BXX-4-YELLOW
BXX-4-YELLOW
    NEUTRIK(优曲克)
    NEUTRIK - BXX-4-YELLOW - Connector Accessory, Bushing, XX Series XLR Cable Connector, POM (Polyoxyme...
BXX-4-YELLOW 数据手册
A c c e s s o r i e s C o l o u r C o d e d Part No. Description A c c e s s o r i e s Black Brown Red Orange Yellow Green Blue Violet Grey White 0 1 2 3 4 5 6 7 8 9 XLR Cable Connectors BSX-* Coloured bushing for X Series BXX-* Coloured bushing for XX Series XCR-* Coloured coding ring for X Series XXR-* Coloured coding ring for XX Series XLR Chassis Connectors ACRF-* ACRM-* DSS-* Coloured ring for female 4 + 5 pole A Series and 3 pole BA Series Coloured ring for male 4 + 5 pole A Series and 3 pole BA Series Lettering plate for D Series A c c e s s o r i e s XLR Cable Connectors XXCR Translucent coding ring for XX Series BXX-CR Bushing with translucent coding ring Example for XX Series XCCR Coding ring for X Series digital signals XLR Chassis Connectors DBA Dummy-plate for D Series panel cut outs SC* Rubber sealing cap for female and male XLR receptacles SCF SCM SCD* Rubber sealing cover for female and male D Series SCDF SCDM SCDR SCDX SFAV Rear end protection cover for D-size chassis connectors Example Hinged cover seals D-size chassis connectors, IP54 rated Example Rubber frame for A / B Series to mount between front plate and rear vertical print Example ® A-Screw-1-8 Plastite screw 2.9 x 8 B-Screw-1-8 TAPTITE® screw 2.5 x 8 - Q u a l i A Screw t y D e s i g B Screw n www.neutrik.com 21
BXX-4-YELLOW 价格&库存
很抱歉,暂时无法提供与“BXX-4-YELLOW”相匹配的价格&库存,您可以联系我们找货
BXX-4-YELLOW
    • 100+9.43292100+1.22040
    • 1000+8.384821000+1.08480
    BXX-4-YELLOW
      BXX-4-YELLOW
      • 100+11.69907100+1.51359
      • 200+11.14005200+1.44127
      • 300+10.82587300+1.40062
      • 500+10.44252500+1.35102
      • 700+10.19732700+1.31930
      • 1000+9.943981000+1.28652
      BXX-4-YELLOW
        库存:195
