HG2J-7UT22TF-B
HG2J-7UT22TF-B
    IDEC(日本和泉)
    7 TFT COLOR LCD, PROJECTED CAPA
HG2J-7UT22TF-B 数据手册
7” HMI HG2J Series Sleek. Stylish. Smart. PRODUCT DESCRIPTION Stylish smart capacitance touchscreens with an input voltage of 12-24V DC make the HG2J HMI a leading choice for applications across a variety of industries, including industrial, solar, and vehicle applications. Offered in a popular size form factor, HG2J uses Projected-Capacitive (PCAP) technology to provide a slimmer and sleeker appearance, small installation footprint, improved performance, and longer life. GENERAL SPECIFICATIONS An industry-leading three year warranty and exceptionally wide operating temperature range, as well as IP66/67F, Type 4X, 12, 13, and Class I Div 2 approval ratings, assure reliable operation even in the toughest environments. Rated Power Voltage 12 to 24V DC Power Voltage Range 10.2 to 28.8V DC Power Consumption 13W maximum 5W maximum when not using USB1 or USB2 3W maximum when Backlight OFF KEY FEATURES Allowable Momentary Power Interruption 10ms max. (power supply voltage 20.4 to 28.8V DC) 1ms max. (power supply voltage 10.2 to 20.4V DC) • 50,000 Hours Backlight Life Inrush Current 30A maximum • 500 cd/m² Brightness Dielectric Strength 500V AC, 10 mA, 1 minute between power and FG terminals • -20 to +60˚C Extreme Operating Temp Operating Temperature -20 to +60°C (no freezing) Operating Humidity 10 to 90%RH (no condensation) • Remote Access, FTP, Email, Mobile App and Custom Web Page Storage Temperature -20 to +70°C (no freezing) Storage Humidity 10 to 90%RH (no condensation) Pollution Degree 2 Vibration Resistance 5 to 8.4 Hz single amplitude 3.5 mm, 8.4 to 150 Hz acceleration, 9.8M/s2 on each of three mutually perpendicular axes (IEC61131-2) Shock Resistance 147m/s2, 11ms, 5 shocks on each of three mutually perpendicular axes ((IEC61131-2) Noise Immunity Fast transient/burst test Power terminals: 2 kV Communication line: 1kV (IEC/EN61131-2) Electrostatic Discharge Contact: 6 kV Air: 8kV (IEC/EN61131-2) Corrosion Immunity Free from corrosive gases Mounting Panel mount (panel thickness: 1.0 to 5.0 mm) Degree of Protection When panel thickness is less than 1 to 5mm: IP66F (IEC60529) When panel thickness is less than 1.6 to 5mm: IP66F, IP67F (IEC60529) TYPE 4X, TYPE 13 Dimensions 186 (W) x 128 (H) mm x 30.4 (D) mm Weight (approx.) 500g • 800 x 480 High Resolution • Support 4 protocols simultaneously ClassI Div2 Hazardous Location Do not use the HG2J in an environment subject to strong ultraviolet rays, otherwise the LCD quality will deteriorate. 1 DISPLAY SPECIFICATIONS OPERATION SPECIFICATIONS Display TFT color LCD (TN type) Switching Element PCAP (Projected capacitance) method Color / Shade 65,536 colors (16-bit color) Multiple Operations Up to 2 points Effective Display Area 154.08 (W) x 85.92 (H) mm Acknowledgement Sound Electronic buzzer or audio output Display Resolution 800 (W) x 480 (H) pixels DPI 0.1926 (W) x 0.179 (H) mm View angle Left/right/top: 80°, bottom 60° Backlight White LED Screen Types Base screen, popup screen, system screen Backlight Life 50,000 hours minimum (* 1) No. of Screens Brightness 500 cd/m2 (Typ.) (*2) Base screen: 3,000 max. Popup screen: 3,015 max. Brightness Adjustment 48 levels User Memory Approx. 24MB Backlight Replacement Not replaceable by user (must be replaced by IDEC) Parts Font Shift_JIS (Japanese) ISO8859-1 (European) GB2312 (Simplified Chinese) BIG5 (Traditional Chinese) KSC5601 (Korean) Bit Button, Word Button, Goto Screen, Print Button, Key Button, Multi Button, Keypad, Numerical Input, Character Input, Pilot Lamp, Multi-State Lamp, Picture Display, Message Display, Message Switching Display, Alarm List Display, Alarm Log Display, Data Log Display, Numerical Display, Bar Graph, Trend Chart, Pie Chart, Meter, Calendar, Bit Write Command, Word Write Command, Goto Screen Command, Print Command, Timer, Screen Script Command, Multi Command Character Size 8 to 512 Character Attribute Blink (1 or 0.5 sec period), reverse Calendar Year, Month, Day, Hour, Min., Sec., Day of Week±90 sec per month (at 25°C) Graphics Straight line, polyline, rectangle, circle, arc, circle/ellipse, equilateral polygons (3, 4, 5, 6, 8) picture Power Failure Backup Data Calendar, log data, keep relay, internal register Window Display 3 popup screens + 1 system screen Backup Time 20 days (Typ.) (*3) FUNCTION SPECIFICATIONS ANSI1250 (Central European language) ANSI1251 (Baltic) ANSI1251 (Cyrillic) ASCII (7-seg) *1) T he backlight life is not guaranteed and refers to the time until the brightness reduces by half after use at 25°C. The actual life depends on operating environments and conditions. *2) Brightness of the LCD alone at an ambient temperature of 25°C. *3) If the power is cut off for more than 20 days, the error message "Backup data lost" will be displayed at the next start-up and the clock data will be initialized to "00:00:00 January 1, 2000". TOUCHSCREEN PART NUMBER ACCESSORIES Part Number Display Type Bezel Color Part Number Description Quantity HG2J-7UT22TF-B 7" TFT Color LCD, Projected Capacitive Touchscreen Black SW1A-W1C Automation Organizer Software 1 Mounting Clip 4 Serial Interface, Removable Push-in Connector 1 Protective Sheets 5 HG9Z-4K2PN04 HG9Z-XT09P HG9Z-2D7PN05 DIMENSIONS (mm) 176.6 +1 0 Panel Thickness: 1.0 to 5.0mm 6.0 24.4 All dimensions in mm. 118.6 +1 0 176.2 118.2 56 15 128.0 186.0 PANEL CUT-OUT Dimensions in blue show the mounting dimensions of the cable. Dimensions in the figure may vary depending on the type of cable connected. The information listed here should be used as a guide for reference when designing. Install the operator interface into a panel cut-out by tightening the six mounting clips (supplied with the operator interface) to a torque of 0.5 to 0.6 N·m. Do not tighten with excessive force, otherwise the operator interface may become distorted. Also, waterproof characteristics may be lost. IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • https://us.idec.com ©2022 IDEC Corporation. All Rights Reserved. HG9Y-DS200-A-0 03/08 PDF Only 2
HG2J-7UT22TF-B 价格&库存
很抱歉,暂时无法提供与“HG2J-7UT22TF-B”相匹配的价格&库存,您可以联系我们找货
HG2J-7UT22TF-B
  • 1+5357.04440
库存:2
