HW1Z-2PQ4B
HW1Z-2PQ4B
    IDEC(日本和泉)
    IDEC - HW1Z-2PQ4B - Transducer, Buzzer, 12 VDC to 24 VDC, 90 dB, 9 mA, Panel
HW1Z-2PQ4B 数据手册
ø22mm HW1Z Illuminated / Non-Illuminated Buzzer Solution example ➀ Waterproof equipment Application examples • Food and packaging • Weigh scales IDEC HW1Z series are A buzzer is installed to detect errors but a waterproof buzzer is required when touched with wet hands. IP65 waterproof from the front of the panel Ideal for equipment requiring washdown. Solution example ➁ Waterproof / Dustproof Application examples • Semi-outdoor (station platform, parking lot) • Elevators IDEC HW1Z series have The buzzer must be installed in a control box to be protected from water and dust. waterproof construction Installing an optional terminal rubber boot upgrades the terminal’s waterproof characteristics to IP54 without the need to use a rear enclosure. Solution example ➂ Downsizing of Equipment / Panels Application examples • Machine tools • Semiconductor • Food and packaging IDEC HW1Z enables The depth of conventional buzzers are too long to mount into slim panels. downsizing of panels / equipment Short, 19.7 mm depth behind panel. Can be installed in tight places. 19.7mm Solution example ➃ Safety measures in factories Application examples • Material handling (AGV, forklift) IDEC HW1Z have Safety measures are required on moving equipment such as AGVs and forklifts. push-in terminals Push-in terminals allow easy wiring. No tightening of screw is required. Solution example ➄ Locate equipment error Buzzer sounds to alert an error but the production line has too many equipment making it difficult to locate the place of error. 2 Application examples • Semiconductor • Production line IDEC HW1Z series can alert danger with sound and light Lamp and buzzer functions are integrated. Note) Illuminated buzzers only. Flashing light Buzzer sound 3 ø22mm HW1Z Illuminated / Non-Illuminated Buzzer Accessories Shape Terminal Rubber Boot Material Part No. (Ordering No.) Package Quantity Nitryl Rubber HW9Z-CZ1 1 Installing the terminal rubber boot Notes Applicable cable: ø4.5 to 8.5 mm Cut the end of rubber boot to fit the cable size (see dimensions). Weight: 10 g (approx.) 6. Make sure that the bellows is 17 to 22 mm long. 1. Cut the end of terminal rubber boot to fit the cable size. 2. Insert the cable into the terminal rubber boot in the direction of arrow shown below. Cut here when cable size is ø5.5 to 6.5 mm Cut here when cable size is ø6.5 to 7.5 mm Cut here when cable size is ø7.5 to 8.5 mm Bellows Note for terminal rubber boot Cable insertion • Be sure to use bellows with an appropriate length. Otherwise, waterproof characteristics cannot be achieved. • Maintain a cable angle of 45° maximum to the axis of the HW1Z, otherwise the terminal rubber boot may come off. 3. Strip the insulation of the cable 30 mm from the end and wire as instructed in “Wiring”. 4. Install the terminal rubber boot as shown below. 5. Cover part B with part A. Part B Bent excessively 45° Installed (terminal rubber boot: cross section view) Part A Transformer Transformer For 24V Operating Voltage Range Primary Voltage 100/110V AC Part No. (Ordering No.) Package Quantity TWR512 1 100/110V AC ±10% Buzzer HW1Z-2PQ4B HW1Z-F2PQ4B 200/220V AC TWR522 200/220V AC ±10% 1 • Terminal cover (TWR-VL3) is supplied as standard. • Sound and sound volume differs when used at DC voltage. Dimensions 22 30 40 48 52 Terminal Cover 40 41 45.5 2,500V AC, 1 minute M3.5 2 mm2 maximum, 2 wires maximum 87g 2 Dielectric Strength Terminal Screw Applicable Wire Weight (approx.) PRI. Damage limits: 1,000 m/s2 Operating Extremes: 100 m/s2 2-ø3.3 Mounting Hole Primary Side 1 Shock Resistance 4 Damage Limits: 30 Hz, amplitude 1.5 mm Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Secondary Side JAPAN Vibration Resistance All dimensions in mm. M3.5 Terminal Screw SEC. TWR52 100/110V AC, 200/220V AC (50/60Hz) 2.4VA 600V 100 MΩ minimum (500V DC megger) –30 to +60°C (no freezing) –40 to +80°C (no freezing) 35 to 85% RH (no condensation) 3 Part No. Operating Voltage Current Draw Rated Insulation Voltage Insulation Resistance Operating Temperature Storage Temperature Operating Humidity 5 Specifications BAA1000 4 ø22mm HW1Z Illuminated / Non-Illuminated Buzzer Part No. (Ordering No.) Shape Illumination Color Sound Package Quantity Intermittent 1 Illuminated Buzzer Red HW1Z-P1F2PQ4R Yellow HW1Z-P1F2PQ4Y Non-Illuminated Buzzer — HW1Z-2PQ4B Steady 1 — HW1Z-F2PQ4B Intermittent • See website for details on approvals and standards. Specifications Rated Current (effective value) Illuminated: 18mA (24V DC), 8mA (12V DC) Non-Illuminated (Steady sound): 9mA (24V DC), 4mA (12V DC) (Intermittent sound): 7mA (24V DC), 3mA (12V DC) Inrush Current 100mA maximum 2,200 to 2,450Hz Sound Type Intermittent Illuminated: Non-Illuminated: Steady/Intermittent ø3 Applicable Wire Solid wire/ferrule (without sleeve): 0.2 to 1.5 mm2 Ferrule (with sleeve): 0.2 to 0.75 mm2 Weight (approx.) 17g 5 3) Bellows (*2) 17 to 22 54 to 59 58 to 63 62 to 67 66 to 71 *1: ø4.5-5.5 cable needs no cutting. *2: The bellows must be 17 to 22mm long after installing the terminal rubber boot. *3: Maintain a cable angle of 45° max. to the HW1Z axis. X2 X1 X1 and X2 have no polarity. Mounting Hole Layout ∗ 3.2 +0.2 0 ax. 8m R0. 24.1 +0.4 0 Terminal Arrangement (botom view) +0 0 .4 Panel front: IP65 (IEC 60529) Terminal: IP40 (IEC 60529) IP54 (with terminal rubber boot) (IEC 60529) Push-in Terminals x. (* Shock Resistance Operation extremes: 100 m/s2 Damage limits: 1,000 m/s2 ma Flashing 105 cycles/minute approx. (1.75Hz approx.) –20 to +50ºC (no freezing) 20% to 85% RH (no condensation) –30 to +80ºC (no freezing) 100MΩ minimum (at 500V DC megger) Between live and earthed metal parts: 1000V AC, 1 minute Operation extremes: 5 to 55Hz, amplitude 0.5mm Damage limits: 5 to 55Hz, amplitude 0.5mm Terminal Style Cut here when cable size is ø5.5 to 6.5 (*1) Cut here when cable size is ø6.5 to 7.5 (*1) Cut here when cable size is ø7.5 to 8.5 (*1) 3 105 cycles/minute approx. (1.75Hz approx.) Vibration Resistance Degree of Protection With terminal rubber boot 45° Dielectric Strength 0.5 17.6 0 Sound Frequency (at 25ºC) Intermittent Cycle (at 25ºC) Illumination Type Illumination Flash Cycle (at 25ºC) Operating Temperature Operating Humidity Storage Temperature Insulation Resistance 19.7 90dB min. at 0.1m (24VDC) 70dB min. at 1m (24V DC, equivalent value) 84dB min. at 0.1m (12V DC) 64dB min. at 1m (12VDC, equivalent value) Panel Thickness 0.8 to 6 mm 2. Buzzer Rubber Gasket Locking Ring ø2 Sound Volume (of HW1Z itself) (at 25ºC) Buzzer only 3 30V 12 to 24V DC 10.8 to 26.4V DC All dimensinos in mm. 3. Rated Insulation Voltage Rated Voltage Voltage Range Dimensions ø3 Specifications and Ratings ∗ Panel cut-out +0.2 3.2 0 hole is for anti-rotation. Not required when nameplate/anti-rotation is not used. ø22mm HW1Z Illuminated / Non-Illuminated Buzzer ø22mm HW1Z Illuminated / Non-Illuminated Buzzer Part No. (Ordering No.) Shape Illuminated Buzzer   Illumination Color Sound Package Quantity Intermittent 1 Red HW1Z-P1F2PQ4R • Turn off the power to the HW1Z before installation, removal, wiring, maintenance, and inspection. Failure to turn power off may cause electrical shocks or fire hazard. • For wiring, use wires of a proper gauge to meet the voltage and current requirements. Panel Mounting Non-Illuminated Buzzer — HW1Z-2PQ4B — Wire removal • Insert the HW1Z into the panel cut-out from the front, and tighten the locking ring from the back. Steady 1 HW1Z-F2PQ4B Note for panel mounting Panel • Use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring to a recommended tightening torque of 1.5 to 2.0 N·m. • Do not use pliers and do not tighten excessively, otherwise the HW1Z may be damaged. Intermittent Locking Ring Illuminated: 18mA (24V DC), 8mA (12V DC) Non-Illuminated   (Steady sound): 9mA (24V DC), 4mA (12V DC)   (Intermittent sound): 7mA (24V DC), 3mA (12V DC) Inrush Current 100mA maximum Operating Conditions 2,200 to 2,450Hz Sound Type Intermittent Illuminated: Non-Illuminated: Steady/Intermittent Terminal Style ø3 Applicable Wire Solid wire/ferrule (without sleeve): 0.2 to 1.5 mm2 Ferrule (with sleeve): 0.2 to 0.75 mm2 Weight (approx.) 17g 5 Stranded wire Strip the wire insulation 8mm from the end and push in the wire removal part above the wire port using a small flat screwdriver. Release the wire removal part. Make sure that the wire does not loosen. Do not use the HW1Z in the following locations. • Exposure to direct sunlight • Subject to corrosive or flammable gases Wire Removal Part (white) 54 to 59 58 to 63 62 to 67 66 to 71 *1: ø4.5-5.5 cable needs no cutting. *2: The bellows must be 17 to 22mm long after installing the terminal rubber boot. *3: Maintain a cable angle of 45° max. to the HW1Z axis. Terminal Arrangement (botom view) X2 X1 X1 and X2 have no polarity. Mounting Hole Layout ∗ 3.2 +0.2 0 ax. 8m R0. 24.1 +0.4 0 Panel front: IP65 (IEC 60529) Terminal: IP40 (IEC 60529) IP54 (with terminal rubber boot) (IEC 60529) Push-in Terminals With sleeve For 0.25mm2: AI0,25-8YE For 0.5mm2: AI0,5-8WH For 0.75mm2: AI0,75-8GY Bellows (*2) 17 to 22 +0 0 .4 Shock Resistance Operation extremes: 100 m/s2 Damage limits: 1,000 m/s2 3) Operation extremes: 5 to 55Hz, amplitude 0.5mm Damage limits: 5 to 55Hz, amplitude 0.5mm x. (* Flashing 105 cycles/minute approx. (1.75Hz approx.) –20 to +50ºC (no freezing) 20% to 85% RH (no condensation) –30 to +80ºC (no freezing) 100MΩ minimum (at 500V DC megger) Between live and earthed metal parts: 1000V AC, 1 minute 3 105 cycles/minute approx. (1.75Hz approx.) Vibration Resistance Degree of Protection Cut here when cable size is ø5.5 to 6.5 (*1) Cut here when cable size is ø6.5 to 7.5 (*1) Cut here when cable size is ø7.5 to 8.5 (*1) ma Dielectric Strength With terminal rubber boot 45° Intermittent Cycle (at 25ºC) Illumination Type Illumination Flash Cycle (at 25ºC) Operating Temperature Operating Humidity Storage Temperature Insulation Resistance 0.5 17.6 0 Sound Frequency (at 25ºC) Without sleeve For 0.5mm2: A0,5-8 For 0.75mm2: A0,75-8 For 1.0mm2: A1-8 2. Buzzer 19.7 90dB min. at 0.1m (24VDC) 70dB min. at 1m (24V DC, equivalent value) 84dB min. at 0.1m (12V DC) 64dB min. at 1m (12VDC, equivalent value) Panel Thickness 0.8 to 6 mm ø2 Sound Volume (of HW1Z itself) (at 25ºC) Rubber Gasket Locking Ring Note for wiring 3 Rated Current (effective value) Buzzer only 3. 30V 12 to 24V DC 10.8 to 26.4V DC ø3 Rated Insulation Voltage Rated Voltage Voltage Range All dimensinos in mm. Use a screwdriver (flat, 2.5mm-wide blade). Recommended Ferrules Phoenix Contact Solid wire Strip the wire insulation 8 mm from the end and insert into the terminal. Make sure that the wire does not loosen. Dimensions Small flat screwdriver Stranded wire with ferrule Clamp a ferrule with a conductor wire length of 8mm and insert into the terminal. Make sure that the wire does not loosen. Wiring Specifications Push in the white wire removal part above the wire ports using a small flat screw driver, and pull out the wire. • Make sure that the terminal is not constantly pulled by the wire. • Wiring must be performed in environments of –5 to +50°C. • Do not damage the conductor wire when stripping the wire insulation. • Do not use wires with bent or deformed conductors wires. Deformed wiring may cause faliures such as strength degradation and overheating. • Connect one wire per terminal. Connecting two wires to a terminal may cause loose wiring and strength degradation. • Do not solder the conductor lines. Connecting soldered stranded wires may loose wiring and strength degradation. • If a stranded wire has loose wires, twist the conductor wires before connection. However be careful not to twist too much. • See website for details on approvals and standards. Specifications and Ratings • Prevent metal fragments and pieces of wire from dropping inside when installing or wiring the HW1Z. Otherwise fire, failure, or malfunction may be caused. Operating Instructions Yellow HW1Z-P1F2PQ4Y Safety Precautions ∗ Panel cut-out USA Germany Singapore Thailand Australia Taiwan IDEC Corporation APEM GmbH IDEC Izumi Asia Pte. Ltd. IDEC Asia (Thailand) Co., Ltd IDEC Australia Pty. Ltd. IDEC Taiwan Corporation Tel: +1-408-747-0550 Tel: +49-40-25 30 54 - 0 Tel: +65-6746-1155 Tel: +66-2-392-9765 Tel: +61-3-8523-5900 Tel: +886-2-2698-3929 opencontact@idec.com service@eu.idec.com info@sg.idec.com sales@th.idec.com sales@au.idec.com service@tw.idec.com +0.2 3.2 0 hole is for anti-rotation. Not required when nameplate/anti-rotation is not used. www.idec.com Head Office 6-64, Nishi-Miyahara-2-Chome, Yodogawa-ku, Osaka 532-0004, Japan Specifications and other descriptions in this brochure are subject to change without notice. Information in this brochure is current as of August 2019. 2019 IDEC Corporation, All Rights Reserved. EP1690-1 Hong Kong China/Shanghai China/Shenzhen China/Beijing Japan IDEC Izumi (H.K.) Co., Ltd. IDEC (Shanghai) Corporation IDEC (Shenzhen) Corporation IDEC (Beijing) Corporation IDEC Corporation Tel: +852-2803-8989 Tel: +86-21-6135-1515 Tel: +86-755-8356-2977 Tel: +86-10-6581-6131 Tel: +81-6-6398-2527 info@hk.idec.com idec@cn.idec.com idec@cn.idec.com idec@cn.idec.com marketing@idec.co.jp ø22mm HW1Z Illuminated / Non-Illuminated Buzzer
HW1Z-2PQ4B 价格&库存
很抱歉,暂时无法提供与“HW1Z-2PQ4B”相匹配的价格&库存,您可以联系我们找货
HW1Z-2PQ4B
    • 1+288.356521+37.47267
    • 3+254.041543+33.01335
    • 4+249.745974+32.45513
    • 5+247.176895+32.12127
    • 9+242.600469+31.52655
    • 10+242.0304710+31.45248
    • 20+239.4531320+31.11755
    库存:27
