EB3C-R01AN
EB3C-R01AN
    IDEC(日本和泉)
    IDEC - EB3C-R01AN - Safety Barrier, Intrinsically Safe, EB3C Series, 1 Channel, Relay Output, 100 to...
EB3C-R01AN 数据手册
EB3C Relay Barriers Input contacts can be used in any explosive gas and Zone 0/Class I Div. 1 areas. Explosion protection Relay Barrier: [Exia] II C Switch (EB9Z-A): Exia II CT6 Switch (EB9Z-A1): Exia II BT6 ••IEC60079 compliant. ••Wide variety of models ranging from 1-circuit to 16 circuit types. ••8- and 16-channel are available in common wiring, ideal for connection to PLCs. 16-circuit also available with a connector. ••No grounding required. ••IDEC’s original spring-up terminal minimizes wiring time. ••35-mm-wide DIN rail mounting or direct screw mounting. ••Global usage IECEx USA: FM, UL Europe: CE marking, ATEX China: CQST Korea: KCS Taiwan TS Japan: TIIS ••Ship class: NK (Japan), KR (Korea) Connector Type Relay Barriers Power Voltage Connection to Non-intrinsically Safe Circuit Input Wiring Method Number of Channels Output Separate/Common Wiring Compatible Relay Common Wiring Only 100 to 240V AC Separate/Common Wiring Compatible Transistor (Sink/Source) Transistor (Sink) Common Wiring Only Transistor (Source) Screw Terminal Separate/Common Wiring Compatible Relay Common Wiring Only 24V DC Separate/Common Wiring Compatible Transistor (Sink/Source) Sink Common Wiring Only Connector T-4 Transistor Source Sink Source 1 2 3 5 6 8 10 8 1 2 3 5 6 8 10 8 16 8 16 1 2 3 5 6 8 10 8 16 1 2 3 5 6 8 10 8 16 8 16 16 Part No. EB3C-R01AN EB3C-R02AN EB3C-R03AN EB3C-R05AN EB3C-R06AN EB3C-R08AN EB3C-R10AN EB3C-R08CAN EB3C-T01AN EB3C-T02AN EB3C-T03AN EB3C-T05AN EB3C-T06AN EB3C-T08AN EB3C-T10AN EB3C-T08CKAN EB3C-T16CKAN EB3C-T08CSAN EB3C-T16CSAN EB3C-R01DN EB3C-R02DN EB3C-R03DN EB3C-R05DN EB3C-R06DN EB3C-R08DN EB3C-R10DN EB3C-R08CDN EB3C-R16CDN EB3C-T01DN EB3C-T02DN EB3C-T03DN EB3C-T05DN EB3C-T06DN EB3C-T08DN EB3C-T10DN EB3C-T08CKDN EB3C-T16CKDN EB3C-T08CSDN EB3C-T16CSDN EB3C-T16CKD-CN EB3C-T16CSD-CN Weight (g) 150 180 190 260 270 300 380 280 140 170 180 250 260 320 340 260 260 260 260 130 170 180 250 260 260 360 270 390 120 160 170 240 250 250 320 250 350 250 350 330 330 EB3C Relay Barriers Accessories Name Part No. BAA1000 BAP1000 BNL6 EB9Z-N1 DIN Rail End Clip Static Electricity Caution Plate Ordering No. BAA1000PN10 BAP1000PN10 BNL6PN10 EB9Z-N1PN10 Explosion-Protection and Electrical Specifications Explosion Protection Intrinsic safety type Degree of Protection IP20 (IEC60529) Safe indoor place (safe area: non-hazardous area) For zone 0, 1, 2 hazardous areas Installation Location Relay Barrier Switch Non-intrinsically Safe Circuit Maximum Voltage (Um) Intrinsically Safe Circuits 227.2 mA 750 mW Allowable Wiring Resistance (Rw) 300Ω 600/(N+1)Ω (N = number of common channels) – 16 Relay Output Contact Resistance 50 mΩ maximum (initial value) Turn ON Time Turn OFF Time 12 ms maximum (rated voltage) 10 ms maximum (rated voltage) 20,000,000 operations minimum (at 18,000 operations/hour, without load) 100,000 operations minimum (at 1,800 operations/hour, rated load) None 24V DC 30V DC 100 mA (connector type: 15 mA) 0.1 mA maximum 1.5 V maximum 33V (1W) 0.5A maximum (1 sec) 0.1 ms maximum (resistive load) 0.4 ms (typical) (resistive load) None Inductive Load Mechanical Life Electrical Life Transistor Output 0.6 mH (0.425 mH) Minimum Applicable Load Resistive Load Short-circuit Protection Rated Voltage Maximum Voltage Maximum Current Leakage Current Voltage Drop Clamping Voltage Inrush Current Turn ON Time Turn OFF Time Short-circuit Protection FM UL PTB (ATEX) CQST KCS TIIS 490 nF (365 nF) 1NO 250V AC, 125V DC 3A (common terminal: 8A) AC: 750 VA, DC: 72W AC: 750 VA (cos ø = 0.3 to 0.4) DC: 48W (L/R = 7 ms) 250V AC 3A, 24V DC 3A 250V AC 3A (cos ø = 0.3 to 0.4) 24V DC 2A (L/R = 7 ms) 0.1V DC, 0.1 mA (reference value) Rated Load Certification Organization PTB (IECEx) Rated Operating Voltage Rated Operating Current Maximum Output Voltage (Uo) Maximum Output Current (lo) Maximum Output Power (Po) Maximum External 470 nF (470 nF) Capacitance (Co) (Note 1) Maximum External Inductance (Lo) 87.5 mH (87.5 (Note 2) mH) Maximum Channels per Common Line Contact Configuration Rated Insulation Voltage (Ui) Thermal Current (lth) Resistive Load Contact Allowable Inductive Load Power Non-intrinsically Safe Circuits 16-channel Common Wiring Description Aluminum (1m long) Steel (1m long) For fastening EB3C units on the DIN rail. Polyester 20 (W) x 6 (H) mm Certification No. 250V AC 1-channel Separate Wiring 12V DC ±10% 10 mA DC ±20% 13.2V DC 14.2 mA 46.9 mW Wiring Method Package Quantity 10 10 10 10 NK KR Explosion Protection Class I, II, III Div. 1 Group A, B, C, D, E, F, G Class I, Zone 0 AEx [ia] II C Class I, II, III, Div. 1 Group A, B, C, D, E, F, G Class I, Zone 0 AEx [ia] II C [Exia] II C: Gas, Vapour [Exia] III C: Dust [Exia] II C: Gas, Vapour [Exia] III C: Dust [Exia Ga] II C [Exia] II C Relay barrier: [Exia] II C Switch (EB9Z-A): Exia II CT6 Switch (EB9Z-A1): Exia II BT6 [Exia] II C [Exia] II C Certification No. 3047250 Switches & Pilot Lights Flush Silhouette Switches Emergency Stop Switches Control Stations Display Lights E234997 PTB09 ATEX2046 IECEx PTB10.0015 CNEx14.0047 14-AV4B0-0373 TC20539 TC15758 TC15961 Type Test No. 13T606 TYK17821-EL003 Operator Interfaces PLCs Softwares Relays Note: For details about switches, see “Switch Explosion-Protection Specifica­tions” on page T-6 and “3. Switches in the Hazardous Area” on page T-10. Sockets General Specifications Timers Power Voltage Rated Power Voltage Allowable Voltage Range AC Power 100 to 240V AC 24V DC DC Power –15 to +10% ±10% 50/60 Hz (allowable range: — 47 to 63 Hz) 10A (100V AC) Inrush Current 10A 20A (200V AC) Between intrinsically safe circuit and non-intrinsically safe circuit: 1526.4V AC Dielectric Strength Between AC power and output terminal: 1500V AC (1 minute, 1 mA) Between DC power and transistor output terminal: 1000V AC (screw terminal type only) Operating Temperature –20 to +60°C (no freezing) Storage Temperature –20 to +60°C (no freezing) Operating Humidity 45 to 85% RH (no condensation) Atmosphere 800 to 1100 hPa Pollution Degree 2 (IEC60664) 10 MΩ minimum (500V DC megger, between the same Insulation Resistance poles as the dielectric strength) Panel mounting: 10 to 55 Hz, amplitude 0.75 mm Vibration Resistance (damage limits) DIN rail mounting: 10 to 55 Hz, amplitude 0.35 mm Panel mounting: 500 m/s2 (3 times each on X, Y, Z) Shock Resistance (damage limits) DIN rail mounting: 300 m/s2 (3 times each on X, Y, Z) Terminal Style M3 screw terminal Mounting 35-mm-wide DIN rail or panel mounting (M4 screw) Power Consumption 9.6 VA (EB3C-R10AN at 200V AC) (approx.) 4.8W (EB3C-R16CDN at 24V DC) Rated Frequency Terminal Blocks Circuit Protectors Power Supplies Sensors Ex-proof Control Boxes Barriers LEDs Safety Products Information Note: Values in ( ) are those approved by TIIS (Technology Institution of Industrial Safety, Japan). T-5 EB3C Relay Barriers Switch Explosion-Protection Specifications (Japan only) Simple apparatuses in accordance with relevant standards of each country can be installed in the hazardous area and connected to the EB3C located in the safe area. In Japan, any switches, though regarded as simple apparatuses, must be certified for explosion-proof devices. EB9Z-A and EB9Z-A1 are IDEC’s generic Part No. of any single apparatuses certified by TIIS for use with the EB3C, therefore simple appa­ratuses with specifications shown below can be used as those approved by the Japanese explosion-proof certification. Switch Part No. Explosion Proof (Note 1) Operating Temperature Operating Humidity Degree of Protection Dielectric Strength EB9Z-A EB9Z-A1 Exia II CT6 Exia II BT6 –20 to +60°C (no freezing) 45 to 85% RH (no condensation) IP20 500V AC, 1 mA 16-channel Common Wiring 1-channel Separate Wiring Maximum input voltage (Ui): 13.2V Maximum input voltage (Ui): 13.2V Maximum input current (Ii): 227.2 mA Maximum input current (Ii): 14.2 mA Maximum input power (Pi): 750 mW Maximum input power (Pi): 46.9 mW Internal capacitance (Ci): ≤ 32 nF Internal capacitance (Ci): ≤ 2 nF Internal inductance (Li): ≤ 80 µH Internal inductance (Li): ≤ 5 µH Metallic: Magnesium content must be 7.5% or less (steel and aluminum are acceptable) Intrinsic Safety Ratings and Parameters Caution Plastic: Switch operator exposed area IIC: 20 cm2 maximum IIB: 100 cm2 maximum When the switch has a wider exposed area, attach a caution label as shown at right. Enclosure Material To prevent electrostatic charges, do not rub the switch surface during operation. Use a soft cloth dipped with water for cleaning. Caution Label Example Contact rating: Ui, Ii minimum Contact resistance: 0.5Ω maximum Cross sectional area of wire: 0.000962 mm2 minimum Printed circuit board: Thickness 0.5 mm minimum Copper foil width 0.15 mm minimum Thickness 18 µm minimum one/both side(s) A resistor to prevent contact welding and an LED can be connected to 1-channel separate wiring circuits. Consult IDEC for details. Switch Ratings (Note 2) Note 1: See “Precautions for Operation” on page T-10. Note 2: For details, see “3. Switches in the Hazardous Area” on page T-10. Internal Circuit Block Diagram AC Power, Relay Output DC Power, Transistor Output Connector Wiring, Sink Output Hazardous Area • • • • • • • • P1 N1 P2 N2 P3 N3 P1 N1 P2 N2 P3 N3 Yellow Green Yellow Yellow Green Yellow Yellow Green ~ ~ ~ ~ L Yellow P1 • • • • P16 N1 + N A1 C1 A2 C2 A3 C3 Yellow N2 Safe Area (Non-hazardous Area) Yellow ~ ~ ~ – A1 C1 A2 C2 A3 C3 + – A1 • • • • A16 C1 C2 Dimensions Connector Type EB3C-T16C-CN M3 ø6 Applicable Crimping Terminal Solid Wire 97 Mounting Hole Layout 6 to 8 mm 65 (4) 77.5 97 10 5.4 min. Stripping the Wire End 4-M4 or 4-4.5 holes 6 T-6 3 max. 83.5 10 ø3.2 min. 6 max. 75 4- 4.5 hole 65 171.5 Stranded Wire (Ferrule) 6 to 8 mm All dimensions in mm. EB3C Relay Barriers EB3C-∗03N EB3C-∗02N 42 EB3C-∗06N EB3C-∗05N EB3C-∗08CN 65 Switches & Pilot Lights EB3C-∗10N EB3C-∗08N EB3C-∗16CN 110.5 77.5 171.5 ø4.4 Screw Terminal EB3C-∗01N Flush Silhouette Switches 65 61 75 Emergency Stop Switches (4) M3 ø6 hole Display Lights 77.5 Operator Interfaces PLCs 4 6 Control Stations 10 10 10 10 10 Softwares Mounting Hole Layout (Screw Mounting) 2-M4 tapped or 2-ø4.5 mounting holes 28 2-M4 tapped or 2-ø4.5 mounting holes 4-M4 tapped or 4-ø4.5 mounting holes 97 97 51 65 2-M4 tapped or 2-ø4.5 mounting holes 65 Relays Sockets Timers Terminal Blocks External Wiring Examples Circuit Protectors Transistor Output (Ex.: EB3C-T06AN) Transistor Sink Output (Ex.: EB3C-T08CKDN) Transistor Source Output (Ex.: EB3C-T08CSDN) Power Supplies P1 N1 P2 N2 P3 N3 P4 N4 P5 N5 P6 N6 Note: On the sink/source transistor output type, ter­minals A can be used as a positive common line. Relay Output (Ex.: EB3C-R06AN) Load Load Load Load Ex-proof Control Boxes Load A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 Load 24V DC Sensors Load – Load Power 24V DC Load Load Load Load Load 24V DC + A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 Load Load Power 24V DC – Load + Load Load Load Load Load 100 to 240V AC A1 C1 A2 C2 A3 C3 A4 C4 A5 C5 A6 C6 Load N Load L P1 P2 P3 P4 P5 P6 P7 P8 N1 N2 Load P1 P2 P3 P4 P5 P6 P7 P8 N1 N2 Load Power 24V DC Barriers LEDs Relay Output Common Wiring (Ex.: EB3C-R16CDN) Safety Products P1 N1 P2 N2 P3 N3 P4 N4 P5 N5 P6 N6 P4 P5 P6 P7 P8 N1 N2 P9 P10 P11 P12 P13 P14 P15 P16 N3 N4 A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 A9 A10 A11 A12 A13 A14 A15 A16 C3 C4 Information Load Load Load Load Load Load Load Load Load Load Load Load 24V DC Load Load Load Load Load Load Load – Load Power AC/DC Load A1 C1 A2 C2 A3 C3 A4 C4 A5 C5 A6 C6 + 100 to 240V AC P3 Load N P2 Load L P1 Load Power AC/DC T-7 EB3C Relay Barriers Connector Type Output Wiring Diagram EB3C-T16CKD-CN (Sink) Wiring Example with IDEC’s MicroSmart PLC Input Modules CH9 CH10 CH11 CH12 CH13 CH14 CH15 CH16 A9 A10 A11 A12 A13 A14 A15 A16 NC NC 19 1 20 2 A8 C1 C2 CH1 CH2 CH3 CH4 CH5 CH6 CH7 CH8 +V COM A1 A2 A3 A4 A5 A6 A7 EB3C + An – COM PLC COM Internal Circuit Internal Circuit +V (C1) + CHn A1-A16 Input I0-I15 COM (C2) EB3C-T16CSD-CN (Source) CH9 CH10 CH11 CH12 CH13 CH14 CH15 CH16 A9 A10 A11 A12 A13 A14 A15 A16 NC NC 19 1 20 2 A8 C1 C2 CH1 CH2 CH3 CH4 CH5 CH6 CH7 CH8 –V COM A1 A2 A3 A4 A5 A6 A7 EB3C CHn – An + COM PLC EB3C-T16CSD-CN FC4A-N16B3 Input Terminal Terminal Output Input Terminal 20 A1 I0 20 20 A1 I0 20 19 A9 I10 19 19 A9 I10 19 18 A2 I1 18 18 A2 I1 18 17 A10 I11 17 17 A10 I11 17 16 A3 I2 16 16 A3 I2 16 15 A11 I12 15 15 A11 I12 15 14 A4 I3 14 14 A4 I3 14 13 A12 I13 13 13 A12 I13 13 12 A5 I4 12 12 A5 I4 12 11 A13 I14 11 11 A13 I14 11 10 A6 I5 10 10 A6 I5 10 9 A14 I15 9 9 A14 I15 9 8 A7 I6 8 8 A7 I6 8 7 A15 I16 7 7 A15 I16 7 6 A8 I7 6 6 A8 I7 6 5 A16 I17 5 5 A16 I17 5 4 +V COM 4 4 –V COM 4 3 NC COM 3 3 NC COM 3 2 COM NC 2 2 COM NC 2 1 NC NC 1 1 NC NC 1 Input I0-I15 Internal Circuit Internal Circuit A1-A16 FC4A-N16B3 Note: The wiring in dashed line does not affect the operation of the EB3C. Applicable connector is IDEC’s JE1S-201. Input power for PLC inputs is supplied by the EB3C, therefore the PLC input does not need an external power supply. COM (C2) + EB3C-T16CKD-CN Terminal Output COM Wiring Example of Intrinsically Safe External Inputs 1. Common Wiring (Maximum 16 circuits) P1 N1 P2 N2 P3 N3 P4 N4 P5 N5 P6 N6 L N A1 C1 A2 C2 A3 C3 A4 C4 A5 C5 A6 C6 N N N P1 P2 P3 P4 P5 P6 P7 P8 N1 N2 P1 N1 P2 N2 P3 N3 L N A1 C1 A2 C2 A3 C3 N L N A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 P1 N1 N2 L N A1 C1 C2 N L N A1 P1 C1 N1 A2 P2 C2 N2 A3 P3 C3 N3 A4 P4 C4 N4 A5 P5 C5 N5 A6 P6 C6 N6 A7 P7 C7 N7 A8 P8 C8 N8 A9 P9 C9 N9 A10 P10 C10 N10 P1 P2 P3 P4 P5 P6 P7 P8 N1 N2 P9 P10 P11 P12 P13 P14 P15 P16 N3 N4 L N A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 A9 A10 A11 A12 A13 A14 A15 A16 C3 C4 All input lines are wired to a common line inside the intrinsically safe switch (one common line per intrinsically safe circuit). N N N N P1 P2 P3 P4 P5 P6 P7 P8 N1 N2 L N A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 P1 N1 P2 N2 P3 N3 P4 N4 P5 N5 P6 N6 L N A1 C1 A2 C2 A3 C3 A4 C4 A5 C5 A6 C6 N L N A1 P1 C1 N1 A2 P2 C2 N2 A3 P3 C3 N3 A4 P4 C4 N4 A5 P5 C5 N5 A6 P6 C6 N6 A7 P7 C7 N7 A8 P8 C8 N8 A9 P9 C9 N9 A10 P10 C10 N10 P1 N1 P2 N2 P3 N3 P1 N1 N2 L N A1 C1 C2 N L N A1 C1 A2 C2 A3 C3 P1 P2 P3 P4 P5 P6 P7 P8 N1 N2 P9 P10 P11 P12 P13 P14 P15 P16 N3 N4 L N A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 A9 A10 A11 A12 A13 A14 A15 A16 C3 C4 Some input lines are wired to a common line inside the intrinsically safe switches, while others are outside switches (one common line per intrinsically safe circuit). N P1 N1 P2 N2 P3 N3 P4 N4 P5 N5 P6 N6 L N A1 C1 A2 C2 A3 C3 A4 C4 A5 C5 A6 C6 N 2. Separate Wiring T-8 Each input line of the EB3C makes up one independent intrinsically safe circuit. N N P1 P2 P3 P4 P5 P6 P7 P8 N1 N2 P1 N1 P2 N2 P3 N3 L N A1 C1 A2 C2 A3 C3 N L N A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 P1 N1 N2 L N A1 C1 C2 N L N A1 P1 C1 N1 A2 P2 C2 N2 A3 P3 C3 N3 A4 P4 C4 N4 A5 P5 C5 N5 A6 P6 C6 N6 A7 P7 C7 N7 A8 P8 C8 N8 A9 P9 C9 N9 A10 P10 C10 N10 P1 P2 P3 P4 P5 P6 P7 P8 N1 N2 P9 P10 P11 P12 P13 P14 P15 P16 N3 N4 L N A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 A9 A10 A11 A12 A13 A14 A15 A16 C3 C4 All input lines are wired to a common line outside the intrinsically safe switch (one common line per intrinsically safe circuit). N P1 N1 P2 N2 P3 N3 P4 N4 P5 N5 P6 N6 L N A1 C1 A2 C2 A3 C3 A4 C4 A5 C5 A6 C6 P1 P2 P3 P4 P5 P6 P7 P8 N1 N2 P1 N1 P2 N2 P3 N3 L N A1 C1 A2 C2 A3 C3 N L N A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 P1 N1 N2 L N A1 C1 C2 N N L N A1 P1 C1 N1 A2 P2 C2 N2 A3 P3 C3 N3 A4 P4 C4 N4 A5 P5 C5 N5 A6 P6 C6 N6 A7 P7 C7 N7 A8 P8 C8 N8 A9 P9 C9 N9 A10 P10 C10 N10 P1 P2 P3 P4 P5 P6 P7 P8 N1 N2 P9 P10 P11 P12 P13 P14 P15 P16 N3 N4 L N A1 A2 A3 A4 A5 A6 A7 A8 C1 C2 A9 A10 A11 A12 A13 A14 A15 A16 C3 C4 N EB3C Relay Barriers N N Switches & Pilot Lights 2. Separate Wiring Each input line of the EB3C makes up one independent intrinsically safe circuit. P1 N1 P2 N2 P3 N3 P1 N1 P2 N2 P3 N3 P4 N4 P5 N5 P6 N6 L N A1 C1 A2 C2 A3 C3 L N A1 C1 A2 C2 A3 C3 A4 C4 A5 C5 A6 C6 N N N Diagram Symbols Emergency Stop Switches L N A1 P1 C1 N1 A2 P2 C2 N2 A3 P3 C3 N3 A4 P4 C4 N4 A5 P5 C5 N5 A6 P6 C6 N6 A7 P7 C7 N7 A8 P8 C8 N8 A9 P9 C9 N9 A10 P10 C10 N10 P1 N1 N2 L N A1 C1 C2 Flush Silhouette Switches Control Stations N Serial-Parallel Connection of Switches Contacts in one switch (EB9Z-A or EB9Z-A1) Notes • As shown in the diagram on the left, a required number of “contacts in one switch” (3 contacts in the example at left) can be added to the “contacts in one switch” connected to one input channel. • Similarly, a required number of “contacts in one switch” can be added to a common line connected to multiple input channels. • The capacitance and inductance of the added “contacts in one switch” must be included in the calculation of the wiring capacitance and inductance in “Precautions for Operation, 5. Wiring for Intrinsic Safety, (7)” on page T-11. • In addition, a required number of contacts can be added in the enclosure of “contacts in one switch.” In this case, however, do not include the capacitance and inductance in the calculation of the wiring capacitance and inductance on page T-11. Instead, make sure that the internal capacitance (Ci) and internal inductance (Li) are within the values shown in the table “Switch Explosion-Protection Specifications (Japan only)” on page T-6. L N A1 C1 C2 P1 N1 N2 One intrinsically safe circuit (maximum 16 circuits) No. of Poles With Shield I/O Terminal Cable Without Shield 20 Cable with Crimping Terminal Length (m) Part No. 0.5 FC9Z-H050A20 1 FC9Z-H100A20 2 FC9Z-H200A20 3 FC9Z-H300A20 0.5 FC9Z-H050B20 1 FC9Z-H100B20 2 FC9Z-H200B20 3 FC9Z-H300B20 1 BX9Z-H100E4 2 BX9Z-H200E4 Operator Interfaces PLCs Softwares Relays Sockets Recommended Connector Cable for Connector Types Description Display Lights shape Applicable Type Timers IDEC MicroSmart I/O Module Terminal Blocks Circuit Protectors IDEC MicroSmart I/O Module Power Supplies 200 Screw Terminal 2 1 40-pin Cable for PLC 3 BX9Z-H300E4 1 BX9Z-H100L 2 BX9Z-H200L 3 BX9Z-H300L Sensors 350 Connector B 10 0 Connector A Mitsubishi A Series Input Module (positive common) ↓ EB3C-T16CKD-CN Ex-proof Control Boxes Barriers FC9Z-HA, FC9Z-HB Internal Connection Fujitsu Connector IDEC Connector FCN-367J024-AU/F JE1S-201 19 20 17 18 15 16 13 11 14 12 9 10 7 8 5 6 3 4 1 2 (Connecting Side) (Connection Side) IDEC Connector IDECJE1S-20111 Connector JE1S-201 BX9Z E4 Internal Connection IDEC Connector JE1S-201 IDEC Connector JE1S-201 19 20 1 2 17 18 3 4 15 16 5 6 13 14 7 8 9 10 11 12 9 10 7 8 5 6 3 4 1 2 (Connecting Side) (Connection Side) 11 12 13 14 15 16 17 18 19 20 BX9Z-HL Internal Connection Fujitsu Connector FCN-367J040-AU/F B A Y-shaped Compresion Terminal Y-shaped Compresion (Marking Tube No.)Terminal 1 1 2 2 3 3 2 4 4 4 5 5 6 6 6 7 7 8 8 9 9 (Marking Tube No.) 1 3 5 7 9 11 13 15 17 19 8 10 12 Connector A IDEC JE1S-201 14 2 1 16 4 3 18 6 5 20 8 7 10 9 (Connecting Side) LEDs 12 11 14 13 16 15 18 17 20 19 (Connecting Side) Safety Products Information Connector B IDEC JE1S-201 10 10 11 11 2 1 12 12 4 3 13 13 6 5 14 14 8 7 15 15 10 9 16 16 12 11 17 17 14 13 18 18 16 15 19 19 18 17 20 20 20 19 (Connecting Side) (Connecting Side) T-9 EB3C Relay Barriers Precautions for Operation 1. Installation of EB3C Relay Barriers (1) The EB3C can be installed in any direction. 3. Switches in the Hazardous Area (For Japan application only) (2) Install the EB3C relay barrier in a safe area (non-hazardous area) in accordance with intrinsic safety ratings and param­ eters. To avoid mechanical shocks, install the EB3C in an enclosure which suppresses shocks. (1) A switch contains the switch contact, enclosure, and internal wiring. A switch contact refers to an ordinary switching device which consists of contacts only, such as a pushbut­ton switch. See below. (3) When installing or wiring the EB3C, prevent electromagnetic and electrostatic inductions in the intrinsically safe circuit. Also prevent the intrinsically safe circuits from contacting with another intrinsically safe circuit and any other circuits. Maintain at least 50 mm clearance, or provide a metallic separating board between the intrinsically safe circuit and non-intrinsically safety circuit. When providing a metallic separating board, make sure that the board fits closely to the enclosure (top, bottom, and both sides). Allowable clear­ance between the enclosure and board is 1.5 mm at the maximum. The clearance of 50 mm between the intrinsically safe cir­ cuit and non-intrinsically safe circuit may not be sufficient when a motor circuit or high-voltage circuit is installed nearby. In this case, provide a wider clearance between the circuits referring to 5 (3) “Minimum Parallel Distance between the Intrinsically Safe Circuit and Other Circuits.” (4) In order to prevent contact between intrinsically safe circuits and non-intrinsically safe circuits, mount EB3C units with terminals arranged in the same direction. Intrinsically Safe Circuit EB3C EB3C EB3C Control Switches Sensing Switches Push-pull Switches Pushbutton, Foot, Trigger, Rocker, Grip Twisting Switches Rotary, Selector, Cam, Drum, Thumb wheel Lever and Slide Switches Toggle, Multidirectional, Wobble stick, Lever, Slide switch Displacement Switches Microswitch, Limit, Magnetic proximity, Door, Reed, Mercury Level Switches Liquid level Others Pressure, Temperature Note: For installation in hazardous areas and connection to the EB3C, use switches which are certified, approved, or considered to be simple apparatus in relevant standards in each country. (2) When the switch has internal wiring or lead wire, make sure that the values of internal inductance (Li) and capacitance (Ci) are within the certified values. (3) Enclose the switch contact’s bare live part in an enclosure of IP20 or higher protection. (4) Depending on the explosion-protection specifications according to TIIS, the exposed area of plastic switch opera­ tor is limited as follows: • Exia II CT6 (EB9Z-A): 20 cm2 maximum • Exia II BT6 (EB9Z-A1): 100 cm2 maximum (5) Attach the certification mark supplied with the EB3C on the EB9Z-A or EB9Z-A1 switch (for Japan application). (6) When the switch operator of plastic enclosure has a wider exposed area than the following limits, attach a caution label as shown below. Caution EB3C Non-intrinsically Safe Circuit Applicable Switches EB3C Intrinsically Safe Circuit (5) Maintain at least 6 mm (or 3 mm according to IEC60079-11: 1999) clearance between the terminal of intrinsically safe circuit and the grounded metal part of a metal enclosure, and between the relay terminal block of an intrinsically safe circuit and the grounded metal part of a metal enclosure. (6) For installing the EB3C, mount on a 35-mm-wide DIN rail or directly on a panel using screws. Make sure to install securely to withstand vibration. When mounting on a DIN rail, push in the clamp completely. Use the BNL6 end clips on both sides of the EB3C to prevent from moving sideways. (7) Excessive extraneous noise may cause malfunction and damage to the EB3C. When extraneous noise activates the voltage limiting circuit (thyristor), remove the noise source and restore the power. To prevent electrostatic charges, do not rub the switch surface during operation. Use a soft cloth dipped with water for cleaning. II C: 20 cm2 maximum II B: 100 cm2 maximum Caution Label Example (7) For the 1-circuit separate wiring, a resistor to prevent reed switch contact welding and an LED miniature pilot lights can be connected in series with the contact. See below. Use the terminal screw of M3 or larger. Applicable Resistor Ratings Resistance 100Ω maximum Rated Wattage 0.5 to 3W Type Metal (oxide) film resistors R 2. Terminal Wiring Reed Switch (1) Using a ø5.5 mm or smaller screw driver, tighten the termi­ nal screws (including unused terminal screws) to a torque of 0.6 to 1.0 N·m (recommended value). Terminal Block (2) Make sure that IP20 is achieved when wiring. Use insulation tubes on bare crimping terminals. (3) To prevent disengaged wires from contacting with other intrinsically safe circuits, bind together the wires of one intrinsically safe circuit. (4) When the adjacent terminal is connected to another intrinsi­ cally safe circuit, provide an insulation distance of at least 6 mm. T-10 EB3C Applicable LED IDEC’s IPL1 series LED miniature pilot lights. See pages T-14 and T-17. EB3C Relay Barriers Precautions for Operation 4. Output Specifications (1) When wiring the output from the EB3C, connect the nonintrinsically safe circuit to terminals A and C. The EB3C out­put circuit is not equipped with short-circuit protection. If required, provide a protection in the external circuit. (2) Relay Output Some types of loads generate reverse emf (such as sole­ noids) or cause a large inrush current (incandescent lamps), resulting in a shorter operation life of output relay contacts. The operation life of contacts can be extended by preventing the reverse emf using a diode, RC, or varistor, or by suppressing the inrush current using a resistor or RL. Contacts are made of gold-clad silver. When using at a small current and a low voltage (reference value: 0.1 mA, 0.1V), test the contact on the actual circuit in advance. (3) Transistor Output When connecting a small load, the load may not turn off because of a leakage current, even though the transistor output is turned off. If this is the case, connect a resistor in parallel with the load to bypass the leakage current. When an excessively high voltage (clamps at 33V, 1W) or a reverse voltage is applied to the output terminals, the clamping circuit or output transistor may be damaged. When driving an inductive load, be sure to connect a diode across the load to absorb reverse emf. Load An ∗ Cn ∗: Surge Absorber Example of Overvoltage Absorption Circuit (4) In the common wiring only types, the output terminals are not isolated from each other. (5) When connecting the connector type EB3C’s in parallel, use one power supply to power the EB3C’s. Do not connect any wiring to the C1 and C2 terminals. 5. Wiring for Intrinsic Safety (1) The voltage applied on the general circuit connected to the non-intrinsically safe circuit terminals of the EB3C relay bar­rier must be 250V AC, 50/60Hz, or 250V DC at the maxi­ mum under any conditions, including the voltage of the input power and the internal circuit. (2) When wiring, take into consideration the prevention of elec­tromagnetic and electrostatic charges on intrinsically safe circuits. Also, prevent intrinsically safe circuits from contact­ing with other circuits. (3) The intrinsically safe circuits must be separated from nonintrinsically safe circuits. Contain intrinsically safe circuits in a metallic tube or duct, or separate the intrinsically safe cir­cuits referring to the table below. Note: Cables with a magnetic shield, such as a metallic sheath, prevent electromagnetic induction and electrostatic induction, however, a non-magnetic shield prevents electrostatic induction only. For non-magnetic shields, take a preventive measure against electro­magnetic induction. Voltage and Current of Other Circuits Over 440V 440V or less 220V or less 110V or less   60V or less Over 100A 2000 2000 2000 2000 2000 100A or less 2000  600  600  600  500 50A or less 2000  600  600  500  300 10A or less 2000  600  500  300  150 Flush Silhouette Switches Emergency Stop Switches Control Stations (4) When identifying intrinsically safe circuits by color, use light blue terminal blocks and cables. Display Lights (5) When using two or more EB3C’s to set up one intrinsically safe circuit in the common wiring configuration, interconnect two neutral terminals (N1 through N10) on each EB3C between adjacent EB3C’s in parallel. Operator Interfaces (6) Make sure that the power of the EB3C and contact are turned off before starting inspection or replacement. (7) When wiring the intrinsically safe circuit, determine the dis­ tance to satisfy the wiring parameters shown below. Note that parameters are different between separate wiring and common wiring. a) Wiring capacitance Cw ≤ Co – (Ci + N × 2 nF) Co: Maximum external capacitance of the EB3C Ci: Internal capacitance of the switch N: The number of switches connected in series or parallel (the number is infinite) PLCs Softwares Relays Sockets b) Wiring inductance Lw ≤ Lo – (Li + N × 5 µH) Lo: Maximum external inductance of the EB3C Li: Internal inductance of the switch N: The number of switches connected in series or parallel (the number is infinite) Timers c) Wiring resistance ≤ Rw Rw: Allowable wiring resistance d) Allowable wiring distance D (km) is the smallest value of those calculated from the capacitance, inductance, and resistance. Circuit Protectors D ≤ Cw/C C (nF/km): Capacitance of cable per km D ≤ Lw/L L (mH/km): Inductance of cable per km D ≤ Rw/2R R (Ω/km): Resistance of cable per km Note: For the details of wiring the intrinsically safe circuits, refer to a rel­evant test guideline for explosion-proof electric equipment in each country. Terminal Blocks Power Supplies Sensors Ex-proof Control Boxes (8) Applicable Wire Size 0.5 to 2.0 mm2 (AWG20 to AWG14): two wires However, one wire for 2.0 mm2 (AWG14) Barriers Mounting Bracket LEDs The following mounting brackets can be used to install the EB3C relay barriers and EB3L lamp barriers on the mounting holes of IBRC contact signal transducer, IBPL pilot relay barrier, and IBZ buzzer. No. of Channels Part No. 1 2 3 5 6 10 EB9Z-K01 EB9Z-K02 EB9Z-K03 EB9Z-K05 EB9Z-K06 EB9Z-K10 Dimensions C B A Finely twisted pair cables prevent electromagnetic induc­ tion. Adding shields to the twisted pair cables provides pro­ tection against electrostatic induction. Dimension (mm) A B C 28.0 44.0 61.0 51.0 59.5 76.0 51.0 75.0 91.5 97.0 105.0 122.0 97.0 120.0 137.0 97.0 181.0 198.0 ø5 (four) Safety Products Information 7 M4 (two or four) ∗ 140 126 90 65 Minimum Parallel Distance between the Intrinsically Safe Circuit and Other Circuits (mm) Switches & Pilot Lights ∗ ∗: EB9Z-K10 only All dimensions in mm. T-11
EB3C-R01AN 价格&库存
很抱歉,暂时无法提供与“EB3C-R01AN”相匹配的价格&库存,您可以联系我们找货
EB3C-R01AN
    • 1+1936.30721
    库存:7
