CW1X-USB20-1M
CW1X-USB20-1M
    IDEC(日本和泉)
    IDEC - CW1X-USB20-1M - USB 2.0 PORT BLACK BEZEL 51AH5774
CW1X-USB20-1M 数据手册
ø22 Flush Silhouette Switches CW Series USB/RJ45 Ports USB / RJ45 ports with flat stylish design New product addition for the flush silhouette switches RJ45 USB2.0 Flush silhouette Cable attached Accessories with IP65/67 protection Flush bezel projects only 2mm from the front of the panel. Ideal for applications where a safe and hygienic surface is required. Plasticencapsulatedstructureoftherear part prevents the cable from falling off. (USB port only) Rubber and transparent plastic covers available. Water- and dust-proof. Specification / Performance USB2.0 RJ45 Part No. CW1X-USB20-1M Connector standard USB2.0 compliant CW4X-USB20-1M Part No. CW1X-RJ45 No. of contacts 8 pin CW4X-RJ45 Operating temperature –25 to +70˚C (no freezing) Operating temperature –25 to +70˚C (no freezing) Storage temperature –25 to +70˚C (no freezing) Storage temperature –25 to +70˚C (no freezing) Storage temperature (when packaged) –10 to +50˚C (no freezing) Storage temperature (when packaged) –10 to +50˚C (no freezing) Relative humidity 0 to 90%RH (Max) (no condensation) Relative humidity 0 to 90%RH (Max) (no condensation) Connecting cycles 1,500 times Connecting cycles 750 times Connecting force 35N max. Removal force 10N min. ISO/IEC 11 801: 2002 EN 50 173-1: Cat.6 Class EA Transmission performance 10/100 Mbit Ethernet 1/10 Gbit Ethernet Locking screw recommended tightening 1.2 to 1.5 N·m torque Locking screw recommended tightening 1.2 to 1.5 N·m torque Bezel material PBT Cable AWG28, USB2.0, Standard cable, PVC shield (black) Bezel material PBT Protection degree IP20 IP65/67 (accessory attached) Protection degree IP20 IP65/67 (accessory attached) Ports Accessories Shape Bezel color Part No. Remarks Black CW1X-USB20-1M Name / Shape USB2.0 Material Color Part No. Protection Degree Black CW9Z-D1X1 IP65/67 [Lens] Polycarbonate [Main body] Translucent CW9Z-D1X2 Polyamide [Gasket] NBR IP65/67 Rubber cap Metallic CW4X-USB20-1M TPE Cable length: 1m Plastic cover USB2.0 TypeA RJ45 Black CW1X-RJ45 No. of contacts: 8 pin Note 1) Accessories can only be used for CW series ports (CW1X / CW4X). Note 2) F or the instruction sheet, read the QR code. Metallic CW4X-RJ45 Dimensions All dimensions in mm. USB2.0 RJ45 2 24 +0.2 1000 2 2.2 0 R0. 8m a 33.9 Potting MAX10 ø28 12 ±0.2 x. ø28 ø4.2 ø20 .4 +0 0 .3 ø22 ø24.1 +0.4 0 37 ±0.5 Panel thickness 1.5 to 5 Panel thickness 1.5 to 5 Panel cut-out Dimensions for Accessories Rubber cap CW9Z-D1X1 77.9 67.75 43 22 35 0.2 17.6 ø3 59 52.65 Plastic cover CW9Z-D1X2 4.3 5.1 6 29.9 Gasket (Thickness 0.4mm) • Panel thickness when CW9Z-D1X1/D1X2 is mounted: 1.5 to 5 mm 12.5 Recommended for use with the following products: Flush Silhouette Switches Programmable Logic Controller Flush Silhouette Switches Micro Smart FC6A Plus LB/LBW LW CW FC6A ø18.2 ø22.3 ø25.3 ø22 All-in-one 18.2 22.5 24.5 15 8.4 inch Flush bezel projecting only2.5mmfrompanel front, with short, 39.9 mm depth behind the panel.Third-generation safety structure. IDEC Corporation IDEC Izumi Asia Pte. Ltd. IDEC Asia (Thailand) Co., Ltd IDEC Australia Pty. Ltd. IDEC Taiwan Corporation Tel: +1-408-747-0550 Tel: +65-6746-1155 Tel: +66-2-392-9765 Tel: +61-3-8523-5900 Tel: +886-2-2577-6938 opencontact@idec.com info@sg.idec.com sales@th.idec.com sales@au.idec.com service@tw.idec.com inch 10.4 4.3 inch Create stylish panel with flushbezelsprojectingonly 2.0 mm from panel front. Easytoinstall/remove,and idealforpanelsthatrequire cleanliness and safety. inch 12.1 5.7 Plus The MicroSmart FC6A series is available in two types of CPUs: Plus and All-in-One. The Plus type has a dual RJ45 Ethernet port, embedded web server functions and the capability to expand up to 2060 I/O, while the All-in-One type has an embedded serial port and RJ45 Ethernet port capable of expanding up to 520 I/O. inch Excellent visibility by super-bright LED backlight. Withstands harsh environments, and suitable for use in a wide temperature range from cold to hot environment. www.idec.com Head Office 6-64, Nishi-Miyahara-2-Chome, Yodogawa-ku, Osaka 532-0004, Japan Hong Kong China/Shanghai China/Shenzhen China/Beijing Japan Specifications and other descriptions in this brochure are subject to change without notice. Information in this brochure is current as of September, 2019. 2019 IDEC Corporation, All Rights Reserved. EP1723-0 HG inch 18.2×24.2 LB series: Slim 2mm-thick bezels for stylish panels. LBW series: Projects only 2mm from the panel. Smart appearancewithlargesurface for secure operation. USA Singapore Thailand Australia Taiwan Operator Interface IDEC Izumi (H.K.) Co., Ltd. Tel: +852-2803-8989 IDEC (Shanghai) Corporation Tel: +86-21-6135-1515 IDEC (Shenzhen) Corporation Tel: +86-755-8356-2977 IDEC (Beijing) Corporation Tel: +86-10-6581-6131 IDEC Corporation Tel: +81-6-6398-2527 info@hk.idec.com idec@cn.idec.com idec@cn.idec.com idec@cn.idec.com marketing@idec.co.jp
CW1X-USB20-1M 价格&库存
很抱歉,暂时无法提供与“CW1X-USB20-1M”相匹配的价格&库存,您可以联系我们找货
