HW SERIES ILLUMINATED BUZZER
HW1Z-P1F2PQ4Y
ILLUMINATED BUZZER Ø22MM, YELLOW 12-24VDC IP65
HW SERIES > ILLUMINATED BUZZER WITH PILOT LIGHTS
FEATURES
- Combination buzzer and pilot light
- Easy wiring and tight installation places
- Lamp and buzzer functions are integrated
- Panel front IP65
- Installing an optional terminal rubber boot upgrades the terminal’s to IP54
- Complies with the new EU elevator safety standard
APPLICATIONS
- Semi-outdoor applications
- Waterproof requirements for fireman’s elevator
- Automatic Storage
- Production lines
- Automatic guided vehicle systems (AGV)
- Control Station
SPECIFICATIONS
Part No. (Illuminated Buzzer)
HW1Z-P1F2PQ4Y
Part No. (Optional Terminal Rubber Boot)
HW9Z-CZ1
Illumination Color
Yellow
Rated Insulation Voltage
30V
Rated Voltage
12 to 24V DC
Voltage Range
10.8 to 26.4V DC
Rated Current (effective value)
18mA (24V DC), 8mA (12V DC)
Inrush Current
Max.100mA
Buzzer
Sound Pressure (of HW1Z itself) (at 25˚C) 12VDC
84dB min. at 0.1m
64dB min. at 1m
Sound Pressure (of HW1Z itself) (at 25˚C) 24VDC
90db min. at 0.1m
70dB min. at 1m
Sound Frequency (at 25˚C)
2,200 to 2,450Hz
Sound Type
Intermittent sound
Intermittent Cycle (at 25˚C)
105 cycles/minute approx. (1.75Hz approx.)
Illumination
Illumination Type
Flashing
Flash Cycle (at 25˚C)
Operating Temperature
–20 to +50˚C (no freezing)
Operating Humidity
20% to 85% RH (no condensation)
Storage Temperature
–30 to +80˚C (no freezing)
Insulation Resistance
100MΩ minimum (at 500V DC megger)
Dielectric Strength Between live and earthed metal parts
1000V AC, 1 minute
Vibration Resistance
Operation extremes: 5 to 55Hz, amplitude 0.5mm
Damage limits: 5 to 55Hz, amplitude 0.5mm
Shock Resistance
Operation extremes: 100 m/s²
Damage limits: 1,000 m/s²
1
HW1Z-P1F2PQ4Y
SPECIFICATIONS
Degree of Protection
Panel front: IP65 (IEC 60529)
Terminal: IP40 (IEC 60529)
IP54 (with terminal rubber boot) (IEC 60529)
Terminal Style
Push-in Terminals
Applicable Wire
Solid wire/ferrule (without sleeve): 0.2 to 1.5 mm²
Ferrule (with sleeve): 0.2 to 0.75 mm²
Weight (approx.)
17g
Standards
UL508, EN60947-5-1
DIMENSIONS
HW1Z-P1F2PQ4Y Illuminated Buzzer
HW9Z-CZ1 Illuminated Buzzer with Terminal Rubber Boot
2
很抱歉,暂时无法提供与“HW1Z-P1F2PQ4Y.”相匹配的价格&库存,您可以联系我们找货
