DB107S
DB107S
    FUXINSEMI(富芯森美)
    DBS
    耐压:1000V 电流:1A
DB107S 数据手册
DB101S THRU DB107S 1.0A Miniature Glass Passivated Single-Phase Surface Mount Bridge Rectifiers-50-1000V Package outline Features Rating to 1000V PRV Ideal for printed circuit board DBS Low forward voltage drop,high current capability Reliable low cost construction utilizing molded plastic technique results in inexpensive product .335(8.5) .295(7.5) + The plastic material has UL flammability classification 94V-0 .255(6.5) .245(6.2) ~ .013(.33) ~ .003(.08) .406(10.3) .047(1.20) .037(0.95) Mechanical data .391(10.0) .060(1.5) .040(1.0) .343(8.7) Case: DBS molded plastic body Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: As marked Mounting Position: Any .319(8.1) .124(3.15) .009(2.25) .205(5.2) .197(5.0) Dimensions in inches and (millimeters) Maximum ratings and Electrical Characteristics (AT CHARACTERISTICS T A=25 oC unless otherwise noted) SYMBOL DB101S DB102S DB103S DB104S DB105S DB106S DB107S UNIT Maximum Recurrent Peak Reverse Voltage VRRM 50 Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current @TA=40℃ 100 200 400 600 800 1000 V I(AV) 1.0 A IFSM 30 A VF 1.1 V Peak Forward Surge Current 8.3ms Single Half Sine-Wave Super Imposed on Rated Load (JEDEC Method) Maximum Forward Voltage at 1.0A DC Maximum DC Reverse Current @TJ=25℃ at Rated DC Bolcking Voltage @TJ=125℃ I2 t Rating for Fusing(t
DB107S 价格&库存
很抱歉,暂时无法提供与“DB107S”相匹配的价格&库存,您可以联系我们找货
DB107S
  • 1+0.25960
  • 50+0.15290
  • 1500+0.13750
库存:3000
