HW1B-M4F10-R
HW1B-M4F10-R
    IDEC(日本和泉)
HW1B-M4F10-R 数据手册
HW_Front Page 1 Tuesday, November 16, 2004 4:40 PM ø22mm HW Series Control Units HW_Selection Page 2 Tuesday, November 16, 2004 4:36 PM ø22 HW Series Control Units (Selection Guide) Function Category Emergency Stop Switch (Unibody Type) Emergency Stop Switch (Separate Type) Pushlock Turn Reset ø29mm Mushroom ø40mm Mushroom ø60mm Mushroom ø40mm Mushroom ø40mm Mushroom HW1E-BV4 9 HW1E-LV4 10 HW1B-V3 11 Pushlock Key Reset ø40mm Mushroom Emergency Stop Switch Push Pull ø40mm Mushroom Pushlock Turn Reset ø40mm EMO Type HW1B-X4 HW1B-Y2 HW1B-V∗∗R-EMO Page 12 12 14 ø29mm Mushroom ø40/60mm Mushroom Shape Type Page Function Category HW1B-V4 11 HW1B-V5 11 Pushbutton Flush Extended Momentary/Maintained Shape Function Category HW1B-M1 HW1B-A1 15 HW1B-M2 HW1B-A2 15 Pushbutton Square Flush Momentary/Maintained Square Extended Flush HW2B-M1 HW2B-A1 HW2B-M2 HW2B-A2 HW3B-M1 HW3B-A1 16 16 17 Shape Type HW1B-M3 HW1B-A3 Page 15 Function Category HW1B-M4 HW1B-A4 HW1B-M5 15 Pushbutton Round Extended ø29mm Mushroom w/Square Bezel w/Square Bezel Momentary/Maintained Pilot Light (LED/Incandescent) Flush (Marking) Extended (Dome) Square Flush (Marking) HW1P-1 HW1P-2 HW2P-1 18 18 18 Shape Type Page Function Category HW3B-M2 HW3B-A2 17 Flush HW3B-M3 HW3B-A3 17 Illuminated Pushbutton (LED/Incandescent) Extended Extended w/Full Shroud Square Flush (Marking) Flush w/Square Bezel Shape Type Page 2 HW1L-M1 HW1L-A1 19 HW1L-M2 HW1L-A2 20 HW1L-MF2 HW1L-AF2 21 HW2L-M1 HW2L-A1 22 HW3L-M1 HW3L-A1 23 HW_Selection Page 3 Tuesday, November 16, 2004 4:36 PM HW Series Control Units (Selection Guide) ø22 Function Category Illuminated Pushbutton Switch (LED/Incandescent) ø29mm Mushroom ø29mm Mushroom ø40mm Mushroom w/ Square Bezel Illuminated Selector Switch (LED/Incandescent) Shape Type Page Function Category HW1L-M3 HW1L-A3 24 HW3L-M3 HW3L-A3 25 Selector Switch Selector Key HW1S 28 HW1K 29 HW1L-M4 HW1L-A4 26 Pushbutton Selector HW1F 30 Mono-Lever Switch Standard Interlocking Shape Type Page Function Category Control Box w/Pushbutton w/Selector Switch HW1X-BM 48 HW1X-S 48 HW1R 37 HW1M 38 HW1M-L 38 Emergency Stop Control Box w/Pushlock Turn w/Pushlock Key Reset Switch Reset Switch Shape Type Page HW1X-BV 48 HW1X-BX 48 Safety Lever Lock HW9Z-LS Every HW series control unit, except for pilot lights and unibody type emergency stop switches, is supplied with the HW9Z-LS safety lever lock. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from unlocking contacts. 3 HW_Spec/Ordering Page 4 Tuesday, November 9, 2004 2:42 PM ø22 HW Series Control Units Complete with IP20 finger-safe contact blocks Ensure safety and save wiring time • The locking lever removable contact block features spring-up screw terminals. • Self-cleaning rolling action contacts have a raked contact surface. • Degree of protection: IP65 • A wide range of operating voltages for worldwide application • UL, CSA approved, and EN compliant Safety Standards File No. or Organization UL UL Listing File No. E68961 CSA File No. LR92374 EN EN60947-1 EN60947-5-1 TÜV Rheinland R9551089 Specifications and Ratings Contact Ratings Pushbuttons Illuminated Pushbuttons Selector Switches Illuminated Selector Switches Pushbutton Selectors Contact Block Rated Insulation Voltage Rated Continuous Current Contact Ratings by Utilization Category IEC 60947-5-1 Type HW-G (HW series) 600V 10A AC-15 (A600) DC-13 (P600) Characteristics • Contact Ratings by Utilization Category Operational Voltage AC-12 Control of resistive loads and solid state loads AC Operational 50/60 Hz AC-15 Control of electromagnetic loads (> 72 VA) Current DC-12 Control of resistive loads and solid state loads DC DC-13 Control of electromagnets 24V 10A 10A 8A 4A 48V — — 4A 2A 50V 10A 7A — — 110V 10A 5A 2.2A 1.1A 220V 6A 3A 1.1A 0.6A 440V 2A 1A — — Note: The operational current represents the classification by making and breaking currents (IEC 60947-5-1). Minimum applicable load: 3V AC/DC, 5 mA (applicable range may vary with operating conditions and load types) For the control units listed below, the rated current (load switching current) is reduced to a half of the rated operational current of the contact block. The rated insulation voltage (600V) and the rated thermal current (10A) remain unchanged. • 3-position selector switches which contain J or S following 3 in the Type No. and which have cam code J or S. Example: HW1S-3JT21N1 • All 4-position and 5-position selector switches • All mono-lever switches • All pushbutton selectors HW-G Contact Block Transformer Unit • Finger-safe terminal Compliant to VDE 0106 Part 100 • Snap-fit latch • Double-break rolling action silver contacts with raked surface • Housing in different colors for NO and NC contact. • Insertion from two directions • Ring or fork connectors can also be used. • Push rod Color-coded for different contacts • Spring-up terminal is ready for wiring. Screw is held captive. • Contact Block Types Type No. Contact Housing Push Rod 4 HW-G10 NO Blue Green HW-G01 NC Purple red Red HW-G10R NO (early make) Blue Black HW-G01R NC (late break) Purple red White • Finger-safe spring-up terminal • Wires can be inserted from three directions. HW_Spec/Ordering Page 5 Tuesday, November 9, 2004 2:42 PM HW Series Control Units ø22 LED Illuminated Unit Specifications Unit Color Code ➁ Input Type Full Voltage Pilot Light Illuminated Pushbutton Illuminated Selector Switch A: G: PW: R: S: W: Y: amber green pure white red blue white yellow Transformer DC-DC Converter Operating Voltage 6V AC/DC 12V AC/DC 24V AC/DC 100/110V AC/DC 115/120V AC/DC 200/220V AC/DC 230/240V AC/DC 380V AC/DC 400/440V AC/DC 480V AC/DC (50/60 Hz) 110V DC Lamp Base LED Lamp Type No. Voltage LSTD-6➁ 6V AC/DC ±10% LSTD-1➁ 12V AC/DC ±10% LSTD-2➁ 24V AC/DC ±10% BA9S/13 LSTD-6➁ 6V AC/DC ±10% LSTD-6➁ 6V AC/DC ±10% Incandescent Illuminated Unit Specifications Unit Color Code ➁ Input Type Full Voltage Pilot Light Illuminated Pushbutton Illuminated Selector Switch A: G: R: S: W: amber green red blue white Transformer Operating Voltage 6V AC/DC 12V AC/DC 24V AC/DC 100/110V AC/DC 115/120V AC/DC 200/220V AC/DC 230/240V AC/DC 380V AC/DC 400/440V AC/DC 480V AC/DC (50/60 Hz) Lamp Base Incandescent Lamp Type No. Rating LS-6 1W (6.3V) LS-8 1W (18V) LS-3 1W (30V) BA9S/13 LS-6 1W (6.3V) LED Lamp Ratings (LSTD Type) LSTD-6➁ LSTD-1➁ LSTD-2➁ BA9S/13 6V AC/DC 12V AC/DC 24V AC/DC 6V AC/DC ±10% 12V AC/DC ±10% 24V AC/DC ±10% A, R, W, Y: 17 mA AC 11 mA 11 mA G, PW, S: 8 mA Current Draw A, R, W, Y: 14 mA DC 10 mA 10 mA G, PW, S: 5.5 mA Color Code A (amber), G (green), PW (pure white), R (red), S (blue), W (white), Y (yellow) Lamp Base Color Same as illumination color Voltage Marking Die stamped on the base Approx. 50,000 hours Life (reference value) (The luminance reduces to 50% the initial intensity when used on complete DC.) A, R, W, Y A, R, W, Y Type No. Lamp Base Rated Voltage Voltage Range Internal Circuit G, PW, S LED Chip Protection Diode Zener Diode Incandescent Lamp Ratings (LS Type) Type No. Lamp Base Rated Voltage Wattage Voltage Marking LS-6 LS-8 LS-2 BA9S/13 6V AC/DC 12V AC/DC 18V AC/DC 1W (6.3V) 1W (18V) 1W (24V) Die stamped on the base Approx. 1,000 hours minimum Life (reference value) (mean value when used on the rated voltage) LS-3 24V AC/DC 1W (30V) 5 HW_Spec/Ordering Page 6 Tuesday, November 9, 2004 2:42 PM ø22 HW Series Control Units Specifications Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance Dielectric Strength Vibration Resistance Shock Resistance Mechanical Life (minimum operations) Electrical Life (minimum operations) –25 to +60°C (no freezing) Illuminated units: –25 to +50°C –40 to +80°C 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts: 2,500V AC, 1 minute (Full voltage type illuminated units: 2,000V AC, 1 minute) Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Damage limits: 1,000 m/s2 Operating extremes: 100 m/s2 Pushbuttons, Illuminated pushbuttons Momentary: 5,000,000 Maintained: 500,000 Selector switches: 500,000 Key selector switches: 500,000 Illuminated selector switches: 500,000 Pushbutton selectors: 250,000 Mono-lever switches: 250,000 Pushbuttons, Illuminated pushbuttons: 500,000 ∗1 Selector switches: 500,000 ∗2 Key selector switches: 500,000 ∗2 Illuminated selector switches: 500,000 ∗2 Pushbutton selectors: 250,000 ∗2 Mono-lever switches: 250,000 ∗3 ∗1 Switching frequency 1,800 operations/h, duty ratio 40% ∗2 Switching frequency 1,200 operations/h, duty ratio 40% ∗3 Switching frequency 900 operations/h, duty ratio 40% Degree of Protection Unit NEMA ICS 6-110 Type 1, 2, 3, 3R, (3S), 4, 5, 12,13 All units IEC 60529 IP65 Mounting Hole Layout R0.8 maximum +0.2 0 +0.4 0 ∗3.2 +0 . 0 4 50 (∗1) (45 minimum) 24.1 ø22 .3 30 (∗2) ∗ The 3.2 mm recess is for preventing rotation and is not necessary when the nameplate or anti-rotation ring is not used. 6 The minimum mounting centers are applicable to switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers in consideration of convenience for wiring. • Minimum Mounting Centers Unit ø40mm mushroom button Pilot light Pushbutton selector Mono-lever switch ∗1 50 mm 30 mm 50 mm 72 mm ∗2 40 mm 30 mm 50 mm 72 mm Note: When using the safety lever lock, determine the vertical spacing (*1) in consideration of convenience for installing and removing the safety lever lock. Recommended vertical spacing: 100 mm HW_Spec/Ordering Page 7 Tuesday, November 9, 2004 2:42 PM HW Series Control Units (Ordering Information) ø22 Ordering Information The Type No. development charts shown below can be used to specify control units other than those listed on the following pages. Gold-plated silver contacts are also available. Emergency Stop Switches For emergency stop purposes, these switches must contain at least one NC contact block. HW1B-V4 11 R -MAU Optional contact MAU: Gold-plated silver contact Button/lens color code Contact arrangement code 01: 1NC 11: 1NO-1NC 02: 2NC 21: 2NO-1NC 12: 1NO-2NC 03: 3NC 31: 3NO-1NC 22: 2NO-2NC 13: 1NO-3NC 04: 4NC Note: Push-pull type HW1B-Y2 can have a maximum of two contact blocks. Pushbuttons HW1B-M1 11 R -MAU Optional contact MAU: Gold-plated silver contact Button color code Contact arrangement code 10: 1NO 01: 1NC 11: 1NO-1NC 20: 2NO 02: 2NC 21: 2NO-1NC 12: 1NO-2NC 30: 3NO 03: 3NC 31: 3NO-1NC 22: 2NO-2NC 13: 1NO-3NC 40: 4NO 04: 4NC Pilot Lights HW1P-1 H 2 R Lens color code Lamp code 0: Without lamp 2: LED (6V: LSTD) 3: LED (12V: LSTD) 4: LED (24V: LSTD) 5: Incandescent (6V: LS-6) 6: Incandescent (12V: LS-8) 7: Incandescent (24V: LS-3) Operating voltage code Q: Full voltage H: Transformer (100/110V AC) H2: Transformer (115/120V AC) M: Transformer (200/220V AC) M4: Transformer (230/240V AC) S: Transformer (380V AC) T: Transformer (400/440V AC) T8: Transformer (480V AC) D: DC-DC converter (110V DC) Illuminated Pushbuttons HW1L-M1 11 H 2 R -MAU Optional contact MAU: Gold-plated silver contact Lens color code Lamp code 0: Without lamp 2: LED (6V: LSTD) 3: LED (12V: LSTD) 4: LED (24V: LSTD) 5: Incandescent (6V: LS-6) 6: Incandescent (12V: LS-8) 7: Incandescent (24V: LS-3) Operating voltage code Q: Full voltage H: Transformer (100/110V AC) H2: Transformer (115/120V AC) M: Transformer (200/220V AC) M4: Transformer (230/240V AC) S: Transformer (380V AC) T: Transformer (400/440V AC) T8: Transformer (480V AC) D: DC-DC converter (110V DC) Contact arrangement code 10: 1NO 01: 1NC 11: 1NO-1NC 20: 2NO 02: 2NC 21: 2NO-1NC 12: 1NO-2NC 30: 3NO 03: 3NC 31: 3NO-1NC 22: 2NO-2NC 13: 1NO-3NC 40: 4NO 04: 4NC Note: Full voltage type is not supplied with a lamp. Transformer and DC-DC converter types contain an LED lamp (LSTD-6➁) or incandescent lamp (LS-6). Transformer and DC-DC converter types can have two or four contact blocks only. Selector Switches HW1S-3 S T 22N9 -MAU Optional contact MAU: Gold-plated silver contact Contact code Knob operator Cam code J S (none) Note: Full voltage type is not supplied with a lamp. Transformer and DC-DC converter types contain an LED lamp (LSTD-6➁) or incandescent lamp (LS-6). 7 HW_Spec/Ordering Page 8 Tuesday, November 9, 2004 2:42 PM ø22 HW Series Control Units (Ordering Information) Key Selector Switches HW1K-2 A 11 - 1H -MAU Optional contact MAU: Gold-plated silver contact Different key number 1H 2H 3H Key removal position code 2-position A: Removable in all positions B: Removable in left only C: Removable in right only 3-position A: Removable in all positions B: Removable in left and center C: Removable in right and center D: Removable in center only E: Removable in right and left G: Removable in left only H: Removable in right only Note: Key is not removable from spring-return positions. Illuminated Selector Switches HW1F-2 11 H 2 R -MAU Optional contact MAU: Gold-plated silver contact Lens color code Lamp code 0: Without lamp 2: LED (6V: LSTD) 3: LED (12V: LSTD) 4: LED (24V: LSTD) 5: Incandescent (6V: LS-6) 6: Incandescent (12V: LS-8) 7: Incandescent (24V: LS-3) Operating voltage code Q: Full voltage H: Transformer (100/110V AC) H2: Transformer (115/120V AC) M: Transformer (200/220V AC) M4: Transformer (230/240V AC) S: Transformer (380V AC) T: Transformer (400/440V AC) T8: Transformer (480V AC) Note: Full voltage type is not supplied with a lamp. Transformer type contains an LED lamp (LSTD-6➁) or incandescent lamp (LS-6). Pushbutton Selectors HW1R-2 D 22N1 B -MAU Optional contact MAU: Gold-plated silver contact Button color code Contact code Circuit category Mono-Lever Switches HW1M - 1111 22N9 -MAU Optional contact MAU: Gold-plated silver contact Contact code Lever operation mode 8 HW_E-stop Page 9 Tuesday, November 9, 2004 1:56 PM HW Series Emergency Stop Switches ø22 Emergency Stop Switches (Unibody Type) Specifications Contact Ratings Rated Insulation Voltage (Ui) 250V Rated Thermal Current (Ith) 10A Rated Operational Voltage (Ue) 24V Resistive Load (AC-12) 6A AC Rated 50/60 Hz Inductive Load (AC-15) 6A Operational Resistive Load (DC-12) 6A Current DC Inductive Load (DC-13) 1.5A 110V 3A 3A 2A 0.3A 220V 3A 3A 1A 0.15A Note: The operational current represents the classification by making and breaking currents (IEC 60947-5-1). Minimum applicable load (reference value): 3V AC/DC, 5 mA (Applicable range may vary with operating conditions and load types.) LED Lamp Ratings Unit Rated Operating Voltage 6V AC/DC 12V AC/DC 24V AC/DC Specifications LED Lamp Type No. Rated Voltage LSTD-6R LSTD-1R LSTD-2R 6V AC/DC ±10% 12V AC/DC ±10% 24V AC/DC ±10% Incandescent Lamp Ratings Unit Rated Operating Voltage 6V AC/DC 12V AC/DC 24V AC/DC Rated Current 14 mA 10 mA 10 mA Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance Dielectric Strength Incandescent Lamp Type No. Wattage LS-6 LS-8 LS-3 1W (6.3V) 1W (18V) 1W (30V) Vibration Resistance Shock Resistance Operating Frequency Life Degree of Protection Terminal Style –25 to +60°C (no freezing) Illuminated units: –25 to +50°C –40 to +80°C 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts Contacts: 2,500V AC, 1 minute Illuminated parts: 1,000V AC, 1 minute Damage limits: 60 m/s2 Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Damage limits: 1,000 m/s2 Operating extremes: 100 m/s2 900 operations/h Mechanical: 250,000 operations minimum Electrical: 100,000 operations minimum (at 900 operations/h, duty ratio 40%) IP65 M3.5 screw Applicable Standards and Approvals Safety Standards UL508 CSA C22.2 No. 14 EN60947-5-5 File No. or Organization UL Listing File No. E55996 c-UL (File No. E55996) DEMKO approved Pushlock Turn Reset Switches (Unibody Type) Shape ø40mm Mushroom Pushlock Turn Reset HW1E-BV4 Contact 1NO-1NC Type No. Button Color HW1E-BV411R Red only 2NC HW1E-BV402R • When pressed, the button is held depressed. The button is released by turning clockwise. • Terminal cover HW-VL7 is supplied with the switch. 9 HW_E-stop Page 10 Tuesday, November 9, 2004 1:56 PM ø22 HW Series Emergency Stop Switches Illuminated Pushlock Turn Reset Switches (Unibody Type) Shape ø40mm Mushroom Pushlock Turn Reset HW1E-LV4 Lamp Contact 1NO-1NC Type No. Lens Color HW1E-LV411Q0R Without Lamp Red only 2NC HW1E-LV402Q0R • When pressed, the button is held depressed. The button is released by turning clockwise. • The illuminated pushlock turn reset switch does not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. • Terminal cover HW-VL7 is supplied with the switch. Dimensions • HW1E-BV4 Panel Thickness 0.8 to 6 Gasket M3.5 Terminal Screw ø40 Locking Ring TOP Marking Terminal Cover 11.5 14 46 32 48 • HW1E-LV4 Panel Thickness 0.8 to 6 M3.5 Terminal Screw Gasket Locking Ring ø40 TOP Marking M3.5 Terminal Screw Lamp Terminal Terminal Cover 11.5 14 32 61 All dimensions in mm. 63 Mounting Hole Terminal Arrangement (Bottom View) • HW1E-BV4 R0.8 max. 3.2 .3 +0 .4 0 • HW1E-LV4 TOP Side X1 24.1 +0.4 0 ø22 +0.2 0 .2 (NC) .1 (NC) .3 (NO) LAMP .2 (NC) .3 (NO) .1 (NC) .4 (NO) .4 (NO) Determine the minimum mounting hole centers in consideration of convenience for wiring. (1NO-1NC) X2 (1NO-1NC) Replacement Parts Name Terminal Cover 10 Type No. HW-VL7 Ordering Type No. HW-VL7PN10 Package Quantity 10 Remarks Used on HW1E emergency stop switches for preventing electrical shocks. The HW-VL7 terminal cover is supplied with the HW1E. HW_E-stop Page 11 Tuesday, November 9, 2004 1:56 PM HW Series Emergency Stop Switches ø22 Emergency Stop Switches (Separate Type) Specifications Contact Ratings Contact Block Specifications Rated Insulation Voltage Rated Continuous Current Contact Ratings by Utilization Category IEC 60947-5-1 600V 10A AC-15 (A600) DC-13 (P600) Operating Temperature Storage Temperature Operating Humidity Contact Resistance Insulation Resistance Characteristics • Contact Ratings by Utilization Category Operational Current Operational Voltage AC-12 Control of resistive loads and solid state loads AC 50/60 Hz AC-15 Control of electromagnetic loads (> 72 VA) DC-12 Control of resistive loads and solid state loads DC DC-13 Control of electromagnets Dielectric Strength 24V 48V 50V 110V 220V 440V 10A — 10A 10A 6A 2A 10A — 7A 5A 3A 1A Vibration Resistance Shock Resistance 8A 4A — 2.2A 1.1A — 4A 2A — 1.1A 0.6A — Operating Frequency 900 operations/h Life Applicable Standards and Approvals Safety Standards UL CSA C22.2 No. 14 EN60947-1 EN EN60947-5-1 File No. or Organization UL Listing File No. E68961 File No. LR92374 –25 to +60°C (no freezing) –40 to +80°C 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts Between terminals of different poles Between terminals of the same pole 2,500V AC, 1 minute Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Damage limits: 1,000 m/s2 Operating extremes: 100 m/s2 Degree of Protection Terminal Style Mechanical: 500,000 operations minimum (push-pull: 250,000 operations) Electrical: 500,000 operations minimum (push-pull: 250,000 operations) (at 900 operations/h, duty ratio 40%) IP65 M3.5 screw TÜV Rheinland R9551089 Pushlock Turn Reset Switches (Separate Type) Shape ø29mm Mushroom Pushlock Turn Reset HW1B-V3 ø40mm Mushroom Pushlock Turn Reset HW1B-V4 ø60mm Mushroom Pushlock Turn Reset HW1B-V5 Contact Type No. Button Color 1NC HW1B-V301➀ 1NO-1NC HW1B-V311➀ 2NC HW1B-V302➀ 2NO-2NC HW1B-V322➀ 1NC HW1B-V401➀ 1NO-1NC HW1B-V411➀ Specify a button color code in place of ➀ in the Type No. 2NC HW1B-V402➀ R: red Y: yellow 2NO-2NC HW1B-V422➀ 1NC HW1B-V501➀ 1NO-1NC HW1B-V511➀ 2NC HW1B-V502➀ 2NO-2NC HW1B-V522➀ • Yellow buttons cannot be used as emergency stop switches in compliance with EN standards. • When pressed, the button is held depressed. The button is released by turning clockwise. • Pushlock turn reset switches with one or three contact blocks contain a dummy block. • Safety lever lock HW9Z-LS is supplied with the switch. • Other contact arrangements and gold-plated silver contacts are also available. See page 7. 11 HW_E-stop Page 12 Tuesday, November 9, 2004 1:56 PM ø22 HW Series Emergency Stop Switches Pushlock Key Reset Switches (Separate Type) Shape ø40mm Mushroom Pushlock Key Reset HW1B-X4 Contact Type No. 1NC HW1B-X401R 1NO-1NC HW1B-X411R 2NC HW1B-X402R 2NO-2NC HW1B-X422R Button Color Red only • When pressed, the button is held depressed. The button is released by turning the key clockwise. • Pushlock key reset switches with one or three contact blocks contain a dummy block. • Two identical keys and safety lever lock HW9Z-LS are supplied with the switch. • Other contact arrangements and gold-plated silver contacts are also available. See page 7. Push-Pull Switches (Separate Type) Shape ø40mm Mushroom Push-Pull (2-position) HW1B-Y2 Contact Type No. Button Color HW1B-Y201➀ 1NC 1NO-1NC HW1B-Y211➀ Specify a button color code in place of ➀ in the Type No. R: red Y: yellow HW1B-Y202➀ 2NC • The button is maintained at either pulled or depressed position. • Push-pull switches are available with one or two contact blocks. • Push-pull switches with one contact block contain a dummy block. • Safety lever lock HW9Z-LS is supplied with the switch. Accessory Nameplate Shape Name HWAV-0 ø 60 Legend 1.5 0.9 HWAV-27 Package Quantity Remarks 1 Background: Yellow Legend: Black Applicable panel thickness: 0.8 to 4.5 mm Material: Polyamide Not applicable for ø60mm mushroom buttons. Legend “EMERGENCY STOP” is indicated outside a ø44mm circle. (blank) Nameplate for Emergency Stop Switch ø2 2 12 Type No. EMERGENCY STOP HW_E-stop Page 13 Tuesday, November 9, 2004 1:56 PM HW Series Emergency Stop Switches ø22 Dimensions • ø29mm Pushlock Turn Reset HW1B-V3 Panel Thickness 0.8 to 6 Gasket Terminal Screw M3.5 LO CK ø29 41.4 25 Locking Ring 1 contact block 49.4 (1 or 2 blocks) 2 contact blocks 4 contact blocks 13 69.4 (4 blocks) • ø40mm Pushlock Turn Reset 29.4 32 • ø60mm Pushlock Turn Reset HW1B-V4 HW1B-V5 LO ø40 41.4 ø60 25 CK 13 29.4 15 32 34.5 • ø40mm Pushlock Key Reset • ø40mm Push-Pull HW1B-X4 HW1B-Y2 LO CK CK 41.4 ø40 ø40 41.4 25 25 LO 13 13 29.4 32 29.4 32 49.4 All dimensions in mm. Mounting Hole R0.8 max. 3.2 +0 . 0 4 +0.2 0 24.1 +0.4 0 ø22 .3 The minimum mounting centers shown below are applicable to emergency stop switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers in consideration of convenience for wiring. • Minimum Mounting Centers for Emergency Stop Switches Unit HW1B-V3 HW1B-V4 HW1B-X4 HW1B-Y2 HW1B-V5 Vertical Spacing Horizontal Spacing 50 mm 50 mm 60 mm 60 mm Note: When using the safety lever lock, determine the vertical spacing in consideration of convenience for installing and removing the safety lever lock. Recommended vertical spacing: 100 mm For emergency stop control boxes, see page 48. 13 HW_E-stop Page 14 Tuesday, November 9, 2004 1:56 PM ø22 HW Series Emergency Stop Switches EMO Pushbuttons EMO is an abbreviation of Emergency Off. Used for emergency stop according to SEMI standards. Shape Contact ø40mm EMO Pushbuttons HW1B-V4∗∗R-EMO Type No. 1NC HW1B-V401R-EMO 1NO-1NC HW1B-V411R-EMO 2NC HW1B-V402R-EMO 2NO-2NC HW1B-V422R-EMO Button Color Red only (Legend: White) Dimensions LOC K Locking Ring Lock Lever 0 20 49.4 (1 or 2 blocks) 69.4 (4 blocks) 13 41.4 25 26.5 ø4 29.4 All dimensions in mm. 32 SEMI Standard Compliant Switch Guards (For ø22mm mounting hole) • SEMI S2-0200 12.5.1 Compliant • Dimensions • Installation 38 22 64 48 TOP Marking 80 32 • Type No.: HW9Z-KG1 • Degree of Protection: IP65 • Color: Yellow Not applicable for ø60mm mushroom buttons. TOP Marking Locking Ring Operator 2 ø2 Gasket Panel Thickness: 1.2 to 4 • SEMATECH Application Guide for SEMI S2-93, 12.4 Compliant • Dimensions • Installation 36.5 ø2 TOP Marking ø76.1 2 2. • Type No.: HW9Z-KG2 • Degree of Protection: IP65 • Color: Yellow ø90 Not applicable for ø60mm mushroom buttons. TOP Marking Locking Ring Operator Panel Thickness: 1.2 to 4 • EMO Sticker • Type No.: HW9Z-EMO-NPP • Package Quantity: 10 • Color: Yellow with red letter 20 50 E MO Caution International industrial standards such as European Union Directive, IEC60204-1, and JIS B9960-1 require that emergency stop switches must be installed in the manner in which the operator can access and operate the switches easily, and prohibit the use of switch guards. The HW9Z-KG1 and HW9Z-KG2 switch guards are used for the emergency stop switches installed on semiconductor manufacturing equipment only. Do not use the switch guards for emergency stop switches installed on machine systems such as machine tool and food processing systems. 14 HW_PB Page 15 Tuesday, November 9, 2004 1:12 PM HW Series Pushbuttons ø22 Flush / Extended / Mushroom Types Momentary Maintained ø40mm Mushroom HW1B-M4 HW1B-A4 Momentary Maintained ø60mm Mushroom HW1B-M5 1NO-1NC HW1B-M511➀ Momentary 2NO HW1B-M520➀ 2NC HW1B-M502➀ 49.4 (1 or 2 blocks) 69.4 (4 blocks) 41.4 13 29.4 M3.5 Terminal Screw Panel Thickness 0.8 to 6 Locking Ring LO CK Specify a button color code in place of ➀ in the Type No. B: G: R: S: W: Y: 41.4 HW1B-M501➀ 25 1NC 3.6 ø2 25 HW1B-M510➀ ø29 1NO CK 13 49.4 (1 or 2 blocks) 29.4 19 69.4 (4 blocks) black green red blue white yellow M3.5 Terminal Screw Panel Thickness 0.8 to 6 Locking Ring LO CK 41.4 ø29mm Mushroom HW1B-M3 HW1B-A3 LO 13 49.4 (1 or 2 blocks) 29.4 23.2 69.4 (4 blocks) M3.5 Terminal Screw Locking Ring Panel Thickness 0.8 to 6 LO CK 41.4 Maintained Panel Thickness 0.8 to 6 Locking Ring 25 Momentary M3.5 Terminal Screw 25 Extended HW1B-M2 HW1B-A2 HW1B-M110➀ HW1B-M101➀ HW1B-M111➀ HW1B-M120➀ HW1B-M102➀ HW1B-M122➀ HW1B-A110➀ HW1B-A101➀ HW1B-A111➀ HW1B-A120➀ HW1B-A102➀ HW1B-A122➀ HW1B-M210➀ HW1B-M201➀ HW1B-M211➀ HW1B-M220➀ HW1B-M202➀ HW1B-M222➀ HW1B-A210➀ HW1B-A201➀ HW1B-A211➀ HW1B-A220➀ HW1B-A202➀ HW1B-A222➀ HW1B-M310➀ HW1B-M301➀ HW1B-M311➀ HW1B-M320➀ HW1B-M302➀ HW1B-M322➀ HW1B-A310➀ HW1B-A301➀ HW1B-A311➀ HW1B-A320➀ HW1B-A302➀ HW1B-A322➀ HW1B-M410➀ HW1B-M401➀ HW1B-M411➀ HW1B-M420➀ HW1B-M402➀ HW1B-M422➀ HW1B-A410➀ HW1B-A401➀ HW1B-A411➀ HW1B-A420➀ HW1B-A402➀ HW1B-A422➀ Dimensions (mm) ø29 Maintained 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC ➀ Button Color Code ø23.6 Momentary Type No. ø29 Flush HW1B-M1 HW1B-A1 Contact ø40 Operation Type 13 29.4 49.4 (1 or 2 blocks) 23.2 69.4 (4 blocks) M3.5 Terminal Screw Locking Ring Panel Thickness 0.8 to 6 Specify a button color code in place of ➀ in the Type No. ø60 Shape B: black G: green R: red 2NO-2NC HW1B-M522➀ 15 49.4 (1 or 2 blocks) 30 69.4 (4 blocks) • Pushbuttons with one or three contact blocks contain a dummy block. • Other contact arrangements and gold-plated silver contacts are also available. See page 7. 15 HW_PB Page 16 Tuesday, November 9, 2004 1:12 PM ø22 HW Series Pushbuttons Square Flush / Square Extended Types Square Extended HW2B-M2 HW2B-A2 Momentary Maintained M3.5 Terminal Screw Locking Ring Panel Thickness 0.8 to 6 B: G: R: S: W: Y: black green red blue white yellow 49.4 (1 or 2 blocks) 13 16 2 contact blocks 4 contact blocks 24.8 69.4 (4 blocks) 29.4 M3.5 Terminal Screw Locking Ring Panel Thickness 0.8 to 6 13 49.4 (1 or 2 blocks) 19 69.4 (4 blocks) Terminal Wiring • Arrows indicate access directions for wiring. 1 contact block CK 29.6 Specify a button color code in place of ➀ in the Type No. • Pushbuttons with one or three contact blocks contain a dummy block. • Other contact arrangements and gold-plated silver contacts are also available. See page 7. Contact Block (Bottom View) LO 41.4 HW2B-M110➀ HW2B-M101➀ HW2B-M111➀ HW2B-M120➀ HW2B-M102➀ HW2B-M122➀ HW2B-A110➀ HW2B-A101➀ HW2B-A111➀ HW2B-A120➀ HW2B-A102➀ HW2B-A122➀ HW2B-M210➀ HW2B-M201➀ HW2B-M211➀ HW2B-M220➀ HW2B-M202➀ HW2B-M222➀ HW2B-A210➀ HW2B-A201➀ HW2B-A211➀ HW2B-A220➀ HW2B-A202➀ HW2B-A222➀ LO CK 29.6 Maintained 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC Dimensions (mm) 29.4 41.4 Momentary Type No. 25 Square Flush HW2B-M1 HW2B-A1 ➀ Button Color Code Contact 25 Operation Type 24.8 Shape HW_PB Page 17 Tuesday, November 9, 2004 1:12 PM HW Series Pushbuttons ø22 Round Button with Square Bezel Type Maintained ø29mm Mushroom with Square Bezel HW3B-M3 HW3B-A3 Momentary Maintained M3.5 Terminal Screw Panel Thickness 0.8 to 6 LO CK 29.6 41.4 25 Locking Ring 3.6 ø2 49.4 (1 or 2 blocks) 29.4 13 69.4 (4 blocks) Specify a button color code in place of ➀ in the Type No. Locking Ring Panel Thickness 0.8 to 6 LO CK black green red blue white yellow 29.6 41.4 B: G: R: S: W: Y: M3.5 Terminal Screw 13 49.4 (1 or 2 blocks) 29.4 19 69.4 (4 blocks) M3.5 Terminal Screw Locking Ring Panel Thickness 0.8 to 6 LO CK 29.6 Momentary HW3B-M110➀ HW3B-M101➀ HW3B-M111➀ HW3B-M120➀ HW3B-M102➀ HW3B-M122➀ HW3B-A110➀ HW3B-A101➀ HW3B-A111➀ HW3B-A120➀ HW3B-A102➀ HW3B-A122➀ HW3B-M210➀ HW3B-M201➀ HW3B-M211➀ HW3B-M220➀ HW3B-M202➀ HW3B-M222➀ HW3B-A210➀ HW3B-A201➀ HW3B-A211➀ HW3B-A220➀ HW3B-A202➀ HW3B-A222➀ HW3B-M310➀ HW3B-M301➀ HW3B-M311➀ HW3B-M320➀ HW3B-M302➀ HW3B-M322➀ HW3B-A310➀ HW3B-A301➀ HW3B-A311➀ HW3B-A320➀ HW3B-A302➀ HW3B-A322➀ 41.4 Round Extended with Square Bezel HW3B-M2 HW3B-A2 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC Dimensions (mm) 25 Maintained Type No. 25 Momentary ➀ Button Color Code Contact ø23.6 Round Flush with Square Bezel HW3B-M1 HW3B-A1 Operation Type ø29 Shape 13 29.4 49.4 (1 or 2 blocks) 23.2 69.4 (4 blocks) • Pushbuttons with one or three contact blocks contain a dummy block. • Other contact arrangements and gold-plated silver contacts are also available. See page 7. Contact Block (Bottom View) Terminal Wiring • Arrows indicate access directions for wiring. 1 contact block 2 contact blocks 4 contact blocks 17 HW_PL Page 18 Tuesday, November 9, 2004 2:41 PM ø22 HW Series Pilot Lights Round Flush / Dome / Square Flush Types Shape Round Flush HW1P-1 Lamp Input Type ➁ Lens/LED Color Code ➂ Operating Voltage Code Type No. Without Lamp Full Voltage HW1P-1Q0➁ Transformer HW1P-1➂2➁ LED DC-DC Converter∗ HW1P-1D2➁ (Photo: Full Voltage Type) Dome HW1P-2 Incandescent Transformer HW1P-1➂5➁ Without Lamp Full Voltage HW1P-2Q0➁ Transformer HW1P-2➂2➁ LED DC-DC Converter∗ HW1P-2D2➁ (Photo: Full Voltage Type) Square Flush HW2P-1 Incandescent Transformer HW1P-2➂5➁ Without Lamp Full Voltage HW2P-1Q0➁ Transformer HW2P-1➂2➁ LED DC-DC Converter∗ HW2P-1D2➁ (Photo: Transformer Type) Incandescent Transformer HW2P-1➂5➁ A: G: PW: R: S: W: Y: amber green pure white red blue white yellow A: G: R: S: W: amber green red blue white A: G: PW: R: S: W: Y: amber green pure white red blue white yellow A: G: R: S: W: amber green red blue white A: G: PW: R: S: W: Y: amber green pure white red blue white yellow A: G: R: S: W: amber green red blue white Specify an operating voltage code in place of ➂ in the Type No. H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC • Specify a lens/LED color code in place of ➁ in the Type No. • Specify an operating voltage code in place of ➂ in the Type No. • Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. • LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). • Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). ∗ DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). Dimensions Mounting Hole Layout • Close mounting on 30mm centers Degree of protection: IP65 • Full Voltage Type Panel Thickness 0.8 to 6 Gasket Locking Ring M3.5 Terminal Screw Flush Dome Square Flush Roound/Dome 9 ø2 3 . ø22 +0.4 0 X2 0.5 43.3 29.6 17.5 30 min. X1 7 • Transformer Type Flush M3.5 Terminal Screw Dome Square Flush Round/Dome 30 min. 9 X1 X2 24 ø2 60.8 29.6 17.5 7 29.6 • DC-DC Converter Type Flush M3.5 Terminal Screw Dome • When mounting transformer or DC-DC converter type units on 30mm centers vertically and horizontally, keep the ambient temperature below 40°C. Square Flush Round/Dome 9 X1 X2 29.6 18 24 ø2 76.2 7 17.5 29.6 All dimensions in mm. HW_IPB Page 19 Tuesday, November 9, 2004 1:21 PM HW Series Illuminated Pushbuttons ø22 Round Flush Illuminated Pushbutton Shape Round Flush HW1L-M1 HW1L-A1 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter∗ Incandescent Without Lamp Transformer Full Voltage Transformer Maintained LED DC-DC Converter∗ Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC Type No. HW1L-M110Q0➁ HW1L-M101Q0➁ HW1L-M111Q0➁ HW1L-M120Q0➁ HW1L-M102Q0➁ HW1L-M122Q0➁ HW1L-M111➂2➁ HW1L-M120➂2➁ HW1L-M102➂2➁ HW1L-M122➂2➁ HW1L-M111D2➁ HW1L-M120D2➁ HW1L-M102D2➁ HW1L-M122D2➁ HW1L-M111➂5➁ HW1L-M120➂5➁ HW1L-M102➂5➁ HW1L-M122➂5➁ 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC HW1L-A110Q0➁ HW1L-A101Q0➁ HW1L-A111Q0➁ HW1L-A120Q0➁ HW1L-A102Q0➁ HW1L-A122Q0➁ HW1L-A111➂2➁ HW1L-A120➂2➁ HW1L-A102➂2➁ HW1L-A122➂2➁ HW1L-A111D2➁ HW1L-A120D2➁ HW1L-A102D2➁ HW1L-A122D2➁ HW1L-A111➂5➁ HW1L-A120➂5➁ HW1L-A102➂5➁ HW1L-A122➂5➁ • Color Code and Operating Voltage Code LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: amber G: green PW: pure white R: red S: blue W: white Y: yellow Incandescent Illuminated Type ➂ Operating Voltage Code ➁ Lens Color Code Specify a lens color code in place of Specify an operating voltage code ➁ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). ∗ DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 19 HW_IPB Page 20 Tuesday, November 9, 2004 1:21 PM ø22 HW Series Illuminated Pushbuttons Round Extended Illuminated Pushbutton Shape Round Extended HW1L-M2 HW1L-A2 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter∗ Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter∗ Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC Type No. HW1L-M210Q0➁ HW1L-M201Q0➁ HW1L-M211Q0➁ HW1L-M220Q0➁ HW1L-M202Q0➁ HW1L-M222Q0➁ HW1L-M211➂2➁ HW1L-M220➂2➁ HW1L-M202➂2➁ HW1L-M222➂2➁ HW1L-M211D2➁ HW1L-M220D2➁ HW1L-M202D2➁ HW1L-M222D2➁ HW1L-M211➂5➁ HW1L-M220➂5➁ HW1L-M202➂5➁ HW1L-M222➂5➁ HW1L-A210Q0➁ HW1L-A201Q0➁ HW1L-A211Q0➁ HW1L-A220Q0➁ HW1L-A202Q0➁ HW1L-A222Q0➁ HW1L-A211➂2➁ HW1L-A220➂2➁ HW1L-A202➂2➁ HW1L-A222➂2➁ HW1L-A211D2➁ HW1L-A220D2➁ HW1L-A202D2➁ 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC HW1L-A222D2➁ HW1L-A211➂5➁ HW1L-A220➂5➁ HW1L-A202➂5➁ HW1L-A222➂5➁ • Color Code and Operating Voltage Code LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: amber G: green PW: pure white R: red S: blue W: white Y: yellow Incandescent Illuminated Type ➂ Operating Voltage Code ➁ Lens Color Code Specify a lens color code in place of Specify an operating voltage code ➁ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). ∗ DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 20 HW_IPB Page 21 Tuesday, November 9, 2004 1:21 PM HW Series Illuminated Pushbuttons ø22 Round Extended with Full Shroud Illuminated Pushbutton Shape Round Extended with Full Shroud HW1L-MF2 HW1L-AF2 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter∗ Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter∗ Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC Type No. HW1L-MF210Q0➁ HW1L-MF201Q0➁ HW1L-MF211Q0➁ HW1L-MF220Q0➁ HW1L-MF202Q0➁ HW1L-MF222Q0➁ HW1L-MF211➂2➁ HW1L-MF220➂2➁ HW1L-MF202➂2➁ HW1L-MF222➂2➁ HW1L-MF211D2➁ HW1L-MF220D2➁ HW1L-MF202D2➁ HW1L-MF222D2➁ HW1L-MF211➂5➁ HW1L-MF220➂5➁ HW1L-MF202➂5➁ HW1L-MF222➂5➁ HW1L-AF210Q0➁ HW1L-AF201Q0➁ HW1L-AF211Q0➁ HW1L-AF220Q0➁ HW1L-AF202Q0➁ HW1L-AF222Q0➁ HW1L-AF211➂2➁ HW1L-AF220➂2➁ HW1L-AF202➂2➁ HW1L-AF222➂2➁ HW1L-AF211D2➁ HW1L-AF220D2➁ HW1L-AF202D2➁ 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC HW1L-AF222D2➁ HW1L-AF211➂5➁ HW1L-AF220➂5➁ HW1L-AF202➂5➁ HW1L-AF222➂5➁ • Color Code and Operating Voltage Code LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: amber G: green PW: pure white R: red S: blue W: white Y: yellow Incandescent Illuminated Type ➂ Operating Voltage Code ➁ Lens Color Code Specify a lens color code in place of Specify an operating voltage code ➁ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). ∗ DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 21 HW_IPB Page 22 Tuesday, November 9, 2004 1:21 PM ø22 HW Series Illuminated Pushbuttons Square Flush Illuminated Pushbutton Shape Square Flush HW2L-M1 HW2L-A1 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter∗ Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter∗ Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC Type No. HW2L-M110Q0➁ HW2L-M101Q0➁ HW2L-M111Q0➁ HW2L-M120Q0➁ HW2L-M102Q0➁ HW2L-M122Q0➁ HW2L-M111➂2➁ HW2L-M120➂2➁ HW2L-M102➂2➁ HW2L-M122➂2➁ HW2L-M111D2➁ HW2L-M120D2➁ HW2L-M102D2➁ HW2L-M122D2➁ HW2L-M111➂5➁ HW2L-M120➂5➁ HW2L-M102➂5➁ HW2L-M122➂5➁ HW2L-A110Q0➁ HW2L-A101Q0➁ HW2L-A111Q0➁ HW2L-A120Q0➁ HW2L-A102Q0➁ HW2L-A122Q0➁ HW2L-A111➂2➁ HW2L-A120➂2➁ HW2L-A102➂2➁ HW2L-A122➂2➁ HW2L-A111D2➁ HW2L-A120D2➁ HW2L-A102D2➁ 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC HW2L-A122D2➁ HW2L-A111➂5➁ HW2L-A120➂5➁ HW2L-A102➂5➁ HW2L-A122➂5➁ • Color Code and Operating Voltage Code LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: amber G: green PW: pure white R: red S: blue W: white Y: yellow Incandescent Illuminated Type ➂ Operating Voltage Code ➁ Lens Color Code Specify a lens color code in place of Specify an operating voltage code ➁ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). ∗ DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 22 HW_IPB Page 23 Tuesday, November 9, 2004 1:21 PM HW Series Illuminated Pushbuttons ø22 Round Flush with Square Bezel Illuminated Pushbutton Shape Round Flush with Square Bezel HW3L-M1 HW3L-A1 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter∗ Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter∗ Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC Type No. HW3L-M110Q0➁ HW3L-M101Q0➁ HW3L-M111Q0➁ HW3L-M120Q0➁ HW3L-M102Q0➁ HW3L-M122Q0➁ HW3L-M111➂2➁ HW3L-M120➂2➁ HW3L-M102➂2➁ HW3L-M122➂2➁ HW3L-M111D2➁ HW3L-M120D2➁ HW3L-M102D2➁ HW3L-M122D2➁ HW3L-M111➂5➁ HW3L-M120➂5➁ HW3L-M102➂5➁ HW3L-M122➂5➁ HW3L-A110Q0➁ HW3L-A101Q0➁ HW3L-A111Q0➁ HW3L-A120Q0➁ HW3L-A102Q0➁ HW3L-A122Q0➁ HW3L-A111➂2➁ HW3L-A120➂2➁ HW3L-A102➂2➁ HW3L-A122➂2➁ HW3L-A111D2➁ HW3L-A120D2➁ HW3L-A102D2➁ 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC HW3L-A122D2➁ HW3L-A111➂5➁ HW3L-A120➂5➁ HW3L-A102➂5➁ HW3L-A122➂5➁ • Color Code and Operating Voltage Code LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: amber G: green PW: pure white R: red S: blue W: white Y: yellow Incandescent Illuminated Type ➂ Operating Voltage Code ➁ Lens Color Code Specify a lens color code in place of Specify an operating voltage code ➁ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). ∗ DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 23 HW_IPB Page 24 Tuesday, November 9, 2004 1:21 PM ø22 HW Series Illuminated Pushbuttons Mushroom (ø29mm) Illuminated Pushbutton Shape ø29mm Mushroom HW1L-M3 HW1L-A3 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter∗ Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter∗ Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC Type No. HW1L-M310Q0➁ HW1L-M301Q0➁ HW1L-M311Q0➁ HW1L-M320Q0➁ HW1L-M302Q0➁ HW1L-M322Q0➁ HW1L-M311➂2➁ HW1L-M320➂2➁ HW1L-M302➂2➁ HW1L-M322➂2➁ HW1L-M311D2➁ HW1L-M320D2➁ HW1L-M302D2➁ HW1L-M322D2➁ HW1L-M311➂5➁ HW1L-M320➂5➁ HW1L-M302➂5➁ HW1L-M322➂5➁ HW1L-A310Q0➁ HW1L-A301Q0➁ HW1L-A311Q0➁ HW1L-A320Q0➁ HW1L-A302Q0➁ HW1L-A322Q0➁ HW1L-A311➂2➁ HW1L-A320➂2➁ HW1L-A302➂2➁ HW1L-A322➂2➁ HW1L-A311D2➁ HW1L-A320D2➁ HW1L-A302D2➁ 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC HW1L-A322D2➁ HW1L-A311➂5➁ HW1L-A320➂5➁ HW1L-A302➂5➁ HW1L-A322➂5➁ • Color Code and Operating Voltage Code LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: amber G: green PW: pure white R: red S: blue W: white Y: yellow Incandescent Illuminated Type ➂ Operating Voltage Code ➁ Lens Color Code Specify a lens color code in place of Specify an operating voltage code ➁ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). ∗ DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 24 HW_IPB Page 25 Wednesday, November 10, 2004 1:51 PM HW Series Illuminated Pushbuttons ø22 Mushroom (ø29mm) with Square Bezel Illuminated Pushbutton Shape ø29mm Mushroom with Square Bezel HW3L-M3 HW3L-A3 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter∗ Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter∗ Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC Type No. HW3L-M310Q0➁ HW3L-M301Q0➁ HW3L-M311Q0➁ HW3L-M320Q0➁ HW3L-M302Q0➁ HW3L-M322Q0➁ HW3L-M311➂2➁ HW3L-M320➂2➁ HW3L-M302➂2➁ HW3L-M322➂2➁ HW3L-M311D2➁ HW3L-M320D2➁ HW3L-M302D2➁ HW3L-M322D2➁ HW3L-M311➂5➁ HW3L-M320➂5➁ HW3L-M302➂5➁ HW3L-M322➂5➁ HW3L-A310Q0➁ HW3L-A301Q0➁ HW3L-A311Q0➁ HW3L-A320Q0➁ HW3L-A302Q0➁ HW3L-A322Q0➁ HW3L-A311➂2➁ HW3L-A320➂2➁ HW3L-A302➂2➁ HW3L-A322➂2➁ HW3L-A311D2➁ HW3L-A320D2➁ HW3L-A302D2➁ 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC HW3L-A322D2➁ HW3L-A311➂5➁ HW3L-A320➂5➁ HW3L-A302➂5➁ HW3L-A322➂5➁ • Color Code and Operating Voltage Code LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: amber G: green PW: pure white R: red S: blue W: white Y: yellow Incandescent Illuminated Type ➂ Operating Voltage Code ➁ Lens Color Code Specify a lens color code in place of Specify an operating voltage code ➁ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). ∗ DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 25 HW_IPB Page 26 Tuesday, November 9, 2004 1:21 PM ø22 HW Series Illuminated Pushbuttons Mushroom (ø40mm) Illuminated Pushbutton Shape ø40mm Mushroom HW1L-M4 HW1L-A4 Operation Type Lamp Without Lamp Input Type Full Voltage Transformer Momentary LED DC-DC Converter∗ Incandescent Transformer Without Lamp Full Voltage Transformer Maintained LED DC-DC Converter∗ Incandescent Transformer Contact 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC 1NO-1NC 2NO 2NC Type No. HW1L-M410Q0➁ HW1L-M401Q0➁ HW1L-M411Q0➁ HW1L-M420Q0➁ HW1L-M402Q0➁ HW1L-M422Q0➁ HW1L-M411➂2➁ HW1L-M420➂2➁ HW1L-M402➂2➁ HW1L-M422➂2➁ HW1L-M411D2➁ HW1L-M420D2➁ HW1L-M402D2➁ HW1L-M422D2➁ HW1L-M411➂5➁ HW1L-M420➂5➁ HW1L-M402➂5➁ HW1L-M422➂5➁ HW1L-A410Q0➁ HW1L-A401Q0➁ HW1L-A411Q0➁ HW1L-A420Q0➁ HW1L-A402Q0➁ HW1L-A422Q0➁ HW1L-A411➂2➁ HW1L-A420➂2➁ HW1L-A402➂2➁ HW1L-A422➂2➁ HW1L-A411D2➁ HW1L-A420D2➁ HW1L-A402D2➁ 2NO-2NC 1NO-1NC 2NO 2NC 2NO-2NC HW1L-A422D2➁ HW1L-A411➂5➁ HW1L-A420➂5➁ HW1L-A402➂5➁ HW1L-A422➂5➁ • Color Code and Operating Voltage Code LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: amber G: green PW: pure white R: red S: blue W: white Y: yellow Incandescent Illuminated Type ➂ Operating Voltage Code ➁ Lens Color Code Specify a lens color code in place of Specify an operating voltage code ➁ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC Note: Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. LED illuminated transformer and DC-DC converter types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). ∗ DC-DC converter types are not approved by UL, CSA, and TÜV, and not CE compliant (operating voltage 90 to 140V DC). 26 HW_IPB Page 27 Tuesday, November 9, 2004 1:21 PM HW Series Illuminated Pushbuttons ø22 Dimensions • Operator Round Panel Thickness 0.8 to 6 LO LO 25 41.4 Panel Thickness 0.8 to 6 ø2 13 CK 3.6 3.6 ø2 24.8 29.4 29.4 29.4 LO 49.4 (1 block) CK 25 ø23.5 Full Voltage Adapter 2 contact blocks 41.4 1 contact block LO CK CK 25 M3.5 Terminal Screw Contact Block Locking Ring Round with Square Bezel Square 29.6 41.4 1 contact block 25 Full Voltage Adapter 29.6 41.4 • Full Voltage Type 3 ø2 Extended .6 13 29.4 18.5 M3.5 Terminal Screw Contact Block Locking Ring Panel Thickness 0.8 to 6 LO ø 69.4 (2 blocks) 2 contact blocks 41.4 ø29.5 25 CK Extended with Full Shroud .6 23 29.4 18.5 Full Voltage Adapter LO 3 contact blocks Locking Ring ø29 M3.5 Terminal Screw Contact Block 41.4 25 CK Mushroom (ø29) Panel Thickness 0.8 to 6 X1 13 23.2 29.4 LO X2 CK ø40 41.4 25 69.4 (3 blocks) 3 contact blocks Full Voltage Adapter Mushroom (ø40) 4 contact blocks 13 29.4 23.2 M3.5 Terminal Screw Contact Block Locking Ring Panel Thickness 0.8 to 6 Terminal Wiring • Arrows indicate access directions for wiring. 89.4 (4 contacts) 4 contact blocks • Transformer Type 3 4 X1 X1 X2 X2 M3.5 Terminal Screws • DC-DC Converter Type 79.5 (2 blocks) 99.5 (4 blocks) Safety Lever Lock Contact Block Full Voltage Adapter Transformer Locking Ring X1 X2 M3.5 Terminal Screw 89.5 (2 blocks) 109.5 (4 blocks) 27 HW_SS Page 28 Tuesday, November 9, 2004 1:27 PM ø22 HW Series Selector Switches No. of Positions Shape 90° 2-position / 60° 2-position Selector Switches Contact Code Dimensions on page 32. Contact Arrangement Chart 10 (1NO) 11 (1NO-1NC) 20 (2NO) 22 (2NO-2NC) Contact Code 20 (2NO) 02 (2NC) 22N1 (2NO-2NC) 45° 3-position HW1S 22N9 ★ (2NO-2NC) 40 (4NO) 40N2 ★ (4NO) 04 (4NC) 21N1 ★ (2NO-1NC) Contact Code Contact Block Mounting Position Operator Position L Type L L C — — — — Spring Return from Left Spring Return Two-way R HW1S-2T10 HW1S-21T10 HW1S-2T11 HW1S-21T11 HW1S-2T20 HW1S-21T20 HW1S-2T22 HW1S-21T22 Maintained Spring Return from Right C C R C R L C R L R L R NO 1 NO 2 NC 1 NC 2 NO 1 NO 2 NC 3 NC 4 NC 1 NC 2 3 NO NO 4 NO 1 NO 2 NO 3 NO 4 NO 1 2 NO NO 3 NO 4 NC 1 NC 2 NC 3 NC 4 NO 1 NO 2 NC 3 Dummy 4 Contact Operator Position Block HW1S-3T20 HW1S-31T20 HW1S-32T20 HW1S-33T20 HW1S-3T02 HW1S-31T02 HW1S-32T02 HW1S-33T02 HW1S-3T22N1 HW1S-31T22N1 HW1S-32T22N1 HW1S-33T22N1 HW1S-3ST22N9 HW1S-3T40 — — HW1S-31T40 HW1S-3ST40N2 HW1S-3T04 HW1S-32T40 — — HW1S-31T04 HW1S-3JT21N1 Maintained 3 HW1S-32T04 — — Maintained 2 1 Mounting Position L R L Type Spring Return from Right (60°) R NO 1 Dummy 2 NO 1 NC 2 NO 1 NO 2 NO 1 NC 2 NO 3 NC 4 Contact Operator Position Block Mounting Position Maintained (90°) 2 1 3 4 5 — HW1S-33T40 — HW1S-33T04 — • Contact Block Mounting Position and Contact Arrangement Chart 30° 5-position / 45° 4-position Type 1 2 3 4 5 4 4 2 1 NC 13N6 ★ NC 2 HW1S-4T13N6 — NC (1NO-3NC) 3 NO 4 NO 1 3 22N3 ★ NC 2 1 HW1S-4T22N3 — NC (2NO-2NC) 3 Center Left Right NO 4 NO 1 12 ★ NC 2 Operator L C R HW1S-4T12 — NC (1NO-2NC) 3 Position 1 NO Dummy 4 2 NO NO 1 22N3 ★ NC 2 3 NC — HW1S-5T22N3 NC (2NO-2NC) 3 4 NC NO 4 • On the contact arrangement marked with ★ in the table above, the rated current (load switching current) is reduced to a half of the rated current of the contact block. The rated insulation voltage and the rated thermal current remain unchanged. • Selector switches with one or three contact blocks contain a dummy block. Knob operator: White indicator on black body • Other contact arrangements are also available. See pages 33 through 36. 28 HW_SS Page 29 Tuesday, November 9, 2004 1:27 PM HW Series Key Selector Switches ø22 No. of Positions Shape 90° 2-position / 60° 2-position Key Selector Switches Contact Code HW1K Dimensions on page 32. Contact Arrangement Chart Contact Block Mounting Position 11 (1NO-1NC) 20 (2NO) 22 (2NO-2NC) Mounting Position Maintained (90°) L Type L L L R — — — — Spring Return from Left Spring Return Two-way R HW1K-2A10 HW1K-21B10 HW1K-2A11 HW1K-21B11 HW1K-2A20 HW1K-21B20 HW1K-2A22 HW1K-21B22 Maintained C Spring Return from Right C C L Type Spring Return from Right (60°) R NO 1 Dummy 2 NO 1 NC 2 NO 1 NO 2 NO 1 NC 2 NO 3 NC 4 Contact Operator Position Block 10 (1NO) Contact Code Operator Position C R L R L C R L R R NO 1 HW1K-3A20 HW1K-31B20 HW1K-32C20 HW1K-33D20 NO 2 NC 1 02 HW1K-3A02 HW1K-31B02 HW1K-32C02 HW1K-33D02 (2NC) NC 2 NO 1 22N1 NO 2 HW1K-3A22N1 HW1K-31B22N1 HW1K-32C22N1 HW1K-33D22N1 NC (2NO-2NC) 3 NC 4 NC 1 22N9 ★ NC 2 HW1K-3SA22N9 — — — (2NO-2NC) 3 NO NO 4 NO 1 40 NO 2 HW1K-3A40 HW1K-31B40 HW1K-32C40 HW1K-33D40 NO (4NO) 3 NO 4 NO 1 40N2 ★ 2 NO HW1K-3SA40N2 — — — NO (4NO) 3 NO 4 NC 1 04 NC 2 HW1K-3A04 HW1K-31B04 HW1K-32C04 HW1K-33D04 NC (4NC) 3 NC 4 NO 1 21N1 ★ NO 2 HW1K-3JA21N1 — — — NC (2NO-1NC) 3 Dummy 4 • On the spring-returned types, the key can be released only from the maintained position. On the maintained types, the key can be released from every position. Key retained positions are also available. See page 8. • Each key selector switch is supplied with two identical keys. Three different keys are also available. See page 8. • On the contact arrangement marked with ★ in the table above, the rated current (load switching current) is reduced to a half of the rated current of the contact block. The rated insulation voltage and the rated thermal current remain unchanged. • Key selector switches with one or three contact blocks contain a dummy block. • Cylinder cover: black, Cylinder: metal • Other contact arrangements are also available. See pages 33 through 36. 20 45° 3-position (2NO) • Contact Block Mounting Position and Contact Arrangement Chart Center Left 4 Right 2 L 3 1 1 2 3 4 NO NO NC NC C R Operator Position 29 HW_SS Page 30 Tuesday, November 9, 2004 1:27 PM ø22 HW Series Illiminated Selector Switches Illuminated Selector Switches 90° 2-position / 60° 2-position Shape HW1F Dimensions on page 32. Contact Arrangement Chart Contact Code Contact Block Maintained (90°) Operator Position Lamp Input Type L Spring Return from Right (60°) L R R Mounting Position Type 1 NO Without Lamp Full Voltage HW1F-211Q0➁ HW1F-2111Q0➁ 2 NC LED Transformer HW1F-211➂2➁ HW1F-2111➂2➁ Incandescent Transformer HW1F-211➂5➁ HW1F-2111➂5➁ 11 (1NO-1NC) 20 (2NO) 22 R 1 NO Without Lamp Full Voltage HW1F-220Q0➁ HW1F-2120Q0➁ 2 NO LED Transformer HW1F-220➂2➁ HW1F-2120➂2➁ Incandescent Transformer HW1F-220➂5➁ HW1F-2120➂5➁ Without Lamp Full Voltage HW1F-222Q0➁ HW1F-2122Q0➁ LED Transformer HW1F-222➂2➁ HW1F-2122➂2➁ Incandescent Transformer HW1F-222➂5➁ HW1F-2122➂5➁ 1 2 3 4 (2NO-2NC) L NO NC NO NC • Color Code and Operating Voltage Code LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: R: S: W: Y: amber green red blue white yellow Incandescent Illuminated Type ➂ Operating Voltage Code ➁ Lens Color Code Specify a lens color code in place of Specify an operating voltage code ➁ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC • Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. • LED illuminated transformer types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). • Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). • Contact Block Mounting Position and Contact Arrangement Chart Transformer 4 Full Voltage Adapter 2 Left 4 Right 2 L 3 3 1 Full Voltage Type 1 1 2 3 4 NO NC NO NC R Operator Position Transformer Type For more contact arrangement chart, see page 33. 30 HW_SS Page 31 Tuesday, November 9, 2004 1:27 PM HW Series Illiminated Selector Switches ø22 45° 3-position Contact Code Contact Block Operator Position Maintained Lamp Input Type Spring Return from Right C C L Spring Return from Left L R Spring Return Two-way C R C R L L R Mounting Position Type 1 NO Without Lamp Full Voltage HW1F-320Q0➁ HW1F-3120Q0➁ HW1F-3220Q0➁ HW1F-3320Q0➁ 2 NO LED Transformer HW1F-320➂2➁ HW1F-3120➂2➁ HW1F-3220➂2➁ HW1F-3320➂2➁ Incandescent Transformer HW1F-320➂5➁ HW1F-3120➂5➁ HW1F-3220➂5➁ HW1F-3320➂5➁ 20 (2NO) 02 (2NC) 22N1 NC Without Lamp Full Voltage HW1F-302Q0➁ HW1F-3102Q0➁ HW1F-3202Q0➁ HW1F-3302Q0➁ 2 NC LED Transformer HW1F-302➂2➁ HW1F-3102➂2➁ HW1F-3202➂2➁ HW1F-3302➂2➁ Incandescent Transformer HW1F-302➂5➁ HW1F-3102➂5➁ HW1F-3202➂5➁ HW1F-3302➂5➁ Without Lamp Full Voltage HW1F-322N1Q0➁ HW1F-3122N1Q0➁ HW1F-3222N1Q0➁ HW1F-3322N1Q0➁ LED Transformer HW1F-322N1➂2➁ HW1F-3122N1➂2➁ HW1F-3222N1➂2➁ HW1F-3322N1➂2➁ Incandescent Transformer HW1F-322N1➂5➁ HW1F-3122N1➂5➁ HW1F-3222N1➂5➁ HW1F-3322N1➂5➁ Without Lamp Full Voltage HW1F-340Q0➁ HW1F-3140Q0➁ HW1F-3240Q0➁ HW1F-3340Q0➁ LED Transformer HW1F-340➂2➁ HW1F-3140➂2➁ HW1F-3240➂2➁ HW1F-3340➂2➁ Incandescent Transformer HW1F-340➂5➁ HW1F-3140➂5➁ HW1F-3240➂5➁ HW1F-3340➂5➁ Without Lamp Full Voltage HW1F-304Q0➁ HW1F-3104Q0➁ HW1F-3204Q0➁ HW1F-3304Q0➁ LED Transformer HW1F-304➂2➁ HW1F-3104➂2➁ HW1F-3204➂2➁ HW1F-3304➂2➁ Incandescent Transformer HW1F-304➂5➁ HW1F-3104➂5➁ HW1F-3204➂5➁ HW1F-3304➂5➁ NO NO NC NC 1 2 3 4 40 (4NO) NO NO NO NO 1 2 3 4 04 (4NC) C R 1 1 2 3 4 (2NO-2NC) L NC NC NC NC • Color Code and Operating Voltage Code LED Illuminated Type ➁ Lens/LED Color Code Specify a lens/LED color code in place of ➁ in the Type No. A: G: R: S: W: Y: amber green red blue white yellow Incandescent Illuminated Type ➂ Operating Voltage Code ➁ Lens Color Code Specify a lens color code in place of Specify an operating voltage code ➁ in the Type No. in place of ➂ in the Type No. A: G: R: S: W: amber green red blue white H: H2: M: M4: S: T: T8: 100/110V AC 115/120V AC 200/220V AC 230/240V AC 380V AC 400/440V AC 480V AC • Full voltage types do not contain a lamp. Order LED or incandescent lamps separately. For lamps, see page 43. • LED illuminated transformer types contain an LED lamp (LSTD-6➁, rated voltage 6V AC/DC). • Incandescent illuminated transformer types contain an incandescent lamp (LS-6, rated voltage 6V AC/DC). • Contact Block Mounting Position and Contact Arrangement Chart Transformer 4 Full Voltage Adapter 2 Center Left 4 Right 2 L 3 3 1 Full Voltage Type 1 1 2 3 4 NO NO NC NC C R Operator Position Transformer Type For more contact arrangement chart, see page 33. 31 HW_SS Page 32 Tuesday, November 9, 2004 1:27 PM ø22 HW Series Selector Switches Dimensions: Selector Switches • Knob Operator M3.5 Terminal Screw Panel Thickness 0.8 to 6 Gasket LO CK 9 ø2 1 contact block 49.4 (1 or 2 blocks) 2 contact blocks 4 contact blocks 41.4 ø28.8 25 Locking Ring 7 69.4 (3 or 4 blocks) 29.4 21 • Key Operator CK 4 9. ø2 17 41.4 25 LO 13 29.4 30.5 Dimensions: Illuminated Selector Switches • Full Voltage Type M3.5 Terminal Screw 9 ø2 41.4 25 LO CK 69.4 (2 blocks) 7 89.4 (4 blocks) 29.4 21 • Transformer Type LO CK 9 ø2 4 41.4 25 3 X1 X2 M.3.5 Terminal Screw 79.5 (2 blocks) 99.5 (4 blocks) 7 21 29.4 All dimensions in mm. Terminal Wiring • Arrows indicate access directions for wiring. X1 Contact Block Full Voltage Adapter 32 X2 Transformer HW_SS Page 33 Tuesday, November 9, 2004 1:27 PM HW Series Selector Switch Contact Arrangement Charts ø22 90° 2-position (Maintained) / 60° 2-position (Spring Return) Operator Availability Contact Code 10 (1NO) 01 (1NC) 11 (1NO-1NC) 11N1 (1NO-1NC) 20 (2NO) 02 (2NC) 22 (2NO-2NC) 22N2 (2NO-2NC) 22N1 (2NO-2NC) 22N4 (2NO-2NC) 31N1 (3NO-1NC) 40 (4NO) 7S ★ (1NO-1NC) 8S ★ (2NO-2NC) 22N7 ★ (2NO-2NC) L Contact Block Mounting Position Type 1 2 1 2 1 2 1 2 1 2 1 2 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 1 2 3 4 1 2 3 4 NO Dummy NC Dummy NO NC NC NO NO NO NC NC NO NO NC NC NC NO NC NO NO NO NC NC NC NO NO NC NC NO NO NO NO NO NO NO NO NC NO NC NO NC NC NO NC NO L C L R Knob Key Illuminated Knob Key Illuminated Cam Code Operator Position R Remarks × × × × × × — Standard × × × × — × — × × × × × × — Standard × × × × — × — × × × × × × — Standard × × × × — × — × × × × × × — Standard × × × × — × — × × × × — × — × × × × — × — × × × × — × — × × × × — × — × × × × — × — × × × × — × — × × × × — × — • On the contact arrangement marked with ★ in the table above, the rated current (load switching current) is reduced to a half of the rated current of the contact block. The rated insulation voltage and the rated thermal current remain unchanged. Remarks: When ordering the contact arrangement indicated with “Standard” in the table above, specify the Type No. shown in the standard Type No. on preceding pages. For other contact arrangements, see page 36 to specify the Type No. and contact code. 33 HW_SS Page 34 Tuesday, November 9, 2004 1:27 PM ø22 HW Series Selector Switch Contact Arrangement Charts 45° 3-position Operator Availability Operator Position 11 (1NO-1NC) 11N1 (1NO-1NC) 7S ★ (1NO-1NC) 11N1 ★ (1NO-1NC) 20 (2NO) 1S ★ (2NO) 2S ★ (2NC) 02 (2NC) 22N1 (2NO-2NC) 22N2 (2NO-2NC) 8S ★ (2NO-2NC) 22N8 ★ (2NO-2NC) 22N2 ★ (2NO-2NC) 31 (3NO-1NC) 31N1 (3NO-1NC) 13 (1NO-3NC) 13N3 ★ (1NO-3NC) L Contact Block Mounting Position Type 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 NO NC NC NO NO NC NC NO NO NO NO NO NC NC NC NC NO NO NC NC NC NO NC NO NO NC NO NC NO NC NC NO NC NO NC NO NO NC NO NO NC NO NO NO NO NC NC NC NC NO NC NC L C R C R L C R L C R L R Knob Key Illuminated Knob Key Illuminated Knob Key Illuminated Knob Key Illuminated Cam Code Contact Code C Remarks × × × × × × × × × × × × — × × × × × × × × × × × × — × × × — — — — — — — — — J × × × — — — — — — — — — J × × × × × × × × × × × × — Standard × × × — — — — — — — — — J × × × — — — — — — — — — J × × × × × × × × × × × × — Standard × × × × × × × × × × × × — Standard × × × × × × × × × × × × — × × × — — — — — — — — — J × × × — — — — — — — — — J × × × — — — — — — — — — J × × × × × × × × × × × × — × × × × × × × × × × × × — × × × × × × × × × × × × — × × × — — — — — — — — — J Remarks: When ordering the contact arrangement indicated with “Standard” in the table above, specify the Type No. shown in the standard Type No. on preceding pages. For other contact arrangements, see page 36 to specify the Type No. and contact code. 34 HW_SS Page 35 Tuesday, November 9, 2004 1:27 PM HW Series Selector Switch Contact Arrangement Charts ø22 45° 3-position Operator Availability Operator Position 40 (4NO) 40N1 ★ (4NO) 04 (4NC) 04N2 ★ (4NC) 22 ★ (2NO-2NC) 21N1 ★ (2NO-1NC) 40N2 ★ (4NO) 22N9 ★ (2NO-2NC) 31N4 ★ (3NO-1NC) 13N1 ★ (1NO-3NC) 22N5 ★ (2NO-2NC) 31N2 ★ (3NO-1NC) 13N2 ★ (1NO-3NC) L Contact Block Mounting Position Type 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 NO NO NO NO NO NO NO NO NC NC NC NC NC NC NC NC NO NC NO NC NO NO NC L C R C R L C R L C R L R Knob Key Illuminated Knob Key Illuminated Knob Key Illuminated Knob Key Illuminated Cam Code Contact Code C Remarks × × × × × × × × × × × × — Standard × × × — — — — — — — — — J × × × × × × × × × × × × — Standard × × × — — — — — — — — — J × × × — — — — — — — — — J × × × — — — — — — — — — J Standard Dummy NO NO NO NO NC NC NO NO NO NC NO NO NO NC NC NC NC NO NC NO NO NO NC NO NC NC NC NO × × × — — — — — — — — — S Standard × × × — — — — — — — — — S Standard × × × — — — — — — — — — J × × × — — — — — — — — — J × × × — — — — — — — — — J × × × — — — — — — — — — J × × × — — — — — — — — — J Remarks: When ordering the contact arrangement indicated with “Standard” in the table above, specify the Type No. shown in the standard Type No. on preceding pages. For other contact arrangements, see page 36 to specify the Type No. and contact code. 35 HW_SS Page 36 Tuesday, November 9, 2004 1:27 PM ø22 HW Series Selector Switch Contact Arrangement Charts 45° 4-position Contact Code Contact Block Cam Code Operator Availability Operator Position 2 3 1 4 12 ★ (1NO-2NC) 04N3 ★ (4NC) 13N6 ★ (1NO-3NC) 13N5 ★ (1NO-3NC) 22N3 ★ (2NO-2NC) Mounting Position Type 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 NO NC NC 1 2 3 4 Remarks Knob × — Standard × — × — Standard × — × — Standard Dummy NC NC NC NC NC NC NC NO NO NC NC NC NO NC NC NO Operator Availability Operator Position Contact Code 22N3 ★ (2NO-2NC) Contact Block 2 3 4 5 1 Mounting Position Type 1 2 3 4 NO NC NC NO 1 2 3 4 5 Cam Code 30° 5-position Remarks Knob × — Standard • Contact Block Mounting Position and Contact Arrangement Chart Transformer 4 4 2 Full Voltage Adapter 2 Center Left 4 L 3 1 Non-illuminated Selector Right 2 3 3 1 Illuminated Selector Full Voltage Type 1 2 3 4 1 NO NO NC NC C R Operator Position Illuminated Selector Transformer Type Type No. Development • When cam code is not required HW1S - 2 T 11 HW1K - 3 J A 22N2 Contact code (1NO-1NC) “T” for knob operator 2-position 36 • When cam code is required Contact code (2NO-2NC) Key removal option code Cam code (J, S, or none) 3-position HW_SS Page 37 Tuesday, November 9, 2004 1:27 PM HW Series Pushbutton Selectors ø22 Pushbutton Selectors Shape Circuit Category Contact Code HW1R 11 (1NO-1NC) 20 (2NO) A 22 (2NO-2NC) 20 (2NO) D 22N1 (2NO-2NC) E F N T 22N1 ★ (2NO-2NC) 22N1 ★ (2NO-2NC) 22N2 ★ (2NO-2NC) 22N1 ★ (2NO-2NC) Contact Block Mounting Position Type 1 2 1 2 1 2 3 4 1 2 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 NO NC NO NO NO NC NO NC NO NO NO NO NC NC NO NO NC NC NO NO NC NC NC NO NC NO NO NO NC NC ➀ Button Color Code Type No. Normal Depressed Normal Depressed HW1R-2A11➀ HW1R-2A20➀ HW1R-2A22➀ HW1R-2D20➀ HW1R-2D22N1➀ HW1R-2E22N1➀ HW1R-2F22N1➀ Specify a button color code in place of ➀ in the Type No. B: G: R: S: W: Y: black green red blue white yellow HW1R-2N22N2➀ Blocked HW1R-2T22N1➀ • On the contact arrangement marked with ★ in the table above, the rated current (load switching current) is reduced to a half of the rated current of the contact block. The rated insulation voltage and the rated thermal current remain unchanged. • When operating the pushbutton selector, do not turn the operator ring or the lock lever while the button is depressed. Otherwise the pushbutton selector may be damaged. • Other contact arrangements are also available upon request. • Contact Block Mounting Position and Contact Arrangement Chart Dimensions Panel Thickness 0.8 to 6 4 Gasket 2 LO Locking Ring 49.4 (2 blocks) 69.4 (4 blocks) 41.4 ø28 25 CK ø29.4 M3.5 Terminal Screw 29.4 23.5 All dimensions in mm. 3 Contact Block 1 NO 2 NO 3 NC 4 NC 1 Left Right Normal Depressed Normal Depressed Ring Position Button 37 HW_SS Page 38 Tuesday, November 9, 2004 1:27 PM ø22 HW Series Mono-Lever Switches Mono-Lever Switches Shape Positions Type No. HW1M-1010-20 HW1M-2020-20 HW1M-0101-20 HW1M-0202-20 HW1M-0101-40 HW1M-0202-40 HW1M-1111-22N9 HW1M-2222-22N9 HW1M-L1010-20 HW1M-L2020-20 HW1M-L0101-20 HW1M-L0202-20 HW1M-L0101-40 HW1M-L0202-40 HW1M-L1111-22N9 HW1M-L2222-22N9 HW1M Standard Lever 2-position 4-position HW1M-L Interlocking Lever 2-position 4-position • On all mono-lever switches, the rated current (load switching current) is reduced to a half of the rated current of the contact block. The rated insulation voltage and the rated thermal current remain unchanged. Contact Arrangement Chart • 2-position (Right/Left) Contact Block Contact Code Mounting Position Type 20 40 1 2 1 2 3 4 • 2-position (Up/Down) Lever Operator Position Left Contact Block • 4-position Lever Operator Position Contact Code Mounting Position Type Down Center Center Right NO NO NO NO NO NO 20 40 1 2 1 2 3 4 Contact Lever Operator Position Block Contact Code Mounting Right Position Type Down Left Center Up Up NO NO NO NO NO NO 1 2 3 4 22N9 NC NC NO NO Ordering Information Up HW1M-L Type HW1M: Standard HW1M-L: Interlocking — R Dn • Contact Block Mounting Position and Lever Operator Position L 1 1 1 1 — Lever Operation Mode Order of Entry Up → Right → Down → Left 1: Maintained 2: Spring returned 0: Blocked 22N9 4 Contact Code Select a required contact operation at each lever operator position from the contact arrangement charts above and specify the Contact Code. Locking Ring Right Lever Operator Position Left Down CK ø3 LO 4. 2 Panel Thickness 0.8 to 6 41.4 25 M3.5 Terminal Screw Up 3 Contact Block 1 Mounting Position • The lever operator of the interlocking type HW1M-L is locked only in the center position. Dimensions 2 8 29.4 38 24 ° 36 max. 45.5 24° 72 36 max. 49.4 (2 blocks) 69.4 (4 blocks) All dimensions in mm. HW_Accessory Page 39 Tuesday, November 9, 2004 1:40 PM HW Series Accessories and Replacement Parts ø22 Accessories Nameplates • HWAM, HWAQ, HWAS, and HWAV Description Legend Material Ordering Type No. Type No. Package Quantity Dimensions (mm) Marking Plate HWAM 2.7 14.5 14.9 Plastic (black) 1.5 mm thick 30 Order marking plate separately. HWAM 29 27 1 12.1 HWAM R14.9 HWAMPN10 10 2 ø2 1.5 Marking Plate 29 HWAQ HWAQPN10 10 2.7 14.5 14.9 Plastic (black) 1.5 mm thick 27 30 Order marking plate separately. HWAQ 1 12.1 HWAQ 1 R14.9 ø22 1.9 45 HWAS Plastic (black) 1.5 mm thick Blank HWAS-0 1 HWAS-0PN10 10 1.6 HWAV-0 ø2 2 HWAV-0 0 ø6 1 Plastic (yellow) 1.5 mm thick HWAV 0.9 HWAS-0 ERGENCY EM Blank 1 ø2 2 STOP EMERGENCY STOP HWAV-27 HWAV-27 1.6 1 0.9 • Legend “Emergency Stop” is indicated outside a ø44mm circle. • Making Plate Material Type No. Ordering Type No. Package Quantity HWNP-∗ Aluminum (black) 1.0 mm thick HWNP 1 Dimensions (mm) • White legend on black background. 27 HWNP-∗ HWNP-∗PN10 10 12 Description • Specify a legend code in place of ∗ in the Ordering Type No. Legends Legend (blank) ON OFF START STOP OFF-ON HAND-AUTO HAND-OFF-AUTO • Installing the marking plate on a nameplate Nameplate Marking Plate Code 0 1 2 3 4 31 35 53 ➁ • To remove the marking plate, insert the flat screwdriver beween the marking plate and nameplate. Flat Screwdriver Marking Plate ➀ When requring no anti-rotation, remove the projection using pliers. Nameplate Note: When using an nameplate, the mounting panel thickness is decreased by 1.5 mm. 39 HW_Accessory Page 40 Tuesday, November 9, 2004 1:40 PM ø22 HW Series Accessories and Replacement Parts Accessories Shape Material Type No. Ordering Type No. Package Quantity • Used to tighten the locking ring when installing the HW switch onto a panel. • Tighten the locking ring to a torque of 2.0 N·m. Locking Ring Wrench Metal (weight: approx. 150g) Dimensions (mm) MW9Z-T1 MW9Z-T1 1 8 ø2 110 OR-55 OR-55 1 ø11.6 Rubber ø14 • Used to install and remove the LED/incandescent lamps. Lamp Holder Tool 59 • Used to remove the contact block and transformer, and also to install/remove the pilot light and illuminated pushbutton lens. 23 Contact Block Removal Tool Metal/Rubber TW-KC1 TW-KC1 1 130 39 ø19 • Used to prevent the operator from turning. Generally used when using no nameplates on selector switches and pushbutton selectors. Anti-rotation Ring TOP 1.5 Plastic HW9Z-RL HW9Z-RLPN10 10 9 ø2 ø22 • Used to plug the unused ø22.2mm mounting holes. Rubber Mounting Hole Plug ø29 OB-31PN05 5 3.5 3.5 Rubber (black) OB-31 Metallic Mounting Hole Plug LW9Z-BM LW9Z-BM 1 • Used to plug the unused ø22.2mm mounting holes. • Tighten the locking ring to a torque of 1.2 N·m. • IP66 ø25.8 • Mounting panel thickness: 0.8 to 6 mm 3 Diecast Metal (locking ring: plastic) ø25 Plastic HW-VG1 HW-VG1PN10 10 • Used to prevent contact between adjacent lead wires when units are mounted closely. Barriers should always be used in close mounting. 45 Barrier 12 Gasket Locking Ring 20 Switchguard Spring Return HW9Z-K1 HW9Z-K1 1 • Used to prevent inadvertent operation for flush pushbuttons and illuminated pushbuttons. • IP65 • Maintained type stops at 90° and 180°. 31 min. 49.4 Spring Return Panel Thickness: 0.8 to 5 HW9Z-K11 HW9Z-K11 1 51.2 68 min. Plastic Maintained .7 R33 17.4 40 1.5 0.4 48.3 HW_Accessory Page 41 Tuesday, November 9, 2004 1:40 PM HW Series Accessories and Replacement Parts ø22 Accessories Pushbutton Clear Boot Material For flush pushbuttons Ordering Type No. Type No. Package Quantity OC-31 OC-31 1 OC-32 OC-32 1 Rubber (EPDM) For extended pushbuttons Dimensions (mm) • Used to cover and protect pushbuttons where units are subject to watersplash. Not suitable for outdoor use or where the units are subject to oil splash. ø32.6 Shape 18 (OC-31) 22 (OC-32) • Used to protect pushbuttons, illuminated pushbuttons, selector switches, and key selector switches. Padlock cover Panel Thickness 0.8 to 3.2 82.5 HW9Z-KL1 1 70 30 HW9Z-KL1 93 5 6. R6 Polyarylate (gasket: nitryl rubber) 24 HW9Z-A25 HW9Z-A25PN05 5 HW9Z-A30 HW9Z-A30PN02 2 Ring Adapter Ring Adapter HW9Z-A30E HW9Z-A30EPN02 2 .2 Ring Adapter 2 ø2 0 ) ø5 4.4 4 :ø D (I Key Hole ø8 29.5 30 Waterproof Rubber Gasket 0.5t • Used to install the HW/TW units into ø25 mounting holes. • IP65 • Cannot be used with anti-rotation ring and nameplate. • Mounting panel thickness: 1.2 to 6.0 mm • Used to install the HW units into ø30 mounting holes (except for HW1E and HW1B-M5/V5). • IP65 • Cannot be used with anti-rotation ring, nameplate, full-shroud illuminated pushbuttons, pushbutton selectors, and mono-lever switches. • Mounting panel thickness:1.6 to 4.0 mm • Used to install the HW1E units into ø30 mounting holes. • IP65 • Cannot be used with anti-rotation ring and nameplate. • Mounting panel thickness:1.6 to 3.8 mm Maintenance Parts Shape Contact Block Specification Type No. Ordering Type No. Package Quantity 1NO contact HW-G10 HW-G10 1 1NC contact HW-G01 HW-G01 1 EM (early make) contact HW-G10R HW-G10R 1 LB (late break) contact HW-G01R HW-G01R 1 TW-DB TW-DBPN10 10 HW-GA1 HW-GA1PN02 2 100/110V AC HW-T16 HW-T16 1 200/220V AC HW-T26 HW-T26 1 AS resin HW1A-P2➁ HW1A-P2➁PN05 Remarks Dummy Block Full Voltage Adapter Transformer Dome Lens for Pilot Light 5 • For illuminated pushbuttons and illuminated selector switches. • Specify a color code in place of ➁. A (amber), G (green), R (red), S (blue), W (white), and Y (yellow) 41 HW_Accessory Page 42 Tuesday, November 9, 2004 1:40 PM ø22 HW Series Accessories and Replacement Parts Maintenance Parts Shape Button Round flush with round or square bezel Round extended with round or square bezel Package Quantity Color Code 5 HW1A-B2➀ HW1A-B2➀PN05 5 HW2A-B1➀ HW2A-B1➀PN05 5 Square extended HW2A-B2➀ HW2A-B2➀PN05 5 ø29mm mushroom HW1A-B3➀ HW1A-B3➀PN02 2 ø40mm mushroom HW1A-B4➀ HW1A-B4➀PN02 2 Round flush HW9Z-L11➁ HW9Z-L11➁PN05 5 HW9Z-L21➁ HW9Z-L21➁PN05 5 HW9Z-L12➁ HW9Z-L12➁PN05 5 ALW31L-➁ ALW31L-➁PN02 2 ALW31LD-➁ ALW31LD-➁PN02 2 A (amber), Y (yellow) Square flush Polyacetal Polyarylate ø29mm mushroom AS, Marking type B (black) G (green) R (red) S (blue) W (white) Y (yellow) A (amber), C (clear), G (green), R (red), S (blue), Y (yellow) Note: Use a clear lens for white illumination. C (clear), G (green), R (red), S (blue) ALW41L-➁ ALW41L-➁ 1 C (clear), G (green), R (red), S (blue) ALW41LD-➁ ALW41LD-➁ 1 A (amber), Y (yellow) HW9Z-P11 HW9Z-P11PN05 5 HW9Z-P12 HW9Z-P12PN05 5 Square flush HW9Z-P21 HW9Z-P21PN05 5 ø29/40mm mushroom ALW3B ALW3BPN05 5 ø40mm mushroom Marking Plate Ordering Type No. HW1A-B1➀PN05 Round extended Lens (for illuminated pushbuttons) Type No. HW1A-B1➀ Square flush Lens (for pilot lights and illuminated pushbuttons) Specification Round flush Round extended Acrylic Operator Knob for Illuminated Selector Switch Polyarylate HW9Z-FDY➁ HW9Z-FDY➁ Metal HW9Z-SK-231 HW9Z-SK-231PN02 2 Plastic HW9Z-LN HW9Z-LNPN05 5 HW9Z-CPM HW9Z-CPM 1 HW9Z-BLM HW9Z-BLM 1 HW9Z-LS HW9Z-LSPN10 10 1 • White A (amber) G (green) R (red) S (blue) W (white) Y (yellow) Replacement key Key selector switch Locking Ring • Black Cap for Mono-Lever Switch Boot for Mono-Lever Switch Standard Rubber Safety Lever Lock Plastic Note: Specify a button color code or lens color code in place of ➀ or ➁ in the Ordering Type No. 42 • Yellow HW_Accessory Page 43 Tuesday, November 9, 2004 1:40 PM HW Series Accessories and Replacement Parts ø22 Maintenance Parts LED Lamps (LSTD Type) Current Draw Operating Voltage AC 6V AC/DC ±5% 17 mA (A, R, W, Y) 14 mA (A, R, W, Y) 8 mA (G, PW, S) 5.5 mA (G, PW, S) LSTD-6∗ 12V AC/DC ±10% 11 mA LSTD-1∗ 10 mA 24V AC/DC ±10% 11 mA Ordering Type No. Type No. DC LSTD-2∗ 10 mA LSTD-6➁ LSTD-6➁PN10 LSTD-1➁ LSTD-1➁PN10 LSTD-2➁ Illumination Color Code Specify a color code in place of ➁ in the Ordering Type No. A: G: PW: R: S: W: Y: amber green pure white red blue white yellow LSTD-2➁PN10 Package Quantity Base 1 10 1 BA9S/13 10 1 10 Incandescent Lamps (LS Type) Rated Operating Voltage 6V AC/DC Lamp Ratings Type No. 1W (6.3V) LS-6 1W (18V) LS-8 Package Quantity 12V AC/DC 1 18V AC/DC 1W (24V) LS-2 1W (30V) LS-3 24V AC/DC Transformer Shape Separate Mounting Type Primary Voltage Secondary Voltage Type No. 100/110V AC 200/220V AC 400/440V AC 5.5V Applicable Load TWR516 One full voltage type pilot light or illuminated switch containing TWR526 LSTD-6 LED lamp (6V AC/DC) or LS-6 incandescent lamp (6V TWR546 AC/DC, 1W) 43 HW_Instructions Page 44 Tuesday, November 9, 2004 1:47 PM ø22 HW Series Instructions Safety Precautions • Turn off the power to the HW series control units before starting installation, removal, wiring, maintenance, and inspection of the products. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid a burn on your hand, use the lamp holder tool when replacing lamps. • For wiring, use wires of a proper size to meet the voltage and current requirements. Tighten the M3.5 terminal screws to a tightening torque of 1.0 to 1.3 N·m. Failure to tighten terminal screws may cause overheat and fire. Instructions Remove the contact block from the operator (for transformer type pilot lights, remove the transformer from the illumination unit). Remove the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block to the operator. • Removing and Installing the Contact Block 1. To remove the operator from the contact block, turn the locking lever in the direction of the arrow shown below. Then the operator can be pulled out. 2. To reinstall, place the TOP markings on the operator and the contact block mounting adapter in the same direction, and insert the operator into the contact block mounting adapter. Then turn the locking lever in the opposite direction. Safety Lever Lock IDEC strongly recommends using the safety lever lock (HW9Z-LS, yellow) to prevent heavy vibration or maintenance personnel from unlocking contacts. 1. HW series can be mounted vertically with a minimum spacing of 50 mm (70 mm for mono-lever switches) but spacing should be determined to ensure easy operation. 2. Mount the control unit onto the panel, lock the lever, and strongly push in the safety lever lock to install. 3. When the spacing is narrower than the recommended value, with the lever unlocked, mount the safety lever lock and insert the contact unit to the operator. Then, lock the lever and strongly push in the safety lever lock to install. 4. To remove the safety lever lock, insert a flat screwdriver into the safety lever lock and push upwards. Lock Lever Safety Lever Lock LO CK 26.5 • Removing and Installing the Transformer Unit on Pilot Lights 1. Insert a flat screwdriver (5mm wide at the maximum) into the latch hole on the transformer unit as shown in the photo below, and disengage the latch. Then pull out the illumination unit. 2. To reinstall, place the TOP marking on the illumination unit and the latch in the same direction, and push the illumination unit into the transformer unit. • Notes for Panel Mounting 1. When mounting the operator onto a panel, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring. Tightening torque must not exceed 2.0 N·m. Do not use pliers. Excessive tightening will damage the locking ring. 2. For the contact blocks and transformers housing LED and incandescent lamps, make sure not to press the lamps too hard, otherwise the lamp socket may be impaired. • Notes for Illuminated Pushbuttons The full shroud cannot be removed from the extended full shroud type. Install Panel Mounting Safety Lever Lock Screwdriver Remove Operator Contact Block Mounting Adapter 44 Panel HW_Instructions Page 45 Tuesday, November 9, 2004 1:47 PM HW Series Instructions ø22 Instructions Replacement of Lens and Marking Plate Marking • Removing 1. Remove the lens unit (color lens, marking plate, and lens holder) by inserting a screwdriver into the recess of the lens thorough the bezel. [Removing the Lens Unit] For HW series illuminated pushbuttons and pilot lights, legends and symbols can be engraved on the built-in marking plates, or printed film can be inserted under the lens for labeling purposes. Films are not supplied with illuminated pushbuttons, and may be provided by the user. • Marking Plates and Marking Film Size Note: The translucent filter in the lens holder cannot be removed because this filter is sealed to make the unit waterproof and oiltight. Round Lens Type Square Lens Type Engraving Area Engraving Area ø19.6 1 1 19.9 • Engraving must be made on the engraving area within 0.5mm deep. • The marking plate is made of white acrylic resin. 22.7 ø21.5 Applicable Marking Film 2. Remove the marking plate by pushing the lens from the rear to disengage the latches between the lens and the lens holder, using the screwdriver as shown below. [Removing the Lens] Built-in Marking Plate Lens Style 19.4 • Mylar for printing labels is not included and must be provided and printed by the user. • Two 0.1mm-thick films or one 0.2mm-thick film can be installed in the lens. • Recommended marking film: Mylar • Insertion Order of Marking Plate and Film [Round Lens Type] • Installing [For Round Lens Type] Lens Marking Plate Lens Holder 1. Place the marking plate on the lens holder with the antirotation projection engaged and press the lens onto the lens holder to engage the latches. 2. Place the marking plate in the correct orientation. Lens Film Marking Plate Lens Holder Housing Lens Holder Housing Note: Films are not included. [Square Lens Type] [For Square Lens Type] Lens Marking Plate Lens Holder 1. Place the marking plate on the lens holder and press the lens onto the lens holder to engage the latches. 2. Place the marking plate in the correct orientation. Lens Film Marking Plate Note: Films are not included. Place the marking plate in the correct orientation. 45 HW_Instructions Page 46 Tuesday, November 9, 2004 1:47 PM ø22 HW Series Instructions Instructions Replacement of Lamps Close Mounting Lamps can be replaced by using the lamp holder tool (OR55) from the front of the panel, or by removing the contact block from the operator unit. • Removing the Lamps from the Front of the Panel [How to Remove] 1. To remove, slip the lamp holder tool onto the lamp head lightly. Then push slightly, and turn the lamp holder tool counterclockwise. When mounting the units closely in a horizontal row on 30mm centers, use optional barriers to prevent interconnection between adjoining terminals. The barriers can be attached simply by pressing them onto the sides of contact blocks. 30 30 [How to Install] 1. To install, insert the lamp head into the lamp holder tool, and hold the lamp as shown in the figure below. Lamp Lamp Holder Tool 2. Place the pins on the lamp base to the grooves in the lamp socket. Insert the lamp and turn it clockwise. Grooves in the Operator Unit Barrier When mounting transformer type illuminated units closely in a horizontal row on 30mm centers, insert solid wires or stranded wires into inside of the terminal screw on the transformer (see figure below) to prevent short circuit between adjoining terminals. Nameplate When anti-rotation is not required, remove the projection from the nameplate using pliers. X1 X2 X1 X2 Projection Inside Nameplate 46 Inside When using transformer type pilot lights closely mounted in horizontal and vertical rows on 30mm centers, keep the ambient temperature below 40°C. HW_Instructions Page 47 Tuesday, November 9, 2004 1:47 PM HW Series Instructions ø22 Instructions Tightening Torque for Terminal Screws Anti-rotation Ring and Panel Cut-out Tighten the M3.5 terminal screws to a torque of 1.0 to 1.3 Align the TOP marking on the operator and the ▲ mark on the anti-rotation ring with the recess in the mounting panel. N·m. Panel Thickness 1.2 to 4.5 Installation of LED Illuminated Units Applicable Wiring The applicable wire size is 2mm2 maximum. (Solid wire ø1.6 mm max.) One or two wires can be connected. • Applicable Crimping Terminal 7.9 max. 4 max. HW Operator Anti-rotation Ring Locking Ring Mounting Panel • Panel Cut-out (Complies with IEC947-5-1) x. 3.2 +0.2 0 .8 R0 ma .4 +0 0 .3 2 ø2 24.1 ø3.6 min. Projection +0.4 0 1. When using full voltage type LED illuminated units, provide protection against electrical noise, if necessary. 2. Notes for Pure White LED Lamps • Do not use the pure white LED outdoors, otherwise it will lead to the degradation of brightness and color. Do not remove or apply shock to the cap on the pure white LED lamp, otherwise it may break or damage the cap. • Use a white lens. The illumination color will be dull if a different color lens is used. 5.5 min. Be sure to use an insulation tube or cover on the crimping part of the crimping terminal to prevent electrical shocks. ø1.6 max. • Solid Wire 8 max. Note: Contact Block and Transformer When connecting wires in the direction shown below, keep the insulation stripping length 6.6 mm at the maximum. Unibody Pushlock Turn Reset • Removing the lens Remove the lens by inserting a screwdriver into the left or right recess of the lens. Be careful that the lens does not drop off. • Removing the LED/incandescent lamp Use a lens removal tool to remove the lamp. See page 46 for more information. • Notes for Wiring Ensure that the crimping terminal of each wiring is properly insulated. Key Selector Switch X1 X2 • Notes for using a different key When a different number key is inserted into the key hole, it will not normally operate. However, if the key is forced to turn or is not inserted properly, it may be turned. 47 HW_Control Box Page 48 Tuesday, November 9, 2004 2:39 PM ø22 HW Series Control Boxes Control Boxes Control Box (Gray Cover) Shape Contact With Pushbutton HW1X-BM 1NO 1NO-1NC Type No. Specify a button color code in place of ➀ in the Type No. B: black G: green R: red S: blue W: white Y: yellow HW1X-BM110➀ HW1X-BM111➀ Operator Position Contact Block Shape With Selector Switch HW1X-S No. of Positions Contact Code 90° 2-position Maintained 45° 3-position Maintained 10 (1NO) 11 (1NO-1NC) 20 (2NO) Mounted Unit (Operator) Button Color Mounting Position 1 2 1 2 1 2 Type L NO C HW1X-S2T10 Dummy NO NC NO NO Mounted Unit (Operator) Type No. R — HW1B-M1 HW1S-2T — — HW1X-S2T11 HW1X-S3T20 HW1S-3T Emergency Stop Control Box (Yellow Cover) Shape Contact With Pushlock Turn Reset Switch HW1X-BV Type No. 1NC HW1X-BV401R 1NO-1NC HW1X-BV411R 2NC HW1X-BV402R 1NC HW1X-BX401R 1NO-1NC HW1X-BX411R 2NC HW1X-BX402R With Pushlock Key Reset Switch HW1X-BX Mounted Unit (Operator) Button Color Red only HW1B-V4R Red only HW1B-X4R Accessories Name Nameplate Cover Gasket Connector Locking Nut Type No. NSA-0 Ordering Type No. Package Quantity Remarks NSA-0 1 NSA-0PN10 10 Black surface, made of aluminum 0.8 mm thick HW9Z-W HW9Z-WPN05 5 Made of rubber HW9Z-G HW9Z-GPN05 5 Made of white plastic, G1/2 thread HW9Z-PG HW9Z-PGPN05 5 Made of black plastic, PG16 thread Ordering Information • Unless otherwise specified, every control box is supplied with two connector locking nuts (G1/2 thread). • When using PG16 connectors, specify as described below. HW1X-BM110➀ - PG Supplied with two PG16 connector locking nuts 48 HW_Control Box Page 49 Tuesday, November 9, 2004 2:39 PM HW Series Control Boxes ø22 Specifications Operating Temperature Storage Temperature Operating Humidity Rated Insulation Voltage Contact Resistance Insulation Resistance Electric Shock Protection Class Dielectric Strength Vibration Resistance Shock Resistance Mechanical Life (minimum operations) Electrical Life (minimum operations) Conduit Port Applicable Connector Applicable Wire Mounting Screw Degree of Protection Contact Ratings –25 to +60°C (no freezing) –40 to +80°C (no freezing) 45 to 80% RH (no condensation) Contact Block 600V 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Rated Insulation Voltage Rated Continuous Current Contact Ratings by Utilization Category IEC 60947-5-1 600V 10A AC-15 (A600) DC-13 (P600) Applicable Standards and Approvals Safety Standards UL508 CSA C22.2 No. 14 EN60947-5-1 Class II (IEC 61140) Between live and dead parts: 2,500V AC, 1 minute Operating extremes: 5 to 55 Hz, amplitude 0.5 mm Damage limits: 1,000 m/s2 Operating extremes: 100 m/s2 Pushbuttons, momentary: 5,000,000 Selector switches: 500,000 Pushlock turn reset switches: 500,000 Pushbuttons, momentary: 500,000 ∗1 Selector switches: 500,000 ∗2 Pushlock turn reset switches: 500,000 ∗3 (Switching frequency) ∗1 1,800 operations/h, duty ratio 40% ∗2 1,200 operations/h, duty ratio 40% ∗3 900 operations/h, duty ratio 40% ø23mm knockout on top and bottom G1/2 or PG16 (plastic fitting) Solid wire: ø1.6mm maximum Stranded wire: 2.0 mm2 maximum Two M4 screws Tightening torque 1.4 to 2.0 N·m IP65 (IEC 60529) File No. or Organization UL Listing File No. E68961 c-UL (File No. E68961) TÜV PS No. B98 08 13332 398 Attachments Name Nameplate ∗1 Cover Gasket ∗2 Connector Locking Nut Type No. NSA-0 HW9Z-W HW9Z-G Quantity 1 1 2 For details, see the instruction sheet attached to the control box. ∗1: The nameplate is supplied with the pushbutton and selector switch control boxes, not with the emergency stop control box. ∗2: The cover gasket is supplied with the emergency stop control box, not with the pushbutton and selector switch control boxes. Characteristics • Contact Ratings by Utilization Category Operational Current Operational Voltage AC-12 Control of resistive loads and solid state loads AC 50/60 Hz AC-15 Control of electromagnetic loads (> 72 VA) DC-12 Control of resistive loads and solid state loads DC 24V 48V 50V 110V 220V 440V DC-13 Control of electromagnets 10A — 10A 10A 6A 2A 10A — 7A 5A 3A 1A 8A 4A — 2.2A 1.1A — 4A 2A — 1.1A 0.6A — Note: The operational current represents the classification by making and breaking currents (IEC 60947-5-1). Minimum applicable load: 3V AC/DC, 5 mA (Applicable range may vary with operating conditions and load types.) Dimensions 70 A 58 Control Unit (Operator) Pushbutton Selector Switch Pushlock Turn Reset 58 58 Pushlock Key Reset Dimension A (mm) 13.0 21.0 32.0 32.0 (Key inserted: 49.4) HW1B-V4R Box Cover Mouting Screws Box Cover Box Base All dimensions in mm. 49 HW_Control Box Page 50 Tuesday, November 9, 2004 2:39 PM ø22 HW Series Control Boxes • Applicable Connector and Installation 1. To install a connector, break open the conduit port on the top and bottom of the control box. Before opening the conduit port, remove the attached two connector locking nuts from the control box base. Place the tip of a screwdriver on the conduit port and strike the screwdriver end. Make sure that the conduit port is free from burs and cracks, which may hamper waterproof characteristics. Mounting Hole Layout 42.4 58 Screwdriver 2-ø4.6 Applicable Terminal 7.9 max. Tightening torque: 1.0 to 1.3 N·m A maximum of two pieces can be connected to one terminal. 4 max. 5.5 min. Nameplate Type No. Thread Size G1/2 PG16 NSA-0 5 Material Aluminum The nameplate is supplied with the pushbutton and selector switch control boxes. When not using the nameplate, use the cover gasket (HW9Z-W). HW series nameplates (HWA∗) cannot be used. Operating Instructions • Panel Mounting To mount the control box on a panel, use two M4 screws, plane washers and spring washers to preventing loosening. Tighten the screws to a torque of 1.4 to 2.0 N·m. Determine the screw length in consideration of the panel thickness. 3 M4 Screw Hexagonal Nut Plain Washer Locking Nut for Installing Connector (supplied with control box) • Applicable Cables Applicable CVV Cable 1.25 mm2 2.0 mm2 Outside Diameter ø14.5 mm maximum ø14.5 mm maximum Spring Washer Panel Core Wires 8 maximum 8 maximum • Applicable Conduits Metal Conduit Outside Diameter IV Wire Quantity Control Box 4 3. Only when using a plastic connector, Insulation Class II (IEC 61140) is satisfied. 4. Install the box cover flat on the box base. When the box cover is installed diagonally, the box cover cannot be secured correctly, resulting in an operation error. Conduit Inside Diameter 50 Locking Nut Type No. HW9Z-G HW9Z-PG ø2 5. Locking Nut Color White Black 36 34 Color: Black, without legend Thickness: 1.2 mm (Remove the anti-rotation projection) 2. Use G1/2 or PG16 connectors which can mount on a panel of 4.0 mm thick minimum. To install the connector to the control box, use the attached connector locking nut and tighten the locking nut sufficiently. If the locking nut is tightened insufficiently, the waterproof characteristics are not ensured. 30 max. ø3.6 min. 1.25 mm2 2.0 mm2 ø10 mm ø8.3 mm minimum 2 to 3 2 to 3 Wire containment density: 32% to 48% Select a cable appropriate for the connector. ø12 mm ø10.6 mm minimum 4 to 6 3 to 4 HW_Back Page 1 Tuesday, February 22, 2005 11:17 AM Specifications and other descriptions in this catalog are subject to change without notice. 7-31, Nishi-Miyahara 1-Chome, Yodogawa-ku, Osaka 532-8550, Japan Tel: +81-6-6398-2571, Fax: +81-6-6392-9731 www.idec.com IDEC CORPORATION (USA) IDEC IZUMI ASIA PTE. LTD. 1175 Elko Drive, Sunnyvale, CA 94089-2209, USA Tel: +1-408-747-0550, Toll Free: (800) 262-IDEC, Fax: +1-408-744-9055 E-mail: opencontact@idec.com, www.idec.com No. 31, Tannery Lane #05-01, Dragon Land Building, Singapore 347788 Tel: +65-6746-1155, Fax: +65-6844-5995 E-mail: generalinfo@idecasia.com.sg IDEC CANADA LIMITED IDEC IZUMI (H.K.) CO., LTD. Unit 22-151, Brunel Road Mississauga, Ontario, L4Z 1X3, Canada Tel: +1-905-890-8561, Toll Free: (888) 317-4332, Fax: +1-905-890-8562 Unit 1505-07, DCH Commercial Centre No. 25, Westlands Road, Quarry Bay, Hong Kong Tel: +852-2803-8989, Fax: +852-2565-0171 E-mail: idec@idechk.com IDEC ELECTRONICS LIMITED Unit 2, Beechwood, Chineham Business Park, Basingstoke, Hampshire RG24 8WA, UK Tel: +44-1256-321000, Fax: +44-1256-327755 E-mail: idec@uk.idec.com IDEC ELEKTROTECHNIK GmbH Wendenstrasse 331, D-20537 Hamburg, Germany Tel: +49-40-25 30 54 10, Fax: +49-40-25 30 54 24 E-mail: service@idec.de, www.idec.de IDEC AUSTRALIA PTY. LTD. 2/3 Macro Court, Rowville, Victoria 3178, Australia Toll Free: 1-800-68-4332, Fax: +61-3-9763-3255 E-mail: sales@au.idec.com IDEC IZUMI (Shanghai) Co., Ltd. Room E, 15F, Majesty Building, No. 138 Pudong Avenue, Shanghai 200120, P.R.C. Tel: +86-21-5887-9181, Fax: +86-21-5887-8930 E-mail: idec@cn.idec.com IDEC TAIWAN CORPORATION 8F, No. 79, Hsin Tai Wu Road, Sec. 1, Hsi-Chih, Taipei County, Taiwan Tel: +886-2-2698-3929, Fax: +886-2-2698-3931 E-mail: service@idectwn.com.tw Cat. No. EP1056-0 NOVEMBER 2004 5DNP PRINTED IN JAPAN
HW1B-M4F10-R 价格&库存
很抱歉,暂时无法提供与“HW1B-M4F10-R”相匹配的价格&库存,您可以联系我们找货
