AD0312HB-G50
AD0312HB-G50
    ADDA(協禧電機)
AD0312HB-G50 数据手册
AD0312HB-G50 SA-0120140912005 2019.07.09 C 研發處 2019.07.09 發行章 (T) DATA-SHEET Engineering Printed On: 19/07/09 BRUSHLESS AXIAL COOLING FANS Ref: (RoHS) Customer : Adda Model No : AD0312HB-G50 Samples attached : Safety Approval : UL,CUL,TUV,CE P.S: (T) Piece(s), TUV:EN 60950-1:2006+A11+A1+A12+A2 UL:UL507 CE:EN 61000-6-1:2007 EN 61000-6-3:2007+A1 Specifications ITEM SPECIFICATION / CONDITION DIMENSIONS : 30x30x10 BEARING TYPE : TWO BALL RATED VOLTAGE : 12.0 VDC OPERATING VOLTAGE RANGE : 10.8 VDC - : 9.0 VDC , NORMAL REAL CURRENT : 0.10 Amp REAL POWER : 1.20 Watt RATED CURRENT : 0.13 Amp RATED POWER : 1.56 Watt RATED SPEED : 10500 RPM  START-UP VOLTAGE mm 13.2 VDC + 10 %MAX ± 20 % (IN FREE AIR AT RATED VOLTAGE) AIR FLOW : 4.000 CFM (min.: 3.200 CFM) AIR FLOW : 0.113 CMM (min.: 0.090 CMM) (IN FREE AIR AT RATED VOLTAGE) STATIC AIR PRESSURE : 0.200 Inch H2O (min.: 0.128 Inch H2O) STATIC AIR PRESSURE : 5.080 mm H2O (min.: 3.251 mm H2O) (IN FREE AIR AT RATED VOLTAGE) NOISE LEVEL : 35.1 dB (A) (max.: 39.1 MOTOR PROTECTION : BY IC POLARITY PROTECTION : NO CONNECTION LEAD TYPE : WIRE, AWG# 28 LIFE EXPECTANCY : 70000 Hours at NET WEIGHT : 8 Gram. PACKING : 560 pcs. Per Export Carton. 40℃ dB(A)) / 65% RH 研發處 2019.07.09 Unless otherwise stated, the relative humidity is 65%, and the temperature is 25oC for the standard testing. Should you have any doubt, please refer to the environmental conditions specified in the acknowledgement document. ADDA CORPORATION Model No.: AD0312HB-G50 P.S: 發行章 (T) Page 1/5 SPECIFICATION 1.0 SCOPE 1.1 If the information or other related document is inconsistent with this acknowledgement document, please refer to the acknowledge document. 1.2 This documentation defines the mechanical & electrical characteristics of DC brushless fans. 1.3 The specification of this product is described in details in the acknowledgement document. No guarantee is given to our product under the use of over specifications. 1.4 For any change or amendment to the specifications, such change will be noticed in writing beforehand. 1.5 If the product is used on the MIS system, please specify the specification in the purchase order. 2.0 MATERIAL 2.1 Frame : UL94V-0 Glass Filled polyester (P.B.T) 2.2 Fan Blade : UL94V-0 Glass Filled polyester (P.B.T) 2.3 RoHS : (V ) YES HF : ( ) YES 3.0 DIMENSIONS & CONSTRUCTION All dimensions, Direction of rotation and air flow were specified as per drawing attached. 4.0 CHARACTERISTICS & DEFINITION 4.1 All rated characteristics were specified as per data sheet enclosed. 4.2 Rated Current:Rated Current shall be measured after 3 minutes of continuous rotation at rated voltage. 4.3 Rated Speed :Rated Speed shall be measured after 3 minutes. of continuous rotation at rated voltage. 4.4 Start Voltage :The voltage which is able to start the fan to operate by suddenly switching ’ON ’. 4.5 Input Power :Input Power shall be measured after 3 minutes of continuous rotation at rated voltage. 4.6 Locked Rotor Current:Locked current shall be measured within one minute of rotor locked, after 3 minutes of continuous rotation at rated voltage in clean air. 4.7 Air Flow & Static Pressure:The air flow data and static pressures should be determined in accordance with AMCA-210 standard in a doublechamber testing with intake – side measurement. 4.8 Noise Level :The measurement of noise level is carried out with reference to ISO7779 in a semi-anechoic chamber with the microphone positioned 1 meter from the fan intake. Testing fan shall be hung in the free air. NOISE LEVEL MEASUREMENT Mic. Fan Direction of air flow >>>>>>>> 研發處 2019.07.09 發行章 ADDA CORPORATION Model No.: AD0312HB-G50 P.S:(T) Page 2/5 SPECIFICATION 5.0 MECHANICAL INSPECTION 5.1 Rotation Direction Counterclockwise when look into impeller side. 5.2 Protection All fans have integrated protection against locked rotor condition so that there will be no damage to winding or any electronic component. Restarting is automatic as soon as any constraint to rotation has been released. As fan placed at dead angle position, and the switch was changed from off to on. Restarting was automatic normal as soon as and proved that this fan is good fan. 5.3 Locked Rotor Protection No damage shall be found after 72 hours continuously at condition of rotation locked. Restarting is automatic as soon as constraint to running has been released. 5.4 Avoid the damage, check the correct voltage and proper polarity before connecting with power. 5.5 Free Drop Shock In minimum package condition, the fan should withstand drops on any three faces from a height of 30cm onto a wood board of 10mm thick. 5.6 Please do not stick a grease and/or an oil to the fan housing or blade which may have a harmful influence by a chemical reaction at high humidity. 5.7 If the fan is reinstalled, please pay special attention to the noise due to the vibration (or resonance). 5.8 During the testing of the fan, please make sure the finger guard is used for safety. 6.0 ELECTRICAL INSPECTION 6.1 Insulation Resistance Not less than 10M ohm between housing and positive end of lead wire (red) at 500V DC. 6.2 Dielectric Strength No damage should be found at 500 VAC for 60 seconds, measured with 1mA trip current between housing and positive end of lead wire. 6.3 Life Expectancy The continous duty life at given temperature after which, 90% of testing units shall still be running. 6.4 While the fan is running, do not intentionally lock the fan for a long time since the overheating of the motor produced by the long-time locking will damage the fan. 7.0 ENVIRONMENTAL 7.1 Improper use such as disassembling the fan, being covered with dust, or dipping the fan in water that results in defects is not covered in the warranty. Do not use the fan in the environment with corrosive air or liquid. 7.2 Operating Temperature / Humidity -10℃ to +70℃ at humidity 65%+/-20% RH. 7.3 Storage Temperature All function shall be normal after 500 hours storage at -40℃ to +70 ℃ with a 24 hour recovery period at room temperature. 7.4 Humidity After 96 hours, 95% RH, 40+/-2℃ per MIL-STD-202F, method 103B humidity test, the measured data on insulation resistance and dielectric strength shall meet the specificaiton. 7.5 Do not place or store the fan in the environment with high/low temperature/humidity. If the fan is stored for more than 6 months, functional test is highly recommended before using. 研發處 2019.07.09 發行章 ADDA CORPORATION Model No.: AD0312HB-G50 P.S:(T) Page 3/5 SPECIFICATION 8.0 REMARKS 8.1 Material and construction are subject to change without advance notice. The changes should be within specification. 8.2 All fans shall meet the quality inspection under sampling plan MIL-STD-105E as follow: Critical Major Minor 9.0 0.25% 1.00% 2.50% OUTLINE STYLING & DIMENSIONS 研發處 2019.07.09 LEAD WIRES : UL 1571, AWG28, L = 140 ± 10 mm Red = positive ; Black = negative. 發行章 10.0 Notes: 10.1 Please do not touch and push Fan Blade with fingers or others, fan blade and ball bearings may be damaged and it causes noise defect. 10.2 Do not carry the fan by its lead wires. 10.3 lf the fan does not have the polarity protection function, the connection of the colored wires should be red + red, and black + black, or else the fan will be damaged in no time. 10.4 For the models without reverse connection of polarity protection, please do not connect the lead wire in reverse 10.5 Please don't install this fan in series with 2x voltage inputs. For example, if a single fan rated at 12V, then don't install two of them in series with 24V input. 10.6.Every specific fan is designed for its certain application (project). Therefore, if you want to use this fan in other application (project), please inform ADDA first so that we can confirm whether there is any issue which might be incurred from the reason of this different application (project) or not. 10.7 The"Life Expectancy" of this fan has not been evaluated for use in combination with any end application. Therefore,the Life Expectancy in the Test Reports(L10 and MTTF Report) that relate to this fan is for reference only and shall not construe any kind of warranty of ADDA to the life of any specific fan,either expressed or implied. 10.8 The period of product warranty,unless otherwise agreed by ADDA in written,shall be 12 months starting from the date of production. 10.9 In Lead Wire, there is a possibility to come off from frame. 10.10 In order to avoid abnormal bumping or interference caused by deformed impeller when fan is fastened, suggested distance of at least 0.5mm is strongly reserved in front of the frame (the sight from the impeller face). 10.11 Hot swapping or Hot plugging is not allowed to cause damage to fans.Notice in advance is strongly requested if design for Hot swapping or Hot plugging is needed. ADDA CORPORATION Model No.: AD0312HB-G50 P.S:(T) Page 4/5 AD0312HB-G50(T) 研發處 2019.07.09 發行章 Page 5/5
AD0312HB-G50 价格&库存
很抱歉,暂时无法提供与“AD0312HB-G50”相匹配的价格&库存,您可以联系我们找货
