CW1P-1EQM4PW
CW1P-1EQM4PW
    IDEC(日本和泉)
    IDEC - CW1P-1EQM4PW - LED Panel Mount Indicator, White, 240 VAC, 22 mm, 18 mA, IP65, IP66, NEMA 4X
CW1P-1EQM4PW 数据手册
lock ct b onta le c oub D Flush Silhouette Switches ø22mm CW Series Double contact block Double Contact Block Double contact block 4-contact configurations available Only 59.9mm behind the panel Single contact block Shortest in its class Safety Only 39.9mm behind the panel Two-action removal IDEC's third-generation safety construction reduces labor and enhances level of safety. 2.5mm-thick bezel (13/07/23) Sleek design Safety in style and ø22mm CW Series Flush Silhouette Switches Double Contact Block New double contact blocks with four-contact configurations. (Illuminated pushbuttons, pushbuttons, selector switches, key selector switches) Double contact blocks Shortest in its class (as of March 2013) Single contact blocks Short depth behind the panel for compact equipment. Double: 59.9mm (maintained: 64.6mm) Single: 39.9mm (maintained: 44.6mm) Switching capacity is 120V AC, 10A (resistive load). The compact style requires less depth behind the panel. Can be used with IDEC's FB and other 22mm control boxes. No transformer needed for any voltage. Double contact block Single contact block (Actual size) (Actual size) Conventional 2 Control Panel Conventional CW series single contact block Devices 50% less space 59% less weight Devices 40% less space 50% less weight CW series double contact block Two-contact illuminated pushbutton Control Panel Devices Four-contact illuminated pushbutton 39.9mm Devices 59.9mm Fits in small space 2.5mm-thick bezel (13/07/23) sophistication Sleek and stylish switches and pilot lights with a 2.5mm-thick bezel The CW series gives a sleek, stylish image to your machines or control panels. The surface is safer with less chance of unexpected operation or accidents by hitting the projections, and also is cleaner with less dust build-up. Safety Third-generation safety construction Two-action removal of contact blocks IP20 Finger-safe Terminal IDEC’s original two-action push-turn locking lever provides a higher level of safety by preventing unexpected release of the locking lever. Whether the contact block is installed securely can be checked easily from the back of the panel, with the position of the locking lever. Finger-safe, IP20 terminal prevents electrical shock. Locking lever integrated with guard ➁ Turn Locking Lever Guard Prevents locking lever from unexpected release or damage by trapped wires. ➀ Push Removing contact blocks Variety Illuminated Pushbuttons (round flush or extended) Black bezel available See page 8. Pilot lights Pushbuttons (round flush or extended) (round flush or extended) Black bezel available See page 10. Black bezel available Illuminated Pushbuttons/Pilot Lights Blue (S) (13/07/23) Green (G) Red (R) Pure White (PW) Yellow (Y) Key Selector Switches Wave key 7 different key numbers 2- and 3-position Knob Lever Black bezel available Black bezel available Black bezel available See page 14. Low extension with flush silhouette. Hard to duplicate, wave-key See page 12. ensures a high level of safety. See page 11. Colors Amber (A) Selector Switches (knob or lever) Pushbuttons Black Blue Green Red Bezels White Yellow Metallic Black (plastic) 3 ø22 Flush Silhouette Switches CW Series Flush bezel projects only 2.5mm from front of panel Only 39.9mm depth behind the panel (single contact block, momentary). • ø22.3mm mounting hole compliant with IEC 60947-5-1 • 3.5-mm operator travel for pushbuttons ensures comfortable and reliable operation. • Black plastic and metallic bezels available. • Four-contact configuration is available with double contact blocks. • Direct opening NC contact ensures shutdown without failure. • Seven different keys can be chosen for key selector switches. • 10A contact rating. Up to three contact blocks for nonilluminated and two contact blocks for illuminated units can be connected. • Contact blocks can be removed by the two-action locking lever integrated with a guard, ensuring safety. • IP20 finger-safe screw terminals • IP66/67, UL Type 4X degree of protection from panel front (see Table 1). Applicable Standards Mark UL508 CSA C22.2 No.14 UL/c-UL File No. E68961 EN60947-5-1 EU Low Voltage Directive GB14048.5 No. 2012010305589209 (Pilot lights: No. 2012010304567962) Specifications Contact Ratings Rated Insulation Voltage (Ui) 300V Rated Thermal Current (Ith) 10A Rated Operating Voltage (Ue) Resistive Load (AC-12) AC 50/60 Hz Inductive Load Electrical (AC-15) Life 50,000 Resistive Load operations (DC-12) DC Inductive Load Rated (DC-13) Operating Current Resistive Load (Ie) (AC-12) AC 50/60 Hz Inductive Load Electrical (AC-15) Life 100,000 Resistive Load operations (DC-12) DC Inductive Load (DC-13) Contact Material 4 45 to 85% RH (no condensation) Storage Temperature –40 to +80°C (no freezing) Contact Resistance 50 mΩ maximum (initial value) Insulation Resistance 100 MΩ minimum (500V DC megger) Overvoltage Category II (IEC 60664-1) Impulse Withstand Voltage 2.5 kV (IEC 60664-1/60947-5-1) 240V 10A 6A Pollution Degree 3 (IEC 60947-5-1) 10A 6A 3A Vibration Resistance Operating extremes: 5 to 55Hz, amplitude 0.5 mm Damage limits: 30 Hz, amplitude 1.5 mm 8A 2.2A 1.1A Shock Resistance Operating extremes: 100 m/s2 Damage limits: 1000 m/s2 4A 1.1A 0.55A 5A 5A 3A 5A 3A 1.5A Mechanical Life (minimum operations) 4A 1.1A 0.55A Illuminated pushbutton/pushbutton Momentary: 2,000,000 (single contact block) 1,000,000 (double contact block) Maintained: 250,000 (single contact block) 100,000 (double contact block) Selector switch: 250,000 (single contact block) 100,000 (double contact block) Key selector switch: 250,000 (single contact block) 100,000 (double contact block) 2A 0.55A 0.27A IP67 UL Type 4X Illuminated Pushbutton Yes Pilot Light Yes Yes (Note) Yes (Note) Yes (Note) Pushbutton Yes Selector Switch Yes Yes Yes Yes Key Selector Switch Yes Yes No Yes No Yes Yes (Note) Yes (Note) Yes (Note) Note: When used with rubber boot (CW9Z-D11, -D12) Operating Humidity 120V Table 1 (Degree of Protection) Yes Non-illuminated: –25 to +60°C (no freezing) LED illuminated: –25 to +55°C (no freezing) 24V Silver IP66 Operating Temperature 10A • Minimum applicable load (reference value): 3V AC/DC, 5 mA (Applicable range is subject to the operating conditions and load.) Note: The operational current represents the classification by making and breaking currents (IEC 60947-5-1). • UL, c-UL rating: A300, CCC rating: A300 IP65 Double Contact Block File No. or Organization Electrical Life (minimum operations) Single contact block 50,000 (see Contact Ratings) 100,000 (see Contact Ratings) Double contact block 25,000 (see Contact Ratings) 50,000 (see Contact Ratings) Switching frequency Momentary: 900 operations/h Maintained: 1800 operations/h Degree of Protection (IEC 60529) Panel front: See table to the left Terminal: IP20 (IEC 60529) Short-circuit Protection 250V/10A fuse (Type aM IEC 60269-1, IEC 602069-2) Electrical Shock Protection Class II (IEC 61140) Terminal Style Screw terminal (M3.5 slotted Phillips screw) (Ring terminal cannot be used.) Bezel Material Polyamide Applicable Wire Size Up to 2 wires of 2 mm2 (solid wire ø1.6) maximum (AWG14 to 16) Recommended Tightening Torque Terminal: 1.0 to 1.3 N·m Locking ring: 1.2 N·m (13/07/23) Flush Silhouette Switches CW Series ø22 Weight (Examples) Illuminated Pushbutton Pilot Light Pushbutton Selector Switch Key Selector Switch Direct Opening of Key Selector Switch Applicable Type Minimum Operator Angle for Direct Opening Action Minimum Operator Torque for Direct Opening Action Maximum Operator Angle 46g (CW1L-M1E02QH, 2 contacts) 62g (CW1L-M1E22QH, 4 contacts) 27g (CW1P-1EQH) 45g (CW1B-M1E03, 3 contacts) 52g (CW1B-M1E22, 4 contacts) 48g (CW1S-2E03, 3 contacts) 55g (CW1S-2E22, 4 contacts) 61g (CW1K-2AE03, 3 contacts) 68g (CW1K-2AE22, 4 contacts) 2-position (3NC) 3-position (2NC) 90° 45° 0.2 N·m 0.3 N·m 90° 45° LED Module Rated Insulation Voltage (Ui) Rated Operating Voltage (Ue) Operating Voltage Range Illumination Color Code ➁ LED Module Part No. Current Draw 250V 6V AC/DC 12V AC/DC 24V AC/DC 100/120V AC 200/220V AC 230/240V AC 6V AC/DC±10% 12V AC/DC ±10% 24V AC/DC ±10% 100/120V AC ±10% 200/220V AC ±10% 230/240V AC ±10% A (amber), G (green), PW (pure white), R (red), S (blue) CW-EAQ2➁ CW-EAQ3➁ CW-EAQ4➁ CW-EAQH➁ CW-EAQM➁ CW-EAQM4➁ 15 mA 15 mA 16.5 mA 18 mA 20 mA 18 mA Approx. 30,000 hours (the illuminance is reduced to 50% of the initial intensity when used on complete DC at 25°C.) Life (reference value) X1 X1 R R LED Chip Internal Circuit R Rectifying Diode Zener Diode X2 Resistor X2 R R C LED Chip Rectifying Diode Zener Diode Resistor Capacitor • Specify an illumination color code in place of ➁ in the Part No. • Use the pure white (PW) LED module for yellow illumination. Contact Blocks Single Contact Block Contact Part No. Double Contact Block 1NO YW-E10R 1NC YW-E01 2NO YW-EW2R0 2NC YW-EW02 1NO-1NC YW-EW1R1 Blue/Black Black Reddish Purple Red 3-4 1-2 Blue/Black Black 1st tier: 13-14 2nd tier: 23-24 Reddish Purple Red 1st tier: 11-12 2nd tier: 21-22 19g Reddish Purple/Blue Gray 1st tier: (NO) 13-14 2nd tier: (NC) 21-22 Shape Housing Color Push Rod Color Terminal No. 11g Weight (approx.) M3.5 Terminal Screw (1st tier) M3.5 Terminal Screw Push Rod Housing M3.5 Terminal Screw (2nd tier) Push Rod Housing Mounting Hole Layout IEC 60947-5-1 compliant 3.2 +0.2 0 R0.8 max. ø22 Double Contact Block YW-E10R YW-EW1R1 0 50 Single Contact Block 24.1+0.4 0 .3 +0.4 30 (13/07/23) Note: Determine mounting centers to ensure easy operation. 5 ø22 Flush Silhouette Switches CW3 Series Part No. Development Note: Please use these charts to interpret the part numbers as all combinations are not possible to be created. Illuminated Pushbuttons CW 1 L - M 1 E 10 Q4 ➁ Bezel Color Code 1 4 Illumination Color Bezel Color Code A G Black Metallic PW Operation Code M A Code Q2 Q3 Q4 Shape Code Shape 1 2 Round Flush Round Extended Code Option 10 01 11 Part No. Example White lens type (when light is off) CW1L-M1E10Q4W➁ • For white lens, clear lens is used instead of colored lens for amber, green, red, and blue illuminated pushbuttons. Amber, green, red, or blue LED units are used. Pilot Lights 1 4 1 2 Code Rated Voltage QH QM QM4 100/120V AC 200/220V AC 230/240V AC Contact Configuration Code 1NO 1NC 1NO-1NC 20 02 22 Contact Configuration 2NO 2NC 2NO-2NC Illumination Color Bezel Color Black Metallic Code A G PW Shape Code Rated Voltage 6V AC/DC 12V AC/DC 24V AC/DC CW 1 P - 1 E Q4 ➁ Bezel Color Code S Y Color Red Blue Yellow Contact Configuration Option W Code R Rated Voltage Operation Momentary Maintained Code Color Amber Green Pure White Color Amber Green Code R Pure White Color S Red Blue Y Yellow Rated Voltage Shape Round Flush Round Extended Code Option Code Option Part No. Example W White lens type (when light is off) CW1P-1EQ4W➁ Q2 Q3 Q4 Rated Voltage Code Rated Voltage 6V AC/DC 12V AC/DC 24V AC/DC QH QM QM4 100/120V AC 200/220V AC 230/240V AC • For white lens, clear lens is used instead of colored lens for amber, green, red, and blue illuminated pushbuttons. Amber, green, red, or blue LED units are used. Pushbuttons CW 1 B - M 1 E 10 ➀ Bezel Color Code 1 4 Bezel Color Black Metallic Operation Code M A Operation Momentary Maintained Operation Code 1 2 6 Shape Round Flush Round Extended Button Color Code A B G Color Code Amber Black Green R S Y Color Black Blue Yellow Contact Configuration Code 10 01 Contact Configuration 1NO 1NC Code 02 21 Contact Configuration 2NC 2NO-1NC 11 1NO-1NC 22 2NO-2NC 12 20 1NO-2NC 2NO 30 03 3NO 3NC (13/07/23) Flush Silhouette Switches CW Series ø22 Selector Switches CW 1 S - 2 L E 10 Bezel Color Code 1 4 Contact Configuration Bezel Color See page 12 and 13. Black Metallic Operator Code Blank L Positions 2-position Code Position Code Positions Spring return from right Maintained 2 1 21 2 Shape Knob Lever 1 2 3-position Code Position Code Positions Maintained 3 0 1 Code Spring return from right 31 2 0 1 Position Code Spring return from left 32 2 1 0 Positions Spring return two-way 33 2 0 1 2 Key Selector Switches CW 1 K - 2 A E 10 - 1H Bezel Color Code 1 4 Key Bezel Color Code Bezel Color Blank Standard 1H to 2H Reversible Key 3H to 6H Non-reversible Key Black Metallic Positions Code 2 21 Contact Configuration Bezel Color 90º 2-position, maintained 90º 2-position, spring return from right 3 45º 3-position, maintained 31 45º 3-position, spring return from right 32 33 45º 3-position, spring return from left 45º 3-position, spring return two-way See page 14 and 15. Key Removal Position 2-position Code Position Code Positions A 0 ➊➋: Code Removable in left only Maintained B C ➋ Positions Spring Return from right Removable in right only 1 2 Note: The key cannot be removed in a spring return position. Key retained position 3-position Code Position Code Maintained 0 A Maintained (removable in right and left) Code ➋ 0 G ➋ Positions Code Removable in right and center C Removable in left only 0 0 Positions Removable in center only D 0 ➋ Removable in right only H 0 Key retained position Spring Return from right L 0 B E 0 ➊➋: Positions Removable in left and center C R Spring Return from left L C R Spring Return two-way L C R Note: The key cannot be removed in a spring return position. (13/07/23) 7 ø22 Flush Silhouette Switches CW Series Illuminated Pushbuttons Illuminated Pushbuttons Package quantity: 1 Shape Operation Round Flush CWL-M1 CWL-A1 Operating Voltage 6V AC/DC 12V AC/DC 24V AC/DC Momentary 100/120V AC 200/220V AC (black bezel) 230/240V AC 6V AC/DC (metallic bezel) 12V AC/DC • See page 21 for replacement LED modules. • Marking film can be inserted to indicate legends. See page 23. • See page 16 for dimensions. • White lens type (when light is off) are available. Clear lens is used instead of colored lens for amber, green, red, and blue illuminated pushbuttons. Amber, green, red, or blue LED units are used. To specify, add W before the color code in Part No. Example: CW1L-M1E10Q2WR • A dummy block is installed when one contact block is used. 24V AC/DC Maintained 100/120V AC 200/220V AC 230/240V AC 8 Part No. Contact Configuration Black Bezel Metallic Bezel 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-M1E10Q2➁ CW1L-M1E01Q2➁ CW1L-M1E11Q2➁ CW1L-M1E20Q2➁ CW1L-M1E02Q2➁ CW1L-M1E22Q2➁ CW1L-M1E10Q3➁ CW1L-M1E01Q3➁ CW1L-M1E11Q3➁ CW1L-M1E20Q3➁ CW1L-M1E02Q3➁ CW1L-M1E22Q3➁ CW1L-M1E10Q4➁ CW1L-M1E01Q4➁ CW1L-M1E11Q4➁ CW1L-M1E20Q4➁ CW1L-M1E02Q4➁ CW1L-M1E22Q4➁ CW1L-M1E10QH➁ CW1L-M1E01QH➁ CW1L-M1E11QH➁ CW1L-M1E20QH➁ CW1L-M1E02QH➁ CW1L-M1E22QH➁ CW1L-M1E10QM➁ CW1L-M1E01QM➁ CW1L-M1E11QM➁ CW1L-M1E20QM➁ CW1L-M1E02QM➁ CW1L-M1E22QM➁ CW1L-M1E10QM4➁ CW1L-M1E01QM4➁ CW1L-M1E11QM4➁ CW1L-M1E20QM4➁ CW1L-M1E02QM4➁ CW1L-M1E22QM4➁ CW1L-A1E10Q2➁ CW1L-A1E01Q2➁ CW1L-A1E11Q2➁ CW1L-A1E20Q2➁ CW1L-A1E02Q2➁ CW1L-A1E22Q2➁ CW1L-A1E10Q3➁ CW1L-A1E01Q3➁ CW1L-A1E11Q3➁ CW1L-A1E20Q3➁ CW1L-A1E02Q3➁ CW1L-A1E22Q3➁ CW1L-A1E10Q4➁ CW1L-A1E01Q4➁ CW1L-A1E11Q4➁ CW1L-A1E20Q4➁ CW1L-A1E02Q4➁ CW1L-A1E22Q4➁ CW1L-A1E10QH➁ CW1L-A1E01QH➁ CW1L-A1E11QH➁ CW1L-A1E20QH➁ CW1L-A1E02QH➁ CW1L-A1E22QH➁ CW1L-A1E10QM➁ CW1L-A1E01QM➁ CW1L-A1E11QM➁ CW1L-A1E20QM➁ CW1L-A1E02QM➁ CW1L-A1E22QM➁ CW1L-A1E10QM4➁ CW1L-A1E01QM4➁ CW1L-A1E11QM4➁ CW1L-A1E20QM4➁ CW1L-A1E02QM4➁ CW1L-A1E22QM4➁ CW4L-M1E10Q2➁ CW4L-M1E01Q2➁ CW4L-M1E11Q2➁ CW4L-M1E20Q2➁ CW4L-M1E02Q2➁ CW4L-M1E22Q2➁ CW4L-M1E10Q3➁ CW4L-M1E01Q3➁ CW4L-M1E11Q3➁ CW4L-M1E20Q3➁ CW4L-M1E02Q3➁ CW4L-M1E22Q3➁ CW4L-M1E10Q4➁ CW4L-M1E01Q4➁ CW4L-M1E11Q4➁ CW4L-M1E20Q4➁ CW4L-M1E02Q4➁ CW4L-M1E22Q4➁ CW4L-M1E10QH➁ CW4L-M1E01QH➁ CW4L-M1E11QH➁ CW4L-M1E20QH➁ CW4L-M1E02QH➁ CW4L-M1E22QH➁ CW4L-M1E10QM➁ CW4L-M1E01QM➁ CW4L-M1E11QM➁ CW4L-M1E20QM➁ CW4L-M1E02QM➁ CW4L-M1E22QM➁ CW4L-M1E10QM4➁ CW4L-M1E01QM4➁ CW4L-M1E11QM4➁ CW4L-M1E20QM4➁ CW4L-M1E02QM4➁ CW4L-M1E22QM4➁ CW4L-A1E10Q2➁ CW4L-A1E01Q2➁ CW4L-A1E11Q2➁ CW4L-A1E20Q2➁ CW4L-A1E02Q2➁ CW4L-A1E22Q2➁ CW4L-A1E10Q3➁ CW4L-A1E01Q3➁ CW4L-A1E11Q3➁ CW4L-A1E20Q3➁ CW4L-A1E02Q3➁ CW4L-A1E22Q3➁ CW4L-A1E10Q4➁ CW4L-A1E01Q4➁ CW4L-A1E11Q4➁ CW4L-A1E20Q4➁ CW4L-A1E02Q4➁ CW4L-A1E22Q4➁ CW4L-A1E10QH➁ CW4L-A1E01QH➁ CW4L-A1E11QH➁ CW4L-A1E20QH➁ CW4L-A1E02QH➁ CW4L-A1E22QH➁ CW4L-A1E10QM➁ CW4L-A1E01QM➁ CW4L-A1E11QM➁ CW4L-A1E20QM➁ CW4L-A1E02QM➁ CW4L-A1E22QM➁ CW4L-A1E10QM4➁ CW4L-A1E01QM4➁ CW4L-A1E11QM4➁ CW4L-A1E20QM4➁ CW4L-A1E02QM4➁ CW4L-A1E22QM4➁ Illumination Color Code ➁  pecify an S illumination color code in place of ➁ in the Part No. A: amber G: green PW: pure white R: red S: blue Y: yellow Specify an illumination color code in place of ➁ in the Part No. A: amber G: green PW: pure white R: red S: blue Y: yellow (13/07/23) Flush Silhouette Switches CW Series Illuminated Pushbuttons ø22 Illuminated Pushbuttons Package quantity: 1 Shape Operation Round Extended CWL-M2 CWL-A2 Operating Voltage 6V AC/DC 12V AC/DC 24V AC/DC Momentary 100/120V AC 200/220V AC (black bezel) 230/240V AC 6V AC/DC (metallic bezel) 12V AC/DC • See page 21 for replacement LED modules. • Marking film can be inserted to indicate legends. See page 23. • See page 16 for dimensions. • White lens type (when light is off) are available. Clear lens is used instead of colored lens for amber, green, red, and blue illuminated pushbuttons. Amber, green, red, or blue LED units are used. To specify, add W before the color code in Part Number. Example: CW1L-M2E10Q2WR • A dummy block is installed when one contact block is used. 24V AC/DC Maintained 100/120V AC 200/220V AC 230/240V AC (13/07/23) Part No. Contact Configuration Black Bezel Metallic Bezel 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-M2E10Q2➁ CW1L-M2E01Q2➁ CW1L-M2E11Q2➁ CW1L-M2E20Q2➁ CW1L-M2E02Q2➁ CW1L-M2E22Q2➁ CW1L-M2E10Q3➁ CW1L-M2E01Q3➁ CW1L-M2E11Q3➁ CW1L-M2E20Q3➁ CW1L-M2E02Q3➁ CW1L-M2E22Q3➁ CW1L-M2E10Q4➁ CW1L-M2E01Q4➁ CW1L-M2E11Q4➁ CW1L-M2E20Q4➁ CW1L-M2E02Q4➁ CW1L-M2E22Q4➁ CW1L-M2E10QH➁ CW1L-M2E01QH➁ CW1L-M2E11QH➁ CW1L-M2E20QH➁ CW1L-M2E02QH➁ CW1L-M2E22QH➁ CW1L-M2E10QM➁ CW1L-M2E01QM➁ CW1L-M2E11QM➁ CW1L-M2E20QM➁ CW1L-M2E02QM➁ CW1L-M2E22QM➁ CW1L-M2E10QM4➁ CW1L-M2E01QM4➁ CW1L-M2E11QM4➁ CW1L-M2E20QM4➁ CW1L-M2E02QM4➁ CW1L-M2E22QM4➁ CW1L-A2E10Q2➁ CW1L-A2E01Q2➁ CW1L-A2E11Q2➁ CW1L-A2E20Q2➁ CW1L-A2E02Q2➁ CW1L-A2E22Q2➁ CW1L-A2E10Q3➁ CW1L-A2E01Q3➁ CW1L-A2E11Q3➁ CW1L-A2E20Q3➁ CW1L-A2E02Q3➁ CW1L-A2E22Q3➁ CW1L-A2E10Q4➁ CW1L-A2E01Q4➁ CW1L-A2E11Q4➁ CW1L-A2E20Q4➁ CW1L-A2E02Q4➁ CW1L-A2E22Q4➁ CW1L-A2E10QH➁ CW1L-A2E01QH➁ CW1L-A2E11QH➁ CW1L-A2E20QH➁ CW1L-A2E02QH➁ CW1L-A2E22QH➁ CW1L-A2E10QM➁ CW1L-A2E01QM➁ CW1L-A2E11QM➁ CW1L-A2E20QM➁ CW1L-A2E02QM➁ CW1L-A2E22QM➁ CW1L-A2E10QM4➁ CW1L-A2E01QM4➁ CW1L-A2E11QM4➁ CW1L-A2E20QM4➁ CW1L-A2E02QM4➁ CW1L-A2E22QM4➁ CW4L-M2E10Q2➁ CW4L-M2E01Q2➁ CW4L-M2E11Q2➁ CW4L-M2E20Q2➁ CW4L-M2E02Q2➁ CW4L-M2E22Q2➁ CW4L-M2E10Q3➁ CW4L-M2E01Q3➁ CW4L-M2E11Q3➁ CW4L-M2E20Q3➁ CW4L-M2E02Q3➁ CW4L-M2E22Q3➁ CW4L-M2E10Q4➁ CW4L-M2E01Q4➁ CW4L-M2E11Q4➁ CW4L-M2E20Q4➁ CW4L-M2E02Q4➁ CW4L-M2E22Q4➁ CW4L-M2E10QH➁ CW4L-M2E01QH➁ CW4L-M2E11QH➁ CW4L-M2E20QH➁ CW4L-M2E02QH➁ CW4L-M2E22QH➁ CW4L-M2E10QM➁ CW4L-M2E01QM➁ CW4L-M2E11QM➁ CW4L-M2E20QM➁ CW4L-M2E02QM➁ CW4L-M2E22QM➁ CW4L-M2E10QM4➁ CW4L-M2E01QM4➁ CW4L-M2E11QM4➁ CW4L-M2E20QM4➁ CW4L-M2E02QM4➁ CW4L-M2E22QM4➁ CW4L-A2E10Q2➁ CW4L-A2E01Q2➁ CW4L-A2E11Q2➁ CW4L-A2E20Q2➁ CW4L-A2E02Q2➁ CW4L-A2E22Q2➁ CW4L-A2E10Q3➁ CW4L-A2E01Q3➁ CW4L-A2E11Q3➁ CW4L-A2E20Q3➁ CW4L-A2E02Q3➁ CW4L-A2E22Q3➁ CW4L-A2E10Q4➁ CW4L-A2E01Q4➁ CW4L-A2E11Q4➁ CW4L-A2E20Q4➁ CW4L-A2E02Q4➁ CW4L-A2E22Q4➁ CW4L-A2E10QH➁ CW4L-A2E01QH➁ CW4L-A2E11QH➁ CW4L-A2E20QH➁ CW4L-A2E02QH➁ CW4L-A2E22QH➁ CW4L-A2E10QM➁ CW4L-A2E01QM➁ CW4L-A2E11QM➁ CW4L-A2E20QM➁ CW4L-A2E02QM➁ CW4L-A2E22QM➁ CW4L-A2E10QM4➁ CW4L-A2E01QM4➁ CW4L-A2E11QM4➁ CW4L-A2E20QM4➁ CW4L-A2E02QM4➁ CW4L-A2E22QM4➁ Illumination Color Code ➁ Specify an illumination color code in place of ➁ in the Part No. A: amber G: green PW: pure white R: red S: blue Y: yellow Specify an illumination color code in place of ➁ in the Part No. A: amber G: green PW: pure white R: red S: blue Y: yellow 9 ø22 Flush Silhouette Switches CW Series Pilot Lights Pilot Lights Package quantity: 1 Shape Round Flush CWP-1 (black bezel) Operating Voltage Part No. Black Bezel Metallic Bezel 6V AC/DC CW1P-1EQ2➁ CW4P-1EQ2➁ 12V AC/DC CW1P-1EQ3➁ CW4P-1EQ3➁ 24V AC/DC CW1P-1EQ4➁ CW4P-1EQ4➁ 100/120V AC CW1P-1EQH➁ CW4P-1EQH➁ 200/220V AC CW1P-1EQM➁ CW4P-1EQM➁ 230/240V AC CW1P-1EQM4➁ CW4P-1EQM4➁ 6V AC/DC CW1P-2EQ2➁ CW4P-2EQ2➁ 12V AC/DC CW1P-2EQ3➁ CW4P-2EQ3➁ 24V AC/DC CW1P-2EQ4➁ CW4P-2EQ4➁ 100/120V AC CW1P-2EQH➁ CW4P-2EQH➁ 200/220V AC CW1P-2EQM➁ CW4P-2EQM➁ 230/240V AC CW1P-2EQM4➁ CW4P-2EQM4➁ Illumination Color Code ➁ A: amber G: green PW: pure white R: red S: blue Y: yellow (metallic bezel) Round Extended CWP-2 (black bezel) A: amber G: green PW: pure white R: red S: blue Y: yellow (metallic bezel) • Specify an illumination color code in place of ➁ in the Part No. • See page 16 for dimensions. • See page 21 for replacement LED modules. • Two dummy blocks are installed. 10 (13/07/23) Flush Silhouette Switches CW Series Pushbuttons ø22 Pushbuttons Package quantity: 1 Shape Operation Round Flush CWB-M1 CWB-A1 Momentary (black bezel) (metallic bezel) Maintained Round Extended CWB-M2 CWB-A2 Momentary (black bezel) (metallic bezel) Maintained Part No. Contact Configuration Black Bezel Metallic Bezel 1NO CW1B-M1E10➀ CW4B-M1E10➀ 1NC CW1B-M1E01➀ CW4B-M1E01➀ 1NO-1NC CW1B-M1E11➀ CW4B-M1E11➀ 2NO CW1B-M1E20➀ CW4B-M1E20➀ 2NC CW1B-M1E02➀ CW4B-M1E02➀ 2NO-1NC CW1B-M1E21➀ CW4B-M1E21➀ 1NO-2NC CW1B-M1E12➀ CW4B-M1E12➀ 3NO CW1B-M1E30➀ CW4B-M1E30➀ 3NC CW1B-M1E03➀ CW4B-M1E03➀ 2NO-2NC CW1B-M1E22➀ CW4B-M1E22➀ 1NO CW1B-A1E10➀ CW4B-A1E10➀ 1NC CW1B-A1E01➀ CW4B-A1E01➀ 1NO-1NC CW1B-A1E11➀ CW4B-A1E11➀ 2NO CW1B-A1E20➀ CW4B-A1E20➀ 2NC CW1B-A1E02➀ CW4B-A1E02➀ 2NO-1NC CW1B-A1E21➀ CW4B-A1E21➀ 1NO-2NC CW1B-A1E12➀ CW4B-A1E12➀ 3NO CW1B-A1E30➀ CW4B-A1E30➀ 3NC CW1B-A1E03➀ CW4B-A1E03➀ 2NO-2NC CW1B-A1E22➀ CW4B-A1E22➀ 1NO CW1B-M2E10➀ CW4B-M2E10➀ 1NC CW1B-M2E01➀ CW4B-M2E01➀ 1NO-1NC CW1B-M2E11➀ CW4B-M2E11➀ 2NO CW1B-M2E20➀ CW4B-M2E20➀ 2NC CW1B-M2E02➀ CW4B-M2E02➀ 2NO-1NC CW1B-M2E21➀ CW4B-M2E21➀ 1NO-2NC CW1B-M2E12➀ CW4B-M2E12➀ 3NO CW1B-M2E30➀ CW4B-M2E30➀ 3NC CW1B-M2E03➀ CW4B-M2E03➀ 2NO-2NC CW1B-M2E22➀ CW4B-M2E22➀ 1NO CW1B-A2E10➀ CW4B-A2E10➀ 1NC CW1B-A2E01➀ CW4B-A2E01➀ 1NO-1NC CW1B-A2E11➀ CW4B-A2E11➀ 2NO CW1B-A2E20➀ CW4B-A2E20➀ 2NC CW1B-A2E02➀ CW4B-A2E02➀ 2NO-1NC CW1B-A2E21➀ CW4B-A2E21➀ 1NO-2NC CW1B-A2E12➀ CW4B-A2E12➀ 3NO CW1B-A2E30➀ CW4B-A2E30➀ 3NC CW1B-A2E03➀ CW4B-A2E03➀ 2NO-2NC CW1B-A2E22➀ CW4B-A2E22➀ Button Color Code ➀ B: black G: green R: red S: blue W: white Y: yellow B: black G: green R: red S: blue W: white Y: yellow B: black G: green R: red S: blue W: white Y: yellow B: black G: green R: red S: blue W: white Y: yellow • Specify a button color code in place of ➀ in the Part No. • See page 17 for dimensions. • Two or one dummy block is installed when one or two contact blocks are used, respectively. (13/07/23) 11 ø22 Flush Silhouette Switches CW Series Selector Switches Selector Switches Package quantity: 1 CWS (Knob Operator) Shape (metallic bezel) (black bezel) No. of Positions Contact Configuration (Code) 1NO (10) 1NC (01) 1NO-1NC (11) 2NO (20) 2NC (02) 2NO-1NC (21) 90° 2-position 1NO-2NC (12) 3NO (30) 3NC (03) Contact Block Mounting Position 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2NO-2NC (22) 2 3 1 4NO (40) 2 3 Contact NO — — — — NC NO — NC NO — NO NC — NC NO NO NC NO NC NC NO NO NO NC NC NC NO/ NO NC NC — NO/ NO NC NC NO 2NO NO — NO 2NO NO Operator Position L L R R Maintained Spring return from right Dummy Dummy Dummy Dummy CWS-2E10 CWS-21E10 CWS-2E01 CWS-21E01 Dummy CWS-2E11 CWS-21E11 Dummy CWS-2E20 CWS-21E20 Dummy CWS-2E02 CWS-21E02 CWS-2E21 CWS-21E21 CWS-2E12 CWS-21E12 CWS-2E30 CWS-21E30 CWS-2E03 CWS-21E03 Dummy CWS-2E22 CWS-21E22 Dummy CWS-21E40 CWS-21E40 L R • Specify a bezel color code in place of  in the Part No.: 1 (black bezel), 4 (metallic bezel) • Lever operator is also available. For dimensions, see page 18. • When ordering a lever operator selector switch, designate L before E in the Part No. of knob operator selector switches. [Example] CW1S-2E10 Knob Operator CW1S-2LE10 Lever Operator Lever Operator CW1S-∗LE (black bezel) 12 Contact Block Mounting Position 1 2 3 CW4S-∗LE (metallic bezel) (13/07/23) Flush Silhouette Switches CW Series Selector Switches ø22 No. of Positions Contact Block Contact Configuration Mounting (Code) Contact Position Operator Position L C R L C R Maintained L C R Spring return from right L C Package quantity: 1 R Spring return from left L C R Spring return two-way 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 NO — Dummy CWS-3E11 CWS-31E11 CWS-32E11 CWS-33E11 NC NC 1NO-1NC — Dummy CWS-3E11N1 CWS-31E11N1 CWS-32E11N1 CWS-33E11N1 (11N1) NO NO 1NO-1NC NC CWS-3E11N2 CWS-31E11N2 CWS-32E11N2 CWS-33E11N2 (11N2) — Dummy — Dummy 1NO-1NC NC CWS-3E11N3 CWS-31E11N3 CWS-32E11N3 CWS-33E11N3 (11N3) NO — Dummy 1NO-1NC NO CWS-3E11N4 CWS-31E11N4 CWS-32E11N4 CWS-33E11N4 (11N4) NC NO 2NO — Dummy CWS-3E20 CWS-31E20 CWS-32E20 CWS-33E20 (20) NO — Dummy 2NO NO CWS-3E20N1 CWS-31E20N1 CWS-32E20N1 CWS-33E20N1 (20N1) NO NC 2NC — Dummy CWS-3E02 CWS-31E02 CWS-32E02 CWS-33E02 (02) NC — Dummy 2NC NC CWS-3E02N1 CWS-31E02N1 CWS-32E02N1 CWS-33E02N1 (02N1) NC NO 2NO-1NC NO CWS-3E21 CWS-31E21 CWS-32E21 CWS-33E21 (21) 45° NC 3-position NO 2NO-1NC NC CWS-3E21N1 CWS-31E21N1 CWS-32E21N1 CWS-33E21N1 (21N1) NO NO 1NO-2NC NC CWS-3E12 CWS-31E12 CWS-32E12 CWS-33E12 (12) NC NC 1NO-2NC NO CWS-3E12N1 CWS-31E12N1 CWS-32E12N1 CWS-33E12N1 (12N1) NC NO 3NO NO CWS-3E30 CWS-31E30 CWS-32E30 CWS-33E30 (30) NO NC 3NC NC CWS-3E03 CWS-31E03 CWS-32E03 CWS-33E03 (03) NC NO/ NO 1 NC NC 2NO-2NC 2 — Dummy CWS-3E22 CWS-31E22 CWS-32E22 CWS-33E22 (22) NO/ NO 3 NC NC NO 1 2NO NO 4NO 2 — Dummy CWS-3E40 CWS-31E40 CWS-32E40 CWS-33E40 (40) NO 2NO 3 NO NC 1 2NC NC 2NO-2NC 2 — Dummy CWS-3E22N2 CWS-31E22N2 CWS-32E22N2 CWS-33E22N2 (22N2) NC 2NO 3 NC • Specify a bezel color code in place of  in the Part No.: 1 (black bezel), 4 (metallic bezel) • For the contact block mounting position, see page 12. • Lever operator is also available. For dimensions, see page 18. • When ordering a lever operator selector switch, designate L before E in the Part No. of knob operator selector switches. [Example] CW1S-3E11 CW1S-3LE11 Knob Operator Lever Operator 1NO-1NC (11) (13/07/23) 13 ø22 Flush Silhouette Switches CW Series Key Selector Switches Key Selector Switches Package quantity: 1 CWK Shape (metallic bezel) (black bezel) No. of Positions Contact Configuration (Code) 1NO (10) 1NC (01) 1NO-1NC (11) Contact Block Operator Position Mounting Position Contact 1 NO 2 — Dummy 3 — Dummy 1 — Dummy 2 — 3 NC 1 NO 2 — 3 NC 1 NO 2NO (20) 2 — 3 NO 2NC (02) 1 NC 2 — 3 NC 1 NO 2 NO 3 NC 1 NO 2 NC 3 NC 2NO-1NC (21) 90° 2-position 1NO-2NC (12) 3NO (30) 1 NO 2 NO 3 NO 3NC (03) 1 NC 2 NC 3 NC 1 2NO-2NC (22) 4NO (40) NO/NC 2 NO/NC 1 2NO 2 Maintained L R Spring return from right CWK-2AE10 CWK-21BE10 Dummy CWK-2AE01 CWK-21BE01 Dummy CWK-2AE11 CWK-21BE11 Dummy CWK-2AE20 CWK-21BE20 Dummy CWK-2AE02 CWK-21BE02 CWK-2AE21 CWK-21BE21 CWK-2AE12 CWK-21BE12 CWK-2AE30 CWK-21BE30 CWK-2AE03 CWK-21BE03 Dummy CWK-2AE22 CWK-21BE22 Dummy CWK-2AE40 CWK-21BE40 NO NC NO NC NO NO — 2NO R R l — 3 3 L L NO NO • Specify a bezel color code in place of  in the Part No.: 1 (black bezel), 4 (metallic bezel) • On the spring-returned types, the key can be released only from the maintained position. On the maintained types, the key can be released from every position. Key retained positions are also available. See below. • Two keys are supplied. • Key cylinder material: Metal • Besides the standard key (key number 0H), six other keys are also available. See below. • For the contact block mounting position, see page 12. • For dimensions, see page 19. • When ordering an optional key or optional key retained positions, specify designation codes as shown below: [Example] CW1K-2AE10-1H (blank): Standard key (0H, reversible) 1H to 2H: Reversible key 3H to 6H: Non-reversible key Key removal position code 2-position A: Removable in all positions B: Removable in left only C: Removable in right only Note: Key number is indicated on the key cylinder. Standard keys do not have a key number indication. 3-position A: Removable in all positions B: Removable in left and center C: Removable in right and center D: Removable in center only E: Removable in right and left G: Removable in left only H: Removable in right only Note: Key is retained in the spring-returned position. 14 (13/07/23) ø22 Flush Silhouette Switches CW Series Key Selector Switches Package quantity: 1 No. of Positions Contact Configuration 1NO-1NC (11) 1NO-1NC (11N1) 1NO-1NC (11N2) 1NO-1NC (11N3) 1NO-1NC (11N4) 2NO (20) 2NO (20N1) 2NC (02) 2NC (02N1) 45° 3-position 2NO-1NC (21) 2NO-1NC (21N1) 1NO-2NC (12) 1NO-2NC (12N1) 3NO (30) 3NC (03) 2NO-2NC (22) Contact Block Mounting Position Contact 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 NO — NC NC — NO NO NC — — NC NO — NO NC NO — NO — NO NO NC — NC — NC NC NO NO NC NO NC NO NO NC NC NC NO NC NO NO NO NC NC NC 1 NO/NC 2 — 3 1 4NO (40) 2 3 1 2NO-2NC (22N2) Operator Position 2 3 L L C R L C R C R L C R Maintained Spring return from right Spring return from left Spring return two-way Dummy CWK-3AE11 CWK-31BE11 CWK-32CE11 CWK-33DE11 Dummy CWK-3AE11N1 CWK-31BE11N1 CWK-32CE11N1 CWK-33DE11N1 CWK-3AE11N2 CWK-31BE11N2 CWK-32CE11N2 CWK-33DE11N2 CWK-3AE11N3 CWK-31BE11N3 CWK-32CE11N3 CWK-33DE11N3 CWK-3AE11N4 CWK-31BE11N4 CWK-32CE11N4 CWK-33DE11N4 CWK-3AE20 CWK-31BE20 CWK-32CE20 CWK-33DE20 CWK-3AE20N1 CWK-31BE20N1 CWK-32CE20N1 CWK-33DE20N1 CWK-3AE02 CWK-31BE02 CWK-32CE02 CWK-33DE02 CWK-3AE02N1 CWK-31BE02N1 CWK-32CE02N1 CWK-33DE02N1 CWK-3AE21 CWK-31BE21 CWK-32CE21 CWK-33DE21 CWK-3AE21N1 CWK-31BE21N1 CWK-32CE21N1 CWK-33DE21N1 CWK-3AE12 CWK-31BE12 CWK-32CE12 CWK-33DE12 CWK-3AE12N1 CWK-31BE12N1 CWK-32CE12N1 CWK-33DE12N1 CWK-3AE30 CWK-31BE30 CWK-32CE30 CWK-33DE30 CWK-3AE03 CWK-31BE03 CWK-32CE03 CWK-33DE03 Dummy CWK-3AE22 CWK-31BE22 CWK-32CE22 CWK-33DE22 Dummy CWK-3AE40 CWK-31BE40 CWK-32CE40 CWK-33DE40 Dummy CWK-3AE22N2 CWK-31BE22N2 CWK-32CE22N2 CWK-33DE22N2 C R Dummy Dummy Dummy Dummy Dummy Dummy Dummy NO NC NO NO/NC NC NO 2NO NO — NO 2NO NO NC 2NC NC — NO 2NO NO • Specify a bezel color code in place of  in the Part No.: 1 (black bezel), 4 (metallic bezel) • On the spring-returned types, the key can be released only from the maintained position. On the maintained types, the key can be released from every position. Key retained positions are also available. See page 14. • Two keys are supplied. • Key cylinder material: Metal • Besides the standard key (key number 0H), six other keys are also available. See page 14. • For the contact block mounting position, see right. • For dimensions, see page 19. (13/07/23) L Contact Block Mounting Position 1 2 3 15 ø22 Flush Silhouette Switches CW Series Dimensions Illuminated Pushbuttons All dimensions in mm. See page 5 for mounting hole layout. 1 to 2 contacts Round Flush Round Extended 41.4 ø19.5 LO CK 28.5 (Lens Diameter) 28.5 CK ø28 LO ø28 ø19.5 (Lens Diameter) 10 10 10 1 10 2 41.4 Panel Thickness 0.8 to 3.2 M3.5 0.5 Terminal Screw LED Module Locking Ring Gasket 0.5 Locking Ring Gasket 3 M3.5 Terminal Screw LED Module 10 M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 M3.5 Terminal Screw Contact Block 2.5 Momentary: 39.9 Maintained: 44.6 2.5 Momentary: 39.9 Maintained: 44.6 30 30 5.2 4 contacts Round Flush Round Extended M3.5 Terminal Screw Contact Block M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 2nd-tier 1st-tier contact block (NC) contact block (NO) LO Locking Ring Gasket 41.4 CK 28.5 28.5 CK ø28 LO ø28 (Lens Diameter) 41.4 ø19.5 Locking Ring Gasket 0.5 (Lens Diameter) 0.5 ø19.5 2nd-tier 1st-tier contact block (NC) contact block (NO) 2.5 Momentary: 59.9 Maintained: 64.6 2.5 Momentary: 59.9 Maintained: 64.6 30 5.2 30 Pilot Lights Round Flush Round Extended Panel Thickness 0.8 to 3.2 LOC Locking Ring Gasket 41.4 ø19.5 28.5 ø28 ø19.5 (Lens Diameter) K K 28.5 LOC Locking Ring Gasket 0.5 ø28 M3.5 Terminal Screw LED Module 0.5 41.4 M3.5 Terminal Screw LED Module (Lens Diameter) 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 2.5 39.9 16 2.5 30 39.9 4.1 30 (13/07/23) Flush Silhouette Switches CW Series Dimensions ø22 Pushbuttons All dimensions in mm. See page 5 for mounting hole layout. 1 to 3 contacts Round Flush Round Extended M3.5 Terminal Screw Contact Block M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 LO Momentary ø19.5 41.4 Maintained LO Locking Ring Gasket LO CK CK 28.5 28.5 CK 28.5 28.5 CK ø28 ø19.5 41.4 (Button Diameter) Locking Ring Gasket 0.5 Maintained LO ø28 Momentary (Button Diameter) 0.5 2.5 Momentary: 39.9 Maintained: 44.6 2.5 30 Momentary: 39.9 Maintained: 44.6 30 5.2 30 30 4 contacts Round Flush Round Extended M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 2.5 ø19.5 41.4 30 Momentary: 59.9 Maintained: 64.6 2.5 5.2 Maintained LO LO CK CK 28.5 28.5 CK 28.5 28.5 30 Momentary Locking Ring Gasket LO CK ø28 (Button Diameter) ø19.5 41.4 Momentary: 59.9 Maintained: 64.6 Maintained LO 0.5 ø28 Momentary Locking Ring Gasket 2nd-tier 1st-tier contact block (NC) contact block (NO) (Button Diameter) 0.5 2nd-tier 1st-tier contact block (NC) contact block (NO) (13/07/23) Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 M3.5 Terminal Screw Contact Block 30 30 17 ø22 Flush Silhouette Switches CW Series Dimensions Selector Switches All dimensions in mm. See page 5 for mounting hole layout. 1 to 3 contacts Knob Operator M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 M3.5 Terminal Screw Contact Block Lever Operator 0.5 0.5 Operator Angle Operator Angle 45º LOC 45 º LOC K 45 º ø28 41.4 ø28 41.4 2.5 39.9 45º Locking Ring Gasket 28.5 K 28.5 Locking Ring Gasket 2.5 13.1 39.9 30 30 4 contacts Knob Operator Lever Operator M3.5 Terminal Screw Contact Block M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 2nd-tier 1st-tier contact block (NC) contact block (NO) 0.5 2nd-tier 1st-tier contact block (NC) contact block (NO) 0.5 Operator Angle Operator Angle LOC K 45 º 18 K 45 º ø28 41.4 28.5 ø28 41.4 59.9 LOC 2.5 2.5 13.1 45º Locking Ring Gasket 28.5 45º Locking Ring Gasket 30 59.9 17.1 30 (13/07/23) Flush Silhouette Switches CW Series Dimensions ø22 Key Selector Switches Keys 1 to 3 contacts Reversible Key M3.5 Terminal Screw Contact Block 8.8 22 8.8 22 10 10 14 14 10 Panel Thickness 0.8 to 3.2 All dimensions in mm. Logo Stamping Operator Angle 0.5 LOC K 45 º ø28 41.4 28.5 Key No. Stamping Key No. Stamping Non-reversible Key 2.5 8.8 22 8.8 22 30 Key No: 0H to 2H (reversible key) 14 14 31.5 6.3 6.3 10.4 39.9 Key No. Key No. 0 H0 H 45º Locking Ring Gasket Logo Stamping Logo Stamping Logo Stamping Key No. Key No. 3 H3 H Key No. Stamping Key No. Stamping 31.5 Key No: 3H to 6H (non-reversible key) 4 contacts M3.5 Terminal Screw Contact Block Screw M3.5 Terminal Contact Block Panel Thickness 0.8 to 3.2 2nd-tier 1st-tier contact block (NC) contact block (NO) 0.5 0.5 Operator AngleOperator Angle 28.5 39.9 59.9 2.5 10.4 10.4 31.5 31.5 LOC K 45 º ø28 ø28 41.4 41.4 2.5 4º LOC45 5º K 45º Locking Ring Gasket Gasket Locking Ring 28.5 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 30 30 Key No: 0H to 2H (reversible key) 31.5 Key No: 3H to 6H (non-reversible key) (13/07/23) See page 5 for mounting hole layout. 19 ø22 Flush Silhouette Switches CW Series Accessories / Maintenance Parts Accessories Shape Material Part No. Package Quantity Locking Ring Wrench MW9Z-T1 Brass 1 • Used to tighten the locking ring when installing the CW series control unit in a 110 panel cut-out. • Weight: Approx 150g 8 ø2 • Used to plug an unnecessary ø22.3mm hole in the panel. ø29.0 Panel • Degree of protection: IP65 Thickness 0.8 to 6 • Panel thickness: 0.8 to 6.0 mm LW9Z-BP1 1 Rubber Boot 1 For round flush 1 CW9Z-D1 1 Rubber (Transparent 2 For round silicon rubber) extended 2 • Degree of protection: IP66/67 UL Type 4X • Panel thickness: 0.8 to 3.2 mm • Use with round extended illuminated pushbuttons/pushbuttons. Gasket Locking Ring M22 P:1 0 ø3 4 Polyamide (black) 15.0 0.5 2.0 Mounting Hole Plug Remarks 0 ø3 1 6.7 CW9Z-D2 Nameplates Description Legend Material Part No. Ordering No. Package Quantity CWAM CWAM 1 Dimensions (mm) • Marking plate HWNP is necessary. • Degree of protection: IP65 • Do not remove the gasket on the operator. 29 27 12.1 15.5 Plastic (black) CWAM 44 Order marking plate (HWNP) separately. 2.7 2.2 ø2 14 10 R CWAMPN10 0.9 • Cannot be used with HW/FB series control box types. Making Plate Description Material Part No. Ordering No. Package Quantity HWNP Dimensions (mm) • White legend on black background. 1 HWNP-∗PN10 10 27 12 Aluminum (black) 1.0 mm thick HWNP∗ HWNP-∗ • Engraving area: W25, H7 • Thickness: 1.0 mm • Specify a legend code in place of ∗ in the Ordering No. Legends Code 0 1 2 3 20 Legend (blank) ON OFF START Code 4 31 33 53 Legend STOP OFF-ON HAND-AUTO HAND-OFF-AUTO (13/07/23) Flush Silhouette Switches CW Series Accessories / Maintenance Parts ø22 Maintenance Parts Used for replacement only. Do not use the maintenance parts to remodel or expand the CW series control units. Shape Button 2 1 Lens 2 1 3 Material Part No. Ordering No. Package Quantity 1 For round flush Polyarylate ø19.5 H3.5 CW9Z-B11➀ CW9Z-B11➀PN05 5 2 For round extended Polyarylate ø19.5 H6.2 CW9Z-B12➀ CW9Z-B12➀PN05 5 1 Round Flush Polyalylate CW9Z-L11➁ CW9Z-L11➁PN05 5 2 Round Extended Polyalylate CW9Z-L12➁ CW9Z-L12➁PN05 5 3 Round Extended Polyalylate CW9Z-L15➁ CW9Z-L15➁PN05 5 1NO YW-E10R YW-E10R 1 1NC YW-E01 YW-E01 1 2NO YW-EW2R0 YW-EW2R0 1 2NC YW-EW02 YW-EW02 1 1NO, 1NC YW-EW1R1 YW-EW1R1 1 Polyamide (black) CW-DB CW-DBPN05 5 Polyamide (black) CW9Z-LN CW9Z-LNPN05 5 Single Contact Block Push rod Housing Double Contact Block Push rod Housing (photo: YW-EW1R1) Remarks • For maintained pushbuttons. • Specify a button color code in place of ➀ in the Part No. B (black), G (green), R (red), S (blue), W (white), Y (yellow) Color code ➁: A (amber), C (clear), G (green), R (red), S (blue), Y (yellow) Use a clear (C) lens for pure white (PW) illumination. 1: For illuminated pushbutton, pilot light 2: For illuminated pushbutton 3: For pilot light Push rod color: black Housing color: blue and black Terminal No.: 3-4 Push rod color: red Housing color: reddish purple Terminal No.: 1-2 Push rod color: black Housing color: blue and black Terminal No. 1st tier: 13-14 2nd tier: 23-24 Push rod color: red Housing color: reddish purple Terminal No. 1st tier: 11-12 2nd tier: 21-22 Push rod color: gray Housing color: reddish purple/blue Terminal No. 1st tier: 13-14 2nd tier: 21-22 Dummy Block Locking Ring Waterproof gasket between CW control unit bezel and the mounting panel. Gasket Nitrile rubber CW9Z-WM CW9Z-WMPN10 .6 10 ø21 5 ±0.1 ø28 .0 ±0.1 5 Thickness: 0.5 Spare Key Non-reversible Zinc (nickelplated) LA9Z-SK- LA9Z-SK- PN02 Reversible 2 Specify a key No. in place of . 0H: Standard key (reversible) 1H to 2H: Reversible key 3H to 6H: Non-reversible key For dimensions, see page 19. LED Module Shape Operating Voltage Range Current Draw 6V AC/DC ±10% 15 mA 12V AC/DC ±10% 15 mA 24V AC/DC ±10% 16.5 mA 100/120V AC ±10% 18 mA 200/220V AC ±10% 20 mA 230/240V AC ±10% 18 mA • Use a pure white (PW) LED module for yellow (Y) illumination. (13/07/23) Package quantity: 1 Part No. CW-EAQ2➁ CW-EAQ3➁ CW-EAQ4➁ CW-EAQH➁ CW-EAQM➁ CW-EAQM4➁ Illumination Color Code ➁ Specify an illumination color code in place of ➁ in the Part No. A: amber G: green PW: pure white R: red S: blue 21 ø22 Flush Silhouette Switches CW Series Instructions Safety Precautions • Turn off the power to the CW series control units before installation, removal, wiring, and maintenance. Failure to turn power off may cause electrical shocks or fire hazard. • For wiring, use wires of a proper size to meet the voltage and current requirements. Tighten the M3.5 terminal screws to a tightening torque of 1.0 to 1.3 N·m. Failure to tighten the terminal screws may cause overheating and fire. Operating Instructions Notes for Operation • When using the CW series control units in a safety-related circuit of a control system, observe safety rules and regulations of each country concerning particular applications of the actual machines and facilities. Perform risk assessment before operation to ensure safety. Note for Panel Mounting When installing the operator in a panel cut-out, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring to a recommended tightening torque of 1.2 N·m. Do not use pliers and do not tighten excessively, otherwise the operator may be damaged. Anti-rotation projection Recess in mounting hole Panel TOP marking on illuminated pushbuttons, pushbuttons, and pilot light Operating Conditions • In corrosive gas or high-temperature, high-humidity atmosphere, contact failure due to corrosion or color change or breakage of the housing may occur. • Main parts of the CW series control units are made of plastics. Do not scratch the surface with a sharp object or apply excessive shocks or load, otherwise the control units may be damaged. In particular, keep the button, lens, and bezel from such damage, otherwise appearance and function may be impaired. • Do not apply detergents, cutting oils, or chemicals which may impair the function and appearance of the CW series control units. Locking Ring TOP marking on selector and key selector switches Removing and Installing the Contact Unit Mounting Hole 1. To remove the contact block from the operator, push the yellow locking lever and turn it to the left. 1. Mounting hole dimensions are in compliance with IEC 60947-5-1. 2. If the anti-rotation projection is removed from the bezel, CW series control units can be mounted in ø22.3 mm mounting holes. To remove the anti-rotation projection, remove the gasket and use cutting pliers to break the projection. Locking Lever 2. To install, align the TOP marking on the operator with the TOP marking on the contact block mounting adaptor, and turn the locking lever to the right. Panel Mounting Remove the contact block from the operator. Remove the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block to the operator. Installation in Panel Cut-out Remove the locking ring from the operator. With the antirotation projection on the operator aligned with the recess in the mounting hole, insert the operator into the mounting hole. Tighten the locking ring from the rear of the panel. 22 (13/07/23) Flush Silhouette Switches CW Series Instructions ø22 Operating Instructions Pushbuttons (momentary) Momentary pushbutton caps cannot be removed. Do not tamper with the pushbutton caps using a screwdriver or pliers, otherwise the pushbutton caps may be damaged. Pushbuttons (maintained) / Illuminated Pushbuttons / Pilot Lights Removing the button/lens To remove the button or lens from a pushbutton, illuminated pushbutton or pilot light, insert a flat screwdriver under the flange of the lens at 90° from the TOP marking and twist the screwdriver. Installing the Rubber Boot When using in places where the switches are subjected to water splash or an excessive amount of dust, make sure to use the optional rubber boot. Mount the rubber boot so that the protrusion at the bottom surface of the operator fits with the recess on the operator, placing the rubber boot all around the operator sleeve. Make sure that the protrusion on the rubber boot and the recess on the operator is properly fitted, otherwise, the waterproof and dustproof characteristics are not ensured. How to Install the Rubber Boot Do not insert the screwdriver too deeply and do not apply excessive force to the lens, otherwise the bezel surface may be damaged. 2Mount [Screwdriver Insertion Direction] TOP Marking 1Remove (do not use) TOP Marking Gasket Installation complete. [Screwdriver Insertion Angle] Note: Install the rubber boot before mounting the unit to the panel. Approx. 30° Panel Surface Maintained Do not replace the button/lens while the operator is latched. Otherwise the internal structure will be damaged. Selector Switches Installing the Lens Turn the selector operator or key to the detent positions. Turn the groove in the lens to the TOP marking on the operator housing. With the groove aligned with the ridge, press the lens in. Key Selector Switches TOP Marking Ridge Groove in the Lens Marking Marking plates are not available for CW series illuminated pushbuttons and pilot lights. Marking film can be inserted to indicate legends. To prevent malfunctions and damage, take the following precautions. • Insert the key to the bottom before turning. • Do not remove the key while turning. • Besides the standard key (0H), six other keys are available. Use a key with a key selector switch of a matching number indicated on the key cylinder. Standard key does not have a key number indication. • Keys are available in two shapes. Key numbers 0H (standard), 1H, and 2H are reversible keys. Key numbers 3H, 4H, 5H, and 6H are non-reversible keys. Make sure of correct insertion direction. Applicable Marking Film Size Illuminated Pushbutton (Round Flush) Pilot Light (Round Flush, Round Extended) Illuminated Pushbutton (Round Extended) 13.8 9 5. ø1 12.6 9 5. ø1 Thickness: 0.2 mm maximum Film material: Polyester (recommended) Note: Film is not supplied and must be prepared by the user. (13/07/23) 23 ø22 Flush Silhouette Switches CW Series Instructions Contact Blocks and LED Modules Wiring To remove the contact block from the operator, insert a flat screwdriver under the latch and push down the screwdriver as shown below. Before removing the LED module, first remove all contact blocks, and remove the LED module in the same manner. Applicable Wires Stranded wire: 2.0 mm2 maximum (14AWG) Solid wire: ø1.6 mm maximum (16 AWG) One or two wires can be connected to the terminal. Applicable Crimping Terminals Nameplate / Marking Plate 11.5 max. 3.6 min. 6.9 max. [Spade terminal] When using crimping terminals, be sure to use insulating tubes or use insulated crimping terminals. Note: Ring terminals cannot be used. 8.1 max. Nameplate Insulation Tube Crimping Terminal ➁ Wire ➀ 0.5 min. • To remove the marking plate, insert the flat screwdriver between the marking plate and nameplate. Nameplate Marking Plate 1.7 max. Flat Screwdriver [Ferrule] When connecting two ferrules to one terminal, use ferrules without insulation. Marking Plate Insulation 1.7 max. Marking Plate • Installing the marking plate on a nameplate Nameplate Note: When using a nameplate, the mounting panel thickness is 2.6 mm maximum. When using spade terminals or ferrules, insert them to the bottom. [Solid Wire] ø1.6 max. Panel Thickness 0.8 to 2.6 8.0 max. 8.0 max. 8.0 max. 3.2 Specifications and other descriptions in this catalog are subject to change without notice. 6-64, Nishi-Miyahara 2-Chome, Yodogawa-ku, Osaka 532-0004, Japan Tel: +81-6-6398-2571, Fax: +81-6-6392-9731 E-mail: marketing@idec.co.jp IDEC CORPORATION (USA) IDEC (SHENZHEN) CORPORATION Unit 2, Beechwood, Chineham Business Park, Basingstoke, Hampshire RG24 8WA, UK Tel: +44-1256-321000, Fax: +44-1256-327755 E-mail: sales@uk.idec.com Unit AB-3B2, Tian Xiang Building, Tian’an Cyber Park, Fu Tian District, Shenzhen, Guang Dong 518040, PRC Tel: +86-755-8356-2977, Fax: +86-755-8356-2944 IDEC CANADA LIMITED IDEC ELEKTROTECHNIK GmbH Wendenstrasse 331, 20537 Hamburg, Germany Tel: +49-40-25 30 54 - 0, Fax: +49-40-25 30 54 - 24 E-mail: service@idec.de Units G &H, 26/F., Tower No. 133 Hoi Bun Road, Kwun Tong, Kowloon Hong Kong Tel: +852-2803-8989, Fax: +852-2565-0171 E-mail: info@hk.idec.com 3155 Pepper Mill Court, Unit 4 Mississauga, Ontario, L5L 4X7, Canada Tel: +1-905-890-8561 Toll Free: (800) 262-IDEC (4332) Fax: +1-905-890-8562 E-mail: sales@ca.idec.com IDEC AUSTRALIA PTY. LTD. Unit 17, 104 Ferntree Gully Road, Oakleigh, Victoria 3166, Australia Tel: +61-3-8523-5900, Toll Free: 1800-68-4332 Fax: +61-3-8523-5999 E-mail: sales@au.idec.com www.idec.com IDEC ELECTRONICS LIMITED 1175 Elko Drive Sunnyvale, CA 94089-2209, USA Tel: +1-408-747-0550 / (800) 262-IDEC (4332) Fax: +1-408-744-9055 / (800) 635-6246 E-mail: opencontact@idec.com IDEC IZUMI (H.K.) CO., LTD. IDEC (SHANGHAI) CORPORATION IDEC TAIWAN CORPORATION Room 701-702 Chong Hing Finance Center, No. 288 Nanjing Road West, Shanghai 200003, PRC Tel: +86-21-6135-1515 Fax: +86-21-6135-6225 / +86-21-6135-6226 E-mail: idec@cn.idec.com 8F-1, No. 79, Hsin Tai Wu Road, Sec. 1, Hsi-Chih District, 22101 New Taipei City, Taiwan Tel: +886-2-2698-3929, Fax: +886-2-2698-3931 E-mail: service@tw.idec.com IDEC (BEIJING) CORPORATION No. 31, Tannery Lane #05-01, HB Centre 2, Singapore 347788 Tel: +65-6746-1155, Fax: +65-6844-5995 E-mail: info@sg.idec.com Room 211B, Tower B, The Grand Pacific Building, 8A Guanghua Road, Chaoyang District, Beijing 100026, PRC Tel: +86-10-6581-6131, Fax: +86-10-6581-5119 IDEC IZUMI ASIA PTE. LTD. Cat. No. EP1473-0 JULY 2013 PDF (13/07/23)
CW1P-1EQM4PW
物料型号:文档中提到了多种型号的开关和指示灯,例如CW1L-M1E02QH、CW1P-1EQH等,这些型号可能代表不同的配置和功能。
器件简介:文档介绍了IDEC公司的CW系列嵌入式轮廓开关,包括双接触块和单接触块。这些开关具有多种配置,如照明按钮、推动按钮、选择开关和钥匙选择开关。
引脚分配:文档中提到了不同开关的引脚分配,例如单接触块和双接触块的引脚编号和功能。
参数特性:开关的参数特性包括额定绝缘电压、额定热电流、额定工作电压和电流等。例如,一些开关的额定工作电压为24V AC/DC,额定电流为10A。
功能详解:文档详细解释了开关的功能,包括它们的操作类型(瞬时或维持)、照明颜色代码、接触配置等。
应用信息:CW系列开关适用于需要紧凑设备的应用场景,具有最短的面板后深度,可以与IDEC的FB和其他22mm控制箱一起使用,无需任何变压器即可适应任何电压。
封装信息:文档提供了开关的尺寸信息,包括安装孔径、操作行程、按钮或镜头的安装方法等。
CW1P-1EQM4PW 价格&库存
很抱歉,暂时无法提供与“CW1P-1EQM4PW”相匹配的价格&库存,您可以联系我们找货
CW1P-1EQM4PW
    • 1+318.173161+41.21456
