CW1B-M1E02G
CW1B-M1E02G
    IDEC(日本和泉)
CW1B-M1E02G 数据手册
Flush Silhouette ø22mm CW Series Control Units Safety in Style and Sophistication Safety Third-generation Safety Construction Two-action removal of contact blocks IDEC’s original two-action push-turn locking lever provides a higher level of safety by preventing unexpected release of the locking lever. Whether the contact bock is installed securely can be checked easily from the back of the panel, with the position of the locking lever. Guard ➁Turn ➀ Push Locking lever integrated with guard Prevents locking lever from unexpected release or damage by trapped wires. IP20 Finger-safe Terminal Finger-safe, IP20 terminal prevents electrical shock. Illuminated Pushbutton Bezel Color Black and metallic (Round flush and extended) Illumination color: amber, blue, green, pure white, red, yellow See page 6 Pushbutton (Round flush and extended) Button color: black, blue, green, red, yellow, white See page 7 Pilot Light (Round flush and extended) Illumination color: amber, blue, green, pure white, red, yellow See page 7 IDEC’s  commitment to assuring safety in all operating environments has resulted in stylish,  compact, and space-saving control units. The innovative two-step locking lever integrated with a guard provides a higher level of safety, and low projection from the panel surface reduces the possibility of unexpected activation or damage of the operator. The CW series control units add a sleek and stylish image to the panel with black or metallic bezels. The shortest depth behind the panel in its class* contributes to reducing the size of your machines and control panels. * As of October 2009 Design & Style 2.5 mm Bezel Thickness Sleek and stylish control units with a 2.5mm-thick bezel The CW series control units give a sleek, stylish image to your machines or control panels. The surface is safer with less chance of unexpected operation or accidents by hitting the projections, and also is cleaner with less dust build-up. Shortest in its class* 39.9 mm Depth behind the panel (Actual size) Ecology & Usability Less space required behind the panel Devices Depth behind the panel comparison Using CW series 50% shorter depth 59% less weight Devices Control Panel Using conventional control units Only 39.9mm depth behind the panel Space-saving design Short depth behind the panel allows size reduction of machines and panels. Up to 3 contact blocks (non-illuminated type) and 2 contact blocks (illuminated type) can be installed. Can be used with IDEC FB series or other control boxes.  120V AC, 10A contact rating  No transformer needed—the same depth behind the panel—for any illumination voltage. The depth behind the panel of the CW series is shorter than the conventional control units, reducing the required space in the control panel (compared with IDEC ø22mmm HW series illuminated pushbutton with 2 contact blocks and a transformer). ø22mm CW Series Line Up Wide Variety Selector Switch (Knob Operator) 2- and 3-position Low knob extension with flush silhouette. See pages 8 and 9 Selector Switch (Lever Operator) 2- and 3-position Lever operator with an easy grip. See pages 8 and 9 Key Selector Switch Wave-key 7 different keys Hard to duplicate, wave-key ensures a high level of safety. See pages 10 and 11 ø22 Flush Silhouette CW Series Control Units Flush bezel projects only 2.5mm from front of panel Only 39.9mm depth behind the panel. • ø22.3mm mounting hole compliant with IEC 60947-5-1 • 3.5-mm operator travel for pushbuttons ensures comfortable and reliable operation. • Black and metallic bezels available. • Illuminated pushbuttons, pushbuttons, pilot lights, selector switches, and key selector switches are available. • Direct opening NC contact ensures shutdown without failure. • Seven different keys can be chosen for key selector switches. • 10A contact rating. Up to three contact blocks for non-illuminated and two contact blocks for illuminated type can be connected. • Contact blocks can be removed by the two-action locking lever integrated with a guard, ensuring safety. • IP20 finger-safe screw terminals • IP65 degree of protection (IEC 60529) from panel front. • CCC approval pending.  Applicable Standards Mark UL508 CSA C22.2 No.14 File No. or Organization UL/c-UL File No. E68961 TÜV SÜD EN60947-5-1 Operating Temperature Contact Ratings Operating Humidity Rated Insulation Voltage (Ui) Rated Thermal Current (Ith) Rated Operating Voltage (Ue) Electrical Life 50,000 operations Rated Operating Current (Ie) Electrical Life 100,000 operations Specifications EC Low Voltage Directive Resistive Load (AC-12) Resistive Load (DC-12) Inductive Load (DC-13) Resistive Load (AC-12) AC 50/60 Hz Inductive Load (AC-15) Resistive Load (DC-12) DC Inductive Load (DC-13) Contact Material Storage Temperature 24V 120V 240V Insulation Resistance 10A 10A 6A 10A 6A 3A 8A 2.2A 1.1A Vibration Resistance 4A 1.1A 0.55A Shock Resistance 5A 5A 3A 5A 3A 1.5A 4A 1.1A 0.55A Electrical Life (minimum operations) 2A 0.55A 0.27A Degree of Protection (IEC60529) 10A AC 50/60 Hz Inductive Load (AC-15) DC 300V Contact Resistance Silver ••Minimum applicable load (reference value): 3V AC/DC, 5 mA (Applicable range is subject to the operating conditions and load.) Note: The operational current represents the classification by making and breaking currents (IEC 60947-5-1). ••UL, c-UL rating: A300 Weight (Examples) Illuminated Pushbutton 46g (CW1L-M1E02QH, 2 contact blocks) Pilot Light 27g (CW1P-1EQH) Pushbutton Selector Switch Key Selector Switch 45g (CW1B-M1E03, 3 contact blocks) 48g (CW1S-2E03, 3 contact blocks) 61g (CW1K-2E03, 3 contact blocks) Overvoltage Category Impulse Withstand Voltage Pollution Degree Mechanical Life (minimum operations) Short-circuit Protection Electrical Shock Protection Non-illuminated: –25 to +60°C (no freezing) LED illuminated: –25 to +55°C (no freezing) 45 to 85% RH (no condensation) –40 to 80°C 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) II (IEC 60664-1) 2.5 kV (IEC60664-1/60947-5-1) 3 (IEC60947-5-1) Operating extremes: 5 to 55Hz, amplitude 0.5 mm Operating extremes: 100 m/s2 Damage limits: 1000 m/s2 Pushbutton, illuminated pushbutton: 2,000,000 Selector switch: 250,000 Key selector switch: 250,000 50,000 (see Contact Ratings) 100,000 (see Contact Ratings) (switching frequency 1800 operations/h) Panel front: Terminal: 250V/10A fuse (Type aM IEC60269-1, IEC602069-2) Class II (IEC61140) Terminal Style Screw terminal (M3.5 slotted Phillips screw) Applicable Wire Size Up to 2 wires of 2 mm2 (solid wire ø1.6) maximum (AWG14 to 16) (Ring terminal cannot be used.) Bezel Material Recommended Tightening Torque Polyamide Terminal: 1.0 to 1.3 N·m Locking ring: 1.2 N·m Direct Opening of Key Selector Switch Applicable Type Minimum Operator Angle for Direct Opening Action Minimum Operator Torque for Direct Opening Action Maximum Operator Angle 4 IP65 IP20 2-position (3NC) 3-position (2NC) 90° 45° 0.2 N·m 0.3 N·m 90° 45° Flush Silhouette CW Series Control Units ø22 LED Module Rated Insulation Voltage (Ui) 250V Operating Voltage Range 6V AC/DC±10% Rated Operating Voltage (Ue) 6V AC/DC 12V AC/DC 12V AC/DC±10% 24V AC/DC 24V AC/DC±10% Illumination Color Code ➁ A (amber), G (green), PW (pure white), R (red), S (blue) Current Draw 15 mA LED Module Type No. CW-EAQ2➁ Life (reference value) CW-EAQ3➁ 15 mA CW-EAQ4➁ 16.5 mA 100/120V AC 200/220V AC 230/240V AC 100/120V AC±10% 200/220V AC±10% 230/240V AC 10% CW-EAQH➁ 18 mA CW-EAQM➁ 20 mA CW-EAQM4➁ 18 mA Approx. 30,000 hours (The illuminance is reduced to 50% the initial intensity when used on complete DC at 25°C.) R X1 X1 LED Chip Internal Circuit R Rectifying Diode Zener Diode Resistor X2 X2 R R C R LED Chip Rectifying Diode Zener Diode Resistor Capacitor • Specify an illumination color code in place of ➁ in the type No. • Use the pure white (PW) LED module for yellow illumination. • See page 14 for replacement LED module. Notes for Using Illuminated Pushbuttons and Pilot Lights When using LED illuminated control units, provide protection against electrical noise as shown below, otherwise the LED elements will deteriorate, resulting in reduced brightness, hue change, or no lighting. Use an RC circuit or surge absorber for suppressing noise. Example 2: DC Circuit Example 1: AC Circuit + C LED Relay Ry Coil, Solenoid R C LED Relay Coil, Solenoid R (Reference value) C: 0.1 μF R: 120Ω − Ry + LED − Diode (Reference value) • Current capacity of diode: Solenoid operating current minimum • Reverse withstand voltage of diode: Approx. 10 times the operating voltage of solenoid Mounting Hole Layout • IEC 60947-5-1 compliant 3.2 +0.2 0 R0.8 max. ø22 50 0 24.1+0.4 0 .3 +0.4 30 Note: Determine mounting centers to ensure easy operation. 5 ø22 Flush Silhouette CW Series Control Units Illuminated Pushbuttons Package quantity: 1 Shape Operation Type Round Flush CWL-M1 Operating Voltage 6V AC/DC 12V AC/DC (black bezel) 24V AC/DC Momentary 100/120V AC (metallic bezel) 200/220V AC 230/240V AC Round Extended CWL-M2 6V AC/DC 12V AC/DC (black bezel) 24V AC/DC Momentary 100/120V AC (metallic bezel) 200/220V AC 230/240V AC Contact Configuration 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC 1NO 1NC 1NO-1NC 2NO 2NC Black Bezel CW1L-M1E10Q2➁ CW1L-M1E01Q2➁ CW1L-M1E11Q2➁ CW1L-M1E20Q2➁ CW1L-M1E02Q2➁ CW1L-M1E10Q3➁ CW1L-M1E01Q3➁ CW1L-M1E11Q3➁ CW1L-M1E20Q3➁ CW1L-M1E02Q3➁ CW1L-M1E10Q4➁ CW1L-M1E01Q4➁ CW1L-M1E11Q4➁ CW1L-M1E20Q4➁ CW1L-M1E02Q4➁ CW1L-M1E10QH➁ CW1L-M1E01QH➁ CW1L-M1E11QH➁ CW1L-M1E20QH➁ CW1L-M1E02QH➁ CW1L-M1E10QM➁ CW1L-M1E01QM➁ CW1L-M1E11QM➁ CW1L-M1E20QM➁ CW1L-M1E02QM➁ CW1L-M1E10QM4➁ CW1L-M1E01QM4➁ CW1L-M1E11QM4➁ CW1L-M1E20QM4➁ CW1L-M1E02QM4➁ CW1L-M2E10Q2➁ CW1L-M2E01Q2➁ CW1L-M2E11Q2➁ CW1L-M2E20Q2➁ CW1L-M2E02Q2➁ CW1L-M2E10Q3➁ CW1L-M2E01Q3➁ CW1L-M2E11Q3➁ CW1L-M2E20Q3➁ CW1L-M2E02Q3➁ CW1L-M2E10Q4➁ CW1L-M2E01Q4➁ CW1L-M2E11Q4➁ CW1L-M2E20Q4➁ CW1L-M2E02Q4➁ CW1L-M2E10QH➁ CW1L-M2E01QH➁ CW1L-M2E11QH➁ CW1L-M2E20QH➁ CW1L-M2E02QH➁ CW1L-M2E10QM➁ CW1L-M2E01QM➁ CW1L-M2E11QM➁ CW1L-M2E20QM➁ CW1L-M2E02QM➁ CW1L-M2E10QM4➁ CW1L-M2E01QM4➁ CW1L-M2E11QM4➁ CW1L-M2E20QM4➁ CW1L-M2E02QM4➁ • Specify an illumination color code in place of ➁ in the Ordering Type No. • See page 14 for dimensions. • See page 14 for replacement LED modules. • A dummy block is installed when one contact block is used. • Momentary: The contact operates when button is pressed and returns when released. 6 Ordering Type No. Metallic Bezel CW4L-M1E10Q2➁ CW4L-M1E01Q2➁ CW4L-M1E11Q2➁ CW4L-M1E20Q2➁ CW4L-M1E02Q2➁ CW4L-M1E10Q3➁ CW4L-M1E01Q3➁ CW4L-M1E11Q3➁ CW4L-M1E20Q3➁ CW4L-M1E02Q3➁ CW4L-M1E10Q4➁ CW4L-M1E01Q4➁ CW4L-M1E11Q4➁ CW4L-M1E20Q4➁ CW4L-M1E02Q4➁ CW4L-M1E10QH➁ CW4L-M1E01QH➁ CW4L-M1E11QH➁ CW4L-M1E20QH➁ CW4L-M1E02QH➁ CW4L-M1E10QM➁ CW4L-M1E01QM➁ CW4L-M1E11QM➁ CW4L-M1E20QM➁ CW4L-M1E02QM➁ CW4L-M1E10QM4➁ CW4L-M1E01QM4➁ CW4L-M1E11QM4➁ CW4L-M1E20QM4➁ CW4L-M1E02QM4➁ CW4L-M2E10Q2➁ CW4L-M2E01Q2➁ CW4L-M2E11Q2➁ CW4L-M2E20Q2➁ CW4L-M2E02Q2➁ CW4L-M2E10Q3➁ CW4L-M2E01Q3➁ CW4L-M2E11Q3➁ CW4L-M2E20Q3➁ CW4L-M2E02Q3➁ CW4L-M2E10Q4➁ CW4L-M2E01Q4➁ CW4L-M2E11Q4➁ CW4L-M2E20Q4➁ CW4L-M2E02Q4➁ CW4L-M2E10QH➁ CW4L-M2E01QH➁ CW4L-M2E11QH➁ CW4L-M2E20QH➁ CW4L-M2E02QH➁ CW4L-M2E10QM➁ CW4L-M2E01QM➁ CW4L-M2E11QM➁ CW4L-M2E20QM➁ CW4L-M2E02QM➁ CW4L-M2E10QM4➁ CW4L-M2E01QM4➁ CW4L-M2E11QM4➁ CW4L-M2E20QM4➁ CW4L-M2E02QM4➁ Illumination Color Code ➁ A: amber G: green PW: pure white R: red S: blue Y: yellow A: amber G: green PW: pure white R: red S: blue Y: yellow Flush Silhouette CW Series Control Units ø22 Pushbuttons Shape Operation Type Contact Configuration Round Flush CWB-M1 CW1B-M1E10➀ CW4B-M1E10➀ 1NC CW1B-M1E01➀ CW4B-M1E01➀ CW1B-M1E11➀ CW4B-M1E11➀ 2NO CW1B-M1E20➀ CW4B-M1E20➀ 2NC CW1B-M1E02➀ CW4B-M1E02➀ 2NO-1NC CW1B-M1E21➀ CW4B-M1E21➀ 1NO-2NC CW1B-M1E12➀ CW4B-M1E12➀ 3NO CW1B-M1E30➀ CW4B-M1E30➀ 3NC CW1B-M1E03➀ CW4B-M1E03➀ 1NO CW1B-M2E10➀ CW4B-M2E10➀ 1NC CW1B-M2E01➀ CW4B-M2E01➀ 1NO-1NC CW1B-M2E11➀ CW4B-M2E11➀ 2NO CW1B-M2E20➀ CW4B-M2E20➀ Round Extended CWB-M2 Momentary (metallic bezel) 1NO 1NO-1NC Momentary (black bezel) Ordering Type No. Black Bezel Metallic Bezel 2NC CW1B-M2E02➀ CW4B-M2E02➀ 2NO-1NC CW1B-M2E21➀ CW4B-M2E21➀ 1NO-2NC CW1B-M2E12➀ CW4B-M2E12➀ 3NO CW1B-M2E30➀ CW4B-M2E30➀ 3NC CW1B-M2E03➀ CW4B-M2E03➀ Package quantity: 1 Button Color Code ➀ B: black G: green R: red Y: yellow S: blue W: white B: black G: green R: red Y: yellow S: blue W: white • Specify a button color code in place of ➀ in the Ordering Type No. • See page 12 for dimensions. • Two or one dummy block is installed when one or two contact blocks are used, respectively. • Momentary: The contact operates when button is pressed and returns when released. Pilot Lights Shape Round Flush CWP-1 (black bezel) Round Extended CWP-2 (metallic bezel) Operating Voltage Ordering Type No. Black Bezel Metallic Bezel 6V AC/DC CW1P-1EQ2➁ CW4P-1EQ2➁ 12V AC/DC CW1P-1EQ3➁ CW4P-1EQ3➁ 24V AC/DC CW1P-1EQ4➁ CW4P-1EQ4➁ 100/120V AC CW1P-1EQH➁ CW4P-1EQH➁ 200/220V AC CW1P-1EQM➁ CW4P-1EQM➁ 230/240V AC CW1P-1EQM4➁ CW4P-1EQM4➁ 6V AC/DC CW1P-2EQ2➁ CW4P-2EQ2➁ 12V AC/DC CW1P-2EQ3➁ CW4P-2EQ3➁ 24V AC/DC CW1P-2EQ4➁ CW4P-2EQ4➁ 100/120V AC CW1P-2EQH➁ CW4P-2EQH➁ 200/220V AC CW1P-2EQM➁ CW4P-2EQM➁ 230/240V AC CW1P-2EQM4➁ CW4P-2EQM4➁ Package quantity: 1 Illumination Color Code ➁ A: G: PW: R: S: Y: amber green pure white red blue yellow A: G: PW: R: S: Y: amber green pure white red blue yellow • Specify an illumination color code in place of ➁ in the Ordering Type No. • See page 12 for dimensions. • See page 14 for replacement LED modules. • Two dummy blocks are installed. 7 ø22 Flush Silhouette CW Series Control Units Selector Switches Package quantity: 1 CWS (Knob Operator) Shape (metallic bezel) (black bezel) No. of Positions Contact Configuration 1NO (10) 1NC (01) 1NO-1NC (11) 2NO (20) 90° 2-position 2NC (02) 2NO-1NC (21) 1NO-2NC (12) 3NO (30) 3NC (03) Contact Block Mounting Position Type 1 2 NO — 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 — — NC NO — NC NO — NO NC — NC NO NO NC NO NC NC NO NO NO NC NC NC Operator Position L L R R Maintained Spring return from right Dummy CWS-2E10 CWS-21E10 Dummy Dummy CWS-2E01 CWS-21E01 CWS-2E11 CWS-21E11 CWS-2E20 CWS-21E20 CWS-2E02 CWS-21E02 CWS-2E21 CWS-21E21 CWS-2E12 CWS-21E12 CWS-2E30 CWS-21E30 CWS-2E03 CWS-21E03 L R l l l Dummy l l Dummy l l Dummy l l l l l l l l l l l l l • Specify a bezel color code in place of  in the Type No.: 1 (black bezel), 4 (metallic bezel) • Lever operator is also available. For dimensions, see page 13. • When ordering a lever operator selector switch, designate L before E in the Type No. of knob operator selector switches. [Example] CW1S-2E10 → CW1S-2LE10 Knob Operator Lever Operator ••Lever Operator ••Contact Block Mounting Position 1 2 3 Left 1 2 3 CW1S-L (black bezel) 8 CW4S-L (metallic bezel) NO NC NC Center L l C l Right R Operator Position Flush Silhouette CW Series Control Units ø22 Package quantity: 1 No. of Positions Contact Configuration 1NO-1NC (11) 1NO-1NC (11N1) 1NO-1NC (11N2) 1NO-1NC (11N3) 1NO-1NC (11N4) 2NO (20) 2NO (20N1) 45° 3-position 2NC (02) 2NC (02N1) 2NO-1NC (21) 2NO-1NC (21N1) 1NO-2NC (12) 1NO-2NC (12N1) 3NO (30) 3NC (03) Contact Block Operator Position Mounting Position Type L 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 NO — NC NC — NO NO NC — — NC NO — NO NC NO — NO — NO NO NC — NC — NC NC NO NO NC NO NC NO NO NC NC NC NO NC NO NO NO NC NC NC l L C R L C R L C R L C R Maintained Spring return from right Spring return from left Spring return two-way CWS-3E11 CWS-31E11 CWS-32E11 CWS-33E11 CWS-3E11N1 CWS-31E11N1 CWS-32E11N1 CWS-33E11N1 CWS-3E11N2 CWS-31E11N2 CWS-32E11N2 CWS-33E11N2 CWS-3E11N3 CWS-31E11N3 CWS-32E11N3 CWS-33E11N3 CWS-3E11N4 CWS-31E11N4 CWS-32E11N4 CWS-33E11N4 CWS-3E20 CWS-31E20 CWS-32E20 CWS-33E20 CWS-3E20N1 CWS-31E20N1 CWS-32E20N1 CWS-33E20N1 Dummy CWS-3E02 CWS-32E02 CWS-33E02 Dummy l CWS-3E02N1 CWS-31E02N1 CWS-32E02N1 CWS-33E02N1 CWS-3E21 CWS-32E21 CWS-33E21 CWS-3E21N1 CWS-31E21N1 CWS-32E21N1 CWS-33E21N1 CWS-3E12 CWS-32E12 CWS-33E12 C R Dummy Dummy l l l Dummy Dummy l l Dummy l l l Dummy l Dummy l l l l l l CWS-31E02 CWS-31E21 l l l l l l l l l CWS-31E12 l CWS-3E12N1 CWS-31E12N1 CWS-32E12N1 CWS-33E12N1 l l CWS-3E30 CWS-31E30 CWS-32E30 CWS-33E30 CWS-3E03 CWS-31E03 CWS-32E03 CWS-33E03 • Specify a bezel color code in place of  in the Type No.: 1 (black bezel), 4 (metallic bezel) • For the contact block mounting position, see page 8. • Lever operator is also available. For dimensions, see page 13. • When ordering a lever operator selector switch, designate L before E in the Type No. of knob operator selector switches. [Example] CW1S-3E11 → CW1S-3LE11 Knob Operator Lever Operator 9 ø22 Flush Silhouette CW Series Control Units Key Selector Switches Package quantity: 1 CWK Shape (metallic bezel) (black bezel) No. of Positions Contact Configuration 1NO (10) 1NC (01) 1NO-1NC (11) 2NO (20) 90° 2-position 2NC (02) 2NO-1NC (21) 1NO-2NC (12) 3NO (30) 3NC (03) Contact Block Mounting Position Type 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 NO — — — — NC NO — NC NO — NO NC — NC NO NO NC NO NC NC NO NO NO NC NC NC Operator Position L R L R Maintained L R Spring return from right l Dummy Dummy Dummy Dummy CWK-2AE10 CWK-21BE10 CWK-2AE01 CWK-21BE01 CWK-2AE11 CWK-21BE11 CWK-2AE20 CWK-21BE20 CWK-2AE02 CWK-21BE02 CWK-2AE21 CWK-21BE21 CWK-2AE12 CWK-21BE12 CWK-2AE30 CWK-21BE30 CWK-2AE03 CWK-21BE03 l l Dummy l l Dummy l l Dummy l l l l l l l l l l l l l • Specify a bezel color code in place of  in the Type No.: 1 (black bezel), 4 (metallic bezel) • On the spring-returned types, the key can be released only from the maintained position. On the maintained types, the key can be released from every position. Key retained positions are also available. See below. • Two keys are supplied. • Key cylinder material: Metal • Besides the standard key (key number 0H), six other keys are also available. See below. • For the contact block mounting position, see page 11. • For dimensions, see page 13. • When ordering an optional key or optional key retained positions, specify designation codes as shown below: [Example] CW1K-2AE10-1H (blank): Standard key (0H, reversible) 1H to 2H: Reversible key 3H to 6H: Non-reversible key Key removal position code 2-position A: Removable in all positions B: Removable in left only C: Removable in right only Note: Key number is indicated on the key cylinder. Standard keys do not have a key number indication. 3-position A: Removable in all positions B: Removable in left and center C: Removable in right and center D: Removable in center only E: Removable in right and left G: Removable in left only H: Removable in right only Note: Key is retained in the spring-returned position. 10 Flush Silhouette CW Series Control Units ø22 Package quantity: 1 No. of Positions Contact Configuration 1NO-1NC (11) 1NO-1NC (11N1) 1NO-1NC (11N2) 1NO-1NC (11N3) 1NO-1NC (11N4) 2NO (20) 2NO (20N1) 45° 3-position 2NC (02) 2NC (02N1) 2NO-1NC (21) 2NO-1NC (21N1) 1NO-2NC (12) 1NO-2NC (12N1) 3NO (30) 3NC (03) Contact Block Mounting Type Position 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 NO — NC NC — NO NO NC — — NC NO — NO NC NO — NO — NO NO NC — NC — NC NC NO NO NC NO NC NO NO NC NC NC NO NC NO NO NO NC NC NC Operator Position L C R L C R Maintained L C R Spring return from right L C R Spring return from left L C R Spring return two-way l Dummy CWK-3AE11 Dummy CWK-31BE11 CWK-32CE11 CWK-33DE11 CWK-3AE11N1 CWK-31BE11N1 CWK-32CE11N1 CWK-33DE11N1 l l CWK-3AE11N2 CWK-31BE11N2 CWK-32CE11N2 CWK-33DE11N2 l Dummy Dummy l CWK-3AE11N3 CWK-31BE11N3 CWK-32CE11N3 CWK-33DE11N3 l Dummy l l CWK-3AE11N4 CWK-31BE11N4 CWK-32CE11N4 CWK-33DE11N4 l Dummy CWK-3AE20 CWK-31BE20 CWK-32CE20 CWK-33DE20 l Dummy l l l CWK-3AE20N1 CWK-31BE20N1 CWK-32CE20N1 CWK-33DE20N1 Dummy CWK-3AE02 Dummy l CWK-3AE02N1 CWK-31BE02N1 CWK-32CE02N1 CWK-33DE02N1 l l l CWK-3AE21 CWK-31BE02 CWK-31BE21 CWK-32CE02 CWK-32CE21 CWK-33DE02 CWK-33DE21 l CWK-3AE21N1 CWK-31BE21N1 CWK-32CE21N1 CWK-33DE21N1 l l l CWK-3AE12 l l l l l CWK-31BE12 CWK-32CE12 CWK-33DE12 l CWK-3AE12N1 CWK-31BE12N1 CWK-32CE12N1 CWK-33DE12N1 l l CWK-3AE30 CWK-31BE30 CWK-32CE30 CWK-33DE30 CWK-3AE03 CWK-31BE03 CWK-32CE03 CWK-33DE03 • Specify a bezel color code in place of  in the Type No.: 1 (black bezel), 4 (metallic bezel) • On the spring-returned types, the key can be released only from the maintained position. On the maintained types, the key can be released from every position. Key retained positions are also available. See page 10. • Two keys are supplied. • Key cylinder material: Metal ••Contact Block Mounting Position • Besides the standard key (key number 0H), six other keys are also available. See page 10. Left Center Right 1 2 3 • For the contact block mounting position, see page 11. Operator • For dimensions, see page 13. L C R Position NO l 1 NC 2 l NC 3 11 ø22 Flush Silhouette CW Series Control Units Dimensions: Illuminated Pushbuttons All dimensions in mm. 10 0.5 Locking Ring Gasket LOC 28.5 K ø28 41.4 ø19.5 28.5 K ø28 ø19.5 (Lens Diameter) 10 10 10 10 41.4 1 1 LOC Gasket 2 2 M3.5 Terminal Screw LED Module 0.5 Locking Ring Panel Thickness 0.8 to 3.2 3 3 M3.5 Terminal Screw LED Module M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 M3.5 Terminal Screw Contact Block • Round Extended (Lens Diameter) • Round Flush 2.5 2.5 39.9 30 Dimensions: Pushbuttons • Round Flush Panel Thickness 0.8 to 3.2 10 10 0.5 0.5 K 28.5 28.5 41.4 LOC Gasket ø28 Locking Ring K ø28 ø19.5 (Button Diameter) 41.4 LOC Gasket ø19.5 Locking Ring (Button Diameter) 10 1 1 2 2 10 Panel Thickness 0.8 to 3.2 M3.5 Terminal Screw Contact Block 3 3 10 M3.5 Terminal Screw Contact Block 30 5.2 • Round Extended 10 39.9 2.5 30 Dimensions: Pilot Lights 10 0.5 ø19.5 41.4 LOC Gasket 28.5 K ø28 Locking Ring 28.5 K ø28 ø19.5 (Lens Diameter) 10 10 10 41.4 1 1 LOC Gasket 2 2 M3.5 Terminal Screw LED Module 0.5 Locking Ring 3 10 Panel Thickness 0.8 to 3.2 3 M3.5 Terminal Screw LED Module 30 • Round Extended Panel Thickness 0.8 to 3.2 10 • Round Flush 5.2 39.9 (Lens Diameter) 2.5 39.9 2.5 39.9 12 2.5 30 39.9 4.1 30 Flush Silhouette CW Series Control Units ø22 Dimensions: Selector Switches All dimensions in mm. • Knob Operator • Lever Operator M3.5 Terminal Screw Contact Block 10 10 10 10 1 1 2 2 3 3 10 Panel Thickness 0.8 to 3.2 10 Panel Thickness 0.8 to 3.2 M3.5 Terminal Screw Contact Block 0.5 0.5 Operator Angle Operator Angle 45° LOC K 45 Locking Ring ° 45° Gasket 17.1 39.9 30 Dimensions: Key Selector Switches 22 3 2 1 Operator Angle 0.5 45° Gasket LOC Logo Stamping Key No. Stamping ø28 41.4 8.8 10.4 22 Key No.: 0H to 2H (reversible key) 14 30 31.5 6.3 39.9 • Non-reversible Key Logo Stamping 31.5 Key No. 3H 1.5 2.5 Key No. ° 0H K 45 28.5 Locking Ring 4.8 14 10 30 • Reversible Key 8.8 10 ° Dimensions: Keys Panel Thickness 0.8 to 3.2 10 45 ø28 41.4 ø28 41.4 13.1 M3.5 Terminal Screw Contact Block K 2.5 2.5 39.9 LOC 28.5 Gasket 28.5 Locking Ring Key No. Stamping Key No.: 3H to 6H (non-reversible key) 13 ø22 Flush Silhouette CW Series Control Units Accessories Shape Material Ordering Type No. Locking Ring Wrench Brass MW9Z-T1 Package Quantity 1 • Used to tighten the locking ring when installing the CW series control unit in a panel cut-out. 110 • Weight: Approx 150g 1 • Used to plug an unnecessary ø22.3mm hole in the panel. • Degree of protection: IP65 • Panel thickness: 0.8 to 6.0 mm Mounting Hole Plug Polyamide (black) LW9Z-BP1 Remarks 8 ø2 Maintenance Parts Used for replacement only. Do not use the maintenance parts to remodel or expand the CW series control units. Material Shape Lens 2 1 3 Contact Block Type No. Ordering Type No. Package Quantity Remarks 1 Round Flush Polyalylate CW9Z-L11➁ CW9Z-L11➁PN05 5 2 Round Extended Polyalylate CW9Z-L12➁ CW9Z-L12➁PN05 5 3 Round Extended Polyalylate CW9Z-L15➁ CW9Z-L15➁PN05 5 Color code ➁: A (amber), C (clear), G (green), R (red), S (blue), Y (yellow) Use a clear (C) lens for pure white (PW) illumination. 1: For illuminated pushbutton, pilot light 2: For illuminated pushbutton 3: For pilot light 1NO CW-E10 CW-E10PN02 2 Housing color: Blue Terminal No.: 3-4 1NC CW-E01 CW-E01PN02 2 Housing color: Reddish purple Terminal No.: 1-2 Polyamide (black) CW-DB CW-DBPN05 5 Polyamide (black) CW9Z-LN CW9Z-LNPN05 5 Dummy Block Locking Ring Gasket Nitrile rubber CW9Z-WM CW9Z-WMPN10 10 Spare Key Non-reversible Zinc LA9Z-SK- (nickel-plated) LA9Z-SK-PN02 Reversible LED Module Shape Operating Voltage Range Current Draw 6V AC/DC±10% 15 mA 12V AC/DC±10% 15 mA 24V AC/DC±10% 16.5 mA 100/120V AC±10% 18 mA 200/220V AC±10% 20 mA 230/240V AC±10% 18 mA • Use a pure white (PW) LED module for yellow (Y) illumination. 14 2 Waterproof gasket between CW control unit bezel and the mounting panel. Specify a key No. in place of . 0H: Standard key (reversible) 1H to 2H: Reversible key 3H to 6H: Non-reversible key For dimensions, see page 13. Ordering Type No. CW-EAQ2➁ CW-EAQ3➁ CW-EAQ4➁ CW-EAQH➁ CW-EAQM➁ CW-EAQM4➁ Package quantity: 1 Illumination Color Code ➁ Specify an illumination color code in place of ➁ in the Ordering Type No. A: amber G: green PW: pure white R: red S: blue Flush Silhouette CW Series Control Units ø22 Safety Precautions • Turn off the power to the CW series control units before installation, removal, wiring, and maintenance. Failure to turn power off may cause electrical shocks or fire hazard. • For wiring, use wires of a proper size to meet the voltage and current requirements. Tighten the M3.5 terminal screws to a tightening torque of 1.0 to 1.3 N·m. Failure to tighten the terminal screws may cause overheating and fire. Operating Instructions Notes for Operation • When using the CW series control units in a safety-related circuit of a control system, observe safety rules and regulations of each country concerning particular applications of the actual machines and facilities. Perform risk assessment before operation to ensure safety. Operating Conditions • In corrosive gas or high-temperature, high-humidity atmosphere, contact failure due to corrosion or color change or breakage of the housing may occur. • Main parts of the CW series control units are made of plastics. Do not scratch the surface with a sharp object or apply excessive shocks or load, otherwise the control units may be damaged. In particular, keep the button, lens, and bezel from such damage, otherwise appearance and function may be impaired. • Do not apply detergents, cutting oils, or chemicals which may impair the function and appearance of the CW series control units. Panel Mounting Remove the contact block from the operator. Remove the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block to the operator. ••Mounting Hole 1. Mounting hole dimensions are in compliance with IEC60947-5-1. 2. If the anti-rotation projection is removed from the bezel, CW series control units can be mounted in ø22.3mm mounting holes. To remove the anti-rotation projection, remove the gasket and use cutting pliers to break the projection. ••Removing and Installing the Contact Unit 1. To remove the contact block from the operator, push the yellow locking lever and turn it to the left. Locking Lever 2. To install, align the TOP marking on the operator with the TOP marking on the contact block mounting adaptor, and turn the locking lever to the right. ••Installation in Panel Cut-out Remove the locking ring from the operator. With the anti-rotation projection on the operator aligned with the recess in the mounting hole, insert the operator into the mounting hole. Tighten the locking ring from the rear of the panel. Anti-rotation projection Recess in mounting hole Illuminated Pushbuttons and Pilot Lights ••Removing the Lens To remove the lens from an illuminated pushbutton or pilot light, insert a flat screwdriver under the flange of the lens at 90° from the TOP marking and twist the screwdriver. Do not insert the screwdriver too deeply and do not apply excessive force to the lens, otherwise the bezel surface may be damaged. [Screwdriver Insertion Direction] TOP Marking TOP Marking [Screwdriver Insertion Angle] Panel Approx. 30° Panel Surface TOP marking on illuminated pushbuttons, pushbuttons, and pilot light Locking Ring TOP marking on selector and key selector switches ••Installing the Lens Turn the groove in the lens to the TOP marking on the operator housing. With the groove aligned with the ridge, press the lens in. TOP Marking Ridge Groove in the Lens ••Note for Panel Mounting When installing the operator in a panel cut-out, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring to a recommended tightening torque of 1.2 N·m. Do not use pliers and do not tighten excessively, otherwise the operator may be damaged. 15 ø22 Flush Silhouette CW Series Control Units Operating Instructions 13.8 9 5. ø1 12.6 9 5. ø1 Thickness: 0.2 mm maximum Film material: Polyester (recommended) Note: Film is not supplied and must be prepared by the user. Pushbuttons Pushbutton caps cannot be removed. Do not tamper with the pushbutton caps using a screwdriver or pliers, otherwise the pushbutton caps may be damaged. Selector Switches One or two wires can be connected to the terminal. ••Applicable Crimping Terminals [Spade terminal] When using crimping terminals, be sure to use insulating tubes or use insulated crimping terminals. Contact Blocks and LED Modules To remove the contact block from the operator, insert a flat screwdriver under the latch and push down the screwdriver as shown below. Before removing the LED module, first remove all contact blocks, and remove the LED module in the same manner. 11.5 max. 8.1 max. Insulation Tube Crimping Terminal Wire 0.5 min. [Ferrule] When connecting two ferrules to one terminal, use ferrules without insulation. �1.7 max. Turn the selector operator or key to the detent positions. 8.0 max. Insulation �1.7 max. Illuminated Pushbutton (Round Extended) • Insert the key to the bottom before turning. • Do not remove the key while turning. • Besides the standard key (0H), six other keys are available. Use a key with a key selector switch of a matching number indicated on the key cylinder. Standard key does not have a key number indication. • Keys are available in two shapes. Key numbers 0H (standard), 1H, and 2H are reversible keys. Key numbers 3H, 4H, 5H, and 6H are non-reversible keys. Make sure of correct insertion direction. Wiring ••Applicable Wires Stranded wire: 2.0 mm2 maximum Solid wire: ø1.6 mm maximum ø1.6 max. Illuminated Pushbutton (Round Flush) Pilot Light (Round Flush, Round Extended) To prevent malfunctions and damage, take the following precautions. 3.6 min. • Applicable Marking Film Size Key Selector Switches 6.9 max. ••Marking Marking plates are not available for CW series illuminated pushbuttons and pilot lights. Marking film can be inserted to indicate legends. 8.0 max. 8.0 max. When using spade terminals or ferrules, insert them to the bottom. Ring terminals cannot be used. ••Screw Tightening Torque Tighten the M3.5 terminal screws to a recommended torque of 1.0 to 1.3 N·m. Specifications and other descriptions in this catalog are subject to change without notice. 7-31, Nishi-Miyahara 1-Chome, Yodogawa-ku, Osaka 532-8550, Japan Tel: +81-6-6398-2571, Fax: +81-6-6392-9731 E-mail: marketing@idec.co.jp IDEC CORPORATION (USA) Tel: +1-408-747-0550 / (800) 262-IDEC (4332) Fax: +1-408-744-9055 / (800) 635-6246 E-mail: opencontact@idec.com IDEC CANADA LIMITED Tel: +1-905-890-8561, Toll Free: (888) 317-4332 Fax: +1-905-890-8562 E-mail: sales@ca.idec.com IDEC AUSTRALIA PTY. LTD. www.idec.com Tel: +61-3-9763-3244, Toll Free: 1800-68-4332 Fax: +61-3-9763-3255 E-mail: sales@au.idec.com IDEC ELECTRONICS LIMITED IDEC IZUMI (H.K.) CO., LTD. IDEC ELEKTROTECHNIK GmbH IDEC TAIWAN CORPORATION Tel: +44-1256-321000, Fax: +44-1256-327755 E-mail: sales@uk.idec.com Tel: +852-2803-8989, Fax: +852-2565-0171 E-mail: info@hk.idec.com Tel: +49-40-25 30 54 - 0, Fax: +49-40-25 30 54 - 24 E-mail: service@idec.de IDEC (SHANGHAI) CORPORATION Tel: +86-21-5353-1000, Fax: +86-21-5353-1263 E-mail: idec@cn.idec.com IDEC (BEIJING) CORPORATION Tel: +886-2-2698-3929, Fax: +886-2-2698-3931 E-mail: service@tw.idec.com IDEC IZUMI ASIA PTE. LTD. Tel: +65-6746-1155, Fax: +65-6844-5995 E-mail: info@sg.idec.com Tel: +86-10-6581-6131, Fax: +86-10-6581-5119 IDEC (SHENZHEN) CORPORATION Tel: +86-755-8356-2977, Fax: +86-755-8356-2944 Cat. No. EP1325-0 JANUARY 2010 PDF
CW1B-M1E02G 价格&库存
很抱歉,暂时无法提供与“CW1B-M1E02G”相匹配的价格&库存,您可以联系我们找货
CW1B-M1E02G
    • 1+300.910071+39.11734
