ABS210
ABS210
    FUXINSEMI(富芯森美)
    ABS
    耐压:1000V 电流:2A
ABS210 数据手册
ABS205 THRU ABS210 2.0A Miniature Glass Passivated Single-Phase Surface Mount Bridge Rectifiers-50-1000V Package outline Features • Surge overload ratings to 50 amperes peak. • Save space on printed circuit board. • Ideal for automated replacement. • Reliable low cost construction utilizing molded plastic ABS 0.268(6.8) 0.236(6.0) technology results in inexpensive product. • Glass passivated chip junctions. • Lead-free parts meet RoHS requirments.. • Suffix "-H" indicates Halogen free part. Mechanical data • Epoxy:UL94-V0 rated flame retardant • Case : Molded plastic, ABS • Terminals : Solder plated, solderable per MIL-STD-750, Method 2026 • Polarity : marked on body • Mounting Position : Any Maximum ratings and Electrical Characteristics (AT CHARACTERISTICS SYMBOL ABS205 T A=25 oC unless otherwise noted) ABS21 ABS22 ABS24 ABS26 ABS28 ABS210 UNIT V Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current @TJ =25℃ I(AV) 2.0 A IFSM 50 A VF 1.1 V Peak Forward Surge Current 8.3ms Single Half Sine-Wave Super Imposed on Rated Load (JEDEC Method) Maximum Forward Voltage at 2.0A DC Maximum DC Reverse Current @TJ=25℃ at Rated DC Bolcking Voltage @TJ=125℃ 10 IR 500 μA I2 t Rating for Fusing(t
ABS210 价格&库存
很抱歉,暂时无法提供与“ABS210”相匹配的价格&库存,您可以联系我们找货
