BNM7
BNM7
    IDEC(日本和泉)
BNM7 数据手册
Terminal Blocks BNH/BN Terminal Blocks BNH/BN Series Key features of the BNH/BN series include: •Touch-down terminals with spring-loaded captive screws available •Jumpers available up to 30A model •Fuse block with or without blown-fuse indicator in neon or LED •Mount on 35mm standard DIN rail File No. R9551701 J9551516 (power blocks) R9650688 (dual-deck blocks) CSA Certified File No. LR64803 UL Recognized File No. E78117 Specifications Part Numbers BNH10W BNH15MW BNH15LW BNH30W Width 0.275" (7mm) 0.315" (8mm) 0.413" (10.5mm) 0.472" (12mm) Approvals UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV No. of Poles 1 1 1 1 Wire Sizes 22 to 16 AWG (2mm2) 22 to 14 AWG (2mm2) 22 to 14 AWG (2mm2) 18 to 10 AWG (5.5mm2) Current 600V / 10A 600V / 10A 600V / 15A 600V / 30A Size M3 M3 M3.5 M4 Type Touch-down Touch-down Touch-down Touch-down Specifications Appearance Terminals Mounting 35mm DIN rail 35mm DIN rail 35mm DIN rail 0.6 - 1.0 0.6 - 1.0 1.0 - 1.3 1.4 - 2.0 (in-lbs.) 5.3 - 8.9 5.3 - 8.9 8.9 - 11.5 12.4 - 17.8 End Plate BNE15W BNE15W BNE15W BNE30W DIN Rail Stop BNL-5 BNL-5 BNL-5 BNL-5 Dust Cover BNC230 BNC230 BNC230 BNC230 PVC BNM7 BNM7 BNM7 BNM7 Fiberglass BNM9 BNM9 BNM9 BNM9 End clip Terminal Torque Marking Strip BNM3 BNM3 BNM3 BNM3 Ring Terminal Jumpers BNJ16 BNJ26W BNJ46 BNJ56 Fork Terminal Jumpers BNJ16F BNJ26FW BNJ46F BNJ56F P Terminal Blocks 35mm DIN rail (N-m) 1. BNDN1000 aluminum DIN rails are available in 1 meter lengths. 2. Marking strips are available in 1 meter lengths. 3. Jumpers are available in groups of six. 4. Remove the “H” in the terminal block part number for standard screw type. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC P-3 Terminal Blocks BNH/BN Terminal Blocks Specifications con’t Part Numbers BNH50W BN75W BN150W BNDH15W Specifications Appearance Width 0.787" (20mm) 0.787" (20mm) 1.024" (26mm) 0.315" (8mm) Approvals UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV No. of Poles 1 1 1 2 Wire Sizes 16 to 6 AWG (14mm2) 16 to 4 AWG (22mm2) 16 to 0 AWG (38mm2) 22 to 14 AWG (2mm2) Current 600V / 50A 600V / 75A 600V / 150A 600V / 10A Terminals Size M5 M6 M8 M3 Type Touch-down Hex bolt Hex bolt Touch-down 35mm DIN rail 35mm DIN rail 35mm DIN rail 35mm DIN rail, surface 2.6 - 3.7 3.9 - 5.4 10 - 13.5 0.6 - 1.0 Mounting (N-m) Terminal Torque (in-lbs.) 23.1 - 32.8 34.6 - 47.9 88.8 - 119.8 5.3 - 8.9 End Plate BNE50W BNE75W BNE150W BNDE15W DIN Rail Stop BNL-5 BNL-6 BNL-6 BNL-8 Dust Cover BNC320 BNC420 BNC520 BNC230 (top level) BNC240 (bottom Level) PVC BNM7 BNM7 BNM7 BNM7 Fiberglass BNM9 BNM9 BNM9 BNM9 End clip BNM3 BNM3 BNM3 BNM3 Connecting Rods — — — BNR1 10.34" (265mm) BNR2 19.69" (500mm) Connecting Nuts — — — BNN1 (2 pieces) Base Mount Brackets — — — BNDL2 Ring Terminal Jumpers — — — BNJ26 Fork Terminal Jumpers — — — BNJ26FW Marking Strip 1. BNDN1000 aluminum DIN rails are available in 1 meter lengths. 2. Marking strips are available in 1 meter lengths. 3. Jumpers are available in groups of six. 4. Remove the “H” in the terminal block part number for standard screw type. Terminal Blocks P P-4 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Terminal Blocks BNF Fuse Blocks Specifications con’t Part Numbers BNF10SW BNF10NW BNF10DW Width 0.591" (15mm) 0.591" (15mm) 0.591" (15mm) Blown Fuse Indicator None Neon (100–300VAC) LED (24V DC) Approvals UL, CSA, Voltage 600V UL, CSA, Voltage 600V UL, CSA, Voltage 600V No. of Poles 1 1 1 Wire Sizes 18 to 10 AWG (5.5mm2) 18 to 10 AWG (5.5mm2) 18 to 10 AWG (5.5mm2) Current 10A maximum 10A maximum 10A maximum Size M4 M4 M4 Type Standard screw Standard screw Standard screw 35mm DIN rail 35mm DIN rail 35mm DIN rail (N-m) 1.4 - 2.0 1.4 - 2.0 1.4 - 2.0 (in-lbs.) 12.4 - 17.8 12.4 - 17.8 12.4 - 17.8 End Plate BNE20 BNE20 BNE20 Specifications Appearance Terminals Mounting Terminal Torque DIN Rail Stop BNL-5 BNL-5 BNL-5 Dust Cover — — — Marking Strip BNM7 BNM7 BNM7 Applicable Fuse Size 1/4" x 1-1/4" (6.35 x 31.8mm) 1/4" x 1-1/4" (6.35 x 31.8mm) 1/4" x 1-1/4" (6.35 x 31.8mm) 1. BNDN1000 aluminum DIN rails are available in 1 meter lengths. 2. Fuses not included. P Terminal Blocks www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC P-5 Terminal Blocks BNDH15W P-6 33 27 52 P Part No. www.idec.com 63 43 62 38 18 BN Series Part No. 53 26 22.5 20 17 BNH50W BN150W 48 24.4 9.6 BNH15LW 74 63 33 29.5 23.5 5.9 33.5 11.3 8 When musing C-rail: 41 38 18 When musing 35-mm DIN Rail: 35 29.5 23.5 BNH15MW 35 29 15.8 12 34.3 28.3 38 19.4 When using C Rail: 41 33.5 10.3 7 42.5 When using 35-mmD IN Rail: 35 18 When using 35-mm DIN Rai: 44 Whem using C Rail: 50 29.5 23.5 BNH Series Part No. 50.5 31.4 Whemusing C Rail: 41 33.5 When using 35-mm DIN Rai: 35 38 When musing 35-mm DIN Rai: 52 Whem using C Rail: 58 BN75W 25.4 BNH30W 31.7 25.7 42.5 Whem using C Rail: 44 36.5 When using 35-mm DIN Rai: 38 BNH10W 55.5 49.5 59.5 BNF10SW BNF10NW BNF10DW When using 35-mm DIN Rai: 44 Whem using C Rail: 50 BN75W BN150W Whem using C Rail: 59.5 BNH30W BNH50W When using 35-mm DIN Rai: 53.5 BNH10W BNH15MW BNH15LW When using 35-mm DIN Rai: 61 Whem using C Rail: 67 BNH/BN Terminal Blocks Terminal Blocks Dimensions Diagrams 6.7 38 18 14.3 10.5 8.5 18 15.5 13 Diagrams 29.8 26 23 Diagrams 17.5 15 13 6.7 12 8 8 USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Terminal Blocks Accessories Accessories Part Numbers: End Plates, DIN Rail Stops, Stand-Offs, DIN Rail and Dust Covers Description Appearance Use with Part No. End Plates DIN Rail Stops BNH10W BNH15MW BNH15LW BNE15W BNH30W BNE30W BNF10SW BNF10NW BNF10DW BNE20 BNH50W BNE50W BN75W BNE75W BN150W BNE150W BNDH15W BNDE15W BNH10W BNH15MW BNH15LW BNH30W BNH50W BNF10SW BNF10NW BNF10DW BA111T BA211T BA311T BA411S BAF111SU BAF111SDU BNL5 (small) Remarks 1. DIN rail stops prevent side-to-side movement. 2. The BNL-5 width is 0.375" (9.5mm). 1. DIN rail stops prevent side-to-side movement. BN75W BN150W BNL6 (medium) 2. The BNL-6 width is 0.375" (9.5mm). 3. To firmly stabilize these higher profile terminal blocks, the BNL-6 has a higher profile than the BNL-5. BNDH15W BN200NW# BN400NW# 1. DIN rail stops prevent side-to-side movement. BNL8 (large) 2. The BNL-8 width is 0.571" (14.5mm). 3. # = number of poles. DIN Rail Stand-Offs P BNS3 1.46" (37mm) height BNS4 3.03" (77mm) height All series DIN Rail All series BNDN1000 (length 39.37" (1m)) 1. For calculating the rail lengths required, see the instructions on page P-18. Terminal Blocks 2. The DIN rail material is aluminum. BNC230 BNC320 BNC420 BNC520 Dust Covers P-12 www.idec.com BNC820 BNC1000 BNDH15W BNH10W BNH15MW BNH15LW BNH30W BNC230 BNH50W BNC320 The overall length is 39.37" (1,000mm). BN75W BNC420 The material is polycarbonate. BN150W BNC520 BN200 BAC820 BN400 BNC1000 USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Terminal Blocks Accessories Accessories con’t Part Numbers: Rods, Nuts, Marking Strips, Dust Covers, and Jumpers Description Appearance Marking Strips Use with Part No. Remarks BNM7 Material: polyvinyl chloride (PVC) Strip dimensions are 0.37"x39" (9.5 x 1,000mm). BNM9 Material: fiberglass Strip dimensions are 0.37"x39" (9.5 x 1,000mm). All series BNM3 Used to prevent marking strips from sliding out. BNH10W BNJ16 BNH15MW BNJ26W BNH15LW BNJ46 BNH30W BNJ56 BNDH15W BNJ26W BNH10W BNJ16F BNH15MW BNJ26FW BNH15LW BNJ46F BNH30W BNJ56F BNDH15W BNJ26FW BNDH15W (dual-deck) BNDL2 Used to surface mount dual-deck terminal blocks. (BNDL2). BNR1 (265mm) 1. Rod and connecting nuts are used to mount dual-decks collectively. BNR2 (500mm) 2. Each connecting nut set includes 1 hex connecting nut and 1 round connecting nut. All series Marking Strip Fastener Ring Terminal Jumpers Fork Terminal Jumpers Surface Mount Bracket M4 Thread Rod BNDH15W BNR1 BNR2 Connecting Nuts BNN1 Jumpers come standard with 6 points. Note: insulated jumpers available - add “B” to end of part number. For example, BNJ26WB. 3. The BNR1 rod dimensions are 0.027 "x 10.43" (0.7 x 265mm). 4. The BNR2 rod dimensions are 0.027" x 19.69" (0.7 x 500mm). www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Terminal Blocks For accessory dimensions, see page P-14. P P-13 Terminal Blocks Accessories Dimensions Dimensions: DIN Rail Part No. Diagram 1.365" ±0.012 (35mm ±0.3) 0.413" +0.020, -0 (10.5mm +0.5, -0) 3.59" (92mm) + BNDN1000 1.99" (51mm) + 1.99"(51mm) + 39.37" (1m) Ø 0.148" x 0.488" Slot, 3 Places (Ø 3.8 x 12.5mm) Dimensions: Jumpers Dimensions Part No. Diagram BNJ16 BNJ16F (fork) A BNJ26W E 0.031" (0.8mm) F BNJ26FW (fork) Part No. with “F" = Fork BNJ46 BNJ46F (fork) A ØD C B C A B ØD BNJ56 BNJ56F (fork) G E F 0.031" (0.8mm) C D E* 0.156" (4mm) 0.433" (11mm) B 0.224" (6mm) 0.146" (4mm) 0.276" (7mm) 1.365" (35mm) F G — 0.433" (11mm) 0.144" (3.7mm) 0.224" (6mm) 0.146" (4mm) 0.276" (7mm) 1.365" (35mm) 0.156" (4mm) 0.175" (4.5mm) 0.429" (11mm) 0.25" (6.4mm) Ø 0.144" (3.7mm) 0.312" (8mm) 1.56" (40mm) — 0.429" (11mm) 0.175" (4.5mm) 0.25" (6.4mm) Ø 0.144" (3.7mm) 0.312" (8mm) 1.56" (40mm) 0.175" (4.5mm) 0.215" (5.5mm) 0.429" (11mm) 0.32" (8.2mm) Ø 0.165" (4.2mm) 0.41" (10.5mm) 2.048" (52.5mm) — 0.429" (11mm) 0.175" (4.5mm) 0.32" (8.2mm) Ø 0.165" (4.2mm) 0.41" (10.5mm) 2.048" (52.5mm) 0.215" (5.5mm) 0.234" (6mm) 0.371" (9.5mm) 0.363" (9.3mm) Ø 0.164" (4.2mm) 0.468" (12mm) 2.34" (60mm) — 0.371" (9.5mm) 0.228" (5.8mm) 0.363" (9.3mm) Ø 0.164" (4.2mm) 0.468" (12mm) 2.34" (60mm) 0.234" (6mm) 1.* Dimension E on center. 2.Thickness + 0.8mm (0.0315"). Terminal Blocks P P-14 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Terminal Blocks Accessories Dimensions (con’t) Dimensions: DIN Rail Stops and Stand-Offs Part No. Dimensions BNL-5 45 BNL-6 9 BNL-6 shown, BNL-5 same except without back crossbar BNL-8 46 14.4 30 26 BNDL2 38 13 36.7 30 2-º5.2 12.5 BNS3 54 26 15 25 2.6 2-M5 15 28 12.5 76.7 2-º5.2 54 26 2-M5 28 15 2.6 15 BNS4 30 12.5 25 12.5 P Terminal Blocks www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC P-15 Terminal Blocks Accessories Dimensions (con’t) Dimensions: End Plates Part No. Dimensions Part No. Dimensions 38 53 BNE15W BNE75W 5 5 74 63 BNE20 BNE150W 3 5 62 38 BNE30W BNDE15W ï 5 48 BNE50W 5 Terminal Blocks P P-16 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Terminal Blocks Instructions Instructions Wiring Touch-Down Terminal Blocks: BNH Series Instructions Step 1 Step 2 Step 3 Step 4 Step 1. Insert the wire (or crimping terminal) into the terminal block with the terminal screws in the open position. (Use of crimping terminals is optional.) Step 2. Push the terminal screw down to hold the wire in place. Step 3. Hold the terminal screw down, and tighten with a screwdriver. Step 4. To remove the wire, loosen the terminal screw and pull up until wire is released. Installation and Removal of Terminal Blocks Instructions Appearance Step 1. Slide the terminal blocks onto the DIN rail from one end. Step 2. Use BNL5 or BNL6 end clips to secure the terminal block row and to prevent side-to-side movement. BNH10W, BNH15MW, BNH15LW, and BNH30W can be installed from the middle of a DIN rail. Step 3. To install, place the terminal block on top of the DIN rail and push down until both edges of the terminal block snap onto the DIN rail. Step 4. Removal Tool BND2 To remove the terminal block, use the BND2 removal tool as shown on the right. Mounting Double-Deck Terminal Blocks Instructions Appearance DIN Rail Mount: Terminal Block Step 1. First install the end plate. Then mount the terminal blocks onto the DIN rail. Step 2. To prevent side-to-side movement on the DIN rail, use the BNL-8 mounting clip at both ends of the rail. End Plate Step 1. Assemble a row of terminal blocks with end plates on exposed end(s). Step 2. Use BNDL2 mounting clips at both ends of a row. Step 3. With the two holes of the mounting clip aligned with the terminal block holes, insert a connecting rod through each hole. Step 4. Secure the ends of the connecting rods with the connecting nuts, as shown below. www.idec.com Connecting Nut (hex) Mounting Clip Connecting Rod USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Mounting Clip P-17 P Terminal Blocks Connecting Nut (round) Panel Mount: Terminal Blocks Instructions Calculating DIN Rail Lengths Instructions Appearance Step 1. Add widths of all terminal blocks (reference pages K-4 through K-9). Overall Mounting Centers Rail Length + 1" (25mm) Step 2. Add the endplate thickness (usually only one). Mounting Centers every 2" (50mm) Step 3. Add the DIN rail stop widths (usually two are used). Step 4. Round to the nearest 2" (50mm) increment to allow for DIN rail hole spacing. Step 5. Add 1" (25mm) to ensure 0.5" (12.5mm) of clearance at each end of the DIN rail. DIN Rail Stop Dimensions Part No. Width BNL-5 BNL-6 BNL-8 .374" (9.5mm) .374" (9.5mm) .571" (14.5mm) Torque Specifications Screw Size M3 0.6 to 1.0 (kgf-cm) 6.1 to 10.2 M3.5 M4 M5 M6 M8 M10 M12 1.4 to 2.0 14.3 to 20.4 0.371" 2.6 to 3.7 26.5 to 37.7 0.499" 3.9 to 5.4 39.8 to 55.1 0.655" 10 to 13.5 21 to 28 38 to 49 102 to 138 214 to 286 388 to 500 Dimension A 0.257" 1.0 to 1.3 10.2 to 13.3 0.332" 0.890" 1.279" 1.981" (6.6mm) (8.5mm) (9.5mm) (12.8mm) (16.8mm) (22.8mm) (32.8mm) (50.8mm) Dimension B 0.129" 0.156" 0.176" 0.176" 0.234" 0.312" 0.429" 0.546" (3.3mm) (4mm) (4.5mm) (4.5mm) (6mm) (8mm) (11mm) (14mm) Dimension C 0.195" 0.195" 0.332" 0.429" 0.624" 1.014" (5mm) (6.5mm) (8.5mm) (11mm) (16mm) (26mm) Dimension D Ø 0.125" Ø 0.140" 0.234" (6mm) Ø 0.164" 0.254" (5mm) Ø 0.203" Ø 0.242" Ø 0.332" Ø 0.410" Ø 0.488" (3.2mm) (3.6mm) (4.2mm) (5.2mm) (6.2mm) (8.5mm) (10.5mm) (12.5mm) Torque (N-m) Diagram B (minimum) C (maximum) A ØD Rated Current Terminal Blocks P Applicable Wire Rated at 60˚C 22 AWG (0.3mm2) 3A 20 AWG (0.5mm2) 5A 18 AWG (0.75mm2) 7A 16 AWG (1.25mm2) 10A 14 AWG (2mm2) 15A 12 (3.5mm2) 20A 10 (5.5mm2) 30A 6 (14mm2) 50A 4 (22mm2) 75A 0 (38mm2) 100A 00 (60mm2) 150A 0000 (100mm2) 200A 300mcm (150mm2) 300A 350A 400mcm (200mm2) UL/CSA ratings are specified. The current carrying capacity depends on the rating of the wire used, as shown. P-18 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC
很抱歉,暂时无法提供与“BNM7”相匹配的价格&库存,您可以联系我们找货
BNM7
  • 1+14.798151+1.91406
