HS9Z-A1
HS9Z-A1
    IDEC(日本和泉)
HS9Z-A1 数据手册
Solenoid Locking Safety Switches HS1E HS1E Full Size Solenoid Locking Switches Overview Key features: • Plastic Housing: Lightweight • 1500N locking retention force • Available with a red or green indicator • Choose from 4 circuit configurations • Flexible Installation: The actuator can be accessed from two directions • Ease of Wiring: M3.5 termination screws XW Series E-Stops Contact Configuration 1 Monitor Circuit 2 3 5 6 None HS1E-40R HS1E-40KR Green HS1E-44R-G HS1E-44KR-G Red HS1E-44R-R None 7 Description HS9Z-A1 Straight Actuator HS9Z-A2 Right-angle Actuator HS1E-44KR-R HS9Z-A3 Adjustable Actuator HS1E-140R HS1E-140KR HS9Z-T1 Key Wrench (included with switch) Green HS1E-144R-G HS1E-144KR-G HS9Z-P1 Conduit Opening Plug (G1/2) Red HS1E-144R-R HS1E-144KR-R None HS1E-240R HS1E-240KR Green HS1E-244R-G HS1E-244KR-G Red HS1E-244R-R HS1E-244KR-R None HS1E-340R HS1E-340KR Green HS1E-344R-G HS1E-344KR-G Red HS1E-344R-R HS1E-344KR-R Main Circuit Solenoid Power 6 Indicator 7 Contacts are linked to the solenoid mechanically. 8 1 Monitor Circuit 2 Safety Control Relays 5 Part Number 8 Monitor Circuit 4 Appearance Indicator 1 3 Manual Unlock Key Solenoid Power Contacts are linked to the solenoid mechanically. Main circuit: 1NC + 1NC Monitor circuit: 1NO Standard Main Circuit 4 2 LED Enabling Switches Main circuit: 1NC + 1NC Monitor circuit: 1NO/1NO Interlock Switches Actuator Keys & Accessories Part Numbers (Mechanical Spring Lock Only) 3 Main circuit: 1NC + 1NC Monitor circuit: 1NC + 1NC Main Circuit 4 5 Solenoid Power Indicator – Contacts are linked to the solenoid mechanically. 7 8 1 Monitor Circuit 2 Light Curtains 6 + 3 Main Circuit 4 5 6 + AS-Interface Safety at Work Main circuit: 1NC + 1NC Monitor circuit: 1NC Solenoid Power Indicator – Contacts are linked to the solenoid mechanically. 7 8 1. Key wrench for TORX screws (HS9Z-T1) is supplied with the interlock switch. 2. Actuator is not supplied with the interlock switch, and must be ordered separately. 3. TORX is a registered trademark of Camcar Textron. 800-262-IDEC (4332) • USA & Canada 315 Solenoid Locking Safety Switches HS1E Safety Control Relays Enabling Switches Interlock Switches XW Series E-Stops Overview Specifications Conforming to Standards EN1088, IEC60947-5-1, EN60947-5-1(TUV), ISO14119, GS-ET-19 (BG), UL508, CSA C22.2 No. 14, GB14048.5 (CCC approval), IEC60204-1, EN60204-1 (applicable standards for use) Operating Temperature –20 to +40˚C (no freezing) Storage Temperature –40 to +80˚C Relative Humidity 40 - 85% RH (no condensation) Altitude 2,000m maximum Rated Insulation Voltage (Ui) 300V (between LED or solenoid and ground: 60V) Impulse Withstand Voltage (Uimp) 4 kV (between LED or solenoid and ground: 2.5 kV) Insulation Resistance (measured with 500V DC megger) Between live and dead metal parts: 100 MΩ minimum Between live metal part and ground: 100 MΩ minimum Between live metal parts: 100 MΩ minimum Between terminals of the same pole: 100 MΩ minimum Electric Shock Protection Class II (according to IEC61140) Pollution Degree 3 (IEC60947-5-1) Degree of Protection IP67 (IEC60529) Vibration Resistance 10 to 55 Hz, minimum (amplitude 0.35 mm) Damage Limits 50 m/sec2 (approx. 5G) Shock Resistance 1,000 m/sec2 (approx. 100G) Actuator Retention Force 1,500N minimum (per GS-ET-19) Actuator Operating Speed 0.05 to 1.0m/s Direct Opening Travel 11mm minimum Direct Opening Force 20N minimum Thermal Current (Ith) Main circuit: 10A, Auxiliary circuit: 3A Contact Gap Main circuit: 1.7 mm min., Auxiliary circuit: 1.2 mm min. Operating Frequency 900 operations/hour max. Mechanical Life 1,000,000 operations min. (at full rated load) 900 ops/hr (AC-12/250V, 6A) Electrical Life 100,000 operations (rated load) Conditional Short-circuit Current 100A (per IEC60947-5-1) Recommended Short Circuit Protection 250V, 10A fuse (Type D01 based on IEC60269-1, 60269-2) Solenoid Unit Indicator Light Curtains Operating Extremes Operating Voltage 24V DC Current 292mA (initial value) Coil Resistance 102Ω (at 20ºC) Pickup Voltage 20.4V maximum (at 20ºC) Drop Out Voltage 2.4V minimum (at 20ºC) Allowable Voltage 26.4V max (continuous) Insulation Class Class F Operating Voltage 24V DC Current 10mA Light Source LED lamp Lens Color Red or Green Weight (approx.) 500g Contact Ratings Main Circuit Rated Operating Current (Ie) Auxiliary Circuit AS-Interface Safety at Work Operating Voltage (Ue) 316 30V 125V 250V AC Resistive load (AC12) Inductive load (AC15) 10A 10A 10A 5A 6A 3A DC Resistive load (DC12) Inductive load (DC13) 6A 3A – 0.9A – – AC Resistive load (AC12) Inductive load (AC15) – – 3A – 3A 3A DC Resistive load (DC12) Inductive load (DC13) 3A – – 0.9A – – www.IDEC.com Solenoid Locking Safety Switches HS1E Application Examples and Circuit Diagrams Status 1 Switch/Door Status Status 2 Door Closed Machine ready to operate Solenoid de-energized Status 3 Door Closed Machine cannot be started Solenoid de-energized Status 4 Door Opened Machine cannot be started Solenoid energized Door Opened Machine cannot be started Solenoid de-energized Overview HS1E-4 (Main Circuit: 1NC-1NC, Auxiliary Circuit: 1NO/1NO) Unlocked Manually Door Closed Machine cannot be started Solenoid de-energized Monitor Circuit Monitor Circuit Monitor Circuit Monitor Monitor Circuit Circuit Main Circuit Main Circuit Main Circuit Main Main Circuit Circuit Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Monitor Circuit Monitor Circuit Monitor Circuit Monitor Monitor Circuit Circuit Main Circuit Main Circuit Main Circuit Main Main Circuit Circuit Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Monitor Circuit Monitor Circuit Monitor Circuit Monitor Monitor Circuit Circuit Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Main Circuit Main Circuit Main Circuit Main Main Circuit Circuit Monitor Circuit Monitor Circuit Monitor Circuit Monitor Monitor Circuit Circuit Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Main Circuit Main Circuit Main Circuit Main Main Circuit Circuit Monitor Circuit Monitor Circuit Monitor Circuit Monitor Monitor Circuit Circuit Main Circuit Main Circuit Main Circuit Main Main Circuit Circuit Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Interlock Switches Circuit Diagram XW Series E-Stops Door Contacts Contacts Contacts Contacts areare linked are linked are to linked linked to to to Contacts Contacts Contacts Contacts Contacts areare linked are linked are to linked linked to to to Contacts Contacts Contacts Contacts areare linked are linked are to linked linked to to to Contacts Contacts Contacts Contacts Contacts areare linked are linked are to linked linked to to to Contacts Contacts Contacts Contacts Contacts areare linked are linked are to linked linked to to to Contacts are linked to are linked to Contacts are linked to are linked to are linked to thethe solenoid the solenoid the solenoid solenoid mechanically mechanically mechanically mechanically thethe solenoid the solenoid the solenoid solenoid mechanically mechanically mechanically mechanically thethe solenoid the solenoid the solenoid solenoid mechanically mechanically mechanically mechanically thethe solenoid the solenoid the solenoid solenoid mechanically mechanically mechanically mechanically thethe solenoid the solenoid the solenoid solenoid mechanically mechanically mechanically mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically 3-4: Closed 3-4: Open 3-4: Open 3-4: Closed 3-4: Open Aux. Circuit 1-2: Open 1-2: Closed 1-2: Closed 1-2: Closed 1-2: Closed 5-6: Power OFF 5-6: Power ON 5-6: Power ON 5-6: Power OFF 5-6: Power OFF Status 3 Status 4 Unlocked Manually Solenoid Enabling Switches Main Circuit HS1E-14 (Main Circuit: 1NC-1NC, Auxiliary Circuit: 1NO) Status 1 Switch/Door Status Status 2 Door Closed Machine ready to operate Solenoid de-energized Door Closed Machine cannot be started Solenoid energized Door Opened Machine cannot be started Solenoid energized Door Opened Machine cannot be started Solenoid de-energized Door Closed Machine cannot be started Solenoid de-energized Safety Control Relays Monitor Circuit Monitor Monitor Circuit Circuit Monitor Circuit Monitor Circuit Main Circuit Main Main Circuit Circuit Main Circuit Main Circuit Monitor Circuit Monitor Monitor Circuit Circuit Monitor Circuit Monitor Circuit Main Circuit Main Main Circuit Circuit Main Circuit Main Circuit Monitor Circuit Monitor Monitor Circuit Circuit Monitor Circuit Monitor Circuit Monitor Circuit Monitor Monitor Circuit Circuit Monitor Circuit Monitor Circuit Main Circuit Main Main Circuit Circuit Main Circuit Main Circuit Main Circuit Main Main Circuit Circuit Main Circuit Main Circuit Monitor Circuit Monitor Monitor Circuit Circuit Monitor Circuit Monitor Circuit Light Curtains Main Circuit Main Main Circuit Circuit Main Circuit Main Circuit Door Solenoid Power Solenoid Solenoid Power Power Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Solenoid Power Solenoid Power (Note) (Note) (Note)(Note) (Note) Circuit Diagram Contacts are Contacts are to Contacts are Contacts are to Contacts are Contacts are to Contacts are Contacts are to toContacts are Contacts are to Contacts are to toContacts Contacts are to to Contacts Contacts are to to Contacts are to Contacts Contacts are to to Contacts are linked to linked are linked to linked are linked to linked Contacts are linked to linked are linked to linked Contacts arelinked linked to linked Contacts arelinked linked to linked Contacts arelinked linked to linked Contacts arelinked linked to linked Contacts arelinked linked to linked the themechanically solenoid mechanically the themechanically solenoid mechanically the themechanically solenoid mechanically the themechanically solenoid mechanically the themechanically solenoid mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically the solenoid mechanically thesolenoid solenoid mechanically thesolenoid solenoid mechanically thesolenoid solenoid mechanically thesolenoid solenoid mechanically thesolenoid solenoid mechanically Aux. Circuit Solenoid 3-4: Closed 3-4: Open 3-4: Open 3-4: Open AS-Interface Safety at Work Main Circuit 3-4: Open 1-2: Open 1-2: Open 1-2: Closed 1-2: Closed 1-2: Open 5-6: Power OFF 5-6: Power ON 5-6: Power ON 5-6: Power OFF 5-6: Power OFF 1. Main Circuit: used to enable the machine to start only when the main circuit is closed. 2. Auxiliary Circuit: used to indicate whether the machine circuit or door is open or closed. 3. Terminals 7 and 8 are used for the LED indicator, and are isolated from solenoid and door status. 800-262-IDEC (4332) • USA & Canada 317 Solenoid Locking Safety Switches HS1E HS1E-24 (Main Circuit: 1NC+1NC, Auxiliary Circuit: 1NC+NC) Monitor Circuit Monitor Monitor Circuit Circuit Monitor Circuit Monitor Circuit Main Circuit Main Main Circuit Circuit Main Circuit Main Circuit Monitor Circuit Monitor Monitor Circuit Circuit Monitor Circuit Monitor Circuit Main Circuit Main Main Circuit Circuit Main Circuit Main Circuit 5 55 55 Solenoid Power Solenoid Solenoid Power Power Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Solenoid Power Solenoid Power Solenoid Power Solenoid Solenoid Power Power Solenoid Power Solenoid Power Main Circuit Main Main Circuit Circuit Main Circuit Main Circuit Main Circuit Main Main Circuit Circuit Main Circuit Main Circuit Solenoid 3-4: Closed 3-4: Open 3-4: Open 3-4: Open 3-4: Open 1-2: Closed 1-2: Open 1-2: Open 1-2: Open 1-2: Open 5-6: Power OFF 5-6: Power ON 5-6: Power ON 5-6: Power OFF 5-6: Power OFF HS1E-34 (Main Circuit: 1NC+1NC, Auxiliary Circuit: 1NC) Status 1 Status 2 Door Closed Machine ready to operate Solenoid de-energized Status 3 Door Closed Machine cannot be started Solenoid energized Door Opened Machine cannot be started Solenoid energized Status 4 Door Opened Machine cannot be started Solenoid de-energized Unlocked Manually Door Closed Machine cannot be started Solenoid de-energized Door Monitor Circuit Monitor Circuit Monitor Circuit Monitor Circuit Monitor Circuit Monitor Circuit Monitor Circuit Monitor Circuit Main Circuit Main Circuit Main Circuit Main Circuit Solenoid Power Solenoid Power Solenoid Power Solenoid Power 5 55 5 Main Circuit Main Circuit Main Circuit Main Circuit Monitor Circuit Monitor Circuit Monitor Circuit Monitor Circuit Main Circuit Main Circuit Main Circuit Main Circuit 4 44 4 Solenoid Power Solenoid Power Solenoid Power Solenoid Power Monitor Circuit Monitor Circuit Monitor Circuit Monitor Circuit Main Circuit Main Circuit Main Circuit Main Circuit Solenoid Power Solenoid Power Solenoid Power Solenoid Power Monitor Circuit Monitor Circuit Monitor Circuit Monitor Circuit 3 33 3 Solenoid Power Solenoid Power Solenoid Power Solenoid Power Circuit Diagram 2 22 2 Main Circuit Main Circuit Main Circuit Main Circuit 1 11 1 Solenoid Power Solenoid Power Solenoid Power Solenoid Power Enabling Switches Aux. Circuit Switch/Door Status Safety Control Relays 4 44 44 Unlocked Manually Door Closed Machine cannot be started Solenoid de-energized Contacts arelinked linked tothe the Contacts arelinked linked tothe the Contacts arelinked linked tothe the Contacts arelinked linked tothe the Contacts arelinked linked tothe the Contacts are linked to the Contacts are linked to the Contacts are linked to the Contacts are linked to the Contacts are linked to the Contacts Contacts Contacts are are are linked tolinked to to thethe Contacts Contacts Contacts are are are linked tolinked to to thethe Contacts Contacts Contacts are are are linked tolinked to to thethe Contacts Contacts Contacts are are are linked tolinked to to thethe Contacts Contacts Contacts are are are linked tolinked to to thethe solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically mechanically mechanically mechanically mechanically solenoid solenoid solenoid mechanically mechanically mechanically solenoid solenoid solenoid solenoid mechanically mechanically mechanically solenoid solenoid solenoid solenoid mechanically mechanically mechanically solenoid solenoid solenoid solenoid mechanically mechanically mechanically solenoid solenoid solenoid solenoid mechanically mechanically mechanically Main Circuit Light Curtains 3 33 33 Monitor Circuit Monitor Monitor Circuit Circuit Monitor Circuit Monitor Circuit Monitor Circuit Monitor Monitor Circuit Circuit Monitor Circuit Monitor Circuit 2 22 22 Door Opened Machine cannot be started Solenoid de-energized Solenoid Power Solenoid Solenoid Power Power Solenoid Power Solenoid Power Circuit Diagram 1 11 11 Status 4 Door Opened Machine cannot be started Solenoid energized Monitor Circuit Monitor Monitor Circuit Circuit Monitor Circuit Monitor Circuit Door Status 3 Door Closed Machine cannot be started Solenoid energized Main Circuit Main Main Circuit Circuit Main Circuit Main Circuit XW Series E-Stops Switch/Door Status Status 2 Door Closed Machine ready to operate Solenoid de-energized Solenoid Power Solenoid Solenoid Power Power Solenoid Power Solenoid Power Status 1 Interlock Switches Overview Application Examples and Circuit Diagrams, continued (Note) (Note)(Note) (Note) AS-Interface Safety at Work Contacts are linked to the Contacts are linked to theContacts Contacts are linked to the Contacts are linked toContacts theContacts Contacts are linked to the Contacts are linked tolinked the Contacts are linked tolinked the are linked tolinked the Contacts are linked tolinked the are linked tolinked the Contacts to the Contacts to the Contacts to the Contacts to the Contacts to the Contacts areare linked to the Contacts areare linked to the Contacts areare linked to the Contacts areare linked to the areare linked to the solenoid mechanically solenoid solenoid mechanically solenoid solenoid mechanically solenoid solenoid mechanically solenoid mechanically solenoid mechanically mechanically mechanically mechanically solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically solenoid mechanically Main Circuit 3-4: Closed 3-4: Open 3-4: Open 3-4: Open 3-4: Open Aux. Circuit 1-2: Closed 1-2: Closed 1-2: Open 1-2: Open 1-2: Closed 5-6: Power OFF 5-6: Power ON 5-6: Power ON 5-6: Power OFF 5-6: Power OFF Solenoid 1. Main Circuit: used to enable the machine to start only when the main circuit is closed. 2. Auxiliary Circuit: used to indicate whether the machine circuit or door is open or closed. 3. Terminals 7 and 8 are used for the LED indicator, and are isolated from solenoid or door status. 318 www.IDEC.com Solenoid Locking Safety Switches HS1E Vertical Mounting Right-angle Actuator HS9Z-A2 104 88 33 54.3 (RP) 2-M6 Actuator Mounting Holes 17.5 ±1 Actuator Cover HS9Z-A1 Actuator 46.5 (RP) 89 89 45 63 23.5 40 35 4 3-M5 Screw Interlock Switches Slot Plug (supplied) (Note) Actuator Cover HS9Z-A2 Actuator 11.0 22 26 RP: Actuator Mounting Reference Position 5 31.2 21 61 61 (RP) 12.3 2 4 7.5 68.8 (RP) 49.5 8.5 ±1 6.5 ±1 XW Series E-Stops 10 19.5 ±1 23.5 26 121 129 4 10 45.4 39.2 Horizontal Mounting Straight Actuator HS9Z-A1 Overview Dimensions (mm) •HS1E HS1E(Actuator Retention 1500N) withMS indicator - using 1500NForce operating force 5 5.5 Mounting Hole Layout Note: Plug the unused actuator entry slot using the slot plug supplied with the interlock switch. MS (Actuator Retention Force 2000N) Accessories Horizontal Mounting(mainly for sliding104 Straight Actuator doors) HS9Z-A1 29.2 43 40 22 22 65.8 (RP) Actuator Cover (red) Actuator Cover HS9Z-A1S Actuator Rubber Bushings Actuator Cover HS9Z-A2S Actuator Rubber Bushings 11.5 17.5±0.5 51.3 (RP) 89 2 4.1 21 ±0.5 4.1 12.3 .2 R3 Holes 2 89 For HS1/HS2 Series (HS9Z-A3) 40 35 4 angle is adjustable (0˚ to 20˚) for hinged doors. 45 63 26 36 3-M5 Screw Mounting Hole Layout (Note) Actuator Stop Film (attached) 58 Light Curtains 29.2 5 5.5 • The minimum radius of the door opening can be as Note: Plug the unused actuator entry slot using the slot plug supplied with the interlock switch. small as 100mm. 18 44 58 72 70.3 (RP) 51 49.5 2 7.5 4 1 ° 1.5 7.4 41.5 Safety Control Relays 19.2 22 61 *After installing the actuator, Actuator remove the actuator Mounting cover. Actuator Cover (red) 11.5 90 Adjustable Actuator Slot Plug • The actuator (supplied) (Note) 21 5 RP: Actuator Mounting Reference Position 2-M6 Screws 7.4 (3.5 ±0.5 ) 55.8 (RP) 2-M5 Actuator Mounting Holes 20 11 23.5 26 121 129 40 22 22 Actuator Mounting Holes (8.0) 7.0 ±0.5 10 Vertical Mounting Right-angle Actuator (mainly for hinged doors) HS9Z-A2 Right-angle Actuator HS9Z-A2S 49.3 19.3 1 10 45.4 39.2 2-M6 Screws 9 • Actuator Mounting Reference Position (RP) As shown in the figure below, the mounting reference position of the actuator when inserted in the interlock switch is: .2 The actuator cover touches the interlock switch lightly. 5 2 R3 After mounting the actuator, remove the actuator cover from the actuator switch. 20 Door hinge Actuator Cover Actuator Actuator Door Stop 800-262-IDEC (4332) • USA & Canada 30 20° Actuator Cover Actuator Mounting Holes 2 Interlock Switch 33 max. 12 (21) 1 Interlock Switch 2-M6 Screws AS-Interface Safety at Work Angle Adjustment Screw (M3 hexagon socket head screw) Door Stop All dimensions in mm. Enabling Switches 88 33 R3 .2 29.2 43 Straight Actuator HS9Z-A1S 4 23.5 • HS1E- 319 Solenoid Locking Safety Switches HS1E Overview Accessories, continued Minimum Radius of Hinged Door • When using the interlock switch for a hinged door, refer to the minimum radius of doors shown below. For the doors with small minimum radius, use angle adjustable actuators (HS9ZA3 or HS9Z-A3S). • When the door hinge is on the extension line of the interlock switch surface: Note: Because deviation or dislocation of hinged door may occur in actual applications, make sure of the correct operation before installation. HS9Z-A2 Actuator M in im um M50 m R in m ad im iu u s 50 m m Rad m iu s • When the door hinge is on the extension line of the interlock switch surface: Door Hinge s s adiu adiu mR mR imu imu Min mm Min mm 230 230 s s adiu adiu mR mR imu imu Min mmMin mm 130 130 • When the door hinge is on the extension line of the actuator mounting HS9Z-A3/A3S surface: Actuator HS9Z-A3/A3S Actuator Door Hinge • When the door hinge is on the extension line of the actuator mounting HS9Z-A2 surface: Actuator M in im 8 um M 0m R in m ad im iu s 80 um m Ra m di us HS9Z-A2 Actuator Door Hinge s s adiu adiu mR mR imu imu Min mmMin mm 400 400 s s adiu adiu mR mR imu imu Min 0 mmMin 0 mm 24 24 Enabling Switches Interlock Switches XW Series E-Stops When using the HS9Z-A3 Angle Adjustable (vertical) Actuator AS-Interface Safety at Work Light Curtains Safety Control Relays Door Hinge 320 www.IDEC.com
HS9Z-A1 价格&库存
很抱歉,暂时无法提供与“HS9Z-A1”相匹配的价格&库存,您可以联系我们找货
