BS-BNC-9
BS-BNC-9
    NEUTRIK(优曲克)
    NEUTRIK - BS-BNC-9 - Connector Accessory, Boot, Push-Pull BNC 75O Connectors, Plastic
BS-BNC-9 数据手册
NEUTRIK BNC CONNECTORS: PUSH-PULL CABLE HDTV A range of high quality BNC connectors, giving excellent mechanical, electrical and assembly performance. Precision machined components give accurate impedance and excellent return-loss, even at high frequencies above 1GHz, suitable for HDTV, SDI (serial digital) and analogue video. An extremely ergonomic 75 ohm cable connector with push-pull locking operation, for high density or rapid assembly installations such as patchbays or location equipment. The connector locks with a straight push on the shell and releases with a straight pull. Assembly is straightforward, as the centre pin may be soldered, or crimped (with any of the Neutrik BNC crimp jaws, except type Z - see “Neutrik BNC Connectors, Tools”). The cable is then held in place and the screen terminated with a cable retention clamp based on the Neutrik chuck principle (not crimped), popular on audio connectors. Connector screen contacts are optimised for certain cable diameters. Connectors in sizes for popular cables are held in stock; versions for other cables are available to special order, please contact Technical Support. Colour-coded cable boots are available to identify cables and connectors. Required accessories: A spanner incorporating a cable preparation guide is required to assemble push-pull connectors- see “Neutrik BNC Connectors, Tools”. Connector Canford cables NBNC75P-FE7 SDV, SDM NBNC75P-LS9 NBNC75P-NS7 VCS (PSF1/3) NBNC75P-VS11 SDV-L, SDV-F 48-581 48-582 48-583 48-584 NEUTRIK NEUTRIK NEUTRIK NEUTRIK BNC BNC BNC BNC 48-590 48-591 48-592 48-593 48-594 48-595 48-596 48-597 48-598 48-599 NEUTRIK NEUTRIK NEUTRIK NEUTRIK NEUTRIK NEUTRIK NEUTRIK NEUTRIK NEUTRIK NEUTRIK BNC BNC BNC BNC BNC BNC BNC BNC BNC BNC Canare Cables Other Cables crimp jaw Belden 1855A, 1855ENH L-4CFB Belden 1505A, 1505F LV-61S RG59B/U L-5CFB Belden 1694A Centre-pin Any Neutrik Any Neutrik Any Neutrik Any Neutrik NBNC75PFE7 Male cable, push-pull, group X NBNC75PLS9 Male cable, push-pull, groups Q1 & Q2, Canare L-4CFB NBNC75PNS7 Male cable, push-pull, groups B, Q and Q1 NBNC75PVS11 Male cable, push-pull, group Y & Canare L-5CFB BS-BNC-0 BS-BNC-1 BS-BNC-2 BS-BNC-3 BS-BNC-4 BS-BNC-5 BS-BNC-6 BS-BNC-7 BS-BNC-8 BS-BNC-9 UK Sales - tel 0191 418 1122 fax 0191 418 1123 sales@canford.co.uk PUSH-PULL PUSH-PULL PUSH-PULL PUSH-PULL PUSH-PULL PUSH-PULL PUSH-PULL PUSH-PULL PUSH-PULL PUSH-PULL CABLE CABLE CABLE CABLE CABLE CABLE CABLE CABLE CABLE CABLE BOOT BOOT BOOT BOOT BOOT BOOT BOOT BOOT BOOT BOOT Black Brown Red Orange Yellow Green Blue Violet Grey White International Sales - tel +44 191 418 1133 fax +44 191 418 1134 international@canford.co.uk Tech Support - tel 0191 418 1144 fax 0191 418 1145 techsupport@canford.co.uk
BS-BNC-9 价格&库存
很抱歉,暂时无法提供与“BS-BNC-9”相匹配的价格&库存,您可以联系我们找货
