BNC520
BNC520
    IDEC(日本和泉)
BNC520 数据手册
Terminal Blocks BNH/BN Terminal Blocks BNH/BN Series • • • • Display Lights UL Recognized File No. E78117 Touch-down terminals with spring-loaded captive screws Jumpers available up to 30A model Fuse block with or without blown-fuse indicator in neon or LED Mount on 35mm standard DIN rail File No. R9551701 J9551516 (power blocks) R9650688 (dual-deck blocks) CSA Certified File No. LR64803 Switches & Pilot Lights Key features of the BNH/BN series include: Specifications Part Numbers BNH10W BNH15MW BNH15LW BNH30W Relays & Sockets Appearance Width 0.275” (7mm) 0.315” (8mm) 0.413” (10.5mm) 0.472” (12mm) Approvals UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV 1 1 1 1 Wire Sizes 22 to 16 AWG 22 to 14 AWG 22 to 14 AWG 18 to 10 AWG 600V / 10A 600V / 10A 600V / 15A 600V / 30A M3 M3 M3.5 M4 Voltage/Current Terminals Size Type Mounting Terminal Torque (N-m) (in-lbs.) End Plate Touch-down Touch-down 35mm DIN rail 35mm DIN rail 0.6 - 1.0 0.6 - 1.0 1.0 - 1.3 1.4 - 2.0 5.3 - 8.9 5.3 - 8.9 8.9 - 11.5 12.4 - 17.8 BNE15W BNE15W BNE15W BNE30W BNL-5 BNL-5 BNL-5 BNL-5 BNC230 BNC230 BNC230 BNC230 PVC BNM7 BNM7 BNM7 BNM7 Fiberglass BNM9 BNM9 BNM9 BNM9 Dust Cover Marking Strip Touch-down 35mm DIN rail BNM3 BNM3 BNM3 BNM3 Ring Terminal Jumpers End clip BNJ16 BNJ26W BNJ46 BNJ56 Fork Terminal Jumpers BNJ16F BNJ26FW BNJ46F BNJ56F Terminal Blocks DIN Rail Stop Touch-down 35mm DIN rail Timers No. of Poles USA: 800-262-IDEC Canada: 888-317-IDEC Circuit Breakers 1. BNDN1000 aluminum DIN rails are available in 1 meter lengths. 2. Marking strips are available in 1 meter lengths. 3. Jumpers are available in groups of six. 4. Remove the “H” in the terminal block part number for standard screw type (ex. BNH10W becomes BN10W). 861 Terminal Blocks BNH/BN Terminal Blocks Switches & Pilot Lights Specifications, continued Part Numbers Display Lights Approvals BN150W BNDH15W 0.610” (15.5mm) 0.787” (20mm) 1.024” (26mm) 0.315” (8mm) UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV UL, CSA, TUV No. of Poles 1 1 1 2 Wire Sizes 16 to 6 AWG 16 to 4 AWG 16 to 0 AWG 22 to 14 AWG 600V / 50A 600V / 75A 600V / 150A 600V / 10A M5 M6 M8 M3 Voltage/Current Terminals Size Type Mounting Terminal Torque Relays & Sockets BN75W Appearance Width (N-m) (in-lbs.) End Plate DIN Rail Stop Touch-down Hex bolt Hex bolt Touch-down 35mm DIN rail 35mm DIN rail 35mm DIN rail 35mm DIN rail, surface 2.6 - 3.7 3.9 - 5.4 10 - 13.5 0.6 - 1.0 23.1 - 32.8 34.6 - 47.9 88.8 - 119.8 5.3 - 8.9 BNE50W BNE75W BNE150W BNDE15W BNL-5 BNL-6 BNL-6 BNL-8 BNC320 BNC420 BNC520 BNC230 (top level) BNC240 (bottom Level) PVC BNM7 BNM7 BNM7 BNM7 Fiberglass BNM9 BNM9 BNM9 BNM9 End clip BNM3 BNM3 BNM3 BNM3 Dust Cover Marking Strip Timers BNH50W Connecting Rods — — — BNR1 10.34” (265mm) BNR2 19.69” (500mm) Connecting Nuts — — — BNN1 (2 pieces) Base Mount Brackets — — — BNDL2 Ring Terminal Jumpers — — — BNJ26 Fork Terminal Jumpers — — — BNJ26FW Circuit Breakers Terminal Blocks 1. BNDN1000 aluminum DIN rails are available in 1 meter lengths. 2. Marking strips are available in 1 meter lengths. 3. Jumpers are available in groups of six. 4. Remove the “H” in the terminal block part number for standard screw type (ex. BNH50W becomes BN50W). 862 www.idec.com Terminal Blocks BNF Fuse Blocks Specifications, continued BNF10SW BNF10NW BNF10DW 0.591” (15mm) 0.591” (15mm) 0.591” (15mm) None Neon (100–300VAC) LED (24V DC) UL, CSA UL, CSA UL, CSA 1 1 1 Switches & Pilot Lights Part Numbers Appearance Width Blown Fuse Indicator No. of Poles Wire Sizes 18 to 10 AWG 18 to 10 AWG 18 to 10 AWG 600V/10A maximum 600V/10A maximum 600V/10A maximum Size M4 M4 M4 Type Standard screw Standard screw Standard screw 35mm DIN rail 35mm DIN rail 35mm DIN rail Voltage/Current Terminals Mounting 1.4 - 2.0 1.4 - 2.0 1.4 - 2.0 12.4 - 17.8 12.4 - 17.8 12.4 - 17.8 End Plate BNE20 BNE20 BNE20 DIN Rail Stop BNL-5 BNL-5 BNL-5 Dust Cover Marking Strip Applicable Fuse Size — — — BNM7 BNM7 BNM7 1/4” x 1-1/4” (6.35 x 31.8mm) 1/4” x 1-1/4” (6.35 x 31.8mm) 1/4” x 1-1/4” (6.35 x 31.8mm) Relays & Sockets (N-m) (in-lbs.) Terminal Torque Display Lights Approvals 1. BNDN1000 aluminum DIN rails are available in 1 meter lengths. 2. Fuses not included. Timers Terminal Blocks Circuit Breakers USA: 800-262-IDEC Canada: 888-317-IDEC 863 Terminal Blocks BNF Fuse Blocks BNH Series Part No. Diagrams BNH15MW BNH10W 38 18 38 18 10.3 7 11.3 8 6.7 5 max. 3.3 min. BNH30W 38 19.4 14.3 10.5 8.5 15.8 12 9.6 9.5 max. 6 max. 31.4 25.4 33.5 29.5 23.5 4 min. 5 max. ø4.2 min. When using C Rail: 44 36.5 ø3.6 min. 8.5 max. When using DIN Rail: 38 38 18 When using C Rail: 41 6.6 max. 29.5 23.5 3.3 min. When using C Rail: 41 33.5 29.5 23.5 5 max. When using 35-mmD IN Rail: 35 5.8 max. BNH15LW BNH15LW BNH30W ø3.2 min. ø3.2 min. 33.5 When using C Rail: 41 BNH10W BNH15MW When using DIN Rail: 35 5.9 When using DIN Rail: 35 Display Lights Switches & Pilot Lights Dimensions 4.5 min. 18 15.5 13 ø5.2 min. 12.8 max. 42.5 6.5 max. 34.3 28.3 BNH50W When using C Rail: 50 48 24.4 When using DIN Rail: 44 Relays & Sockets BNH50W 4.5 min. BN Series Part No. Diagrams BN75W BN150W 22.5 20 17 74 63 33 6 min. 31.7 25.7 8.5 max. Part No. 864 10 min. BND15W 62 38 18 5 min. 6.6 max. 55.5 49.5 33 27 5.2 max. 12 8 6.7 ø3.2 min. 59.5 ø4.2 min. 11.3 max. When using 35-mm DIN Rai: 61 Whem using C Rail: 67 17.5 15 13 63 43 5 max. 8 Circuit Breakers BNDH15W 11 max. Diagrams BNF10SW/BNF10NW/BNF10DW When using C Rail: 59.5 52 BNF10SW BNF10NW BNW10DW 22.8 max. 35 29 16.8 max. 29.8 26 23 ø8.5 min. When using DIN Rail: 52 When using C Rail: 50 50.5 ø6.2 min. 42.5 When using C Rail: 50 When using DIN Rail: 44 BN75W BN150W When using DIN Rail: 53.5 Terminal Blocks Timers 53 26 www.idec.com 3.3 min. Terminal Blocks Accessories Switches & Pilot Lights Accessories Part Numbers: End Plates, DIN Rail Stops, Stand-Offs, DIN Rail and Dust Covers Description Appearance Use with Part No. Remarks BNH10W BNH15MW BNE15W BNH15LW BNH30W BNE30W BNF10SW End Plates BNF10NW BNE20 Display Lights BNF10DW BNH50W BNE50W BN75W BNE75W BN150W BNE150W BNDH15W BNDE15W BNH10W BNH15MW BNH15LW BNH30W Relays & Sockets BNH50W BNF10SW BNF10NW BNL5 (small) 1. DIN rail stops prevent side-to-side movement. 2. The BNL-5 width is 0.375” (9mm). BN75W BN150W BNL6 (medium) 1. DIN rail stops prevent side-to-side movement. 2. The BNL-6 width is 0.375” (9mm). 3. To firmly stabilize these higher profile terminal blocks, the BNL-6 has a higher profile than the BNL-5. BNDH15W BN200NW# BN400NW# BNL8 (large) 1. DIN rail stops prevent side-to-side movement. 2. The BNL-8 width is 0.571” (14.5mm). 3. # = number of poles. BNS3 1.46” (37mm) height BNS4 3.03” (77mm) height BNDN1000 (length 39.37” (1mm) 1. For calculating the rail lengths required, see the instructions on page 876. 2. The DIN rail material is aluminum. BNF10DW BA111T BA211T DIN Rail Stops BA311T BA411S BAF111SU Terminal Blocks Timers BAF111SDU DIN Rail Stand-Offs All series DIN Rail All series BNDH15W BNH10W BNH15MW BNC230 Circuit Breakers BNH15LW Dust Covers 870 BNH30W BNH50W BNC320 BN75W BNC420 BN150W BNC520 BN200 BAC820 BN400 BNC1000 www.idec.com The overall length is 39.37” (1,000mm). The material is polycarbonate (UL94-V2). Terminal Blocks Accessories Accessories, continued Switches & Pilot Lights Part Numbers: Rods, Nuts, Marking Strips, Dust Covers, and Jumpers Description Appearance Marking Strips Use with Part No. Material: polyvinyl chloride (PVC) Strip dimensions are 0.37”x39” (9.5 x 1,000mm). BNM9 Material: fiberglass Strip dimensions are 0.37”x39” (9.5 x 1,000mm). All series BNM3 Used to prevent marking strips from sliding out. BNH10W BNJ16 Ring Terminal Jumpers Surface Mount Bracket BNH15MW BNJ26W BNH15LW BNJ46 BNH30W BNJ56 BNDH15W BNJ26W Jumpers come standard with 6 points. BNH10W BNJ16F BNH15MW BNJ26FW Note: insulated jumpers available - add “B” to end of part number. For example, BNJ26WB. BNH15LW BNJ46F BNH30W BNJ56F BNDH15W BNJ26FW BNDH15W (dual-deck) BNDL2 Relays & Sockets Fork Terminal Jumpers Display Lights BNM7 All series Marking Strip Fastener Remarks Used to surface mount dual-deck terminal blocks. (BNDL2). BNDH15W Connecting Nuts BNR1 BNR2 Terminal Block Removal Tool BNR2 (500mm) BNN1 1. Rod and connecting nuts are used to mount dual-decks collectively. 2. Each connecting nut set includes 1 hex connecting nut and 1 round connecting nut. 3. The BNR1 rod dimensions are 0.027 “x 10.43” (0.7 x 265mm). 4. The BNR2 rod dimen-sions are 0.027” x 19.69” (0.7 x 500mm). Terminal Blocks M4 Thread Rod Timers BNR1 (265mm) BND2 For accessory dimensions, see page 872. Circuit Breakers USA: 800-262-IDEC Canada: 888-317-IDEC 871 Terminal Blocks Accessories Switches & Pilot Lights Dimensions Dimensions: DIN Rail Part No. Diagrams 1000mm (39.37in) 12.50mm 35.00mm Display Lights BNDN1000 25.18mm 3.80mm 31.00mm 10.50mm 51.00mm 41.00mm Dimensions: Jumpers BNH Series Diagrams BNJ16F (fork) BNJ16 1.4 0.8 Timers Insulation Terminal Blocks Circuit Breakers www.idec.com 2 4.5 Insulation 60 (6-pole) 0.8 4.2 9.3 12 .1 R2 1.4 0.8 1.7 1.4 9.5 5.8 12 2 9.3 0.8 ø4 . 1.4 Thickness + 0.8mm (0.0315”) 872 11 11 2 10.5 4.2 9.5 2.8 Insulation 8.2 R2 .1 0.8 BNJ56W (fork) 60 (6-pole) 6 5.5 BNJ56 2.8 0.8 11 4.5 1.4 2 . ø4 1.4 3.7 Insulation 52.5 (6-pole) 5.5 10.5 11 8.2 8 R1 6.4 .8 5 0.8 4.5 11 4 Insulation BNJ46F (fork) 52.5 (6-pole) 40 (6-pole) 1.4 6 BNJ46 8 6.4 ø3. 7 4.5 3.7 R1 3.7 .85 2 Insulation BNJ46 BNJ46F (fork) BNJ56 BNJ56F (fork) BNJ26FW (fork) 40 (6-pole) 7 1.7 5.7 2 1.4 0.8 7 5.7 ø3.7 11 BNJ16 BNJ16F (fork) BNJ26W BNJ26FW (fork) BNJ26W 35 (6-pole) 35 (6-pole) 4 Relays & Sockets Part No. Insulation Insulation Terminal Blocks Accessories Dimensions, continued Switches & Pilot Lights Dimensions, DIN Rail Stops and Stand-offs Part No. Dimensions BNL-6 45 9 BNL-6 shown, BNL-5 same except without back crossbar Display Lights BNL-8 46 14.4 Relays & Sockets 30 BNDL2 26 38 13 36.7 2-ø5.2 12.5 BNS3 54 26 15 30 Timers 25° 2.6 2-M5 15 28 12.5 BNS3 76.7 2-ø5.2 54 15 26 28 15 2.6 2-M5 Terminal Blocks BNS4 30 12.5 25° 12.5 BNS4 Circuit Breakers USA: 800-262-IDEC Canada: 888-317-IDEC 873 Terminal Blocks Accessories Switches & Pilot Lights Dimensions, continued Dimensions: End Plates Part No. Dimensions Part No. Dimensions 38 53 BNE15W Display Lights BNE75W 5 5 74 Relays & Sockets 63 BNE20 BNE150W 5 3 62 Timers 38 BNDE15W Circuit Breakers Terminal Blocks BNE30W 5 48 BNE50W 5 874 www.idec.com Terminal Blocks Instructions Instructions Switches & Pilot Lights Wiring Touch-Down Terminal Blocks: BNH Series Instructions Step 1 Step 2 Step 3 Step 4 Display Lights Step 1. Insert the wire (or crimping terminal) into the terminal block with the terminal screws in the open position. (Use of crimping terminals is optional.) Step 2. Push the terminal screw down to hold the wire in place. Step 3. Hold the terminal screw down, and tighten with a screwdriver. Step 4. To remove the wire, loosen the terminal screw and pull up until wire is released. Installation and Removal of Terminal Blocks Instructions Appearance Relays & Sockets Step 1. Slide the terminal blocks onto the DIN rail from one end. Step 2. Use BNL5 or BNL6 end clips to secure the terminal block row and to prevent side-to-side movement. BNH10W, BNH15MW, BNH15LW, and BNH30W can be installed from the middle of a DIN rail. Step 3. To install, place the terminal block on top of the DIN rail and push down until both edges of the terminal block snap onto the DIN rail. Step 4. To remove the terminal block, use the BND2 removal tool as shown on the right. Removal Tool BND2 Instructions Timers Mounting Double-Deck Terminal Blocks Appearance DIN Rail Mount: Step 1. First install the end plate. Then mount the terminal blocks onto the DIN rail. Step 2. To prevent side-to-side movement on the DIN rail, use the BNL-8 mounting clip at both ends of the rail. End Plate Connecting Nut (hex) Terminal Blocks Panel Mount: Step 1. Assemble a row of terminal blocks with end plates on exposed end(s). Step 2. Use BNDL2 mounting clips at both ends of a row. Step 3. With the two holes of the mounting clip aligned with the terminal block holes, insert a connecting rod through each hole. Step 4. Secure the ends of the connecting rods with the connecting nuts, as shown below. Terminal Block Connecting Nut (round) Mounting Clip Connecting Rod Mounting Clip Circuit Breakers USA: 800-262-IDEC Canada: 888-317-IDEC 875 Terminal Blocks Instructions Display Lights Switches & Pilot Lights Calculating DIN Rail Lengths Instructions Appearance BN150W BNE150W BN100W BNT20 BN75W BNF10S BN50W (BNH50W) BNE20 BN40W (BNH40W) Step 1. Add widths of all terminal blocks (reference pages 864 through 869). Step 2. Add the endplate thickness (usually only one). Step 3. Add the DIN rail stop widths (usually two are used). Step 4. Round to the nearest 2” (50mm) increment to allow for DIN rail hole spacing. Step 5. Add 1” (25mm) to ensure 0.5” (12.5mm) of clearance at each end of the DIN rail. BN400BW2 (BN400NW2) BN30W (BNH30W) BN300BW2 (BN300NW2) BN15LWT (BNH15LWT) BN15LW (BNH15LW) BN200BW2 (BN200NW2) BN15MWT (BNH15MWT) BN15MW (BNH15MW) BN10W (BNH10W) 12.5 13 8.5 12 6.7 6 9.6 7 8 12 14 15.5 17 23 23 13 13 20 26 26 5 15 15 33 40 78 (2P) 115 (3P) 152 (4P) 92 (2P) 136 (3P) 180 (4P) 52 119 (2P) 176 (3P) 233 (4P) 3 10.5 L 2 (Mounting Centers) L1 (Rail Length) Relays & Sockets DIN Rail Stop Dimensions Part No. Width BNL-5 .374” (9mm) BNL-6 .374” (9mm) BNL-8 .571” (14.5mm) Torque Specifications Screw Size M3 M3.5 M4 M5 M6 M8 M10 M12 (N-m) 0.6 to 1.0 1.0 to 1.3 1.4 to 2.0 2.6 to 3.7 3.9 to 5.4 10 to 13.5 21 to 28 38 to 49 (kgf-cm) 6.1 to 10.2 10.2 to 13.3 14.3 to 20.4 26.5 to 37.7 39.8 to 55.1 102 to 138 214 to 286 388 to 500 Dimension A 0.257” (6.6mm) 0.332” (8.5mm) 0.371” (9.5mm) 0.499” (12.8mm) 0.655” (16.8mm) 0.890” (22.8mm) 1.279” (32.8mm) 1.981” (50.8mm) Dimension B 0.129” (3.3mm) 0.156” (4mm) 0.176” (4.5mm) 0.176” (4.5mm) 0.234” (6mm) 0.312” (8mm) 0.429” (11mm) 0.546” (14mm) Dimension C 0.195” (5mm) 0.195” (5mm) 0.234” (6mm) 0.254” (6.5mm) 0.332” (8.5mm) 0.429” (11mm) 0.624” (16mm) 1.014” (26mm) Dimension D Ø 0.125” (3.2mm) Ø 0.140” (3.6mm) Ø 0.164” (4.2mm) Ø 0.203” (5.2mm) Ø 0.242” (6.2mm) Ø 0.332” (8.5mm) Ø 0.410” (10.5mm) Ø 0.488” (12.5mm) Terminal Blocks Timers Torque Rated Current Applicable Wire Rated at 60˚C Applicable Wire Rated at 60˚C 22 AWG (0.3mm ) 3A 6 (14mm ) 50A 20 AWG (0.5mm2) 5A 4 (22mm2) 75A 18 AWG (0.75mm ) 7A 0 (38mm ) 100A 16 AWG (1.25mm2) 10A 00 (60mm2) 2 2 2 2 150A 14 AWG (2mm ) 15A 0000 (100mm ) 200A 12 (3.5mm2) 20A 300mcm (150mm2) 300A 10 (5.5mm2) 30A 400mcm (200mm2) 350A Circuit Breakers 2 2 UL/CSA ratings are specified. The current carrying capacity depends on the rating of the wire used, as shown. 876 www.idec.com Diagram B (minimum) C (maximum) A øD
BNC520 价格&库存
很抱歉,暂时无法提供与“BNC520”相匹配的价格&库存,您可以联系我们找货
