HAAV4-27
HAAV4-27
    IDEC(日本和泉)
HAAV4-27 数据手册
ø16mm XA Series Emergency Stop Switches (Unibody Type) Only 19.5mm behind the panel, compact ø16mm emergency stop switches. Actual Size 19.5 mm Conventional XA Series: 27.9 mm Reducing mounting depth! Ideal for installing in equipment which has mounting limitations Easy to Reset Push-to-lock, Pull/turn-to-reset Resetting is possible by either pulling or turning the button, allowing for easy operation. Unlatching by pulling Operator diameter ø29/ø40 mm Operator color: bright red, dark red, yellow, gray Degree of protection: IP40/IP65 HG1U Unlatching by turning HG2S IDEC's emergency stop switches value safety. Safety Potential Structure 2nd-generation Conventional Energy Status of Emergency Stop Switches Normal Status Direct Opening Action 3rd-generation (Safety Potential Structure) Enegy Status of XA Series Emergency Stop Switches Latched Normal Status Latched Achievement of contact separation (of a contact element) of the switch actuator through a direct mechanical link (for example not dependent upon springs) (IEC 60947-5-5; 5.2, IEC 60947-5-1; Annex K) NC contacts: ON (machine can operate) NC contacts: OFF (machine cannot operate) NC contacts: ON (machine can operate) High NC contacts are always on standby to turn on (hazardous) Normal Operator Stroke Latched Low NC contacts are always on standby to turn off (safe) Normal Operator Stroke Latched With XA emergency stop switches, the potential energy level of the latched status is lower than that of normal status. In the event the switch is damaged due to excessive shocks, the NC contacts will turn off, thus stopping the machine (patented). (080630) The emergency stop signal shall be maintained until the emergency stop device is reset (disengaged). (IEC 60947-5-5; 6.2) International Safety Standards Energy Energy High Low Safe Lock Mechanism NC contacts: OFF (machine cannot operate) ø16 XA Series Emergency Stop Switches (Unibody Type) Small, unibody emergency stop switches suitable for equipment with small mounting space. Requires only ø16mm × 19.5mm for installation. • ø29mm and ø40mm mushroom operators • Degree of protection IP65 and IP40 (IEC 60529) • Dark red (Munsell 5R4/12) and bright red (Munsell 7.5R4.5/14) colors for operators of emergncy stop switches, and yellow/gray for stop switch operators. • Gold-plated crossbar contacts • Push-to-lock, pull or turn-to-reset operator • UL, c-UL recognized. EN compliant. • Safety lock mechanism (IEC 60947-5-5, 6.2) • Direct opening action mechanism (IEC 60947-5-5, 5.2, IEC60947-5-1, Annex K) Solder Terminal IP40 Type (body color: black) Solder Terminal IP65 Type (body color: yellow) Standards Standards Applicable Standards UL508, CSA C22.2 No.14 IEC 60947-5-1, EN 60947-5-1 IEC 60947-5-5 (Note), EN 60947-5-5 (Note) JIS C8201-5-1 Operating Temperature −25 to +60°C (no freezing) TÜV SÜD Operating Humidity 45 to 85% RH (no condensation) Storage Temperature −45 to +80°C (no freezing) European Commission’s Low Voltage Directive Operating Force Push-to-lock: 10.5N Pull to reset: 10N Turn to reset: 0.16 N·m Mark UL508 CSA C22.2 No.14 Specifications Organization/File No. UL/c-UL File No. E68961 EN60947-5-5 (Note) Minimum Force Required for Direct Opening Action Minimum Operator Stroke Required for Direct Opening Action Note: Except for stop switches (operator color: yellow and gray) Contact Ratings Rated Insulation Voltage (Ui) 250V Thermal Current (Ith) Rated Operating Current DC Resistive Load (AC-12) Inductive Load (AC-15) Resistive Load (DC-12) Inductive Load (DC-13) 40N 4.0 mm Maximum Operator Stroke 4.5 mm 5A Rated Operating Voltage (Ue) AC 50/60Hz Solder/tab #110 30V 125V 250V — 5A 3A Contact Resistance 50 mΩ maximum (initial value) Insulation Resistance 100 MΩ minimum (500V DC megger) Overvoltage Category II Impulse Withstand Voltage 2.5 kV — 3A 1.5A Pollution Degree 3 2A 0.4A 0.2A Operating Frequency 900 operations/hour 1A 0.22A 0.1A Shock Resistance •• Minimum applicable load: 5V AC/DC, 1 mA (reference value) (May vary depending on the operating conditions and load.) •• The rated operating currents are measured at resistive/inductive loads as specified in IEC 60947-5-1. Vibration Resistance Durability Operating extremes: 150 m/s2 Damage limits: 1000 m/s2 Operating extremes: 10 to 500 Hz, amplitude 0.35mm, acceleration 50 m/s2 Damage limits: 10 to 500 Hz, amplitude 0.35 mm, acceleration 50 m/s2 Mechanical: 250,000 Electrical: 100,000 250,000 (24V AC/DC, 100mA) Degree of Protection IP65, IP40 (IEC 60529) Short-circuit Protection 250V/10A fuse (Type aM IEC 60269-1/IEC 60269-2) Conditional Short-circuit Current Terminal Style 1000A Solder terminal, Solder/tab #110 terminal Recommended Tightening 0.88 N·m Torque for Locking Ring Applicable Wire Size 1.25 mm2 maximum (AWG16 maximum) Terminal Soldering Condition 310 to 350°C, within 3 seconds Weight (approx.) ø29mm mushroom: 14g ø40mm mushroom: 17g Note: Except for stop switches (operator color: yellow and gray) 2 (080630) XA Series Emergency Stop Switches (Unibody Type) ø16 Types ••Solder Terminal Type Emergency Stop Switches Shape Ordering Type No. Contact IP40 (contact part: black) IP65 (contact part: yellow) 1NC XA1E-BV3U01K XA1E-BV3U01 2NC XA1E-BV3U02K XA1E-BV3U02 ø29mm Mushroom  Operator Color Code R: red RH: bright red ø40mm Mushroom 1NC XA1E-BV4U01K XA1E-BV4U01 2NC XA1E-BV4U02K XA1E-BV4U02 •• Solder/tab #110 terminal is also available. Specify “T” before  in the Ordering Type No. XA1E-BV3U02KR → XA1E-BV3U02KTR ••Solder Terminal Type Stop Switches Operator Type Shape Contact ø29mm Mushroom ø40mm Mushroom Ordering Type No. IP40 (contact part: black) IP65 (contact part: yellow) 1NC XA1E-BV3U01K XA1E-BV3U01 2NC XA1E-BV3U02K XA1E-BV3U02 1NC XA1E-BV4U01K XA1E-BV4U01 2NC XA1E-BV4U02K XA1E-BV4U02  Operator Color Code Y: yellow N: gray •• Solder/tab #110 terminal is also available. Specify “T” before  in the Ordering Type No. XA1E-BV3U02KY → XA1E-BV3U02KTY Dimensions Terminal Arrangement (Bottom View) Panel Thickness 0.8 to 4.5 +0 0 .2 8.0 15.9 3.6 20.6 +0.2 0 TOP 1 2 2 1 1NC: Termimals on top Mounting Hole Solder Terminal (Behind the panel: 19.5) Mounting Hole Layout 0 Solder/Tab Terminal #110 (Behind the panel: 23.9) 15.9 1.7 +0.2 0 2 10.2 10.2 0.5 0.5 6. 17.9 ø1 ø4 9.0 8 ø2 5. ø1 ø16.2 +0.2 0 • The values shown on the left are the minimum dimensions for mounting with other ø16 mm pushbuttons. For other control units of different sizes and styles, determine the values according to the dimensions, operation, and wiring. Y 20.6 ø29 mm Mushroom ø40 mm Mushroom X X All dimensions in mm. (080630) Y ø29mm Mushroom 40 mm minimum ø40mm Mushroom 50 mm minimum 3 ø16 XA Series Emergency Stop Switches (Unibody Type) Nameplate Description Legend Ordering Type No. Blank For ø29mm Mushroom Dimensions 3.5 Blank 0 HAAV4-0 ø1 6 1.7 EMERGENCY STOP HAAV4-27 Mounting panel thickness: 0.5 to 3 mm Material: Polyamide Nameplate color: yellow Legend color: black ø6 ø4 EMERGENCY STOP HAAV-27 For ø40mm Mushroom For ø40mm Mushroom For ø29mm Mushroom HAAV-0 Remarks ø1 6 0.3 1.7 0.5 •• See “When using a nameplate” in Instructions below. Accessories Shape Material Ring Wrench Type No. Metal (nickel-plated MT-001 brass) Ordering Type No. Package Quantity MT-001 Remarks Used to ltighten the locking ring when installing the XA switch onto a panel. TIghtening torque: 0.88 N·m maximum 1 •• SEMI S2-compliant switch guard (XA9Z-KG1) and EMO label (HW9Z-EMO-NPP) are also available. Safety Precautions •• Turn off power to the XA series emergency stop switch before installation, removal, wiring, maintenance, and inspection of the switches. Failure to turn power off may cause electrical shocks or fire hazard. •• For wiring, use wires of a proper size to meet voltage and current requirements and solder correctly. Failure to solder correctly may cause overheating and fire. Instructions Panel Mounting Remove the locking ring from the operator and check that the gasket is in place. Insert the operator from panel front into the panel hole. Face the side with a projection upward, and tighten the locking ring. Operator Projection Gasket Locking Ring •• Notes for Panel Mounting Using ring wrench MT-001, tighten the locking ring to a torque of 0.88 N·m. Do not use pliers. Do not apply excessive force, otherwise the locking ring will be damaged. Wiring 111The applicable wire size is 1.25 mm2 maximum. 222Solder the terminals using a soldering iron at 310 to 350°C for 3 seconds. Make sure that the soldering iron touches the terminals only, not plastic parts. When wiring, do not apply external force such as bending the terminals or applying tensile force on the wires. 333Use a non-corrosive rosin flux. 444Because the terminal spacing is narrow, use protective tubes or heat shrinkable tubes to avoid burning wire insulation or short circuit. 555Solder/Tab Terminal #110 • Use #110 receptacles for 0.5mm-thick tabs. • Because the terminal spacing is narrow, use protective tubes or heat shrinkable tubes of 0.5mm minimum in thickness. 666Do not apply force on the terminals in the direction other than vertical to the mounting panel, otherwise the terminals will be damaged. Contact Bounce When the button is reset by pulling or turning, the NC contacts will bounce. When designing a control circuit, take the contact bounce time into consideration (reference value: 20 ms). Nameplate Remove the projection from the nameplate using pliers, otherwise the switch cannot be installed. Handling Projection Nameplate Do not expose the switch to excessive shock and vibrations, otherwise the switch may be deformed or damaged, causing malfunction or operation failure. Specifications and other descriptions in this catalog are subject to change without notice. 7-31, Nishi-Miyahara 1-Chome, Yodogawa-ku, Osaka 532-8550, Japan Tel: +81-6-6398-2571, Fax: +81-6-6392-9731 E-mail: products@idec.co.jp IDEC CORPORATION (USA) IDEC ELEKTROTECHNIK GmbH IDEC CANADA LIMITED Room 608-609, 6F, Gangtai Plaza, No. 700, Yan'an East Road, Shanghai 200001, PRC Tel: +86-21-5353-1000, Fax: +86-21-5353-1263 E-mail: idec@cn.idec.com 1175 Elko Drive, Sunnyvale, CA 94089-2209, USA Tel: +1-408-747-0550 / (800) 262-IDEC (4332) Fax: +1-408-744-9055 / (800) 635-6246 E-mail: opencontact@idec.com 3155 Pepper Mill Court, Unit 4, Mississauga, Ontario, L5L 4X7, Canada Tel: +1-905-890-8561, Toll Free: (888) 317-4332 Fax: +1-905-890-8562 E-mail: sales@ca.idec.com IDEC AUSTRALIA PTY. LTD. 2/3 Macro Court, Rowville, Victoria 3178, Australia Tel: +61-3-9763-3244, Toll Free: 1800-68-4332 Fax: +61-3-9763-3255 E-mail: sales@au.idec.com IDEC ELECTRONICS LIMITED www.idec.com Unit 2, Beechwood, Chineham Business Park, Basingstoke, Hampshire RG24 8WA, UK Tel: +44-1256-321000, Fax: +44-1256-327755 E-mail: sales@uk.idec.com Wendenstrasse 331, 20537 Hamburg, Germany Tel: +49-40-25 30 54 - 0, Fax: +49-40-25 30 54 - 24 E-mail: service@idec.de IDEC (SHANGHAI) CORPORATION IDEC (BEIJING) CORPORATION Room 211B, Tower B, The Grand Pacific Building, 8A Guanghua Road, Chaoyang District, Beijing 100026, PRC Tel: +86-10-6581-6131, Fax: +86-10-6581-5119 IDEC (SHENZHEN) CORPORATION Unit AB-3B2, Tian Xiang Building, Tian’an Cyber Park, Fu Tian District, Shenzhen, Guang Dong 518040, PRC Tel: +86-755-8356-2977, Fax: +86-755-8356-2944 IDEC IZUMI (H.K.) CO., LTD. Units 11-15, Level 27, Tower 1, Millennium City 1, 388 Kwun Tong Road, Kwun Tong, Kowloon, Hong Kong Tel: +852-2803-8989, Fax: +852-2565-0171 E-mail: info@hk.idec.com IDEC TAIWAN CORPORATION 8F-1, No. 79, Hsin Tai Wu Road, Sec. 1, Hsi-Chih, Taipei County, Taiwan Tel: +886-2-2698-3929, Fax: +886-2-2698-3931 E-mail: service@tw.idec.com IDEC IZUMI ASIA PTE. LTD. No. 31, Tannery Lane #05-01, HB Centre 2, Singapore 347788 Tel: +65-6746-1155, Fax: +65-6844-5995 E-mail: info@sg.idec.com (080630) Cat. No. EP1235-0 JULY 2008 3.8DNP PRINTED IN JAPAN
HAAV4-27 价格&库存
很抱歉,暂时无法提供与“HAAV4-27”相匹配的价格&库存,您可以联系我们找货
HAAV4-27
  • 1+45.068401+5.83080
  • 10+40.9633310+5.29970
库存:9
HAAV4-27
    库存:21
    HAAV4-27
      • 1+43.55067
      • 50+41.83239
      • 100+40.07245
      库存:21
      HAAV4-27
      • 1+44.73783
      • 10+40.66531
      库存:9
