FL1F-KW1
FL1F-KW1
    IDEC(日本和泉)
    IDEC - FL1F-KW1 - MOUNTING CLIP & GASKET, TEXT DISPLAY
FL1F-KW1 数据手册
6th-Generation IDEC SmartRelay PRODUCT DESCRIPTION With an ever-changing market and tough competition, you need an edge to stay on top. This sixth-generation IDEC SmartRelay meets your demands from all small-scale applications by offering more powerful hardware, a new display and full communication options via Ethernet. BASE MODULE HIGHLIGHTS Embedded RJ45 Ethernet Port • Remote program download, upload and monitor • Integrated web server for remote monitoring and control Micro SD Card • Equipped with micro SD slot for program storage, transfer and data logging BASE MODULE GENERAL SPECIFICATIONS Item • No need for a special memory cartridge Specifications Standard Horizontal Mounting 0 to 55°C (no freezing) Vertical Mounting 0 to 55°C (no freezing) Cold: IEC60068-2-1 Hot: IEC60068-2-2 Storage/Transportation Temp. –40 to +70°C (no freezing) — Relative Humidity 10 to 95% (no condensation) IEC60068-2-30 Atmospheric Pressure 795 to 1080hPa — Operating Condition No corrosive gas — Degree of Protection IP20 — Vibration Resistance 5 to 8.4Hz, amplitude 3.5mm 8.4 to 150Hz, acceleration 9.8m/s² IEC60068-2-6 Shock Resistance 147m/s² IEC60068-2-27 Drop Test (packaged) 0.3m IEC60068-2-32 Emissions Limit class B Group 1 EN55011/A EN55022/B EN50081-1 Electrostatic Discharge Immunity 8kV air discharge 6kV contact discharge IEC61000-4-2 Radiation Field Immunity Field Strength: 1V/m and 10V/m IEC61000-4-3 Fast Transient Burst 2kV (power line) 2kV (I/O signal line) IEC61000-4-4 Surge Immunity1 1kV (power line) normal 2kV (power line) common IEC61000-4-5 Communication Cable 2.5mm² (one wire) 1.5mm² (two wires) — Terminal Style Finger-safe type 2 — Operating Temperature (FL1F-H12RCC, FL1F-B12RCC only) Data Logging • Up to 20,000 lines in a file with a maximum of 50 files can be stored in the Micro SD Memory card Integrated Web Server • Easily monitor and control web pages with no HTML knowledge • Instant monitoring and control using standard web browser like Chrome, IE and Firefox • View and control I/O status, timer, counters, analog set point and more There's an App for that! • Download iOS and Android App for free • Using the SmartRelay App, users can view and control any I/O status, timer, counters, and analog set point anywhere and at any time 1:N Communication • FL1F SmartRelays now have the capability to communicate with each other over an Ethernet network 1: For protection against surge noise on DC power supply types (FL1F-H12RCE/B12RCE, FL1F-H12SCD, FL1F-H12RCA/B12RCA), use surge absorbers, noise cut transformers or noise filters. Use of a surge protection device (DEHN + SÖHNE GmbH + Co, BVT AD 24 Part No. 918 402) is recommended. 2: Tightening torque 0.5 to 0.6N·m • Up to 16 FL1F SmartRelays can be configured on the network C 1 R US TEXT DISPLAY PANEL HIGHLIGHTS: New and improved LCD display • Improved display with 6 lines and 20 characters per line, more than twice as many characters as before • Selectable white, amber or red backlighting for optical emphasis on alarms and events Two RJ45 Ethernet ports • Use a standard Ethernet cable to the connect FL1F base module to the Text Display Panel. A special cable is not required. • Provide different ways to connect TEXT DISPLAY SPECIFICATIONS Text Display General Specifications Item Operating Temperature Specifications Horizontal Mounting Vertical Mounting 0 to 55°C (no freezing) 0 to 55°C (no freezing) Text Display General Specifications Cont. Standard Cold: IEC60068-2-1 Hot: IEC60068-2-2 Storage/Transportation Temp. –40 to +70°C (no freezing) — Relative Humidity 10 to 95% (no condensation) IEC60068-2-30 Atmospheric Pressure 795 to 1080hPa — Operating Condition No corrosive gas — Degree of Protection IP20 — Vibration Resistance 5 to 8.4Hz, amplitude 3.5mm 8.4 to 150Hz, acceleration 9.8m/s2 IEC60068-2-6 Shock Resistance 147m/s2 Drop Test (packaged) 0.3m Emissions Limit class B Group 1 Electrostatic Discharge Immunity 8kV air discharge 6kV contact discharge IEC61000-4-2 Radiation Field Immunity Field Strength: 1V/m and 10V/m IEC61000-4-3 Fast Transient Burst 2kV (power line) 2kV (I/O signal line) IEC61000-4-4 1kV (power line) normal 2kV (power line) common IEC61000-4-5 Communication Cable 2.5mm2 (one wire) 1.5mm2 (two wires) — Terminal Style Finger-safe type2 — Surge Immunity1 (FL1F-H12RCC, FL1F-B12RCC only) Dimensions (W × H × D) 128.2 × 86 × 38.7 mm Weight (approx.) Installation 220g Panel cut-out using mounting clips Keyboard Membrane keypad Display FSTN graphic display (W × H: 160 × 96 dots) LED backlight (White, Amber, Red) Font type English, Spanish, Russian, Chinese, Italian, Turkish, German, Dutch, French, Japanese Displayable string 1 screen 6 lines × 20 columns Power Supply Specifications Power Voltage 24V AC/DC 12V DC IEC60068-2-27 Allowable Voltage Range 20.4 to 26.4V AC 10.2 to 28.8V DC IEC60068-2-32 EN55011/A EN55022/B EN50081-1 Allowable Voltage Frequency 47 to 63Hz Power Consumption 12V DC: 145mA (Typ.) 24V DC: 70mA (Typ.) 24V AC: 75mA (Typ.) Data Transmission Rate 10/100M full/half duplex data transmission rate LCD Display / Backlight Specifications LCD Display Durability3 Backlight Durability 4 50,000 hours 20,000 hours 3 Display durability is calculated under ordinary operating and storage conditions: room temperature, normal humidity below 65% RH, and not subjected to direct sunlight. 4 Backlight durability is the number of hours taken for the light to become 50% of the original brightness. 1 For protection against surge noise on DC power supply types (FL1F-H12RCE/B12RCE, FL1F-H12SCD, FL1FH12RCA/B12RCA), use surge absorbers, noise cut transformers, or noise filters. Use of a surge protection device (DEHN + SÖHNE GmbH + Co, BVT AD 24 Part No. 918 402) is recommended. 2 Tightening torque 0.5 to 0.6N·m 2 PART NUMBERS Base Module Rated Power Voltage Input Signal 24V DC Output Signal Display Transistor Yes DC I1, I2, I7 and I8 are used for digital/ analog inputs 12/24V DC 24V AC/DC AC/DC 100 to 240V AC/DC Yes Relay 1 — Yes Relay AC/DC Clock Yes Yes 8/4 points 8/4 points Yes — Weight (approx.) 8/4 points Yes — Relay I/O Points Yes 8/4 points Part No. 195g FL1F-H12SCD 240g FL1F-H12RCE 200g FL1F-B12RCE 240g FL1F-H12RCA 200g FL1F-B12RCA 240g FL1F-H12RCC 200g FL1F-B12RCC 1 With NPN/PNP sensor input. For details, see Input Internal Circuits in the Specifications table. Expansion I/O Module Type Rated Power Voltage Input Signal Output Signal I/O Points Weight (approx.) Part No. 24V DC DC Transistor 4/4 points 95g FL1F-M08B1S2 12/24VDC DC Relay 4/4 points 130g FL1F-M08B2R2 24V AC/DC 2 AC/DC 2 Relay 4/4 points 130g FL1F-M08D2R2 100 to 240V AC/DC AC/DC Relay 4/4 points 130g FL1F-M08C2R2 Analog Input 12/24V DC Analog — 2/0 points 95g FL1F-J2B2 Analog Output 24V DC — Analog 0/2 points 95g FL1F-K2BM2 Input/Output 2 With NPN/PNP sensor input. For details, see Input Internal Circuits in the Specifications table. I/O points within the maximum number of expandable I/O points can be used. When using modules of the same power voltage, supply power to the base module and expansion I/O modules using one power supply. When power is supplied to the modules from different power supplies, the fast transient burst is 1 kV (IEC61000-4-4). Text Display Rated Power Voltage Weight (approx.) Part Number Remarks 24V AC/DC 12V DC 220g FL1F-RD1 Supplied with mounting clip and gasket Options Description Part Number Package Quantity Remarks Application Software: WindLGC FL9Y-LP1CDW 1 DVD-ROM (incl. online help manual) Mounting Clip for Base Module FL1F-PSP1PN05 5 Supplied with a module 3 Mounting Clip and Waterproof Gasket for Text Display FL1F-KW1 1 Supplied with text display4 IDEC SmartRelay User’s Manual (English) FL9Y-B1789 1 Downloadable from: http://www.idec.com/download 3 Supplied with a base module and an expansion module. 4 Supplied with a text display, it includes a gasket, four mounting clips, and a power supply connector. NEW FUNCTION BLOCKS En AQ Lap AX R Sn=8 Sn 1 2 3 4 5 6 7 8 Sn=8 Sn=8 Analog filter Ax Ax En Lap Sw R CurT 9 10 ... Stopwatch AQ LapT AQ AQ AQ AX Monday Astronomical clock Tuesday Ta Ta Ta TR TS TR TS TR TS AC Sn 1 2 3 4 5 300 380 200 250 100 100 300 0 0 200 0 100 1 Ax AQ 350 380 250 2 3 6 7 8 1 2 3 4 5 Average value En R Ax En (If ERst=1) S1 Mode Q Sn=8 St=10s Ax AQ En R Q 300 Max/Min Wednesday... En S1 Ax Ax AQ 3 Sn=8 St=10s 6 7 8 BASE MODULE SPECIFICATIONS Base Module Type No. Rated Power Voltage Clock Power Supply Allowable Voltage Range FL1F-H12RCE FL1F-B12RCE FL1F-H12RCA FL1F-B12RCA FL1F-H12RCC FL1F-B12RCC 24V DC 12/24V DC 24V AC/DC 100 to 240V AC/DC 10.8 to 28.8V DC 20.4 to 26.4V AC 20.4 to 28.8V DC 85 to 265V AC 100 to 253V DC 20.4 to 28.8V DC Rated Frequency — 15 to 50 mA (24V DC) 1.2A (with max. load on digital output) Current Draw Allowable Momentary Power Interruption — 47 to 63Hz 47 to 63Hz 30 to 140 mA (12V DC) 15 to 90 mA (24V DC) — 15 to 150mA (12V DC) 15 to 130mA (24V DC) 15 to 40mA (100V AC)   5 to 10mA (100V DC) 15 to 25mA (240V AC)   2 to 8mA (240V DC) 2ms Typ. (12V DC) 5ms Typ. (24V DC) 5ms Typ. (24V AC/DC) 10ms Typ. (100V AC/DC) 20ms Typ. (240V AC/DC) 3.6 W (24V AC) 3.2 W (24V DC) 4.6W (100V AC)  1.2W (100V DC) 6.0W (240V AC)  2.0W (240V DC) Power Consumption 1.2 W (24V DC) 1.7W (12V DC) 2.2W (24V DC) Reverse Polarity Protection Yes Yes Backup Duration 20 days 20 days 20 days 20 days Clock Accuracy ±2 sec/day (Typ.) ±2 sec/day (Typ.) ±2 sec/day (Typ.) ±2 sec/day (Typ.) Input Signal DC DC AC/DC AC/DC Input Points 8 (I1 to I8) 8 (I1 to I8) 8 (I1 to I8) High-speed Input1 4 (I3, I4, I5, I6), 5kHz maximum 4 (I3, I4, I5, I6), 5kHz maximum — — Analog Input Points 4 (I1, I2, I7, I8) 4 (I1, I2, I7, I8) — — Analog Input Range 0 to 10V DC (max. rated input: 28.8V DC) 0 to 10V DC (max. rated input: 28.8V DC) — — Analog Input Error ±1.5 (of full scale) ±1.5 (of full scale) — — Analog Input Resolution 10 bits (0 to 1000) 10 bits (0 to 1000) — Cycle time 300ms 300ms 300ms 300ms Allowable Voltage Range 0 to 28.8V DC 0 to 28.8V DC 0 to 26.4V AC 0 to 28.8V DC 0 to 265V AC 0 to 253V DC Digital Input 5.8kΩ 5.8kΩ 4.8kΩ Analog Input 72kΩ 72kΩ Input Impedance Input FL1F-H12SCD Isolation — — — 8 (I1 to I8) — 610kΩ — — — — — OFF Voltage < 5V DC < 5V DC < 5V AC/DC < 40V AC < 30V DC ON Voltage ≥ 12V DC ≥ 8.5 V DC ≥ 12V AC/DC ≥ 79V AC OFF Current < 0.9mA (I3 to I6) < 0.07mA (I1, I2, I7, I8) < 0.88mA (I3 to I6) < 0.07mA (I1, I2, I7, I8) < 1.2mA < 0.05mA (AC) < 0.06mA (DC) ON Current ≥ 2.1mA (I3 to I6) ≥ 0.18mA (I1, I2, I7, I8) ≥ 1.5mA (I3 to I6) ≥ 0.12mA (I1, I2, I7, I8) ≥ 2.6mA ≥ 0.08mA (AC) ≥ 0.13mA (DC) Turn ON Time 1.5ms (Typ.) ≤ 1.0ms (I3 to I6) 1.5ms (Typ.) ≤ 1.0ms (I3 to I6) 1.5ms (Typ.) 100V AC: 40ms (Typ.) 240V AC: 30ms (Typ.) 100V DC: 25ms (Typ.) 240V DC: 20ms (Typ.) Turn OFF Time 1.5ms (Typ.) ≤ 1.0ms (I3 to I6) 1.5ms (Typ.) ≤ 1.0ms (I3 to I6) 15ms (Typ.) 100V AC: 45ms (Typ.) 240V AC: 70ms (Typ.) 100V DC: 60ms (Typ.) 240V DC: 75ms (Typ.) Wire Length2 100m 100m 100m 100m Output Signal Output Points/ Contact Configuration Transistor source output Relay output Relay output Relay output 4 points (separate) 4NO contacts 4NO contacts 4NO contacts — Isolated Isolated Isolated — 2500V AC, 1 minute 500V DC, 1 minute 2500V AC, 1 minute 500V DC, 1 minute 2500V AC, 1 minute 500V DC, 1 minute Operating Range Isolation Dielectric Strength (between power/input terminals and output terminals) Output Voltage External power voltage — ≥ 79V DC — — Resistive load 10A at 12/24V AC/DC 10A at 100/120V AC 10A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC Inductive load 2A at 12/24V AC/DC 3A at 100/120V AC 3A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC Resistive load 10A at 12/24V AC/DC 10A at 100/120V AC 10A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC Inductive load 2A at 12/24V AC/DC 3A at 100/120V AC 3A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC Resistive load 10A at 12/24V AC/DC 10A at 100/120V AC 10A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC Inductive load 2A at 12/24V AC/DC 3A at 100/120V AC 3A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC 30A maximum 30A maximum 30A maximum External fuse required: 16A maximum External fuse required: 16A maximum External fuse required: 16A maximum — 10mA, 12V DC (reference value) 10mA, 12V DC (reference value) 10mA, 12V DC (reference value) Initial Contact Resistance — 100mΩ maximum (at 1A, 24V DC) 100mΩ maximum (at 1A, 24V DC) 100mΩ maximum (at 1A, 24V DC) Mechanical Life — 10 million operations (no load, 10Hz) 10 million operations (no load, 10Hz) 10 million operations (no load, 10Hz) Electrical Life — 100,000 operations (rated resistive load) 1800 operations/hour 100,000 operations (rated resistive load) 1800 operations/hour 100,000 operations (rated resistive load) 1800 operations/hour Output Maximum Load Current Surge Current Short-circuit Protection Minimum Switching Load 0.3A maximum — Built-in current limiting resistor: Approx. 1A 1 When selecting frequency trigger function and up/down counter function. 2 10m when connected to analog input (twisted pair cable) Initialization Time: After power-up, the FL1F takes a maximum of 9 seconds (when using a micro SD card) for initialization. When initialization is complete, the FL1F is automatically set to RUN mode. 4 EXPANSION I/O MODULE SPECIFICATIONS Expansion I/O Module Type No. FL1F-M08B1S2 FL1F-M08B2R2 FL1F-M08D2R2 Rated Power Voltage 24V DC 12/24V DC Allowable Voltage Range 20.4 to 28.8V DC 24V AC/DC 20.4 to 26.4V AC 20.4 to 28.8V DC 50/60Hz (47 to 63Hz) Power Supply Rated Frequency Current Draw — 15 to 40mA 10 to 80mA (12V DC) 10 to 40mA (24V DC) Allowable Momentary Power Interruption — Power Consumption Input 1.0W Reverse Polarity Protection Input Signal Input Points Isolation DC input Allowable Voltage Range 2 ms (typ.) (12V DC) 5 ms (typ.) (24V DC) 1.0W (12V DC) 1.0W (24V DC) Yes Yes DC input — 20.4 to 28.8V DC 10.8 to 28.8V DC OFF Voltage ON Voltage < 5V DC ≥ 12V DC < 5V DC ≥ 8.5V DC AC/DC input 4 — 20.4 to 26.4V AC 20.4 to 28.8V DC < 5V AC/DC ≥ 12V AC/DC OFF Current < 0.88mA < 0.88mA < 1.1mA ON Current ≥ 2.1mA ≥ 1.5mA ≥ 2.63mA Turn ON Time 1.5ms (Typ.) 1.5ms (typ.) 1.5ms (typ.) Turn OFF Time 1.5ms (Typ.) 1.5ms (typ.) 15ms (typ.) Operating Range 4 — 4 — FL1F-J2B2 FL1F-K2BM2 12/24V DC 24V DC 10.8 to 28.8V DC 20.4 to 28.8V DC — — 15 to 30mA 15 to 82mA 10ms (typ.) (12/24V DC) 0.4W (12V DC) 0.8W (24V DC) 10ms (typ.) 2.0W — Yes Yes 4 — Analog input — — — — — — — — — — — — — — — — — — — — AC/DC input   85 to 265V AC 100 to 253V DC < 40V AC < 30V DC ≥ 79V AC ≥ 79V DC < 0.05mA (AC) < 0.06mA (DC) ≥ 0.08mA (AC) ≥ 0.13mA (DC) 100V AC: 40 ms (typ.) 240V AC: 30 ms (typ.) 100V DC: 25 ms (typ.) 240V DC: 20 ms (typ.) 100V AC: 45 ms (typ.) 240V AC: 70 ms (typ.) 100V DC: 60 ms (typ.) 240V DC: 75 ms (typ.) — Analog Input Points — — — Analog Input Range — — — — Digital Resolution Input Error — — — — — — — — Input Impedance — — — — Sampling Cycle — — — — Wire Length 100m 100m 100m 100m Output Signal Output Points/ Contact Configuration Isolation Dielectric Strength Transistor source output Relay output Relay output Relay output 2 0 to 10V (max. rated input: 28.8V) 0 to 20mA (max. rated input: 40mA) 10 bits (0 to 1000) ±1.5% (of full scale) 76kΩ (0 to 10V) 250Ω (0 to 20mA) 50ms 10m (twisted-pair shielded cable) — 4 points (separate) 4NO contacts 4NO contacts 4NO contacts — — — Isolated Isolated Isolated — — — 2500V AC, 1 minute 500V DC, 1 minute 2500V AC, 1 minute 500V DC, 1 minute 2500V AC, 1 minute 500V DC, 1 minute — — Output Voltage External power voltage (20.4 to 28.8V DC) (between power/input terminals and output terminals) Output 10.8 to 28.8V DC — FL1F-M08C2R2 100 to 240V AC/DC 85 to 265V AC 100 to 253V DC 50/60Hz (47 to 63Hz) 10 to 30mA (100V AC) 20 to 100mA (24V AC) 10 to 20mA (240V AC) 8 to 50mA (24V DC)   5 to 15mA (100V DC)   5 to 10mA (240V DC) (typ) (100V AC/DC) 5 ms (typ.) (24V AC/DC) 10ms 20ms (typ.) (240V AC/DC) 2.4W (24V AC) 3.5W (100V AC)  1.8W (100V DC) 1.2W (24V DC) 4.8W (240V AC)  2.4W (240V DC) — — — — — — — — — — — — Resistive load 5A at 12/24V AC/DC 5A at 100/120V AC 5A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC Inductive load 2A at 12/24V AC/DC 3A at 100/120V AC 3A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC Resistive load 5A at 12/24V AC/DC 5A at 100/120V AC 5A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC Inductive load 2A at 12/24V AC/DC 3A at 100/120V AC 3A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC — — External fuse required: 16A maximum External fuse required: 16A maximum — Yes 10mA, 12V DC (reference value) 100mΩ maximum (at 1A, 24V DC) 10 million operations (no load, 10Hz) 100,000 operations (rated resistive load) 1800 operations/hour — 10mA, 12V DC (reference value) — — 100 mΩ maximum (at 1A, 24V DC) 10 million operations (no load, 10Hz) 100,000 operations (rated resistive load) 1800 operations/hour — — — — — — — — Analog Output Points — Resistive load 5A at 12/24V AC/DC 5A at 100/120V AC 5A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC Inductive load 2A at 12/24V AC/DC 3A at 100/120V AC 3A at 230/240V AC 0.2A at 120V DC 0.1A at 240V DC External fuse required: 16A maximum 10mA, 12V DC (reference value) 100mΩ maximum (at 1A, 24V DC) 10 million operations (no load, 10Hz) 100,000 operations (rated resistive load) 1800 operations/hour — Analog Output Range — — — — — Digital Resolution — — — — — Output Error (of full scale) — — — — — Output Impedance — — — — — Analog Value Conversion Interval 2 Voltage: 0-10V DC Current: 0-20, 4-20 mA 10 bits (0 to 1000) Voltage output: ±2.5% Current output: ±3% Voltage: 5kΩ min Current: 250Ω max — — — — — 50ms (typ.) Wire Length — — — — — 10m (twisted-pair shielded cable) Maximum Load Current 0.3A maximum Short-circuit Protection Built-in current limiting resistor: Approx. 1A Minimum Switching Load — Initial Contact Resistance — Mechanical Life — Electrical Life — 5 (All dimensions in mm) Base Module (with Display) Base Module (without Display) Base Module (with Display) Mounting Hole Layout (Using Mounting Slides) 98 +/- 0.3 90 53.5 +0.2 -0.0 ➁ ➀ 55 71.5 Expansion I/O Module 35.5 +0.2 -0.0 35.5 ➁ ➁ n x 35.5 60 +0.2 -0.0 35.5 ➁ +0.2 -0.0 35.5 ➁ +0.2 -0.0 35.5 ➁ +0.2 -0.0 ➁ +0.2 -0.0 Text Display 90 86 Base Module (without Display) 77.6 DIMENSIONS 31.9 34.7 38.7 128.2 71.5 53 58 Expansion I/O Module (Panel Cutout) Mounting clip 90 119.0+0.5mm 53 58 78.5+0.5mm 35.5 Mounting screws (tightening torque: 0.15 to 0.2N·m) Mounting clip Gasket Panel (thickness: 1.5 to 4mm) Note: Drawings are not to scale IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2015 IDEC Corporation. All Rights Reserved. FL9Y-DS100-0a 10/15 PDF Only
FL1F-KW1 价格&库存
很抱歉,暂时无法提供与“FL1F-KW1”相匹配的价格&库存,您可以联系我们找货
