AB6Q-A1-R
AB6Q-A1-R
    IDEC(日本和泉)
AB6Q-A1-R 数据手册
A series Switches & Pilot Lights ø16 ø12 ø10 ø8 A Series Selection Guide Series A6 Series Switches and Pilot Lights Mounting Hole Size Model ø16 AL6 AB6 AS6 AS6 (key) Disc tumbler key Shape Wave key Illuminated Push­buttons (Momen­tary, Maintained) Pilot Light Unit Bezel Size (mm) ø18 18 18 × 24 Bezel Color Button/Illumination Color Illumination: amber, blue, green, pure white, red, white, yellow Contact Light Source Durability ø18 18 × 24 18 Black LED Lamp (IDEC’s LATD) — Button: black, blue, green, red, white, yellow Lens: amber, blue, green, red, yellow, white — Knob: black — Key cylinder: chrome plating (metal) Contact Configuration SPDT, DPDT (Gold-clad silver contact) Contact Rating (resistive load) 110V AC/1A, 24V DC/1A Electrical Momentary: 100,000 operations minimum Maintained:   50,000 operations minimum 100,000 operations minimum Mechanical Momentary: 1,000,000 operations minimum Maintained:   100,000 operations minimum 250,000 operations minimum Degree of Protection IP65, IP40 (IEC 60529) Terminal Style Solder terminal Accessories Key Selector Switch (90° 2-position maintained, 90° 2-position spring return, 45° 3-position main­ tained, 45° 3-position spring return) Selector Switch (90° 2-position maintained, Pushbuttons (Momentary, 90° 2-position spring return, Main­tained) 45° 3-position main­ tained, 45° 3-position spring return) Switch Guard Yes Yes — — Socket Yes Yes Yes Yes Terminal Cover Yes Yes Yes Yes Dust Cover Yes Yes — — Mounting Hole Plug Yes Yes Yes Yes Remarks • LED lamps contain a current-limiting resistor and a pro­tection diode. • Available with threesided barrier. • Available with threesided barrier. • Operator position can be changed by IDEC’s original bezel rotating and locking system. Approvals Page 2 5 8 10 11 A Series Selection Guide ø16 ø12 ø10 Series A Series Switches and Pilot Lights Mounting Hole Size Model ø8 ø12 AL2 ø10 AB2 AL1 ø8 AB1 AL8 AB8 Shape Unit Bezel Size (mm) • Illuminated Pushbuttons (Momentary, Maintained) • Pilot Light ø14 • Pushbuttons (Momentary, Maintained) 14 × 18 14 Bezel Color • Illuminated Pushbuttons (Momentary, Maintained) • Pilot Light ø12 • Pushbuttons (Momentary, Maintained) 12 × 16 12 Black • Illuminated Pushbuttons (Momentary, Maintained) • Pilot Light • Pushbuttons (Momentary, Maintained) 9 × 12 9 ø9 Black Black LED lamp (IDEC’s LAD-S) Button/Illumination Color Button: black, blue, green, red, Illumination: white, yellow amber, green, Lens: amber, red, white, yellow blue, green, red, yellow, white Button: black, blue, green, red, Illumination: white, yellow amber, green, Lens: amber, red, white, yellow blue, green, red, yellow, white Button: black, blue, green, red, Illumination: white, yellow amber, green, Lens: amber, red, white, yellow blue, green, red, yellow, white Contact Configuration SPDT, DPDT (silver contact) SPDT (silver contact) SPDT (silver contact) Contact Rating (resistor load) 110V AC/1A, 24V DC/1A 110V AC/1A, 24V DC/1A 110V AC/1A, 24V DC/1A Electrical Momentary: 100,000 operations minimum Maintained: 50,000 operations minimum Momentary: 100,000 operations minimum Maintained: 50,000 operations minimum Momentary: 100,000 operations minimum Maintained: 50,000 operations minimum Mechanical Momentary: 200,000 operations minimum Maintained: 100,000 operations minimum Momentary: 200,000 operations minimum Maintained: 100,000 operations minimum Momentary: 200,000 operations minimum Maintained: 100,000 operations minimum Degree of Protection IP65, IP40 (IEC 60529) IP40 (IEC 60529) IP40 (IEC 60529) Terminal Style Solder terminal Solder terminal Solder terminal Accessories Durability Contact Light Source — LED lamp (IDEC’s LAD-S) — LED lamp (IDEC’s LAD-S) — Switch Guard Yes Yes Yes Socket Yes Yes Yes Terminal Cover Yes Yes Yes Dust Cover Yes — — Mounting Hole Plug Yes Yes Yes Remarks • External current-limiting resistor type (Note) Approvals Page • External current-limiting resistor type (Note) (except for pilot lights) 23 24 • External current-limiting resistor type (Note) (except for pilot lights) 30 31 (except for pilot lights) 36 37 Note: LED lamps do not contain a current-limiting resistor, and external resistors must be connected. 3 ø16 A6 Series Switches and Pilot Lights Light duty in short 22mm body length. • Features IDEC’s original mechanism for snap-action switching. Suitable for a wide variety of office and factory aplications. • The LED lamp contains a current-limiting resistor and a diode for protection against reverse connection. • Degree of protection: IP40 and IP65 (IEC 60529) • UL recognized, CSA certified, EN compliant, and CCC approved. Applicable Standards Mark File No. or Organization UL508 UL Recognition File No. E55996 CSA C22.2 No.14 CSA File No. LR 21451 EN60947-5-1 EU Low Voltage Directive GB14048.5 CCC 2003010305027381 (switches) 2008010304288772 (pilot lights) Contact Ratings (Contact Block) Rated Insulation Voltage Rated Thermal Current Operating Voltage (AC/DC) Resistive Load AC 50/60 Hz Inductive Load Resistive Load DC Inductive Load Contact Material 250V 3A 12V 24V 110V – – 1.0A – – 0.7A 1.0A 1.0A 0.2A 0.7A 0.7A 0.5A Gold-clad silver 220V 0.5A 0.5A – – • Minimum applicable load: 5V AC/DC, 1 mA (applicable range may vary with operating conditions and load types) Weight (example) Weight (approx.) AL6M-M24:   8g AL6M-M221: 46g AL6M-P4:   6g AL6M-P21: 45g AB6M-M2:   7g AS6M-2Y2:   9g AS6M-2KT2A: 21g Specifications Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance –25 to +55°C (no freezing) –30 to +80°C (no freezing) 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts: 2,000V AC, 1 minute Between terminals of different poles: Switch 2,000V AC, 1 minute Between terminals of the same pole: Dielectric Unit 1,000V AC, 1 minute Strength Between contact and lamp terminals: 1,500V AC, 1 minute Illumination Between live part and ground: Unit 2,000V AC, 1 minute Operating extremes: Vibration Resistance 5 to 55 Hz, amplitude 0.75 mm Damage limits: 500 m/s2 (50G) Shock Resistance Operating extremes: 200 m/s2 (20G) Momentary: 1,000,000 operations Mechanical Durability Maintained:   100,000 operations (minimum Pushlock Turn Reset:   100,000 operations operations) Selector Switch:   250,000 operations Key Selector Switch:   250,000 operations Electrical Durability Other than Maintained: 100,000 operations (minimum Maintained:   50,000 operations operations) (Switching frequency 1200 operations/h) Degree of Protection IP40, IP65 (IEC 60529) Terminal Style Solder terminal LED Lamp Ratings (LATD) Part No. Lamp Base Voltage Range Rated Voltage Current Draw AC DC Color Code ➁ Lamp Base Color Voltage Marking Life (reference value) LATD-1➁ LATD-2➁ LATD-5➁ Exclusive for A series 5V DC ±5% 12V AC/DC ±10% 24V AC/DC ±10% 5V DC 12V AC/DC 24V AC/DC — 9 mA 9 mA 8 mA 8 mA 8 mA A (amber), G (green), JW (pure white), R (red), S (blue), W (white) Same as illumination color (except JW - gray base) Die stamped on the base Approx. 50,000 hours (The luminance is reduced to 50% of the initial intensity when used on complete DC.) (+) (–) Internal Circuit LED Chip Protection Diode Zener Diode • Specify a color code in place of ➁ in the Part No. A (amber), G (green), JW (pure white), R (red), S (blue), W (white) • Use a pure white (JW) LED lamp for yellow illumination. 4 A6 Series Illuminated Pushbuttons ø16 Illuminated Pushbuttons  Package Quantity: 1 Shape Operation Round AL6M Operating Voltage IP65 AL6M-M11➁ AL6M-M11P➁ DPDT AL6M-M21➁ AL6M-M21P➁ SPDT AL6M-M13➁ AL6M-M13P➁ DPDT AL6M-M23➁ AL6M-M23P➁ SPDT AL6M-M14➁ AL6M-M14P➁ DPDT AL6M-M24➁ AL6M-M24P➁ SPDT AL6M-A11➁ AL6M-A11P➁ DPDT AL6M-A21➁ AL6M-A21P➁ 12V AC/DC ±10% SPDT AL6M-A13➁ AL6M-A13P➁ DPDT AL6M-A23➁ AL6M-A23P➁ 24V AC/DC ±10% SPDT AL6M-A14➁ AL6M-A14P➁ DPDT AL6M-A24➁ AL6M-A24P➁ SPDT AL6Q-M11➁ AL6Q-M11P➁ DPDT AL6Q-M21➁ AL6Q-M21P➁ 12V AC/DC ±10% 24V AC/DC ±10% 5V DC ±5% Maintained Square AL6Q 5V DC ±5% Momentary 12V AC/DC ±10% 24V AC/DC ±10% 5V DC ±5% Maintained Rectangular AL6H AL6Q-M23P➁ SPDT AL6Q-M14➁ AL6Q-M14P➁ DPDT AL6Q-M24➁ AL6Q-M24P➁ SPDT AL6Q-A11➁ AL6Q-A11P➁ DPDT AL6Q-A21P➁ AL6Q-A13P➁ DPDT AL6Q-A23➁ AL6Q-A23P➁ 24V AC/DC ±10% SPDT AL6Q-A14➁ AL6Q-A14P➁ DPDT AL6Q-A24➁ AL6Q-A24P➁ SPDT AL6H-M11➁ AL6H-M11P➁ DPDT AL6H-M21➁ AL6H-M21P➁ 12V AC/DC ±10% SPDT AL6H-M13➁ AL6H-M13P➁ DPDT AL6H-M23➁ AL6H-M23P➁ 24V AC/DC ±10% SPDT AL6H-M14➁ AL6H-M14P➁ DPDT AL6H-M24➁ AL6H-M24P➁ SPDT AL6H-A11➁ AL6H-A11P➁ DPDT AL6H-A21➁ AL6H-A21P➁ SPDT AL6H-A13➁ AL6H-A13P➁ DPDT AL6H-A23➁ AL6H-A23P➁ SPDT AL6H-A14➁ AL6H-A14P➁ DPDT AL6H-A24➁ AL6H-A24P➁ SPDT AL6G-M11➁ AL6G-M11P➁ DPDT AL6G-M21➁ AL6G-M21P➁ SPDT AL6G-M13➁ AL6G-M13P➁ DPDT AL6G-M23➁ AL6G-M23P➁ SPDT AL6G-M14➁ AL6G-M14P➁ DPDT AL6G-M24➁ AL6G-M24P➁ 12V AC/DC ±10% 12V AC/DC ±10% 24V AC/DC ±10% SPDT AL6G-A11➁ AL6G-A11P➁ DPDT AL6G-A21➁ AL6G-A21P➁ 12V AC/DC ±10% SPDT AL6G-A13➁ AL6G-A13P➁ DPDT AL6G-A23➁ AL6G-A23P➁ 24V AC/DC ±10% SPDT AL6G-A14➁ AL6G-A14P➁ DPDT AL6G-A24➁ AL6G-A24P➁ 5V DC ±5% Maintained AL6Q-M13P➁ AL6Q-A13➁ 5V DC ±5% Momentary AL6Q-M13➁ AL6Q-M23➁ AL6Q-A21➁ 24V AC/DC ±10% Rectangular w/three-sided barrier AL6G SPDT DPDT SPDT 5V DC ±5% Maintained SPDT 12V AC/DC ±10% 5V DC ±5% Momentary ➁ Illumination IP40 5V DC ±5% Momentary Contact Part No. Color Code Specify a color code in place of ➁ in the Part No. A: amber G: green JW: pure white R: red S: blue W: white Y: yellow • See page 7 for dimensions. • See page 20 for marking plate size and engraving area. • When using white lens unit (clear lens + white marking plate) with color codes A, G, R, or S, specify “W” before ➁ in the Part No. (without CCC marking) Example: AL6H-M24W➁ • A pure white (JW) LED lamp is used for yellow illumination. 5 ø16 A6 Series Pilot Lights Pilot Lights  Package Quantity: 1 Shape Round AL6M-P Square AL6Q-P Operating Voltage Part No. ➁ Illumination IP40 IP65 5V DC ±5% AL6M-P1➁ AL6M-P1P➁ 12V AC/DC ±10% AL6M-P3➁ AL6M-P3P➁ 24V AC/DC ±10% AL6M-P4➁ AL6M-P4P➁ 5V DC ±5% AL6Q-P1➁ AL6Q-P1P➁ 12V AC/DC ±10% AL6Q-P3➁ AL6Q-P3P➁ Color Code Specify a color code in place of ➁ in the Part No. Rectangular AL6H-P Rectangular w/three-sided barrier AL6G-P 24V AC/DC ±10% AL6Q-P4➁ AL6Q-P4P➁ 5V DC ±5% AL6H-P1➁ AL6H-P1P➁ 12V AC/DC ±10% AL6H-P3➁ AL6H-P3P➁ 24V AC/DC ±10% AL6H-P4➁ AL6H-P4P➁ 5V DC ±5% AL6G-P1➁ AL6G-P1P➁ 12V AC9DC ±10% AL6G-P3➁ AL6G-P3P➁ 24V AC/DC ±10% AL6G-P4➁ AL6G-P4P➁ A: amber G: green JW: pure white R: red S: blue W: white Y: yellow • See page 7 for dimensions. • See page 20 for marking plate size and engraving area. • When using white lens unit (clear lens + white marking plate) with color codes A, G, R, or S, specify “W” before ➁ in the Part No. (without CCC marking) Example: AL6H-M24W➁ • A pure white (JW) LED lamp is used for yellow illumination. 6 A6 Series Illuminated Pushbuttons and Pilot Lights Dimensions ø16 Dimensions (Illuminated Pushbuttons & Pilot Lights) Terminal Width 2.8×0.5t 3 Panel Thickness 0.5 to 6 Rectangular Rectangular w/3-way barrier (TOP) Locking Ring Round Square (TOP) ø18 (TOP) 5 18 5 2.5 Rubber Gasket Anti-rotation Ring 6 1 6 8 Pilot Light 0.6 22 18 24 9 5.7 9 Illuminated Pushbutton Terminal Arrangement (bottom view) Illuminated Pushbutton Pilot Light (TOP) (TOP) NC1 NC2 NO1 NO2 Lamp Terminal (+) C1 C2 Lamp Terminal (–) Lamp Terminal (+) Lamp Terminal (–) With contact: NC1, NO1, C1 terminal only Mounting Hole Layout Round/Square +0.2 0 ø16.2 +0.2 0 Note: Determine mounting centers to ensure easy operation. 18 min. 18 min. ø16.2 Rectangular Rectangular w/3-way barrier 18 min. 24 min. All dimensions in mm. 7 ø16 A6 Series Pushbuttons Pushbuttons  Package Quantity: 1 Shape Button Style Round AB6M Operation Momentary Button Maintained Momentary Lens Maintained Square AB6Q Momentary Button Maintained Momentary Lens Maintained Rectangular AB6H Momentary Button Maintained Momentary Lens Maintained Rectangular w/three-sided barrier AB6G Momentary Button Maintained Momentary Lens Maintained Contact Part No. SPDT IP40 AB6M-M1➀ IP65 AB6M-M1P➀ DPDT AB6M-M2➀ AB6M-M2P➀ SPDT AB6M-A1➀ AB6M-A1P➀ DPDT AB6M-A2➀ AB6M-A2P➀ SPDT AB6M-M1L➁ AB6M-M1PL➁ DPDT AB6M-M2L➁ AB6M-M2PL➁ SPDT AB6M-A1L➁ AB6M-A1PL➁ DPDT AB6M-A2L➁ AB6M-A2PL➁ SPDT AB6Q-M1➀ AB6Q-M1P➀ DPDT AB6Q-M2➀ AB6Q-M2P➀ SPDT AB6Q-A1➀ AB6Q-A1P➀ DPDT AB6Q-A2➀ AB6Q-A2P➀ SPDT AB6Q-M1L➁ AB6Q-M1PL➁ DPDT AB6Q-M2L➁ AB6Q-M2PL➁ SPDT AB6Q-A1L➁ AB6Q-A1PL➁ DPDT AB6Q-A2L➁ AB6Q-A2PL➁ SPDT AB6H-M1➀ AB6H-M1P➀ DPDT AB6H-M2➀ AB6H-M2P➀ SPDT AB6H-A1➀ AB6H-A1P➀ DPDT AB6H-A2➀ AB6H-A2P➀ SPDT AB6H-M1L➁ AB6H-M1PL➁ DPDT AB6H-M2L➁ AB6H-M2PL➁ SPDT AB6H-A1L➁ AB6H-A1PL➁ DPDT AB6H-A2L➁ AB6H-A2PL➁ SPDT AB6G-M1➀ AB6G-M1P➀ DPDT AB6G-M2➀ AB6G-M2P➀ SPDT AB6G-A1➀ AB6G-A1P➀ DPDT AB6G-A2➀ AB6G-A2P➀ SPDT AB6G-M1L➁ AB6G-M1PL➁ DPDT AB6G-M2L➁ AB6G-M2PL➁ SPDT AB6G-A1L➁ AB6G-A1PL➁ DPDT AB6G-A2L➁ AB6G-A2PL➁ Color Code ➀➁ B black G: green R: red S: blue W: white Y: yellow A: amber G: green R: red S: blue W: white Y: yellow B black G: green R: red S: blue W: white Y: yellow A: amber G: green R: red S: blue W: white Y: yellow B black G: green R: red S: blue W: white Y: yellow A: amber G: green R: red S: blue W: white Y: yellow B black G: green R: red S: blue W: white Y: yellow A: amber G: green R: red S: blue W: white Y: yellow • Specify a color code in place of ➀ or ➁ in the Part No. • See page 9 for dimensions. • See page 20 for marking plate size and engraving area. • Black is available for lens style buttons. Black lens consists of a clear lens and a black marking plate. Specify “B” in place of ➁ in the Part No. Example:AB6H-M2LB 8 A6 Series Pushbuttons ø16 Dimensions Rubber Gasket Terminal Width 2.8×0.5t Anti-rotation Ring 2.5 3 Locking Ring Panel Thickness 0.5 to 6 Rectangular Rectangular w/3-way barrier (TOP) Square (TOP) ø18 Round (TOP) 5 18 5 Pushbutton 1 8 0.6 9 22 24 5.7 18 9 Mounting Hole Layout Terminal Arrangement (bottom view) +0.2 0 18 min. ø16.2 Rectangular Rectangular w/3-way barrier ø16.2 +0.2 0 Pushbutton (TOP) Note: Determine mounting centers to ensure easy operation. 18 min. Round/Square NC1 NC2 NO1 NO2 C1 18 min. 24 min. C2 Note: SPDT has only NC1, NO1, and C1 terminals. All dimensions in mm. 9 ø16 A6 Series Selector Switches Selector Switches Operator position can be changed by IDEC’s original bezel rotating and locking system. The bezel can be locked at every 45° and bezel rotation is prevented while mounting on a panel. Example: 3-position R (C) R (C) L R L (C) (C) Pull out the bezel to release the lock. Rotate the bezel, and push it in at 45° intervals to lock the bezel. R L L How to change the operator position Normal Operator Position Package Quantity: 1 90° 2-position Round AS6M-Y Position Maintained Spring return from right to left 45° 3-position Maintained Spring return from right to center Spring return from left to center Spring return two-way 90° 2-position Square AS6Q-Y Maintained Spring return from right to left 90° 2-position 45° 3-position Maintained Spring return from right to center Spring return from left to center Spring return two-way Maintained Spring return from right to left Maintained Spring return from right to center Spring return from left to center Spring return two-way 45° 3-position Rectangular AS6H-Y • Bezel: black SPDT DPDT SPDT DPDT DPDT Part No. IP40 IP65 AS6M-2Y1 AS6M-2Y1P AS6M-2Y2 AS6M-2Y2P AS6M-21Y1 AS6M-21Y1P AS6M-21Y2 AS6M-21Y2P AS6M-3Y2 AS6M-3Y2P DPDT AS6M-31Y2 AS6M-31Y2P DPDT AS6M-32Y2 AS6M-32Y2P DPDT SPDT DPDT SPDT DPDT DPDT AS6M-33Y2 AS6Q-2Y1 AS6Q-2Y2 AS6Q-21Y1 AS6Q-21Y2 AS6Q-3Y2 AS6M-33Y2P AS6Q-2Y1P AS6Q-2Y2P AS6Q-21Y1P AS6Q-21Y2P AS6Q-3Y2P DPDT AS6Q-31Y2 AS6Q-31Y2P DPDT AS6Q-32Y2 AS6Q-32Y2P DPDT SPDT DPDT SPDT DPDT DPDT AS6Q-33Y2 AS6H-2Y1 AS6H-2Y2 AS6H-21Y1 AS6H-21Y2 AS6H-3Y2 AS6Q-33Y2P AS6H-2Y1P AS6H-2Y2P AS6H-21Y1P AS6H-21Y2P AS6H-3Y2P DPDT AS6H-31Y2 AS6H-31Y2P DPDT AS6H-32Y2 AS6H-32Y2P DPDT AS6H-33Y2 AS6H-33Y2P Contact Contact Operation Position Operation Left Center Right SPDT L 90° 2-position Shape R NO NC NO NC — Maintained C C DPDT L R L C Left Right Contact Contact NO NC NO NC Left Right Contact Contact NO NC NO NC Spring return from right — C C C C DPDT right R Maintained L C R Spring return from right 45° 3-position  L C Spring return from left L C Left Right Contact Contact NO NC NO NC Left Right Contact Contact NO NC NO NC R C C C Left Right Contact Contact NO NC NO NC C C C R Two-way return • Knob: black Dimensions Terminal Width 2.8×0.5t 2.5 3 Rubber Gasket Anti-rotation Ring Panel Thickness 0.5 to 6 Rectangular (TOP) Locking Ring Square (TOP) Round (TOP) 8 5 18 5 ø1 8 1 8 22 15.5 24 c18 Terminal Arrangement (bottom view) Mounting Hole Layout (Selector Switch) Round/Square ø16.2 +0.2 0 Rectangular ø16.2 +0.2 0 (TOP) C1 18 min. NO1 NO2 18 min. NC1 NC2 C2 SPDT has NC1, NO1, and C1 only. 18 min. Note: Determine mounting centers to ensure easy operation. 10 24 min. All dimensions in mm. A6 Series Key Selector Switches ø16 Key Selector Switches  Package Quantity: 1 Shape Position Key Retained at ● Operation Round AS6M A B Maintained 90° 2-position B A B C Maintained D Disc tumbler key 45° 3-position Spring return from right Spring return from left Spring return two-way R L R L L L L L E L G L H L B L D L G L C L D L H L D R L C Spring return from right Wave key L L R C C C C C C C C C C C C C C Contact Part No. IP40 IP65 SPDT AS6M-2K1A AS6M-2K1PA DPDT AS6M-2K2A AS6M-2K2PA SPDT AS6M-2K1B AS6M-2K1PB DPDT AS6M-2K2B AS6M-2K2PB SPDT AS6M-2K1C AS6M-2K1PC DPDT AS6M-2K2C AS6M-2K2PC SPDT AS6M-21K1B AS6M-21K1PB DPDT AS6M-21K2B AS6M-21K2PB AS6M-3K2A AS6M-3K2PA AS6M-3K2B AS6M-3K2PB AS6M-3K2C AS6M-3K2PC AS6M-3K2D AS6M-3K2PD AS6M-3K2E AS6M-3K2PE AS6M-3K2G AS6M-3K2PG AS6M-3K2H AS6M-3K2PH AS6M-31K2B AS6M-31K2PB AS6M-31K2D AS6M-31K2PD AS6M-31K2G AS6M-31K2PG AS6M-32K2C AS6M-32K2PC AS6M-32K2D AS6M-32K2PD AS6M-32K2H AS6M-32K2PH AS6M-33K2D AS6M-33K2PD R DPDT R DPDT R DPDT R DPDT R DPDT R DPDT R DPDT R DPDT R DPDT R DPDT R DPDT R DPDT R DPDT R DPDT • Specify the key code in place of  in the Part No.: T (disc tumbler key), S (wave key) • For contact operation, see page 14. • Key is retained at ● positions and removable at  positions. • Two keys are supplied. • The front of key cylinder is made of metal. • For disc tumbler key, only one type of key is available. • For wave key, besides the standard key (key number 0H), six other keys are also available. To order other keys, specify the key number as shown below: Example: AS6M-2KS1PA-1H (blank): Standard key (0H) 1H to 2H: Reversible key 3H to 6H: Non-reversible key Note: Key number is indicated on the key cylinder. Standard keys do not have a key number indication. 11 ø16 A6 Series Key Selector Switches Key Selector Switches  Package Quantity: 1 Shape Position Key Retained at ● Operation Square AS6Q A 90° 2-position B Maintained Maintained Disc tumbler key B 45° 3-position Spring return from right B L C L D L Spring return from left Spring return two-way L G L H L B L D L C D R L L G R L A E R L C Spring return from right Wave key L L L L H L D L C C C C C C C C C C C C C IP40 IP65 SPDT AS6Q-2K1A AS6Q-2K1PA DPDT AS6Q-2K2A AS6Q-2K2PA SPDT AS6Q-2K1B AS6Q-2K1PB DPDT AS6Q-2K2B AS6Q-2K2PB SPDT AS6Q-2K1C AS6Q-2K1PC DPDT AS6Q-2K2C AS6Q-2K2PC SPDT AS6Q-21K1B AS6Q-21K1PB DPDT AS6Q-21K2B AS6Q-21K2PB R DPDT AS6Q-3K2A AS6Q-3K2PA R DPDT AS6Q-3K2B AS6Q-3K2PB R DPDT AS6Q-3K2C AS6Q-3K2PC R DPDT AS6Q-3K2D AS6Q-3K2PD R DPDT AS6Q-3K2E AS6Q-3K2PE R DPDT AS6Q-3K2G AS6Q-3K2PG R DPDT AS6Q-3K2H AS6Q-3K2PH R DPDT AS6Q-31K2B AS6Q-31K2PB R DPDT AS6Q-31K2D AS6Q-31K2PD R DPDT AS6Q-31K2G AS6Q-31K2PG R DPDT AS6Q-32K2C AS6Q-32K2PC DPDT AS6Q-32K2D AS6Q-32K2PD R DPDT AS6Q-32K2H AS6Q-32K2PH R DPDT AS6Q-33K2D AS6Q-33K2PD R C Contact Part No. R • Specify the key code in place of  in the Part No.: T (disc tumbler key), S (wave key) • For contact operation, see page 14. • Key is retained at ● positions and removable at  positions. • Two keys are supplied. • The front of key cylinder is made of metal. • For disc tumbler key, only one type of key is available. • For wave key, besides the standard key (key number 0H), six other keys are also available. To order other keys, specify the key number as shown below: Example: AS6M-2KS1PA-1H (blank): Standard key (0H) 1H to 2H: Reversible key 3H to 6H: Non-reversible key 12 Note: Key number is indicated on the key cylinder. Standard keys do not have a key number indication. A6 Series Key Selector Switches ø16 Key Selector Switches  Package Quantity: 1 Shape Position Key Retained at ● Operation Rectangular AS6H A 90° 2-position B Maintained Maintained B 45° 3-position Spring return from right B L C L D L Spring return from left L H L B L D L D H Spring return two-way L G C D R L A G R L L E Disc tumbler key R L C Spring return from right Wave key L L L L L L C C C C C C C C C C C C C IP40 IP65 SPDT AS6H-2K1A AS6H-2K1PA DPDT AS6H-2K2A AS6H-2K2PA SPDT AS6H-2K1B AS6H-2K1PB DPDT AS6H-2K2B AS6H-2K2PB SPDT AS6H-2K1C AS6H-2K1PC DPDT AS6H-2K2C AS6H-2K2PC SPDT AS6H-21K1B AS6H-21K1PB DPDT AS6H-21K2B AS6H-21K2PB R DPDT AS6H-3K2A AS6H-3K2PA R DPDT AS6H-3K2B AS6H-3K2PB R DPDT AS6H-3K2C AS6H-3K2PC R DPDT AS6H-3K2D AS6H-3K2PD R DPDT AS6H-3K2E AS6H-3K2PE R DPDT AS6H-3K2G AS6H-3K2PG R DPDT AS6H-3K2H AS6H-3K2PH R DPDT AS6H-31K2B AS6H-31K2PB R DPDT AS6H-31K2D AS6H-31K2PD R DPDT AS6H-31K2G AS6H-31K2PG R DPDT AS6H-32K2C AS6H-32K2PC DPDT AS6H-32K2D AS6H-32K2PD R DPDT AS6H-32K2H AS6H-32K2PH R DPDT AS6H-33K2D AS6H-33K2PD R C Contact Part No. R • Specify the key code in place of  in the Part No.: T (disc tumbler key), S (wave key) • For contact operation, see page 14. • Key is retained at ● positions and removable at  positions. • Two keys are supplied. • The front of key cylinder is made of metal. • For disc tumbler key, only one type of key is available. • For wave key, besides the standard key (key number 0H), six other keys are also available. To order other keys, specify the key number as shown below: Example: AS6M-2KS1PA-1H (blank): Standard key (0H) 1H to 2H: Reversible key 3H to 6H: Non-reversible key Note: Key number is indicated on the key cylinder. Standard keys do not have a key number indication. 13 ø16 A6 Series Key Selector Switches Contact Operation Operator Position & Contact Operation (Top View) Positions Contact Left Center Right NO NC NO NC — SPDT L R L C R 90° 2-position Maintained Spring return from right DPDT C L C R L C R C L R C L R 45° 3-position DPDT Maintained Spring return from right Dimensions Spring return from left Spring return two-way C Left Right Contact Contact NO NC NO NC Left Right Contact Contact NO NC NO NC — C C Left Right Contact Contact NO NC NO NC Left Right Contact Contact NO NC NO NC C C C C Left Right Contact Contact NO NC NO NC C C C 2.5 Right Contact Disc Tumbler Key 1.0 2.6 1.2 3 TOP Left Contact 2-R0.6 Rubber Gasket Terminal Width 2.8×0.5t 5 3 Panel Thickness 0.5 to 6 Locking Ring Round (TOP) Square (TOP) Rectangular (TOP) NC 18 5 2.5 Anti-rotation Ring NO C 1 8 Wave Key 9 22 18 ø18 26 24 Panel thickness 0.5 to 6 Gasket 2.5 Locking Ring 3 TOP Anti-rotation Ring Round/Square C C SPDT DPDT 22 ø18 18 24 ø18 18 24 10.2 0.6 31.3 NC NC NO C C 18 Key No.: 0H to 2H NO SPDT 1 8 Rectangular Rectangular 18 NC NO Square 5 NC NO Round 5 Terminal Width 2.8×0.5t DPDT Terminal Arrangement (bottom view) (Key Selector Switch) Key No.: 3H to 6H Mounting Hole Layout Round/Square (TOP) ø16.2 Rectangular +0.2 0 ø16.2 +0.2 0 C1 Note: Determine mounting centers to ensure easy operation. 18 min. NO1 NO2 18 min. NC1 NC2 C2 SPDT has NC1, NO1, and C1 only. 18 min. 14 24 min. All dimensions in mm. A6 Series Accessories ø16 Accessories Shape Material Part No. Ordering No. Package Quantity Remarks Locking Ring Wrench ø18 60 Lamp Holder Tool ø10 Metal (nickel-plated brass) MT-001 MT-001 1 • Used to tighten the locking ring when installing A6 series into a panel. Rubber OR-77 OR-77 1 • Used to install and remove the LED lamps. Stainless Steel MT-101 MT-101 1 • Used to install and remove lenses and buttons. LB9Z-K2 LB9Z-K2 1 • Degree of protection: IP40 • Used to protect pushbuttons from inadvertent operation. LB9Z-K3P LB9Z-K3P 1 • Degree of protection: IP65 • Used to protect pushbuttons from inadvertent operation. AL-K6S AL-K6S 1 • Degree of protection: IP40 • Used to protect pushbuttons from inadvertent operation. AL-K6SP AL-K6SP 1 • Degree of protection: IP65 (when used with IP65 control units) • Used to protect pushbuttons from inadvertent operation. AL-KH6S AL-KH6S 1 • Degree of protection: IP40 • Used to protect pushbuttons from inadvertent operation. 1 • Degree of protection: IP65 (when used with IP65 control units) • Used to protect pushbuttons from inadvertent operation. ø9 55 Lens Removal Tool 60 For round/ square units (110°, 180°) Guard (polyacetal) Cover (polyarylate) For round/ square units (180°) See page 16 for dimen­ sions. For rectan­ gular units (180°) AL-D6 Translucent cover: For square units elastomer AL-DQ6 Black part: For rectan­gular polypropylene AL-DH6 units For round units Terminal Cover Solder Terminal PC Board Terminal See page 17 for dimen­sions. 1 AL-DQ6 1 AL-DH6 1 AL-V6 AL-V6PN10 10 AL-C6 AL-C6 1 AL-C6V AL-C6V 1 • When mounting the units with the dust covers installed, refer to mounting hole layout on page 17. • Operating temperature: –10 to +55°C • When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. • Terminal cover is not attached and must be ordered separately. • Plugs on the rear of the A series. Mounting Hole Plug • Degree of protection: IP65 2 Mounting Hole 5 ø1 AL-B6PN05 ø18 AL-B6 Mounting Hole Plug 6 ø16.5 Rubber Nitryl rubber (black) 0 .2 Socket Polyamide (white) See page 17 for dimen­sions. AL-D6 6. 2 + 0 Dust Cover AL-KH6SP AL-KH6SP • Degree of protection: IP65 • Tightening torque: 0.1 to 0.29 N·m. 2.5 12 Mounting Hole AL-BM6 1 Gasket ø1 AL-BM6 ø17.8 Metal Plug: metal (diecast) Locking ring: polyacetal Gasket: nitrile 6. 2 + 0 0 .2 [Spring return] For pushbuttons, illuminated pushbuttons Spring Return Switch Guard For rectan­ gular units (remains 110°, 180°) 11 0° 18 0° [Remains open} For pushbuttons, illuminated pushbuttons Locking Ring Panel Thickness 0.5 to 6 All dimensions in mm. 15 ø16 A6 Series Accessories Dimensions Switch Guard [Remains open] For round/square units (Degree of protection: IP40) LB9Z-K2 Panel Thickness 0.5 to 5.6 32.7 Rubber Gasket 18 24 12.4 23.5 13 11 18 0° 0° 13 23.5 11 11 18 0° 0° 32.9 32.9 Rubber Gasket 32.7 11 Panel Thickness 0.5 to 5.6 For rectangular units (Degree of protection: IP65) LB9Z-K3P 12.4 [Spring return] Panel Thickness 0.5 to 5 Rubber Gasket 2 Rubber Gasket 18 R2 24 2 11 11 13 23.5 33 R2 34 13.5 13.5 For rectangular units (Degree of protection: IP65) AL-KH6SP Panel Thickness 0.5 to 5 34 2 Rubber Gasket 18 R2 33 11 13 23.5 R2 Waterproof Gasket for Switch Guard 16 0.4 13.5 24 2 11 13 23.5 Rubber Gasket 34 33 For round/square units (Degree of protection: IP65) AL-K6SP Panel Thickness 0.5 to 5 23.5 34 13 Panel Thickness 0.5 to 5 For rectangular units (Degree of protection: IP40) AL-KH6S 33 For round/square units (Degree of protection: IP40) AL-K6S Waterproof Gasket for Switch Guard 0.4 13.5 A6 Series Accessories ø16 Socket 2.5 TOP 8-1.6 2.5 Terminal 1.5×0.3t 33.5 3 +0.3 0 Holes 3 2.4 33.5 (TOP) 5 5 5 5 NC1 NC2 NO1 NO2 16.2 6 7.5 6 16.2 Solder Terminal (AL-C6) 3.8 6 6 Lamp Terminal (+) PC Board Mounting Hole Layout (Bottom View) PC Board Terminal (AL-C6V) C1 C2 Lamp Terminal (–) Terminal Arrangement (Bottom View) Terminal Cover 17.3 ø16.8 Note: When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. 33.5 Dust Cover Mounting Hole Centers For Round Units (AL-D6) For Square Units (AL-DQ6) For Rectangular Units (AL-DH6) c 24 30 ø16.2 Rectangular Units +0.2 0 ø16.2 +0.2 0 7.5 13 Waterproof Gasket for Dust Cover 24 min. 30 min. 24 min. 0.3 7.5 13 Waterproof Gasket for Dust Cover 0.3 7.5 0.3 13 24 min. 24 ø24 Round/Square Units Waterproof Gasket for Dust Cover Large Lens and Large Button Rubber Gasket Anti-rotation Ring Terminal Width 2.8×0.5t Locking Ring 2.5 3 Panel Thickness 0.5 to 6 6 6 1 8 0.6 22 9 Round (TOP) 23.5 15.5  23.5 ø23.5 Square (TOP) 17.5 5 5 Rectangular (TOP) 0.6 9 0.6 15.5 AL6Q-LK2-H➁ AB6Q-BK2-H➁ 12.5 AL6Q-LK2-Q➁ AB6Q-BK2-Q➁ AL6Q-LK2-M➁ AB6Q-BK2-M➁ All dimensions in mm. 17 ø16 A6 Series Accessories Grip Style Enabling Switch Housing The following A6 series switches can be installed on the HE9ZGSH51 grip style enabling switch housing to be used as handheld switches. • AB6M pushbutton (IP65) • AS6M selector switch (IP65) • AS6M key selector switch (IP65) (illuminated pushbutton and pilot light cannot be installed) Part No. HE9Z-GSH51 Ordering No. Package Quantity HE9Z-GSH51 1 Specifications Applicable Cable Conduit Port Size Weight (approx.) Outside diameter ø4.5 to 10 mm M16 (cable gland is supplied with the grip style enabling switch housing) 65g (grip style enabling switch housing only) • The above specifications are for the grip style enabling switch housing only. Make sure to check the specifications of switches also. • For the detailed specifications of grip style enabling switch housing, A6 series switches, and HE5B enabling switch, see their catalogs. Notes: • The HE9Z-GSH51 grip style enabling switch housing does not include the A6 series switche or HE5B enabling switch, and they must be ordered separately. • The switches must be installed and wired to the HE9ZGSH51 grip style enabling switch housing by the user. For infor­mation on wiring, see the instruction sheet supplied with the HE9Z-GSH51. Dimensions HE5B Enabling Switch (78) 144 (ordered separately) 92 39 HE9Z-GSH51 38 Cable Gland Part No. SKINTOP BS-M16 × 1.5 (LAPP) HE9Z-GSH51 + HE5B Construction Housing Head Cable Gland Locking Ring HE5B Enabling Switch (not supplied with the grip style enabling switch housing) • Anti-rotation ring is not required when installing the HE5B enabling switch on the HE9Z-GSH51 grip style enabling switch housing. Use the locking ring only. Mounting Bracket Part No: HE9Z-GH1 50 2-ø5.3 (For M5 mounting screws) 20 Plastic Coating 33 81 18 86 Material: SUS304 Thickness: 3.0 mm All dimensions in mm. A6 Series Maintenance Parts ø16 Maintenance Parts Shape Lens Round Ordering No. AL6M-L➁PN05 AL6Q-L➁ AL6Q-L➁PN05 Rectangular AL6H-L➁ AL6H-L➁PN05 Round AB6M-B➀ AB6M-B➀PN05 AB6Q-B➀ AB6Q-B➀PN05 AB6H-B➀ AB6H-B➀PN05 Square Polyarylate Polyarylate Rectangular Marking Plate Round Square Acrylic Rectangular Large Lens Unit Part No. AL6M-L➁ Square Button Specification Round (installed on round units) Square (installed on square units) Rectangular (installed on square units) White AL6M-W AL6M-WPN05 Black AL6M-B AL6M-BPN05 White AL6Q-W AL6Q-WPN05 Black AL6Q-B AL6Q-BPN05 White AL6H-W AL6H-WPN05 Black AL6H-B AL6H-BPN05 Package Quantity Remarks Specify a color code in place of ➁ in the Part No. A (amber), C (clear), G (green) R (red), S (blue), Y (yellow) • Use a C (clear) lens for W (white) and JW (pure white) illumination. 5 Specify a color code in place of ➀ in the Part No. B (black), G (green), R (red) S (blue), W (white), Y (yellow) Translucent color lens AL6M-LK2-M➁ Opaque button AB6M-BK2-M➁ AB6M-BK2-M➁ Translucent color lens AL6Q-LK2-Q➁ AL6Q-LK2-Q➁ Opaque button AB6Q-BK2-Q➁ AB6Q-BK2-Q➁ Translucent color lens AL6Q-LK2-H➁ AL6Q-LK2-H➁ Opaque button AB6Q-BK2-H➁ AB6Q-BK2-H➁ • See page 17 for dimensions. Polyacetal HA9Z-LN HA9Z-LNPN10 • Black AL6M-LK2-M➁ 1 • Specify a color code in place of ➁ in the Part No. • Degree of protection: IP65 ➁ Color Code Translucent Opaque Button Color Lens A (amber) G (green) R (red) S (blue) W (white) Y (yellow) B (black) G (green) R (red) S (blue) W (white) Y (yellow) Locking Ring 10 Anti-rotation Ring Stainless Steel LB9Z-LP1 LB9Z-LP1PN10 AS6-SK-132 AS6-SK-132PN02 Spare key Key selector (disc Brass with tumbler nickel plating key) 2 • Thickness 1.8 mm Spare Key Reversible Key selector (wave key) • Specify a key number in place of  in the Part No. Diecast zinc alloy (nickelplated) LA9Z-SK- LA9Z-SK-PN02 2 Rubber AP6M-WM AP6M-WMPN10 10 0H: Standard key (reversible) 1H to 2H: Reversible key 3H to 6H: Non-reversible key Non-reversible Gasket 19 ø16 A6 Series Maintenance Parts LED Lamps Dimensions Current Draw Operating Volt­age 5V DC ±5% 6V DC ±5% AC DC — 8 mA 7 mA (G, S, JW) 8 mA (A, R, W) 5 mA (G, S, JW) 6 mA (A, R, W) Part No. LATD-5➁ LATD-6➁ 13.3 12 4 Voltage Electrode 12V AC/ DC ±10% 9 mA 8 mA LATD-1➁ 24V AC/ DC ±10% 9 mA 8 mA LATD-2➁ ➁ Illumination Package Ordering No. Quantity Color Code LATD-5➁ 1 LATD-5➁PN10 Specify a color code in place of ➁ in the LATD-6➁ Ordering No. LATD-6➁PN10 A: amber G: green LATD-1➁ JW: pure white LATD-1➁PN10 R: red S: blue LATD-2➁ W: white 10 LATD-2➁PN10 10 Base 1 10 1 Exclusive for A6 series 10 1 • Use a pure white (JW) LED lamp for yellow illumination Safety Precautions • Turn off the power to A series before starting installation, removal, wiring, maintenance, and inspection of the units. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid a burn on your hand, use the lamp holder tool when replacing lamps. • For wiring, use wires of a proper size to meet the voltage and current requirements. Failure to tighten terminal screws may cause overheating and create a fire hazard. Operating Instructions Replacement of Lens and Marking Plate Replacing the LED Lamp Removal Removal Remove the lens assembly (color lens, marking plate, lens holder, and spring) by holding the color lens recesses with the Lens Removal Tool (MT-101) and pulling it out. Remove the marking plate by disengaging the latches between the color lens and lens holder. Fitting Grooves The marking plate must be Grooves engraved on the front side as shown at right. When using a color film, insert it between the color Engraving lens and marking plate. Surface Use the lamp holder tool (OR-77) to remove lamps. Do not use pliers. Installation Color Lens Marking Plate Marking For A series illuminated pushbuttons, legends and symbols can be engraved on the built-in marking plates, or printed film can be inserted under the lens for labelling purposes. Marking Plate & Engraving Area c12.0 12.0 12.0 Rectangular Engraving Area 18.0 0.8 Engraving Area 0.8 ø12.0 0.8 Built-in Marking Plate and Engraving Area Square Engraving Area 13.6 ø13.6 • Engraving must be made on the engraving area within 0.5mm deep. • The marking plate is made of white acrylic resin. Applicable Marking Film (not supplied) 11.8 c13.6 • Thickness = 0.1 mm × 1 film • Recommended film material: polyester 20 Use the lamp holder tool (OR-77) to install lamps. Note the correct side of the tool for removal or installation. OR-77 19.6 For removing lamps ø9 ø10 For installing lamps Lens Holder Place the marking plate on the lens holder in the correct direction, and press the color lens onto the lens holder to engage the latches. Put the spring on the lens holder and insert the lens holder into the housing in the correct direction. Round Installation 55 All dimensions in mm. Panel Mounting When mounting the units into a panel, use the optional locking ring wrench (MT-001) to tighten the locking ring. Do not use pliers. Tightening torque must not exceed 0.88 N·m. Excessive tightening will damage the locking ring. Wiring Solder the terminal at 350°C within 3 seconds using a 60W soldering iron. Sn-Ag-Cu is recommended when using lead-free solder. When soldering, do not touch the unit with the soldering iron. Also ensure that no tensile force is applied to the terminal. Do not bend the terminal or apply excessive force to the terminal. Use a non-corrosive rosin flux. Installing the Socket Install the socket on the unit with the TOP markings on the unit and the socket placed in the same direction. A6 Series Operating Instructions ø16 Switch Guard IP65 (IEC 60529) switch guards must be used with IP65 (IEC 60529) units only. Even if IP65 type switch guards are installed, enclosed type (IP40) units are not made waterproof. Item Switch IP65 IP40 Switch Guard IP65 (IEC 60529) IP40 (IEC 60529) IP65 IP40 IP40 IP40 Opening/closing the Switch Guard (LB9Z-K2, LB9Z-K3P) When opening/closing the switch guard while the switch guard is not installed on a panel, make sure to hold the hinge. Holding the base might result in damage. Also do not apply force on the guard in other than open/close directions, otherwise the hinge may be damaged. Hinge Base Operating Voltage of LED Lamps The operating voltage of 5V DC is measured at complete DC. Other Notes Close Proximity Mounting When mounting pilot lights or illuminated pushbuttons collectively or lighting them continuously, heat may cause the ambient temperature to rise above the rated operating temperature. When the mounting panel is not made of metal or when the units are mounted in an enclosed panel, provide for ventilation or lower the operating voltage. Replacement of Buttons (Illuminated/Non-illuminated) Do not replace buttons of maintained action units while the button is in the locked position. Replacing the button in the locked position may damage the internal mechanism. Be sure to release the button before replacing. Operating and Storage Environment 1. Make sure that the operating/storage temperature and humidity are within the ratings. 2. Do not use enclosed type units in an environment subject to oil, water or dust accumulation. In such an area, use the waterproof/ oiltight units (IP65). Microswitch Contacts Do not connect NO and NC contacts of a microswitch to different voltages or different power sources to prevent a dead short-circuit. IP65 Units IP65 units are evaluated by conventional cutting and cooling oils, and can not be used with some special oils. Contact IDEC for resistance against specific oils. Selector Switches with Key Observe the following instructions to prevent malfunction or damage. • Insert the key to the bottom of the key hole. • Do not remove the key from any key retained position. • Besides the standard key (key number 0H), six other key numbers are available. Use a key of the matching number with the key cylinder. The standard key does not have a key number indication. • Keys are available in two types. Key numbers 0H (standard), 1H, and 2H are reversible keys which can be inserted in two ways. Key numbers 3H, 4H, 5H, and 6H are non-reversible keys. Make sure of correct insertion direction. 21 ø12 A2 Series Switches and Pilot Lights Short 22-mm-long body miniature switches and pilot lights with bright LED illumination face and snap-action switching. • Degree of protection: IP40 and IP65 (IEC 60529) • All series have terminals on the same plane. • UL recognized, CSA certified Applicable Standards Mark File No. or Organization UL508 UL Recognition File No. E55996 CSA C22.2 No.14 CSA File No. LR 21451 GB14048.5 CCC No.2013010305647324 (except for pilot lights) Contact Ratings (Contact Block) Rated Insulation Voltage Rated Thermal Current Operating Voltage (AC/DC) Resistive Load AC 50/60 Hz Inductive Load Resistive Load DC Inductive Load Contact Material 250V 3A 24V – – 1.0A 0.7A Silver 110V 1.0A 0.7A 0.2A 0.1A Specifications 220V 0.5A 0.5A – – • Minimum applicable load: 5V AC/DC, 3 mA (applicable range may vary with operating conditions and load types) Weight Weight (approx.) AL2M-M11: 4g AL2M-P1: 4g AB2M-M1: 4g Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance –25 to +55°C (no freezing) –30 to +80°C (no freezing) 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts: 2,000V AC, 1 minute Between terminals of different poles: 2,000V AC, 1 minute Switch Unit Between terminals of the same pole: Dielectric 1,000V AC, 1 minute Strength Between contact and lamp terminals: 1,500V AC, 1 minute Illumination Between live part and ground: Unit 2,000V AC, 1 minute Damage limits, Operating extremes: Vibration Resistance 5 to 55 Hz, amplitude 0.75 mm Damage limits: 500 m/s2 (50G) Shock Resistance Operating extremes: 200 m/s2 (20G) Mechanical Durability Momentary: 200,000 operations (minimum operations) Maintained: 100,000 operations Momentary: 100,000 operations Electrical Durability Maintained:   50,000 operations (minimum operations) (Switching frequency 1200 operations/h) Degree of Protection IP40, IP65 (IEC 60529) LED Lamp Ratings (LAD-S) Built-in LED Part No. Lamp Base Forward Current (If) Forward Voltage (Vf) (nominal) Reverse Voltage (Vr) Illumination Color LED Lamp Color Applicable Lens Color Base Plastic Color LED Lamp Life (reference value) Operating Voltage & External Current-limiting Resistor (recommended value) (Note) Internal Circuit LAD-SA LAD-SG LAD-SR LAD-SY Exclusive for A series 20 mA 2.2V 2.1V 1.7V 2.2V 4V A G R Y Amber Clear Yellow Diffused Red Clear Yellow Clear Amber Green Red Yellow and White Red Approx. 50,000 hours (The illuminance reduces to 50% of the initial intensity when used on complete DC.) 5V DC: 150Ω, 1/2W 6V DC: 200Ω, 1/2W 12V DC: 510Ω, 1W 24V DC: 1.1 kΩ, 1W (+) (–) Note: When LED lamps are used on voltages other than the above, external resistor value R is determined by the following formula: R = (operating voltage – Vf) / If (+) (–) • LED lamps do not have a current-limiting resistor, and external resistors of recommended values for each voltage must be provided. Connect a current-limiting resistor in series, otherwise LED Current Lamp Lamp Limiting lamps will be damaged. Because no protection diode is contained, ensure the correct polarity is Terminal (+) Terminal (–) Resistor observed. 22 A2 Series Illuminated Pushbuttons and Pilot Lights ø12 Illuminated Pushbuttons & Pilot Lights  Package Quantity: 1 LED Lamp Part No., Rated Current Part No. Shape Operation Round AL2M Contact ➁ Lens Color IP40 IP65 SPDT AL2M-M11➁ AL2M-M11P➁ DPDT AL2M-M21➁ AL2M-M21P➁ SPDT AL2M-A11➁ AL2M-A11P➁ DPDT AL2M-A21➁ AL2M-A21P➁ — AL2M-P1➁ AL2M-P1P➁ SPDT AL2Q-M11➁ AL2Q-M11P➁ DPDT AL2Q-M21➁ AL2Q-M21P➁ SPDT AL2Q-A11➁ AL2Q-A11P➁ DPDT AL2Q-A21➁ AL2Q-A21P➁ — AL2Q-P1➁ AL2Q-P1P➁ SPDT AL2H-M11➁ AL2H-M11P➁ DPDT AL2H-M21➁ AL2H-M21P➁ SPDT AL2H-A11➁ AL2H-A11P➁ DPDT AL2H-A21➁ AL2H-A21P➁ — AL2H-P1➁ AL2H-P1P➁ Code (External Resistor Recommended Value) Momentary Maintained (except for pilot lights) Pilot Light Square AL2Q Momentary Maintained (except for pilot lights) Pilot Light Rectangular AL2H A: LAD-SA Specify a color G: LAD-SG code in place of R: LAD-SR ➁ in the Part No. W/Y: LAD-SY A: amber G: green R: red W: white Y: yellow Rated Current: 20 mA 5V DC: 150Ω, 1/2W 6V DC: 200Ω, 1/2W 12V DC: 510Ω, 1W 24V DC: 1.1 kΩ, 1W Momentary Maintained (except for pilot lights) Pilot Light • LED lamps do not have a current-limiting resistor. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. • External current-limiting resistor is not necessary when an optional socket with built-in resistor is used (see page 25). • AP2M series pilot lights (round bezel only) with built-in current-limiting resistors are also available. (+) (–) • Pilot lights are not CCC certifed. Current Limiting Resistor Dimensions Lamp Terminal (+) Lamp Terminal (–) Panel Thickness 0.5 to 6 Rubber Gasket Rectangular (TOP) Locking Ring Square (TOP) Round (TOP) c14 ø14 2.8 5 5.5 ø14 14 9.2 2.8 Terminal Width 1.8×0.4t 0.6 7 Terminal Arrangement 22 0.6 9 18 9 Mounting Hole Layout Round/Square Units Lamp Terminal (+) 5.5 Rectangular Units +0.2 ø12 0 (TOP) ø12 +0.2 0 NC1 NC2 Note: Determine mounting centers to ensure easy operation. 14 min. C1 C2 SPDT has NC1, NO1, and C1 only. 14 min. NO1 NO2 Lamp Terminal (–) 14 min. 18 min. All dimensions in mm. 23 ø12 A2 Series Pushbuttons Pushbuttons  Package Quantity: 1 Shape Button Style Operation Round AB2M Contact Momentary Button Maintained Momentary Lens Maintained Square AB2Q Momentary Button Maintained Momentary Lens Maintained Rectangular AB2H Part No. Momentary Button Maintained Momentary Lens Maintained IP40 IP65 SPDT AB2M-M1➀ AB2M-M1P➀ DPDT AB2M-M2➀ AB2M-M2P➀ SPDT AB2M-A1➀ AB2M-A1P➀ DPDT AB2M-A2➀ AB2M-A2P➀ Color Code ➀➁ B: black G: green R: red S: blue W: white Y: yellow SPDT AB2M-M1L➁ AB2M-M1PL➁ DPDT AB2M-M2L➁ AB2M-M2PL➁ SPDT AB2M-A1L➁ AB2M-A1PL➁ DPDT AB2M-A2L➁ AB2M-A2PL➁ SPDT A: amber G: green R: red W: white Y: yellow B: black G: green R: red S: blue W: white Y: yellow AB2Q-M1➀ AB2Q-M1P➀ DPDT AB2Q-M2➀ AB2Q-M2P➀ SPDT AB2Q-A1➀ AB2Q-A1P➀ DPDT AB2Q-A2➀ AB2Q-A2P➀ SPDT AB2Q-M1L➁ AB2Q-M1PL➁ DPDT AB2Q-M2L➁ AB2Q-M2PL➁ SPDT AB2Q-A1L➁ AB2Q-A1PL➁ DPDT AB2Q-A2L➁ AB2Q-A2PL➁ SPDT AB2H-M1➀ AB2H-M1P➀ DPDT AB2H-M2➀ AB2H-M2P➀ SPDT AB2H-A1➀ AB2H-A1P➀ DPDT AB2H-A2➀ AB2H-A2P➀ SPDT AB2H-M1L➁ AB2H-M1PL➁ DPDT AB2H-M2L➁ AB2H-M2PL➁ SPDT AB2H-A1L➁ AB2H-A1PL➁ DPDT AB2H-A2L➁ AB2H-A2PL➁ A: amber G: green R: red W: white Y: yellow B: black G: green R: red S: blue W: white Y: yellow A: amber G: green R: red W: white Y: yellow • Specify a color code in place of ➀ or ➁ in the Part No. Dimensions Panel Thickness 0.5 to 6 Rubber Gasket Locking Ring Square (TOP) Round (TOP) c14 ø14 5 0.6 5.5 22 Terminal Arrangement (TOP) 0.6 9 18 Round/Square Units ø12 Rectangular Units +0.2 0 14 min. C1 C2 9 Mounting Hole Layout NC1 NC2 NO1 NO2 5.5 ø12 +0.2 0 14 min. 2.8 14 2.8 Rectangular (TOP) SPDT has NC1, NO1, and C1 only. 14 min. 18 min. Note: Determine mounting centers to ensure easy operation. 24 All dimensions in mm. A2 Series Accessories ø12 Accessories Shape Material Part No. Ordering Part No. Package Quantity Remarks Locking Ring Wrench ø14 Metal (nickel-plated brass) MT-002 MT-002 1 • Used to tighten the locking ring when installing the A2 series into a panel. Stainless Steel MT-101 MT-101 1 • Used to remove lens and button. Rubber OR-66 OR-66 1 • Used to remove and install LED lamps. For round/ square unit AL-K2 AL-K2 1 For rectangular unit AL-KH2 AL-KH2 1 Solder Terminal AL-C2 AL-C2 1 PC Board Terminal AL-C2V AL-C2V 1 5V DC AL-C21 AL-C21 1 6V DC AL-C22 AL-C22 1 12V DC AL-C23 AL-C23 1 24V DC AL-C24 AL-C24 1 5V DC AL-C21V AL-C21V 1 6V DC AL-C22V AL-C22V 1 12V DC AL-C23V AL-C23V 1 24V DC AL-C24V AL-C24V 1 60 Lens Removal Tool 60 Lamp Holder Tool 70 90° open Socket Socket with Built-in Resistor Solder Terminal PC Board Terminal Terminal Cover Nylon AL-V2 AL-V2PN10 10 For round units AL-D2 AL-D2 1 For square units AL-DQ2 AL-DQ2 1 For rectangular units AL-DH2 AL-DH2 1 Nitryl rubber (black) AL-B2 AL-B2PN05 5 Dust Cover • Degree of protection: IP40 • Used to protect pushbuttons from inadvertent operation. • See page 26 for dimensions. (remains 90° open) • Snaps on the rear of the A2 series. (see page 26 for dimensions) • A current limiting resistor is contained, eliminating the need for external resistors. Green • When using the socket with a built-in resistor, make sure Yellow that the continuous current is 1A maximum and the Red operating temperature is –25 to +40°C. In collective Blue mounting, keep center-to center-spacing of 20 mm Green or more between adjacent units in consideration of Yellow built-in resistor heating. • See page 26 for Red dimensions. Blue Socket Bottom Color Switch Guard • When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. • Terminal cover is not attached and must be ordered separately. • When mounting the units with the dust covers installed, refer to mounting hole layout on page 26. • Operating temperature: –10 to +55°C • Material Front part: Elastomer (transparent) Rear part: Polypropylene (black) • See page 26 for dimensions and mounting hole layout. Mounting Hole Plug • Degree of protection: IP65 25 ø12 A2 Series Accessories Dimensions Switch Guard 11 22.5 min. 19.5 22.5 min. Rubber Gasket 12.5 Panel Thickness 0.5 to 5 26.5 18 11 8.5 19.5 For Rectangular Units (AL-KH2) Panel Thickness 0.5 to 5 26.5 14 8.5 For Round/Square Units (AL-K2) 15 min. Rubber Gasket 12.5 19 min. Socket (AL-C2, AL-C2V, AL-C2) 6 1 33 2.8 17 Solder Terminal (AL-C2) 1 4.5 8-1.0 +0.2 0 C1 C2 Lamp Terminal (–) Holes Panel Cut-out Bottom View PC Board Terminal (AL-C2V) 6 NO1 NO2 2.8 13 2.8 6.5 36 1 6 20 2.8 10.2 3.5 20 Solder Terminal with Built-in Resistor (AL-C2  ) Terminal Cover 2.8 13 5.3 4.9 6.5 7.3 5.5 7 2.8 10.5 6.5 7.3 2.8 36 NC1 NC2 10.5 10.5 17 Lamp Terminal (+) (TOP) 6 1 2.8 33 Terminal Arrangement Terminal 0.8 × 0.3t 8-1.0 5 +0.2 0 Holes Panel Cut-out Bottom View PC Board Terminal with Built-in Resistor (AL-C2  V) 17.3 ø12.8 (AL-V2) Note: When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. 33.5 Dust Cover For Square Units (AL-DQ2) For Rectangular Units (AL-DH2) c 20 24 ø12 20 min. 12 12 12 20 ø20 Mounting Hole Centers (Round Units, Square Units) 20 min. For Round Units (AL-D2) ø12 Waterproof Gasket for Dust Cover 20 min. 0.3 Waterproof Gasket for Dust Cover 6.5 0.3 Waterproof Gasket for Dust Cover 6.5 0.3 6.5 (Rectangular Units) 24 min. Note: Determine mounting centers to ensure easy operation. All dimensions in mm. 26 A2 Series Maintenance Parts ø12 Maintenance Parts Specification Marking Plate Part No. Round AL2M-W AL2M-WPN05 Square AL2Q-W AL2Q-WPN05 Rectangular AL2H-W AL2H-WPN05 Round AL2M-LK1-➁ AL2M-LK1-➁PN02 Square AL2Q-LK1-➁ AL2Q-LK1-➁PN02 Rectangular AL2H-LK1-➁ AL2H-LK1-➁PN02 Round AL2M-LK2-➁ AL2M-LK2-➁ Square AL2Q-LK2-➁ AL2Q-LK2-➁ Rectangular AL2H-LK2-➁ AL2H-LK2-➁ Round AL2M-LK3-➁ AL2M-LK3-➁ Square AL2Q-LK3-➁ AL2Q-LK3-➁ Rectangular AL2H-LK3-➁ AL2H-LK3-➁ Round AB2M-BK1-➀ AB2M-BK1-➀PN02 Square AB2Q-BK1-➀ AB2Q-BK1-➀PN02 Rectangular AB2H-BK1-➀ AB2H-BK1-➀PN02 Round AB2M-BK2-➀ AB2M-BK2-➀ Square AB2Q-BK2-➀ AB2Q-BK2-➀ Rectangular AB2H-BK2-➀ AB2H-BK2-➀ Lens Unit For IP40 units For IP65 illumi­ nated pushbut­ tons For IP65 pilot lights Button Unit For IP40 pushbuttons For IP65 pushbuttons LED Lamp 5.3 9.0 Illumination color: amber LAD-SA Illumination color: green LAD-SG Illumination color: red LAD-SR Illumination color: yellow LAD-SY ø4.0 Current-limiting resistor is not contained. All dimensions in mm. Ordering Part No. Package Quantity 5 Color Code ➀➁ White 2 • Specify a color code in place of ➁ in the Part No. 1 2 1 LAD-SA 1 LAD-SAPN10 10 LAD-SG 1 LAD-SGPN10 10 LAD-SR 1 LAD-SRPN10 10 LAD-SY 1 LAD-SYPN10 10 A: amber G: green R: red W: white Y: yellow • Specify a color code in place of ➀ in the Part No. B: black G: green R: red S: blue W: white Y: yellow Lens color Shape Amber LED color: amber clear Green LED color: yellow diffused Red LED color: clear red White/ LED color: yellow Yellow clear 27 ø12 A2 Series Operating Instructions Safety Precautions • Turn off the power to A series before starting installation, removal, wiring, maintenance, and inspection of the units. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid burning your hand, use the lamp holder tool when replacing lamps. • For wiring, use wires of a proper gauge to meet the voltage and current requirements. Failure to tighten terminal screws may cause overheating and create a fire hazard. Operating Instructions Replacement of Lens and Marking Plate Panel Mounting Removal When mounting the units onto a panel, use the optional locking ring wrench (MT-002) to tighten the locking ring. Do not use pliers. Tightening torque must not exceed 0.78 N·m. Excessive tightening will damage the locking ring. Remove the lens assembly (color lens, marking plate, lens holder, and spring) by holding the color lens recesses with the Lens Removal Tool (MT-101) and pulling it out. Remove the marking plate by disengaging the latches between the color lens and lens holder. The marking plate must be engraved on the front side as shown below. Latches Wiring Solder the terminal at 350°C within 3 seconds using a 60W soldering iron. Sn-Ag-Cu is recommended when using lead-free solder. When soldering, do not touch the unit with the soldering iron. Also ensure that no tensile force is applied to the terminal. Do not bend the terminal or apply excessive force to the terminal. Use non-corrosive rosin flux. Installing the Socket Engraving Area Color Lens Marking Plate Install the socket on the unit with the TOP markings on the unit and the socket placed in the same direction. Lens Holder Installation Operating Voltage of LED Lamps Place the marking plate on the lens holder in the correct direction, and press the color lens onto the lens holder to engage the latches. Put the spring on the lens holder and insert the lens holder into the housing in the correct direction. The operating voltage is measured at complete DC. When using a pulsating voltage such as a full-wave rectification voltage, keep peak currents within the forward current If. Peak currents exceeding the If may shorten the LED lamp life. Installing Non-illuminated Button Non-illuminated pushbuttons contain a marking plate like illuminated units. Be sure to install the marking plate when replacing the button. Marking For A series illuminated pushbuttons, legends and symbols can be engraved on the built-in marking plates, or printed film can be inserted under the lens. Marking Plate & Engraving Area Engraving Area 9 8 Size: 10 Size: ø10 Engraving Area 8 Engraving Area Rectangular 12 0.8 Square 0.8 ø9 Round 0.8 Built-in Marking Plate Lens Size: 14 x 10 • Engraving must be made on the engraving area less than 0.5mm deep. • The marking plate is made of white acrylic resin. Replacing the LED Lamp Removal Use the lamp holder tool (OR-66) to remove lamps. Do not use pliers. Installation Use the lamp holder tool (OR-66) to install lamps. Note the correct side of the tool for removal or installation. Lamp Holder Tool OR-66 (ø8, ø10, ø12 series) For removing lamps 28 For installing lamps Other Notes Close Proximity Mounting When mounting pilot lights or illuminated pushbuttons collectively or lighting them continuously, heat may cause the ambient temperature to rise above the rated operating temperature. When the mounting panel is not made of metal or when the units are mounted in an enclosed panel, provide for ventilation or lower the operating voltage. Replacement of Buttons (Illuminated/Non-illuminated) Do not replace buttons of maintained action units while the button is in the locked position. Replacing the button in the locked position may damage the internal mechanism. Be sure to release the button before replacing. Operating and Storage Environment 1. Make sure that the operating/storage temperature and humidity are within the ratings. 2. Do not use enclosed units (IP40) in an environment subject to oil, water or dust accumulation. In such an area, use the waterproof/oiltight units (IP65). Microswitch Contacts Do not connect NO and NC contacts of the microswitch to different voltages or different power sources to prevent a dead short-circuit. IP65 Units IP65 units are evaluated by conventional cutting and cooling oils, and can not be used with some special oils. Contact IDEC for resistance against special oils. ø10 A1 Series Switches and Pilot Lights Short 22-mm-long body miniature switches and pilot lights with LED illumination face and snap-action switching. • Bright and clear LED illumination. • All series have terminals on the same plane. • UL recognized, CSA certified Applicable Standards Mark File No. or Organization UL508 UL Recognition File No. E55996 CSA C22.2 No.14 CSA File No. LR 21451 GB14048.5 CCC No.2013010305662162 (except for pilot lights) Contact Ratings (Contact Block) Rated Insulation Voltage Rated Thermal Current Operating Voltage (AC/DC) Resistive Load AC 50/60 Hz Inductive Load Resistive Load DC Inductive Load Contact Material 250V 3A 24V – – 1.0A 0.7A Silver 110V 1.0A 0.7A 0.2A 0.1A Specifications 220V 0.5A 0.5A – – • Minimum applicable load: 5V AC/DC, 3 mA (applicable range may vary with operating conditions and load types) Weight Weight (approx.) AL1M-M11: 3g AL1M-P1: 3g AB1M-M1: 3g Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance –25 to +55°C (no freezing) –30 to +80°C (no freezing) 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts: 2,000V AC, 1 minute Between terminals of different poles: 2,000V AC, 1 minute Switch Unit Between terminals of the same pole: Dielectric 1,000V AC, 1 minute Strength Between contact and lamp terminals: 1,500V AC, 1 minute Illumination Between live part and ground: Unit 2,000V AC, 1 minute Damage Limits, Operating extremes: Vibration Resistance 5 to 55 Hz, amplitude 0.75 mm Damage limits: 500 m/s2 (50G) Shock Resistance Operating extremes: 200 m/s2 (20G) Mechanical Durability Momentary: 200,000 operations (minimum operations) Maintained: 100,000 operations Momentary: 100,000 operations Electrical Durability Maintained:   50,000 operations (minimum operations) (Switching frequency 1200 operations/h) Degree of Protection IP40 (IEC 60529) LED Lamp Ratings (LAD-S) Built-in LED Part No. Lamp Base Forward Current (If) Forward Voltage (Vf) (nominal) Reverse Voltage (Vr) Illumination Color LED Lamp Color Applicable Lens Color Base Plastic Color LED Lamp Life (reference value) Operating Voltage & External Current-limiting Resistor (recommended value) (Note) Internal Circuit LAD-SA LAD-SG LAD-SR LAD-SY Exclusive for A series 20 mA 2.2V 2.1V 1.7V 2.2V 4V A G R Y Amber Clear Yellow Diffused Red Clear Yellow Clear Amber Green Red Yellow and White Red Approx. 50,000 hours (The illuminance reduces to 50% of the initial intensity when used on complete DC.) 5V DC: 150Ω, 1/2W (+) (–) 6V DC: 200Ω, 1/2W Current 12V DC: 510Ω, 1W Lamp Lamp Limiting Terminal (+) Terminal (–) 24V DC: 1.1 kΩ, 1W Resistor (+) (–) Note: When LED lamps are used on voltages other than the above, external resistor value R is determined by the following formula: R = (operating voltage – Vf) / If • LED lamps do not have a current-limiting resistor, and external resistors of recommended values for each voltage must be provided. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. Because no protection diode is contained, ensure the correct polarity is observed. 29 ø10 A1 Series Illuminated Pushbuttons and Pilot Lights Illuminated Pushbuttons & Pilot Lights  Part No. Shape Operation Round AL1M (except for pilot lights) Square AL1Q (except for pilot lights) Rectangular AL1H (except for pilot lights) Contact ➁ Lens Color Code IP40 Momentary SPDT AL1M-M11➁ Maintained SPDT AL1M-A11➁ Pilot Light — AL1M-P1➁ Momentary SPDT AL1Q-M11➁ Maintained SPDT AL1Q-A11➁ Pilot Light — Momentary SPDT AL1H-M11➁ Maintained SPDT AL1H-A11➁ Pilot Light — AL1H-P1➁ AL1Q-P1➁ Specify a color code in place of ➁ in the Part No. A: amber G: green R: red W: white Y: yellow Package Quantity: 1 LED Lamp Part No., Rated Current (External Resistor Recommended Value) A: LAD-SA G: LAD-SG R: LAD-SR W/Y: LAD-SY Rated Current: 20 mA 5V DC: 150Ω, 1/2W 6V DC: 200Ω, 1/2W 12V DC: 510Ω, 1W 24V DC: 1.1 kΩ, 1W • LED lamps do not have a current-limiting resistor. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. • AP1M series pilot lights (round bezel only) with built-in current-limiting resistor are also available. • Pilot lights are not CCC certifed. (+) (–) Dimensions Panel Thickness 0.5 to 6 Rectangular (TOP) Locking Ring Round (TOP) c12 ø12 2.8 12 2.8 Terminal Width 1.8×0.4t Square (TOP) ø12 6 5.5 5.5 22 16 9 Terminal Arrangement (bottom view) Mounting Hole Layout Round/Square Units (TOP) ø10 Lamp Terminal (+) COM Lamp Terminal (–) ø10 +0.2 0 12 min. NO 12 min. NC Rectangular Units +0.2 0 12 min. Note: Determine mounting centers to ensure easy operation. 30 16 min. All dimensions in mm. A1 Series Pushbuttons ø10 Pushbuttons  Package Quantity: 1 Shape Button Style Round AB1M Operation Contact Part No. IP40 Momentary SPDT AB1M-M1➀ Maintained SPDT AB1M-A1➀ Momentary SPDT AB1M-M1L➁ Maintained SPDT AB1M-A1L➁ Momentary SPDT AB1Q-M1➀ Maintained SPDT AB1Q-A1➀ Momentary SPDT AB1Q-M1L➁ Maintained SPDT AB1Q-A1L➁ Momentary SPDT AB1H-M1➀ Maintained SPDT AB1H-A1➀ Momentary SPDT AB1H-M1L➁ Maintained SPDT AB1H-A1L➁ Button Lens Square AB1Q Button Lens Rectangular AB1H Button Lens Color Code ➀➁ B black G: green R: red S: blue W: white Y: yellow A: amber G: green R: red W: white Y: yellow B black G: green R: red S: blue W: white Y: yellow A: amber G: green R: red W: white Y: yellow B black G: green R: red S: blue W: white Y: yellow A: amber G: green R: red W: white Y: yellow • Specify a color code in place of ➀ or ➁ in the Part No. Dimensions Panel Thickness 0.5 to 6 Locking Ring Rectangular (TOP) Square (TOP) Round (TOP) c12 ø12 6 5.5 5.5 22 16 9 Terminal Arrangement (bottom view) Mounting Hole Layout Round/Square Units (TOP) ø10 NC ø10 +0.2 0 12 min. NO COM Rectangular Units +0.2 0 12 min. 2.8 12 2.8 Terminal Width 1.8×0.4t 12 min. 16 min. Note: Determine mounting centers to ensure easy operation. All dimensions in mm. 31 ø10 A1 Series Accessories Accessories Shape Material Part No. Ordering No. Package Quantity Remarks Locking Ring Wrench ø12 Metal (nickel-plated brass) MT-003 MT-003 1 • Used to tighten the locking ring when installing the A1 series into a panel. Stainless Steel MT-101 MT-101 1 • Used to remove lens and button. Rubber OR-66 OR-66 1 • Used to remove and install LED lamps. AL-K1 AL-K1 1 AL-KH1 1 AL-C1 1 60 Lens Removal Tool 60 Lamp Holder Tool 70 Switch Guard For round/ square unit 90° open For rectangular AL-KH1 unit Socket Solder Terminal AL-C1 • Used to protect pushbuttons from inadvertent operation. • See page 33 for dimensions. (remains 90° open) • Snaps on the rear of the A1 series. (see page 33 for dimensions) PC Board Terminal AL-C1V AL-C1V 1 Terminal Cover Nylon AL-V1 AL-V1PN10 10 • Degree of protection: IP65 AL-B1 AL-B1PN05 5 4.4 Nitryl rubber (black) 2 Mounting Hole Plug • When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. • Terminal cover is not attached and must be ordered separately. 32 ø12 A1 Series Accesories and Maintenance Parts ø10 Dimensions Switch Guard For Round/Square Units (AL-K1) For Rectangular Units (AL-KH1) 10 20.5 min. 17.5 20.5 min. Panel Thickness 0.5 to 5 24.5 7.5 10 16 7.5 17.5 12 13 min. 12.5 17 min. Socket (AL-C1, AL-C1V) Terminal 0.8 × 0.3t 33 Terminal Arrangement (TOP) 7.3 2.8 7.3 2.8 33 NC 5 11 17 2.8 17 2.8 NO 3 5-1.0 Solder Terminal (AL-C1) PC Board Terminal (AL-C1V) +0.2 0 Holes Lamp Terminal (+) COM Lamp Terminal (–) (Bottom View) (PC Board Terminal Mounting Hole Layout) Terminal Cover ø10.8 17.3 Note: When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. 33.5 All dimensions in mm. Maintenance Parts Marking Plate Lens Unit Button Unit Current-limiting resistor is not contained. 5.3 9.0 ø4.0 LED Lamp All dimensions in mm. Part No. Ordering No. Round AL1M-W AL1M-WPN05 Square AL1Q-W AL1Q-WPN05 Rectangular AL1H-W AL1H-WPN05 Round AL1M-LK1-➁ AL1M-LK1-➁PN02 Square AL1Q-LK1-➁ AL1Q-LK1-➁PN02 Rectangular AL1H-LK1-➁ AL1H-LK1-➁PN02 Round AB1M-BK1-➀ AB1M-BK1-➀PN02 Square AB1Q-BK1-➀ AB1Q-BK1-➀PN02 Rectangular AB1H-BK1-➀ AB1H-BK1-➀PN02 Illumination color: amber LAD-SA Illumination color: green LAD-SG Illumination color: red LAD-SR Illumination color: yellow LAD-SY Package Quantity 5 2 Color Code ➀➁ • White Specify a color code in place of ➁ in the Part No. A (amber), G (green), R (red) W (white), Y (yellow) Specify a color code in place of ➀ in the Part No. B (black), G (green), R (red) S (blue), W (white), Y (yellow) LAD-SA 1 LAD-SAPN10 10 LAD-SG 1 LAD-SGPN10 10 LAD-SR 1 LAD-SRPN10 10 LAD-SY 1 LAD-SYPN10 10 Lens color Shape Amber LED color: amber clear Green LED color: yellow diffused Red LED color: clear red White/ Yellow LED color: yellow clear 33 ø10 A1 Series Operating Instructions Safety Precautions • Turn off the power to A series before starting installation, removal, wiring, maintenance, and inspection of the units. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid burning your hand, use the lamp holder tool when replacing lamps. • For wiring, use wires of a proper gauge to meet the voltage and current requirements. Failure to tighten terminal screws may cause overheating and create a fire hazard. Operating Instructions Replacement of Lens and Marking Plate Replacing the LED Lamp Removal Removal Remove the lens assembly (color lens, marking plate, lens holder, and spring) by holding the color lens recesses with the Lens Removal Tool (MT-101) and pulling it out. Remove the marking plate by disengaging the latches between the color lens and lens holder. The marking plate must be engraved on the front side as shown below. Use the lamp holder tool (OR-66) to remove lamps. Do not use pliers. Installation Use the lamp holder tool (OR-66) to install lamps. Note the correct side of the tool for removal or installation. Lamp Holder Tool OR-66 (ø8, ø10, ø12 series) Latches For removing lamps Color lens Engraving Area Marking Plate Spring Lens Retaining Holder Groove For installing lamps Panel Mounting Spring Note: Make sure that the spring is inserted in the correct direction. The base of spring must fit the groove in the holder. When mounting the units into a panel, use the optional locking ring wrench (MT-003) to tighten the locking ring. Do not use pliers. Tightening torque must not exceed 0.29 N·m. Excessive tightening will damage the locking ring. Wiring Place the marking plate on the lens holder in the correct direction, and press the color lens onto the lens holder to engage the latches. Put the spring on the lens holder and insert the lens holder into the housing in the correct direction. Solder the terminal at 350°C within 3 seconds using a 60W soldering iron. Sn-Ag-Cu is recommended when using lead-free solder. When soldering, do not touch the unit with the soldering iron. Also ensure that no tensile force is applied to the terminal. Do not bend the terminal or apply excessive force to the terminal. Use non-corrosive rosin flux. Installing Non-illuminated Button Installing the Socket Installation Non-illuminated pushbuttons contain a marking plate like illumi­ nated units. Be sure to install the marking plate when replacing the button. Marking For A series illuminated pushbuttons, legends and symbols can be engraved on the built-in marking plates, or printed film can be inserted under the lens. Marking Plate & Engraving Area Engraving Area 7.5 7.5 Size: ø8.5 Size: 8.5 7.5 Engraving Area Rectangular Engraving Area 11.5 0.8 Square 0.8 ø7.5 Round 0.8 Built-in Marking Plate Lens Size: 12.5 x 8.5 • Engraving must be made on the engraving area less than 0.5mm deep. • The marking plate is made of white acrylic resin. Install the socket on the unit with the TOP markings on the unit and the socket placed in the same direction. Operating Voltage of LED Lamps The operating voltage is measured at complete DC. When using a pulsating voltage such as a full-wave rectification voltage, keep peak currents within the forward current If. Peak currents exceeding the If may shorten the LED lamp life. Other Notes Close Proximity Mounting When mounting pilot lights or illuminated pushbuttons collectively or lighting them continuously, heat may cause the ambient temperature to rise above the rated operating temperature. When the mounting panel is not made of metal or when the units are mounted in an enclosed panel, provide for ventilation or lower the operating voltage. Replacement of Buttons (Illuminated/Non-illuminated) Do not replace buttons of maintained action units while the button is in the locked position. Replacing the button in the locked position may damage the internal mechanism. Be sure to release the button before replacing. Operating and Storage Environment 1. Make sure that the operating/storage temperature and humidity are within the ratings. 2. Do not use enclosed type units in an environment subject to oil, water or dust accumulation. Microswitch Contacts Do not connect NO and NC contacts of the microswitch to different voltages or different power sources to prevent a dead short-circuit. 34 ø8 A8 Series Switches and Pilot Lights Short 22-mm-long body miniature switches and pilot lights with LED illumination face and snap-action switching. • Bright and clear LED illumination. • All series have terminals on the same plane. • UL recognized, CSA certified Applicable Standards Mark File No. / Organization UL508 UL Recognition File No. E55996 CSA C22.2 No.14 CSA File No. LR 21451 GB14048.5 CCC No.2013010305650376 (except for pilot lights) Contact Ratings (Contact Block) Rated Insulation Voltage Rated Thermal Current Operating Voltage (AC/DC) Resistive Load AC 50/60 Hz Inductive Load Resistive Load DC Inductive Load Contact Material 250V 3A 24V – – 1.0A 0.7A Silver 110V 1.0A 0.7A 0.2A 0.1A Specifications 220V 0.5A 0.5A – – • Minimum applicable load: 5V AC/DC, 3 mA (applicable range may vary with operating conditions and load types) Weight Weight (approx.) AL8M-M11: 2g AL8M-P1: 2g AB8M-M1: 2g Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance –25 to +55°C (no freezing) –30 to +80°C (no freezing) 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts 2,000V AC, 1 minute Between terminals of different poles: 2,000V AC, 1 minute Switch Unit Dielectric Between terminals of the same pole: Strength 1,000V AC, 1 minute Between contact and lamp terminals: 1,500V AC, 1 minute Illumination Between live part and ground: Unit 2,000V AC, 1 minute Damage Limits, Operating extremes: Vibration Resistance 5 to 55 Hz, amplitude 0.75 mm Damage limits: 500 m/s2 (50G) Shock Resistance Operating extremes: 200 m/s2 (20G) Mechanical Durability Momentary: 200,000 operations (minimum operations) Maintained: 100,000 operations Momentary: 100,000 operations Electrical Durability Maintained:   50,000 operations (minimum operations) (Switching frequency 1200 operations/h) Degree of Protection IP40 (IEC 60529) LED Lamp Ratings (LAD-S) Part No. Lamp Base Forward Current (If) Forward Voltage (Vf) (nominal) Reverse Voltage (Vr) Illumination Color LED Lamp Color Applicable Lens Color Base Plastic Color LED Lamp Life (reference value) Operating Voltage & External Current-limiting Resistor (recommended value) (Note) Internal Circuit LAD-SA LAD-SG LAD-SR LAD-SY Exclusive for A series 20 mA 2.2V 2.1V 1.7V 2.2V 4V A G R Y Amber Clear Yellow Diffused Red Clear Yellow Clear Amber Green Red Yellow and White Red Approx. 50,000 hours (The illuminance reduces to 50% of the initial intensity when used on complete DC.) 5V DC: 150Ω, 1/2W (+) (–) 6V DC: 200Ω, 1/2W Current 12V DC: 510Ω, 1W Lamp Lamp Limiting Terminal (+) Terminal (–) 24V DC: 1.1 kΩ, 1W Resistor (+) (–) Note: When LED lamps are used on voltages other than the above, external resistor value R is determined by the following formula: R = (operating voltage – Vf) / If • LED lamps do not have a current-limiting resistor, and external resistors of recommended values or each voltage must be provided. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. Because no protection diode is contained, ensure the correct polarity is observed. 35 ø8 A8 Series Illuminated Pushbuttons and Pilot Lights Illuminated Pushbuttons & Pilot Lights  Package Quantity: 1 LED Lamp Part No. Shape Operation Round AL8M (except for pilot lights) Square AL8Q (except for pilot lights) Rectangular AL8H (except for pilot lights) Contact IP40 ➁ Lens Color Code Momentary SPDT AL8M-M11➁ Maintained SPDT AL8M-A11➁ Pilot Light — AL8M-P1➁ Momentary SPDT AL8Q-M11➁ Specify a color code in place of ➁ in the Part No. Maintained SPDT AL8Q-A11➁ A: amber G: green R: red W: white Y: yellow Pilot Light — Momentary SPDT AL8H-M11➁ Maintained SPDT AL8H-A11➁ Pilot Light — AL8H-P1➁ AL8Q-P1➁ Part No., Rated Current (External Resistor Recommended Value) A: LAD-SA G: LAD-SG R: LAD-SR W/Y: LAD-SY Rated Current: 20 mA 5V DC: 150Ω, 1/2W 6V DC: 200Ω, 1/2W 12V DC: 510Ω, 1W 24V DC: 1.1 kΩ, 1W • LED lamps do not have a current-limiting resistor. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. • AP8M series pilot lights (round bezel only) with built-in current-limiting resistor are also available. • Pilot lights are not CCC certified. (+) (–) Dimensions Panel Thickness 0.5 to 6 Rectangular (TOP) Locking Ring Square (TOP) Round (TOP) c9 ø9 2.5 9 2.5 Terminal Width 1.8 × 0.4t ø9 5 5.5 7 5.5 22 12 9 Terminal Arrangement Mounting Hole Layout Round/Square Units ø8 NO Lamp Terminal (+) COM Lamp Terminal (–) 9 min. NC Rectangular Units +0.2 0 ø8 +0.2 0 9 min. (TOP) 9 min. Note: Determine mounting centers to ensure easy operation. 36 12 min. All dimensions in mm. A8 Series Accessories ø8 Pushbuttons  Package Quantity: 1 Shape Button Style Round AB8M Operation Contact Part No. IP40 Momentary SPDT AB8M-M1➀ Maintained SPDT AB8M-A1➀ Momentary SPDT AB8M-M1L➁ Maintained SPDT AB8M-A1L➁ Momentary SPDT AB8Q-M1➀ Maintained SPDT AB8Q-A1➀ Momentary SPDT AB8Q-M1L➁ Maintained SPDT AB8Q-A1L➁ Momentary SPDT AB8H-M1➀ Maintained SPDT AB8H-A1➀ Momentary SPDT AB8H-M1L➁ Maintained SPDT AB8H-A1L➁ Color Code ➀➁ B black G: green R: red S: blue W: white Y: yellow Button Lens Square AB8Q B black G: green R: red S: blue W: white Y: yellow Button Lens Rectangular AB8H A: amber G: green R: red W: white Y: yellow A: amber G: green R: red W: white Y: yellow B black G: green R: red S: blue W: white Y: yellow Button Lens A: amber G: green R: red W: white Y: yellow • Specify a color code in place of ➀ or ➁ in the Part No. • Lens style buttons can be used with marking plate and film. Dimensions Panel Thickness 0.5 to 6 Locking Ring Rectangular (TOP) Square (TOP) Round (TOP) c9 ø9 2.5 9 2.5 Terminal Width 1.8 × 0.4t 5.5 7 5.5 22 12 9 Terminal Arrangement (bottom view) Mounting Hole Layout Round/Square Units ø8 NO COM +0.2 0 9 min. NC ø8 +0.2 0 9 min. (TOP) Rectangular Units 9 min. 12 min. Note: Determine mounting centers to ensure easy operation. All dimensions in mm. 37 ø8 A8 Series Accessories Accessories Shape Material Ordering Part No. Part No. Package Quantity Remarks Locking Ring Wrench ø9 Metal (nickel-plated brass) MT-004 MT-004 1 • Used to tighten the locking ring when installing the A8 series into a panel. Stainless Steel MT-101 MT-101 1 • Used to remove the lens and button. Rubber OR-66 OR-66 1 • Used to remove and install the LED lamps. AL-K8 AL-K8 1 AL-KH8 1 60 Lens Removal Tool 60 Lamp Holder Tool 70 Switch Guard For round/ square Unit • Used to protect pushbuttons from inadvertent operation. • See page 38 for dimensions. 90° open For rectangular AL-KH8 unit Socket Solder Terminal AL-C8 AL-C8 1 PC Board Terminal AL-C8V AL-C8V 1 (remains 90° open) • Snaps on the rear of the A8 series. (see page 38 for dimensions) Terminal Cover Nylon AL-V8 AL-V8PN10 10 • When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. • Terminal cover is not attached and must be ordered separately. Nitryl rubber (black) AL-B8 AL-B8PN05 5 • Degree of protection: IP65 Mounting Hole Plug Dimensions Switch Guard For Round/Square Units (AL-K8) For Rectangular Units (AL-KH8) Panel Thickness 0.5 to 5 8.5 17.5 min. 14.5 17.5 min. 6 8.5 6 14.5 21.5 12 10 12.5 13 min. 11 min. Socket (AL-C8, AL-C8V) Terminal 0.8 × 0.3t Terminal Arrangement (TOP) 6.3 33 2.5 6.3 2.5 33 NC 8.8 Solder Terminal (AL-C8) 17 3 5-1.0 PC Board Terminal (AL-C8V) 33.5 38 +0.2 0 Holes (PC Board Terminal Mounting Hole Layout) COM Lamp Terminal (–) (Bottom View) 17.3 ø9.1 Terminal Cover (AL-V8) 5 2.5 17 2.5 NO Lamp Terminal (+) Note: When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. All dimensions in mm. A8 Series Accessories ø8 Maintenance Parts Marking Plate Lens Unit Button Unit Current-limiting resistor is not contained. 5.3 9.0 ø4.0 LED Lamp Part No. Round AL8M-W AL8M-WPN05 Square AL8Q-W AL8Q-WPN05 Rectangular AL8H-W AL8H-WPN05 Round AL8M-LK1-➁ AL8M-LK1-➁PN02 Square AL8Q-LK1-➁ AL8Q-LK1-➁PN02 Rectangular AL8H-LK1-➁ AL8H-LK1-➁PN02 Round AB8M-BK1-➀ AB8M-BK1-➀PN02 Square AB8Q-BK1-➀ AB8Q-BK1-➀PN02 Rectangular AB8H-BK1-➀ AB8H-BK1-➀PN02 Illumination color: amber LAD-SA Illumination color: green LAD-SG Illumination color: red LAD-SR All dimensions in mm. Illumination color: yellow LAD-SY Package Quantity Ordering Part No. 5 2 Color Code ➀➁ • White Specify a color code in place of ➁ in the Part No. A (amber), G (green), R (red) W (white), Y (yellow) Specify a color code in place of ➀ in the Part No. B (black), G (green), R (red) S (blue), W (white), Y (yellow) LAD-SA 1 LAD-SAPN10 10 LAD-SG 1 LAD-SGPN10 10 LAD-SR 1 LAD-SRPN10 10 LAD-SY 1 LAD-SYPN10 10 Lens color Shape Amber LED color: amber clear Green LED color: yellow diffused Red LED color: clear red White/ Yellow LED color: yellow clear Safety Precautions • Turn off the power to A series before starting installation, removal, wiring, maintenance, and inspection of the units. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid burning your hand, use the lamp holder tool when replacing lamps. • For wiring, use wires of a proper size to meet the voltage and current requirements. Failure to tighten terminal screws may cause overheating and create a fire hazard. Operating Instructions Replacement of Lens and Marking Plate Removal Remove the operator (color lens, marking plate, lens holder, and spring) by holding the color lens recesses with the Lens Removal Tool (MT-101) and pulling it out. Remove the marking plate by disengaging the latches between the color lens and lens holder. The marking plate must be engraved on the front side as shown below. Latches Installing Non-illuminated Button Non-illuminated pushbuttons contain a marking plate like illumi­ nated units. Be sure to install the marking plate when replacing the button. Marking For A series illuminated pushbuttons, legends and symbols can be engraved on the built-in marking plates, or printed film can be inserted under the lens. Marking Plate & Engraving Area Note: Make sure that the spring is inserted in the correct direction. The base of spring must fit the groove in the holder. Installation Engraving Area 5 5 Size: ø6.1 Size: 6.1 5 Engraving Area Rectangular Engraving Area 8 0.8 Spring Square 0.8 Spring Lens Retaining Holder Groove ø5 Engraving Area Marking Plate Round 0.8 Color lens Built-in Marking Plate Lens Size: 9.1 x 6.1 • Engraving must be made on the engraving area less than 0.5mm deep. • The marking plate is made of white acrylic resin. Place the marking plate on the lens holder in the correct direction, and press the color lens onto the lens holder to engage the latches. Put the spring on the lens holder and insert the lens holder into the housing in the correct direction. 39 ø8 A8 Series Operating Instructions Operating Instructions Replacing the LED Lamp Operating Voltage of LED Lamps Removal The operating voltage of 5V DC is measured at complete DC. When using a pulsating voltage such as a full-wave rectification voltage, keep peak currents within the forward current If. Peak currents exceeding the If may shorten the LED lamp life. Use the lamp holder tool (OR-66) to remove lamps. Do not use pliers. Installation Use the lamp holder tool (OR-66) to install lamps. Note the correct side of the tool for removal or installation. Lamp Holder Tool OR-66 (ø8, ø10, ø12 series) For removing lamps For installing lamps Panel Mounting Other Notes Close Proximity Mounting When mounting pilot lights or illuminated pushbuttons collectively or lighting them continuously, heat may cause the ambient temperature to rise above the rated operating temperature. When the mounting panel is not made of metal or when the units are mounted in an enclosed panel, provide for ventilation or lower the operating voltage. Replacement of Buttons (Illuminated/Non-illuminated) When mounting the units onto a panel, use the optional locking ring wrench (MT-004) to tighten the locking ring. Do not use pliers. Tightening torque must not exceed 0.29 N·m. Excessive tightening will damage the locking ring. Do not replace buttons of maintained action units while the button is in the locked position. Replacing the button in the locked position may damage the internal mechanism. Be sure to release the button before replacing. Operating and Storage Environment Wiring Solder the terminal at 350°C within 3 seconds using a 60W soldering iron. Sn-Ag-Cu is recommended when using lead-free solder. When soldering, do not touch the enabling switch with the soldering iron. Also ensure that no tensile force is applied to the terminal. Do not bend the terminal or apply excessive force to the terminal. Use a non-corrosive rosin flux. Installing the Socket 1. Make sure that the operating/storage temperature and humidity are within the ratings. 2. Do not use enclosed type units in an environment subject to oil, water or dust accumulation. Microswitch Contacts Do not connect NO and NC contacts of the microswitch to different voltages or different power sources to prevent a dead short-circuit. Install the socket on the unit with the TOP markings on the unit and the socket placed in the same direction. www.idec.com Head Office 6-64, Nishi-Miyahara-2-Chome, Yodogawa-ku, Osaka 532-0004, Japan USA Germany Singapore Thailand Australia Taiwan IDEC Corporation IDEC Electrotechnik GmbH IDEC Izumi Asia Pte. Ltd. IDEC Asia (Thailand) Co., Ltd IDEC Australia Pty. Ltd. IDEC Taiwan Corporation Tel: +1-408-747-0550 Tel: +49-40-25 30 54 - 0 Tel: +65-6746-1155 Tel: +66-2-392-9765 Tel: +61-3-8523-5900 Tel: +886-2-2698-3929 opencontact@idec.com service@eu.idec.com info@sg.idec.com sales@th.idec.com sales@au.idec.com service@tw.idec.com Specifications and other descriptions in this brochure are subject to change without notice. 2017 IDEC Corporation, All Rights Reserved. EP1558-5 MARCH 2017 40 Hong Kong China/Shanghai China/Shenzhen China/Beijing Japan IDEC Izumi (H.K.) Co., Ltd. IDEC (Shanghai) Corporation IDEC (Shenzhen) Corporation IDEC (Beijing) Corporation IDEC Corporation Tel: +852-2803-8989 Tel: +86-21-6135-1515 Tel: +86-755-8356-2977 Tel: +86-10-6581-6131 Tel: +81-6-6398-2527 info@hk.idec.com idec@cn.idec.com idec@cn.idec.com idec@cn.idec.com marketing@idec.co.jp
AB6Q-A1-R 价格&库存
很抱歉,暂时无法提供与“AB6Q-A1-R”相匹配的价格&库存,您可以联系我们找货
