FR1AD3 THRU FR1MD3
1.0A Surface Mount Fast
Recovery Rectifiers-50-1000V
Package outline
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Fast switching for high efficiency
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
Compliant to Halogen-free
0.071(1.80)
0.063(1.40)
Case: JEDEC SOD-323 molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
0.108(2.75)
0.096(2.45)
Dimensions in inches and (millimeters)
Maximum ratings and Electrical Characteristics (AT
SYMBOLS
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
0.003(0.08)
0.008(0.20)
0.039(1.00)
0.031(0.80)
Mechanical data
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length at TA=75 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
0.016(0.40)
0.010(0.25)
0.055(1.40)
0.047(1.20)
SOD-323
VRRM
VRMS
VDC
FR
FR
1AD3 1BD3
50
35
50
T A=25 oC unless otherwise noted)
FR
1DD3
100
70
100
200
140
200
FR
FR
1GD3 1JD3
FR
1KD3
FR
1MD3
400
280
400
800
560
800
1000
700
1000
600
420
600
UNITS
V
V
V
I(AV)
1.0
A
IFSM
15.0
A
VF
1.3
V
IR
5.0
50.0
µA
trr
150
CJ
250
5.0
80.0
-55 to +150
RθJA
TJ,TSTG
500
ns
pF
C/W
C
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
www.fuxinsemi.com
Page 1
Ver2.1
FR1AD3 THRU FR1MD3
Rating and characteristic curves
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
10
3.0
1.0
1.2
1.0
0.8
Single Phase
0.6
Half Wave 60Hz
Resistive Or Inductive Load
0.4
0.375"(9.5mm) Lead Length
0.2
TJ=25 C
40
60
80
100
120
140
160
180
200
AMBIENT TEMPERATURE,( C)
Pulse Width 300us
1% Duty Cycle
0.1
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
.01
.6
.8
1.0
1.2
1.4
1.6
1.8
2.0
FORWARD VOLTAGE,(V)
FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERISTICS
50W
NONINDUCTIVE
10W
NONINDUCTIVE
D.U.T.
25Vdc
(approx.)
PEAK FORWAARD SURGE CURRENT,(A)
INSTANTANEOUS FORWARD CURRENT,(A)
50
25
8.3ms Single Half
TJ=25 C
10
JEDEC method
5
5
PULSE
GENERATOR
(NOTE 2)
Sine Wave
10
50
100
NUMBER OF CYCLES AT 60Hz
1W
NONINDUCTIVE
OSCILLISCOPE
(NOTE 1)
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
trr
+0.5A
-0.25A
-1.0A
1cm
SET TIME BASE FOR
50 / 10ns / cm
www.fuxinsemi.com
Page 2
Ver2.1
FR1AD3 THRU FR1MD3
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
1
Symbol
2
1
2
Marking
Type number
Marking code
FR1AD3
FR1BD3
FR1DD3
FR1GD3
FR1JD3
FR1KD3
FR1MD3
1R
2R
3R
4R
5R
6R
7R
Suggested solder pad layout
C
A
B
PACKAGE
A
B
C
SOD-323
0.047 (1.20)
0.047 (1.20)
0.055 (1.40)
Reel packing
PACKAGE
SOD-323
REEL SIZE
7"
www.fuxinsemi.com
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
3,000
4.0
30,000
183*183*123
178
Page 3
CARTON
SIZE
(m/m)
382*262*387
CARTON
(pcs)
240,000
Ver2.1
FR1AD3 THRU FR1MD3
Suggested thermal profiles for soldering processes
1.Storage environment: Temperature=5 oC ~40 oC Humidity=55%±25%
2.Reflow soldering of surface-mount devices
Critical Zone
TL to TP
Tp
TP
Ramp-up
TL
TL
Tsmax
Temperature
Tsmin
tS
Preheat
Ramp-down
25
o
t25 C to Peak
Time
3.Reflow soldering
Profile Feature
Soldering Condition
Average ramp-up rate(T L to T P )
o
很抱歉,暂时无法提供与“FR1MD3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.22227
- 200+0.17853
- 600+0.15423
- 3000+0.12723
- 9000+0.11459
- 21000+0.10779
- 国内价格
- 1+0.52360
- 200+0.17380
- 1500+0.10912
- 3000+0.08668
