AS12024MB25A100
AS12024MB25A100
    ADDA(協禧電機)
AS12024MB25A100 数据手册
AS12025 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) (CFM) 0.66 7.92 2900 3.560 125.817 Rated System Voltage Current Type (VDC) (mm) 120x120x25 Rated Bearing *Noise Level Weight (InAq) (mmAq) (dB/A) (g) 0.277 7.035 51.0 AS12012LB25AB00 ◎ 12 A S12012MB25AB00 ◎ 12 0.84 10.08 3400 4.266 150.766 0.387 9.829 54.7 A S12012HB25AB00 ◎ 12 1.06 12.72 3700 4.570 161.505 0.443 11.252 57.8 A S12012UB25AB00 ◎ 12 1.42 17.04 4000 4.977 175.895 0.523 13.284 58.6 A S12024LB25AB00 ◎ 24 0.28 6.72 2900 3.560 125.817 0.277 7.035 51.0 A S12024MB25AB00 ◎ 24 0.43 10.32 3400 4.266 150.766 0.387 9.829 54.7 A S12024HB25AB00 ◎ 24 0.55 13.20 3700 4.570 161.505 0.443 11.252 57.8 A S12024UB25AB00 ◎ 24 0.71 17.04 4000 4.977 175.895 0.523 13.284 58.6 A S12048LB25AB00 ◎ 48 0.17 8.16 2900 3.560 125.817 0.277 7.035 51.0 A S12048MB25AB00 ◎ 48 0.23 11.04 3400 4.266 150.766 0.387 9.829 54.7 A S12048HB25AB00 ◎ 48 0.30 14.40 3700 4.570 161.505 0.443 11.252 57.8 A S12048UB25AB00 ◎ 48 0.37 17.76 4000 4.977 175.895 0.523 13.284 58.6 220.0 Specif ic atio ns subje ct to change wit hout notic e. Fan Performance Curve FLOWRATE(CMM) 1.132 2.264 3.396 4.528 STATIC PRESSURE(mmAq) 風扇型號: 5.660 0.590 M L H U 12.0 0.472 9.0 0.354 6.0 0.236 3.0 0.118 0.0 STATIC PRESSURE(InAq) 0.000 15.0 *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0 40 80 120 160 200 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AS12024MB25A100 价格&库存
很抱歉,暂时无法提供与“AS12024MB25A100”相匹配的价格&库存,您可以联系我们找货
AS12024MB25A100
    库存:94
