FC4A-USB
FC4A-USB
    IDEC(日本和泉)
    Module
FC4A-USB 数据手册
Programmable Logic Controllers MicroSmart Pentra Series OI Touchscreens PLCs MicroSmart Pentra Series Safety Maximize efficiency and cut development time! MicroSmart Pentra PLCs combine advanced networking capabilities with unparalleled power, performance and connectivity. Designed to meet all your communication requirements, now and in the future, MicroSmart Pentra PLCs give you the flexibility to expand your system with as many as fifteen modules! Our new Embedded Ethernet PLC with built-in Modbus TCP also lets you remotely monitor status in real-time, receive email alerts and customize your own web page. All MicroSmart Pentra PLCs meet the highest standards for safety including: cULus listed for Class 1 Division 2 hazardous locations*, CE compliant, as well as certified for marine use by ABS, DNV, and Lloyd’s Registry*. *Not applicable for all models. Visit www.IDEC.com/approvals for details. Power Supplies Power, Performance, Connectivity Automation Software The Power to Control. Anywhere. Anytime. The MicroSmart Pentra PLC Family: Everything you need in a controller Email and text notifications Modbus TCP, RTU and ASCII USB programming port Seven communication ports NEW Advanced PID control modules User web page NEW 4-pt. analog output module Sensors Embedded Ethernet Port Communication Barriers 800-262-IDEC (4332) • USA & Canada 59 Programmable Logic Controllers MicroSmart Pentra Performance Embedded Ethernet Port Remote Access and Control The new MicroSmart Pentra PLC with an embedded Ethernet port, you can configure the MicroSmart Pentra PLC for remote monitoring and control. Using WindLDR software, you can remotely monitor or update the PLC programs without having to be near the PLC. PLCs OI Touchscreens MicroSmart Pentra Series Web Server Functions Using standard web browsers like Internet Explorer or Firefox, you can remotely log-in and access web pages that are stored directly on the MicroSmart Pentra PLC. Up to 1 MB of memory is dedicated for web page storage! Use the built-in web pages or create your own using an HTML editor. Automation Software Internet 14 Simultaneous Connections Sensors Power Supplies The new embedded Ethernet Pentra supports up to 14 simultaneous connections through its Ethernet port. Through the Ethernet port, the embedded Ethernet Pentra can be configured to communicate to WindLDR for maintenance communications, to an Operator Interface touchscreen, and to VFD using Modbus TCP communications, all simultaneously. Embedded USB Maintenance Port The new MicroSmart Pentra PLC with an embedded Ethernet PLC port also has an embedded mini-B USB port for maintenance. Barriers Communication You can now easily connect your PC to this PLC using a standard USB cable. 60 www.IDEC.com Programmable Logic Controllers MicroSmart Pentra Series Modbus TCP, RTU and ASCII OI Touchscreens Web Browser - Remote Monitor & Control WindLDR Software Monitor & Update Program SCADA Supervisory Controls TCP Modbus TCP Server 255 Modbus TCP Client Ethernet Modbus TCP Server 3 Modbus TCP Server 2 Pentra with Radio Modem OI Touchscreen PLCs Modbus TCP Server 1 VFD Pentra Pentra OI Touchscreen Modbus RTU/ASCII RS485 Automation Software Temperature Controller Pentra with Radio Modem Using intuitive WindLDR software, you can configure the MicroSmart Pentra to be a Master or Slave device on a Modbus network. All MicroSmart Pentra PLCs support Modbus RTU/ASCII protocols and our CPU with embedded Ethernet port also supports Modbus TCP protocol. Power Supplies Email and Text Message SMS Sensors Internet Communication Easily configure the MicroSmart Pentra PLCs to send out system status and alarms to your email or mobile phone. Data registers values in the PLC can also be incorporated in the body of the email. It also supports email login authentication so third party email server like Yahoo can be used. Up to 255 email templates can be configured with multiple recipients can be included. Barriers 800-262-IDEC (4332) • USA & Canada 61 Programmable Logic Controllers MicroSmart Pentra Series Power Supplies Automation Software PLCs OI Touchscreens User Web Pages With IDEC MicroSmart Pentra, users do not need to know JAVA programming to embed dynamic values and parts on their PLC web pages. Even novice HTML programmer can take full advantage of the integrated IDEC system library of numerical display/input, horizontal and vertical bar graphs, trend chart, ON/OFF pilot lights and pushbuttons. Up to 1MB of memory is reserved for user web pages. Integrated 100KHz Fast Inputs and Outputs Configure up to four high-speed inputs from high-speed output devices such as rotary encoders or proximity switches at a maximum frequency of 100KHz, independent of the scan time. Up to three high-speed outputs can be used for simple positioning controls for stepper or servo motors. Sensors HSC1: 930 V out Barriers Communication 1 PULSE 62 www.IDEC.com Programmable Logic Controllers MicroSmart Pentra Series Maximum 7 Communication Ports Port 6 RS232C/ RS485 Port 1 RS232C VFD Automation Software Port 5 RS232C/RS485 PLCs With MicroSmart Pentra PLCs, you don’t have to worry about limited communication capabilities. It doesn’t matter if you’re just starting out or a current user expanding your MicroSmart Pentra PLC, you can rest assured that these communication modules will provide reliable and seamless communication. If RS485 modules are used for all six ports, up to 186 RS485 slave devices can be connected with as high as a 115K baud rate available for fast transmission. Port 2 RS232C/RS485 Port 3 RS232C/RS485 OI Touchscreens Port 4 RS232C/RS485 Port 7 RS232C/RS485 Temperature Controller Power Supplies Sensors Communication Barriers 800-262-IDEC (4332) • USA & Canada 63 Programmable Logic Controllers OI Touchscreens MicroSmart Pentra Series Choose a CPU for every application With three controller types to choose from, MicroSmart Pentra PLCs offer the features you need for your applications. Built to allow you the flexibility to expand when you need to, MicroSmart Pentra PLCs are the best way to get everything you need in just one controller. Potentiometer PLCs Power, Status, I/O LED Indicators Removable Terminal Block Automation Software Optional HMI module Optional Clock Cartridge USB mini-B Programming Port Optional HMI base module Optional EEPROM cartridge (up to 128KB) • Optional RS232C adaptor Power Supplies 0-10V DC Analog Input (8-bit resolution) (8-pin mini DIN connector) • Optional RS485 adaptor (8-pin mini DIN or screw terminal connector) RJ-45 Ethernet Port • Optional RS232C module Power Terminal • Optional RS485 module Sensors (mini-DIN or screw terminal type) Slim CPU with Ethernet Port Communication The perfect design when you need Ethernet capability, this slim CPU with embedded Ethernet port is available with 24V DC power and equipped with eight DC inputs and four transistor outputs (sink or source). Up to seven functional modules, including analog and communication modules can be mounted on the right-hand expansion bus. Using an expansion interface module, an additional eight discrete expansion modules can be mounted. Barriers Modules snap together easily without the need for additional tools. 64 www.IDEC.com Programmable Logic Controllers MicroSmart Pentra Series OI Touchscreens Potentiometer 0-10V DC Analog Input (8-bit resolution) Potentiometer (x2) Optional HMI module RS232C port PLCs RS232C port Automation Software Optional Clock Cartridge Optional EEPROM cartridge Power, Status, I/O LED Indicators Power Supplies • Optional RS232C adaptor (8-pin mini DIN connector) • Optional RS485 adaptor (8-pin mini DIN or screw terminal connector) Screw Terminal or MIL connector termination Sensors • Optional EEPROM cartridge • Optional Clock Cartridge All-in-One CPU If you don’t need Ethernet, but still want a high-performance CPU, the MicroSmart Pentra slim CPU is your best choice! Available with 24V DC power, this controller has all the functionalities you need in 16 and 32 I/O configurations. Each 16 I/O CPU is equipped with eight DC inputs, two transistor outputs (sink or source) and six relay outputs, while the 32 I/O CPU is equipped with 16 DC inputs and 16 transistor outputs (sink or source). Available with 12V DC, 24V DC and 100-240V AC power, you can choose from 10, 16 and 24 I/O configurations. The 10 I/O CPU is equipped with six DC inputs and four relay outputs, while the 16 I/O CPU is equipped with nine DC inputs and seven relay outputs. The 24 I/O CPU is equipped with 14 DC inputs and ten relay outputs. The 24 I/O CPU (24V DC and 100-240V AC models) can also be expanded with a maximum of four functional or discreet expansion modules. Communication Slim CPU Barriers 800-262-IDEC (4332) • USA & Canada 65 Programmable Logic Controllers OI Touchscreens MicroSmart Pentra Series MicroSmart Pentra CPU Part Numbers Slim Base Module with Embedded Ethernet Style Part Number Embedded I/Os Operating Voltage Ethernet & USB Port FC5A-D12K1E Output Maximum No. of Expansion Modules Transistor Sink 12 (8in/4out) 24V DC 15 (Maximum 492 digital I/Os) Yes Transistor Source PLCs FC5A-D12S1E Slim Base Module Automation Software Style Part Number Operating Voltage Ethernet & USB Port Output 6 Relays, 2 Trans. Sink FC5A-D16RK1 15 (Maximum 496 digital I/Os) 16 (8in/8out) 6 Relays, 2 Trans. Source FC5A-D16RS1 24V DC — FC5A-D32K3 Power Supplies Maximum No. of Expansion Modules Transistor Sink 15 (Maximum 512 digital I/Os) 32 (16in/16out) FC5A-D32S3 Transistor Source All-in-One Base Module Sensors Style Part Number Operating Voltage FC5A-C10R2 120-240V AC FC5A-C10R2C 10 (6in/4out) Ethernet & USB Port Output Maximum No. of Expansion Modules 24V DC FC5A-C10R2D 12V DC FC5A-C16R2 120-240V AC Communication — Barriers FC5A-C16R2C 24V DC FC5A-C16R2D 12V DC FC5A-C24R2 120-240V AC FC5A-C24R2C FC5A-C24R2D 66 16 (9in/7out) 24 (14in/10out) 24V DC 12V DC www.IDEC.com — Relay 4 (Maximum 88 digital I/Os) — Programmable Logic Controllers MicroSmart Series OI Touchscreens MicroSmart Performance MicroSmart Series Key features: PLCs • Available in 10, 16, 20, 24, and 40 I/O CPUs. • PID Controls -Program up to 14 PID loops • High Speed I/O -Built-in 4 high speed inputs -Single or Dual Phase -Max. 20KHz frequency • Built-in 2 High speed outputs (Slim model only) • Configure up to 264 I/O Points • Data link up to 32 MicroSmart and Pentra CPUs • Using RS485 communication module/port, you can create a network of up to 32 CPUs. • Worldwide Approvals -cULus listed, CE marked -Class 1 Div. 2 for hazardous locations -Lloyds Registered and ABS approved for shipping industry Automation Software MicroSmart CPU Part Numbers All-in-One Part Number Power FC4A-C10R2C 24V DC I/O Points Input Output Maximum No. of Expansion Modules Power Supplies Style 10 (6 in/ 4 out) FC4A-C10R2 100-240V AC FC4A-C16R2C 24V DC 16 (9 in/ 7 out) 100-240V AC FC4A-C24R2C 24V DC   24 (14 in/ 10 out) 24V DC (Sink/Source) Relay Communication FC4A-C16R2 FC4A-C24R2 Sensors — 4 (Maximum 88 digital I/Os) 100-240V AC Barriers 800-262-IDEC (4332) • USA & Canada 67 Programmable Logic Controllers OI Touchscreens MicroSmart Series MicroSmart CPU Part Numbers Slim Style Part Number Power I/O Points Input Output Maximum No. of Expansion Modules 6 Relays, 2 Transistor Sink PLCs FC4A-D20RK1 7 (Maximum 244 digital I/Os) 6 Relays, 2 Transistor Source Automation Software FC4A-D20RS1 20 (12 in/8 out) Power Supplies FC4A-D20K3 Transistor Sink 24V DC 7 (Maximum 148 digital I/Os) 24V DC (Sink/Source) Transistor Source FC4A-D40K3 Transistor Sink Sensors FC4A-D20S3 7 (Maximum 264 digital I/Os) Communication 40 (24 in/16 out) FC4A-D40S3 Transistor Source Barriers 68 www.IDEC.com Programmable Logic Controllers MicroSmart Family OI Touchscreens Digital I/O Expansion Modules MicroSmart Family Key features: • 15 modules to choose from • Available with Screw or MIL connectors • Easy snap-on • Available 8, 16 or 32 point modules • Up to 512 I/O can be configured in the Pentra and 264 I/O in the MicroSmart system Input Modules Part Number FC4A-N08A11 Input Input Points PLCs Style Terminal 100-120V AC Automation Software 8 Removable Screw Terminals FC4A-N08B1 Power Supplies FC4A-N16B1 Sensors 24V DC 16 Communication FC4A-N16B3 MIL Connector (ribbon cable) FC4A-N32B3 32 Barriers 800-262-IDEC (4332) • USA & Canada 69 Programmable Logic Controllers OI Touchscreens MicroSmart Family Digital I/O Expansion Modules Output Modules Style Part Number Output Output Points 8 PLCs FC4A-R081 Terminal FC4A-R161 16 FC4A-T08K1 8 Removable Screw Terminals Power Supplies Automation Software Relay Transistor Sink 16 Sensors FC4A-T16K3 MIL Connector (ribbon cable) 32 Barriers Communication FC4A-T32K3 70 www.IDEC.com Programmable Logic Controllers MicroSmart Family OI Touchscreens Digital I/O Expansion Modules Output Modules (cont.) Style Part Number Output Output Points FC4A-T08S1 Terminal 8 Removable Screw Terminals PLCs Transistor Source Automation Software FC4A-T16S3 16 MIL Connector (ribbon cable) 32 Power Supplies FC4A-T32S3 Combination I/O Modules Style Part Number Input Output I/O Points 24V DC (Sink/Source) 8 (4 in/4 out) Removable Screw Terminals 24 (16 in/ 8 out) Wire Spring Clamp Sensors FC4A-M08BR1 Terminal Relay Communication FC4A-M24BR2 Barriers 800-262-IDEC (4332) • USA & Canada 71 Programmable Logic Controllers PLCs OI Touchscreens MicroSmart Family Analog I/O Expansion Modules Key features: • 9 different modules to choose from • 0-10V, 4-20mA, RTD, Thermocouple, Thermistor inputs, 0-10V DC or -10V DC to 10V DC output • 12 or 16-bit resolution • Fast conversion time • Maximum of 56 I/O can be configured in the MicroSmart Pentra system • Easy to configure using a Macro instruction in WindLDR Modules Part Number I/O Points FC4A-J8C1 8 (8 inputs) FC4A-L03A1 3 (2 inputs, 1 output) Input 0-10V DC, 4-20mA Output Resolution – 16-bit (0-50000) Terminal 0-10V DC, 4-20mA Power Supplies Automation Software Style 12-bit (0-4095) Removable Screw Terminals 2 (2 inputs) – FC4A-J4CN1 4 (4 inputs) 0-10V DC, 4-20mA, RTD, Thermocouple – 16-bit (0-50000) FC4A-L03AP1 3 (2 inputs, 1 output) RTD, Thermocouple 0-10V DC, 4-20mA 12-bit (0-4095) Barriers Communication Sensors FC4A-J2A1 72 www.IDEC.com Programmable Logic Controllers MicroSmart Family OI Touchscreens Analog I/O Expansion Modules Modules (cont.) Style I/O Points Input Output Resolution FC4A-J8AT1 8 (8 inputs) Thermistor (NTC/PTC) – 12-bit (0-4000) FC4A-K2C1 2 (2 outputs) – -10 to 10V DC, 4-20mA 16-bit (0-50000) FC4A-K1A1 1 (1 output) – 0-10V DC, 4-20mA 12-bit (0-4095) Terminal PLCs Part Number Automation Software Power Supplies FC4A-K4A1 Removable Screw Terminals 4 (4 outputs) Communication Modules Web Server Module Features: Sensors • Easy to configure • Comes with interface cable and Quick Start Guide Part Numbers Style Description FC4A-ENET Web Server Module (includes cable and Quick Start Guide) Style Part Number Description FC9Y-QS100-0 Quick Start Guide Communication Part Number Quick Start Guide Web Server Module for MicroSmart PLC Barriers 800-262-IDEC (4332) • USA & Canada 73 Programmable Logic Controllers Advanced PID for precision control PID (Proportional Integral Derivative) is the most commonly used feedback control loop in industrial control systems. PID calculates an error value as the difference between a measured process variable and a desired set point. The controller then attempts to minimize the error by adjusting the process control. With MicroSmart Pentra PLCs, PID implementation can be deployed in two ways: integrated PID controls or a dedicated Process Control module, which can be mounted on the MicroSmart Pentra expansion bus. Automation Software PLCs OI Touchscreens MicroSmart Family P Setpoint + Error K p e(t) I Process Output – Kd de(t) dt Advanced PID Control Module Advanced PID Control Module Part Numbers A dedicated PID Control module is available for extreme stability and complex applications. This particular module has more functionalities than you will find in any other controller on the market. Independent of CPU scan time, the PID Control module does the work, reducing PLC scan time without taking up PLC memory space. Style Part Number Description FC5A-F2M2 PID Control Module with 2x analog inputs and 2x 4-20mA/non-contact voltage for SSR drive Sensors Power Supplies D FC5A-F2MR2 PID Controls Module with 2x analog inputs and 2x Relay Outputs PID Control Module Highlights: Communication • Precise, stable and accurate PID control with less than a 0.2% error • Available in two models: – Built-in 2 analog inputs, 2 x 4-20mA/ non-contact voltage for SSR drive – Built-in 2 analog inputs, 2 x relay outputs • Each input individually configured to accept different signal types Barriers • Up to seven modules can be mounted on the MicroSmart Pentra • Maximum 14 PID loops with auto-tuning 74 www.IDEC.com • 14-bit resolution • ARW (anti-reset windup) • Accepts many different input types including: – Type K, J, R, S, B, E, T, C, PL-II and N thermocouples – RTD – 0-20 mA and 4-20 mA – 0-1V, 0-5V, 1-5V, and 0-10V DC • Numerous control methods including: – Cascade – External set point – Heating and cooling control action – Difference input control Programmable Logic Controllers MicroSmart Family OI Touchscreens Communication Modules AS-Interface Module PLCs Automation Software AS-Interface Master Module Style Part Number Description FC4A-AS62M MicroSmart AS-Interface Master Module IDEC offers a plug-in AS-Interface master module (as well as other AS-Interface devices, please see AS-Interface Communication section) that is easy to configure; it can also connect up to 62 slaves. With this technology, you’ll reduce the amount of engineering needed, simplify wiring and enhance your operations; requiring less maintenance. With an average cost of savings of 15 to 40% compared with traditional cabling methods, using an IDEC AS-Interface module is the easy choice. Sensors Master-Slave Principle Power Supplies The Actuator Sensor-interface (AS-Interface) is the simplest and most costeffective of the PLC-based , industrial-networking protocols. AS-Interface is a truly open, low-cost electromechanical connection system designed to operate over a two-wire cable carrying data and power over a distance of up to 100m. It is especially suitable for lower levels of plant automation where simple - often binary (On/Off) - field devices such as switches, sensors, and actuators need to interoperate in a local area automation network controlled by a PLC. IDEC supports this open technology. range. A/B slaves have an address of 1A through 31A in the standard address range or 1B through 31B in the expanded address range. Among the A/B slaves, slaves with an address of Various types of slave devices can be connected to the AS-Interface bus, including sensors, actuators, and remote I/O devices. Analog slaves can also be connected to process analog data. Slaves are available in standard slaves and A/B slaves. Standard slaves have an address of 1 through 31 in the standard address 1A through 31A are called A slaves, and slaves with an address of 1B through 31B are called B slaves. (see AS-Interface Communication section for more details) Communication The AS-Interface master controls and monitors the status of slave devices connected to the AS-Interface bus. Normally, the AS-Interface master is connected to a PLC (sometimes called ‘host’) or a gateway. Controller Master Master call B-Slaves Master call A-Slaves Slave 2A Slave 31A Slave 1B Slave 1A Slave 2A Slave 31A Slave 1B Slave answer A-Slaves Slave 2B Barriers Slave 1A Slave 2B Slave answer B-Slaves 800-262-IDEC (4332) • USA & Canada 75 Programmable Logic Controllers MicroSmart Family PLCs OI Touchscreens Communication Module Style Part Number Description FC5A-SIF4 RS485 Communication Module for MicroSmart Pentra configure as port 3 to 7 FC5A-SIF2 RS232 Communication Module for MicroSmart Pentra configure as port 3 to 7 Communicate with up to seven different serial devices Only IDEC offers communication modules that enable you to configure up to seven serial devices! Now you can connect your operator interface, PC, barcode reader, RFID equipment, printer and more. Just imagine the possibilities. Barriers Communication Sensors Power Supplies Automation Software Using the MicroSmart Pentra slim CPU,you can configure up to seven communication ports. Using the All-in-one MicroSmart Pentra you can communicate with up to five serial devices. 76 www.IDEC.com Programmable Logic Controllers MicroSmart Family Style Part Number Description Usage FC4A-PH1 HMI Module For displaying and changing operands FC4A-PM32 EEPROM memory cartridge 32KB EEPROM memory cartridge FC4A-PM64 EEPROM memory cartridge 64KB EEPROM memory cartridge FC4A-PM128 EEPROM memory cartridge 128KB EEPROM memory cartridge Clock cartridge Real-time clock cartridge Power Supplies For mounting HMI module and communication ports with slim model CPU module (HMI module is not included) Automation Software HMI Base Module PLCs FC4A-HPH1 FC4A-PT1 OI Touchscreens Optional Modules Sensors Communication Ports Style Part Number Description Terminal Mini DIN FC4A-PC2 RS485 Mini DIN FC4A-PC3 RS485 Screw Terminal 800-262-IDEC (4332) • USA & Canada Barriers RS232C Communication FC4A-PC1 77 Programmable Logic Controllers Communication Module — for Slim CPU Style Part Number Description Expansion Power Supply Module Terminal Style Part Number Description FC4A-HPC1 RS232C Mini DIN FC5A-EXM1M Master Expansion Power Supply For MicroSmart Pentra FC4A-HPC2 RS485 Mini DIN FC5A-EXM1S Slave Expansion Power Supply For MicroSmart Pentra FC4A-HPC3 RS485 Screw Terminal FC5A-EXM2 Expansion Power Supply For MicroSmart Pentra Power Supplies Automation Software PLCs OI Touchscreens MicroSmart Family Expansion Power Supply System Configuration FC5A-EXM2 (Expansion Interface Module) FC5A-EXM2 Sensors Slim CPU Module FC5A-EXM1M and FC5A-EXM1S (Expansion Interface Master & Salve Modules) Slim CPU Module Communication FC5A-EXM1M FC5A-KX1C (Expansion Interface Cable) 1m Barriers FC5A-EXM1S 78 www.IDEC.com Programmable Logic Controllers MicroSmart Family Cables OI Touchscreens Communication Cables Part Number Appearance FC4A-KC4CA 5ft. (1.53m) FC2A-KM1C FC2A-KP1C USB to Serial Converter Web Server Module interface cable 6ft. (1.83m) USB programming cable for embedded Ethernet CPU FC5A-KX1C Length 9.84 Ft. (3m) 9.84 Ft. (3m) 3.28 Ft. (1m) Expanded Description Modem cable. Used to connect a modem to the MicroSmart RS232C port. User communication cable. Used to connect RS232C equipment to the MicroSmart RS232C port. MicroSmart Pentra expansion power supply interface cable. Used to connect expansion interface master and expansion slave modules. Power Supplies 0.33ft. (100mm) Part Number Automation Software HG9Z-XCM2A Programming cable (Maintenance/User Communication Mode selectable) 6ft. (1.83m) FC4A-KC3C Appearance PLCs FC4A-USB Expanded Description Length MIL Connector Cables (use with Breakout Modules) Use with Part Number Length Use with Part Number FC9Z-H050B26 1.64ft. (0.5m) FC9Z-H050B20 FC9Z-H100B26 3.28ft. (1m) FC9Z-H100B20 FC9Z-H200B26 Non-shielded Model Length 1.64ft. (0.5m) Non-shielded 3.28ft. (1m) 6.56ft (2m) FC9Z-H200B20 FC9Z-H300B26 9.85ft. (3m) FC9Z-H300B20 9.85ft. (3m) FC9Z-H050A26 1.64ft. (0.5m) FC9Z-H050A20 1.64ft. (0.5m) FC9Z-H100A26 FC9Z-H200A26 3.28ft. (1m) Shielded 6.56ft (2m) FC9Z-H300A26 FC9Z-H100C26A I/O Expansion Modules (20-wire) BX1D-S20A, BX1D-T20A 9.85ft. (3m) Shielded Single Connectors 5ft. (1.5m) FC9Z-H100A20 FC9Z-H200A20 Shielded FC9Z-H300A20 FC9Z-H100C20A 6.56ft (2m) Sensors CPU Module (26-wire) BX1D-S26A, BX1D-T26A Model 3.28ft. (1m) 6.56ft (2m) 9.85ft. (3m) Shielded Single Connectors 5ft. (1.5m) Communication Breakout Modules Part Number Descrption 26-wire MIL connector cable BX1D-S26A 26-terminal breakout module BX1D-T26A 26-terminal touch-down terminal breakout module BX1D-S20A 20-terminal breakout module BX1D-T20A 20-terminal touch-down terminal breakout module 20-wire MIL connector cable 800-262-IDEC (4332) • USA & Canada Barriers Use with 79 Programmable Logic Controllers OI Touchscreens MicroSmart Family Accessories Part Number Use with FC4A-PMT13 FC5A-PMT13 CPU module FC4A-PMTS16 16-position right-side terminal block for FC4A-D20RK1 and FC5A-D16RK1 CPU 11-position terminal block for 8-pt I/O expansion modules PLCs I/O expansion modules 10-position terminal block for 16-pt I/O expansion modules FC4A-PMC20 20-position connector socket for MIL connector I/O expansion modules FC4A-PMC26 26-position connector socket for MIL connector CPU modules FC4A-PSP1 Direct mounting strips for mounting on a panel FC4A-PMAC2 Analog voltage input cable for slim CPU FC4A-DS824-SW14 14-pt input simulator switch for 24 I/O CPU FC4A-DS824-SW9 9-pt input simulator switch for 16 I/O CPU FC4A-DS824-SW6 6-pt input simulator switch for 10 I/O CPU FC9Y-B812-0A MicroSmart user manual FC9Y-B1138-0 MicroSmart Pentra user manual SW1A-WIC Automation Organizer Software Suite RV8H Series 6mm Interface Relays Key FeaturesRV8H • Space-saving 6mm width • Only 70mm in height from DIN rail • Gold-plated contacts • Pre-assembled relay and DIN mount socket • Universal screw terminals (flat and Phillips) • Universal AC/DC socket with built-in surge suppression and green LED • Lever for easy locking and removal of relay • Wide input voltage range: 6 to 240V • High dielectric strength and impulse withstand voltages • Sensitive coil 170mW • Reverse Polarity protected • 400V AC maximum switching voltage • 1500VA maximum switching power • RoHS compliant Sensors Power Supplies Automation Software 16-position right-side terminal block for FC4A-D20RS1 and FC5A-D16RS1 CPU FC4A-PMT11 Part Numbers Coil Voltage Communication 13-position left-side terminal block for FC5A-D16RK1/-D16RS1 CPU FC4A-PMTK16 FC4A-PMT10 DC AC/DC Barriers Description 13-position left-side terminal block for FC4A-D20RK1/-D20RS1 CPU Accessories Part Number 6V RV8H-L-D6 9V RV8H-L-D9 12V RV8H-L-D12 18V RV8H-L-D18 24V RV8H-L-D24 12V RV8H-L-AD12 18V RV8H-L-AD18 24V RV8H-L-AD24 48V RV8H-L-AD48 60V RV8H-L-AD60 110V - 125V RV8H-L-AD110 220V - 240V RV8H-L-AD220 Item Color Part Number Black SV9Z-J20B Gray SV9Z-J20W Blue SV9Z-J20S Spacer (circuit separator) 2 - SV9Z-SAW Marking plate (10 pcs) - SV9Z-PW10 Jumper (20 combs) 1 1. Jumper combs come with 20 points, if shorter lengths are needed simply cut off the excess points. 2. Width of spacer: 2mm Note: When using a cut jumper, please use a spacer on the cut side. For additional information see instruction sheet. Standard stock models in bold. 80 (when using combination of RV1H relay and SV1H socket) www.IDEC.com Programmable Logic Controllers MicroSmart Family OI Touchscreens Starter Kits and Solution Packages MicroSmart Starter Kits Part Numbers Controller Power Supply MM-SMART-10 10 I/O FC4A-C10R2 CPU – MM-SMART-16 16 I/O FC4A-C16R2 CPU – MM-SMART-20 20 I/O FC4A-D20RK1 CPU 15W MM-SMART-24 24 I/O FC4A-C24R2 CPU – MM-SMART-40 40 I/O FC4A-D40K3 Slim CPU 15W MM-PENTRA-16 16 I/Os FC5A-D16RS1 CPU 30W MM-PENTRA-24 24 I/Os FC5A-C24R2 CPU – MM-PENTRA-12 12 I/Os FC5A-D12S1E Embedded Ethernet 30W Software (Prog. Cables Included) Automation Organizer Software Suite PLCs MicroSmart Pentra MicroSmart Item MicroSmart Solution Packages Automation Software KIT-PENTRA-12-HG3G-AHP shown KIT-PENTRA-24-HG1F 4.6" HG1F Mono 24 I/O FC5A-C24R2C CPU 60W KIT-PENTRA-12-HG1F 4.6" HG1F Mono 12 I/O FC5A-D12S1E Embedded Ethernet CPU 60W KIT-PENTRA-24-HG2G-M 5.7" HG2G Color TFT LCD 24 I/O FC5A-C24R2C CPU 60W KIT-PENTRA-12-HG2G-M 5.7" HG2G Color TFT LCD 12 I/O FC5A-D12S1E Embedded Ethernet CPU 60W KIT-PENTRA-24-HG2G-TE 5.7" HG2G Color TFT LCD 24 I/O FC5A-C24R2C CPU 60W KIT-PENTRA-12-HG2G-TE 5.7" HG2G Color TFT LCD 12 I/O FC5A-D12S1E Embedded Ethernet CPU 60W KIT-PENTRA-24-HG2G-HP 5.7" HG2G Color TFT LCD 24 I/O FC5A-C24R2C CPU 60W KIT-PENTRA-16-HG2G-HP 5.7" HG2G Color TFT LCD 16 I/O FC5A-D16RS1 CPU 60W KIT-PENTRA-12-HG2G-HP 5.7" HG2G Color TFT LCD 12 I/O FC5A-D12S1E Embedded Ethernet CPU 60W KIT-PENTRA-16-HG3G-8HP 8.4" HG3G Color TFT LCD 16 I/O FC5A-D16RS1 CPU 60W KIT-PENTRA-12-HG3G-8HP 8.4" HG3G Color TFT LCD 12 I/O FC5A-D12S1E Embedded Ethernet CPU 60W KIT-PENTRA-16-HG3G-AHP 10.4" HG3G Color TFT LCD 16 I/O FC5A-D16RS1 CPU 60W KIT-PENTRA-12-HG3G-AHP 10.4" HG3G Color TFT LCD 12 I/O FC5A-D12S1E Embedded Ethernet CPU 60W KIT-PENTRA-16-HG4G-HP 12.1" HG4G Color TFT LCD 16 I/O FC5A-D16RS1 CPU 60W KIT-PENTRA-12-HG4G-HP 12.1" HG4G Color TFT LCD 12 I/O FC5A-D12S1E Embedded Ethernet CPU 60W Software (Prog. Cables Included) Automation Organizer Software Suite Barriers Power Supply Communication Controller Sensors Operator Interface Power Supplies Part Numbers OI Touchscreens have black bezels. All packages come with Automation Organizer software suite and communication cables. 800-262-IDEC (4332) • USA & Canada 81 MicroSmart Family Programmable Logic Controllers OI Touchscreens Automation Organizer Suite Sensors Power Supplies Automation Software PLCs Programming Software Automation Organizer (AO) is a powerful software suite containing PLC programming software (WindLDR), OI touchscreen configuration software (WindO/I-NV2) and system configuration software (WindCFG). AO boasts a completely new graphic user interface and redesigned menu icons. AO is a one-stop automation software package for IDEC MicroSmart Pentra PLCs and IDEC OI touchscreens, and is compatible with Windows XP, Vista (32 bit) and Windows 7 (32 and 64-bit). All IDEC MicroSmart Pentra PLCs are programmable with WindLDR ladder logic software. This icon-driven programming tool combines logic and intuition with an incredibly easy-to-use interface to allow you to take advantage of MicroSmart features. Even without ladder program experience, you can use the built-in editors, shortcuts and debuggers to configure programs. WindLDR is an excellent, long-term investment for your control solutions. Communication Simulation Mode WindLDR allows you to simulate ladder programs with built-in Simulation mode. You can easily test and verify functionality of your ladder program without actual hardware. Online Editing Shutting down your PLC for minor changes can be a major hassle, so WindLDR allows you to edit and download programs without interrupting PLC operation. You can write new values to counters, timers and registers at any time without switching between editor mode (for programming) and monitor mode. Barriers WindO/I-NV2 software is the programming tool available for all IDEC OI touchscreens. It is used to create projects or programs that can display information from a PLC, process status, or can be used to input data with virtual switches or keypads to make changes to a process. The objects are extremely easy to configure with the help of step- by-step navigation. It lets you quickly create colorful graphical screens in no time using drop-down menus and intuitive drag and drop functionality for the objects. A workspace is available to help you organize and manage projects, objects and screens. Firmware Download With WindLDR version 6.4 or later, you have the option to upgrade or downgrade your CPU system program. It’s as simple as clicking on the checkbox in the Download dialog box. Now you can easily update your PLC system firmware with the click of a button. 82 WindCFG is a system layout and configuration tool for IDEC PLCs and OI touchscreens. Using WindCFG, you can create a visual layout of the system design and basic configuration of your PLC and OI touchscreens. FREE Upgrades The Automation Organizer suite comes with free lifetime upgrades. Once you make the initial purchase, upgrades are absolutely free. Part Number Part Number Description SW1A-W1C Automation Organizer software suite www.IDEC.com For more information, see page 121. Programmable Logic Controllers MicroSmart Family OI Touchscreens Specifications Slim Type Model FC5A-D12K1E FC5A-D12S1E FC5A-D16RK1 FC5A-D16RS1 FC5A-D32K3 FC5A-D32S3 FC4A-D20K3 FC4A-D20S3 Rated Power Voltage FC4A-D40K3 FC4A-D40S3 24V DC Allowable Voltage Range 20.4 to 26.4V DC (including ripple) Maximum Input Current 560 mA (26.4V DC)1 700 mA (26.4V DC)1 Maximum Power Consumption 19W (26.4V DC)1 700 mA (26.4V DC)1 14W (26.4V DC)1 Allowable Momentary Power Interruption 17W (26.4V DC)1 10 ms (at 24V DC) PLCs Between power and terminals: 500V AC, 1 minute Between I/O and terminals: 500V AC, 1 minute Dielectric Strength Between power and terminals: 10 MΩ minimum (500V DC megger) Between I/O and terminals: 10 MΩ minimum (500V DC megger) Insulation Resistance DC power terminals: 1.0 kV, 50 ns to 1 µs I/O terminals (coupling clamp): 1.5 kV, 50 ns to 1 µs Noise Resistance 50A maximum (24V DC) Power Supply Wire Automation Software Inrush Current UL1015, AWG22, UL1007 AWG18 Operating Temperature 0 to 55°C Storage Temperature –25 to +70°C (no freezing) Relative Humidity Level RH1 (IEC61131-2), 10 to 95% (no condensation) Altitude Operation: 0 to 2,000m, Transport: 0 to 3,000m Pollution Degree 2 (IEC60664-1) Corrosion Immunity Free from corrosive gases IP20 (IEC60529) Grounding Wire Power Supplies Degree of Protection UL1015, AWG22, UL1007, AWG18 When mounted on a DIN rail or panel surface: 5 to 8.4 Hz amplitude 3.5 mm, 8.4 to 150 Hz acceleration 9.8 m/s2 (1G), 2 hours per axis on each of three mutually perpendicular axes (IEC61131-2) Vibration Resistance Shock Resistance Weight FC4A-D20RK1 FC4A-D20RS1 147 m/s2 (15G), 11 ms duration, 3 shocks per axis on three mutually perpendicular axes (IEC61131-2) 200g 230g 190g 140g 185g 180g 1. CPU module + 7 I/O modules Sensors Communication Barriers 800-262-IDEC (4332) • USA & Canada 83 Programmable Logic Controllers MicroSmart Family OI Touchscreens All-in-One Type FC5A-C10R2 FC5A-C10R2C FC5A-C10R2D Model FC5A-C16R2 FC5A-C16R2C FC5A-C16R2D Rated Power Voltage Allowable Voltage Range FC5A-C24R2 FC5A-C24R2C FC5A-C24R2D PLCs Maximum Power Consumption AC power type: 50/60 Hz (47 to 63 Hz) 250 mA (85V AC) 160 mA (24V DC) 300 mA (85V AC) 190 mA (24V DC) 450 mA (85V AC)1 360 mA (24V DC)2 DC Power FC5A-C10R2C/FC4A-C10R2C: 3.9W (24V DC) *5 FC5A-C10R2D: 2.8W (12V DC)4 FC5A-C16R2C/FC4A-C16R2C: 4.6W (24V DC) *5 FC5A-C16R2D: 3.4W (12V DC)4 FC5A-C24R2C/FC4A-C24R2C: 8.7W (24V DC) *3 FC5A-C24R2D: 4.2W (12V DC)4 Automation Software Power Supplies 300 mA (85V AC) 190 mA (24V DC) 450 mA (85V AC)1 360 mA (24V DC)2 10 ms (rated power voltage) Between power and or terminals: 1,500V AC, 1 minute Between I/O and or terminals: 1,500V AC, 1 minute Dielectric Strength Between power and or terminals: 10 MΩ minimum (500V DC megger) Between I/O and or terminals: 10 MΩ minimum (500V DC megger) Insulation Resistance AC power terminals: 1.5 kV, 50 ns to 1 µs DC power terminals: 1.0 kV, 50 ns to 1 µs I/O terminals (coupling clamp): 1.5 kV, 50 ns to 1 µs Noise Resistance FC5A-C10R2/FC5A-C10R2C/FC5A-C16R2/ FC5A-C16R2C: 35A FC5A-C10R2D/FC5A-C16R2D: 20A Power Supply Wire FC5A-C24R2/ FC5A-C24R2C: 40A FC5A-C24R2D: 20A 35A 40A UL1015 AWG22, UL1007 AWG18 Operating Temperature 0 to 55°C Storage Temperature –25 to +70°C (no freezing) Relative Humidity Level RH1 (IEC61131-2), 10 to 95% (no condensation) Altitude Operation: 0 to 2,000m, Transport: 0 to 3,000m Pollution Degree 2 (IEC60664-1) Corrosion Immunity Free from corrosive gases Degree of Protection Sensors 250 mA (85V AC) 160 mA (24V DC) FC5A-C10R2/FC4A-C10R2: 30VA (264V AC), 20VA (100V AC)3 FC5A-C16R2/FC4A-C16R2: 31VA (264 V AC), 22VA (100V AC )3 FC5A-C24R2/FC4A-C24R2: 40VA (264V AC), 33VA (100V AC)1 Allowable Momentary Power Interruption IP20 (IEC60529) Ground Ground resistance 100Ω (max.) Grounding Wire UL1007, AWG16 When mounted on a DIN rail or panel surface: 5 to 8.4 Hz amplitude 3.5 mm, 8.4 to 150 Hz acceleration 9.8 m/s2 (1G), 2 hours per axis on each of three mutually perpendicular axes (IEC61131-2) Vibration Resistance Shock Resistance 147 m/s2 (15G), 11 ms duration, 3 shocks per axis on three mutually perpendicular axes (IEC61131-2) AC type: 230g DC type: 240g Weight 1. 2. 3. 4. AC type: 250g DC type: 260g AC type: 305g DC type: 310g AC type: 230g DC type: 240g CPU module (including 250 mA sensor power) + 4 I/O modules CPU module + 4 I/O modules CPU module (including 250 mA sensor power) CPU module Barriers Communication FC4A-C24R2 FC4A-C24R2C AC power type: 85 to 264V AC, 24V DC power type: 20.4 to 28.8V DC (including ripple), 12V DC type: 10.2 to 18.0V DC AC Power Inrush Current FC4A-C16R2 FC4A-C16R2C AC power type: 100 to 240V AC, DC power type: 24V DC, 12V DC Rated Power Frequency Maximum Input Current FC4A-C10R2 FC4A-C10R2C 84 www.IDEC.com AC type: 250g DC type: 260g AC type: 305g DC type: 310g Programmable Logic Controllers MicroSmart Family Slim Type Function Specifications FC5A-D16RK1 FC5A-D16RS1 FC5A-D32K3 FC5A-D32S3 Control System 152 advanced Program Capacity 1 User Program Storage Flash ROM (10,000 times rewritable) 35 basic 126 advanced 130 advanced 62.4 KB (10,400 steps) 53 advanced 72 advanced 27 KB (4,500 steps) 31.2 KB (5,200 steps) 2 EEPROM (10,000 times rewritable) 83 µs (1,000 steps) 1.65 ms (1,000 steps) END Processing 3 0.35 ms 0.64 ms 7 modules + additional 8 modules using the expansion interface module 7 modules Input 8 Output 4 Expansion: 224 Additional: 256 8 Expansion: 224 Additional: 256 16 16 Expansion: 224 Additional: 256 12 8 Expansion: 128 12 8 2,048 points Shift Register 42,000 points Expansion Data Register 6,000 points — 6,000 points 100 points Timer (1-sec, 100-ms, 10-ms, 1-ms) 256 points 100 points Internal relay, shift register, counter, data register, expansion data register Approx. 30 days (typical) at 25°C after backup battery fully charged Battery Power Supplies RAM Backup Backup Duration Lithium secondary battery Charging Time Approx. 15 hours for charging from 0% to 90% of full charge Battery Life 5 years in cycles of 9-hour charging and 15-hour discharging Replaceability Self-diagnostic Function Not possible to replace battery Power failure, watchdog timer, data link connection, user program ROM sum check, timer/counter preset value sum check, user program RAM sum check, keep data, user program syntax, user program writing, CPU module, clock IC, I/O bus initialize, user program execution Input Filter Without filter, 3 to 15 ms (selectable in increments of 1 ms) Maximum Counting Frequency and High-speed Counter Points Four inputs (I2 and I5) (I3 and I4) Minimum turn on pulse width: 40 µs maximum Minimum turn off pulse width: 150 µs maximum Minimum turn on pulse width: 5 µs maximum Minimum turn off pulse width: 5 µs maximum Total 4 points Single/two-phase selectable: 100 kHz (2 points) Single-phase: 100 kHz (2 points) Counting Range Total 4 points Single/two-phase selectable: 20 kHz (2 points) Single-phase: 5 kHz (2 points) 0 to 4,294,967,295 (32 bits) Operation Mode 0 to 65,535 (16 bits) Rotary encoder mode and adding counter mode Quantity 1 point Data Range 0 to 255 Quantity 1 point Input Voltage Range 0 to 10V DC Input Impedance Approx. 100 kΩ Data Range 0 to 255 (8 bits) Quantity Maximum Frequency Communication Analog Potentiometer Four inputs (I2 through I5) Minimum turn on pulse width: 40 µs maximum Minimum turn off pulse width: 150 µs maximum Sensors Catch Input/Interrupt Input High-speed Counter Expansion: 224 1,300 points 256 points Pulse Output 16 128 points 42,000 points 4 Counter Backup Data 24 1,024 points 256 points Data Register Expansion: 224 Automation Software Internal Relay 8 PLCs Basic Instruction Expandable I/O Modules Analog Voltage Input FC4A-D40K3 FC4A-D40S3 Stored program system 127.8 KB (21,300 steps) I/O Points FC4A-D20RK1 FC4A-D20RS1 42 basic Instruction Words Processing Time FC4A-D20K3 FC4A-D20S3 OI Touchscreens FC5A-D12K1E FC5A-D12S1E Model 3 points 2 points 3 points 100 kHz 2 points 20 kHz Barriers Note: The maximum number of relay outputs that can be turned on simultaneously is 54 including those on the CPU module. Modem communication not possible on FC5A-D12K1E/D12S1E modules. 1. 1 step equals 6 bytes. 2. Expandable up to 62.4 KB when a memory cartridge is used. 3. Not including expansion I/O service time, clock function processing time, data link processing time, and interrupt processing time. 4. Extra data registers D10000 through D49999 are enabled using WindLDR Function Area Settings, then run-time program download cannot be used. 5. Maintenance communication (change monitor device values, upload/download user programs, download system program) 6. Maintenance communication, user communication, modem communication, data link, Modbus ASCII/RTU master/slave communication (FC5A only). 800-262-IDEC (4332) • USA & Canada 85 Programmable Logic Controllers MicroSmart Family OI Touchscreens Slim Type Function Specifications (con’t) Automation Software PLCs Ethernet Port FC5A-D16RK1 FC5A-D16RS1 Ethernet Specifications Electrical Characteristics: Complies with IEEE802.3 Transmission Speed: 10BASE-T/100BASE-TX Ethernet Interface RJ45 User Web Page Area 1 MB Compliant Browser Internet Explorer 7 and 8, Firefox 3 Protocol Data Link Layer: IP, ARP Network Layer: UDP, TCP, ICMP Application Layer: SMTP, DHCP, HTTP, NBNS, DNS, SNTP Function (see table next page) Web server, Send email, PING, Maintenance commnunication server, Modbus TCP server/ client, User communication server/client, SNTP USB mini-B (CDC class) Maintenance Communication5 Port 1 FC5A-D32K3 FC5A-D32S3 FC4A-D20K3 FC4A-D20S3 FC4A-D20RK1 FC4A-D20RS1 FC4A-D40K3 FC4A-D40S3 — RS232C – maintenance communication, user communications, Modbus slave ASCII/RTU communication (FC5A only) Port 2 Communication Adapter/ Module (option)6 Possible Clock Cartridge (option) Possible Memory Cartridge (option) Possible HMI Module (option) Possible Note: The maximum number of relay outputs that can be turned on simultaneously is 54 including those on the CPU module. Modem communication not possible on FC5A-D12K1E/D12S1E modules. 1. 1 step equals 6 bytes. 2. Expandable up to 62.4 KB when a memory cartridge is used. 3. Not including expansion I/O service time, clock function processing time, data link processing time, and interrupt processing time. 4. Extra data registers D10000 through D49999 are enabled using WindLDR Function Area Settings, then run-time program download cannot be used. 5. Maintenance communication (change monitor device values, upload/download user programs, download system program) 6. Maintenance communication, user communication, modem communication, data link, Modbus ASCII/RTU master/slave communication (FC5A only). Barriers Communication Sensors Power Supplies FC5A-D12K1E FC5A-D12S1E Model 86 www.IDEC.com Programmable Logic Controllers MicroSmart Family All-in-One Type Function Specifications FC5A-C10R2 FC5A-C10R2C FC5A-C10R2D FC5A-C16R2 FC5A-C16R2C FC5A-C16R2D FC5A-C24R2 FC5A-C24R2C FC5A-C24R2D Control System Instruction Words RAM Backup Catch Input/Interrupt Input High-speed Counter 115 advanced 38 advanced 54 KB (9,000 steps) 4.8 KB (800 steps) EEPROM (10,000 times rewritable) 35 basic 40 advanced 15 KB (2,500 steps) 48 advanced 27 KB (4,500 steps) 1.16 ms (1,000 steps) 1.65 ms (1,000 steps) 0.64 ms 0.64 ms — 4 modules — 4 modules 6 9 14 9 14 Expansion: 6 Expansion: 64 64 3 4 7 10 4 7 10 2,048 points 256 points 1,024 points 128 points 64 points 128 points 2,000 points 400 points 1,300 points — — 256 points 32 points 100 points 256 points 32 points 100 points Internal relay, shift register, counter, data register Approx. 30 days (typical) at 25°C after backup battery fully charged Lithium secondary battery Approx. 15 hours for charging from 0% to 90% of full charge 5 years in cycles of 9-hours charging and 15-hours discharging Not possible to replace battery Power failure, watchdog timer, data link connection, user program EPPROM sum check, timer/counter preset value sum check, user program RAM sum check, keep data, user program syntax, user program writing, CPU module, clock IC, I/O bus initialize, user program execution Without filter, 3 to 15 ms (selectable in increments of 1 ms) Four inputs (I2 through I5) Minimum turn on pulse width: 40 µs maximum Minimum turn off pulse width: 150 µs maximum Total 4 points Total 4 points 50 kHz (1 point) 20 kHz (1 point) Single/two-phase selectable: Single/two-phase selectable: Single-phase: 5 kHz (3 points) Single-phase: 5 kHz (3 points) 0 to 65,535 (16 bits) Rotary encoder mode and adding counter mode 1 point 2 points 1 point 2 points 0 to 255 Sensors — — Communication Maximum Counting Frequency and High-speed Counter Points Counting Range Operation Mode Quantity Analog Potentiometer Data Range Quantity Analog Input Voltage Range Voltage Input Impedance Input Data Range Quantity Pulse Output Max. Frequency Output Voltage/Current Sensor Power Supply Overload (AC Power Type Detection Only) Isolation Port 1 Port 2 Communication Adapter (option) 4 Clock Cartridge (option) Memory Cartridge (option) HMI Module (option) Stored program system 42 basic 103 advanced 103 advanced 13.8 KB (2,300 steps) 27 KB (4,500 steps) Power Supplies Input Filter FC4A-C24R2 FC4A-C24R2C Automation Software Self-diagnostic Function FC4A-C16R2 FC4A-C16R2C PLCs Program Capacity 1 User Program Storage Basic Instruction Processing Time END Processing 2 Expandable I/O Module Input I/O Points Output Internal Relay Shift Register Data Register Expansion Data Register Counter Timer (1-sec, 100-ms, 10-ms, 1-ms) Backup Data Backup Duration Battery Charging Time Battery Life Replaceability FC4A-C10R2 FC4A-C10R2C OI Touchscreens Model 24V DC (+10% to –15%), 250 mA Not available Isolated from the internal circuit RS232C – maintenance communication, user communications, Modbus ASCII/RTU slave communication (FC5A only) Possible Possible Possible — Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible Possible 800-262-IDEC (4332) • USA & Canada Barriers 1. 1 step equals 6 bytes. 2. Not including expansion I/O service time, clock function processing time, data link processing time, and interrupt processing time. 3. Expansion modules cannot be connected to FC5A-C24R2D. 4. Maintenance communication, user communication, Modem communication, data link, Modbus ASCII/RTU master/slave communication (FC5A only). Note: The maximum number of relay outputs that can be turned on simulatneously is 33 including those on the CPU module. 87 Programmable Logic Controllers MicroSmart Family OI Touchscreens Communication Port (Port 1) Specifications CPU Module FC5A-D12K1E/D12S1E Slim CPU Standards USB 2.0 EIA RS232C All-in-One CPU Maximum Baud Rate USB 2.0 FC5A: 57,600 bps (maintenance communication) FC4A: 19,200 bps (maintenance communication) Cable HG9Z-XCM2A FC2A-KC4C, FC2A-KP1C, FC4A-KC1C, FC4A-KC2C Isolation between Internal Circuit and Communication Port Not isolated Not isolated Sensors Power Supplies Automation Software PLCs Slim Type Input Specifications Model FC5A-D12K1E FC5A-D12S1E FC4A-D20K3 FC4A-D20S3 FC5A-D16RK1 FC5A-D16RS1 FC4A-D20RK1 FC4A-D20RS1 FC5A-D32K3 FC5A-D32S3 FC4A-D40K3 FC4A-D40S3 Input Points 8 (8/1 common) 12 (12/1 common) 8 (8/1 common) 12 (12/1 common) 16 (8/1 common) 24 (12/1 common) Rated Input Voltage 24V DC sink/source input signal Input Voltage Range 20.4 to 26.4V DC Rated Input Current FC5A FC4A I0, I1, I3, I4, I6, I7: I2, I5, I10 to I17: I0, I1, I6, I7: I2 to I5, I10 to I27: 4.5 mA/point (24V DC) 7 mA/point (24V DC) 5 mA/point (24V DC) 7 mA/point (24V DC) Input Impedance FC5A FC4A I0, I1, I3, I4, I6, I7: I2, I5, I10 to I17: I0, I1, I6, I7: I2 to I5, I10 to I27: 4.9 kΩ 3.4 kΩ 5.7 kΩ 3.4 kΩ Turn ON Time FC5A FC4A I0, I1, I3, I4, I6, I7: I2 and I5: I10 to I17: I0, I1, I6, I7: I2 to I5: I10 to I27: 5 µs + filter value 35 µs + filter value 40 µs + filter value 35 µs + filter value 35 µs + filter value 40 µs + filter value Turn OFF Time FC5A FC4A I0, I1, I3, I4, I6, I7: I2 and I5: I10 to I17: I0, I1, I6, I7: I2 to I5: I10 to I27: 5 µs + filter value 150 µs + filter value 150 µs + filter value 45 µs + filter value 150 µs + filter value 150 µs + filter value Connector On Mother Board MC1.5/16-G3.81BK (Phoenix Contact) FL26A2MA (Oki Electric Cable) MC1.5/13-G-3.81BK (Phoenix Contact) Insertion Durability 100 times minimum Isolation Between input terminals: Optocoupler isolated Internal circuit: Not isolated Input Type Type 1 (IEC61131-2) External Load for I/O Interconnection Not needed Single Determination Method Static Effect of Improper Input Connection Both sinking and sourcing input signals can be connected, therefore reverse connection does not cause permanent damage. If any input exceeding the rated value is applied, permanent damage may be caused. Cable Length 3m in compliance with electromagnetic immunity Barriers Communication FL26A2MA (Oki Electric Cable) 88 www.IDEC.com Programmable Logic Controllers MicroSmart Family All-in-One Type Input Specifications Input Points FC5A-C16R2 FC5A-C16R2C FC5A-C24R2 FC5A-C24R2C FC4A-C10R2 FC4A-C10R2C FC4A-C16R2 FC4A-C16R2C FC4A-C24R2 FC4A-C24R2C 6 (6/1 common) 9 (9/1 common) FC5A-C10R2D 14 (14/1 common) FC5A-C16R2D FC5A-C24R2D — — — 6 (6/1 common) 9 (9/1 common) 14 (14/1 common) Rated Input Voltage 24V DC sink/source input signal 12V DC sink/source input signal Input Voltage Range 20.4 to 28.8V DC 10.2 to 18.0V DC I0 and I1: I2 to I7, I10 to I15: I0 and I1: I2 to I7, I10 to I15: 6.4 mA/point 7 mA/point (24V DC) 11 mA 7 mA/point (24V DC) I0 and I1: I2 to I7, I10 to I15: 6 mA 6 mA Input Impedance FC5A FC4A I0 and I1: I2 to I7, I10 to I15: I0 and I1: I2 to I7, I10 to I15: 3.7 kΩ 3.4 kΩ 2.1 kΩ 3.4 kΩ I0 and I1: I2 to I7, I10 to I15: 1.8 kΩ 2.0 kΩ Turn ON Time FC5A FC4A I0 and I1: I2 to I5: I6, I7, I10 to I15: I0 and I1: I2 to I5: I6, I7, I10 to I15: 2 µs + filter value 35 µs + filter value 40 µs + filter value 35 µs + filter value 35 µs + filter value 40 µs + filter value I0 and I1: I2 to I5: I6, I7, I10 to I15: 2 µs + filter value 35 µs + filter value 40 µs + filter value Turn OFF Time FC5A FC4A I0 and I1: I2 to I5: I6, I7, I10 to I15: I0 and I1: I2 to I5: I6, I7, I10 to I15: 16 µs + filter value 150 µs + filter value 150 µs + filter value 45 µs + filter value 150 µs + filter value 150 µs + filter value I0 and I1: I2 to I5: I6, I7, I10 to I15: 16 µs + filter value 150 µs + filter value 150 µs + filter value Input Type Type 1 (IEC61131-2) External Load for I/O Interconnection Single Determination Method Power Supplies Between input terminals: Optocoupler isolated Internal circuit: Not isolated Automation Software Isolation PLCs Rated Input Current FC5A FC4A OI Touchscreens Model FC5A-C10R2 FC5A-C10R2C Not needed Static — Effect of Improper Input Connection Both sinking and sourcing input signals can be connected, therefore reverse connection does not cause permanent damage. If any input exceeding the rated value is applied, permanent damage may be caused. Cable Length 3m in compliance with electromagnetic immunity Sensors Communication Barriers 800-262-IDEC (4332) • USA & Canada 89 Programmable Logic Controllers MicroSmart Family OI Touchscreens Transistor Sink and Source Output Specifications FC5A-D12K1E FC5A-D12S1E Model FC4A-D20RK1 FC4A-D20RS1 — Transistor Output Points Output Type FC5A-D16RK1 FC5A-D16RS1 — 4 (4/1 common) — 2 (2/1 common) Transistor Sink Transistor Source FC5A-D12S1E/D16RS1/D32S3 FC4A-D20S3/D20RS1/D40S3 PLCs Rated Load Voltage 16 (8/1 common) 20.4 to 28.8V DC 0.3A per output point Maximum Load Current 1A per common Voltage Drop (ON Voltage) 1V maximum (voltage between COM and output terminals when output is on) Inrush Current Automation Software FC4A-D40K3 FC4A-D40S3 24V DC Operating Load Voltage Range Rated Load Current Power Supplies 2 (2/1 common) FC5A-D12K1E/D16RK1/D32K3 FC4A-D20K3/D20RK1/D40K3 FC5A-D32K3 FC5A-D32S3 1A Leakage Current 0.1 mA maximum Clamping Voltage 39V±1V Maximum Lamp Load 8W Inductive Load L/R = 10 ms (28.8V DC, 1 Hz) External Current Draw Sink output: 100 mA maximum, 24V DC (power voltage at the +V terminal) Source output: 100 mA maximum, 24V DC (power voltage at the –V terminal) Isolation Between output terminal and Internal circuit: Photocoupler isolated Between output terminals: Not isolated Connector on Mother Board MC1.5/16-G-3.81BK (Phoenix Contact) FL26A2MA (Oki Electric Cable) Connector Insertion/ Removal Durability MC1.5/16-G-3.81BK (Phoenix Contact) 100 times minimum Turn ON Time FC5A FC4A Q0 to Q2: Q3 to Q7, Q10 to Q17: Q0, Q1: Q2 to Q7, Q10 to Q17: 5 µs max. 300 µs max. 5 µs max. 300 µs max. Turn OFF Time FC5A FC4A Q0 to Q2: Q3 to Q7, Q10 to Q17: Q0, Q1: Q2 to Q7, Q10 to Q17: 5 µs max. 300 µs max. 5 µs max. 300 µs max. Barriers Communication Sensors Output Delay 90 www.IDEC.com FL26A2MA (Oki Electric Cable) Programmable Logic Controllers MicroSmart Family Relay Output Specifications FC5A-C16R2 FC5A-C16R2C FC5A-C16R2D FC5A-C24R2 FC5A-C24R2C FC5A-C24R2D FC5A-D16RK1 FC5A-D16RS1 FC4A-C10R2 FC4A-C10R2C FC4A-C16R2 FC4A-C16R2C FC4A-C24R2 FC4A-C24R2C FC4A-D20RK1 FC4A-D20RS1 Relay Output Points Output Points per Common Line 4 7 10 6 — 3 4 4 1 2 4 3 COM2 — 1 1 2 COM3 — — 1 1 Output Type 1NO 2A per point 8A per common line Maximum Load Current Minimum Switching Load 1 mA/ 5V DC (reference value) Initial Contact Resistance 30 mΩ maximum 100,000 operations minimum (rated load 1,800 operations/hour) Mechanical Life 20,000,000 operations minimum (no load 18,000 operations/hour) Automation Software Electrical Life 240V AC/2A (resistive load, inductive load cos ø = 0.4) 30V DC/2A (resistive load, inductive load L/R =7 ms) Rated Load Dielectric Strength PLCs COM0 COM1 OI Touchscreens Model FC5A-C10R2 FC5A-C10R2C FC5A-C10R2D Between output and terminals: Between output terminal and internal circuit: Between output terminals (COMs): 1,500V AC, 1 minute 1,500V AC, 1 minute 1,500V AC, 1 minute — *1 Connector Insertion/ Removal Durability — 100 times minimum Power Supplies Connector on Mother Board 1. MC1.5/16-G-3.81BK (Phoenix Contact) Sensors Communication Barriers 800-262-IDEC (4332) • USA & Canada 91 Programmable Logic Controllers Input Usage Limits Slim CPU FC5A-D32K3/D32S3 FC4A-D40K3/D40S3 FC4A-D20K3/D20S3 Input Voltage (V DC) Input Voltage (V DC) FC5A-D16RK1/D16RS1 FC5A-D12K1E/D12S1E Input Voltage (V DC) 26.4 Ambient Temperature 40ºC 26.4 Ambient Temperature 55ºC 24.0 26.4 Ambient Temperature 40ºC Input Voltage (V DC) 26.4 Ambient Temperature 55ºC 24.0 0 50 100 I/O Simultaneous ON Ratio (%) FC5A-C10R2 FC5A-C10R2C FC4A-C10R2 FC4A-C10R2C 24.0 0 50 100 I/O Simultaneous ON Ratio (%) Input Voltage (V DC) 28.8 FC5A-C16R2 FC5A-C16R2C FC4A-C16R2 FC4A-C16R2C Ambient Temperature 55ºC Input Voltage (V DC) 28.8 26.4 0 50 100 I/O Simultaneous ON Ratio (%) FC5A-C24R2 FC5A-C24R2C FC4A-C24R2 FC4A-C24R2C Ambient Temperature 45ºC Ambient Temperature 55ºC 26.4 0 50 100 I/O Simultaneous ON Ratio (%) Input Voltage (V DC) 28.8 CAUTION: When using at an operating ambient temperature above 40°C, reduce the input voltage or the quantity of I/O points that turn on simultaneously. Ambient Temperature 45ºC Ambient Temperature 55ºC 26.4 0 50 100 I/O Simultaneous ON Ratio (%) 0 50 100 I/O Simultaneous ON Ratio (%) Input Internal Circuit I0, I1 Input FC5A All-in-One CPU 12V DC Type I0, I1 3.3 kΩ (FC5A) 1.8 kΩ (FC4A) Input COM COM I2 to I15 COM I2 to I15 Input 3.3 kΩ COM COM Internal Circuit Input 3.3 kΩ Internal Circuit Sensors Input FC5A: I2, I5, I10 to I17 FC4A: I2 to I5, I10 to I27 Output Internal Circuit Slim CPU Sink Output Internal Circuit +V Output Source Output COM (+) Internal Circuit Output COM (–) –V Barriers 92 www.IDEC.com 1.8 kΩ Internal Circuit All-in-One CPU FC5A: I0, I1, I3, I4, I6, I7 FC4A: I0, I1, I6, I7 4.7 kΩ Input 2.0 kΩ Internal Circuit Slim CPU COM Communication Ambient Temperature 55ºC All-in-One CPU Internal Circuit PLCs Automation Software Ambient Temperature 55ºC 24.0 0 50 100 I/O Simultaneous ON Ratio (%) Power Supplies Ambient Temperature 40ºC FC4A-D20RK1/D20RS1 Internal Circuit OI Touchscreens MicroSmart Family Programmable Logic Controllers Communication Adapter/Module Specifications HMI Module Specifications FC4A-PC2 FC4A-HPC2 FC4A-PC3 FC4A-HPC3 Standards EIA RS232C EIA RS485 EIA RS485 Maximum Baud Rate FC5A: 57,600 bps1 FC4A: 19,200 bps FC5A: 57,600 bps1 FC4A: 19,200 bps FC5A: 57,600 bps1 FC4A: 19,200 bps (38,400 bps2) Maintenance Communication Possible Possible Possible User Communication Possible Possible3 Possible3 — Possible Possible Half-duplex Communication — Possible Possible Maximum Cable Length Isolation between Internal Circuit and Communication Port — 31 RS485 Cable Weight 20g Memory Cartridge Specifications Model FC4A-PM32 FC4A-PM646 Memory Type Accessible Memory Capacity EEPROM 32 KB 64 KB Hardware for Storing Data CPU Module Software for Storing Data WindLDR Quantity of Stored Programs FC4A-PM1286 128 KB One user program can be stored on one memory cartridge 6. Even when using a large-capacity memory cartridge, the program capacity of the CPU module takes effect, except when using FC4A-D20RK1, FC4A-D20RS1, FC4AD40K3, and FC4A-D40S3 CPU modules, the program capacity expands to 64KB. Clock Cartridge Specifications — Twisted-pair shielded cable with a minimum core wire of 0.3 mm2 Model FC4A-PT1 Accuracy ±30 sec/month (typical) at 25°C 85 Ω/km maximum 20 Ω/km maximum Backup Duration Approx. 30 days (typical) at 25°C after backup battery fully charged Battery Lithium secondary battery Charging Time Approx. 10 hours for charging from 0% to 90% of full charge Replaceability Not possible to replace battery Power Supplies Shield Resistance 31 Not isolated Cable Conductor Resistance 200m 5V DC (supplied from the CPU module) Automation Software Quantity of Slave Stations Special cable Special cable 5 FC4A-PH1 Power Voltage PLCs Data Link Communication Model OI Touchscreens Model FC4A-PC1 FC4A-HPC1 4 MicroSmart Family 1. Maximum speed is 115,200 bps for FC5A-D12*1E. 2. Maximum speed when data link is used. 3. FC5A (all types), FC4A-D20RK1, FC4A-D20RS1, FC4A-D40K3, FC4A-D40S3 4. FC2A-KC4C, FC2A-KM1C, FC4A-KC1C, FC4A-KC2C, FC2A-KP1C 5. FC2A-KP1C Sensors Communication Barriers 800-262-IDEC (4332) • USA & Canada 93 Programmable Logic Controllers Power Supplies Automation Software PLCs OI Touchscreens MicroSmart Family Expansion Serial Communication Module General Specifications (Expansion RS232C Communication Module) (Expansion RS485 Communication Module) Model FC5A-SIF2 Model FC5A-SIF4 No. of Port 1 No. of Port 1 Synchronization Synchronization Start-stop synchronization Synchronization Synchronization Start-stop synchronization Electrical Characteristics Electrical Characteristics EIA RS232C compliant Electrical Characteristics Electrical Characteristics EIA RS485 compliant Maximum Delay in One Scan Approx. 4 ms Maximum Baud Rate 115,200 bps Operating Temperature 0 to 55°C Operating Temperature 0 to 55°C Relative Humidity 10 to 95% (no condensation) Relative Humidity 10 to 95% (no condensation) Recommended Cable Specifications Shielded multi-core cable: 24AWG x 6 Dielectric strength: 2,000V AC/min Insulation resistance: 100 MΩ/km Recommended Cable Specifications Recommended Cable KIDU-SB 24 AWG×6C (Nihon Electric Wire & Cable) Shielded twisted pair cable: 22 AWG (0.3 mm2 x 2P) Conductor Resistance: 67 MΩ/km maximum (at 20°C) Connector on Mother Board MC1.5/10-G-3.81BK (Phoenix Contact) Applicable terminal block: FC4A-PMT10P Connector on Mother Board MC1.5/10-G-3.81BK (Phoenix Contact) Applicable terminal block: FC4A-PMT10P Connector Insertion/Removal Durability 100 times minimum 100 times minimum Connector Insertion/ Removal Durability Isolation from Internal Circuit Transformer isolated Isolation from Internal Circuit Transformer isolated Quantity of Applicable Expansion RS232C Communication Modules All-in-One 24-I/O type CPU module: 3 maximum 1 Slim type CPU module: 5 maximum Quantity of Applicable Expansion RS485C Communication Modules All-in-One 24-I/O type CPU module: 3 maximum 1 Slim type CPU module: 5 maximum Internal Current Draw 40 mA (5V/24V DC) 5 Weight 100g Note: FC5A-SIF2 cannot be connected to FC4A CPU modules. 1. FC5A All-in-One 24-I/O CPU module cannot use the FC5A-SIF2/SIF4 module in combination with the function modules listed in the table on the left. When using these modules in combination with the FC5A-SIF2/SIF4 module, use the slim type CPU module. Function Modules Type No. Analog Modules FC4A-L03A1, FC4A-L03AP1, FC4A-J2A1, FC4A-K1A1, FC4A-J4CN1, FC4A-J8C1, FC4A-J8AT1, FC4A-K2C1, FC4A-K4A1 AS-Interface Master Module FC4A-AS62M Sensors 5. 85 mA (5V DC), 0 mA (24V DC) when the communication module version is lower than V200. Internal Current Draw 40 mA (5V/24V DC) Weight 100g Note: FC5A-SIF4 cannot be connected to FC4A CPU modules. Communication Specifications Model Maximum Baud Rate FC5A-SIF2 FC5A-SIF4 1,200/2,400/4,800/9,600/19,200/38,400/57,6004/115,200 4 Maintenance Communication Possible2 Modbus Communication Modbus ASCII master Modbus ASCII slave Modbus RTU master Modbus RTU slave Data Link Max Cable Length Quantity of Slave Stations - 03 10m 1,200m 1 31 Barriers Communication 2. Run-time program download is not possible. 3. Data Link can be used only on one of the communication ports. 4. Can be used when the communication module is version V200 or higher. 94 www.IDEC.com Programmable Logic Controllers FC4A-N08B1 Input Points FC4A-N16B1 8 (8/1 common) FC4A-N32B3 16 (16/1 common) Rated Input Voltage FC4A-N08A11 32 (16/1 common) 8 (4/1 common) 24V DC sink/source input signal Input Voltage Range Rated Input Current FC4A-N16B3 100 to 120V AC (50/60 Hz) 20.4 to 28.8V DC 85 to 132V AC 7 mA/point (24V DC) 5 mA/point (24V DC) 17 mA/point (120V AC, 60 Hz) 3.4 kΩ 4.4 kΩ 0.8 kΩ (60 Hz) Input Impedance 15V minimum 79V minimum OFF Voltage 5V maximum 20V maximum ON Current 4.2 mA minimum (at 15V DC) 3.2 mA minimum (at 15V DC) — OFF Current 1.2 mA maximum 0.9 mA maximum — 4 ms 25 ms Turn OFF Time 4 ms 30 ms Between input terminals: Not isolated Internal circuit: Photocoupler isolated Between input terminals in the same common: Not isolated Between input terminals in different commons: Isolated Between input terminals and internal circuits: Photocoupler isolated External Load for I/O Interconnection Not needed Not needed Single Determination Method Static Static Both sink and source input signals can be connected. If any input exceeding the rated value is applied, permanent damage may be caused. If any input exceeding the rated value is applied, permanent damage may be caused. 3m in compliance with electromagnetic immunity — Effect of Improper Input Connection Cable Length MC1.5/10-G-3.81BK (Phoenix Contact) FL20A2MA (Oki Electric Cable) Connector Insertion/ Removal Durability Applicable Ferrule Internal Current Draw 100 times minimum 1-wire: AI 0.5-8 WH (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-8 WH (Phoenix Contact) — — 25 mA (5V DC) 40 mA (5V DC) 35 mA (5V DC) 65 mA (5V DC) 60 mA (5V DC), 0 mA (24V DC) All Inputs OFF 5 mA (5V DC) 5 mA (5V DC) 5 mA (5V DC) 10 mA (5V DC) 30 mA (5V DC), 0 mA (24V DC) 0.17W 0.27W 0.24W 0.44W — 85g 100g 65g 100g 80g Sensors All Inputs ON Internal Power Consumption (at 24V DC while all inputs ON) Weight MC1.5/11-G-3.81BK (Phoenix Contact) Power Supplies Connector on Mother Board Automation Software Turn ON Time PLCs ON Voltage Isolation OI Touchscreens Specifications (I/O Modules) Input Module Specifications Model MicroSmart Family Communication Barriers 800-262-IDEC (4332) • USA & Canada 95 Programmable Logic Controllers MicroSmart Family OI Touchscreens Transistor Output Module Specifications Model FC4A-T16K3 FC4A-T16S3 Output Points 8 (8/1 common) 16 (16/1 common) 32 (16/1 common) Output Type PLCs Operating Load Voltage Range Maximum Load Current Automation Software Initial Contact Resistance 3A per common 1A per common Inrush Current 1A maximum 8W Inductive Load MC1.5/10-G-3.81BK (Phoenix Contact) Connector Insertion/ Removal Durability Applicable Ferrule Internal Current Draw Output Delay — 20 mA (5V DC) 70 mA (24V DC) All outputs OFF 5 mA (5V DC) 0 mA (24V DC) 5 mA (5V DC) 0 mA (24V DC) 10 mA (5V DC) 0 mA (24V DC) 1.03W Turn ON Time 300 µs maximum Turn OFF Time 300 µs maximum 70g 96 Between output and or terminals: 1,500V AC, 1 minute Between output terminal and internal circuit: 1,500V AC, 1 minute Between output terminals (COMs): 1,500V AC, 1 minute MC1.5/11-G-3.81BK (Phoenix Contact) MC1.5/10-G-3.81BK (Phoenix Contact) 100 times minimum 1-wire: AI 0.5-8 WH (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-8 WH (Phoenix Contact) 30 mA (5V DC) 40 mA (24V DC) 45 mA (5V DC) 75 mA (24V DC) All outputs OFF 5 mA (5V DC) 0 mA (24V DC) 5 mA (5V DC) 0 mA (24V DC) 1.16W 2.10W 110g 145g 1.82W 105g Barriers 85g 240V AC/2A (resistive load, inductive load cos ø = 0.4) 30V DC/2A (resistive load, inductive load L/R = 7 ms) All outputs ON Weight 10 mA (5V DC) 40 mA (24V DC) 0.55W Internal Current Draw Internal Power Consumption (at 24V DC while all outputs ON) 10 mA (5V DC) 20 mA (24V DC) Weight Rated Load Applicable Ferrule All outputs ON Internal Power Consumption (at 24V DC while all outputs ON) 30 mΩ maximum Connector Insertion/ Removal Durability 100 times minimum 8A per common 1 mA/ 5V DC (reference value) 20,000,000 operations minimum (no load 18,000 operations/hour) Connector On Mother Board FL20A2MA (Oki Electric Cable) 1-wire: AI 0.5-8 WH (Phoenix Contact) 2-wire: AI-TWIN 2×0.5-8 WH (Phoenix Contact) 7A per common Mechanical Life L/R = 10 ms (28.8V DC, 1 Hz) Between output terminal and internal circuit: Photocoupler isolated Between output terminals: Not isolated Connector on Mother Board 1NO 2A per point Electrical Life Dielectric Strength FC4A-T0K0: 100 mA maximum, 24V DC (power voltage at the +V terminal) FC4A-T0S0: 100 mA maximum, 24V DC (power voltage at the –V terminal) 16 (8/1 common) 100,000 operations minimum (rated load 1,800 operations/hour) 39V±1V Maximum Lamp Load Power Supplies 20.4 to 28.8V DC 0.1A per point FC4A-R161 8 (4/1 common) Output Type Minimum Switching Load 1V maximum (voltage between COM and output terminals when output is on) Isolation FC4A-R081 Output Points 24V DC Voltage Drop (ON Voltage) External Current Draw Model Maximum Load Current 0.3A per point Clamping Voltage Sensors FC4A-T32K3 FC4A-T32S3 FC4A-T0K0: Transistor sink output FC4A-T0S0: Transistor source output Rated Load Voltage Communication Relay Output Module Specifications FC4A-T08K1 FC4A-T08S1 www.IDEC.com Programmable Logic Controllers MicroSmart Family Mixed I/O Module Specifications FC4A-M08BR1 Input Points FC4A-M24BR2 4 (4/1 common) 16 (16/1 common) Rated Input Voltage 24V DC sink/source input signal Input Voltage Range 20.4 to 28.8V DC Rated Input Current 7 mA/point (24V DC) 3.4 kΩ ON Voltage 15V minimum OFF Voltage 5V maximum ON Current 4.2 mA minimum (at 15V DC) OFF Current 1.2 mA maximum Turn ON Time 4 ms (24V DC) Turn OFF Time 4 ms (24V DC) Between input terminals: Not isolated Internal circuit: Photocoupler isolated Isolation Not needed Signal Determination Method Effect of Improper Input Connection Static Both sinking and sourcing input signals can be connected. If any input exceeding the rated value is applied, permanent damage may be caused. Cable Length 3m in compliance with electromagnetic immunity Output Points 4 (4/1 common) 8 (4/1 common) Output Type 1NO 2A per point 7A per common Maximum Load Current Power Supplies Minimum Switching Load 1 mA/ 5V DC (reference value) Initial Contact Resistance 30 mΩ maximum Electrical Life 100,000 operations minimum (rated load 1,800 operations/hour) Mechanical Life 20,000,000 operations minimum (no load 18,000 operations/hour) 240V AC/2A (resistive load, inductive load cos ø = 0.4) 30V DC/2A (resistive load, inductive load L/R = 7 ms) Rated Load Between output and or terminals: Between output terminal and internal circuit: Between output terminals (COMs): Dielectric Strength 1,500V AC, 1 minute 1,500V AC, 1 minute 1,500V AC, 1 minute MC1.5/11-G-3.81BK (Phoenix Contact) Input: F6018-17P (Fujicon) Output: F6018-11P (Fujicon) Connector Insertion/Removal Durability 100 times minimum Not removable Applicable Ferrule Sensors Connector on Mother Board 1-wire: AI 0.5-8 WH (Phoenix Contact), 2-wire: AI-TWIN 2×0.5-8 WH (Phoenix Contact) 25 mA (5V DC), 20 mA (24V DC) 65 mA (5V DC), 45 mA (24V DC) All I/Os OFF 5 mA (5V DC), 0 mA (24V DC) 10 mA (5V DC), 0 mA (24V DC) 0.65W 1.52W 95g 140g Communication All I/Os ON Internal Power Consumption (at 24V DC while all I/Os are ON) Weight Automation Software External Load for I/O Interconnection Output Specifications PLCs Input Specifications Input Impedance Internal Current Draw OI Touchscreens Model Barriers 800-262-IDEC (4332) • USA & Canada 97 Programmable Logic Controllers PLCs FC4A-N16B3/N32B3 Input Input Voltage Voltage (V(V AC) AC) Ambient Ambient Temperature Temperature Temperature Input Voltage (V(V DC) Ambient Temperature FC4A-N08A11 Input Voltage DC)Ambient 55ºC 55ºC 30ºC 30ºC 28.8 28.8 132 132 Input Voltage Voltage (V (V(V AC) AC) Ambient Ambient Temperature Temperature Ambient Temperature Input Voltage (V(V DC) Input Voltage (V DC) Temperature Input Input Voltage Voltage (V AC) AC) Ambient Ambient Temperature Temperature Input Voltage (V DC) Ambient Temperature Input Voltage DC)Ambient Ambient Temperature Input 26.4 26.4 55ºC 55ºC 30ºC 30ºC 120 120 Ambient Ambient 55ºC 55ºC 30ºC 30ºC 28.8 28.8 132 132 28.8 28.8 132 132 24.0 24.0 Temperature Temperature 102 102 26.4 26.4 120 120 26.4 26.4 Ambient Ambient 120 120 Ambient Ambient 55ºC 55ºC 24.0 24.0 Temperature Temperature 102 102 24.0 24.0 Temperature Temperature 102 102 55ºC 55ºC 55ºC 55ºC Automation Software 100 0 0 5050 100 I/OI/O Simultaneous ONON Ratio (%) Simultaneous Ratio (%) 5050 100 0 50 100 00 0 50 100 100 I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) Voltage (V(V DC) Input Voltage DC) Ambient Temperature Ambient Temperature Temperature Ambient Temperature Input Input Voltage (V(V DC) Input Voltage DC)Ambient FC4A-M08BR1 FC4A-M24BR2 45ºC 45ºC 55ºC 55ºC 28.8 28.8 28.8 28.8 Input Voltage (V(V DC) Input Voltage (V DC) Ambient Temperature Ambient Temperature Ambient Temperature Temperature Input Voltage (V(V DC) Input Voltage (V DC) Input Voltage Voltage (V DC) DC) Ambient Ambient Temperature Temperature Ambient Temperature Input Ambient Temperature Input Voltage (V DC) Input Voltage DC)Ambient 45ºC 45ºC 55ºC 55ºC 26.4 26.4 26.4 26.4 45ºC 45ºC 55ºC 55ºC 28.8 28.8 28.8 28.8 28.8 28.8 28.8 28.8 Ambient Ambient 24.0 24.0 24.0 24.0 26.4 26.4 26.4 26.4 Temperature Temperature 26.4 26.4 26.4 26.4 Ambient Ambient 24.0 24.0 24.0 24.0 Ambient Ambient 55ºC 55ºC 24.0 24.0 24.0 24.0 Temperature Temperature Temperature Temperature 55ºC 55ºC 55ºC 55ºC 100 0 0 5050 100 100 0 0 5050 100 I/OI/O Simultaneous ONON Ratio (%) Simultaneous Ratio (%) 5050 100 0 50 100 100 00 0 50 100 I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/OI/O Simultaneous ONON Ratio (%) Simultaneous Ratio (%) 5050 100 0 50 100 00 0 50 100 100 I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O I/O Simultaneous Simultaneous ON ON Ratio Ratio (%) (%) When using at an operating ambient temperature above 40°C, reduce the input voltage or the quantity of I/O points that turn on simultaneously. Input 3.3 kΩ COM Input 4.3 kΩ COM Internal Circuit Input 3.3 kΩ COM Communication Barriers www.IDEC.com Output FC4A-T08S1, FC4A-T16S3, FC4A-T32S3 COM (+) Internal Circuit Output –V FC4A-N08A11 Input +V COM (–) FC4A-M08BR1, FC4A-M24BR2 COM 98 FC4A-T08K1, FC4A-T16K3, FC4A-T32K3 FC4A-N16B3, FC4A-N32B3 Sensors Power Supplies 100 0 0 5050 100 I/OI/O Simultaneous ONON Ratio (%) Simultaneous Ratio (%) 5050 100 0 50 100 00 0 50 100 100 I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O I/O Simultaneous Simultaneous ON ON Ratio Ratio (%) (%) FC4A-N08B1, FC4A-N16B1 Internal Circuit FC4A-N16B1 Input Voltage (V(V DC) Temperature Voltage (V(V DC) Input Voltage DC) Ambient Ambient Temperature Input Input Voltage DC)Ambient Ambient Temperature Temperature 55ºC 45ºC 55ºC 45ºC 28.8 28.8 28.8 28.8 Input Voltage (V(V DC) Ambient Temperature Input Voltage (V(V DC) Ambient Temperature Input Voltage (V DC) Input Voltage (V DC) Ambient Temperature Ambient Temperature Input Voltage (V DC) Voltage (V DC) Input Voltage DC) Ambient Ambient Temperature Input Input Voltage DC)Ambient Ambient Temperature Temperature Temperature 55ºC 45ºC 55ºC 45ºC 26.4 26.4 26.4 26.4 55ºC 45ºC 55ºC 45ºC 28.8 28.8 28.8 28.8 Ambient Ambient 28.8 28.8 28.8 28.8 24.0 24.0 24.0 24.0 26.4 26.4 26.4 26.4 Temperature Temperature 26.4 26.4 26.4 26.4 Ambient Ambient Ambient Ambient 55ºC 55ºC 24.0 24.0 24.0 24.0 24.0 24.0 24.0 24.0 Temperature Temperature Temperature Temperature 55ºC 55ºC 55ºC 55ºC 0 0 5050 100 100 0 0 5050 100 100 Simultaneous Ratio (%) I/OI/O Simultaneous ONON Ratio (%) I/OI/O Simultaneous Simultaneous ONON Ratio Ratio (%) (%) 5050 100 00 0 50 100 5050 100 0 50 100 100 0 50 100 00 0 50 100 100 I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) I/O Simultaneous ON Ratio (%) Output Internal Circuit Internal Circuit FC4A-N08B1 Input Internal Circuit Internal Circuit Input Usage Limits Internal Circuit OI Touchscreens MicroSmart Family Programmable Logic Controllers MicroSmart Family OI Touchscreens Specifications (Analog I/O Modules) Analog I/O Module Specifications Model FC4A-L03A1 FC4AL03AP1 FC4A-J2A1 FC4A-J4CN1 FC4A-J8C1 FC4A-J8AT1 FC4A-K4A1 FC4A-K1A1 FC4A-K2C1 Input Points 2 2 2 4 8 8 — — — Output Points 1 1 — — — — 4 1 2 55 mA 130 mA 40 mA 85 mA Power Voltage 24V DC Allowable Voltage Range 20.4 to 28.8V DC 45 mA Connector on Mother Board 40 mA 35 mA 55 mA MC1.5/11-G-3.81BK (Phoenix Contact) 50 mA MC1.5/11-G-3.81BK (Phoenix Contact) MC1.5/10-G-3.81BK (Phoenix Contact) Connector Insertion/ Removal Durability PLCs External Current Draw * (24V DC) MC1.5/10-G-3.81BK (Phoenix Contact) 100 times minimum Applicable Ferrule 1-wire: AI 0.5-8 WH (Phoenix Contact), 2-wire: AI-TWIN 2×0.5-8 WH (Phoenix Contact) 50 mA 50 mA 50 mA 50 mA 40 mA 45 mA 65 mA 50 mA 60 mA Internal Power Consumption (at 24V DC while all I/Os are ON) 0.34W 0.34W 0.34W 0.34W 0.27W 0.30W 0.44W 0.34W 0.40W 85g 85g 85g 140g 140g 125g 100g 85g 110g Weight Automation Software Internal Power Consumption (5V DC) * The external current draw is the value when all the analog inputs are used and the analog output value is at 100%. Input Circuit FC4A-J4CN1 1 kΩ Input – (B) + − Input Selection Signal I− 7Ω Internal Circuit 10Ω + CS Internal Circuit 1 kΩ Multiplexer + (B’) Current Source Current Source 1 kΩ NC (A) FC4A-J8AT1 100Ω − 10kΩ A Input Selection Signal B Internal Circuit +V2 +V1 15MΩ FC4A-J8C1 Power Supplies FC4A-L03A1, FC4A-L03AP1 FC4A-J2A1 Sensors –V1 Communication Barriers 800-262-IDEC (4332) • USA & Canada 99 Programmable Logic Controllers MicroSmart Family OI Touchscreens Analog Input Specifications (1) Model FC4A-L03A1, FC4A-J2A1 Input Signal Type Voltage Input 0 to 10V DC Current Input 4 to 20 mA Resistance Thermometer Pt100 3-wire type (–100 to 500°C) Thermocouple (0 to 1,300°C) Type K Type J (0 to 1,200°C) (0 to 400°C) Type T Input Impedance 1 MΩ minimum 10Ω 1 MΩ minimum 1 MΩ minimum PLCs Input Detection Current AD Conversion FC4A-L03AP1 — — 1.0 mA maximum 10 ms maximum 20 ms maximum 10 ms maximum Sampling Repetition Time 20 ms maximum 40 ms maximum 20 ms maximum 80 ms + 1 scan time 60 ms + 1 scan time Total Input System Transfer Time Type of Input 60 ms + 1 scan time Single-ended input Differential input Operating Mode Self-scan Conversion Method ∑ ∆ type ADC Automation Software Maximum Error at 25°C Input Error ±0.006% of full scale /°C Repeatability after Stabilization Time ±0.5% of full scale Non-linearity ±0.2% of full scale Maximum Error ±1% of full scale Power Supplies Digital Resolution 4096 increments (12 bits) Input Value of LSB 2.5 mV Data Type in Application Program Default: Optional: 4 µA Monotonicity Sensors 0.1°C 0.1°C 0.1°C No Twisted pair shielded cable — 2 LSB maximum Between input and power circuit: Isolated Between input and internal circuit: Photocoupler-isolated Effect of Improper Input Connection Maximum Permanent Allowed Overload (No Damage) Type K: Type J: Type T: ±3% maximum when a 500V clamp voltage is applied to the power supply and I/O lines 3 Crosstalk Isolation 0.1°C Detectable 2 Input Filter Recommended Cable for Noise Immunity Type K: 13,000 increments (14 bits) Type J: 12,000 increments (14 bits) Type T: 4,000 increments (14 bits) Yes Maximum Temporary Deviation during Electrical Noise Tests Noise Resistance 6,000 increments (14 bits) 0 to 4,095 –32,768 to 32,767 (selectable for each channel)1 Input Data Out of Range No damage 13V DC 40 mA — Selection of Analog Input Signal Type Using programming software Calibration or Verification to Maintain Rated Accuracy Impossible 1: The data processed in the analog I/O module can be linear-converted to a value between –32,768 and 32,767. The optional range designation, and analog I/O data minimum and maximum values can be selected using data registers allocated to analog I/O modules. 2: When an error is detected, a corresponding error code is stored to a data register allocated to analog I/O operating status. 3: The accuracy of the thermocouple input is not guaranteed when noise is applied. Barriers Communication ±0.2% of full scale plus cold junction compensation error (±4°C maximum) ±0.2% of full scale Temperature Coefficient Data — Sampling Duration Time 100 www.IDEC.com Programmable Logic Controllers MicroSmart Family Analog Input Specifications (2) Input Signal Type Input Range Input Impedance Input Detection Current FC4A-J4CN1, FC4A-J8C1 Voltage Input 0 to 10V DC FC4A-J4CN1 Current Input Thermocouple 4 to 20 mA Type K (0 to 1,300°C) Type J (0 to 1,200°C) Type T (0 to 400°C) Pt100, Pt1000 3-wire type (–100 to 500°C) Ni100, Ni1000 3-wire type (–60 to 180°C) –50 to 150°C 1 MΩ — — 0.1 mA 0.1 mA 30 ms maximum 10 ms maximum 2 ms × channels 85 ms × channels + 1 scan time 50 ms × channels + 1 scan time 10 ms × channels + 1 scan time 7 Ω (FC4A-J4CN1) 1 MΩ FC4A-J8AT1 Resistance Thermometer 100Ω (FC4A-J8C1) — — — Total Input System Transfer Time 2 ms maximum FC4A-J4CN1: 10 ms maximum FC4A-J8C1: 2 ms maximum FC4A-J4CN1: 50 ms × channels + 1 scan time FC4A-J8C1: 8 ms × channels + 1 scan time Type of Input Single-ended input Operating Mode Self-scan Conversion Method ∑ ∆ type ADC (FC4A-J4CN1), Successive approximation register method (FC4A-J8C1, FC4A-J8AT1) ±0.2% of full scale — — ±0.2% of full scale +cold junction compensation error (±3°C maximum) Pt100, Ni100: ±0.4% of full scale Pt1000, Ni1000: ±0.2% of full scale ±0.2% of full scale ±3°C maximum — — Temperature Coefficient ±0.005% of full scale/°C Repeatability after Stabilization Time ±0.5% of full scale Non-linearity ±0.04% of full scale Maximum Error Input Value of LSB Non-linear ±1% of full scale 50,000 increments (16 bits) 0.2 mV 0.32 µA Type K: Approx. 24,000 increments (15 bits) Type J: Approx. 33,000 increments (15 bits) Type T: Approx. 10,000 increments (14 bits) Pt100: Approx. 6,400 increments (13 bits) Pt1000: Approx. 64,000 increments (16 bits) Ni100: Approx. 4,700 increments (13 bits) Ni1000: Approx. 47,000 increments (16 bits) Type K: Type J: Type T: Pt100: 0.086°C Pt1000: 0.0086°C Ni100: 0.037°C Ni1000: 0.0037°C 0.058°C 0.038°C 0.042°C Approx. 4,000 increments (12 bits) Sensors Data Digital Resolution Power Supplies Input Error Maximum Error at 25°C Cold Junction Compensation Error Automation Software AD Conversion Sampling Repetition Time PTC Thermistor PLCs Sampling Duration Time NTC Thermistor 0.05°C Default: Optional: Optional: –32,768 to 32,767 (selectable for each channel) 1 Resistance: 0 to 10,000 0 to 50,000 –32,768 to 32,767 (selectable for each channel) 1 Temperature: °C, °F Monotonicity Communication Default: 0 to 4,000 Data Type in Application Program OI Touchscreens Model — Yes Input Data Out of Range Detectable2 1: The data processed in the analog I/O module can be linear-converted to a value between –32,768 and 32,767. The optional range designation, and analog I/O data minimum and maximum values can be selected using data registers allocated to analog I/O modules. 800-262-IDEC (4332) • USA & Canada 101 Barriers Analog Input Specifications (2) con’t on next page. Programmable Logic Controllers MicroSmart Family Model Noise Resistance OI Touchscreens Analog Input Specifications (2), con’t FC4A-J4CN1, FC4A-J8C1 Maximum Temporary Deviation during Electrical Noise Tests FC4A-J4CN1 ±3% maximum (when a 500V clamp voltage is applied to the power supply and I/O lines) Input Filter Recommended Cable for Noise Immunity Twisted pair cable — PLCs Automation Software Effect of Improper Input Connection Maximum Permanent Allowed Overload (No Damage) Selection of Analog Input Signal Type Calibration or Verification to Maintain Rated Accuracy No damage 11V DC 22 mA DC — Using programming software Impossible Analog Ouput Specifications Model FC4A-K4A1 Output Range Load Power Supplies 2 LSB maximum Between input and power circuit: Isolated Between input and internal circuit: Optocoupler-isolated Isolation Sensors ±3% maximum (when a 500V clamp voltage is applied to the power supply and I/O lines) Not assured Software Crosstalk DA Conversion Output Error Data Voltage 0 to 10V DC Current 4 to 20 mA FC4A-L03A1 FC4A-L03AP1 FC4A-K1A1 FC4A-K2C1 –10 to 10V DC Impedance Voltage output: 1 kΩ minimum Current output: 300Ω maximum Load Type Resistive load Settling Time 2 ms/ch 10 ms 10 ms 10 ms 1 ms/ch Total Output System Transfer Time 2 ms/ch + 1 scan time 10 ms + 1 scan time 10 ms + 1 scan time 10 ms + 1 scan time 1 ms × channels + 1 scan time Maximum Error at 25°C ±0.2% of full scale Temperature Coefficient ±0.015% of full scale/°C Repeatability after Stabilization Time ±0.5% of full scale Output Voltage Drop ±1% of full scale Non-lineality ±0.2% of full scale Output Ripple 20 mV maximum Overshoot 0% Total Error ±1% of full scale Digital Resolution 4096 increments (12 bits) 50,000 increments (16 bits) Voltage 2.5 mV 0.4 mV Current 4 µA 0.32 µA Output Value of LSB Communication FC4A-J8AT1 Data Type in Application Program ±0.005% of full scale/°C ±0.1% of full scale Default: 0 to 4,095 (voltage, current) –25,000 to 25,000 (voltage) 0 to 50,000 (current) Optional: –32,768 to 32,767 (selected for each channel)1 Monotonicity Yes Current Loop Open Undetectable 1: The data processed in the analog I/O module can be linear-converted to a value between –32,768 and 32,767. The optional range designation, and analog I/O data minimum and maximum values can be selected using data registers allocated to analog I/O modules. Barriers Analog Input Specifications con’t on next page. 102 www.IDEC.com Programmable Logic Controllers MicroSmart Family Analog Ouput Specifications, con’t Noise Resistance FC4A-K4A1 Maximum Temporary Deviation during Electrical Noise Tests Isolation FC4A-L03AP1 FC4A-K1A1 FC4A-K2C1 ±3% maximum when a 500V clamp voltage is applied to the power and I/O lines Recommended Cable for Noise Immunity Crosstalk FC4A-L03A1 OI Touchscreens Model Twisted pair shielded cable 2LSB maximum None Between output and power circuit Isolated Between output and internal circuit Photocoupler-isolated Effect of Improper Output Connection Twisted pair cable 2 LSB maximum No damage Using software programming Calibration or Verification to Maintain Rated Accuracy PLCs Selection of Analog Output Signal Type Impossible Automation Software Power Supplies Sensors Communication Barriers 800-262-IDEC (4332) • USA & Canada 103 Programmable Logic Controllers MicroSmart Family OI Touchscreens PID Module Specifications Model Control Mode FC5A-F2MR2 Possible Heating/Cooling Control Possible (overlappling deadband settings available) * Difference Input Temperature Control Possible * Cascade Control Possible * Input Points 2ch PLCs Thermocouple Resistance Thermometer Automation Software Power Supplies 2ch K, J, R, S, B, E, T, N, PL-II, C (W/Re5-26) External resistance: 100Ω maximum However, external resistance of B input: 40Ω maximum Pt100, JPt100, 3-wire type Allowable conductor resistance (per wire): 10Ω maximum Current Input 0 to 20 mA DC, 4 to 20 mA DC Input impedance: 50Ω Maximum permanent allowed overload (no damage): 50 mA maximum Voltage Input 0 to 1V DC Input impedance: 1MΩ minimum Maximum permanent allowed overload (No damage): 5V DC Allowable output impedance: 2 kΩ 0 to 5V DC, 1 to 5V DC, 0 to 10V DC Input impedance: 100kΩ minimum Maximum permanent allowed overload (No damage): 15V DC maximum Allowable output impedance: 100Ω maximum Types of Inputs AD Conversion FC5A-F2M2 Independent PID Control Sampling Duration Time 100 ms Sampling Repetition Time 125 ms Type of Input Differential input Conversion Method ∑ ∆ type ADC Thermocouple Input ±0.2% of full scale or ±2°C (4°F), whichever is greater However, R, S inputs: 0 to 200°C (0 to 400°F): ±6°C (12°F) B input: 0 to 300°C (0 to 600°F) Accuracy is not guranteed. K, J, E, T, N inputs: Less than 0°C (32°F): ±0.4% of full scale Maximum Error at 25°C Resistance Thermometer Input ±0.1% of full scale or ±1°C (2°F), whichever is greater Sensors Voltage/Current Inputs Input Accuracy (at 0 to 55°C) Thermocouple Input ±0.2% of full scale ±0.7% of full scale However, R, S input,:0 to 200°C (0 to 400°F): ±6°C (12°F) B input: 0 to 300°C (0 to 600°F) Accuracy is not guranteed. K, J, E, T, N inputs: Less than 0°C (32°F): ±0.9% of full scale Resistance Thermometer Input ±0.6% of full scale Voltage/Current Inputs Maximum Temporary Deviation during Electrical Noise Tests Communication Noise Resistance ±0.7% of full scale Voltage input, current input ±3% maximum when a 500V clamp voltage is applied to the power supply and I/O lines Termocouple, Resistance Thermometer Not assured Input Filter None Recommended Cable for Noise Immunity Twisted pair cable Cross Talk Isolation Data Accuracy None Between input and power circuit: Transformer Isolated Between input and internal circuit: Optocoupler isolated Maximum error at 25°C±Minimum digital resolution of each input range Cold Junction Temperature Compensation Accuracy ±1°C at 0 to 55°C Sampling Period 125 ms Barriers Output Points 2ch *Dual channel input is required for one loop circuit. PID Module Specifications con’t on next page. 104 www.IDEC.com Programmable Logic Controllers MicroSmart Family PID Module Specifications, con’t Relay output 1NO Rated load 5A 250V AC/30V DC (resistive load) 3A 250V AC (inductive load cos ø=0.4) Minimum open/closed load: 10 mA 5V DC Electrical life: 100,000 cycles (at the maximum rating of resistive load) Non-contact voltage output (for SSR drive) 12V DC±15% Maximum 40 mA (short circuit protected) Leakage current: 0.3 mA maximum Analog current output 4 to 20 mA DC Maximum Error: ±0.5% Full Scale at 25°C ±1.0% Full Scale at 55°C Load resistance: 550Ω maximum Analog output digital resolution: 1,000 LSB input value: 0.016 mA Maximum Temporary Deviation during Electrical Noise Tests — ±3% maximum when a 500V clamp voltage is applied to the power supply and I/O lines Recommended Cable for Noise Immunity — Twisted pair cable Cross Talk — None Isolation Between output and power circuit: Transformer Isolated Between output and power circuit: Transformer Isolated Between output and internal circuit: Optocoupler isolated Power Voltage 24V DC (External power), 5V DC (Internal power) Allowable Voltage Range 20.4 to 28.8V DC External Power Consumption Approx. 3.5W maximum Output Noise Resistance Automation Software FC5A-F2M2 PLCs FC5A-F2MR2 OI Touchscreens Model Internal Power Consumption (at 24V DC while all I/Os are on) 65mA (5V DC) Connector on Mother Board Input: F6018-17P (Fujicon) Weight (approx.) 140g Output: F6018-11P (Fujicon) Input Range K Input Value of LSB -200 to 1,370°C -328 to 2,498°F 1°C (°F) -328.0 to 752.0°F 0.1°C (°F) -200 to 1,000°C -328 to 1,832°F 1°C (°F) R 0 to 1,760°C 32 to 3,200°F 1°C (°F) S 0 to 1,760°C 32 to 3,200°F 1°C (°F) B 0 to 1,820°C 32 to 3,308°F 1°C (°F) E -200 to 800°C -328 to 1,472°F 1°C (°F) T -200.0 to 400.0°C -328.0 to 752.0°F 0.1°C (°F) N -200 to 1,300°C -328 to 2,372°F 1°C (°F) PL-II 0 to 1,390°C 32 to 2,534°F 1°C (°F) C (W/Re5-26) 0 to 2,315°C 32 to 4,199°F 1°C (°F) -200.0 to 850.0°C -328.0 to 1,562.0°F 0.1°C (°F) -200 to 850°C -328 to 1,562°F 1°C (°F) -200.0 to 500.0°C -328.0 to 932.0°F 0.1°C (°F) -200 to 500°C -328 to 932°F 1°C (°F) Pt100 JPt100 4 to 20mA DC -2,000 to 10,000 (12,000 increments) 1.333 μA 0 to 20mA DC -2,000 to 10,000 (12,000 increments) 1.666 μA 0 to 1V DC -2,000 to 10,000 (12,000 increments) 0.083 mA 0 to 5V DC -2,000 to 10,000 (12,000 increments) 0.416 mA 1 to 5V DC -2,000 to 10,000 (12,000 increments) 0.333 mA 0 to 10V DC -2,000 to 10,000 (12,000 increments) 0.833 mA Communication -200.0 to 400.0°C J Sensors Input Type Input Range (Digital Resolution) Power Supplies Input Barriers 800-262-IDEC (4332) • USA & Canada 105 Programmable Logic Controllers MicroSmart Family OI Touchscreens Expansion Interface Module Specifications FC5A-EXM1M (Expansion Interface Master Module) Type No. — 24V DC (supplied from external power) 24V DC (supplied from external power) Allowable Voltage Range — 20.4 to 26.4V DC (including ripple) 20.4 to 26.4V DC (including ripple) Internal power (supplied from CPU module): 0 mA (5V DC) 0 mA (24V DC) External power: With I/O modules 750 mA (26.4V DC)1 Internal power (supplied from CPU module): 50 mA (5V DC) 0 mA (24V DC) External power: With I/O modules 750 mA (26.4V DC)1 PLCs Internal power (supplied from CPU module): 90 mA (5V DC) 0 mA (24V DC) Maximum Power Consumption (External Power)1 — 19W (26.4V DC) 19W (26.4V DC) Allowable Momentary Power Interruption — 10 ms minimum (24V DC) 10 ms minimum (24V DC) Between CPU module and expansion interface module Connectable CPU modules: FC5A-D16RK1/D16RS1/D32K3/D32S3/D12K1E/D12S1E Connectable I/O modules: 7 maximum Beyond the expansion interface module Connectable I/O modules: 8 digital I/O modules maximum (AC input modules are not applicable)2 I/O Expansion Automation Software FC5A-EXM2 (Expansion Interface Module) Rated Power Voltage Current Draw (Internal Power/External Power) Maximum I/O Refresh Time3 Communication between CPU Module and Expansion Interface Module 3.6 ms 2.8 ms Asynchronous communication (I/O refresh of I/O modules on both sides of the expansion interface module is asynchronous.) Isolation from Internal Circuit Only communication interface part is isolated Not isolated EMC Compliant Cable Length 1m (FC5A-KX1C) — Power Supply Connector Power Supplies FC5A-EXM1S (Expansion Interface Slave Module) Expansion Cable Connector Weight Connector on Mother Board — MKDSN1.5/3-5.08-BK (Phoenix Contact) MSTB2.5/3-GF-5.08BK (Phoenix Contact) Connector Insertion/Removal Durability — — 100 times minimum Connector on Mother Board FCN-365P024-AU (Fujitsu Component) — Connector Insertion/Removal Durability 100 times minimum — 70g 135g Barriers Communication Sensors 1: Power consumption by the expansion interface module and eight I/O modules. 2: The maximum number of relay outputs that can be turned on simultaneously is 54 points. 3: Maximum I/O refresh time of the expansion interface module. D8252 stores the refresh time. 106 www.IDEC.com 140g Programmable Logic Controllers MicroSmart Family FC5A-D16RK1, FC5A-D16RS1, FC4A-D20RK1, FC4A-D20RS1 FC5A-D32K3, FC5A-D32S3, FC4A-D40K3, FC4A-D40S3 70.0 11.3 47.5 FC5A-D12K1E, FC5A-D12S1E 70.0 90.0 90.0 14.6 PLCs FC5A-C24R2, FC5A-C24R2C, FC5A-C24R2D, FC4A-C24R2, FC4A-C24R2C FC5A-C10R2, FC5A-C16R2, FC5A-C10R2C, FC5A-C16R2C, FC5A-C10R2D, FC5A-C16R2D, FC4A-C10R2, FC4A-C16R2, FC4A-C10R2C, FC4A-C16R2C 11.3 35.4 95.0 90.0 70.0 11.3 35.4 70.0 70.0 Automation Software 4.5* 4.5* 90.0 90.0 80.0 FC4A-D20K3, FC4A-D20S3 70.0 90.0 47.5 OI Touchscreens Dimensions (mm) *8.5 mm when the clamp is pulled out. *8.5 mm when the clamp is pulled out. FC4A-N16B1, FC4A-R161, FC4A-J4CN1, FC4A-J8C1, FC4A-J8AT1 FC5A-SIF2, FC5A-SIF4, FC4A-AS62M, FC4A-N08A11, FC4A-J2A1, FC4A-N08B1, FC4A-K1A1, FC4A-R081, FC4A-K2C1, FC4A-T08K1, FC4A-L03A1, FC4A-T08S1, FC4A-L03AP1, FC4A-K4A1, FC4A-M08BR1 23 .5 14 .6 14.6 23.5 70.0 90.0 70.0 90.0 23.5 .3 2-ø4 6.3 3 .8 17.6 11.3 3.8 3.8 Power Supplies FC4A-N16B3, FC4A-T16K3, FC4A-T16S3 FC4A-HPC1, FC4A-HPC2, FC4A-HPC3 70 .0 11.3 29.7 13.9 70.0 70.0 90.0 4 .5* 90.0 90.0 103.0 90 .0 3.8 22.5 Sensors FC4A-N32B3, FC4A-T32K3, FC4A-T32S3 3.0 *8.5 mm when the clamp is pulled out. 1.0 39.1 70.0 13.9 71.0 80.0 38.0 70.0 45.0 FC4A-HPH1 800-262-IDEC (4332) • USA & Canada Barriers 2.1* 90.0 90.0 3.8 Communication FC4A-SX5ES1E FC5A-F2MR2, FC5A-F2M2, FC4A-M24BR2 *5.6 mm when the clamp is pulled out. 107 Programmable Logic Controllers MicroSmart Family 17.6 60.0 *2 35.4 70.0 60.0 *2 90.0 *8.5 mm when the clamp is pulled out. 70.0 90.0 3.8 4.5 *1 *1: 8.5 mm when the clamp is pulled out. *2: Reference length when the cable is bent. Example 95.0 23.5 23.5 9.0 Automation Software 45.0 35.0 90.0 9.0 The following figure illustrates a system setup consisting of the all-in-one 24-I/O type CPU module, an 8-point relay output module, and a 16-point DC input module mounted on a 35-mm-wide-DIN rail using BNL6 end clips. *1: 8.5 mm when the clamp is pulled out. *2: Reference length when the cable is bent. DIN Rail Clamp 4.5* PLCs 70.0 9.4 FC5A-EXM1S 4.5 *1 39.1 90.0 3.8 FC5A-EXM1M 4.5* OI Touchscreens FC5A-EXM2 End Clip (BNL6) *8.5 mm when the clamp is pulled out. 47.5 24.1 .3 2–ø4 90.0 103.0 90.0 103.0 90.0 83.0 2-ø 83.0 FC4A-SX5ES1E 45.0 35.0 3.0 Barriers 108 23.5 4.3 4.3 2-ø 68.0 6.3 95.0 80.0 Communication .3 2–ø4 FC5A-SIF2, FC5A-SIF4 FC4A-AS62M, FC4A-N08A11, FC4A-J2A1, FC4A-N08B1, FC4AJ4CN1, FC4A-N16B1, FC4AJ8AT1, FC4A-R081, FC4A-J8C1, FC4A-R161, FC4A-K1A1, FC4A-T08K1, FC4AK2C1, FC4A-T08S1, FC4A-L03A1, FC4A-K4A1, FC4A-L03AP1, FC4AM08BR1 www.IDEC.com 3.0 4.3 2–ø 70.0 80.0 FC5A-D12K1E, FC5A-D12S1E FC5A-D16RK1, FC5A-D16RS1 FC5A-D32K3, FC5A-D32S3 FC4A-D20RK1, FC4A-D20RS1 FC4A-D40K3, FC4A-D40S3 FC5A-C24R2 FC5A-C24R2C FC5A-C24R2D FC4A-C24R2 FC4A-C24R2C FC5A-C10R2, FC5A-C10R2C, FC5A-C10R2D, FC5A-C16R2, FC5A-C16R2C, FC5A-C16R2D FC4A-C10R2, FC4A-C10R2C FC4A-C16R2, FC4A-C16R2C 90.0 83.0 Sensors Power Supplies Mounting Hole Layouts Programmable Logic Controllers 3.0 6.3 17.6 .3 2–ø4 4.8 22.5 .3 4.3 38.0 20.3 4 2–ø 2–ø 90.0 103.0 4.3 2-ø FC4A-HPH1 PLCs 90.0 103.0 90.0 103.0 35.4 24.1 .3 2–ø4 FC4A-HPC1 FC4A-HPC2 FC4A-HPC3 90.0 103.0 39.1 6.3 FC5A-EXM1M FC4A-N16B3 FC4A-T16K3 FC4A-T16S3 90.0 103.0 .3 2–ø4 F C5A-EXM1S F C4A-D20K3 FC4A-D20S3 90.0 103.0 29.7 6.3 FC5A-F2MR2 FC5A-F2M2 FC5A-EXM2 FC4A-M24BR2 3.0 3.0 3.0 3.0 3.0 Mounting hole layout for FC5A-C24R2 or FC4A-C24R2 and four 23.5mm-wide I/O modules Mounting hole layout from left, FC4A-HPH1, FC4A-D20K3, FC4A-N16B3, FC4A-N32B3, and FC4A-M24R2 modules 4.3 Example 23.5 –ø 41.8 23.5 17.6 17.6 29.7 3.0 15.3 23.5 3.0 3.0 23.5 23.5 113.0±0.2 103.0 3.0 3.0 41.8 3.0 3.0 17.6 17.6 Power Supplies 3.0 83.0 113.0±0.2 83.0 103.0 10 23.5 Automation Software Example 12.3 OI Touchscreens FC4A-N32B3 FC4A-T32K3 FC4A-T32S3 MicroSmart Family 3.0 29.7 All dimensions in mm. Sensors Communication Barriers 800-262-IDEC (4332) • USA & Canada 109
FC4A-USB 价格&库存
很抱歉,暂时无法提供与“FC4A-USB”相匹配的价格&库存,您可以联系我们找货
