BNJ16F
BNJ16F
    IDEC(日本和泉)
BNJ16F 数据手册
BN1U Spring-Up Screw Terminal Blocks [Actual Size] BN1U Spring-Up Screw Terminal Blocks Spring-up screws save up to 30% wiring time (compared to IDEC standard terminal blocks) The terminal screw is always in the lifted position, ready for wiring. A ring terminal can be inserted easily. 2 Immediate Tightening 1 Temporary Hold 2 Push the terminal screw straight down to the bus bar using a screwdriver. After pressing the terminal screw to the bus bar, tilt the terminal screw in the the direction as shown. 3 3 Tighten the terminal screw. When tightening the screw, make sure that it is in the upright position. 4 4 When loosening, the screw springs straight up. Tighten the terminal screw. If the screw stops at the temporary position, the screw will return to the original position by pushing further down. BN1U-16W, BN1U-20W, BN1U-40W all have the same height and width. The same dust covers, marking strips (9.5-mm-wide), and end plates can be used. Width: 38 34 Height: 34 3 5.9 6.7 9.6 7 8 11 All dimensions in mm. Mount to a 35-mm-wide DIN rail or a 30-mm-wide C type rail. Each block can be easily removed from a 35-mm-wide DIN rail using a flat screwdriver. Terminal block to be removed Flat screwdriver Disconnect the terminal blocks ∗ ∗ ∗ Leave a space of about 5 mm. 35-mm-wide DIN rail UL recognized for field wiring (FW2). Detach from the joints UL recognized, CSA certified, and EN compliant (TÜV approved). UL1059 File No. E78117 UL CSA C22.2 No.158 File No. LR64803 CSA TÜV TÜV Rheinland EN60947-7-1 License No. R 9551701 RoHS directive compliant 2 When removing each block, disconnect the blocks on either side. Then, insert the flat screwdriver into the groove of the terminal block as shown in the left diagram. BN1U Spring-Up Screw Terminal Blocks Types 16A BN1U-20W M3 BN1U-40W M3.5 TÜV Rheinland 10.8 7 38 18 3 6.7 Ordering Type No. BN1U-16WPN50 BN1U-20WPN50 Package Quantity 50 50 Weight (Approx.) 11.8 8 7g 38 19.4 3 31 23.8 31 23.8 When using DIN Rail: 36.5 When using C Rail: 43.7 34 5.9 M4 TÜV Rheinland When using C Rail: 43.7 34 38 18 3 When using DIN Rail: 36.5 Dimensions 40A 9.6 When using DIN Rail: 36.5 When using C Rail: 43.7 34 TÜV Rheinland 21A 15.1 11 31.9 24.7 BN1U-16W Type No. BN1U-40WPN50 50 8g 14g Specifications and Ratings UL Standards CSA UL1059 Insulation Voltage EN CSA22.2 No.158 600V Wire Size 22-14 AWG Rated Current JIS C 2811 UL CSA UL1059 660V 600V 22-14 AWG 1.25 mm2 (2 mm2) 22-14 AWG 22A 16A 15A JIS UL EN 60947-7-1 JIS C 2811 660V 600V 600V 2 mm2 22-14 AWG CSA UL1059 CSA22.2 No.158 EN JIS EN 60947-7-1 JIS C 2811 660V 600V 600V 2 mm 18-10 AWG 21A 35A 22A M3 Max. No. of Crimp Terminals EN CSA22.2 No.158 2 mm2 15A Terminal Screw JIS EN 60947-7-1 2 5.5 mm2 18-10 AWG 38A M3.5 2 2 2 0.6 to 1.0 N·m 1.0 to 1.3 N·m 1.4 to 2.0 N·m Terminal Centers 7 mm 8 mm 11 mm 5 max. ø4.2 min. 6.6 max. 5.8 max. –25 to +55℃ (no freezing) Operating Humidity 45 to 85% RH (no condensation) Mounting Method Rail mounting Insulation Resistance 100 MΩ minimum (500V DC megger) Dielectric Strength 2500V AC, 1 minute Vibration Resistance Frequency: 5 to 55 Hz, Amplitude: 0.5 mm Shock Resistance 1000 m/s2 (100G) 9.5 max. 5 max. 3.3 min. Operating Temperature Accessories ø3.6 min. ø3.2 min. End Plate BN9Z-E16W Dust Cover BTB-CV30L2 (1000 mm), BTB-CV30L1 (500 mm) Marking Strip BNM7: PVC 1m, BNM9: Fiber glass: 1m, BNM725: PVC 25m Marking Strip Fastener BNM3 DIN Rail / End Clip BAA1000: Aluminium, BAP1000: Steel / BNL6 C Rail / End Clip BNCA1000: Aluminium, BNCP1000: Steel / BNL7 35 mm DIN + C Rail / End Clip BNJA1000: Aluminium / BNL6 (35-mm-DIN rail side), BNL7 (C rail side) Jumpers BNJ16, BNJ16B BNJ16F, BNJ16FB 3.9 min. BNJ26W, BNJ26WB BNJ26FW, BNJ26FWB 4.5 min. 5.5 max. BPJ-56, BPJ-56B BPJ-56F, BPJ-56FB 38 End Plate Material 40A M4 Tightening Torque Crimp Terminal Dimensions (mm) 5.5 mm2 Housing Modified PPE (UL94V-0) Type No. BN9Z-E16W End Plate Modified PPE (UL94V-0) Ordering Type No. BN9Z-E16WPN10 Bus Bar Brass (nickel-plated) Applicable Terminal Block BN1U-16W, BN1U-20W, BN1U-40W Terminal Screw Steel (zinc trivalent chrome-plated) Package Quantity 10 Spring Stainless steel Weight (Approx.) 3g 5 3 BN1U Spring-Up Screw Terminal Blocks Accessories ••Rail Length Item Type No. 35-mm-wide DIN Rail 1000 mm 30-mm-wide C Rail 35-mm-wide DIN+C Rail BAA1000 BAP1000 BNCA1000 BNCP1000 BNJA1000 Ordering Type No. BAA1000PN10 BAP1000PN10 BNCA1000PN10 BNCP1000PN10 BNJA1000PN10 Material Weight (Approx.) Aluminum (anodized) Steel (trivalent chrome-plated) Aluminum (anodized) Steel (trivalent chrome-plated) Aluminum (anodized) 200g 320g 260g 700g 340g Package Quantity 10 10 10 10 10 ••End Clip Type No. Ordering Type No. BNL6 BNL7 Material (Surface Treatment) BNL6PN10 BNL7PN10 Weight (Approx.) Steel (trivalent chrome-plated) Steel (trivalent chrome-plated) 15.2g 16g Applicable Rail Package Quantity Applicable Terminal Blocks Package Quantity 35-mm-wide DIN Rail (BAA, BAP, BNJA) 30-mm-wide C Rail (BNCA, BNCP, BNJA) 10 10 ••Dust Cover Length Type No. 1000 mm 500 mm Ordering Type No. BTB-CV30L2 BTB-CV30L1 Material BTB-CV30L2PN10 BTB-CV30L1 Weight (Approx.) 53g 27g Polycarbonate (UL94V-0) BN1U-16W, BN1U-20W, BN1U-40W BN1U-16W, BN1U-20W, BN1U-40W 10 1 •• BNC230 dust cover (1000 mm) can also be mounted to the BN1U-16W and BN1U-20W terminal blocks. ••Marking Strip, Marking Strip Fastener Item Type No. BNM7 BNM9 BNM625 BNM725 BNM3 9.5-mm-wide Marking Strip Marking Strip Fastner Ordering Type No. BNM7PN10 BNM9PN10 BNM625 BNM725 BNM3PN50 Weight 7.2g 6.4g – – 0.1g Package Quantity Description 10 10 1 (25m) 1 (25m) 10 PVC (glossy surface), length 1000 mm × width 9.5 mm × thickness 0.5 mm Fiber glass (matte surface), length 1000 mm × width 9.5 mm × thickness 0.5 mm Polypropylene (glossy surface), length 25m × width 9.5 mm × thickness 0.5 mm PVC (matte surface), length 25m × width 9.5 mm × thickness 0.5 mm Material: polycarbonate ••Jumper Terminal Centers Terminal Style 7 mm (6 poles) 8 mm (6 poles) 11 mm (6 poles) Ring Fork Ring Fork Ring Fork Insulation Without With Without With Without With Without With Without With Without With Type No. BNJ16 BNJ16B BNJ16F BNJ16FB BNJ26W BNJ26WB BNJ26FW BNJ26FWB BPJ-56 BPJ-56B BPJ-56F BPJ-56FB Ordering Type No. BNJ16PN10 BNJ16BPN10 BNJ16FPN10 BNJ16FBPN10 BNJ26WPN10 BNJ26WBPN10 BNJ26FWPN10 BNJ26FWBPN10 BPJ-56PN10 BPJ-56BPN10 BPJ-56FPN10 BPJ-56FBPN10 Maximum Rated Current * Applicable Terminal Package Quantity 10A BN1U-16W 10 20A BN1U-20W 10 20A BN1U-40W 10 * The maximum rated current is the value of each pole. Notes on Wiring ••Tighten all terminal screws including unused terminal screws. ••Be careful not to drop a terminal block (without an end plate) as the spring may fall out from the housing. ••Tighten the terminal screw to the recommended tightening torque. Bus Bar ••Crimp Terminals ••When using crimp terminals, be sure to use insulated terminals to prevent electrical shocks. ••Without Crimp Terminals Wire ••Insert wire until the insulation comes into contact with the bus bar. ••Strip the insulation so that the wire is longer than the washer width. (BN1U-16W: approx. 9 mm, BN1U-20W: approx. 9 mm, BN1U-40W: approx. 11 mm) ••When connecting two wires, use wires of the same size. Specifications and other descriptions in this catalog are subject to change without notice. 7-31, Nishi-Miyahara 1-Chome, Yodogawa-ku, Osaka 532-8550, Japan Tel: +81-6-6398-2571, Fax: +81-6-6392-9731 E-mail: products@idec.co.jp IDEC CORPORATION (USA) 1175 Elko Drive, Sunnyvale, CA 94089-2209, USA Tel: +1-408-747-0550 / (800) 262-IDEC (4332) Fax: +1-408-744-9055 / (800) 635-6246 E-mail: opencontact@idec.com IDEC CANADA LIMITED Unit 22-151, Brunel Road, Mississauga, Ontario, L4Z 1X3, Canada Tel: +1-905-890-8561, Toll Free: (888) 317-4332 Fax: +1-905-890-8562 E-mail: sales@ca.idec.com IDEC AUSTRALIA PTY. LTD. 2/3 Macro Court, Rowville, Victoria 3178, Australia Tel: +61-3-9763-3244, Toll Free: 1800-68-4332 Fax: +61-3-9763-3255 E-mail: sales@au.idec.com IDEC ELECTRONICS LIMITED www.idec.com Unit 2, Beechwood, Chineham Business Park, Basingstoke, Hampshire RG24 8WA, UK Tel: +44-1256-321000, Fax: +44-1256-327755 E-mail: sales@uk.idec.com IDEC ELEKTROTECHNIK GmbH Wendenstrasse 331, 20537 Hamburg, Germany Tel: +49-40-25 30 54 - 0, Fax: +49-40-25 30 54 - 24 E-mail: service@idec.de IDEC (SHANGHAI) CORPORATION Room 608-609, 6F, Gangtai Plaza, No. 700, Yan'an East Road, Shanghai 200001, PRC Tel: +86-21-5353-1000, Fax: +86-21-5353-1263 E-mail: idec@cn.idec.com IDEC (BEIJING) CORPORATION Room 211B, Tower B, The Grand Pacific Building, 8A Guanghua Road, Chaoyang District, Beijing 100026, PRC Tel: +86-10-6581-6131, Fax: +86-10-6581-5119 IDEC (SHENZHEN) CORPORATION Unit AB-3B2, Tian Xiang Building, Tian’an Cyber Park, Fu Tian District, Shenzhen, Guang Dong 518040, PRC Tel: +86-755-8356-2977, Fax: +86-755-8356-2944 IDEC IZUMI (H.K.) CO., LTD. Units 11-15, Level 27, Tower 1, Millennium City 1, 388 Kwun Tong Road, Kwun Tong, Kowloon, Hong Kong Tel: +852-2803-8989, Fax: +852-2565-0171 E-mail: info@hk.idec.com IDEC TAIWAN CORPORATION 8F-1, No. 79, Hsin Tai Wu Road, Sec. 1, Hsi-Chih, Taipei County, Taiwan Tel: +886-2-2698-3929, Fax: +886-2-2698-3931 E-mail: service@tw.idec.com IDEC IZUMI ASIA PTE. LTD. No. 31, Tannery Lane #05-01, HB Centre 2, Singapore 347788 Tel: +65-6746-1155, Fax: +65-6844-5995 E-mail: info@sg.idec.com Cat. No. EP1180-0 OCTOBER 2007 3Y PRINTED IN MALAYSIA
BNJ16F 价格&库存
很抱歉,暂时无法提供与“BNJ16F”相匹配的价格&库存,您可以联系我们找货
BNJ16F
  • 80+5.31823
库存:160
