FB9Z-PK1
FB9Z-PK1
    IDEC(日本和泉)
FB9Z-PK1 数据手册
Switches & Pilot Devices Signaling Lights Switches & Pilot Devices FB Enclosures Enclosures for XW, HW & TW 22mm Switches and Pilot Devices Key features: • Three compact sizes (mm): 76 x 76, 140 x 76 and 200 x 76 • Available in 1, 2, 3, 4 or 5 mounting hole configurations • Easy installation: panel, wall or frame mountable • Polycarbonate enclosure cover and base, stainless steel screws • UL Listed, RoHS Compliant • IP65 and Type 4X rated (when installed with IP65 or Nema Type 4X unit) • Class II electric shock protection (when installed with applicable unit) • Ideal for high temperatures (-25 to +60ºC) and corrosive environments Relays & Sockets Specifications Accessories Operating Conditions Timers Relative humidity 45 to 85%RH (no condensation) Storage temperature –40 to +80°C (no freezing) Degree of pollution 3 Description Part Number Plug Adaptor 13.5mm HW9Z-PG135 Mounting Bracket FB9Z-PK1 IP65 (when IP65 switches and pilot devices are installed) Type 4X Indoor Use Only (when Type 4X switches and pilot devices are installed) Electric Shock Protection Class II (when class II switches and pilot devices are installed) Cover and base Polycarbonate Cover mounting screws Stainless steel HW, TW and XW series switches, pilot devices and accessories (see note below) Weight (approx.) 76mm type: 125g (FB1W-111Z) 140mm type: 184g (FB2W-211Z) 200mm type: 243g (FB3W-311Z) Choose switches, pilot devices and accessories that match the mounting hole centers, effective depth behind the cover, and the thickness of the cover where switches and pilot devices are installed (3 mm). Enclosures with 30 or 36mm mounting hole centers may limit the knob orientation of selector switches because the contact blocks can be mounted in one direction only on these mounting centers. HW Series Enclosure Part Numbers Size (mm) 76 x 76 x 59.5 140 x 76 x 59.5 200 x 76 x 59.5 Description Part Number Distance Between Hole Centers (mm) Enclosure 1 hole, Yellow FB1W-111Y – Enclosure 1 hole, Beige FB1W-111Z – Enclosure 2 hole, Beige FB2W-211Z 50 Enclosure 3 hole, Beige FB2W-312Z 30 Enclosure 3 hole, Beige FB3W-311Z 50 Enclosure 4 hole, Beige FB3W-413Z 36 Enclosure 5 hole, Beige FB3W-512Z 30 XW Series E-Stops Circuit Breakers TW Series 652 www.IDEC.com Connectors and nuts are not supplied with accessories. Switch and Pilot Device Accessories Series Applicable Switches and Pilot Devices Contactors –25 to +60°C (no freezing) Degree of Protection Material Terminal Blocks Ambient temperature Description Part Number Nameplate HWAM, HWAQ, HWAS, HWAV Marking plate for nameplate HWNP Anti-rotation ring HW9Z-RL EMO switch guard HW9Z-KG1, HW9Z-KG2, HW9Z-KG3, HW9Z-KG4 Switch cover HW9Z-K1, HW9Z‑K11 Pushbutton clear boot OC-31, OC-32 Padlock cover HW9Z-KL1 Nameplate HWAV EMO switch guard HW9Z-KG1, HW9Z-KG2, HW9Z-KG3, HW9Z-KG4 Anti-rotation ring HW9Z-RL Nameplate NWA, NWAQ, NWAS-0, NWAL-0, NWAQL-0, NWAV Anti-rotation ring OGL-31 Metal button guard OLW-C Pushbutton clear boot OC-31, OC-32 Button cover OCW-11 Padlock cover HW9Z-KL1 Switches & Pilot Devices FB Enclosures Cover Mounting Screws Cover Mounting Screws Cover Mounting Screws 2-ø21.3 Knockout Cover Mounting Screws 30 50 18 36 30 59.5 Cover Mounting Screws Switches & Pilot Devices External Dimensions (mm) 30 36 50 30 30 30 36 50 76 76 76 FB1W-111Y/Z 76 FB2W-211Z FB2W-312Z Internal Dimensions (mm) FB3W-413Z FB3W-512Z 76mm (FB1) Model FB1 FB2 FB3 45 92 140 and 200mm (FB2/FB3) 4-M4 Tapped Holes for Rear Mounting (Depth: 10 mm) 2-Front Mounting Holes 150 Model FB2 FB3 2-Front Mounting Holes ø14 Knockout Switch & Pilot Device Mounting Area Thickness Measurements (mm) 4-M4 Tapped Screw Holes for Rear Mounting (Depth: 10mm) 2-ø14 Knockout 2 A 84 144 B 104 164 C 106 166 .2 R2 21 41 21 D 3 FB3W-311Z 4- 55 76 Relays & Sockets 45 76 External Back Dimensions (mm) Measurements (mm) D 76 Signaling Lights 140 140 .3 ø22 200 200 200 Cover Mounting Screws A B C ø4 .6 Timers 2- 15.5 62 Mounting FB9Z-PK1 Frame Mounting Adapter R3 .3 72 36 6.6 10.5 Four M4 Tapped Screw Holes 31 62 Contactors 54 FB9Z-PK1 30 2 6.5 10 13 Two M4 Tapped Screws (supplied) R2 .5 R4 Terminal Blocks Mounting Hole Dimensions FB2 FB3 FB2/FB3 50mm Mounting Centers 36/50mm Mounting Centers 30mm Mounting Centers Shape 2. 13 ø2 3 13 800-262-IDEC (4332) • USA & Canada Circuit Breakers 3 . 22 ø 3.2 3.2 3.2 FB1 13 Model 653
FB9Z-PK1 价格&库存
很抱歉,暂时无法提供与“FB9Z-PK1”相匹配的价格&库存,您可以联系我们找货
