HS6E-N7Y4B03-G
HS6E-N7Y4B03-G
    IDEC(日本和泉)
HS6E-N7Y4B03-G 数据手册
HS6E Subminiature Interlock Switches with Solenoid HS6B Subminiature Interlock Switches (07/03/12) 5-pole Subminiature Interlock Switches Thinnest Body in Its Class 15 75 dy Bo Thin 75 Actual Size (mm) Energy saving 276 mA 40% Space saving design with angled connection cable HS6E rox. pared witehls) d (com ous mo i prev led Ang nection con le cab M 30 inimu mm m Ra diu s 110 mA Mi 30 nimu mm m R a diu s App HS5E HS6E Miniature Interlock Switch with Solenoid Subminiature Interlock Switch with Solenoid Power Consumption by Solenoid + Indicator 2 Space Saving (Approx. 30 mm) RoHS directive compliant (2002/95/EC) The HS6E series subminiature interlock switches with solenoid do not contain lead, cadmium, mercury, hexavalent chromium, PBB, or PBDE. (07/03/12) Virtually Limitless Mounting Options Sliding Doors Top Mounting HS6E Top Mounting Actuator Left-opening Right-opening Front Mounting Left-opening Front Mounting Right-opening Hinged Doors Top Mounting Left-opening Right-opening Side Mounting Up-opening (07/03/12) Side Mounting Left-opening Right-opening Bottom Mounting Up-opening 3 Manual Unlocking Possible from Three Directions The actuator can be unlocked manually with manual unlocks on either sides of the switch body, or by depressing a plate. For details, see page 14. When unlocking with manual unlocks Make a key access hole in the wall for manual unlocking. Manual Unlocking Key When the switch is installed inside a machine, the actuator can be unlocked with the manual unlocking key by making a key access hole in the wall. Optically enhanced lens provides for wide viewing angle for power indicator. Wide viewing angle (approx. 120°) Solenoid Power Indicator (Green LED) Mounting Surface 4 (07/03/12) Features - HS6E and HS6B Subminiature Interlock Switches • HS6E: with solenoid, HS6B: without solenoid • Common mounting holes - HS6E and HS6B • Common actuators - HS6E and HS6B Dimensions HS6B (without solenoid) HS6E (with solenoid) 15 75 30 15 75 78 Mounting Hole Layout • Add one additional hole in the mounting panel for the HS6B, then the HS6E can be installed on the same panel. 30 50.8 HS6B (without solenoid) 50.8 HS6E (with solenoid) HS6E 28.5 1 20 1 1 20 1 All dimensions in mm. Common Actuators • The same actuators can be used on the HS6E and HS6B. Vertical/Horizontal Angle Adjustable HS6E HS6B (07/03/12) HS9Z-A65 HS9Z-A66 HS9Z-A61 Straight HS9Z-A62 Right-angle HS9Z-A62S Right-angle with Plate 5 HS6E Subminiature Interlock Switches with Solenoid Small interlock switch with five poles and solenoid. Ideal for applications in tight spaces. • Compact body: 75 × 15 × 75 mm 15-mm-wide, thinnest solenoid type interlock switch in the world. • Reversible mounting and angled cable allow four actuator insertion directions. • Energy saving. 24V DC, 110 mA (solenoid: 100 mA, LED: 10 mA) • Manual unlocking possible on three sides. • RoHS compliant • LED indicator shows solenoid operation • Horizontal/Vertical Angle Adjustable Actuators • Straight Actuator (SUS304) Spring Lock Type • Automatically locks the actuator without power applied to the solenoid. • After the machine stops, unlocking is completed by the solenoid. • Manual unlocking is possible on three sides in the event of power failure or maintenance. • Right-angle Actuator (SUS304) Solenoid Lock Type • The actuator is locked when energized. • The actuator is unlocked when de-energized. • Flexible locking function can be achieved, for an application where locking is not required and sudden stopping of a machine must be prevented. Ratings • Contact Ratings Rated Insulation Voltage (Ui) (Note 1) 300V (door monitor contact) 150V (lock monitor contact) 30V (between LED or solenoid and ground) Rated Thermal Current (Ith) Operating temperature –25 to 35°C 2.5A (up to 2 circuits) 1.0A (3 or more circuits) Operating temperature 35 to 50°C 1.0A (1 circuit) 0.5A (2 or more circuits) Main & Lock Monitor Circuits Door Monitor Circuit Rated Current (Ie) ∗ Rated Voltage (Ue) Specifications Applicable Standards UL 508 (UL listed) CSA C22.2, No. 14 (c-UL listed) ISO 14119 IEC 60947-5-1 EN 60947-5-1 (TÜV approval) EN 1088 (TÜV approval) GS-ET-19 IEC 60204-1/EN 60204-1 (applicable standards for use) Operating Temperature –25 to +50°C (no freezing) Relative Humidity 45 to 85% (no condensation) 30V 125V 250V Resistive load (AC-12) — 2A — Inductive Load (AC-15) — 1A — Storage Temperature –40 to +80°C (no freezing) Resistive load (DC-12) 2A 0.4A — Pollution Degree 3 Inductive Load (DC-13) 1A 0.22A — Impulse Withstand Voltage Main & lock monitor circuits: 1.5 KV Door monitor circuit: 2.5 kV Between solenoid/LED and ground: 0.5 kV AC DC Resistive load (AC-12) — 2.5A 1.5A Inductive Load (AC-15) — 1.5A 0.75A Resistive load (DC-12) 2.5A 1.1A 0.55A Inductive Load (DC-13) 2.3A 0.55A 0.27A AC DC • Minimum applicable load (reference value): 3V AC/DC, 5 mA • UL rating Main/Lock Monitor: 125V AC, 1A Pilot duty 125V DC, 0.22A Pilot duty Door Monitor: 240V AC, 0.75A Pilot duty 250V DC, 0.27A Pilot duty • TÜV rating Main & lock monitor circuit: AC-15 125V/1A, DC-13 125V/0.22A Door monitor circuit: AC-15 240V/0.75A, DC-13 250V/0.27A • Solenoid/Indicator Locking Mechanism Spring Lock Type Solenoid Lock Type Insulation Resistance Between live and dead metal parts: 100 MΩ minimum (500V DC megger) Between terminals of different poles: 100 MΩ minimum Contact Resistance 300 mΩ maximum (initial value, 1m cable) 500 mΩ maximum (initial value, 3m cable) 700 mΩ maximum (initial value, 5m cable) Electric Shock Protection Class II (IEC 61140) Degree of Protection IP67 (IEC 60529) Shock Resistance Operating extremes: 100 m/s2 (10G) Damage limits: 1000 m/s2 (100G) Vibration Resistance Operating extremes: 10 to 55 Hz, amplitude 0.35 mm Damage limits: 30 Hz, amplitude 1.5 mm Actuator Operating Speed 0.05 to 1.0 m/s Direct Opening Travel 8.0 mm minimum 24V DC Direct Opening Force 60N minimum Rated Current 110 mA (solenoid 100 mA, LED 10 mA) (initial value) Actuator Retention Force 500N minimum (GS-ET-19) Coil Resistance 240Ω (at 20°C) Operating Frequency 900 operations/h Pickup Voltage Rated voltage × 85% maximum (at 20°C) 1,000,000 operations minimum (GS-ET-19) Dropout Voltage Rated voltage × 10% minimum (at 20°C) Mechanical Durability Maximum Continuous Applicable Voltage Rated voltage × 110% Electrical Durability 100,000 operations minimum (rated load) 1,000,000 operations minimum (24V AC/DC, 100 mA) (operating frequency 900 operations/h) Maximum Continuous Applicable Time Continuous Conditional Short-circuit Current 50A (250V) (Use 250V/10A fast-blow fuse for short-circuit protection.) Cable UL2464, No. 22 AWG (12-core: 0.3 mm2 or equivalent/core) Cable Diameter ø7.6 mm Weight (approx.) 200g (HS6E-∗∗∗01) Indicator Solenoid Rated Voltage 6 Insulation Class Class F Light Source LED Illumination Color Green (07/03/12) HS6E Subminiature Interlock Switches with Solenoid Types • Subminiature Interlock Switch Lock Mechanism Circuit Number Contact Arrangement Cable Length (When inserted) (When OFF) (+) A2 L 11 21 31 12 22 32 41 53 42 54 Main Circuit: 1NC+1NC, Monitor Circuit: 2NC/1NC M Spring Lock Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 31 12 22 32 41 51 42 52 Main Circuit: 1NC+1NC, Monitor Circuit: 1NC, 1NO/1NO N Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 33 12 22 34 41 53 42 54 Main Circuit: 1NC+1NC, Monitor Circuit: 1NC, 1NO/1NC P Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 33 12 22 34 41 51 42 52 (When inserted) (When ON) (+) A2 L 11 21 31 12 22 32 41 53 42 54 Main Circuit: 1NC+1NC, Monitor Circuit: 2NC/1NC M Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 31 12 22 32 41 51 42 52 Solenoid Lock Main Circuit: 1NC+1NC, Monitor Circuit: 1NC, 1NO/1NO N Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 33 12 22 34 41 53 42 54 Main Circuit: 1NC+1NC, Monitor Circuit: 1NC, 1NO/1NC P Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 33 12 22 34 41 51 HS6E-L44B01-G 3m HS6E-L44B03-G 5m HS6E-L44B05-G 1m HS6E-M44B01-G 3m HS6E-M44B03-G 5m HS6E-M44B05-G 1m HS6E-N44B01-G 3m HS6E-N44B03-G 5m HS6E-N44B05-G 1m HS6E-P44B01-G 3m HS6E-P44B03-G 5m HS6E-P44B05-G 1m HS6E-L7Y4B01-G 3m HS6E-L7Y4B03-G 5m HS6E-L7Y4B05-G 1m HS6E-M7Y4B01-G 3m HS6E-M7Y4B03-G 5m HS6E-M7Y4B05-G 1m HS6E-N7Y4B01-G 3m HS6E-N7Y4B03-G 5m HS6E-N7Y4B05-G 1m HS6E-P7Y4B01-G 3m HS6E-P7Y4B03-G 5m HS6E-P7Y4B05-G (–) A1 Main Circuit: 1NC+1NC, Monitor Circuit: 2NC/1NO Main Circuit: Monitor Circuit: Monitor Circuit: 1m (–) A1 Main Circuit: 1NC+1NC, Monitor Circuit: 2NC/1NO Main Circuit: Monitor Circuit: Monitor Circuit: Type No. 42 52 • The contact arrangements show the contact status when the actuator is inserted and locked. • LED color is G (green) only. • Actuators are not supplied with the interlock switch and must be ordered separately. (07/03/12) 7 HS6E Subminiature Interlock Switches with Solenoid • Actuator Appearance Straight Actuator Ordering Type No. Remarks HS9Z-A61 The tensile strength of HS9Z-A61 actuator is 500N maximum. Do no apply excessive load, otherwise the actuator may fall off the door. HS9Z-A62 The tensile strength of HS9Z-A62 actuator is 100N maximum. Do no apply excessive load, otherwise the actuator may fall off the door. When tensile strength of 100N or more is required, use the HS9Z-A62S actuator. HS9Z-A62S The tensile strength of HS9Z-A62S actuator is 500N maximum. Do no apply excessive load, otherwise the actuator may fall off the door. Right-angle Actuator Right-angle Actuator with Mounting Plate Angle Adjustable Actuator HS9Z-A65 Angle Adjustable Actuator HS9Z-A66 The HS9Z-A65 and HS9Z-A66 have the metal key installed in opposite directions. Select actuator by determining the required moving direction in consideration of the door and interlock switch. See pages 10, 13, and 14. The tensile strength of HS9Z-A65 and HS9Z-A66 actuators is 500N maximum. Type No. Development H S 6 E - L 4 4 B 05 - G Circuit Code Main Circuit L: M: N: P: 1NC+1NC 1NC+1NC 1NC+1NC 1NC+1NC Door Monitor Circuit 2NC 2NC 1NC, 1NO 1NC, 1NO Lock Monitor Circuit 1NO 1NC 1NO 1NC Solenoid Unit Voltage/Lock Mechanism 4: 24V DC/Spring Lock 7Y: 24V DC/Solenoid Lock 8 LED Color G: green Cable Length 01: 1m 03: 3m 05: 5m Housing Color B: Black Pilot Light Voltage 4: 24V DC (07/03/12) HS6E Subminiature Interlock Switches with Solenoid Dimensions • Interlock Switch • Mounting Hole Layout 5.5 3-M4 Screw (ø4.3 or M4 tapped hole) Hole for Manual Unlocking ø12 (reference) 20.5 4 30 15 4 10.4 10.1 15 37 46.1 41.8 ø4 .4 (22.5) 28.5 (22.5) 41.8 20.5 35 30 28.5 20 to 22 75 Manual Unlocking Key 4 Hole for Manual Unlocking ø12 (reference) 3-M4 Screw (ø4.3 or M4 tapped hole) 12 20 1 20.5 1 30 C (2 .3 ) .1 R2 4 28.5 41.8 20 to 22 When using straight actuator (HS9Z-A61) (12.6±1) When using right-angle actuator (HS9Z-A62S) When using horizontal/vertical angle adjustable actuator (HS9Z-A65/A66) (14) (5) (25) Actuator Stop (supplied) 48.8 0.8 0.8 Actuator Stop (supplied) (42) (Note) (14) 50.8 0.8 22.6 ±1 (6.2) 22.6 ±1 Actuator Stop (supplied) Note: 41.4 when using HS9Z-A62. The tensile strength of the HS9Z-A62 actuator is 100N. When tensile force exceeding 100N is expected, use the HS9Z-A62S actuator, which has a mounting plate. • Actuator Mounting Reference Position Interlock Switch Door Stop Actuator Stop 0.8 As shown in the figure on the right, the mounting reference position of the actuator when inserted in the interlock switch is: The actuator stop on the actuator lightly touches the interlock switch. Note: After mounting the actuator, remove the actuator stop from the actuator. Door Stop HS9Z-A61 Actuator (07/03/12) 9 HS6E Subminiature Interlock Switches with Solenoid Actuator Dimensions Straight Actuator (HS9Z-A61) 43.2 20.9 Right-angle Actuator (HS9Z-A62S) Right-angle Actuator (HS9Z-A62) The tensile strength of the HS9Z-A62 actuator is 100N. When tensile force exceeding 100N is expected, use the HS9Z-A62S actuator. Note: See page 15 for actuator installation. When mounted (33.8) (15.8) When mounted (6.2) .3 When mounted (33.8) 14 When mounted (5.6) When mounted (5) 0.8 8.4 0.8 0.8 8.4 15 8.4 ø4 2- 14 When mounted (6.2) 2-ø 13.1 1.2 Rubber Bushing 3.5 1.2 13.1 Rubber Bushing 3.5 14 4.2 34 2-ø9 14 Rubber Bushing 2-ø4 .3 14 Note 1 Actuator Stop (supplied) 14 Mounting Plate (supplied) 41.1 When mounted (5) 2-ø9 ø2-9 3.5 10.4 1.2 When mounted (10.2) (Note) Actuator Stop (supplied) (Note) Actuator Stop (supplied) Note: The actuator stop is used to adjust the actuator position. Remove the actuator stop after the actuator position is mounted. Angle Adjustable Actuator (HS9Z-A65) Angle Adjustable Actuator (HS9Z-A66) Actuator Adjustment Orientation Horizontal Adjustment The HS9Z-A65 and HS9Z-A66 have the metal key inserted in opposite directions. The orientation of actuator adjustment (horizontal/vertical) can be changed using the orienting insert (white plastic) installed on the back of the actuator. 0.8 3.5 Orienting Insert 1.2 Orienting Insert Horizontal Adjustment Angle Adjustment (M3 Hexagon Socket Head Screw) 20° 20° Horizontal Adjustment Vertical Adjustment Angle Adjustment (M3 Hexagon Socket Head Screw) 13 Vertical Adjustment 28.2 Angle Adjustment (M3 Hexagon Socket Head Screw) 2 7.5 5.5 Orienting Insert 16.8 Vertical Adjustment (Note 1) Actuator Stop (Supplied) 2.5 20° 34 25 20° 15 (Note) Actuator Stop (supplied) Angle Adjustment (M3 Hexagon Socket Head Screw) (M R2.1 4H ole s) Note: The base is made of glass-reinforced PA66 (66 nylon). Angle adjustment screws are stainless steel. When using adhesive on screws, take material compatibility into consideration. Actuator Mounting Hole Layout (horizontal/vertical swing) 25 2-M4 Screw (ø4.3 or M4 tapping screw) Accessory Ordering Type No. HS9Z-T3 Manual Unlock Key (supplied) (plastic) Manual Unlock Key (long type) (metal) 18 6.5 ø4 15 (24) 15 9 ø10 3 Description Manual Unlock Key (long type) 130 4 (24.5) All dimensions in mm. 10 (07/03/12) HS6E Subminiature Interlock Switches with Solenoid Circuit Diagrams and Operating Characteristics • Spring Lock Type Status 1 Status 2 • Door closed • Machine ready to operate • Solenoid de-energized Interlock Switch Status Status 3 Status 4 • Door closed • Door open • Door open • Machine cannot be • Machine cannot be • Machine cannot be operated operated operated • Solenoid • Solenoid • Solenoid energized energized de-energized Unlocking using Manual Unlock Key • Door closed • Machine cannot be operated • Solenoid de-energized Door Status UNLOCK LOCK Manually Unlocked (+) A2 Circuit Diagram (Example: HS6E-N4) Door HS6E-L4 Door Lock Monitor Monitor (+) A2 Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 31 12 41 22 53 32 (–) A1 42 54 Type No. and Circuit Diagram HS6E-M4 Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 31 12 41 22 51 32 42 52 HS6E-N4 Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 33 12 41 22 53 34 42 54 HS6E-P4 Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 33 12 41 22 51 34 42 52 (–) A1 (+) A2 (–) A1 (+) A2 (+) A2 (–) A1 (–) A1 11 12 41 42 11 12 41 42 11 12 41 42 11 12 41 42 21 22 53 54 21 22 53 54 21 22 53 54 21 22 53 54 33 34 33 34 33 34 33 34 Closed (locked) Closed (unlocked) Open Open Closed (unlocked) Main Circuit 11-42 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) Door Monitor Circuit (door closed) 21-22 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Door Monitor Circuit (door closed) 31-32 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Lock Monitor Circuit (unlocked) 53-54 OFF (open) ON (closed) ON (closed) ON (closed) ON (closed) Main Circuit 11-42 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) Door Monitor Circuit (door closed) 21-22 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Door Monitor Circuit (door closed) 31-32 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Lock Monitor Circuit (locked) 51-52 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) Main Circuit 11-42 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) Door Monitor Circuit (door closed) 21-22 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Door Monitor Circuit (door open) 33-34 OFF (open) OFF (open) ON (closed) ON (closed) OFF (open) Lock Monitor Circuit (unlocked) 53-54 OFF (open) ON (closed) ON (closed) ON (closed) ON (closed) Main Circuit 11-42 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) Door Monitor Circuit (door closed) 21-22 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Door Monitor Circuit (door open) 33-34 OFF (open) OFF (open) ON (closed) ON (closed) OFF (open) Lock Monitor Circuit (locked) 51-52 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) OFF (de-energized) ON (energized) ON (energized) OFF (de-energized) OFF (de-energized) Solenoid Power A1-A2 (all types) Main circuit: Connected to the control circuit of machine drive part, sending the interlock signals of the protective door. Monitor circuit: Sends the monitoring signals of open/closed and lock/unlocked statuses of the protective door. Operation Characteristics (reference) 0 (Actuator Insertion Position) 1.1 (Locked Position) 4.7 5.0 27.4 (stroke in mm) Main Circuit Door Monitor Circuit (door open, NO) Door Monitor Circuit (door closed, NC) Lock Monitor Circuit (unlocked, NO) Lock Monitor Circuit (locked, NC) : Contacts ON (closed) : Contacts OFF (open) • The characteristics shown in the chart above are of the HS9Z-A61, -A62, -A65, and -A66 actuators. For HS9Z-A62S actuator, subtract 0.6 mm. • The characteristics show the contact status when the actuator enters an entry slot of an interlock switch. (07/03/12) 11 HS6E Subminiature Interlock Switches with Solenoid • Solenoid Lock Type Status 1 Status 2 • Door closed • Machine ready to operate • Solenoid energized Interlock Switch Status Status 3 Status 4 • Door closed • Door open • Door open • Machine cannot be • Machine cannot be • Machine cannot be operated operated operated • Solenoid • Solenoid • Solenoid de-energized de-energized energized Unlocking using Manual Unlock Key • Door closed • Machine cannot be operated • Solenoid de-energized Door Status UNLOCK LOCK Manually Unlocked (+) A2 Circuit Diagram (Example: HS6E-N7Y) Door HS6E-L7Y Door Lock Monitor Monitor (+) A2 Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 31 12 41 22 53 32 (–) A1 42 54 Type No. and Circuit Diagram HS6E-M7Y Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 31 12 41 22 51 32 42 52 HS6E-N7Y Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 33 12 41 22 53 34 42 54 HS6E-P7Y Main Circuit: Monitor Circuit: Monitor Circuit: 11 21 33 12 41 22 51 34 42 52 (+) A2 (–) A1 (–) A1 (+) A2 (+) A2 (–) A1 (–) A1 11 12 41 42 11 12 41 42 11 12 41 42 11 12 41 42 21 22 53 54 21 22 53 54 21 22 53 54 21 22 53 54 33 34 33 34 33 34 33 34 Closed (locked) Closed (unlocked) Open Open Closed (unlocked) Main Circuit 11-42 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) Door Monitor Circuit (door closed) 21-22 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Door Monitor Circuit (door closed) 31-32 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Lock Monitor Circuit (unlocked) 53-54 OFF (open) ON (closed) ON (closed) ON (closed) ON (closed) Main Circuit 11-42 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) Door Monitor Circuit (door closed) 21-22 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Door Monitor Circuit (door closed) 31-32 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Lock Monitor Circuit (locked) 51-52 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) Main Circuit 11-42 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) Door Monitor Circuit (door closed) 21-22 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Door Monitor Circuit (door open) 33-34 OFF (open) OFF (open) ON (closed) ON (closed) OFF (open) Lock Monitor Circuit (unlocked) 53-54 OFF (open) ON (closed) ON (closed) ON (closed) ON (closed) Main Circuit 11-42 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) Door Monitor Circuit (door closed) 21-22 ON (closed) ON (closed) OFF (open) OFF (open) ON (closed) Door Monitor Circuit (door open) 33-34 OFF (open) OFF (open) ON (closed) ON (closed) OFF (open) Lock Monitor Circuit (locked) 51-52 ON (closed) OFF (open) OFF (open) OFF (open) OFF (open) ON (energized) OFF (de-energized) OFF (de-energized) ON (energized) (Note 2) OFF (de-energized) to ON (re-energized) (Note 1) (Note 2) Solenoid Power A1-A2 (all types) Main circuit: Connected to the control circuit of machine drive part, sending the interlock signals of the protective door. Monitor circuit: Sends the monitoring signals of open/closed and lock/unlocked statuses of the protective door. Note 1: Do not attempt manual unlocking while the solenoid is energized. Note 2: Do not energize the solenoid for a long period of time while the door is open or while the door is unlocked manually using the manual unlock key. Operation Characteristics (reference) 0 (Actuator Insertion Position) 1.1 (Locked Position) 4.7 5.0 27.4 (stroke in mm) Main Circuit Door Monitor Circuit (door open, NO) Door Monitor Circuit (door closed, NC) Lock Monitor Circuit (unlocked, NO) Lock Monitor Circuit (locked, NC) : Contacts ON (closed) : Contacts OFF (open) • The characteristics shown in the chart above are of the HS9Z-A61, -A62, -A65, and -A66 actuators. For HS9Z-A62S actuator, subtract 0.6 mm. • The characteristics show the contact status when the actuator enters an entry slot of an interlock switch. 12 (07/03/12) HS6E Subminiature Interlock Switches with Solenoid Safety Precautions • In order to avoid electric shock or fire, turn power off before installation, removal, wiring, maintenance, or inspection of the interlock switch. • If relays are used in the circuit between the interlock switch and the load, use only safety relays, since welded or sticking contacts of standard relays may invalidate the functions of the interlock switch. Perform a risk assessment and make a safety circuit which satisfies the requirements of the safety category. • Do not place a PLC in the circuit between the interlock switch and the load. Safety security can be endangered in the event of a malfunction of the PLC. • Do not disassemble or modify the interlock switch, otherwise a malfunction or an accident may occur. • Do not install the actuator in a location where a human body may come in contact. Otherwise injury may occur. • Solenoid lock type is locked when energized, and unlocked when de-energized. When energization is interrupted due to wire disconnection or other failures, the interlock switch may be unlocked causing possible danger to the operators. Solenoid lock type must not be used in applications where locking is strictly required for safety. Perform a risk assessment and determine whether solenoid lock type is appropriate. Instructions • Regardless of door types, do not use the interlock switch as a door stop. Install a mechanical door stop at the end of the door to protect the interlock switch against excessive force. • Do not apply external force on the actuator while unlocking, otherwise the actuator may not be unlocked. • Do not apply excessive shock to the interlock switch when opening or closing the door. A shock to the interlock switch exceeding 1,000 m/s2 may cause damage to the interlock switch. • If the operating atmosphere is contaminated, use a protective cover to prevent the entry of foreign objects into the interlock switch through the actuator entry slots. • Entry of a considerable amount of foreign objects into the interlock switch may affect the mechanism of the interlock switch and cause a malfunction. • Do not store the interlock switches in a dusty, humid, or organic-gas atmosphere, or in an area subjected to direct sunlight. • Use proprietary actuators only. When other actuators are used, the interlock switch may be damaged. • The locking strength is rated at 500N. Do not apply a load higher than the rated value. When a higher load is expected, provide an additional system consisting of another interlock switch without lock (such as the HS6B/ HS7A interlock switch) or a sensor to detect door opening and stop the machine. • Regardless of door types, do not use the interlock switch as a door lock. Install a separate lock using a latch or other measures. • While the solenoid is energized, the switch temperature rises approximately 35°C above the ambient temperature (to approximately 85°C while the ambient temperature is 50°C). Do not touch to prevent burns. If cables come into contact with the switch, use heat-resistant cables. • Bouncing will occur on the lock monitor contact during locking and unlocking (reference value: 20 ms). • Although the HS9Z-A61/A62/A62S actuators alleviate shock when the actuator enters a slot in the interlock switch, make sure that excessive shock is not applied. If the rubber bushings become deformed or cracked, replace with new ones. (07/03/12) Minimum Radius of Hinged Door • When using the interlock switch on hinged doors, refer to the minimum radius of doors shown below. When using on doors with small minimum radius, use the angle adjustable actuator (HS9Z-A65 and HS9Z-A66). Note: Because deviation or dislocation of hinged doors may occur in actual applications, make sure of the correct operation before installation. When using the HS9Z-A62/A62S Right-angle Actuator • When the door hinge is on the extension line of the interlock switch surface: M in im 16 um 0 Ra m m diu M in s im u 16 m R 0 a m diu m s Door Hinge Door Hinge • When the door hinge is on the extension line of the interlock switch surface: M M in in im 23 um 0 m Ra m di us Door Hinge im u 23 m R 0 m adiu m s Door Hinge 13 HS6E Subminiature Interlock Switches with Solenoid When using the HS9Z-A65/HS9Z-A66 Angle Adjustable Actuator • When the door hinge is on the extension line of the interlock switch surface Horizontal Adjustment Minimum Radius 50 mm Vertical Adjustment Minimum Radius Door Hinge 50 mm Door Hinge Label HS9Z-A65 HS9Z-A65 For Manual Unlocking Spring lock type The HS6E allows manual unlocking of the actuator to pre-check proper door operation before wiring or turning power on, as well as for emergency use such as a power failure. Solenoid lock type The HS6E can be unlocked manually in emergency. When using the manual unlock key Manual Unlocking (installed on both sides) HS9Z-A66 HS9Z-A66 UNLOCK Door Hinge 50 mm Door Hinge Minimum Radius LOCK 50 mm Minimum Radius • When the door hinge is on the extension line of the actuator mounting surface Horizontal Adjustment Normal Position Vertical Adjustment s diu Door Hinge Ra um m inim 70m us Door Hinge adi mR imu 70 mm n i M M Label HS9Z-A65 HS9Z-A65 HS9Z-A66 HS9Z-A66 M Rainimu d m 70 ius mm M Rainimu m d 70m ius m Door Hinge Door Hinge Actuator Angle Adjustment for the HS9Z-A65/HS9Z-A66 • Using the angle adjustment screw, the actuator angle can be adjusted (see figures on page 10). Adjustable angle: 0 to 20° • The larger the adjusted angle of the actuator, the smaller the applicable radius of the door opening. • After installing the actuator, open the door. Then adjust the actuator so that its edge can enter properly into the actuator entry slot of the interlock switch. • After adjusting the actuator angle, apply Loctite to the adjustment screw so that the screw will not become loose. Mounting Examples Application on Hinged Doors Application on Sliding Doors Door HS9Z-A62S Actuator Manual Unlocking Position • When locking or unlocking the interlock switch manually, turn the key fully using the manual unlocking key supplied with the switch. • Using the interlock switch with the key not fully turned (less than 90°) may cause damage to the switch or operation failures (when manually unlocked, the switch will keep the main circuit disconnected and the door unlocked). • Do not apply excessive force (0.45 N·m or more) to the manual unlock part, otherwise the manual unlock part will become damaged. • Do not leave the manual unlocking key attached to the switch during operation. This is dangerous because the switch can always be unlocked while the machine is in operation. Manual Unlock Key (supplied with the switch) When unlocking pushing the plate inside the interlock switch • Remove the screw at the side of the interlock switch (the same side where actuator is inserted) and insert a small screwdriver. • Push the plate inside the interlock switch toward the LED indicator using the screwdriver until the actuator is unlocked. • Tighten the screw to a proper torque (0.3 to 0.5 N·m). Do not tighten with excessive force, otherwise the interlock switch will be damaged. Be sure to reinstall the screw, otherwise the waterproof capability will be lost. HS9Z-A61 Actuator HS6E Interlock Switch Latch Door Stop Note: When mounting an actuator, make sure that the actuator enters the slot in the correct direction, as shown on the right. Screwdriver Caution Before manually unlocking the interlock switch, make sure that the machine has come to a complete stop. Manual unlocking during operation may unlock the interlock switch before the machine stops, and the function of the interlock switch with solenoid is lost. While the solenoid is energized, do not unlock the switch manually (solenoid lock type). 14 (07/03/12) HS6E Subminiature Interlock Switches with Solenoid Recommended Tightening Torque of Mounting Screws • Interlock switch: 1.0 to 1.5 N·m (three M4 screws) • Actuators: 1.0 to 1.5 N·m (two M4 screws) • The above recommended tightening torques of the mounting screws are the values with hex socket head bolts. When other screws are used and tightened to a smaller torque, make sure that the screws do not become loose after mounting. • Mounting bolts are not supplied with the interlock and must be supplied by the user. • To avoid unauthorized or unintended removal of the interlock switch and the actuator, it is recommended that the interlock switch and the actuator are installed in an unremovable manner, for example using special screws, rivets, or welding the screws. • When installing the HS9Z-A62S actuator, use the mounting plate (supplied with the actuator) on the hinged door, and secure the actuator tightly using two M4 screws. • The mounting plate has orientation. • Do not lose the mounting plate. M4 Screws Mounting Plate (supplied) Rubber Bushing Wire Identification • Wires can be identified by the color and or a white line printed on the wire. No. Insulation Color No. Insulation Color 1 Blue/White 7 White 2 Gray 8 Black 3 Pink 9 Pink/White 4 Orange 10 Brown/White 5 Orange/White 11 Brown 6 Gray/White 12 Blue Note: Wires of gray or gray/white are not used and should not be connected. Colored Insulation 11 12 4 10 1 5 3 2 9 6 8 7 Jacket Terminal Number Identification • When wiring, identify the terminal number of each contact by the color of insulation. • The following table shows the identification of terminal numbers. • When wiring, cut unused wires at the end of the jacket to avoid incorrect wiring. Type Contact Arrangement Door Monitor Lock Monitor Hinged Door (+) (–) A1 Black White A2 M4 Tapped Hole HS6E-L Main circuit: Blue Monitor circuit: Brown Cables Monitor circuit: Orange • Do not fasten or loosen the gland at the bottom of the interlock switch. • When bending the cable during wiring, make sure that the cable radius is kept at 30 mm minimum. • When wiring, make sure that water or oil does not enter from the end of the cable. • Do not open the lid of the interlock switch. Otherwise the interlock switch will be damaged. • The solenoid has polarity. Make sure of the correct polarity when wiring. Main circuit: Blue HS6E-M Monitor circuit: Brown Monitor circuit: Orange Main circuit: Blue HS6E-N Monitor circuit: Brown Monitor circuit: Orange Main circuit: Blue HS6E-P Monitor circuit: Brown Monitor circuit: Orange 11 21 31 12 22 32 Brown/White Pink 53 41 11 21 31 12 22 32 Brown/White Pink 51 11 21 33 12 22 34 Brown/White Pink 53 11 21 33 12 22 34 Brown/White Pink 51 42 54 Blue/White 42 52 Blue/White 42 54 Blue/White 42 52 Blue/White Pink/White Orange/White 41 Pink/White Orange/White 41 Pink/White Orange/White 41 Pink/White Orange/White Note: The contact arrangements show the contact status when the actuator is inserted and locked. Gland dius Minimum Ra 30 mm (50) Min im Rad um 30 ius mm (70) Gland (07/03/12) 15 HS6B Subminiature Interlock Switches World-class compactness with three poles of contacts. • World’s smallest switch: 30 × 30 × 78 mm • Dual contacts and monitor contacts achieve the highest safety category (ISO 13849-1, EN 954-1) • Two actuator entry slots provide flexibility for installation options. • Integral cable design minimizes wiring, preventing wiring mistakes. • Can be mounted in two directions. • Degree of protection (contacts): IP67 (IEC 60529) Housing allows drainage. • NC contacts are direct opening action (IEC/EN 60947-5-1). • Proprietary actuators prevent unauthorized opening of the contacts (ISO14119, EN1088). Direct Opening Action • Vertical/horizontal Angle Adjustable Actuator (for hinged door) • Straight Actuator (SUS304) Double Insulation Types Specifications Contact Configuration Cable Length 1NC-1NO Zb 11 33 12 34 2NC Zb 11 31 12 32 2NC-1NO Type No. (Package quantity: 1) 12 22 32 3NC HS6B-11B01 3m HS6B-11B03 5m HS6B-11B05 1m HS6B-02B01 3m HS6B-02B03 Applicable Directive –25 to +70°C (no freezing) 45 to 85% (no condensation) Applicable Standards IEC 60204-1/ EN 60204-1 (applicable standards for use) 12 22 32 5m HS6B-02B05 1m HS6B-12B01 Relative Humidity 3m HS6B-12B03 Storage Temperature –40 to +80°C (no freezing) Pollution Degree 3 Impulse Withstand Voltage 4 kV Insulation Resistance (500V DC megger) Between live and dead metal parts: 100 MΩ minimum Between terminals of different poles: 100 MΩ minimum Contact Resistance 300 mΩ maximum (initial value, 1m cable) 500 mΩ maximum (initial value, 3m cable) 700 mΩ maximum (initial value, 5m cable) 5m HS6B-12B05 1m HS6B-03B01 3m HS6B-03B03 5m HS6B-03B05 Actuators Description Straight Right-angle Horizontal/vertical Angle Adjustable (for hinged doors) (Note) Type No. (Package quantity: 1) HS9Z-A61 HS9Z-A62 HS9Z-A65 HS9Z-A66 Note: Select an actuator that moves in the direction required by the hinged door and interlock switch (see pages 17 and 18). Contact Ratings Rated Insulation Voltage (Ui) Rated Current (Ith) Rated Voltage (Ue) ∗ AC DC 30V 300V 2.5A 125V Resistive load (AC-12) — 2.5A 1.5A Inductive Load (AC-15) — 1.5A 0.75A Resistive load (DC-12) 2.5A 1.1A 0.55A Inductive Load (DC-13) 2.3A 0.55A 0.27A • Minimum applicable load (reference): 3V AC/DC, 5mA ∗ Ratings approved by safety agencies C300: AC-15, 0.75A/240V Q300: DC-13, 0.27A/250V 16 73/23/EEC (Low Voltage Directive) Operating Temperature Zb 11 21 31 UL508 (UL listed) CSA C22.2, No. 14 (c-UL listed) ISO 14119 EN 1088 IEC 60947-5-1 EN 60947-5-1 (DEMKO approval) GS-ET-15 (BG approval) 1m Zb 11 21 31 Rated Current (Ie) ∗ • Right-angle Actuator (SUS304) 250V Electric Shock Protection Class Class II (IEC 61140) Degree of Protection IP67 (IEC 60529) Shock Resistance Operating extremes: 300 m/s2 (30G) Damage limits: 1000 m/s2 (100G) Vibration Resistance Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Damage limits: 30 Hz, amplitude 1.5 mm Actuator Operating Speed 0.05 to 1.0 m/s Direct Opening Travel 8 mm minimum Direct Opening Force 60N minimum Operating Frequency 1200 operations/h Mechanical Durability 1,000,000 operations minimum (GS-ET-15) Electrical Durability 100,000 operations minimum (operating frequency 1200 operations/h, load AC-12 250V/1.5A, DC-12 250V/0.2A) Conditional Short-circuit Current 50A (250V) (Use 250V/10A fast-blow fuse for shortcircuit protection.) Housing Color Black Cable UL2464 No. 20 AWG (6-core) Weight (approx.) 120g (HS6B-03B01) (07/03/12) HS6B Subminiature Interlock Switches Dimensions • Interlock Switch • Mounting Hole Layout R (58) 20 20 to 22 2-M4 Screws (ø4.3 or M4 tapped) 35 1 15 (9) 78 Slot Plug (Note 1) (supplied) The interlock switch can be mounted in two directions. 10.4 27.6 4 Note 1: Plug the unused actuator entry slot using the slot plug supplied with the interlock switch. (ø7.6) 4 5.5 • Using the HS9Z-A61 Straight Actuator • Using the HS9Z-A62 Right-angle Actuator (12.6±1) • Using the HS9Z-A65/A66 Angle Adjustable Actuator (25) (21.4) 30.8 28.8 22.6±1 0.8 (25) 0.8 15.1±1 Actuator Stop (Note 2) (supplied) 0.8 (14) 40.1±1 50.8 (30.1±1) 0.8 (5) 0.8 22.6±1 0.8 48.8 (14) (5) (41.4) 10.1 5.5 30 1 2. 2 10.4 Actuator Stop (Note 2) (supplied) Actuator Stop (Note 2) (supplied) Actuator Dimensions Horizontal Adjustment 3.5 0.8 8.4 15 Horizontal Adjustment Angle Adjustment (M3 Hexagon Socket Head Screw) 3.5 1.2 20° 10.4 20° When mounted (5) 14 .3 ø4 214 The HS9Z-A65 and HS9Z-A66 have the metal key inserted in opposite directions. 0.8 Orienting Insert (15.8) 1.2 43.2 20.9 • Angle Adjustmentable Actuator (HS9Z-A66) • Angle Adjustmentable Actuator (HS9Z-A65) • Straight Actuaor (HS9Z-A61) Angle Adjustment (M3 Hexagon Socket Head Screw) Vertical Adjustment Angle Adjustment (M3 Hexagon Socket Head Screw) Vertical Adjustment 34 3.5 Actuator Stop (supplied) (Note 2) 13.1 14 2-ø 20° Orienting Insert R2 4 H .1 ole s) (M The orientation of actuator adjustment (horizontal/vertical) can be changed using the orienting insert (white plastic) installed on the back of the actuator. 14 4.3 2.5 Angle Adjustment (M3 Hexagon Socket Head Screw) 25 34 8.4 15 When mounted (5) Rubber Bushing 20° When mounted (33.8) When mounted (5.6) 0.8 Actuator Stop (supplied) (Note 2) 2 5.5 7.5 Orienting Insert • Right-angle Actuator (HS9Z-A62) 2-ø9 28.2 16.8 Actuator Stop (supplied) (Note 2) 2-ø9 Rubber Bushing 1.2 13 The base is made of glass-reinforced PA66 (66 nylon). Angle adjustment screws are stainless steel. When using adhesive on screws, take material compatibility into consideration. Note 2: After mounting the actuator, remove the actuator stop from the interlock switch. Horizontal Adjustment Vertical Adjustment • Actuator Mounting Hole Layout Straight/Right-angle Actuator 14 2-M4 Screws (ø4.3 or M4 tapped) Angle Adjustable Actuator 25 2-M4 Screws (ø4.3 or M4 tapped) (07/03/12) 17 HS6B Subminiature Interlock Switches Contact Configuration and Operation Chart Type Contact Configuration Contact Operation Chart 0.8 (Actuator Mounting Reference Position) 0 5.5 5.8 28.2 (Travel: mm) HS6B-11 1NC-1NO Zb 11 33 12 34 11-12 33-34 12 32 11-12 31-32 12 22 34 11-12 21-22 33-34 12 22 32 11-12 21-22 31-32 : Contact ON (closed) Zb HS6B-02 2NC 11 31 2NC-1NO 11 21 33 3NC 11 21 31 : Contact OFF (open) Zb HS6B-12 Zb HS6B-03 Actuator inserted completely Minimum Radius of Hinged Door • When using the interlock switch on hinged doors, refer to the minimum radius of doors shown below. When using on doors with small minimum radius, use the angle adjustable actuator (HS9Z-A65 and HS9Z-A66). Note: Because deviation or dislocation of hinged doors may occur in actual applications, make sure of the correct operation before installation. Actuator removed completely When using the HS9Z-A65/HS9Z-A66 Angle Adjustable Actuator • When the door hinge is on the extension line of the interlock switch surface: Horizontal Adjustment 50 mm dius Minimum Ra Door Hinge 50 mm Minimum Radius Door Hinge Label When using the HS9Z-A62 Right-angle Actuator • When the door hinge is on the extension line of the interlock switch surface: Vertical Adjustment Label HS9Z-A65 HS9Z-A65 HS9Z-A66 HS9Z-A66 Door Hinge 50 mm Minimum Radiu s Door Hinge 50 mm Minimum Radiu s • When the door hinge is on the extension line of the actuator mounting surface M 1 im 60 m um m Ra di us M in 1 im 60 m um m Ra di us Horizontal Adjustment in Door Hinge Door Hinge s mm diu 70 m Ra u m i n Mi Vertical Adjustment Door Hinge us mm adi 70 um R m i n Mi Label • When the door hinged is on the extension line of the actuator mounting surface: HS9Z-A65 Door Hinge Label HS9Z-A65 HS9Z-A66 HS9Z-A66 Min imu 70 mm mR adi us Door Hinge 7 imu 0 mm mR adi us Min Door Hinge Actuator Angle Adjustment for the HS9Z-A65/HS9Z-A66 M 2 im 30 m um m Ra di us M 18 2 im 30 m um m Ra di us in in Door Hinge Door Hinge • Using the angle adjustment screw, the actuator angle can be adjusted (see figures on page 17). Adjustable angle: 0 to 20° • The larger the adjusted angle of the actuator, the smaller the applicable radius of the door opening. • After installing the actuator, open the door. Then adjust the actuator so that its edge can enter properly into the actuator entry slot of the interlock switch. • After adjusting the actuator angle, apply Loctite to the adjustment screw so that the screw will not become loose. (07/03/12) HS6B Subminiature Interlock Switches Safety Precautions • In order to avoid electric shock or fire, turn the power off before installation, removal, wiring, maintenance, or inspection of the switch. • If relays are used in the circuit between the interlock switch and the load, use only safety relays, since welded or sticking contacts of standard relays may invalidate the functions of the interlock switch. Perform a risk assessment and make a safety circuit which satisfies the requirements of the safety category. • Do not place a PLC in the circuit between the interlock switch and the load. Safety security can be endangered in the event of a malfunction of the PLC. • Do not disassemble or modify the interlock switch, otherwise a malfunction or an accident may occur. • Do not install the actuator in the location where a human body may come in contact. Otherwise injury may occur. Instructions • Regardless of door types, do not use the interlock switch as a door stop. Install a mechanical door stop at the end of the door to protect the interlock switch against excessive force. • Do not apply excessive shock to the interlock switch when opening or closing the door. A shock to the interlock switch exceeding 1,000 m/s2 may cause damage to the interlock switch. • If the operating atmosphere is contaminated, use a protective cover to prevent the entry of foreign objects into the interlock switch through the actuator entry slots. • Entry of a considerable amount of foreign objects into the interlock switch may affect the mechanism of the interlock switch and cause a malfunction. • Do not store the interlock switches in a dusty, humid, or organic-gas atmosphere. • Use proprietary actuators only. When other actuators are used, the interlock switch may be damaged. • Cover the unused actuator entry slot using the slot plug supplied with the interlock switch. Mounting Wire Identification Mount the interlock switch on the machine. Mount the actuator on the hinged door. • Wires can be identified by color and/or a white line printed on the wire. Colored Insulation Note: When mounting an actuator, make sure that the actuator enters into the slot in the correct direction, as shown on the right. No. Insulation Color No. Insulation Color 1 Orange/White 4 Brown 2 Blue/White 5 Blue 3 Brown/White 6 Orange Jacket Dummy Insulation (black) Recommended Screw Tightening Torque • Interlock switch (M4 screw): 1.0 to 1.5 N·m • Actuator (M4 screw): 1.0 to 1.5 N·m • Mounting bolts are not supplied, and must be purchased separately by the user. Terminal Number Identification Note: The above recommended tightening torque of the mounting screw is the value with hex socket head bolts. When other screws are used and tightened to a smaller torque, make sure that the screws do not become loose after mounting. Cable Gland (07/03/12) u nim ius Mi ad R mm 40 (100) • Do not fasten or loosen the gland at the bottom of the interlock switch. • When bending cable during wiring, make sure that the cable radius is kept at 40 mm minimum. • When wiring, make sure that water or oil does not enter from the end of cable. m • When wiring, the terminal number on each contact can be identified by wire color. • The following diagrams show a safety (main) contact and one or two auxiliary contacts for two-contact and three-contact types. 1NC-1NO Zb 2NC Zb Blue 11 12 Blue/White Orange 33 34 Orange/White Orange 31 Blue 11 2NC-1NO Zb 12 Blue/White 32 Orange/White 3NC Zb Blue 11 12 Blue/White Blue 11 12 Blue/White Brown 21 22 Brown/White Brown 21 22 Brown/White Orange 33 34 Orange/White Orange 31 32 Orange/White • When wiring, cut any dummy insulation (black) and any unused wires at the end of the jacket to avoid incorrect wiring. 19 HS5E Series Miniature Interlock Switches with Solenoid Solenoid interlock switch with four contacts in a compact body. Ideal for small or special-shape doors with limited mounting space. • • • • • • • • Compact body. 35 × 40 × 146 mm. Four poles with gold-plated contacts. Spring lock and solenoid lock types are available. The head orientation can be rotated, allowing for 8 different actuator entries. Metal head ensures durability. Locking strength 1000N minimum (GS-ET-19) Integrated cable design minimizes wiring, preventing incorrect wiring. RoHS directive compliant. BG standard in Germany Direct Opening Double Action Insulation HS5B Series Miniature Interlock Switches Metal head type and M20 conduit port newly added. • Actuators are interchangeable with the HS5E miniature interlock switches with solenoid. • Actuators with rubber bushing available. • RoHS directive compliant. • The head orientation can be rotated, allowing for 8 different actuator entries. • Compact body. 30 × 30 × 90 mm. BG standard in Germany Direct Opening Double Action Insulation Specifications and other descriptions in this catalog are subject to change without notice. 7-31, Nishi-Miyahara 1-Chome, Yodogawa-ku, Osaka 532-8550, Japan Tel: +81-6-6398-2571, Fax: +81-6-6392-9731 E-mail: products@idec.co.jp IDEC CORPORATION (USA) 1175 Elko Drive, Sunnyvale, CA 94089-2209, USA Tel: +1-408-747-0550 / (800) 262-IDEC (4332) Fax: +1-408-744-9055 / (800) 635-6246 E-mail: opencontact@idec.com IDEC CANADA LIMITED Unit 22-151, Brunel Road, Mississauga, Ontario, L4Z 1X3, Canada Tel: +1-905-890-8561, Toll Free: (888) 317-4332 Fax: +1-905-890-8562 E-mail: sales@ca.idec.com IDEC AUSTRALIA PTY. LTD. 2/3 Macro Court, Rowville, Victoria 3178, Australia Tel: +61-3-9763-3244, Toll Free: 1800-68-4332 Fax: +61-3-9763-3255 E-mail: sales@au.idec.com IDEC ELECTRONICS LIMITED www.idec.com Unit 2, Beechwood, Chineham Business Park, Basingstoke, Hampshire RG24 8WA, UK Tel: +44-1256-321000, Fax: +44-1256-327755 E-mail: sales@uk.idec.com IDEC ELEKTROTECHNIK GmbH IDEC IZUMI (H.K.) CO., LTD. Wendenstrasse 331, 20537 Hamburg, Germany Tel: +49-40-25 30 54 - 0, Fax: +49-40-25 30 54 - 24 E-mail: service@idec.de Unit 1505-07, DCH Commercial Centre No. 25, Westlands Road, Quarry Bay, Hong Kong Tel: +852-2803-8989, Fax: +852-2565-0171 E-mail: info@hk.idec.com IDEC (SHANGHAI) CORPORATION Room 608-609, 6F, Gangtai Plaza, No. 700, Yan'an East Road, Shanghai 200001, PRC Tel: +86-21-5353-1000, Fax: +86-21-5353-1263 E-mail: idec@cn.idec.com IDEC (BEIJING) CORPORATION Room 211B, Tower B, The Grand Pacific Building, 8A Guanghua Road, Chaoyang District, Beijing 100026, PRC Tel: +86-10-6581-6131, Fax: +86-10-6581-5119 IDEC (SHENZHEN) CORPORATION IDEC TAIWAN CORPORATION 8F-1, No. 79, Hsin Tai Wu Road, Sec. 1, Hsi-Chih, Taipei County, Taiwan Tel: +886-2-2698-3929, Fax: +886-2-2698-3931 E-mail: service@tw.idec.com IDEC IZUMI ASIA PTE. LTD. No. 31, Tannery Lane #05-01, Dragon Land Building, Singapore 347788 Tel: +65-6746-1155, Fax: +65-6844-5995 E-mail: info@sg.idec.com Unit AB-3B2, Tian Xiang Building, Tian’an Cyber Park, Fu Tian District, Shenzhen, Guang Dong 518040, PRC Tel: +86-755-8356-2977, Fax: +86-755-8356-2944 Cat. No. EP1162-0 MARCH 2007 13.5DNP PRINTED IN JAPAN (07/03/12)
HS6E-N7Y4B03-G 价格&库存
很抱歉,暂时无法提供与“HS6E-N7Y4B03-G”相匹配的价格&库存,您可以联系我们找货
