HE1B-M1N
HE1B-M1N
    IDEC(日本和泉)
    按动开关
HE1B-M1N 数据手册
Enabling Switches HE1B XW Series E-Stops Overview HE1B Basic Enabling Switch Key features: • 3-position functionality (OFF – ON –OFF) as required for manual robotic control • Ideally suited for use as enabling (aka “deadman”) switch on teach pendants • Provides a high level of safety based on human behavioral studies that determine personnel may squeeze OR let go when presented with a panic situation • Positive action contacts “On” (pos. 2) to “Off” (pos. 3) ensure no contact welding (per EN60947-5-1 / IEC60947-5-1) • Contacts will not close when released from “Off” (pos. 3) to “Off” (pos. 1) (per IEC60204-1; 9.2.5.8) • Small and lightweight Part Numbers Installation Part Number Side HE1B-M1 Front HE1B-M1N Safety Control Relays Enabling Switches Interlock Switches Item Specifications Conforming to Standards UL508 (UL recognized), CSA C22.2, No. 14 (c-UL recognized), IEC/EN 60947-5-1, IEC/EN 60947-5-8 (TÜV approval) Operating Temperature –25 to +60˚C (no freezing) Operating Humidity 45 to 85% RH (no condensation) Storage Temperature –40 to +80˚C (no freezing) Pollution Degree 2 Initial Contact Resistance 50mΩ maximum Insulation Resistance 100MΩ minimum Impulse Withstand Voltage 2.5kV Operating Frequency 1200 operations/hour Light Curtains Position 1 2 3 1: 100,000 operations minimum Electrical Life Shock Resistance AS-Interface Safety at Work Position 1 2 1: 1,000,000 operations minimum Mechanical Life Vibration Resistance 100,000 operations minimum at rated load Operating Extremes 150m/s2 (15G) Damage Limits 1000m/s2 (100G) Operating Extremes 5 to 55Hz, amplitude 0.5mm minimum Damage Limits 16.7Hz, amplitude 1.5mm minimum Terminal Solder Terminal Recommended Wire Size 0.5mm2 maximum / 1 line (20AWG) Solder Heat Resistance 260°C / 3 seconds maximum Terminal Pulling Strength 20N minimum Recommended Screw Torque HE1B-M1: M3 screw / 0.5 to 0.8Nm Degree of Protection IP40 (IEC 60529) excluding terminal part Conditional Short-Circuit Current 50A (250V) Recommended Short Circuit Protection 250V, 10A fast blow fuse (IEC 60127-1) Circuit Opening Force 30N minimum (position 2 3) Control Resistance (Operating) 250N minimum Weight Approx. 6g 392 www.IDEC.com 1705151129 Enabling Switches HE1B Current Ratings Rated Insulation Voltage (Ui) 5A Rated Operating Voltage (Ue) Rated Operating Current (le) Overview AC / DC250V Thermal Current (lth) 30V 125V 250V – 3A 1.5A Inductive Load (AC-15) – 1.5A 0.75A Resistive Load (DC-12) 2A 0.4A 0.2A 1A 0.22A 0.1A Resistive Load (AC-12) AC 50/60Hz DC Inductive Load (DC-13) XW Series E-Stops Contact Configuration SPST-NO three position (OFF-ON-OFF) Minimum applicable load: AC/DC3V • 5mA (For reference only). Operating Characteristics Position 1 Position 2 Position 3 Interlock Switches Approx. 15N Operating Force (reference value) (when pressing the center) Approx. 3N : ON (closed) Travel (mm) : OFF (open) 0 1.4±0.3 2.2±0.3 2.7±0.5 5.0 Pressing (position 1 to 2 to 3) Enabling Switches Releasing (position 2 to 1) Releasing (position 3 to 1) Dimensions (mm) HE1B-M1N (Front Mounting) When pressed to position 3: 2 12 7.6 1. M3 Screw (not provided) 2. Locking nut (2 pcs) included 4 13 5 7 4 Safety Control Relays 30 13.6 2.8 24 4 8 Solder Terminal 3 M Light Curtains HE1B-M1 (Side Mounting) 24±0.5 AS-Interface Safety at Work 15 min. 9 min. Screw Length = (panel thickness + 5 to 6mm) 1. M3 Screw (not provided) 2. Thread built in 24±0.2 When using a panel thicker than 2mm, the button will be lower than the surface of the panel Panel Thickness 1mm - 2mm 1705151129 Insert the nuts supplied with the switch. 800-262-IDEC (4332) • USA & Canada 393
HE1B-M1N 价格&库存
很抱歉,暂时无法提供与“HE1B-M1N”相匹配的价格&库存,您可以联系我们找货
HE1B-M1N
    • 1+197.04021
    • 5+191.12516
    • 10+185.37672
    • 25+179.82614
    • 50+174.43177
    库存:9
    HE1B-M1N
    • 1+212.573231+27.50202
