HW4L-M1F11QD-G-24V
HW4L-M1F11QD-G-24V
    IDEC(日本和泉)
HW4L-M1F11QD-G-24V 数据手册
ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices HW Series — 22mm IEC Style Global Pushbuttons Key features: • • • • Signaling Lights • • • • • • Locking lever removable contact blocks Finger-safe IP20 contacts Tamperproof construction All E-stops meet EN60947-5-5, and are compliant with SEMI S2 standards Worldwide approvals Easy to assemble Choice of black plastic or metallic front bezels LED illumination Transformer or full voltage Slow make double break contacts HW: The Best Engineered Switch in the World IDEC’s HW switches are “The best engineered switch in the world” for a reason. Carrying the CE mark, UL, CSA, CCC (Chinese), and TUV approvals, these switches are designed for use in almost any part of the world. Complete with finger-safe contact blocks offering IP20 protection, these 7/8” (22mm) switches All switches also incorporate mechanically keyed safety locking levers, ensuring correct installation and maintaining safety in high-vibration applications. Relays & Sockets File No. E68961 include illuminated and non-illuminated pushbuttons, pilot lights, selector switches, and emergency stop switches. Certificate No. Certificate No. R50086203_HW_e-stop 2017010305987846 R50391189_HW File No. LR21451 Specifications Rated Insulation Voltage 600V Rated Switching Over-Voltage Less than 4kV, conforming to IEC60947-1 Rated Impulse Withstanding Voltage 4kV for contact circuit, 2.5kV for lamp circuit Rated Thermal Current 10 Amp Minimum Switching Capacity 5 mA at 3V AC/DC Electrical Reliability MTBF < 1 fault for 10 million operation cycles (3V DC, 5mA) Lamp Ratings LEDs: 6V/17mA max, 12V & 24V/11mA max, 120 & 240V/10mA max Contact Operation Slow break NC or NO Positive Action Operation (Emergency Stops with NC contacts) 5.5mm to 10mm travel to latch, 45N minimum force to latch 10mm maximum travel, 1,800 operations per hour maximum for a Pushlock Turn Reset 900 operations per hour maximum for a Push-Pull Operating Force Flush and extended pushbuttons—with 1NO or 1NC contact: 6.2±2N (momentary), 7.0±2N (maintained) Additional contacts—1NO or 1NC: +3.2N (momentary), + 3.3N (maintained) Timers Electrical Rated Operational Characteristics AC-15: A600 or Ue = 250V, le = 3A (NO, NC, NO-EM, NC-LB) DC-13: P600 or Ue = 125V, le = 1.1A (NO, NC) DC-13: Q600 or Ue = 125V, le = 0.9A (NO-EM, NC-LB) Wire Crimping Terminal Recommended Terminal Torque HW-U Contact Block Solid Wire Stranded Wire Number of Wires Recommended Tightening Torque (Nm) 2 1.0 to 1.3 ø0.5 to 1.6 mm (AWG14 to 22) 2 1.0 to 1.3 ø1.7 to 2.0 mm (AWG12) 1 1.2 to 1.3 0.3 to 2.0 mm2 (AWG14 to 22) 2 1.0 to 1.3 2.1 to 3.5 mm2 (AWG12) 1 1.2 to 1.3 2 1.0 to 1.3 Contactors Unit Terminal Screw M3.5 Illuminated Unit (*1) Solid Wire ø0.5 to 1.6 mm (AWG14 to 22) Stranded Wire 0.3 to 2.0 mm (AWG14 to 22) Crimping Terminal Applicable Wire Size Pilot Light Solid Wire ø0.5 to 1.6 mm (AWG14 to 22) Stranded Wire ø0.3 to 2.0 mm (AWG14 to 22) M3.5 Terminal Blocks Mechanical Crimping Terminal 0.6 to 1.0 (M3.0) 2 1.0 to 1.3 (M3.5) 1. * refers to the lamp terminals of the illuminated push buttons and selector switches. Minimum 1 x 22 AWG, max. 2 x 14 AWG or 1 x 12 AWG Contact Resistance Initial contact resistance of 50mΩ or less Contact Gap 4mm (NO and NC), 2mm (NO-EM and NC-LB) Horsepower Rating Reference Value: 1/4 HP @ 120V (1ø non-reversing), 1HP @ 240V (3ø non-reversing) Contact Material Silver (gold plated contacts available - contact IDEC) Operating Temperature Operation: –25 to +50°C (without freezing), Storage: –40 to +70°C (without freezing) Vibration Resistance 10 to 55Hz, 98m/sec2 (10G) conforming to IEC6068-2-6 Shock Resistance 980m/sec2 (100G) conforming to IEC6068-2-7 Mechanical Life Momentary pushbuttons: 5,000,000 (900 operations per hour), All other switches: 500,000 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1804091617 Applicable Wire Size 609 Switches & Pilot Devices Standards & Approvals Conforming to Standards File No. E68961 EN60947-1, EN60947-5-1, VDE0660-200, UL508, CSA C22-2 No.14 File No. LR92374 Approvals Registration No. R9551089 (E-stops) Registration No. R50054316 (Dual Pushbuttons) Registration No. J9650511 (Pilot Lights) Registration No. J9551458 (all other switches) Certificate No. 2005010305145656 Electric Shock Protection Contact Ratings CSA: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) UL: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) TÜV: pushbuttons and selector switches: A600=P600 (NO, NC)/Q600 (NO-EM, NC-LB) pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) Class 2 conforming to IEC60664-7 UL Type 1, 4X, 12, 13 1 IP65 (from front of the panel) IP20 (Type HW-U contact block) Degree of Protection (conforming to IEC60529 and UL50) Pollution Degree (conforming to IEC60947-1) 3 External Short-Circuit Protection 10A 250V fuse conforming to IEC60269-1 Pushbuttons Illuminated Pushbuttons Selector Switches Illuminated Selector Switches Pushbutton Selectors Contact Block Type HW-U Rated Insulation Voltage 600V Rated Continuous Current 10A Contact Ratings by Utilization Category IEC 60947-5-1 AC-15 (A600) DC-13 (P600) Operational Voltage Characteristics Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series 24V AC 50/60 Hz Operational Current DC AC-12 Control of resistive loads & solid state loads AC-15 Control of electromagnetic loads (> 72VA) DC-12 Control of resistive loads & solid state loads DC-13 Control of electromagnets 48V 50V 110V 220V 440V 10A — 10A 10A 6A 2A 10A — 7A 5A 3A 1A 10A 5A — 2.2A 1.1A — 5A 2A — 1.1A 0.6A — Timers For dimensions, see page 660. Note 1. Except HW2B LED Lamp Ratings (LSTD Type) Model LSTD-6N LSTD-1N Contactors Lamp Base LSTD-2N LSTD-H2N LSTD-M4N BA9S/13 Rated Voltage 6V AC/DC 12V AC/DC 24V AC/DC 120V AC 240V AC Voltage Range 6V AC/DC ±10% 12V AC/DC ±10% 24V AC/DC ±10% 120V AC ±5% 240V AC ±5% Current Draw AC A, R, W: G, S: 17mA 8mA 11mA 11mA 10mA 10mA DC A, R, W: G, S: 14mA 5.5mA 10mA 10mA – – Color Code A (amber), G (green), R (red), S (blue), W (white) Lamp Base Color Same as illumination color Voltage Marking Life (reference value) Die stamped on the base Approx. 50,000 hours (The luminance reduces to 50% the initial intensity when used on complete DC.) A, R, W Terminal Blocks A, R, W In place of N, specify the Lens/LED Color Code. Internal Circuit G, S LED Chip Circuit Breakers Protection Diode Zener Diode 610 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Non-Illuminated Round Pushbuttons (Assembled) Signaling Lights Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-M1-M HW4B-M1-M HW1B-M2-M HW4B-M2-M 1NO HW1B-M1F10-M HW4B-M1F10-M HW1B-M2F10-M HW4B-M2F10-M 1NC HW1B-M1F01-M HW4B-M1F01-M HW1B-M2F01-M HW4B-M2F01-M 1NO-1NC HW1B-M1F11-M HW4B-M1F11-M HW1B-M2F11-M HW4B-M2F11-M 2NO HW1B-M1F20-M HW4B-M1F20-M HW1B-M2F20-M HW4B-M2F20-M 2NC HW1B-M1F02-M HW4B-M1F02-M HW1B-M2F02-M HW4B-M2F02-M 2NO-2NC HW1B-M1F22-M HW4B-M1F22-M HW1B-M2F22-M HW4B-M2F22-M Operator Only HW1B-A1-M HW4B-A1-M HW1B-A2-M HW4B-A2-M 1NO HW1B-A1F10-M HW4B-A1F10-M HW1B-A2F10-M HW4B-A2F10-M 1NC HW1B-A1F01-M HW4B-A1F01-M HW1B-A2F01-M HW4B-A2F01-M 1NO-1NC HW1B-A1F11-M HW4B-A1F11-M HW1B-A2F11-M HW4B-A2F11-M 2NO HW1B-A1F20-M HW4B-A1F20-M HW1B-A2F20-M HW4B-A2F20-M 2NC HW1B-A1F02-M HW4B-A1F02-M HW1B-A2F02-M HW4B-A2F02-M 2NO-2NC HW1B-A1F22-M HW4B-A1F22-M HW1B-A2F22-M HW4B-A2F22-M M Button Color Code Code Black B Green G Red R Blue S White W Yellow Y In place of M, specify the Button Color Code from table below. For nameplates and accessories, see page 655 and 658. For dimensions, see page 660. For contact assembly part numbers, see page 659. All assembled part numbers in catalog include standard, Finger-Safe (HW-U...) contacts. Operator only models include operator plus button. Additional contact configurations available (up to 6 total contacts). Terminal Blocks Color 1. 2. 3. 4. 5. 6. 7. Contactors Maintained Round Extended Contacts Timers Momentary Relays & Sockets Round Flush Function Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 611 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 B - M 1 F 10 – R Button Colors Bezel 1: Plastic Bezel 4: Metal Bezel Function Contact Arrangement Operator M: Momentary Action A: Maintained Action 1: Flush 2: Extended Terminals F: Finger-Safe Spring-Up Contacts Signaling Lights Note: Use only for interpreting part numbers. Do not use for developing part numbers. 10: 1NO 01: 1NC 11: 1NO-NC 20: 2NO 02: 2NC 22: 2NO-2NC B: Black G: Green R: Red S: Blue W: White Y: Yellow Non-Illuminated Round Pushbuttons (Replacement Parts) Relays & Sockets Contact Blocks + Mounting Adaptor + Safety Lever Lock Contact Blocks Timers Style + Anti-Rotation Ring + Operator Anti-Rotation Ring Contacts 1NO 1NC FingerSafe Spring-Up Terminal HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Dummy Block Style + Button = Buttons Part Number Style Part Number Round Flush HW9Z-RL HW1A-B1-M Use with notched panel cutout to prevent unit rotation. Round Extended HW-DB Operators Contactors Style Part Number HW1A-B2-M  Plastic Bezel Style Round Flush/ Extended HW-CB2C Momentary Contact Block Mounting Adaptor Completed Unit Metal Bezel 1. In place of M, specify the Button Color Code from table. HW1B-M0 HW4B-MO Maintained M Button Color Code Terminal Blocks 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Color HW1B-A0 Safety Lever Lock Style HW4B-AO Code Black B Green G Red R Blue S White W Yellow Y Part Number Circuit Breakers HW9Z-LS 612 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Non-Illuminated Mushroom Head Pushbuttons (Assembled) Signaling Lights Momentary ø40mm Mushroom Head Contacts Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-M3-M HW4B-M3-M HW1B-M4-M HW4B-M4-M 1NO HW1B-M3F10-M HW4B-M3F10-M HW1B-M4F10-M HW4B-M4F10-M 1NC HW1B-M3F01-M HW4B-M3F01-M HW1B-M4F01-M HW4B-M4F01-M 1NO-1NC HW1B-M3F11-M HW4B-M3F11-M HW1B-M4F11-M HW4B-M4F11-M 2NO HW1B-M3F20-M HW4B-M3F20-M HW1B-M4F20-M HW4B-M4F20-M 2NC HW1B-M3F02-M HW4B-M3F02-M HW1B-M4F02-M HW4B-M4F02-M 2NO-2NC HW1B-M3F22-M HW4B-M3F22-M HW1B-M4F22-M HW4B-M4F22-M Operator Only HW1B-A3-M HW4B-A3-M HW1B-A4-M HW4B-A4-M 1NO HW1B-A3F10-M HW4B-A3F10-M HW1B-A4F10-M HW4B-A4F10-M HW1B-A3F01-M HW4B-A3F01-M HW1B-A4F01-M HW4B-A4F01-M HW1B-A3F11-M HW4B-A3F11-M HW1B-A4F11-M HW4B-A4F11-M 2NO HW1B-A3F20-M HW4B-A3F20-M HW1B-A4F20-M HW4B-A4F20-M 2NC HW1B-A3F02-M HW4B-A3F02-M HW1B-A4F02-M HW4B-A4F02-M 2NO-2NC HW1B-A3F22-M HW4B-A3F22-M HW1B-A4F22-M HW4B-A4F22-M M Button Color Code Momentary B ø60mm Mushroom Head Green G Contacts Plastic Bezel Red R Operator Only HW1B-M5-M* Blue S 1NO HW1B-M5F10-M* 1NC White W HW1B-M5F01-M* 1NO-1NC HW1B-M5F11-M* Yellow Y 2NO HW1B-M5F20-M* 2NC HW1B-M5F02-M* 2NO-2NC HW1B-M5F22-M* 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1804091617 Code Black In place of M, specify the Button Color Code from table. *60mm mushroom available only in red, green, black, and yellow. For nameplates and accessories, see page 655 and 658. For dimensions, see page 660. For contact assembly part numbers, see page 659. All assembled part numbers in catalog include standard spring-up Finger-Safe (HW-U...) contacts. 7. Operator only models include operator plus button. 8. Additional contact configurations available (up to 6 total contacts). 1. 2. 3. 4. 5. 6. Terminal Blocks Function Color Contactors 1NC 1NO-1NC Timers Maintained Relays & Sockets ø29mm Mushroom Head Function 613 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H 1 B - M 3 F 10 – R Button Colors Bezel 1: Plastic Bezel 4: Metal Bezel Function (Not available for 60mm mushroom) Signaling Lights B: Black G: Green R: Red S: Blue W: White Y: Yellow Contact Arrangement M: Momentary Action A: Maintained Action (Not available for 60mm jumbo mushroom pushbutton.) 10: 1NO 01: 1NC 11: 1NO-NC Operator 3: ø29mm Mushroom 4: ø40mm Mushroom 5: ø60mm Mushroom Note: Use only for interpreting part numbers. Do not use for developing part numbers. Terminals 20: 2NO 02: 2NC 22: 2NO-2NC F: Finger-Safe Spring-Up Contacts Non-Illuminated Mushroom Head Pushbuttons (Replacement Parts) Contact Blocks Relays & Sockets W + Mounting Adaptor + Safety Lever Lock Contacts FingerSafe Spring-Up Terminal Timers Anti-Rotation Ring + Operator + Button 1NO 1NC HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Style = Completed Unit Buttons Safety Lever Lock Contact Blocks Style + Part Number Style HW9Z-LS ø29mm Mushroom Cap Part Number HW1A-B3-M Anti-Rotation Ring Dummy Block HW-DB Appearance Part Number ø40mm Mushroom Cap HW9Z-RL Contact Block Mounting Adaptor Contactors Style Part Number HW1A-B4-M Operators Terminal Blocks 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Circuit Breakers Ø60mm Jumbo Mushroom HW1B-M0L Maintained ø29mm Mushroom ø40mm Mushroom HW1B-A0L Momentary HW-CB2C Plastic Bezel Momentary Style HW1B-M5-M* Metal Bezel HW4B-MOL HW4B-AOL 1. In place of M, specify the Button Color Code from table. M Button Color Code Color Code Color Code Black B Blue S Green G White W Red R Yellow Y HW1B-M5 available only in black, red, green and yellow. – 1. *60mm mushroom operator includes non-removable button (available in red, black, green and yellow only). 2. For nameplates and accessories, see page 655 and 658. 3. For dimensions, see page 660. 614 www.IDEC.com 1804091617 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Non-Illuminated Square Pushbuttons (Assembled) Signaling Lights Contacts Momentary Operator Only HW2B-M1-M HW2B-M2-M HW2B-M1F10-M HW2B-M2F10-M 1NC HW2B-M1F01-M HW2B-M2F01-M 1NO-1NC HW2B-M1F11-M HW2B-M2F11-M 2NO HW2B-M1F20-M HW2B-M2F20-M 2NC HW2B-M1F02-M HW2B-M2F02-M 2NO-2NC HW2B-M1F22-M HW2B-M2F22-M Operator Only HW2B-A1-M HW2B-A2-M 1NO HW2B-A1F10-M HW2B-A2F10-M 1NC HW2B-A1F01-M HW2B-A2F01-M 1NO-1NC HW2B-A1F11-M HW2B-A2F11-M HW2B-A1F20-M HW2B-A2F20-M HW2B-A1F02-M HW2B-A2F02-M 2NO-2NC HW2B-A1F22-M HW2B-A2F22-M G Red R Blue S White W Yellow Y In place of M, specify the Button Color Code from table. For nameplates and accessories, see page 655 and 658. For dimensions, see page 660. For contact assembly part numbers, see page 659. Square pushbuttons available in plastic bezel only. All assembled part numbers in catalog include finger-safe spring-up (HW-U...) contacts. 7. Operator only model includes operator and button. 8. Additional contact configurations available (up to 6 total contacts). 1. 2. 3. 4. 5. 6. Terminal Blocks B Green Contactors 2NO 2NC Code Black Plastic Bezel 1NO M Button Color Code Color Square Extended Plastic Bezel Timers Maintained Square Flush Relays & Sockets Function Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 615 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 2 B - M 1 F 10 – R Button Colors Function M: Momentary Action A: Maintained Action Contact Arrangement Operator 10: 1NO 01: 1NC F: Finger-Safe Spring-Up Contacts 11: 1NO-NC 1: Flush 2: Extended Terminals 20: 2NO 02: 2NC 22: 2NO-2NC Signaling Lights Note: Use only for interpreting part numbers. Do not use for developing part numbers. B: Black G: Green R: Red S: Blue W: White Y: Yellow Non-Illuminated Square Pushbuttons (Replacement Parts) + + Safety Lever Lock + Anti-Rotation Ring + Operator + Button = Completed Unit Relays & Sockets Contact Blocks Mounting Adaptor Contact Blocks Timers Style Buttons Safety Lever Lock Contacts 1NO 1NC FingerSafe Spring-Up Terminal HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Dummy Block Style Part Number Part Number Square Flush HW9Z-LS HW2A-B1-M Anti-Rotation Ring HW-DB Style Appearance Part Number Square Extended HW2A-B2-M HW9Z-RL Contact Block Mounting Adaptor Contactors Style Part Number Use with notched panel cutout to prevent unit rotation. HW-CB2C M Button Color Code Operators Plastic Bezel Momentary Terminal Blocks Square Flush Extended HW2B-M0 Maintained Style 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. 1. In place of M, specify the Button Color Code from table. HW2B-A0 Color Code Color Code S Black B Blue Green G White W Red R Yellow Y Circuit Breakers 2. For nameplates and accessories, see pages 655 and 658. 3. For dimensions, see page 660. 616 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Non-Illuminated E-Stop Pushbuttons (Assembled) Signaling Lights Ø40mm Head Pushlock Turn Reset Contacts Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-V3M† HW4B-V3M† HW1B-V4M† HW4B-V4M† 1NO HW1B-V3F10-M† HW4B-V3F10-M† HW1B-V4F10-M† HW4B-V4F10-M† 1NC HW1B-V3F01-M† HW4B-V3F01-M† HW1B-V4F01-M† HW4B-V4F01-M† 1NO-1NC HW1B-V3F11-M† HW4B-V3F11-M† HW1B-V4F11-M† HW4B-V4F11-M† 2NO HW1B-V3F20-M† HW4B-V3F20-M† HW1B-V4F20-M† HW4B-V4F20-M† 2NC HW1B-V3F02-M† HW4B-V3F02-M† HW1B-V4F02-M† HW4B-V4F02-M† Relays & Sockets Ø29mm Head Pushlock Turn Reset Timers Ø40mm Head EMO Pushlock Turn Reset Ø40mm Head Pushlock Key Reset Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-V4R-EMO-2* HW4B-V4R-EMO-2* HW1B-X4R* HW4B-X4R* 1NO HW1B-V4F10-R-EMO-2* HW4B-V4F10-R-EMO-2* HW1B-X4F10-R* HW4B-X4F10-R* 1NC HW1B-V4F01-R-EMO-2* HW4B-V4F01-R-EMO-2* HW1B-X4F01-R* HW4B-X4F01-R* 1NO-1NC HW1B-V4F11-R-EMO-2* HW4B-V4F11-R-EMO-2* HW1B-X4F11-R* HW4B-X4F11-R* 2NO HW1B-V4F20-R-EMO-2* HW4B-V4F20-R-EMO-2* HW1B-X4F20-R* HW4B-X4F20-R* 2NC HW1B-V4F02-R-EMO-2* HW4B-V4F02-R-EMO-2* HW1B-X4F02-R* HW4B-X4F02-R* Operator Only HW1B-V5R* 1NO HW1B-V5F10-R* 1NC HW1B-V5F01-R* 1NO-1NC HW1B-V5F11-R* 2NO HW1B-V5F20-R* 2NC HW1B-V5F02-R* 1804091617 1. 2. 2. 3. 5. 4. 7. * Available in Red only. † Available in red or yellow. Insert color code in place of M (R: Red, Y: Yellow). For accessories, see page 658. For dimensions, see page 660. For nameplates and shrouds, see page 659. For contact assembly part numbers, see page 659. All HW series E-stops comply with EN60947-5-5, the IEC “E-Stop Addendum to the Low Voltage Directive,” this includes “tamper proof” operation whereby a change of contact state is not possible by “teasing” or “floating” the operator. 8. All assembled part numbers in catalog include standard finger-safe spring-up (HW-U...) contacts. 9. Operator only models include operator and button. 10. Additional contact configurations available (up to 6 total contacts). 800-262-IDEC (4332) • USA & Canada Circuit Breakers Plastic Bezel Terminal Blocks ø60mm Head Pushlock Turn Reset Contacts Contactors Contacts 617 Switches & Pilot Devices ø22mm - HW Series Part Number Structure H W 1 B – V 3 F 10 – R – EMO-2 Engraved Button* Bezel EMO-2: EMO switch 1: Plastic Bezel 4: Metal Bezel (not available for 60mm Signaling Lights jumbo mushroom) Function V: Pushlock Turn Reset X: Pushlock Key Reset Note: Use only for interpreting part numbers. Do not use for developing part numbers. *Option available for red EMO E-Stop only Operator 3: ø29mm Head 4: ø40mm Head 5: ø60mm Head Button Colors Contact Arrangement 10: 1NO 01: 1NC 11: 1NO-NC Terminals F: Finger-Safe Spring-Up R: Red Y: Yellow 20: 2NO 02: 2NC 22: 2NO-2NC Note: some switches only available in red. Non-Illuminated E-Stop Pushbuttons (Replacement Parts) Contact Blocks Relays & Sockets Switches & Pilot Devices + Mounting Adaptor + Contact Blocks Timers Style Safety Lever Lock + Anti-Rotation Ring + Safety Lever Lock Contacts 1NO 1NC FingerSafe Spring-Up Terminal HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Dummy Block HW-DB Style Operator Contactors Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Style Plastic Part Number ø40mm Head Pushlock Turn Reset HW-CB2C Terminal Blocks Appearance HW9Z-LS Contact Block Mounting Adaptor 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Completed Unit Anti-Rotation Ring Part Number ø29mm Head Pushlock Turn Reset Style = Metal red HW1B-V3R HW4B-V3R yellow HW1B-V3Y HW4B-V3Y red HW1B-V4R HW4B-V4R yellow HW1B-V4Y HW4B-V4Y ø40mm Head EMO Pushlock Turn Reset* HW1B-V4R-EMO-2 HW4B-V4R-EMO-2 HW1B-X4R HW4B-X4R HW1B-V5R – ø40mm Head Pushlock Key Reset* Circuit Breakers ø60mm Head Pushlock Turn Reset* 1. *Available in red only. 2. All E-Stop buttons are not removable from the operator. 618 www.IDEC.com Note: Determine mounting centers to ensure proper spacing. 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Push Pull & Unibody E-Stop Pushbuttons (Assembled) Signaling Lights Contacts Plastic Bezel Metal Bezel Contacts Plastic Bezel Operator Only (Red) HW1B-Y2R HW4B-Y2R 1NO-1NC HW1E-BV4F11-R 2NC HW1E-BV4F02-R 1NO-2NC* HW1E-BV412R-TK2093-1 HW1B-Y2Y HW4B-Y2Y 1NO HW1B-Y2F10-M† HW4B-Y2F10-M† 1NC HW1B-Y2F01-M† HW4B-Y2F01-M† 1NO-1NC HW1B-Y2F11-M† HW4B-Y2F11-M† 2NC HW1B-Y2F02-M† HW4B-Y2F02-M† 2NO HW1B-Y2F20-M† HW4B-Y2F20-M† * NO contact is used as a monitoring contact Timers Operator Only (Yellow) O Full Voltage LED Code Unibody Illuminated E-Stops* LED 1NO-1NC HW1E-LV4F11QD-R-O 2NC HW1E-LV4F02QD-R-O 2NC (with push-on illumination) HW1E-TV4F02QD-R-O 1NO-1NC (with push-on illumination ) HW1E-TV4F11QD-R-O Terminal Numbering (Unibody only) Voltage Code Models Terminal Number 6VAC/DC 6V 1NO-1NC NO = 13/14, NC = 11/12 12VAC/DC 12V 2NC NC = 11/12, NC = 21/22 24VAC/DC 24V 120V HW1E-L HW1E-T LED + = X2, LED - = X1 120V AC 240V AC 240V Contactors Contacts Relays & Sockets ø40mm Unibody Pushlock Turn Reset* ø40mm Head Push–Pull 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1804091617 Terminal Blocks 1. * Available in Red only. 2. † Available in red or yellow. Insert color code in place of M (R: Red, Y: Yellow). 3. In place of O, specify Full Voltage LED Code. 4. With single unit construction, the positive action contacts are integrated in the body of the switch. This provides an extra degree of safety and reliability for critical emergency stop functions. 5. In the illuminated version, the light is independent of the switch action (except push-on LED model). 6. For accessories, see page 658. 7. For dimensions, see page 660. 8. For nameplates and shrouds, see page 658. 9. For contact assembly part numbers, see page 658. 10. All HW Series E-Stop operators include non-removable color caps. 11. All HW series E-Stops comply with EN60947-5-5, the IEC “E-Stop Addendum to the Low Voltage Directive,” this includes “tamper proof” operation whereby a change of contact state is not possible by “teasing” or “floating” the operator. 12. All HW series E-Stop switches comply with SEMI S2 standards. 13. All assembled part numbers in catalog include standard finger-safe spring-up (HW-U...) contacts. 14. Additional contact configurations available (up to 6 total contacts). 619 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 E – LV4 F 11 – Q D – R – 24V Bezel 1: Plastic Bezel 4: Metal Bezel* Full Voltage Code Button Colors (Illuminated E-Stop) Function R: Red Y: Yellow* Lamp Code B: Push Pull E: Unibody Pushlock Turn Reset (*not available for HW1E unibody) D: LED (*only available in 40mm Push Pull E-Stop) Illumination Signaling Lights Contacts BV4: Non-illuminated (unibody style) 11: 1NO-1NC LV4: Illuminated (unibody style) TV4: Illuminated Push On (unibody style) 02: 2NC 10: 1NO Y2: Non-illuminated Push Pull E-Stop 20: 2NO 6V: 12V: 24V: 120V: 240V: 6V AC/DC 12V AC/DC 24V AC/DC 120VC AC 240V AC Illumination Circuit blank: 40mm Push Pull & Non-illuminated Unibody E-Stop Q: Illuminated Unibody E-Stop Note: Use only for interpreting part numbers. Do not use for developing part numbers. Illuminated & Non-Illuminated E-Stop Pushbuttons (Replacement Parts) + Safety Lever Lock Contact Blocks Timers Style Contactors Anti-Rotation Ring + Operator Contact Block Mounting Adaptor Contacts 1NO 1NC FingerSafe Spring-Up Terminal HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Dummy Block + Style Part Number = Completed Unit Anti-Rotation Ring Appearance Part Number HW9Z-RL HW-CB2C Use with notched panel cutout to prevent unit rotation. 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. HW-DB 1. There are no replacement parts for the HW1E unibody E-Stop. 2. For illuminated unibody E-Stop, see page 659 for replacement lens. Safety Lever Lock Style Part Number HW9Z-LS Operators Style Part Number ø40mm Head Push-Pull Plastic Metal HW4B-Y2R Plastic HW1B-Y2Y Metal Terminal Blocks HW1B-Y2R red Mounting Adaptor yellow + Relays & Sockets Contact Blocks HW4B-Y2Y Circuit Breakers All E- Stop Buttons are not removable from the operator. 620 www.IDEC.com 1804091617 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices E-Stop Stations Signaling Lights Relays & Sockets 29mm Pushlock Turn Reset 40mm Pushlock Turn Reset Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel 1NO-1NC FB1W-HW1B-V311R FB1W-HW4B-V311R FB1W-HW1B-V411R FB1W-HW4B-V411R 2NC FB1W-HW1B-V302R FB1W-HW4B-V302R FB1W-HW1B-V402R FB1W-HW4B-V402R Contacts Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel 1NO-1NC FB1W-HW1B-Y211R FB1W-HW4B-Y211R FB1W-HW1B-X411R FB1W-HW4B-X411R 2NC FB1W-HW1B-Y202R FB1W-HW4B-Y202R FB1W-HW1B-X402R FB1W-HW4B-X402R Timers Contacts 40mm Push-Pull Reset 40mm Pushlock Key Reset Contactors Terminal Blocks 40mm EMO Pushlock Turn Reset Contacts Plastic Bezel Metal Bezel 1NO-1NC FB1W-HW1B-V411R-EMO-2 FB1W-HW4B-V411R-EMO-2 2NC FB1W-HW1B-V402R-EMO-2 FB1W-HW4B-V402R-EMO-2 1. Maximum of two contact blocks. 2. Box is supplied with yellow top and black bottom only. Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 621 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Jumbo Dome Pilot Lights Actual Size Jumbo Dome Signaling Lights Plastic Bezel Relays & Sockets HW1P-5Q0 Full Voltage 24V AC/DC HW1P-5Q4-N LED 1. 2. 3. 4. Timers Operator Only In place of N, specify the Lens/LED Color Code. Spring-Up terminals with 24V LED. For nameplates and accessories, see page 655 and 658. For dimensions, see page 660. N Lens/LED Color Code Color Code Amber A Green G Red R Blue S White W Yellow Y Jumbo Dome Replacement Parts Item Appearance Description Part Number Lens HW1A-P5N Contactors Polycarbonate Lens LED Diffusing Lens HW9Z-PP5C Jumbo Dome LED Lamp LED Lamps LSTDB-2N Terminal Blocks 1. In place of N, specify the Lens/LED Color Code. 2 . Use white LED for yellow lens. Lamp Ratings Operating Voltage Rated Current Power Consumption LSTDB-2 24V AC/DC ±10% 15mA 0.36W Circuit Breakers LED Part Number 622 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Pilot Lights (Assembled) Signaling Lights Operator Only Full Voltage 120V AC Transformer DC-DC Converter* Dome Metal Bezel Plastic Bezel Metal Bezel HW1P-1FQ0-N HW4P-1FQ0-N HW1P-2FQ0-N HW4P-2FQ0-N HW1P-1FQD-N-O HW4P-1FQD-N-O HW1P-2FQD-N-O HW4P-2FQD-N-O HW1P-1FH2D-N HW4P-1FH2D-N HW1P-2FH2D-N HW4P-2FH2D-N 240V AC HW1P-1FM4D-N HW4P-1FM4D-N HW1P-2FM4D-N HW4P-2FM4D-N 480V AC HW1P-1FT8D-N HW4P-1FT8D-N HW1P-2FT8D-N HW4P-2FT8D-N 110V DC HW1P-1D2D-N – HW1P-2D2D-N – Relays & Sockets Round Flush Plastic Bezel Timers Square Flush Plastic Bezel HW2P-1FQ0-N Full Voltage HW2P-1FQD-N-O Transformer DC-DC Converter* 120V AC HW2P-1FH2D-N 240V AC HW2P-1FM4D-N 480V AC HW2P-1FT8D-N 110V DC HW2P-1D2D-N Contactors Operator Only * DC-DC converter voltage input from 90-140V DC. Color Code Voltage Code Amber A 6VAC/DC 6V Green G 12VAC/DC 12V Red R 24VAC/DC 24V Blue S 120V AC 120V White W 240V AC 240V Yellow Y 1. In place of N, specify the Lens/LED Color Code from table below. 2. 3. 4. 5. 6. 7. In place of Ospecify the Full Voltage Code from table below. For nameplates and accessories, see page 655 and 658. For dimensions, see page 660. Pilot lights do not come with anti-rotation ring. Operator models come with operator and lens. Yellow pilot light comes with white LED. Circuit Breakers 1804091617 O LED Full Voltage Code Terminal Blocks N Lens/LED Color Code 800-262-IDEC (4332) • USA & Canada 623 Switches & Pilot Devices Part Number Structure H 1 P – 2 F Q D – R – 12V LED Voltage 1: Round Plastic 2: Square Plastic 4: Round Metal Operator 1: Flush 2: Dome Illumination Circuit Note: Use only for interpreting part numbers. Do not use for developing part numbers. A: Amber G: Green R: Red S: Blue W: White Y: Yellow Lamp Type Code D: LED Pilot Lights (Replacement Parts) + LED + Operator + Lens = Completed Unit (not applicable for full voltage units) Operators Timers Transformer Units Style Voltage Part Number LED 120V AC HW-FH20 240V AC HW-FM40 480V AC HW-FT80 110V DC† (6V secondary voltage) HW-RD0* 1. *DC-DC convertor can only be used with HW1P-100 and HW2P-100 operators 2. † DC-DC converter voltage input from 90-140V DC. Style Round Flush Type Plastic Bezel Metal Bezel Finger-Safe HW1P-1FQ0 HW4P-1FQ0 Finger-Safe HW1P-10 HW4P-10 Used for DC-DC convertor only HW1P-100 - Full Voltage Finger-Safe HW1P-2FQ0 HW4P-2FQ0 Transformer Finger-Safe HW1P-20 HW4P-20 Full Voltage Transformer Dome Square Flush Full Voltage LED Lamps Style Contactors Terminal Blocks (full voltage units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120V AC 240V: 240V AC Lens/LED Colors Q: Full Voltage H2: 120V AC Transformer M4: 240V AC Transformer T8: 480V AC Transformer D2: DC-DC Converter Transformer* Relays & Sockets W Bezel Signaling Lights Switches & Pilot Devices ø22mm - HW Series LED Voltage Part Number 6V AC/DC LSTD-6N 12V AC/DC LSTD-1N 24V AC/DC LSTD-2N 120V AC LSTD-H2N 240V AC LSTD-M4N 1. In place of N, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. Transformer Code Color A Blue S Green G White W Red Used for DC-DC convertor only HW2P-100 – Style Part Number Round/ Flush HW1A-P1-O Dome HW1A-P2-O Color Code Amber A Green G Red R Blue S White W Yellow Y For yellow lens use white LED. R For yellow lens use white LED. Circuit Breakers – – O Lens Color Code Lenses Code Amber HW2P-1FQ0 HW2P-10 1. Transformer type requires separate transformer & LED. Must select correct transformer bases. Use 6V LEDs. 2. Full voltage type only requires LED. N LED Color Code Color Finger-Safe Finger-Safe Square/ Flush HW2A-P1-O In place of O, specify the Lens Color Code. 624 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Illuminated Round Pushbuttons (Assembled) Signaling Lights Illuminated Full Voltage Pushbuttons Extended Extended w/ Full Shroud Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Momentary HW1L-M1-N HW1L-M1F10QD-N-O HW1L-M1F01QD-N-O HW1L-M1F11QD-N-O HW1L-M1F20QD-N-O HW4L-M1-N HW4L-M1F10QD-N-O HW4L-M1F01QD-N-O HW4L-M1F11QD-N-O HW4L-M1F20QD-N-O HW1L-M2-N HW1L-M2F10QD-N-O HW1L-M2F01QD-N-O HW1L-M2F11QD-N-O HW1L-M2F20QD-N-O HW4L-M2-N HW4L-M2F10QD-N-O HW4L-M2F01QD-N-O HW4L-M2F11QD-N-O HW4L-M2F20QD-N-O HW1L-MF2-N HW1L-MF2F10QD-N-O HW1L-MF2F01QD-N-O HW1L-MF2F11QD-N-O HW1L-MF2F20QD-N-O HW4L-MF2-N HW4L-MF2F10QD-N-O HW4L-MF2F01QD-N-O HW4L-MF2F11QD-N-O HW4L-MF2F20QD-N-O Maintained Plastic Bezel Operator Only 1NO 1NC 1NO-1NC 2NO HW1L-A1-N HW1L-A1F10QD-N-O HW1L-A1F01QD-N-O HW1L-A1F11QD-N-O HW1L-A1F20QD-N-O HW4L-A1-N HW4L-A1F10QD-N-O HW4L-A1F01QD-N-O HW4L-A1F11QD-N-O HW4L-A1F20QD-N-O HW1L-A2-N HW1L-A2F10QD-N-O HW1L-A2F01QD-N-O HW1L-A2F11QD-N-O HW1L-A2F20QD-N-O HW4L-A2-N HW4L-A2F10QD-N-O HW4L-A2F01QD-N-O HW4L-A2F11QD-N-O HW4L-A2F20QD-N-O HW1L-AF2-N HW1L-AF2F10QD-N-O HW1L-AF2F01QD-N-O HW1L-AF2F11QD-N-O HW1L-AF2F20QD-N-O HW4L-AF2-N HW4L-AF2F10QD-N-O HW4L-AF2F01QD-N-O HW4L-AF2F11QD-N-O HW4L-AF2F20QD-N-O Timers Metal Bezel Operator Only 1NO 1NC 1NO-1NC 2NO Relays & Sockets Flush Contacts Illuminated Transformer Pushbuttons Flush Extended w/ Full Shroud Metal Bezel Plastic Bezel Metal Bezel HW1L-M1-N HW1L-M1F11-OD-N HW1L-M1F20-OD-N HW4L-M1-N HW4L-M1F11-OD-N HW4L-M1F20-OD-N HW1L-M2-N HW1L-M2F11-OD-N HW1L-M2F20-OD-N HW4L-M2-N HW4L-M2F11-OD-N HW4L-M2F20-OD-N HW1L-MF2-N HW1L-MF2F11-OD-N HW1L-MF2F20-OD-N HW4L-MF2-N HW4L-MF2F11-OD-N HW4L-MF2F20-OD-N Operator Only 1NO-1NC 2NO HW1L-A1-N HW1L-A1F11-OD-N HW1L-A1F20-OD-N HW4L-A1-N HW4L-A1F11-OD-N HW4L-A1F20-OD-N HW1L-A2-N HW1L-A2F11-OD-N HW1L-A2F20-OD-N HW4L-A2-N HW4L-A2F11-OD-N HW4L-A2F20-OD-N HW1L-AF2-N HW1L-AF2F11-OD-N HW1L-AF2F20-OD-N HW4L-AF2-N HW4L-AF2F11-OD-N HW4L-AF2F20-OD-N Color Code Amber A Green G Red R Blue S White W Yellow Y Yellow LED not available. Use white LED for yellow lens. O Voltage Code Full Voltage Models Transformer Models Voltage Code Voltage Code 6V AC/DC 6V 120V AC H2 12V AC/DC 12V 240V AC M4 24V AC/DC 24V 480V AC T8 120V AC 120V 240V AC 240V 800-262-IDEC (4332) • USA & Canada Circuit Breakers In place of Ospecify Voltage Code from table. Light independent of switch position. For replacement part numbers, see page 626. For nameplates and accessories, see page 655. and 658. 6. For dimensions, see page 660. 7. For contact assembly part numbers, see page 659. 8. Full voltage and transformer models use the same operator. 9. Additional contact configurations available (up to 6 total contacts). 10. Yellow pushbutton comes with white LED. 2. 3. 4. 5. N Lens/LED Color Code Terminal Blocks Momentary Plastic Bezel Operator Only 1NO-1NC 2NO 1. In place of N, specify Lens/LED Color Code from table. 1804091617 Extended Metal Bezel Maintained Plastic Bezel Contactors Contacts 625 Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series H 1: Plastic 4: Metal Function Contactors 1 L Part Number Structure – M 1F 10 Q D – G – 12V Lens Color Operator M: Momentary A: Maintained A: Amber S: Blue G: Green W: White R: Red Y: Yellow Contact Arrangement 1F: Flush 2F: Extended F2F: Extended w/ shroud 10: 01: 11: 20: 1NO 1NC 1NO-1NC 2NO Note: Use only for interpreting part numbers. Do not use for developing part numbers. Illumination Circuit Q: Full Voltage H2: Transformer 120V AC M4: Transformer 240V AC T8: Transformer 480V AC (full voltage units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120VC AC 240V: 240V AC Illuminated Round Pushbuttons (Replacement Parts) Transformer* + Contact Blocks + Lead Holder + Mounting Adaptor + Safety Lever Lock + Lamp + Anti-Rotation Ring + Operator + Lens Completed Unit = *Transformer not needed with full voltage models. Contact Blocks Lamp Circuit Components Style Description Lead Holder For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. HW-LH3 For use with odd number of contacts. HW-DA1FBN Dummy Block with Full Voltage Adaptor Transformer Unit (6V secondary voltage) DC-DC Converter For use with even number of contacts. Terminals Finger-Safe Part Number Finger-Safe TW-DA1FB 120VAC 240VAC 480VAC Finger-Safe 1NO 1NC Finger-Safe Spring-Up Terminal HW-U10 HW-U10R (early make) HW-U01 HW-U01R (late break) 1. All assembled part numbers in catalog include standard finger-safe spring-up (HW-U...) contacts. . Style Part Number 110VDC 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. TW-F126B TW-F246B TW-F486B HW-L16D Operators Extended with Full Shroud Contacts Anti-Rotation Ring Part Number Appearance HW-CBL 1. *With spring-up terminals - to use spring-up terminal type, must use transformer type operator designed for spring-up transformer. 2. ** DC-DC converter voltage input from 90-140V DC. Round Flush/ Extended Style Contact Block Mounting Adaptor Plastic Bezel Metal Bezel Momentary HW1L-M0 HW4L-M0 Maintained HW1L-A0 HW4L-A0 Momentary HW1L-MF0 HW4L-MF0 Maintained HW1L-AF0 HW4L-AF0 Style Circuit Breakers W LED Lamp Voltage Bezel Full Voltage Adaptor Terminal Blocks Switches & Pilot Devices Safety Lever Lock Style HW9Z-RL Use with notched panel cutout to prevent unit rotation. LED Lamps Style Part Number HW9Z-LS Lenses Style Round Flush Part Number HW1A-L1-N Round Extended HW1A-L2-N LED Voltage Part Number 6V AC/DC LSTD-6N 12V AC/DC LSTD-1N 24V AC/DC LSTD-2N 120V AC LSTD-H2N 240V AC LSTD-M4N 1. In place of N, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Yellow LED not available, use white LED when using yellow lens. In place of N, specify the Lens Color Code from previous page. 626 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Illuminated Mushroom & Square Pushbuttons (Assembled) Signaling Lights Momentary Maintained 1. Contacts Plastic Bezel Metal Bezel Plastic Bezel Operator Only† HW1L-M4-N HW4L-M4-N HW2L-M1-N 1NO HW1L-M4F10QD-N-O HW4L-M4F10QD-N-O HW2L-M1F10QD-N-O 1NC HW1L-M4F01QD-N-O HW4L-M4F01QD-N-O HW2L-M1F01QD-N-O 1NO-1NC HW1L-M4F11QD-N-O HW4L-M4F11QD-N-O HW2L-M1F11QD-N-O 2NO HW1L-M4F20QD-N-O HW4L-M4F20QD-N-O HW2L-M1F20QD-N-O Operator Only† HW1L-A4-N HW4L-A4-N HW2L-A1-N 1NO HW1L-A4F10QD-N-O HW4L-A4F10QD-N-O HW2L-A1F10QD-N-O 1NC HW1L-A4F01QD-N-O HW4L-A4F01QD-N-O HW2L-A1F01QD-N-O 1NO-1NC HW1L-A4F11QD-N-O HW4L-A4F11QD-N-O HW2L-A1F11QD-N-O 2NO HW1L-A4F20QD-N-O HW4L-A4F20QD-N-O HW2L-A1F20QD-N-O 1NO-1NC HW1L-M4F11OD-N HW4L-M4F11OD-N HW2L-M1F11OD-N 2NO HW1L-M4F20OD-N HW4L-M4F20OD-N HW2L-M1F20OD-N 1NO-1NC HW1L-A4F11OD-N HW4L-A4F11OD-N HW2L-A1F11OD-N 2NO HW1L-A4F20OD-N HW4L-A4F20OD-N HW2L-A1F20OD-N † Full voltage and transformer units use the same operator. 3. In place of Ospecify the Voltage Code from table. 4. Light independent of switch position 5. For nameplates and accessories, see page 655. and 658. 6. For dimensions, see page 660. 7. For contact assembly part numbers, see page 659. 8. Additional contact configurations available (up to 6 total contacts). 9. Yellow pushbutton comes with white LED. Code Amber A Green G Red R Blue S White W Yellow Y* 1. *40mm mushroom lenses not available in yellow. 2. Yellow LED not available. Use white LED for yellow lens. 800-262-IDEC (4332) • USA & Canada Full Voltage Models Transformer Models Voltage Code Voltage Code 6V AC/DC 6V 120V AC H2 12V AC/DC 12V 240V AC M4 24V AC/DC 24V 480V AC T8 120V AC 120V 240V AC 240V Circuit Breakers 1804091617 Color O Voltage Code Terminal Blocks 2. In place of N, specify the Lens/LED Color Code from table. N Lens/LED Color Code Contactors Transformer Maintained Square Flush Timers Full Voltage Momentary Relays & Sockets 40mm Mushroom Head 627 Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series H Contactors 1 Part Number Structure – M 1 F 10 Q D – G – 12V L Voltage 1: Round Plastic 2: Square Plastic 4: Round Metal Function M: Momentary A: Maintained Lens Color Operator 1: Square Flush 4: Mushroom A: Amber S: Blue G: Green W: White R: Red Y: Yellow Contact Arrangement 10: 01: 11: 20: Note: Use only for interpreting part numbers. Do not use for developing part numbers. 1NO 1NC 1NO-1NC 2NO Illumination Circuit Q: Full Voltage H2: Transformer 120V AC M4: Transformer 240V AC T8: Transformer 480V AC (full voltage units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120VC AC 240V: 240V AC Illuminated Mushroom & Square Pushbuttons (Replacement Parts) Transformer* + Contact Blocks + Lead Holder + Adaptor† + Safety Lever Lock + LED Anti-Rotation Ring + + Operator + Lens = Completed Unit *Transformer not needed with full voltage models. Lamp Circuit Components Contact Blocks Style Description Lead Holder For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. HW-LH3 For use with odd number of contacts. HW-DA1FBN Dummy Block with Full Voltage Adaptor Transformer Unit (6V secondary voltage) DC-DC Converter For use with even number of contacts. Terminals Finger-Safe Part Number Finger-Safe TW-DA1FB Contacts 1NO 1NC Finger-Safe Spring-Up Terminal HW-U10 HW-U10R (early make) HW-U01 HW-U01R (late break) 1. All assembled part numbers in catalog include standard finger-safe spring-up contacts (HW-U...). . Style Part Number Anti-Rotation Ring Appearance Part Number HW-CBL 120VAC 240VAC 480VAC Finger-Safe 110VDC 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. TW-F126B TW-F246B TW-F486B HW-L16D Safety Lever Lock Style 1. *With spring-up terminals - to use spring-up terminal type, must use transformer type operator designed for spring-up transformer. 2. ** DC-DC converter voltage input from 90-140V DC. Plastic Bezel Metal Bezel Momentary HW1L-M0L HW4L-M0L Maintained HW1L-A0L HW4L-A0L Momentary HW2L-M0 – Maintained Use with notched panel cutout to prevent unit rotation. LED Lamps Style LED Lenses Square HW9Z-RL Part Number HW9Z-LS Operators ø40mm Mushroom Style Contact Block Mounting Adaptor Style Circuit Breakers W Bezel Full Voltage Adaptor Terminal Blocks Switches & Pilot Devices Style Part Number ø40mm Mushroom Lens ALW4BLU-N* Square Flush HW2A-L1-N Voltage Part Number 6V AC/DC LSTD-6N 12V AC/DC LSTD-1N 24V AC/DC LSTD-2N 120V AC LSTD-H2N 240V AC LSTD-M4N 1. In place of N, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Yellow LED not available, use white LED when using yellow lens. HW2L-A0 1. In place of N, specify the Lens Color Code. 2. *Mushroom lens not available in yellow. 628 www.IDEC.com 1804091617 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Selector Switches 2-Position (Assembled) Signaling Lights Mounting Operator Position L Handle R Operator Only Maintained L Spring Return from Right L R R Knob Lever HWQS-2T HWQS-2L HWQS-21T HWQS-21L 1 O X Knob Lever HWQS-2TF10 HWQS-2LF10 HWQS-21TF10 HWQS-21LF10 1NO1NC 1 2 O X X O Knob Lever HWQS-2TF11 HWQS-2LF11 HWQS-21TF11 HWQS-21LF11 2NO 1 2 O O X X Knob Lever HWQS-2TF20 HWQS-2LF20 HWQS-21TF20 HWQS-21LF20 2NO2NC 1 2 3 4 X O X O O X O X Knob Lever HWQS-2TF22 HWQS-2LF22 HWQS-21TF22 HWQS-21LF22 Timers 1NO Q Bezel Type Type Code Plastic 1 Metal 4 Contactors 1. In place of Q enter 1 for plastic bezel or 4 for metal bezel. 2. For nameplates, see page 655. 3. All assembled part numbers in catalog include standard fingersafe spring-up (HW-U...) contacts. 4. Standard color for knob and lever is black. 5. Optional colors available for lever type. Must order in components. See next page for part numbers. 6. Additional contact configurations available (up to 6 total contacts). 7. For Truth Tables see page 668. Relays & Sockets Contact 2-Position Selector Switches Terminal Blocks Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 629 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Part Number Structure H W 1 S - 2 1 T F 10 Contact Arrangement 10: 1NO 11: 1NO-1NC 20: 2NO Bezel 1: Plastic 4: Metal # of Positions 2: 2-Position Handle Operator T: Knob L: Lever Signaling Lights blank: Maintained 1: Spring Return from Right Note: Use only for interpreting part numbers. Do not use for developing part numbers. Selector Switches 2-Position (Replacement Parts) Relays & Sockets Contact Blocks + Mounting Adaptor + Safety Lever Lock Contact Blocks Style Anti-Rotation Ring + Operator = Completed Unit Anti-Rotation Ring Contacts 1NO 1NC FingerSafe Spring-Up Terminal HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Dummy Block Timers + Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. HW-DB Contact Block Mounting Adaptor Style Style Operators Style Description Handle Plastic Bezel Metal Bezel Knob HW1S-2T HW4S-2T Lever HW1S-2 HW4S-2 Knob HW1S-21T HW4S-21T Lever HW1S-21 HW4S-21 Part Number Maintained Contactors HW-CB2C 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Style Spring Return from Right 1. Knob operator comes with black handle. 2. To order lever type, lever and inserts must be ordered separately, along with lever operator. See part numbers below. Part Number Terminal Blocks Levers & Inserts HW9Z-LS Style Part Number Lever Circuit Breakers Lever Color Insert ASWHHL-M TW-HC1-M Standard lever color is black. Standard insert color is white. 630 www.IDEC.com M Handle/Insert Color Code Color Code Black* B Blue S Green G Red R Yellow Y White W † 1. * Lever color inserts not available in black. 2. †Lever not available in white. 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Selector Switches 3-Position (Assembled) Signaling Lights Mounting Contact 3–Position Selector Switches Operator Position L C Handle R C L C L R Spring Return Two-Way C L R C L R Knob Lever HWQS-3T* HWQS-3L HWQS-31T HWQS-31L HWQS-32T HWQS-32L HWQS-33T HWQS-33L R 1 2 0 0 X 0 X X Knob Lever HWQS-3TF11 HWQS-3LF11 HWQS-31TF11 HWQS-31LF11 HWQS-32TF11 HWQS-32LF11 HWQS-33TF11 HWQS-33LF11 2NO 1 2 X 0 0 0 0 X Knob Lever HWQS-3TF20 HWQS-3LF20 HWQS-31TF20 HWQS-31LF20 HWQS-32TF20 HWQS-32LF20 HWQS-33TF20 HWQS-33LF20 2NC 1 2 0 X X X X 0 Knob Lever HWQS-3TF02 HWQS-3LF02 HWQS-31TF02 HWQS-31LF02 HWQS-32TF02 HWQS-32LF02 HWQS-33TF02 HWQS-33LF02 2NO1NC 1 2 3 X 0 0 0 0 X 0 X 0 Knob HWQS-3JTF21N1 – – – 2NO2NC 1 2 3 4 X 0 0 X 0 0 X X 0 X X 0 Knob HWQS-3TF22 HWQS-31TF22 HWQS-32TF22 HWQS-33TF22 2NO2NC 1 2 3 4 0 X X 0 0 0 X 0 X 0 0 X Knob HWQS-3STF22N9 – – – 4NO 1 2 3 4 X 0 X 0 0 0 0 0 0 X 0 X Knob 4NO 1 2 3 4 X 0 X 0 0 X 0 0 0 X 0 X Knob HWQS-3STF40N2 – – – 4NC 1 2 3 4 0 X 0 X X X X X X 0 X 0 Knob HWQS-3TF04 HWQS-31TF04 HWQS-32TF04 HWQS-33TF04 Timers 1NO1NC HWQS-3TF40 HWQS-31TF40 HWQS-32TF40 HWQS-33TF40 Type Code Plastic 1 Metal 4 Contactors Q Bezel Type Terminal Blocks 7. All assembled part numbers in catalog include standard finger-safe spring-up (HW-U...) contacts. 8. Standard color for knob and lever is black. 9. Optional colors available for lever type. Must order in components. See next page for part numbers. 10. Additional contact configurations available (up to 6 total contacts). 11. For Truth Tables see page 668. 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. In place of Q enter 1 for plastic bezel or 4 for metal bezel. 2. Knob operator includes black knob/lever operator includes black lever. 3. * Three position operator is available with three different cams. HWQS-3T: Maintained (standard cam) HWQS-3ST: Maintained (S cam) HWQS-3JT: Maintained (J cam) 4. Operator cams are color coded (white=standard cam, red=S cam, black =J cam). 5. For nameplates, see page 655. 6. For contact assembly part numbers, see page 659 1804091617 Spring Return from Left Relays & Sockets Operator Only Spring Return from Right Maintained 631 Switches & Pilot Devices ø22mm - HW Series Part Number Structure H W 1 S - 3 1 F 20 11: 20: 21: 22: 40: 04: Bezel Signaling Lights 1: Plastic 4: Metal # of Positions 3: 3-Position Handle Operator Note: Use only for interpreting part numbers. Do not use for developing part numbers. T: Knob L: Lever blank: Maintained 1: Spring Return from Right 2: Spring Return from Left 3: Spring Return Two Way 1NO-1NC 2NO 2NO-1NC 2NO-2NC 4NO 4NC Selector Switches 3-Position (Replacement Parts) + Mounting Adaptor + Safety Lever Lock Contact Blocks Timers Style + Anti-Rotation Ring 1NO 1NC FingerSafe Spring-Up Terminal HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Dummy Block Style = Completed Unit Use with notched panel cutout to prevent unit rotation. HW9Z-RL Operators Style HW-DB HW-CB2C 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. 1. 2. 3. 4. Safety Lever Lock Description Handle Plastic Bezel Metal Bezel Maintained (standard cam) Knob HW1S-3T HW4S-3T Lever HW1S-3 HW4S-3 Maintained (S cam) Knob HW1S-3ST HW4S-3ST Maintained (J cam) Knob HW1S-3JT HW4S-3JT Spring Return from Right (standard cam) Knob HW1S-31T HW4S-31T Lever HW1S-31 HW4S-31 Spring Return from Left (standard cam) Knob HW1S-32T HW4S-32T Lever HW1S-32 HW4S-32 2-Way Spring Return (standard cam) Knob HW1S-33T HW4S-33T Lever HW1S-33 HW4S-33 Knob operator comes with black handle. Three position knob operator is available with three different cams. Operator cams are color coded (white=standard cam, red=S cam, black =J cam). To order lever type, lever and inserts must be ordered separately, along with lever operator. See part numbers below. Part Number M Handle/Insert Color Code Levers & Inserts HW9Z-LS Style Part Number Lever Circuit Breakers Operator Part Number Part Number Contactors Style Style + Anti-Rotation Ring Contacts Contact Block Mounting Adaptor Terminal Blocks T Contact Arrangement Contact Blocks Relays & Sockets Switches & Pilot Devices Lever Color Insert ASWHHL-M TW-HC1-M Black* B Color Blue S Yellow Y Green G White W Red R Code † 1. * Lever color inserts not available in black. 2. †Lever not available in white. Standard lever color is black. Standard insert color is white. 632 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Selector Switches 4- & 5-Position (Assembled) Signaling Lights 2 3 Maintained 2 4 1 3 Mounting 1 Handle Contact Contact 5-Position Selector Switch Operator Position Operator Position 1 2 3 4 Handle Maintained 2 5 3 1 4 Relays & Sockets Mounting 4-Position Selector Switches 5 4 Operator Only Knob Lever HWQS-4T HWQS-4L Operator Only 2NO2NC 1 2 3 4 X 0 0 0 0 X 0 0 O 0 X 0 O 0 0 0 Knob Lever HWQS-4TF12 HWQS-4LF12 1NO3NC 1 2 3 4 O O O O X X O O X O X O X O O X Knob Lever HWQS-4TF13N6 HWQS-4LF13N6 2NO2NC 1 2 3 4 X O O O O X O O O O X O O O O X Knob Lever HWQS-4TF22N3 HWQS-4LF22N3 O X O O O O O O O O X O O O O X Knob Lever HWQS-5TF22N3 HWQS-5LF22N3 Q Bezel Type Type Code Plastic 1 Metal 4 Terminal Blocks In place of Q enter 1 for plastic bezel or 4 for metal bezel. Knob operator includes black knob/lever operator includes black lever. For nameplates, see page 655. For contact assembly part numbers, see page 659. Five position circuit cannot be made to make five independent contact closures. All assembled part numbers in catalog include standard finger-safe spring-up (HW-U...) contacts. 7. Standard color for knob and lever is black. 8. Optional colors available for lever type. Must order in components. See next page for part numbers. 9. Additional contact configurations available (up to 6 total contacts). 10. For Truth Tables see page 668. X O O O Contactors 1. 2. 3. 4. 5. 6. 1 2 3 4 HWQS-5T HWQS-5L Timers 1NO2NC Knob Lever Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 633 Switches & Pilot Devices ø22mm - HW Series Part Number Structure H W 1 S - 4 T F 13N6 Contact Arrangement Bezel 1: Plastic 4: Metal Signaling Lights (based on desired truth table) 12: 1NO-2NC 13N6: 1NO-3NC 22N3: 2NO-2NC # of Positions 4: 4-Position 5: 5-Position Handle T: Knob L: Lever Note: Use only for interpreting part numbers. Do not use for developing part numbers. Selector Switches 4- & 5-Position (Replacement Parts) Contact Blocks + Mounting Adaptor + Safety Lever Lock Contact Blocks Style + Anti-Rotation Ring + Contacts 1NO 1NC FingerSafe Spring-Up Terminal HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) HW-DB Style Style Use with notched panel cutout to prevent unit rotation. Operators Position Description Part Number 4 Contactors 5 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Terminal Blocks Part Number Handle Plastic Bezel Metal Bezel Knob HW1S-4T HW4S-4T Lever HW1S-4 HW4S-4 Knob HW1S-5T HW4S-5T Lever HW1S-5 HW4S-5 Maintained HW-CB2C Maintained 1. Knob operator comes with black handle. 2. To order lever type, lever and inserts must be ordered separately, along with lever operator. See part numbers below. Levers & Inserts Style Part Number M Handle/Insert Color Code Color HW9Z-LS Lever Lever Color Insert Circuit Breakers Completed Unit Part Number Contact Block Mounting Adaptor ASWHHL-M TW-HC1-M Standard lever color is black. Standard insert color is white. 634 = HW9Z-RL Style Style Operator Anti-Rotation Ring Dummy Block Timers Relays & Sockets Switches & Pilot Devices www.IDEC.com Code Black* B Blue S Green G Red R Yellow Y White† W 1. * Lever color inserts not available in black. 2. †Lever not available in white. 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Key Switches 2-Position (Assembled) Signaling Lights Mounting Contact 2-Position Key Switches Operator Position L R L R Spring Return from Right L HWQK-2A HWQK-21B R 1NO 1 O X HWQK-2AF10 HWQK-21BF10 1NO1NC 1 2 0 X X 0 HWQK-2AF11 HWQK-21BF11 2NO 1 2 O O X X HWQK-2AF20 HWQK-21BF20 2NO2NC 1 2 3 4 0 X 0 X X 0 X 0 HWQK-2AF22 HWQK-21BF22 Timers Q Bezel Type Type Code Plastic 1 Metal 4 Contactors 1. In place of Q enter 1 for plastic bezel or 4 for metal bezel. 2. Key is removable in all maintained positions. Other key removable options available. 3. Two keys are supplied with all switches. 4. All standard operators are keyed alike. 5. Other key removable options available. See table below 6. For nameplates, see page 655. 7. For contact assembly part numbers, see page 659. 8. Key is retained in “Spring Return” position. 9. All assembled part numbers in catalog include finger-safe spring-up (HW-U...) contacts. 10. Additional contact configurations available (up to 6 total contacts). 11. For Truth Tables see page 659. Relays & Sockets Operator Only Maintained Key Removable Option Codes Description A Key not retained in any position (removable in all positions) B Key retained in right position only (removable LEFT) C Key retained in left position only (removable RIGHT) Terminal Blocks Code Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 635 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 K - 2 1 B 10 Contact Arrangement 10: 1NO 20: 2NO 11: 1NO-1NC 22: 2NO-2NC Bezel 1: Plastic 4: Metal # of Positions 2: 2-Position Operator Key Retained Position Signaling Lights blank: Maintained 1: Spring Return from Right A: Key not retained in any position (removable in all positions) B: Key retained in right position only (removable LEFT) C: Key retained in left position only (removable RIGHT) Note: Use only for interpreting part numbers. Do not use for developing part numbers. Key Switches 2-Position (Replacement Parts) Contact Assembly Relays & Sockets F + Mounting Adaptor + Safety Lever Lock Contact Blocks Timers Style + Anti-Rotation Ring + Operator = Completed Unit Safety Lever Lock Contacts 1NO 1NC FingerSafe Spring-Up Terminal HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Style Part Number HW9Z-LS Anti-Rotation Ring Dummy Block HW-DB Style Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Contactors Contact Block Mounting Adaptor Style Part Number Operators Style HW-CB2C Terminal Blocks 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Description Plastic Bezel Metal Bezel Maintained HW1K-2A HW4K-2A Maintained, key removed left only HW1K-2B HW4K-2B Spring Return from Right HW1K-21B HW4K-21B Maintained, key removed right only HW1K-2C HW4K-2C Circuit Breakers 1. Operator includes two keys. 2. All standard operators are keyed alike. 636 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Key Switches 3-Position (Assembled) Signaling Lights Mounting Contact 3-Position Key Switches Operator Position L C R Spring Return from Right Maintained C L Spring Return from Left C L R Spring Return Two Way C R L C L R R Q Bezel Type Operator Only HWQK-3A* HWQK-31B HWQK-32C HWQK-33D Type HWQK-31BF11 HWQK-32CF11 HWQK-33DF11 Plastic 1 Metal 4 1 2 0 0 X 0 X X HWQK-3AF11 2NO 1 2 X 0 0 0 0 X HWQK-3AF20 HWQK-31BF20 HWQK-32CF20 HWQK-33DF20 2NC 1 2 0 X X X X 0 HWQK-3AF02 HWQK-31BF02 HWQK-32CF02 HWQK-33DF02 2NO1NC 1 2 3 X 0 0 0 0 X 0 X 0 HWQK-3JAF21N1 2NO2NC 1 2 3 4 X 0 0 X 0 0 X X 0 X X 0 HWQK-3AF22 2NO2NC 1 2 3 4 0 X X 0 0 0 X 0 X 0 0 X HWQK-3SAF22N9 4NO 1 2 3 4 X 0 X 0 0 0 0 0 0 X 0 X HWQK-3AF40 4NO 1 2 3 4 X 0 X 0 0 X 0 0 0 X 0 X HWQK-3SAF40N2 4NC 1 2 3 4 0 X 0 X X X X X X 0 X 0 HWQK-3AF04 – HWQK-31BF40 – HWQK-31BF04 HWQK-32CF22 – HWQK-33DF22 – HWQK-32CF40 – HWQK-33DF40 – HWQK-32CF04 HWQK-33DF04 Key Removable Option Codes Code Description A Key not retained in any position (removable in all positions) B Key retained in right position only C Key retained in left position only D Key retained in left and right (3 position only) E Key retained in center only (3 position only) G Key retained right and center (3 position only) H Key retained left and center (3 position only) Circuit Breakers 800-262-IDEC (4332) • USA & Canada – Terminal Blocks 8. For contact assembly part numbers, see page 659. 9. All assembled part numbers in catalog include standard Finger-Safe spring-up (HW-U...) contacts. 10. Additional contact configurations available (up to 6 total contacts). 11. For Truth Tables see page 668. Contactors 1804091617 HWQK-31BF22 – Timers 1. In place of Q enter 1 for plastic bezel or 4 for metal bezel. 2. Key is removable in all maintained positions. Other key removable options available. 3. Two keys are supplied with all switches. 4. All standard operators are keyed alike. 5. Other key removable options available. See table to the right. 6. * Operator is available with three different cams. HWQK-3A: Maintained (standard cam) HWQK-3SA: Maintained (Cam S) HWQK-3JA: Maintained (Cam J) 7. For nameplates, see page 655. – Code Relays & Sockets 1NO1NC 637 Switches & Pilot Devices ø22mm - HW Series Part Number Structure H W 1 K - 3 1 B F 11 Contact Arrangement 11: 1NO-1NC 40: 4NO 20: 2NO 04: 4NC 22: 2NO-2NC Bezel 1: Plastic 4: Metal # of Positions 3: 3-Position Operator Signaling Lights blank: Maintained 1: Spring Return from Right 2: Spring Return from Left 3: Spring Return Two Way Key Removable Option Code (see chart on previous page) Note: Use only for interpreting part numbers. Do not use for developing part numbers. Key Switches 3-Position (Replacement Parts) Contact Assembly Relays & Sockets Switches & Pilot Devices + Mounting Adaptor + Safety Lever Lock Timers Anti-Rotation Ring + Operator = Completed Unit Safety Lever Lock Contact Blocks Style + Contacts 1NO 1NC FingerSafe Spring-Up Terminal HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Style Part Number HW9Z-LS Anti-Rotation Ring Dummy Block HW-DB Style Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Contactors Contact Block Mounting Adaptor Style Part Number Operators Style HW-CB2C 1. 2. 3. 4. Plastic Bezel Metal Bezel HW1K-3A HW4K-3A Maintained (S cam) HW1K-3SA HW4K-3SA Maintained (J cam) HW1K-3JA HW4K-3JA Spring Return from Right (standard cam) HW1K-31B HW4K-31B Spring Return from Left (standard cam) HW1K-32C HW4K-32C 2-Way Spring Return (standard cam) HW1K-33D HW4K-33D Operator includes two keys. All standard operators are keyed alike. Other key removable options available. See table on previous page. Key not removable from spring-returned position Circuit Breakers Terminal Blocks 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Description Maintained (standard cam) 638 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Illuminated Selector Switches 2-Position (Assembled) Signaling Lights 2-Position Illuminated Selector Switches Contact Operator Position L Part Number Type Maintained R L Operator Only Full Voltage 1 2 O X X O 2NO 1 2 X O O X 2NO2NC 1 2 3 4 O X O X X O X O 120V 240V 480V Transformer Full Voltage 120V 240V 480V Transformer Full Voltage 120V 240V 480V Transformer L R HWQF-2N HWQF-21N HWQF-2F11QD-N-O HWQF-21F11QD-N-O HWQF-2F11H2D-N HWQF-2F11M4D-N HWQF-2F11T8D-N HWQF-21F11H2D-N HWQF-21F11M4D-N HWQF-21F11T8D-N HWQF-2F20QD-N-O HWQF-21F20QD-N-O HWQF-2F20H2D-N HWQF-2F20M4D-N HWQF-2F20T8D-N HWQF-21F20H2D-N HWQF-21F20M4D-N HWQF-21F20T8D-N HWQF-2F22QD-N-O HWQF-21F22QD-N-O HWQF-2F22H2D-N HWQF-2F22M4D-N HWQF-2F22T8D-N HWQF-21F22H2D-N HWQF-21F22M4D-N HWQF-21F22T8D-N Timers 1NO1NC R Spring Return from Right Relays & Sockets Mounting Style Code Full Voltage Models Amber A Voltage Green G 6VAC/DC Red R 12VAC/DC 12V Blue S 24VAC/DC 24V White W 120V AC 120V Yellow Y 240V AC 240V Q Bezel Code Type Code Code Plastic 1 6V Metal 4 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1804091617 O Full Voltage Code Color Terminal Blocks N Lens/LED Color Code Contactors 1. In place of N specify Lens/LED color code. 2. In place of O specify Full Voltage code. 3. In place of Q enter 1 for plastic bezel or 4 for metal bezel. 4. For nameplates, see page 655. 5. For contact assembly part numbers, see page 659. 6. Light is independent of switch position. 7. All assembled part numbers in catalog include standard Finger-Safe spring-up (HW-U...) contacts. 8. Yellow selector switch comes with white LED. 9. Additional contact configurations available (up to 6 total contacts). 10. For Truth Tables see page 668. 639 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices H W 1 Signaling Lights Part Number Structure – 21 F 20 Q D – G – 24V LED Voltage Bezel 1: Plastic 4: Metal (Full voltage units only) 6V: 6V AC/DC A: Amber S: Blue G: Green W: White 12V: 12V AC/DC R: Red Y: Yellow 24V: 24V AC/DC 120V: 120V AC 240V: 240V AC Lens Color Position 2: Maintained 21: Spring Return from Right Contact Arrangement 11: 1NO-1NC 20: 2NO 22: 2NO-2NC Illumination Circuit Q: Full Voltage H2: Transformer 120V AC M4: Transformer 240V AC T8: Tranformer 480V AC Note: Use only for interpreting part numbers. Do not use for developing part numbers. Relays & Sockets F Illuminated Selector Switches 2-Position (Replacement Parts) Transformer* + Contact Blocks + Lead Holder + Mounting Adaptor + Safety Lever Lock + LED + Anti-Rotation Ring + Operator Lens = Completed Unit *Transformer not needed with full voltage models. Lamp Circuit Components Description Lead Holder For use with HW-CBL on all illuminated pushbutton units. HW-LH3 One required for each deck (pair) of contacts. Timers Full Voltage Adaptor Transformer Unit (6V secondary voltage) Contactors Contact Blocks Terminals Part Number Style Dummy Block with Full Voltage Adaptor For use with odd number of contacts. For use with even number of contacts. 120VAC 240VAC 480VAC Finger-Safe HW-DA1FBN Style Contacts 1NO 1NC Finger-Safe Spring-Up Terminal HW-U10 HW-U10R (early make) HW-U01 HW-U01R (late break) Contact Block Mounting Adaptor N Lens/LED Color Code Style Part Number HW-CBL Finger-Safe Finger-Safe TW-DA1FB 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. TW-F126B TW-F246B TW-F486B Color Code Color Code Amber A Blue S Green G White W Red R Yellow Y Anti-Rotation Ring Style Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Safety Lever Lock Style DC-DC Converter Terminal Blocks + 110VDC Part Number HW-L16D Style 1. DC-DC convertor features spring-up terminals. 2. DC-DC convertor applicable voltage range 90-140V DC. HW9Z-LS LED Operators Style Description Maintained Plastic Bezel HW1F-2 Metal Bezel Illuminated Knob Appearance Part Number HW4F-2 HW9Z-FDY-N Circuit Breakers Spring return from right HW1F-21 Illuminated knobs must be ordered separately. 640 Lamps HW4F-21 In place of N, specify the Color Code. www.IDEC.com Voltage Part Number 6V AC/DC LSTD-6N 12V AC/DC LSTD-1N 24V AC/DC LSTD-2N 120V AC LSTD-H2N 240V AC LSTD-M4N 1. In place of N, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Use white LED for yellow lens. Yellow LED not available. 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Illuminated Selector Switches 3-Position (Assembled) Signaling Lights 3-Position Illuminated Selector Switches Mounting Part Number Operator Position L C Type Maintained R C L Operator Only X O X X 2NO 1 2 X 0 0 0 O X 2NC 1 2 O X X X X O 1 2 3 4 X O O X O O X X O X X O Full Voltage 2NO2NC X O X O O O O O O X O X Full Voltage 4NO 1 2 3 4 O X O X X X X X X O X O Full Voltage 4NC 1 2 3 4 Transformer 120V 240V 480V Full Voltage Transformer 120V 240V 480V Full Voltage Transformer Transformer Transformer Transformer 120V 240V 480V 120V 240V 480V 120V 240V 480V C L R HWQF-32N R HWQF-33N HWQF-3F11QD-N-O HWQF-31F11QD-N-O HWQF-32F11QD-N-O HWQF-33F11QD-N-O HWQF-3F11H2D-N HWQF-3F11M4D-N HWQF-3F11T8D-N HWQF-31F11H2D-N HWQF-31F11M4D-N HWQF-31F11T8D-N HWQF-32F11H2D-N HWQF-32F11M4D-N HWQF-32F11T8D-N HWQF-33F11H2D-N HWQF-33F11M4D-N HWQF-33F11T8D-N HWQF-3F20QD-N-O HWQF-31F20QD-N-O HWQF-32F20QD-N-O HWQF-33F20QD-N-O HWQF-3F20H2D-N HWQF-3F20M4D-N HWQF-3F20T8D-N HWQF-31F20H2D-N HWQF-31F20M4D-N HWQF-31F20T8D-N HWQF-32F20H2D-N HWQF-32F20M4D-N HWQF-32F20T8D-N HWQF-33F20H2D-N HWQF-33F20M4D-N HWQF-33F20T8D-N HWQF-3F02QD-N-O HWQF-31F02QD-N-O HWQF-32F02QD-N-O HWQF-33F02QD-N-O HWQF-3F02H2D-N HWQF-3F02M4D-N HWQF-3F02T8D-N HWQF-31F02H2D-N HWQF-31F02M4D-N HWQF-31F02T8D-N HWQF-32F02H2D-N HWQF-32F02M4D-N HWQF-32F02T8D-N HWQF-33F02H2D-N HWQF-33F02M4D-N HWQF-33F02T8D-N HWQF-3F22QD-N-O HWQF-31F22QD-N-O HWQF-32F22QD-N-O HWQF-33F22QD-N-O HWQF-3F22H2D-N HWQF-3F22M4D-N HWQF-3F22T8D-N HWQF-31F22H2D-N HWQF-31F22M4D-N HWQF-31F22T8D-N HWQF-32F22H2D-N HWQF-32F22M4D-N HWQF-32F22T8D-N HWQF-33F22H2D-N HWQF-33F22M4D-N HWQF-33F22T8D-N HWQF-3F40QD-N-O HWQF-31F40QD-N-O HWQF-32F40QD-N-O HWQF-33F40QD-N-O HWQF-3F40H2D-N HWQF-3F40M4D-N HWQF-3F40T8D-N HWQF-31F40H2D-N HWQF-31F40M4D-N HWQF-31F40T8D-N HWQF-32F40H2D-N HWQF-32F40M4D-N HWQF-32F40T8D-N HWQF-33F40H2D-N HWQF-33F40M4D-N HWQF-33F40T8D-N HWQF-3F04QD-N-O HWQF-31F04QD-N-O HWQF-32F04QD-N-O HWQF-33F04QD-N-O HWQF-3F04H2D-N HWQF-3F04M4D-N HWQF-3F04T8D-N HWQF-31F04H2D-N HWQF-31F04M4D-N HWQF-31F04T8D-N HWQF-32F04H2D-N HWQF-32F04M4D-N HWQF-32F04T8D-N HWQF-33F04H2D-N HWQF-33F04M4D-N HWQF-33F04T8D-N 8. Yellow selector switch comes with white LED. 9. Additional contact configurations available (up to 6 total contacts). 10. For Truth Tables see page 668. N Lens/LED Color O Full Voltage Code Code Amber A Voltage Code Plastic 1 Green G 6VAC/DC 6V Metal 4 Red R 12VAC/DC 12V Blue S 24VAC/DC 24V White W 120V AC 120V Yellow Y 240V AC 240V 800-262-IDEC (4332) • USA & Canada Full Voltage Models Q Bezel Code Color Type Code Circuit Breakers 1. In place of N specify Lens/LED color code. 2. In place of O specify Full Voltage code. 3. In place of Q enter 1 for plastic bezel or 4 for metal bezel. 4. For nameplates, see page 655. 5. For contact assembly part numbers, see page 659. 6. Light is independent of switch position. 7. All assembled part numbers in catalog include standard Finger-Safe spring-up (HW-U..) contacts. 120V 240V 480V HWQF-31N L Terminal Blocks O O C R Contactors 1 2 L Spring Return TwoWay Timers 1NO1NC Spring Return from Left C R HWQF-3N Full Voltage 1804091617 Spring Return from Right Relays & Sockets Contact Style 641 Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series H W 1 F Part Number Structure – 31 F 20 Q D – G – 24V Full Voltage Code Bezel 1: Plastic Position 4: Metal 3: Maintained 31: Spring Return from Right 32: Spring Return from Left 33: Spring Return 2-Way Transformer* Contact Blocks + + 6V: 6V AC/DC 12V: 12V AC/DC A: Amber S: Blue G: Green W: White 24V: 24V AC/DC R: Red Y: Yellow 120V: 120V AC 240V: 240V AC Lens Color Contact Arrangement 11: 1NO-1NC 22: 2NO-2NC Illumination Circuit 20: 2NO 40: 4NO Q: Full Voltage 02: 2NC 04: 4NC H2: Transformer 120V AC M4: Transformer 240V AC T8: Tranformer 480V AC Note: Use only for interpreting part numbers. Do not use for developing part numbers. Lead Holder Illuminated Selector Switches 3-Position (Replacement Parts) + Mounting Adaptor + Safety Lever Lock + LED + Anti-Rotation Ring + Operator Lamp Circuit Components Lens = Completed Unit Contact Blocks Description Lead Holder For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. HW-LH3 For use with odd number of contacts. HW-DA1FBN Timers Terminals Part Number Style Finger-Safe Style Transformer Unit (6V secondary voltage) For use with even number of contacts. 120VAC 240VAC 480VAC Finger-Safe Finger-Safe Contacts 1NO 1NC Finger-Safe Spring-Up Terminal HW-U10 HW-U10R (early make) HW-U01 HW-U01R (late break) Contact Block Mounting Adaptor N Lens/LED Color Code Style Full Voltage Adaptor Part Number HW-CBL TW-DA1FB 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. TW-F126B TW-F246B TW-F486B Color Code Color Code Amber A Blue S Green G White W Red R Yellow Y Anti-Rotation Ring Style Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Safety Lever Lock DC-DC Converter 110VDC HW-L16D Style Part Number 1. DC-DC convertor features spring-up terminals. 2. DC-DC convertor applicable voltage range 90-140V DC. HW9Z-LS Operators Style 642 Lamps Style LED Description Plastic Bezel Metal Bezel Maintained HW1F-3 HW4F-3 Spring return from right HW1F-31 HW4F-31 Spring return from left HW1F-32 HW4F-32 2-Way spring return HW1F-33 HW4F-33 Illuminated knobs must be ordered separately. Circuit Breakers Terminal Blocks + *Transformer not needed with full voltage models. Dummy Block with Full Voltage Adaptor Contactors Switches & Pilot Devices Illuminated Knob Appearance Part Number HW9Z-FDY-N In place of N, specify the Color Code. www.IDEC.com Voltage Part Number 6V AC/DC LSTD-6N 12V AC/DC LSTD-1N 24V AC/DC LSTD-2N 120V AC LSTD-H2N 240V AC LSTD-M4N 1. In place of N, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Use white LED for yellow lens. Yellow LED not available. 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Mono Lever Switches 2-Position (Assembled) Signaling Lights 2-Position Mono Lever Switches Style Maintained up and down HW1M-F2020-20 Spring return up and down Circuit Number Contact Mounting No. 1 HW-U10 Position Left Center Right X 0 0 HW1M-F1010-40 Maintained up and down HW1M-F2020-40 Spring return up and down 2 HW-U10 0 0 X HW1M-F0101-20 Maintained right and left 1 HW-U10 X 0 0 HW1M-F0202-20 Spring return right and left 2 HW-U10 0 0 X HW-U10 X 0 0 HW-U10 0 0 X 20 40 HW1M-F0101-40 Maintained right and left 3 HW1M-F0202-40 Spring return right and left 4 HW1M-LF1010-20 Maintained up and down HW1M-LF2020-20 Spring return up and down HW1M-LF1010-40 Maintained up and down HW1M-LF2020-40 Spring return up and down HW1M-LF0101-20 Maintained right and left HW1M-LF0202-20 Spring return right and left HW1M-LF0101-40 Maintained right and left HW1M-LF0202-40 Spring return right and left 2 Position Up/Down Circuit Number 20 40 Position Down Center Up X 0 0 1 HW-U10 2 HW-U10 0 0 X 1 HW-U10 X 0 0 2 HW-U10 0 0 X 3 HW-U10 X 0 0 4 HW-U10 0 0 X Contactors All Assembled units with Finger-Safe spring-up (HW-U...) contacts Contact Mounting No. Timers HW1M-L Interlocking Lever Description HW1M-F1010-20 Relays & Sockets HW1M Standard Lever Part Number Circuit Diagrams 2 Position Left/Right Terminal Blocks Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 643 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Part Number Structure H W M - L F 0 Type blank: Standard L: Interlocking Signaling Lights 1 0 1 20 up right down left Circuit Number 20 or 40 (see contact arrangement on previous page) Lever Action 1: Maintained 2: Spring 0: Blocked Note: Use only for interpreting part numbers. Do not use for developing part numbers. Mono Lever Switches 2-Position (Sub-assembled) Part Numbers Contact Assembly + Mounting Adaptor + Contact Blocks Style Timers Relays & Sockets 1 Safety Lever Lock Anti-Rotation Ring + 1NO 1NC FingerSafe Spring-Up Terminal HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) HW-DB Contact Block Mounting Adaptor Style Style Contactors = Completed Unit Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Style Description Part Number Standard Maintained Up/Down HW1M-1010 Spring return Up/Down HW1M-2020 Maintained Left/Right HW1M-0101 Spring return Left/Right HW1M-0202 Part Number HW-CB2C Interlocking 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Terminal Blocks Operator Anti-Rotation Ring Contacts Dummy Block Style + Part Number Maintained Up/Down HW1M-L1010 Spring return Up/Down HW1M-L2020 Maintained Left/Right HW1M-L0101 Spring return Left/Right HW1M-L0202 Replacement Parts Item Part Number Black Cap HW9Z-CPM HW9Z-LS Boot Circuit Breakers HW9Z-BLM (fits standard operator only) 644 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Mono Lever Switches 3- & 4-Position (Assembled) Signaling Lights 3-Position 4-Position Style HW1M-L Interlocking Lever Description HW1M-F0121-12N3 Maintained right and left, spring return down Style HW1M-F0222-12N3 Spring return right, down, left HW1M-LF0121-12N3 Maintained right and left, spring return down HW1M-LF0222-12N3 Spring return right, down, left HW1M Standard Lever Circuit Diagram Circuit Number No. Position Down Left Center Up Right 1 HW-U01 0 0 0 O X 2 HW-U01 X 0 0 O 0 3 HW-U10 0 X 0 0 0 HW1M-L Interlocking Lever Description HW1M-F1111-22N9 Maintained all positions HW1M-F1212-22N9 Maintained up and down, spring left and right HW1M-2121-22N9 Spring up and down, maintained left and right HW1M-2222-22N9 Spring return all positions HW1M-LF1111-22N9 Maintained all positions HW1M-LF1212-22N9 Maintained up and down, spring left and right HW1M-LF2121-22N9 Spring up and down, maintained left and right HW1M-LF2222-22N9 Spring return all positions Timers 12N3 Contact Mounting Part Number Relays & Sockets HW1M Standard Lever Part Number Circuit Diagram Circuit Number No. Position Down Left Center Up Right 1 HW-U01 0 O 0 0 X 2 HW-U01 X 0 0 0 0 3 HW-U10 0 X 0 0 0 4 HW-U10 0 0 0 X 0 Contactors 22N9 Contact Mounting All assembled part numbers in catalog include Finger-Safe spring-up (HW-U...) contacts. Terminal Blocks Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 645 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Part Number Structure H W M - L F 0 Type blank: Standard L: Interlocking Signaling Lights 1 2 1 12N3 up right down left Circuit Number 3 Position: 12N3 4 Position: 22N9 Lever Action 1: Maintained 2: Spring 0: Blocked Note: Use only for interpreting part numbers. Do not use for developing part numbers. Relays & Sockets 1 Mono Lever Switches 3 & 4-Position (Sub-assembled) Part Numbers Contact Assembly + Mounting Adaptor + Contact Blocks Style + Anti-Rotation Ring 1NO 1NC HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Dummy Block HW-DB Contact Block Mounting Adaptor Style = Completed Unit HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Style Description Standard HW-CB2C Interlocking 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Terminal Blocks Operator Part Number Part Number Contactors Style Style + Anti-Rotation Ring Contacts Spring-Up Terminal Timers Safety Lever Lock Part Number Combination, 3 position HW1M-0121 Spring return, 3 position HW1M-0222 Maintained, 4 position HW1M-1111 Combination, 4 position HW1M-1212 Combination, 4 position HW1M-2121 Spring return, 4 position HW1M-2222 Combination, 3 position HW1M-L0121 Spring return, 3 position HW1M-L0222 Maintained, 4 position HW1M-L1111 Combination, 4 position HW1M-L1212 Combination, 4 position HW1M-L2121 Spring return, 4 position HW1M-L2222 Part Number Replacement Parts HW9Z-LS Item Part Number Black Cap HW9Z-CPM Circuit Breakers Boot HW9Z-BLM (fits standard operator only) 646 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Pushbutton Selectors (Assembled) Signaling Lights 2-Position Pushbutton Selectors Operator Position Left Cam Contacts Mounting Normal M Button Color Code Right Push Normal Push 1NO-1NC A HW1R-2A-M 1 2 HW-U10 HW-U01 0 X X 0 0 0 X 0 2NO 1 2 HW-U10 HW-U10 0 0 X X 0 X X X HW1R-2AF20-M 2NO-2NC 1 2 3 4 HW-U10 HW-U01 HW-U10 HW-U01 0 X 0 X X 0 X 0 0 0 0 0 X 0 X 0 HW1R-2AF22-M 2NO 1 2 HW-U10 HW-U10 0 0 X 0 0 0 0 X HW1R-2DF20-M 2NO-2NC 1 2 3 4 HW-U10 HW-U10 HW-U01 HW-U01 0 0 X X X 0 0 X 0 0 X X 0 X X 0 HW1R-2DF22N1-M 1 2 3 4 HW-U10 HW-U10 HW-U01 HW-U01 0 0 0 X X 0 0 X 0 0 X 0 0 X X 0 1 2 3 4 HW-U10 HW-U10 HW-U01 HW-U01 0 0 0 X 0 X 0 0 0 0 X 0 X 0 0 0 Operator Only 2NO-2NC Yellow Y Red R Blue S HW1R-2EF22N1-M HW1R-2FF22N1-M HW1R-2N-M 1 2 3 4 HW-U01 HW-U10 HW-U01 HW-U10 0 0 0 0 0 X 0 X X 0 X 0 0 X 0 X Operator Only T G Terminal Blocks 2NO-2NC W Green HW1R-2F-M Operator Only N Code Contactors 2NO-2NC White HW1R-2E-M Operator Only F Color B HW1R-2D-M Operator Only 2NO-2NC Code Black Timers D E HW1R-2AF11-M Color Relays & Sockets Operator Only Part Number HW1R-2NF22N2-M HW1R-2T-M 1 2 3 4 HW-U10 HW-U10 HW-U01 HW-U01 0 0 X X X X 0 0 X X 0 0 Blocked HW1R-2TF22N1-M Circuit Breakers 1. All assembled part numbers in catalog include Finger-Safe spring-up (HW-U...) contacts. 2. Operator only models come with operator and button. 1804091617 800-262-IDEC (4332) • USA & Canada 647 ø22mm - HW Series Relays & Sockets Signaling Lights Switches & Pilot Devices Switches & Pilot Devices Part Number Structure H W 1 R - 2 D F 22N1 – R Button Colors Operator A: D: E: F: N: T: Cam A Cam D Cam E Cam F Cam N Cam T B: Black G: Green R: Red S: Blue W: White Y: Yellow Contact Arrangement Code 11: 1NO-1NC 20: 2NO (For additional contact codes see previous page) Note: Use only for interpreting part numbers. Do not use for developing part numbers. Pushbutton Selectors (Sub-assembled) Contact Blocks + Mounting Adaptor + Safety Lever Lock Contact Blocks Style Anti-Rotation Ring + Operator Safety Lever Lock Contacts Spring-Up Terminal Timers + 1NO 1NC HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Dummy Block Style Completed Unit Part Number Round Flush HW9Z-LS HW1A-B1-M Anti-Rotation Ring HW-DB Style (safety lever lock included) Contactors = Style Use with notched panel cutout to prevent unit rotation. Part Number Operators HW-CB2C 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Description Part Number Cam A HW1R-2A Cam D HW1R-2D Cam E HW1R-2E Cam F HW1R-2F Cam N HW1R-2N Cam T HW1R-2T M Button Color Code Color Code Color Code Black B White W Green G Yellow Y Red R Blue S Circuit Breakers Style In place of M, specify the Button Color Code from table below. Part Number HW9Z-RL Terminal Blocks Button Buttons Part Number Contact Block Mounting Adaptor Style + 648 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Dual Pushbutton Switches Key features: • Two pushbuttons and a pilot light are integrated into one spacesaving ø22 mm control unit. • Momentary and interlock types are available for pushbuttons. Interlock type prevents both buttons from being pressed at the same time. • Pilot lights are available in full voltage and transformer with LED. • IP40 protection, IP65 when using silicon boot. Signaling Lights Applications: Relays & Sockets • Ideal for use as power switches and start/stop switches (available with I/ON and O/OFF markings on the buttons and a pilot light in the center). • Interlock type prevents two pushbuttons from being pressed at the same time. Dual Pushbutton Switches (Assembled) Part Numbers Without Center Pilot Light Operation Type Button Style Momentary Flush (top) Flush (bottom) Flush (top) Extended (bottom) 1NO 1NC HW7D-B11F1001-PQ 1NO 1NO HW7D-B11F1010-PQ 1NO-1NC 1NO-1NC HW7D-B11F1111-PQ 2NO 2NC HW7D-B11F2002-PQ 2NO 2NO HW7D-B11F2020-PQ 1NO 1NC HW7D-B12F1001-PQ 1NO 1NO HW7D-B12F1010-PQ 1NO-1NC 1NO-1NC HW7D-B12F1111-PQ 2NO 2NC HW7D-B12F2002-PQ 2NO 2NO HW7D-B12F2020-PQ 1NO 1NC HW7D-B21F1001-PQ 1NO 1NO HW7D-B21F1010-PQ 1NO-1NC 1NO-1NC HW7D-B21F1111-PQ 2NO 2NC HW7D-B21F2002-PQ 2NO 2NO HW7D-B21F2020-PQ 1NO 1NC HW7D-B22F1001-PQ 1NO 1NO HW7D-B22F1010-PQ 1NO-1NC 1NO-1NC HW7D-B22F1111-PQ 2NO 2NC HW7D-B22F2002-PQ 2NO 2NO HW7D-B22F2020-PQ PButton Color Code QLegend Code GR: Green (top) Red (bottom) Blank: Without legend 1: WB: White (top) Black (bottom) I/ON (top) O/OFF (bottom) Terminal Blocks Interlock* Part Number Contactors Flush (top) Extended (bottom) Bottom Button Timers Flush (top) Flush (bottom) Contact Arrangement Top Button 1804091617 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. *Interlock type prevents both top and bottom buttons from being pressed simultaneously. 2. Clear silicon rubber cover part number HW9Z-D7D. 3. Additional contact configurations available (up to 6 total contacts). 649 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices With Center Pilot Light Operation Type Button Style Flush (Top) Flush (Bottom) Flush (top) Flush (bottom) Signaling Lights Momentary Flush (Top) Extended (Bottom) Relays & Sockets Flush (top) Extended (bottom) Flush (Top) Flush (Bottom) Interlock* Flush (Top) Extended (Bottom) Top Button Bottom Button Part Number 1NO 1NC HW7D-L11F1001NO-PQ 1NO 1NO HW7D-L11F1010NO-PQ 1NO-1NC 1NO-1NC HW7D-L11F1111NO-PQ 2NO 2NC HW7D-L11F2002NO-PQ 2NO 2NO HW7D-L11F2020NO-PQ 1NO 1NC HW7D-L12F1001NO-PQ 1NO 1NO HW7D-L12F1010NO-PQ 1NO-1NC 1NO-1NC HW7D-L12F1111NO-PQ 2NO 2NC HW7D-L12F2002NO-PQ 2NO 2NO HW7D-L12F2020NO-PQ 1NO 1NC HW7D-L21F1001NO-PQ 1NO 1NO HW7D-L21F1010NO-PQ 1NO-1NC 1NO-1NC HW7D-L21F1111NO-PQ 2NO 2NC HW7D-L21F2002NO-PQ 2NO 2NO HW7D-L21F2020NO-PQ 1NO 1NC HW7D-L22F1001NO-PQ 1NO 1NO HW7D-L22F1010NO-PQ 1NO-1NC 1NO-1NC HW7D-L22F1111NO-PQ 2NO 2NC HW7D-L22F2002NO-PQ 2NO 2NO HW7D-L22F2020NO-PQ Timers 1. *Interlock type prevents both top and bottom buttons from being pressed simultaneously. 2. Clear silicon rubber cover part number HW9Z-D7D. 3. All assembled part numbers in catalog include Finger-Safe spring-up (HW-U...) contacts. NPilot Light Illumination & Voltage Code Contactors Full Voltage O Pilot Lamp Color Code PPushbutton Color Code Color Code Color Amber A Top Green Code Voltage Code Green G Bottom Red 6V AC/DC, LED Q2 Red R Top White 12V AC/DC, LED Q3 Blue S Bottom Black 24V AC/DC, LED Q4 White W 120V AC, LED Q8 GR WB QEngraving Codes Engraving Code No Engraving Blank I/ON Top O/OFF Bottom 1 Voltage Code 120V AC, LED H22 240V AC, LED M42 480V AC, LED T82 Circuit Breakers Terminal Blocks Step-Down Transformer (6V Secondary LED Voltage) 650 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Pilot Light 7 D Part Number Structure – L 21 F 20 20 H22 R – GR 1 Engraving Code Contact Arrangement Top Button 01: 1NC 10: 1NO Button Arrangement Voltage Code A: Amber blank: without center pilot light G: Green Full Voltage* Transformer* Q2: 6V LED H22: 120V AC LED R: Red S: Blue *For additional voltage codes, please see previous page W: White 02: 2NC 20: 2NO Momentary (Flush/Flush) Momentary (Flush/Extended) Bottom Button 01: 1NC 02: 2NC Interlock (Flush/Flush) 10: 1NO 20: 2NO Interlock (Flush/Extended) Contact Blocks + Mounting Adaptor For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. For use with odd number of contacts. + Safety Lever Lock + Operator For use with even number of contacts. 120VAC 240VAC 480VAC Transformer Unit (6V secondary voltage) Lens Style Contacts 1NO 1NC Dummy Block Contact Block Mounting Adaptor HW-DA1FBN Style Part Number Illuminated (with Pilot Light) TW-DA1FB Momentary Flush (bottom) Flush (top) Extended (bottom) Top Green Bottom Red 1804091617 GR HW9Z-RL Use with notched panel cutout to prevent unit rotation. Bottom Black LSTD-6N 12V AC/DC LSTD-1N 24V AC/DC LSTD-2N 120V AC LSTD-H2N 240V AC LSTD-M4N Nonilluminated HW9Z-B7B Illuminated HW9Z-L7W NLED Color Code Color Code Color Code Amber A Blue S Green G White W Red R Code No Engraving Code White 6V AC/DC QEngraving Codes Engraving Top Part Number 1. In place of N, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. HW7D-*21P-Q Color Voltage WB I/ON Top O/OFF Bottom Blank Circuit Breakers Code Style HW-CBL Part Number Instead of * insert: B: Non-illuminated L: Illuminated PPushbutton Color Code Color Lamps/Lens Anti-Rotation Ring HW7D-*22P-Q HW-U01 HW-U01R (late break) Terminal Blocks Flush (top) Interlock HW7D-*11P-Q HW7D-*12P-Q 1NC Contactors Extended (bottom) HW-U10 Spring-Up HW-U10R Terminal (early make) HW9Z-LS Appearance Flush (top) 1NO Part Number Part Number Flush (bottom) Contacts HW-CB2C 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. TW-F126B TW-F246B TW-F486B Operators Flush (top) Style HW-LH3 Style Button Completed Unit HW-DB Safety Lever Lock Style = Contact Blocks Non-illuminated Full Voltage Adaptor + Timers Dummy Block with Full Voltage Adaptor GR: Top: Green Bottom: Red WB: Top: White Bottom: Black Relays & Sockets Part Number Description Lead Holder Pushbutton Color Dual Pushbutton Switches (Sub-assembled) Part Numbers Lamp Circuit Components with Finger-Safe Terminals Style Y: Yellow blank: without center pilot light Signaling Lights Note: Use only for interpreting part numbers. Do not use for developing part numbers. blank: No Engraving 1: Top: I/ON Bottom: O/OFF Pilot Lamp Color LED B: Without Center Pilot Light L: With Center Pilot Light 11: 12: 21: 22: W Switches & Pilot Devices H 1 800-262-IDEC (4332) • USA & Canada 651 Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Contact Arrangement Chart Contact Arrangement Top Button Bottom Button Contact Code 1NO 1NO 1010 1NO 1NC 1001 1NC 1NO 0110 1NC 1NC 1NO 2NO 1NO 1NO-1NC 1NO 2NC 2NO 1020 1011 1002 0120 Timers 1NC 0101 Contactors 1NC 1NO-1NC 1NC 2NC Terminal Blocks 2NO 1NO 2NO 1NC Circuit Breakers 1NO-1NC 1NO-1NC 1NO 1NC 0111 0102 2010 2001 1110 1101 Contact Block Mounting Position Example Contact Block Top Button Mounting Position Type 1 NO 2 NO 1 NO 2 NC 1 NC 2 NO 1 NC 2 NC 1 NO 2 NO 3 Dummy 4 NO 1 NO 2 NO 3 Dummy 4 NC 1 NO 2 NC 3 Dummy 4 NC 1 NC 2 NO 3 Dummy 4 NO 1 NC 2 NO 3 Dummy 4 NC 1 NC 2 NC 3 Dummy 4 NC 1 NO 2 NO 3 NO 4 Dummy 1 NO 2 NC 3 NO 4 Dummy 1 NO 2 NO 3 NC 4 Dummy 1 NO 2 NC 3 NC 4 Dummy Normal Push Bottom Button Normal Mounting Position 4 Mounting Position 2 Push X X X Mounting Position 3 Mounting Position 1 X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X 1. Transformers can have two or four contact blocks only. 2. Contact blocks 1 and 3 are actuated by the top button. Contact blocks 2 and 4 are actuated by the bottom button. 652 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Contact Arrangement Top Button 2NC 2NO 2NO 1NO-1NC 2NC 2NC 2NO 1NO-1NC 2NC 2NO 1NO-1NC 2NC 2002 1120 1111 1102 0220 0211 0202 NC X 2 NO 3 NC 4 Dummy 1 NC 2 NC 3 NC 4 Dummy 1 NO 2 NO 3 NO 4 NO 1 NO 2 NO 3 NO 4 NC 1 NO 2 NC 3 NO 4 NC 1 NO 2 NO 3 NC 4 NO 1 NO 2 NO 3 NC 4 NC 1 NO 2 NC 3 NC 4 NC 1 NC 2 NO 3 NC 4 NO 1 NC 2 NO 3 NC 4 NC 1 NC 2 NC 3 NC 4 NC Normal Mounting Position 4 Mounting Position 2 Push X X Mounting Position 3 Mounting Position 1 X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1804091617 2NC 2011 1 Push Terminal Blocks 2NC 1NO-1NC 2020 Normal Contactors 1NO-1NC 2NO 0201 Type Bottom Button Timers 1NO-1NC 1NC 0210 Mounting Position Top Button Relays & Sockets 2NO 1NO Contact Code Contact Block Signaling Lights 2NC Bottom Button Switches & Pilot Devices Contact Block Mounting Position Example Contact Arrangement Chart (con’t) 653 ø22mm - HW Series Signaling Lights Switches & Pilot Devices Switches & Pilot Devices Contactor Reset Button Reset Buttons (Assembled) (Blank) Engraved “R” M Button Color Code Plastic Bezel Metal Bezel HW1B-M1RS-MT HW4B-M1RS-MT Color Code Color Code HW4B-M1RS-MT-ENG-R Black B White W Green G Yellow Y Red R Blue S HW1B-M1RS-MT-ENG-R Relays & Sockets 1. In place of M specify Button Color Code. 2. 130mm (5.1”) overall length. 3. 16mm flat base for easy alignment Contactor Reset Button (Sub-assembled) + Operator + Button = Completed Unit Timers Rod Rod Button Part Number Contactors Style Style Part Number HW9Z-RS-TK2141 HW1A-B1-M Operator Style Plastic In place of M, specify the Button Color Code from table. Metal Terminal Blocks M Button Color Code HW4B-MO Code Color Code Black B White W Green G Yellow Y Red R Blue S Circuit Breakers HW1B-MO Color 654 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Nameplates - HW Series HWAQ–Black Plastic Engraving Plate 45 1.6 0.9 2.7 12.1 30 R14.9 ø22 ø22 1.9 1 1 Nameplate (blank engraving plate included) HWAM-OB HWAQ-OB HWAS-OB HWAV-O HWAV5-0† Nameplate (engraved) HWAM-M HWAQ-M HWAS-M HWAV-27* HWAV5-27† Additional Insert (blank) HWNP-O HWNP-O HWNP Dimensions Additional Insert (engraved) HWNP-M 27 12 Relays & Sockets 1. 2. 3. 4. 22mm Signaling Lights 1.5 HWAV–Yellow Plastic Engraving Plate 27 14.5 14.9 2 ø2 14.5 14.9 R14.9 29 2.7 12.1 30 29 27 HWAS–Black Plastic ø60mm HWAM–Black Plastic HWNP-M In place of M, insert either the standard legend code from table below or custom engraving delimited by “ “. Standard engravings are available at no charge. * HWAV-27 comes engraved “Emergency Stop” as shown in drawing. † HWAV5-27 and HWAV5-0 for 60mm diameter E-Stops (80mm diameter nameplate). Standard Legend Codes Pushbuttons Pushbuttons/Selector Switches Selector Switches Legend Code Legend Code Legend Code Legend Code AUTO CLOSE DOWN EMERG.STOP FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 OPEN OUT RAISE RESET REVERSE RUN SLOW START STOP TEST UP I (Int’l On) O (Int’l Off) EMO 116 117 118 119 120 121 122 123 125 126 127 150 151 152 AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWER-RAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISE-LOWER 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN OI (Int’l OFF ON) 216 217 218 219 220 221 222 223 250 AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFF-WINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 To order engraved nameplates, add legend code to nameplate part number. Character height based on the number of characters and size of nameplate. Standard character size is 3/16”. Nameplates with standard legends are the same list price as blank nameplates. Nameplates have built-in anti-rotation feature for use with notched panel cut-outs. Additional anti-rotation ring (HW9Z-RL) is not necessary. Terminal Blocks 1. 2. 3. 4. Contactors Code Timers Legend Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 655 Signaling Lights Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Nameplates Order Form — HW Series Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To ensure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: IDEC Rep/Distributor Contact: Name: PO number (if known): Telephone: IDEC Rep/Distributor Phone: Fax & Email: IDEC Rep/Distributor Fax & Email: HWAM Nameplate Relays & Sockets Engraving Location Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 9 characters. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 11 characters maximum (for 7/64” size letters) 1/8” Letter Size 9 characters maximum (for 7/8” size letters) Sample Letter Sizes Qty 1 2 3 4 5 6 7 8 9 10 11 7/64” Letters: ABCD 1/8” Letters: A BCD Timers HWAQ Nameplate Engraving Location Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 9 characters. Contactors Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 11 characters maximum (for 7/64” size letters) 1/8” Letter Size 9 characters maximum (for 1/8” size letters) Sample Letter Sizes Qty 1 2 3 4 5 6 7 8 9 10 11 7/64” Letters: ABCD 1/8” Letters: A BCD HWAS Nameplate Terminal Blocks Engraving Location A Step 1. Choose Letter Size - 3/32” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 14 characters. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. Circuit Breakers Engraving Location B Qty Step 3. Specify Location. Enter the location of engraving Location (A or B or Both), in box on the right. 3/32” Letter Size 20 characters maximum (for 3/32” size letters) 1/8” Letter Size 14 characters maximum (for 1/8” size letters) A 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 B 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Sample Letter Sizes 3/32” Letters: A B C D 1/8” Letters: A 656 www.IDEC.com BCD 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Switch Engraving Order Form – HW Series Copy this order form and use it to specify Letter Height, Maximum Number of Lines and Text to be engraved. To ensure engraving accuracy, fax it to your IDEC representative or Distributor. Telephone: Name: Fax: Address: Email: PO: Part Number to be Engraved: Signaling Lights Your Company: Please check one of the boxes below to indicate your choice of engraving options: ø29mm, ø40mm Mushroom Head Engraving Area 2† # of Lines Letter Height Max. Characters Per Line 5/32 5 1 # of Lines Letter Height Max. Characters Per Line 5/32 5 1 1/8 6 5/32 5 5 5/32 5 2 1/8 6 3 1/8 6 4 3/32 5 6 3 1/8 5 4 3/32 5 1 Engraving Area 2 1 Max. Characters Per Line 5/32 5 1/8 5 5/32 7 1/8 7 Above mentioned specifications hold true for standard size pushbuttons (round and square). Engraving Area 2 can be engraved for 40mm mushroom Head non-Illuminated push button only. Engraving is done on the button itself for non-Illuminated push buttons and on marking plate for illuminated push buttons and pilot lights. Please enter text exactly how you want it engraved, take care to emphasize capital or small letters. † Enter text to be engraved: Contactors 1. 2. 3. 4. 1/8 Engraving Area 1 Letter Height Timers 2 1/8 # of Lines Relays & Sockets Engraving Area 1 Round Switch Square Switch Sample Letter Sizes 1/8 Letters: Line 1: 5/32 Letters: Line 2: Terminal Blocks Line 3: Line 4: For IDEC Internal Use Only: 1804091617 Circuit Breakers Work Order #: 800-262-IDEC (4332) • USA & Canada 657 Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Accessories Item Appearance Description/Usage Part Number Locking Ring Wrench Metallic tool used to tighten the plastic locking ring when installing the HW series in a panel MW9Z-T1 Lamp/LED Removal Tool Rubber tool makes lamp/LED removal easier. OR-55 Anti-Rotation Ring Prevents rotation of switches in panel. (included with all assembled switches except pilot lights) for notched panel cutout (standard) HW9Z-RL for round panel cutout LW9Z-L Rubber Mounting Hole Plug Black rubber plug fills unused 7/8” mounting holes in panel. OB-31 Metallic Mounting Hole Plug For plugging unused 7/8” mounting holes in the panel. Tighten the attached locking ring to a torque of 12 kfg-cm maximum Degree of protection: IP66 LW9Z-BM Used to cover and protect pushbuttons Flush Pushbuttons OC-31 Operating temperature: –50 to +60°C Extended Pushbuttons OC-32 Pushbutton Clear Boot Padlock Cover Plastic hinged padlockable cover to protect pushbuttons or selector switches. (Not intended for E-Stops) HW9Z-KL1 Circuit Breakers Terminal Blocks Contactors Timers Degree of protection: IP65 Tab Terminal Adapter Tab #250 (6.35 x 0.8mm): Single tab Mounting Adaptor Used to mount round HW series (except Jumbo Mushroom, unibody, and square units) into a larger panel cut-out. (includes both pieces) TW-FA4 22 to 30mm HW9Z-A30 22 to 25mm HW9Z-A25 Replacement Safety Lever Lock Used to prevent contact mounting lever from moving due to heavy vibration or panel maintenance. HW9Z-LS Reset Rod for Contactors Overload 5” rod used with HW1B-M0. HW9Z-RS-TK2141 Replacement Operator Washer Provided with operator. Insert between bezel and locking ring. HWM-WASHER Replacement Locking Ring Plastic locking nut comes with all HW operators & assemblies. Switch Cover (Square) Used only with round or square flush pushbuttons. HW9Z-K1 (spring return) HW9Z-K11 (maintained cover) Replacement Keys Pair of Keys (#231) HW9Z-SKP Replacement Lens HW Illuminated Unibody Replacement Lens HWLV-LENSR 658 www.IDEC.com Standard (plastic) HW9Z-LN Optional (metal) HW9Z-LNM 1804091617 ø22mm - HW Series Switches & Pilot Devices Appearance Description/Usage Switches & Pilot Devices Item Part Number Replacement Jumbo Dome Lens HW1A-P5M M = (A, G, R, S, W, Y)) Polycarbonate Replacement Lens (If using yellow lens, use white LED.) Replacement Jumbo LED Diffusing Lens HW9Z-PP5C Replacement LED Lamp - applicable for jumbo pilot lights only LSTDB-2M M = (A, G, R, S, W) Rubber Cover for Dual Pushbuttons Clear Silicon rubber cover HW9Z-D7D Barrier for Dual Pushbuttons Plastic barrier. Used when mounting the HW7 units on 30mm horizontal centers, to prevent possible interconnections between adjoining terminals. HW-VU1 Emergency stop nameplate sticker HW9Z-EMO-NP-TK2120 Relays & Sockets E MO EMO Sticker Signaling Lights Replacement LED Lamps for HW Jumbo Dome E-Stop Shrouds Style Applicable Standards HW9Z-KG1 40mm Mushroom Head SEMI S2-0703, 12.5.1 Compliant HW9Z-KG2 40mm, and 60mm Mushroom Head SEMI S2-0703, 12.5.1 & SEMATECH Compliant Style E-Stop Types Applicable Standards HW9Z-KG3 40mm Mushroom Head SEMI S2 Compliant (Approved by TUV) HW9Z-KG4 40mm Mushroom Head SEMI S2 Compliant (Approved by TUV) & SEMATECH Part Numbers Timers E-Stop Types Part Numbers Contactors Contact Assemblies Standard Contact Assemblies Full Voltage Contact Assemblies For use with Non-Illuminated Pushbuttons & E-Stops For use with Illuminated Pushbuttons. Contacts Part Number Standard Finger-Safe Contacts 1NO 1NC 1NO/1NC 2NO 2NC 2NO/2NC HW-CBF10 HW-CBF01 HW-CBF11 HW-CBF20 HW-CBF02 HW-CBF22 Style Gold contact option is available. Add suffix “MAU” to end of part number. For example, HW-CBF20 becomes HW-CBF20-MAU. Contacts Part Number 1NO 2NO 1NO/1NC 1NC 2NC HW-FL10Q0 HW-FL20Q0 HW-FL11Q0 HW-FL01Q0 HW-FL02Q0 Terminal Blocks Style Order LED separately. Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 659 Switches & Pilot Devices Transfomer Contact Assemblies For use with Illuminated Pushbuttons. Style Signaling Lights Switches & Pilot Devices ø22mm - HW Series Contacts Part Number 120V AC with LED 1NO 2NO 1NC 1NO/1NC HW-FL10H2-N HW-FL20H2-N HW-FL01H2-N HW-FL11H2-N 240V AC with LED 1NO 2NO 1NC 1NO/1NC HW-FL10M4-N HW-FL20M4-N HW-FL01M4-N HW-FL11M4-N 480V AC with LED 1NO 2NO 1NC 1NO/1NC HW-FL10T8-N HW-FL20T8-N HW-FL01T8-N HW-FL11T8-N 1. In place of N, specify the LED Color Code. N = A, G, R, S, or W Dimensions (mm) Non-Illuminated Pushbuttons Flush (HW1B-M1, -A1) Extended (HW1B-M2, -A2) Locking Ring Safety Lever Lock Panel Thickness 0.8 to 6 Panel Thickness 0.8 to 6 LO CK 26.5 25 26.5 25 41.4 ø29 41.4 41.4 ø29 49.4 (1 or 2 blocks) ø23.6 29.4 13 Panel Thickness 0.8 to 6 CK ø23.6 29.4 13 69.4 (3 or 4 blocks) 49.4 (1 or 2 blocks) 29.4 13 69.4 (3 or 4 blocks) 19 23.2 Timers 49.4 (1 or 2 blocks) 69.4 (3 or 4 blocks) Locking Ring Safety Lever Lock LO LO CK ø29 Locking Ring Safety Lever Lock ø29mm Mushroom (HW1B-M3 -A3) 26.5 25 Relays & Sockets 2. 6V LED included. ø40mm Mushroom (HW1B-M4, -A4) Panel Thickness 0.8 to 6 Locking Ring Safety Lever Lock Panel Thickness 0.8 to 6 Square Flush (HW2B-M1, -A1) CK Locking Ring Safety Lever Lock CK LO 49.4 (1 or 2 blocks) 23.2 69.4 (3 or 4 blocks) Square Extended (HW2B-M2, -A2) 41.4 29.4 15 …29.6 26.5 25 26.5 25 ø60 41.4 29.4 13 Panel Thickness 0.8 to 6 CK ø40 41.4 Contactors 49.4 (1 or 2 blocks) 69.4 (3 or 4 blocks) LO LO 26.5 25 Locking Ring Safety Lever Lock ø60mm Mushroom (HW1B-M5) 49.4 (1 or 2 blocks) 69.4 (3 or 4 blocks) 13 …24.8 29.4 30.1 Contact Block (Bottom View) Terminal Wiring Panel Thickness 0.8 to 6 LO 41.4 …29.6 26.5 25 CK 1 contact block 49.4 (1 or 2 blocks) 69.4 (3 or 4 blocks) 13 19 …24.8 29.4 2 contact blocks 4 contact blocks Circuit Breakers Terminal Blocks Arrows indicate access directions for wiring Locking Ring Safety Lever Lock 660 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Flush (Round & Square) Extended Round Panel Thickness 0.8 to 6 LO CK Square LO LO CK 13 29.4 Extended with Full Shroud ø40mm Mushroom LO CK LO ø40 41.4 41.4 25 CK 25 ø29.5 Signaling Lights 18.5 24.8 29.4 29.4 Extended .6 23 ø 3. 6 ø2 13 41.4 ø23.5 41.4 29.6 41.4 25 25 25 CK Switches & Pilot Devices Dimensions (mm) Operators 3. 6 ø2 13 29.4 23.2 Dimensions (mm) Emergency Stop Pushbuttons ø29mm Head Pushlock Turn Reset (HW1B-V3) Relays & Sockets 29.4 18.5 Panel Thickness 0.8 to 6 Gasket Terminal Screw M3.5 LOC Locking Ring 41.4 ø29 50.2 (1 or 2 blocks) 2 contact blocks 4 contact blocks 70.2 (4 blocks) 13 29.4 32 ø40mm Head EMO Pushlock Turn Reset (HW1B-V4) LO CK LOC K Locking Ring Lock Lever 20 41.4 41.4 26.5 0 ø4 25 ø40 Contactors ø40mm Head Pushlock Turn Reset (HW1B-V4) 25 1 contact block Timers 25 K 50.2 (1 or 2 blocks) 70.2 (4 blocks) 13 13 29.4 32 Terminal Blocks 29.4 32 ø40mm Head Pushlock Key Reset (HW1B-X4) ø60mm Head Pushlock Turn Reset (HW1B-V5) LO ø60 41.4 ø40 25 CK Circuit Breakers 13 29.4 32 49.4 1804091617 15 34.5 800-262-IDEC (4332) • USA & Canada 661 Switches & Pilot Devices ø40mm Head Push-Pull (HW1B-Y2) ø40mm Head Unibody Pushlock Turn Reset (HW1B-BV4) LO Panel Thickness 0.8 to 6 CK Gasket M3.5 Terminal Screw 41.4 25 Locking Ring ø40 ø40 Switches & Pilot Devices ø22mm - HW Series Signaling Lights 13 29.4 25.5 TOP Marking Terminal Cover 14 32 48 Illuminated E-Stop Pushbuttons (HW1E-LV4) Mounting Hole Panel Thickness 0.8 to 6 R0.8 max. Gasket ø22 .3 Locking Ring Relays & Sockets 3.2 +0.4 0 ø40 24.1 TOP Marking +0.2 0 +0.4 0 M3.5 Terminal Screw M3.5 Terminal Screw Lamp Terminal 11.5 14 32 61 Terminal Cover 63 Timers 11.5 46 The minimum mounting centers shown below are applicable to E-Stop switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers for ease of wiring. Unit Vertical Spacing Horizontal Spacing HW1B-V3 HW1B-V4 HW1B-X4 HW1B-Y2 50 mm 50 mm HW1B-V5 60 mm 60 mm Terminal Arrangement (Bottom View) HW1E-BV4 Side HW1E-LV4 TOP X1 .2 (NC) .1 (NC) .3 (NO) .4 (NO) LAMP .2 (NC) .3 (NO) .1 (NC) .4 (NO) X2 (1NO-1NC) Circuit Breakers Terminal Blocks Contactors (1NO-1NC) 662 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices A 59.5 Mounting Hole Layout Operator Dimension A (mm) Pushlock Turn Reset 32 Pushlock Key Reset 32 (Key inserted: 49.4) Push Pull 25.5 4-M4 Tapped Holes for Rear Mounting (Depth: 10 mm) 2-Front Mounting Holes ø14 Knockout 21 76 76 21 41 HW1B-V4R Box Cover Mouting Screws Switches & Pilot Devices Dimensions (mm) Emergency Stop Stations Box Cover Box Base .6 15.5 62 Dimensions (mm) Pilot Lights Signaling Lights 2ø4 Round Flush Terminal screws: M3.5, integrated terminal cover ø2 3.5 3.5 ø2 9 24 24 ø2 Panel Thickness 0.8 to 6 Gasket Locking Ring Panel Thickness 0.8 to 6 Gasket Locking Ring Relays & Sockets Panel Thickness 0.8 to 6 Gasket Locking Ring 110V DC, 380V AC minumum ø2 9 100/110V AC, 200/220V AC (240V AC maximum) ø2 9 6, 12, 24V AC/DC, Without LED lamp ø2 3.5 11.5 60.8 7 43.3 7 76.2 29.6 7 29.6 Extended Terminal screws: M3.5, integrated terminal cover Panel Thickness 0.8 to 6 Gasket Locking Ring ø2 3 Panel Thickness 0.8 to 6 Gasket Locking Ring 9 .6 11.5 43.3 60.8 17.5 17.5 24 24 9 ø2 3.6 .6 ø2 ø2 3 Timers Panel Thickness 0.8 to 6 Gasket Locking Ring 110V DC, 380V AC minimum ø2 9 100/110V AC, 200/220V AC (240V AC maximum) ø2 6, 12, 24V AC/DC, Without LED lamp 29.6 76.2 17.5 29.6 Square Flush Terminal screws: M3.5, integrated terminal cover 100/110V AC, 200/220V AC (240V AC maximum) Panel Thickness 0.8 to 6 7 …24.6 …24.6 60.8 …29.6 …29.6 7 76.2 …29.6 7 Terminal Blocks Jumbo Dome Pilot Light terminal cover Panel Thickness 0.8 to 6 Gasket Locking Ring Terminal screws: M3.5, integrated LED Lamp LSTDB Panel Thickness 1 to 5 Mounting Hole Layout Base BA9S/13 Illumination Color R0.8 max. ø22.3 3.2 +0.2 0 +0.4 0 Mounting Hole Layout Close mounting on 30mm centers Degree of protection: IP65 .3 +0.4 0 ø22 24.1 ø10.6 Light blue: LSTDB +0.4 0 11.5 43.3 110V DC, 380V AC minimum Panel Thickness 0.8 to 6 Gasket Locking Ring …24.6 Gasket Locking Ring Contactors 6, 12, 24V AC/DC, Without LED lamp Locking Ring 6 ø6 Gasket 85 0.5 34.4 Circuit Breakers 30 min. 85 20.4 50.5 30 min. When mounting transformer or DC-DC converter type units on 30mm centers vertically and horizontally, keep the ambient temperature below 40ºC. 1804091617 800-262-IDEC (4332) • USA & Canada 663 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Illuminated Pushbuttons Full Voltage Models 1 Contact Block 2 Contact Blocks Full Voltage Adapter M3.5 Terminal Screw Contact Block Locking Ring Panel Thickness 0.8 to 6 Full Voltage Adapter M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 6 Panel Thickness 0.8 to 6 Locking Ring X1 X2 Signaling Lights M3.5 Terminal Screw Contact Block Locking Ring Relays & Sockets 3 Contact Blocks Full Voltage Adapter 50.2 (1 block) 1 contact block 65.8 (2 blocks) 2 contact blocks 3 contact blocks Dimensions (mm) Illuminated Pushbuttons con’t 4 Contact Blocks Terminal Wiring Arrows indicate access directions for wiring. Full Voltage Adapter Contact Block Full Voltage Adaptor M3.5 Terminal Screw Contact Block 70.2 (3 blocks) Locking Ring Transformer Panel Thickness 0.8 to 6 X2 Timers X1 85.8 (4 contacts) 4 contact blocks Transformer Models DC-DC Converter Models Safety Lever Lock 3 4 X1 Locking Ring X2 M3.5 Terminal Screws 89.7 (2 blocks) 109.5 (4 blocks) M3.5 Terminal Screw 89.5 (2 blocks) 109.5 (4 blocks) Circuit Breakers Terminal Blocks Contactors X2 X1 664 www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Knob Operator Terminal Wiring M3.5 Terminal Screw Arrows indicate access directions for wiring. Panel Thickness 0.8 to 6 Gasket LO CK Contact Block Full Voltage Adaptor 9 ø2 2 contact blocks 4 contact blocks 48.5 (1 or 2 blocks) 7 Signaling Lights 1 contact block 41.4 ø28.8 25 Locking Ring Switches & Pilot Devices Dimensions (mm) Non-Illuminated Selector & Key Switches 29.4 68.5 (3 or 4 blocks) 21 Key Operator Tranformer LO CK .4 29 ø 25 Relays & Sockets 17 41.4 X1 X2 13 29.4 30.5 Illuminated Selector Switches Full Voltage Model Transformer Model M3.5 Terminal Screw LO C LO 41.4 41.4 25 89.4 (4 blocks) 7 9 ø2 25 4 X1 69.4 (2 blocks) K Timers 9 ø2 3 CK 29.4 X2 M.3.5 Terminal Screw 79.5 (2 blocks) 99.5 (4 blocks) 7 21 29.4 21 Contactors Terminal Blocks Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 665 Switches & Pilot Devices Dimensions (mm) Dual Pushbutton Without Pilot Light Mounting Hole Layout R0.8 max. HW .3 +0. 4 0 +0.2 0 +0.4 0 *3.2 ø22 24.1 Switches & Pilot Devices ø22mm - HW Series 49.4 (2 contacts) Without Button Markings Locking Ring 55 ** Panel Thickness 0.8 to 6 Safety Lever Lock With Button Markings (I/ON and O/OFF) 54.8 54.8 OFF Rubber Gasket Relays & Sockets 30 ON 41.4 Signaling Lights 69.4 (3 or 4 contacts) 0.5 29.8 14.5 20 29.8 With Pilot Light Full Voltage The depth of a 3-contact model depends on the combination of contact blocks at top and bottom pushbuttons. Full Voltage Adapter HW (Bottom Button) Timers (Top Button) Top Button 1 contact block 2 contact blocks Bottom Button 2 contact blocks 1 contact block Depth 89.4 mm 69.4 mm -The 3.2 mm recess is for preventing rotation and is not necessary when a nameplate or anti-rotation ring is not used. -When using the safety lever lock, determine the vertical spacing in consideration of convenience for installing and removing the safety lever lock. -Recommended vertical spacing: 100 mm -The minimum mounting centers are applicable to switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers for ease of wiring. 69.4 (2 contacts), 89.4 (4 contacts) (Note) Transfomer (240V minimum) Transformer (480V) Transformer Transformer, DC-DC Converter Contactors HW HW 89.5 (2 contacts), 109.5 (4 contacts) 79.5 (2 contacts), 99.5 (4 contacts) Dimensions (mm) Monolever Locking Ring LO 41.4 25 Terminal Blocks CK 4.2 Panel Thickness 0.8 to 6 ø3 M3.5 Terminal Screw 8 29.4 666 24 36 max. 45.5 36 max. Circuit Breakers 72 24 49.4 (2 blocks) 69.4 (4 blocks) www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Accessory Dimensions OB-31 Rubber Mounting Hole Plug ø25.8 OR-55 Lamp/LED Removal Tool 3 ø29 TOP 1.5 3.5 3.5 ø11.6 ø29 ø22 12 Gasket Locking Ring HW9Z-RL Anti-Rotation Ring ø14 LW9Z-BM Metallic Mounting Hole Plug ø25 HW-VU1 Dual Pushbutton Barrier MW9Z-T1 Locking Ring Wrench 22.5 8 ø2 110 58 45 45 33 HW-VL1 Barrier Signaling Lights HW9Z-D7D Dual Pushbutton Rubber Cover 59 1.5 20 1.5 HWLS-TK1971 Safety Lever Lock Panel Thickness 0.8 to 3.2 Safety Lever Lock Screwdriver Remove Lock Lever Safety Lever Lock CK LO 26.5 70 30 93 6.5 R6 Operator Install 82.5 Relays & Sockets HW9Z-KL1 Padlock Cover 20 24 2 ø2 .2 0 ø5 .4) 44 :ø (ID 29.5 30 Key Hole ø8 Waterproof Rubber Gasket 0.5t HW9Z-KG1 Timers Contact Block Mounting Adapter Panel HW9Z-KG2 38 22 36.5 ø2 80 32 ø76.1 2.2 64 48 ø90 Gasket Contactors ø22 TOP Marking TOP Marking Locking Ring Operator Panel Thickness: 1.2 to 4 Operator Terminal Blocks Panel Thickness: 1.2 to 4 HW9Z-KG3 ø2 HW9Z-KG4 LSTD 35 25 35 25 ø9.5 2 ø10.6 42 Circuit Breakers 20.4 ø90 67 ø75 ø74 52 ø66 ø22 50 1804091617 800-262-IDEC (4332) • USA & Canada 667 ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices Specification Charts Signaling Lights Conforming to IEC 947-5-1 Appendix C. Utilization categories AC-15 and DC-13. Operation rate: 1,800 op. hour Load factor: Inductive 0.4 ± 0.05 Resistive 0.9 ± 0.05 Operator Truth Tables 3 Position Selector Switches con’t 2 Position Selector Switches Timers Relays & Sockets Contact HW-U10 (NO) HW1S-2T HW1K-2* HW1F-2 HW-U01 (NC) HW-U10R (NO-EM) HW-U01R (NC-LB) Left Right L O X R O X L X O R X O L O X R O X L X O R X O Contact HW1S-3JT HW1K-3J* Mounting Position Operator Position Left Center Right HW-U10 (NO) L X O O R O O X HW-U01 (NC) L O X O R O X O HW-U10R (NO-EM) L X O X R X O X HW-U01R (NC-LB) L O X X R X X O 4 Position Selector Switches 3 Position Selector Switches Contact HW-U10 (NO) Contactors Mounting Position Operator Position HW1S-3T HW1K-3* HW1F-3 HW-U01 (NC) HW-U10R (NO-EM) HW-U01R (NC-LB) Contact Operator Position Mounting Position Left L X O O R O O X L O X X R X X O L X O O R O O X L O X X R X X O Center Right HW1S-4T Mounting Position Operator Position 1 2 3 4 HW-U10 (NO) L X O O O R O O O X HW-U01 (NC) L O O X O R O X O O HW-U10R (NO-EM) L X X O X R X O X X HW-U01R (NC-LB) L O X X X R X X X O 1 2 Terminal Blocks 5 Position Selector Switches Contact HW-U10 (NO) Circuit Breakers HW1S-3ST HW1K-3S* HW-U01 (NC) HW-U10R (NO-EM) HW-U01R (NC-LB) Operator Position Mounting Position Left Center Right L X O O R O O X L O O X R X O O L X X O R O X X L O X X R X X O Contact HW1S-5T 1. Mounting position indicates which side of operator each contact should be mounted (as viewed from the front of the panel). 2. *For key removable code see page 638. 668 Mounting Position Operator Position 3 4 5 HW-U10 (NO) L X O O O O R O O O O X HW-U01 (NC) L O O O X O R O X O O O HW-U10R (NO-EM) L X X X O X R X O X X X HW-U01R (NC-LB) L O X X X X R X X X X O 3. HW1S-3T is identified by white plungers on the operator. 4. HW1S-3ST is identified by red plungers on the operator. 5. HW1S-3JT is identified by black plungers on the operator. www.IDEC.com 1804091617 ø22mm - HW Series Switches & Pilot Devices Turn off power to HW series control units before starting installation, removal, wiring, maintenance, and inspection of the products. Failure to turn power off may cause electrical shocks or fire hazard. To avoid the possibility of burning yourself, use the lamp holder tool when replacing lamps. For wiring, use wires of a proper size to meet voltage and current requirements. HW General Instructions Safety Lever Lock Remove the contact block assembly from the operator (for transformer type pilot lights, remove the transformer from the illumination unit). Remove the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block assembly to the operator. IDEC strongly recommends using the safety lever lock (HW9Z-LS, yellow) to prevent heavy vibration or maintenance personnel from unlocking the contact assembly. Removing and Installing the Contact Block Assembly 1. To remove the operator from the contact block, turn the locking lever in the direction of the arrow shown below. The operator can now be removed. 1. HW series can be mounted vertically with a minimum spacing of 55 mm but spacing should be determined to ensure easy operation (recommended minimum spacing: 100 mm). 2. Mount the control unit onto the panel, lock the lever, and push in the safety lever lock to install. 3. When the spacing is narrower than the recommended value, with the lever unlocked, mount the safety lever lock and insert the contact unit to the operator. Then, lock the lever and strongly push in the safety lever lock to install. 4. To remove the safety lever lock, insert a flat screwdriver into the safety lever and push upwards. Remove Lock Lever LO Safety Lever Lock CK 26.5 Operator Install Safety Lever Lock Screwdriver Relays & Sockets 2. To reinstall, place the TOP markings on the operator and the contact block mounting adapter in the same direction, and insert the operator into the contact block mounting adapter. Then turn the locking lever in the opposite direction. Signaling Lights Panel Mounting Switches & Pilot Devices HW Safety Precautions Timers Contact Block Mounting Adapter Panel Notes for Panel Mounting Contactors 1. When mounting the operator onto a panel, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring. Tightening torque must not exceed 2.0 N·m. Do not use pliers. Excessive tightening will damage the locking ring. 2. For the contact blocks and transformers housing LED lamps, make sure not to press the lamps too hard, otherwise the lamp socket may be damaged. Dual Pushbutton Instructions Terminal Blocks Replacement of Lens Removing Remove the lens by inserting a screwdriver into the recess of the lens through the bezel. Installing Install the lens in the recess between the buttons by pressing against the bezel. Circuit Breakers 1804091617 800-262-IDEC (4332) • USA & Canada 669 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Dual Pushbuttons Instructions continued Replacement of Lamps Installation of LED Illuminated Units LED lamps can be replaced by using the lamp holder tool (OR-55) from the front of the panel, or by removing the contact block assembly from the operator unit. When using full voltage type LED illuminated units, provide protection against electrical noise, if necessary. Removing the Lamps from the Front of the Panel Applicable Wiring The applicable wire size is 2 mm2 maximum. (solid wire ø1.6mm2 maximum) One or two wires can be connected. Applicable Crimping Terminal 1. To remove, slip the lamp holder tool onto the lamp head lightly. Then push slightly, and turn the lamp holder tool counterclockwise. ø3.6 min. 7.9 max. Signaling Lights Removal 4 max. Be sure to use an insulation tube or cover on the crimping part of the crimping terminal to prevent electrical shocks. Lamp 8 max. Timers 2. Place the pins on the lamp base to the grooves in the lamp socket. Insert the lamp and turn it clockwise. Lamp Base Do not attempt to remove using a flat screwdriver or pincers, otherwise the dual pushbuttons may be damaged. Contactors Note: When connecting wires to contact blocks or transformers in the direction shown below, keep the insulation stripping length 6.6 mm at the maximum. About Dual Pushbutton Switches X1 X2 X1 X2 Do not attempt to remove the pushbuttons! The dual pushbuttons cannot be removed or replaced! Inside Inside Pushbuttons Installing the Rubber Boot When using the HW7D pushbuttons in places where the pushbuttons are subjected to water splash or an excessive amount of dust, make sure to use the HW9Z-D7D rubber boot (IP65) which is ordered separately. Narrow Mounting When mounting the units closely in a horizontal row on 30mm centers, use optional barriers to prevent interconnection between adjoining terminals. The barriers can be attached simply by pressing them onto the sides of contact blocks. 30 30 Notes for Installing the Rubber Boot Remove the gasket from the operator, and install the rubber boot on the operator. Pull out the seals of the rubber boot and place them around the operator sleeve as shown. Make sure that the seals are not twisted or tucked inside and that the gasket does not remain, otherwise the normal waterproof and dustproof characteristics are not ensured. 1. Remove the gasket. Terminal Blocks Circuit Breakers Solid Wire Lamp Holder Tool ø1.6 max. Relays & Sockets Installation 1. To install, insert the lamp head into the lamp holder tool, and hold the lamp as shown in the figure below. 5.5 min. 2. Install the rubber boot on the pushbuttons. 3. Rubber boot is installed. Seals Install Barrier When mounting transformer type illuminated units closely in a horizontal row on 30-mm centers, insert solid wires or stranded wires into inside of the terminal screw on the transformer (see figure on the right) to prevent short circuit between adjoining terminals. 670 X1 X2 Inside Remove X1 X2 Gasket Seals Inside www.IDEC.com 1804091617
HW4L-M1F11QD-G-24V 价格&库存
很抱歉,暂时无法提供与“HW4L-M1F11QD-G-24V”相匹配的价格&库存,您可以联系我们找货
