ASD33K20N
ASD33K20N
    IDEC(日本和泉)
    KEY SWITCH 30MM
ASD33K20N 数据手册
Oiltight Switches & Pilot Devices ø30mm - TWTD Series TWTD Series — Full Size NEMA Pushbuttons Switches & Pilot Devices A4 TWTD Series: Heavy duty switches built to last Key features include: • Variety of button sizes up to 2 9/16" (65mm) • Rugged construction includes chrome plated zinc locking ring die cast zinc mounting threads, screw mounted contact blocks • LED or incandescent illumination • Transformer or full voltage • Transparent contact windows • Slow make, double break self cleaning contacts • Modular construction for maximum flexibility • Double nickel plated terminal screws • Available assembled or as sub-components • NEMA 4x and IP65 watertight/oiltight panel • Large M3.5 screw terminals with captive sems plate UL Listed File No. E70646 A4-166 File No. LR48366 www.idec.com The rugged series of TWTD switches offers both variety and durability in an attractive design. With button sizes up to 2 9/16" (65mm), chrome plated zinc locking rings, die cast zinc mounting threads, steel anti-rotation rings, and self cleaning contacts, the TWTD's are here to stay. The TWTD series also offers either LED or incandescent illumination in full voltage and transformer models. Transparent contact windows allow the viewing of IDEC's self cleaning slow-make/slow-break contacts. Regardless of your switching needs, the TWTD series provides the kind of long lasting, industrial strength quality you've come to expect from IDEC. Ref. No. 117617MC Certificate No. 2005010305145658 USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices Conforming to Standards Approvals Mechanical-Electrical Specifications EN60947-1, EN60947-5-1, VDE0660-200, UL508, CSA C22-2 No.14 File No. LR48366 Ref. No. 117617MC ) Operating Temperature CSA: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) UL: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) TÜV: pushbuttons and selector switches: A600=P600 (NO, NC)/Q600 (NO-EM, NC-LB) pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) Operation: –25 to +50°C (without freezing) Storage: –40 to +70°C (without freezing) Vibration Resistance Shock Resistance Electric Shock Protection 10 to 55Hz, 98m/sec2 (10g) conforming to IEC6068-2-6 980m/sec2 (100g) conforming to IEC6068-2-7 Class 0 conforming to IEC60536 Degree of Protection IP65 (from front of the panel) (conforming to IEC60529) IP54 (key switches) NEMA 1, 2, 3, 3R, 3S, 4, 4X, 5, 12, 13 (conforming to NEMA ICS6-110) Mechanical Life Momentary pushbuttons: 5,000,000 (900 operations per hour) All other switches: 500,000 Pollution Degree (conforming to IEC60947-1) 3 for switches not using a transformer 2 for switches using a transformer Rated Operational Characteristics AC-15: A600 or Ue = 250V, le = 3A (NO, NC, NO-EM, NC-LB) DC-13: P600 or Ue = 125V, le = 1.1A (NO, NC) DC-13: Q600 or Ue = 125V, le = 0.9A (NO-EM, NC-LB) Rated Insulation Voltage Rated Switching Over-Voltage 600V Rated Impulse Withstanding Voltage 4kV for contact circuit 2.5kV for lamp circuit Rated Thermal Current Minimum Switching Capacity Contact Operation 10 Amp Less than 4kV, conforming to IEC60947-1 5 mA at 3V AC/DC Slow break NC or NO, self-cleaning Flush and extended pushbuttons—with 1NO or 1NC contact: 6.2±2N (momentary), 7.0±2N (maintained) Additional contacts—1NO or 1NC: +3.2N (momentary), + 3.3N (maintained) Operating Force Terminal Referencing Recommended Terminal Torque External Short-Circuit Protection Applicable Wire Size Contact Resistance Conforming to CENELEC EN50005 Contact Gap 4mm (NO and NC) 2mm (NO-EM and NC-LB) Incandescent: 1 W LEDs: 6, 12, 24V: 20mA / 120, 240V: 10mA Lamp Ratings 0.8 N m (7.1 in lb.) 10A 250V fuse conforming to IEC60269-1 Minimum 1 x 22 AWG, max. 2 x 14 AWG or 1 x 12 AWG Initial contact resistance of 50mΩ or less Maximum Inrush Current Contact Material 40 A (40 msec) Silver Contact Ratings by Utilization Category IEC 60947-5-1 Contact Ratings A4 Switches & Pilot Devices Specifications UL Listed File No. E70646 ø30mm - TWTD Series AC-15 (A600) DC-13 (P600) Contact Ratings by Utilization Category Operational Voltage Operation Current AC 50/60 Hz DC www.idec.com 24V 48V 50V 110V 220V 440V AC-12 Control of resistive loads & solid state loads 10A — 10A 10A 6A 2A AC-15 Control of electromagnetic loads (> 72VA) 10A — 7A 5A 3A 1A DC-12 Control of resistive loads & solid state loads 8A 5A — 2.2A 1.1A — DC-13 Control of electromagnets 5A 2A — 1.1A 0.6A — USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-167 ø30mm - TWTD Series Oiltight Switches & Pilot Devices Non-Illuminated Pushbuttons (Assembled) Switches & Pilot Devices A4 Assembled Pushbuttons A B ( ) D 1 10 N - B Button Color B: Black G: Green R: Red S: Blue W: White Y: Yellow Function B: Momentary O: Maintained V: Pushlock Turn Reset Y: Push-Pull Contact Arrangement 10: 1NO 01: 1NC 20: 2NO 02: 2NC 11: 1NO-1NC 22: 2NO-2NC Bezel Shape Blank: Octagonal F: Full Shroud G: Mushroom Shroud P: Neoprene Boot Button Shape 1: Flush 2: Extended 3: Mushroom Ø 40mm 4: Jumbo Mushroom Ø 65mm Series Designation D: TWTD Series 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. Custom contact configurations available, contact IDEC for details. A4-168 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Non-Illuminated Pushbuttons (Assembled) con’t Part Numbers: Non-Illuminated Pushbuttons Style Flush Contacts Part Number Momentary Maintained ABD110N-➀ ABD101N-➀ ABD111N-➀ ABD120N-➀ ABD102N-➀ AOD110N-➀ AOD101N-➀ AOD111N-➀ AOD120N-➀ AOD102N-➀ Extended 1NO 1NC 1NO-1NC 2NO 2NC ABD210N-➀ ABD201N-➀ ABD211N-➀ ABD220N-➀ ABD202N-➀ AOD210N-➀ AOD201N-➀ AOD211N-➀ AOD220N-➀ AOD202N-➀ Extended with Neoprene Boot 1NO 1NC 1NO-1NC 2NO 2NC ABPD210N-➀ ABPD201N-➀ ABPD211N-➀ ABPD220N-➀ ABPD202N-➀ AOPD210N-➀ AOPD201N-➀ AOPD211N-➀ AOPD220N-➀ AOPD202N-➀ Recessed 1NO 1NC 1NO-1NC 2NO 2NC ABFD110N-➀ ABFD101N-➀ ABFD111N-➀ ABFD120N-➀ ABFD102N-➀ AOFD110N-➀ AOFD101N-➀ AOFD111N-➀ AOFD120N-➀ AOFD102N-➀ Extended with Full Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABFD210N-➀ ABFD201N-➀ ABFD211N-➀ ABFD220N-➀ ABFD202N-➀ AOFD210N-➀ AOFD201N-➀ AOFD211N-➀ AOFD220N-➀ AOFD202N-➀ 1NO 1NC 1NO-1NC 2NO 2NC ABD310N-➀ ABD301N-➀ ABD311N-➀ ABD320N-➀ ABD302N-➀ AOD310N-➀ AOD301N-➀ AOD311N-➀ AOD320N-➀ AOD302N-➀ Ø 40mm Mushroom Head with Full Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABGD310N-➀ ABGD301N-➀ ABGD311N-➀ ABGD320N-➀ ABGD302N-➀ AOGD310N-➀ AOGD301N-➀ AOGD311N-➀ AOGD320N-➀ AOGD302N-➀ Ø 65mm Jumbo Mushroom Head 1NO 1NC 1NO-1NC 2NO 2NC ABD410N-➀ ABD401N-➀ ABD411N-➀ ABD420N-➀ ABD402N-➀ AOD410N-➀ AOD401N-➀ AOD411N-➀ AOD420N-➀ AOD402N-➀ Ø 65mm Jumbo Mushroom Head with Shallow Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABGD410N-➀ ABGD401N-➀ ABGD411N-➀ ABGD420N-➀ ABGD402N-➀ AOGD410N-➀ AOGD401N-➀ AOGD411N-➀ AOGD420N-➀ AOGD402N-➀ Ø 65mm Jumbo Mushroom Head With Deep Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABFD410N-➀ ABFD401N-➀ ABFD411N-➀ ABFD420N-➀ ABFD402N-➀ AOFD410N-➀ AOFD401N-➀ AOFD411N-➀ AOFD420N-➀ AOFD402N-➀ Ø 40mm Mushroom Head www.idec.com A4 1. In place of ➀, specify the Button Color Code. 2. For sub-assembly part numbers, see next page. 3. For accessories, see page A4-188. 4. † Neoprene boot available only in Black (B), Green (G), Red (R) and Yellow (Y). ① Button Color Code Color Code Black B Green G Red R Blue S White W Yellow Y 1. 65mm Jumbo mushroom not available in white. 2. Neoprene boot is not available in blue or white. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-169 Switches & Pilot Devices 1NO 1NC 1NO-1NC 2NO 2NC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Non-Illuminated Pushbuttons (Sub-Assembled) Contact Block + Operator + Button + = Complete Part Part Number Part Numbers: Buttons and Lenses Style Switches & Pilot Devices A4 Part Numbers: Operators Style Momentary Maintained Part Number Flush Flush/Extended ABD1BN-① ABD-100 AOD-100 Extended ABD2BN-① Extended with Full Shroud ABFD-200 AOFD-200 Ø 40mm Mushroom Ø 40mm Mushroom/ Ø 65mm Jumbo Mushroom ABD3BN-① ABD-300 AOD-300 Ø 65mm Jumbo Mushroom Ø 40mm Mushroom with Full Shroud ABD4BN-① ABGD-300 AOGD-300 In place of ①, specify the Button Color Code. (See table previous page) Ø 65mm Jumbo Mushroom with Shallow Shroud ABGD-400 AOGD-400 Part Numbers: Contact Blocks Description Part Number 1NO Ø 65mm Jumbo Mushroom with Deep Shroud ABFD-400 AOFD-400 Dummy Block 1NC BST-010 BST-001 BST-010S BST-001S (early make) (late break) BST-D 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining BST-010S and BST-001S result in overlapping contacts. A4-170 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series E-Stops (Assembled) A4 Lamp Voltage (full voltage illuminated units only) Function V: Pushlock Turn Reset Y: Push-Pull 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120V AC/DC 240V: 240V AC/DC Illumination Blank: None L: Illuminated Series Designation D: TWTD Series Button/Lens Color A: Amber R: Red G: Green S: Blue Button/Lens Size 3: 40mm Mushroom Illuminated Circuit (illuminated unit only) 99: Full Voltage (lamp determines voltage) 126:120V AC Step Down Transformer 246: 240V AC Step Down Transformer 486: 480V AC Step Down Transformer W: White Y: Yellow Lamp Type (illuminated units only) Blank: Incandescent D: LED Contact Arrangement 10: 1NO 01: 1NC 20: 2NO 02: 2NC 11: 1NO/1NC 22: 2NO/2NC 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. Custom contact configurations available, contact IDEC for details. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-171 Switches & Pilot Devices Assembled E-Stops A V (L) D 3 (99) 11 (D) N - R - (24V) ø30mm - TWTD Series Oiltight Switches & Pilot Devices E-Stops (Assembled) Part Numbers: E-Stop Switches Style A4 Ø 40mm Pushlock Turn Reset Switches & Pilot Devices Non-Illuminated Ø 40mm Illuminated Pushlock Turn Reset Contacts Part Number 1NO 1NC 1NO-1NC 2NO 2NC AVD310N-R* AVD301N-R* AVD311N-R* AVD320N-R* AVD302N-R* 1NO-1NC 2NO 2NC AVLD39911➄N-R-➂* AVLD39920➄N-R-➂* AVLD39902➄N-R-➂* Transformer 1NO-1NC 2NO 2NC AVLD3 ➃ 11➄N-R* AVLD3 ➃ 20➄N-R* AVLD3 ➃ 02➄N-R* Non-Illuminated 1NO 1NC 1NO-1NC 2NO 2NC AYD310N-➀ AYD301N-➀ AYD311N-➀ AYD320N-➀ AYD302N-➀ Full Voltage 1NO-1NC 2NO 2NC AYLD39911➄N-➁-➂ ** AYLD39920➄N-➁-➂ ** AYLD39902➄N-➁-➂ ** Transformer 1NO-1NC 2NO 2NC AYLD3 ➃ 11➄N-➁ ** AYLD3 ➃ 20➄N-➁ ** AYLD3 ➃ 02➄N-➁** Full Voltage 1NO-1NC 1NC-1LB† AYLD229911➄N-➁-➂ -TK962 AYLD229902S➄N-➁-➂-TK962 Full Voltage 3 Position Push-Pull Contact Push Center Pull NC (BST-001) 0 0 X NC-LB (BST-001S) 0 X X NO (BST-010) X 0 0 NO-EM (BST-010S) X X 0 1. In place of ➀, specify the button color code 2. In place of ➁, specify the lens color code. 3. In place of ➂, specify the Full Voltage (lamp voltage) Code. 4. In place of ➃, specify the transformer voltage code. 5. In place of ➄, specify the Lamp Type code. 6. *Available in red only. 7. 3 position push-pull available in spring return to center only. 8. † The most common configuration for motor starting applications. 9. For accessories, see page A4-188. 10. For dimensions, see page A4-192. Ø 40mm Push-Pull Ø 40mm Push-Pull ① Button Color Code Ø 40mm Momentary Push-Pull (3-position) Transformer Part Numbers: Unibody E-Stops Style Ø 40mm Pushlock Turn Reset (available in Red only) 1NO-1NC 1NC-1LB† AYLD22 ➃ 11➄N-➁-TK962 AYLD22 ➃ 02S➄N-➁-TK962 Color Code Black B Amber A Green G Green G Red R Red R Blue S Blue S Yellow Y White W ➂ Full Voltage Code Contacts Part Number Voltage 6V AC/DC 6V 1NO-1NC 2NC HN1E-BV4F11-R* HN1E-BV4F02-R* 12V AC/DC 12V Code 1NO-1NC 2NC HN1E-LV4F11Q➄-R-➂ HN1E-LV4F02Q➄-R-➂ ➃ Transformer Voltage Codes Voltage Code 120VAC 240VAC 480VAC 24V AC/DC 24V Illuminated Ø 40mm Pushlock Turn Reset (available in Red only) 120V AC 120V 240V AC 240V (LED only) 126 246 486 Transformers step down to 6V. ➄ Lamp Type Code 1. * Available in Red only. 2. **Not available in blue. 3. In place of ➂, specify Full Voltage Code. 4. With single unit construction, the positive action contacts are integrated in the body of the switch. This provides an extra degree of safety and reliability for critical emergency stop functions. 5. For nameplates and accessories, see page A3-96. 6. For dimensions, see page A3-100. 7. For sub-assembly part numbers, see next page. 8. HN1E series E-stops comply with EN418, the IEC “E-Stop Addendum to the Low Voltage Directive,” this includes “tamper proof” operation whereby a change of contact state is not possible by “teasing” or “floating” the operator. A4-172 ➁ LED Color Codes Code Color www.idec.com Lamp Code Incandescent Blank LED D USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series E-Stops (Sub-Assembled) Transformer* + Operator + Lamp + Button/Lens = Complete Part A4 Part Numbers: Lamps Type Voltage LED Ø 40mm Pushlock Turn Reset AVD-300 Illuminated Ø 40mm Pushlock Turn Reset Incandescent AVLD3-0600N Ø 40mm Push-Pull AYD-3100 2 pos AYLD-0600 Illuminated Ø 40mm Push-Pull ① Button Color Code Part Number Color Code 6V AC/DC LSTD-6➁ Black B 12V AC/DC LSTD-1➁ Green G 24V AC/DC LSTD-2➁ Red R 120V AC LSTD-H2➁ Blue S 240V AC LSTD-M4➁ Yellow Y 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 120VAC L-120L 1. In place of ➁, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. Part Numbers: Contact Blocks Description All Control Units 3 pos ➁ LED Color Codes Color Code Amber A Green G Red R Blue S White W Part Number 1NO 1NC AYLD22TK962-0B01 Part Numbers: Buttons and Lenses Style Part No. Dummy Blocks Button for Pushlock Turn Reset E-Stop (Ø 40mm, red only) AVN3B-R Lens for Illuminated Pushlock Turn Reset E-Stop (Ø 40mm, red only) AVLN3LU-R BST-010 BST-001 BST-010S BST-001S (early make) (late break) BST-D 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining BST-010S and BST-001S result in overlapping contacts (remain on, or closed, when switch is moved between two positions). Part Numbers: Full Voltage Clips Primary Voltage (50/60Hz) Part Number Full Voltage Clips (2 req’d for each unit) APD-F Button for Push-Pull E-Stop (Ø 40mm) Lens for Illuminated Push-Pull E-Stop (Ø 40mm) AYD3BN-① 2 pos* AYLD3L-➁ 3 pos AYLD2L-➁ 1. In place of ①, specify the Button Color Code. (See table below) 2. In place of ➁, specify the LED Color Code. 3. *Not available in blue. www.idec.com Part Numbers: Transformers Primary Voltage Description (50/60Hz) Part Number 120V AC TWD-0126 240V AC TWD-0246 480V AC TWD-0486 6V secondary voltage (uses 6V lamp). USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-173 Switches & Pilot Devices *Not required for full voltage units (full voltage clips used instead). Part Numbers: Operators Style Part Number Oiltight Switches & Pilot Devices ø30mm - TWTD Series Pilot Lights (Assembled) Switches & Pilot Devices A4 Assembled Pilot Lights A P D 1 126 D N - R - ( Function P: Pilot Light ) Lamp Voltage (Full Voltage Only) 6V: 6V AC/DC 12V:12V AC/DC 24V:24V AC/DC 120V:120V AC 240V: 240V AC (LED only) Series Designation D: TWTD Series Lens Shape 1: Dome Rated Operational Voltage (Primary) Transformer Type Full Voltage Type 126:120V AC 99:Full Voltage 246:240V AC 486:480V AC Lens Color Code A: Amber G: Green R: Red S: Blue W: White Y: Yellow Lamp Type Blank: Incandescent Lamp D: LED Lamp Use only when interpreting part numbers. Do not use for developing part numbers. Part Numbers: LED and Incandescent Pilot Lights Style Operating Voltage Part Number Transformer Dome LED 120V AC 240V AC 480V AC APD1126DN-➁ APD1246DN-➁ APD1486DN-➁ Incandescent APD1126N-➁ APD1246N-➁ APD1486N-➁ Full Voltage Dome — APD199DN-➁-➂ 1. In place of ➁, specify the Lens/LED Color Code. 2. In place of ➂, specify the Full Voltage Code (lamp voltage). A4-174 www.idec.com APD199N-➁-➂ ➁ Lens Color Code Color Code Amber A Green G Red R Blue S White W Yellow Y ➂ Full Voltage Code Voltage Code 6V AC/DC 12V AC/DC 24V AC/DC 120V AC 240V AC (LED only) 6V 12V 24V 120V 240V USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Pilot Lights (Sub-Assembled) Transformer* + Operator + Lamp + Lens = Complete Part A4 Part Numbers: Operators Style Part Number Part Numbers: Full Voltage Clips Primary Voltage (50/60Hz) Part Number Full Voltage APD-F APD-199 Required for all full voltage models. Two pieces each. AC Adaptor/Transformer APD-006 Part Numbers: Transformers Primary Voltage Description (50/60Hz) Transformers The lens, lamp, and transformer/adaptor or the full voltage clips must be ordered separately. Part Numbers: Lenses Style Part Number Dome Lens Part Number 120V AC TWD-0126 240V AC TWD-0246 480V AC TWD-0486 6V secondary voltage (use 6V lamp). APN106L-➁ 1. In place of ➁, specify the Lens Color Code. 2. LED and incandescent lenses differ in shade only. Some colors have only one shade. Code Amber A Green G Red R Blue S LSTD-6➁ White W 12V AC/DC LSTD-1➁ Yellow Y 24V AC/DC LSTD-2➁ 120V AC LSTD-H2➁ 240V AC LSTD-M4➁ 6.3V AC/DC IS-6 12V AC/DC IS-12 6V AC/DC Incandescent Color Part Number Part Numbers: Lamps Type Voltage LED ➁ Lens/LED Color Code 24V AC/DC IS-24 120VAC, 1-8W L-120L 1. In place of ➁, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-175 Switches & Pilot Devices Note: Not required for full voltage units (full voltage clips used instead). Oiltight Switches & Pilot Devices ø30mm - TWTD Series Illuminated Pushbuttons (Assembled) Switches & Pilot Devices A4 Assembled Illuminated Pushbuttons A L ( ) D 2 126 11 (D) N - R - ( ) Function L: Momentary Action OL: Alternate Action Lamp Voltage (Full Voltage Only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V:120V AC 240V: 240V AC (LED only) Bezel Shape Blank: Octagonal F: Full Shroud Series Designation D: TWTD Series Lens Shape 2: Extended 3: Mushroom Ø 40mm Lens Color Code A: Amber G: Green R: Red S: Blue W: White Y: Yellow Rated Operational Voltage (Primary) Transformer Full Voltage Type 126:120V AC 99:Full Voltage 246:240V AC 486:480V AC Lamp Type Blank: Incandescent Lamp D: LED Contact Arrangement 20: 2NO 02: 2NC 11: 1NO-1NC 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. All transformers and AC Adaptors step down to 6V. A4-176 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Illuminated Pushbuttons (Assembled) con’t Part numbers: Illuminated Pushbuttons Style Extended Lens with Full Shroud Ø 40mm Mushroom Lens Momentary A4 Maintained Full Voltage 1NO-1NC 2NO 2NC ALD29911➄N-➁-➂ ALD29920➄N-➁-➂ ALD29902➄N-➁-➂ AOLD29911➄N-➁-➂ AOLD29920➄N-➁-➂ AOLD29902➄N-➁-➂ Transformer 1NO-1NC 2NO 2NC ALD2 ➃ 11➄N-➁ ALD2 ➃ 20➄N-➁ ALD2 ➃ 02➄N-➁ AOLD2 ➃ 11➄N-➁ AOLD2 ➃ 20➄N-➁ AOLD2 ➃ 02➄N-➁ Full Voltage 1NO-1NC 2NO 2NC ALFD29911➄N-➁-➂ ALFD29920➄N-➁-➂ ALFD29902➄N-➁-➂ AOLFD29911➄N-➁-➂ AOLFD29920➄N-➁ ➂ AOLFD29902➄N-➁-➂ Transformer 1NO-1NC 2NO 2NC ALFD2 ➃ 11➄N-➁ ALFD2 ➃ 20➄N-➁ ALFD2 ➃ 02➄N-➁ AOLFD2 ➃ 11➄N-➁ AOLFD2 ➃ 20➄N-➁ AOLFD2 ➃ 02➄N-➁ Full Voltage 1NO-1NC 2NO 2NC ALD39911➄N-➁-➂ ALD39920➄N-➁-➂ ALD39902➄N-➁-➂ AOLD39911➄N-➁-➂ AOLD39920➄N-➁-➂ AOLD39902➄N-➁-➂ Transformer 1NO-1NC 2NO 2NC ALD3 ➃ 11➄N-➁ ALD3 ➃ 20➄N-➁ ALD3 ➃ 02➄N-➁ AOLD3 ➃ 11➄N-➁ AOLD3 ➃ 20➄N-➁ AOLD3 ➃ 02➄N-➁ Switches & Pilot Devices Extended Lens Part Number Contacts 1. In place of ➁, specify the Lens Color Code. 2. In place of ➂, specify the Full Voltage Code (lamp voltage). 3. In place of ➃, specify the Transformer Voltage Code. 4. In place of ➄, specify the Lamp Type Code. ➁ Lens Color Codes Color Code ➂ Full Voltage Codes Voltage Code Amber A 6V AC/DC 6V Green G 12V AC/DC 12V Red R 24V AC/DC 24V Blue S 120V AC 120V White W 240V AC (LED only) 240 V Yellow Y ➃ Transformer Voltage Codes Voltage Code 120VAC 240VAC 480VAC 126 246 486 6V secondary voltage (uses 6V lamp). ➄ Lamp Type Code Lamp Code Incandescent Blank LED D www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-177 Oiltight Switches & Pilot Devices ø30mm - TWTD Series Illuminated Pushbuttons (Sub-Assembled) Transformer* + Contact Block + Operator + Lamp + Lens = Complete Part Switches & Pilot Devices A4 * Not required for full voltage types (full voltage types use APD-F full voltage clips). Part Numbers: Operators Part Number Style Part Numbers: Lamps Type Voltage Momentary Maintained LED Extended ALD-0600 AOLD-0600 Incandescent Extended with Full Shroud ALFD-0600 AOLFD-0600 40mm Mushroom ALD-0600 AOLD-0600 ➁ Lens/LED Color Codes Part Number 6V AC/DC LSTD-6➁ 12V AC/DC LSTD-1➁ Green G 24V AC/DC LSTD-2➁ Red R 120V AC LSTD-H2➁ Blue S 240V AC LSTD-M4➁ White W 6V AC/DC IS-6 Yellow Y 12V AC/DC IS-12 24V AC/DC IS-24 120VAC L-120L Mushroom lens not available in yellow. 1. In place of ➁, specify the LED Color code. 2. The LED contains a current-limiting resistor and a protection diode. All Control Units ALN06LU-➁ Dummy Blocks ALN3LU-➁ 1. In place of ➁, specify the Lens Color Code. 2. LED and incandescent lenses differ in shade only. Some colors have only one shade. Part Numbers: Full Voltage Clips Primary Voltage (50/60Hz) Part Number Full Voltage Clips (2 req’d for each unit) APD-F Required for all full voltage models. Part Number 1NO Extended Ø 40mm Mushroom Code A Amber Part Numbers: Contact Blocks Description Part Numbers: Lenses Style Part No. Color 1NC BST-010 BST-001 BST-010S BST-001S (early make) (late break) BST-D 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining BST-010S and BST-001S result in overlapping contacts (remain on, or closed, when switch is moved between two positions). Part Numbers: Transformers Primary Voltage Description (50/60Hz) Transformers Part Number 120V AC TWD-0126 240V AC TWD-0246 480V AC TWD-0486 6V secondary voltage (uses 6V lamp). A4-178 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Non-Illuminated Selector Switches (Assembled) A4 Key Selector (Non-illuminated) Switches & Pilot Devices Knob Selector (Non-illuminated) Lever Selector (Non-illuminated) Assembled Selector Switches A S D 2 ( ) ( ) 11 N - ( ) Function S: Selector Switch Circuit Number Series Designation D: TWTD Series Contact Arrangement Code 10: 1NO 01: 1NC 20: 2NO 02: 2NC 40: 4NO 04: 4NC 11: 1NO-1NC 22: 2NO-2NC (See Circuit # column of Selector Switch Contact Arrangement Chart on beginning on A4-185.) Number of Positions 2: 2-Position 3: 3-Position Spring Return Action Blank: Maintained 1: Spring return from Right 2: Spring return from Left 3: 2-Way spring return from Left and Right Operator Style Code Blank: Knob Operator L: Lever Operator K: Key Operator Use only when interpreting part numbers. Do not use for developing part numbers. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-179 Oiltight Switches & Pilot Devices ø30mm - TWTD Series Non-Illuminated Selector Switches (Assembled) con’t Mounting 1NO 1 2 O O X O 1NC 1 2 X O O O 1NO 1NC 1 2 O X X O 2NO 1 2 O O X X 2NC 1 2 X X O O 1 2 3 4 1 2 3 4 O X O X O O X X X O X O X X O O 2NO 2NC 2NO 2NC L R L R L Part Number Spring Return from Left L R R Knob Lever Key Knob Lever Key Knob Lever Key Knob Lever Key Knob Lever Key ASD210N ASD2L10N ASD2K10N ASD201N-116 ASD2L01N-116 ASD2K01N-116 ASD211N ASD2L11N ASD2K11N ASD220N ASD2L20N ASD2K20N ASD202N-104 ASD2L02N-104 ASD2K02N-104 ASD2110N ASD21L10N ASD21K10N ASD2101N-116 ASD21L01N-116 ASD21K01N-116 ASD2111N ASD21L11N ASD21K11N ASD2120N ASD21L20N ASD21K20N ASD2102N-104 ASD21L02N-104 ASD21K02N-104 ASD2210N ASD22L10N ASD22K10N ASD2201N-116 ASD22L01N-116 ASD22K01N-116 ASD2211N ASD22L11N ASD22K11N ASD2220N ASD22L20N ASD22K20N ASD2202N-104 ASD22L02N-104 ASD22K02N-104 Knob Lever Key ASD222N ASD2L22N ASD2K22N ASD2122N ASD21L22N ASD21K22N ASD2222N ASD22L22N ASD22K22N Knob Lever Key ASD222N-111 ASD2L22N-111 ASD2K22N-111 ASD2122N-111 ASD21L22N-111 ASD21K22N-111 ASD2222N-111 ASD22L22N-111 ASD22K22N-111 Mounting Part Numbers: Non-Illuminated 3–Position Selector Switches Style Part Number Part Number Part Number Part Number Operator Position Maintained Spring Return from Right Spring Return From Left Spring Return Two-Way Contact Switches & Pilot Devices A4 Contact Part numbers: Non-Illuminated 2–Position Selector Switches Style Part Number Part Number Operator Position Spring Return from Right Maintained 2NO 1 2 X O O O O X 2NC 1 2 O X X X X O 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 X O O X X X O O O O O O X O X O O X O X O O X X O X X O X O X O O O O O X X X X O X X O X O O X O X O X O X O X X O X O 2NO 2NC 2NO 2NC 2NO 2NC 4NO 4NC C L C R L L C C C R R L R L Knob Lever Key Knob Lever Key ASD320N ASD3L20N ASD3K20N ASD302N ASD3L02N ASD3K02N ASD3120N ASD31L20N ASD31K20N ASD3102N ASD31L02N ASD31K02N ASD3220N ASD32L20N ASD32K20N ASD3202N ASD32L02N ASD32K02N ASD3320N ASD33L20N ASD33K20N ASD3302N ASD33L02N ASD33K02N Knob Lever Key ASD322N ASD3L22N ASD3K22N ASD3122N ASD31L22N ASD31K22N ASD3222N ASD32L22N ASD32K22N ASD3322N ASD33L22N ASD33K22N Knob Lever Key ASD322N-309 ASD3L22N-309 ASD3K22N-309 ASD3122N-309 ASD31L22N-309 ASD31K22N-309 ASD3222N-309 ASD32L22N-309 ASD32K22N-309 ASD3322N-309 ASD33L22N-309 ASD33K22N-309 Knob Lever Key ASD322N-310 ASD3L22N-310 ASD3K22N-310 ASD3122N-310 ASD31L22N-310 ASD31K22N-310 ASD3222N-310 ASD32L22N-310 ASD32K22N-310 ASD3322N-310 ASD33L22N-310 ASD33K22N-310 Knob Lever Key ASD340N ASD3L40N ASD3K40N ASD3140N ASD31L40N ASD31K40N ASD3240N ASD32L40N ASD32K40N ASD3340N ASD33L40N ASD33K40N Knob Lever Key ASD304N ASD3L04N ASD3K04N ASD3104N ASD31L04N ASD31K04N ASD3204N ASD32L04N ASD32K04N ASD3304N ASD33L04N ASD33K04N R 1. The truth table indicates the operating position of contact block when the operator is switched to that position. X = On (closed contacts) O = Off (open contacts) X X = Overlapping Contacts: Remain on (closed contacts) when switch is moved between these two positions. 2. All knob and lever selector switches come in black. Other colors are available by ordering the knob or lever separately. 3. Custom contact arrangements available, see page A4-185 or call IDEC for details. A4-180 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Non-Illuminated Selector Switches (Sub-Assembled) Contact Blocks + Operator + Knob or Lever* + Color Insert* = Complete Part † A4 Switches & Pilot Devices 1. * Not needed with key type switches. 2. † Knob type shown. Part Numbers: Operators Appearance/ Description Position 2 Knob & Lever 2 3 3 2 Key 2 3 3 Part Number Maintained ASD200 Spring-Ret. from Right ASD2100 Spring-Ret. from Left ASD2200 Maintained, Cam 1 Maintained, Cam 2 ASD300-1 ASD300-2 Spring-Ret. from Right, Cam1 Spring-Ret. from Right, Cam 2 ASD3100-1 ASD3100-2 Spring-Ret. from Left, Cam 1 Spring-Ret. from Left, Cam 2 ASD3200-1 ASD3200-2 Spring-Ret. from L/R, Cam 1 Spring-Ret. from L/R, Cam 2 ASD3300-1 ASD3300-2 Maintained ASD2K00-RA Spring-Ret. from Right ASD21K00-RL Spring-Ret. from Left ASD22K00 Maintained, Cam 1 Maintained, Cam 2 ASD3K00-1-RA ASD3K00-2-RA Spring-Ret. from Right, Cam1 Spring-Ret. from Right, Cam 2 ASD31K00-1-RLC ASD31K00-2-RLC Spring-Ret. from Left, Cam 1 Spring-Ret. from Left, Cam 2 ASD32K00-1-RRC ASD32K00-2-RRC Spring-Ret. from L/R, Cam 1 Spring-Ret. from L/R, Cam 2 ASD33K00-1-RC ASD33K00-2-RC Part Numbers: Handles and Inserts Style Part Number Knob ASDHHY - ① Lever ASDHHL -① Color Insert TW-HC1 - ① In place of ①, specify the Color Code. Part Numbers: Contact Blocks Style 1. Order knobs, levers, color inserts separately (see below). 2. For key switches, keys are removable in all maintained positions. Other options available, contact IDEC for details. 3. See page A4-187 “Operator Truth Tables” for details of difference between cams. Part Number 1NO 1NC BST-010 BST-010S (early BST-001 BST-001S (late make) break) ① Color Codes Knob/Lever Color Code Black Blue Green Red Yellow White B S G R Y W Dummy Blocks BST-D 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining BST-010S and BST-001S result in overlapping contacts (remain on, or closed, when switch is moved between two positions). 1. Knob/Lever not available in white. 2. Color inserts not available in Black. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-181 ø30mm - TWTD Series Oiltight Switches & Pilot Devices Illuminated Selector Switches (Assembled) Switches & Pilot Devices A4 Assembled Illuminated Selector Switches A SL D 2 (2) 126 11 D N - 111 - R - 24 Lamp Voltage (Full Voltage Only) 6V: 6V AC/DC 12V:12V AC/DC 24V:24V AC/DC 120V:120V AC 240V: 240V AC (LED only) Function SL: Illuminated Selector Switch Series Designation D: TWTD Series Number of Positions 2: 2-Position 3: 3-Position Spring Return Action Blank: Maintained 1: Spring return from Right 2: Spring return from Left 3: 2-Way spring return from Left and Right Lens Color Code A: Amber G: Green R: Red S: Blue W: White Y: Yellow Rated Operational Voltage (Primary) Transformer Full Voltage Type 126:120V AC 99: Full Voltage 246:240V AC 486:480V AC Circuit Code Number See Circuit # column of Selector Switch Contact Arrangement Charts on page A4-185. Contact Arrangement 20: 2NO 02: 2NC 40: 4NO 04: 4NC 11: 1NO-1NC 22: 2NO-2NC Lamp Type Blank: Incandescent D: LED Use only when interpreting part numbers. Do not use for developing part numbers. A4-182 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Illuminated Selector Switches (Assembled) con’t Mounting L R L ➁ Lens/LED Color Codes Spring Return From Left L L R 1NO 1 1NC 2 O X X O transformer full voltage ASLD2 ➃11➄N-➁ ASLD29911➄N-➁-➂ ASLD21 ➃11➄N-➁ ASLD219911➄N-➁-➂ ASLD22 ➃11➄N-➁ ASLD229911➄N-➁-➂ 2NO 12 O O X X O X O X O O X X X X O O X O X O X X O O transformer full voltage transformer full voltage ASLD2 ➃20➄N-➁ ASLD29920➄N-➁-➂ ASLD2 ➃02➄N-104-➁ ASLD29902➄N-104-➁-➂ ASLD21 ➃20➄N-➁ ASLD219920➄N-➁-➂ ASLD21 ➃02➄N-104-➁ ASLD219902➄N-104-➁-➂ ASLD22 ➃20➄N-➁ ASLD229920➄N-➁-➂ ASLD22 ➃02➄N-104-➁ ASLD229902➄N-104-➁-➂ transformer full voltage ASLD2 ➃22➄N-➁ ASLD29922➄N-➁- ➂ ASLD21 ➃22➄N-➁ ASLD219922➄N-➁-➂ ASLD22 ➃22➄N-➁ ASLD229922➄N-➁-➂ 2NC 12 1 2NO 2 2NC 3 4 1 2NO 2 2NC 3 4 transformer full voltage ASLD2 ➃22➄N-11-➁ ASLD29922➄N-111-➁-➂ R ASLD21 ➃22➄N-111-➁ ASLD219922➄N-111-➁-➂ R ASLD22 ➃22➄N-111-➁ ASLD229922➄N-111-➁-➂ 2NC 2NO 2NC 2NO 2NC 2NO 2NC 4NO 4NC Mounting Contact 2NO 1 2 1 2 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 C L C R X O O X X O O X X X O O O O O O X O X O O X O X O O X X O O X X O X X O X O X O O O O O X X X X O X X O O X X O X O O X O X O X O X O X X O X O L Code Incandescent Blank LED D C R L Voltage A4 Code 6V AC/DC 12V AC/DC 24V AC/DC 120V AC 240V AC (LED only) 6V 12V 24V 120V 240V ➃Transformer Voltage Codes Voltage Code 126 246 486 6V secondary voltage (uses 6V lamps). Spring Return From Left Spring Return Two-Way C C L R A G R S W Y 120VAC 240VAC 480VAC Lamp Spring Return From Right Code Amber Green Red Blue White Yellow ➂ Full Voltage Codes ➄ Lamp Type Code Part Numbers: Illuminated 3–Position Selector Switches Style Operator Maintained Position Color R L R transformer full voltage transformer full voltage ASLD3 ➃ 20➄N-➁ ASLD39920➄N-➁-➂ ASLD3 ➃ 02➄N-➁ ASLD39902➄N-➁-➂ ASLD31 ➃ 20➄N-➁ ASLD319920➄N-➁- ➂ ASLD31 ➃ 02➄N-➁ ASLD319902➄N-➁-➂ ASLD32 ➃ 20D➄N-➁ ASLD329920D➄N-➁-➂ ASLD32 ➃ 02D➄N-➁ ASLD329902D➄N-➁-➂ ASLD33 ➃ 20D➄N-➁ ASLD339920D➄N-➁-➂ ASLD33 ➃ 02D➄N-➁ ASLD339902D➄N-➁-➂ transformer full voltage ASLD3 ➃ 22➄N-➁ ASLD39922➄N-➁-➂ ASLD31 ➃ 22➄N-➁ ASLD319922➄N-➁-➂ ASLD32 ➃ 22D➄N-➁ ASLD329922D➄N-➁-➂ ASLD33 ➃ 22D➄N-➁ ASLD339922D➄N-➁-➂ transformer full voltage ASLD3 ➃ 22➄N-309-➁ ASLD39922➄N-309-➁-➂ ASLD31 ➃ 22➄N-309-➁ ASLD319922➄N-309-➁-➂ ASLD32 ➃ 22D➄N-309-➁ ASLD329922D➄N-309-➁-➂ ASLD33 ➃ 22D➄N-309-➁ ASLD339922D➄N-309-➁-➂ transformer full voltage ASLD3 ➃ 22➄N-310-➁ ASLD39922➄N-310-➁-➂ ASLD31 ➃ 22➄N-310-➁ ASLD319922➄N-310-➁-➂ ASLD32 ➃ 22D➄N-310-➁ ASLD329922D➄N-310-➁-➂ ASLD33 ➃ 22D➄N-310-➁ ASLD339922D➄N-310-➁-➂ transformer full voltage ASLD3 ➃ 40➄N-➁ ASLD39940➄N-➁-➂ ASLD31 ➃ 40➄N-➁ ASLD319940➄N-➁-➂ ASLD32 ➃ 40➄N-➁ ASLD329940➄N-➁-➂ ASLD33 ➃ 40➄N-➁ ASLD339940➄N-➁-➂ transformer full voltage ASLD3 ➃ 04➄N-➁ ASLD39904➄N-➁-➂ ASLD31 ➃ 04➄N-➁ ASLD319904➄N-➁-➂ ASLD32 ➃ 04➄N-➁ ASLD329904➄N-➁-➂ ASLD33 ➃ 04➄N-➁ ASLD339904➄N-➁-➂ 1. In place of ➁, specify the Lens/LED Color Code, in place of ➂, specify the Full Voltage (lamp voltage) Code, in place of ➃, specify the Transformer Voltage Code and in place of ➄ specify the Lamp Type Code. 2. The truth table indicates the operating position of contact block when the operator is switched to that position. X = On (Closed Contacts) O = Off (Open Contacts) X X = Overlapping Contacts: Remain on (closed contacts) when switch is moved between these positions www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-183 Switches & Pilot Devices Contact Part Numbers: Illuminated 2–Position Selector Switches Style Operator Spring Return Maintained Position From Right Oiltight Switches & Pilot Devices ø30mm - TWTD Series Illuminated Selector Switches (Sub-Assembled) Transformer* + Contact Block + Operator + Lamp Lense = Complete Part Switches & Pilot Devices A4 *Not required for full voltage units (use APD-F full voltage clips instead). Part Numbers: Operators Appearance/ Description Positions 2 Operator 3 2 3 Part Number Maintained Maintained, Cam 1 Maintained, Cam 2 Spring-Ret. from Right Spring-Ret. from Left Spring-Ret. from Right, Cam 1 Spring-Ret. from Right, Cam 2 Spring-Ret. from Left, Cam 1 Spring-Ret. from Left, Cam 2 Spring-Ret. from L/R, Cam 1 Spring-Ret. from L/R, Cam 2 Knob ASLNHU - ➀ LED Incandescent Part Number 1NO Dummy Blocks 1NC BST-010 BST-001 BST-010S BST-001S (early make) (late break) BST-D 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining BST-010S and BST-001S result in overlapping contacts (make before break). Part Numbers: Lenses Style Part Number Part Numbers: Lamps Type Voltage ASLD200 ASLD300-1 ASLD300-2 ASLD2100 ASLD2200 ASLD3100-1 ASLD3100-2 ASLD3200-1 ASLD3200-2 ASLD3300-1 ASLD3300-2 Contact Blocks Description Part Numbers: Full Voltage Clips Primary Voltage (50/60Hz) Full Voltage Clips Part Number APD-F (2 req’d for each unit) Part Number 6V AC/DC LSTD-6➁ 12V AC/DC LSTD-1➁ 24V AC/DC LSTD-2➁ 120V AC LSTD-H2➁ 240V AC LSTD-M4➁ 6.3V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 120VAC L-120L 1. In place of ➁, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. Part Numbers: Transformers Primary Voltage Description (50/60Hz) Transformers Part Number 120V AC TWD-0126 240V AC TWD-0246 480V AC TWD-0486 6V secondary voltage ➁ Lens/LED Color Codes A4-184 www.idec.com Color Code Amber Green Red Blue White Yellow A G R S W Y USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Contact Arrangement Charts How to Read Contact Arrangement Charts To determine contact block mounting position, first make sure the selector switch is oriented as shown on the right Contact Arrangement Type and quantity of switch contacts L R 4 2 Operator Position * N/D = No designation Contact Block Mounting Position or mounting contact blocks on operator Truth table indicates the operating position of contact block when operator is switched to that position. 3 1 X = On (Closed Contacts) O = Off (Open Contacts) X X = Overlapping Contacts: Remain on (closed) when switch is moved between these two positions Contact Block Part Number Part number to use when ordering subassembly contact blocks, as required for use with corresponding mounting position Contact Arrangement Chart: 2-position Selector Switches Style Mounting Operator Contact Block Description Circuit Position Position Part Number Contact Number L R Operator Part Number Spring Ret. Spring Ret. Maintained from Rt. from Lt. L 1NO N/D 1NC 116 N/D 1NO 1NC 103 600 1NO-EM 1NC-LB 601 2NO N/D 2NC 104 N/D 2NO 2NC 110 111 4NO N/D www.idec.com 1 O X BST-010 2 O O BST-D 1 X O BST-001 2 O O BST-D 1 O X BST-010 2 X O BST-001 1 X O BST-001 2 O X BST-010 1 O X BST-010S 2 X O BST-001S 1 X O BST-001S 2 O X BST-010S 1 O X BST-010 2 O X BST-010 1 X O BST-001 2 X O BST-001 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 O X O X X O X O O O X X O O O O X O X O O X O X X X O O X X X X BST-010 BST-001 BST-010 BST-001 BST-001 BST-010 BST-001 BST-010 BST-010 BST-010 BST-001 BST-001 BST-010 BST-010 BST-010 BST-010 R L R L R Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-185 Switches & Pilot Devices Circuit Number A4 Oiltight Switches & Pilot Devices ø30mm - TWTD Series Contact Arrangement Chart: 3-Position Selector Switches Style Mounting Operator Contact Block Circuit Position Position Part Number Contact Number L C Description Maintained R C L Switches & Pilot Devices A4 202 203 1NO 1NC 302 303 N/D 2NO 301 304 2NC N/D N/D 210 2NO 2NC 308 309 310 N/D 4NO 305 N/D 4NC 314 Operator Part Number Spring Ret. Spring Ret. from Rt. from Lt. 1 X 0 0 BST-010 2 X X O BST-001 1 0 X X BST-001 2 O 0 X BST-010 1 X 0 X BST-010 2 X X O BST-001 1 0 X O BST-001 2 O 0 X BST-010 1 X 0 0 BST-010 2 O 0 X BST-010 1 X 0 X BST-010 2 O 0 X BST-010 1 0 X O BST-001 2 X X O BST-001 1 0 X X BST-001 2 X X O BST-001 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 X 0 0 X 0 0 0 0 X X X X X X 0 O 0 O 0 0 X 0 X 0 X 0 X 0 0 X 0 X 0 X 0 X 0 0 X X X 0 X 0 0 X 0 X 0 X X 0 X 0 X 0 0 0 0 0 0 0 0 0 X X X X X X X X 0 X X 0 X X X X X 0 X O X 0 O X O X O X 0 X 0 X X X X X X 0 X O O 0 O 0 BST-010 BST-010 BST-001 BST-001 BST-001 BST-010 BST-001 BST-010 BST-010 BST-001 BST-010 BST-001 BST-010 BST-001 BST-001 BST-010 BST-001 BST-010 BST-001 BST-010 BST-010 BST-010 BST-010 BST-010 BST-010 BST-010 BST-010 BST-010 BST-001 BST-001 BST-001 BST-001 BST-001 BST-001 BST-001 BST-001 C C R L Two-Way R L C R L R Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 1. Each operator sub-assembly is available as a “-1" and a “-2" for 3-position selector switches. The internal cam of a “-1" is different from that of a “-2". This results in designated combinations of open and closed contacts in the various operator positions. 2. N/D = No circuit number designation required in assembled part number. 3. X = On (closed contacts) O = Off (open contacts). X X Overlapping contacts remain on (closed) when switch is moved between these two positions. A4-186 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Operator Truth Tables Use the following tables to build custom selector switches. 2 Position Selector Switches Contact Operator Position Mounting Position BST-001 (NC) ASD200 BST-010S (NO-EM) BST-001S (NC-LB) A4 Right L O X R O X L X O R X O L 0 X R O X L X O R X O Switches & Pilot Devices BST-010 (NO) Left 3 Position Selector Switches Contact Left L X O O R O O X L O X X R X X O L X O O R O O X L O X X R X X O BST-010 (NO) ASD300-1 ASLD300-1 ASD3K00-1 BST-001 (NC) BST-010S (NO-EM) BST-001S (NC-LB) Contact Center Right Operator Position Mounting Position Left L X O R O O X L O X O R X X O L X O X R O O X L O X O R X X O BST-010 (NO) ASD300-2 ASLD300-2 ASD3K00-2 Operator Position Mounting Position BST-001 (NC) BST-010S (NO-EM) BST-001S (NC-LB) Center Right X 1. For Operator Truth Tables, see next page. 2. For examples of how to assemble selector switches, see A3-82. 3 Position Push/Pull Switches Contact BST-010 (NO) AYLD22 Operator Position Pull Normal Push O O X BST-001 (NC) X O O BST-010S (NO-EM) O X X BST-001S (NC-LB) X X O www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-187 ø30mm - TWTD Series Oiltight Switches & Pilot Devices Accessories — TWTD Series Lamp Removal Tool Tool used to install LED’s and incandescent lamps. Switches & Pilot Devices A4 Metal Bezel Replacement locking ring/bezel Plastic Bezel Standard octagonal units (chrome-pl.). OG-81 Extended, non-illuminated (chrome-pl.). OG-82 Extended, illuminated (chrome-pl.). OG-83L Jumbo Mushroom Shallow Shroud ABN4G Jumbo Mushroom Deep Shroud ABN4F Black plastic locking ring/bezel Used to cover and protect pushbuttons. Boot/Cover OR-55 OGP11B In place of ➀, specify neoprene Rubber Boot color: B (black), G (green), R (red), Y (yellow) OC-11 ➀ Flush units (clear plastic -40˚ to +60˚C). OC-121 Extended units (clear plastic -40˚ to +60˚C). OC-122 Plastic washer For nameplates or panels that should not be scratched. OGL-D1T Thrust washer/Anti-rotation ring for use with notched panel cutout. OGL-D1S Anti-Rotation Ring Mounting Hole Plug Plugs used to fill unused 30mm panel cutouts. Plastic with locking nut attached. OBP-11 Metal with locking nut attached OB-11 Grey rubber (-5˚ to +60˚C) OB-13 Terminal Tab Adaptor Tab #250 17/64" x 3/64" (6.35mm x 0.8mm): Single tab TW-FA1 Full Voltage Adaptor Used on all full voltage illuminated units. Two required per unit. (M3.5 screw and saddle) APD-F Lock Out Adaptor Used to provide lockout protection for TWTD pushbuttons and knob selectors. Ø 1-13/64" (30mm) OL-KL1 Replacement Keys Pair of Keys (#0) TW-SK A4-188 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Accessories con’t Part Numbers: Fingersafe Covers for TWTD Series Appearance Description Used with Part Number A4 N-VL2 N-VL3 N-VL4 Fingersafe terminal cover, for full voltage pilot lights, adds 3mm to overall depth APD199... full voltage pilot lights APD-PVL Fingersafe terminal cover, for contact blocks, adds 3mm to overall depth Non-Illuminated pushbuttons ABD..., and AOD... N-VL2 Fingersafe terminal cover, adds 1.5mm to overall depth Transformer pilot lights and illuminated units N-VL3 Fingersafe terminal cover, adds 4 mm to depth Full voltage illuminated pushbuttons N-VL4 Dimensions on page A4-192. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-189 Switches & Pilot Devices APD-PVL Oiltight Switches & Pilot Devices ø30mm - TWTD Series Nameplates — TWTD Series Part Numbers: Nameplates NAKD Ø1.19" (30.5mm) Emergency 1.95" (50mm) 2.24" (57.5mm) 1.85" (47.5mm) Switches & Pilot Devices Dimensions Ø1.19" (30.5mm) HNAV 1.95" (50mm) 2.03" (52mm) 1.56" (40mm) A4 NAQD 2.34" (60mm) NALD Ø1.19" (30.5mm) Ø1.19" (30.5mm) Stop 5mm Description Nameplate (blank) Part Number Part Number Part Number Black NALD-B NAKD-B NAQD-B Red NALD-R NAKD-R NAQD-R NALD-➀ NAKD-➀ NAQD-➀ Nameplate (engraved) Part Number HNAV-0 HNAV-27 “Emergency Stop” 1. Nameplates are made of 0.031" aluminum. Lettering is white letters engraved on black background. 2. In place of ➀, insert either the standard legend code from table below or custom engraving delimited by “ “. 3. HNAV available in yellow only. * Standard Legend Codes Pushbuttons Legend Code Legend AUTO CLOSE DOWN *EMERG.STOP FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 OPEN OUT RAISE RESET REVERSE RUN SLOW START *STOP STOP TEST UP I (Int’l On) O (Int’l Off) EMO Pushbuttons/Selector Switches Code Legend Code Legend 116 117 118 119 120 121 122 123 124 125 126 127 150 151 152 AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWER-RAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISE-LOWER 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN Code 216 217 218 219 220 221 222 223 Selector Switches Legend Code AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFF-WINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 1. *Available in Red as standard legend code 104 and 124. To order engraved nameplate and codes, add legend code to nameplate part number. Character height based on the number of characters, space and size of nameplate. Standard character size is 3/16". 2. Nameplates with standard legends are the same list price as blank nameplates. Special engravings, additional cost. To specify engraving instructions, use the Nameplate order form on next page. A4-190 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Nameplates Order Form — TWTD Series Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To insure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: IDEC Rep/Distributor Contact: Name: PO number (if known): Telephone: IDEC Rep/Distributor Phone: Fax & Email IDEC Rep/Distributor Fax & Email A4 Sample Letter Sizes 7/64” Letters: Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 13 characters. Engraving Location Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. ABCD 7/64” Letter Size 16 characters max (for 7/64” size letters) 1/8” Letter Size 13 characters max (for 1/8” size letters) 1/8” Letters: ABCD Qty 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 NAKD Nameplate Step 1. 1/8” Letter Size Only Specify Lettering Write your lettering in box to the right. Maximum 17 characters per line, maximum 4 lines. Engraving Location Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Sample Letter Size 1/8” Letters: A B C D Qty NAQD Nameplate Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 16 characters. Engraving Location 1 Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. www.idec.com 2 3 4 5 7/64” Letter Size 20 characters max (for 7/64” size letters) 1/8” Letter Size 16 characters max (for 1/8” size letters) 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Sample Letter Sizes 7/64” Letters: A B C D Qty 1/8” Letters: A B C D USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-191 Switches & Pilot Devices NALD Nameplate Oiltight Switches & Pilot Devices ø30mm - TWTD Series Dimensions — TWTD Series Pushbutton ø40 ø35 ø25 5.5 23 40 53 (1 or 2 blocks) 9 14.5 76 (3 or 4 blocks) Mushroom Pushbutton w/Full Shroud Panel Thickness 0.8 to 7.5 ø40 M3.5 Terminal Screw B 5.5 23 Dimension A Dimension B Flush Extended Extended w/Full Shroud 0.351" (9mm) 0.566" (14.5mm) 0.663" (17mm) Ø 0.975" (25mm) Ø 0.975"(25mm) Ø 1.11" (28.5mm) Mushroom Mushroom w/Full Shroud Jumbo Mushroom Ø 1.56" (40mm) 0.858" (22mm) 0.936" (24mm) 1.13" (29mm) Ø 1.56" (40mm) Ø 1.87" (48mm) Ø 2.54" (65mm) Mushroom, Pushlock Turn Reset and Push-Pull Ø 1.56" (40mm) *0.975" (25mm) **0.975" (25mm) Ø 1.56" (40mm) Ø 1.56" (40mm) Note: *Dimension when operator is in reset position. **Dimension when operator is in pull position. 40 53 (1 or 2 blocks) A 76 (3 or 4 blocks) Illuminated Pushbuttons M3.5 Terminal Screw Full Voltage ø24 ø40 ø35 B Panel Thickness 0.8 to 7.5 M3 Terminal Screw 5.5 23 40 40 9 9 Dimension B Ø 0.936" (24mm) Ø 0.936" (24mm) Extended w/Full Shroud 0.741" (19mm) 0.761" (19.5mm) Ø 0.936" (24mm) Ø 0.936" (24mm) Ø 1.56" (40mm) Mushroom Pushlock Turn Reset, Push-Pull *0.975" (25mm) **0.975" (25mm) Ø 1.56" (40mm) Ø 1.56" (40mm) Pilot Lights Full Voltage ø25 *Dimension when operator is in reset position. **Dimension when operator is in pull position. A:29.5 B:64.5 Selector Switches Knob Panel Thickness 0.8 to 7.5 90° 5.5 23 53 (1 or 2 blocks) 5.5 40 45° 21 76 (4 blocks) 5.5 40 21.5 90° M3.5 Terminal Screw 45° 45° ø40 23 53 (1 or 2 blocks) 76 (4 blocks) 40 22 Panel Thickness 0.8 to 7.5 90° M3.5 Terminal Screw 45° ø40 45° ø35 M3.5 Terminal Screw 9 Key Lever Panel Thickness 0.8 to 7.5 Panel Thickness: 0.8 to 7.5 mm 45° 23 9 53 (1 or 2 blocks) 16.5 ø40 Note: M3.5 Terminal Screw M3.5 Terminal Screw ø40 0.975" (25mm) 0.995" (25.5mm) Flush w/Full Shroud ø35 Dimension A ø35 Illuminated Pushbuttons 24 63 (2 blocks) 86 (4 blocks) A 97.5 (2 blocks) 120.5 (4 blocks) ø40 Panel Thickness 0.8 to 7.5 M3 Terminal Screw ø35 M3.5 Terminal Screw w/AC Adapter w/Transformer ø35 40 38 76 (4 blocks) Illuminated Knob Panel Thickness 0.8 to 7.5 (including nameplate) 5.5 90° 4 5° 45 ° ø40 M3 Terminal Screw ø35 M3.5 Terminal Screws ø25 Switches & Pilot Devices A4 Pushbuttons Panel Thickness 0.8 to 7.5 M3.5 Terminal Screw 40 23 63 (2 blocks) 9 A: 86 (4 blocks) B: 97.5 (2 blocks), 120.5 (4 blocks) A4-192 28 www.idec.com All measurements in mm. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø30mm - TWTD Series Dimensions — TWTD Series con’t Selector Switches Panel Cut-Out Ø 0.195"(5mm) 1. *Jumbo Mushroom < 2.61" (66mm) 2. Minimum mounting centers are applicable to switches with one stack of contact blocks. When mounting two stacks of contact blocks, minimum centers should allow for access to wiring. 3. The Ø 0.195" (Ø 5mm) recess is necessary when either the nameplate or anti-rotation ring is used. Ø 1.20" (30.5mm) > 1.95" (50mm)* 0.33" (8.4mm) Cut-out is the only difference between TW and TWTD 3.66" (93mm) 2.76" OGL-31 Anti-Rotation Ring OC-31 Pushbutton Clear Boot 3.25" (82.5mm) 1.18" (30mm) (70mm) 1.76" 0.398" (10.2mm) Ø1.27" (Ø32.6mm) Accessory Dimensions OL-KL1 Lock-Out Adaptor Ø1.07" (Ø27.4mm) Flush: 0.702" (18mm) Extended: 0.858" (22mm) (44.8mm) 3.66" (2.62mm) 0.31" 1.97" (50mm) OB-31 Mounting Hole Rubber Plug (8mm) 1.16 Ø0.858" (22mm) (29.5mm) 0.137" (3.5mm) Ø1.13" (Ø29mm) 0.137" (3.5mm) Ø0.975" (Ø25mm) Finger-Safe Cover N-VL3 N-VL2 N-VL4 0.68" (17.2mm) N-VL2 0.61" (15.5MM) 1.51" (38.4MM) N-VL3 0.94" (24mm) 0.19" (4.7mm) 0.41" (10.5mm) 1.71" (18MM) 1.5" (38mm) 0.06" (1.4mm) 0.55" (14mm) 1.51" (38.4mm) 0.26" (6.5mm) N-VL4 ( R 0. 3 . 13 2M " M ) 0.87" (22mm) 0.71" (18mm) 0.94" (24MM) ( 6 0.2 . 2 4" m m ) 1.22" (31mm) (6 0.2 .2 4" m m ) 1.20" (30.4mm) 0.63" (16mm) APD-PVL .413" (10.5mm) .354" (9mm) 1.45" (37mm) 2m m) (6 . 1.26" (32mm) APD-PVL 6" 1.73" (44mm) .25 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A4-193 Switches & Pilot Devices 1.64" (42mm) A4 Oiltight Switches & Pilot Devices ø30mm - TWTD Series Instructions — TWTD Series Adjustment for Panel Thickness Switches & Pilot Devices A4 Each unit is shipped with several waterproof gaskets which are 0.06" (1.5mm) and 0.12" (3mm) thick. Combine the gaskets for a dimension approximately equal to panel thickness and install between the bezel and the body of the unit. Installation of LED Illuminated Units—Transformer units are recommended for use in areas subjected to inductive noise. When using full voltage types, install a protection diode as shown below. Use diode with AC power supply to protect against reverse polarity. Use with DC power supply to protect against surges and noise. Terminal X1 A trim washer must be used with a thrust washer or a nameplate to prevent the control unit from rotating in the mounting hole. When using anti-rotation rings (trim washer with thrust washer or nameplate), install as shown below. LED Terminal X2 Diode Make sure that LED illuminated units are installed with correct polarity, as indicated at the terminals. Application Example For Push-To-Test Pilot Light A typical application of illuminated pushbuttons is a push-to-test pilot light which can be used to check the lamp/LED circuit. Thrust Washer Panel Cut-Out Unit Trim Washer Transformer/AC-Adapter Circuit Nameplate Start Stop M2 C L NC M2 NO T Selector Switches Test Pilot Light The operator shaft of each unit has a recess to identify in which direction to install the handle. Align the handle with the recess. Press color insert (TWHC1) into the Standard Operating Positions. L Full Voltage Circuit Standard operation positions 2-Position, 90° 3-Position, 45° Start OLS Stop M 1 0 2 1 L 2 L M Non-Illuminated 3-Position Operators 1 0 1 2 0 NO T 1 C NC Test Pilot Light 0 2 2 Installation of TWTD Series Units TWTD Pilot Lights TWTD Illuminated Pushbuttons, TWTD Selector Switches (Transformer or Full Voltage) Terminal X1 = Positive Terminal X2 = Negative A4-194 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC
ASD33K20N 价格&库存
很抱歉,暂时无法提供与“ASD33K20N”相匹配的价格&库存,您可以联系我们找货
