ASDHHL-B
ASDHHL-B
    IDEC(日本和泉)
ASDHHL-B 数据手册
Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWTD Series Relays & Sockets Signaling Lights TWTD Series — Full Size NEMA Pushbuttons TWTD Series: Heavy duty switches built to last Contactors Timers Key features: • Variety of button sizes up to 2 9/16” (65mm) • Rugged construction includes chrome plated zinc locking ring die cast zinc mounting threads, screw mounted contact blocks • LED or incandescent illumination • Transformer or full voltage • Transparent contact windows • Slow make, double break self-cleaning contacts • Modular construction for maximum flexibility • Double nickel plated terminal screws • Available assembled or as sub-components • Type 4x and IP65 watertight/oiltight panel • Large M3.5 screw terminals with captive sems plate File No. LR21451 With button sizes up to 2 9/16” (65mm), chrome plated zinc locking rings, die cast zinc mounting threads, steel anti-rotation rings, and self cleaning contacts, the TWTDs are here to stay. The TWTD series also offers either LED or incandescent illumination in full voltage and transformer models. Transparent contact windows allow the viewing of IDEC’s self cleaning slowmake/slow-break contacts. Regardless of your switching needs, the TWTD series provides the kind of long lasting, industrial strength quality you’ve come to expect from IDEC. Ref No. 117617MC Circuit Breakers Terminal Blocks UL Listed File No. E68961 The rugged series of TWTD switches offers both variety and durability in an attractive design. 660 www.IDEC.com Certificate No. 2005010305145658 Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Specifications EN60947-1, EN60947-5-1, VDE0660-200, UL508, CSA C22-2 No.14 Approvals CSA: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) UL: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) TÜV: pushbuttons and selector switches: A600=P600 (NO, NC)/Q600 (NO-EM, NC-LB) pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) Operating Temperature Operation: –25 to +50°C (without freezing) Storage: –40 to +70°C (without freezing) Vibration Resistance 10 to 55Hz, 98m/sec2 (10g) conforming to IEC6068-2-6 Shock Resistance 980m/sec2 (100g) conforming to IEC6068-2-7 Electric Shock Protection Class 0 conforming to IEC60536 Degree of Protection IP65 (from front of the panel) (conforming to IEC60529) IP54 (key switches) Type 1, 2, 3, 3R, 3S, 4, 4X, 5, 12, 13 (conforming to NEMA ICS6-110) Mechanical Life Momentary pushbuttons: 5,000,000 (900 operations per hour) All other switches: 500,000 Pollution Degree (conforming to IEC60947-1) 3 for switches not using a transformer 2 for switches using a transformer Signaling Lights Conforming to Standards Relays & Sockets Mechanical-Electrical Specifications Rated Operational Characteristics AC-15: A600 or Ue = 250V, le = 3A (NO, NC, NO-EM, NC-LB) DC-13: P600 or Ue = 125V, le = 1.1A (NO, NC) DC-13: Q600 or Ue = 125V, le = 0.9A (NO-EM, NC-LB) Rated Insulation Voltage 600V Less than 4kV, conforming to IEC60947-1 Rated Impulse Withstanding Voltage 4kV for contact circuit 2.5kV for lamp circuit Rated Thermal Current 10 Amp Minimum Switching Capacity 5 mA at 3V AC/DC Contact Operation Slow break NC or NO, self-cleaning Operating Force Flush and extended pushbuttons—with 1NO or 1NC contact: 6.2±2N (momentary), 7.0±2N (maintained) Additional contacts—1NO or 1NC: +3.2N (momentary), + 3.3N (maintained) Terminal Referencing Conforming to CENELEC EN50005 Timers Rated Switching Overvoltage 10A 250V fuse conforming to IEC60269-1 Applicable Wire Size Minimum 1 x 22 AWG, max. 2 x 14 AWG or 1 x 12 AWG Contact Resistance Initial contact resistance of 50mΩ or less Contact Gap 4mm (NO and NC) 2mm (NO-EM and NC-LB) Lamp Ratings Incandescent: 1 W LEDs: 6V: 17mA, 12V: 11mA, 24V: 11mA, / 120, 240V: 10mA Maximum Inrush Current 40 A (40 msec) Contact Material Silver Terminal Blocks 0.8 N m (7.1 in lb.) External Short-Circuit Protection Contactors Recommended Terminal Torque Contact Ratings AC-15 (A600) Contact Ratings by Utilization Category IEC 60947-5-1 DC-13 (P600) Contact Ratings by Utilization Category AC 50/60 Hz Operation Current DC 24V 48V 50V 110V 220V 440V AC-12 Control of resistive loads & solid state loads 10A — 10A 10A 6A 2A AC-15 Control of electromagnetic loads (> 72VA) 10A — 7A 5A 3A 1A DC-12 Control of resistive loads & solid state loads 8A 5A — 2.2A 1.1A — DC-13 Control of electromagnets 5A 2A — 1.1A 0.6A — 800-262-IDEC (4332) • USA & Canada Circuit Breakers Operational Voltage 661 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWTD Series Timers Relays & Sockets Signaling Lights Non-Illuminated Pushbuttons (Assembled) Assembled Pushbuttons A B ( ) D 1 10 Function Button Color B: Momentary O: Maintained V: Pushlock Turn Reset Y: Push-Pull B: Black R: Red Bezel Shape 10: 1NO 20: 2NO 11: 1NO-1NC W: White Y: Yellow 01: 1NC 02: 2NC 22: 2NO-2NC Button Shape 1: Flush 2: Extended 3: Mushroom ø 40mm 4: Jumbo Mushroom ø 65mm Series Designation D: TWTD Series Circuit Breakers Terminal Blocks 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. Custom contact configurations available, contact IDEC for details. 662 G: Green S: Blue Contact Arrangement Blank: Octagonal F: Full Shroud G: Mushroom Shroud P: Neoprene Boot Contactors N – R www.IDEC.com Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Non-Illuminated Pushbuttons (Assembled) Non-Illuminated Pushbuttons Style j Button Color Codes Contacts Momentary Maintained Color Code Black B Green G Red R AOD210N-j AOD201N-j AOD211N-j AOD220N-j AOD202N-j Extended with Neoprene Boot† 1NO 1NC 1NO-1NC 2NO 2NC ABPD210N-j ABPD201N-j ABPD211N-j ABPD220N-j ABPD202N-j AOPD210N-j AOPD201N-j AOPD211N-j AOPD220N-j AOPD202N-j Recessed 1NO 1NC 1NO-1NC 2NO 2NC ABFD110N-j ABFD101N-j ABFD111N-j ABFD120N-j ABFD102N-j AOFD110N-j AOFD101N-j AOFD111N-j AOFD120N-j AOFD102N-j Extended with Full Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABFD210N-j ABFD201N-j ABFD211N-j ABFD220N-j ABFD202N-j AOFD210N-j AOFD201N-j AOFD211N-j AOFD220N-j AOFD202N-j ø 40mm Mushroom Head 1NO 1NC 1NO-1NC 2NO 2NC ABD310N-j ABD301N-j ABD311N-j ABD320N-j ABD302N-j AOD310N-j AOD301N-j AOD311N-j AOD320N-j AOD302N-j ø 40mm Mushroom Head with Full Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABGD310N-j ABGD301N-j ABGD311N-j ABGD320N-j ABGD302N-j AOGD310N-j AOGD301N-j AOGD311N-j AOGD320N-j AOGD302N-j ø 65mm Jumbo Mushroom Head 1NO 1NC 1NO-1NC 2NO 2NC ABD410N-j ABD401N-j ABD411N-j ABD420N-j ABD402N-j AOD410N-j AOD401N-j AOD411N-j AOD420N-j AOD402N-j ø 65mm Jumbo Mushroom Head with Shallow Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABGD410N-j ABGD401N-j ABGD411N-j ABGD420N-j ABGD402N-j AOGD410N-j AOGD401N-j AOGD411N-j AOGD420N-j AOGD402N-j ø 65mm Jumbo Mushroom Head With Deep Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABFD410N-j ABFD401N-j ABFD411N-j ABFD420N-j ABFD402N-j AOFD410N-j AOFD401N-j AOFD411N-j AOFD420N-j AOFD402N-j Blue S Yellow Y White W 1. 65mm Jumbo mushroom not available in white. 2. Neoprene boot is not available in blue or white. Terminal Blocks ABD210N-j ABD201N-j ABD211N-j ABD220N-j ABD202N-j Contactors Extended 1NO 1NC 1NO-1NC 2NO 2NC Timers AOD110N-j AOD101N-j AOD111N-j AOD120N-j AOD102N-j Relays & Sockets ABD110N-j ABD101N-j ABD111N-j ABD120N-j ABD102N-j Signaling Lights Flush 1NO 1NC 1NO-1NC 2NO 2NC 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. In place of j, specify the Button Color Code. 2. For sub-assembly part numbers, see next page. 3. For accessories, see page 682. 4. †Neoprene boot available only in Black (B), Green (G), Red (R) and Yellow (Y). 663 Switches & Pilot Devices Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø30mm - TWTD Series Non-Illuminated Pushbuttons (Sub-Assembled) Contact Block + Operator + Operators Part Number Maintained Flush/Extended ABD-100 AOD-100 Extended with Full Shroud ABFD-200 AOFD-200 ABD-300 Terminal Blocks ABD1BN-j Extended ABD2BN-j ø 40mm Mushroom ABD3BN-j ø 65mm Jumbo Mushroom ABD4BN-j AOD-300 AOGD-300 Contactors ABGD-300 ABGD-400 AOGD-400 In place of j, specify the Button Color Code. (See table previous page) Contact Blocks Style All Control Units ø 65mm Jumbo Mushroom with Deep Shroud ABFD-400 Part Number Flush ø 65mm Jumbo Mushroom with Shallow Shroud Complete Part Style Momentary ø 40mm Mushroom with Full Shroud = Buttons and Lenses Style ø 40mm Mushroom/ø 65mm Jumbo Mushroom Button AOFD-400 Dummy Block Part Number 1NO 1NC BST-010 BST-001 BST-010S (early make) BST-001S (late break) BST-D Circuit Breakers 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining BST-010S and BST-001S result in overlapping contacts (remain on, or closed, when switch is moved between two positions). 664 www.IDEC.com Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Stop Switches (Assembled) Signaling Lights A V (L) D 3 (99) 11 (D) Function N – R – (24V) Lamp Voltage (full voltage illuminated units only) V: Pushlock Turn Reset Y: Push-Pull Blank: None L: Illuminated 6V AC/DC 12V AC/DC 24V AC/DC 120V AC (LED only) 240V AC (LED only) Timers 6V: 12V: 24V: 120V: 240V: Illumination Button/Lens Color Code Series Designation Illumination Circuit Lamp Type (illuminated units only) Button/Lens Size Full Voltage (lamp determines voltage) 120V AC Step Down Transformer 240V AC Step Down Transformer 480V AC Step Down Transformer Contactors 3: 40mm Mushroom A: Amber G: Green R: Red S: Blue W: White Y: Yellow D: TWTD Series 99: 126: 246: 486: Relays & Sockets Assembled Stop Switches Blank: Incandescent D: LED 10: 1NO 20: 2NO 11: 1NO-1NC Terminal Blocks Contact Arrangement 01: 1NC 02: 2NC 22: 2NO-2NC 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. Custom contact configurations available, contact IDEC for details. 665 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø30mm - TWTD Series Stop Switches (Assembled) Stop Switches 3 Position Push-Pull† Style Contacts ø 40mm Pushlock Turn Reset 1NO 1NC 1NO-1NC 2NO 2NC AVD310N-R* AVD301N-R* AVD311N-R* AVD320N-R* AVD302N-R* Full Voltage 1NO-1NC 2NO 2NC AVLD39911nN-R-l* AVLD39920nN-R-l* AVLD39902nN-R-l* Transformer 1NO-1NC 2NO 2NC AVLD3 m 11nN-R* AVLD3 m 20nN-R* AVLD3 m 02nN-R* Non-Illuminated ø 40mm Illuminated Pushlock Turn Reset Part Number Relays & Sockets ø 40mm Push-Pull Non-Illuminated ø 40mm Push-Pull Timers Full Voltage Transformer ø 40mm Momentary Push-Pull (3-position) Full Voltage Contactors Transformer Terminal Blocks AYD310N-j AYD301N-j AYD311N-j AYD320N-j AYD302N-j 1NO-1NC 2NO 2NC AYLD39911nN-k-l ** AYLD39920nN-k-l ** AYLD39902nN-k-l ** 1NO-1NC 2NO 2NC AYLD3 m 11nN-k ** AYLD3 m 20nN-k ** AYLD3 m 02nN-k** 1NO-1NC 1NC-1LB† AYLD229911nN-k-l -TK962 AYLD229902SnN-k-l-TK962 1NO-1NC 1NC-1LB† AYLD22 m 11nN-k-TK962 AYLD22 m 02SnN-k-TK962 Unibody E-Stops Style ø 40mm Pushlock Turn Reset (available in Red only) Circuit Breakers 1NO 1NC 1NO-1NC 2NO 2NC Illuminated ø 40mm Pushlock Turn Reset (available in Red only) 1. 2. 3. 4. 5. 6. In place of j, specify the button color code In place of k, specify the lens color code. In place of l, specify the Full Voltage (lamp voltage) Code. In place of m, specify the transformer voltage code. In place of n, specify the Lamp Type code. With single unit construction, the positive action contacts are integrated in the body of the switch. This provides an extra degree of safety and reliability for critical emergency stop functions. 7. HN1E series E-stops comply with the IEC “E-Stop Addendum to the Low Voltage Directive,” this includes “tamper proof” operation whereby a change of contact state is not possible by “teasing” or “floating” the operator. 666 Contacts Part Number 1NO-1NC 2NC HN1E-BV4F11-R* HN1E-BV4F02-R* 1NO-1NC 2NC HN1E-LV4F11Qn-R-l HN1E-LV4F02Qn-R-l 8. 3 position push-pull available in spring return to center only. 9. *Available in red only. 10. **Not available in blue. 11. †The most common configuration for motor starting applications. 12. For sub-assembly part numbers, see next page. 13. For nameplates and accessories, see page 684 and page 682. 14. For dimensions, see page 687. www.IDEC.com Contact Push Center Pull NC (BST-001) O O X NC-LB (BST-001S) O X X NO (BST-010) X O O NO-EM (BST-010S) X X O j Button Color Codes Color Code Black B Green G Red R Blue S Yellow Y k LED/Lens Color Codes Color Code Amber A Green G Red R Blue S White W l Full Voltage Codes Voltage Code 6V AC/DC 6V 12V AC/DC 12V 24V AC/DC 24V 120V AC 120V 240V AC 240V (LED only) m Transformer Voltage Codes Voltage Code 120VAC 126 240VAC 246 480VAC 486 Transformers step down to 6V. n Lamp Type Codes Lamp Code Incandescent Blank LED D Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Stop Switches (Sub-Assembled) Transformer* + Operator + Lamp + Button/Lens = Complete Part * Not required for full voltage units (full voltage clips used instead). Lamps Style Part Number ø40mm Pushlock Turn Reset AVD-300 AVLD3-0600N Style LED Incandescent Voltage Part Number Color Code 6V AC/DC LSTD-6k Black B 12V AC/DC LSTD-1k Green G 24V AC/DC LSTD-2k Red R 120V AC LSTD-H2k Blue S 240V AC LSTD-M4k Yellow Y 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 120V AC AYD-3100 ø40mm Push-Pull AYLD-0600 3 pos AYLD22TK962-0B01 Illuminated ø 40mm Push-Pull 1. In place of k, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. Part Number AVN3B-R Code A Green G Red R Blue S White W Part Number Style All Control Units Dummy Block 1NO 1NC BST-010 BST-001 BST-010S (early make) BST-001S (late break) Contactors Button for Pushlock Turn Reset Stop Switches (ø40mm, red only) Color Amber Contact Blocks Buttons and Lenses Style k LED Color Codes Timers 2 pos L-120L Relays & Sockets Illuminated ø40mm Pushlock Turn Reset j Button Color Codes Signaling Lights Operators BST-D 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining BST-010S and BST-001S result in overlapping contacts. Full Voltage Clips Lens for Illuminated Pushlock Turn Reset Stop Switches (ø40mm, red only) AVLN3LU-R Primary Voltage (50/60Hz) Button for Push-Pull Stop Switches (ø40mm) Terminal Blocks Full Voltage Clips (2 required for each unit) Part Number APD-F AYD3BN-j Transformers 2 pos* 3 pos 1. In place of j, specify the Button Color Code. (See table below) 2. In place of k, specify the LED Color Code. 3. *Not available in blue. Style AYLD3L-k Primary Voltage (50/60Hz) Part Number 120V AC TWD-0126 240V AC TWD-0246 480V AC TWD-0486 AYLD2L-k Circuit Breakers Lens for Illuminated Push-Pull Stop Switches (ø40mm) 6V secondary voltage (uses 6V lamp). 800-262-IDEC (4332) • USA & Canada 667 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWTD Series Signaling Lights Pilot Lights (Assembled) Assembled Pilot Lights Relays & Sockets A Function P: P D 1 126 D N – R– ( ) Lamp Voltage Pilot Light (full voltage illuminated units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120V AC (LED only) 240V: 240V AC (LED only) Series Designation D: TWTD Series Lens Shape Timers 1: Dome Lens Color Code A: Amber G: Green R: Red S: Blue W: White Y: Yellow Rated Operational Voltage (Primary) Transformer Type 126: 120V AC 246: 240V AC 486: 480V AC Full Voltage Type 99: Full Voltage Contactors Lamp Type Blank: Incandescent D: LED Use only when interpreting part numbers. Do not use for developing part numbers. LED and Incandescent Pilot Lights Style Operating Voltage k Lens Color Codes Part Number LED Incandescent Terminal Blocks Transformer Dome 120V AC 240V AC 480V AC APD1126DN-k APD1246DN-k APD1486DN-k APD1126N-k APD1246N-k APD1486N-k Full Voltage Dome Circuit Breakers Code A Green G Red R Blue S White W Yellow Y l Full Voltage Codes — APD199DN-k-l 1. In place of k, specify the Lens/LED Color Code. 2. In place of l, specify the Full Voltage Code (lamp voltage). 3. Yellow pilot light comes with white LED. 668 Color Amber APD199N-k-l Voltage Code 6V AC/DC 6V 12V AC/DC 12V 24V AC/DC 24V 120V AC 120V 240V AC 240V (LED only) www.IDEC.com Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Pilot Lights (Sub-Assembled) Transformer* + Operator + Lamp + Lens = Complete Part * Not required for full voltage units (full voltage clips used instead). plus Operators Signaling Lights One Each from Left Column One Selection from Right Column Full Voltage Clips Style Part Number Part Number APD-F APD-006 Relays & Sockets Transformer Primary Voltage (50/60Hz) Required for all full voltage models. Two pieces each. Full Voltage Transformers APD-199 Style Primary Voltage (50/60Hz) Full voltage operator comes with full voltage clips. Style Part Number 120V AC TWD-0126 240V AC TWD-0246 480V AC TWD-0486 Timers LED Lenses Part Number 6V secondary voltage (use 6V lamp). Dome Lens APN106LN-k Contactors 1. In place of k, specify the Lens Color Code. 2. LED and incandescent lenses differ in shade only. Some colors have only one shade. k LED/Lens Color Codes Lamps Style Incandescent Code Part Number Amber A 6V AC/DC LSTD-6k Green G 12V AC/DC LSTD-1k Red R 24V AC/DC LSTD-2k Blue S 120V AC LSTD-H2k White W Yellow Y LSTD-M4k IS-6 12V AC/DC IS-12 24V AC/DC IS-24 120V AC L-120L Yellow lens only. Yellow LED not available, use white LED. Circuit Breakers 240V AC 6V AC/DC Terminal Blocks LED Color Voltage 1. In place of k, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. 800-262-IDEC (4332) • USA & Canada 669 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWTD Series Relays & Sockets Signaling Lights Illuminated Pushbuttons (Assembled) Assembled Illuminated Pushbuttons A L ( ) D 2 126 11 (D) Lamp Voltage Function (full voltage only) L: Momentary Action OL: Maintained Action 6V: 12V: 24V: 120V: 240V: Timers Bezel Shape Blank: Octagonal F: Full Shroud A: Amber G: Green R: Red S: Blue W: White Y: Yellow Contactors D: TWTD Series Lens Shape 2: Extended 3: Mushroom ø 40mm Lamp Type Rated Operational Voltage (Primary) Terminal Blocks 6V AC/DC 12V AC/DC 24V AC/DC 120V AC 240V AC (LED only) Lens Color Code Series Designation Transformer Type 126: 120V AC 246: 240V AC 486: 480V AC N – R – ( ) Blank: Incandescent D: LED Full Voltage Type 99: Full Voltage Contact Arrangement 20: 2NO 02: 2NC 11: 1NO-1NC Circuit Breakers 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. All transformers step down to 6V. 670 www.IDEC.com Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Illuminated Pushbuttons (Assembled) Illuminated Pushbuttons k Lens Color Codes Style Contacts Extended Lens Full Voltage Extended Lens with Full Shroud Transformer ø 40mm Mushroom Lens 1NO-1NC 2NO 2NC 1NO-1NC 2NO 2NC ALD2 m 11nN-k ALD2 m 20nN-k ALD2 m 02nN-k ALFD29911nN-k-l ALFD29920nN-k-l ALFD29902nN-k-l ALFD2 m 11nN-k ALFD2 m 20nN-k ALFD2 m 02nN-k ALD39911nN-k-l ALD39920nN-k-l ALD39902nN-k-l AOLD29911nN-k-l AOLD29920nN-k-l AOLD29902nN-k-l AOLD2 m 11nN-k AOLD2 m 20nN-k AOLD2 m 02nN-k AOLFD29911nN-k-l AOLFD29920nN-k l AOLFD29902nN-k-l AOLFD2 m 11nN-k AOLFD2 m 20nN-k AOLFD2 m 02nN-k AOLD39911nN-k-l AOLD39920nN-k-l AOLD39902nN-k-l Amber A Green G Red R Blue S White W Yellow Y l Full Voltage Codes Voltage Code 6V AC/DC 6V 12V AC/DC 12V 24V AC/DC 24V 120V AC 120V 240V AC 240V (LED only) m Transformer Voltage Codes Voltage Code 120VAC 126 240VAC 246 480VAC 486 6V secondary voltage (uses 6V lamp). Timers Full Voltage 1NO-1NC 2NO 2NC ALD29911nN-k-l ALD29920nN-k-l ALD29902nN-k-l Maintained Code Relays & Sockets Full Voltage 1NO-1NC 2NO 2NC Momentary Color Signaling Lights Transformer 1NO-1NC 2NO 2NC Part Number n Lamp Type Codes Transformer ALD3 m 11nN-k ALD3 m 20nN-k ALD3 m 02nN-k AOLD3 m 11nN-k AOLD3 m 20nN-k AOLD3 m 02nN-k Lamp Code Incandescent Blank LED D In place of k, specify the Lens Color Code. In place of l, specify the Full Voltage Code (lamp voltage). In place of m, specify the Transformer Voltage Code. In place of n, specify the Lamp Type Code. Light is independent of switch position. Yellow pushbutton comes with white LED only. Contactors 1. 2. 3. 4. 5. 6. 1NO-1NC 2NO 2NC Terminal Blocks Circuit Breakers 800-262-IDEC (4332) • USA & Canada 671 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWTD Series Illuminated Pushbuttons (Sub-Assembled) Transformer* + Contact Block + Operator + Lamp + Lens = Complete Part Signaling Lights *Not required for full voltage types (full voltage types use APD-F full voltage clips). Operators Lamps Part Number Style Momentary Style Maintained LED Extended Relays & Sockets k LED/Lens Color Codes ALD-0600 AOLD-0600 Incandescent Extended with Full Shroud ALFD-0600 AOLFD-0600 Voltage Part Number Color Code 6V AC/DC LSTD-6k Amber A 12V AC/DC LSTD-1k Green G 24V AC/DC LSTD-2k Red R 120V AC LSTD-H2k Blue S 240V AC LSTD-M4k White W 6V AC/DC IS-6 Yellow Y 12V AC/DC IS-12 24V AC/DC IS-24 120V AC L-120L Yellow lens only. Yellow LED not available, use white LED. 1. In place of k, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. Contact Blocks 40mm Mushroom AOLD-0600 All Control Units Lenses Style Part Number Style Timers ALD-0600 Part Number 1NO 1NC BST-010 BST-001 BST-010S (early make) BST-001S (late break) Contactors Dummy Block Extended ALN06LU-k BST-D 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining BST-010S and BST-001S result in overlapping contacts (remain on, or closed, when switch is moved between two positions). Transformers Style Terminal Blocks ø 40mm Mushroom ALN3LU-k Transformers In place of k, specify the Lens Color Code. 6V secondary voltage (use 6V lamp). Full Voltage Clips Circuit Breakers Style Full Voltage Clips (2 required for each unit) Part Number APD-F Required for all full voltage models. 672 www.IDEC.com Primary Voltage (50/60Hz) Part Number 120V AC TWD-0126 240V AC TWD-0246 480V AC TWD-0486 Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Non-Illuminated Selector Switches (Assembled) Signaling Lights A S D 2 ( ) ( ) 11 Relays & Sockets Assembled Selector Switches N – ( ) Circuit Number S: Selector Switch Series Designation (See Circuit # column of Selector Switch Contact Arrangement Chart on beginning on page 679.) D: TWTD Series Contact Arrangement Code Number of Positions 2: 2-Position 3: 3-Position 10: 1NO 20: 2NO 40: 4NO 11: 1NO-1NC Spring Return Action Operator Style Code Blank: Maintained 1: Spring return from Right 2: Spring return from Left 3: 2-Way spring return from Left and Right Blank: Knob Operator L: Lever Operator K: Key Operator Timers Function 01: 1NC 02: 2NC 04: 4NC 22: 2NO-2NC Contactors Terminal Blocks 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. Custom key removal codes available. Please contact IDEC for details. Circuit Breakers 800-262-IDEC (4332) • USA & Canada 673 Switches & Pilot Devices Non-Illuminated Selector Switches (Assembled) Non-Illuminated 2-Position Selector Switches Style Mounting Operator Position 1NO 1 2 O O X O 1NC 1 2 X O O O 1NO 1NC 1 2 X O O X 2NO 1 2 O O X X 2NC 1 2 X X O O 1 2 3 4 1 2 3 4 O X O X O O X X X O X O X X O O 2NO 2NC 2NO 2NC Timers Part Number Contact Relays & Sockets Signaling Lights Switches & Pilot Devices ø30mm - TWTD Series L R Spring Return from Right Maintained L L R Spring Return from Left L R R Knob Lever Key Knob Lever Key Knob Lever Key Knob Lever Key Knob Lever Key ASD210N ASD2L10N ASD2K10N ASD201N-116 ASD2L01N-116 ASD2K01N-116 ASD211N ASD2L11N ASD2K11N ASD220N ASD2L20N ASD2K20N ASD202N-104 ASD2L02N-104 ASD2K02N-104 ASD2110N ASD21L10N ASD21K10N ASD2101N-116 ASD21L01N-116 ASD21K01N-116 ASD2111N ASD21L11N ASD21K11N ASD2120N ASD21L20N ASD21K20N ASD2102N-104 ASD21L02N-104 ASD21K02N-104 ASD2210N ASD22L10N ASD22K10N ASD2201N-116 ASD22L01N-116 ASD22K01N-116 ASD2211N ASD22L11N ASD22K11N ASD2220N ASD22L20N ASD22K20N ASD2202N-104 ASD22L02N-104 ASD22K02N-104 Knob Lever Key ASD222N ASD2L22N ASD2K22N ASD2122N ASD21L22N ASD21K22N ASD2222N ASD22L22N ASD22K22N Knob Lever Key ASD222N-111 ASD2L22N-111 ASD2K22N-111 ASD2122N-111 ASD21L22N-111 ASD21K22N-111 ASD2222N-111 ASD22L22N-111 ASD22K22N-111 Non-Illuminated 3-Position Selector Switches Part Number Maintained Spring Return from Right Spring Return from Left Spring Return Two-Way Mounting Operator Position Contact Terminal Blocks Contactors Style 2NO 1 2 X O O O O X Knob Lever Key ASD320N ASD3L20N ASD3K20N ASD3120N ASD31L20N ASD31K20N ASD3220N ASD32L20N ASD32K20N ASD3320N ASD33L20N ASD33K20N 2NC 1 2 O X X X X O Knob Lever Key ASD302N ASD3L02N ASD3K02N ASD3102N ASD31L02N ASD31K02N ASD3202N ASD32L02N ASD32K02N ASD3302N ASD33L02N ASD33K02N 2NO 2NC 1 2 3 4 X O O X O O X X O X X O Knob Lever Key ASD322N ASD3L22N ASD3K22N ASD3122N ASD31L22N ASD31K22N ASD3222N ASD32L22N ASD32K22N ASD3322N ASD33L22N ASD33K22N 1 2 3 4 1 2 3 4 1 2 3 4 X X O O O O O O X O X O X O O X O X O X O X O X Knob Lever Key ASD322N-309 ASD3L22N-309 ASD3K22N-309 ASD3122N-309 ASD31L22N-309 ASD31K22N-309 ASD3222N-309 ASD32L22N-309 ASD32K22N-309 ASD3322N-309 ASD33L22N-309 ASD33K22N-309 Knob Lever Key ASD322N-310 ASD3L22N-310 ASD3K22N-310 ASD3122N-310 ASD31L22N-310 ASD31K22N-310 ASD3222N-310 ASD32L22N-310 ASD32K22N-310 ASD3322N-310 ASD33L22N-310 ASD33K22N-310 Knob Lever Key ASD340N ASD3L40N ASD3K40N ASD3140N ASD31L40N ASD31K40N ASD3240N ASD32L40N ASD32K40N ASD3340N ASD33L40N ASD33K40N 1 2 3 4 O X O X O X X O X O X O O O O O X X X X Knob Lever Key ASD304N ASD3L04N ASD3K04N ASD3104N ASD31L04N ASD31K04N ASD3204N ASD32L04N ASD32K04N ASD3304N ASD33L04N ASD33K04N 2NO 2NC 2NO 2NC Circuit Breakers 1. The truth table indicates the operating position of contact block when the operator is switched to that position. X = On (closed contacts) O = Off (open contacts) X X = Overlapping Contacts: Remain on (closed contacts) when switch is moved between these two positions. 2. All knob and lever selector switches come in black. Other colors are available by ordering the knob or lever separately. 3. Custom contact arrangements available, see page 679. 4NO 4NC 674 L C R X O X O L C R L C www.IDEC.com R L C R L C R Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Non-Illuminated Selector Switches (Sub-Assembled) Contact Blocks + Operator + Knob or Lever* + Color Insert* = Complete Part† Operators Style Signaling Lights 1. *Not needed with key type switches. 2. †Knob type shown. Handles and Inserts Position Description 2 Knob/Lever 2 3 Spring return from right ASD2100 Spring return from left ASD2200 Maintained, Cam 1 Maintained, Cam 2 ASD300-1 ASD300-2 Spring return from right, Cam 1 Spring return from right, Cam 2 ASD3100-1 ASD3100-2 Spring return from left, Cam 1 Spring return from left, Cam 2 ASD3200-1 ASD3200-2 Spring return from left/right, Cam 1 Spring return from left/right, Cam 2 ASD3300-1 ASD3300-2 Maintained ASD2K00-RA Spring return from right ASD21K00-RL Spring return from left ASD22K00 Maintained, Cam 1 Maintained, Cam 2 ASD3K00-1 ASD3K00-2 Spring return from right, Cam 1 Spring return from right, Cam 2 ASD31K00-1-RLC ASD31K00-2-RLC Spring return from left, Cam 1 Spring return from left, Cam 2 ASD32K00-1-RRC ASD32K00-2-RRC Spring return from left/right, Cam 1 Spring return from left/right, Cam 2 ASD33K00-1-RC ASD33K00-2-RC Part Number Knob ASDHHY-j Lever ASDHHL-j* Color Insert TW-HC1-j 1. In place of j, specify the Color Code. *Not available in yellow. Contact Blocks Style All Control Units Dummy Block Part Number 1NO 1NC BST-010 BST-001 BST-010S (early make) BST-001S (late break) Contactors 1. Order knobs, levers, color inserts separately (see below). 2. For key switches, keys are removable in all maintained positions. Other options available, contact IDEC for details. 3. See page 681 “Operator Truth Tables” for details of difference between cams. Style Timers Key ASD200 Relays & Sockets 3 Part Number Maintained BST-D 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining BST-010S and BST-001S result in overlapping contacts (remain on, or closed, when switch is moved between two positions). j Color Codes Knob/Lever Color Code Black B S G Red R Yellow Y White W Terminal Blocks Blue Green 1. Knob/Lever not available in white. 2. Color inserts not available in Black. 3. Lever not available in yellow. Circuit Breakers 800-262-IDEC (4332) • USA & Canada 675 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWTD Series Signaling Lights Illuminated Selector Switches (Assembled) Assembled Illuminated Selector Switches Relays & Sockets A SL D 2 (2) 99 11 D N – 111 – R – 24 Function Lamp Voltage (Full Voltage Units Only) SL: Illuminated Selector Switch 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120V AC 240V: 240V AC (LED only) Series Designation D: TWTD series Number of Positions Lens Color Code Timers 2: 2-Position 3: 3-Position A: Amber G: Green R: Red S: Blue W: White Y: Yellow Spring Return Action Contactors Blank: Maintained 1: Spring return from Right 2: Spring return from Left 3: Two-Way spring return from Left and Right Circuit Code Number See Circuit # column of Selector Switch Contact Arrangement Charts on page 679. Rated Operational Voltage (Primary) Transformer Type 126: 120V AC 246: 240V AC 486: 480V AC Full Voltage Type 99: Full Voltage Lamp Type Blank: Incandescent Lamp D: LED Lamp Terminal Blocks Contact Arrangement Code 20: 2NO 02: 2NC 40: 4NO 04: 4NC 11: 1NO-1NC 22: 2NO-2NC Circuit Breakers Use only when interpreting part numbers. Do not use for developing part numbers. 676 www.IDEC.com Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Illuminated Selector Switches (Assembled) Illuminated 2-Position Selector Switches k LED/Lens Color Codes Style Part Number Spring Return from Right 1 2 O X X O Transformer Full Voltage ASLD2 m11nN-k ASLD29911nN-k-l ASLD21 m11nN-k ASLD219911nN-k-l ASLD22 m11nN-k ASLD229911nN-k-l 2NO 1 2 O O X X Transformer Full Voltage ASLD2 m20nN-k ASLD29920nN-k-l ASLD21 m20nN-k ASLD219920nN-k-l ASLD22 m20nN-k ASLD229920nN-k-l 2NC 1 2 X X O O Transformer Full Voltage ASLD2 m02nN-104-k ASLD29902nN-104-k-l ASLD21 m02nN-104-k ASLD219902nN-104-k-l ASLD22 m02nN-104-k ASLD229902nN-104-k-l 2NO 2NC 1 2 3 4 O X O X X O X O Transformer Full Voltage ASLD2 m22nN-k ASLD29922nN-k- l ASLD21 m22nN-k ASLD219922nN-k-l ASLD22 m22nN-k ASLD229922nN-k-l 2NO 2NC 1 2 3 4 O O X X X X O O R Lamp Circuit Type Transformer Full Voltage L L R ASLD2 m22nN-111-k ASLD29922nN-111-k-l L R ASLD21 m22nN-111-k ASLD219922nN-111-k-l R Code A Green G Red R Blue S White W Yellow Y l Full Voltage Codes Voltage ASLD22 m22nN-111-k ASLD229922nN-111-k-l Code 6V AC/DC 6V 12V AC/DC 12V 24V AC/DC 24V 120V AC 120V 240V AC 240V (LED only) Relays & Sockets 1NO 1NC L Color Amber Signaling Lights Mounting Maintained Contact Operator Position Spring Return from Left Illuminated 3-Position Selector Switches, Maintained and Spring Return Style Part Number Spring Return From Right Spring Return from Left Spring Return Two-Way Mounting Maintained Contact Operator Position 2NO 1 2 X O O O O X Transformer Full Voltage ASLD3 m 20nN-k ASLD39920nN-k-l ASLD31 m 20nN-k ASLD319920nN-k- l ASLD32 m 20nN-k ASLD329920nN-k-l ASLD33 m 20nN-k ASLD339920nN-k-l 2NC 1 2 O X X X X O Transformer Full Voltage ASLD3 m 02nN-k ASLD39902nN-k-l ASLD31 m 02nN-k ASLD319902nN-k-l ASLD32 m 02nN-k ASLD329902nN-k-l ASLD33 m 02nN-k ASLD339902nN-k-l 2NO 2NC 1 2 3 4 X O O X O O X X O X X O Transformer Full Voltage ASLD3 m 22nN-k ASLD39922nN-k-l ASLD31 m 22nN-k ASLD319922nN-k-l ASLD32 m 22nN-k ASLD329922nN-k-l ASLD33 m 22nN-k ASLD339922nN-k-l 2NO 2NC 1 2 3 4 X X O O O X X O X O O X Transformer Full Voltage ASLD3 m 22nN-309-k ASLD39922nN-309-k-l ASLD31 m 22nN-309-k ASLD319922nN-309-k-l ASLD32 m 22nN-309-k ASLD329922nN-309-k-l ASLD33 m 22nN-309-k ASLD339922nN-309-k-l 2NO 2NC 1 2 3 4 O O O O X O X O O X O X Transformer Full Voltage ASLD3 m 22nN-310-k ASLD39922nN-310-k-l ASLD31 m 22nN-310-k ASLD319922nN-310-k-l ASLD32 m 22nN-310-k ASLD329922nN-310-k-l ASLD33 m 22nN-310-k ASLD339922nN-310-k-l 4NO 1 2 3 4 X O X O O O O O O X O X Transformer Full Voltage ASLD3 m 40nN-k ASLD39940nN-k-l ASLD31 m 40nN-k ASLD319940nN-k-l ASLD32 m 40nN-k ASLD329940nN-k-l ASLD33 m 40nN-k ASLD339940nN-k-l 4NC 1 2 3 4 O X O X X X X X X O X O Transformer Full Voltage ASLD3 m 04nN-k ASLD39904nN-k-l ASLD31 m 04nN-k ASLD319904nN-k-l ASLD32 m 04nN-k ASLD329904nN-k-l ASLD33 m 04nN-k ASLD339904nN-k-l L C R Lamp Circuit Type L C R C L R L R Terminal Blocks Lamp Code 126 246 486 Incandescent Blank LED D Circuit Breakers Code 120VAC 240VAC 480VAC 800-262-IDEC (4332) • USA & Canada R n Lamp Type Codes Voltage Transformers step down to 6V (use 6V lamp). C Contactors m Transformer Voltage Codes C Timers 1. In place of k, specify the Lens/LED Color Code, in place of l, specify the Full Voltage (lamp voltage) Code, in place of m, specify the Transformer Voltage Code and in place of n specify the Lamp Type Code. 2. The truth table indicates the operating position of contact block when the operator is switched to that position. X = On (Closed Contacts) O = Off (Open Contacts) X X = Overlapping Contacts: Remain on (closed contacts) when switch is moved between these positions 3. Yellow selector switch comes with white LED. L Light is independent of switch position. 677 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWTD Series Illuminated Selector Switches (Sub-Assembled) Transformer* + Contact Block + Operator + Lamp + Lens = Complete Part Signaling Lights *Not required for full voltage units (use APD-F full voltage clips instead). Operators Style Contact Blocks Position Part Number 2 Maintained ASLD200 3 Maintained, Cam 1 Maintained, Cam 2 ASLD300-1 ASLD300-2 Spring return from right ASLD2100 Spring return from left ASLD2200 Spring return from right, Cam 1 Spring return from right, Cam 2 ASLD3100-1 ASLD3100-2 Spring return from left, Cam 1 Spring return from left, Cam 2 ASLD3200-1 ASLD3200-2 Spring return from left/right, Cam 1 Spring return from left/right, Cam 2 ASLD3300-1 ASLD3300-2 Operator 2 Relays & Sockets Description 3 Part Number Style All Control Units 1NO 1NC BST-010 BST-001 BST-010S (early make) BST-001S (late break) Dummy Block BST-D 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining BST-010S and BST-001S result in overlapping contacts (remain on, or closed, when switch is moved between two positions). Full Voltage Clips Style Timers Lenses Style Part Number Part Number Full Voltage Clips (2 required for each unit) APD-F Required for all full voltage models. Knob ASLNHU-j Transformers Contactors Style Lamps Style Terminal Blocks LED Incandescent Voltage Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 120V AC TWD-0126 240V AC TWD-0246 480V AC TWD-0486 Transformers LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 Color Code 120V AC L-120L Amber A Blue S Green G White W Red R Yellow Y 6V secondary voltage. k LED/Lens Color Codes Circuit Breakers Part Number 24V AC/DC 1. In place of k, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. 678 Primary Voltage (50/60Hz) Color Code Yellow lens only. Yellow LED not available, use white LED. www.IDEC.com Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Contact Arrangement Charts How to Read Contact Arrangement Charts To determine contact block mounting position, first make sure the selector switch is oriented as shown on the right Operator Position Contact Arrangement Type and quantity of switch contacts Contact Block Mounting Position Circuit Number Position or mounting contact blocks on operator X = On (Closed Contacts) O = Off (Open Contacts) X X = Overlapping Contacts: Remain on (closed) when switch is moved between these two positions Contact Arrangement Chart: 2-Position Selector Switches Style 1NO N/D 1NC 116 1NO 1NC 103 600 601 N/D 2NC 104 N/D 2NO 2NC 110 4NO N/D R 1 O X BST-010 2 O O BST-D 1 X O BST-001 2 O O BST-D 1 O X BST-010 2 X O BST-001 1 X O BST-001 2 O X BST-010 1 O X BST-010S 2 X O BST-001S 1 X O BST-001S 2 O X BST-010S 1 O X BST-010 2 O X BST-010 1 X O BST-001 2 X O BST-001 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 O X O X X O X O O O X X O O O O X O X O O X O X X X O O X X X X BST-010 BST-001 BST-010 BST-001 BST-001 BST-010 BST-001 BST-010 BST-010 BST-010 BST-001 BST-001 BST-010 BST-010 BST-010 BST-010 L R Spring Return from Right L R Spring Return from Left L Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 Knob/Lever Key Illuminated Knob ASD200 ASD2K00 ASLD200 ASD2100 ASD21K00 ASLD2100 ASD2200 ASD22K00 ASLD2200 800-262-IDEC (4332) • USA & Canada R Circuit Breakers 111 L Maintained Description Terminal Blocks 2NO Contact Block Part Number Contactors 1NO-EM 1NC-LB Operator Part Number Timers N/D Mounting Position Part number to use when ordering sub-assembly contact blocks, as required for use with corresponding mounting position Relays & Sockets Contact Circuit Number Operator Position Contact Block Part Number Signaling Lights * N/D = No designation Truth table indicates the operating position of contact block when operator is switched to that position. 679 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWTD Series Contact Arrangement Chart: 3-Position Selector Switches Style Operator Part Number Operator Position Contact Circuit Number Signaling Lights 202 203 1NO 1NC 302 Relays & Sockets 303 N/D 2NO 301 Timers 304 2NC N/D Contactors N/D 210 2NO 2NC Terminal Blocks 308 309 Circuit Breakers 310 Mounting Position Contact Block Part Number L C 1 X O O BST-010 2 X X O BST-001 1 O X X BST-001 2 O O X BST-010 1 X O X BST-010 2 X X O BST-001 1 O X O BST-001 2 O O X BST-010 1 X O O BST-010 2 O O X BST-010 1 X O X BST-010 2 O O X BST-010 1 O X O BST-001 2 X X O BST-001 1 O X X BST-001 R Description Maintained L 2 X X O BST-001 1 X O O BST-010 2 O O X BST-010 3 O X X BST-001 4 X X O BST-001 1 O X X BST-001 2 O O X BST-010 3 O X X BST-001 4 O O X BST-010 1 X O X BST-010 2 X X O BST-001 3 X O X BST-010 4 X X O BST-001 1 X O X BST-010 2 X X O BST-001 3 O X O BST-001 4 O O X BST-010 1 O X O BST-001 2 O O X BST-010 3 O X O BST-001 4 O O X BST-010 C R Spring Return from Right L C R Spring Return from Left L C R Two-Way L C R Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 1. Each operator sub-assembly is available as a “-1” and a “-2” for 3-position selector switches. The internal cam of a “-1” is different from that of a “-2”. This results in designated combinations of open and closed contacts in the various operator positions. 2. N/D = No circuit number designation required in assembled part number. 3. X = On (closed contacts) O = Off (open contacts). X X Overlapping contacts remain on (closed) when switch is moved between these two positions. 680 www.IDEC.com Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Contact Arrangement Chart: 3-Position Selector Switches Style Operator Part Number Operator Position Contact Circuit Number Mounting Position N/D 305 4NC 314 L 1 X O O BST-010 2 O O X BST-010 3 X O O BST-010 4 O O X BST-010 1 X O X BST-010 2 O O X BST-010 3 X O X BST-010 4 O O X BST-010 1 O X X BST-001 2 X X O BST-001 3 O X X BST-001 4 X X O BST-001 1 O X O BST-001 2 X X O BST-001 3 O X O BST-001 4 X X O BST-001 C R L C Spring Return from Left L R C R Two-Way L C R Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Knob/Lever Key Illuminated Knob ASD300-1 ASD3K00-1 ASLD300-1 ASD3100-1 ASD31K00-1 ASLD3100-1 ASD3200-1 ASD32K00-1 ASLD3200-1 ASD3300-1 ASD33K00-1 ASLD3300-1 Knob/Lever Key Illuminated Knob ASD300-2 ASD3K00-2 ASLD300-2 ASD3100-2 ASD31K00-2 ASLD3100-2 ASD3200-2 ASD32K00-2 ASLD3200-2 ASD3300-2 ASD33K00-2 ASLD3300-2 Relays & Sockets N/D R Description Maintained Signaling Lights 4NO C L Contact Block Part Number Spring Return from Right Operator Truth Tables Timers 1. Each operator sub-assembly is available as a “-1” and a “-2” for 3-position selector switches. The internal cam of a “-1” is different from that of a “-2”. This results in designated combinations of open and closed contacts in the various operator positions. 2. N/D = No circuit number designation required in assembled part number. 3. X = On (closed contacts) O = Off (open contacts). X X Overlapping contacts remain on (closed) when switch is moved between these two positions. Use the following tables to build custom selector switches. 2 Position Selector Switches Contact 3 Position Selector Switches Mounting Position BST-001 (NC) ASD200 BST-010S (NO-EM) Right L O X R O X L X O R X O L O X R O X L X O R X O Contact BST-010 (NO) ASD300-1 ASLD300-1 ASD3K00-1 AYLD22 Contact Operator Position Pull Normal BST-010S (NO-EM) BST-001S (NC-LB) 3 Position Push/Pull Switches Contact BST-001 (NC) Push O O X BST-001 (NC) X O O BST-010S (NO-EM) O X X BST-001S (NC-LB) X X O ASD300-2 ASLD300-2 ASD3K00-2 BST-001 (NC) BST-010S (NO-EM) BST-001S (NC-LB) 800-262-IDEC (4332) • USA & Canada Operator Position Left Center Right L X O O R O O X L O X X R X X O L X O O R O O X L O X X R X X O Operator Position Mounting Position Left Center Right L X O X R O O X L O X O R X X O L X O X R O O X L O X O R X X O Circuit Breakers BST-010 (NO) BST-010 (NO) Mounting Position Terminal Blocks BST-001S (NC-LB) Left Contactors BST-010 (NO) Operator Position 681 Switches & Pilot Devices Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø30mm - TWTD Series Accessories — TWTD Series TWTD Series Accessories Item Lamp Removal Tool Metal Bezel Plastic Bezel Boot/Cover Contactors Description/Usage Rubber tool used to install or remove LED’s and incandescent lamps Replacement locking ring/ bezel OR-55 Standard octagonal units (chrome-pl.). OG-81 Extended, non-illuminated (chrome-pl.). OG-82 Extended, illuminated (chrome-pl.). OG-83L Jumbo Mushroom Shallow Shroud ABN4G Jumbo Mushroom Deep Shroud ABN4F Black plastic locking ring/bezel Used to cover and protect pushbuttons Part Number OGP11B In place of j, specify Neoprene Rubber Boot color: B (black), G (green), R (red), Y (yellow) OC-11 j Flush units (clear plastic -40˚ to +60˚C). OC-121 Extended units (clear plastic -40˚ to +60˚C). OC-122 Plastic washer For nameplates or panels that should not be scratched. OGL-D1T Thrust washer/Anti-rotation ring for use with notched panel cutout. OGL-D1S Anti-Rotation Ring Mounting Hole Plug Plugs used to fill unused 30mm panel cutouts. Plastic with locking nut attached. OBP-11 Metal with locking nut attached OB-11 Grey rubber (-5˚ to +60˚C) OB-13 Terminal Tab Adaptor Tab #250 17/64” x 3/64” (6.35mm x 0.8mm): Single tab Full Voltage Adaptor Used on all full voltage illuminated units. Two required per unit. (M3.5 screw and saddle) APD-F Lock Out Adaptor Used to provide lockout protection for TWTD pushbuttons and knob selectors. ø 1-13/64” (30mm) OL-KL1 Replacement Keys Pair of keys (#0) TW-SK Circuit Breakers Terminal Blocks Appearance 682 www.IDEC.com TW-FA1 Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Fingersafe Covers for TWTD Series Item Description Used with Part Number Fingersafe terminal cover, for full voltage pilot lights, adds 3mm to overall depth APD199... full voltage pilot lights Fingersafe terminal cover, for contact blocks, adds 3mm to overall depth Non-Illuminated pushbuttons ABD..., and AOD... N-VL2 Fingersafe terminal cover, adds 1.5mm to overall depth Transformer pilot lights and illuminated units N-VL3 Fingersafe terminal cover, adds 4 mm to depth Full voltage illuminated pushbuttons N-VL4 APD-PVL Signaling Lights Relays & Sockets Timers Dimensions on page 687. Contactors Terminal Blocks Circuit Breakers 800-262-IDEC (4332) • USA & Canada 683 Switches & Pilot Devices Nameplates — TWTD Series Faceplates Ø1.19" (30.5mm) Description Timers (30.5mm) 30.5mm Part Number Nameplate (blank) NALD-B (black) NALD-R (red) NAKD-B (black) NAKD-R (red) NAQD-B (black) NAQD-R (red) HNAV-O Nameplate (engraved) NALD-j NAKD-j NAQD-j HNAV-27 “Emergency Stop” 1. Nameplates are made of 0.031” aluminum. Lettering is white letters engraved on black background. 2. In place of j, insert either the standard legend code from table below or custom engraving delimited by “ “. 3. HNAV available in yellow only. Standard Legend Codes Legend Contactors Ø1.19" 5mm Pushbuttons AUTO CLOSE DOWN EMERG.STOP* FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON Code 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 Pushbuttons/Selector Switches Legend OPEN OUT RAISE RESET REVERSE RUN SLOW START STOP* STOP TEST UP I (Int’l On) O (Int’l Off) EMO Code 116 117 118 119 120 121 122 123 124 125 126 127 150 151 152 Legend AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWER-RAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISE-LOWER Code 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 Legend REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN 1. *Available in Red as standard legend code 104 and 124. To order engraved nameplate and codes, add legend code to nameplate part number. Character height based on the number of characters, space and size of nameplate. Standard character size is 3/16”. 2. Nameplates with standard legends are the same list price as blank nameplates. Special engravings, additional cost. To specify engraving instructions, use the Nameplate order form on next page. Circuit Breakers Terminal Blocks HNAV 1.95" (50mm) 1.95" (50mm) (30.5mm) 2.24" (57.5mm) Signaling Lights Ø1.19" NAQD 2.03" (52mm) 1.56" (40mm) Dimensions Relays & Sockets NAKD ø60mm NALD 1.85" (47.5mm) Switches & Pilot Devices ø30mm - TWTD Series 684 www.IDEC.com Selector Switches Code 216 217 218 219 220 221 222 223 Legend AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFF-WINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO Code 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 Switches & Pilot Devices ø30mm - TWTD Series Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To ensure engraving accuracy, fax it to your IDEC representative. or Distributor. IDEC Rep/Distributor Contact:__________________________________ Your Name:__________________________________________ PO number (if known):__________________________________ Telephone:__________________________________________ IDEC Rep/Distributor Phone:__________________________________ IDEC Rep/Distributor Fax & Email:__________________________________ Fax & Email:__________________________________________ NALD Nameplate Step 1. Engraving Location Sample Letter Sizes Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 13 characters. 7/64” Letters: 7/64” 11 characters max (for 7/64” size letters) 1/8” 9 characters max (for 1/8” size letters) Letter Size 1/8” Letters: Letter Size Relays & Sockets Choose Letter Size - 7/64” or 1/8”. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. Qty 1 2 3 4 5 6 7 8 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Signaling Lights Your Company Name:__________________________________________ Switches & Pilot Devices Custom engraved Nameplates Order Form — TWTD Series 9 10 11 12 13 14 15 16 Step 1. NAKD Nameplate Timers Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 9 characters. Engraving Location Step 2. Specify Quantity. NAQD Nameplate Sample Letter Sizes Qty 1/8” Letters: Step 1. Choose Letter Size - 7/64” or 1/8”. 2 3 20 characters max (for 7/64” size letters) 1/8” 16 characters max (for 1/8” size letters) Letter Size 4 5 8 9 10 11 12 13 14 15 16 17 18 19 20 Sample Letter Sizes Specify Quantity. Enter the number of nameplates desired in the box on the right. 7 Circuit Breakers Step 2. 6 Terminal Blocks 1 7/64” Letter Size Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 16 characters. Engraving Location Contactors Enter the number of nameplates desired in the box on the right. 1 3/32” Letters: 1/8” Letters: Qty 800-262-IDEC (4332) • USA & Canada 685 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø30mm - TWTD Series Switch Engraving Order Form – TWTD Series Copy this order form and use it to specify Letter Height, Maximum Number of Lines and Text to be engraved. To insure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: Telephone: Name: Fax: Address: Email: PO: Part Number to be Engraved: Please check one of the boxes below to indicate your choice of engraving options: ø29mm, ø40mm Mushroom Head 65mm Jumbo Mushroom Relays & Sockets Square Switch Engraving Engraving Area 1 Area 2† # of Lines Letter Height Max. Characters Per Line 5/32 7 # of Lines 1 Letter Height Max. Characters Per Line 3/4 4 1 1/8 8 5/32 7 5/16 5/16 5 5 Timers 2 3 1/8 8 1/8 8 4 2 Custom* Contactors Round Switch 4 Letter Height Max. Characters Per Line 5/32 7 1/8 8 1 6 5/32 8 5/32 8 1/8 9 1/8 9 3 *Engraving is possible, but character size will be smaller than standard sizes. # of Lines 1/4 Terminal Blocks 3 Circuit Breakers 4 1 Engraving Area 2 1 Max. Characters Per Line 5/32 5 1/8 5 5/32 7 1/8 7 1. Above mentioned specifications hold true for standard size pushbuttons (round and square). 2. †Engraving Area 2 can be engraved for 40mm mushroom head non-Illuminated pushbutton only. 3. Engraving is done on the button itself for non-Illuminated push buttons and on marking plate for illuminated push buttons and pilot lights. 4. Please enter text exactly how you want it engraved, take care to emphasize capital or small letters. 1/8 Letters: 5/32 7 1/8 8 Line 3: 1/8 8 Line 4: 5/32 Letters: Line 2: Custom* *Engraving is possible, but character size will be smaller than standard sizes. For IDEC Internal Use Only: Work Order #: 686 Engraving Area 1 Letter Height Enter text to be engraved: Sample Letter Sizes Line 1: 2 # of Lines www.IDEC.com All engraving is 5/8mm wide. Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices Dimensions (mm) Pushbutton Panel Thickness 0.8 to 7.5 40 9 14.5 76 (3 or 4 blocks) Panel Thickness 0.8 to 7.5 ø40 ø40 23 ø 0.975” (25mm) ø 0.975”(25mm) ø 1.11” (28.5mm) Mushroom Mushroom w/Full Shroud Jumbo Mushroom ø 1.56” (40mm) 0.858” (22mm) 0.936” (24mm) 1.13” (29mm) ø 1.56” (40mm) ø 1.87” (48mm) ø 2.54” (65mm) Mushroom, Pushlock Turn Reset and Push-Pull ø 1.56” (40mm) *0.975” (25mm) **0.975” (25mm) ø 1.56” (40mm) ø 1.56” (40mm) *Dimension when operator is in reset position. **Dimension when operator is in pull position. 40 22 w/Transformer M3.5 Terminal Screw Full Voltage Panel Thickness 0.8 to 7.5 M3.5 Terminal Screw Panel Thickness 0.8 to 7.5 M3 Terminal Screw ø24 ø40 B ø35 M3 Terminal Screw 5.5 40 23 40 9 9 24 63 (2 blocks) 86 (4 blocks) A Dimension B Flush w/Full Shroud 0.975” (25mm) 0.995” (25.5mm) ø 0.936” (24mm) ø 0.936” (24mm) Extended w/Full Shroud 0.741” (19mm) 0.761” (19.5mm) ø 0.936” (24mm) ø 0.936” (24mm) ø 1.56” (40mm) Mushroom Pushlock Turn Reset, Push-Pull *0.975” (25mm) **0.975” (25mm) ø 1.56” (40mm) ø 1.56” (40mm) Pilot Lights M3.5 Terminal Screw M3.5 Terminal Screw Timers Dimension A Panel Thickness: 0.8 to 7.5 mm ø25 97.5 (2 blocks) 120.5 (4 blocks) Illuminated Pushbuttons Relays & Sockets Illuminated Pushbuttons ø40 76 (3 or 4 blocks) A:29.5 B:64.5 ø40 53 (1 or 2 blocks) ø35 5.5 0.351” (9mm) 0.566” (14.5mm) 0.663” (17mm) Signaling Lights Mushroom Pushbutton w/Full Shroud M3.5 Terminal Screw Dimension B ø35 53 (1 or 2 blocks) Dimension A Flush Extended Extended w/Full Shroud ø40 ø25 23 5.5 Pushbuttons ø35 M3.5 Terminal Screw 9 40 22 Contactors *Dimension when operator is in reset position. **Dimension when operator is in pull position. Selector Switches 45 5.5 40 23 53 (1 or 2 blocks) 21 76 (4 blocks) 5.5 40 21.5 76 (4 blocks) 45 45 ø40 ø35 53 (1 or 2 blocks) 90 M3.5 Terminal Screw 45 45 23 9 53 (1 or 2 blocks) 16.5 Terminal Blocks 23 5.5 Panel Thickness 0.8 to 7.5 90 M3.5 Terminal Screw ø40 45 ø35 M3.5 Terminal Screw Key Panel Thickness 0.8 to 7.5 90 ø40 Lever Panel Thickness 0.8 to 7.5 ø35 Knob 40 38 76 (4 blocks) Illuminated Knob Panel Thickness 0.8 to 7.5 (including nameplate) 40 23 63 (2 blocks) A: 86 (4 blocks) B: 97.5 (2 blocks), 120.5 (4 blocks) 45 Circuit Breakers 5.5 90 45 ø40 ø25 M3 Terminal Screw ø35 M3.5 Terminal Screws 9 28 800-262-IDEC (4332) • USA & Canada 687 Switches & Pilot Devices Selector Switches Panel Cut-Out Ø 0.195" (5mm) 1. *Jumbo Mushroom < 2.61” (66mm) 2. Minimum mounting centers are applicable to switches with one stack of contact blocks. When mounting two stacks of contact blocks, minimum centers should allow for access to wiring. 3. The ø 0.195” (ø 5mm) recess is necessary when either the nameplate or anti-rotation ring is used. Ø 1.20" (30.5mm) 1.64" (42mm) > 1.95" (50mm)* IlluminatedSelector Switches OL-KL1 OC-31 Lock-Out Adaptor Pushbutton Clear Boot OGL-31 OB-31 Anti-Rotation Ring Mounting Hole Rubber Plug ø29 82.5 70 30 10.2 93 6.5 24 ø3 0 3.5 ø32.6 R6 Relays & Sockets Panel Thickness 0.8 to 3.2 18 (OC-31) 22 (OC-32) ø22 ø27.4 0.8 0. ø5 2 Key Hole ø8 29.5 Waterproof Rubber Gasket 0.5t 30 N-VL2 N-VL3 N-VL4 Contactors Timers Finger-Safe Cover Circuit Breakers Terminal Blocks APD-PVL 688 www.IDEC.com ø25 3.5 Signaling Lights Switches & Pilot Devices ø30mm - TWTD Series Switches & Pilot Devices ø30mm - TWTD Series Adjustment for Panel Thickness Installation of LED Illuminated Units Each unit is shipped with several waterproof gaskets which are 0.06” (1.5mm) and 0.12” (3mm) thick. Combine the gaskets for a dimension approximately equal to panel thickness and install between the bezel and the body of the unit. Transformer units are recommended for use in areas subjected to inductive noise. When using full voltage types, install a protection diode as shown below. Use diode with DC power supply to protect against surges and noise. Signaling Lights Switches & Pilot Devices Operating Instructions Make sure that LED illuminated units are installed with correct polarity, as indicated at the terminals. Application Example For Push-To-Test Pilot Light A typical application of illuminated pushbuttons is a push-to-test pilot light which can be used to check the lamp/LED circuit. Relays & Sockets Transformer/AC-Adapter Circuit A trim washer must be used with a thrust washer or a nameplate to prevent the control unit from rotating in the mounting hole. When using anti-rotation rings (trim washer with thrust washer or nameplate), install as shown below. The operator shaft of each unit has a recess to identify in which direction to install the handle. Align the handle with the recess. Press color insert (TW-HC1) into the Standard Operating Positions. Timers Selector Switches Full Voltage Circuit Standard Operation Positions 2-Position, 90° 3-Position, 45° 1 1 Contactors 0 2 2 Non-Illuminated 3-Position Operators 1 0 1 2 1 0 0 2 2 Terminal Blocks Installation of TWTD Series Units TWTD Pilot Lights TWTD Illuminated Pushbuttons TWTD Selector Switches (Transformer or Full Voltage) Circuit Breakers Terminal X1 = Positive Terminal X2 = Negative 800-262-IDEC (4332) • USA & Canada 689
ASDHHL-B 价格&库存
很抱歉,暂时无法提供与“ASDHHL-B”相匹配的价格&库存,您可以联系我们找货
ASDHHL-B
    • 1+28.64160
    • 200+11.42640
    • 500+11.04840
