IAC-R8
IAC-R8
    IDEC(日本和泉)
    IDEC - IAC-R8 - REFLECTOR, LARGE, 51X51MM
IAC-R8 数据手册
Sensors SA1C-F OI Touchscreens High-speed Fiber Optic: SA1C-F PLCs Key features: Automation Software • Ideal for remote sensing applications • Featuring quick-connect cable and easy-insert fiber optic units for simple installation • Through-beam and reflected-light sensing available • Sensing range up to 7.09” (180mm) for throughbeam sensors • Dual outputs: Select NPN and PNP transistor outputs or NPN transistor output combined with a self-diagnostic output • Outputs selectable for light on or dark on • High-speed, 50µs response time • Featuring variable off-delay (0 to 100msec) and finetune sensitivity adjustment • Stable LED makes alignment easy • Red or green LEDs available for detecting color marks • Mount on a 35mm DIN rail Power Supplies Sensors The perfect fiber optic sensor for applications where you have difficulty mounting regular or miniature sensors or where accessability is a problem. Available in through-beam and retro-reflective models, the built-in variable off-delay (0 - 10ms) can help you bring your complete system in tune. The 50µs response time ensures detection of fast moving targets in a high-speed manufacturing environment where speed counts. Communication Barriers 800-262-IDEC (4332) • USA & Canada 199 Sensors OI Touchscreens SA1C-F Part Numbers Function Amplifier Output SA1C-FN3E (Cable) SA1C-FN3EC (Quick-Connect) 30V DC NPN transistor: 100mA (maximum) Self-diagnostic: 50mA (maximum) Light Source Power Supplies Automation Software PLCs Red LED SA1C-FD3F (Cable) SA1C-FD3FC (Quick-Connect) 30V DC NPN transistor: 100mA (maximum) PNP transistor: 200mA (maximum) SA1C-FN3EG (Cable) SA1C-FN3EGC (Quick-Connect) 30V DC NPN transistor: 100mA (maximum) Self-diagnostic: 50mA (maximum) SA1C-FD3FG (Cable) SA1C-FD3FGC (Quick-Connect) 30V DC NPN transistor: 100mA (maximum) PNP transistor: 200mA (maximum) SA1C-F1N3E (Cable) SA1C-F1N3EC (Quick-Connect) 30V DC NPN transistor: 100mA (maximum) Self-diagnostic: 50mA (maximum) Green LED Red LED Sensors SA1C-F1D3F (Cable) SA1C-F1D3FC (Quick-Connect) 30V DC NPN transistor: 100mA (maximum) PNP transistor: 200mA (maximum) Response Standard speed: 0.5 ms Standard speed: 0.5 ms Highspeed: 50 µs Through-Beam Units Diffuse-Reflected Units Part Number Range SA9F-TS: ø0.16” (M4) Straight SA9F-TC: ø0.16” (M4) Coiled SA9F-TT: ø0.12” (M3) Straight SA9F-TM: ø0.16” (M4) Multicore SA9F-TH: Heat-resistant glass fiber SA9F-TL: Side view 180mm (7.09”) SA9F-TS: ø0.16” (M4) Straight SA9F-TC: ø0.16” (M4) Coiled SA9F-TT: ø0.12” (M3) Straight SA9F-TM: ø0.16” (M4) Multicore SA9F-TH: Heat-resistant glass fiber SA9F-TL: Incompatible with green LED 16mm (0.63”) SA9F-TS: ø0.16” (M4) Straight SA9F-TC: ø0.16” (M4) Coiled SA9F-TT: ø0.12” (M3) Straight SA9F-TM: ø0.16” (M4) Multicore SA9F-TH: Heat-resistant glass fiber SA9F-TL: Side view 50mm (1.97”) 150mm (5.91”) 50mm (1.97”) 150mm (5.91”) 100mm (3.94”) 40mm (1.57”) 14mm (0.55”) 5mm (0.20”) 14mm (0.55”) 8mm (0.31”) N/A 40mm (1.57”) 15mm (0.59”) 40mm (1.57”) 30mm (1.18”) 13mm (0.51”) Part Number Range SA9F-DS: ø0.24” (M6) Straight SA9F-DC: ø0.24” (M6) Coiled SA9F-DD: ø0.24” (M6) Coaxial SA9F-DT: ø0.12” (M3) Straight SA9F-DM: ø0.01” (0.26mm) Multicore SA9F-DH: Heat-resistant glass fiber SA9F-DL: Side view 60mm (2.36”) SA9F-DS: ø0.24” (M6) Straight SA9F-DC: Incompatible with green LED SA9F-DD: ø0.24” (M6) Coaxial SA9F-DT: Incompatible with green LED SA9F-DM: ø0.01” (0.26mm) Multicore SA9F-DH: Incompatible with green LED SA9F-DL: Incompatible with green LED 7mm (0.28”) SA9F-DS: ø0.24” (M6) Straight SA9F-DC: ø0.24” (M6) Coiled SA9F-DD: ø0.24” (M6) Coaxial SA9F-DT: ø0.12” (M3) Straight SA9F-DM: ø0.01” (0.26mm) Multicore SA9F-DH: Heat-resistant glass fiber SA9F-DL: Side view 20mm (0.79”) 25mm (0.98”) 60mm (2.36”) 20mm (0.79”) 60mm (2.36”) 27mm (1.06”) 10mm (0.39”) N/A 7mm (0.28”) N/A 4mm (0.16”) N/A N/A 7mm (0.28”) 20mm (0.79”) 6mm (0.24”) 18mm (0.71”) 7mm (0.28”) 3mm (0.12”) Communication Function is determined by the fiber optic unit used. Barriers For information on accessories, see page 203. 200 www.IDEC.com Sensors SA1C-F Power Voltage Operating Voltage √ √ 40mA (maximum) – √ Operating Temperature Amplifier only: –25° to +55°C Fiber optic cords (except heat-resistant types): –40° to +70°C Heat-resistant fiber optic cords: –40°C to +350°C (avoid ice coating) √ √ Operating Humidity 35 to 85% RH (avoid condensation) √ √ Extraneous Light Immunity Sunlight: 10,000 lux (maximum); Incandescent light: 3,000 lux (maximum) on receiver surface— defined as incident or unwanted light received by a sensor, unrelated to the presence or absence of the intended object √ √ Material Amplifier only: PBT resin (housing) with polycarbonate lens Fiber optic cords (except heat-resistant types): Nickel-plated brass (sensing head), polyethylene-covered PMMA (cord), and SUS304 stainless (sleeve) Heat-resistant fiber optic cords: SUS 304 stainless (sensing head) and SUS spiral tube around glass fiber cord √ √ Degree of Protection IP66 — IEC Pub 529, sensors rated IP66 are dust-tight, water-resistant, and perform best when not subjected to heavy particle or water blasts √ √ Connection Cable type: 0.2mm2; Vinyl cabtyre cable #24 AWG, 6’–6-3/4’ (2m) long Connector type: Ø 0.31” (8mm) 3- or 4-pin connector (cable ordered separately for quick connect sensors) √ √ Light Source Red or green LED (pulse-modulated) √ √ Output NPN transistor: 30V DC (1.2V residual), 100mA (maximum) PNP transistor: 30V DC (2.0V residual), 200mA (maximum) Self-diagnostic: 30V DC (1.2V residual), 50mA (maximum) √ √ 0.5ms (maximum) √ – √ √ √ Sensitivity 4-turn adjustment √ √ Minimum Bending Radius Fiber optic cord (except SA9F-TT, -DT, -TL, and -DL): 1”R (25mm); Sleeve: 0.39”R (10mm) SA9F-TT and -DT: 0.59”R (15mm); Sleeve: 0.39”R (10mm) SA9F-TL and DL: 0.59”R (15mm); Sleeve: Unbendable √ √ Light on or dark on (selectable by switch on amplifier) √ √ Operation indicator: Red LED (out) √ √ Stable level indicator: Green LED (stable) √ √ 500V √ – 300V – √ 300V √ – 150V – √ Operation Mode Indicator Normal Mode Noise Resistance Common Mode Pulse Width √ √ –30 to +70°C (avoid freezing) √ √ Insulation Resistance 20M minimum with 500V DC megger (between live & dead parts) √ √ Dielectric Strength 1000V, 1 minute (between live & dead parts) √ √ Vibration Resistance Damage limits: 10 – 55Hz Amplitude: 1.5mm p-p, 20 cycles in each of 3 axes crossed (one cycle = 5 minutes) √ √ Shock Resistance Damage limits: 500m/s2 (approximately 49G), 10 shocks in each of 3 axes √ √ Weight Cable type: Approximately 75g Quick-connect type: Approximately 30g √ √ 800-262-IDEC (4332) • USA & Canada Barriers 50ns –1µs, 100Hz (using a noise simulator) Storage Temperature Communication – 0 to 100 ms (adjustable) Sensors 50µs (maximum) Off Delay Power Supplies √ – Automation Software √ √ PLCs 10V to 30V DC, ripple 10% (maximum) Response Function Specifications SA1C-F1N, -F1D (High-speed) 30mA (maximum) Current Draw General Specifications 12V to 24V DC SA1C-FN, -FD (Standard Speed) OI Touchscreens Specifications 201 Sensors SA1C-F 4 x 2m OI Touchscreens Dimensions (mm) ø2.6 - 2 places Receiver Port Projector Port PLCs ø3.2mm - 2 places Automation Software Operation LED Stable LED Background Color White Yellow Chartreuse Orange Red Magenta Turquoise Blue Violet Green Black – v u v v u u u u u u White Power Supplies Off Delay Selector Detecting Color Marks Color of Mark Yellow v – u v v v u u u u u Chartreuse u u – o o v o u v u u Orange v v o – – v o u u u u Red v v o – – o o u u u u Magenta u v v v o – o o – o u Turquoise u u o o o o – o u v u Blue u u u u u o o – o o o Violet u u v u u – u o – o o Green u u u u u o v o o – o Black u u u u u u u o o o – o = Use Red LED v = Use Green LED u = Use Red or Green LED – = Not Detectable Barriers Communication Sensors Operation Mode Selector Sensitivity Adjustment 202 www.IDEC.com Sensors Accessories Slits Reflectors Appearance Item Use with Standard reflector Part Number IAC-R6 Large reflector IAC-R8 SA1E IAC-R7B Tape (35 x 40mm) IAC-RS1 Tape (70 x 80mm) IAC-RS2 Standard IAC-R9 SA1E-X Ultra-small IAC-R10 Use with 0.5mm x 18mm SA9Z-S06 1.0mm x 18mm SA9Z-S07 2.0mm x 18mm SA9Z-S08 0.5mm x 6.5mm Horizontal slit 1.0mm x 6.5mm Round slit Part Number SA9Z-S09 SA1E SA9Z-S10 2.0mm x 6.5mm SA9Z-S11 ø0.5mm SA9Z-S12 ø1.0mm SA9Z-S13 ø2.0mm SA9Z-S14 Appearance Number of Core Wires IAC-R11 Type & Length Use with Part No. Straight, 2m SA9Z-CM8K-4S2 Straight, 5m 4 Use with Part Number SA9Z-K01 Horizontal mounting bracket SA9Z-K02 Cover mounting bracket SA9Z-K03 Back mounting bracket SA9Z-K04 4 photo not available Right angle, 2m SA9Z-CM8K-4S5 SA1E SA9Z-CM8K-4L2 Right angle, 5m SA9Z-CM8K-4L5 2m SA9C-CA4D2 5m SA9C-CA4D5 SA1C-F 2m Power Supplies Vertical mounting bracket 2 Connector Cables (for connector model sensors) Brackets Item Min. Order Qty Automation Software Narrow (rear mounting) Slit Size PLCs IAC-R7S Item Vertical slit IAC-R7M Narrow (side mounting) Small Appearance IAC-R5 Small reflector Narrow (rear/side mounting) Appearance OI Touchscreens Accessories SA9C-CA4D2S 5m SA9C-CA4D5S Air Blower Mounting Blocks Appearance Item Use with Part Number Air blower mounting block SA1E SA9Z-A02 SA1E IAC-L2 Reflector mounting bracket IAC-L3 Reflector mounting bracket IAC-L5 Sensors Sensitivity Control Screwdriver Item Part No. Communication photo not available Reflector mounting bracket Package Quantity Sensitivity Control Screwdriver SA9Z-AD01 1 Barriers 800-262-IDEC (4332) • USA & Canada 203 Sensors Accessories Appearance Part Number Description Use with Range SA9F-DS31 No sleeve SA9F-DS32 3.54” (90mm) sleeve SA9F-DS33 1.77” (45mm) sleeve Straight: Two fibers ø1mm (0.04”) Threaded mount: ø6mm (M6) Detects: ø0.03mm (0.0012”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 60mm (2.36”) 7mm (0.28”) SA9F-DC31 No sleeve SA9F-DC32 3.54” (90mm) sleeve SA9F-DC33 1.77” (45mm) sleeve (All three not compatible with green LED) Coiled: Two fibers ø1mm (0.04”) Threaded mount: ø6mm (M6) Detects: ø0.03mm (0.0012”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 25mm (0.98”) — SA9F-DT11 No sleeve SA9F-DT12 3.54” (90mm) sleeve SA9F-DT13 1.77” (45mm) sleeve (All three not compatible with green LED) Straight: Two fibers ø0.5mm (0.02”) Threaded mount: ø3mm (M3) Detects: ø0.03mm (0.0012”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 20mm (0.78”) — SA9F-DD31 Coaxial: Core ø1mm (0.04”) + 16 fibers: ø0.26mm (0.01”) Threaded mount: ø6mm (M6) Detects: ø0.03mm (0.0012”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 60mm (2.36”) 7mm (0.28”) SA9F-DM74 1 row = 32 fibers SA9F-DM75 2 rows = 16 each (Not compatible with green LED) Multicore: 32 fibers ø0.26mm (0.010”) Detects: ø0.06mm (0.0024”) minimum object SA1C-FK SA1C-FK3G SA1C-F 60mm (2.36”) 4mm (0.16”) SA9F-DH21 No sleeve SA9F-DH22 3.54” (90mm) sleeve (Both not compatible with green LED) Heat-resistant glass: Two fibers ø0.7mm (0.03”) Threaded mount: ø4mm (M4) Detects: ø0.03mm (0.0012”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 27mm (1.06” ) — Barriers Communication Sensors Power Supplies Automation Software PLCs OI Touchscreens Diffuse-Reflected Light Fiber Optic Units - SA9F 204 www.IDEC.com (not compatible with SA9F-DM75, SA9F-DM76) Sensors Accessories Through-Beam Fiber Optic Units - SA9F Part Number Amplifier Range Straight fiber: ø1mm (0.04”) Threaded mount: ø4mm (M4) Detects: ø0.3mm (0.012”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 180mm (7.09”) 16mm (0.63”) SA9F-TC21 No sleeve Coiled fiber: ø1mm (0.04”) Threaded mount: ø4mm (M4) Detects: ø0.3mm (0.012”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 150mm (5.91”) 14mm (0.55”) SA9F-TT11 No sleeve Straight fiber: ø0.5mm (0.02”) Threaded mount: ø3mm (M3) Detects: ø0.15mm (0.006”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 50mm (1.97”) 5mm (0.2”) SA9F-TM21 No sleeve SA9F-TM22 3.54” (90mm) sleeve SA9F-TM23 1.77” (45mm) sleeve 16 fibers (cluster) Multicore: ø0.26mm (0.010”) Threaded mount: ø4mm (M4) Detects: ø0.3mm (0.012”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 150mm (5.91”) 14mm (0.55”) SA9F-TM74 16 fibers in one row Multicore: 16 fibers (one row) ø0.26mm (0.010”) Detects: ø0.06mm (0.0024”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 150mm (5.91”) 14mm (0.55”) SA9F-TH21 No sleeve SA9F-TH22 3.54” (90mm) sleeve Heat-resistant glass fiber: ø1mm (0.04”) Threaded mount: ø4mm (M4) Detects: ø0.3mm (0.012”) minimum object SA1C-FK3 SA1C-FK3G SA1C-F 100mm (3.94”) 8mm (0.31”) SA9F-TS21 No sleeve SA9F-TS23 1.77” (45mm) sleeve PLCs Description OI Touchscreens Appearance Automation Software Power Supplies Sensors Communication Barriers 800-262-IDEC (4332) • USA & Canada 205 Sensors Accessories OI Touchscreens Miscellaneous Accessories Description Use with Part Number Fiber cutter All fiber units except heat resistant HxLxD: 23x 45 x 8mm (0.91” x 1.77” x 0.31”) Included with fiber units; order replacement only SA9Z-F01 Set of 2 easy-insert adaptors SA9F-TT, SA9F-TL, SA9F-DT, and SA9F-DL ø2.2 x 24mm long (ø0.087” (OD) x 0.945”) Included with applicable fiber optic units; order replacement set only SA9Z-F02 Power Supplies Automation Software PLCs SA1C-F through-beam fiber unit only Lens attachment for long-range detection of opaque objects, minimum size: Ø 0.14” (3.5mm) Sensing ranges: Standard speed red LED: SA9F-TS21: 1.3m (4’ – 3-3/16”) SA9F-TC21: 1m (3’ – 3-3/8”) 0.1m (3.94”) SA9F-TM21: 1.05m (3’ – 5-3/8”) Sensing ranges: Standard speed green LED: SA9F-TS21: 0.135m (5.31”) SA9F-TC21: 0.1m (3.94”) SA9F-TM21: 0.13m (5.12”) SA9Z-F11 Sensing ranges: High-speed red LED: SA9F-TS21: 0.4m (5.75”) SA9F-TC21: 0.3m (1.81”) SA9F-TM21: 0.38m (4.96”) SA1C-F through-beam fiber unit only Side view attachment to rotate axis by 90° for detection of opaque objects, minimum size: Ø 0.14” (3.5mm) Side-on attachment for narrow clearance, Range: 1.26” (32mm), for detection of transparent or opaque objects Sensing ranges: Standard speed red LED: SA9F-TS21: 200mm (7.87”) SA9F-TC21: 130mm (5.12”) SA9F-TM21: 160mm (6.30”) SA9Z-F12 Sensing ranges: High-speed red LED: SA9F-TS21: 50mm (1.97”) SA9F-TC21: 35mm (1.38”) SA9F-TM21: 40mm (1.57”) SA1C-F diffuse-reflected light fiber unit only Sensing ranges: Standard speed red LED: SA9F-TS21: 35mm (1.38”) SA9F-TC21: 30mm (1.81”) SA9F-TM21: 35mm (1.38”) SA9Z-F13 SA1C-F through-beam fiber unit only Sensing ranges: Standard speed red LED: SA9F-TS21: SA9F-TC21: SA9F-TM21: 10mm ± 1mm (0.394” ± 0.039”) Barriers Communication Sensors Attachment for high-accuracy: Range: 0.4” ± 0.04” (10mm ± 1mm), for detection of transparent or opaque objects 206 www.IDEC.com SA9Z-F14 Sensors Accessories OI Touchscreens Accessory Dimensions (mm) Mounting Bracket SA9Z-K01 With Mounting Bracket PLCs Automation Software SA9Z-K02 With Mounting Bracket Power Supplies Sensors Communication Barriers 800-262-IDEC (4332) • USA & Canada 207 Sensors Accessories OI Touchscreens SA9Z-K03 Automation Software PLCs With Mounting Bracket SA9Z-K04 30 25 5 7 t=1.2 25.4 24 10.8 24.8 13.4 7 32 Material: Stainless Steel Reflector IAC-R5 IAC-R6 2-ø4.3 4 8 72 60 42.3 34.3 Sensors 25 Communication 8.3 35.3 (21) Power Supplies 28.4 19.5 1.6 7 3.4 3.2 14 8 With Mounting Bracket 3.3 2-ø3.6 (Effective reflecting area: 30 × 31) 51 3 9 Material: PMMA (reflector), ABS (base) (Effective reflecting area: 47.2 × 47.2) Barriers Material: PMMA (reflector), ABS (base) 208 www.IDEC.com Sensors IAC-RS1 IAC-RS2 70 35 Thickness = 0.5 mm 2-ø4.5 Material: PMMA 8 (Effective reflecting area: 47 × 47) PLCs 30 40 80 30.4 40 61 51.2 51.2 OI Touchscreens Reflector IAC-R8 Accessories Material: PMMA (reflector), ABS (base) Thickness = 0.5 mm Material: PMMA IAC-R7M (rear/side mounting) IAC-R7B (rear mounting) 12.4 Positioning Projection (ø3.0 mm, height 1.0 mm) 12.4 12.4 2-7.3 M3 tapping screw hole (ø2.6 mm, depth 7.7 mm) Material: PMMA (reflector), ABS (base) Material: PMMA (reflector), ABS (base) 25.4 Material: PMMA (reflector), ABS (base) Effective reflecting area: 8.6 × 29.5 The mounting plate for reflector must be 0.8 to 2.5 mm in thickness. IAC-R9 2-M3 tapping screw hole (ø2.6 mm, depth 8.6 mm) 2-7.3 11.5 33.3 11.5 M3 tapping screw hole (ø2.6 mm, depth 7.7 mm) Power Supplies 2-7.3 12.4 3.0 25.4 33.3 3.0 2-M3 tapping screw hole (ø2.6 mm, depth 8.6 mm) IAC-R7S (side mounting) Positioning Projection (ø3.0 mm, height 1.0 mm) 33.3 12.4 Automation Software 12.4 IAC-R10 IAC-R11 2-ø7 2-ø3.8 26 32 5 60 50 4.4 Sensors 61.6 51 2-ø4.4 6.1 3.1 2-R2.2 20 40 51.6 2-R2.2 (Reflecting surface 47×47.6) Material: PMMA (reflector), ABS (base) 3.5 6.1 20.2 2 3.2 19.4 Material: PMMA (reflector), ABS (base) Communication (Reflecting surface 38.5×16) (Reflecting surface 18×18.2) Material: PMMA (reflector), ABS (base) Barriers 800-262-IDEC (4332) • USA & Canada 209 Sensors Reflector Mounting Bracket IAC-L2 (for IAC-R5) IAC-L3 (for IAC-R6) IAC-L5 (for IAC-R8) 19 6 40 25 4.5 10 4-ø4.4 11 11 37 16 18 (3) 6.1 Slit 0.3 Connector Cable (connector on one end) Straight (SA9Z-CM8K-4S) Part No. Slight Width: A SA9Z-S06 0.5 mm SA9Z-S07 1.0 mm SA9Z-S08 2.0 mm Right-angle (SA9Z-CM8K-4L) ø9.6 ➁ White ➃ Black ➁ White ➂ Blue ➀ Brown ➂ Blue ➀ Brown 28 ➃ Black 16.5 32 Sensors ø9.6 20 26 (28) 8-M3 × 0.7 holes Material: SPCC (zinc plating) Material: Stainless Steel ø5.2 ø5.2 Barriers Dielectric strength when installed on the SA1E: 1000V AC (between live part and mounting bracket, except between live part and tightening ring) 210 7 12 1.6 Material: SPCC (zinc plating) 32.1 18 Power Supplies 8.2 A 20 8-M3 × 0.5 holes Material: SPCC (zinc chromate plating, black) 15 35 44 16 10 6 8 58 2 Automation Software 70 113 35 25 (2) 74 60 50 40 61 PLCs 2-ø3.4 Slit (Vertical Slit) SA9Z0S06, -S07, -S08 Communication 4.5 10 30 (3) 28 42 5.5 OI Touchscreens Accessories www.IDEC.com Sensors Accessories 8.0 14.0 With Mounting Bracket (3.2) .2 17.4 P0.8 42.5 37.0 25.4 M5 19.5 PLCs (3.8) 2- ø3 SA1E-∗∗∗∗ 6.9 Recommended mounting bracket (SA9Z-K01) Air Blower Mounting Block Automation Software 25.0 6.5 5.8 3.5 6.5 • The SA9Z-A02 air blower mounting block is supplied with two mounting screws (M3 × 20 mm sems screws), one 2.0 screw for plugging the air supply port (M5 × 6 mm), and one gasket for plugging the air supply port. Plugging screws • An air tube fitting (M5) can be installed to either the top or for air supply port side. Tighten the fitting to a torque of 0.5 N·m maxi­mum. (M5), Gasket • The air tube fitting and mounting bracket are not supplied (used on one side only) and must be ordered separately (recommended mounting bracket: SA9Z-K01). 31.5 P0.8 10.9 M5 Air supply port 8.0 14.0 3.4 OI Touchscreens Air Blower Mounting Block (Material: Anodized aluminum surface) Diffuse-Reflective Light Fiber Optic Units SA9F-DS31 SA9F-DS32, SA9F-DS33 M6 (P=0.45) M6 (P=0.75) Power Supplies SA9F-DC31 SA9F-DC32, SA9F-DC33 M6 (P=0.75) M6 (P=0.75) Sensors Straight SA9F-DT11 SA9F-DT12, SA9F-DT13 M3 (P=0.5) Communication M3(P=0.5) Barriers 800-262-IDEC (4332) • USA & Canada 211 Sensors Diffuse-Reflective Light Fiber Optic Units con’t SA9F-DD31 Dimensions (mm) SA9F-DM74 1 M6 (P=0.75) 10.9 OI Touchscreens Accessories PLCs 2-ø 3 hole .2 moun s ting SA9F-DM75 s Automation Software 5.3 m ole 2m h 3. ing - ø unt 2 o m SA9F-DH21 Power Supplies M4 (P0.7) SA9F-DH22 Sensors M4 (P0.7) 2 - mounting screws SA9F-TS23 2 - mounting screws washer Barriers Communication SA9F-TS21 212 www.IDEC.com washer Sensors Accessories Diffuse-Reflective Light Fiber Optic Units con’t OI Touchscreens SA9F-TC21 Dimensions (mm) SA9F-TT11 (straight) 2 - mounting screws 2 - mounting screws washer washer PLCs SA9F-TM21 washer 2 - mounting screws SA9F-TM74 Automation Software 2 - mounting screws SA9F-TM22, SA9F-TM23 washer SA9F-TH21 2 - ø3.2mm mounting holes Power Supplies Sensors Communication Barriers 800-262-IDEC (4332) • USA & Canada 213
IAC-R8 价格&库存
很抱歉,暂时无法提供与“IAC-R8”相匹配的价格&库存,您可以联系我们找货
