FL9Y-LP1CDW
FL9Y-LP1CDW
    IDEC(日本和泉)
FL9Y-LP1CDW 数据手册
Think Automation and beyond... PS5R Slim Line Power Supplies SA1E Sensors IDEC PS5R Slim Line power supplies have all the features, all the power, and only half the size of traditional power supplies. Save valuable DIN Rail space with the 30W, 60W, 90W, 120W, or 240W models which can fit any of your power needs. The PS5R Slim Line models are UL508 and UL1604 listed for hazardous locations. The 30W and 60W models are also NEC Class 2 rated. The 120W and 240W models comply with SEMI F47 sag immunity requirements. Choose your sensing method, operation mode, control output and connection method with the simple and affordable SA1E sensors, and get exactly what you need in a very small package. There are 32 models available, all rated IP67 for water resistance, with a response time of 1 msec (maximum). Special interference prevention allows close mounting of two sensors (except for through-beam type), and the quick connect and disconnect option make installation a breeze. Support Information HW Switches IDEC SmartRelay www.idec.com/smartrelay In basic black or stylish metal, the HW series of 22mm switches from IDEC are available in several styles to dress up any panel. HW pushbuttons and pilot devices are internationally-rated, designed for use almost anywhere in the world, and have removable contact blocks, finger-safe terminals, and tamperproof construction. Choose simple black plastic bezels for clean uniformity or chrome-plated metallic bezels for a rugged industrial look. Technical support: support@idec.com 800-262-IDEC www.idec.com * New Advanc ed Featu Think Automation and beyond... www.idec.com USA Japan Germany China/Beijing China/Shenzhen IDEC Corporation Tel: (408) 747-0550 opencontact@idec.com IDEC Corporation Tel: +81-6-6398-2571 products@idec.co.jp IDEC Elektrotechnik GmbH Tel: +49-40-253054-10 service@idec.de IDEC (Shanghai) Corporation Tel: +86-10-6599-5541 IDEC (Shenzhen) Corporation Tel: +86-755-8356-2977 Canada United Kingdom Hong Kong China/Shanghai Singapore IDEC Canada Ltd. Tel: (905) 890-8561 sales@idec.com IDEC Electronics Ltd. Tel: +44-1256-321000 idec@uk.idec.com IDEC (H.K.) Co., Ltd. Tel: +852-2803-8989 info@hk.idec.com IDEC (Shanghai) Corporation Tel: +86-21-5353-1000 idec@cn.idec.com IDEC Asia Pte. Ltd. Tel: +65-6746-1155 info@sg.idec.com Australia IDEC Australia Pty. Ltd. Tel: +61-3-9763-3244 sales@au.idec.com Taiwan ©2006 IDEC Corporation. All Rights Reserved. Catalog No. FL9Y-B100-0 2/06 15K Specifications and other descriptions in this catalog are subject to change without notice. IDEC Taiwan Corporation Tel: +886-2-2698-3929 service@idectwn.com.tw IDEC SmartRelay res The possibilities are endless www.idec.com/smartrelay * 1 Nedw ures Feat Select "Program" from the main menu. nce Adva 2 Now our new fourth-generation SmartRelays include new advanced feaures that offer even more versatility and functions! With new features including: an analog output module, 3 new function block types, upgraded software and Industrial Facility Systems Conveyor systems • Elevator controls • Liquid level controls • Motor, pump and valve controls • Water treatment and irrigation systems • available expansion modules, you can get everything you need from one compact module. When you need a product you can rely on, is easy to use, and meets safety standards, look no further than IDEC. Our SmartRelays meet all industry standard approvals including cULus, CE, C-tick and ABS (American Bureau of Shipping). Plus they are FM approved for Class 1 Div 2 hazardous locations. The bottom line is IDEC SmartRelays provide the right solution for all your control needs! Why wait? Replace your complicated system of relays, timers and counters with just one IDEC SmartRelay! It’s safe to say we all want to reduce workloads while saving money, and with IDEC SmartRelays it’s easy. These all-in-one controllers require less space in your control cabinet. And as you know, space in your panel is money in your pocket. Combine that with low maintenance and you’ve got a cost-effective product you can count on for all your control operations! Housing and Building Management • Lighting controls • HVAC • Gate and door controls • Shutter and sun blind controls • Water and sprinkler systems 7 F - ) 4UBSU 4UPQ Solar-electric systems • Traffic light controls • Ventilation systems on ships • Extreme environmental conditions • $ $3 - - / ) 7 . Monitoring Systems • Access controls • Alarm systems • Parking lot control monitoring ) 43$4 0-T $3 4MPX è 'BTU 4QFFE$POUSPM $3 $3 - $ . 'JFME$POUBDUPS $ . $ %$ .PUPS'JFME 8JOEJOH .PUPS "SNBUVSF Your logic circuit can be accomplished ... 2 Select "Start," and you're done. Your time is valuable and with that in mind, IDEC has created a product that will require very little of it. Using a system smaller than a PLC, with minimal wiring, mounting as simple as a quick snap on to a DIN rail, and programming as easy as one touch of a button, the user-friendly SmartRelay is the perfect solution. ) Unique Solutions Create your control logic. Why spend all that time wiring when it's as simple as 1, 2, 3? Smart Control - IDEC SmartRelay Look around you. IDEC SmartRelays are everywhere! You can find them in lighting controls, ice-making machines, grocery store mist systems and more. And there’s a good reason: IDEC SmartRelays meet all safety requirements, while at the same time saving you time and money. 3 by just installing this unit. 3 The possibilities are endless www.idec.com/smartrelay * 1 Nedw ures Feat Select "Program" from the main menu. nce Adva 2 Now our new fourth-generation SmartRelays include new advanced feaures that offer even more versatility and functions! With new features including: an analog output module, 3 new function block types, upgraded software and Industrial Facility Systems Conveyor systems • Elevator controls • Liquid level controls • Motor, pump and valve controls • Water treatment and irrigation systems • available expansion modules, you can get everything you need from one compact module. When you need a product you can rely on, is easy to use, and meets safety standards, look no further than IDEC. Our SmartRelays meet all industry standard approvals including cULus, CE, C-tick and ABS (American Bureau of Shipping). Plus they are FM approved for Class 1 Div 2 hazardous locations. The bottom line is IDEC SmartRelays provide the right solution for all your control needs! Why wait? Replace your complicated system of relays, timers and counters with just one IDEC SmartRelay! It’s safe to say we all want to reduce workloads while saving money, and with IDEC SmartRelays it’s easy. These all-in-one controllers require less space in your control cabinet. And as you know, space in your panel is money in your pocket. Combine that with low maintenance and you’ve got a cost-effective product you can count on for all your control operations! Housing and Building Management • Lighting controls • HVAC • Gate and door controls • Shutter and sun blind controls • Water and sprinkler systems 7 F - ) 4UBSU 4UPQ Solar-electric systems • Traffic light controls • Ventilation systems on ships • Extreme environmental conditions • $ $3 - - / ) 7 . Monitoring Systems • Access controls • Alarm systems • Parking lot control monitoring ) 43$4 0-T $3 4MPX è 'BTU 4QFFE$POUSPM $3 $3 - $ . 'JFME$POUBDUPS $ . $ %$ .PUPS'JFME 8JOEJOH .PUPS "SNBUVSF Your logic circuit can be accomplished ... 2 Select "Start," and you're done. Your time is valuable and with that in mind, IDEC has created a product that will require very little of it. Using a system smaller than a PLC, with minimal wiring, mounting as simple as a quick snap on to a DIN rail, and programming as easy as one touch of a button, the user-friendly SmartRelay is the perfect solution. ) Unique Solutions Create your control logic. Why spend all that time wiring when it's as simple as 1, 2, 3? Smart Control - IDEC SmartRelay Look around you. IDEC SmartRelays are everywhere! You can find them in lighting controls, ice-making machines, grocery store mist systems and more. And there’s a good reason: IDEC SmartRelays meet all safety requirements, while at the same time saving you time and money. 3 by just installing this unit. 3 Control at the push of a button www.idec.com/smartrelay EEPROM memory Never worry about your program being lost again! With IDEC SmartRelays, your program is stored in a non-volatile EEPROM. Digital/Analog Inputs Each SmartRelay is equipped with 8 digital inputs for you to utilize in your applications. On selected models such as FL1D-H12RCE, FL1D-B12RCE and FL1D-H12SND, inputs 5 and 6 can be used as fast inputs up to 2 kHhz and inputs 7 and 8 can be configured as 0-10V analog inputs. A maximum of 24 digital inputs can be utilized with this system using digital expansion modules. Universal Voltages SmartRelays are available in 12/24VDC, 24VAC/DC, and 100-240VAC/DC voltages. Password Protection Concerned about your program being copied or altered? IDEC SmartRelays keep you safe with a unique password protection scheme allowing end users to access certain parameters without seeing or modifying the actual program. Multifunction Interface If you prefer not to program your SmartRelay using the LCD and keypad, simply connect the interface cable to your PC and program with our WindLGC software instead. Or you can plug-in the special memory cartridge (FL1C-PM3) and have your SmartRelay operate the circuit program through the cartridge itself. DIN Rail or Surface Mountable Large Program Capacity Running out of program space is a thing of the past. IDEC SmartRelays can handle up to 130 function blocks (2000 bytes). Integrated Functions 8 predefined basic function blocks and 28 special function blocks ensure that almost all your conventional switching devices — timers and counters — can be replaced. Three New functions include a PI controller (e.g. for temperature control), a two-stage ramp function (e.g. for the control of frequency converters) and an analog multiplexer (e.g. for light control). See page 9. * Quality IDEC means quality and dependability you can trust and our SmartRelays are no exception. Each model is cULus listed, CE certified, EMC compliant, FM approved for Class 1 Div 2 hazardous locations, C-tick compliant, Lloyds Registered, and ABS approved. $ Backlit LCD Display System status — input, output, analog values, timers and counters — can be monitored through an embedded 4x12 LCD on your SmartRelay. This allows you to display a predefined message with up to 48 characters chosen from 103 special character types. New You can now adjust the contrast on your display screen to your preference. Non-LCD versions are also available. * Digital Outputs IDEC SmartRelays are equipped with 4 relay outputs rated at 10A/pt. A maximum of 16 outputs can be configured with this system using digital expansion modules. 4 Operational Control Buttons IDEC SmartRelays can be programmed with just the push of a button! Control buttons can be used to program, modify and change preset parameters. The four cursor keys can also be configured as inputs if needed. R 64 FM APPROVED Expansion Modules Just snap-on and go! No cable required. Each digital expansion module has 4 inputs and 4 outputs available in 12/24VDC, 24VAC/DC and 100-240VAC/DC. Up to 4 expansion modules can be mounted on an IDEC SmartRelay base module. Plus SmartRelay also has the capability to communicate within a LONWORKS® network and AS-interface system with its LONWORKS and AS-interface modules. Analog Inputs & Outputs Using the 2-pt analog input and 2-pt analog output expansion modules allows you to easily control and process your analog signal. IDEC SmartRelays can control and process 0-10V and 4-20mA signals with a 10-bit resolution. Up to 4 analog input and 1 analog output modules can be attached to the base module. 5 Control at the push of a button www.idec.com/smartrelay EEPROM memory Never worry about your program being lost again! With IDEC SmartRelays, your program is stored in a non-volatile EEPROM. Digital/Analog Inputs Each SmartRelay is equipped with 8 digital inputs for you to utilize in your applications. On selected models such as FL1D-H12RCE, FL1D-B12RCE and FL1D-H12SND, inputs 5 and 6 can be used as fast inputs up to 2 kHhz and inputs 7 and 8 can be configured as 0-10V analog inputs. A maximum of 24 digital inputs can be utilized with this system using digital expansion modules. Universal Voltages SmartRelays are available in 12/24VDC, 24VAC/DC, and 100-240VAC/DC voltages. Password Protection Concerned about your program being copied or altered? IDEC SmartRelays keep you safe with a unique password protection scheme allowing end users to access certain parameters without seeing or modifying the actual program. Multifunction Interface If you prefer not to program your SmartRelay using the LCD and keypad, simply connect the interface cable to your PC and program with our WindLGC software instead. Or you can plug-in the special memory cartridge (FL1C-PM3) and have your SmartRelay operate the circuit program through the cartridge itself. DIN Rail or Surface Mountable Large Program Capacity Running out of program space is a thing of the past. IDEC SmartRelays can handle up to 130 function blocks (2000 bytes). Integrated Functions 8 predefined basic function blocks and 28 special function blocks ensure that almost all your conventional switching devices — timers and counters — can be replaced. Three New functions include a PI controller (e.g. for temperature control), a two-stage ramp function (e.g. for the control of frequency converters) and an analog multiplexer (e.g. for light control). See page 9. * Quality IDEC means quality and dependability you can trust and our SmartRelays are no exception. Each model is cULus listed, CE certified, EMC compliant, FM approved for Class 1 Div 2 hazardous locations, C-tick compliant, Lloyds Registered, and ABS approved. $ Backlit LCD Display System status — input, output, analog values, timers and counters — can be monitored through an embedded 4x12 LCD on your SmartRelay. This allows you to display a predefined message with up to 48 characters chosen from 103 special character types. New You can now adjust the contrast on your display screen to your preference. Non-LCD versions are also available. * Digital Outputs IDEC SmartRelays are equipped with 4 relay outputs rated at 10A/pt. A maximum of 16 outputs can be configured with this system using digital expansion modules. 4 Operational Control Buttons IDEC SmartRelays can be programmed with just the push of a button! Control buttons can be used to program, modify and change preset parameters. The four cursor keys can also be configured as inputs if needed. R 64 FM APPROVED Expansion Modules Just snap-on and go! No cable required. Each digital expansion module has 4 inputs and 4 outputs available in 12/24VDC, 24VAC/DC and 100-240VAC/DC. Up to 4 expansion modules can be mounted on an IDEC SmartRelay base module. Plus SmartRelay also has the capability to communicate within a LONWORKS® network and AS-interface system with its LONWORKS and AS-interface modules. Analog Inputs & Outputs Using the 2-pt analog input and 2-pt analog output expansion modules allows you to easily control and process your analog signal. IDEC SmartRelays can control and process 0-10V and 4-20mA signals with a 10-bit resolution. Up to 4 analog input and 1 analog output modules can be attached to the base module. 5 Create, test and save your program in seconds www.idec.com/smartrelay WindLGC 5.0 Software Basic Function Blocks Program Comparison WindLGC is the exclusive programming software for the IDEC SmartRelay using Windows®. Simplicity  Ê­ `}i® `}iÊ`iÌiV̈œ˜Ê܈̅ i`}iÊiÛ>Õ>̈œ˜Ê­˜i}°Êi`}i®  *>À>iÊVœ˜˜iV̈œ˜Êœv ˜œÀ“>ÞÊVœÃi`ÊVœ˜Ì>VÌà ", -iÀˆiÃÊVœ˜˜iV̈œ˜Êœv ˜œÀ“>ÞÊVœÃi`ÊVœ˜Ì>VÌà ", *>À>iÊVœ˜˜iV̈œ˜Êœv ˜œÀ“>Þʜ«i˜ÊVœ˜Ì>VÌà  Create, simulate, test and save your program in just a matter of seconds using drag and drop functions. £ Ó Î { + Control ÞVi Choose either function block or ladder programming, but keep in mind that you can always convert from one to the other with just the click of an icon. Offline program simulation (without the need for an actual unit) enables testing of the entire program from a PC, or you can test and monitor your IDEC SmartRelay online. £ Ó Î { Simulation Mode/Online Monitor Documentation £ Ó Î { £ +  -iÀˆiÃÊVœ˜˜iV̈œ˜Êœv ˜œÀ“>Þʜ«i˜ÊVœ˜Ì>VÌà You can create and save your WindLGC program as a .pdf or .jpg file. Professional documentation is included with all necessary configuration information such as comments and program settings. £ Ó Î { £ + Ó Î { x È Ç £ Ó E Î { E + 8", œÕLiÊV…>˜}iœÛiÀÊVœ˜Ì>VÌ  Ê­ `}i® `}iÊ`iÌiV̈œ˜Ê܈̅ i`}iÊiÛ>Õ>̈œ˜Ê­«œÃ°Êi`}i® £ n ™ £ä + "/ œ˜˜iV̈œ˜ÊœvÊVœÃi`ÊVœ˜Ì>VÌ  £ Ó Î { + ÞVi On the Web £ Ó Î { Ladder Programming Visit IDEC at www.idec.com/smartrelay for additional information on software upgrades, demo software, FAQs, manuals or brochures. £ Ó Î { x È £ Ó E Î { E + Ç n ™ £ä £ Ó + r£ £ + £ + Loaded with functions! Special Function Blocks ON Delay OFF Delay ON/OFF Delay Retentive ON Delay Interval Time-Delay Relay/Pulse Output Current Impulse Relay Edge-Triggered Interval Time-Delay Relay Latching Relay Seven-Day Time Switch Twelve-Month Time Switch Up/Down Counter Analog Differential Trigger Analog Value Monitoring Operating Hours Counter T Trg Q T Trg R Q Trg Trg R Q Q T TH TL Trg Trg Trg Q T S R Q T T 6 Q Trg R Par Q Trg Par Q Trg R Par Q Trg Par Q T TStarts S R Par RS Q Trg R Par No1 S R Q Q Trg Trg Par Sa Q No2 Sa Su ON 12:00 OFF 20:00 Su ON  8:00 OFF 22:00 Q S R Par RS Q 12 Su 20 12 20 8 12 20 8 No1 No2 No3 Q 22 MM.DDt Fed. Mar. Apr. No 02.25 No 04.15 Q 25 MM DD Q R Cnt Dir Par Aen+ Aen Aen- OFF=On+ AX Q AX Q 0 25 Q R En Ral Mi Mn En AX Q Q 20 No o n OFF=On+ R Cnt Dir 3 Par 21 OT Q Ax Par Q En Ax Par Q R En Ral Par h Q 7 Create, test and save your program in seconds www.idec.com/smartrelay WindLGC 5.0 Software Basic Function Blocks Program Comparison WindLGC is the exclusive programming software for the IDEC SmartRelay using Windows®. Simplicity  Ê­ `}i® `}iÊ`iÌiV̈œ˜Ê܈̅ i`}iÊiÛ>Õ>̈œ˜Ê­˜i}°Êi`}i®  *>À>iÊVœ˜˜iV̈œ˜Êœv ˜œÀ“>ÞÊVœÃi`ÊVœ˜Ì>VÌà ", -iÀˆiÃÊVœ˜˜iV̈œ˜Êœv ˜œÀ“>ÞÊVœÃi`ÊVœ˜Ì>VÌà ", *>À>iÊVœ˜˜iV̈œ˜Êœv ˜œÀ“>Þʜ«i˜ÊVœ˜Ì>VÌà  Create, simulate, test and save your program in just a matter of seconds using drag and drop functions. £ Ó Î { + Control ÞVi Choose either function block or ladder programming, but keep in mind that you can always convert from one to the other with just the click of an icon. Offline program simulation (without the need for an actual unit) enables testing of the entire program from a PC, or you can test and monitor your IDEC SmartRelay online. £ Ó Î { Simulation Mode/Online Monitor Documentation £ Ó Î { £ +  -iÀˆiÃÊVœ˜˜iV̈œ˜Êœv ˜œÀ“>Þʜ«i˜ÊVœ˜Ì>VÌà You can create and save your WindLGC program as a .pdf or .jpg file. Professional documentation is included with all necessary configuration information such as comments and program settings. £ Ó Î { £ + Ó Î { x È Ç £ Ó E Î { E + 8", œÕLiÊV…>˜}iœÛiÀÊVœ˜Ì>VÌ  Ê­ `}i® `}iÊ`iÌiV̈œ˜Ê܈̅ i`}iÊiÛ>Õ>̈œ˜Ê­«œÃ°Êi`}i® £ n ™ £ä + "/ œ˜˜iV̈œ˜ÊœvÊVœÃi`ÊVœ˜Ì>VÌ  £ Ó Î { + ÞVi On the Web £ Ó Î { Ladder Programming Visit IDEC at www.idec.com/smartrelay for additional information on software upgrades, demo software, FAQs, manuals or brochures. £ Ó Î { x È £ Ó E Î { E + Ç n ™ £ä £ Ó + r£ £ + £ + Loaded with functions! Special Function Blocks ON Delay OFF Delay ON/OFF Delay Retentive ON Delay Interval Time-Delay Relay/Pulse Output Current Impulse Relay Edge-Triggered Interval Time-Delay Relay Latching Relay Seven-Day Time Switch Twelve-Month Time Switch Up/Down Counter Analog Differential Trigger Analog Value Monitoring Operating Hours Counter T Trg Q T Trg R Q Trg Trg R Q Q T TH TL Trg Trg Trg Q T S R Q T T 6 Q Trg R Par Q Trg Par Q Trg R Par Q Trg Par Q T TStarts S R Par RS Q Trg R Par No1 S R Q Q Trg Trg Par Sa Q No2 Sa Su ON 12:00 OFF 20:00 Su ON  8:00 OFF 22:00 Q S R Par RS Q 12 Su 20 12 20 8 12 20 8 No1 No2 No3 Q 22 MM.DDt Fed. Mar. Apr. No 02.25 No 04.15 Q 25 MM DD Q R Cnt Dir Par Aen+ Aen Aen- OFF=On+ AX Q AX Q 0 25 Q R En Ral Mi Mn En AX Q Q 20 No o n OFF=On+ R Cnt Dir 3 Par 21 OT Q Ax Par Q En Ax Par Q R En Ral Par h Q 7 Modules that expand the possibilities www.idec.com/smartrelay I/O Expansion Modules Part Number Module Input Power Input Type Output Type Total I/O 12/24V DC DC input Relay output 8 (4 in/4 Out) 8 (4 in/4 Out) FL1B-M08B2R2 FL1D Base Modules – With LCD Part Number Rated Voltage FL1D-H12RCE Input Signal 12/24V DC DC FL1D-H12SND 24V DC I7 and I8 are used for digital/analog FL1D-H12RCA 24V AC/DC FL1D-H12RCC 100-240V AC/DC FL1B-M08B1S2 Input Type PNP Output Type Yes Transistor Source Output — Relay Output Yes PNP DC input Transistor Output AC/DC input Relay Output 8 (4 in/4 Out) 24V AC/DC AC/DC input Relay Output 8 (4 in/4 Out) Analog Input Module 12/24V DC 0-10V, 4-20mA — 2 (2 in/0 Out) Analog Output Module 24V DC — 0-10V 2 (0 in/2 Out) FL1B-M08D2R2 FL1B-J2B2 PNP/NPN AC/DC With Clock Relay Output 24V DC 100-240V AC/DC Combination I/O Module FL1B-M08C2R2 * New FL1D-K2B2 LONWORKS® Communication Module $ FM 64 R • LONWORKS® Communication module contains standard network variable type (SNVT) to achieve open network communication for building automation • Maximum virtual inputs/analog inputs/outputs: 16/8/12 points • An external interface file (XIF extension) unique to each LONWORKS® module is needed to communicate through the LONWORKS® network and can be downloaded at www.idec.com/smartrelay • See page 11 for more details APPROVED Part Number FL1B-CL1C12 FL1D Base Modules – Without LCD Part Number Rated Voltage Input Signal Module Input Power Total I/O LONWORKS® Communication Module 24V AC/DC Input: 16 points Analog Input: 8 points Output: 12 points *LoNWORKS® is a registered trademark of Echelon Input Type Output Type With Clock PNP Relay Output Yes Relay Output Yes DC FL1D-B12RCE 12/24V DC FL1D-B12RCA 24V AC/DC FL1D-B12RCC 100-240V AC/DC I7 and I8 are used for digital/analog PNP/NPN AC/DC PNP AS-Interface Communication Module • The AS-Interface communication module provides optimum solutions for decentralized controls and savings in installation space and wiring • Virtual I/O points: 4 inputs, 4 outputs • See page 11 for more details Part Number Module FL1B-CAS2 Random Generator Frequency Trigger Analog Trigger Analog Comparator Stairwell Light Switch Softkey Message Text Dual-Function Switch Trg A/1 0 Fre G-T Q Q TH T Starts TL TH fa=5Hz fa=3Hz 1s 1s TL 1000 SW SW 1000 Q A/1-A/2 0 1000 200 A/1 or 0 A/2 Trg Q A/2 0 In Trg Q Dir EN TL Q 15s S1 S2 S3 S4 S5 S6 S7 S8 Switch TIL T1 T T 1s T Starts Q -200 TL Q tor =200 8 En Inv Par Q En Par Q Fre Par Q Ax Par Q Shift Register Analog Amplifier 1000 Trg 30V DC * New Q EN Inv Q Total I/O Input: 4 points Output: 4 points AS-Interface Communication Module Special Function Blocks (Cont.) Asynchronous Pulse Generator Input Power 0 0 0 0 1 1 0 0 1 0 0 0 0 1 1 0 0 1 0 0 0 0 1 1 1 0 1 0 0 0 0 1 Shift Up Ax Ay Par Q Trg Par Q Trg R Par Q En P Par Q En Par Q Ax Par Q 1 1 0 1 0 0 0 0 0 1 1 0 1 0 0 0 1 1 0 1 0 0 0 1 PI Controller * New * New Analog Ramp Control Analog Multiplexer S4=Q (Example) Shift Down In Trg Dir Par Q 9 Modules that expand the possibilities www.idec.com/smartrelay I/O Expansion Modules Part Number Module Input Power Input Type Output Type Total I/O 12/24V DC DC input Relay output 8 (4 in/4 Out) 8 (4 in/4 Out) FL1B-M08B2R2 FL1D Base Modules – With LCD Part Number Rated Voltage FL1D-H12RCE Input Signal 12/24V DC DC FL1D-H12SND 24V DC I7 and I8 are used for digital/analog FL1D-H12RCA 24V AC/DC FL1D-H12RCC 100-240V AC/DC FL1B-M08B1S2 Input Type PNP Output Type Yes Transistor Source Output — Relay Output Yes PNP DC input Transistor Output AC/DC input Relay Output 8 (4 in/4 Out) 24V AC/DC AC/DC input Relay Output 8 (4 in/4 Out) Analog Input Module 12/24V DC 0-10V, 4-20mA — 2 (2 in/0 Out) Analog Output Module 24V DC — 0-10V 2 (0 in/2 Out) FL1B-M08D2R2 FL1B-J2B2 PNP/NPN AC/DC With Clock Relay Output 24V DC 100-240V AC/DC Combination I/O Module FL1B-M08C2R2 * New FL1D-K2B2 LONWORKS® Communication Module $ FM 64 R • LONWORKS® Communication module contains standard network variable type (SNVT) to achieve open network communication for building automation • Maximum virtual inputs/analog inputs/outputs: 16/8/12 points • An external interface file (XIF extension) unique to each LONWORKS® module is needed to communicate through the LONWORKS® network and can be downloaded at www.idec.com/smartrelay • See page 11 for more details APPROVED Part Number FL1B-CL1C12 FL1D Base Modules – Without LCD Part Number Rated Voltage Input Signal Module Input Power Total I/O LONWORKS® Communication Module 24V AC/DC Input: 16 points Analog Input: 8 points Output: 12 points *LoNWORKS® is a registered trademark of Echelon Input Type Output Type With Clock PNP Relay Output Yes Relay Output Yes DC FL1D-B12RCE 12/24V DC FL1D-B12RCA 24V AC/DC FL1D-B12RCC 100-240V AC/DC I7 and I8 are used for digital/analog PNP/NPN AC/DC PNP AS-Interface Communication Module • The AS-Interface communication module provides optimum solutions for decentralized controls and savings in installation space and wiring • Virtual I/O points: 4 inputs, 4 outputs • See page 11 for more details Part Number Module FL1B-CAS2 Random Generator Frequency Trigger Analog Trigger Analog Comparator Stairwell Light Switch Softkey Message Text Dual-Function Switch Trg A/1 0 Fre G-T Q Q TH T Starts TL TH fa=5Hz fa=3Hz 1s 1s TL 1000 SW SW 1000 Q A/1-A/2 0 1000 200 A/1 or 0 A/2 Trg Q A/2 0 In Trg Q Dir EN TL Q 15s S1 S2 S3 S4 S5 S6 S7 S8 Switch TIL T1 T T 1s T Starts Q -200 TL Q tor =200 8 En Inv Par Q En Par Q Fre Par Q Ax Par Q Shift Register Analog Amplifier 1000 Trg 30V DC * New Q EN Inv Q Total I/O Input: 4 points Output: 4 points AS-Interface Communication Module Special Function Blocks (Cont.) Asynchronous Pulse Generator Input Power 0 0 0 0 1 1 0 0 1 0 0 0 0 1 1 0 0 1 0 0 0 0 1 1 1 0 1 0 0 0 0 1 Shift Up Ax Ay Par Q Trg Par Q Trg R Par Q En P Par Q En Par Q Ax Par Q 1 1 0 1 0 0 0 0 0 1 1 0 1 0 0 0 1 1 0 1 0 0 0 1 PI Controller * New * New Analog Ramp Control Analog Multiplexer S4=Q (Example) Shift Down In Trg Dir Par Q 9 AS-Interface Communication Module FL1B-CAS2 SX5A AS-Interface Gateway MicroSmart AS-Interface Master Module Branch Connector PS2R AS-Interface Power Supply SX5A Safety Monitor Starter Kit SX5A IP20 Communication Terminal AS-Interface Communication Module • IDEC SmartRelay Starter Kit is an economical and ideal solution for first time IDEC SmartRelay users • Package includes a base module, WindLGC programming software, programming cable, simulator switch (DC models only) and a user’s manual www.idec.com/smartrelay Open Network (CC-Link, DeviceNet) Sensor (AS-Interface Direct Connection Type) SX5A IP67 Communication Terminal Light Curtain Manifold Solenoid Value Light Tower Sensor Part Number Description Emergency Stop Switch HW tL6 tMCM Series SwitchNet™ Control Units (AS-Interface Direct Connection Type) SMARTSTART-BAC-D FL1D-B12RCC, WindLGC software and programming cable SMARTSTART-BDC-D FL1D-B12RCE, WindLGC software, programming cable, and simulator switch SMARTSTART-HAC-D FL1D-H12RCC, WindLGC software and programming cable Module Combination and Allocation Numbers SMARTSTART-HDC-D FL1D-H12RCE, WindLGC software, programming cable, and simulator switch Using expansion I/O modules I AI Q 1 1 1 2 2 2 3 AS-Interface Safety at work FL1B-MO8B2R2 FL1D-H12RCE Digital Input: Analog Input: Digital Output: 4 5 6 7 8 9 FL1B-CAS2 10 11 12 3 3 4 5 6 7 The AS-Interface communication module provides the optimum solution for savings in cables, installation space, and wiring costs, and offers the possibility of decentralized control. 13 14 15 16 Base module Analog input module 9 Combination I/O module AS-interface communication module 4 8 10 11 12 FL1B-J2B2 Accessories Part Number FL1C-PM3 User’s Manual FL9Y-B966-0 LONWORKS Communication Module FL1B-CL1C12 Description Memory cartridge, with user defined protection freature FL9Y-LP1CDW Programming Software: WindLGC Ver. 5CD w/Online Manual FL1A-PC1 Programming Cable BNDN1000 35mm Aluminum DIN Rail, 1m/3.28ft BNL6 End Clips, Prevents modules from sliding off DIN Rail MT-101 Memory Cartridge Removal Tool FL1B-PSP1 Mounts Module Directly to Panel FL1B-Y1371-SW8 8pt Input Simulator Switch, Used with 12, 24V DC Base Module Only FL9Y-B966-0 FL1D User's Manual, Available for download at: www.idec.com/smartrelay FC4A-USB USB to RS232 Converter, For use with "USB Only" PC's WindLGC 5.0 Software Memory Cartridge FL9Y-LP1CDW FL1C-PM3 Combination of easy-to-program IDEC SmartRelay and LONWORKS communicaton module achieves remote control and monitoring on a LONWORKS network. Simulator Switch Programming Cable FL1B-Y1371-SW8 FL1A-PC1 Module Combination and Allocation Numbers 1. Maximum number of I/O points when using LONWORKS communication module FL1B-CL1C12 FL1D-H12RCC Base Module Dimensions N - I1 I2 I3 I4 I5 I6 I7 I/O Expansion Module Dimensions Digital Input: Analog Input: Digital Output: I AI Q 1 2 3 4 1 2 3 4 5 6 7 8 9 1 5 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 2 3 4 5 6 7 8 6 7 8 9 10 11 12 13 14 15 16 Base module Combination I/O module I8 2. Using analog inputs on the base module  90 90  Digital Input: Analog Input: Digital Output: I AI Q 1 1 1 2 2 2 3 4 3 4 LONWORKS communication module FL1B-CL1C12 FL1D-H12RCE 5 6 7 8 9 3 5 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 4 5 6 7 8 6 7 8 9 10 11 12 13 14 15 16 Analog input module Analog output module 3. Using I/O expansion module Q1 Q2 Q3 Q4   10 60 All dimensions in mm. Detailed CAD drawings are available on our website at: www.idec.com/smartrelay. 58 I AI AI Q 1 1 2 2 3 1 2 3 4 FL1B-CL1C12 FL1B-MO8B2R2 FL1D-H12RCE Digital Input: Analog Input: Analog Output: Digital Output: 5 6 7 8 9 10 11 12 3 13 14 15 16 17 18 19 20 21 22 23 24 5 6 7 8 4 1 4 5 6 7 8 2 9 10 11 12 13 14 15 16 FL1B-J2B2 FL1D-K2B2 Note 1: One LONWORKS communication module can be used with a base module and must be mounted at the right-most position of the row. Note 2: I/O numbers are automatically allocated starting with the base module. Note 3: When the base module with analog inputs is used, l1 to l8, Al1, and Al2 are occupied whether the analog inputs are used or not. LonMark, LONWORKS, LON, Lon Builder, Neuron, 3120, 3150, and Echelon are registered trademarks of Echelon, USA. 11 AS-Interface Communication Module FL1B-CAS2 SX5A AS-Interface Gateway MicroSmart AS-Interface Master Module Branch Connector PS2R AS-Interface Power Supply SX5A Safety Monitor Starter Kit SX5A IP20 Communication Terminal AS-Interface Communication Module • IDEC SmartRelay Starter Kit is an economical and ideal solution for first time IDEC SmartRelay users • Package includes a base module, WindLGC programming software, programming cable, simulator switch (DC models only) and a user’s manual www.idec.com/smartrelay Open Network (CC-Link, DeviceNet) Sensor (AS-Interface Direct Connection Type) SX5A IP67 Communication Terminal Light Curtain Manifold Solenoid Value Light Tower Sensor Part Number Description Emergency Stop Switch HW tL6 tMCM Series SwitchNet™ Control Units (AS-Interface Direct Connection Type) SMARTSTART-BAC-D FL1D-B12RCC, WindLGC software and programming cable SMARTSTART-BDC-D FL1D-B12RCE, WindLGC software, programming cable, and simulator switch SMARTSTART-HAC-D FL1D-H12RCC, WindLGC software and programming cable Module Combination and Allocation Numbers SMARTSTART-HDC-D FL1D-H12RCE, WindLGC software, programming cable, and simulator switch Using expansion I/O modules I AI Q 1 1 1 2 2 2 3 AS-Interface Safety at work FL1B-MO8B2R2 FL1D-H12RCE Digital Input: Analog Input: Digital Output: 4 5 6 7 8 9 FL1B-CAS2 10 11 12 3 3 4 5 6 7 The AS-Interface communication module provides the optimum solution for savings in cables, installation space, and wiring costs, and offers the possibility of decentralized control. 13 14 15 16 Base module Analog input module 9 Combination I/O module AS-interface communication module 4 8 10 11 12 FL1B-J2B2 Accessories Part Number FL1C-PM3 User’s Manual FL9Y-B966-0 LONWORKS Communication Module FL1B-CL1C12 Description Memory cartridge, with user defined protection freature FL9Y-LP1CDW Programming Software: WindLGC Ver. 5CD w/Online Manual FL1A-PC1 Programming Cable BNDN1000 35mm Aluminum DIN Rail, 1m/3.28ft BNL6 End Clips, Prevents modules from sliding off DIN Rail MT-101 Memory Cartridge Removal Tool FL1B-PSP1 Mounts Module Directly to Panel FL1B-Y1371-SW8 8pt Input Simulator Switch, Used with 12, 24V DC Base Module Only FL9Y-B966-0 FL1D User's Manual, Available for download at: www.idec.com/smartrelay FC4A-USB USB to RS232 Converter, For use with "USB Only" PC's WindLGC 5.0 Software Memory Cartridge FL9Y-LP1CDW FL1C-PM3 Combination of easy-to-program IDEC SmartRelay and LONWORKS communicaton module achieves remote control and monitoring on a LONWORKS network. Simulator Switch Programming Cable FL1B-Y1371-SW8 FL1A-PC1 Module Combination and Allocation Numbers 1. Maximum number of I/O points when using LONWORKS communication module FL1B-CL1C12 FL1D-H12RCC Base Module Dimensions N - I1 I2 I3 I4 I5 I6 I7 I/O Expansion Module Dimensions Digital Input: Analog Input: Digital Output: I AI Q 1 2 3 4 1 2 3 4 5 6 7 8 9 1 5 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 2 3 4 5 6 7 8 6 7 8 9 10 11 12 13 14 15 16 Base module Combination I/O module I8 2. Using analog inputs on the base module  90 90  Digital Input: Analog Input: Digital Output: I AI Q 1 1 1 2 2 2 3 4 3 4 LONWORKS communication module FL1B-CL1C12 FL1D-H12RCE 5 6 7 8 9 3 5 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 4 5 6 7 8 6 7 8 9 10 11 12 13 14 15 16 Analog input module Analog output module 3. Using I/O expansion module Q1 Q2 Q3 Q4   10 60 All dimensions in mm. Detailed CAD drawings are available on our website at: www.idec.com/smartrelay. 58 I AI AI Q 1 1 2 2 3 1 2 3 4 FL1B-CL1C12 FL1B-MO8B2R2 FL1D-H12RCE Digital Input: Analog Input: Analog Output: Digital Output: 5 6 7 8 9 10 11 12 3 13 14 15 16 17 18 19 20 21 22 23 24 5 6 7 8 4 1 4 5 6 7 8 2 9 10 11 12 13 14 15 16 FL1B-J2B2 FL1D-K2B2 Note 1: One LONWORKS communication module can be used with a base module and must be mounted at the right-most position of the row. Note 2: I/O numbers are automatically allocated starting with the base module. Note 3: When the base module with analog inputs is used, l1 to l8, Al1, and Al2 are occupied whether the analog inputs are used or not. LonMark, LONWORKS, LON, Lon Builder, Neuron, 3120, 3150, and Echelon are registered trademarks of Echelon, USA. 11 Think Automation and beyond... PS5R Slim Line Power Supplies SA1E Sensors IDEC PS5R Slim Line power supplies have all the features, all the power, and only half the size of traditional power supplies. Save valuable DIN Rail space with the 30W, 60W, 90W, 120W, or 240W models which can fit any of your power needs. The PS5R Slim Line models are UL508 and UL1604 listed for hazardous locations. The 30W and 60W models are also NEC Class 2 rated. The 120W and 240W models comply with SEMI F47 sag immunity requirements. Choose your sensing method, operation mode, control output and connection method with the simple and affordable SA1E sensors, and get exactly what you need in a very small package. There are 32 models available, all rated IP67 for water resistance, with a response time of 1 msec (maximum). Special interference prevention allows close mounting of two sensors (except for through-beam type), and the quick connect and disconnect option make installation a breeze. Support Information HW Switches IDEC SmartRelay www.idec.com/smartrelay In basic black or stylish metal, the HW series of 22mm switches from IDEC are available in several styles to dress up any panel. HW pushbuttons and pilot devices are internationally-rated, designed for use almost anywhere in the world, and have removable contact blocks, finger-safe terminals, and tamperproof construction. Choose simple black plastic bezels for clean uniformity or chrome-plated metallic bezels for a rugged industrial look. Technical support: support@idec.com 800-262-IDEC www.idec.com * New Advanc ed Featu Think Automation and beyond... www.idec.com USA Japan Germany China/Beijing China/Shenzhen IDEC Corporation Tel: (408) 747-0550 opencontact@idec.com IDEC Corporation Tel: +81-6-6398-2571 products@idec.co.jp IDEC Elektrotechnik GmbH Tel: +49-40-253054-10 service@idec.de IDEC (Shanghai) Corporation Tel: +86-10-6599-5541 IDEC (Shenzhen) Corporation Tel: +86-755-8356-2977 Canada United Kingdom Hong Kong China/Shanghai Singapore IDEC Canada Ltd. Tel: (905) 890-8561 sales@idec.com IDEC Electronics Ltd. Tel: +44-1256-321000 idec@uk.idec.com IDEC (H.K.) Co., Ltd. Tel: +852-2803-8989 info@hk.idec.com IDEC (Shanghai) Corporation Tel: +86-21-5353-1000 idec@cn.idec.com IDEC Asia Pte. Ltd. Tel: +65-6746-1155 info@sg.idec.com Australia IDEC Australia Pty. Ltd. Tel: +61-3-9763-3244 sales@au.idec.com Taiwan ©2006 IDEC Corporation. All Rights Reserved. Catalog No. FL9Y-B100-0 2/06 15K Specifications and other descriptions in this catalog are subject to change without notice. IDEC Taiwan Corporation Tel: +886-2-2698-3929 service@idectwn.com.tw IDEC SmartRelay res
FL9Y-LP1CDW 价格&库存
很抱歉,暂时无法提供与“FL9Y-LP1CDW”相匹配的价格&库存,您可以联系我们找货
FL9Y-LP1CDW
    • 1+885.661551+115.16039
    • 10+801.9702710+104.27822
    • 25+770.8914025+100.23711
    • 50+748.1823050+97.28431
    • 100+726.13151100+94.41710
    库存:4
