjacent lead wires when buttons or switches are tightly mounted close together. HW-VL1 Used to cover and protect pushbuttons Flush Pushbuttons OC-31 Operating temperature: –50 to +60°C Extended Pushbuttons OC-32 Pushbutton Clear Boot Padlock Cover Circuit Breakers for notched panel cutout (standard) Plastic hinged padlockable cover to protect pushbuttons or selector switches. (Not intended for E-Stops) HW9Z-KL1 Degree of protection: IP65 Tab Terminal Adapter Tab #250 (6.35 x 0.8mm): Single tab Mounting Adaptor Used to mount round HW series (except Jumbo Mushroom, unibody, and square units) into a larger panel cut-out. (includes both pieces) TW-FA1 22 to 30mm HW9Z-A30 22 to 25mm HW9Z-A25 Replacement Safety Lever Lock Used to prevent contact mounting lever from moving due to heavy vibration or panel maintenance. HW9Z-LS Reset Rod for Contactors Overload 5” rod used with HW1B-M0. HW9Z-RS-TK2141 Replacement Operator Washer Provided with operator. Insert between bezel and locking ring. HWM-WASHER Replacement Locking Ring Plastic locking nut comes with all HW operators & assemblies. Switch Cover (Square) Used only with round or square flush pushbuttons. HW9Z-K1 (spring return) HW9Z-K11 (maintained cover) Replacement Keys Pair of Keys (#231) HW9Z-SKP 658 www.IDEC.com Standard (plastic) HW9Z-LN Optional (metal) HW9Z-LNM 1705151132 Switches & Pilot Devices Appearance Replacement Lens Description/Usage Part Number HW Illuminated Unibody Replacement Lens HWLV-LENSR Replacement Jumbo Dome Lens Switches & Pilot Devices Item ø22mm - HW Series HW1A-P5j j = (A, G, R, S, W, Y)) Polycarbonate Replacement Lens (If using yellow lens, use white LED.) Signaling Lights Replacement Jumbo LED Diffusing Lens HW9Z-PP5C Replacement LED Lamp - applicable for jumbo pilot lights only LSTDB-2j j = (A, G, R, S, W) Rubber Cover for Dual Pushbuttons Clear Silicon rubber cover HW9Z-D7D Barrier for Dual Pushbuttons Plastic barrier. Used when mounting the HW7 units on 30mm horizontal centers, to prevent possible interconnections between adjoining terminals. HW-VG1 Emergency stop nameplate sticker HW9Z-EMO-NP-TK2120 E MO EMO Sticker Relays & Sockets Replacement LED Lamps for HW Jumbo Dome E-Stop Shrouds HW9Z-KG2 40mm Mushroom Head 40mm, and 60mm Mushroom Head SEMI S2-0703, 12.5.1 Compliant Applicable Standards HW9Z-KG3 40mm Mushroom Head SEMI S2 Compliant (Approved by TUV) HW9Z-KG4 40mm Mushroom Head SEMI S2 Compliant (Approved by TUV) & SEMATECH SEMI S2-0703, 12.5.1 & SEMATECH Compliant Contactors E-Stop Types Part Numbers Timers HW9Z-KG1 Style Contact Assemblies Standard Contact Assemblies For use with Non-Illuminated Pushbuttons & E-Stops Part Number Standard Fingersafe Contacts 1NO 1NC 1NO/1NC 2NO 2NC 2NO/2NC HW-CBF10 HW-CBF01 HW-CBF11 HW-CBF20 HW-CBF02 HW-CBF22 Spring Up Terminal Contacts 1NO 1NC 1NO/1NC 2NO 2NC 2NO/2NC HW-CB10 HW-CB01 HW-CB11 HW-CB20 HW-CB02 HW-CB22 1705151132 For use with Illuminated Pushbuttons. Style Contacts Part Number 1NO 2NO 1NO/1NC 1NC 2NC HW-FL10Q0 HW-FL20Q0 HW-FL11Q0 HW-FL01Q0 HW-FL02Q0 Order lamp separately. Circuit Breakers Contacts Terminal Blocks Style Full Voltage Contact Assemblies Gold contact option is available for spring-up terminals. Add suffix “MAU” to end of part number. For example, HW-CB20 becomes HW-CB20-MAU. 800-262-IDEC (4332) • USA & Canada 659 Switches & Pilot Devices Transfomer Contact Assemblies For use with Illuminated Pushbuttons. Style Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Contacts Part Number 120V AC with LED 1NO 2NO 1NC 1NO/1NC HW-FL10H2-k HW-FL20H2-k HW-FL01H2-k HW-FL11H2-k 240V AC with LED 1NO 2NO 1NC 1NO/1NC HW-FL10M4-k HW-FL20M4-k HW-FL01M4-k HW-FL11M4-k 480V AC with LED 1NO 2NO 1NC 1NO/1NC HW-FL10T8-k HW-FL20T8-k HW-FL01T8-k HW-FL11T8-k 120V AC with Incandescent 1NO 2NO 1NC 1NO/1NC HW-FL10H2 HW-FL20H2 HW-FL01H2 HW-FL11H2 240V AC with Incandescent 1NO 2NO 1NC 1NO/1NC HW-FL10M4 HW-FL20M4 HW-FL01M4 HW-FL11M4 1. In place of k, specify the LED Color Code. k = A, G, R, S, or W 2. 6V LED or incandescent lamp included. Dimensions (mm) Flush (HW1B-M1, -A1) Extended (HW1B-M2, -A2) M3.5 Terminal Screw M3.5 Terminal Screw LO CK M3.5 Terminal Screw Panel Thickness 0.8 to 6 Locking Ring LO Locking Ring CK Panel Thickness 0.8 to 6 CK 41.4 ø29 41.4 ø29 ø23.6 41.4 ø29 LO 25 25 Locking Ring Panel Thickness 0.8 to 6 ø29mm Mushroom (HW1B-M3 -A3) 25 Timers Non-Illuminated Pushbuttons 3.6 ø2 13 29.4 50.2 (1 or 2 blocks) 70.2 (4 blocks) 29.4 19 13 50.2 (1 or 2 blocks) 70.2 (4 blocks) ø40mm Mushroom (HW1B-M4, -A4) ø60mm Mushroom (HW1B-M5) Square Flush (HW2B-M1, -A1) M3.5 Terminal Screw M3.5 Terminal Screw Locking Ring M3.5 Terminal Screw LO CK Panel Thickness 0.8 to 6 Locking Ring Panel Thickness 0.8 to 6 13 50.2 (1 or 2 blocks) 70.2 (4 blocks) CK 70.2 (4 blocks) 29.6 70.2 (4 blocks) 15 13 30 Contact Block (Bottom View) 24.8 29.4 Terminal Wiring Arrows indicate access directions for wiring Panel Thickness 0.8 to 6 LO CK 24.8 13 50.2 (1 or 2 blocks) 70.2 (4 blocks) 660 19 29.4 41.4 25 Locking Ring LO ø60 50.2 (1 or 2 blocks) Square Extended (HW2B-M2, -A2) M3.5 Terminal Screw Circuit Breakers 50.2 (1 or 2 blocks) 29.4 23.2 29.6 Terminal Blocks ø40 41.4 25 Locking Ring Panel Thickness 0.8 to 6 29.4 23.2 41.4 13 25 Contactors 50.2 (1 or 2 blocks) 70.2 (4 blocks) 1 contact block 2 contact blocks 4 contact blocks www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Dimensions (mm) Flush (Round & Square) Extended Round Panel Thickness 0.8 to 6 LO Square CK LO LO CK 3.6 13 ø2 18.5 24.8 29.4 29.4 Extended with Full Shroud 29.4 ø40mm Mushroom LO LO CK 13 29.4 23.2 Emergency Stop Pushbuttons Dimensions (mm) ø29mm Head Pushlock Turn Reset (HW1B-V3) Relays & Sockets 29.4 18.5 41.4 3.6 ø2 ø40 41.4 25 25 CK ø29.5 Signaling Lights 13 .6 3 ø2 Extended 41.4 ø23.5 41.4 29.6 41.4 25 25 25 CK Switches & Pilot Devices Operators Panel Thickness 0.8 to 6 Gasket Terminal Screw M3.5 LOC Locking Ring 41.4 ø29 50.2 (1 or 2 blocks) 2 contact blocks 4 contact blocks 70.2 (4 blocks) 13 29.4 32 ø40mm Head EMO Pushlock Turn Reset (HW1B-V4) LO LOC K Locking Ring Lock Lever 0 ø4 41.4 ø40 20 25 25 26.5 CK Contactors ø40mm Head Pushlock Turn Reset (HW1B-V4) 41.4 1 contact block Timers 25 K 50.2 (1 or 2 blocks) 29.4 13 32 29.4 Terminal Blocks 13 70.2 (4 blocks) 32 ø40mm Head Pushlock Key Reset (HW1B-X4) ø60mm Head Pushlock Turn Reset (HW1B-V5) LO ø60 41.4 ø40 25 CK Circuit Breakers 13 29.4 32 49.4 1705151132 15 34.5 800-262-IDEC (4332) • USA & Canada 661 Switches & Pilot Devices ø40mm Head Push-Pull (HW1B-Y2) ø40mm Head Unibody Pushlock Turn Reset (HW1B-BV4) LO Panel Thickness 0.8 to 6 CK Gasket M3.5 Terminal Screw 41.4 25 Locking Ring ø40 ø40 Switches & Pilot Devices ø22mm - HW Series 13 29.4 Signaling Lights 25.5 TOP Marking Terminal Cover 14 32 48 Illuminated E-Stop Pushbuttons (HW1E-LV4) Mounting Hole Panel Thickness 0.8 to 6 R0.8 max. Gasket ø22 .3 Locking Ring Relays & Sockets 3.2 +0.4 0 ø40 24.1 TOP Marking +0.2 0 +0.4 0 M3.5 Terminal Screw M3.5 Terminal Screw Lamp Terminal 11.5 14 32 61 Terminal Cover 63 Timers 11.5 46 The minimum mounting centers shown below are applicable to E-Stop switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers for ease of wiring. Unit Vertical Spacing Horizontal Spacing HW1B-V3 HW1B-V4 HW1B-X4 HW1B-Y2 50 mm 50 mm HW1B-V5 60 mm 60 mm Terminal Arrangement (Bottom View) HW1E-BV4 Side HW1E-LV4 TOP X1 .2 (NC) .3 (NO) .1 (NC) .4 (NO) Contactors (1NO-1NC) LAMP .2 (NC) .3 (NO) .1 (NC) .4 (NO) X2 (1NO-1NC) Emergency Stop Stations Circuit Breakers Terminal Blocks Dimensions (mm) 662 www.IDEC.com 1705151132 Switches & Pilot Devices Operator Dimension A (mm) Pushlock Turn Reset 32 Pushlock Key Reset 32 (Key inserted: 49.4) Push Pull 25.5 Mounting Hole Layout 4-M4 Tapped Holes for Rear Mounting (Depth: 10 mm) 2-Front Mounting Holes ø14 Knockout 21 76 59.5 Switches & Pilot Devices A 76 ø22mm - HW Series 21 41 HW1B-V4R Box Cover Mouting Screws Box Cover Box Base 2- ø4 .6 Signaling Lights 15.5 62 Pilot Lights Dimensions (mm) Full Voltage Flush Gasket Locking Ring Dome Round/Dome 9 ø2 Relays & Sockets Panel Thickness 0.8 to 6 M3.5 Terminal Screw Square Flush X2 X1 44.7 0.5 29.6 17.5 7 Transformer Mounting Hole Layout Flush M3.5 Terminal Screw Dome Round/Dome Square Flush Close mounting on 30mm centers Degree of protection: IP65 72.1 29.6 17.5 7 29.6 +0.4 0 30 min. X2 24 X1 .3 ø22 Timers 9 ø2 DC-DC Converter Flush Dome Round/Dome 9 ø2 Square Flush 30 min. 76.2 29.6 29.6 17.5 7 Contactors X1 X2 When mounting transformer or DC-DC converter type units on 30mm centers vertically and horizontally, keep the ambient temperature below 40ºC. 24 M3.5 Terminal Screw Jumbo Dome Pilot Lights Incandescent Lamp LSB Base BA9S/13 Mounting Hole Layout R0.8 max. ø22.3 +0.4 0 +0.2 0 +0.4 0 3.2 27 2 24.1 Base BA9S/13 Illumination Color 1 Light blue: LSTDB ø10.6 M3.5 Terminal Screw LED Lamp LSTDB Terminal Blocks 6 ø6 ø10 Panel Thickness 1 to 5 85 20.4 Locking Ring Rubber Gasket 0.5 34.4 50.5 85 Circuit Breakers Illuminated Pushbuttons Full Voltage Models 1 Contact Block 1705151132 2 Contact Blocks 800-262-IDEC (4332) • USA & Canada 3 Contact Blocks 663 Switches & Pilot Devices Full Voltage Adapter Full Voltage Adapter M3.5 Terminal Screw Contact Block Locking Ring M3.5 Terminal Screw Contact Block Locking Ring Panel Thickness 0.8 to 6 Full Voltage Adapter M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 6 X2 50.2 (1 block) 1 contact block 65.8 (2 blocks) 2 contact blocks 3 contact blocks 70.2 (3 blocks) Illuminated Pushbuttons con’t Dimensions (mm) 4 Contact Blocks Terminal Wiring Arrows indicate access directions for wiring. Relays & Sockets Full Voltage Adapter Contact Block Full Voltage Adaptor M3.5 Terminal Screw Contact Block Locking Ring Transformer Panel Thickness 0.8 to 6 X1 DC-DC Converter Models Safety Lever Lock 3 Timers Transformer Models 4 X1 X2 85.8 (4 contacts) 4 contact blocks X1 Locking Ring X2 X2 M3.5 Terminal Screws 89.7 (2 blocks) 109.5 (4 blocks) M3.5 Terminal Screw 89.5 (2 blocks) 109.5 (4 blocks) Non-Illuminated Selector & Key Switches Dimensions (mm) Knob Operator Terminal Wiring Circuit Breakers Terminal Blocks Contactors Panel Thickness 0.8 to 6 Locking Ring X1 Signaling Lights Switches & Pilot Devices ø22mm - HW Series 664 www.IDEC.com 1705151132 Switches & Pilot Devices Panel Thickness 0.8 to 6 Switches & Pilot Devices M3.5 Terminal Screw ø22mm - HW Series Arrows indicate access directions for wiring. Gasket LO Locking Ring Contact Block Full Voltage Adaptor 9 ø2 2 contact blocks 4 contact blocks 48.5 (1 or 2 blocks) 7 29.4 68.5 (3 or 4 blocks) Signaling Lights 1 contact block 41.4 ø28.8 25 CK 21 Key Operator Tranformer LO CK 9.4 25 ø2 17 X2 Relays & Sockets 41.4 X1 13 29.4 30.5 Illuminated Selector Switches Full Voltage Model Transformer Model M3.5 Terminal Screw LO CK LO 41.4 41.4 25 89.4 (4 blocks) 7 29.4 21 Timers X1 69.4 (2 blocks) 9 ø2 25 ø 4 29 3 CK X2 M.3.5 Terminal Screw 79.5 (2 blocks) 99.5 (4 blocks) 7 21 Dual Pushbutton 29.4 Dimensions (mm) Without Pilot Light Mounting Hole Layout Contactors Terminal Blocks Circuit Breakers 1705151132 800-262-IDEC (4332) • USA & Canada 665 Switches & Pilot Devices 49.4 (2 contacts) Locking Ring Without Button Markings With Button Markings (I/ON and O/OFF) 30 54.8 54.8 ON OFF 29.8 14.5 20 29.8 With Pilot Light Full Voltage Full Voltage Adapter (Bottom Button) The depth of a 3-contact model depends on the combination of contact blocks at top and bottom pushbuttons. HW Relays & Sockets 55 ** Panel Thickness 0.8 to 6 Safety Lever Lock 0.5 (Top Button) 69.4 (2 contacts), 89.4 (4 contacts) (Note) Timers +0.2 0 69.4 (3 or 4 contacts) Rubber Gasket Transfomer (240V minimum) Top Button 1 contact block 2 contact blocks Bottom Button 2 contact blocks 1 contact block Depth 89.4 mm 69.4 mm Transformer, DC-DC Converter HW HW 89.5 (2 contacts), 109.5 (4 contacts) Monolever Dimensions (mm) Locking Ring CK ø3 LO 4.2 Panel Thickness 0.8 to 6 8 29.4 24 Circuit Breakers 45.5 36 max. 72 36 max. 49.4 (2 blocks) 69.4 (4 blocks) 24 Terminal Blocks 41.4 25 M3.5 Terminal Screw -The 3.2 mm recess is for preventing rotation and is not necessary when a nameplate or anti-rotation ring is not used. -When using the safety lever lock, determine the vertical spacing in consideration of convenience for installing and removing the safety lever lock. -Recommended vertical spacing: 100 mm -The minimum mounting centers are applicable to switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers for ease of wiring. Transformer (480V) Transformer 79.5 (2 contacts), 99.5 (4 contacts) Contactors *3.2 +0. 4 0 24.1 .3 +0.4 0 ø22 41.4 Signaling Lights R0.8 max. HW Switches & Pilot Devices ø22mm - HW Series 666 www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Accessory Dimensions OR-55 Lamp/LED Removal Tool TOP 1.5 3.5 3.5 ø25 HW-VG1 Dual Pushbutton Barrier MW9Z-T1 Locking Ring Wrench 22.5 8 ø2 110 58 45 45 33 HW-VL1 Barrier Signaling Lights HW9Z-D7D Dual Pushbutton Rubber Cover 59 ø11.6 ø29 ø22 12 Gasket Locking Ring HW9Z-RL Anti-Rotation Ring ø29 3 ø25.8 OB-31 Rubber Mounting Hole Plug ø14 LW9Z-BM Metallic Mounting Hole Plug 1.5 20 1.5 HWLS-TK1971 Safety Lever Lock Screwdriver Remove Lock Lever Safety Lever Lock CK LO 26.5 70 30 93 6.5 R6 Operator Install Safety Lever Lock Panel Thickness 0.8 to 3.2 82.5 Relays & Sockets HW9Z-KL1 Padlock Cover 20 24 ø2 2.2 0 ø5 .4) 44 :ø (ID Waterproof Rubber Gasket 0.5t HW9Z-KG1 Contact Block Mounting Adapter Panel Timers 29.5 30 Key Hole ø8 HW9Z-KG2 38 22 36.5 80 32 ø76.1 2.2 ø2 64 48 ø90 Gasket TOP Marking TOP Marking Contactors ø22 Locking Ring TOP Marking TOP Marking Locking Ring Operator Panel Thickness: 1.2 to 4 Operator Terminal Blocks Panel Thickness: 1.2 to 4 HW9Z-KG3 HW9Z-KG4 LSTD 35 25 ø2 35 25 2 800-262-IDEC (4332) • USA & Canada 20.4 Circuit Breakers 50 ø10.6 ø90 67 ø75 ø74 52 ø66 ø22 42 1705151132 ø9.5 667 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Specification Charts Signaling Lights Conforming to IED 947-5-1 Appendix C. Utilization categories AC-15 and DC-13. Operation rate: 1,800 op. hour Load factor: Inductive 0.4 ± 0.05 Resistive 0.9 ± 0.05 Operator Truth Tables 2 Position Selector Switches Timers Relays & Sockets Contact HW-F10 (NO) HW1S-2T HW1K-2* HW1F-2 HW-F01 (NC) HW-F10R (NO-EM) HW-F01R (NC-LB) Operator Position Left Right L O X R O X L X O R X O L O X R O X L X O R X O Contact HW1S-3JT HW1K-3J* HW-F10 (NO) HW1S-3T HW1K-3* HW1F-3 HW-F01 (NC) HW-F10R (NO-EM) HW-F01R (NC-LB) Mounting Position Operator Position Left Center Right HW-F10 (NO) L X O O R O O X HW-F01 (NC) L O X O R O X O HW-FC10R (NO-EM) L X O X R X O X HW-F01R (NC-LB) L O X X R X X O 4 Position Selector Switches 3 Position Selector Switches Contact Contactors Mounting Position 3 Position Selector Switches con’t Contact Operator Position Mounting Position Left L X O O R O O X L O X X R X X O L X O O R O O X L O X X R X X O Center Right HW1S-4T Mounting Position Operator Position 1 2 3 4 HW-F10 (NO) L X O O O R O O O X HW-F01 (NC) L O O X O R O X O O HW-F10R (NO-EM) L X X O X R X O X X HW-F01R (NC-LB) L O X X X R X X X O 1 2 Terminal Blocks 5 Position Selector Switches Contact HW-F10 (NO) Circuit Breakers HW1S-3ST HW1K-3S* HW-F01 (NC) HW-F10R (NO-EM) HW-F01R (NC-LB) Operator Position Mounting Position Left Center Right L X O O R O O X L O O X R X O O L X X O R O X X L O X X R X X O Contact HW-F10 (NO) HW1S-5T HW-F10R (NO-EM) HW-F01R (NC-LB) 1. Mounting position indicates which side of operator each contact should be mounted (as viewed from the front of the panel). 2. *For key removable code see page 638. 668 HW-F01 (NC) Mounting Position Operator Position 3 4 5 O L X O O O R O O O O X L O O O X O R O X O O O L X X X O X R X O X X X L O X X X X R X X X X O 3. HW1S-3T is identified by white plungers on the operator. 4. HW1S-3ST is identified by red plungers on the operator. 5. HW1S-3JT is identified by black plungers on the operator. www.IDEC.com 1705151132 Switches & Pilot Devices ø22mm - HW Series Turn off power to HW series control units before starting installation, removal, wiring, maintenance, and inspection of the products. Failure to turn power off may cause electrical shocks or fire hazard. For wiring, use wires of a proper size to meet voltage and current requirements. Tighten the M3.5 terminal screws to a tightening torque of 1.0 to 1.3 N·m. Failure to tighten terminal screws may cause overheating and fire. To avoid the possibility of burning yourself, use the lamp holder tool when replacing lamps. Switches & Pilot Devices HW Safety Precautions HW General Instructions Removing and Installing the Contact Block Assembly 2. To reinstall, place the TOP markings on the operator and the contact block mounting adapter in the same direction, and insert the operator into the contact block mounting adapter. Then turn the locking lever in the opposite direction. 1. HW series can be mounted vertically with a minimum spacing of 55 mm but spacing should be determined to ensure easy operation (recommended minimum spacing: 100 mm). 2. Mount the control unit onto the panel, lock the lever, and push in the safety lever lock to install. 3. When the spacing is narrower than the recommended value, with the lever unlocked, mount the safety lever lock and insert the contact unit to the operator. Then, lock the lever and strongly push in the safety lever lock to install. 4. To remove the safety lever lock, insert a flat screwdriver into the safety lever and push upwards. Relays & Sockets 1. To remove the operator from the contact block, turn the locking lever in the direction of the arrow shown below. The operator can now be removed. IDEC strongly recommends using the safety lever lock (HW9Z-LS, yellow) to prevent heavy vibration or maintenance personnel from unlocking the contact assembly. Safety Lever Lock Screwdriver Remove Lock Lever Safety Lever Lock CK LO Contact Block Mounting Adapter Timers 26.5 Operator Install Remove the contact block assembly from the operator (for transformer type pilot lights, remove the transformer from the illumination unit). Remove the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block assembly to the operator. Signaling Lights Panel Mounting Panel Notes for Panel Mounting Contactors 1. When mounting the operator onto a panel, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring. Tightening torque must not exceed 2.0 N·m. Do not use pliers. Excessive tightening will damage the locking ring. 2. For the contact blocks and transformers housing LED and incandescent lamps, make sure not to press the lamps too hard, otherwise the lamp socket may be damaged. Safety Lever Lock Terminal Blocks Dual Pushbutton Instructions Replacement of Lens Removing Remove the lens by inserting a screwdriver into the recess of the lens through the bezel. Circuit Breakers Installing Install the lens in the recess between the buttons by pressing against the bezel. 1705151132 800-262-IDEC (4332) • USA & Canada 669 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Dual Pushbuttons Instructions con’t Replacement of Lamps Tightening Torque for Terminal Screws Lamps can be replaced by using the lamp holder tool (OR-55) from the front of the panel, or by removing the contact block assembly from the operator unit. Tighten the M3.5 terminal screws to a torque of 1.0 to 1.3 N·m. Removing the Lamps from the Front of the Panel When using full voltage type LED illuminated units, provide protection against electrical noise, if necessary. Applicable Wiring The applicable wire size is 2 mm2 maximum. (solid wire ø1.6mm2 maximum) One or two wires can be connected. 1. To remove, slip the lamp holder tool onto the lamp head lightly. Then push slightly, and turn the lamp holder tool counterclockwise. Applicable Crimping Terminal ø3.6 min. 7.9 max. Signaling Lights Removal 4 max. Lamp Timers Lamp Base 8 max. Note: When connecting wires to contact blocks or transformers in the direction shown below, keep the insulation stripping length 6.6 mm at the maximum. About Pushbutton Switches Do not attempt to remove the pushbuttons! The pushbuttons cannot be removed or replaced! Contactors Be sure to use an insulation tube or cover on the crimping part of the crimping terminal to prevent electrical shocks. Lamp Holder Tool Solid Wire 2. Place the pins on the lamp base to the grooves in the lamp socket. Insert the lamp and turn it clockwise. Do not attempt to remove using a flat screwdriver or pincers, otherwise the pushbuttons may be damaged. 5.5 min. ø1.6 max. Relays & Sockets Installation 1. To install, insert the lamp head into the lamp holder tool, and hold the lamp as shown in the figure below. Installation of LED Illuminated Units X1 Pushbuttons X2 Inside X1 X2 Inside Installing the Rubber Cover Narrow Mounting When mounting the units closely in a horizontal row on 30mm centers, use optional barriers to prevent interconnection between adjoining terminals. The barriers can be attached simply by pressing them onto the sides of contact blocks. Terminal Blocks 30 When using the HW7D pushbuttons in places where the pushbuttons are subjected to water splash or an excessive amount of dust, make sure to use the HW9Z-D7D rubber boot (IP65) which is ordered separately. Notes for Installing the Rubber Cover 30 Remove the gasket from the operator, and install the rubber boot on the operator. Pull out the seals of the rubber boot and place them around the operator sleeve as shown. Make sure that the seals are not twisted or tucked inside and that the gasket does not remain, otherwise the normal waterproof and dustproof characteristics are not ensured. 1. Remove the gasket. Barrier 2. Install the rubber boot on the pushbuttons. 3. Rubber boot is installed. Circuit Breakers Seals When mounting transformer type illuminated units closely in a horizontal row on 30-mm centers, insert solid wires or stranded wires into inside of the terminal screw on the transformer (see figure on the right) to prevent short circuit between adjoining terminals. 670 Install Remove X1 X2 Inside X1 Inside X2 Gasket www.IDEC.com Seals 1705151132
HW4B-M1F10-G 价格&库存
很抱歉,暂时无法提供与“HW4B-M1F10-G”相匹配的价格&库存,您可以联系我们找货
