FC4A-J8C1
FC4A-J8C1
    IDEC(日本和泉)
    Module
FC4A-J8C1 数据手册
FC9Y-B902 FC4A SERIES Analog I/O Module User’s Manual SAFETY PRECAUTIONS • Read this user’s manual to make sure of correct operation before starting installation, wiring, operation, maintenance, and inspection of the FC4A series MicroSmart analog I/O modules. • All MicroSmart modules are manufactured under IDEC’s rigorous quality control system, but users must add a backup or failsafe provision to the control system using the MicroSmart in applications where heavy damage or personal injury may be caused in case the MicroSmart should fail. • In this user’s manual, safety precautions are categorized in order of importance to Warning and Caution: Warning Warning notices are used to emphasize that improper operation may cause severe personal injury or death. • Turn off the power to the MicroSmart before starting installation, removal, wiring, maintenance, and inspection of the MicroSmart. Failure to turn power off may cause electrical shocks or fire hazard. • Special expertise is required to install, wire, program, and operate the MicroSmart. People without such expertise must not use the MicroSmart. • Emergency stop and interlocking circuits must be configured outside the MicroSmart. If such a circuit is configured inside the MicroSmart, failure of the MicroSmart may cause disorder of the control system, damage, or accidents. • Install the MicroSmart according to the instructions described in this user’s manual. Improper installation will result in falling, failure, or malfunction of the MicroSmart. Caution Caution notices are used where inattention might cause personal injury or damage to equipment. • The MicroSmart is designed for installation in a cabinet. Do not install the MicroSmart outside a cabinet. • Install the MicroSmart in environments described in this user’s manual. If the MicroSmart is used in places where the MicroSmart is subjected to high-temperature, high-humidity, condensation, corrosive gases, excessive vibrations, and excessive shocks, then electrical shocks, fire hazard, or malfunction will result. • The environment for using the MicroSmart is “Pollution degree 2.” Use the MicroSmart in environments of pollution degree 2 (according to IEC 60664-1). • Prevent the MicroSmart from falling while moving or transporting the MicroSmart, otherwise damage or malfunction of the MicroSmart will result. • Prevent metal fragments and pieces of wire from dropping inside the MicroSmart housing. Put a cover on the MicroSmart modules during installation and wiring. Ingress of such fragments and chips may cause fire hazard, damage, or malfunction. • Use a power supply of the rated value. Use of a wrong power supply may cause fire hazard. • Use an IEC 60127-approved fuse on the power line outside the MicroSmart. This is required when equipment containing the MicroSmart is destined for Europe. • Use an IEC 60127-approved fuse on the output circuit. This is required when equipment containing the MicroSmart is destined for Europe. • Use an EU-approved circuit breaker. This is required when equipment containing the MicroSmart is destined for Europe. • Make sure of safety before starting and stopping the MicroSmart or when operating the MicroSmart to force outputs on or off. Incorrect operation on the MicroSmart may cause machine damage or accidents. • If relays or transistors in the MicroSmart output modules should fail, outputs may remain on or off. For output signals which may cause heavy accidents, provide a monitor circuit outside the MicroSmart. • Do not connect the ground wire directly to the MicroSmart. Connect a protective ground to the cabinet containing the MicroSmart using an M4 or larger screw. This is required when equipment containing the MicroSmart is destined for Europe. • Do not disassemble, repair, or modify the MicroSmart modules. • When disposing of the MicroSmart, do so as an industrial waste. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL PREFACE-1 About This Manual This user’s manual primarily describes entire functions, installation, programming, and troubleshooting procedures of the FC4A series MicroSmart analog I/O modules. CHAPTER 1: GENERAL INFORMATION General information about the analog I/O modules, applicable CPU module system program version, and WindLDR version. CHAPTER 2: MODULE SPECIFICATIONS Specifications of the analog I/O modules. CHAPTER 3: INSTALLATION AND WIRING Methods and precautions for installing and wiring the analog I/O modules. CHAPTER 4: ANALOG I/O CONTROL General information about programming and setting up various communication systems for the analog I/O modules. CHAPTER 5: TROUBLESHOOTING Procedures to determine the cause of trouble and actions to be taken when any trouble occurs while operating the analog I/O modules. INDEX Alphabetical listing of key words. MicroSmart Modules Category Modules All-in-one type FC4A-C10R2, FC4A-C16R2, FC4A-C24R2 FC4A-C10R2C, FC4A-C16R2C, FC4A-C24R2C Slim type FC4A-D20K3, FC4A-D20S3 FC4A-D20RK1, FC4A-D20RS1 FC4A-D40K3, FC4A-D40S3 Expansion I/O modules Input modules, output modules, mixed I/O modules Function modules Analog I/O modules, AS-Interface master module CPU modules Expansion modules Option modules HMI module, RS232C communication adapter, RS485 communication adapter, memory cartridge, clock cartridge Communication modules HMI base module, RS232C communication module, RS485 communication module IMPORTANT INFORMATION Under no circumstances shall IDEC Corporation be held liable or responsible for indirect or consequential damages resulting from the use of or the application of IDEC PLC components, individually or in combination with other equipment. All persons using these components must be willing to accept responsibility for choosing the correct component to suit their application and for choosing an application appropriate for the component, individually or in combination with other equipment. All diagrams and examples in this manual are for illustrative purposes only. In no way does including these diagrams and examples in this manual constitute a guarantee as to their suitability for any specific application. To test and approve all programs, prior to installation, is the responsibility of the end user. PREFACE-2 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL TABLE OF CONTENTS CHAPTER 1: GENERAL INFORMATION About the Analog I/O Modules . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-1 Applicable CPU Modules and WindLDR Version . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-2 Confirming System Program Version . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-2 CHAPTER 2: MODULE SPECIFICATIONS Parts Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-1 Analog I/O Module Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-2 Analog I/O Module Terminal Arrangement and Wiring Diagrams . . . . . . . . . . . . . . . 2-8 Type of Protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-12 Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-14 CHAPTER 3: INSTALLATION AND WIRING Mounting Hole Layout for Direct Mounting on Panel Surface . . . . . . . . . . . . . . . . . . 3-1 Terminal Connection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-2 CHAPTER 4: ANALOG I/O CONTROL System Setup . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-1 Programming WindLDR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-2 Analog I/O Control Parameters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-7 Data Register Allocation Numbers for Analog I/O Modules . . . . . . . . . . . . . . . . . . . 4-8 Analog Input Parameters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-11 Analog Output Parameters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-15 CHAPTER 5: TROUBLESHOOTING Troubleshooting Diagrams . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-1 INDEX FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL i 1: GENERAL INFORMATION Introduction This chapter describes general information and specifications of the FC4A series MicroSmart analog I/O modules. About the Analog I/O Modules Analog I/O modules are available in 3-I/O types, 2-, 4-, and 8-input types, and 1- and 2-output types. The input channel can accept voltage and current signals, thermocouple and resistance thermometer signals, or thermistor signals. The output channel generates voltage and current signals. Analog I/O Module Type Numbers Name Analog I/O Module Analog Input Module Analog Output Module I/O Signal Voltage (0 to 10V DC) Current (4 to 20mA) Voltage (0 to 10V DC) Current (4 to 20mA) Thermocouple (K, J, T) Resistance thermometer (Pt100) Voltage (0 to 10V DC) Current (4 to 20mA) Voltage (0 to 10V DC) Current (4 to 20mA) Voltage (0 to 10V DC) Current (4 to 20mA) Thermocouple (K, J, T) Resistance thermometer (Pt100, Pt1000, Ni100, Ni1000) Voltage (0 to 10V DC) Current (4 to 20mA) Thermistor (NTC, PTC) Voltage (0 to 10V DC) Current (4 to 20mA) Voltage (–10 to +10V DC) Current (4 to 20mA) I/O Points Category Type No. 2 inputs FC4A-L03A1 1 output 2 inputs END Refresh Type FC4A-L03AP1 1 output 2 inputs FC4A-J2A1 4 inputs FC4A-J4CN1 Ladder Refresh Type 8 inputs FC4A-J8C1 8 inputs FC4A-J8AT1 1 output END Refresh Type FC4A-K1A1 2 outputs Ladder Refresh Type FC4A-K2C1 END Refresh Type and Ladder Refresh Type Depending on the internal circuit design for data refreshing, analog I/O modules are categorized into two types. Analog I/O Module Category While CPU is running While CPU is stopped END Refresh Type Ladder Refresh Type Parameter Refreshing At the end processing in the first scan When executing ANST macro Analog I/O Data Refreshing At the end processing In the step after ANST macro (always refreshed whether input to ANST is on or off) Analog Output Data Refreshing When M8025 (maintain outputs while CPU stopped) is on, output data is refreshed. When off, output is turned off. Maintains output status when the CPU is stopped. Output data can be changed using STPA instruction while the CPU is stopped. See page 4-21. By default Optionally designated in ANST macro Data Register Allocation END Refresh Type Each END refresh type analog I/O module is allocated 20 data registers to store analog I/O data and parameters for controlling analog I/O operation. These data registers are updated at ever y end processing while the CPU module is running. WindLDR has ANST macro to program the analog I/O modules. The CPU module checks the analog I/O configuration only once at the end processing in the first scan. If you have changed the parameter while the CPU is running, stop and restart the CPU to enable the new parameter. Ladder Refresh Type Each ladder refresh type analog I/O module can be allocated any data registers to store analog I/O data and parameters for controlling analog I/O operation. The data registers are programmed in the ANST macro. Analog I/O data are updated at the ladder step following the ANST macro. Analog I/O parameters are updated when the ANST macro is executed, so analog I/O parameters can be changed while the CPU is running. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 1-1 1: GENERAL INFORMATION Applicable CPU Modules and WindLDR Version END refresh type analog I/O modules as many as listed below can be used with any FC4A and FC5A MicroSmart CPU modules and WindLDR versions. Ladder refresh type analog I/O modules can be used with the FC4A and FC5A MicroSmart CPU module system program versions and WindLDR versions as listed below. All-in-one 10- and 16-I/O type CPU modules cannot use either END refresh or ladder refresh type analog I/O modules. All-in-One Type Slim Type FC4A-C10R2 FC4A-C10R2C FC4A-C16R2 FC4A-C16R2C FC4A-C24R2 FC4A-C24R2C FC4A-D20K3 FC4A-D20S3 FC4A-D20RK1 FC4A-D20RS1 FC4A-D40K3 FC4A-D40S3 CPU System Program Version — — 204 or higher 204 or higher 203 or higher WindLDR Version — — Quantity of Analog I/O Modules — — FC4A MicroSmart CPU Module 5.0 or higher 4 7 All-in-One Type FC5A MicroSmart CPU Module 7 Slim Type FC5A-C10R2 FC5A-C10R2C FC5A-C16R2 FC5A-C16R2C FC5A-C24R2 FC5A-C24R2C (Note) CPU System Program Version — — 100 or higher WindLDR Version — — Quantity of Analog I/O Modules — — FC5A-D16RK1 FC5A-D16RS1 FC5A-D32K3 FC5A-D32S3 100 or higher 100 or higher 5.0 or higher 4 7 7 Note: FC5A all-in-one 24-I/O type CPU modules cannot use analog I/O modules in combination with the AS-Interface master module (FC4A-AS62M) and/or expansion RS232C communication module (FC5A-SIF2). When using these modules in combination with analog I/O modules, use the slim type CPU module. Confirming System Program Version The system program version can be confirmed using WindLDR. 1. Connect a PC to communication port 1 or 2 on the MicroSmart CPU module using the computer link cable 4C (FC2A-KC4C). 2. From the WindLDR menu bar, select Online > Monitor. The monitor mode is enabled. 3. From the WindLDR menu bar, select Online > PLC Status. The PLC Status dialog box appears and shows the system program version. System Program Version (Special data register D8029) 1-2 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2: MODULE SPECIFICATIONS Introduction This chapter describes parts names, functions, specifications, and dimensions of the analog I/O modules. Parts Description (1) Expansion Connector (2) Module Label (3) Power LED (PWR) (3) Status LED (STAT) (4) Terminal No. (5) Cable Terminal The terminal style depends on the model of analog I/O modules. (1) Expansion Connector Connects to the CPU and other I/O modules. (The all-in-one 10- and 16-I/O type CPU modules cannot be connected.) (2) Module Label Indicates the analog I/O module Type No. and specifications. (3) Power LED (PWR) END refresh type FC4A-L03A1, FC4A-L03AP1, FC4A-J2A1, FC4A-K1A1: Turns on when power is supplied to the analog I/O module. (3) Status LED (STAT) Ladder refresh type FC4A-J4CN1, FC4A-J8C1, FC4A-J8AT1, FC4A-K2C1: Indicates the operating status of the analog I/O module. Status LED Analog Input Operating Status OFF Analog I/O module is stopped ON Normal operation Flash Initializing Changing configuration Hardware initialization error External power supply error (4) Terminal No. Indicates terminal numbers. (5) Cable Terminal All analog I/O modules have a removable terminal block. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2-1 2: MODULE SPECIFICATIONS Analog I/O Module Specifications General Specifications (END Refresh Type) Type No. FC4A-L03A1 FC4A-L03AP1 FC4A-J2A1 FC4A-K1A1 Rated Power Voltage 24V DC Allowable Voltage Range 20.4 to 28.8V DC Terminal Arrangement See Analog I/O Module Terminal Arrangement on pages 2-8 to 2-11. Connector on Mother Board MC1.5/11-G-3.81BK (Phoenix Contact) Connector Insertion/Removal Durability 100 times minimum Internal Current Draw 50 mA (5V DC) 0 mA (24V DC) 50 mA (5V DC) 0 mA (24V DC) 50 mA (5V DC) 0 mA (24V DC) 50 mA (5V DC) 0 mA (24V DC) External Current Draw (Note) 45 mA (24V DC) 40 mA (24V DC) 35 mA (24V DC) 40 mA (24V DC) Weight 85g Note: The external current draw is the value when all analog inputs are used and the analog output value is at 100%. General Specifications (Ladder Refresh Type) Type No. FC4A-J4CN1 FC4A-J8C1 FC4A-J8AT1 FC4A-K2C1 Rated Power Voltage 24V DC Allowable Voltage Range 20.4 to 28.8V DC Terminal Arrangement See Analog I/O Module Terminal Arrangement on pages 2-8 to 2-11. Connector on Mother Board MC1.5/10-G-3.81BK (Phoenix Contact) Connector Insertion/Removal Durability 100 times minimum Internal Current Draw 50 mA (5V DC) 0 mA (24V DC) 40 mA (5V DC) 0 mA (24V DC) 45 mA (5V DC) 0 mA (24V DC) 60 mA (5V DC) 0 mA (24V DC) External Current Draw (Note) 55 mA (24V DC) 50 mA (24V DC) 55 mA (24V DC) 85 mA (24V DC) Weight 140g 140g 125g 110g Note: The external current draw is the value when all analog inputs are used and the analog output value is at 100%. 2-2 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2: MODULE SPECIFICATIONS Analog Input Specifications (END Refresh Type) Type No. FC4A-L03A1 / FC4A-J2A1 Input Range 0 to 10V DC 4 to 20 mA DC Input Impedance Allowable Conductor Resistance (per wire) Input Detection Current Sample Duration Time Sample Repetition Time Total Input System Transfer Time (Note 1) AD Conversion Type of Input 1 MΩ minimum 10Ω FC4A-L03AP1 Resistance Thermocouple Thermometer Type K (0 to 1300°C) Pt 100 Type J 3-wire type (0 to 1200°C) (–100 to 500°C) Type T (0 to 400°C) 1 MΩ minimum 1 MΩ minimum — — — 200Ω maximum — — 20 ms maximum 20 ms maximum — 20 ms maximum 20 ms maximum 1.0 mA maximum 105 ms + 1 scan time 200 ms + 1 scan time Analog Input Signal Type Voltage Input Operating Mode Conversion Method Input Error Data Noise Resistance Single-ended input Self-scan ∑∆ type ADC Current Input Differential input ±0.2% of full scale + reference junction compensation accuracy (±4°C maximum) ±0.2% of full scale K: 0.325°C J: 0.300°C T: 0.100°C 0.15°C Maximum Error at 25°C ±0.2% of full scale Temperature Coefficient Repeatability after Stabilization Time Non-lineality Maximum Error Digital Resolution ±0.006% of full scale/°C Input Value of LSB 2.5 mV Data Type in Application Program Monotonicity Input Data Out of Range Maximum Temporary Deviation during Electrical Noise Tests (Note 4) Input Filter Recommended Cable for Noise Immunity Crosstalk Default: 0 to 4095 Optional: –32768 to 32767 (selectable each channel) (Note 2) Yes Detectable (Note 3) Isolation Effect of Improper Input Connection Maximum Permanent Allowed Overload (No Damage) Selection of Analog Input Signal Type Calibration or Verification to Maintain Rated Accuracy ±0.5% of full scale ±0.2% of full scale ±1% of full scale 4096 increments (12 bits) 4 µA ±3% maximum Not assured No Twisted pair shielded cable — 2 LSB maximum Isolated between input and power circuit Photocoupler-isolated between input and internal circuit No damage 13V DC 40 mA DC — Using software programming Impossible For Note 1 through Note 4, see page 2-7. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2-3 2: MODULE SPECIFICATIONS Analog Input Specifications (Ladder Refresh Type) Type No. FC4A-J4CN1 / FC4A-J8C1 Analog Input Signal Type Voltage Input Input Range 0 to 10V DC 4 to 20 mA DC FC4A-J4CN1: 12Ω FC4A-J8C1: 100Ω — Input Impedance 1 MΩ Input Detection Current Sample Duration Time — — 2 ms maximum FC4A-J4CN1: 10 ms maximum 10 ms maximum FC4A-J8C1: 2 ms maximum FC4A-J4CN1: 45 ms 40 ms × channels + 1 scan time × channels FC4A-J8C1: + 1 scan time 8 ms × channels + 1 scan time Single-ended input Self-scan FC4A-J4CN1: ∑∆ type ADC FC4A-J8C1: Successive approximation register method Sample Repetition Time AD Conversion Total Input System Transfer Time (Note 1) Type of Input Operating Mode Conversion Method Maximum Error at 25°C Input Error 2-4 Current Input FC4A-J4CN1 Resistance Thermocouple Thermometer Type K: Pt100, Pt1000: 0 to 1300°C –100 to 500°C Type J: 0 to 1200°C Ni100, Ni1000: Type T: –60 to 180°C 0 to 400°C Cold Junction Compensation Error Temperature Coefficient Repeatability after Stabilization Time Non-lineality Maximum Error ±0.2% of full scale — — 1 MΩ — 0.1 mA 30 ms maximum 65 ms × channels + 1 scan time ±0.2% of full scale + reference junction compensation accuracy (±3°C maximum) ±0.2% of full scale ±3.0°C maximum — ±0.005% of full scale/°C ±0.5% of full scale ±0.04% of full scale ±1% of full scale FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2: MODULE SPECIFICATIONS Type No. FC4A-J4CN1 / FC4A-J8C1 Analog Input Signal Type Voltage Input Current Input FC4A-J4CN1 Resistance Thermocouple Thermometer Pt100: Approx. 6400 increments K: Approx. 24000 increments (15 bits) J: Approx. Digital Resolution 50000 increments (16 bits) 33000 increments (15 bits) T: Approx. 10000 increments (14 bits) Data Input Value of LSB Data Type in Application Program Data Noise Resistance Monotonicity Input Data Out of Range Digital Resolution Input Value of LSB Maximum Temporary Deviation during Electrical Noise Tests (Note 4) Input Filter Recommended Cable for Noise Immunity Crosstalk Isolation Effect of Improper Input Connection Maximum Permanent Allowed Overload (No Damage) Selection of Analog Input Signal Type Calibration or Verification to Maintain Rated Accuracy 0.2 mV 0.32 µA K: 0.058°C J: 0.038°C T: 0.042°C (13 bits) Pt1000: Approx. 64000 increments (16 bits) Ni100: Approx. 4700 increments (13 bits) Ni1000: Approx. 47000 increments (16 bits) Pt100: 0.086°C Pt1000: 0.0086°C Ni100: 0.037°C Ni1000: 0.0037°C Pt100, Ni100: 0 to 6000 Default: 0 to 50000 Pt1000, Ni1000: 0 to 60000 Optional: –32768 to 32767 (selectable for each channel) (Note 2) — Temperature: Celsius, Fahrenheit Yes Detectable (Note 3) Default: 0 to 50000 ±3% maximum Not assured Software Twisted pair cable — 2 LSB maximum Isolated between input and power circuit Photocoupler-isolated between input and internal circuit No damage 11V DC 22 mA DC — Using software programming Impossible For Note 1 through Note 4, see page 2-7. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2-5 2: MODULE SPECIFICATIONS Analog Input Specifications (Ladder Refresh Type) Type No. Analog Input Signal Type Input Range Applicable Thermistor Input Detection Current Sample Duration Time Sample Repetition Time Total Input System AD Transfer Time (Note 1) Conversion Type of Input Operating Mode Conversion Method Maximum Error at 25°C Temperature Coefficient Repeatability after Input Error Stabilization Time Non-lineality Maximum Error Digital Resolution Input Value of LSB Data Noise Resistance Data Type in Application Program Monotonicity Input Data Out of Range Maximum Temporary Deviation during Electrical Noise Tests (Note 4) Input Filter Recommended Cable for Noise Immunity Crosstalk Isolation Effect of Improper Input Connection Selection of Analog Input Signal Type Calibration or Verification to Maintain Rated Accuracy FC4A-J8AT1 NTC –50 to 150°C 100 kΩ maximum 0.1 mA 2 ms maximum 2 ms × channels 10 ms × channels + 1 scan time (Note 1) Single-ended input Self-scan Successive approximation register method ±0.2% of full scale ±0.005% of full scale/°C ±0.5% of full scale No ±1% of full scale Approx. 4000 increments (12 bits) 0.05°C Default: 0 to 4000 Optional: –32768 to 32767 (selectable for each channel) (Note 2) Temperature: Celsius, Fahrenheit (NTC only) Resistance: 0 to 10000 Yes Detectable (Note 3) ±3% maximum Software — 2 LSB maximum Isolated between input and power circuit Photocoupler-isolated between input and internal circuit No damage Using software programming Impossible For Note 1 through Note 4, see page 2-7. 2-6 PTC FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2: MODULE SPECIFICATIONS Analog Output Specifications Category Type No. END Refresh Type FC4A-L03AP1 Voltage Output Range Current Load Impedance Load Applicable Load Type Settling Time DA Total Output System Conversion Transfer Time Maximum Error at 25°C Temperature Coefficient Repeatability after Stabilization Time Output Error Output Voltage Drop Non-lineality Output Ripple Overshoot Total Error Digital Resolution Output Value of LSB Voltage Current Data Data Type in Application Program Monotonicity Current Loop Open Maximum Temporary Deviation during Electrical Noise Tests Noise (Note 4) Resistance Recommended Cable for Noise Immunity Crosstalk Isolation Effect of Improper Output Connection Selection of Analog Output Signal Type Calibration or Verification to Maintain Rated Accuracy FC4A-L03A1 FC4A-K1A1 0 to 10V DC 4 to 20 mA DC 2 kΩ minimum (voltage), 300Ω maximum (current) Resistive load 50 ms 130 ms 50 ms Settling time + 1 scan time Ladder Refresh FC4A-K2C1 –10 to +10V DC 1 ms/ch 1 ms × channels + 1 scan time ±0.2% of full scale ±0.015% of full scale/°C ±0.005% of full scale/°C ±0.5% of full scale ±1% of full scale ±0.2% of full scale 1 LSB maximum 0% ±1% of full scale ±0.1% of full scale 50000 increments (16 bits) 2.5 mV 0.4 mV 4 µA 0.32 µA –25000 to 25000 (voltage) Default: 0 to 4095 (voltage, current) 0 to 50000 (current) Optional: –32768 to 32767 (selectable for each channel) (Note 2) Yes Not detectable 4096 increments (12 bits) ±3% maximum Twisted pair shielded cable Twisted pair cable No crosstalk because of 1 channel output 2 LSB maximum Isolated between output and power circuit Photocoupler-isolated between output and internal circuit No damage Using software programming Impossible Note 1: Total input system transfer time = Sample repetition time + Internal processing time When using the FC4A-J4CN1, FC4A-J8C1, or FC4A-J8AT1, the total input system transfer time increases in proportion to the number of channels used. Note 2: The data processed in the analog I/O module can be linear-converted to a value between –32768 and 32767. The optional range designation, and analog I/O data minimum and maximum values can be selected using data registers allocated to analog I/O modules. See page 4-12. Note 3: When an error is detected, a corresponding error code is stored to a data register allocated to analog I/O operating status. See page 4-6. Note 4: The value is measured when a 500V clamp voltage is applied to the power supply and I/O lines. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2-7 2: MODULE SPECIFICATIONS Analog I/O Module Terminal Arrangement and Wiring Diagrams FC4A-L03A1 (Analog I/O Module) — Screw Terminal Type Applicable Terminal Block: FC4A-PMT11P (supplied with the analog I/O module) Fuse 24V DC – + Analog voltage/current input device Analog voltage/current output device Analog voltage/current output device Terminal No. + Channel – 24V DC + + – – NC + – NC + – + – + – OUT IN0 IN1 • Connect a fuse appropriate for the applied voltage and current draw, at the position shown in the diagram. This is required when equipment containing the MicroSmart is destined for Europe. • Do not connect any wiring to unused terminals. • Before turn on the power, make sure that wiring to the analog I/O module is correct. If wiring is incorrect, the analog I/O module may be damaged. FC4A-L03AP1 (Analog I/O Module) — Screw Terminal Type Applicable Terminal Block: FC4A-PMT11P (supplied with the analog I/O module) Fuse 24V DC – + Analog voltage/current input device Resistance thermometer Channel – 24V DC + + – A B’ B – + Thermocouple Terminal No. + – NC + – NC + – OUT A B’ B A B’ B IN0 IN1 • Connect a fuse appropriate for the applied voltage and current draw, at the position shown in the diagram. This is required when equipment containing the MicroSmart is destined for Europe. • When connecting a resistance thermometer, connect the three wires to RTD (resistance temperature detector) terminals A, B’, and B of input channel IN0 or IN1. • When connecting a thermocouple, connect the two wires to terminals + and – of input channels IN0 or IN1. • Do not connect any wiring to unused terminals. • Do not connect the thermocouple to a hazardous voltage (60V DC or 42.4V peak or higher). 2-8 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2: MODULE SPECIFICATIONS FC4A-J2A1 (Analog Input Module) — Screw Terminal Type Applicable Terminal Block: FC4A-PMT11P (supplied with the analog input module) Fuse 24V DC – + Analog voltage/current output device Analog voltage/current output device Terminal No. + Channel – 24V DC NC NC NC + – NC + – + – + – — IN0 IN1 • Connect a fuse appropriate for the applied voltage and current draw, at the position shown in the diagram. This is required when equipment containing the MicroSmart is destined for Europe. • Do not connect any wiring to unused terminals. FC4A-J4CN1 (Analog Input Module) — Screw Terminal Type Applicable Terminal Block: FC4A-PMT10P (supplied with the analog input module) Fuse 24V DC – + Analog voltage output device + – NC + Analog current output device – Resistance thermometer B B’ A NC + Thermocouple – NC Terminal No. 24V 0V Channel NC CS + – I– CS + — – I– CS + – I– CS + – I– 24V DC IN0 IN1 IN1 IN2 IN3 • Connect a fuse appropriate for the applied voltage and current draw, at the position shown in the diagram. This is required when equipment containing the MicroSmart is destined for Europe. • When connecting a resistance thermometer, connect three wires B, B’, and A to the CS (current sense), +, and – terminals of input channels IN0 through IN3, respectively. • When connecting a thermocouple, connect the + wire to the + terminal and the – wire to the CS and – terminals. • Do not connect the thermocouple to a hazardous voltage (60V DC or 42.4V peak or higher). • Do not connect any wiring to unused terminals. • – terminals of input channels IN0 through IN3 are interconnected. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2-9 2: MODULE SPECIFICATIONS FC4A-J8C1 (Analog Input Module) — Screw Terminal Type Applicable Terminal Block: FC4A-PMT10P (supplied with the analog input module) Fuse 24V DC – + Analog voltage output device Analog current output device + – + – • Connect a fuse appropriate for the applied voltage and current draw, at the position shown in the diagram. This is required when equipment containing the MicroSmart is destined for Europe. • Do not connect any wiring to unused terminals. • – terminals of input channels IN0 through IN7 are interconnected. Terminal No. 24V 0V Channel NC + – + – + – — + – + – + – + – + – 24V DC IN0 IN1 IN2 IN3 IN4 IN5 IN6 IN7 FC4A-J8AT1 (Analog Input Module) — Screw Terminal Type Applicable Terminal Block: FC4A-PMT10P (supplied with the analog input module) Fuse 24V DC – + NTC Thermistor PTC Thermistor A B A B • Connect a fuse appropriate for the applied voltage and current draw, at the position shown in the diagram. This is required when equipment containing the MicroSmart is destined for Europe. • Do not connect any wiring to unused terminals. 2-10 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL Terminal No. 24V 0V Channel NC A B A B A B — A B A B A B A B A B 24V DC IN0 IN1 IN2 IN3 IN4 IN5 IN6 IN7 2: MODULE SPECIFICATIONS FC4A-K1A1 (Analog Output Module) — Screw Terminal Type Applicable Terminal Block: FC4A-PMT11P (supplied with the analog output module) Fuse 24V DC – + Analog voltage/current input device Terminal No. + Channel – 24V DC + + – – NC NC NC NC NC NC OUT — — • Connect a fuse appropriate for the applied voltage and current draw, at the position shown in the diagram. This is required when equipment containing the MicroSmart is destined for Europe. • Do not connect any wiring to unused terminals. FC4A-K2C1 (Analog Output Module) — Screw Terminal Type Applicable Terminal Block: FC4A-PMT10P (supplied with the analog output module) Fuse 24V DC – + + Analog voltage input device Analog current input device NC – + NC – Terminal No. 24V 0V Channel NC V+ I+ – V+ I+ – — 24V DC OUT0 OUT1 • Connect a fuse appropriate for the applied voltage and current draw, at the position shown in the diagram. This is required when equipment containing the MicroSmart is destined for Europe. • Do not connect any wiring to unused terminals. • – terminals of output channels OUT0 and OUT1 are interconnected. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2-11 2: MODULE SPECIFICATIONS Type of Protection Input Circuits FC4A-L03A1, FC4A-L03AP1, FC4A-J2A1 +V2 FC4A-J4CN1 +V1 15 MΩ Current Source 1 kΩ 10Ω 1 kΩ Input Data CS Input Circuit 1 kΩ + (B’) Multiplexer NC (A) + – (B) 15Ω Input Selection Signal – I– –V1 FC4A-J8C1 FC4A-J8AT1 + 100Ω Input Circuit Input Circuit Current Source A 10 kΩ B Input Selection Signal – Output Circuits FC4A-K2C1 + – Output Circuit Output Circuit FC4A-L03A1, FC4A-L03AP1, FC4A-K1A1 V+ I+ – 2-12 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 2: MODULE SPECIFICATIONS Power Supply for Analog I/O Modules When supplying power to the analog I/O modules, take the following considerations. • Power Supply for END Refresh Type Analog I/O Modules Use separate power supplies for the MicroSmart CPU module and END refresh type analog I/O modules. Power up the analog I/O modules at least 1 second earlier than the CPU module. This is recommended to ensure correct operation of the analog I/O control. • Power Supply for Ladder Refresh Type Analog I/O Modules Use the same power supply for the MicroSmart CPU module and ladder refresh type analog I/O modules to suppress the influence of noises. After the CPU module has started to run, ladder refresh type analog input modules perform initialization for a maximum of 5 seconds. During this period, the analog input data have an indefinite value. Design the user program to make sure that the analog input data are read to the CPU module after the analog input operating status has changed to 0 (normal operation). For the analog input operating status, see page 4-13. Wiring Analog I/O Lines Separate the analog I/O lines, particularly resistance thermometer inputs, from motor lines as much as possible to suppress the influence of noises. 24V DC – + Separate the analog I/O line from the power line. Analog voltage/current input device Resistance thermometer Analog voltage/current output device Fuse Terminal No. + Channel – 24V DC + + – A B’ B – + – NC + – NC + – OUT A B’ B A B’ B FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL IN0 IN1 2-13 2: MODULE SPECIFICATIONS Dimensions FC4A-L03A1, FC4A-L03AP1, FC4A-J2A1, FC4A-K1A1, FC4A-K2C1 23.5 14.6 70.0 4.5* 90.0 3.8 *8.5 mm when the clamp is pulled out. FC4A-J4CN1, FC4A-J8C1, FC4A-J8AT1 23.5 14.6 70.0 4.5* 90.0 3.8 *8.5 mm when the clamp is pulled out. All dimensions in mm. 2-14 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 3: INSTALLATION AND WIRING Introduction This chapter describes precautions for installing the analog I/O modules in connection with the internal current draw by other expansion modules. For general methods and precautions for installation and wiring of the analog I/O modules, see the FC4A MicroSmart user’s manual (FC9Y-B812). Warning • This equipment is suitable for use in Class I, Division 2, Groups A, B, C, D or non-hazardous locations only. • Explosion hazard — Substitution of components may impair suitability for Class I, Division 2. • Explosion hazard — Do not disconnect equipment unless power has been switched off or the area is known to be non-hazardous. Mounting Hole Layout for Direct Mounting on Panel Surface To mount the analog I/O module on a panel surface, use the direct mounting strip and two M4 screws (6 or 8 mm long). 23.5 6.3 .3 2-ø4 Direct Mounting Strip FC4A-PSP1P 113.0±0.2 90.0 103.0 For details about the direct mounting strip, see the FC4A MicroSmart user’s manual (FC9Y-B812). 3.0 3 Example: Mounting hole layout for FC4A-C24R2 and three analog I/O modules 23.5 23.5 83.0 103.0 10 -ø 4. 12.3 3.0 83.0 15.3 3.0 3.0 23.5 23.5 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL All dimensions in mm. 3-1 3: INSTALLATION AND WIRING Terminal Connection Caution • Make sure that the operating conditions and environments are within the specification values. • Be sure to connect the grounding wire to a proper ground, otherwise electrical shocks may be caused. • Do not touch live terminals, otherwise electrical shocks may be caused. • Do not touch terminals immediately after power is turned off, otherwise electrical shocks may be caused. • When using ferrules, insert a wire to the bottom of the ferrule and crimp the ferrule. • When connecting a stranded wire or multiple solid wires to a screw terminal block, use a ferrule. Otherwise the wire may slip off the screw terminal block. Ferrules, Crimping Tool, and Screwdriver for Phoenix Terminal Blocks The screw terminal block can be wired with or without using ferrules on the end of cable. Applicable ferrules for the Phoenix terminal blocks and crimping tool for the ferrules are listed below. The screwdriver is used for tightening the screw terminals on the MicroSmart modules. These ferrules, crimping tool, and screwdriver are made by Phoenix Contact and are available from Phoenix Contact. Type numbers of the ferrules, crimping tool, and screwdriver listed below are the type numbers of Phoenix Contact. When ordering these products from Phoenix Contact, specify the Order No. and quantity listed below. Ferrule Order No. Quantity of Cables Order No. Pcs./Pkt. UL1007 AWG16 AI 1,5-8 BK 32 00 04 3 100 UL1007 AWG18 AI 1-8 RD 32 00 03 0 100 UL1015 AWG22 AI 0,5-8 WH 32 00 01 4 100 UL1007 AWG18 AI-TWIN 2 x 0,75-8 GY 32 00 80 7 100 UL1015 AWG22 AI-TWIN 2 x 0,5-8 WH 32 00 93 3 100 Phoenix Type Order No. Pcs./Pkt. CRIMPFOX ZA 3 12 01 88 2 1 For CPU modules SZS 0,6 x 3,5 12 05 05 3 10 For I/O modules and communication adapter SZS 0,4 x 2,5 12 05 03 7 10 For 1-cable connection For 2-cable connection Cable Size Phoenix Type Crimping Tool and Screwdriver Order No. Tool Name Crimping Tool Screwdriver Screw Terminal Tightening Torque 3-2 CPU modules 0.5 N·m I/O modules Communication adapter 0.22 to 0.25 N·m FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4: ANALOG I/O CONTROL Introduction The MicroSmart provides analog I/O control capabilities of 12- through 16-bit resolution using analog I/O modules. This chapter describes the system setup for using analog I/O modules, WindLDR programming procedures, data register allocation numbers for analog I/O modules, and application examples. For hardware specifications of analog I/O modules, see page 2-2. System Setup The FC4A and FC5A MicroSmart CPU modules can be used with a maximum of seven expansion I/O modules, which include digital I/O modules and analog I/O modules. Quantity of Applicable Analog I/O Modules The quantity of the analog I/O modules that can be connected to the MicroSmart CPU module depends on the model of the MicroSmart CPU modules as listed below: All-in-One Type FC4A MicroSmart CPU Module Quantity of Analog I/O Modules Slim Type FC4A-C10R2 FC4A-C10R2C FC4A-C16R2 FC4A-C16R2C FC4A-C24R2 FC4A-C24R2C FC4A-D20K3 FC4A-D20S3 FC4A-D20RK1 FC4A-D20RS1 FC4A-D40K3 FC4A-D40S3 — — 4 7 7 All-in-One Type FC5A MicroSmart CPU Module Quantity of Analog I/O Modules Slim Type FC5A-C10R2 FC5A-C10R2C FC5A-C16R2 FC5A-C16R2C FC5A-C24R2 FC5A-C24R2C FC5A-D16RK1 FC5A-D16RS1 FC5A-D32K3 FC5A-D32S3 — — 4 7 7 System Setup Example Slot No.: Slim Type CPU Module 1 2 3 4 5 6 7 Analog I/O Module Digital I/O Module Analog I/O Module Digital I/O Module Digital I/O Module Analog I/O Module Analog I/O Module Expansion I/O Modules (7 maximum) • Slot No. Indicates the position where the expansion module is mounted. The slot number starts with 1 next to the CPU module up to a maximum of 7. Note: Analog I/O modules cannot be mounted to the right of the expansion interface module. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4-1 4: ANALOG I/O CONTROL Programming WindLDR Use WindLDR ver. 5.0 or later which has the ANST (Set Analog Module Parameters) macro for easy programming of analog I/O modules. For a start input of the ANST macro, use special internal relay M8120 (initialize pulse) to execute the ANST macro only once after starting the CPU. 1. Click the ANST icon from the WindLDR tool bar, then place the cursor where you want to insert the ANST instruction on the ladder editing screen, and click the mouse. Or, place the cursor where you want to insert the ANST instruction on the ladder editing screen, and type ANST. The Set Analog Module Parameters dialog box appears. 2. Select the slots where analog I/O modules are mounted. All slots are selected to use seven analog I/O modules as default. Click the check box to deselect slots where analog I/O modules are not mounted. When using analog I/O modules on Slots 1, 3, 6, and 7, deselect Slots 2, 4, and 5 as shown below. 4-2 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4: ANALOG I/O CONTROL 3. Click the Configure button under the selected slots. The Configure Parameters dialog box appears. All parameters for analog I/O control can be set in this dialog box. Available parameters vary with the type of the analog I/O module. END Refresh Type Configure Parameters dialog box FC4A-L03A1 FC4A-L03AP1 FC4A-J2A1 FC4A-K1A1 Analog I/O Data (Note) Analog I/O Operating Status 4. Select the type of the analog I/O module. Click on the right of the analog I/O module Type No., then a pull-down list shows eight available modules. Depending on the selected analog I/O module, other parameters available for the selected module are shown. Ladder Refresh Type Configure Parameters dialog box FC4A-J4CN1 FC4A-J8C1 FC4A-J8AT1 FC4A-K2C1 Analog I/O Data (Note) Analog I/O Operating Status In the Configure Parameters dialog box, parameters in white cells are selectable while gray cells indicate default parameters. In the white cells, optional values can be selected from a pull-down list or entered by typing required values. Note for PID Instruction Source Operand S4 (process variable) When using the PID instruction, specify the data register number shown under Data in the Configure Parameters dialog box as source operand S4 (process variable) of the PID instruction. The analog input data in the selected data register is used as the process variable of the PID instruction. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4-3 4: ANALOG I/O CONTROL 5. Select a DR allocation number (Ladder refresh type only). CPU Module DR Allocation END Refresh Type FC4A-L03A1 FC4A-L03AP1 FC4A-J2A1 FC4A-K1A1 DR allocation starts with D760 as default, and the first DR number cannot be changed. One analog I/O module occupies 20 data registers. When a maximum of seven analog I/O modules are used, data registers D760 through D899 are used for analog I/O control. Ladder Refresh Type FC4A-J4CN1 FC4A-J8C1 FC4A-J8AT1 FC4A-K2C1 The first data register can be selected as required. Enter the first DR number used for analog I/O control. One analog input module occupies a maximum of 65 data registers. One analog output module occupies 15 data registers. Ladder Refresh Type Configure Parameters dialog box First Data Register No. Allocation range changes automatically. 6. Enter a filter value (Ladder refresh type analog input modules only). The filter function is available for the FC4A-J4CN1, FC4A-J8C1, and FC4A-J8AT1 only. Filtering ensures smooth input of analog data into the CPU module. Filter Value 0 or 1 2 to 255 Description Without filter function The average of N pieces of analog input data is read as analog input data, where N is the designated filter value. (Previous analog input data) × (Filter value) + (Current analog input data) Analog input data = -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------(Filter value) + 1 7. Select a signal type for each channel. Click on the right of the Signal Type field, then a pull-down list appears to show all available input or output signal types. When you do not use any input or output signal, select the default value or Not used for the channel. END Refresh Type Ladder Refresh Type 4-4 Analog I/O Module For unused channel, select FC4A-L03A1, FC4A-J2A1 0 to 10V DC FC4A-L03AP1 FC4A-J4CN1, FC4A-J8C1, FC4A-J8AT1, FC4A-K2C1 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL Type K Not used 4: ANALOG I/O CONTROL 8. Select a data type for each channel. Click on the right of the Data Type field, then a pull-down list appears to show all available input or output data types. 9. Select a scale value (Ladder refresh type analog input modules only). When Celsius or Fahrenheit is selected for thermocouple, resistance thermometer, or thermistor signal types on ladder refresh type analog input modules, the scale value can be selected from ×1, ×10, or ×100 depending on the selected signal type. Using this function, the analog input data can be multiplied to ensure precise control. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4-5 4: ANALOG I/O CONTROL 10. Select maximum and minimum values. For analog input values, when Optional range is selected for the Data Type, designate the analog input data minimum and maximum values which can be –32,768 through 32,767. In addition, when using resistance thermometers (Pt100, Pt1000, Ni100, or Ni1000) with the Celsius or Fahrenheit Data Type and the ×100 scale, select the analog input data minimum value from 0 or another value in the pull-down list. The maximum value is changed automatically according to the selected minimum value. For analog output values, when Optional range is selected for the Data Type, designate the analog output data minimum and maximum values which can be –32,768 through 32,767. 11. View the data register numbers allocated to Data and Status. Parameter Data Analog I/O Data Stores the digital data converted from an analog input signal or converted into an analog output signal. Designated as source operand S4 (process variable) of the PID instruction. Status Analog I/O Operating Status Stores an analog I/O operating status code. See pages 4-13 and 4-15. DR Allocation END Refresh Type Data registers are automatically allocated depending on the slot where the analog I/O module is mounted. Ladder Refresh Type Data registers are automatically allocated depending on the number designated in the DR Allocation Number field. 12. Click the OK button to save changes and exit the Configure Parameter dialog box. 13. Repeat the same steps for other slots. 14. When finished, click the OK button to save changes and exit the Set Analog Module Parameters dialog box. 4-6 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4: ANALOG I/O CONTROL Analog I/O Control Parameters Available parameters for analog I/O control depend on the type of analog I/O modules as summarized in the following table. Designate the parameters in the Configure Parameters dialog box of the ANST macro as required by your application. Analog I/O Module END Refresh Type Analog Input Data Type Analog Input Data Minimum/Maximum Values Filter Value Thermistor Parameter Analog Input Data Analog Input Operating Status Analog Output Signal Type Analog Output Data Type Analog Output Data Minimum/Maximum Values Analog Output Data Analog Output Operating Status Analog Output Module END Ladder FC4AL03A1 FC4AL03AP1 FC4AJ2A1 FC4AJ4CN1 FC4AJ8C1 FC4AJ8AT1 FC4AK1A1 FC4AK2C1 X X X X X X — — X X X X — Parameter Analog Input Signal Type Analog Input Module Ladder Refresh Type Page 4-11 X Page 4-11 Page 4-11 X X X — X Page 4-13 — — — — — X X — X X — X X — — Page 4-15 — X — X — — X — — X — X — — X — — — — X — — X — — X Page 4-15 — — X — — X X Page 4-15 — — — — — X — — 4-13 X — — — Page 4-15 X X Page 4-13 Page 4-15 X — X Page 4-15 X — Page 4-13 Page 4-15 X X Page 4-13 Page 4-13 X X — Page 4-13 X X — — Page 4-13 — X — Page 4-11 X — X X Page 4-15 — — X — — X — X Page 4-15 — FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL X Page 4-15 4-7 4: ANALOG I/O CONTROL Data Register Allocation Numbers for Analog I/O Modules Analog I/O modules are numbered from 1 through 7, in the order of increasing distance from the CPU module. Data registers are allocated to each analog I/O module depending on the analog I/O module number. END refresh type analog I/O modules and ladder refresh type analog I/O modules have different data register allocation. END Refresh Type Analog I/O Modules Each END refresh type analog I/O module is automatically allocated 20 data registers to store parameters for controlling analog I/O operation, starting with D760 through D779 for analog I/O module No. 1, up to D880 through D899 for analog I/O module No. 7. When a maximum of seven analog I/O modules are not used, data registers allocated to the unused analog I/O module numbers can be used as ordinary data registers. When a maximum of seven END refresh type analog I/O modules are mounted, data registers D760 through D899 are allocated to analog modules 1 through 7 as shown below. The ANST macro is used to program data registers for the analog I/O module configuration. The CPU module checks the analog I/O configuration only once when the CPU starts to run. If you have changed the parameter while the CPU is running, stop and restart the CPU to enable the new parameter. The END refresh type analog I/O module number starts with 1 next to the CPU module up to a maximum of 7. The run-time program download and test program download cannot be used to change analog I/O parameters. Channel Function Analog input data Analog Input Ch 0 Analog Input Ch 1 Analog Output END Refresh Type Analog I/O Module No. 1 2 3 4 5 6 7 D760 D780 D800 D820 D840 D860 D880 R Analog input operating status D761 D781 D801 D821 D841 D861 D881 R Analog input signal type D762 D782 D802 D822 D842 D862 D882 R/W Analog input data type D763 D783 D803 D823 D843 D863 D883 R/W Analog input data minimum value D764 D784 D804 D824 D844 D864 D884 R/W Analog input data maximum value D765 D785 D805 D825 D845 D865 D885 R/W Analog input data D766 D786 D806 D826 D846 D866 D886 R Analog input operating status D767 D787 D807 D827 D847 D867 D887 R Analog input signal type D768 D788 D808 D828 D848 D868 D888 R/W Analog input data type D769 D789 D809 D829 D849 D869 D889 R/W Analog input data minimum value D770 D790 D810 D830 D850 D870 D890 R/W Analog input data maximum value D771 D791 D811 D831 D851 D871 D891 R/W Analog output data D772 D792 D812 D832 D852 D872 D892 R/W Analog output operating status D773 D793 D813 D833 D853 D873 D893 R Analog output signal type D774 D794 D814 D834 D854 D874 D894 R/W Analog output data type D775 D795 D815 D835 D855 D875 D895 R/W Analog output data minimum value D776 D796 D816 D836 D856 D876 D896 R/W Analog output data maximum value – Reserved – D777 D797 D817 D837 D857 D877 D897 R/W D778 D798 D818 D838 D858 D878 D898 R/W D779 D799 D819 D839 D859 D879 D899 R/W Note: Data registers allocated to the unused analog I/O module numbers can be used as ordinary data registers. 4-8 R/W FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4: ANALOG I/O CONTROL Ladder Refresh Type Analog I/O Modules When using a ladder refresh type analog input or output module, the first data register number can be designated in the ASNT macro dialog box. The quantity of required data registers depends on the model of the ladder refresh type analog input or output module. Analog I/O Module FC4A-J4CN1 FC4A-J8C1 FC4A-J8AT1 FC4A-K2C1 65 65 65 15 Quantity of Data Registers for Analog I/O Operation Data register numbers and parameters are shown in the table below. Ladder Refresh Type Analog Input Module Data Register Allocation (FC4A-J4CN1, FC4A-J8C1, and FC4A-J8AT1) Data Register Number Offset +0 (Low Byte) +0 (High Byte) Data Size (word) 1 Parameter Analog input signal type — Reserved — +1 4 Analog input data configuration +5 1 Analog input signal type +6 4 Analog input data configuration +10 1 Analog input signal type +11 4 Analog input data configuration +15 1 Analog input signal type +16 4 Analog input data configuration +20 1 Analog input signal type +21 4 Analog input data configuration +25 1 Analog input signal type +26 4 Analog input data configuration +30 1 Analog input signal type +31 4 Analog input data configuration +35 1 Analog input signal type +36 4 Analog input data configuration +40 3 +43 3 +46 1 +47 +48 +49 1 +50 1 +51 +52 Channel Default CH0 FFh All channels 00h CH0 CH1 CH2 CH3 CH4 * CH5 * CH6 * CH7 * R/W R/W 0 R/W 00FFh R/W 0 R/W 00FFh R/W 0 R/W 00FFh R/W 0 R/W 00FFh R/W 0 R/W 00FFh R/W 0 R/W 00FFh R/W 0 R/W 00FFh R/W 0 R/W 0 R/W CH4 to CH7 * 0 R/W CH0 — R 1 CH1 — R 1 CH2 — R Thermistor parameters (FC4A-J8AT1 only) CH0 to CH3 CH3 — R CH4 * — R 1 CH5 * — R 1 CH6 * — R +53 1 CH7 * — R +54 1 CH0 — R +55 1 CH1 — R +56 1 CH2 — R +57 1 +58 1 +59 +60 +61 1 +62 3 Analog input data CH3 — R CH4 * — R 1 CH5 * — R 1 CH6 * — R CH7 * — R All channels — R Analog input operating status — Reserved — * Data registers for channels 4 through 7 are reserved on the FC4A-J4CN1. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4-9 4: ANALOG I/O CONTROL Ladder Refresh Type Analog Output Module Data Register Allocation (FC4A-K2C1) Data Register Number Offset +0 (Low Byte) +0 (High Byte) 4-10 Data Size (word) 1 Parameter Analog output signal type — Reserved — +1 3 Analog output data configuration +4 1 Analog output signal type +5 3 Analog output data configuration +8 1 +9 1 +10 1 +11 1 +12 3 Analog output data Analog output operating status — Reserved — Channel Default CH0 FFh All channels 00h CH0 CH1 CH0 R/W R/W 0 R/W 00FFh R/W 0 R/W 0 R/W CH1 0 R/W CH0 — R CH1 — R All channels — R FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4: ANALOG I/O CONTROL Analog Input Parameters Analog input parameters include the analog input signal type, analog input data type, analog input minimum and maximum values, filter value, thermistor parameter, analog input data, and analog input operating status. This section describes these parameters in detail. Analog Input Signal Type A total of 11 analog input signal types are available, depending on the analog I/O or analog input module. Select an analog input signal type for each analog input channel. When a channel is not used, select the default value or Not used for the channel. Parameter FC4AL03A1 FC4AL03AP1 FC4AJ2A1 FC4AJ4CN1 FC4AJ8C1 FC4AJ8AT1 0 Voltage input (0 to 10V DC) X — X X X — 1 Current input (4 to 20 mA DC) X — X X X — 2 Type K thermocouple — X — X — — 3 Type J thermocouple — X — X — — 4 Type T thermocouple — X — X — — 5 Pt 100 resistance thermometer — X — X — — 6 Pt 1000 resistance thermometer — — — X — — 7 Ni 100 resistance thermometer — — — X — — 8 Ni 1000 resistance thermometer — — — X — — 9 NTC type thermistor — — — — — X 10 PTC type thermistor — — — — — X 255 Not used — — — X X X Analog Input Data Type A total of five analog input data types are available, depending on the analog I/O or analog input module. Select an analog input data type for each analog input channel. Parameter FC4AL03A1 FC4AL03AP1 FC4AJ2A1 FC4AJ4CN1 FC4AJ8C1 FC4AJ8AT1 X X X X X X 0 Binary data 1 Optional range X X X X X X 2 Celsius — X — X — NTC only 3 Fahrenheit — X — X — NTC only 4 Resistance — — — — — X Binary Data When Binary data is selected as an analog input data type, the analog input is linearly converted into digital data in the range described in the table below. Type No. Analog Input Data FC4A-L03A1 FC4A-L03AP1 FC4A-J2A1 0 to 4095 FC4A-J4CN1 Analog Input Signal Type Voltage/Current: Thermocouple: Pt100, Ni100: Pt1000, Ni1000: Analog Input Data 0 to 50,000 0 to 50,000 0 to 6,000 0 to 60,000 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL FC4A-J8C1 FC4A-J8AT1 0 to 50000 0 to 4000 4-11 4: ANALOG I/O CONTROL Optional Range When Optional range is selected as an analog input data type, the analog input is linearly converted into digital data in the range between the minimum and maximum values designated in the Configure Parameters dialog box. Type No. FC4A-L03A1 Analog Input Data FC4A-L03AP1 FC4A-J2A1 FC4A-J4CN1 FC4A-J8C1 FC4A-J8AT1 Analog input data minimum value to maximum value (–32768 to 32767) Celsius and Fahrenheit When Celsius or Fahrenheit is selected as an analog input data type, the analog input data range depends on the analog input signal type, scale value, and the type of the analog input module, FC4A-L03AP1, FC4A-J4CN1, and FC4A-J8AT1. • FC4A-L03AP1 Analog Input Signal Type Celsius Fahrenheit Temperature (°C) Analog Input Data Temperature (°F) Analog Input Data Type K thermocouple 0 to 1300 0 to 13000 32 to 2372 320 to 23720 Type J thermocouple 0 to 1200 0 to 12000 32 to 2192 320 to 21920 Type T thermocouple 0 to 400 0 to 4000 32 to 752 320 to 7520 –100.0 to 500.0 –1000 to 5000 –148.0 to 932.0 –1480 to 9320 Pt100 resistance thermometer • FC4A-J4CN1 Analog Input Signal Type Type K thermocouple Type J thermocouple Type T thermocouple Pt100, Pt1000 resistance thermometer Ni100, Ni1000 resistance thermometer Scale Celsius Temperature (°C) Fahrenheit Analog Input Data Temperature (°F) Analog Input Data ×1 0 to 1300 0 to 1300 32 to 2372 32 to 2372 ×10 0.0 to 1300.0 0 to 13000 32.0 to 2372.0 320 to 23720 ×1 0 to 1200 0 to 1200 32 to 2192 32 to 2192 ×10 0.0 to 1200.0 0 to 12000 32.0 to 2192.0 320 to 21920 ×1 0 to 400 0 to 400 32 to 752 32 to 752 ×10 0.0 to 400.0 0 to 4000 32.0 to 752.0 320 to 7520 ×1 –100 to 500 –100 to 500 –148 to 932 –148 to 932 ×10 –100.0 to 500.0 –1000 to 5000 –148.0 to 932.0 –1480 to 9320 ×100 0.00 to 500.00 –100.00 to 327.67 0 to 50000 –10000 to 32767 0.00 to 655.35 –148.00 to 327.67 0 to 65535 –14800 to 32767 ×1 –60 to 180 –60 to 180 –76 to 356 –76 to 356 ×10 –60.0 to 180.0 –600 to 1800 –76.0 to 356.0 –760 to 3560 –6000 to 18000 0.00 to 356.00 –76.00 to 327.67 0 to 35600 –7600 to 32767 ×100 –60.00 to 180.00 • FC4A-J8AT1 Analog Input Signal Type NTC thermistor Scale Celsius Fahrenheit Temperature (°C) Analog Input Data Temperature (°F) Analog Input Data ×1 –50 to 150 –50 to 150 –58 to 302 –58 to 302 ×10 –50.0 to 150.0 –500 to 1500 –58.0 to 302.0 –580 to 3020 Resistance When Resistance is selected as an analog input data type, the analog input is linearly converted into digital data in the range described in the table below. This option is available only when NTC or PTC type thermistor is selected for the FC4A-J8AT1. • FC4A-J8AT1 Analog Input Signal Type NTC/PTC thermistor 4-12 Resistance Resistance (Ω) Analog Input Data 0 to 100000 0 to 10000 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4: ANALOG I/O CONTROL Analog Input Minimum/Maximum Values For analog input values, when Optional range is selected for the Data Type, designate the analog input data minimum and maximum values which can be –32,768 through 32,767. In addition, when using resistance thermometers (Pt100, Pt1000, Ni100, or Ni1000) with the Celsius or Fahrenheit Data Type and the ×100 scale, select the analog input data minimum value from 0 or another value in the pull-down list. The maximum value is changed automatically according to the selected minimum value. Filter Value The filter function is available for the ladder input type FC4A-J4CN1, FC4A-J8C1, and FC4A-J8AT1 only. Filtering ensures smooth input of analog data into the CPU module. For the filtering function of analog input signals, see page 4-4. Valid values are 0 through 255. Thermistor Parameter Thermistor parameters are enabled when selecting NTC thermistor for the analog input type of the FC4A-J8AT1. The same parameters are specified for four channels: CH0 to CH3 and CH4 to CH7. NTC Thermistor Parameters (Values indicated on the thermistor) Channel R0: CH0 to CH3 CH4 to CH7 Thermistor resistance value at the temperature (°C) T0: Temperature (°C) B: Thermistor B parameter (Kelvin) Valid Range 0 to 65535 –32768 to 32767 0 to 65535 For NTC type thermistors, analog input data can be calculated from the following formula: B × T0 Analog Input Data = ------------------------------------------------B + T0 × log ( r ⁄ R0 ) where, r = thermistor resistance (Ω) For PTC type thermistors, linearize the analog input data using the XYFS instruction. Analog Input Data The analog input signal is converted into a digital value within the range specified by the analog input data type and applicable parameters, and is stored to a data register allocated to analog input data. The analog input data register number is shown under Data in the Configure Parameters dialog box. END Refresh Type The analog input signal is converted into a digital value and stored to a data register, such as D760 or D766, allocated to analog input channel 1 or 2 on analog module number 1 through 7 depending on the mounting position. The analog input data stored in the allocated data register is updated whether the CPU module is running or stopped. When the CPU module is running, the update occurs at the END processing of every scan or 10 ms, whichever is longer. When the CPU module is stopped, the update occurs every 10 ms. Ladder Refresh Type The analog input signal is converted into a digital value and stored to a data register determined by the data register number selected in the Configure Parameters dialog box of the ANST macro. The analog input data stored in the allocated data register is updated when the RUNA instruction contained in the ANST macro is executed. When a certain channel of a ladder refresh type analog input module is not used, data registers allocated to the unused channel will store indefinite values if the values are read out of the analog input module. Do not use the allocated data registers for other purposes. Only when the analog input status code is 0, the analog input data is assured. Make sure that a user program reads analog input data only when the analog input status code is 0. Analog Input Operating Status The operating status of each analog input channel is stored to a data register allocated to analog input operating status. While the analog input is operating normally, the data register stores 0. The analog input operating status data register number is shown under Status in the Configure Parameters dialog box. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4-13 4: ANALOG I/O CONTROL END Refresh Type The operating status of each analog input channel is stored to a data register, such as D761 or D767, allocated to analog input channel 1 or 2 on analog module number 1 through 7 depending on the mounting position. The analog input operating status data is updated whether the CPU module is running or stopped. When the CPU module is running, the update occurs at the END processing of every scan or 10 ms, whichever is longer. When the CPU module is stopped, the update occurs every 10 ms. Status Code Analog Input Operating Status (END refresh type) 0 Normal operation 1 Converting data (during the first data conversion after power-up) 2 Initializing 3 Invalid parameter or analog input channel not available on the installed analog module 4 Hardware failure (external power supply failure) 5 Incorrect wiring (input data over valid range) 6 Incorrect wiring (input data below valid range or current loop open) Ladder Refresh Type The operating status of each analog input channel is stored to a data register determined by the data register number selected in the Configure Parameters dialog box of the ANST macro. Operating Status Bit Bit 0 Bit 1 Bit 2 Bit 3 Bit 4 Bit 5 to Bit 15 4-14 0 1 0 1 0 1 0 1 0 1 0 Analog Input Operating Status (Ladder refresh type) Operating status bit Parameter bit External power supply bit Maximum value over bit Minimum value over bit Reserved Normal operation Initializing, changing configuration, hardware initialization error Parameter configuration normal Parameter configuration error External power supply normal External power supply error Within the maximum value Maximum value over error Within the minimum value Minimum value under error Normal operation FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4: ANALOG I/O CONTROL Analog Output Parameters Analog output parameters include the analog output signal type, analog output data type, analog output minimum and maximum values, analog output data, and analog output operating status. This section describes these parameters in detail. Analog Output Signal Type A total of three analog output signal types are available, depending on the analog I/O or analog output module. Select an analog output signal type for each analog output channel. When a channel is not used, select the default value or Not used for the channel. Parameter 0 Voltage output 1 Current output 255 FC4A-L03A1 FC4A-L03AP1 FC4A-K1A1 0 to 10V DC FC4A-K2C1 –10 to +10V DC 4 to 20 mA DC Not used — — — X Analog Output Data Type A total of two analog output data types are available, depending on the analog I/O or analog output module. Select an analog output data type for each analog output channel. Parameter 0 Binary data 1 Optional range FC4A-L03A1 Voltage Current FC4A-K1A1 0 to 4095 Current Voltage FC4A-L03AP1 FC4A-K2C1 –25000 to 25000 0 to 50000 Analog output data minimum value to maximum value (–32768 to 32767) Analog Output Minimum/Maximum Values For analog output values, when Optional range is selected for the Data Type, designate the analog output data minimum and maximum values which can be –32,768 through 32,767. Analog Output Data The analog output data is converted into an analog output signal within the range specified by the analog output data type and applicable parameters. The analog output data register number is shown under Data in the Configure Parameters dialog box. END Refresh Type The analog output data stored in a data register, such as D772, is converted into an analog output signal of voltage output (0 to 10V DC) or current output (4 to 20 mA) as designated by the value stored in the data register allocated to analog output signal type, such as D774. While the CPU module is running, the analog output data stored in the allocated data register is updated at the END processing of every scan or 10 ms, whichever is longer. While the CPU module is stopped, the analog output data remains at 0 or the designated analog output data minimum value, so the generated analog output signal remains at the minimum value of 0V DC or 4 mA DC. Ladder Refresh Type While the CPU module is running, the analog output data stored in the allocated data register is updated when the RUNA instruction contained in the ANST macro is executed. While the CPU module is stopped, the analog output data is not updated. But the analog output signal can be changed by using the STPA instruction. For details, see page 4-21. Analog Output Operating Status The operating status of each analog output channel is stored to a data register allocated to analog output operating status. While the analog output is operating normally, the data register stores 0. The analog output operating status data register number is shown under Status in the Configure Parameters dialog box. END Refresh Type The operating status of each analog output is stored to a data register, such as D773. While the analog output is operating normally, the data register stores 0. The analog output operating status data is updated whether the CPU module is running or stopped. The update occurs at the END processing of every scan or 10 ms, whichever is longer. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4-15 4: ANALOG I/O CONTROL Status Code Analog Output Operating Status (END refresh type) 0 Normal operation 1 (reserved) 2 Initializing 3 Invalid parameter or analog output channel not available on the installed analog module 4 Hardware failure (external power supply failure) Ladder Refresh Type The operating status of each analog output channel is stored to a data register determined by the data register number selected in the Configure Parameters dialog box of the ANST macro. Operating Status Bit Bit 0 Bit 1 Bit 2 Bit 3 Bit 4 to Bit 15 4-16 0 1 0 1 0 1 0 1 0 Analog Output Operating Status (Ladder refresh type) Operating status bit Parameter bit External power supply bit Output data error bit Reserved Normal operation Initializing, changing configuration, hardware initialization error Parameter configuration normal Parameter configuration error External power supply normal External power supply error Output data normal Output data range error Normal operation FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4: ANALOG I/O CONTROL Example: Analog I/O The following example demonstrates a program of analog I/O control using an NTC thermistor. Two analog I/O modules are mounted in the slots shown below. System Setup Slim Type CPU Module FC4A-D40S3 Analog Input Module (Thermistor) FC4A-J8AT1 Slot No.: 1 Output Module (Tr. Source) FC4A-T08S1 2 3 Analog Output Module FC4A-K1A1 Analog Meter Calibrated voltage Thermistor External Device Operation In this example, the input value from the NTC thermistor is calibrated. When the temperature reaches the preset value, the output is turned off. The thermistor temperature is monitored on an analog meter. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4-17 4: ANALOG I/O CONTROL Wiring Diagram FC4A-J8AT1 (Analog Input Module) Fuse 24V DC – + Terminal No. 24V 0V Channel NC A B A B A B — A B NTC Thermistor • Thermistor Specifications Type No. NTC RO 10,000Ω T0 298K (25°C) B Parameter IN0 IN1 IN2 A B A B A B A B A B NT731ATTD103K38J (KOA) Type 24V DC 3,800K IN3 IN4 IN5 IN6 IN7 FC4A-T08S1 (8-point Transistor Source Output Module) +IN External Device – + Fuse –IN Terminal No. 0 1 2 3 4 5 6 7 COM(+) –V Output Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 COM(+) –V FC4A-K1A1 (Analog Output Module) 24V DC – + Fuse Terminal No. + Channel – 24V DC + + V – Analog Meter 4-18 – NC NC NC NC NC NC OUT FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL — — 4: ANALOG I/O CONTROL WindLDR Programming Analog I/O modules are programmed using the ANST macro in WindLDR. Program the ANST macro as shown below. • Analog Input Module FC4A-J8AT1 on Slot 1 I/O DR Allocation Range Designation D630 - D694 D630 Channel Item Designation Filter 10 Data Type Celsius Analog input range –50 to 150°C Scale ×10 Analog input data –500 to 1500 CH1 Data Type Not used Unused channel CH2 Data Type Not used Unused channel CH3 Data Type Not used Unused channel CH4 Data Type Not used Unused channel CH5 Data Type Not used Unused channel CH6 Data Type Not used Unused channel CH0 IN Description Optional range allocation, 65 words CH7 CH0 - CH3 Description Averages input values Data Type Not used Unused channel Thermistor Type NTC NTC thermistor R0 10,000 T0 298 B 3,800 Resistance value at the absolute temperature = 10 kΩ Absolute temperature = 298K (25°C) B parameter = 3,800K Note: When CH4 through CH7 are not used, thermistor settings are not required. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4-19 4: ANALOG I/O CONTROL • Analog Output Module FC4A-K1A1 on Slot 3 DR Allocation Range Designation D760 - D779 — I/O Channel OUT CH0 Description Automatic range allocation, 20 words Item Designation Description Signal Type 0 to 10V DC Voltage output Data Type Binary data 0 to 4095 Ladder Diagram As shown in the ladder diagram below, when initialize pulse special internal relay M8120 is used for the ANST macro in parallel with another instruction, load M8120 again for the other instruction. M8120 ANST NO.1 NO.3 J8AT1 K1A1 M8120 S Q30 MOV(I) I0 CMP>(I) S1 – D676 S1 – D676 S2 – 1000 M8120 is the initialize pulse special internal relay. When the CPU starts to run, ANST stores parameters to data registers to configure analog I/O modules and Q30 is turned on. D1 – D1000 REP When I0 is turned on, analog input data is moved from D676 to D1000. D1 – M30 REP The temperature is compared with the alarm temperature of 100°C. M30 R Q30 M30 S Q30 When the temperature is higher than 100°C, Q30 is turned off. When the temperature is not higher than 100°C, Q30 is turned on. S1 – S2 – D1 – D1000 500 D1000 REP Analog input data of –500 to +1500 is converted to 0 to 2000. MUL(W) S1 – S2 – D1 – D1000 2 D1000 REP Analog input data of 0 to 2000 is converted to 0 to 4000. REP Analog input data of 0 to 4000 is moved to D772 (analog output data) of the analog output module. ADD(I) MOV(W) S1 – D1000 D1 – D772 Note: The above ladder diagram is only an example and should be modified as required. 4-20 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4: ANALOG I/O CONTROL Changing Analog Output While CPU is Stopped When using the FC4A-K2C1 analog output module, the analog output value can be changed while the CPU module is stopped. To change the analog output value, store a required output value to the memory addresses allocated to the analog output data. Example: Memory Allocation of Ladder Refresh Type Analog Output Module FC4A-K2C1 Memory Address (data address used for STPA) Data Size (bytes) R/W +20 2 R/W +22 2 R/W Parameter Analog Output Data CH0 CH1 STPA instruction when FC4A-K2C1 is mounted on slot 4 Ladder Diagram MOV(I) M8120 STPA(I) WRITE DATA STATUS D1400 D1500 S1 – 0 SLOT 4 D1 R D1400 REP 2 ADDRESS BYTE 20 4 M8120 is the initialize pulse special internal relay. MOV stores output values at the OFF state. When the CPU stops, STPA updates the analog output value of the analog output module. Note: The above ladder diagram is only an example and should be modified as required. Precautions for Programming ANST Macro When using the ANST macro, do not make a branch from the ladder line of the ANST macro. ANST Incorrect M8120 NO.1 J8AT1 Q1 Delete the branch from the ANST macro, and start another line by inserting a LOD instruction. ANST Correct M8120 M8120 NO.1 J8AT1 Q1 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 4-21 4: ANALOG I/O CONTROL 4-22 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 5: TROUBLESHOOTING Introduction This chapter describes the procedures to determine the cause of trouble and actions to be taken when any trouble occurs while operating the analog I/O modules. When a trouble occurred, check the points and take the actions described below. If the trouble cannot be solved, call IDEC for assistance. Troubleshooting Diagrams Analog I/O module does not work correctly (END Refresh Type) Analog I/O module does not work correctly (END Refresh Type). Does the Status DR store status code 4 (hardware failure)? YES Supply the rated power voltage to the analog I/O module. See pages 4-14 and 4-16. NO Does the Status DR store status code 3 (invalid parameter)? YES Make sure of correct parameters. NO After changing settings, was the CPU stopped and restarted? NO Stop and restart the CPU to configure the analog I/O settings. YES Change data register numbers to eliminate duplicated data registers. YES Are data registers duplicated? NO Call IDEC for assistance. FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL 5-1 5: TROUBLESHOOTING Analog I/O module does not work correctly (Ladder Refresh Type) Analog I/O module does not work correctly (Ladder Refresh Type). Is the status LED turned on? NO YES Does the Status DR store status code 4 (external power supply error)? YES Supply the rated power voltage to the analog I/O module. See pages 4-14 and 4-16. NO Does the Status DR store status code 1 (initializing)? YES Program M8120 (initialize pulse) as an input for the ANST macro, and stop and restart the CPU. NO Does the Status DR store status code 2 (parameter configuration error)? YES Make sure of correct parameters. NO Is “Not used” selected for the Signal Type? YES Select a required Signal Type for the channel to be used. NO Stop and restart the CPU to configure the analog I/O settings. NO After changing settings, was the CPU stopped and restarted? YES Are data registers duplicated? YES Change data register numbers to eliminate duplicated data registers. NO Call IDEC for assistance. 5-2 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL INDEX A analog I/O control 4-1 data 4-3, 4-6 module specifications 2-2 module type numbers 1-1 modules 1-1 operating status 4-3, 4-6 input data 4-13 data type 4-11 minimum/maximum values 4-13 operating status 4-13 parameters 4-11 signal type 4-11 output changing 4-21 data 4-15 data type 4-15 minimum/maximum values 4-15 operating status 4-15 parameters 4-15 signal type 4-15 ANST 4-2 applicable CPU modules 1-2 WindLDR version 1-2 C Celsius 4-12 changing analog output 4-21 confirming system program version 1-2 crimping tool 3-2 D data register for analog I/O modules 4-8 dimensions 2-14 direct mounting strip 3-1 E END refresh type 1-1 example 4-17 F Fahrenheit 4-12 ferrule 3-2 filter value 4-13 G general information 1-1 specifications 2-2 I installation and wiring 3-1 L ladder refresh type 1-1 M module specifications 2-1 mounting hole layout for direct mounting 3-1 O operating status 4-3 P parts description 2-1 Phoenix 3-2 PID instruction source operand S4 4-3 PLC status 1-2 power supply 2-13 precautions for programming ANST macro 4-21 programming WindLDR 4-2 protection type 2-12 R resistance 4-12 S screwdriver 3-2 specifications analog I/O module 2-2 input 2-3, 2-4, 2-6 output 2-7 general 2-2 system program version D8029 1-2 T terminal arrangement 2-8 connection 3-2 thermistor parameter 4-13 tightening torque 3-2 troubleshooting 5-1 diagrams 5-1 type numbers analog I/O module 1-1 of protection 2-12 W WindLDR programming 4-2 version 1-2 wiring 3-1 diagrams 2-8 FC4A MICROSMART ANALOG I/O MODULE USER’S MANUAL i UNITED STATES JAPAN IDEC CORPORATION 1175 Elko Drive, Sunnyvale, CA 94089-2209, USA Tel: +1-408-747-0550 Toll Free: (800) 262-IDEC Fax: +1-408-744-9055 Toll Free Fax: (800) 635-6246 E-mail: opencontact@idec.com IDEC CORPORATION 7-31, Nishi-Miyahara 1-Chome, Yodogawa-ku, Osaka 532-8550, Japan Tel: +81-6-6398-2571 Fax: +81-6-6392-9731 E-mail: products@idec.co.jp CANADA IDEC (SHANGHAI) CORPORATION Room 608-609, 6F, Gangtai Plaza, No. 700, Yan’an East Road, Shanghai 200001, PRC Tel: +86-21-5353-1000 Fax: +86-21-5353-1263 E-mail: idec@cn.idec.com IDEC CANADA LIMITED Unit 22-151, Brunel Road, Mississauga, Ontario, L4Z 1X3, Canada Tel: +1-905-890-8561 Toll Free: (888) 317-4332 Fax: +1-905-890-8562 E-mail: sales@ca.idec.com AUSTRALIA IDEC AUSTRALIA PTY. LTD. 2/3 Macro Court, Rowville, Victoria 3178, Australia Tel: +61-3-9763-3244 Toll Free: 1800-68-4332 Fax: +61-3-9763-3255 E-mail: sales@au.idec.com UNITED KINGDOM IDEC ELECTRONICS LIMITED Unit 2, Beechwood, Chineham Business Park, Basingstoke, Hampshire RG24 8WA, UK Tel: +44-1256-321000 Fax: +44-1256-327755 E-mail: sales@uk.idec.com GERMANY IDEC ELEKTROTECHNIK GmbH Wendenstrasse 331, 20537 Hamburg, Germany Tel: +49-40-25 30 54 - 0 Fax: +49-40-25 30 54 - 24 E-mail: service@idec.de CHINA IDEC (BEIJING) CORPORATION Room 211B, Tower B, The Grand Pacific Building, 8A Guanghua Road, Chaoyang District, Beijing 100026, PRC TEL: +86-10-6581-6131 FAX: +86-10-6581-5119 IDEC (SHENZHEN) CORPORATION Unit AB-3B2, Tian Xiang Building, Tian’an Cyber Park, Fu Tian District, Shenzhen, Guang Dong 518040, PRC Tel: +86-755-8356-2977 Fax: +86-755-8356-2944 HONG KONG IDEC IZUMI (H.K.) CO., LTD. Unit 1505-07, DCH Commercial Centre No. 25, Westlands Road, Quarry Bay, Hong Kong Tel: +852-2803-8989 Fax: +852-2565-0171 E-mail: info@hk.idec.com TAIWAN IDEC TAIWAN CORPORATION 8F-1, No. 79, Hsin Tai Wu Road, Sec. 1, Hsi-Chih, Taipei County, Taiwan Tel: +886-2-2698-3929 Fax: +886-2-2698-3931 E-mail: service@tw.idec.com SINGAPORE IDEC IZUMI ASIA PTE. LTD. No. 31, Tannery Lane #05-01 Dragon Land Building, Singapore 347788 Tel: +65-6746-1155 Fax: +65-6844-5995 E-mail: info@sg.idec.com www.idec.com B-902(1) ©2006 IDEC CORPORATION. All Rights Reserved. Manual No. FC9Y-B902-0 01/07
FC4A-J8C1 价格&库存
很抱歉,暂时无法提供与“FC4A-J8C1”相匹配的价格&库存,您可以联系我们找货
