79L05
Three-terminal positive voltage regulator
FEATURES
Maximum output current
IOM: 0.1A
Output voltage
Vo: -5 V
Continuous total dissipation
PD:0.6 W (Ta= 25 ℃ )
SOT-89
3
2
1. GND
1
2. IN
3.OUT
ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Value
Symbol
Parameter
Unit
Vi
-30
V
Thermal Resistance from Junction to Ambient
RθJA
208.3
Operating Junction Temperature Range
TOPR
-40~+125
℃/W
Storage Temperature Range
TSTG
-65~+150
Input Voltage
ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JINCTION TEMPERATURE
(VI =-10V,Io=40mA,Ci=0.33μ F,Co=0.1μF, unless otherwise specified )
Parameter
Symbol
Test conditions
25℃
Output Voltage
Vo
-7V≤Vl≤-20V, Io=1mA~40mA
Io=1mA~70mA
Load Regulation
ΔVo
Line Regulation
ΔVo
Quiescent Current
Iq
0-125℃
MLQ
T\S
Max
Unit
-4.8
-5.0
-5.2
V
-4.75
-5.0
-5.25
V
-4.75
-5.0
-5.25
V
Io=1mA~100mA
25℃
mV
Io=1mA~40mA
25℃
10
30
mV
-7V≤Vl≤-20V
25℃
15
150
mV
-8V≤Vl≤-20V
25℃
12
100
mV
6
mA
25℃
ΔIq
-8V≤Vl≤-20V
0-125℃
1.5
mA
ΔIq
1mA≤Vl≤40mA
0-125℃
0.1
mA
Output Noise Voltage
VN
10Hz≤f≤100KHz
25℃
Ripple Rejection
RR
-8V≤Vl≤-18V,f=120Hz
0-125℃
Dropout Voltage
Vd
Quiescent Current Change
25℃
41
40
μV/Vo
49
dB
1.7
V
* Pulse test.
TYPICAL APPLICATION
-Vi
2
3
-Vo
79 L05
Ci
1
Co
0.1μF
0.33μF
Note : Bypass capacitors are recommended for optimum stability and transient response and should be located as close as
Possible to the regulators.
www.fuxinsemi.com
Page 1
Ver2.1
79L05
Typical Characteristics
Output Characteristics
Dropout Characteristics
-7
-5.5
IO=0mA
(V)
-5.0
VO
-5
-4
OUTPUT VOLTAGE
(V)
OUTPUT VOLTAGE VO
TJ=25℃
TJ=25℃
-6
-3
-2
-1
IO=0mA
-4.5
-4.0
IO=-40mA,-70mA,-100mA
-3.5
-3.0
-2.5
-2.0
-10
-15
INPUT VOLTAGE
-20
VIN
-25
-1.5
-4.0
-30
-4.5
(V)
-5.0
-5.5
-6.0
INPUT VOLTAGE
VIN
-6.5
Current Cut-off Grid Voltage
Quiescent Current vs Input Voltage
-3.0
-7
IO=0mA
TJ=25℃
-6
(V)
(mA)
VIN=-10V
TJ=25℃
-2.5
-2.0
Pulsed
-5
OUTPUT VOLTAGE
QUIESCENT CURRENT
VO
IQ
-7.0
(V)
-1.5
-1.0
-0.5
0.0
-4
-3
-2
-1
-10
-15
INPUT VOLTAGE
-20
VIN
-25
(V)
100
150
OUTPUT CURRENT
Output Voltage vs Junction Temperature
IO
200
250
(mA)
Power Derating Curve
800
-8
Vin=-10V
IO=5mA
-6
(mW)
600
-5
PD
700
500
POWER DISSIPATION
OUTPUT VOLTAGE VO
(V)
-7
-4
-3
-2
-1
400
300
200
100
50
75
JUNCTION TEMPERATURE
www.fuxinsemi.com
100
TJ
125
150
50
75
Page 2
100
TJ
125
150
Ver2.1
79L05
SOT-89 Package Outline Dimensions
A
SOT-89
C
H
B
K
L
E
D
J
F
Dim
Min
Max
A
4.30
4.70
B
2.20
2.70
C
1.30
1.70
D
0.30
0.60
E
1.40
1.60
F
0.30
0.60
H
1.40
1.80
J
0.30
0.60
L
0.90
1.10
K
3.75
4.35
All Dimensions in mm
45°
1.50
0.90
45°
2.20
0.90
SOT-89 Suggested Pad Layout
1.00
1.00
1.50
www.fuxinsemi.com
1.50
Unit:mm
Page 3
Ver2.1
很抱歉,暂时无法提供与“79L05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.46938
- 100+0.38939
- 300+0.34944
- 1000+0.28111
- 5000+0.25710
- 10000+0.24505
- 国内价格
- 1+0.44110
- 50+0.25960
- 1000+0.23320
