FC4A-R161
FC4A-R161
    IDEC(日本和泉)
FC4A-R161 数据手册
Programmable Logic Controllers MicroSmart Series MicroSmart Key features of the MicroSmart series include: • 10, 16, or 24 I/O All-in-one type CPU modules with Sink/ Source DC input and Relay Output • 20 I/O Slim type CPU modules with Sink/Source DC input and Transistor Sink or Source Output • 20 I/O Slim type CPU modules with Sink/Source DC input and Relay Output with high-speed Transistor Sink or Source Output • 40 I/O Slim type CPU modules with Sink/Source DC input and Transistor Sink or Source Output • AC Input, DC Input, Relay Output, Transistor Output, Combination I/O and Analog I/O expansion modules available • 24 I/O All-in-one CPU expandable to 88 I/O points; 20 I/O slim types expandable up to 148 or 244 I/O; 40 I/O slim type expandable up to 264 I/O points • Standard RS232 port, optional plug-in RS485/RS232 port • Optional memory cartridge or real-time clock and calendar cartridge • Data link to other MicroSmart modules, PLCs, PCs or HG series operator interfaces • Approved for Class 1–Div. 2 hazardous locations (UL1604) • Compact size UL Listed File No. E211795 Pulse Output/Trapezoidal Control Independent dual-axis control is available with two pulse outputs. Locational values can be easily defined for precise positional (trapezoidal) control. • Pulse output instruction • PWM instruction (Pulse Width Modulation control) J Number of output points 2 Maximum output frequency 20 kHz *Only one point of trapezoidal control is available. Setting the desired values enables you to precisely manage the trapezoidal control Trapezoidal Control (RAMP) Hz Steady Speed 5000 Operation mode (S1) 1 Steady pulse frequency (S1 + 1) 50 Initial pulse frequency (S1 + 2) 10 Frequency change rate (S1 + 3) 2 Present value (S1 + 6, 7) 10,000 Initial Speed 0 ms Acceleration period www.idec.com RAMP S1 D1 Deceleration period USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J-5 Programmable Logic Controllers Pulse Output Function Specifications Programmable Logic Controllers MicroSmart Series CPU and Module Combination Examples All-In-One Type Maximum I/O 88 90 • Attach Maximum 4 Expansion Modules • Maximum I/O 88 points • Only FC4A-C24R2/C24R2C CPU Module is expandable FC4A-N16B3 16 80 70 FC4A-N16B3 FC4A-M24BR2 I/O Points The maximum number of relay outputs that can be turned on simultaneously is 33 points including relay outputs on the CPU module. 16 24 60 FC4AN08B1 8 50 FC4A-N08B1 8 40 FC4A-M24BR2 24 FC4A-N08B1 16 FC4A-R161 16 8 FC4A-N08B1 30 FC4A-R161 8 FC4A-R161 FC4A-N08B1 16 8 20 FC4A-C24R2 10 FC4A-C16R2 FC4A-C10R2 10 on CPU 16 24 on CPU FC4A-C24R2 24 on CPU FC4A-C24R2 FC4A-C24R2 FC4A-C24R2 24 24 on CPU on CPU on CPU 46 Inputs 38 Inputs 46 Inputs 24 on CPU 0 6 Inputs 9 Inputs 14 Inputs 30 Inputs 4 Outputs 7 Outputs 10 Outputs 18 Outputs 10 Outputs 34 Outputs 42 Outputs 10 Total I/O 16 Total I/O 24 Total I/O 48 Total I/O 56 Total I/O 72 Total I/O 88 Total I/O Slim Type Maximum I/O 264 FC4A-N32B3 250 The maximum number of relay outputs that can be turned on simultaneously is 54 points including relay outputs on the CPU module. 32 FC4A-T32K3 • Attach Maximum 7 Expansion Modules • Maximum I/O - 148 points (D20K3, D20S3) - 244 points (D20RK1, D20RS1) -264 points (D40K3, D40S3) 32 200 FC4A-M24BR2 FC4A-T32K3 24 32 FC4A-T32K3 FC4A-T32K3 32 150 FC4A-M24BR2 24 FC4A-R16S3 FC4A-R16S3 16 100 FC4A-R32S3 16 FC4A-T32K3 32 FC4A-D20K3 FC4A-D20S3 FC4A-D20RK1 FC4A-D20RS1 20 0 on CPU 40 on CPU on CPU 12 Inputs www.idec.com 40 FC4A-D40S3 32 32 FC4A-D20RS1 20 24 Inputs 92 Inputs FC4A-T32S3 32 FC4A-N32B3 FC4A-N32B3 32 32 32 FC4A-N32B3 32 FC4A-N32B3 FC4A-N32B3 32 FC4A-N32B3 FC4A-D40K3 40 on CPU on CPU 24 Inputs 32 32 FC4A-N32B3 FC4A-D40K3 FC4A-D40S3 32 FC4A-N32B3 32 FC4A-R32S3 FC4A-T32K3 16 32 50 32 FC4A-N16B3 FC4A-N32B3 FC4A-N32B3 32 FC4A-T32S3 32 FC4A-T32S3 J-6 FC4A-R32S3 32 I/O Points Programmable Logic Controllers J 32 FC4A-D20RK1 20 FC4A-D40S3 40 on CPU on CPU 120 Inputs 108 Inputs 152 Inputs 8 Outputs 16 Outputs 96 Outputs 64 Outputs 88 Outputs 136 Outputs 112 Outputs 20 Total I/O 40 Total I/O 120 Total I/O 156 Total I/O 208 Total I/O 244 Total I/O 264 Total I/O USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series PID Control To automatically maintain a target water temperature (PID control), use the auto tuning function to perform sampling. Based on the determined PID parameters, PID control is executed automatically. (Slim type CPU units only.) Water Temperature High alarm value 33ºC Set point 30ºC Low alarm value 27ºC AT set point 25ºC Set point 30 AT set point 25 High alarm value 35 Low alarm value 27 Time Auto Tuning PID Control PID S1 S2 S3 S4 D1 CPU Modules - All-in-One Type FC4A-C10R2* FC4A-C16R2* FC4A-C24R2 DC Power Type FC4A-C10R2C* FC4A-C16R2C* FC4A-C24R2C J Programmable Logic Controllers Part Numbers AC Power Type Item I/O Points 10 (6 in/ 4 out) 16 (9 in/7 out) Output Type Input Type Power Voltage 24 (14 in/10 out) Relay Output, 240V AC/30V DC, 2A 24V DC (Sink/Source) AC 100-240V AC, 50/60 Hz DC 24V DC Memory 4.8KB 15KB 27KB Expandability N/A* N/A 88 maximum I/O (up to 4 expansion I/O modules) 1. * I/O expansion modules not applicable to these two models. 2. For specifications see page J-15 & for dimensions see page J-25. 3. For options see J-11 & for accessories see J-12. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J-7 Programmable Logic Controllers MicroSmart Series CPU Modules - Slim Type FC4A-D20K3 Part Number FC4A-D20RK1 FC4A-D40K3 Item I/O Points Output Type 20 (12 in/ 8 out)* 20 (12 in/ 8 out) 40 (24 in/16 out)** Transistor Sink Output 0.3A Relay Output, 240V AC/30V DC, 2A* Sink Output 0.3A* Transistor Sink Output 0.3A Input Type 24V DC (Sink/Source) Power Voltage 24V DC Memory 27KB 31.2KB 31.2KB Expandability 148 maximum I/O (up to 7 expansion modules) 244 maximum I/O (up to 7 expansion modules) 264 maximum I/O (up to 7 expansion modules) Part Number FC4A-D20S3 FC4A-D20RS1 FC4A-D40S3 Programmable Logic Controllers J Item I/O Points Output Type 20 (12 in/ 8 out)* 20 (12 in/ 8 out) 40 (24 in/16 out)** Transistor Source Output 0.3A Relay Output, 240V AC/30V DC, 2A* Transistor, Source Output 0.3A* Transistor Source Output 0.3A Input Type 24V DC (Sink/Source) Power Voltage 24V DC Memory 27KB 31.2KB 31.2KB Expandability 148 maximum I/O (up to 7 expansion modules) 244 maximum I/O (up to 7 expansion modules) 264 maximum I/O (up to 7 expansion modules) 1. * Transistor output 2 points and relay output 6 points. 2. **For MIL connector type modules, see page J-12 for cables and breakout modules. 3. For specifications see page J-15 & for dimensions see page J-25. 4. For options see J-11 & for accessories see J-12. J-8 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series Input Modules - 5 Types Part Number FC4A-N08B1 FC4A-N16B1 FC4A-N16B3 FC4A-N32B3 FC4A-N08A11 Item Input Points 8-point DC 16-point DC Input Type Power Voltage Terminal 16-point DC* 32-point DC* 24V DC (Sink/Source) 100 - 120V AC 24V DC Removable screw terminal 8-point AC 100 - 120V AC (50/60Hz) Removable screw terminal MIL connector MIL connector Removable screw terminal 1. For specifications see page J-19 & for dimensions see page J-25. 2. For options see J-11 & for accessories see J-12. 3. *For MIL connector type modules, see page J-12 for cables and breakout modules. Output Modules - 8 Types Part Number FC4A-R081 FC4A-R161 FC4A-T08K1 FC4A-T08S1 J Item Output Type 8-point Relay 16-point Relay Relay Output (1NO contact), 240V AC/30V DC, 2A Terminal Part Number 8-point Transistor 8-point Transistor Transistor sink output 0.3A Transistor Source Output 0.3A Programmable Logic Controllers Output Points Removable screw terminal FC4A-T16K3 FC4A-T16S3 FC4A-T32K3 FC4A-T32S3 Item Output Points 16-point Transistor 16-point Transistor 32-point Transistor 32-point Transistor Output Type Transistor sink output 0.1A* Transistor source output 0.1A* Transistor sink output 0.1A* Transistor source output 0.1A* Terminal MIL connector 1. For specifications see page J-19 & for dimensions see page J-25. 2. For options see J-11 & for accessories see J-12. 3. *For MIL connector type modules, see page J-12 for cables and breakout modules. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J-9 Programmable Logic Controllers MicroSmart Series Combination I/O Modules - 2 Types Part Number FC4A-M08BR1 FC4A-M24BR2 Item I/O Points 8 (4 in/ 4 out) 24 (16 in/ 8 out) Output Type 1. For specifications see page J-21 & for dimensions see page J-25. 2. For options see J-11 & for accessories see J-12. Relay Output, 240V AC/30V DC, 2A Input Type 24V DC (Sink/Source) Terminal Removable terminal block Wire clamp terminal Analog I/O Modules - 4 Types Part Number FC4A-K1A1 FC4A-J2A1 FC4A-L03AP1 FC4A-L03A1 Item 1. For specifications see page J-22 & for dimensions see page J-25. 2. For options see J-11 & for accessories see J-12. 3. New analog modules available Fall ‘05. See page J-4 for details. Programmable Logic Controllers J I/O Points 1 Analog Output 2 Analog Inputs 2 Analog Inputs, 1 Analog Output Output Type Voltage (0-10V DC) Current (4-20mA) – Voltage (0-10V DC) Current (4-20mA) – Voltage (0-10V DC) Current (4-20mA) Thermocouple Resistance thermometer (RTD) Input Type Terminal 2 Analog Inputs, 1 Analog Output Voltage (0-10V DC) Current (4-20mA) Removable terminal block Expansion Module Examples Example 1 Module Example 2 Type No. Input Output Module Type No. Input Output CPU FC4A-C24R2 14 10 CPU FC4A-C24R2 14 10 DC Input FC4A-N16B1 16 0 DC Input FC4A-N08B1 8 0 DC Input FC4A-N16B1 16 0 DC Input/Relay Output FC4A-M08BR1 4 4 Relay Output FC4A-R161 0 16 Relay Output FC4A-R081 0 8 Relay Output FC4A-R161 0 16 Transistor Sink Output FC4A-T08K1 0 8 46 42 Total 26 30 Total J-10 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series Optional Modules Part Number FC4A-HPH1 FC4A-PM32 FC4A-PM64 FC4A-PH1 FC4A-PT1 Item Type HMI Base Module (does not come with HMI module) HMI Module Memory Cartridge Clock Cartridge Description For mounting HMI module with slim type CPU module For displaying and changing required operands 32KB or 64KB – 1. For specifications see page J-24. Communication Adapters Part Number FC4A-PC1 FC4A-PC2 FC4A-PC3 Item J RS232C RS485 RS485 Terminal Mini DIN Mini DIN Screw Terminal Type Programmable Logic Controllers Type 1. For specifications see page J-24. 2. Used for All-In-One CPU units only, or for FC4A-HPH1 unit shown above. Communication Modules for Slim Type CPUs Part Number FC4A-HPC1 FC4A-HPC2 FC4A-HPC3 FC4A-AS62M* Item Type RS232C RS485 RS485 Terminal Mini DIN for Slim Type CPU Module Mini DIN for Slim Type CPU Module Screw Terminal Type for Slim Type CPU Module AS-Interface Master Module – 1. For specifications see page J-24. 2. *FC4A-AS62M is compatible with CPUs: FC4A-D20RK1, FC4A-D20RS1, FC4A-D40K3, and FC4A-D40S3. (See Communication & Networking Section M for more information.) 3. New web server module available Fall ‘05. See page J-3 for details. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J-11 Programmable Logic Controllers MicroSmart Series Accessories MicroSmart Options Item Description Length Part Number Programming cable (Loader /user mode selectable) 3m/9.84’ FC4A-KC4CA O/I Interface Cable (MicroSmart port 1/2 RS232 to HG1B/2A) O/I Interface Cable (MicroSmart port 1/2 RS232 to HG2F/3F/4F) Modem Cable MIL Connector Cables (Use with Breakout Modules) Item Length Part Number Non-Shielded FC4A-KC1CA 1.5m/5’ FC4A-KC2CA 3m/9.84’ Shielded 16pt & 32pt I/O Modules (20-wire) FC2A-KM1C 0.5m FC9Z-H050B20 1m FC9Z-H100B20 2m FC9Z-H200B20 3m FC9Z-H300B20 0.5m FC9Z-H050A20 1m FC9Z-H100A20 2m FC9Z-H200A20 3m FC9Z-H300A20 5 ft FC9Z-H100C20A 0.5m FC9Z-H050B26 1m FC9Z-H100B26 2m FC9Z-H200B26 3m FC9Z-H300B26 0.5m FC9Z-H050A26 1m FC9Z-H100A26 2m FC9Z-H200A26 3m FC9Z-H300A26 5 ft FC9Z-H100C26A Shielded Single Connectors 16pt & 32pt I/O Modules (20-wire) User Communication Cable Analog Voltage Input Cables (included with slim type CPU only) 2.4m/7.87’ 1m/3.28’ FC2A-KP1C FC4A-PMAC2P Non-Shielded Shielded 20pt & 40pt CPU Modules (26-wire) Programmable Logic Controllers J USB/RS232 Converter Breakout Modules Item J-12 FC4A-USB Description Part Number 20 points (for 16 & 32 I/O expansion modules) BX1D-S20A 26 points (for 20 & 40 I/O CPU modules) BX1D-S26A www.idec.com Shielded Single Connectors 20pt & 40pt CPU Modules (26-wire) USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series Accessories con’t Item Pkg Qty Part Number 13-position terminal blocks for slim type CPU modules (TB1 for FC4A-D20RK1/-D20RS1) 2 FC4A-PMT13P 16-position terminal blocks for slim type CPU modules (TB2 for FC4A-D20RS1) 2 FC4A-PMTS16P 16-position terminal blocks for slim type CPU modules (TB2 for FC4A-D20RK1) 2 FC4A-PMTK16P 11-position terminal blocks for I/O modules (8 point I/O modules) 2 FC4A-PMT11P 10-position terminal blocks for I/O module (16 point I/O modules) 2 FC4A-PMT10P Direct Mounting Strips (for direct mounting of slim type CPU or I/O modules on a panel) 5 FC4A-PSP1P End Clips BNL6 DIN Rails (1m/3.28’ long, 7.5mm height) BAA1000 DIN Rails (1m/3.28’ long, 10.5mm height) BNDN1000 White IDEC screwdriver (2.5mm) FC9Z-SD2 Blue IDEC screwdriver (3.5mm) FC9Z-SD1 20-position connector socket (MIL connector for I/O modules) 2 FC4A-PMC20P 26-position connector socket (MIL connector for Slim Type CPU) 2 FC4A-PMC26P 14-point input simulator switch (Use with FC4A-C24R2 & FC4A-C24R2C) FC4A-DS824-SW14 9-point input simulator switch (Use with FC4A-C16R2 & FC4A-C16R2C) FC4A-DS824-SW9 6-point input simulator switch (Use with FC4A-C10R2 & FC4A-C10R2C) FC4A-DS824-SW6 MicroSmart Users Manual FC9Y-B812-0A Windows-based programming software for IDEC PLCs (for more information, see page J-44). WINDLDR USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J Programmable Logic Controllers www.idec.com Description J-13 Programmable Logic Controllers MicroSmart Series MicroSmart Packages MicroSmart Starter Kits Part Number Includes Input Simulator Switch Screwdriver WindLDR HMI Display & Base Module Breakout Module Cables 26-Wire I/O Cable Manuals 15w Power Supply MM-SMART-10 MM-SMART-16 MM-SMART-24 MM-SMART-20 FC4A-C10R2, Input Simulator Switch, Screwdriver WindLDR, Cables & Manuals FC4A-C16R2, Input Simulator Switch, Screwdriver WindLDR, Cables & Manuals MM-SMART-40 FC4A-D40K3, HMI Display & Base Module,15w Power Supply, 26-Wire I/O Cable & Brea- WindLDR, Cables & Manuals kout Module, Screwdriver FC4A-C24R2, Input Simulator Switch, Screwdriver WindLDR, Cables & Manuals FC4A-D20RK1, HMI Display & Base Module,15w Power Supply, Screwdriver WindLDR, Cables & Manuals MicroSmart Solution Packages Part Number Micro Smart CPU Operator Interface Power Supply Accessories WindLDR 15W Programmable Logic Controllers J Cables WindO/I-NV2 WindMSG 50W HG1X MM-SMART-10-252 10 I/O HG1X 2 line – WindLDR, WindMSG, Cables & Manuals – MM-SMART-16-452 16 I/O HG1X 4 line – WindLDR, WindMSG, Cables & Manuals – MM-SMART-10-HG1B MM-SMART-16-HG1B MM-SMART-24-HG1B HG1B MM-SMART-20-HG1B MM-SMART-40-HG1B MM-SMART-16-HG2F-M MM-SMART-16-HG2F-C MM-SMART-24-HG2F-M MM-SMART-24-HG2F-C MM-SMART-20-HG2F-M MM-SMART-20-HG2F-C HG2F MM-SMART-40-HG2F-M MM-SMART-40-HG2F-C 10 I/O HG1B RS232/485 15W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 16 I/O HG1B RS232/485 15W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 24 I/O HG1B RS232/485 15W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 20 I/O HG1B RS232/485 50W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 40 I/O HG1B RS232/485 50W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 16 I/O HG2F Monochrome 15W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 16 I/O HG2F Color 15W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 24 I/O HG2F Monochrome 15W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 24 I/O HG2F Color 15W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 20 I/O HG2F Monochrome 50W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 20 I/O HG2F Color 50W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 40 I/O HG2F Monochrome 50W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate 40 I/O HG2F Color 50W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate MM-SMART-24-HG3F 10.4” TFT 24 I/O HG3F Color 60W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate MM-SMART-24-HG4F 12.1” TFT 24 I/O HG4F Color 60W WindLDR, WindO/I-NV2, Cables & Manuals E-Stop & Nameplate HG3F/4F J-14 Manuals www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series General Specifications (CPU Module) FC4A-C10R2 FC4A-C10R2C FC4A-C24R2 FC4A-C24R2C FC4A-D20K3 FC4A-D20S3 FC4A-D20RK1 FC4A-D20RS1 FC4A-D40K3 FC4A-D40S3 AC Power Type: 100-240V AC DC Power Type: 24V DC 24V DC Allowable Range AC Power Type: 85-264V AC DC Power Type: 16.0 - 31.2V DC 20.4 to 26.4V DC (including ripple) Rated Frequency AC Power Type: 50/60 Hz (47-63 Hz) — Rated Voltage Maximum Input Current 0.25A (85V AC or 24V DC) 0.30A (85V AC or 24V DC) 0.45A (85V AC or 0.56A (26.4V DC) # 24V DC) ** AC 30VA/264V AC * 20VA/100V AC 31VA/264V AC * 22VA/100V AC 40VA/264V AC ** 33VA/100V AC DC 3.8W/24V DC 4.6W/24V DC 8.7W/24V DC Max. Power Consumption Allowable Momentary Power Interruption 15W/26.4V DC # 0.70A (26.4V DC) # 19W/26.4V DC # Not applicable 10 msec at the rated inputs and outputs (IEC61131) 10 msec (at 24V DC) Between power and terminal: 1500V AC, 1 min Between I/O and terminal: 1500V AC, 1 min Between power and terminal: 500V AC, 1 min Between I/O and terminal: 1500V AC, 1 min Between power and terminal: 10 MΩ (min), 500V DC Between I/O and terminal: 10 MΩ (min), 500V DC Between power and terminal: 10 MΩ (min) Between I/O and terminal: 10 MΩ (min) Noise Resistance AC or DC power terminal: 1.5 kV, 50ns to 1µs I/O terminal (coupling clamp): 1.5 kV, 50ns to 1µs DC power terminals: 1.0 kV, 50 nsec to 1µsec I/O terminals (coupling clamp): 1.5 kV, 50 nsec to 1µsec Inrush Current 35A max. Dielectric Strength CPU General Specifications FC4A-C16R2 FC4A-C16R2C Insulation Resistance 35A max. 40A max. Power Supply Wire 50A maximum (24V DC) 22 - 18AWG Operating Temperature 0 to 55°C Storage Temperature –25 to +70°C Operating Humidity 30-95% Level RH1 (no condensation) Altitude Operation: 0 to 2,000m (0 to 6,595 ft) Transport: 0 to 3,000m (0 to 9.840 ft) Pollution Degree Free from corrosive gases Degree of Protection IP20 Grounding Wire 16 AWG Programmable Logic Controllers Corrosion Immunity 22 AWG DIN rail mounted: 10 to 57Hz / amplitude 0.075mm, 57 to 150Hz / acceleration 9.8m/s2 (1G) Direct mounted: 2 to 25Hz / amplitude 1.6mm, 25 to 100Hz / acceleration 39.2m/s2 (4B) in each of 3 axes Vibration Resistance Shock Resistance Weight J 2 (IEC60664) 15G, 11ms, 3 shocks in each of 3 axes AC 230g 250g 305g DC 240g 260g 310g Not Applicable 140g 185g 180g 1. * CPU module power consumption includes 250 mA sensor power. 2. ** CPU module (including 250 mA sensor power) + 4 I/O modules 3. # CPU module + 7 I/O modules Communication Port 1 Specifications EIA RS232C Standards Maximum Baud Rate 19200 bps Maintenance Communication Possible User Communication Possible Modem Communication Not possible Data Link Communication Not possible Cable Special Cables: FC2A-KC4C, FC2A-KP1C, FC4A-KC1CA, FC4A-KC2CA Isolation between Internal Circuit and Communication Port Not isolated www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J-15 Programmable Logic Controllers MicroSmart Series Function Specifications (CPU Module) FC4A-C10R2 FC4A-C10R2C FC4A-C16R2 FC4A-C16R2C FC4A-C24R2 FC4A-C24R2C Control System FC4A-D20K3 FC4A-D20S3 FC4A-D20RK1 FC4A-D20RS1 FC4A-D40K3 FC4A-D40S3 Stored program system 35 basic instructions Instruction words Program Capacity 38 advanced 40 advanced 46 advanced 53 advanced 70 advanced 4,800 bytes (800 steps) 15,000 bytes (2,500 steps) 27,000 bytes (4,500 steps) 27,000 bytes (4,500 steps) 31,200 bytes (5,200 steps) Calculated 6 bytes per step User Program Storage Internal EEPROM, Memory cartridge (option: EEPROM) Basic instruction: 1.65 msec (1000 steps); END processing: 0.64 msec (does not include expansion I/O service, clock function processing, data link processing and interrupt processing) Processing Time Programmable Logic Controllers J CPU Function Specifications Expandable I/O Modules – – 4 modules 7 modules RAM Backup Backup Data: Internal relay, shift register, counter, data register Backup Duration: Approx. 30 days (typical) at 25° C after backup battery fully charged Battery: Lithium secondary battery Charging Time: Approx. 15 hours for charging from 0% to 90% of full charge Battery Life: 5 years Replaceability: Impossible to replace battery I/O Points 6 input, 4 output 14 input, 10 output Expansion: 64 I/O 9 input, 7 output 12 input, 8 output Expansion: 128 I/O Internal Relay 256 1024 Shift Register 64 128 Data Register 400 1300 Expansion Data Register 12 input, 8 output Expansion: 224 I/O — 24 input, 16 output Expansion: 224 I/) 6000 Counter 32 100 Timer (1-sec, 100-msec, 10-msec, 1-msec) 32 100 Power failure check, watchdog timer, data link connection, user program EEPROM sum check, timer/counter preset value sum check, user program RAM sum check, keep data, user program syntax, user program writing, CPU module, clock IC, I/O bus initialize, user program execution Self-Diagnostic Function Input Filter 3 to 15 msec (1-msec increments) Catch Input/ Interrupt Input 4 input (I2 through I5) High-Speed Counter Minimum turn on pulse width: 40 µsec maximum Minimum turn off pulse width: 150 µsec maximum Total 4 points: Single/two-phase selectable: 20kHz (1 point) Single-phase: 5kHz (3 points) Total 4 points: Single/two-phase selectable: 20kHz (2 points) Single-phase: 5kHz (2 points) Counting Range 0 to 65535 (16 bits), Operation Mode: Rotary encoder mode and adding counter mode 1 point Analog Potentiometer 1 point Data Range: 0 to 255 Analog Voltage Input — 1 point, 0 to 10V DC Input Voltage Range, approx. 100kΩ Input Impedance, data range 0-255 (8 bit) Pulse Output — 2 points, max. frequency 20kHz 24V DC (+10% to -15%), 250 mA, no overload detection Isolated from the internal circuit — Sensor Power Supply Port 1 RS232C Maintenance Communication, User Communication, Modem Communication Port 2 (optional) — Clock Function (optional) Possible: RS232C or RS485 (Maintenance communication, data link) Possible Select either clock or memory cartridge Memory Cartridge (optional) Possible Year, month, day, day of week, hour, minute, second Possible HMI Module (optional) J-16 2 points www.idec.com Possible Possible using HMI Base Module USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series DC Input/Relay Output Specifications (CPU Module) DC Input Specifications for CPU modules FC4A-C10R2 FC4A-C16R2 FC4A-C24R2 FC4A-C10R2C FC4A-C16R2C FC4A-C24R2C FC4A-D20K3 FC4A-D20S3 FC4A-D20RK1 FC4A-D20RS1 FC4A-D40K3 FC4A-D40S3 Rated Input Voltage 24V DC sink / source input signal Allowable Range 20.4 to 28.8V DC 20.4 to 26.4V DC Rated Input Current I0, I1: 11mA, I2 to I7, I10 to I15: 7mA I0, I1, I6, I7: 5mA/point, I2 to I5, I10 to I27: 7mA/point Input Impedance I0, I1: 2.1kΩ, I2 to I7, I10 to I15: 3.4kΩ I0, I1, I6, I7: 5.7kΩ, I2 to I5, I10 to I27: 3.4kΩ OFF/ON I0 to I5: 35µsec + Filter Value I6, I7, I10 to I15: 40µsec + Filter Value I0 to I7: 35µsec + Filter Value I10 to I27: 40µsec + Filter Value ON/OFF I0, I1: 45µsec + Filter Value I2 to I7, I10 to I15: 150µsec + Filter Value I0, I1, I6, I7: 45µsec + Filter Value I2 to I5, I10 to I27: 150µsec + Filter Value 6 inputs 6/1 common 12 inputs 12/1 common 12 inputs 12/1 common 24 inputs, 12/1 common MC1.5/13-G-3.81BK (Phoenix Contact) FL26A2MA (Oki Electric Cable) OFF/ON Time Input Points 9 inputs 9/1 common 14 inputs 14/1 common On Mother Board — FL26A2MA (Oki Electric Cable) Insertion/Removal Durability — 100 times minimum Connector Isolation Between input terminals: Not isolated Internal circuit: Photocoupler isolated Input Type Type 1 (IEC61131) External Load for I/O Interconnection Not needed Signal Determination Method Static Effect of Improper Input Connection Both sinking and sourcing input signals can be connected. If any input exceeding the rated value is applied, permanent damage may be caused. Cable Length 3m (9.84 ft) FC4A-C24R2 FC4A-C24R2C FC4A-D20RK1 FC4A-D20RS1 4 points 7 points 10 points 8 points COM0 3 points 4 points 4 points 2 points (transistor output) COM1 1 point 2 points 4 points 3 points COM2 – 1 point 1 point 2 points COM3 – – 1 point 1 point Output Points Output Points per Common J FC4A-C16R2 FC4A-C16R2C Type of Output Maximum Load Current 1NO Per point 2A Per Common 8A Minimum Switching Load 0.1mA, 0.1V DC (reference value) Initial Contact Resistance 30mΩ maximum Electrical Life 100,000 operations (rated load) @ 1,800 operations/hr Mechanical Life 200,000 operations (no load) @ 18,000 operations/hr Rated Load Current (resistive/inductive) www.idec.com 240V AC/2A, 24V DC/2A (30V DC / 2A) Between output and terminals: 1500V AC, 1 minute Between output terminals and internal circuit: 1500V AC, 1 minute Between output terminals (COMs): 1500 V AC, 1 minute Dielectric Strength Connector Programmable Logic Controllers Relay Output Specifications for CPU modules FC4A-C10R2 FC4A-C10R2C On Mother Board — MC1.5/16-G-3.81BK (Phoenix Contact) Insertion/ Removal Durability — 100 times minimum USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J-17 Programmable Logic Controllers MicroSmart Series Transistor Sink and Source Output Specifications (CPU Module) Transistor Sink and Source Output Specifications for CPU modules FC4A-D20K3 FC4A-D20RK1 FC4A-D20S3 FC4A-D20RS1 Output Points and Common Line 8 points, 8/1 common Rated Load Voltage 24V DC Operating Load Voltage Range 20.4 to 28.8V DC Rated Load Current 0.3A per output point Maximum Load Current 1A per common line Voltage Drop (ON Voltage) 1V maximum (voltage between COM and output terminals when output is on) Inrush Current 1A maximum Leakage Current 0.1 mA maximum Clamping Voltage 39V±1V Maximum Lamp Load 8W Inductive Load L/R = 10ms (28.8V DC, 1Hz) External Current Draw 100mA maximum, 24V DC (power voltage at the +V or -V terminal) Between output terminal and internal circuit: Photocoupler isolated Between output terminals: Not isolated Isolation On Mother Board Connector Insertion/Removal Durability FL26A2MA (Oki Electric Cable) MC1.5/16-G-3.81BK (Phoenix Contact) FL26A2MA (Oki Electric Cable) 100 times minimum Turn ON time 5 µs (Q0, Q1), 300 µs max (Q2 to Q7, Q10 to Q17) Turn OFF time 5 µs (Q0, Q1), 300 µs max (Q2 to Q7, Q10 to Q17) Programmable Logic Controllers Output Delay 16 points, 8/1 common FC4A-D20K3/D20RK1/D40K3 = Sink Output FC4A-D20S3/D20RS1/D40S3 = Source Output Type of Output J 2 points, 2/1 common FC4A-D40K3 FC4A-D40S3 J-18 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series Input/Relay Output Specifications (Expansion Modules) Input Module Specifications DC Input FC4A-N08B1 Input Points FC4A-N16B1 8 points (8/1 common) AC Input FC4A-N16B3 FC4A-N32B3 16 points (16/1 common) FC4A-N08A11 32 points (16/1 common) 8 points (4/1 common) Rated Input Voltage 24V DC sink/source input signal 100 - 120V AC (50-60Hz) Input Voltage Range 20.4 to 28.8V DC 85 to 132V AC Rated Input Current 7mA/point (24V DC) Input Impedance 5mA/point (24V DC) 3.4 kΩ 4.4 kΩ ON time: 25 msec OFF time: 30 msec Between input terminals Not isolated In the same commons: not isolated In different commons: 500V Internal circuit Photocoupler isolated 2500V (photocoupler isolated) External Load for I/O Interconnection Not needed Signal Determination Method Static Effect of Improper Input Connection Both sinking and sourcing input signals can be connected. If any input exceeding the rated value is applied, permanent damage may be caused. Cable Length 3m (9.84 ft) in compliance with electromagnetic immunity On Mother Board MC1.5/10-G-3.81BK (Phoenix contact) FL20A2MA (Oki Electric Cable) Connector Insertion/Removal Durability Internal Current Draw 0.8kΩ (60Hz) ON time: 4 msec OFF time: 4 msec Input Delay Time Isolation 7.5mA/pt (100V AC, 60Hz) 100 times minimum All Inputs ON 25 mA (5V DC) 0 mA (24V DC) 40 mA (5V DC) 0 mA (24V DC) 35 mA (5V DC) 0 mA (24V DC) 65 mA (5V DC) 0 mA (24V DC) 60mA (5V DC) 0mA (24V DC) All Inputs OFF 5 mA (5V DC) 0 mA (24V DC) 5 mA (5V DC) 0 mA (24V DC) 5 mA (5V DC) 0 mA (24V DC) 10 mA (5V DC) 0 mA (24V DC) 30mA (5V DC) 0mA (24V DC) 85g 100g 65g 100g – Weight J Programmable Logic Controllers Relay Output Module Specifications Output Points and Common Lines FC4A-R081 FC4A-R161 8 points (4/1 common) 16 points (8/1 common) Output Type Maximum Load Current 1NO per point 2A per common Minimum Switching Load 7A 8A 0.1 mA/0.1V DC (reference value) Initial Contact Resistance 30 mΩ maximum 100,000 operations minimum (rated load 1,800 operations/hour) Electrical Life 20,000,000 operations minimum (no load 18,000 operations/hour) Mechanical Life Rated Load (resistive/inductive) 240V AC/2A, 30V DC/2A Between output and terminals: 1500V AC, 1 minute Between output terminals and internal circuit: 1500V AC, 1 minute Between output terminals (COMs): 1500 V AC, 1 minute Dielectric Strength On Mother Board Connector Insertion/Removal Durability www.idec.com MC1.5/10-G-3.81BK (Phoenix contact) 100 times minimum All Inputs ON 30 mA (5V DC) 40 mA (24V DC) 45 mA (5V DC) 75 mA (24V DC) All Inputs OFF 5 mA (5V DC) 0 mA (24V DC) 5 mA (5V DC) 0 mA (24V DC) 110g 145g Internal Current Draw Weight MC1.5/11-G-3.81BK (Phoenix contact) USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J-19 Programmable Logic Controllers MicroSmart Series Transistor Output Specifications (Expansion Modules) Transistor Output Module Specifications FC4A-T08K1 FC4A-T08S1 Output Points FC4A-T16K3 FC4A-T16S3 8 points (8/1 common) Rated Load Voltage 24V DC Operating Load Voltage Range Rated Load Current per point Maximum Load Current per common Voltage Drop (ON Voltage) 20.4 to 28.8V DC 0.3A per output point (at 28.8V DC) 0.1A per output point (at 28.8V DC) 0.36A (at28.8V DC) 0.12A (at 28.8V DC) 3A (at 28.8V DC) 1A (at 28.8V DC) 1V maximum (between COM and output terminals when output is on) Inrush Current 1A maximum Leakage Current 0.1A maximum Clamping Voltage 39V ± 1V Maximum Clamping Load 8W Inductive Load L/R = 10 msec (DC 28.8V, 1Hz) FC4A-TK: 100mA maximum, 24V DC (power voltage at the +V) FC4A-TS: 100mA maximum, 24V DC (power voltage at the -V) External Current Draw Between output terminal and internal circuit: Photocoupler isolated Between output terminals: Not isolated Isolation Programmable Logic Controllers J 16 points (16/1 common) 32 points (16/1 common) FC4A-TK: Transistor sink output FC4A-TS: Transistor source output Output Type Connector Type (on Mother Board) FL20A2MA (Oki Electric Cable) 100 times minimum All Inputs ON 10mA (5V DC) 20mA (24V DC) 10mA (5V DC) 40mA (24V DC) 20mA (5V DC) 70mA (24V DC) All Inputs OFF 5mA (5V DC) 0mA (24V DC) 5mA (5V DC) 0mA (24V DC) 10mA (5V DC) 0mA (24V DC) Turn ON time 300µsec maximum Turn OFF time Weight J-20 MC1.5/10-G-3.81BK (Phoenix contact) Insertion/Removal Durability Internal Current Draw Output Delay FC4A-T32K3 FC4A-T32S3 300µsec maximum 85g www.idec.com 70g 105g USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series Combination I/O Specifications (Expansion Modules) Combination I/O Module Specifications DC Input Specifications Input Points FC4A-M08BR1 FC4A-M24BR2 4 points (4/1 common) 16 points (16/1 common) Rated Input Voltage 24V DC sink/source input signal Input Voltage Range 20.4 to 28.8V DC Range Input Current 7 mA/point (24V DC) Input Impedance 3.4 kΩ Turn ON Time 4 msec (24V DC) Turn OFF Time 4 msec (24V DC) Between input terminals: Not isolated Internal circuit: Photocoupler isolated Isolation External Load for I/O Interconnection Not needed Signal Determination Method Static Effect of Improper Input Connection Cable Length 3m (9.84 ft) in compliance with electromagnetic immunity Output Points 4 points (4/1 common) Output Type Maximum Load Current 8 points (8/2 common) 1NO per point 2A per common 7A Minimum Switching Load 0.1 mA/0.1V DC (reference value) Initial Contact Resistance 30 mΩ maximum Electrical Life 100,000 operations minimum (rated load 1,800 operations/hour) Mechanical Life 20,000,000 operations minimum (no load 18,000 operations/hour) Rated Load (resistive/inductive) 240V AC/2A, 30V DC/2A Between output and or terminals: 1,500V AC, 1 minute Between output terminal and internal circuit: 1,500V AC, 1 minute Between output terminal (COMs): 1,500V AC, 1 minute Dielectric Strength Connector on Mother Board MC1.5/11-G-3.81BK (Phoenix contact) Input: F6018-17P (Fujicon) Output: F6018-11P (Fujicon) Insertion/Removal Durability 100 times minimum — All Inputs ON 25 mA (5V DC) 20 mA (24V DC) 65 mA (5V DC) 45 mA (24V DC) All Inputs OFF 5 mA (5V DC) 0 mA (24V DC) 10 mA (5V DC) 0 mA (24V DC) 95g 140g Internal Current Draw Weight www.idec.com J Programmable Logic Controllers Relay Output Specifications Both sinking and sourcing input signals can be connected. If any input exceeding the rated value is applied, permanent damage may be caused. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J-21 Programmable Logic Controllers MicroSmart Series Analog I/O Specifications (Expansion Modules) Analog I/O Module Specifications FC4A-L03A1 Input Points FC4A-L03AP1 2 Voltage Input (0 to 10V DC) Current Input (4 to 20 mA DC) 1 Input Signal Type Output Points Output Signal Type Rated Power Voltage Allowable Voltage Range On Mother Board Connector Insertion/Removal Durability Internal Internal Power Current External Power Draw Weight FC4A-J2A1 FC4A-K1A1 2 2 — Thermocouple Voltage Input (0 to 10V DC) Resistance Thermometer Current Input (4 to 20 mA DC) — 1 — 1 Voltage Output (0 to 10V DC) Voltage Output (0 to 10V DC) Voltage Output (0 to 10V DC) Current Output (4 to 20 mA Current Output (4 to 20 mA DC) Current Output (4 to 20 mA DC) — DC) 24V DC 20.4 to 28.8V DC MC1.5/11-G-3.81BK (Phoenix contact) 100 times minimum 50 mA (5V DC) 0 mA (24V DC) 40 mA (24V DC) 50 mA (5V DC) 0 mA (24V DC) 40 mA (24V DC) 50 mA (5V DC) 0 mA (24V DC) 40 mA (24V DC) 50 mA (5V DC) 0 mA (24V DC) 40 mA (24V DC) 85g Analog Output Specifications FC4A-L03A1, FC4A-L03AP1, FC4A-K1A1 Output Signal Type Output Range Load Impedance Voltage Output Current Output 0 to 10V DC 4 to 20 mA DC 2 kΩ minimum 300Ω maximum Applicable Load Type Resistive load Setting Time 20 msec Total Output System Transfer Time Programmable Logic Controllers J 20 msec + 1 scan time Maximum Error at 25°C ±0.2% of full scale Temperature Coefficient ±0.015% of full scale/°C Repeatability after Stabilization Time Output Error ±0.5% of full scale Output Voltage Drop ±1% of full scale Non-lineality ±0.2% of full scale Output Ripple 1 LSB maximum Overshoot 0% Total Error ±1% of full scale Digital Resolution 4096 increments (12 bits) Output Value of LSB Data 2.5 mV Yes Current Loop Open — Maximum Temporary Deviation during Electrical Noise Tests Cable 4 µA 0 to 4095 (12-bit data); -32768 to 32767 (optional range designation) See note on page J-23 Data Type in Application Program Monotonicity Noise — Detectable (See note on page J-23) ±3% max. when a 500V clamp is applied to the power and I/O wiring Twisted pair shielded cable recommended for improved noise immunity Crosstalk No crosstalk because of 1 channel output Dielectric Strength 500V between output and power circuit Type of Protection Photocoupler between output and internal circuit Effect of Improper Output Connection No damage Selection of Analog Output Signal Type Using software programming Calibration or Verification to Maintain Rated Accuracy Impossible (approx. 10 years) J-22 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series Analog Input Specifications (Expansion Modules) Analog Input Specifications FC4A-L03A1, FC4A-J2A1 Voltage Input Current Input Input Signal Type Input Range Input Impedance Allowable Conductor Resistance Input Detection Current Sample Duration Time Sample Repetition Time Total Input System Transfer Time Type of Input Operating Mode Conversion Method 0 to 10V DC 4 to 20 mA DC Type K (0 to 1300°C) Type J (0 to 1200°C) Type T (0 to 400°C) 1 MΩ minimum 10Ω 1 MΩ minimum 1 MΩ minimum — — — 200Ω maximum — — — Data 16 msec maximum 50 msec maximum 32 msec + 1 scan time * 100 msec + 1 scan time * Single-ended input Crosstalk Dielectric Strength Type of Protection Effect of Improper Input Connection Maximum Permanent Allowed Overload (No damage) Selection of Analog Input Signal Type Calibration or Verification to Maintain Rated Accuracy Differential input Self scan ∑∆ type ADC ±0.2% of full scale plus reference junction compensation accuracy (±4°C maximum) ±0.2% of full scale Temperature Coefficient Repeatability after Stabilization Time Non-lineality Maximum Error Digital Resolution Input Value of LSB Data Type in Application Program Monotonicity Input Data Out of Range Maximum Temporary Deviation during Electrical Noise Tests Common Mode Characteristics Common Mode Voltage Input Filter Cable 50 msec maximum ±0.2% of full scale ±0.006% of full scale / °C ±0.5% of full scale ±0.2% of full scale ±1% of full scale 4096 increments (12 bits) 2.5 mV 4 µA K: 0.325°C; J: 0.300°C; T: 0.100°C 0.15°C 0 to 4095 (12-bit data); -32768 to 32767 (optional range designation) ** Yes J Detectable # is not assured when ±3% maximum when a 500V clamp voltage is applied to the power and I/O wiring Accuracy noise is applied Common mode reject ratio (CMRR): -50 dB 16V DC No Twisted pair shielded cable recommended for improved noise immunity — 2 LSB maximum 500V between input and power circuit Photocoupler between input and internal circuit No damage 13V DC 40 mA DC — Using software programming Impossible (approx. 10 years) NOTES FOR ANALOG EXPANSION UNITS: 1. * Total input system transfer time = Sample repetition time x 2 + 1 scan time 2. ** The 12-bit data (0 to 4095) processed in the analog I/O module can be linear-converted to a value between -32768 and 32767. Select the optional range designations and analog I/O data minimum and maximum values by using data registers allocated to analog I/O modules. 3. # When an error is detected, a corresponding error code is sorted to a data register allocated to analog I/O operating status. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J-23 Programmable Logic Controllers Noise Resistance Pt 100 3-wire type (-100 to 500°C) 1.0 mA maximum 16 msec maximum Maximum Error at 25°C Input Error FC4A-L03AP1 Thermocouple Resistance Thermometer Programmable Logic Controllers MicroSmart Series Communication Adapter and Communication Module Specifications (Expansion Modules) Communication Adapter and Communication Module Specifications FC4A-PC1 FC4A-PC2 FC4A-HPC1 FC4A-HPC2 Standards FC4A-PC3 FC4A-HPC3 EIA RS232C EIA RS485 EIA RS485 Maximum Baud Rate 19200 bps 19200 bps Computer link: 19200 bps Data link: 38400 bps Maintenance Communication Possible Possible Possible User Communication Possible Impossible Impossible Modem Communication Possible Impossible Impossible Impossible Impossible Possible special cable special cable 200m — — 31 Data Link Communication Maximum Cable Length Quantity of Slave Stations Isolation between Internal Circuit and Communication Port Not isolated Recommended Cable for RS485 — Twisted-pair shielded cable with a minimum core wire of 0.3 mm2 Conductor Resistance — 85 Ω/km maximum Shield Resistance — 20 Ω/km maximum Option Specifications Optional HMI Module Specifications FC4A-PH1 J Power Voltage 5V DC (supplied from the CPU module) Programmable Logic Controllers Internal Current Draw 200mA DC Weight 20g Optional Memory Cartridge Specifications FC4A-PM32 Memory Type FC4A-PM64 EEPROM Accessible Memory Capacity 32 KB 64 KB Hardware for Storing Data CPU module Software for Storing Data WindLDR Quantity of Store Programs One user program can be stored on one memory cartridge Optional Clock Cartridge Specifications FC4A-PT1 Accuracy ±30 sec/month (typical) at 25°C Backup Duration Approx. 30 days (typical) at 25°C after backup battery fully charged Battery Lithium secondary battery Charging Time Approx. 10 hours for charging from 0% to 90% of full charge Replaceability Impossible to replace battery J-24 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series Dimensions CPU Modules: all dimensions in mm FC4A-C10R2, FC4A-C16R2 FC4A-C10R2C, FC4A-C16R2C FC4A-C10R2, FC4A-C16R2 FC4A-C24R2, FC4A-C24R2 FC4A-C24R2C 70.0 70.0 95.0 4.5* 90.0 90.0 80.0 FC4A-D20RK1, FC4A-D20RS1 11.3 70.0 14.6 47.5 11.3 47.5 70.0 90.0 90.0 35.4 FC4A-D40K3, FC4A-D40S3 70.0 90.0 FC4A-D20K3, FC4A-D20S3 Expansion Modules: FC4A-N08B1, FC4A-N08A11, FCA-T08K1, FC4A-M08BR1, FC4A-L03AP1, FC4A-K1A1 FC4A-N08B1, FC4A-T08K1, FC4A-M08BR1, FC4A-R081, FC4A-T08S1, FC4A-L03A1, FC4A-L03AP1, FC4A-K1A1, FC4A-R081 FC4A-T08S1, FC4A-L03A1, FC4A-J2A1 FC4A-J2A1 14.6 FC4A-HPC1, FC4A-HPC2, FC4A-HPC3 FC4A-N16B3, FC4A-T16K3, FC4A-T16S3 3.8 14.6 70.0 3.8 1.0 70.0 11.3 17.6 70.0 22.5 13.9 90.0 FC4A-HPH1 FC4A-N32B3, FC4A-T32K3, FC4A-T32S3 38.0 70.0 90.0 71.0 23.5 23.5 9.0 23.5 9.0 35.0 23.5 DINRail Rail DIN BNL6P Mounting Clip BNL6 Mounting Clip www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC 90.0 95.0 95.0 35.0 45.0 9.0 90.0 9.0 4.5* 90.0 Example: This figure illustrates a EXAMPLE: system setup with the This figure illustrates a FC4A-C24R2 system setupAll-in-one with the type CPU, an 8-point FC4A-C24R2 All-in-one relay module, typeoutput CPU, an 8-point and a 16-point DC input relay output module, module, mounted oninput a and a 16-point DC module, on a 35mm DINmounted rail using 35mm DIN rail using BNL6 mounting clips. BNL6P mounting clips. 45.0 90.0 39.1 13.9 4.5* 11.3 29.7 90.0 23.5 FC4A-M24BR2 3.8 J 4.5* 4.5* FC4A-N16B1, FC4A-R161 3.8 70.0 Programmable Logic Controllers 70.0 90.0 23.5 90.0 3.8 J-25 Programmable Logic Controllers MicroSmart Series Mounting Hole Layout CPU Modules: FC4A-C20K3 FC4A-D20S3 FC4A-C24R2, FC4A-C24R2 FC4A-C24R2C 4.3 35.4 24.1 95.0 90.0 103.0 90.0 83.0 4.3 2-ø 47.5 24.1 2-ø 90.0 83.0 80.0 FC4A-C20RK1, FC4A-D40K3 FC4A-C20RS1, FC4A-D40S3 4.3 90.0 103.0 FC4A-C10R2, FC4A-C10R2C FC4A-C10R2 FC4A-C16R2, FC4A-C16R2C FC4A-C16R2 2-ø 83.0 68.0 3.0 3.0 Expansion Modules: 17.6 4.3 2-ø 6.3 29.7 4.3 2-ø 23.5 23.5 23.5 90.0 103.0 90.0 103.0 90.0 103.0 J 3.0 3.0 15.3 23.5 83.0 3.0 3.0 4.8 22.5 4.3 2-ø FC4A-HPH1 4.3 2-ø 38.0 20.3 3.0 J-26 www.idec.com 17.6 17.6 29.7 103.0 90.0 103.0 3.0 3.0 3.0 23.5 EXAMPLE: Mounting hole layout for, from left, FC4A-HPH1, FC4A-D20K3, FC4A-N16B3, FC4A-N32B3, and FC4A-M24R2 modules. 41.8 90.0 103.0 6.3 39.1 4.3 2-ø 3.0 23.5 3.0 FC4A-HP1C FC4A-HPC2 FC4A-HPC3 FC4A-M24BR2 90.0 103.0 Programmable Logic Controllers 12.3 103.0 6.3 .3 4.3 2-ø EXAMPLE: Mounting hole layout for FC4A-C24R2 and 23.5mm-wide I/O modules. ø4 23.5 FC4A-N32B3 FC4A-T32K3 FC4A-T32S3 83.0 6.3 FC4A-N16B3 FC4A-T16K3 FC4A-T16S3 10 - FC4A-N08B1, FC4A-N16B1, FC4A-N08B1, FC4A-N08A11, FC4A-R081, FC4A-N16B1,FC4A-R161, FC4A-R081, FC4A-T08K1, FC4A-T08S1, FC4A-R161, FC4A-T08K1, FC4A-M08BR1, FC4A-L03A1 FC4A-T08S1, FC4A-M08BR1, FC4A-L03AP1, FC4A-J2A1, FC4A-L03A1, FC4A-L03AP1, FC4A-K1A1 FC4A-J2A1, FC4A-K1A1 3.0 41.8 3.0 3.0 17.6 17.6 3.0 29.7 3.0 USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Programmable Logic Controllers MicroSmart Series Usage Limits I/O Usage Limits All-in-one Type CPU Modules: Input Voltage (V DC) 28.8V Ambient temperature 55°C 26.4V Input Voltage (V DC) Ambient temperature 45°C Input Voltage (V DC) Ambient temperature 45°C 28.8V Ambient temperature 55°C 26.4V 0 50% 100% I/O Simultaneous ON Ratio (%) 28.8V 26.4V 0 50% 100% I/O Simultaneous ON Ratio (%) Ambient temperature 55°C When using at an operating ambient temperature above 40°C, reduce the input voltage or the quantity of I/O points that turn on simultaneously. 0 50% 100% I/O Simultaneous ON Ratio (%) Slim Type CPU Modules: Input Voltage (V DC) Ambient temperature 40°C 26.4V Ambient temperature 55°C 24.0V Input Voltage (V DC) Ambient temperature 55°C Input Voltage (V DC) Ambient temperature 40°C 26.4V 26.4V 24.0V 24.0V 0 50% 100% I/O Simultaneous ON Ratio (%) 0 50% 100% I/O Simultaneous ON Ratio (%) Ambient temperature 55°C 0 50% 100% I/O Simultaneous ON Ratio (%) Input Usage Limits Input Voltage (V DC) Ambient temperature Input Voltage (V DC) Ambient temperature 55°C 45°C 28.8V 26.4V Ambient 24.0V temperature 55°C 28.8V 26.4V 24.0V 0 50% 100% I/O Simultaneous ON Ratio (%) 0 50% 100% I/O Simultaneous ON Ratio (%) 0 50% 100% I/O Simultaneous ON Ratio (%) Input Voltage (V DC) Ambient temperature 45°C 28.8V 26.4V 24.0V Ambient temperature 55°C 0 50% 100% I/O Simultaneous ON Ratio (%) Internal Circuits Input Internal Circuits Output Internal Circuit (Slim Type) +V I0, I1, I6, I7 1.8 kΩ Internal Circuit Input COM 4.7 kΩ Internal Circuit I0, I1 Input SINK OUTPUT SLIM TYPE ALL-IN-ONE TYPE COM Internal Circuit Output COM(-) SOURCE OUTPUT I2 to I5 and I10 to I27 COM Internal Circuit 3.3 kΩ Input COM 3.3 kΩ Internal Circuit I2 to I15 Input Internal Circuit COM(+) Output -V www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC J Programmable Logic Controllers 0 50% 100% I/O Simultaneous ON Ratio (%) Input Voltage (V DC) Ambient temperature Input Voltage (V DC) Ambient temperature 30°C 55°C 28.8V Ambient 26.4V temperature 24.0V 55°C 28.8V 26.4V 24.0V J-27 Programmable Logic Controllers MicroSmart Series Internal Circuits Input Internal Circuits (Expansion Modules) Output Internal Circuits FC4A-T08K1, FC4A-T16K3, FC4A-T32K3 FC4A-N081, FC4A-N16B1 3.3 kΩ +V Internal Circuit Input COM Output Internal Circuit FC4A-N16B3, FC4A-N32B3 COM(-) 4.3 kΩ Internal Circuit Input COM FC4A-T08S1, FC4A-T16S3, FC4A-T32S3 COM(+) FC4A-M08BR1, FC4A-M24BR2 3.3 kΩ Internal Circuit Input COM Output Internal Circuit -V Input COM Analog I/O Module Input Circuit Output Circuit +V2 +V1 1 kΩ NC(A) + (B') 1 kΩ 10 Ω 1 kΩ Input Data Output Circuit + 15 MΩ Multiplexer Programmable Logic Controllers J Internal Circuit FC4A-N08A11 - - (B) Input Selection Signal - V1 J-28 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC
FC4A-R161 价格&库存
很抱歉,暂时无法提供与“FC4A-R161”相匹配的价格&库存,您可以联系我们找货
