AL6M-LK2-G
AL6M-LK2-G
    IDEC(日本和泉)
AL6M-LK2-G 数据手册
Miniature Switches & Pilot Devices ø16mm - A6 Series A6 Series — Miniature Switches and Pilot Devices: 16mm Key features of the A6 series switches and pilot lights include: • 16mm (5/8") mounting hole • LED illumination • Compact design saves space • Momentary, Maintained, Selectors, and E-Stops • Gold-clad Silver contacts for reliable low level switching • Snap action contacts • IP40 (dustproof) or IP65 (oiltight) versions Specifications CSA Certified File No. LR21451 Certificate No. 2030010305027380 Degree of Protection IP40: Dustproof IP65 Waterproof/Oiltight/Corrosion Resistant Contact Configuration Maximum Voltage Thermal Current Minimum Applicable Load Contact Material Terminal Style Operating Temperature Operating Humidity Contact Resistance Insulation Resistance Vibration Resistance SPDT, DPDT Shock Resistance Damage limits: 500m/sec2 (approx. 50G) Operating extremes: 200m/sec2 (approx. 20G) Electrical Life 100,000 operations minimum (at full rated load) 250V AC/DC 3A 5V AC/DC, 1mA (subject to operating conditions) Gold-clad silver .110" Solder/ Quick Connect LED Type: -25° to +55°C (no freezing) 45 to 85% RH 50mΩ maximum (initial value) 100MΩ minimum (500V DC megger) 10 to 55Hz, amplitude 1.5mm p-p Maintained: 100,000 operations minimum Momentary: 1,000,000 operations minimum Selector/Keylock: 250,000 operations minimum Switch Unit: 2,000VAC, 1 min. between live/dead part and terminals of different poles; 1,000V AC, 1 minute between terminals of the same pole; 1,500V AC, 1 minute between contact and lamp terminals. Illumination Unit: 2,000VAC, 1 min. between live part/ground Mechanical Life Dielectric Strength LED Lamp Ratings Contact Ratings Switches & Pilot Devices UL Recognized File No.E55996 A2 Soldering Temperature Operating Voltage AC (50/60Hz) DC 20W/5 seconds or 260°C/3 seconds Resistive 120V 240V — 1.0A 0.5A Inductive — 0.7A 0.5A Resistive 1.0A 0.2A — Inductive 0.7A 0.1A — 5V DC ±5% 6V AC/DC (±10%) 12V AC/DC (±10%) 24V AC/DC (±10%) DC: A, R, W, Y: 6mA G, S: 5mA AC: A, R, W, Y: 8mA G, S: 7mA DC: 8mA DC: 8mA 8mA AC: 9mA AC: 9mA Rated Voltage/Current 1. 2. 3. 4. 24V AC Inductive Load, PF = 0.6 – 0.7; DC Inductive Load, L/R = 7ms. Minimum applicable load (reference value) is 5V AC/DC/1mA (applicable range is subject to the operating conditions and load). LED lamp contains a built-incurrent-limiting resistor and a protection diode. LED’s don’t “burn out.” Luminance is reduced to 50% of initial intensity after being lit for 50,000 hours continuously. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-17 Miniature Switches & Pilot Devices ø16mm - A6 Series AB6 Non-Illuminated Pushbuttons (Assembled) Part Numbers: Non-Illuminated Pushbuttons Style Part Number Momentary Maintained (Latching) Dustproof (IP40) Oiltight (IP65) Dustproof (IP40) Oiltight (IP65) Standard Button Round 18mm SPDT DPDT AB6M-M1-① AB6M-M2-① AB6M-M1P-① AB6M-M2P-① AB6M-A1-① AB6M-A2-① AB6M-A1P-① AB6M-A2P-① SPDT DPDT AB6Q-M1-① AB6Q-M2-① AB6Q-M1P-① AB6Q-M2P-① AB6Q-A1-① AB6Q-A2-① AB6Q-A1P-① AB6Q-A2P-① Square 18mm Rectangular 18mm x 24mm ① Button Color Code SPDT DPDT AB6H-M1-① AB6H-M2-① AB6H-M1P-① AB6H-M2P-① AB6H-A1-① AB6H-A2-① AB6H-A1P-① AB6H-A2P-① Round 23.5mm Oversize Button Switches & Pilot Devices A2 Contact SPDT DPDT – AB6M-M1P-M① AB6M-M2P-M① – SPDT DPDT SPDT DPDT AB6M-A1P-M① AB6M-A2P-M① – AB6Q-M1P-Q① AB6Q-M2P-Q① – AB6Q-A1P-Q① AB6Q-A2P-Q① – AB6Q-M1P-H① AB6Q-M2P-H① – AB6Q-A1P-H① AB6Q-A2P-H① Color Code Black B Green G Red R Blue S White W Yellow Y Square 23.5mm Rectangular 17.5 X 23.5mm 1. In place of ①, specify Button Color Code from the table at the right. 2. To order as sub-assembled, see page A2-19. 3. For accessories, see page A2-25. 4. For dimensions, see page A2-27. Part Numbers: AB6-V Pushlock Turn Reset Shape Operation Contact Part Number Dustproof (IP40) Oiltight (IP65) Pushlock Turn Reset SPDT DPDT AB6M-V1-R AB6M-V2-R Remarks 23.5mm Round Mushroom Part Numbers: Buzzer Style Shape Voltage AB6M-V1P-R AB6M-V2P-R 1. Button available in red only. 2. Replacement button: order AB6M-V-R Part Number 12V DC UZ6-11 24V DC UZ6-12 Round (18mm) A2-18 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - A6 Series AB6 Non-Illuminated Pushbuttons (Sub-Assembled) Operator + Button = Completed Unit A2 Switches & Pilot Devices Part Numbers: Operators Style Contact Non-Illuminated Pushbuttons SPDT DPDT Part Number Operator Round Square Rectangular Momentary AB6M-M100 AB6Q-M100 AB6H-M100 Maintained AB6M-A100 AB6Q-A100 AB6H-A100 Momentary AB6M-M200 AB6Q-M200 AB6H-M200 Maintained AB6M-A200 AB6Q-A200 AB6H-A200 Part Numbers: Buttons/Lens Description Part Number Button Dustproof (IP40) Oiltight (IP65) Round AB6M-BK1-① AB6M-BK2-① AB6Q-BK1① AB6Q-BK2-① AB6H-BK1-① AB6H-BK2-① Square Rectangular ① Button Color Code Round Oversize – AB6M-BK2-M① Color Code Black B Green G Red R Blue S White W Yellow Y Square Oversize – AB6Q-BK2-Q① – AB6Q-BK2-H① Rectangular Oversize 1. In place of ①, specify Button Color Code from table on right. 2. Buttons which are rated IP65 include a waterproof rubber gasket. 3. For accessories, see page A2-25. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-19 Miniature Switches & Pilot Devices ø16mm - A6 Series AL6 Illuminated Pushbuttons (Assembled) Part Numbers: LED Illuminated Pushbuttons A2 Description Style Contact Part Numbers Momentary Maintained (Latching) Dustproof (IP40) Oiltight (IP65) Dustproof (IP40) Oiltight (IP65) 24V AC/DC ±10% SPDT DPDT AL6M-M14-➁ AL6M-M24-➁ AL6M-M14P-➁ AL6M-M24P-➁ AL6M-A14-➁ AL6M-A24-➁ AL6M-A14P-➁ AL6M-A24P-➁ 24V AC/DC ±10% SPDT DPDT AL6Q-M14-➁ AL6Q-M24-➁ AL6Q-M14P-➁ AL6Q-M24P-➁ AL6Q-A14-➁ AL6Q-A24-➁ AL6Q-A14P-➁ AL6Q-A24P-➁ 24V AC/DC ±10% SPDT DPDT AL6H-M14-➁ AL6H-M24-➁ AL6H-M14P-➁ AL6H-M24P-➁ AL6H-A14-➁ AL6H-A24-➁ AL6H-A14P-➁ AL6H-A24P-➁ 24V AC/DC ±10% SPDT DPDT – AL6M-M14P-M➁ AL6M-M24P-M➁ – AL6M-A14P-M➁ AL6M-A24P-M➁ 24V AC/DC ±10% SPDT DPDT – AL6Q-M14P-Q➁ AL6Q-M24P-Q➁ – AL6Q-A14P-Q➁ AL6Q-A24P-Q➁ 24V AC/DC ±10% SPDT DPDT – AL6Q-M14P-H➁ AL6Q-M24P-H➁ – AL6Q-A14P-H➁ AL6Q-A24P-H➁ Voltage Switches & Pilot Devices Round 18mm diameter Square 18mm Standard Lens Rectangular 18mm x 24mm Round 24mm diameter Oversize Lens Square 24 mm Rectangular 18mm x 24mm 1. In place of ➁, specify Lens/LED Color Code from table below. 2. Lamps also available in 5V DC, 6V AC/DC or 12 V AC/DC, change “4” using voltage/lamp codes (ie AL6M-M13-➁ uses 12V AC/DC LED). 3. LED lamp is included in unit and contains a current-limiting resistor and a protection diode. (External resistor not required.) 4. To order as sub-assembled, see page A2-21. 5. For accessories, see page A2-25. 6. For dimensions, see page A2-27. A2-20 www.idec.com ➁ Lens/LED Color Code Color Code Voltage Code Voltage Code Amber A 5V DC 1 Green G 6V AC/DC 2 Red R 12V AC/DC 3 Blue S 24V AC/DC 4 White W Yellow Y USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - A6 Series AL6 Illuminated Pushbuttons (Sub-Assembled) Operator + LED Lamp + Lens = Completed Unit A2 Switches & Pilot Devices Part Numbers: Operators Style AL6 Illuminated Pushbuttons Contact SPDT DPDT Part Numbers: Lenses Unit Degree of Dustproof (IP40) Protection Size Standard AL6M-LK1-➁ Part Number Operator Round Square Rectangular Momentary AL6M-M100 AL6Q-M100 AL6H-M100 Maintained AL6M-A100 AL6Q-A100 AL6H-A100 Momentary AL6M-M200 AL6Q-M200 AL6H-M200 Maintained AL6M-A200 AL6Q-A200 AL6H-A200 Part Number Oiltight (IP65) Standard Oversize AL6M-LK2-➁ AL6M-LK2-M➁ AL6Q-LK1-➁ AL6Q-LK2-➁ AL6Q-LK2-Q➁ AL6H-LK1-➁ AL6H-LK2-➁ AL6Q-LK2-H➁ Round Square Rectangular 1. In place of ➁, specify Lens Color Code from table below. 2. Lenses which are rated IP65 include a waterproof rubber gasket. 3. For accessories, see page A2-25. ➁Lens/LED Color Code Color Code Part Numbers: LED Lamps Appearance Rated Voltage Part Number A 5V DC LATD-5➁ Green G 6V AC/DC LATD-6➁ Red R 12V AC/DC LATD-1➁ Blue S 24V AC/DC LATD-2➁ White W Yellow Y Amber www.idec.com In place of ➁, specify LED Color Code from table at left. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-21 Miniature Switches & Pilot Devices ø16mm - A6 Series AL6 Pilot Lights (Assembled) Part Numbers: LED Pilot Lights Description Switches & Pilot Devices A2 Voltage Part Number Dustproof (IP40) Oiltight (IP65) 24V AC/DC AL6M-P4-➁ AL6M-P4P-➁ 24V AC/DC AL6Q-P4-➁ AL6Q-P4P-➁ Round (18mm Lens) Square (18mm Lens) Rectangular (18mm x 24mm Lens) 24V AC/DC AL6H-P4-➁ AL6H-P4P-➁ ➁ Lens/LED Color Code Color Code Amber A Green G Red R Blue S White W Yellow Y 1. In place of ➁, specify LED/Lens Color Code. 2. Lamps also available in 5V DC, 6V AC/DC or 12 V AC/DC, change “4” using voltage codes (ie AL6M-P3-➁ uses 12V AC/DC lamp). 3. LED Lamp is included and contains built-in current limiting resistor and reverse polarity protection diode. (no external resistor required) 4. To order sub-assembled, see page A2-23. 5. For accessories, see page A2-25. 6. For dimensions, see page A2-27. 7. For one piece pilot lights and/or dome lens pilot lights, see page A5-210. Voltage Code Voltage Code 5V DC 1 6V AC/DC 2 12V AC/DC 3 24V AC/DC 4 A2-22 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - A6 Series AL6 Pilot Lights (Sub-Assembled) Operator + LED Lamp + Lens = Completed Unit A2 Switches & Pilot Devices Part Numbers: Operators Part Number Style Round Square Rectangular AL6 Pilot Lights AL6M-P00 Part Numbers: Lenses Unit Degree of Protection Dustproof IP40 AL6Q-P00 AL6H-P00 Pilot Lights Oiltight IP65 AL6M-LK1-➁ AL6M-LK3-➁ AL6Q-LK1-➁ AL6Q-LK3-➁ AL6H-LK1-➁ AL6H-LK3-➁ Round Square Rectangular 1. In place of ➁, specify Lens Color Code from table below. 2. Lenses which are rated IP65 include a waterproof rubber gasket. 3. For accessories, see page A2-25. ➁Lens/LED Color Code Color Code Part Numbers: LED Lamps Appearance Rated Voltage Part Number Amber A 5V DC LATD-5➁ Green G 6V AC/DC LATD-6➁ Red R 12V AC/DC LATD-1➁ Blue S 24V AC/DC LATD-2➁ White W Yellow Y www.idec.com In place of ➁, specify LED Color Code from table at left. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-23 Miniature Switches & Pilot Devices ø16mm - A6 Series AS6 Selector and Keylock Switches (Assembled) Part Numbers: AS6 Selector Switches and Keylock Switches (2- & 3- Position) Round Selector Square Selector 3-Position 45° 2-Position 90° Round Keylock Maintained 3-Position 45° 2-Position 90° Rectangular Selector Spring Return Right Spring Return Right ➛Center Spring Return Left➛Center L R L L L L 2-Way Return➛Center L Maintained L Spring Return to Right Spring Return Right➛Center Spring Return Left ➛Center R C C C C L L R R R R L L R R C R C R C R 2-Way Return➛Center L Maintained L R Spring Return Right L R Maintained Rectangular Keylock Keylock Switches Contact Operations (for all selectors) AS6M-2Y2P Operator Position and Contact Operation AS6M-2KT2P① Left Left Maintained Square Keylock Selector Switches Contacts Maintained 3-Position 45° Switches & Pilot Devices A2 Function 2-Position 90° Style L Spring Return Right ➛Center L Spring Return Left➛Center L 2-Way Return➛Center L C R C R C R C R C R AS6M-21Y2P AS6M-21KT2PB 2-pos. (DPDT) AS6M-32Y2P AS6M-33Y2P NO AS6M-31KT2P① AS6M-32KT2P① NO NC Left Center NO NC Left Right NO NC NO NC Right Left 3-pos. (DPDT) NO Right NC AS6M-3KT2P① Left AS6M-31Y2P Right NC Left Right AS6M-3Y2P NO NC NO NC Right NO NC Right NO NC AS6M-33KT2PD ①Key Retention Codes AS6Q-2Y2P AS6Q-21Y2P Code Description A Key not retained in any position (removable in all positions) B Key retained in right position only C Key retained in left position only AS6Q-2KT2P① AS6Q-21KT2PB AS6Q-3Y2P AS6Q-3KT2P① D Key retained in left and right (3 position only) AS6Q-31Y2P AS6Q-31KT2P① E Key retained in center only (3 position only) G Key retained right and center (3 position only) H Key retained left and center (3 position only) AS6Q-32Y2P AS6Q-32KT2P① AS6Q-33Y2P AS6Q-33KT2PD AS6H-2Y2P AS6H-2KT2P① AS6H-21Y2P AS6H-21KT2PB AS6H-3Y2P AS6H-3KT2P① AS6H-31Y2P AS6H-31KT2P① AS6H-32Y2P AS6H-32KT2P① AS6H-33Y2P AS6H-33KT2PD 1. For more information on these options, contact your IDEC representative. 2. Key cannot be removed in a spring return position. 1. In place of ①, specify Key Retention Code. See table on right. 2. All models are IP65 and DPDT. 3. Available as assembled units only. 4. For accessories, see page A2-25. 5. For dimensions, see page A2-27. A2-24 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - A6 Series Accessories — A Series: 16mm Appearance Used With Part Number Ø 5/8" (16mm) units MT-001 Made of metal. Used for tightening plastic locking ring during installation. Tightening torque should not exceed 3kgfcm Ø 31/64" (12mm) AP2M units MT-002 Ø 13/32" (10mm) AP1M units MT-003 Lens Removal Tool Made of metal. Used for removing lens or button from the housing All pushbuttons and pilot lights MT-101 Lamp Holder Tool Made of rubber. Used for removing and replacing LED lamps in illuminated units All illuminated pushbuttons and pilot lights OR-77 Round/Square AL-K6 Switch Guard Prevents inadvertent switch operation. IP40 dust-tight rated. 90 degrees opening maintained Rectangular AL-KH6 Prevents inadvertent switch operation. IP65 oiltight rated 180 degrees opening, spring return Round/Square Rectangular AL-K6SP AL-KH6SP Terminal Cover Made of translucent nylon. Fits over and shields the terminals All 5/8" (16mm) units AL-V6 Dust Cover Fits over the lens or button to provide protection from dust. (not applicable for oversize lenses or buttons) All round units All square units AL-D6 AL-DQ6 All rectangular units AL-DH6 Locking Ring Wrench Description AL-C6 All 5/8" (16mm) units Plug-on terminal adaptor with PCB terminal Mounting Hole Plug Switches & Pilot Devices Plug-on terminal adaptor with solder terminal Adaptor Socket A2 Fills unused panel cutouts. Made of nitrile rubber. Push-in installation from front of panel. IP65 (oiltight) rated. Fills unused panel cutouts. Made of aluminum. Screw-on locking ring from inside of panel. IP65 (oiltight) rated. AL-C6V Rubber AL-B6 Aluminum AL-BM6 LATD-5➁ LATD-6➁ LATD-1➁ LATD-2➁ Replacement LED Lamps LED with built in current limiting resistor (with all illuminated assemblies). 5V DC 6V AC/DC 12V AC/DC 24V AC/DC Replacement Locking Ring Fastens operators to panel (included with all operators). All switches & pilot lights HA9Z-LN Anti-Rotation Ring Prevents rotation of switches in panel (included with all operators). All switches & pilot lights AL6-LP Engraving plates to allow legends underneath translucent lenses (included with all lenses). Round standard Square standard Rectangular standard Round oversize Square/rectangular oversize AL6M-W AL6Q-W AL6H-W AL6M-MW All key selectors AS6-SK Replacement Engraving Inserts Replacement Keys Pair of keys (#132). All key switches use same standard key. AL6Q-QW 1, In place of ➁ specify color code. A=Amber, W=White, G=Green, Y=Yellow, R=Red, S=Blue. 2. LEDs include built-in current limiting resistor and reverse polarity protection diode. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-25 Miniature Switches & Pilot Devices ø16mm - A6 Series Schematics — A Series: 5/8" (16mm) Terminal Arrangement (Top View) A2 Switches & Pilot Devices Illuminated Pushbuttons NC NC NO NO COM COM (+) Lamp (–) Lamp SPDT Contact (Single-pole/Double Throw) (+) Lamp (–) Lamp DPDT Contact (Double-pole/Double Throw) Non-illuminated Pushbuttons and Selector Switches NC NC NO NO COM COM SPDT Contact (Single-pole/Double Throw) DPDT Contact (Double-pole/Double Throw) IDEC’s Superbright LED Internal Circuit LATD-1,-2,-6 (GS) LED Chip Protective Diode Zener Diode LATD-5 (ARWY) LATD-1,-2,-6 (ARWY) LATD-5 (GS) A2-26 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - A6 Series Dimensions — A Series: 5/8" (16mm) Pushbuttons, Ø 5/8" (16mm) 2.5 Panel Thickness 0.5 to 6mm Rubber Gasket Anti-rotation Ring Locking Ring Terminal Width 2.8 × 0.5t Square (TOP) Rectangular (TOP) A2 ø18 (TOP) 5 18 Round Switches & Pilot Devices 5 3 1 8 0.6 22 24 5.7 18 9 9 all dimensions are in mm Large Size Lens Rubber Gasket 6 1 0.6 8 9 22 23.5 23.5 17.5 5 6 Round (TOP) Square (TOP) Rectangular (TOP) Locking Ring 3 5 2.5 ø23.5 Terminal Width 2.8 × 0.5 t Panel Thickness 0.5 to 6mm Anti-rotation Ring 0.6 9 15.5 0.6 15.5 12.5 all dimensions are in mm Selector Switches, Ø 5/8" (16mm) Gasket Terminal Width 2.8 × 0.5t 2.5 3 Anti-Rotation Ring Panel Thickness: 0.5 to 6 mm Rectangular (TOP) Locking Ring Square (TOP) Round (TOP) 8 5 18 5 ø1 8 1 8 22 15.5 18 24 all dimensions are in mm Gasket Terminal Width 2.8 × 0.5t 3 Panel Thickness: 0.5 to 6 mm Locking Ring Rectangular (TOP) Square (TOP) Round (TOP) NC 18 5 2.5 Anti-Rotation Ring 5 NO C 1 8 22 26 24 18 ø18 all dimensions are in mm www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-27 Miniature Switches & Pilot Devices ø16mm - A6 Series Dimensions con’t A2 Switch Guard, Ø 5/8" (16mm) Panel Thickness: 0.5 to 5 mm 32 18 23.5 13 26.5 min. 33 R2 2 10.5 26.5 min. 10.5 23.5 13 (45.5 min. for 180° opening type) 24 (45.5 min. for 180° opening type) Switches & Pilot Devices Panel Thickness: 0.5 to 5 mm 34 Gasket 14 Gasket 28 14 (180° opening type) (90°, 110° opening types) 19 min. 28 25 min. Panel Thickness: 0.5 to 5 mm 34 Waterproof Gasket for Switch Guard R2 2 24 45.5 min. 10.5 45.5 min. 10.5 23.5 23.5 13 13 33 18 Gasket 0.4 14 19 min. 25 min. Terminal Sockets Dust Covers AL-C6, 5/8" (16mm), Solder AL-D6, Round Rubber Gasket Terminal Width 2.8 × 0.5t 3 AL-DQ6, Square Panel Thickness 0.5 to 6mm Anti-rotation Ring ❏0.936" (❏24) 1.17" (30) 17.5 5 0.293" (7.5) 6 6 1 8 0.6 9 22 23.5 15.5 Square (TOP) ø23.5 Round (TOP) 23.5 0.6 AL-DH6, Rectangular ❏0.936" (❏24) Rectangular (TOP) Locking Ring 5 2.5 28 9 0.507" (13) 0.012" (0.3) 0.293" (7.5) 0.507" (13) Dust Cover Gasket 0.012" (0.3) 0.293" (7.5) 0.507" (13) Dust Cover Gasket 0.012" (0.3) Dust Cover Gasket Panel Cut-Outs For Units w/Dust Cover 0.6 15.5 12.5 Round/Square Rectangular Ø 0.632"+0.007 (Ø 16.2+0.2) AL-C6V, Ø 5/8" (16mm), PCB Terminal: 0.012 x 0.059" (0.3 x 1.5) 1.303" (33.4) 0.098" (2.5) 0.117" (3) ❏0.936" (❏24) Ø 0.632"+0.007 (Ø 16.2+0.2) ❏0.936" (❏24) Ø 0.936" (Ø 24) Ø 1.17" (Ø 30) 0.195" (5) 0.195" (5) 0.234" (6) 0.148" 0.638" (16.2) (3.8) 0.234" 8 - Ø 0.062" (6) (Ø 1.6) Holes A2-28 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - A6 Series Dimensions con’t Marking Plates for Pushbuttons with Standard Size Lens Style Round—AL6M-W Square—AL6Q-W Rectangular—AL6H-W A2 OD2 Øa Ø OD ❏a Marking Area Marking Area OD1 a1 a2 Switches & Pilot Devices ❏OD Dimensions Marking Area Ø 5/8" (16mm) Outside (OD) Ø 0.538" (13.8mm) ❏0.538" (13.8mm) 0.538" x 0.772" (13.8 x 19.8mm) Marking Area (a) Ø 0.468" (12mm) ❏0.468" (12mm) 0.468" x 0.702" (12 x 18mm) Engraving must be made on the engraving area within 0.02" (0.5mm) deep. Marking Plates for Pushbutton with Oversize Lens Style Round—AL6M-MW Øa Square/Rectangular—AL6Q-QW Ø OD ❏OD ❏a Dimensions Marking Area Marking Area Outside (OD) Ø 0.491" (12.6mm) ❏0.491" (12.6mm) Marking Area (a) Ø 0.429" (11mm) ❏0.429" (11mm) Replacing Lens and Marking Plate Removal Remove the lens holder assembly (lens, marking plate and holder) from the operator by holding the color lens recesses with the lens removal tool (Part No.MT-101) and pulling out. Remove marking plate by pushing the color lens from the rear to disengage the latches. Marking plate must be engraved on the side as shown in the figure on the right. Ø 5/8" (16mm) Latches Recess Installation For illuminated and non-illuminated pushbuttons: 1. Insert marking plate inside lens in correct direction (For non-illuminated, install marking plate when replacing button). 2. Press color lens on to lens holder to engage latches. 3. Insert lens holder into housing in correct direction. Color Lens Engraving Area Marking Plate Lens Holder Operator Do not loosen spring on illuminated pushbutton units (except on pilot light units). The marking plate must be engraved on the front side as shown above. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-29
AL6M-LK2-G 价格&库存
很抱歉,暂时无法提供与“AL6M-LK2-G”相匹配的价格&库存,您可以联系我们找货
AL6M-LK2-G
  • 1+50.852041+6.61060
  • 10+43.9387210+5.71189
  • 25+41.4325125+5.38610
  • 50+39.6315150+5.15197
  • 100+37.90713100+4.92781
  • 250+35.73717250+4.64572
  • 500+34.17541500+4.44270
  • 1000+32.679221000+4.24820
库存:9
